iMX6DQ MAX9286 MIPI CSI2 720P camera surround view solution for Linux BSP
For iMX6DQ, there are two IPUs, so they can support up to 4 cameras at the same time. But the default BSP can only support up to two cameras at the same time.
The attached patch can make the BSP support up to 4 cameras based on 3.10.53 GA 1.1.0 BSP.
The 4 cameras can be:
- 1xCSI, 3xMIPI
- 2xCSI, 2xMIPI
- 4xMIPI
For 4xMIPI case, the four cameras should be combined on the single MIPI CSI2 interface, and each camera data should be transfered on a mipi virtual channel.
In this patch, we given the example driver for Maxim MAX9286, it was verified working on iMX6DQ SabreAuto board. The input to MAX9286 is four 720P30 cameras.
The verified camera boards:
    (1) Onsemi AR0140+AP0101+MAX9271 boards.
    (2) OmniVision OV10635+MAX9271 boards.
The MIPI CSI2 CVBS camera surround view solution can be found at: iMX6DQ ISL79985/79987 MIPI CSI2 CVBS camera surround view solution for Linux BSP
The MIPI CSI2 CVBS HD camera surround view solution can be found at: iMX6DQ TP2854 MIPI CSI2 720P CVBS camera surround view solution for Linux BSP
The kernel patches:
0001-IPU-update-IPU-capture-driver-to-support-up-to-four-.patch
     Updated IPU common code to support up to four cameras.
0002-Add-Max9286-support-on-SabreAuto-board-which-can-sup.patch
     MAX9286 driver, it includes MAX9271, AP0101 and AR0140 drivers.
0003-Remove-the-page-size-align-requirement-for-v4l2-capt.patch
     With this patch, the mxc_v4l2_tvin test application can use overlay framebuffer as V4l2 capture buffer directly.
0004-Max9286-skip-AP0101-camera-re-initialization.patch
     If the camera board's power had been kept after initialized, this patch will bypass the re-initialization to reduce the start up time.
0005-Max9286-set-I2C-speed-to-400Kbps.patch
    Set I2C to 400Kbps to reduce the AP0101+AR0140 initialization time.
0006-Max9286-add-retry-for-MAX9271-I2C-access.patch
    Added retry for MAX9271 I2C access.
0007-Max9286-Add-support-for-OV10635-camera.patch
    Updated code for OV10635 camera.
0008-Max9286-support-auto-detect-camera-number.patch
    Make the Max9286 driver can detect the camera number automatically.
How to builld the kernel with MAX9286 support:
      make imx_v7_defconfig
      make menuconfig (In this command, you should select the MAX9286 driver:
            Device Drivers  --->
                  <*> Multimedia support  --->
                        [*]   V4L platform devices  --->
                              <*>   MXC Video For Linux Video Capture
                                      MXC Camera/V4L2 PRP Features support  --->
                                          <*>Maxim max9286 GMSL Deserializer Input support
                                              Select Camera Sensor (OmniVision OV10635 camera sensor)  // Or (Onsemi AP0101 and AR0140 camera sensor)
                                          <*>mxc VADC support
                                          <*>Select Overlay Rounting (Queue ipu device for overlay library)
                                          <*>Pre-processor Encoder library
                                          <*>IPU CSI Encoder library)
      make zImage
      make dtbs
The built out image file:
      arch/arm/boot/dts/imx6q-sabreauto.dtb
      arch/arm/boot/zImage
"mxc_v4l2_tvin_max9286.tar.gz" is the test application, test command to capture the four cameras and render on 1080P HDMI display:
/mxc_v4l2_tvin.out -ol 0 -ot 0 -ow 960 -oh 540 -d 1 -x 0 -g2d &
/mxc_v4l2_tvin.out -ol 960 -ot 0 -ow 960 -oh 540 -d 1 -x 1 -g2d &
/mxc_v4l2_tvin.out -ol 0 -ot 540 -ow 960 -oh 540 -d 1 -x 2 -g2d &
/mxc_v4l2_tvin.out -ol 960 -ot 540 -ow 960 -oh 540 -d 1 -x 3 -g2d &
Some hardware check point on AR0140+AP0101+MAX9271 camera board (Please get MAX9286 and OV10635 schematics from Maxim):
1. In this patch, MAX9286's I2C address is 0x4D, so ADD0 and ADD1 should be connected to high.
AP0101's I2C address is 0xBA, so SADDR should be connected to high.
2. AP0101's DOUT0~DOUT7 should be connected to MAX9271's DIN7~DIN0, the order should be switched, MSB connected to LSB.
3. MAX9271's GPO pin should be connected to AP0101's FRAME_SYNC pin. The pull down resistance on FRAME_SYNC pin should not be 0 ohm.
Some known limitation:
1. AP0101's VSYNC invalid time, last video line's HSYNC to VSYNC porch's max value is 255 pixel clocks, it is not enough for MAX9286 to generate the Frame End MIPI packets for each camera. So in order to let iMX6DQ to capture 1280x720 video for each camera, we had let AP0101 output 1280*724 frame size, and iMX6 will only capture 720 lines, the remained video data and Frame End will be ignored.
This solution will not impact the function, but there will be "Error matching Frame Start with Frame End for Virtual Channel x" error reported from iMX6 MIPI_CSI_ERR1 register.
Maxim suggested to use MAX96705 to relace the MAX9271, it can delay the VSYNC invalid time, then the MIPI error will be fixed.
2015-11-17 update: Updated for OV10635 camera support.
File: L3.10.53_GA1.1.0_MAX9286_Surroundview_Patch_2015-11-17.zip
2015-12-04 update:
File: L3.10.53_GA1.1.0_MAX9286_Surroundview_Patch_2015-12-04.zip
Added patch 0009-Max9286-updated-PCLK-edge-setting-for-OV10635.patch to correct the OV10635 PCLK edge setting
2016-03-07 update:
File L3.14.38_GA_MAX9286_Surroundview_Patch_2016-03-07.zip
Added kernel patch for L3.14.38 GA 1.1.0 BSP.
2016-07-26 update:
Files: L3.10.53_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip; L3.14.38_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip; L3.14.52_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip.
Added gstreamer support.
Added MAX96705 support.
Added patch for L3.14.52_GA1.1.0.
2017-12-11 update:
Added CVBS surround view link: iMX6DQ TP2854 MIPI CSI2 720P CVBS camera surround view solution for Linux BSP
2021-04-26 update:
Some customer reported, when system loading is heavy, sometimes, some camera will flicker left and right. It is caused by SFMC FIFO data lost. The original patch used IDMAC 0 and IDMAC 1 for two cameras on one IPU, this is not the best setting.
IDMAC 1 is fixed to use 1/4 SMFC FIFO and it will cause IDMAC 0 to use 1/4 SMFC FIFO too. And another 1/2 of SMFC FIFO can't be used in this case.
Some code update to improve it:
For each IPU, please use IDMAC 0 and IDMAC 2 to capture the two cameras.
This needs change the hard coding in "drivers\media\platform\mxc\capture\ipu_csi_enc.c",
"CSI_MEM1" and "IPU_IRQ_CSI1_OUT_EOF" should be changed to "CSI_MEM2" and "IPU_IRQ_CSI2_OUT_EOF". In this case, all SMFC FIFO can be used.
And in "ipu_common.c", function ipu_probe(), the followed code should be changed to make IDMAC2 use high priority too.
/* Set sync refresh channels and CSI->mem channel as high priority */
- ipu_idmac_write(ipu, 0x18800003L, IDMAC_CHA_PRI(0));
+ ipu_idmac_write(ipu, 0x1880000FL, IDMAC_CHA_PRI(0));
ラベル(4)
添付
コメント
dqz
now i use BSP 3.10.53, max9286+max96707+ISX016
when connest one camera i can get image successfully,but when i connect tow cameras i always get mipi csi2 can not receive sensor clk! MIPI_CSI_PHY_STATE = 0x6f0.
i have patched L3.10.53_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip
my code :
 max9271_write_reg(0, 0x40, 0x2F);
 msleep(2);
 max9271_write_reg(0, 0x97, 0x5F);
 max9286_write_reg(0x01, 0x00);
 max9286_write_reg(0x63, 0x00);
 max9286_write_reg(0x64, 0x00);
 max9286_write_reg(0x06, 0x00);
 max9286_write_reg(0x07, 0x00);
 max9286_write_reg(0x08, 0x26);
mipi_csi2_reset(mipi_csi2_info, (576 * g_sensor_num) / (lanes + 1));
i have refer Debug steps for customer MIPI sensor.docx.
my doubt is how to  confirm hsp_clk  and  ccm_pixel_clkm and where to configure hsp_clk  and  ccm_pixel_clkm?
another question is about MAX9286 (FSYN CLOCKED in register 0x31 ) when i read it it is 0x0, if the two camera can not get FSYNC LOCKED, this will lead to can not receive sensor clk???
how to fix this?
thanks
I think your cameras are not working in sync mode. They should work in such mode: MAX9286 send a pulse to each camera, then each camera send out one frame. The VSYNC for each camera should appear in almost same time.
If MAX9286 can't sync the multi-cameras, it will not output MIPI signals. But for single camera, no sync was needed.
dqz
Thank you for your reply,
the camera is working in sync mode.
sometime i can connect two camrea successfully:
max9286_mipi: sensor number = 2.
mxc_mipi_csi2 21dc000.mipi_csi: mipi_csi2_reset: mipi_lane_bps = 336 Mbps
mxc_mipi_csi2 21dc000.mipi_csi: mipi_csi2_reset: value = 0x2a.
max9286_mipi 1-006a: ap0101_initialize: AP0101 was found, index = 1.
max9286_mipi 1-006a: ap0101_initialize:AP0101 is already in Slave (Shutter-Sync) Mode.
max9286_mipi 1-006a: ap0101_initialize: AP0101 was found, index = 2.
but when i try to get image,the image is not  normal,
the clock configure is not right? g_sensor_num = 2  lanes = 3
mipi_csi2_reset(mipi_csi2_info, (672* g_sensor_num) / (lanes + 1));
I think you still need check and tuning your ISX016 camera setting, the reference code is for AP0101+AR0140 camera board.
Dear Qiang,
  我正在使用s32v-evb开发板调试 MAX9286 + Onsemi AR0140+AP0101+MAX9271,您那边是否有相关调试文档(documents)或者参考代码(reference code)能够提供给我一份吗?
万分感谢。
Please check with your S32V contact window for that, here is just for IMX6.
dqz
Qiang_FSL‌  @zhang hongliang
i want to put the four Independent camera data together in the ipu driver like one of below image , so then user can just use once DQBUF call to get all the four camera data.
Any suggestions?
or
You can alloc a big buffer array for V4l2 capture driver with 2560*1440 pixel buffers:
For camera 1, let its DMA buffer base address to pixel (0, 0), width 1280, height 720, but set the stride to 1280*2*2; then after filled 1280 pixels (1280*2 bytes for UYVY input), it will jump 1280*2*2 bytes; so camera 1 will fill the left-up 1280*720 pixels of the buffer;
For camera 2, let its DMA buffer base address to pixel (1280, 0), width 1280, height 720, but set the stride to 1280*2*2; then after filled 1280 pixels (1280*2 bytes for UYVY input), it will jump 1280*2*2 bytes; so camera 2 will fill the right-up 1280*720 pixels of the buffer;
For camera 3, let its DMA buffer base address to pixel (0, 720), width 1280, height 720, but set the stride to 1280*2*2; then after filled 1280 pixels (1280*2 bytes for UYVY input), it will jump 1280*2*2 bytes; so camera 3 will fill the left-down 1280*720 pixels of the buffer;
For camera 4, let its DMA buffer base address to pixel (1280, 720), width 1280, height 720, but set the stride to 1280*2*2; then after filled 1280 pixels (1280*2 bytes for UYVY input), it will jump 1280*2*2 bytes; so camera 4 will fill the right-down 1280*720 pixels of the buffer.
dqz
Thanks for your reply.
where should i change the ipu driver code?like csi_enc_setup in ipu_csi_enc.c ,and  camera_callback in mxc_v4l2_capture.c
Could you please describe in more detail?
thanks
dqz
Hi li
How to use gstreamer record the four channel camera data?
VPU performance is not enough for 4x720P30 recoder.
For one camera:
grecorder-1.0 --camera_id 0 --video_format 4 --width1280 --height 720 --fps 30
dqz
where can i get grecorder-1.0
3.14.52 BSP release has this tool. For other release, it is same as normal camera recode.
Dear Qiang!
I am using MAX9286+OV10635+MAX9271. I have tested 3.10.53patch and 3.14.52patch, but both of them are not work. When I ran "/mxc_v4l2_tvin.out -ol 0 -ot 0 -ow 960 -oh 540 -d 1 -x 0 -g2d &". I got the same errors, like this
[ 2027.062578] max9286_mipi 0-0048: max9286_write_reg reg = 0x15, val = 0x13.
[ 2027.070238] max9286_mipi 0-0048: max9286_write_reg reg = 0xe, val = 0x5f.
root@wandboard-quad:/usr/src# [ 2027.093488] max9286_mipi 0-0048: max9286_write_reg reg = 0x3f, val = 0x4f.
[ 2027.113488] max9286_mipi 0-0048: max9286_write_reg reg = 0x3b, val = 0x1e.
[ 2027.332778] max9286_mipi 0-0048: max9271_write_reg:write reg error:reg= 4,val=43
[ 2027.552770] max9286_mipi 0-0048: max9271_write_reg:write reg error:reg= 8,val= 1
[ 2027.573473] max9286_mipi 0-0048: max9286_write_reg reg = 0x3b, val = 0x19.
[ 2027.593452] max9286_mipi 0-0048: max9286_write_reg reg = 0x12, val = 0xf3.
[ 2027.601029] max9286_mipi 0-0048: max9286_write_reg reg = 0x1, val = 0x2.
[ 2027.713713] max9286_mipi: sensor number = 1.
[ 2027.718679] max9286_mipi 0-0048: max9286_write_reg reg = 0xe, val = 0x50.
[ 2027.728809] max9286_mipi 0-0048: max9286_write_reg reg = 0xb, val = 0xe1.
[ 2027.735691] mxc_mipi_csi2 21dc000.mipi_csi: mipi_csi2_reset: mipi_lane_bps = 192 Mbps
[ 2027.744033] mxc_mipi_csi2 21dc000.mipi_csi: mipi_csi2_reset: value = 0x44.
[ 2027.751624] max9286_mipi 0-0048: max9286_write_reg reg = 0x0, val = 0xe2.
[ 2027.760490] max9286_mipi 0-0048: max9286_write_reg reg = 0xa, val = 0x22.
[ 2027.962765] max9286_mipi 0-0048: max9271_write_reg:write reg error:reg= 0,val= 4
[ 2028.182767] max9286_mipi 0-0048: max9271_write_reg:write reg error:reg= 7,val=84
[ 2028.402761] max9286_mipi 0-0048: max9271_write_reg:write reg error:reg= 1,val=90
[ 2028.602752] max9286_mipi 0-0048: max9271_write_reg:write reg error:reg= 9,val=c4
[ 2028.802767] max9286_mipi 0-0048: max9271_write_reg:write reg error:reg= a,val=c0
[ 2029.002791] max9286_mipi 0-0048: max9271_write_reg:write reg error:reg= b,val= a
[ 2029.202766] max9286_mipi 0-0048: max9271_write_reg:write reg error:reg= c,val= 4
[ 2029.223462] max9286_mipi 0-0048: max9286_write_reg reg = 0xa, val = 0x22.
[ 2029.230955] max9286_mipi 0-0048: max9286_write_reg reg = 0xa, val = 0xff.
[ 2029.432766] max9286_mipi 0-0048: max9271_write_reg:write reg error:reg= 4,val=43
[ 2029.441134] max9286 reg 0x0A = 0xff.
[ 2029.447266] max9286_mipi 0-0048: max9286_write_reg reg = 0x34, val = 0x36.
[ 2029.652766] max9286_mipi 0-0048: max9271_read_reg:read reg error: reg= 4
[ 2029.659488] max9271 reg 0x04 = 0xffffffff.
[ 2029.862766] max9286_mipi 0-0048: max9271_read_reg:read reg error: reg= 4
[ 2029.869489] max9271 reg 0x04 = 0xffffffff.
[ 2030.072766] max9286_mipi 0-0048: max9271_read_reg:read reg error: reg= 4
[ 2030.079487] max9271 reg 0x04 = 0xffffffff.
[ 2030.282776] max9286_mipi 0-0048: max9271_read_reg:read reg error: reg= 4
[ 2030.289497] max9271 reg 0x04 = 0xffffffff.
[ 2030.492792] max9286_mipi 0-0048: ov10635_read_reg:read reg error: reg=0x300a.
[ 2030.499957] max9286_mipi 0-0048: ov10635_check_device: OV10635 hasn't been found, reg[0x300a] = 0x0.
[ 2030.510196] max9286_mipi 0-0048: max9286_write_reg reg = 0x34, val = 0xb6.
[ 2030.712770] max9286_mipi 0-0048: max9271_write_reg:write reg error:reg= 4,val=83
[ 2030.823490] max9286_mipi 0-0048: max9286_write_reg reg = 0x15, val = 0x9b.
[ 2031.442763] mipi csi2 can not receive sensor clk! MIPI_CSI_PHY_STATE = 0x200.
g_in_width = 1280, g_in_height = 800.
fb_fix.id = DISP3 FG.
fb: smem_start = 0x40800000, smem_len = 0xa8c000.
fb: frame buffer size = 0x384000 bytes.
fb: g_screen_info.xres = 1280, g_screen_info.yres = 720.
fb: g_display_left = 0.
fb: g_display_top = 0.
fb: g_display_width = 960.
fb: g_display_height = 540.
start time = 1499055466 s, 40751 us
[ 2041.482836] ERROR: v4l2 capture: mxc_v4l_dqueue timeout enc_counter 0
VIDIOC_DQBUF failed.
It shows that can't find OV10635 and MAX9271. If there are something wrong with I2C drivers?
I can confirm my hardware board is OK, because I am using the "MAX9286 COAX EVKIT" board.
Could you help me?
dqz
Hi, Li
now i try to use VPU to encode the camera data, i use MJPEG, i do not want to use other standed (H263 H264),
the the file is a too large, 100 frames will make a file about 11M.
how to reduce MJPEG file?
thanks
dqz
Qiang_FSL
now i try use h.264,
./mxc_vpu_test.out -E "-x 0 -f 0 -c 1800 -a 30 -w 1280 -h 792 -o ss.mp4 -l 0 -b 5204"
when i try to play ss.mp4 on PC i can't play it normally, like the mp4 file has no header,
how to create a mp4 file when use H.264 recoder video data?
Hi Li,
Why do I need to set video format to 4 (UYVY) when using grecorder tool?
hello yu  :  能否将l3.0.35的补丁给我一份,455030349@qq.com。感激不尽
Hi Qiang,
How to sync the camera of the MAX9296 + 4 96705 +4camera?
We have 2 customer want to use the IMX.6 + MAX9268+ 4 MAX96705---camera. Could you suggest how to sync the camera?
Thank you very much.
"MAX9296 + 4 96705 +4camera" the reference patch had already covered this, the sync setting is in camera and Maxim chip side.
The iMX6 SabreAuto board can only supply 5V power to MAX9286 board, so if you are using long Coax cable, there will be issue. You can rework your MAX9286 board, and supply 7~12V power to it.
Dear Qiang Li, could you please kindly take a look at following post and give me an insight ?
Adding X11 Interlace Video Mode Support to Yocto
Thanks in Advance
Anuradha
hi zhang hongliang
您好:我现在是基于 imx6-sabresd + L3.14.28调试MAX9286+AR0140+AP0101+MAX96705,运行mxc_v4l2_tvin程序出现了和您一样的错误,ERROR: v4l2 capture: mxc_v4l_dqueue timeout enc_counter 0,同时把ov5640注释相关掉,bit 19位置为0,现在出现同样的问题,并且我在内核启动的时候看到如下的报错信息,还请您帮忙看一下:QQ图片20170817110628.png
以下还有程序运行的log:
Hi Brave,
That error means there is no valid MIPI CSI2 signal to IMX6, from your log, it seems there is flash in your camera module, if so, the flash setting for the camera should be algined with the AP0101 setting in max9286.c, the camera should work in frame sync mode.
On Max9286, there is a lock pin, only when the four cameras are working in frame sync mode and are locked by MAX9286, it will output valid MIPI CSI2 signal to iMX6.
4 in 1 HD recorder resolved?
你好 Qiang Li
按照这个帖子的补丁,我们目前MAX9286+9271四路720P输入没问题,因为需要录像,所以要使用IPU进行RGBA32/UYUY到NV12的色彩空间转换,但是一启动IPU进行色彩空间转换,视频图像就会异常,图像抖动。720*480转化下只有一个通道有问题,720P转换下会有三个通道有问题,请问是否在此方案条件下,不能再使用IPU进行色彩空间不换了,还是说底层驱动处理上有冲突所致?!如何消除?
我们使用的是IMX6D+linux3.14.28
你可以参考一下mxc_vpu_test的代码,camera driver可以直接把UYVY的图输出成NV12的,然后直接编码,不需要额外的转换。
另外,4路720P30的编码在VPU这边是支持不了的。
谢谢你的回复,
我们的应用场景时这样的,把4路拼接后的显示画面再编码存储,所以相当于只进行一路720P的编码,由于不是原始图像的直接编码所以没办法通过camera driver把UYVY的图输出成NV12的进行编码。我们的拼接是通过GPU实现的,送给编码器的是RGBA32的,所以需要在编码前进行色彩空间转换,然后就出现了图像不正常的现象。
实际上我们也测试了只针对单通道720×480图像的色彩转化,也即先把720P的图像通过GPU缩小到720×480然后在用此分辨率的图像进行转码并录像,同样会引起输入图像异常,如果我们转码的是720×480的(RGBA32——>NV12或者UYVY——>NV12),只有一个通道出现异常。如果转码的是1280×720的则除了第一个通道正常外,其余3个通道全部异常。
检查了底层驱动,数据流是CSI-->SMFC-->IDMAC-->MEM,跟踪IDMAC通道使用情况,默认是
    CSI_MEM0 = _MAKE_CHAN(15, NO_DMA, NO_DMA, NO_DMA, 0),
    CSI_MEM1 = _MAKE_CHAN(16, NO_DMA, NO_DMA, NO_DMA, 1),
    CSI_MEM2 = _MAKE_CHAN(17, NO_DMA, NO_DMA, NO_DMA, 2),
    CSI_MEM3 = _MAKE_CHAN(18, NO_DMA, NO_DMA, NO_DMA, 3),
720×480下出问题的是CSI_MEM1 = _MAKE_CHAN(16, NO_DMA, NO_DMA, NO_DMA, 1),如果把上述通道控制修改如下
    CSI_MEM0 = _MAKE_CHAN(15, NO_DMA, NO_DMA, NO_DMA, 1),
    CSI_MEM1 = _MAKE_CHAN(16, NO_DMA, NO_DMA, NO_DMA, 0),
则问题通道变成CSI_MEM0 = _MAKE_CHAN(15, NO_DMA, NO_DMA, NO_DMA, 1),从这个角度看,似乎是驱动对底层资源的管理出现冲突所致。亦或者硬件本身不支持这种用法。是否可以帮忙确认问题产生的根源,以及是否有建议的思路?
Hello Qiang,
The attached tvin source code includes a local file #include "g2d.h".  However this file is not included in the archive.  Where do we get this file?
This file can be found from your rootfs.
When you used IPU for CSC on 1280*720 frames, the IPU loading is heavy, there is chance that IPU can't service the capture on time.
To improve it, you need use IDMAC 0 and IDMAC 2, then all FIFO can be used:
In ipu_common.c, function ipu_probe(), please make sure all CSI->MEM channels are set to high priority:
hi, Qiang Li
my custom board is ref to saresd, max9286+max96705+ap010.
my yocto version is 3.14.52, i  got message below after patched the kernel
pr_info("max9286_mipi: sensor number = %d.\n", g_sensor_num);
if (g_sensor_num == 0) {
pr_err("%s: no camera connected.\n", __func__);
return -1;
can you please give me some suggestion to find the program?
Hi Yu fe,
This error means MAX9286 can't detect the cameras, you need check your hardware signal and power between MAX9286 and MAX96705.
你好 Qiang Li
感谢协助,如你提供的方案,问题已经获得解决!之前所述会出现系统不稳定的问题是其它原因所致,于此方案无关!
Hi Qiang,
      Have a nice holiday. I have some trouble with  my borad. We refer to the sabresd and max9286+max96705+ap 0101, and we used the 3.14.52 BSP.  Now our four camera are all working properly, but when I used '-g2d'  in the test command  there is a error just like 'Segmentation fault'. I think It may be  something wrong with  my GPU,but I don't kown how to deal with the problem. Could you give  some advices to me ?Thanks . Here is the log below.
root@imx6qdlsolo:~# ./mxc_v4l2_tvin.out -ol 0 -ot 0 -ow 960 -oh 540 -d 0 -x 0
------------------------------here is AP0101--------------------------------
max9286_mipi: sensor number = 4.
mxc_mipi_csi2 21dc000.mipi_csi: mipi_csi2_reset: mipi_lane_bps = 594 Mbps
mxc_mipi_csi2 21dc000.mipi_csi: mipi_csi2_reset: value = 0x2e.
max9286_mipi 1-006a: ap0101_initialize: AP0101 was found, index = 3.
max9286_mipi 1-006a: ap0101_initialize: AP0101 was found, index = 4.
g_in_width = 1280, g_in_height = 720.
fb_fix.id = DISP4 BG.
It is background screen, only full screen default format was supported.
fb: smem_start = 0x25600000, smem_len = 0x546000.
fb: frame buffer size = 0x1c2000 bytes.
fb: g_display_width = 1280.
fb: g_display_height = 720.
start time = 1449238585 s, 124037 us
^CERROR: v4l2 capture: mxc_v4l_dqueue() interrupt received
root@imx6qdlsolo:~# ./mxc_v4l2_tvin.out -ol 0 -ot 0 -ow 960 -oh 540 -d 0 -x 0 -g2d
Segmentation fault
With my best regards
 Jun
That means your kernel is not aligned with the GPU libs in your rootfs.
Hi Qiang
I am using following hardwares for similiar surroundview implementation under linux 3.14.52
ov10635 <--> ds90ub913 <-->
ov10635 <--> ds90ub913 <--> DS90ub964-q <-----> imx6q
the driver patches are most the same as the one you provided
and currently the mipi-csi2 can detect the pixclock successfully
also the waves on the data lines of mipi-csi2 seems correctly
however, I can not receive the camera_callback for camera 0-2, only can receive camera_callback of camera 3
I have read all the comments above, and can not find the similiar causes
I have checked the following things
1) the MIPI_IPU1_MUX and MIPI_IPU2_MUX are set to 0 for mipi_csi
2) the register dumps:
IPU1_CSI0_SENSE_CONF(0x2630000): 0x04008a00
IPU1_CSI1_SENSE_CONF(0x2638000): 0x04008a00
IPU2_CSI0_SENSE_CONF(0x2a30000): 0x04008a00
IPU2_CSI1_SENSE_CONF(0x2a38000): 0x04008a00
IPU1_IDMAC_CH_EN_1(0x2608004): 0x00000003
IPU1_IDMAC_CH_EN_2(0x2608008): 0x00000000
IPU2_IDMAC_CH_EN_1(0x2a08004): 0x00800003
IPU2_IDMAC_CH_EN_2(0x2a08008): 0x00000000
IPU1_IDMAC_CH_BUSY_1(0x2608100): 0x00000003
IPU2_IDMAC_CH_BUSY_1(0x2a08100): 0x00800002
IPU1_SMFC_MAP(0x2650000): 0x00000020
IPU2_SMFC_MAP(0x2a50000): 0x00000020
my questions are
1) are the smfc and idmac setting correct for these four cameras?
2) from the spec, it says ipu mipi should use non-gated mode, but mxc_v4l2_capture.c uses gated mode in mxc_v4l2_s_param
which mode should I use(I have tried both modes, and neither of them works for me)
3) which case need me to set the hsync_pol, vsync_pol?
4) any suggestion to identify this issue?
thanks
Hi Lion, no special modification is needed on iMX6 side, you should tune the Ti chip setting.
As I know, some customer had already make the Ti 964 work on iMX6 platform, the main work is in Ti side, you should check with them. For iMX6, you just need make sure the four cameras is transfered on 4 MIPI virtual channel.
Hi Qiang
is there any way on imx6 to confirm the mipi data correct or not from mipi csi-2?
for example some register show the status of the mipi csi-2, specially the virtual channel/frame size related
Hi lionwei Qiang_FSL ;
According to iMX6 CSI2IPU documentation we need to create  short or long type packages  and also we need Start Of Transmission and End Of Transmission packages too,
How can I send this packages for example in the camera device driver source this packages should be created and sent these data types or we are defining these values to another files . What is the format of SoT and EoT packages?
Can someone give me any example about that, I have been working to solve the csi2 format mipi clock and data lane problem, I couldnt define to the iMX6Q processor custom board since 3 week. It would be very very appreciated.
Best Regards
Hi Mustafa, the information can be found from MIPI CSI2 specification:
Hi Lion,
The MIPI CSI2 error registers can be used to check the MIPI CSI2 package is correct with CRC or follows the protocol.
Thank you for respond Qiang_FSL
I am now looking at the MIPI CSI2 Reference Documentation , I am checking all. Also I made search on the my imx6q(Wandboard Quad) custom board source and header files. After my research I could not find  relative source code in the my kernel files, which defines packet types and communication sub-structures for CSI-2 Interface Low Level Protocol message protocol , SoT and EoT package sample codes. I will take the video by using  "mxc" relative files and it's ipu source codes. So If you can share any source code or any relative codes which informs me about  SoT,EoT and LLP Massage Package Structures sample codes, It would be very nice and useful for me because I don't have any reference code in my kernel files.
Best Regards.
Hi Mustafa,
These packages are implemented by the MIPI CSI2 hardware, from software side, we just tell it the virtual channel number and Data Identifier (It can be found at include\linux\mipi_csi2.h).
Hi Qiang
thanks for your help!
after tune the ti settings, I can receive four camera data now.
currently for 1/2/3 sensors, I can receive the data with correct pixels
however for 4 sensors, the pixel data has some line corruptions(see the below picture)
from TI side, we can set the data lane numbers and data lane rate
however, the data lane rate has only three options(400M, 800M, 1.6G)
with different rate+lane number setting, the 1/2/3 sensors can work perfectly
for 4 sensors, only 800M+4 data lanes works, but the data has some corruptions
my question is
1) for imx6 mipi csi2 receiver, is there any special requirement on the rate and data lanes setting?
2) for imx6 mipi csi, what is the suitable ratio between the real data rate and the total data capability?
2) any suggestions?
Hi Lion Wei, the MAX throughput for IMX6 MIPI CSI2 is 3.2Gbps in 4 lanes mode, so each camera can be up to 800Mbps (include blank data).
And the followed code should be adjust for your real camera, the 768 should be your real camera bps:
 /* 48MHz pixel clock (1280*800@30fps) * 16 bits per pixel (YUV422) = 768Mbps mipi data rate for each camera */
 mipi_csi2_reset(mipi_csi2_info, (768 * g_sensor_num) / (lanes + 1));
Anoter limitation, at least 3 blank lines are needed for two frames from camera.
Hi Qiang
I also use ov10635, and use  the same sensor register values as in your patch
the sensor output 1280*800@30fps with yuv422(uyvy,0x1e)
per my understanding, the camera data rate should be 30M*16bits=480Mbps
how to get the value of 768Mbps?
and in function mipi_csi2_reset, it just sets register MIPI_CSI_PHY_TST_CTL1,
from the name, it is just a test related register, is it useful for the mipi csi2 init?
thanks
Hi Lion,
You need include blank data too. So use the pixel clock to calculate the throughput is more simple and accuracy.
Qiang Li,我现在在调MAX96705+AP0101+AR0141,基于Linux 3.14.52版本,提示错误信息如下,请帮忙看看是哪里出了问题。
-oh 540 -d 1 -x 0 -g2da/usb/CameraTest# ./mxc_v4l2_tvin.out -ol 0 -ot 0 -ow 960
[ 34.334381] max9286_read_reg 0x49 = 1.
[ 34.338883] mipi_csi2_set_lanes = 3.
[ 34.342494] mxc_mipi_csi2 21dc000.mipi_csi: mipi_csi2_reset: mipi_lane_bps = 148 Mbps
[ 34.350399] mxc_mipi_csi2 21dc000.mipi_csi: mipi_csi2_reset: value = 0x42.
[ 34.555059] max9286_mipi 2-006a: ap0101_initialize: AP0101 was found, index = 1.
[ 34.563125] max9286_mipi 2-006a: ap0101_initialize:AP0101's 0xC88D is 0x0.
[ 34.570775] max9286_mipi 2-006a: ap0101_initialize:AP0101 is not in Host Configuration Mode. reg = 0x4.
[ 34.580281] max9286_mipi 2-006a: ap0101_initialize:AP0101's 0xdc07 is 0x4.
[ 36.453930] max9286_mipi 2-006a: ap0101_IssueHostCommand: timeout.
[ 36.460877] max9286_mipi 2-006a: ap0101_ApplyPatch: PATCH_APPLY_PATCH error.
[ 36.468012] max9286_mipi 2-006a: ap0101_LoadAp0101Patch: Patch111 load failed, result = 1794
[ 36.476664] max9286_mipi 2-006a: ap0101_initialize: LoadAp0101Patch failed, result = 1794
[ 36.613908] max9271_dump_registers: index = 1.
[ 36.618960] MAX9271 Reg 0x00 = 0x82.
[ 36.623149] MAX9271 Reg 0x01 = 0xd4.
[ 36.627402] MAX9271 Reg 0x02 = 0x1f.
[ 36.631579] MAX9271 Reg 0x03 = 0x0.
[ 36.635802] MAX9271 Reg 0x04 = 0x83.
[ 36.639915] MAX9271 Reg 0x05 = 0x0.
[ 36.643952] MAX9271 Reg 0x06 = 0xa0.
[ 36.648075] MAX9271 Reg 0x07 = 0x84.
[ 36.652172] MAX9271 Reg 0x08 = 0x0.
[ 36.656243] MAX9271 Reg 0x09 = 0x92.
[ 36.660336] MAX9271 Reg 0x0a = 0x90.
[ 36.664482] MAX9271 Reg 0x0b = 0x8a.
[ 36.668582] MAX9271 Reg 0x0c = 0x82.
[ 36.672672] MAX9271 Reg 0x0d = 0xb6.
[ 36.676826] MAX9271 Reg 0x0e = 0x2.
[ 36.680840] MAX9271 Reg 0x0f = 0x3e.
[ 36.684991] MAX9271 Reg 0x10 = 0x12.
[ 36.689069] MAX9271 Reg 0x11 = 0x0.
[ 36.693058] MAX9271 Reg 0x12 = 0x40.
[ 36.697179] MAX9271 Reg 0x13 = 0x2.
[ 36.701168] MAX9271 Reg 0x14 = 0x60.
[ 36.705282] MAX9271 Reg 0x15 = 0xe3.
[ 36.709358] MAX9271 Reg 0x16 = 0x1f.
[ 36.713434] MAX9271 Reg 0x17 = 0x99.
[ 36.717557] MAX9271 Reg 0x18 = 0xff.
[ 36.721633] MAX9271 Reg 0x19 = 0xff.
[ 36.725747] MAX9271 Reg 0x1a = 0xff.
[ 36.729823] MAX9271 Reg 0x1b = 0xff.
[ 36.733918] MAX9271 Reg 0x1c = 0x0.
[ 36.737938] MAX9271 Reg 0x1d = 0x0.
[ 36.741931] MAX9271 Reg 0x1e = 0x41.
[ 36.746045] MAX9271 Reg 0x1f = 0x1.
[ 36.749624] Dump MAX9286 registers:
[ 36.753611] MAX9286 Reg 0x00 = 0xe1.
[ 36.757734] MAX9286 Reg 0x01 = 0x0.
[ 36.761722] MAX9286 Reg 0x02 = 0x0.
[ 36.765750] MAX9286 Reg 0x03 = 0x1.
[ 36.769738] MAX9286 Reg 0x04 = 0x0.
[ 36.773727] MAX9286 Reg 0x05 = 0x0.
[ 36.777758] MAX9286 Reg 0x06 = 0x60.
[ 36.781836] MAX9286 Reg 0x07 = 0x89.
[ 36.785948] MAX9286 Reg 0x08 = 0x25.
[ 36.790025] MAX9286 Reg 0x09 = 0xd4.
[ 36.794114] MAX9286 Reg 0x0a = 0xff.
[ 36.798198] MAX9286 Reg 0x0b = 0xe4.
[ 36.802276] MAX9286 Reg 0x0c = 0x99.
[ 36.806407] MAX9286 Reg 0x0d = 0xf3.
[ 36.810484] MAX9286 Reg 0x0e = 0x50.
[ 36.814604] MAX9286 Reg 0x0f = 0xb.
[ 36.818595] MAX9286 Reg 0x10 = 0x0.
[ 36.822583] MAX9286 Reg 0x11 = 0x0.
[ 36.826610] MAX9286 Reg 0x12 = 0xf3.
[ 36.830686] MAX9286 Reg 0x13 = 0xf.
[ 36.834717] MAX9286 Reg 0x14 = 0xe4.
[ 36.838794] MAX9286 Reg 0x15 = 0x9b.
[ 36.842869] MAX9286 Reg 0x16 = 0x0.
[ 36.846895] MAX9286 Reg 0x17 = 0x1.
[ 36.850885] MAX9286 Reg 0x18 = 0x0.
[ 36.854902] MAX9286 Reg 0x19 = 0x0.
[ 36.858891] MAX9286 Reg 0x1a = 0x60.
[ 36.862967] MAX9286 Reg 0x1b = 0x0.
[ 36.867021] MAX9286 Reg 0x1c = 0xf4.
[ 36.871098] MAX9286 Reg 0x1d = 0xff.
[ 36.875218] MAX9286 Reg 0x1e = 0x40.
[ 36.879294] MAX9286 Reg 0x1f = 0x2.
[ 36.883282] MAX9286 Reg 0x20 = 0xff.
[ 36.887394] MAX9286 Reg 0x21 = 0x0.
[ 36.891383] MAX9286 Reg 0x22 = 0x0.
[ 36.895414] MAX9286 Reg 0x23 = 0x0.
[ 36.899403] MAX9286 Reg 0x24 = 0x0.
[ 36.903391] MAX9286 Reg 0x25 = 0x0.
[ 36.907715] MAX9286 Reg 0x26 = 0x0.
[ 36.911704] MAX9286 Reg 0x27 = 0xb1.
[ 36.916104] MAX9286 Reg 0x28 = 0x0.
[ 36.920094] MAX9286 Reg 0x29 = 0x0.
[ 36.924135] MAX9286 Reg 0x2a = 0x0.
[ 36.928142] MAX9286 Reg 0x2b = 0x0.
[ 36.932132] MAX9286 Reg 0x2c = 0x0.
[ 36.936164] MAX9286 Reg 0x2d = 0x0.
[ 36.940154] MAX9286 Reg 0x2e = 0x0.
[ 36.944177] MAX9286 Reg 0x2f = 0x0.
[ 36.948180] MAX9286 Reg 0x30 = 0x0.
[ 36.952182] MAX9286 Reg 0x31 = 0x40.
[ 36.956295] MAX9286 Reg 0x32 = 0x99.
[ 36.960377] MAX9286 Reg 0x33 = 0x99.
[ 36.964497] MAX9286 Reg 0x34 = 0xb6.
[ 36.968580] MAX9286 Reg 0x35 = 0x0.
[ 36.972567] MAX9286 Reg 0x36 = 0x0.
[ 36.976594] MAX9286 Reg 0x37 = 0x0.
[ 36.980582] MAX9286 Reg 0x38 = 0x0.
[ 36.984612] MAX9286 Reg 0x39 = 0x0.
[ 36.988601] MAX9286 Reg 0x3a = 0x0.
[ 36.992589] MAX9286 Reg 0x3b = 0x19.
[ 36.996699] MAX9286 Reg 0x3c = 0x24.
[ 37.000774] MAX9286 Reg 0x3d = 0x54.
[ 37.004896] MAX9286 Reg 0x3e = 0xc8.
[ 37.008971] MAX9286 Reg 0x3f = 0x4f.
[ 37.013045] MAX9286 Reg 0x40 = 0x5a.
[ 37.017183] MAX9286 Reg 0x41 = 0x10.
[ 37.021271] MAX9286 Reg 0x42 = 0x0.
[ 37.025300] MAX9286 Reg 0x43 = 0xa0.
[ 37.029384] MAX9286 Reg 0x44 = 0x0.
[ 37.033372] MAX9286 Reg 0x45 = 0x0.
[ 37.037403] MAX9286 Reg 0x46 = 0x1.
[ 37.041392] MAX9286 Reg 0x47 = 0x11.
[ 37.045507] MAX9286 Reg 0x48 = 0xc1.
[ 37.049619] MAX9286 Reg 0x49 = 0x1.
[ 37.053607] MAX9286 Reg 0x4a = 0xff.
[ 37.057754] MAX9286 Reg 0x4b = 0x0.
[ 37.061745] MAX9286 Reg 0x4c = 0x0.
[ 37.065772] MAX9286 Reg 0x4d = 0x0.
[ 37.069761] MAX9286 Reg 0x4e = 0x5.
[ 37.073750] MAX9286 Reg 0x4f = 0x0.
[ 37.077781] MAX9286 Reg 0x50 = 0x0.
[ 37.081771] MAX9286 Reg 0x51 = 0x0.
[ 37.085798] MAX9286 Reg 0x52 = 0x0.
[ 37.089789] MAX9286 Reg 0x53 = 0x0.
[ 37.093778] MAX9286 Reg 0x54 = 0x0.
[ 37.097809] MAX9286 Reg 0x55 = 0x0.
[ 37.101798] MAX9286 Reg 0x56 = 0x0.
[ 37.105824] MAX9286 Reg 0x57 = 0x0.
[ 37.109816] MAX9286 Reg 0x58 = 0x0.
[ 37.113804] MAX9286 Reg 0x59 = 0x0.
[ 37.117834] MAX9286 Reg 0x5a = 0x0.
[ 37.121824] MAX9286 Reg 0x5b = 0x60.
[ 37.125936] MAX9286 Reg 0x5c = 0x89.
[ 37.130013] MAX9286 Reg 0x5d = 0x25.
[ 37.134119] MAX9286 Reg 0x5e = 0x0.
[ 37.138127] MAX9286 Reg 0x5f = 0xf.
[ 37.142115] MAX9286 Reg 0x60 = 0x45.
[ 37.146230] MAX9286 Reg 0x61 = 0xff.
[ 37.150306] MAX9286 Reg 0x62 = 0x1f.
[ 37.154427] MAX9286 Reg 0x63 = 0x0.
[ 37.158417] MAX9286 Reg 0x64 = 0x0.
[ 37.162405] MAX9286 Reg 0x65 = 0x12.
[ 37.166519] MAX9286 Reg 0x66 = 0x96.
[ 37.170595] MAX9286 Reg 0x67 = 0x0.
[ 37.174629] MAX9286 Reg 0x68 = 0x50.
[ 37.178708] MAX9286 Reg 0x69 = 0x0.
[ 37.182941] MAX9286 Reg 0x6a = 0x0.
[ 37.186967] MAX9286 Reg 0x6b = 0x0.
[ 37.190957] MAX9286 Reg 0x6c = 0x0.
[ 37.194976] MAX9286 Reg 0x6d = 0x0.
[ 37.198965] MAX9286 Reg 0x6e = 0x0.
[ 37.202954] MAX9286 Reg 0x6f = 0x0.
[ 37.206995] MAX9286 Reg 0x70 = 0x10.
[ 37.211071] MAX9286 Reg 0x71 = 0x1.
fb: smem_start = 0x24a00000, smem_len = 0xbdd800.
fb: frame buffer size = 0x3f4800 bytes.
fb: g_screen_info.xres = 1920, g_screen_info.yres = 1080.
start time = 1481829237 s, 120527 us
[ 47.283991] ERROR: v4l2 capture: mxc_v4l_dqueue timeout enc_counter 0
"ap0101_initialize:AP0101 is not in Host Configuration Mode"
This log means the camera is not in I2C config mode, so we can't initialize it. You need check your camera board, if it has flash on board, then you need update the flash ROM setting with the driver's. You can also remove the flash ROM on camera board, then the MAX9286 driver can initialize it with I2C commands.
%3CLINGO-SUB%20id%3D%22lingo-sub-1116501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EiMX6DQ%E3%81%AB%E3%81%AF2%E3%81%A4%E3%81%AEIPU%E3%81%8C%E6%90%AD%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E5%90%8C%E6%99%82%E3%81%AB%E6%9C%80%E5%A4%A74%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E6%A8%99%E6%BA%96%E3%81%AEBSP%E3%81%A7%E3%81%AF%E3%80%81%E5%90%8C%E6%99%82%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AF%E6%9C%80%E5%A4%A72%E5%8F%B0%E3%81%AB%E5%88%B6%E9%99%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2287418_87418.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2287418_87418.png%22%20style%3D%22width%3A%20996px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F118404i3F312F87BA942CD7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2287418_87418.png%22%20alt%3D%2287418_87418.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22untitled.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22untitled.png%22%20style%3D%22width%3A%20996px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F102583i76B3FFFEF6E81A1B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22untitled.png%22%20alt%3D%22untitled.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%B7%BB%E4%BB%98%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81BSP%E3%81%AF3.10.53%20GA%201.1.0%20BSP%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E6%9C%80%E5%A4%A74%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E4%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E-%201xCSI%2C%203xMIPI%3C%2FP%3E%0A%3CP%3E-%202xCSI%2C%202xMIPI%3C%2FP%3E%0A%3CP%3E-%204xMIPI%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E4xMIPI%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%AF%E3%80%814%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E5%8D%98%E4%B8%80%E3%81%AEMIPI%20CSI-2%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92MIPI%E3%81%AE%E4%BB%AE%E6%83%B3%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%A7%E8%BB%A2%E9%80%81%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AB%E3%81%AF%E3%80%81Maxim%20MAX9286%E7%94%A8%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81iMX6DQ%20SabreAuto%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E3%81%AE%E5%8B%95%E4%BD%9C%E3%81%8C%E6%A4%9C%E8%A8%BC%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82MAX9286%E3%81%B8%E3%81%AE%E5%85%A5%E5%8A%9B%E3%81%AF4%E5%8F%B0%E3%81%AE720P30%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%8B%95%E4%BD%9C%E6%A4%9C%E8%A8%BC%E6%B8%88%E3%81%BF%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%9C%E3%83%BC%E3%83%89%3A%3C%2FP%3E%0A%3CP%3E%EF%BC%881%EF%BC%89Onsemi%20AR0140%2BAP0101%2BMAX9271%E3%83%9C%E3%83%BC%E3%83%89%E3%80%82%3C%2FP%3E%0A%3CP%3E%EF%BC%882%EF%BC%89OmniVision%20OV10635%2BMAX9271%E3%83%9C%E3%83%BC%E3%83%89%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EMIPI%20CSI2%20CVBS%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%BB%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%BB%E3%83%93%E3%83%A5%E3%83%BC%E3%83%BB%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E5%85%88%E3%81%A7%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-158531%22%20data-objecttype%3D%22102%22%20target%3D%22_blank%22%3EiMX6DQ%E5%90%91%E3%81%91ISL79985%2F79987%20MIPI%20CSI2%20CVBS%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%BB%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%BB%E3%83%93%E3%83%A5%E3%83%BC%E3%83%BB%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%EF%BC%88Linux%20BSP%E7%94%A8%EF%BC%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EMIPI%20CSI2%20CVBS%20HD%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%BB%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%BB%E3%83%93%E3%83%A5%E3%83%BC%E3%83%BB%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E5%85%88%E3%81%A7%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-335803%22%20data-objecttype%3D%22102%22%20target%3D%22_blank%22%3EiMX6DQ%E5%90%91%E3%81%91TP2854%20MIPI%20CSI2%20720P%20CVBS%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%BB%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%BB%E3%83%93%E3%83%A5%E3%83%BC%E3%83%BB%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%EF%BC%88Linux%20BSP%E7%94%A8%EF%BC%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%91%E3%83%83%E3%83%81%3A%3CBR%20%2F%3E0001-IPU-update-IPU-capture-driver-to-support-up-to-four-.patch%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%E6%9C%80%E5%A4%A74%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81IPU%E5%85%B1%E9%80%9A%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E0002-Add-Max9286-support-on-SabreAuto-board-which-can-sup.patch%3CBR%20%2F%3E%20MAX9286%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E3%81%AF%E3%80%81MAX9271%E3%80%81AP0101%E3%80%81AR0140%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E0003-v4l2-capt%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%E3%82%B5%E3%82%A4%E3%82%BA%E6%95%B4%E5%88%97%E8%A6%81%E4%BB%B6%E3%82%92%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3CBR%20%2F%3E%20%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81mxc_v4l2_tvin%E3%83%86%E3%82%B9%E3%83%88%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92V4l2%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%A8%E3%81%97%E3%81%A6%E7%9B%B4%E6%8E%A5%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E0004-Max9286-skip-AP0101-camera-re-initialization.patch%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E9%9B%BB%E6%BA%90%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E5%BE%8C%E3%82%82%E7%B6%AD%E6%8C%81%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E5%86%8D%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%92%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%81%97%E3%81%A6%E8%B5%B7%E5%8B%95%E6%99%82%E9%96%93%E3%82%92%E7%9F%AD%E7%B8%AE%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E0005-Max9286-set-I2C-speed-to-400Kbps.patch%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20AP0101%EF%BC%8BAR0140%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E6%99%82%E9%96%93%E3%82%92%E7%9F%AD%E7%B8%AE%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81I2C%E3%82%92400%20Kbps%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E0006-Max9286-add-retry-for-MAX9271-I2C-access.patch%3CBR%20%2F%3E%20MAX9271%20I2C%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AB%E3%83%AA%E3%83%88%E3%83%A9%E3%82%A4%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E0007-Max9286-Add-support-for-OV10635-camera.patch%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20OV10635%E3%82%AB%E3%83%A1%E3%83%A9%E7%94%A8%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E0008-Max9286-support-auto-detect-camera-number.patch%3CBR%20%2F%3E%20Max9286%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%82%AB%E3%83%A1%E3%83%A9%E7%95%AA%E5%8F%B7%E3%82%92%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E6%A4%9C%E5%87%BA%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EMAX9286%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%96%B9%E6%B3%95%3A%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20make%20imx_v7_defconfig%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20make%20menuconfig%20(%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81MAX9286%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84)%3A%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Device%20Drivers%26nbsp%3B%20---%26gt%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26lt%3B*%26gt%3B%20%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%26nbsp%3B%20---%26gt%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%26nbsp%3B%26nbsp%3B%20V4L%20platform%20devices%26nbsp%3B%20---%26gt%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26lt%3B*%26gt%3B%26nbsp%3B%26nbsp%3B%20MXC%20Video%20For%20Linux%20Video%20Capture%3C%2FP%3E%0A%3CP%3EMXC%20%E3%82%AB%E3%83%A1%E3%83%A9%2FV4L2%20PRP%20%E6%A9%9F%E8%83%BD%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%26nbsp%3B%20---%26gt%3B%3C%2FP%3E%0A%3CP%3E%26lt%3B*%26gt%3BMaxim%20max9286%20GMSL%20%E3%83%87%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%A9%E3%82%A4%E3%82%B6%E5%85%A5%E5%8A%9B%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FP%3E%0A%3CP%3E%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%82%92%E9%81%B8%E6%8A%9E%EF%BC%88OmniVision%20OV10635%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%EF%BC%89%E3%81%BE%E3%81%9F%E3%81%AF%EF%BC%88Onsemi%20AP0101%E3%81%8A%E3%82%88%E3%81%B3AR0140%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%EF%BC%89%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26lt%3B*%26gt%3Bmxc%20VADC%20support%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26lt%3B*%26gt%3BSelect%20Overlay%20Rounting%20(Queue%20ipu%20device%20for%20overlay%20library)%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26lt%3B*%26gt%3BPre-processor%20Encoder%20library%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26lt%3B*%26gt%3BIPU%20CSI%20Encoder%20library)%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20make%20zImage%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20make%20dtbs%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E5%BE%8C%E3%81%AB%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%82%8B%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%3C%2FP%3E%0A%3CP%3Earch%2Farm%2Fboot%2Fdts%2Fimx6q-sabreauto.dtb%3C%2FP%3E%0A%3CP%3Earch%2Farm%2Fboot%2FzImage%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%22mxc_v4l2_tvin_max9286.tar.gz%22%E3%81%AF%E3%83%86%E3%82%B9%E3%83%88%E7%94%A8%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%99%E3%80%824%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%97%E3%80%811080P%20HDMI%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%3C%2FP%3E%0A%3CP%3E%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20960%20-oh%20540%20-d%201%20-x%200%20-g2d%20%26amp%3B%3C%2FP%3E%0A%3CP%3E%2Fmxc_v4l2_tvin.out%20-ol%20960%20-ot%200%20-ow%20960%20-oh%20540%20-d%201%20-x%201%20-g2d%20%26amp%3B%3C%2FP%3E%0A%3CP%3E%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%20540%20-ow%20960%20-oh%20540%20-d%201%20-x%202%20-g2d%20%26amp%3B%3C%2FP%3E%0A%3CP%3E%2Fmxc_v4l2_tvin.out%20-ol%20960%20-ot%20540%20-ow%20960%20-oh%20540%20-d%201%20-x%203%20-g2d%20%26amp%3B%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EAR0140%2BAP0101%2BMAX9271%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E4%B8%8A%E3%81%AE%E7%A2%BA%E8%AA%8D%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%EF%BC%88MAX9286%E3%81%8A%E3%82%88%E3%81%B3OV10635%E3%81%AE%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%81%AFMaxim%E3%81%8B%E3%82%89%E5%85%A5%E6%89%8B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%89%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E1.%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E3%81%AF%E3%80%81MAX9286%E3%81%AEI2C%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF0x4D%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81ADD0%E3%81%8A%E3%82%88%E3%81%B3ADD1%E3%81%AFHigh%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EAP0101%E3%81%AEI2C%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF0xBA%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81SADDR%E3%81%AFHigh%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E2.%20AP0101%E3%81%AEDOUT0%EF%BD%9EDOUT7%E3%81%AF%E3%80%81MAX9271%E3%81%AEDIN7%EF%BD%9EDIN0%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%8E%A5%E7%B6%9A%E9%A0%86%E3%81%AF%E5%8F%8D%E8%BB%A2%E3%81%95%E3%81%9B%E3%80%81MSB%E3%82%92LSB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E3.%20MAX9271%E3%81%AEGPO%E3%83%94%E3%83%B3%E3%81%AF%E3%80%81AP0101%E3%81%AEFRAME_SYNC%E3%83%94%E3%83%B3%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82FRAME_SYNC%E3%83%94%E3%83%B3%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E6%8A%B5%E6%8A%97%E3%81%AF%E3%80%810%CE%A9%E3%81%AB%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E6%97%A2%E7%9F%A5%E3%81%AE%E5%88%B6%E9%99%90%E4%BA%8B%E9%A0%85%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E1.%20AP0101%E3%81%AEVSYNC%E7%84%A1%E5%8A%B9%E6%9C%9F%E9%96%93%E3%81%AB%E3%81%8A%E3%81%84%E3%81%A6%E3%80%81%E6%9C%80%E7%B5%82%E3%83%93%E3%83%87%E3%82%AA%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AEHSYNC%E3%81%8B%E3%82%89VSYNC%E3%81%BE%E3%81%A7%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%81%E3%81%AE%E6%9C%80%E5%A4%A7%E5%80%A4%E3%81%AF255%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%81%93%E3%82%8C%E3%81%AFMAX9286%E3%81%8C%E5%90%84%E3%82%AB%E3%83%A1%E3%83%A9%E7%94%A8%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%82%A8%E3%83%B3%E3%83%89MIPI%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E4%B8%8D%E5%8D%81%E5%88%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81iMX6DQ%E3%81%8C%E5%90%84%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE1280%C3%97720%E6%98%A0%E5%83%8F%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81AP0101%E3%81%AB%E3%81%AF1280%C3%97724%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%95%E3%81%9B%E3%80%81iMX6%E3%81%AF%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1720%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E3%81%BF%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%99%E3%82%8B%E6%A7%8B%E6%88%90%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%AE%8B%E3%82%8A%E3%81%AE%E6%98%A0%E5%83%8F%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8A%E3%82%88%E3%81%B3%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%82%A8%E3%83%B3%E3%83%89%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%82%92%E4%B8%8E%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81iMX6%20%E3%81%AE%20MIPI_CSI_ERR1%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E3%81%AF%22%3CSPAN%20style%3D%22font-family%3A%20HelveticaLTStd-Roman%3B%20font-size%3A%209pt%3B%20mso-fareast-font-family%3A%20%E5%AE%8B%E4%BD%93%3B%20mso-fareast-theme-font%3A%20minor-fareast%3B%20mso-ansi-language%3A%20EN-US%3B%20mso-fareast-language%3A%20ZH-CN%3B%20mso-bidi-language%3A%20AR-SA%3B%20mso-bidi-font-family%3A%20'Times%20New%20Roman'%3B%22%3EError%20matching%20Frame%20Start%20with%20Frame%20End%20for%20Virtual%20Channel%20x%EF%BC%88%E4%BB%AE%E6%83%B3%E3%83%81%E3%83%A3%E3%83%8D%E3%83%ABx%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E9%96%8B%E5%A7%8B%E3%81%A8%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E7%B5%82%E4%BA%86%E3%81%AE%E4%B8%8D%E4%B8%80%E8%87%B4%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%89%3C%2FSPAN%3E%22%E3%81%8C%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EMaxim%20%E3%81%AF%E3%80%81MAX9271%20%E3%82%92%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%20MAX96705%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%8F%90%E6%A1%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81VSYNC%20%E7%84%A1%E5%8A%B9%E6%99%82%E9%96%93%E3%82%92%E9%81%85%E3%82%89%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%80%81MIPI%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E4%BF%AE%E6%AD%A3%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E2015%E5%B9%B411%E6%9C%8817%E6%97%A5%E6%9B%B4%E6%96%B0%EF%BC%9AOV10635%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EFile%3A%20L3.10.53_GA1.1.0_MAX9286_Surroundview_Patch_2015-11-17.zip%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E2015-12-04%20update%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EFile%3A%20L3.10.53_GA1.1.0_MAX9286_Surroundview_Patch_2015-12-04.zip%3C%2FP%3E%0A%3CP%3EOV10635%E3%81%AEPCLK%E3%82%A8%E3%83%83%E3%82%B8%E8%A8%AD%E5%AE%9A%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%83%91%E3%83%83%E3%83%810009-Max9286-updated-PCLK-edge-setting-for-OV10635.patch%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E2016-03-07%20update%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20L3.14.38_GA_MAX9286_Surroundview_Patch_2016-03-07.zip%3C%2FP%3E%0A%3CP%3EL3.14.38%20GA%201.1.0%20BSP%E7%94%A8%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E2016-07-26%20update%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EFiles%3A%20L3.10.53_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip%3B%20L3.14.38_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip%3B%20L3.14.52_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip.%3C%2FP%3E%0A%3CP%3EGStreamer%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3EMAX96705%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3EL3.14.52_GA1.1.0%20%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E2017-12-11%20update%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3ECVBS%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%B8%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-335803%22%20data-objecttype%3D%22102%22%20target%3D%22_blank%22%3EiMX6DQ%20TP2854%20MIPI%20CSI2%20720P%20CVBS%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%BB%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%BB%E3%83%93%E3%83%A5%E3%83%BC%E3%83%BB%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%EF%BC%88Linux%20BSP%E7%94%A8%EF%BC%89%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E2021-04-26%26nbsp%3Bupdate%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E4%B8%80%E9%83%A8%E3%81%AE%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8B%E3%82%89%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E8%B2%A0%E8%8D%B7%E3%81%8C%E9%AB%98%E3%81%84%E7%8A%B6%E6%B3%81%E4%B8%8B%E3%81%A7%E3%80%81%E7%89%B9%E5%AE%9A%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8C%E5%B7%A6%E5%8F%B3%E3%81%AB%E3%81%A1%E3%82%89%E3%81%A4%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AFSFMC%E3%81%AEFIFO%E3%83%87%E3%83%BC%E3%82%BF%E6%90%8D%E5%A4%B1%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%99%E3%80%82%E5%85%83%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E3%81%AF%E3%80%811%E3%81%A4%E3%81%AEIPU%E4%B8%8A%E3%81%A72%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6IDMAC%200%E3%81%8A%E3%82%88%E3%81%B3IDMAC%201%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E6%9C%80%E9%81%A9%E3%81%AA%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3EIDMAC%201%E3%81%AF1%2F4%E3%81%AESMFC%20FIFO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%9B%BA%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%9D%E3%81%AE%E5%BD%B1%E9%9F%BF%E3%81%A7IDMAC%200%E3%82%821%2F4%E3%81%AESMFC%20FIFO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E6%AE%8B%E3%82%8A1%2F2%E3%81%AESMFC%20FIFO%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22qiang_li-mpu_se_0-1619426236653.png%22%20style%3D%22width%3A%20733px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22qiang_li-mpu_se_0-1619426236653.png%22%20style%3D%22width%3A%20733px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F143217i8EDD1960CA9C3699%2Fimage-dimensions%2F733x303%3Fv%3Dv2%22%20width%3D%22733%22%20height%3D%22303%22%20role%3D%22button%22%20title%3D%22qiang_li-mpu_se_0-1619426236653.png%22%20alt%3D%22qiang_li-mpu_se_0-1619426236653.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%94%B9%E5%96%84%E3%81%AB%E5%90%91%E3%81%91%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E6%9B%B4%E6%96%B0%3A%3C%2FP%3E%0A%3CP%3E%E5%90%84IPU%E3%81%A72%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AFIDMAC%200%E3%81%8A%E3%82%88%E3%81%B3IDMAC%202%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3CBR%20%2F%3E%3CFONT%20color%3D%22%230000FF%22%3E%E3%81%93%E3%81%AE%E4%BD%9C%E6%A5%AD%E3%81%AB%E3%81%AF%E3%80%81%22drivers%5Cmedia%5Cplatform%5Cmxc%5Ccapture%5Cipu_csi_enc.c%22%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%B3%E3%83%BC%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%230000FF%22%3E%22CSI_MEM1%22%E3%81%8A%E3%82%88%E3%81%B3%22IPU_IRQ_CSI1_OUT_EOF%22%E3%82%92%22CSI_MEM2%22%E3%81%8A%E3%82%88%E3%81%B3%22IPU_IRQ_CSI2_OUT_EOF%22%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AESMFC%20FIFO%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%22%20ipu_common.c%22%E3%81%AEipu_probe()%E9%96%A2%E6%95%B0%E5%86%85%E3%81%AB%E3%81%82%E3%82%8B%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%82%E3%80%81IDMAC2%E3%81%8C%E9%AB%98%E5%84%AA%E5%85%88%E5%BA%A6%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CFONT%20color%3D%22%230000FF%22%3E%2F*%20%E5%90%8C%E6%9C%9F%E3%83%AA%E3%83%95%E3%83%AC%E3%83%83%E3%82%B7%E3%83%A5%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%A8CSI-%26gt%3B%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E9%AB%98%E5%84%AA%E5%85%88%E5%BA%A6%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%20*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%230000FF%22%3E-%20ipu_idmac_write(ipu%2C%200x18800003L%2C%20IDMAC_CHA_PRI(0))%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%230000FF%22%3E%2B%20ipu_idmac_write(ipu%2C%200x1880000FL%2C%20IDMAC_CHA_PRI(0))%3B%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1116501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A8%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%20style%3D%22color%3A%20%23212121%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20white%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3EHi%20Qiang%20Li%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23212121%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20white%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23212121%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20white%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%E6%B7%B7%E4%B9%B1%E3%82%92%E6%8B%9B%E3%81%84%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%80%81%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%8D%98%E4%B8%80%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8C%E3%82%AE%E3%82%B6%E3%82%AE%E3%82%B6%E7%8A%B6%E3%81%AE%E8%A1%A8%E7%A4%BA%E4%B8%8D%E5%85%B7%E5%90%88%E3%82%92%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8C%E6%8F%8F%E7%94%BB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%A8%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23212121%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20font-family%3A%20Calibri%2C%20sans-serif%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23212121%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20white%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%23gst-launch-1.0%20-v%20-e%20imxv4l2videosrc%20device%3D%2Fdev%2Fvideo2%20!%20imxg2dvideosink%20framebuffer%3D%2Fdev%2Ffb0%20force-aspect-ratio%3Dfalse%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23212121%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20white%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23212121%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20white%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%E7%8F%BE%E5%9C%A8%E3%80%814%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E6%98%A0%E5%83%8F%E3%82%921%E3%81%A4%E3%81%AE%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AB%E6%8F%8F%E7%94%BB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81GStreamer%E3%82%92%E7%94%A8%E3%81%84%E3%81%9F%E6%A4%9C%E8%A8%BC%E3%82%92%E9%80%B2%E3%82%81%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23212121%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20white%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22color%3A%20%23212121%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20white%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%E3%81%A9%E3%81%86%E3%81%9E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116732%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116732%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%94%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8A%E3%82%8A%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%99%E3%80%8260fps%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A7%E3%81%AF%E3%80%81PAN%E8%A1%A8%E7%A4%BA%E3%81%AE%E6%9C%80%E5%A4%A7%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%E3%82%8260%20fps%E3%81%AB%E5%88%B6%E9%99%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%814%E5%8F%B0%E3%81%AE720P30%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E5%80%8B%E5%88%A5%E3%81%AB%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%90%88%E8%A8%88%E3%81%A7120%20fps%E3%81%A8%E3%81%AA%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E6%AD%A3%E3%81%97%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%824%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E6%98%A0%E5%83%8F%E3%82%92%E3%81%BE%E3%81%A8%E3%82%81%E3%81%A6%E3%81%8B%E3%82%89%E3%80%81%E4%B8%80%E5%BA%A6%E3%81%AB%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%AD%E3%82%B0%E3%81%AB%E3%81%AF%E3%83%A1%E3%83%A2%E3%83%AA%E4%B8%8D%E8%B6%B3%E3%81%8C%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82GPU%E7%94%A8%E3%81%AB%E3%82%88%E3%82%8A%E5%A4%9A%E3%81%8F%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E7%A2%BA%E4%BF%9D%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%20vertical-align%3A%20inherit%3B%22%3EHi%20Qiang%20Li%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E4%BB%A5%E4%B8%8B%E3%81%AE2%E3%81%A4%E3%81%AE%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E3%80%81%E5%8D%98%E4%BD%93%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3Egst-launch-1.0-v%20-e%20imxv4l2videosrc%20device%3D%2Fdev%2Fvideo0%20!imxg2dvideosink%20framebuffer%3D%2Fdev%2Ffb0%20force-aspect-ratio%3Dfalse%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3Egst-launch-1.0-v%20-e%20imxv4l2videosrc%20device%3D%2Fdev%2Fvideo1%20!imxg2dvideosink%20framebuffer%3D%2Fdev%2Ffb0%20force-aspect-ratio%3Dfalse%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%90%84%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%EF%BC%88%E7%89%B9%E3%81%ABvideo3%EF%BC%89%E3%81%AF%E3%80%81%E5%88%A5%E3%80%85%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E6%B7%BB%E4%BB%98%E3%81%AEgif%E3%81%AB%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%81%AE%E3%81%93%E3%81%8E%E3%82%8A%E7%8A%B6%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22color%3A%20%233d3d3d%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3Egst-launch-1.0-v%20-e%20imxv4l2videosrc%20device%3D%2Fdev%2Fvideo2%20!imxg2dvideosink%20framebuffer%3D%2Fdev%2Ffb0%20force-aspect-ratio%3Dfalse%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3Egst-launch-1.0-v%20-e%20imxv4l2videosrc%20device%3D%2Fdev%2Fvideo3%20!imxg2dvideosink%20framebuffer%3D%2Fdev%2Ffb0%20force-aspect-ratio%3Dfalse%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.gif%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.gif%22%20style%3D%22width%3A%20600px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F114452iFEAC8ADBC91DC931%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.gif%22%20alt%3D%22pastedImage_2.gif%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%E4%B8%80%E6%96%B9%E3%80%81%E3%83%84%E3%82%A4%E3%83%B3%E3%82%A2%E3%83%97%E3%83%AA%E3%81%AF%E5%90%84%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E5%95%8F%E9%A1%8C%E3%82%92%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3EGStreamer%E3%81%AE%E4%BD%BF%E7%94%A8%E6%99%82%E3%81%AB%E3%80%81%E3%81%93%E3%81%86%E3%81%97%E3%81%9F%E7%8A%B6%E6%B3%81%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%A8%E3%81%AA%E3%82%8A%E5%BE%97%E3%82%8B%E3%82%82%E3%81%AE%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%93%E3%82%8C%E3%81%AFGStreamer%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82IPU2%E3%81%AB%E9%96%A2%E4%BF%82%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EGStreamer%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A64%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E5%90%8C%E6%99%82%E3%81%AB%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%924%E5%9B%9E%E7%B5%90%E5%90%88%E3%81%97%E3%80%81%E3%81%95%E3%82%89%E3%81%AB4%E5%9B%9E%E3%82%B9%E3%83%AF%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%82%92%E4%B8%8E%E3%81%88%E3%81%BE%E3%81%99%E3%80%82tvin%E3%83%86%E3%82%B9%E3%83%88%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E6%98%A0%E5%83%8F%E3%82%92%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AB%E7%9B%B4%E6%8E%A5%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B9%E3%83%AF%E3%83%83%E3%83%97%E3%81%AF%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81%E3%82%AE%E3%82%B6%E3%82%AE%E3%82%B6%E7%8A%B6%E3%81%AE%E8%A1%A8%E7%A4%BA%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E3%82%82%E6%9C%9B%E3%81%BE%E3%81%97%E3%81%84%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%814%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E6%98%A0%E5%83%8F%E3%82%921%E3%81%A4%E3%81%AE%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AB%E6%8F%8F%E7%94%BB%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%82%921%E5%9B%9E%E3%81%AE%E3%82%B9%E3%83%AF%E3%83%83%E3%83%97%E3%81%A7%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AB%E5%8F%8D%E6%98%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EHi%20Qiang%20Li%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EImx6qp%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EWIDTH%3D640%3CBR%20%2F%3EHEIGHT%3D240%3CBR%20%2F%3E.%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20%24%7BWIDTH%7D%20-oh%20%24%7BHEIGHT%7D%20-d%200%20-x%200%20-g2d%20%26amp%3B%3CBR%20%2F%3E.%2Fmxc_v4l2_tvin.out%20-ol%20%24%7BWIDTH%7D%20-ot%200%20-ow%20%24%7BWIDTH%7D%20-oh%20%24%7BHEIGHT%7D%20-d%200%20-x%201%20-g2d%20%26amp%3B%3CBR%20%2F%3E.%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%20%24%7BHEIGHT%7D%20-ow%20%24%7BWIDTH%7D%20-oh%20%24%7BHEIGHT%7D%20-d%200%20-x%202%20-g2d%20%26amp%3B%3CBR%20%2F%3E.%2Fmxc_v4l2_tvin.out%20-ol%20%24%7BWIDTH%7D%20-ot%20%24%7BHEIGHT%7D%20-ow%20%24%7BWIDTH%7D%20-oh%20%24%7BHEIGHT%7D%20-d%200%20-x%203%20-g2d%20%26amp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F114357i7D5C1A40743AC888%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.jpg%22%20alt%3D%22pastedImage_1.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7GStreamer%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%813%E5%8F%B0%E7%9B%AE%E3%81%8A%E3%82%88%E3%81%B34%E5%8F%B0%E7%9B%AE%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E6%98%A0%E5%83%8F%E3%81%AB%E3%82%B8%E3%83%83%E3%82%BF%E3%82%84%E3%82%B9%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWINDOW1%3D%22window-x-coord%3D0%20window-y-coord%3D0%20window-width%3D%24%7BWIDTH%7D%20window-height%3D%24%7BHEIGHT%7D%22%3CBR%20%2F%3EWINDOW2%3D%22window-x-coord%3D%24%7BWIDTH%7D%20window-y-coord%3D0%20window-width%3D%24%7BWIDTH%7D%20window-height%3D%24%7BHEIGHT%7D%22%3CBR%20%2F%3EWINDOW3%3D%22window-x-coord%3D0%20window-y-coord%3D%24%7BHEIGHT%7D%20window-width%3D%24%7BWIDTH%7D%20window-height%3D%24%7BHEIGHT%7D%22%3CBR%20%2F%3EWINDOW4%3D%22window-x-coord%3D%24%7BWIDTH%7D%20window-y-coord%3D%24%7BHEIGHT%7D%20window-width%3D%24%7BWIDTH%7D%20window-height%3D%24%7BHEIGHT%7D%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Egst-launch-1.0-v%20-e%20imxv4l2videosrc%20device%3D%2Fdev%2Fvideo0%20!imxg2dvideosink%20framebuffer%3D%2Fdev%2Ffb0%20force-aspect-ratio%3Dfalse%20%24WINDOW1%20%26amp%3Bgst-launch-1.0-v%20-e%20imxv4l2videosrc%20device%3D%2Fdev%2Fvideo1%20!imxg2dvideosink%20framebuffer%3D%2Fdev%2Ffb0%20force-aspect-ratio%3Dfalse%20%24WINDOW2%20%26amp%3Bgst-launch-1.0-v%20-e%20imxv4l2videosrc%20device%3D%2Fdev%2Fvideo2%20!imxg2dvideosink%20framebuffer%3D%2Fdev%2Ffb0%20force-aspect-ratio%3Dfalse%20%24WINDOW3%20%26amp%3Bgst-launch-1.0-v%20-e%20imxv4l2videosrc%20device%3D%2Fdev%2Fvideo3%20!imxg2dvideosink%20framebuffer%3D%2Fdev%2Ffb0%20force-aspect-ratio%3Dfalse%20%24WINDOW4%20%26amp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.gif%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.gif%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F114358iD7BDF0F348BD58C6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.gif%22%20alt%3D%22pastedImage_1.gif%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3EV4L%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81GStreamer%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AE%E3%81%BF%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E4%B8%8D%E5%85%B7%E5%90%88%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E4%BB%B6%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E4%BD%95%E3%81%8B%E6%80%9D%E3%81%84%E5%BD%93%E3%81%9F%E3%82%8B%E5%8E%9F%E5%9B%A0%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116726%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116726%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%94%E3%83%B3%E3%81%AE%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AF%E4%BD%8E%E3%81%84%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%200x27%20%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%207%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%A8%201%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20841px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F114285i52DBBA6FB9A56961%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%82%E7%95%B0%E5%B8%B8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116725%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116725%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EMAX9286%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%E3%83%94%E3%83%B3%E3%81%8C%E3%83%8F%E3%82%A4%E3%83%AC%E3%83%99%E3%83%AB%E3%82%92%E7%B6%AD%E6%8C%81%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E4%BF%A1%E5%8F%B7%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AB%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81MIPI%20CSI2%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AFiMX6%E3%81%A8%E3%81%AF%E9%96%A2%E4%BF%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116724%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116724%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BB%8A%E3%80%81%E7%A7%81%E3%81%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%83%94%E3%83%B3%E3%81%8C%E5%B8%B8%E3%81%AB%E4%BD%8E%E3%81%8F%E3%80%81%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D%E3%82%82%E4%BD%8E%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Emax9286%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%8C%E8%AA%BF%E6%95%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%8A%B9%E6%9E%9C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eimx6%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116723%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116723%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EMAX9286%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%E3%83%94%E3%83%B3%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82MIPI%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%9F%E5%87%BA%E5%8A%9B%E3%82%92%E7%A2%BA%E4%BF%9D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E5%B8%B8%E3%81%AB%E3%83%8F%E3%82%A4%E3%83%AC%E3%83%99%E3%83%AB%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%A8MAX9286%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%83%8F%E3%82%A4%E3%83%AC%E3%83%99%E3%83%AB%E3%82%92%E5%B8%B8%E3%81%AB%E7%B6%AD%E6%8C%81%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAP0101%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E7%B5%90%E6%9E%9C%E3%81%8B%E3%82%89%E3%80%81MAX9286%E3%82%92%E6%89%8B%E5%8B%95%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%E8%A8%AD%E5%AE%9A%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF0x08%E3%82%92%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23ifdef%20SENSOR_AP0101%3CBR%20%2F%3E%26nbsp%3B%2F%2FManual%20Mode%3CBR%20%2F%3E%26nbsp%3Bmax9286_write_reg(0x01%2C%200x00)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3Bmax9286_write_reg(0x63%2C%200x00)%3B%3CBR%20%2F%3E%26nbsp%3Bmax9286_write_reg(0x64%2C%200x00)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3Bmax9286_write_reg(0x06%2C%200x00)%3B%3CBR%20%2F%3E%26nbsp%3Bmax9286_write_reg(0x07%2C%200x00)%3B%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%26nbsp%3Bmax9286_write_reg(0x08%2C%200x26)%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%23endif%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116722%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116722%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E6%84%9F%E5%85%89%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AF%20AP0143%20%E3%81%A7%E3%81%99%E3%80%82%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E4%BB%A5%E5%89%8D%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E8%A4%87%E6%95%B0%E3%81%AE%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%A7%E7%94%BB%E5%83%8F%E3%82%92%E7%94%9F%E6%88%90%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AF%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E5%90%8C%E6%9C%9F%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%20320%20%E8%A1%8C%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%97%E3%80%813%20%E3%81%A4%E3%81%AE%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B9%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E6%B0%B4%E5%B9%B3%E3%83%90%E3%83%BC%E3%81%A8%E3%82%B8%E3%83%83%E3%82%BF%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116721%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116721%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%22240238%22%20data-username%3D%22%E4%BD%B3%E6%9D%B0%E5%90%B4%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2F%E4%BD%B3%E6%9D%B0%E5%90%B4%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%230066cc%3B%20text-decoration%3A%20underline%3B%22%3E%E3%82%A6%E3%83%BC%E3%83%BB%E3%82%B8%E3%82%A2%E3%82%B8%E3%82%A8%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%97%A2%E8%A3%BD%E3%81%AE%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E8%B3%BC%E5%85%A5%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AF%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%8C%E4%BB%98%E5%B1%9E%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E5%8B%95%E4%BD%9C%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5ROM%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82MAX9286%E3%81%A7%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E5%90%8C%E6%9C%9F%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%A6%E3%82%82%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E4%B8%80%E9%83%A8%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%EF%BC%88AP0101%2BAR0130%E3%81%AA%E3%81%A9%EF%BC%89%E3%81%A7%E3%81%AF%E3%80%81%E6%9C%80%E7%B5%82%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AEHSYNC%E3%81%8B%E3%82%89VSYNC%E3%81%BE%E3%81%A7%E3%81%AE%E6%99%82%E9%96%93%E3%81%8C255%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E6%9C%AA%E6%BA%80%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E3%82%82%E5%95%8F%E9%A1%8C%E3%82%92%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%99%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81IPU%20CSI%E3%81%8C%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%99%E3%82%8B%E3%83%87%E3%83%BC%E3%82%BF%E3%83%A9%E3%82%A4%E3%83%B3%E6%95%B0%E3%81%8C%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81720%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E5%85%A5%E5%8A%9B%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E3%80%81IPU%20CSI%E3%81%AF712%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%97%E3%81%8B%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116720%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116720%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHI%20Liqiang%3A%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81%3C%2FP%3E%3CP%3Eimx6d%20%2B%20max9286%20%2B%20max96705%20%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A63%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E5%90%8C%E6%99%82%E3%81%AB%E3%83%97%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%822%E5%8F%B0%E3%81%BE%E3%81%9F%E3%81%AF3%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%97%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E7%94%BB%E9%9D%A2%E3%81%8C%E6%8F%BA%E3%82%8C%E3%81%9F%E3%82%8A%E5%9B%9E%E8%BB%A2%E3%81%97%E3%81%9F%E3%82%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%201%20%E5%8F%B0%E3%81%A0%E3%81%91%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8C%E6%99%AE%E9%80%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8C%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E5%90%8C%E6%9C%9F%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%20Maxim%20FAE%20%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E8%B3%AA%E5%95%8F%E3%82%92%E3%81%9A%E3%81%A3%E3%81%A8%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116718%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116718%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E7%A7%81%E3%81%AF2%E3%81%A4%E3%81%AEIC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%20adv7181d%20(%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3A%20BT1120)%20%E3%81%A8%20nextchip%20(N4)%3C%2FP%3E%3CP%3Eadv7180%20%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ev4l2_cap_0%20%7B%3CBR%20%2F%3E%20compatible%20%3D%20%22fsl%2Cimx6q-v4l2-capture%22%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bipu_id%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bcsi_id%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bmclk_source%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bstatus%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eadv7180%3A%20adv7180%4021%20%7B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bcompatible%20%3D%20%22adv%2Cadv7180%22%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Breg%20%3D%20%26lt%3B0x21%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bpinctrl-names%20%3D%20%22default%22%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bpinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_ipu1_2%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bclocks%20%3D%20%26lt%3B%26amp%3Bclks%20IMX6QDL_CLK_CKO%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bclock-names%20%3D%20%22csi_mclk%22%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bpwn-gpios%20%3D%20%26lt%3B%26amp%3Bgpio1%204%200%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Breset-gpios%20%3D%20%26lt%3B%26amp%3Bgpio3%2016%20GPIO_ACTIVE_HIGH%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bipu_id%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bcsi_id%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bmclk%20%3D%20%26lt%3B24000000%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bmclk_source%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bcvbs%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ENextchip%20(N4)%20%E3%81%AF%204%20%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AF%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1%202%20%E5%8F%B0%E3%81%AE%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%81%AF%20720p%20%E3%81%A7%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Emipi-csi2-channel%402%20%7B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bipu_id%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bcsi_id%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bv_channel%20%3D%20%26lt%3B2%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bstatus%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3Emipi-csi2-channel%403%20%7B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bipu_id%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bcsi_id%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bv_channel%20%3D%20%26lt%3B3%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bstatus%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E----------------------------------------------------------------------%3C%2FP%3E%3CP%3Ev4l2_cap_1%20%7B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bcompatible%20%3D%20%22fsl%2Cimx6q-v4l2-capture%22%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bipu_id%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bcsi_id%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bmclk_source%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bstatus%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20v4l2_cap_2%20%7B%3CBR%20%2F%3E%20compatible%20%3D%20%22fsl%2Cimx6q-v4l2-capture%22%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bipu_id%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bcsi_id%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bmclk_source%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bstatus%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%813%20%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E7%94%BB%E5%83%8F%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%20%3CSPAN%3Eipu_id%20%3D%20%26lt%3B1%26gt%3B%3B%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3Ecsi_id%20%3D%20%26lt%3B1%26gt%3B%3B%20%E9%80%94%E4%B8%AD%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%A7%E6%92%AE%E5%BD%B1%E3%81%97%E3%81%9F%E7%94%BB%E5%83%8F%E3%81%8C%E3%81%A1%E3%82%89%E3%81%A4%E3%81%8D%E3%80%81%E7%94%BB%E5%83%8F%E3%81%AB%E6%AC%A0%E9%99%A5%E3%81%8C%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%E3%81%A1%E3%82%89%E3%81%A4%E3%81%8D%E3%81%AE%E3%81%AA%E3%81%84%E7%94%BB%E5%83%8F%E3%82%92%E9%96%8B%E3%81%8F%E3%81%AB%E3%81%AF%E3%80%81mxc-v4l2-tvin%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emxc-v4l2-tvin%26nbsp%3B%20-ol%200%20-ot%200%20-ow%201280%20-oh%20800%20-d%201%20-x%202%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EHAL%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%AF%E3%80%81%E5%90%84%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E5%80%8B%E5%88%A5%E3%81%AB%E9%96%8B%E3%81%8F%E3%81%9F%E3%82%81%E3%81%AE%E3%83%87%E3%83%A2%E3%81%8C%E8%A8%98%E8%BF%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82video2%20(ipu_id%20%3D%20%26lt%3B1%26gt%3B%3B%20%E3%82%92%E9%96%8B%E3%81%8F%E3%81%A8%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3Ecsi_id%20%3D%20%26lt%3B1%26gt%3B%3B%3C%2FSPAN%3E%20%EF%BC%89%E3%80%81%E7%94%BB%E9%9D%A2%E3%81%8C%E3%81%A1%E3%82%89%E3%81%A4%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%A9%E3%81%93%E3%81%8B%E3%82%89%E5%88%86%E6%9E%90%E3%82%92%E5%A7%8B%E3%82%81%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%AE%E3%81%8B%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BD%95%E3%81%8B%E8%89%AF%E3%81%84%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%86%99%E7%9C%9F%E3%82%92%E6%92%AE%E3%82%8B%E3%81%A8%E3%80%81%E3%81%A1%E3%82%89%E3%81%A4%E3%81%8D%E3%82%84%E6%96%AD%E7%B7%9A%E7%8F%BE%E8%B1%A1%E3%81%8C%E3%81%86%E3%81%BE%E3%81%8F%E6%8D%89%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82MP4%E5%BD%A2%E5%BC%8F%E3%81%A7%E5%8B%95%E7%94%BB%E3%82%92%E6%92%AE%E5%BD%B1%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E6%99%82%E3%81%AB%E3%80%8C%E3%81%93%E3%81%AE%E5%BD%A2%E5%BC%8F%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%A9%E3%81%AE%E5%BD%A2%E5%BC%8F%E3%81%AE%E5%8B%95%E7%94%BB%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDear%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%E3%81%99%E3%81%BF%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E5%B0%91%E3%81%97%E6%B7%B7%E4%B9%B1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%8A%E3%81%A3%E3%81%97%E3%82%83%E3%81%A3%E3%81%9F%E3%82%88%E3%81%86%E3%81%ABi.MX6Q%E3%81%AF%E6%9C%80%E5%A4%A74%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%82%88%E3%81%AD%EF%BC%9F%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E4%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E-%201xCSI%2C%203xMIPI%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E-%202xCSI%2C%202xMIPI%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E-%204xMIPI%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E1x%20%3CSTRONG%3ECSI%3C%2FSTRONG%3E%E3%82%843x%26nbsp%3B%3CSTRONG%3EMIPI%3C%2FSTRONG%3E%E3%81%A8%E3%81%AF%E3%81%A9%E3%81%86%E3%81%84%E3%81%86%E6%84%8F%E5%91%B3%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%E9%80%9A%E5%B8%B8%E3%81%AF%3CSTRONG%3EMIPI%20CSI-2%3C%2FSTRONG%3E%E3%81%A8%E3%81%84%E3%81%86%E5%BD%A2%E3%81%A7%E4%B8%80%E7%B7%92%E3%81%AB%E8%A1%A8%E8%A8%98%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81CSI%E3%81%AFMIPI%20CSI-2%E3%81%A8%E5%90%8C%E3%81%98%E6%84%8F%E5%91%B3%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%81%A1%E3%81%AA%E3%81%BF%E3%81%AB%E3%80%81Imx6Q%E3%81%AF%E5%90%8C%E6%99%82%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%AEBT656%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E7%9B%B4%E6%8E%A5%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116712%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116712%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%820143%2B0101%2B96705%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%820143%E3%81%AE%E5%90%8C%E6%9C%9F%E3%81%AF%E7%A2%BA%E3%81%8B%E3%81%AB%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AE%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E5%85%A5%E5%8A%9B%E3%81%A7%E5%88%B6%E5%BE%A1%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81IMX225%E3%81%AB%E3%81%AF%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%83%94%E3%83%B3%E3%81%8C%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E3%81%AF%E3%80%81%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AFVS%E3%81%A8HS%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81FH8536%20ISP%E3%81%AF%E3%82%A2%E3%83%8A%E3%83%AD%E3%82%B0%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%8B%E3%81%AA%E3%81%8F%E3%80%8196705%E3%81%AF%E3%82%A2%E3%83%8A%E3%83%AD%E3%82%B0%E5%85%A5%E5%8A%9B%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82IMX225%2BFH8536%2BMAX96705%E3%81%AE%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE2%E3%81%A4%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8B%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116711%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116711%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E96705%E3%81%AB%E3%81%AF%E3%80%81%E5%90%8C%E6%9C%9F30Hz%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E4%BF%A1%E5%8F%B7%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%A7%E3%81%8D%E3%82%8BGPO%E3%83%94%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AE%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E5%85%A5%E5%8A%9B%E3%81%AB%E7%9B%B4%E6%8E%A5%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E5%90%8C%E6%9C%9F%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E5%90%8C%E6%99%82%E3%81%AB%E3%80%81%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AF%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Edezhijiang%40126.com%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116710%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116710%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E8%B3%AA%E5%95%8F%E3%81%95%E3%81%9B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%821.%20FH8536%E3%81%AF%E3%82%A2%E3%83%8A%E3%83%AD%E3%82%B0%E5%87%BA%E5%8A%9B%E3%81%AE%E3%81%BF%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%8196705%E3%81%A8%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F2.%20IMX225%2BFH8536%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%814%E3%81%A4%E3%81%AE%E3%83%AC%E3%83%B3%E3%82%BA%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E7%94%BB%E5%83%8F%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%90%8C%E6%9C%9F%E3%81%95%E3%81%9B%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%92%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20z%20dq%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8B%95%E4%BD%9C%E4%B8%8D%E5%AE%89%E5%AE%9A%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%922%E5%8F%B0%E4%BB%A5%E4%B8%8A%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%83%BB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EMAX96705%E3%81%AEGPO%E3%83%94%E3%83%B3%E3%81%AFAP0101%E3%81%AEFRAME_SYNC%E3%83%94%E3%83%B3%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%922%E5%8F%B0%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E28.463487%5D%20max9286_mipi%201-006a%3A%20ap0101_initialize%3A%20AP0101%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%2C%20reg%20%3D%200x0%E3%80%81index%20%3D%204%E3%80%82%3CBR%20%2F%3E%5B%2028.472625%5D%20max9286_mipi%201-006a%3A%20max9286_write_reg%3A%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3Areg%3D34%2Cval%3Db6%3CBR%20%2F%3E%5B%2028.673495%5D%20max9286_mipi%201-006a%3A%20max9271_write_reg%3A%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3Areg%3D%204%2Cval%3D83%3CBR%20%2F%3E%5B%2028.783553%5D%20max9286_mipi%201-006a%3A%20max9286_write_reg%3A%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3Areg%3D15%2Cval%3D9b%3CBR%20%2F%3E%5B%2029.403469%5D%20MIPI%20CSI2%E3%81%8C%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%81%20MIPI_CSI_PHY_STATE%20%3D%200x6f0%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116708%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116708%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81Liqiang%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Efps%E3%81%AE%E5%80%A4%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E6%8F%90%E4%BE%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E3%83%91%E3%83%83%E3%83%81%E3%81%A8%20i.MX6D%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%92%E7%94%A8%E3%81%84%E3%81%A6%E3%80%81%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%BB%E3%83%93%E3%83%A5%E3%83%BC%EF%BC%884%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%80%811280x720%EF%BC%89%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E5%8B%95%E4%BD%9C%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3EDDR%E3%81%AE%E5%B8%AF%E5%9F%9F%E5%B9%85%E3%81%AF%E5%8D%81%E5%88%86%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E4%B8%AD%E6%96%87%EF%BC%9A%3C%2FP%3E%3CP%3E-----------------%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B8%AApatch%E5%B9%B6%E8%B7%91%E5%9C%A8imx6d%E7%9A%84%E6%9D%BF%E5%AD%90%E4%B8%8A%EF%BC%8C%E7%9B%AE%E5%89%8Dsurroundview%EF%BC%88%E5%9F%BA%E4%BA%8E4%E4%B8%AA720p%E7%9A%84%E6%91%84%E5%83%8F%E5%A4%B4%EF%BC%89%E8%83%BD%E8%BE%BE%E5%88%B0%E5%A4%9A%E5%B0%91%E4%B8%AAfps%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%86%85%E5%AD%98%E5%B8%A6%E5%AE%BD%E5%A4%9F%E7%94%A8%E5%90%97%EF%BC%9F%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%3CSPAN%3E---------------%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116704%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116704%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%EF%BC%8C%20liqiang%3C%2FP%3E%3CP%3E%E8%87%AA%E5%88%86%E3%81%AE%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E7%92%B0%E5%A2%83%E3%81%A7%E3%81%AF%E3%82%A4%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%83%BB%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E3%81%94%E6%8F%90%E6%A1%88%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E3%82%B9%E3%83%AF%E3%83%83%E3%83%97%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%94%BB%E5%83%8F%E3%81%AE%E8%89%B2%E3%81%AB%E3%81%AF%E5%A4%89%E5%8C%96%E3%81%8C%E8%A6%8B%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AE%E8%A7%A3%E6%B6%88%E3%81%AB%E3%81%AF%E8%87%B3%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%EF%BC%88%E5%B8%96%E5%AD%90%E9%87%8C%E5%A5%BD%E5%83%8F%E5%B8%96%E4%B8%8D%E4%BA%86%E9%99%84%E4%BB%B6%EF%BC%8C%E5%8D%95%E7%8B%AC%E5%83%8F%E6%82%A8%E6%8F%90%E4%BA%86%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81%E7%8F%BE%E5%9C%A8%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AFLeopard%20Imaging%E3%81%AELI-USB30-OV10635-SER%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.leopardimaging.com%2Fuploads%2FLI-OV10635-SER_datasheet.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.leopardimaging.com%2Fuploads%2FLI-OV10635-SER_datasheet.pdf%3C%2FA%3E%3C%2FP%3E%3CP%3EUSB%203.0%E7%B5%8C%E7%94%B1%E3%81%A7PC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3EHi%20Qiang%20Li%EF%BC%9A%3C%2FP%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3EIMX6Q%E3%82%B3%E3%82%A2%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82GC2000%E3%81%A8GC320%E3%82%92%E5%90%8C%E6%99%82%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E7%94%BB%E9%9D%A2%E8%A1%A8%E7%A4%BA%E3%81%AB%E7%94%BB%E5%83%8F%E3%81%AE%E3%83%86%E3%82%A3%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%8C%E6%99%82%E6%8A%98%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20style%3D%22border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%20%2F%3E%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AA%E5%AE%9F%E8%A3%85%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20style%3D%22border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B4%E6%96%B9%E5%90%91%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%81%A7%E6%98%A0%E5%83%8F%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%80%81GPU%E4%B8%8A%E3%81%A7%E8%A1%A8%E7%A4%BA%E5%87%A6%E7%90%86%E3%82%92%E8%A1%8C%E3%81%84%E3%80%81LVDS%E7%94%BB%E9%9D%A2%E3%81%AB%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%81%A7%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%90%8C%E6%99%82%E3%81%AB%E3%80%81g2d%E3%81%8C4%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E5%88%86%E3%81%AE%E6%98%A0%E5%83%8F%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%80%81g2g_blit%E9%96%A2%E6%95%B0%E3%81%A7%E3%83%AA%E3%82%B5%E3%82%A4%E3%82%BA%E5%87%A6%E7%90%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%90%84%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%AF720P%E3%81%8B%E3%82%89640%C3%97480%E3%81%AB%E3%83%AA%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%95%E3%82%8C%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C1%E3%81%A4%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%AB%E5%90%88%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%824%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E5%88%86%E3%81%AE%E6%98%A0%E5%83%8F%E3%82%921%E3%81%A4%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E5%86%85%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E7%94%BB%E5%83%8F%E3%82%92%E5%90%88%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%90%88%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E6%98%A0%E5%83%8F%E3%81%AF%E7%94%BB%E9%9D%A2%E3%81%AB%E3%81%AF%E8%A1%A8%E7%A4%BA%E3%81%9B%E3%81%9A%E3%80%81%E7%9B%B4%E6%8E%A5%E3%83%93%E3%83%87%E3%82%AA%E3%81%A8%E3%81%97%E3%81%A6%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E7%8F%BE%E5%9C%A8%E3%80%81GPU%E3%81%A7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%81%AB%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%9F%E6%98%A0%E5%83%8F%E3%81%AB%E3%83%86%E3%82%A3%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%9F%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E5%86%8D%E7%94%9F%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E6%98%A0%E5%83%8F%E3%81%AB%E3%83%86%E3%82%A3%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%8C%E8%A6%8B%E3%82%89%E3%82%8C%E3%80%81%E8%A6%96%E8%81%B4%E3%81%AB%E6%94%AF%E9%9A%9C%E3%82%92%E3%81%8D%E3%81%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%20%3C%2FDIV%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3EGPU%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E8%A1%A8%E7%A4%BA%E3%82%92%E5%88%A5%E9%80%94%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%9F%E3%82%8A%E3%80%814%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%81%AE%E5%8B%95%E7%94%BB%E3%82%92G2D%E5%90%88%E6%88%90%E3%81%A7%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%9F%E3%82%8A%E3%81%99%E3%82%8C%E3%81%B0%E3%80%81%E7%94%BB%E5%83%8F%E3%81%AE%E3%83%86%E3%82%A3%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20style%3D%22border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%82%892%E3%81%A4%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%8C1%E3%81%A4%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E3%81%BE%E3%81%A8%E3%82%81%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E9%99%90%E3%82%8A%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E3%81%AE%E8%A1%A8%E7%A4%BA%E6%99%82%E3%81%A8%E4%BF%9D%E5%AD%98%E6%99%82%E3%81%AB%E7%94%BB%E5%83%8F%E3%81%AE%E3%83%86%E3%82%A3%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%20%3C%2FDIV%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E1.%20IMX6%E3%81%AEGC2000%E3%81%A8GC320%E3%81%AF%E5%90%8C%E6%99%82%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3FGPU%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%97%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20style%3D%22border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%20%2F%3E2.%20GPU%E3%81%A7%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E7%AB%B6%E5%90%88%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%99%E3%81%A7%E3%81%ABGC2000%E3%81%A8GC320%E3%81%AB%E3%83%96%E3%83%83%E3%83%95%E3%82%A7%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%95%E3%81%9B%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%812%E3%81%A4%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E7%B5%B1%E5%90%88%E3%81%97%E3%81%9F%E5%BE%8C%E3%82%82%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E3%81%AE%E3%83%86%E3%82%A3%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E6%AE%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%20%3C%2FDIV%3E%3CDIV%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%E7%A7%81%E3%81%AF%E6%95%B0%E9%80%B1%E9%96%93%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E6%82%A9%E3%81%BE%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E8%89%AF%E3%81%84%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%AF%E3%81%A8%E3%81%A6%E3%82%82%E4%B8%8D%E5%AE%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%EF%BC%9A%3C%2FP%3E%3CDIV%3EIMX6Q%E3%82%B3%E3%82%A2%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81GC2000%E3%81%A8GC320%E3%82%92%E5%90%8C%E6%99%82%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E7%94%BB%E9%9D%A2%E8%A1%A8%E7%A4%BA%E3%81%AB%E6%99%82%E6%8A%98%E3%83%86%E3%82%A3%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AA%E5%AE%9F%E8%A3%85%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B4%E6%96%B9%E5%90%91%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%81%A7%E6%98%A0%E5%83%8F%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%80%81GPU%E4%B8%8A%E3%81%A7%E8%A1%A8%E7%A4%BA%E5%87%A6%E7%90%86%E3%82%92%E8%A1%8C%E3%81%84%E3%80%81LVDS%E7%94%BB%E9%9D%A2%E3%81%AB%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%81%A7%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%90%8C%E6%99%82%E3%81%AB%E3%80%81g2d%E3%81%8C4%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E5%88%86%E3%81%AE%E6%98%A0%E5%83%8F%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%80%81g2g_blit%E9%96%A2%E6%95%B0%E3%81%A7%E3%83%AA%E3%82%B5%E3%82%A4%E3%82%BA%E5%87%A6%E7%90%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%90%84%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%AF720P%E3%81%8B%E3%82%89640%C3%97480%E3%81%AB%E3%83%AA%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%95%E3%82%8C%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C1%E3%81%A4%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%AB%E5%90%88%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%824%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E5%88%86%E3%81%AE%E6%98%A0%E5%83%8F%E3%82%921%E3%81%A4%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E5%86%85%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E7%94%BB%E5%83%8F%E3%82%92%E5%90%88%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%90%88%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E6%98%A0%E5%83%8F%E3%81%AF%E7%94%BB%E9%9D%A2%E3%81%AB%E3%81%AF%E8%A1%A8%E7%A4%BA%E3%81%9B%E3%81%9A%E3%80%81%E7%9B%B4%E6%8E%A5%E3%83%93%E3%83%87%E3%82%AA%E3%81%A8%E3%81%97%E3%81%A6%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E7%8F%BE%E5%9C%A8%E3%80%81GPU%E3%81%A7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%81%AB%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%9F%E6%98%A0%E5%83%8F%E3%81%AB%E3%83%86%E3%82%A3%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%9F%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E5%86%8D%E7%94%9F%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E6%98%A0%E5%83%8F%E3%81%AB%E3%83%86%E3%82%A3%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%8C%E8%A6%8B%E3%82%89%E3%82%8C%E3%80%81%E8%A6%96%E8%81%B4%E3%81%AB%E6%94%AF%E9%9A%9C%E3%82%92%E3%81%8D%E3%81%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3BGPU%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AB%E3%82%88%E3%82%8B%E8%A1%A8%E7%A4%BA%E3%82%92%E5%8D%98%E7%8B%AC%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%82%84%E3%80%814%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E5%88%86%E3%81%AE%E6%98%A0%E5%83%8F%E3%82%92G2D%E3%81%A7%E5%90%88%E6%88%90%E3%81%97%E3%81%A6%E3%83%93%E3%83%87%E3%82%AA%E3%81%A8%E3%81%97%E3%81%A6%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AF%E3%80%81%E6%98%A0%E5%83%8F%E3%81%AE%E3%83%86%E3%82%A3%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%82%892%E3%81%A4%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%921%E3%81%A4%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E8%A1%A8%E7%A4%BA%E3%81%8A%E3%82%88%E3%81%B3%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%9F%E3%83%93%E3%83%87%E3%82%AA%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%AB%E3%81%8A%E3%81%84%E3%81%A6%E3%82%82%E3%80%81%E6%98%A0%E5%83%8F%E3%81%AE%E3%83%86%E3%82%A3%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%3E1.%20IMX6%E3%81%AEGC2000%E3%81%A8GC320%E3%82%92%E5%90%8C%E6%99%82%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9FGPU%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AE%E5%85%88%E5%8F%96%E3%82%8A%E3%81%AB%E3%82%88%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E2.%20GPU%E5%86%85%E3%81%A7%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E7%AB%B6%E5%90%88%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9FGC2000%E3%81%A8GC320%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%81%99%E3%81%A7%E3%81%AB%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%892%E3%81%A4%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E7%B5%B1%E5%90%88%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6%E6%98%A0%E5%83%8F%E3%81%AE%E3%83%86%E3%82%A3%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%3E%E7%A7%81%E3%81%AF%E6%95%B0%E9%80%B1%E9%96%93%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E6%82%A9%E3%81%BE%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E8%89%AF%E3%81%84%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%AF%E3%81%A8%E3%81%A6%E3%82%82%E4%B8%8D%E5%AE%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%E3%81%99%E3%81%BF%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%86%E3%81%BE%E3%81%8F%E4%BC%9D%E3%82%8F%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E1.-g2d%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E7%94%BB%E5%83%8F%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E7%94%BB%E9%9D%A2%E3%81%AE%E3%83%86%E3%82%A3%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%82%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%83%87%E3%83%A2%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AB%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EFBIOPAN_DISPLAY%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%A1%A8%E7%A4%BA%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%3CP%3E2.%E3%81%97%E3%81%8B%E3%81%97%E3%80%81-g2d%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%3CSPAN%3E%E3%80%81%E7%94%BB%E9%9D%A2%E3%81%AE%E3%83%86%E3%82%A3%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%A2%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%20g2d_blit%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22color%20error.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22color%20error.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71472i0FC9B4C09D43C3F0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22color%20error.png%22%20alt%3D%22color%20error.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E5%9B%9E%E5%A4%8D%EF%BC%81%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3EOV10635%E3%81%8A%E3%82%88%E3%81%B3MAX9286%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A7%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%AE%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%AFYUYV%E3%81%A7%E3%81%99%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E5%86%85%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AFYUYV%E5%BD%A2%E5%BC%8F%E3%81%A7%E3%81%99%E3%80%82%E3%82%82%E3%81%97%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%81%B4%E3%81%A7RGB565%E3%81%AA%E3%81%A9%E5%88%A5%E3%81%AE%E5%BD%A2%E5%BC%8F%E3%81%A8%E3%81%97%E3%81%A6%E5%87%A6%E7%90%86%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%E8%89%B2%E3%81%AE%E8%A1%A8%E7%A4%BA%E3%81%8C%E3%81%8A%E3%81%8B%E3%81%97%E3%81%8F%E3%81%AA%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%B8%8A%E9%9D%A2%E5%9B%BE%E7%89%87%E6%98%AF%E4%BD%BF%E7%94%A87yuv%E6%9F%A5%E7%9C%8B%E7%9A%84%E7%BB%93%E6%9E%9C%EF%BC%8C%E9%80%89%E6%8B%A9%E7%9A%84%E6%A0%BC%E5%BC%8F%E6%98%AFYUYV%EF%BC%9B%E5%9B%BE%E5%83%8F%E9%A2%9C%E8%89%B2%E4%B8%8D%E5%AF%B9%E3%80%82%E6%89%80%E4%BB%A5%E4%B8%8D%E6%98%AF%E6%98%BE%E7%A4%BA%E6%A0%BC%E5%BC%8F%E4%B8%8D%E5%8C%B9%E9%85%8D%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%26gt%3B%E3%82%82%E3%81%86%E4%B8%80%E7%82%B9%E6%B3%A8%E6%84%8F%E3%81%99%E3%81%B9%E3%81%8D%E3%81%AA%E3%81%AE%E3%81%AF%E3%80%81MAX96705%E3%81%AF%E3%83%87%E3%83%BC%E3%82%BF%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E9%A0%86%E5%BA%8F%E3%82%92%E5%85%A5%E3%82%8C%E6%9B%BF%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E8%A8%AD%E5%AE%9A%E3%82%92%E8%AA%A4%E3%82%8B%E3%81%A8%E3%80%81%E8%89%B2%E3%81%8C%E3%81%8A%E3%81%8B%E3%81%97%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E8%AF%B7%E9%97%AE%E6%82%A8%E7%9F%A5%E9%81%93%E9%A9%B1%E5%8A%A8%E9%82%A3%E9%87%8C%E5%8F%AF%E4%BB%A5swap%20dataline%20order%E5%90%97%EF%BC%9F%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116696%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116696%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3E%E3%81%AA%E3%81%8A%E3%80%81%E7%A7%81%E3%81%AE%E7%92%B0%E5%A2%83%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3EOV10635%20sensor%3C%2FLI%3E%3CLI%3EMAX96705%20Serializer%3C%2FLI%3E%3CLI%3EMAX9286%20Deserializer%3C%2FLI%3E%3CLI%3Ekernel%204.1.15%3C%2FLI%3E%3CLI%3Epatch%20L3.14.52_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%94%BB%E5%83%8F%E3%81%AF%E8%A1%A8%E7%A4%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E8%89%B2%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81Liqiang%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%80%81i.MX6D%2FOV10635%2FMAX96705%2FMAX9286%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E3%80%814%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E7%99%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81L3.14.52_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip%E3%81%A7%E3%81%99%E3%80%82%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E7%94%BB%E5%83%8F%E3%81%AE%E8%89%B2%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22color-error.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22color-error.png%22%20style%3D%22width%3A%20804px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71301iE6667237C9E1F67B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22color-error.png%22%20alt%3D%22color-error.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116694%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116694%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3E1.%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E5%85%A5%E5%8A%9B%E3%81%AE%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%81%A8%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%A8%E5%90%8C%E3%81%98%E5%A0%B4%E5%90%88%E3%80%81IPU%E3%81%AF%E5%87%A6%E7%90%86%E3%82%92%E8%A1%8C%E3%82%8F%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E2.%20%E3%82%82%E3%81%86%E3%81%B2%E3%81%A8%E3%81%A4%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%3C%2FSPAN%3E-g2d%E5%BC%95%E6%95%B0%E3%82%92%E3%81%A4%E3%81%91%E3%81%A6%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E4%BA%8B%E8%B1%A1%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3Eroot%40imx6qsabresd%3A%2F%23%20.%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%201280%20-oh%26nbsp%3B%3C%2FSPAN%3E720%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E-d%201%20-x%200%20-g2d%E3%80%81%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E7%94%BB%E9%9D%A2%E3%81%8C%E4%BB%A5%E4%B8%8B%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%86%E3%82%A3%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tearing.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tearing.png%22%20style%3D%22width%3A%20907px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F71335i32BD58F756C4DD71%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22tearing.png%22%20alt%3D%22tearing.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%22%3E%E4%BD%95%E3%81%8B%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116692%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116692%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E-g2d%E5%BC%95%E6%95%B0%E3%81%AA%E3%81%97%E3%81%A7%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Eroot%40imx6qsabresd%3A%2F%23%20.%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%201280%20-oh%20%3CSTRONG%3E720%3C%2FSTRONG%3E%20-d%201%20-x%200%20%3CBR%20%2F%3Eg_in_width%20%3D%201280%2C%20g_in_height%20%3D%20720.%3CBR%20%2F%3Efb_fix.id%20%3D%20DISP3%20FG.%3CBR%20%2F%3Efb%3A%20smem_start%20%3D%200x26700000%2C%20smem_len%20%3D%200xa8c000.%3CBR%20%2F%3Efb%3A%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%20%3D%200x1c2000%20%E3%83%90%E3%82%A4%E3%83%88.%3CBR%20%2F%3Efb%3A%20g_screen_info.xres%20%3D%201280%2C%20g_screen_info.yres%20%3D%20720.%3CBR%20%2F%3Efb%3A%20g_display_left%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_top%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_width%20%3D%201280.%3CBR%20%2F%3Efb%3A%20g_display_height%20%3D%20720.%3CBR%20%2F%3EIPU_CHECK_TASK%E5%A4%B1%E6%95%97.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3CSPAN%3E.%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%201280%20-oh%3CSTRONG%3E%20719%3C%2FSTRONG%3E%20-d%201%20-x%200%3C%2FSPAN%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E8%A1%A8%E7%A4%BA%E7%94%BB%E5%83%8F%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8D%E5%8F%AF%E8%83%BD%E3%81%AA%E7%90%86%E7%94%B1%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116691%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116691%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ei.MX6%20QuadPLUS%E5%90%91%E3%81%91%E3%81%ABYocoto%E3%81%A7%E3%80%8C%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%BB%E3%83%93%E3%83%A5%E3%83%BC%E3%83%BB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%8D%E3%81%A8%E3%81%9D%E3%81%AE%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%86%E5%B0%91%E3%81%97%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AB%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%A8%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBala%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116690%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116690%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EMAX9286%E5%81%B4%E3%81%A7%E3%81%AF%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF0x08%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%BF%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Emax9286_write_reg(0x08%2C%200x26)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3Emax9286_write_reg(0x08%2C%200x2C)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82FrameSync%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AFMAX9286%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%B1%BA%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81%E7%90%86%E8%AB%96%E4%B8%8A%E3%81%AF%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8C25fps%E3%81%A7%E7%94%BB%E5%83%8F%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81MAX9286%E3%81%8C30fps%E3%81%A7%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%ABFrameSync%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%AF%E8%B5%B7%E3%81%93%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%EF%BC%8CQiang%20Li%EF%BC%8C%E8%B0%A2%E8%B0%A2%E5%9B%9E%E5%A4%8D%EF%BC%8C%E6%88%91%E4%BB%AC%E7%8E%B0%E5%9C%A8%E7%A1%AE%E5%AE%9E%E6%98%AF%E9%95%9C%E5%A4%B4%E6%A8%A1%E7%BB%84%E4%B8%8A%E6%8C%82%E4%BA%86%E4%B8%AAflash%EF%BC%8C%E4%B8%8D%E8%BF%87flash%E9%87%8C%E9%9D%A2%E7%9A%84%E5%9B%BA%E4%BB%B6%E6%98%AF%E5%AE%89%E6%A3%AE%E7%BE%8E%E7%9A%84%E4%BB%A3%E7%90%86%E5%95%86%E6%8F%90%E4%BE%9B%E7%9A%84%EF%BC%8C%E4%BB%96%E4%BB%AC%E7%A1%AE%E8%AE%A4%E5%B7%B2%E7%BB%8F%E5%B7%A5%E4%BD%9C%E5%9C%A8framesync%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%B9%B6%E4%B8%94%E8%BF%99%E4%B8%AA%E5%9B%BA%E4%BB%B6%E5%B7%B2%E7%BB%8F%E6%9C%89%E5%88%AB%E7%9A%84%E5%AE%A2%E6%88%B7%E5%9C%A8%E9%87%8F%E4%BA%A7%EF%BC%8C%E6%88%91%E4%BB%AC%E8%AF%BB%E5%87%BAAP0101%E7%9A%840xC88C%EF%BC%8C0xC88D%EF%BC%8C0xC88E%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E5%80%BC%E5%88%86%E5%88%AB%E6%98%AF0x03%2C0x03%2C0x00%EF%BC%8C%E5%90%8C%E6%97%B6%E9%80%9A%E8%BF%87%E9%80%BB%E8%BE%91%E5%88%86%E6%9E%90%E4%BB%AA%E5%88%86%E6%9E%90AP0101%E5%AF%B9AR0143%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%8C%E6%84%9F%E8%A7%89%E4%B9%9F%E5%BA%94%E8%AF%A5%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%EF%BC%9Bmax9286%E8%BF%99%E7%AB%AF%E5%B7%B2%E7%BB%8F%E7%A1%AE%E8%AE%A4%E7%94%9F%E6%88%90%E7%9A%84framesync%E4%BF%A1%E5%8F%B7%E6%9C%89%E4%BC%A0%E8%BE%93%E5%88%B0AP0101%EF%BC%8C%E7%8E%B0%E5%9C%A8sensor%E5%87%BA%E6%9D%A5%E7%9A%84%E5%B8%A7%E7%8E%87%E6%98%AF25fps%EF%BC%9B%3C%2FP%3E%3CP%3E%E8%AF%B7%E9%97%AE%E9%92%88%E5%AF%B925fps%EF%BC%8Cmax9286%E8%BF%99%E8%BE%B9%E7%9A%84%E9%85%8D%E7%BD%AE%E5%BA%94%E8%AF%A5%E5%A6%82%E6%9E%9C%E4%BF%AE%E6%94%B9%EF%BC%8C%E7%9B%BC%E5%A4%8D%EF%BC%8C%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116688%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116688%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E5%8B%95%E4%BD%9C%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%80%81SYNC%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5ROM%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AF%E9%80%9A%E5%B8%B8%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AB%E3%83%95%E3%83%AA%E3%83%BC%E3%83%A9%E3%83%B3%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E8%A4%87%E6%95%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E5%90%8C%E6%9C%9F%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116686%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116686%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E5%89%8D%E5%9B%9E%E3%81%AE%E8%A8%98%E8%BF%B0%E3%81%AF%E8%AA%A4%E3%82%8A%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E5%AE%9F%E9%9A%9B%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%AF%E3%80%81CSI2IPU%E3%82%AC%E3%82%B9%E3%82%B1%E3%83%83%E3%83%88%E3%81%AE%E5%87%BA%E5%8A%9B%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%8CYUYV%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%9F%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82CSI2IPU_SW_RST%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AEYUV422_8BIT_FM%E3%82%92UYVY%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116685%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116685%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EMIPI%20%E4%BB%95%E6%A7%98%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81MIPI%20CSI2%20%E3%81%A7%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%82%8B%20YUV422%20%E3%81%AF%20UYVY%20%E5%BD%A2%E5%BC%8F%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81YUYV%20%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E7%B5%B1%E4%B8%80%E3%81%95%E3%82%8C%E3%81%9F%E8%A8%AD%E5%AE%9A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%87%A6%E7%90%86%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emxc_v4l2_tvin%E3%81%A7%E3%81%AF%E3%80%81g_in_fmt%EF%BC%88g_g2d_fmt%EF%BC%89%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%80%81%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E6%99%82%E3%81%AB%E3%82%82%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E7%8A%B6%E6%B3%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6UYVY%E8%A8%AD%E5%AE%9A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E6%99%82%E3%81%ABg_in_fmt%EF%BC%88g_g2d_fmt%EF%BC%89%E3%82%92YUYV%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116684%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116684%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82VS%20%E3%81%AE%E6%A5%B5%E6%80%A7%E3%82%92%E5%8F%8D%E8%BB%A2%E3%81%97%E3%80%81%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E7%94%BB%E5%83%8F%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116683%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116683%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E7%94%BB%E5%83%8F%E3%81%AF%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E7%94%BB%E5%83%8F%E3%81%8C%E7%95%B0%E5%B8%B8%E3%81%A7%E3%81%99%E3%80%82%E7%94%BB%E5%83%8F%E5%85%A8%E4%BD%93%E3%81%8C%E7%B7%91%E8%89%B2%E3%81%A7%E3%80%81%E6%98%8E%E3%82%8B%E3%81%84%E9%83%A8%E5%88%86%E3%81%8C%E3%83%94%E3%83%B3%E3%82%AF%E8%89%B2%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E5%87%BA%E5%8A%9B%E3%81%8CYUYV%E5%BD%A2%E5%BC%8F%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3mxc_v4l2_tvin.c%E3%81%A7%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92UYVY%E5%BD%A2%E5%BC%8F%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%A6%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E7%94%BB%E5%83%8F%E3%81%AE%E8%89%B2%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E5%87%BA%E5%8A%9B%E5%BD%A2%E5%BC%8F%E3%81%8CYUYV%E5%BD%A2%E5%BC%8F%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%20UYVY%20%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E3%81%A8%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8C%E6%B6%88%E8%B2%BB%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A8%20max9286_mipi.c%20%E3%81%AB%E6%AC%A1%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E-%20max9286_data%5B0%5D.pix.pixelformat%20%3D%20V4L2_PIX_FMT_UYVY%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%3CSPAN%3Emax9286_data%5B0%5D.pix.pixelformat%20%3D%20V4L2_PIX_FMT_YUYV%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-%20if(sensor-%26gt%3Bpix.pixelformat%20%3D%3D%20V4L2_PIX_FMT_UYVY)%7B%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%3CSPAN%3Eif(sensor-%26gt%3Bpix.pixelformat%20%3D%3D%20V4L2_PIX_FMT_YUYV)%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bfor(i%20%3D%200%3B%20i%20%26lt%3B%20MAX_SENSOR_NUM%3Bi%2B%2B)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bmipi_csi2_set_datatype(mipi_csi2_info%2Ci%2CMIPI_DT_YUV422)%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E.%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20960%20-oh%20540%20-d%201%20-x%200%20-if%20YUYV%3C%2FP%3E%3CP%3E%3CSPAN%3ECSI_SENS_CONF%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E5%80%A4%E3%81%8C%200x900%20%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%BF%BD%E8%B7%A1%E3%81%97%E3%81%A6%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81SENS_DATA_FORMAT%20%E3%81%8C%20YUYV%20%E3%81%AB%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81HDMI%20%E7%B5%8C%E7%94%B1%E3%81%AE%E7%94%BB%E5%83%8F%E5%87%BA%E5%8A%9B%E3%81%AF%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6%E7%95%B0%E5%B8%B8%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E5%A4%89%E6%9B%B4%E5%89%8D%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%A8%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E5%90%8C%E3%81%98%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%A4%89%E6%9B%B4%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E6%84%9F%E3%81%98%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E4%BF%AE%E6%AD%A3%E6%96%B9%E6%B3%95%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%20%E4%BB%96%E3%81%AB%E5%90%8C%E6%9C%9F%E7%9A%84%E3%81%AB%E4%BF%AE%E6%AD%A3%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E7%AE%87%E6%89%80%E3%81%AF%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%20%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%83%86%E3%82%B9%E3%83%88%E7%94%A8%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%96%B0%E3%81%97%E3%81%84%E3%82%BB%E3%83%83%E3%83%88%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81VIDIOC_DQBUF%3CSPAN%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E6%B6%88%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82VIDIOC_DQBUF%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E8%AA%BF%E6%9F%BB%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3EVIDIOC_DQBUF%E3%82%84MIPI%20CLK%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSPAN%3E%3CSPAN%3E%E3%81%8C%E6%99%82%E3%80%85%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%AE%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E7%94%BB%E5%83%8F%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3EAR0140%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%3C%2FLI%3E%3CLI%3EAP0101%20ISP%3C%2FLI%3E%3CLI%3EMAX96705%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%A9%E3%82%A4%E3%82%B6%3C%2FLI%3E%3CLI%3EMAX9286%E3%83%87%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%A9%E3%82%A4%E3%82%B6%3C%2FLI%3E%3CLI%3EMAX9286%20EVM%E3%81%A8i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E9%96%93%E3%81%AB%E5%BD%93%E7%A4%BE%E8%A8%AD%E8%A8%88%E3%81%AE%E3%83%89%E3%83%BC%E3%82%BF%E3%83%9C%E3%83%BC%E3%83%89%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AF4.1.15%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E7%94%A8%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%2B%20max9271_write_reg(i%2C%200x20%2C%200x07)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x21%2C%200x06)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x22%2C%200x05)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x23%2C%200x04)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x24%2C%200x03)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x25%2C%200x02)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x26%2C%200x01)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x27%2C%200x00)%3B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x30%2C%200x17)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x31%2C%200x16)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x32%2C%200x15)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x33%2C%200x14)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x34%2C%200x13)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x35%2C%200x12)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x36%2C%200x11)%3B%3CBR%20%2F%3E%2B%20max9271_write_reg(i%2C%200x37%2C%200x10)%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22after_patch.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22after_patch.jpg%22%20style%3D%22width%3A%20490px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74688i185EB5054F16D904%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22after_patch.jpg%22%20alt%3D%22after_patch.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%81%8A%E8%BF%94%E4%BA%8B%E3%82%92%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116680%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116680%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E5%BC%8A%E7%A4%BE%E3%81%AE%E3%83%AC%E3%83%B3%E3%82%BA%E3%81%AFMAX96705%2BAP0101%2BAR0143AT%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82AP0101%E3%81%AB%E3%81%AF%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81ISP%E5%87%BA%E5%8A%9B%E3%81%AFYUV422%2F8bit%2FLSB%E3%81%A7%E3%81%99%E3%80%82VIDIOC_DQBUF%20%3CSTRONG%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%22%3Efailed%E3%81%A8%3C%2FSTRONG%3E%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E4%BB%96%E3%81%AE%E6%96%B9%E3%81%AE%E8%B3%AA%E5%95%8F%E3%82%92%E8%AA%AD%E3%82%93%E3%81%A7%E3%81%BF%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E4%B8%8D%E6%95%B4%E5%90%88%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0VIDIOC_DQBUF%20failed%E3%81%AF%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116679%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116679%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%3CSTRONG%3EIMX6QP%2BMAX9286%2BMAX96705%2BAP0101AT%2BAR0143AT%3C%2FSTRONG%3E%E3%81%A7%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%3CSTRONG%3EL4.1.15%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EAP0101%E3%81%AF%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%B5%E3%83%97%E3%83%A9%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8B%E3%82%89%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%93%E3%83%87%E3%82%AA%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%AFYUV422%208bit%2FLSB%E3%81%A7%E3%81%99%E3%80%82ISP%E3%81%8B%E3%82%89%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%82%8B%E3%83%93%E3%83%87%E3%82%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E7%94%A8%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AF1%E3%81%A4%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40imx6qp-avm718%3A%2Funit_tests%23%26nbsp%3B.%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20960%20-oh%20540%20-d%200%20-x%200%3C%2FP%3E%3CP%3EIn%20MVC%3A%20mxc_v4l_open%3CBR%20%2F%3E%20device%20name%20is%20Mxc%20Camera%3CBR%20%2F%3EEnd%20of%20mxc_v4l_open%3A%20v2f%20pix%20widthxheight%20288%20x%20352%3CBR%20%2F%3EEnd%20of%20mxc_v4l_open%3A%20crop_bounds%20widthxheight%201280%20x%20720%3CBR%20%2F%3EEnd%20of%20mxc_v4l_open%3A%20crop_defrect%20widthxheight%201280%20x%20720%3CBR%20%2F%3EEnd%20of%20mxc_v4l_open%3A%20crop_current%20widthxheight%201280%20x%20720%3CBR%20%2F%3EOn%20Open%3A%20Input%20to%20ipu%20size%20is%201280%20x%20720%3CBR%20%2F%3Emax9286_mipi%3A%20sensor%20number%20%3D%201.%3CBR%20%2F%3Emxc_mipi_csi2%2021dc000.mipi_csi%3A%20mipi_csi2_reset%3A%20mipi_lane_bps%20%3D%20148%20Mbps%3CBR%20%2F%3Emxc_mipi_csi2%2021dc000.mipi_csi%3A%20mipi_csi2_reset%3A%20value%20%3D%200x42.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3A%20AP0101%20was%20found%2C%20index%20%3D%201.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%20is%20already%20in%20Slave%20(Shutter-Sync)%20Mode.%3CBR%20%2F%3EIn%20MVC%3Amxc_v4l_ioctl%3CBR%20%2F%3EIn%20MVC%3A%20mxc_v4l_do_ioctl%2080685600%3CBR%20%2F%3E%20case%20VIDIOC_QUERYCAP%3CBR%20%2F%3EIn%20MVC%3Amxc_v4l_ioctl%3CBR%20%2F%3EIn%20MVC%3A%20mxc_v4l_do_ioctl%20c0045627%3CBR%20%2F%3E%20case%20VIDIOC_S_INPUT%3CBR%20%2F%3EIn%20MVC%3Amxc_streamoff%3CBR%20%2F%3EIn%20MVC%3Amxc_v4l_ioctl%3CBR%20%2F%3EIn%20MVC%3A%20mxc_v4l_do_ioctl%20c02c563a%3CBR%20%2F%3E%20case%20VIDIOC_CROPCAP%3CBR%20%2F%3EIn%20MVC%3Amxc_v4l_ioctl%3CBR%20%2F%3EIn%20MVC%3A%20mxc_v4l_do_ioctl%20c0cc5616%3CBR%20%2F%3E%20case%20VIDIOC_S_PARM%3CBR%20%2F%3EIn%20mxc_v4l2_s_param%3CBR%20%2F%3E%20Current%20capabilities%20are%200%3CBR%20%2F%3E%20Current%20capturemode%20is%200%20change%20to%200%3CBR%20%2F%3E%20Current%20framerate%20is%2030%20change%20to%200%3CBR%20%2F%3E%20clock_curr%3Dmclk%3D27000000%3CBR%20%2F%3E%20g_fmt_cap%20returns%20widthxheight%20of%20input%20as%201280%20x%20720%3CBR%20%2F%3EIn%20MVC%3Amxc_v4l_ioctl%3CBR%20%2F%3EIn%20MVC%3A%20mxc_v4l_do_ioctl%20c0cc5605%3CBR%20%2F%3E%20case%20VIDIOC_S_FMT%3CBR%20%2F%3EIn%20MVC%3A%20mxc_v4l2_s_fmt%3CBR%20%2F%3E%20type%3DV4L2_BUF_TYPE_VIDEO_CAPTURE%3CBR%20%2F%3EEnd%20of%20mxc_v4l2_s_fmt%3A%20v2f%20pix%20widthxheight%201280%20x%20720%3CBR%20%2F%3EEnd%20of%20mxc_v4l2_s_fmt%3A%20crop_bounds%20widthxheight%201280%20x%20720%3CBR%20%2F%3EEnd%20of%20mxc_v4l2_s_fmt%3A%20crop_defrect%20widthxheight%201280%20x%20720%3CBR%20%2F%3EEnd%20of%20mxc_v4l2_s_fmt%3A%20crop_current%20widthxheight%201280%20x%20720%3CBR%20%2F%3EIn%20MVC%3Amxc_v4l_ioctl%3CBR%20%2F%3EIn%20MVC%3A%20mxc_v4l_do_ioctl%20c0cc5604%3CBR%20%2F%3E%20case%20VIDIOC_G_FMT%3CBR%20%2F%3EIn%20MVC%3A%20mxc_v4l2_g_fmt%20type%3D1%3CBR%20%2F%3E%20type%20is%20V4L2_BUF_TYPE_VIDEO_CAPTURE%3CBR%20%2F%3EEnd%20of%20mxc_v4l2_g_fmt%3A%20v2f%20pix%20widthxheight%201280%20x%20720%3CBR%20%2F%3EEnd%20of%20mxc_v4l2_g_fmt%3A%20crop_bounds%20widthxheight%201280%20x%20720%3CBR%20%2F%3EEnd%20of%20mxc_v4l2_g_fmt%3A%20crop_defrect%20widthxheight%201280%20x%20720%3CBR%20%2F%3EEnd%20of%20mxc_v4l2_g_fmt%3A%20crop_current%20widthxheight%201280%20x%20720%3CBR%20%2F%3Eg_in_width%20%3D%201280%2C%20g_in_height%20%3D%20In%20MVC%3Amxc_v4l_ioctl%3CBR%20%2F%3E720.%3CBR%20%2F%3EIn%20MVC%3A%20mxc_v4l_do_ioctl%20c0145608%3CBR%20%2F%3E%20case%20VIDIOC_REQBUFS%3CBR%20%2F%3EIn%20MVC%3Amxc_streamoff%3CBR%20%2F%3EMVC%3A%20In%20mxc_free_frame_buf%3CBR%20%2F%3EIn%20MVC%3Amxc_allocate_frame_buf%20-%20size%3D1843200%3CBR%20%2F%3Efb_fix.id%20%3D%20DISP3%20BG%20-%20DI1.%3CBR%20%2F%3EIt%20is%20background%20screen%2C%20only%20full%20screen%20default%20format%20was%20supported.%3CBR%20%2F%3Efb%3A%20smem_start%20%3D%200x73500000%2C%20smemIn%20MVC%3Amxc_v4l_ioctl%3CBR%20%2F%3E_len%20%3D%200xbdd800.%3CBR%20%2F%3Efb%3A%20frame%20buffIn%20MVC%3A%20mxc_v4l_do_ioctl%20c0445609%3CBR%20%2F%3Eer%20size%20%3D%200x3f4800%20bytes.%3CBR%20%2F%3Efb%3A%20g%20case%20VIDIOC_QUERYBUF%3CBR%20%2F%3E_screen_info.xres%20%3D%201920%2C%20g_screeIn%20MVC%3Amxc_v4l2_buffer_status%3CBR%20%2F%3En_info.yres%20%3D%201080.%3CBR%20%2F%3Efb%3A%20g_displIn%20MVC%3Amxc_mmap%3CBR%20%2F%3Eay_left%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_top%20pgoff%3D0x72d00%2C%20start%3D0x75e00000%2C%20end%3D0x75fc2000%3CBR%20%2F%3E%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_width%20%3D%201920In%20MVC%3Amxc_v4l_ioctl%3CBR%20%2F%3E.%3CBR%20%2F%3EIn%20MVC%3A%20mxc_v4l_do_ioctl%20c0445609%3C%2FP%3E%3CP%3Ecase%20VIDIOC_QUERYBUF%3CBR%20%2F%3EIn%20MVC%3Amxc_v4l2_buffer_status%3CBR%20%2F%3EIn%20MVC%3Amxc_mmap%3CBR%20%2F%3E%20pgoff%3D0x72f00%2C%20start%3D0x75c3e000%2C%20end%3D0x75e00000%3CBR%20%2F%3EIn%20MVC%3Amxc_v4l_ioctl%3CBR%20%2F%3EIn%20MVC%3A%20mxc_v4l_do_ioctl%20c0445609%3CBR%20%2F%3E%20case%20VIDIOC_QUERYBUF%3CBR%20%2F%3EIn%20MVC%3Amxc_v4l2_buffer_status%3CBR%20%2F%3EIn%20MVC%3Amxc_mmap%3CBR%20%2F%3E%20pgoff%3D0x73100%2C%20start%3D0x75a7c000%2C%20end%3D0x75c3e000%3CBR%20%2F%3EIn%20MVC%3Amxc_v4l_ioctl%3CBR%20%2F%3EIn%20MVC%3A%20mxc_v4l_do_ioctl%20c0445609%3CBR%20%2F%3E%20case%20VIDIOC_QUERYBUF%3CBR%20%2F%3EIn%20MVC%3Amxc_v4l2_buffer_status%3CBR%20%2F%3EIn%20MVC%3Amxc_mmap%3CBR%20%2F%3E%20pgoff%3D0x73300%2C%20start%3D0x758ba000%2C%20end%3D0x75a7c000%3CBR%20%2F%3EIn%20MVC%3Amxc_v4l_ioctl%3CBR%20%2F%3EIn%20MVC%3A%20mxc_v4l_do_ioctl%20c044560f%3CBR%20%2F%3E%20case%20VIDIOC_QBUF%3CBR%20%2F%3EIn%20MVC%3Amxc_v4l_ioctl%3CBR%20%2F%3EIn%20MVC%3A%20mxc_v4l_do_ioctl%20c044560f%3CBR%20%2F%3E%20case%20VIDIOC_QBUF%3CBR%20%2F%3EIn%20MVC%3Amxc_v4l_ioctl%3CBR%20%2F%3EIn%20MVC%3A%20mxc_v4l_do_ioctl%20c044560f%3CBR%20%2F%3E%20case%20VIDIOC_QBUF%3CBR%20%2F%3EIn%20MVC%3Amxc_v4l_ioctl%3CBR%20%2F%3EIn%20MVC%3A%20mxc_v4l_do_ioctl%20c044560f%3CBR%20%2F%3E%20case%20VIDIOC_QBUF%3CBR%20%2F%3EIn%20MVC%3Amxc_v4l_ioctl%3CBR%20%2F%3EIn%20MVC%3A%20mxc_v4l_do_ioctl%2040045612%3CBR%20%2F%3E%20case%20VIDIOC_STREAMON%3CBR%20%2F%3EIn%20MVC%3Amxc_streamon%3CBR%20%2F%3EIPU%3AIn%20csi_enc_enabling_tasks%3CBR%20%2F%3EIn%20csi_enc_setup%3CBR%20%2F%3Estart%20time%20%3D%201540834851%20s%2C%2023859%20In%20MVC%3Amxc_v4l_ioctl%3CBR%20%2F%3Eus%3CBR%20%2F%3EIn%20MVC%3A%20mxc_v4l_do_ioctl%20c0445611%3CBR%20%2F%3E%20case%20VIDIOC_DQBUF%3CBR%20%2F%3EIn%20MVC%3Amxc_v4l_dqueue%3CBR%20%2F%3E%3CSTRONG%3EERROR%3A%20v4l2%20capture%3A%20mxc_v4l_dqueue%20timeout%20enc_counter%200%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EVIDIOC_DQBUF%20failed.%3C%2FSTRONG%3E%3CBR%20%2F%3EIn%20MVC%3Amxc_v4l_ioctl%3CBR%20%2F%3EIn%20MVC%3A%20mxc_v4l_do_ioctl%2040045613%3CBR%20%2F%3E%20case%20VIDIOC_STREAMOFF%3CBR%20%2F%3EIn%20MVC%3Amxc_streamoff%3CBR%20%2F%3ECSI_MEM0%3Afffffc0%2CCIS_MEM1%3A10ffffc1%2CCSI_MEM2%3A11ffffc2%2CCSI_MEM3%3A12ffffc3%2CCSI_PRP_ENC_MEM%3A13ffffd4%2CCSI_PRP_VF_MEM%3A14ffffd5%3CBR%20%2F%3Echannel%3Afffffc0%3CBR%20%2F%3EIn%20MVC%3Amxc_free_frames%3CBR%20%2F%3EIn%20MVC%3Amxc_v4l_close%3CBR%20%2F%3EIn%20MVC%3Amxc_streamoff%3CBR%20%2F%3Emxc_v4l_close%3A%20release%20resource%3CBR%20%2F%3EMVC%3A%20In%20mxc_free_frame_buf%3CBR%20%2F%3EIn%20MVC%3Amxc_free_frames%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%87%E3%82%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82MAX9286%20mipi%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82mipi%20clk%E3%81%AF72MHz%E3%81%A7%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%83%94%E3%83%B3%E3%81%AE%E6%B3%A2%E5%BD%A2%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EAP0101%E3%81%A8MAX96705%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%83%94%E3%83%B3%E3%81%AE%E4%BD%8D%E7%BD%AE%E3%81%8C%E3%81%9A%E3%82%8C%E3%81%A6%E3%81%84%E3%81%9F%E3%82%8A%E9%80%86%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%82%8A%E3%81%99%E3%82%8B%E5%95%8F%E9%A1%8C%E3%82%92%E6%A4%9C%E8%A8%8E%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%BB%96%E3%81%AE%E4%BA%BA%E3%81%AE%E9%81%8E%E5%8E%BB%E3%81%AE%E7%B5%8C%E9%A8%93%E3%81%8B%E3%82%89%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%83%94%E3%83%B3%E3%81%AE%E4%BD%8D%E7%BD%AE%E3%81%8C%E3%81%9A%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E3%81%AF%E8%A6%8B%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E7%94%BB%E5%83%8F%E3%81%8C%E7%95%B0%E5%B8%B8%E3%81%A7%E3%80%81VIDIOC_DQBUF%20failed%E3%81%AF%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AE%E3%83%92%E3%83%B3%E3%83%88%E3%82%92%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%20%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20763px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74720i49DAD8ADC9E4F883%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20798px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F74799i9D55B01043DCC3D8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116678%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116678%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%85%A5%E5%8A%9B%E3%81%8C%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%3A%3C%2FP%3E%3CP%3ERAW%E3%83%87%E3%83%BC%E3%82%BF%E5%85%A5%E5%8A%9B%E3%81%BE%E3%81%9F%E3%81%AFYUV%E5%85%A5%E5%8A%9B%E3%80%82CMOS%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E5%85%A5%E5%8A%9B%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF12%E3%83%93%E3%83%83%E3%83%88%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%93%E3%83%83%E3%83%88%E6%90%8D%E5%A4%B1%E3%81%AF%E5%95%8F%E9%A1%8C%E3%82%92%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%97%E3%81%BE%E3%81%99%E3%80%828%E3%83%93%E3%83%83%E3%83%88YUV%E5%85%A5%E5%8A%9B%EF%BC%88BT656%EF%BC%89%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E9%81%A9%E5%88%87%E3%81%AA%E3%83%93%E3%83%83%E3%83%88%E6%95%B0%EF%BC%880%EF%BD%9E7%E3%81%BE%E3%81%9F%E3%81%AF2%EF%BD%9E9%EF%BC%89%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82Serdis%E3%81%AF%E9%80%9A%E5%B8%B8%E3%80%81%E9%80%81%E4%BF%A1%E3%82%92%E8%A1%8C%E3%81%86%E3%81%9F%E3%82%81%E3%80%81%E5%85%A5%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%82%82%E3%81%AE%E3%81%8C%E3%81%9D%E3%81%AE%E3%81%BE%E3%81%BE%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Edezhijiang%40126.com%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116677%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116677%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fferhatolgun%22%20target%3D%22_blank%22%3Eferhatolgun%3C%2FA%3E%20%E2%80%8C%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%E7%A7%81%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%82%E3%81%97%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%9F%E3%82%89%E3%80%81%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116676%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116676%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81MAX96705%E3%81%AF10%E6%9C%AC%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AB%E3%83%A1%E3%83%A9%E7%94%BB%E5%83%8F%E3%82%92%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%828%E6%9C%AC%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%97%E3%81%8B%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E5%8F%8D%E8%BB%A2%E5%BE%8C%E3%81%AB%E7%94%BB%E5%83%8F%E3%81%AE%E4%B8%8A%E4%BD%8D2%E3%83%93%E3%83%83%E3%83%88%E3%81%8C%E5%A4%B1%E3%82%8F%E3%82%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AB%E8%A8%B1%E5%AE%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%828%E3%83%A9%E3%82%A4%E3%83%B3%E6%96%B9%E5%BC%8F%E3%81%AE%E5%8F%96%E3%82%8A%E6%89%B1%E3%81%84%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81Maxim%E3%81%AB%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116675%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116675%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%40%3CA%20_jive_internal%3D%22true%22%20class%3D%22%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20style%3D%22color%3A%20%233d9ce7%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20text-decoration%3A%20underline%3B%20font-size%3A%201.286rem%3B%22%20target%3D%22_blank%22%3EQiang%20Li%20-%20Mpu%20Se%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89MAX96705%E3%81%B8%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AEHigh%E3%81%A8Low%E3%81%AF%E7%A2%BA%E3%81%8B%E3%81%AB%E5%8F%8D%E8%BB%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%9F%E3%81%AE%E3%81%AF10%E6%9C%AC%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F8%E6%9C%AC%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%E4%B8%8A%E3%81%AE%E5%86%99%E7%9C%9F%E3%81%AF%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E5%8F%8D%E8%BB%A2%E3%81%95%E3%81%9B%E3%81%9F%E5%BE%8C%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%A7%E3%81%99%E3%80%82%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AA%E8%A8%AD%E5%AE%9A%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Emax9271_write_reg(i%2C%200x20%2C%200x07)%3B%3CBR%20%2F%3E%20max9271_write_reg(i%2C%200x21%2C%200x06)%3B%3CBR%20%2F%3E%20max9271_write_reg(i%2C%200x22%2C%200x05)%3B%3CBR%20%2F%3E%20max9271_write_reg(i%2C%200x23%2C%200x04)%3B%3CBR%20%2F%3E%20max9271_write_reg(i%2C%200x24%2C%200x03)%3B%3CBR%20%2F%3E%20max9271_write_reg(i%2C%200x25%2C%200x02)%3B%3CBR%20%2F%3E%20max9271_write_reg(i%2C%200x26%2C%200x01)%3B%3CBR%20%2F%3E%20max9271_write_reg(i%2C%200x27%2C%200x00)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emax9271_write_reg(i%2C%200x30%2C%200x17)%3B%3CBR%20%2F%3E%20max9271_write_reg(i%2C%200x31%2C%200x16)%3B%3CBR%20%2F%3E%20max9271_write_reg(i%2C%200x32%2C%200x15)%3B%3CBR%20%2F%3E%20max9271_write_reg(i%2C%200x33%2C%200x14)%3B%3CBR%20%2F%3E%20max9271_write_reg(i%2C%200x34%2C%200x13)%3B%3CBR%20%2F%3E%20max9271_write_reg(i%2C%200x35%2C%200x12)%3B%3CBR%20%2F%3E%20max9271_write_reg(i%2C%200x36%2C%200x11)%3B%3CBR%20%2F%3E%20max9271_write_reg(i%2C%200x37%2C%200x10)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F63363iB40359864214D996%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E7%94%BB%E5%83%8F%E3%81%AE%E8%BC%AA%E9%83%AD%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%8C%E3%81%95%E3%82%89%E3%81%AB%E5%A4%B1%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%96%E3%81%AB%E5%8E%9F%E5%9B%A0%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%20%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116674%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116674%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89MAX96705%E3%81%B8%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E3%83%8F%E3%82%A4%E3%81%A8%E3%83%AD%E3%83%BC%E3%81%8C%E5%8F%8D%E8%BB%A2%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%8296705%EF%BC%88%E6%96%9C%E4%BD%93%E9%83%A8%E5%88%86%EF%BC%89%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E5%8F%8D%E8%BB%A2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23ifdef%20MAX96705%3CBR%20%2F%3E%20%2F%2FVSYNC%E3%82%92%E5%8F%8D%E8%BB%A2%3CBR%20%2F%3Emax9271_write_reg(0%2C%200x40%2C%200x2F)%3B%3CBR%20%2F%3E%20msleep(2)%3B%3CBR%20%2F%3E%20max9271_write_reg(0%2C%200x08%2C%200x81)%3B%3CBR%20%2F%3E%20msleep(2)%3B%3C%2FP%3E%3CP%3E%26nbsp%3Bmax9271_write_reg(0%2C%200x97%2C%200x5F)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%3E%26nbsp%3Bmax9271_write_reg(0%2C%200x20%2C%200x09)%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%26nbsp%3Bmax9271_write_reg(0%2C%200x21%2C%200x08)%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%26nbsp%3Bmax9271_write_reg(0%2C%200x22%2C%200x07)%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%26nbsp%3Bmax9271_write_reg(0%2C%200x23%2C%200x06)%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%26nbsp%3Bmax9271_write_reg(0%2C%200x24%2C%200x05)%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%26nbsp%3Bmax9271_write_reg(0%2C%200x25%2C%200x04)%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%26nbsp%3Bmax9271_write_reg(0%2C%200x26%2C%200x03)%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%26nbsp%3Bmax9271_write_reg(0%2C%200x27%2C%200x02)%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%26nbsp%3Bmax9271_write_reg(0%2C%200x28%2C%200x01)%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%26nbsp%3Bmax9271_write_reg(0%2C%200x29%2C%200x00)%3B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%3E%26nbsp%3Bmax9271_write_reg(0%2C%200x30%2C%200x19)%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%26nbsp%3Bmax9271_write_reg(0%2C%200x31%2C%200x18)%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%26nbsp%3Bmax9271_write_reg(0%2C%200x32%2C%200x17)%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%26nbsp%3Bmax9271_write_reg(0%2C%200x33%2C%200x16)%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%26nbsp%3Bmax9271_write_reg(0%2C%200x34%2C%200x15)%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%26nbsp%3Bmax9271_write_reg(0%2C%200x35%2C%200x14)%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%26nbsp%3Bmax9271_write_reg(0%2C%200x36%2C%200x13)%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%26nbsp%3Bmax9271_write_reg(0%2C%200x37%2C%200x12)%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%26nbsp%3Bmax9271_write_reg(0%2C%200x38%2C%200x11)%3B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%26nbsp%3Bmax9271_write_reg(0%2C%200x39%2C%200x10)%3B%3C%2FEM%3E%3CBR%20%2F%3E%23else%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116673%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116673%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81%E7%8F%BE%E5%9C%A8%E3%80%81IMX225%2BFH8536%2BMAX96705%E3%80%81%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%EF%BC%9AIMX6%2BMAX9286%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B33.14.52%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E8%AA%BF%E6%95%B4%E4%B8%AD%E3%81%A7%E3%81%99%E3%80%82%E3%83%93%E3%83%87%E3%82%AA%E3%81%AE%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E8%BC%AA%E9%83%AD%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%9B%B3%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E8%89%B2%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AD%E3%83%B3%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89ISP%E5%87%BA%E5%8A%9B%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E5%AE%9F%E9%A8%93%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82MAX96705%E3%81%8B%E3%82%89ISP%E3%82%92%E5%A4%96%E3%81%97%E3%80%81ISP%E5%87%BA%E5%8A%9B%E3%82%92%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%EF%BC%88TW8836%EF%BC%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81TW8836%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%AE%E7%B5%90%E6%9E%9C%E3%80%81%E7%94%BB%E5%83%8F%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%80%81%E3%81%A4%E3%81%BE%E3%82%8AISP%E3%81%8B%E3%82%89%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%82%8B%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E5%87%BA%E5%8A%9B%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%AFYVYU%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%93%E3%81%A7%E8%B3%AA%E5%95%8F%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81max96705%E3%81%AFYVYU%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92UYVY%E5%BD%A2%E5%BC%8F%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%A6MAX9286%E3%81%AB%E6%B8%A1%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%BE%E3%81%9F%E3%80%81imx6%E5%81%B4%E3%81%A7%E8%A1%A8%E7%A4%BA%E9%83%A8%E5%88%86%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%87%A6%E7%90%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F63930iEA9156C7D5162028%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221.jpg%22%20alt%3D%221.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Ferhat%2C%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AB%E3%81%AF%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%83%91%E3%83%83%E3%83%81%E3%81%AB%E3%81%AF%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%81%8A%E8%A6%8B%E3%81%9B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82MAX96705%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AE%E8%A9%B3%E7%B4%B0%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81Maxim%E3%81%AB%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%86%85%E3%81%AB%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E6%9C%80%E6%96%B0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%8A%E8%BF%94%E4%BA%8B%E3%82%92%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116670%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116670%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20DONGON%20KIM%2C%3C%2FP%3E%3CP%3E%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E5%90%88%E6%88%90%E3%83%81%E3%83%83%E3%83%97%E3%81%AF%E3%80%81%E5%90%84%E3%83%93%E3%83%87%E3%82%AA%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E6%95%B0%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E6%8C%BF%E5%85%A5%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E5%81%B4%E3%81%A7%E6%8C%BF%E5%85%A5%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E7%95%AA%E5%8F%B7%E3%82%92%E8%AD%98%E5%88%A5%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116667%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116667%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Ferhat%EF%BC%8C%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%B3%E3%83%BC%E3%83%89%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emax9271_write_reg(0%2C%200x20%2C%200x09)%3B%3CBR%20%2F%3Emax9271_write_reg(0%2C%200x21%2C%200x08)%3B%3CBR%20%2F%3Emax9271_write_reg(0%2C%200x22%2C%200x07)%3B%3CBR%20%2F%3Emax9271_write_reg(0%2C%200x23%2C%200x06)%3B%3CBR%20%2F%3Emax9271_write_reg(0%2C%200x24%2C%200x05)%3B%3CBR%20%2F%3Emax9271_write_reg(0%2C%200x25%2C%200x04)%3B%3CBR%20%2F%3Emax9271_write_reg(0%2C%200x26%2C%200x03)%3B%3CBR%20%2F%3Emax9271_write_reg(0%2C%200x27%2C%200x02)%3B%3CBR%20%2F%3Emax9271_write_reg(0%2C%200x28%2C%200x01)%3B%3CBR%20%2F%3Emax9271_write_reg(0%2C%200x29%2C%200x00)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emax9271_write_reg(0%2C%200x30%2C%200x19)%3B%3CBR%20%2F%3Emax9271_write_reg(0%2C%200x31%2C%200x18)%3B%3CBR%20%2F%3Emax9271_write_reg(0%2C%200x32%2C%200x17)%3B%3CBR%20%2F%3Emax9271_write_reg(0%2C%200x33%2C%200x16)%3B%3CBR%20%2F%3Emax9271_write_reg(0%2C%200x34%2C%200x15)%3B%3CBR%20%2F%3Emax9271_write_reg(0%2C%200x35%2C%200x14)%3B%3CBR%20%2F%3Emax9271_write_reg(0%2C%200x36%2C%200x13)%3B%3CBR%20%2F%3Emax9271_write_reg(0%2C%200x37%2C%200x12)%3B%3CBR%20%2F%3Emax9271_write_reg(0%2C%200x38%2C%200x11)%3B%3CBR%20%2F%3Emax9271_write_reg(0%2C%200x39%2C%200x10)%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E6%8F%90%E4%BE%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E3%83%91%E3%83%83%E3%83%81%E3%81%AB%E3%81%AF%E3%80%81MAX96705%E3%81%A7MSB%E3%81%8B%E3%82%89LSB%E3%81%AB%E5%85%A5%E3%82%8C%E6%9B%BF%E3%81%88%E3%82%8B%E8%A8%AD%E5%AE%9A%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9FMAX96705%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E5%81%B4%E3%81%A7%E3%81%93%E3%81%86%E3%81%97%E3%81%9F%E5%85%A5%E3%82%8C%E6%9B%BF%E3%81%88%E5%87%A6%E7%90%86%E3%81%AF%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116665%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116665%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Ferhat%2C%3C%2FP%3E%3CP%3EMAX9286%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%AB%E3%81%AF%E3%80%81MSB%E3%81%A8LSB%E3%81%AE%E5%85%A5%E3%82%8C%E6%9B%BF%E3%81%88%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82MAX96705%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%81%93%E3%81%AE%E5%85%A5%E3%82%8C%E6%9B%BF%E3%81%88%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81MAX9271%E3%81%A7%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81AP0101%E3%82%82%E3%81%93%E3%81%86%E3%81%97%E3%81%9F%E5%85%A5%E3%82%8C%E6%9B%BF%E3%81%88%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%BF%AE%E6%AD%A3%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Dongoh%2C%3C%2FP%3E%3CP%3EiMX8MQ%E3%81%AF%E8%A4%87%E6%95%B0%E3%81%AE%E4%BB%AE%E6%83%B3%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%A7%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E5%8F%97%E4%BF%A1%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AE%E4%BB%AE%E6%83%B3%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%8B%E3%82%89%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E5%88%86%E9%9B%A2%E3%81%99%E3%82%8B%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AF%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%88%86%E5%89%B2%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81MIPI%E9%80%81%E4%BF%A1%E8%80%85%E3%81%AF%E5%90%84%E4%BB%AE%E6%83%B3%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%AD%98%E5%88%A5%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E6%8C%BF%E5%85%A5%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20Qiang%20Li%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ei.MX8MQ%E3%81%8C%E8%A4%87%E6%95%B0%E3%81%AE%E4%BB%AE%E6%83%B3%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E7%90%86%E7%94%B1%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3Ei.MX8M%20Quad%E3%81%AE%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BMIPI-CSI2%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%8A%E3%82%88%E3%81%B3%E8%AA%AC%E6%98%8E%E3%81%AB%E3%82%88%E3%82%8C%E3%81%B0%E3%80%81%3C%2FP%3E%3CP%3Ei.MX8M%E3%81%AF%E8%A4%87%E6%95%B0%E3%81%AE%E4%BB%AE%E6%83%B3%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E5%8F%97%E3%81%91%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%EF%BC%8813.6.1.1%E3%81%8A%E3%82%88%E3%81%B313.6.3%EF%BC%89%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDear%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AB%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9F%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%81%94%E6%8C%87%E6%91%98%E3%81%AE%E7%90%86%E7%94%B1%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%80%8C2.%20AP0101%E3%81%AEDOUT0%EF%BD%9EDOUT7%E3%81%AF%E3%80%81MAX9271%E3%81%AEDIN7%EF%BD%9EDIN0%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%8E%A5%E7%B6%9A%E9%A0%86%E3%81%AF%E5%8F%8D%E8%BB%A2%E3%81%95%E3%81%9B%E3%80%81MSB%E3%82%92LSB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%80%8D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EOnsemi%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%9C%E3%83%BC%E3%83%89%EF%BC%88MARS%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%EF%BC%89%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AF%E7%9B%B4%E6%8E%A5%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%88DOUT0%EF%BD%9EDOUT7%E3%82%92DIN0%EF%BD%9EDIN7%E3%81%AB%E6%8E%A5%E7%B6%9A%EF%BC%89%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%82%92%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9FMAX96705%E3%81%A8AP0101%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E3%81%AF%E8%A8%98%E8%BC%89%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A91%E5%8F%B0%E3%82%92MAX9286%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%814.1.15%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E6%8F%90%E4%BE%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E6%99%82%E3%81%AB%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E7%94%BB%E5%83%8F%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CIMG%20alt%3D%22%22%20class%3D%22image-1%20jive-image%20j-img-original%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CIMG%20alt%3D%22%22%20class%3D%22image-3%20jive-image%22%20src%3D%22https%3A%2F%2Fdrive.google.com%2Fopen%3Fid%3D0B5HptjiQQyECUG93YXNsSjR6cjlVR0x1SER1a0ZiSTVLUC1R%22%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220180831_104651(0).jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220180831_104651(0).jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F67813i70D174B44B428AD6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2220180831_104651(0).jpg%22%20alt%3D%2220180831_104651(0).jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%AD%E3%82%B0%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40esomimx6q%3A~%23%20.%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20400%20-oh%20240%20-d%201%20-x%200%3CBR%20%2F%3E%5B%203144.243857%5D%20max9286_mipi%3A%20%E3%82%BB%E3%83%B3%E3%82%B5%E7%95%AA%E5%8F%B7%20%3D%201.%3CBR%20%2F%3E%5B%203144.248939%5D%20mxc_mipi_csi2%2021dc000.mipi_csi%3Amipi_csi2_reset%3A%20mipi_lane_bps%20%3D%20148%20Mbps%3CBR%20%2F%3E%5B%203144.257446%5D%20mxc_mipi_csi2%2021dc000.mipi_csi%3Amipi_csi2_reset%3A%20value%20%3D%200x42.%3CBR%20%2F%3E%5B%203144.743416%5D%20max9286_mipi%201-006a%3A%20ap0101_initialize%3A%20AP0101%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%2C%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%201.%3CBR%20%2F%3E%5B%203144.751541%5D%20max9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20(%E3%82%B7%E3%83%A3%E3%83%83%E3%82%BF%E3%83%BC%E5%90%8C%E6%9C%9F)%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99.%3CBR%20%2F%3Eg_in_width%20%3D%201280%2C%20g_in_height%20%3D%20720.%3CBR%20%2F%3Efb_fix.id%20%3D%20DISP4%20FG.%3CBR%20%2F%3Efb%3A%20smem_start%20%3D%200x6a100000%2C%20smem_len%20%3D%200x8ca00.%3CBR%20%2F%3Efb%3A%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%20%3D%200x2ee00%20%E3%83%90%E3%82%A4%E3%83%88.%3CBR%20%2F%3Efb%3A%20g_screen_info.xres%20%3D%20400%2C%20g_screen_info.yres%20%3D%20240.%3CBR%20%2F%3Efb%3A%20g_display_left%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_top%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_width%20%3D%20400.%3CBR%20%2F%3Efb%3A%20g_display_height%20%3D%20240.%3CBR%20%2F%3E%E9%96%8B%E5%A7%8B%E6%99%82%E9%96%93%20%3D%201535715437%20%E7%A7%92%2C%20436911%20%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E7%A7%92%3CBR%20%2F%3E%5B%203154.993386%5D%E3%82%A8%E3%83%A9%E3%83%BC%3A%20v4l2%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%3A%20mxc_v4l_dqueue%20%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%20enc_counter%200%3CBR%20%2F%3EVIDIOC_DQBUF%E5%A4%B1%E6%95%97.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%8C%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%EF%BC%88%E3%81%BE%E3%81%9F%E3%80%81GPR1%E3%81%AE%E3%83%94%E3%83%B319%E3%81%8A%E3%82%88%E3%81%B320%E3%81%AF0%E3%81%AB%E8%A8%AD%E5%AE%9A%E6%B8%88%E3%81%BF%E3%81%A7%E3%81%99%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%8B%E3%82%89%E3%80%81%2Fdev%2Fvideo0%E3%81%8A%E3%82%88%E3%81%B3%2Fdev%2Fvideo2%20%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%82%E3%82%8B%E4%B8%80%E6%96%B9%E3%81%A7%E3%80%81%2Fdev%2Fvideo1%E3%81%8A%E3%82%88%E3%81%B3%2Fdev%2Fvideo3%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%AFCSI%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%A7%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%88%E3%81%AA%E3%81%8A%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AF1%E5%8F%B0%E3%81%97%E3%81%8B%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%22cat%20%2Fdev%2Fvideo0%22%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E3%81%BF%E3%81%8CAP0101%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40esomimx6q%3A~%23%20cat%20%2Fdev%2Fvideo0%3CBR%20%2F%3E%5B%203313.913877%5D%20max9286_mipi%3A%20%E3%82%BB%E3%83%B3%E3%82%B5%E7%95%AA%E5%8F%B7%20%3D%201%E3%80%82%3CBR%20%2F%3E%5B%203313.918963%5D%20mxc_mipi_csi2%2021dc000.mipi_csi%3Amipi_csi2_reset%3A%20mipi_lane_bps%20%3D%20148%20Mbps%3CBR%20%2F%3E%5B%203313.926941%5D%20mxc_mipi_csi2%2021dc000.mipi_csi%3Amipi_csi2_reset%3A%20%E5%80%A4%20%3D%200x42.%3CBR%20%2F%3E%5B%203314.413402%5D%20max9286_mipi%201-006a%3A%20ap0101_initialize%3A%20AP0101%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%2C%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%201%E3%80%82%3CBR%20%2F%3E%5B%203314.421469%5D%20max9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20(%E3%82%B7%E3%83%A3%E3%83%83%E3%82%BF%E3%83%BC%E5%90%8C%E6%9C%9F)%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99.%3CBR%20%2F%3E%5B%203324.583392%5D%E3%82%A8%E3%83%A9%E3%83%BC%3A%20v4l2%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%3A%20mxc_v4l_read%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC0%3CBR%20%2F%3Ecat%3A%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E6%9C%9F%E9%99%90%E5%88%87%E3%82%8C%3CBR%20%2F%3Eroot%40esomimx6q%3A~%23%20cat%20%2Fdev%2Fvideo1%3CBR%20%2F%3E%5B%203337.083393%5D%E3%82%A8%E3%83%A9%E3%83%BC%3A%20v4l2%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%3A%20mxc_v4l_read%20%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC0%3CBR%20%2F%3E%5B%203337.089359%5D%20imx-ipuv3%202400000.ipu%3ACSI%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Ecat%3A%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E6%9C%9F%E9%99%90%E5%88%87%E3%82%8C%3CBR%20%2F%3Eroot%40esomimx6q%3A~%23%20cat%20%2Fdev%2Fvideo2%3CBR%20%2F%3E%5B%203351.493394%5D%E3%82%A8%E3%83%A9%E3%83%BC%3A%20v4l2%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%3A%20mxc_v4l_read%20%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC0%3CBR%20%2F%3Ecat%3A%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E6%9C%9F%E9%99%90%E5%88%87%E3%82%8C%3CBR%20%2F%3Eroot%40esomimx6q%3A~%23%20cat%20%2Fdev%2Fvideo3%3CBR%20%2F%3E%5B%203403.463393%5D%E3%82%A8%E3%83%A9%E3%83%BC%3A%20v4l2%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%3A%20mxc_v4l_read%20%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC0%3CBR%20%2F%3E%5B%203403.469360%5D%20imx-ipuv3%202800000.ipu%3ACSI%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Ecat%3A%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E6%9C%9F%E9%99%90%E5%88%87%E3%82%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%AC%E4%BB%B6%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E3%81%94%E6%94%AF%E6%8F%B4%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82video1%E3%81%8A%E3%82%88%E3%81%B3video3%E3%81%AB%E3%81%8A%E3%81%84%E3%81%A6%E3%80%8Cnot%20a%20csi%20channel%EF%BC%88CSI%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%89%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E7%90%86%E7%94%B1%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E4%BB%96%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%AF%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E8%A6%8B%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%22vidioc_dqbuf%20failed%22%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E3%81%BB%E3%81%86%E3%81%8C%E3%80%81%E3%82%88%E3%82%8A%E9%87%8D%E8%A6%81%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116654%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116654%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%2236648%22%20data-username%3D%22Qiang_FSL%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20style%3D%22color%3A%20%23000000%3B%22%20target%3D%22_blank%22%3EQiang%20Li%3C%2FA%3E%20%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3Emax9286_mipi.c%20%E3%81%A7%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Ereg_item2_t%20ap0101_settings%5B%5D%20%3D%20%7B%3CBR%20%2F%3E%20%2F%2F%E3%82%B9%E3%83%86%E3%83%83%E3%83%972-PLL_%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%20-%20YUV8%20720p30%3CBR%20%2F%3E%20%7B%20%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E0xCA84%3C%2FSPAN%3E%20%2C%208%2C%200x05%7D%2C%20%2F%2F%20CAM_SYSCTL_PLL_CONTROL%3CBR%20%2F%3E%20%7B%20%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E0xCA88%3C%2FSPAN%3E%20%2C%2016%2C%200x0462%7D%2C%20%2F%2F%20CAM_SYSCTL_PLL_DIVIDER_M_N_1_CLK%3CBR%20%2F%3E%20%7B%20%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E0xCA8A%3C%2FSPAN%3E%20%2C%2016%2C%200x0462%7D%2C%20%2F%2F%20CAM_SYSCTL_PLL_DIVIDER_M_N_2_CLK%3CBR%20%2F%3E%20%7B%20%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E0xCA8C%3C%2FSPAN%3E%20%2C%2016%2C%200x00FF%7D%2C%20%2F%2F%20CAM_SYSCTL_PLL_DIVIDER_P_1_CLK%3CBR%20%2F%3E%20%7B%20%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E0xCA8E%3C%2FSPAN%3E%20%2C%2016%2C%200x007F%7D%2C%20%2F%2F%20CAM_SYSCTL_PLL_DIVIDER_P_2_CLK%3CBR%20%2F%3E%20%7B%20%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E0xCA9C%3C%2FSPAN%3E%20%2C%2016%2C%200x0405%7D%2C%20%2F%2F%20CAM_PORT_PARALLEL_CONTROL%2C%20YUV8%3CBR%20%2F%3E%20%7B%20%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E0xC838%3C%2FSPAN%3E%20%2C%2032%2C%200x080210C5%7D%2C%20%2F%2F%20CAM_SENSOR_CONTROL_EXTERNAL_PLL%3CBR%20%2F%3E%20%7B%20%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E0xC804%3C%2FSPAN%3E%20%2C%2016%2C%200x000C%7D%2C%20%2F%2F%20CAM_SENSOR_CFG_Y_ADDR_START%3C%2FP%3E%3CP%3E%26nbsp%3B................................%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E0xCA84%20%E3%81%AA%E3%81%A9%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116653%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116653%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%E4%BB%A5%E4%B8%8B%E3%81%8C%E7%A7%81%E3%81%AE%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%99%E3%80%82%E3%81%94%E5%AF%BE%E5%BF%9C%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20547px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F68151i926039B7A9A1744B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116650%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116650%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%8C%3CSPAN%3Eg2d.h%3C%2FSPAN%3E%E3%80%8D%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%80%8Cmxc_v4l2_tvin.c%E3%80%8D%E3%81%AB%E3%81%AF%E3%80%8C%23include%20%22g2d.h%22%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%80%83%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116649%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116649%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHI%20Qiang%20Li%3C%2FP%3E%3CP%3E%E3%80%8C%E3%83%91%E3%83%83%E3%83%81%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%20kernel-3.10.53%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%20%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E7%A7%81%E3%81%AF%3CSPAN%3Ekernel-3.10.53%E3%81%A8L3.10.53_1.1.0-GA%3C%2FSPAN%3E%E3%81%AE%E9%81%95%E3%81%84%E3%82%92%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EHi%20Li%20Qiang%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%81%95%E3%81%A6%E3%80%81%E3%80%8C%E3%83%91%E3%83%83%E3%83%81%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E5%B0%91%E3%81%97%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%80%8C%E3%83%91%E3%83%83%E3%83%81%E3%80%8D%E3%81%AE%E4%BD%BF%E3%81%84%E6%96%B9%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%92%E6%9B%B8%E3%81%84%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E5%BF%83%E3%81%8B%E3%82%89%E6%84%9F%E8%AC%9D%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EZhongmao%20Liu%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116646%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116646%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EHi.%20Qiang%20Li%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22mailto%3A720p%4060pfs%E7%9A%84camera%E6%97%B6%EF%BC%8C%E4%BB%8E%E6%91%84%E5%83%8F%E5%A4%B4%E6%8E%A5%E5%85%A5%E5%88%B0%E5%9C%A8%E5%B1%8F%E4%B8%8A%E6%98%BE%E7%A4%BA%E6%97%B6%E7%9A%84%E5%BB%B6%E8%BF%9F%E6%98%AF%E5%A4%9A%E5%B0%91%EF%BC%9Fp%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E720p%4060pfs%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%924%E5%8F%B0%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E6%8E%A5%E7%B6%9A%E3%81%8B%E3%82%89%E7%94%BB%E9%9D%A2%E8%A1%A8%E7%A4%BA%E3%81%BE%E3%81%A7%E3%81%AE%E9%81%85%E5%BB%B6%E3%81%AF%E3%81%A9%E3%82%8C%E3%81%8F%E3%82%89%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FA%3E%E3%81%93%E3%81%AE%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E6%8C%87%E6%A8%99%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E8%E3%82%A6%E3%82%A7%E3%82%A4%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E3%81%A8%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CA%20href%3D%22mailto%3A720p%4060pfs%25E7%259A%2584camera%25E6%2597%25B6%25EF%25BC%258C%25E4%25BB%258E%25E6%2591%2584%25E5%2583%258F%25E5%25A4%25B4%25E6%258E%25A5%25E5%2585%25A5%25E5%2588%25B0%25E5%259C%25A8%25E5%25B1%258F%25E4%25B8%258A%25E6%2598%25BE%25E7%25A4%25BA%25E6%2597%25B6%25E7%259A%2584%25E5%25BB%25B6%25E8%25BF%259F%25E6%2598%25AF%25E5%25A4%259A%25E5%25B0%2591%25EF%25BC%259Fp%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E720p%4060pfs%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%B8%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%8B%E3%82%89%E7%94%BB%E9%9D%A2%E8%A1%A8%E7%A4%BA%E3%81%BE%E3%81%A7%E3%81%AE%E9%81%85%E5%BB%B6%E3%81%AF%E3%81%A9%E3%82%8C%E3%81%8F%E3%82%89%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FA%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E6%8C%87%E6%A8%99%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116645%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116645%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EHi.%20Qiang%20Li%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E4%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E6%98%A0%E5%83%8F%E3%81%AF%E3%80%811080P%E3%81%AEHDMI%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%BB%E3%83%93%E3%83%A5%E3%83%BC%E3%83%BB%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%AF%E3%80%814%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%8F%96%E5%BE%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%8B%E8%89%AF%E3%81%84%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116644%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116644%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%A8%99%E6%BA%96%E3%81%AE720P60%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AF74.25MHz%E3%81%A7%E3%81%99%E3%80%82UYVY%E3%81%AE%E5%A0%B4%E5%90%8816bpp%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%811%20%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E5%B8%AF%E5%9F%9F%E5%B9%85%E3%81%AF%2074.25M*16%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3D%201.188Gbps%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EiMX8%20%E3%81%A8%20iMX8X%20%E3%81%AE%20MIPI%20CSI2%20%E3%81%AE%E6%9C%80%E5%A4%A7%E5%B8%AF%E5%9F%9F%E5%B9%85%E3%81%AF%206Gbps%20%E3%81%A7%E3%80%81%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%204%20%E3%81%A4%E3%81%AE%E4%BB%AE%E6%83%B3%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%90%84%20MIPI%20CSI2%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF%204%20%E5%8F%B0%E3%81%AE%20720P60%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82iMX8%20%E3%81%AB%E3%81%AF%202%20%E3%81%A4%E3%81%AE%20MIPI%20CSI2%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%818%20%E5%8F%B0%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82iMX8X%20%E3%81%AB%E3%81%AF%20MIPI%20CSI2%20%E3%81%8C%201%20%E3%81%A4%E3%81%97%E3%81%8B%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%814%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%818%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%91%E3%83%A9%E3%83%AC%E3%83%AB%20CSI%20%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%93%E3%82%8C%E3%82%82%201%20%E5%8F%B0%E3%81%AE%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%90%88%E8%A8%88%205%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EiMX8M%20%E3%81%AB%E3%81%AF%202%20%E3%81%A4%E3%81%AE%20MIPI%20CSI2%20%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%9E%E3%83%AB%E3%83%81%E4%BB%AE%E6%83%B3%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%812%20%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%97%E3%81%8B%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116643%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116643%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EHi%20Qiang%20Li%20!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eimx8%20%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%AE%20720P%2060fps%20%E3%82%AB%E3%83%A1%E3%83%A9%E5%85%A5%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%20(%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20IMX8%20%E3%82%92%E5%90%AB%E3%82%80)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116642%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116642%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%20!%3C%2FP%3E%3CP%3E%E3%80%8C60-persistent-v4l.rules%E3%80%8D%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8F%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%2Flib%2Fudev%2Frules.d%E3%81%AB%E3%81%82%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EGokcen%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi!%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%81%AF1280x720%E3%81%A7%E3%81%99%E3%80%82%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF4.1.15%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%5B%2036.921793%5D%20v4l2_int_device%20wlcore_sdio%20mxc_dcic%3CBR%20%2F%3E%5B%2036.926813%5D%20CPU%3A%203%20PID%3A%20399%20Comm%3A%20v4l_id%20Not%20tainted%204.1.15%231%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%5B%2094.823493%5D%20udevd%5B215%5D%3A%20worker%20%5B230%5D%E3%81%8C%20%2Fdevices%2Fsoc0%2Fv4l2_cap_1%2Fvideo4linux%2Fvideo1%E3%81%AE%E5%87%A6%E7%90%86%E3%81%AB%E6%99%82%E9%96%93%E3%82%92%E8%A6%81%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%5B%2095.098316%5D%20udevd%5B230%5D%3A%20%E9%81%85%E3%81%84%3A%20'v4l_id%20%2Fdev%2Fvideo1'%20%5B402%5D%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Ebootlogd%3A%20%E7%96%91%E4%BC%BCTTY%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%82%88%E3%81%84%E4%B8%80%E6%97%A5%E3%82%92%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116638%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116638%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%A9%9F%E5%99%A8%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EONSEMI%20MARS%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%EF%BC%88MAX96705%E3%80%81AP0101%E3%80%81AR0140%EF%BC%89%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%AB%E3%81%AF%E3%80%8130cm%E3%81%AERG174%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%EF%BC%88%E3%81%8A%E3%82%88%E3%81%B33m%E3%81%AE%E5%90%8C%E8%BB%B8%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%EF%BC%89%E3%82%82%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EMAX9286S32V%E3%83%89%E3%83%BC%E3%82%BF%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81i.MX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E5%8F%96%E3%82%8A%E5%A4%96%E3%81%97%E3%81%A6%E3%80%81AP0101%E3%82%92%E3%83%9B%E3%82%B9%E3%83%88%E6%A7%8B%E6%88%90%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%81%AE%E8%87%AA%E5%8B%95%E5%BF%9C%E7%AD%94%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81MAX9286%E3%81%AE34%E7%95%AA%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB0x36%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%82%8B%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81SCL%E3%81%AE8%E3%83%93%E3%83%83%E3%83%88%E7%9B%AE%E3%81%AE%E7%9B%B4%E5%BE%8C%E3%81%AB9%E3%83%93%E3%83%83%E3%83%88%E7%9B%AE%E3%81%8C%E3%81%99%E3%81%90%E3%81%AB%E7%8F%BE%E3%82%8C%E3%82%8B%E3%81%AE%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%AA%E3%82%B7%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%AE%E5%87%BA%E5%8A%9B%E7%B5%90%E6%9E%9C%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%95%8F%E9%A1%8C%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%82%8B%E3%83%93%E3%83%83%E3%83%88%E3%81%AB%E3%81%AF%E8%B5%A4%E3%81%84%E4%B8%B8%E3%82%92%E4%BB%98%E3%81%91%E3%81%A6%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EMAX9286%20LFLT%20LED%20%E3%81%AF%E3%82%AA%E3%83%B3%E3%81%A7%E3%80%81LOCK%20LED%20%E3%81%AF%E3%82%AA%E3%83%95%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tek00002.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tek00002.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F66105i41676A217FBC9F2A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22tek00002.png%22%20alt%3D%22tek00002.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81AP0101%EF%BC%88%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%EF%BC%9A0x92%EF%BC%89%E3%81%8B%E3%82%89%E3%81%AE%E8%AA%AD%E3%81%BF%E5%87%BA%E3%81%97%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%9F%E7%B5%90%E6%9E%9C%E3%81%A7%E3%81%99%E3%80%82%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tek00003.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tek00003.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F66119i638B78663985C83C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22tek00003.png%22%20alt%3D%22tek00003.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E4%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E-%201xCSI%2C%203xMIPI%3C%2FP%3E%3CP%3E-%202xCSI%2C%202xMIPI%3C%2FP%3E%3CP%3E-%204xMIPI%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%AF%E4%BB%A5%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%E4%B8%8A%E9%9D%A2%E7%9A%84CSI%E5%92%8CMIPI%E4%BB%80%E4%B9%88%E6%84%8F%E6%80%9D%E5%90%97%EF%BC%9F%E4%B8%8D%E7%9F%A5%E9%81%93%E8%BF%99%E4%B8%AAcsi%E6%98%AF%E6%8C%87ipu%E5%86%85%E9%83%A8%E7%9A%84csi0-3%20%E8%BF%98%E6%98%AFcamera%20mipi%E6%80%BB%E7%BA%BF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116636%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116636%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1xCSI%E3%80%813xMIPI%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%A9%E3%81%86%E3%81%84%E3%81%86%E6%84%8F%E5%91%B3%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20qiang%20%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB'mx8_v4l2_cap_drm.out'%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E5%87%A6%E7%90%86%E3%81%8C'start_capturing'%E9%96%A2%E6%95%B0%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AB%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF'ioctl(fd_v4l%2C%20VIDIOC_DQBUF%2C%20%26amp%3Bbuf)'%E9%96%A2%E6%95%B0%E3%81%A7%E5%87%A6%E7%90%86%E3%81%8C%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81MAX9286%E3%81%AE4%E3%81%A4%E3%81%AE%E5%87%BA%E5%8A%9B%E4%BF%A1%E5%8F%B7%EF%BC%88Dout0%E3%80%9CDout3%EF%BC%89%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AB%E4%BF%A1%E5%8F%B7%E3%81%8C%E5%87%BA%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AF295MHz%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E5%85%A5%E5%8A%9B%E5%81%B4%E3%81%AB%E3%82%82%E4%BF%A1%E5%8F%B7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82MAX9286%E3%81%A8%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E7%94%BB%E9%9D%A2%E3%81%AB%E3%81%AF%E4%BD%95%E3%82%82%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E6%95%B0%E6%97%A5%E9%96%93%E6%82%A9%E3%81%BE%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%8A%E9%A1%98%E3%81%84%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%AD%E3%82%B0%E3%82%92%E4%BB%A5%E4%B8%8B%E3%81%AB%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40imx8mqevk%3A~%23%20.%2Fmx8_v4l2_cap_drm.out%20-cam%203%3CBR%20%2F%3Einit_video_channel%2C%20%2Fdev%2Fvideo0%20%E5%88%9D%E6%9C%9F%E5%8C%96%E4%B8%AD%200%3CBR%20%2F%3Einit_video_channel%2C%20%2Fdev%2Fvideo1%20%E5%88%9D%E6%9C%9F%E5%8C%96%E4%B8%AD%201%3CBR%20%2F%3E%20%2Fdev%2Fdri%2Fcard0%20%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E6%88%90%E5%8A%9F%3CBR%20%2F%3Efb%E6%95%B0%3A0%3CBR%20%2F%3Ecrtc%E6%95%B0%3A2%3CBR%20%2F%3E%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E6%95%B0%3A1%3CBR%20%2F%3E%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E6%95%B0%3A1%3CBR%20%2F%3E%E3%83%A2%E3%83%BC%E3%83%89%E6%95%B0%20%3D%201%3CBR%20%2F%3E%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E6%95%B0%20%3D%201%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E6%95%B0%20%3D%202%5B%2021.059227%5D%20mxc-mipi-csi2%2058227000.csi%3Awidth%3D1280%2C%20height%3D800%2C%20fmt.code%3D0x2011%3C%2FP%3E%3CP%3Emodes%5B0%5D%20%E6%83%85%E5%A0%B1%3A%E8%A7%A3%E5%83%8F%E5%BA%A6%3D1024*600%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%3CBR%20%2F%3Ekms%20%E6%83%85%E5%A0%B1%3A%20fb_base%20%3D%200%5B%2021.071187%5D%20%E5%85%A5%E5%8A%9B%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20YUV4%3CBR%20%2F%3Ex789b3000%3CBR%20%2F%3Ew%2Fh%3D(1024%2C600)%3CBR%20%2F%3Ebits_per_pixel%3D4%3CBR%20%2F%3Ebpp%3D32%3CBR%20%2F%3Escreen_buf_s%5B%2021.079551%5D%20%E5%87%BA%E5%8A%9B%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20RGB4%3CBR%20%2F%3Eize%20%3D2457600%3CBR%20%2F%3Exres%3D1024%2C%20y_res%3D600%3CBR%20%2F%3Ech_id%3D0%2C%20w%3D512%2C%20h%3D300%2C%20x_offs%5B%2021.088947%5D%20mxc-isi%2058100000.isi%3Ainput_size(800%2C1280)%2C%20output_size(300%2C512)%3CBR%20%2F%3Eet%3D0%2C%20y_offset%3D0%3CBR%20%2F%3Ech_id%3D1%2C%20w%3D512%2C%20h%3D300%2C%20x_offset%3D512%2C%20y_offset%3D0%5B%2021.105981%5D%20mxc-mipi-csi2%2058227000.csi%3Awidth%3D1280%2C%20height%3D800%2C%20fmt.code%3D0x2011%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2Fdev%2Fvideo0%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%92%E8%A9%A6%E8%A1%8C%E4%B8%AD%3CBR%20%2F%3Ecap%3D0x84201000%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3D0%3CBR%20%2F%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%5B%2021.113602%5D%20%E5%85%A5%E5%8A%9B%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20YUV4%3CBR%20%2F%3E%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20(%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B)%3A%20RGBP%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3D1%3CBR%20%2F%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20(%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B)%20%5B%2021.121958%5D%20%E5%87%BA%E5%8A%9B%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20RGB4%3CBR%20%2F%3E(%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B)%3A%20RGB3%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3D2%3CBR%20%2F%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20(%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B)%3A%20RGB4%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%5B%2021.130400%5D%20mxc-isi%2058110000.isi%3Ainput_size(800%2C1280)%2C%20output_size(300%2C512)%3CBR%20%2F%3Ex%3D3%3CBR%20%2F%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20(%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B)%3A%20BGR3%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3D4%3CBR%20%2F%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20(%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B)%3A%20BA24%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3D5%3CBR%20%2F%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20(%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B)%5B%2021.150628%5D%20mxc-mipi-csi2%2058227000.csi%3Awidth%3D1280%2C%20height%3D800%2C%20fmt.code%3D0x2011%3CBR%20%2F%3E%3A%20YUYV%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3D6%3CBR%20%2F%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20(%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B)%3A%20YUV4%3CBR%20%2F%3EVIDIOC%20ENUM%20FMT%E5%A4%B1%E6%95%97%2C%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3D7%20%3CBR%20%2F%3Evideo_ch%3D0%2C%20width%3D512%2C%20height%3D300%2C%20%3CBR%20%2F%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3A%20RGB4%3CBR%20%2F%3E%20WxH%40fps%20%3D%20512x300%4030%20%E7%94%BB%E5%83%8F%E3%82%B5%E3%82%A4%E3%82%BA%20%3D%20614400%3CBR%20%2F%3Ev4l_capture_setup%2C%20Open%20v4l_dev%3D0x4%2C%20channel%3D0%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2Fdev%2Fvideo1%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%92%E8%A9%A6%E8%A1%8C%E4%B8%AD%3CBR%20%2F%3Ecap%3D0x84201000%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3D0%3CBR%20%2F%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20(%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B)%3A%20RGBP%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3D1%3CBR%20%2F%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20(%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B)%3A%20RGB3%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3D2%3CBR%20%2F%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20(%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B)%3A%20RGB4%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3D3%3CBR%20%2F%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20(%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B)%3A%20BGR3%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3D4%3CBR%20%2F%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20(%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B)%3A%20BA24%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3D5%3CBR%20%2F%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20(%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B)%3A%20YUYV%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3D6%3CBR%20%2F%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20(%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B)%3A%20YUV4%3CBR%20%2F%3EVIDIOC%20ENUM%20FMT%E5%A4%B1%E6%95%97%2C%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3D7%20%3CBR%20%2F%3Evideo_ch%3D1%2C%20width%3D512%2C%20height%3D300%2C%20%3CBR%20%2F%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3A%20RGB4%3CBR%20%2F%3E%20WxH%40fps%20%3D%20512x300%4030%20%E7%94%BB%E5%83%8F%E3%82%B5%E3%82%A4%E3%82%BA%20%3D%20614400%3CBR%20%2F%3Ev4l_capture_setup%2C%20v4l_dev%3D0x5%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%2C%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%3D1%3CBR%20%2F%3E%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%5B0%5D%20startAddr%3D0x7891d000%2C%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3D0x0%2C%20buf_size%3D614400%3CBR%20%2F%3E%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%5B1%5D%20startAddr%3D0x78887000%2C%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3D0x96000%2C%20buf_size%3D614400%3CBR%20%2F%3E%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%5B2%5D%20startAddr%3D0x787f1000%2C%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3D0x12c000%2C%20buf_size%3D614400%3CBR%20%2F%3E%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%5B0%5D%20startAddr%3D0x7875b000%2C%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3D0x0%2C%20buf_size%3D614400%3CBR%20%2F%3E%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%5B1%5D%20startAddr%3D0x786c5000%2C%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3D0x96000%2C%20buf_size%3D614400%3CBR%20%2F%3E%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%5B2%5D%20startAddr%3D0x7862f000%2C%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3D0x12c000%2C%20buf_size%3D614400%EF%BD%82%3CBR%20%2F%3Estart_capturing%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%3D0%2C%20v4l_dev%3D0x4%3CBR%20%2F%3Estart_capturing%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%3D1%2C%20v4l_dev%3D0x5%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ei.MX8M%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E6%AD%A3%E3%81%97%E3%81%84%E5%AE%9F%E8%A1%8C%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%A9%E3%82%8C%E3%81%8B%E3%80%81%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3CIMG%20data-custom%3D%22AAMkADE5ZGEwYzU4LTZkY2UtNGQwOS1hMGM4LTM5YWJhZTY2MGI2MABGAAAAAABmjdtvz7q%252FTJBDgxuz9lskBwBqSWXQe3qtRo%252F37gmvj2roAAos0XePAADu7T14o7e1RrYLOTRTwTUNAABK19s1AAABEgAQAJebFUz9EYJHtkNAjqSUp3A%253D%22%20data-downloadimage%3D%22service.svc%2Fs%2FGetFileAttachment%3Fid%3DAAMkADE5ZGEwYzU4LTZkY2UtNGQwOS1hMGM4LTM5YWJhZTY2MGI2MABGAAAAAABmjdtvz7q%252FTJBDgxuz9lskBwBqSWXQe3qtRo%252F37gmvj2roAAos0XePAADu7T14o7e1RrYLOTRTwTUNAABK19s1AAABEgAQAJebFUz9EYJHtkNAjqSUp3A%253D%26amp%3BX-OWA-CANARY%3DasQ4qVui-0GtcywhvNNQmcBJfpHGsNUYnhPJi77cJvg1a7XfqbNhlZQ566OMYlqzfxU2YD4q4K0.%22%20data-imagetype%3D%22AttachmentByCid%22%20data-thumbnailimage%3D%22https%3A%2F%2Fattachment.outlook.office.net%2Fowa%2Fhuang.benson%40inventec.com%2Fservice.svc%2Fs%2FGetFileAttachment%3Fid%3DAAMkADE5ZGEwYzU4LTZkY2UtNGQwOS1hMGM4LTM5YWJhZTY2MGI2MABGAAAAAABmjdtvz7q%252FTJBDgxuz9lskBwBqSWXQe3qtRo%252F37gmvj2roAAos0XePAADu7T14o7e1RrYLOTRTwTUNAABK19s1AAABEgAQAJebFUz9EYJHtkNAjqSUp3A%253D%26amp%3BX-OWA-CANARY%3DasQ4qVui-0GtcywhvNNQmcBJfpHGsNUYnhPJi77cJvg1a7XfqbNhlZQ566OMYlqzfxU2YD4q4K0.%26amp%3Btoken%3DeyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiIsIng1dCI6IkJnRDU5blJpQnpmbk5BVGloOFJhZ1l5M3pyZyJ9.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.qaxYVZySJYx1QE_ZEsX5P-EA3YJzdm2uvF9VrbUOXEO_I9ssi_mWH9Kv6lR6GGBbV8F2l1zsYVflAUCXjyU2POUC_X1GT0aXdrSiPHcOVbdmTpmLmuHPC_X1E-2pEWOAT9msbbiqVmfdqIa3RG_HfUE5I69Bffx_OJj0mb89ShVowrVOuyuMYufSdps3Cz90U_zru7HkcKxW8l4GBR2u21x2r78ZAak8X0AWJO9-tAI-_lq7uTde9n3wmJo7JDYVVCiI5RTfl4eNmjQYs9J8ZwgwoIAakW1NqDI27DYraQuxslAWHLPK8nr5j42O0HfI4bV1FN-autCgjLg_bgsMjQ%26amp%3Bowa%3Doutlook.office.com%26amp%3BisImagePreview%3DTrue%22%20src%3D%22https%3A%2F%2Fattachment.outlook.office.net%2Fowa%2Fhuang.benson%40inventec.com%2Fservice.svc%2Fs%2FGetFileAttachment%3Fid%3DAAMkADE5ZGEwYzU4LTZkY2UtNGQwOS1hMGM4LTM5YWJhZTY2MGI2MABGAAAAAABmjdtvz7q%252FTJBDgxuz9lskBwBqSWXQe3qtRo%252F37gmvj2roAAos0XePAADu7T14o7e1RrYLOTRTwTUNAABK19s1AAABEgAQAJebFUz9EYJHtkNAjqSUp3A%253D%26amp%3BX-OWA-CANARY%3DasQ4qVui-0GtcywhvNNQmcBJfpHGsNUYnhPJi77cJvg1a7XfqbNhlZQ566OMYlqzfxU2YD4q4K0.%26amp%3Btoken%3DeyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiIsIng1dCI6IkJnRDU5blJpQnpmbk5BVGloOFJhZ1l5M3pyZyJ9.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.qaxYVZySJYx1QE_ZEsX5P-EA3YJzdm2uvF9VrbUOXEO_I9ssi_mWH9Kv6lR6GGBbV8F2l1zsYVflAUCXjyU2POUC_X1GT0aXdrSiPHcOVbdmTpmLmuHPC_X1E-2pEWOAT9msbbiqVmfdqIa3RG_HfUE5I69Bffx_OJj0mb89ShVowrVOuyuMYufSdps3Cz90U_zru7HkcKxW8l4GBR2u21x2r78ZAak8X0AWJO9-tAI-_lq7uTde9n3wmJo7JDYVVCiI5RTfl4eNmjQYs9J8ZwgwoIAakW1NqDI27DYraQuxslAWHLPK8nr5j42O0HfI4bV1FN-autCgjLg_bgsMjQ%26amp%3Bowa%3Doutlook.office.com%26amp%3BisImagePreview%3DTrue%22%20style%3D%22max-width%3A%20525px%3B%20max-height%3A%20244px%3B%20width%3A%20100%25%3B%20cursor%3A%20pointer%3B%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20qiang%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20imx8qxp%E3%83%99%E3%83%BC%E3%82%B9%E3%81%A7360%E5%BA%A6%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%81%AE%E7%A7%BB%E6%A4%8D%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AF4.9.51%E3%81%A7%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AFAP0101%EF%BC%8BAR0140%E3%80%81%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E6%A7%8B%E6%88%90%E8%A6%81%E7%B4%A0%E3%81%A8%E3%81%97%E3%81%A6MAX9286%EF%BC%8BMAX96705%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82imx6q%E7%94%A8%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92imx8%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%83%AD%E3%82%B0%E4%B8%8A%E3%81%A7MAX9286%E3%81%8A%E3%82%88%E3%81%B34%E3%81%A4%E3%81%AEAP0101%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81imx6%E7%94%A8%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%82%B3%E3%83%BC%E3%83%89'mxc_v4l2_tvin.out'%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81'no%20such%20files%20found%EF%BC%88%E8%A9%B2%E5%BD%93%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%89'%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82imx6%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8Cimx8qxp%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%AF%E7%A2%BA%E4%BF%A1%E3%81%8C%E6%8C%81%E3%81%A6%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82imx8%E5%B0%82%E7%94%A8%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%82%82%E3%81%97%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%83%87%E3%83%A2%E3%82%92%E3%81%94%E6%8F%90%E4%BE%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EJun%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116627%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116627%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EFRSYNC%2FGPI%E3%81%AFiMX6%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81CSI0_MCLK%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E5%8B%95%E4%BD%9C%E3%83%A2%E3%83%BC%E3%83%89%E8%A8%AD%E5%AE%9A%E3%81%AFMAX9286%E3%81%A8%E3%82%AB%E3%83%A1%E3%83%A9%E9%96%93%E3%81%A7%E8%A1%8C%E3%82%8F%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81MAX9286%E3%81%A8%E3%82%AB%E3%83%A1%E3%83%A9%EF%BC%88AP0101%EF%BC%89%E9%96%93%E3%81%AE%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AA%E6%8E%A5%E7%B6%9A%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AFMaxim%E3%81%AB%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82iMX6%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81MIPI%20CSI2%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%A8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E3%81%BF%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMAX9286%20%E3%81%A8%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E5%8B%95%E4%BD%9C%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81MIPI%20%E3%81%8B%E3%82%89%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%82%8B%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E7%95%B0%E5%B8%B8%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81Jianfeng%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%E3%80%8C%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222004%22%20data-containertype%3D%2214%22%20data-objectid%3D%22335803%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-335803%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%235e89c1%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-335803%22%20target%3D%22test_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-335803%3C%2FA%3E%E3%80%8D%E3%81%AB%E3%81%82%E3%82%8B%E3%80%8Cmxc_v4l2_tvin%E3%80%8D%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%93%E3%81%A1%E3%82%89%E3%81%A7%E3%81%AF%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%AF%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81mxc_v4l2_tvin.c%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92PC%E3%81%A7YUVPlayer%E3%81%AA%E3%81%A9%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8C%E3%81%B0%E3%80%81%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F*%3CBR%20%2F%3E%26nbsp%3Bchar%20still_file%5B100%5D%20%3D%20%22.%2Fstill.yuv%22%3B%3CBR%20%2F%3E%26nbsp%3Bint%20fd_still%20%3D%200%3B%3CBR%20%2F%3E%26nbsp%3Bif%20((fd_still%20%3D%20open(still_file%2C%20O_RDWR%20%7C%20O_CREAT%20%7C%20O_TRUNC%2C%200x0666))%20%26lt%3B%200)%3CBR%20%2F%3E%26nbsp%3B%7B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3Bprintf(%22Unable%20to%20create%20y%20frame%20recording%20file%5Cn%22)%3B%3CBR%20%2F%3E%26nbsp%3B%7D%3CBR%20%2F%3E*%2F%3C%2FP%3E%3CP%3E...%20...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%26nbsp%3B%26nbsp%3Bif(i%26gt%3B100%20%26amp%3B%26amp%3B%20i%26lt%3B120)%3CBR%20%2F%3E%2F%2F%26nbsp%3B%26nbsp%3B%26nbsp%3Bwrite(fd_still%2C%20capture_buffers%5Bcapture_buf.index%5D.start%2C720*240*2)%3B%3C%2FP%3E%3CP%3E...%20...%3C%2FP%3E%3CP%3E%2F%2F%26nbsp%3Bclose(fd_still)%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116624%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116624%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Pengtao%EF%BC%8C%3C%2FP%3E%3CP%3EAP0101%E3%81%AF%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%83%A9%E3%83%B3%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E5%90%8C%E6%9C%9F%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%83%A9%E3%83%B3%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%811%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%A7%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E8%A4%87%E6%95%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%A7%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E7%8F%BE%E8%B1%A1%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20ROM%20%E3%81%AB%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116623%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116623%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EHi%20Qiang%20Li%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3EL3.14.52_GA1.1.0%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E7%8A%B6%E6%B3%81%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E1.%20%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3EOnsemi%20AR0143%2BAP0101%2BMAX9%3C%2FSPAN%3E%20%3CSPAN%3E6705%2BMax9286%2BImx6D%20%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E2.%20Onsemi%20AR0143%2BAP0101%2BMAX9%20%3CSPAN%3E6705%2BMax9286%2BImx6D%20%E5%8F%8C%E6%96%B9%E5%90%91%E8%A1%A8%E7%A4%BA%E5%8A%B9%E6%9E%9C%E3%81%AF%E5%9B%B3%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%8F%B3%E5%81%B4%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%A8%E3%80%81%E3%81%AA%E3%81%9C%E3%81%9D%E3%81%86%E3%81%AA%E3%82%8B%E3%81%AE%E3%81%8B%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%B7%91%E8%89%B2%E3%81%8C%E3%81%8B%E3%81%A3%E3%81%9F%204%20%E3%81%A4%E3%81%AE%E5%90%8C%E4%B8%80%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22360.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22360.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F15829iF86E8C3036F81D2F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22360.jpg%22%20alt%3D%22360.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116622%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116622%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%9C%E3%82%B9%E3%80%81%E4%BB%A5%E5%89%8D%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B33.0.35%E3%81%A7%E8%AA%BF%E6%95%B4%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%20%E3%81%9C%E3%81%B2%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116621%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116621%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Ehi%20liqiang%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%26nbsp%3B%20imx6d%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%ABimx6q%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6%E8%A7%A3%E6%B6%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%8A%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%8C%E6%80%9D%E3%81%84%E4%BB%98%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%A8%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116620%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116620%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%20liqiang%2C%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%82%E3%81%97%E3%81%8B%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81imx6Q%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%20imx6D%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9Fimx6D%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8C%E3%81%B0%E6%AD%A3%E3%81%97%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%81%94%E6%94%AF%E6%8F%B4%E3%81%AE%E3%81%BB%E3%81%A9%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116617%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116617%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%20liqiang%2C%3C%2FP%3E%3CP%3Emxc_v4l2_tvin_max9286.tar%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C2%E7%82%B9%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%94%BB%E9%9D%A2%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%81%AF800x480%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%22mxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20800%20-oh%20480%20-d%201%20-x%200%22%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20905px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F22728i37DD38904104B984%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E1.%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%22%3CSPAN%3Emxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20400%20-oh%20240%20-d%201%20-x%200%3C%2FSPAN%3E%22%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E7%94%BB%E9%9D%A2%E3%81%8C%E3%82%B9%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20950px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F22562i380E0C90D2FAF4C3%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%22%20%3CSPAN%3Emxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20800%20-oh%20480%20-d%201%20-x%200%20-g2d%22%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E7%94%BB%E9%9D%A2%E3%81%AB%E3%81%A1%E3%82%89%E3%81%A4%E3%81%8D%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20974px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F22616i7656661182A8D79E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%94%E5%A4%9A%E5%BF%99%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E6%81%90%E3%82%8C%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CDIV%20style%3D%22margin-top%3A%200%3B%20margin-bottom%3A%200%3B%22%3E%3CSTRONG%3EIMX8%20BSP%E3%81%8CMAX9286%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81i.MX8Q%E3%81%AE%E3%81%BF%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FSTRONG%3E%20%3C%2FDIV%3E%3CDIV%20style%3D%22margin-top%3A%200%3B%20margin-bottom%3A%200%3B%22%3EMAX9286%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81MIPI%20CSI2%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A8%E9%80%A3%E6%90%BA%E3%81%97%E3%81%A6%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22margin-top%3A%200%3B%20margin-bottom%3A%200%3B%22%3Ei.MX8Q%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%EF%BC%88fsl-imx8qm-mek.dts%EF%BC%89%E3%81%A7%E3%81%AF%E3%80%81'fsl%2Cmxc-mipi-csi2'%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%EF%BC%88drivers%2Fmedia%2Fplatform%2Fimx8%2Fmxc-mipi-csi2.c%EF%BC%89%E3%81%A8%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22margin-top%3A%200%3B%20margin-bottom%3A%200%3B%22%3E%E4%B8%80%E6%96%B9%E3%80%81%3CSTRONG%3Ei.MX8M%3C%2FSTRONG%3E%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%A7%E3%81%AF%E3%80%81MIPI%20CSI2%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A8%E3%81%97%E3%81%A6'fsl%2Cmxc-mipi-csi2_yav'%EF%BC%88drivers%2Fmedia%2Fplatform%2Fimx8%2Fmxc-mipi-csi2-yav.c%EF%BC%89%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22margin-top%3A%200%3B%20margin-bottom%3A%200%3B%22%3E%E3%81%93%E3%82%8C%E3%82%892%E3%81%A4%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E6%AF%94%E8%BC%83%E3%81%97%E3%81%9F%E7%B5%90%E6%9E%9C%E3%80%81%E4%B8%BB%E3%81%AA%E9%81%95%E3%81%84%E3%81%AF%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E6%93%8D%E4%BD%9C%E3%81%A8V4L2%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%83%91%E3%83%83%E3%83%89%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E5%87%A6%E7%90%86%E3%81%AB%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22margin-top%3A%200%3B%20margin-bottom%3A%200%3B%22%3E%20%3C%2FDIV%3E%3CDIV%20style%3D%22margin-top%3A%200%3B%20margin-bottom%3A%200%3B%22%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22margin-top%3A%200%3B%20margin-bottom%3A%200%3B%22%3E%26nbsp%3B%201.%20'fsl%2Cmxc-mipi-csi2'%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81%3CSTRONG%3Ei.MX8M%3C%2FSTRONG%3E%E4%B8%8A%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FDIV%3E%3CDIV%20style%3D%22margin-top%3A%200%3B%20margin-bottom%3A%200%3B%22%3E%26nbsp%3B%202.%20%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81'fsl%2Cmxc-mipi-csi2_yav'%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E4%BB%AE%E6%83%B3%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E9%81%A9%E5%88%87%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FDIV%3E%3CDIV%20style%3D%22margin-top%3A%200%3B%20margin-bottom%3A%200%3B%22%3E%26nbsp%3B%203.%E3%81%BE%E3%81%9F%E3%80%81%3CSTRONG%3E'fsl%2Cmxc-mipi-csi2_yav'%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A7%E4%BB%AE%E6%83%B3%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E6%A9%9F%E8%83%BD%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FSTRONG%3E%EF%BC%88i.MX8M%E3%81%AE%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81MIPI%20CSI2%E3%81%AE%E4%BB%AE%E6%83%B3%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%8D%81%E5%88%86%E3%81%AA%E6%83%85%E5%A0%B1%E3%81%8C%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%89%3C%2FDIV%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116615%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116615%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ezhang%20hongliang%20%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E7%A7%81%E3%81%AE%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A8%E5%90%8C%E3%81%98%E3%80%81ov10640%2B%20ov490%20ISP%20%2B%20max96705%E3%81%A7%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%B8%88%E3%81%BF%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%82%92%E9%80%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E3%80%81%E5%85%AC%E5%BC%8F%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%A9%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%84%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116613%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116613%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23545454%3B%20background-color%3A%20%23ffffff%3B%22%3ELI-USB30-OV10635-SER%E3%82%92USB%203.0%E7%B5%8C%E7%94%B1%E3%81%A7PC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81%E3%83%84%E3%83%BC%E3%83%AB%E4%B8%8A%E3%81%A7%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81OV10635%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E8%87%AA%E4%BD%93%E3%81%AB%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%AA%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23545454%3B%20background-color%3A%20%23ffffff%3B%22%3Emax9286%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%80%81max9286%20%E3%81%AF%20I2C%20%E3%81%A7%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E5%8F%AF%E8%83%BD%E3%81%A7%E3%80%81I2C%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%3CSPAN%3Emax9286%E3%81%8A%E3%82%88%E3%81%B3max96705%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%81%AF%E3%80%81i.MX8X%EF%BC%88%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B34.9.51%EF%BC%89%E4%B8%8A%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Ei.MX8X%E4%B8%8A%E3%81%A7max9286%E3%81%8A%E3%82%88%E3%81%B3max96705%2Bov10635%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF4.9.51%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%26nbsp%3B%E3%81%93%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%AF%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB4.9.51%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%A8%99%E6%BA%96%E3%81%AEmax9286%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E6%99%82%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3EOV10635%E3%81%A8%E3%81%AEI2C%E9%80%9A%E4%BF%A1%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%90%8C%E3%81%98I2C%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8Bmax9286%E3%81%A8%E3%81%AE%E9%80%9A%E4%BF%A1%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%AD%E3%82%B0%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.525043%5D%20mxc-mipi-csi2%2058227000.csi%3A%20mipi_csi2_probe%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.549343%5D%20mxc-mipi-csi2%2058227000.csi%3A%20lanes%3A%204%2C%20name%3A%20mxc-mipi-csi2.0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.556705%5Dmax9286_mipi%200-006a%3A%20In%20max9286_hardware_preinit()%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%EF%BC%BB2.854197%EF%BC%BDmax9286_mipi%3A%20reg%20%3D%200xf0%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%EF%BC%BB2.857870%EF%BC%BDmax9286_mipi%3A%20%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E7%95%AA%E5%8F%B7%20%3D%204%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.862158%5Dmax9286_mipi%200-006a%3A%20In%20max9286_hardware_init()%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%EF%BC%BB2.893273%EF%BC%BDmax9286_mipi%3A%20%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20%3D%200x01%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.921271%5D%20max9286_mipi%3A%20%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%26nbsp%3B%20%3D%200x02.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%EF%BC%BB2.949272%EF%BC%BDmax9286_mipi%3A%20%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20%3D%200x03%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%EF%BC%BB2.977271%EF%BC%BDmax9286_mipi%3A%20%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20%3D%200x04%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%EF%BC%BB3.145279%EF%BC%BDmax9286_mipi%200-006a%3A%20ov10635_read_reg%3A%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20reg%3D0x300a%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%EF%BC%BB3.152433%EF%BC%BDmax9286_mipi%200-006a%3A%20ov10635_check_device%3A%20OV10635%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%81reg%EF%BC%BB0x300a%EF%BC%BD%EF%BC%9D0x0%E3%80%81index%EF%BC%9D1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%EF%BC%BB3.321275%EF%BC%BDmax9286_mipi%200-006a%3A%20ov10635_read_reg%3A%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20reg%3D0x300a%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203.328419%5D%20max9286_mipi%200-006a%3A%20ov10635_check_device%3A%20OV10635%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%2C%20reg%5B0x300a%5D%20%3D%200x0.%2C%20index%3D2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%EF%BC%BB3.497275%EF%BC%BDmax9286_mipi%200-006a%3A%20ov10635_read_reg%3A%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20reg%3D0x300a%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203.504421%5D%20max9286_mipi%200-006a%3A%20ov10635_check_device%3A%20OV10635%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%2C%20reg%5B0x300a%5D%20%3D%200x0.%2C%20index%3D3%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203.673275%5D%20max9286_mipi%200-006a%3A%20ov10635_read_reg%3A%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20reg%3D0x300a%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203.680420%5D%20max9286_mipi%200-006a%3A%20ov10635_check_device%3A%20OV10635%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%2C%20reg%5B0x300a%5D%20%3D%200x0%E3%80%81index%3D4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%204.752679%5D%20max9286_mipi%200-006a%3A%20max9286_mipi%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%2C%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E5%90%8D%3A%20max9286_mipi%200-006a%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AE%E9%83%A8%E5%88%86%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%20ov10635%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E9%9A%9C%E5%AE%B3%E3%81%AB%E3%81%A4%E3%81%AA%E3%81%8C%E3%82%8B%E3%81%AE%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A8%E3%81%A6%E3%82%82%E5%8F%82%E8%80%83%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%822%E5%8F%B0%E3%81%AECSI2%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AB%E7%9B%B4%E6%8E%A5%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%882%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%81%AE2%E7%B5%84%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%9A%E3%82%A2%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%87%A6%E7%90%86%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%89%EF%BC%9F%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81%E4%BF%A1%E5%8F%B7%E3%82%A2%E3%82%B0%E3%83%AA%E3%82%B2%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%A4%87%E6%95%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%921%E3%81%A4%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20li%3C%2FP%3E%3CP%3Emax9286%E3%81%A8max96705%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%8E%A5%E7%B6%9A%E3%81%8C%E4%B8%8D%E5%AE%89%E5%AE%9A%E3%81%AA%E3%82%88%E3%81%86%E3%81%A7%E3%80%81%22mipi%20csi2%20can%20not%20receive%20sensor%20clk...%EF%BC%88MIPI%20CSI2%E3%81%8C%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93...%EF%BC%89%22%20%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E6%99%82%E6%8A%98%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E8%A8%AD%E5%AE%9A%E8%87%AA%E4%BD%93%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F328548-7-390480%2FL3.10.53_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip%22%20target%3D%22_blank%22%3E%3CSTRONG%20style%3D%22color%3A%20%235e89c1%3B%22%3EL3.10.53_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip%3C%2FSTRONG%3E%3C%2FA%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E5%86%85%E3%81%A7%E3%80%81MAX9286%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF0x3F%E3%81%8A%E3%82%88%E3%81%B30x3B%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%AA%AC%E6%98%8E%E3%81%8C%E8%A6%8B%E5%BD%93%E3%81%9F%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116600%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116600%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EQiang%20Li%E3%81%95%E3%82%93%E3%80%81%E7%8F%BE%E5%9C%A8Linux%203.14.52%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7MAX96705%2BAP0101%2BAR0141%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%E4%BD%95%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%8B%E3%80%81%E3%81%94%E6%95%99%E7%A4%BA%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E-oh%20540%20-d%201%20-x%200%20-g2da%2Fusb%2FCameraTest%23%20.%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20960%20%3CBR%20%2F%3E%5B%2034.334381%5D%20max9286_read_reg%200x49%20%3D%201.%3CBR%20%2F%3E%5B%2034.338883%5D%20mipi_csi2_set_lanes%20%3D%203.%3CBR%20%2F%3E%5B%2034.342494%5D%20mxc_mipi_csi2%2021dc000.mipi_csi%3A%20mipi_csi2_reset%3A%20mipi_lane_bps%20%3D%20148%20Mbps%3CBR%20%2F%3E%5B%2034.350399%5D%20mxc_mipi_csi2%2021dc000.mipi_csi%3A%20mipi_csi2_reset%3A%20value%20%3D%200x42.%3CBR%20%2F%3E%5B%2034.555059%5D%20max9286_mipi%202-006a%3A%20ap0101_initialize%3A%20AP0101%20was%20found%2C%20index%20%3D%201.%3CBR%20%2F%3E%3CEM%3E%3CSTRONG%3E%5B%2034.563125%5D%20max9286_mipi%202-006a%3A%20ap0101_initialize%3AAP0101's%200xC88D%20is%200x0.%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%3CSTRONG%3E%5B%2034.570775%5D%20max9286_mipi%202-006a%3A%20ap0101_initialize%3AAP0101%20is%20not%20in%20Host%20Configuration%20Mode.%20reg%20%3D%200x4.%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%3CSTRONG%3E%5B%2034.580281%5D%20max9286_mipi%202-006a%3A%20ap0101_initialize%3AAP0101's%200xdc07%20is%200x4.%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%3CSTRONG%3E%5B%2036.453930%5D%20max9286_mipi%202-006a%3A%20ap0101_IssueHostCommand%3A%20timeout.%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%3CSTRONG%3E%5B%2036.460877%5D%20max9286_mipi%202-006a%3A%20ap0101_ApplyPatch%3A%20PATCH_APPLY_PATCH%20error.%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%3CSTRONG%3E%5B%2036.468012%5D%20max9286_mipi%202-006a%3A%20ap0101_LoadAp0101Patch%3A%20Patch111%20load%20failed%2C%20result%20%3D%201794%20%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%3CSTRONG%3E%5B%2036.476664%5D%20max9286_mipi%202-006a%3A%20ap0101_initialize%3A%20LoadAp0101Patch%20failed%2C%20result%20%3D%201794%3C%2FSTRONG%3E%20%3C%2FEM%3E%3CBR%20%2F%3E%5B%2036.613908%5D%20max9271_dump_registers%3A%20index%20%3D%201.%3CBR%20%2F%3E%5B%2036.618960%5D%20MAX9271%20Reg%200x00%20%3D%200x82.%3CBR%20%2F%3E%5B%2036.623149%5D%20MAX9271%20Reg%200x01%20%3D%200xd4.%3CBR%20%2F%3E%5B%2036.627402%5D%20MAX9271%20Reg%200x02%20%3D%200x1f.%3CBR%20%2F%3E%5B%2036.631579%5D%20MAX9271%20Reg%200x03%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.635802%5D%20MAX9271%20Reg%200x04%20%3D%200x83.%3CBR%20%2F%3E%5B%2036.639915%5D%20MAX9271%20Reg%200x05%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.643952%5D%20MAX9271%20Reg%200x06%20%3D%200xa0.%3CBR%20%2F%3E%5B%2036.648075%5D%20MAX9271%20Reg%200x07%20%3D%200x84.%3CBR%20%2F%3E%5B%2036.652172%5D%20MAX9271%20Reg%200x08%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.656243%5D%20MAX9271%20Reg%200x09%20%3D%200x92.%3CBR%20%2F%3E%5B%2036.660336%5D%20MAX9271%20Reg%200x0a%20%3D%200x90.%3CBR%20%2F%3E%5B%2036.664482%5D%20MAX9271%20Reg%200x0b%20%3D%200x8a.%3CBR%20%2F%3E%5B%2036.668582%5D%20MAX9271%20Reg%200x0c%20%3D%200x82.%3CBR%20%2F%3E%5B%2036.672672%5D%20MAX9271%20Reg%200x0d%20%3D%200xb6.%3CBR%20%2F%3E%5B%2036.676826%5D%20MAX9271%20Reg%200x0e%20%3D%200x2.%3CBR%20%2F%3E%5B%2036.680840%5D%20MAX9271%20Reg%200x0f%20%3D%200x3e.%3CBR%20%2F%3E%5B%2036.684991%5D%20MAX9271%20Reg%200x10%20%3D%200x12.%3CBR%20%2F%3E%5B%2036.689069%5D%20MAX9271%20Reg%200x11%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.693058%5D%20MAX9271%20Reg%200x12%20%3D%200x40.%3CBR%20%2F%3E%5B%2036.697179%5D%20MAX9271%20Reg%200x13%20%3D%200x2.%3CBR%20%2F%3E%5B%2036.701168%5D%20MAX9271%20Reg%200x14%20%3D%200x60.%3CBR%20%2F%3E%5B%2036.705282%5D%20MAX9271%20Reg%200x15%20%3D%200xe3.%3CBR%20%2F%3E%5B%2036.709358%5D%20MAX9271%20Reg%200x16%20%3D%200x1f.%3CBR%20%2F%3E%5B%2036.713434%5D%20MAX9271%20Reg%200x17%20%3D%200x99.%3CBR%20%2F%3E%5B%2036.717557%5D%20MAX9271%20Reg%200x18%20%3D%200xff.%3CBR%20%2F%3E%5B%2036.721633%5D%20MAX9271%20Reg%200x19%20%3D%200xff.%3CBR%20%2F%3E%5B%2036.725747%5D%20MAX9271%20Reg%200x1a%20%3D%200xff.%3CBR%20%2F%3E%5B%2036.729823%5D%20MAX9271%20Reg%200x1b%20%3D%200xff.%3CBR%20%2F%3E%5B%2036.733918%5D%20MAX9271%20Reg%200x1c%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.737938%5D%20MAX9271%20Reg%200x1d%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.741931%5D%20MAX9271%20Reg%200x1e%20%3D%200x41.%3CBR%20%2F%3E%5B%2036.746045%5D%20MAX9271%20Reg%200x1f%20%3D%200x1.%3CBR%20%2F%3E%5B%2036.749624%5D%20Dump%20MAX9286%20registers%3A%3CBR%20%2F%3E%5B%2036.753611%5D%20MAX9286%20Reg%200x00%20%3D%200xe1.%3CBR%20%2F%3E%5B%2036.757734%5D%20MAX9286%20Reg%200x01%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.761722%5D%20MAX9286%20Reg%200x02%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.765750%5D%20MAX9286%20Reg%200x03%20%3D%200x1.%3CBR%20%2F%3E%5B%2036.769738%5D%20MAX9286%20Reg%200x04%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.773727%5D%20MAX9286%20Reg%200x05%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.777758%5D%20MAX9286%20Reg%200x06%20%3D%200x60.%3CBR%20%2F%3E%5B%2036.781836%5D%20MAX9286%20Reg%200x07%20%3D%200x89.%3CBR%20%2F%3E%5B%2036.785948%5D%20MAX9286%20Reg%200x08%20%3D%200x25.%3CBR%20%2F%3E%5B%2036.790025%5D%20MAX9286%20Reg%200x09%20%3D%200xd4.%3CBR%20%2F%3E%5B%2036.794114%5D%20MAX9286%20Reg%200x0a%20%3D%200xff.%3CBR%20%2F%3E%5B%2036.798198%5D%20MAX9286%20Reg%200x0b%20%3D%200xe4.%3CBR%20%2F%3E%5B%2036.802276%5D%20MAX9286%20Reg%200x0c%20%3D%200x99.%3CBR%20%2F%3E%5B%2036.806407%5D%20MAX9286%20Reg%200x0d%20%3D%200xf3.%3CBR%20%2F%3E%5B%2036.810484%5D%20MAX9286%20Reg%200x0e%20%3D%200x50.%3CBR%20%2F%3E%5B%2036.814604%5D%20MAX9286%20Reg%200x0f%20%3D%200xb.%3CBR%20%2F%3E%5B%2036.818595%5D%20MAX9286%20Reg%200x10%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.822583%5D%20MAX9286%20Reg%200x11%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.826610%5D%20MAX9286%20Reg%200x12%20%3D%200xf3.%3CBR%20%2F%3E%5B%2036.830686%5D%20MAX9286%20Reg%200x13%20%3D%200xf.%3CBR%20%2F%3E%5B%2036.834717%5D%20MAX9286%20Reg%200x14%20%3D%200xe4.%3CBR%20%2F%3E%5B%2036.838794%5D%20MAX9286%20Reg%200x15%20%3D%200x9b.%3CBR%20%2F%3E%5B%2036.842869%5D%20MAX9286%20Reg%200x16%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.846895%5D%20MAX9286%20Reg%200x17%20%3D%200x1.%3CBR%20%2F%3E%5B%2036.850885%5D%20MAX9286%20Reg%200x18%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.854902%5D%20MAX9286%20Reg%200x19%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.858891%5D%20MAX9286%20Reg%200x1a%20%3D%200x60.%3CBR%20%2F%3E%5B%2036.862967%5D%20MAX9286%20Reg%200x1b%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.867021%5D%20MAX9286%20Reg%200x1c%20%3D%200xf4.%3CBR%20%2F%3E%5B%2036.871098%5D%20MAX9286%20Reg%200x1d%20%3D%200xff.%3CBR%20%2F%3E%5B%2036.875218%5D%20MAX9286%20Reg%200x1e%20%3D%200x40.%3CBR%20%2F%3E%5B%2036.879294%5D%20MAX9286%20Reg%200x1f%20%3D%200x2.%3CBR%20%2F%3E%5B%2036.883282%5D%20MAX9286%20Reg%200x20%20%3D%200xff.%3CBR%20%2F%3E%5B%2036.887394%5D%20MAX9286%20Reg%200x21%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.891383%5D%20MAX9286%20Reg%200x22%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.895414%5D%20MAX9286%20Reg%200x23%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.899403%5D%20MAX9286%20Reg%200x24%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.903391%5D%20MAX9286%20Reg%200x25%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.907715%5D%20MAX9286%20Reg%200x26%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.911704%5D%20MAX9286%20Reg%200x27%20%3D%200xb1.%3CBR%20%2F%3E%5B%2036.916104%5D%20MAX9286%20Reg%200x28%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.920094%5D%20MAX9286%20Reg%200x29%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.924135%5D%20MAX9286%20Reg%200x2a%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.928142%5D%20MAX9286%20Reg%200x2b%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.932132%5D%20MAX9286%20Reg%200x2c%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.936164%5D%20MAX9286%20Reg%200x2d%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.940154%5D%20MAX9286%20Reg%200x2e%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.944177%5D%20MAX9286%20Reg%200x2f%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.948180%5D%20MAX9286%20Reg%200x30%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.952182%5D%20MAX9286%20Reg%200x31%20%3D%200x40.%3CBR%20%2F%3E%5B%2036.956295%5D%20MAX9286%20Reg%200x32%20%3D%200x99.%3CBR%20%2F%3E%5B%2036.960377%5D%20MAX9286%20Reg%200x33%20%3D%200x99.%3CBR%20%2F%3E%5B%2036.964497%5D%20MAX9286%20Reg%200x34%20%3D%200xb6.%3CBR%20%2F%3E%5B%2036.968580%5D%20MAX9286%20Reg%200x35%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.972567%5D%20MAX9286%20Reg%200x36%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.976594%5D%20MAX9286%20Reg%200x37%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.980582%5D%20MAX9286%20Reg%200x38%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.984612%5D%20MAX9286%20Reg%200x39%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.988601%5D%20MAX9286%20Reg%200x3a%20%3D%200x0.%3CBR%20%2F%3E%5B%2036.992589%5D%20MAX9286%20Reg%200x3b%20%3D%200x19.%3CBR%20%2F%3E%5B%2036.996699%5D%20MAX9286%20Reg%200x3c%20%3D%200x24.%3CBR%20%2F%3E%5B%2037.000774%5D%20MAX9286%20Reg%200x3d%20%3D%200x54.%3CBR%20%2F%3E%5B%2037.004896%5D%20MAX9286%20Reg%200x3e%20%3D%200xc8.%3CBR%20%2F%3E%5B%2037.008971%5D%20MAX9286%20Reg%200x3f%20%3D%200x4f.%3CBR%20%2F%3E%5B%2037.013045%5D%20MAX9286%20Reg%200x40%20%3D%200x5a.%3CBR%20%2F%3E%5B%2037.017183%5D%20MAX9286%20Reg%200x41%20%3D%200x10.%3CBR%20%2F%3E%5B%2037.021271%5D%20MAX9286%20Reg%200x42%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.025300%5D%20MAX9286%20Reg%200x43%20%3D%200xa0.%3CBR%20%2F%3E%5B%2037.029384%5D%20MAX9286%20Reg%200x44%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.033372%5D%20MAX9286%20Reg%200x45%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.037403%5D%20MAX9286%20Reg%200x46%20%3D%200x1.%3CBR%20%2F%3E%5B%2037.041392%5D%20MAX9286%20Reg%200x47%20%3D%200x11.%3CBR%20%2F%3E%5B%2037.045507%5D%20MAX9286%20Reg%200x48%20%3D%200xc1.%3CBR%20%2F%3E%5B%2037.049619%5D%20MAX9286%20Reg%200x49%20%3D%200x1.%3CBR%20%2F%3E%5B%2037.053607%5D%20MAX9286%20Reg%200x4a%20%3D%200xff.%3CBR%20%2F%3E%5B%2037.057754%5D%20MAX9286%20Reg%200x4b%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.061745%5D%20MAX9286%20Reg%200x4c%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.065772%5D%20MAX9286%20Reg%200x4d%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.069761%5D%20MAX9286%20Reg%200x4e%20%3D%200x5.%3CBR%20%2F%3E%5B%2037.073750%5D%20MAX9286%20Reg%200x4f%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.077781%5D%20MAX9286%20Reg%200x50%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.081771%5D%20MAX9286%20Reg%200x51%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.085798%5D%20MAX9286%20Reg%200x52%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.089789%5D%20MAX9286%20Reg%200x53%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.093778%5D%20MAX9286%20Reg%200x54%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.097809%5D%20MAX9286%20Reg%200x55%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.101798%5D%20MAX9286%20Reg%200x56%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.105824%5D%20MAX9286%20Reg%200x57%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.109816%5D%20MAX9286%20Reg%200x58%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.113804%5D%20MAX9286%20Reg%200x59%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.117834%5D%20MAX9286%20Reg%200x5a%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.121824%5D%20MAX9286%20Reg%200x5b%20%3D%200x60.%3CBR%20%2F%3E%5B%2037.125936%5D%20MAX9286%20Reg%200x5c%20%3D%200x89.%3CBR%20%2F%3E%5B%2037.130013%5D%20MAX9286%20Reg%200x5d%20%3D%200x25.%3CBR%20%2F%3E%5B%2037.134119%5D%20MAX9286%20Reg%200x5e%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.138127%5D%20MAX9286%20Reg%200x5f%20%3D%200xf.%3CBR%20%2F%3E%5B%2037.142115%5D%20MAX9286%20Reg%200x60%20%3D%200x45.%3CBR%20%2F%3E%5B%2037.146230%5D%20MAX9286%20Reg%200x61%20%3D%200xff.%3CBR%20%2F%3E%5B%2037.150306%5D%20MAX9286%20Reg%200x62%20%3D%200x1f.%3CBR%20%2F%3E%5B%2037.154427%5D%20MAX9286%20Reg%200x63%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.158417%5D%20MAX9286%20Reg%200x64%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.162405%5D%20MAX9286%20Reg%200x65%20%3D%200x12.%3CBR%20%2F%3E%5B%2037.166519%5D%20MAX9286%20Reg%200x66%20%3D%200x96.%3CBR%20%2F%3E%5B%2037.170595%5D%20MAX9286%20Reg%200x67%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.174629%5D%20MAX9286%20Reg%200x68%20%3D%200x50.%3CBR%20%2F%3E%5B%2037.178708%5D%20MAX9286%20Reg%200x69%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.182941%5D%20MAX9286%20Reg%200x6a%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.186967%5D%20MAX9286%20Reg%200x6b%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.190957%5D%20MAX9286%20Reg%200x6c%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.194976%5D%20MAX9286%20Reg%200x6d%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.198965%5D%20MAX9286%20Reg%200x6e%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.202954%5D%20MAX9286%20Reg%200x6f%20%3D%200x0.%3CBR%20%2F%3E%5B%2037.206995%5D%20MAX9286%20Reg%200x70%20%3D%200x10.%3CBR%20%2F%3E%5B%2037.211071%5D%20MAX9286%20Reg%200x71%20%3D%200x1.%3CBR%20%2F%3Eg_in_width%20%3D%201280%2C%20g_in_height%20%3D%20720.%3CBR%20%2F%3Efb_fix.id%20%3D%20DISP3%20FG.%3CBR%20%2F%3Efb%3A%20smem_start%20%3D%200x24a00000%2C%20smem_len%20%3D%200xbdd800.%3CBR%20%2F%3Efb%3A%20frame%20buffer%20size%20%3D%200x3f4800%20bytes.%3CBR%20%2F%3Efb%3A%20g_screen_info.xres%20%3D%201920%2C%20g_screen_info.yres%20%3D%201080.%3CBR%20%2F%3Efb%3A%20g_display_left%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_top%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_width%20%3D%20960.%3CBR%20%2F%3Efb%3A%20g_display_height%20%3D%20540.%3CBR%20%2F%3Estart%20time%20%3D%201481829237%20s%2C%20120527%20us%3CBR%20%2F%3E%5B%2047.283991%5D%20ERROR%3A%20v4l2%20capture%3A%20mxc_v4l_dqueue%20timeout%20enc_counter%200%3CBR%20%2F%3EVIDIOC_DQBUF%20failed.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%8F%E3%82%A4%E3%83%81%E3%83%A3%E3%83%B3%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3ETI%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E8%AA%BF%E6%95%B4%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AF4%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E3%80%811%2F2%2F3%E3%82%BB%E3%83%B3%E3%82%B5%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%AF%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%814%E3%82%BB%E3%83%B3%E3%82%B5%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%AF%E3%80%81%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AB%E4%B8%80%E9%83%A8%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E7%A0%B4%E6%90%8D%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%88%E4%B8%8B%E3%81%AE%E7%94%BB%E5%83%8F%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22error_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22error_2.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F28151iDC414904E44DC5E4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22error_2.png%22%20alt%3D%22error_2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETI%E5%81%B4%E3%81%A7%E3%81%AF%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%B3%E3%81%AE%E6%9C%AC%E6%95%B0%E3%81%A8%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%B3%E3%81%AE%E8%BB%A2%E9%80%81%E3%83%AC%E3%83%BC%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%B3%E3%81%AE%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AF3%E7%A8%AE%E9%A1%9E%EF%BC%88400M%E3%80%81800M%E3%80%811.6G%EF%BC%89%E3%81%97%E3%81%8B%E9%81%B8%E6%8A%9E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%AC%E3%83%BC%E3%83%88%E3%81%A8%E3%83%AC%E3%83%BC%E3%83%B3%E6%95%B0%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E5%A4%89%E3%81%88%E3%82%8B%E3%81%A8%E3%80%811%2F2%2F3%E3%82%BB%E3%83%B3%E3%82%B5%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E4%E3%82%BB%E3%83%B3%E3%82%B5%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%AF%E3%80%81800M%EF%BC%8B4%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%B3%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AE%E3%81%BF%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AB%E4%B8%80%E9%83%A8%E7%A0%B4%E6%90%8D%E3%81%8C%E8%A6%8B%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%3C%2FP%3E%3CP%3E1)%20i.MX6%E3%81%AEMIPI%20CSI-2%E3%83%AC%E3%82%B7%E3%83%BC%E3%83%90%E5%81%B4%E3%81%AB%E3%81%AF%E3%80%81%E3%83%AC%E3%83%BC%E3%83%88%E3%82%84%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%B3%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E7%89%B9%E5%88%A5%E3%81%AA%E8%A6%81%E4%BB%B6%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E2)%20i.MX6%E3%81%AEMIPI%20CSI%E3%81%AB%E3%81%8A%E3%81%84%E3%81%A6%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%88%E3%81%A8%E7%B7%8F%E3%83%87%E3%83%BC%E3%82%BF%E8%BB%A2%E9%80%81%E8%83%BD%E5%8A%9B%E3%81%A8%E3%81%AE%E9%96%93%E3%81%A7%E9%81%A9%E5%88%87%E3%81%AA%E6%AF%94%E7%8E%87%E3%81%AF%E3%81%A9%E3%81%AE%E7%A8%8B%E5%BA%A6%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E2)%20%E4%BD%95%E3%81%8B%E3%81%94%E6%8F%90%E6%A1%88%E3%81%AF%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116592%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116592%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81Mustafa%E3%81%95%E3%82%93%E3%80%82%E8%A9%B2%E5%BD%93%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%AFMIPI%20CSI2%E3%81%AE%E4%BB%95%E6%A7%98%E6%9B%B8%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19379i48079F224D67B17C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221.jpg%22%20alt%3D%221.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20593px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19241iFEA60F46F5860C8A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222.jpg%22%20alt%3D%222.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.jpg%22%20style%3D%22width%3A%20506px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19291i0F83D65DC84678B0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%223.jpg%22%20alt%3D%223.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116591%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116591%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Flionwei%22%20target%3D%22_blank%22%3Elionwei%3C%2FA%3E%26nbsp%3B%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%26nbsp%3B%3B%3C%2FP%3E%3CP%3EiMX6%20CSI2IPU%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%88%E3%82%BF%E3%82%A4%E3%83%97%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%AD%E3%83%B3%E3%82%B0%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E5%8A%A0%E3%81%88%E3%81%A6%E3%80%81%E4%BC%9D%E9%80%81%E9%96%8B%E5%A7%8B%EF%BC%88SoT%EF%BC%89%E3%81%8A%E3%82%88%E3%81%B3%E4%BC%9D%E9%80%81%E7%B5%82%E4%BA%86%EF%BC%88EoT%EF%BC%89%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%82%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20527px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F18280i3186E2657EDB4F66%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E5%86%85%E3%81%A7%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%83%87%E3%83%BC%E3%82%BF%E3%82%BF%E3%82%A4%E3%83%97%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%81%B9%E3%81%8D%E3%81%AA%E3%81%AE%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E5%88%A5%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%80%A4%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82SoT%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%81%8A%E3%82%88%E3%81%B3EoT%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%81%AE%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20588px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F18334iAD0E1FA2A7D1B2FE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E3%80%81%E3%81%93%E3%82%8C%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E3%81%94%E6%8F%90%E4%BE%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%AA%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%E7%A7%81%E3%81%AF%E3%81%93%E3%81%933%E9%80%B1%E9%96%93%E3%80%81CSI-2%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%AEMIPI%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8A%E3%82%88%E3%81%B3%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%B3%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81iMX6Q%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%86%E3%81%BE%E3%81%8F%E5%AE%9A%E7%BE%A9%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%94%E6%94%AF%E6%8F%B4%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%8F%E3%82%A4%E3%83%81%E3%83%A3%E3%83%B3%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELinux3.14.52%E3%81%AE%E7%92%B0%E5%A2%83%E3%81%A7%E3%80%81%E5%90%8C%E6%A7%98%E3%81%AE%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Eov10635%20%26lt%3B--%26gt%3B%20ds90ub913%20%26lt%3B--%26gt%3B%3CBR%20%2F%3Eov10635%20%26lt%3B--%26gt%3B%20ds90ub913%20%26lt%3B--%26gt%3B%20DS90ub964-q%20%26lt%3B-----%26gt%3B%20imx6q%3CBR%20%2F%3Eov10635%20%26lt%3B--%26gt%3B%20ds90ub913%20%26lt%3B--%26gt%3B%20%3CBR%20%2F%3Eov10635%20%26lt%3B--%26gt%3B%20ds90ub913%20%26lt%3B--%26gt%3B%3C%2FP%3E%3CP%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81%E3%81%94%E6%8F%90%E4%BE%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E3%82%82%E3%81%AE%E3%81%A8%E3%81%BB%E3%81%BC%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E7%8F%BE%E5%9C%A8%E3%80%81MIPI-CSI2%E3%81%AF%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%A4%9C%E5%87%BA%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%80%81MIPI-CSI2%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%83%A9%E3%82%A4%E3%83%B3%E4%B8%8A%E3%81%AE%E6%B3%A2%E5%BD%A2%E3%82%82%E6%AD%A3%E3%81%97%E3%81%8F%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A90%E3%80%9C2%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AFcamera_callback%E3%81%8C%E5%8F%97%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A93%E3%81%AEcamera_callback%E3%81%AE%E3%81%BF%E5%8F%97%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%90%8C%E6%A7%98%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%A0%85%E7%9B%AE%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E1)%20MIPI_IPU1_MUX%E3%81%8A%E3%82%88%E3%81%B3MIPI_IPU2_MUX%E3%81%AFmipi_csi%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A60%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%3CBR%20%2F%3E2)%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%83%80%E3%83%B3%E3%83%97%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3EIPU1_CSI0_SENSE_CONF(0x2630000)%3A%200x04008a00%3CBR%20%2F%3EIPU1_CSI1_SENSE_CONF(0x2638000)%3A%200x04008a00%3CBR%20%2F%3EIPU2_CSI0_SENSE_CONF(0x2a30000)%3A%200x04008a00%3CBR%20%2F%3EIPU2_CSI1_SENSE_CONF(0x2a38000)%3A%200x04008a00%3C%2FP%3E%3CP%3EIPU1_IDMAC_CH_EN_1(0x2608004)%3A%200x00000003%3CBR%20%2F%3EIPU1_IDMAC_CH_EN_2(0x2608008)%3A%200x00000000%3CBR%20%2F%3EIPU2_IDMAC_CH_EN_1(0x2a08004)%3A%200x00800003%3CBR%20%2F%3EIPU2_IDMAC_CH_EN_2(0x2a08008)%3A%200x00000000%3C%2FP%3E%3CP%3EIPU1_IDMAC_CH_BUSY_1(0x2608100)%3A%200x00000003%3CBR%20%2F%3EIPU2_IDMAC_CH_BUSY_1(0x2a08100)%3A%200x00800002%3C%2FP%3E%3CP%3EIPU1_SMFC_MAP(0x2650000)%3A%200x00000020%3CBR%20%2F%3EIPU2_SMFC_MAP(0x2a50000)%3A%200x00000020%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE2%E7%82%B9%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E1)%20%E3%81%93%E3%81%AE4%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8BSMFC%E3%81%8A%E3%82%88%E3%81%B3IDMAC%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E2)%20%E4%BB%95%E6%A7%98%E6%9B%B8%E3%81%A7%E3%81%AF%E3%80%81IPU%20MIPI%E3%81%AF%E3%83%8E%E3%83%B3%E3%82%B2%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81mxc_v4l2_capture.c%E3%81%AEmxc_v4l2_s_param%E3%81%A7%E3%81%AF%E3%82%B2%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%EF%BC%88%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%84%E3%81%9A%E3%82%8C%E3%82%82%E3%81%86%E3%81%BE%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%EF%BC%89%3CBR%20%2F%3E3)%20%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%A7hsync_pol%E3%82%84vsync_pol%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E4)%20%E5%95%8F%E9%A1%8C%E3%82%92%E7%89%B9%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E8%A9%A6%E3%81%99%E3%81%B9%E3%81%8D%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E6%84%9F%E8%AC%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%80%80%E3%81%8A%E5%BF%99%E3%81%97%E3%81%84%E3%81%A8%E3%81%93%E3%82%8D%E6%81%90%E3%82%8C%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82SabreSD%E3%81%A8MAX9286%EF%BC%8BMAX96705%EF%BC%8BAP0101%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%92%E5%8F%82%E8%80%83%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81BSP%E3%81%AF3.14.52%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%814%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AF%E3%81%84%E3%81%9A%E3%82%8C%E3%82%82%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7'-g2d'%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81'Segmentation%20fault%EF%BC%88%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%EF%BC%89'%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82GPU%E3%81%AB%E4%BD%95%E3%81%8B%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%AF%BE%E5%87%A6%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%AE%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BD%95%E3%81%8B%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%8C%E3%83%AD%E3%82%B0%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3Eroot%40imx6qdlsolo%3A~%23%20.%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20960%20-oh%20540%20-d%200%20-x%200%20%3CBR%20%2F%3E------------------------------%E3%81%93%E3%81%93%E3%81%8B%E3%82%89AP0101%E3%81%AE%E6%83%85%E5%A0%B1--------------------------------%3CBR%20%2F%3Emax9286_mipi%3A%20%E3%82%BB%E3%83%B3%E3%82%B5%E7%95%AA%E5%8F%B7%20%3D%204.%3CBR%20%2F%3Emxc_mipi_csi2%2021dc000.mipi_csi%3Amipi_csi2_reset%3A%20mipi_lane_bps%20%3D%20594%20Mbps%3CBR%20%2F%3Emxc_mipi_csi2%2021dc000.mipi_csi%3Amipi_csi2_reset%3A%20%E5%80%A4%20%3D%200x2e.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3A%20AP0101%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%2C%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%201.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20(%E3%82%B7%E3%83%A3%E3%83%83%E3%82%BF%E3%83%BC%E5%90%8C%E6%9C%9F)%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3A%20AP0101%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%2C%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%202.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20(%E3%82%B7%E3%83%A3%E3%83%83%E3%82%BF%E3%83%BC%E5%90%8C%E6%9C%9F)%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3A%20AP0101%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%2C%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%203.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20(%E3%82%B7%E3%83%A3%E3%83%83%E3%82%BF%E3%83%BC%E5%90%8C%E6%9C%9F)%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3A%20AP0101%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%2C%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%204.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20(%E3%82%B7%E3%83%A3%E3%83%83%E3%82%BF%E3%83%BC%E5%90%8C%E6%9C%9F)%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99.%3CBR%20%2F%3Eg_in_width%20%3D%201280%2C%20g_in_height%20%3D%20720.%3CBR%20%2F%3Efb_fix.id%20%3D%20DISP4%20BG.%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AF%E8%83%8C%E6%99%AF%E7%94%BB%E9%9D%A2%E3%81%A7%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%81%AF%E3%83%95%E3%83%AB%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E5%BD%A2%E5%BC%8F%E3%81%AE%E3%81%BF%E3%81%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Efb%3A%20smem_start%20%3D%200x25600000%2C%20smem_len%20%3D%200x546000.%3CBR%20%2F%3Efb%3A%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%20%3D%200x1c2000%20%E3%83%90%E3%82%A4%E3%83%88.%3CBR%20%2F%3Efb%3A%20g_screen_info.xres%20%3D%201280%2C%20g_screen_info.yres%20%3D%20720.%3CBR%20%2F%3Efb%3A%20g_display_left%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_top%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_width%20%3D%201280.%3CBR%20%2F%3Efb%3A%20g_display_height%20%3D%20720.%3CBR%20%2F%3E%E9%96%8B%E5%A7%8B%E6%99%82%E9%96%93%20%3D%201449238585%20%E7%A7%92%2C%20124037%20%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E7%A7%92%3CBR%20%2F%3E%5ECERROR%3A%20v4l2%20capture%3A%20mxc_v4l_dqueue()%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40imx6qdlsolo%3A~%23%20.%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20960%20-oh%20540%20-d%200%20-x%200%20-g2d%3CBR%20%2F%3E------------------------------%E3%81%93%E3%81%93%E3%81%8B%E3%82%89AP0101%E3%81%AE%E6%83%85%E5%A0%B1--------------------------------%3CBR%20%2F%3Emax9286_mipi%3A%20%E3%82%BB%E3%83%B3%E3%82%B5%E7%95%AA%E5%8F%B7%20%3D%204.%3CBR%20%2F%3Emxc_mipi_csi2%2021dc000.mipi_csi%3Amipi_csi2_reset%3A%20mipi_lane_bps%20%3D%20594%20Mbps%3CBR%20%2F%3Emxc_mipi_csi2%2021dc000.mipi_csi%3Amipi_csi2_reset%3A%20%E5%80%A4%20%3D%200x2e.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3A%20AP0101%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%2C%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%201.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20(%E3%82%B7%E3%83%A3%E3%83%83%E3%82%BF%E3%83%BC%E5%90%8C%E6%9C%9F)%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3A%20AP0101%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%2C%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%202.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20(%E3%82%B7%E3%83%A3%E3%83%83%E3%82%BF%E3%83%BC%E5%90%8C%E6%9C%9F)%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3A%20AP0101%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%2C%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%203.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20(%E3%82%B7%E3%83%A3%E3%83%83%E3%82%BF%E3%83%BC%E5%90%8C%E6%9C%9F)%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3A%20AP0101%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%2C%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%204.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20(%E3%82%B7%E3%83%A3%E3%83%83%E3%82%BF%E3%83%BC%E5%90%8C%E6%9C%9F)%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99.%3CBR%20%2F%3Eg_in_width%20%3D%201280%2C%20g_in_height%20%3D%20720.%3CBR%20%2F%3Efb_fix.id%20%3D%20DISP4%20BG.%3CBR%20%2F%3Efb%3A%20smem_start%20%3D%200x25600000%2C%20smem_len%20%3D%200x546000.%3CBR%20%2F%3Efb%3A%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%20%3D%200x1c2000%20%E3%83%90%E3%82%A4%E3%83%88.%3CBR%20%2F%3Efb%3A%20g_screen_info.xres%20%3D%201280%2C%20g_screen_info.yres%20%3D%20720.%3CBR%20%2F%3Efb%3A%20g_display_left%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_top%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_width%20%3D%20960.%3CBR%20%2F%3Efb%3A%20g_display_height%20%3D%20540.%3CBR%20%2F%3E%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3BJun%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116585%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116585%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FSPAN%3E%3CA%20_jive_internal%3D%22true%22%20class%3D%22%22%20data-containerid%3D%22-1%22%20data-containertype%3D%22-1%22%20data-content-finding%3D%22Community%22%20data-objectid%3D%2236648%22%20data-objecttype%3D%223%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20style%3D%22color%3A%20%235e89c1%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20padding%3A%201px%200px%201px%20calc(12px%20%2B%200.35ex)%3B%22%20target%3D%22_blank%22%3E%20%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%80%81%20%E3%83%81%E3%83%A3%E3%83%B3%E3%83%BB%E3%83%AA%E3%83%BC%E3%81%95%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%94%E6%8F%90%E7%A4%BA%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E4%B8%8D%E5%AE%89%E5%AE%9A%E3%81%95%E3%81%AF%E4%BB%96%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%AB%E3%82%88%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%81%93%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%A8%E3%81%AF%E4%B8%80%E5%88%87%E9%96%A2%E4%BF%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116584%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116584%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Yu%20fe%2C%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%80%81MAX9286%20%E3%81%8C%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82MAX9286%20%E3%81%A8%20MAX96705%20%E3%81%AE%E9%96%93%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E4%BF%A1%E5%8F%B7%E3%81%A8%E9%9B%BB%E6%BA%90%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116583%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116583%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%2C%20Qiang%20Li%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%20saresd%E3%80%81MAX9286%2BMAX96705%2BAP010%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8BYocto%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF3.14.52%E3%81%A7%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Epr_info(%22max9286_mipi%3A%20%E3%82%BB%E3%83%B3%E3%82%B5%E7%95%AA%E5%8F%B7%20%3D%20%25d.%5Cn%22%2Cg_sensor_num)%3B%3C%2FP%3E%3CP%3Eif%20(g_sensor_num%20%3D%3D%200)%20%7B%3CBR%20%2F%3E%20pr_err(%22%25s%3A%20%E3%82%AB%E3%83%A1%E3%83%A9%E6%9C%AA%E6%8E%A5%E7%B6%9A.%5Cn%22%2C__func__)%3B%3CBR%20%2F%3E%20return%20-1%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E1280%C3%97720%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%A7%20CSC%20%E3%81%AB%20IPU%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81IPU%20%E3%81%AE%E8%B2%A0%E8%8D%B7%E3%81%8C%E5%A4%A7%E3%81%8D%E3%81%8F%E3%81%AA%E3%82%8A%E3%80%81IPU%20%E3%81%8C%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%82%92%E6%99%82%E9%96%93%E9%80%9A%E3%82%8A%E3%81%AB%E5%87%A6%E7%90%86%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E6%94%B9%E5%96%84%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81IDMAC%200%E3%81%A8IDMAC%202%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEFIFO%E3%82%92%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F29543i5665BB537284462F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222.jpg%22%20alt%3D%222.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eipu_common.c%E3%81%AEipu_probe()%E9%96%A2%E6%95%B0%E5%86%85%E3%81%A7%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AECSI%E2%86%92MEM%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%8C%E9%AB%98%E5%84%AA%E5%85%88%E5%BA%A6%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%2F*%20%E5%90%8C%E6%9C%9F%E3%83%AA%E3%83%95%E3%83%AC%E3%83%83%E3%82%B7%E3%83%A5%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%8A%E3%82%88%E3%81%B3CSI-%26gt%3B%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E9%AB%98%E5%84%AA%E5%85%88%E5%BA%A6%E3%81%AB%E8%A8%AD%E5%AE%9A%20*%2F%3CBR%20%2F%3E-%20ipu_idmac_write(ipu%2C%200x18800003L%2C%20IDMAC_CHA_PRI(0))%3B%3C%2FP%3E%3CP%3E%2B%20ipu_idmac_write(ipu%2C%200x1880000FL%2C%20IDMAC_CHA_PRI(0))%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116579%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116579%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%B7%E3%83%8A%E3%83%AA%E3%82%AA%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%824%E5%88%86%E5%89%B2%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E7%94%BB%E9%9D%A2%E3%82%92%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E4%BF%9D%E5%AD%98%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81720P%201%E6%9E%9A%E3%81%AE%E3%81%BF%E3%82%92%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A8%E5%90%8C%E7%AD%89%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E5%8E%9F%E7%94%BB%E5%83%8F%E3%82%92%E7%9B%B4%E6%8E%A5%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6UYVY%E7%94%BB%E5%83%8F%E3%82%92NV12%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%A6%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%82%B9%E3%83%97%E3%83%A9%E3%82%A4%E3%82%B9%E3%81%AFGPU%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E8%A1%8C%E3%82%8F%E3%82%8C%E3%80%81%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%82%8B%E7%94%BB%E5%83%8F%E3%81%AFRGBA32%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E5%89%8D%E3%81%AB%E8%89%B2%E7%A9%BA%E9%96%93%E5%A4%89%E6%8F%9B%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AB%E3%81%AA%E3%82%8A%E3%80%81%E7%94%BB%E5%83%8F%E3%81%AB%E7%95%B0%E5%B8%B8%E3%81%8C%E7%94%9F%E3%81%98%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AE%9F%E9%9A%9B%E3%80%81720%C3%97480%E3%81%AE%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E7%94%BB%E5%83%8F%E3%81%AE%E8%89%B2%E5%A4%89%E6%8F%9B%E3%82%82%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E3%81%BE%E3%81%9A720P%E7%94%BB%E5%83%8F%E3%82%92GPU%E3%81%A7720%C3%97480%E3%81%AB%E7%B8%AE%E5%B0%8F%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%93%E3%81%AE%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%A7%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E8%A8%98%E9%8C%B2%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%85%A5%E5%8A%9B%E7%94%BB%E5%83%8F%E3%81%AB%E7%95%B0%E5%B8%B8%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82720%C3%97480%EF%BC%88RGBA32%E2%86%92NV12%E3%81%BE%E3%81%9F%E3%81%AFUYVY%E2%86%92NV12%EF%BC%89%E3%82%92%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%80%811%E3%81%A4%E3%81%AE%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AE%E3%81%BF%E3%81%8C%E7%95%B0%E5%B8%B8%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%821280%C3%97720%E3%81%AB%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E9%99%A4%E3%81%84%E3%81%A6%E3%80%81%E6%AE%8B%E3%82%8A%E3%81%AE3%E3%81%A4%E3%81%AE%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E7%95%B0%E5%B8%B8%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9F%BA%E7%9B%A4%E3%81%A8%E3%81%AA%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%83%95%E3%83%AD%E3%83%BC%E3%81%AFCSI--%26gt%3B%20SMFC--%26gt%3B%20IDMAC--%26gt%3B%20%3CBR%20%2F%3EMEM%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82IDMAC%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AE%E4%BD%BF%E7%94%A8%E7%8A%B6%E6%B3%81%E3%82%92%E8%BF%BD%E8%B7%A1%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AFCSI_MEM0%20%3D%20_MAKE_CHAN(15%2C%20NO_DMA%2C%20NO_DMA%2C%20NO_DMA%2C%200)%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CSTRONG%3E%20CSI_MEM1%20%3D%20_MAKE_CHAN(16%2C%20NO_DMA%2C%20NO_DMA%2C%20NO_DMA%2C%201)%2C%3C%2FSTRONG%3E%3CBR%20%2F%3E%20CSI_MEM2%20%3D%20_MAKE_CHAN(17%2C%20NO_DMA%2C%20NO_DMA%2C%20NO_DMA%2C%202)%2C%3CBR%20%2F%3E%20CSI_MEM3%20%3D%20_MAKE_CHAN(18%2C%20NO_DMA%2C%20NO_DMA%2C%20NO_DMA%2C%203)%2C%3CBR%20%2F%3E%20720%C3%97480%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%A8%E3%81%AA%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81CSI_MEM1%20%3D%20_MAKE_CHAN(16%2C%20NO_DMA%2C%20NO_DMA%2C%3CBR%20%2F%3E%3CSTRONG%3E%20NO_DMA%2C%201)%E3%81%A7%E3%81%99%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E5%88%B6%E5%BE%A1%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%A8%20%E3%80%81CSI_MEM0%20%3D%20_MAKE_CHAN(15%2C%20NO_DMA%2C%20NO_DMA%2C%20NO_DMA%2C%201)%E3%81%A8%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3CBR%20%2F%3E%20CSI_MEM1%20%3D%20_MAKE_CHAN(16%2C%20NO_DMA%2C%20NO_DMA%2C%20NO_DMA%2C%200)%2C%3CBR%20%2F%3E%20CSI_MEM2%20%3D%20_MAKE_CHAN(17%2C%20NO_DMA%2C%20NO_DMA%2C%20NO_DMA%2C%202)%2C%3CBR%20%2F%3E%20CSI_MEM3%20%3D%20_MAKE_CHAN(18%2C%20NO_DMA%2C%20NO_DMA%2C%20NO_DMA%2C%203)%2C%3CBR%20%2F%3E%20%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AE%E3%81%82%E3%82%8B%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AFCSI_MEM0%20%3D%20_MAKE_CHAN(15%2C%20NO_DMA%2C%20NO_DMA%2C%20NO_DMA%2C%201)%E3%81%A8%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E8%A6%B3%E7%82%B9%E3%81%8B%E3%82%89%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E5%9F%BA%E7%9B%A4%E3%81%A8%E3%81%AA%E3%82%8B%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AE%E7%AE%A1%E7%90%86%E3%81%A7%E7%AB%B6%E5%90%88%E3%82%92%E8%B5%B7%E3%81%93%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E8%87%AA%E4%BD%93%E3%81%8C%E3%81%93%E3%81%AE%E4%BD%BF%E7%94%A8%E6%B3%95%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AE%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%95%8F%E9%A1%8C%E3%81%AE%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E3%82%92%E7%89%B9%E5%AE%9A%E3%81%97%E3%80%81%E4%BD%95%E3%81%8B%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%AA%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116578%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116578%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Emxc_vpu_test%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AFUYVY%E7%94%BB%E5%83%8F%E3%82%92NV12%E3%81%AB%E7%9B%B4%E6%8E%A5%E5%87%BA%E5%8A%9B%E3%81%97%E3%80%81%E8%BF%BD%E5%8A%A0%E3%81%AE%E5%A4%89%E6%8F%9B%E3%81%AA%E3%81%97%E3%81%A7%E7%9B%B4%E6%8E%A5%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81VPU%20%E3%81%A7%E3%81%AF%204%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20720P30%20%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116577%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116577%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20_jive_internal%3D%22true%22%20class%3D%22%22%20data-containerid%3D%22-1%22%20data-containertype%3D%22-1%22%20data-content-finding%3D%22Community%22%20data-objectid%3D%2236648%22%20data-objecttype%3D%223%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20style%3D%22color%3A%20%235e89c1%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20padding%3A%201px%200px%201px%20calc(12px%20%2B%200.35ex)%3B%22%20target%3D%22_blank%22%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%83%BB%E3%83%AA%E3%83%BC%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81MAX9286%2B9271%E3%81%AE4%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB720P%E5%85%A5%E5%8A%9B%E3%81%A7%E3%81%AF%E7%8F%BE%E5%9C%A8%E5%95%8F%E9%A1%8C%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E9%8C%B2%E7%94%BB%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81IPU%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6RGBA32%2FUYUY%E3%81%8B%E3%82%89NV12%E3%81%B8%E3%81%AE%E8%89%B2%E7%A9%BA%E9%96%93%E5%A4%89%E6%8F%9B%E3%82%92%E8%A1%8C%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81IPU%E3%81%8C%E8%89%B2%E7%A9%BA%E9%96%93%E5%A4%89%E6%8F%9B%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%98%A0%E5%83%8F%E3%81%AB%E7%95%B0%E5%B8%B8%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E6%98%A0%E5%83%8F%E3%81%8C%E6%8F%BA%E3%82%8C%E5%8B%95%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82720*480%E5%A4%89%E6%8F%9B%E3%81%A7%E3%81%AF1%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AE%E3%81%BF%E3%80%81720P%E5%A4%89%E6%8F%9B%E3%81%A7%E3%81%AF3%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%A7%E3%81%AF%E3%80%81IPU%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%9F%E8%89%B2%E7%A9%BA%E9%96%93%E5%A4%89%E6%8F%9B%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81%E5%9F%BA%E7%9B%A4%E3%81%A8%E3%81%AA%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E5%87%A6%E7%90%86%E3%81%AE%E7%AB%B6%E5%90%88%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E8%A7%A3%E6%B6%88%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EIMX6D%2Blinux3.14.28%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Brave%2C%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%80%81%E6%9C%89%E5%8A%B9%E3%81%AAMIPI%20CSI2%E4%BF%A1%E5%8F%B7%E3%81%8CiMX6%E3%81%AB%E5%B1%8A%E3%81%84%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%AD%E3%82%B0%E3%82%92%E8%A6%8B%E3%82%8B%E9%99%90%E3%82%8A%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E5%81%B4%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E8%A8%AD%E5%AE%9A%E3%81%AF%E3%80%81max9286.c%20%E5%86%85%E3%81%AEAP0101%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%95%E3%81%9B%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AF%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E5%90%8C%E6%9C%9F%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EMAX9286%E3%81%AB%E3%81%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%94%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%80%814%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8C%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E5%90%8C%E6%9C%9F%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%80%81MAX9286%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%83%AD%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%81%9F%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%AE%E3%81%BF%E3%80%81%E6%9C%89%E5%8A%B9%E3%81%AAMIPI%20CSI2%E4%BF%A1%E5%8F%B7%E3%81%8CiMX6%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMAX9296%E3%81%A84%E3%81%A4%E3%81%AEMAX96705%E3%81%8A%E3%82%88%E3%81%B34%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E5%90%8C%E6%9C%9F%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3EIMX.6%20%2B%20MAX9268%20%2B%204%20MAX96705---%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E5%B8%8C%E6%9C%9B%E3%81%99%E3%82%8B%E9%A1%A7%E5%AE%A2%E3%81%8C2%E5%90%8D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E5%90%8C%E6%9C%9F%E6%96%B9%E6%B3%95%E3%82%92%E6%8F%90%E6%A1%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Li%2C%3C%2FP%3E%3CP%3Egrecorder%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%82%924%EF%BC%88UYVY%EF%BC%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81H.264%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E.%2Fmxc_vpu_test.out%20-E%20%22-x%200%20-f%200%20-c%201800%20-a%2030%20-w%201280%20-h%20792%20-o%20ss.mp4%20-l%200%20-b%205204%22%3C%2FP%3E%3CP%3EPC%E3%81%A7%20ss.mp4%E3%82%92%E5%86%8D%E7%94%9F%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%86%8D%E7%94%9F%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82MP4%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%8C%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AA%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EH.264%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8B%E3%82%89MP4%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20Li%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81VPU%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AFMJPEG%E3%81%A7%E3%80%81%E4%BB%96%E3%81%AE%E8%A6%8F%E6%A0%BC%EF%BC%88H.263%E3%82%84H.264%E3%81%AA%E3%81%A9%EF%BC%89%E3%81%AF%E4%BD%BF%E3%81%84%E3%81%9F%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%E5%A4%A7%E3%81%8D%E3%81%8F%E3%80%81100%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%A7%E7%B4%8411MB%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EMJPEG%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E5%B0%8F%E3%81%95%E3%81%8F%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%84%9F%E8%AC%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20li%3C%2FP%3E%3CP%3EGStreamer%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A64%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E6%98%A0%E5%83%8F%E3%82%92%E9%8C%B2%E7%94%BB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8C%26nbsp%3B%20%40%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%22285749%22%20data-username%3D%22zhanghongliang%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fzhanghongliang%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%20large%3B%22%3Ezhang%20hongliang%3C%2FSPAN%3E%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E4%E3%81%A4%E3%81%AE%E7%8B%AC%E7%AB%8B%E3%81%97%E3%81%9F%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%AE%E3%82%88%E3%81%86%E3%81%ABIPU%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E5%86%85%E3%81%A71%E3%81%A4%E3%81%AB%E3%81%BE%E3%81%A8%E3%82%81%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AF1%E5%9B%9E%E3%81%AEDQBUF%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A74%E5%8F%B0%E5%88%86%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcn.bing.com%2Fdict%2Fclientsearch%3Fmkt%3Dzh-CN%26amp%3BsetLang%3Dzh%26amp%3Bform%3DBDVEHC%26amp%3BClientVer%3DBDDTV3.5.1.4320%26amp%3Bq%3D%25E4%25BD%25A0%25E6%259C%2589%25E4%25BB%2580%25E4%25B9%2588%25E5%25BB%25BA%25E8%25AE%25AE%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Segoe%20UI%3B%22%3E%E4%BD%95%E3%81%8B%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Segoe%20UI%3B%22%3E%20%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcn.bing.com%2Fdict%2Fclientsearch%3Fmkt%3Dzh-CN%26amp%3BsetLang%3Dzh%26amp%3Bform%3DBDVEHC%26amp%3BClientVer%3DBDDTV3.5.1.4320%26amp%3Bq%3D%25E4%25BD%25A0%25E6%259C%2589%25E4%25BB%2580%25E4%25B9%2588%25E5%25BB%25BA%25E8%25AE%25AE%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Segoe%20UI%3B%22%3E%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3C%2FSPAN%3E%3C%2FA%3E%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%97%A0%E6%A0%87%E9%A2%98.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%97%A0%E6%A0%87%E9%A2%98.png%22%20style%3D%22width%3A%20881px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F18582iEB0FC3DC4D6CDAFB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E6%97%A0%E6%A0%87%E9%A2%98.png%22%20alt%3D%22%E6%97%A0%E6%A0%87%E9%A2%98.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%97%A0%E6%A0%87%E9%A2%981.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%97%A0%E6%A0%87%E9%A2%981.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F18633iE8789A0170FAC82D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E6%97%A0%E6%A0%87%E9%A2%981.png%22%20alt%3D%22%E6%97%A0%E6%A0%87%E9%A2%981.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116556%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116556%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDear%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Es32v-evb%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81MAX9286%20%2B%20Onsemi%20AR0140%20%2B%20AP0101%20%2B%20MAX9271%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E9%96%A2%E9%80%A3%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%84%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AA%E3%81%A9%E3%81%94%E6%8F%90%E4%BE%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AF%E5%90%8C%E6%9C%9F%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E7%8A%B6%E6%B3%81%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%81%AF%E3%80%812%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3Emax9286_mipi%3A%20%E3%82%BB%E3%83%B3%E3%82%B5%E7%95%AA%E5%8F%B7%20%3D%202.%3CBR%20%2F%3Emxc_mipi_csi2%2021dc000.mipi_csi%3Amipi_csi2_reset%3A%20mipi_lane_bps%20%3D%20336%20Mbps%3CBR%20%2F%3Emxc_mipi_csi2%2021dc000.mipi_csi%3Amipi_csi2_reset%3A%20%E5%80%A4%20%3D%200x2a.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3A%20AP0101%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%2C%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%201.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20(%E3%82%B7%E3%83%A3%E3%83%83%E3%82%BF%E3%83%BC%E5%90%8C%E6%9C%9F)%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3A%20AP0101%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%2C%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%202.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ap0101_initialize%3AAP0101%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20(%E3%82%B7%E3%83%A3%E3%83%83%E3%82%BF%E3%83%BC%E5%90%8C%E6%9C%9F)%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99.%3C%2FDIV%3E%3CDIV%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%94%BB%E5%83%8F%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%8D%95%E8%8E%B7.PNG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%8D%95%E8%8E%B7.PNG%22%20style%3D%22width%3A%20743px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F18547iB356B38924454BFE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E6%8D%95%E8%8E%B7.PNG%22%20alt%3D%22%E6%8D%95%E8%8E%B7.PNG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%8D%95%E8%8E%B7.PNG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%8D%95%E8%8E%B7.PNG%22%20style%3D%22width%3A%20712px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F18602iA829D84D887281A4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E6%8D%95%E8%8E%B7.PNG%22%20alt%3D%22%E6%8D%95%E8%8E%B7.PNG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9Fg_sensor_num%20%3D%202%20%E3%83%AC%E3%83%BC%E3%83%B3%E6%95%B0%20%3D%203%3C%2FDIV%3E%3CDIV%3Emipi_csi2_reset(mipi_csi2_info%2C%20(672*%20g_sensor_num)%20%2F%20(lanes%20%2B%201))%3B%3C%2FDIV%3E%3CDIV%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8C%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116552%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116552%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81BSP%203.10.53%E3%80%81MAX9286%2BMAX96707%2BISX016%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E7%94%BB%E5%83%8F%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%812%E5%8F%B0%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E5%B8%B8%E3%81%AB%E3%80%8Cmipi%20csi2%20can%20not%20receive%20sensor%20clk!%20(MIPI%20CSI2%E3%81%8C%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93)%20MIPI_CSI_PHY_STATE%20%3D%200x6f0%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%87%BA%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F328548-7-390480%2FL3.10.53_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip%22%20target%3D%22_blank%22%3E%3CSTRONG%20style%3D%22color%3A%20%235e89c1%3B%22%3EL3.10.53_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip%3C%2FSTRONG%3E%3C%2FA%3E%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E6%B8%88%E3%81%BF%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Emax9271_write_reg(0%2C%200x40%2C%200x2F)%3B%3CBR%20%2F%3Emsleep(2)%3B%3CBR%20%2F%3Emax9271_write_reg(0%2C%200x97%2C%200x5F)%3B%3C%2FP%3E%3CP%3E....%3C%2FP%3E%3CP%3Emax9286_write_reg(0x01%2C%200x00)%3B%3CBR%20%2F%3Emax9286_write_reg(0x63%2C%200x00)%3B%3CBR%20%2F%3Emax9286_write_reg(0x64%2C%200x00)%3B%3C%2FP%3E%3CP%3E%26nbsp%3Bmax9286_write_reg(0x06%2C%200x00)%3B%3CBR%20%2F%3E%26nbsp%3Bmax9286_write_reg(0x07%2C%200x00)%3B%3CBR%20%2F%3E%26nbsp%3Bmax9286_write_reg(0x08%2C%200x26)%3B%3C%2FP%3E%3CP%3E...%3C%2FP%3E%3CP%3Emipi_csi2_reset(mipi_csi2_info%2C%20(576%20*%20g_sensor_num)%20%2F%20(lanes%20%2B%201))%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%80%8CDebug%20steps%20for%20customer%20MIPI%20sensor.docx%EF%BC%88%E3%81%8A%E5%AE%A2%E6%A7%98%E5%90%91%E3%81%91MIPI%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%89%8B%E9%A0%86%EF%BC%89%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%20medium%3B%22%3Ehsp_clk%E3%81%A8ccm_pixel_clkm%3C%2FSPAN%3E%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E3%81%A9%E3%81%93%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%AE%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%E3%82%82%E3%81%861%E3%81%A4%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E3%80%81MAX9286%EF%BC%88%3CSPAN%20style%3D%22color%3A%20%23231f20%3B%20font-family%3A%20ArialMT%3B%20font-size%3A%209pt%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%22%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF0x31%E3%81%AEFSYN%20CLOCKED%3C%2FSPAN%3E%EF%BC%89%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%A80x0%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%82%E3%81%972%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8C%3CSPAN%20style%3D%22color%3A%20%23231f20%3B%20font-family%3A%20ArialMT%3B%20font-size%3A%209pt%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%22%3EFSYNC%20LOCKED%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%82%BB%E3%83%B3%E3%82%B5%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3CBR%20style%3D%22text-transform%3A%20none%3B%20line-height%3A%20normal%3B%20text-indent%3A%200px%3B%20letter-spacing%3A%20normal%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20normal%3B%20word-spacing%3A%200px%3B%20white-space%3A%20normal%3B%20orphans%3A%202%3B%20widows%3A%202%3B%20-webkit-text-size-adjust%3A%20auto%3B%20-webkit-text-stroke-width%3A%200px%3B%22%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%E6%84%9F%E8%AC%9D%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116551%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116551%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%3E4%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%A7%E6%92%AE%E5%BD%B1%E3%81%97%E3%81%9F%E5%8B%95%E7%94%BB%E3%82%92%E3%80%81%E4%B8%8A%E4%B8%8B%E5%B7%A6%E5%8F%B3%E3%81%AE%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%A71%E6%9C%AC%E3%81%AE720p%E5%8B%95%E7%94%BB%E3%81%AB%E5%9C%A7%E7%B8%AE%E3%81%97%E3%81%A6%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%814%E6%9C%AC%E3%81%AE%E5%8B%95%E7%94%BB%E3%82%92%E7%B5%B1%E5%90%88%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E4%BD%95%E3%81%8B%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116548%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116548%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A3%9C%E8%B6%B3%EF%BC%9A%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AFov490(isp)%2Bov10640(%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC)%E3%81%A7%E3%80%81%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%99%E3%82%8B%E3%83%87%E3%83%BC%E3%82%BF%E5%BD%A2%E5%BC%8F%E3%81%AFYUV422---YUYV%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116547%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116547%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20class%3D%22%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82video0%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%88%A5%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82mxc_v4l2_tvin_max9286%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%A7%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9FYUV%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E5%B8%B8%E3%81%AB%E5%8F%8D%E8%BB%A2%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%97%E3%81%BE%E3%81%86%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7g_in_fmt%20%3D%20V4L2_PIX_FMT_UYVY%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81capture_buffers%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AFYUYV%E3%81%A7%E3%81%99%E3%80%82g_in_fmt%20%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3D%20V4L2_PIX_FMT_YUYV%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%20%3CSPAN%3Ecapture_buffers%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AFUYVY%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%22%3E%E3%80%82CSI0_SENS_DATA_FORMAT%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%22%3E%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6CSI%E3%83%87%E3%83%BC%E3%82%BF%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%82%92YUYV%E3%81%A8UYUV%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116545%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116545%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%93%E3%83%83%E3%83%8819%E3%81%AF1%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82CSI%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88YUYV%E3%81%8A%E3%82%88%E3%81%B3UYUV%E3%81%AE%3CSPAN%20class%3D%22%22%3ECSI0_SENS_DATA_FORMAT%3C%2FSPAN%3E%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%BE%E3%81%9F%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116540%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116540%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AF%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.35%20%E3%81%A7%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81Li%E3%81%95%E3%82%93%E3%80%82BSP%20L3.14.52.1.1%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E4%B8%AD%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%94%E6%94%AF%E6%8F%B4%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A8%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%81%A9%E3%81%86%E3%81%9E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ebitback%20fsl-image-gui%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%8D%95%E8%8E%B7111.PNG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E6%8D%95%E8%8E%B7111.PNG%22%20style%3D%22width%3A%20992px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F3302i28168E5CE22CB08C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E6%8D%95%E8%8E%B7111.PNG%22%20alt%3D%22%E6%8D%95%E8%8E%B7111.PNG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%8A%E8%BF%94%E4%BA%8B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82OV10635%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5ROM%E3%81%8C%E6%90%AD%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81FSIN%E3%80%81HRFE%E3%80%81VSYNC%E3%81%AE%E6%B3%A2%E5%BD%A2%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AFOV10635%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%81%82%E3%82%8B%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8BOV10635%E3%81%AF2014%E5%B9%B4%E8%A3%BD%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF2014%E5%B9%B4%E7%89%88%E3%81%AE%E3%83%81%E3%83%83%E3%83%97%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E8%A8%AD%E5%AE%9A%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FSIN-VS1.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FSIN-VS1.JPG%22%20style%3D%22width%3A%20640px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2374iD859654232EAC2D4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FSIN-VS1.JPG%22%20alt%3D%22FSIN-VS1.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FSIN-VS2.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FSIN-VS2.JPG%22%20style%3D%22width%3A%20640px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2415iEEFFB224294A9992%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FSIN-VS2.JPG%22%20alt%3D%22FSIN-VS2.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSTRONG%3E%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%EF%BC%9A%E9%BB%84%E8%89%B2%E3%81%8CFSIN%E3%80%81%E9%9D%92%E3%81%8CVSYNC%E3%81%A7%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22HREF-VS1.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22HREF-VS1.JPG%22%20style%3D%22width%3A%20640px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2459i7C23CEC4E4A8ED79%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22HREF-VS1.JPG%22%20alt%3D%22HREF-VS1.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22HREF-VS2.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22HREF-VS2.JPG%22%20style%3D%22width%3A%20640px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2498i825C64F8793FA088%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22HREF-VS2.JPG%22%20alt%3D%22HREF-VS2.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%EF%BC%9A%E9%BB%84%E8%89%B2%E3%81%8CHREF%E3%80%81%E9%9D%92%E8%89%B2%E3%81%8CVSYNC%E3%81%A7%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%EF%BC%8C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3BHD%20720p%E3%81%AE%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E7%94%A8%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81I.MX6qp-sabreauto%E4%B8%8A%E3%81%A7%E5%8B%95%E4%BD%9C%E7%A2%BA%E8%AA%8D%E6%B8%88%E3%81%BF%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E7%8F%BE%E5%9C%A8%E3%81%AF%E3%80%81I.MX6qsabresd%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%A8%AD%E8%A8%88%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81BSP%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AFimx6qsabresd%E5%90%91%E3%81%91%E3%81%AEL3.14.52%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%81%93%E3%81%A7%E3%81%8A%E9%A1%98%E3%81%84%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82imx6qsabresd%E5%90%91%E3%81%91%E3%81%AEL3.14.52%E7%94%A8%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%80%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%AA%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116535%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116535%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EHi~Li%20Qiang!%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E3%81%94%E6%8F%90%E4%BE%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20OV10635%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8F%90%E4%BE%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82OV10635%E3%81%AEVSYNC%E3%81%8C%E4%B8%8D%E9%80%A3%E7%B6%9A%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82HREF%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%80%81%E7%B4%8430fps%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%A1%E3%82%89%E3%81%ABVSYNC%E6%B3%A2%E5%BD%A2%E3%82%92%E8%B2%BC%E3%82%8A%E4%BB%98%E3%81%91%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116534%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116534%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%26nbsp%3B%20Qiang%20li%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBYD%E3%81%A8%E5%85%B1%E5%90%8C%E9%96%8B%E7%99%BA%E3%81%97%E3%81%9F%E8%A3%BD%E5%93%81%E3%81%AB%E3%81%AFtw6865%E3%81%A8max9286%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82tw6865%E3%81%AF3.0.35%E3%81%A7%E6%97%A2%E3%81%AB%E8%AA%BF%E6%95%B4%E6%B8%88%E3%81%BF%E3%81%A7%E3%81%99%E3%81%8C%E3%80%819286%E3%81%AF3.0.35%E3%81%A7%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8C%E9%9B%A3%E3%81%97%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%81%94%E5%8D%94%E5%8A%9B%E3%82%92%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81imx6%E3%81%AE4%E3%81%A4%E3%81%AE%E4%BB%AE%E6%83%B3%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E5%90%8C%E6%99%82%E3%81%AB%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%83%87%E3%83%BC%E3%82%BF%E5%8F%8E%E9%9B%86%E3%82%92%E8%A1%8C%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E8%AA%BF%E6%95%B4%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81max9286%E3%81%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9AP0101%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%A7%E3%81%8D%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%A8%E6%A4%9C%E5%87%BA%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%8E%9F%E5%9B%A0%E3%81%AF%E4%B8%8D%E6%98%8E%E3%81%A7%E3%81%99%E3%81%8C%E3%80%814%E3%81%A4%E3%81%AE%E4%BB%AE%E6%83%B3%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AE%E6%9C%89%E5%8A%B9%E5%8C%96%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%8B%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%95%E3%82%8C%E3%81%9F%E3%83%91%E3%83%83%E3%83%813.10.53%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E7%A7%BB%E6%A4%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%94%E5%8D%94%E5%8A%9B%E3%82%92%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116533%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116533%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Qiang%20li%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIPU%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%903.0.35%E3%81%A74%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%82%82%E3%81%97%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E9%80%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%A8%E5%AC%89%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116532%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116532%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EQiang%20li%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ebsp%203.10.53%20%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%9F%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3Estatic%20int%20mipi_csi2_probe(struct%20platform_device%20*pdev)%3CBR%20%2F%3E%7B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E.%20.%20.%20.%20.%20.%20.%20.%20.%20.%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3Eret%20%3D%20of_property_read_u32(np%2C%20%22lanes%22%2C%20%26amp%3B(gmipi_csi2-%26gt%3Blanes))%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20if%20(ret)%20%7B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20dev_err(%26amp%3Bpdev-%26gt%3Bdev%2C%20%22lanes%20missing%20or%20invalid%5Cn%22)%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20goto%20err%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20%7D%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20if%20(gmipi_csi2-%26gt%3Blanes%20%26gt%3B%204)%20%7B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20dev_err(%26amp%3Bpdev-%26gt%3Bdev%2C%20%22invalid%20lanes%20for%20mipi%20csi2!%5Cn%22)%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20ret%20%3D%20-EINVAL%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20goto%20err%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3Efor_each_child_of_node(np%2C%20child)%20%7B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20struct%20mipi_csi2_chan%20*chan%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3Eif%20(!of_device_is_available(child))%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20continue%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3Eret%20%3D%20of_property_read_u32(child%2C%20%22v_channel%22%2C%20%26amp%3Bv_channel)%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20if%20(ret)%20%7B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20dev_err(%26amp%3Bpdev-%26gt%3Bdev%2C%20%22v_channel%20missing%5Cn%22)%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20goto%20err%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3Eif%20(v_channel%20%26gt%3B%203)%20%7B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20dev_err(%26amp%3Bpdev-%26gt%3Bdev%2C%20%22v_channel%20invalid%5Cn%22)%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20ret%20%3D%20-EINVAL%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20goto%20err%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3Echan%20%3D%20%26amp%3B(gmipi_csi2-%26gt%3Bmipi_chan%5Bv_channel%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3Eret%20%3D%20of_property_read_u32(child%2C%20%22ipu_id%22%2C%20%26amp%3B(gmipi_csi2-%26gt%3Bmipi_chan%5Bv_channel%5D.ipu_id))%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20if%20(ret)%20%7B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20dev_err(%26amp%3Bpdev-%26gt%3Bdev%2C%20%22ipu_id%20missing%20or%20invalid%5Cn%22)%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20goto%20err%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20%7D%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20ret%20%3D%20of_property_read_u32(child%2C%20%22csi_id%22%2C%20%26amp%3B(gmipi_csi2-%26gt%3Bmipi_chan%5Bv_channel%5D.csi_id))%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20if%20(ret)%20%7B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20dev_err(%26amp%3Bpdev-%26gt%3Bdev%2C%20%22csi_id%20missing%20or%20invalid%5Cn%22)%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20goto%20err%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3Eif%20((gmipi_csi2-%26gt%3Bmipi_chan%5Bv_channel%5D.ipu_id%20%26lt%3B%200)%20%7C%7C%20%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20(gmipi_csi2-%26gt%3Bmipi_chan%5Bv_channel%5D.ipu_id%20%26gt%3B%201)%20%7C%7C%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20(gmipi_csi2-%26gt%3Bmipi_chan%5Bv_channel%5D.csi_id%20%26gt%3B%201))%20%7B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20dev_err(%26amp%3Bpdev-%26gt%3Bdev%2C%20%22invalid%20param%20for%20mipi%20csi2!%5Cn%22)%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20ret%20%3D%20-EINVAL%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff6600%3B%22%3E%20goto%20err%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%E3%80%82%E3%80%82%E3%80%82%E3%80%82%E3%80%82%E3%80%82%E3%80%82%E3%80%82%E3%80%82%E3%80%82%E3%80%82%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.0.35%E3%81%A7%E3%81%AF%E3%81%93%E3%81%AE%E9%83%A8%E5%88%86%E3%82%92%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%87%A6%E7%90%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%AA%E3%81%84%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%A8%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3Estatic%20int%20mipi_csi2_probe(struct%20platform_device%20*pdev)%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20struct%20mipi_csi2_platform_data%20*plat_data%20%3D%20pdev-%26gt%3Bdev.platform_data%3B%3CBR%20%2F%3E%20struct%20resource%20*res%3B%3CBR%20%2F%3E%20u32%20mipi_csi2_dphy_ver%3B%3CBR%20%2F%3E%20struct%20mipi_csi2_chan%20*chan%3B%3C%2FP%3E%3CP%3Eint%20ret%20%2C%20v_channel%3B%3C%2FP%3E%3CP%3Eprintk(%22mipi_csi2%20probe%20start%20!!!!!!!!!!!!!!!!!!!!!%5Cn%22)%3B%3CBR%20%2F%3E%20gmipi_csi2%20%3D%20kmalloc(sizeof(struct%20mipi_csi2_info)%2C%20GFP_KERNEL)%3B%3CBR%20%2F%3E%20if%20(!gmipi_csi2)%20%7B%3CBR%20%2F%3E%20ret%20%3D%20-ENOMEM%3B%3CBR%20%2F%3E%20goto%20alloc_failed%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20printk(%22v_channel%20is%20%25d%20!!!!!!!!!!!!!!!!1111%5Cn%22%2Cv_channel)%3B%3CBR%20%2F%3E%20%2F*%20initialize%20mutex%20*%2F%3CBR%20%2F%3E%20mutex_init(%26amp%3Bgmipi_csi2-%26gt%3Bmutex_lock)%3B%3C%2FP%3E%3CP%3Echan%20%3D%20%26amp%3B(gmipi_csi2-%26gt%3Bmipi_chan%5Bv_channel%5D)%3B%3C%2FP%3E%3CP%3E%2F*%20get%20mipi%20csi2%20informaiton%20*%2F%3CBR%20%2F%3E%20gmipi_csi2-%26gt%3Bpdev%20%3D%20pdev%3B%3CBR%20%2F%3E%20gmipi_csi2-%26gt%3Bmipi_en%20%3D%20false%3B%3CBR%20%2F%3E%20%2F%2Fgmipi_csi2-%26gt%3Bipu_id%20%3D%20plat_data-%26gt%3Bipu_id%3B%3CBR%20%2F%3E%20%2F%2Fgmipi_csi2-%26gt%3Bcsi_id%20%3D%20plat_data-%26gt%3Bcsi_id%3B%3CBR%20%2F%3E%20%2F%2Fgmipi_csi2-%26gt%3Bv_channel%20%3D%20plat_data-%26gt%3Bv_channel%3B%3CBR%20%2F%3E%20gmipi_csi2-%26gt%3Blanes%20%3D%20plat_data-%26gt%3Blanes%3B%3CBR%20%2F%3E%20printk(%22plat_data%20lanes%20is%20%25d%20!!!!!!!!!!!!!!!%5Cn%22%2C%20plat_data-%26gt%3Blanes)%3B%3CBR%20%2F%3E%20v_channel%20%3D%20plat_data-%26gt%3Bv_channel%3B%3CBR%20%2F%3E%20gmipi_csi2-%26gt%3Bmipi_chan%5Bv_channel%5D.ipu_id%3D%20plat_data-%26gt%3Bipu_id%3B%3CBR%20%2F%3E%20gmipi_csi2-%26gt%3Bmipi_chan%5Bv_channel%5D.csi_id%3D%20plat_data-%26gt%3Bcsi_id%3B%3C%2FP%3E%3CP%3Eif%20((gmipi_csi2-%26gt%3Bmipi_chan%5Bv_channel%5D.ipu_id%20%26lt%3B%200)%20%7C%7C%20%3CBR%20%2F%3E%20(gmipi_csi2-%26gt%3Bmipi_chan%5Bv_channel%5D.ipu_id%20%26gt%3B%201)%20%7C%7C%3CBR%20%2F%3E%20(gmipi_csi2-%26gt%3Bmipi_chan%5Bv_channel%5D.csi_id%20%26gt%3B%201))%20%7B%3CBR%20%2F%3E%20dev_err(%26amp%3Bpdev-%26gt%3Bdev%2C%20%22invalid%20param%20for%20mipi%20csi2!%5Cn%22)%3B%3CBR%20%2F%3E%20ret%20%3D%20-EINVAL%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E.%20.%20.%20.%20.%20.%20.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3Bstatic%20struct%20mipi_csi2_platform_data%20mipi_csi2_pdata%20%3D%20%7B%3CBR%20%2F%3E%20.ipu_id%20%3D%200%2C%20%2F%2F0%20%2F%2F%20modify%20by%20lee%3CBR%20%2F%3E%20.csi_id%20%3D%200%2C%3CBR%20%2F%3E%20.v_channel%20%3D%200%2C%3CBR%20%2F%3E%20.lanes%20%3D%204%2C%3CBR%20%2F%3E%20.dphy_clk%20%3D%20%22mipi_pllref_clk%22%2C%3CBR%20%2F%3E%20.pixel_clk%20%3D%20%22emi_clk%22%2C%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%93%8D%E4%BD%9C%E3%81%A7%E5%A4%A7%E4%B8%88%E5%A4%AB%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%823.0.35%E3%81%AEmax9286%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E9%95%B7%E3%81%84%E9%96%93%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E9%80%B2%E5%B1%95%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%94%E6%94%AF%E6%8F%B4%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%20%26nbsp%3BLi%20Qiang%EF%BC%9A%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%E8%A8%AD%E5%AE%9A%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%8F%90%E4%BE%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AFAP0101%E3%81%97%E3%81%8B%E3%81%AA%E3%81%8F%E3%80%81AR0140%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20426px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F5203i8FC86447DC8D50A9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116528%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116528%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%20%26nbsp%3BLi%20qiang%EF%BC%9A%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%E7%A7%81%E3%81%AE%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AFAR0140%E3%81%A7%E3%80%81OV10635%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%A9%E3%81%93%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%94%E6%95%99%E7%A4%BA%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116526%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116526%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%20%26nbsp%3Bqiang%20li%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%E7%A7%81%E3%81%AFMAX9286%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%815V%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AEMAX9286%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AFMaxim%E7%A4%BE%E8%A3%BD%E3%81%A7%E3%80%81i.MX6%E5%90%91%E3%81%91%E3%81%AB%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%9F%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2261600121988173929.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2261600121988173929.jpg%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2668i9665C55642DCE1BE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2261600121988173929.jpg%22%20alt%3D%2261600121988173929.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MAX9286_iMX6_SCH_RevP11.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MAX9286_iMX6_SCH_RevP11.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2717i3EF186C49B5B7191%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MAX9286_iMX6_SCH_RevP11.png%22%20alt%3D%22MAX9286_iMX6_SCH_RevP11.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MAX9286_iMX6_SCH_RevP12.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MAX9286_iMX6_SCH_RevP12.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2738iAFA18967749D04B9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MAX9286_iMX6_SCH_RevP12.png%22%20alt%3D%22MAX9286_iMX6_SCH_RevP12.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116524%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116524%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Einux_3.10.35%2Farch%2Farm%2Fboot%2Fdts%2Fimx6q-sabreauto.dts%20%26nbsp%3B%E4%B8%AD%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%3C%2FP%3E%3CP%3E%26amp%3Bmipi_csi%20%7B%3CBR%20%2F%3E%20status%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%20lanes%20%3D%20%26lt%3B4%26gt%3B%3B%3C%2FP%3E%3CP%3Emipi-csi2-channel%400%20%7B%3CBR%20%2F%3E%20ipu_id%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20csi_id%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20v_channel%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20status%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3Emipi-csi2-channel%401%20%7B%3CBR%20%2F%3E%20ipu_id%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20csi_id%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20v_channel%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20status%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3Emipi-csi2-channel%402%20%7B%3CBR%20%2F%3E%20ipu_id%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20csi_id%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20v_channel%20%3D%20%26lt%3B2%26gt%3B%3B%3CBR%20%2F%3E%20status%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3Emipi-csi2-channel%403%20%7B%3CBR%20%2F%3E%20ipu_id%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20csi_id%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20v_channel%20%3D%20%26lt%3B3%26gt%3B%3B%3CBR%20%2F%3E%20status%20%3D%20%22okay%22%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%3CP%3E%E8%BF%99%E4%B8%80%E6%AE%B5%E5%9C%A83.0.35%E4%B8%AD%E6%80%8E%E4%B9%88%E5%A4%84%E7%90%86%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116523%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116523%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%813.10.53%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%80%81%E5%A4%89%E6%9B%B4%E3%82%92%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E3%80%813.0%20%E3%81%AB%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%2035%20%E3%81%AB%201%20%E3%81%A4%E3%81%9A%E3%81%A4%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116522%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116522%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%87%AA%E5%88%86%E3%81%A7%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E7%B0%A1%E5%8D%98%E3%81%AA%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116519%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116519%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Edear%26nbsp%3B%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%2236648%22%20data-username%3D%22Qiang_FSL%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20style%3D%22color%3A%20%238ca9cd%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20font-size%3A%201.286rem%3B%22%20target%3D%22_blank%22%3EQiang%20Li%3C%2FA%3E%EF%BC%9A%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bimx6q-sabreauto%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E5%8B%95%E4%BD%9C%E7%A2%BA%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E7%A7%81%E3%81%AE%E7%92%B0%E5%A2%83%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7MAX9286%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%9B%E3%81%9A%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1%20-x%200%20-g2d%20%26amp%3Blo%3A%2Funit_tests%23%20.%2Fmxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20960%20-oh%20540%20-d%20%3CBR%20%2F%3E%5B1%5D%20845%3CBR%20%2F%3Eroot%40imx6qdlsolo%3A%2Funit_tests%23%20max9286_mipi%3A%20%E3%82%BB%E3%83%B3%E3%82%B5%E7%95%AA%E5%8F%B7%20%3D%201.%3CBR%20%2F%3Emxc_mipi_csi2%2021dc000.mipi_csi%3Amipi_csi2_reset%3A%20mipi_lane_bps%20%3D%20192%20Mbps%3CBR%20%2F%3Emxc_mipi_csi2%2021dc000.mipi_csi%3Amipi_csi2_reset%3A%20%E5%80%A4%20%3D%200x44.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ov10635_read_reg%3A%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20reg%3D0x300a.%3CBR%20%2F%3Emax9286_mipi%201-006a%3A%20ov10635_check_device%3A%20OV10635%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%2C%20reg%5B0x300a%5D%20%3D%200x0.%3CBR%20%2F%3EMIPI%20CSI2%20%E3%81%8C%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E4%BF%A1%E5%8F%B7%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%81%20MIPI_CSI_PHY_STATE%20%3D%200x6f0.%3CBR%20%2F%3Eg_in_width%20%3D%201280%2C%20g_in_height%20%3D%20800.%3CBR%20%2F%3Efb_fix.id%20%3D%20DISP4%20FG.%3CBR%20%2F%3Efb%3A%20smem_start%20%3D%200x73600000%2C%20smem_len%20%3D%200x480000.%3CBR%20%2F%3Efb%3A%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%20%3D%200x180000%E3%83%90%E3%82%A4%E3%83%88.%3CBR%20%2F%3Efb%3A%20g_screen_info.xres%20%3D%201024%2C%20g_screen_info.yres%20%3D%20768.%3CBR%20%2F%3Efb%3A%20g_display_left%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_top%20%3D%200.%3CBR%20%2F%3Efb%3A%20g_display_width%20%3D%20960.%3CBR%20%2F%3Efb%3A%20g_display_height%20%3D%20540.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Edear%20Qiang%20Li%EF%BC%9A%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20L3.14.52%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%81%A1%E3%82%89%E3%81%AEmxc_v4l2_tvin_max9286.tar.gz%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E4%BD%BF%E3%81%86%E3%81%A8%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%8C%E3%83%AD%E3%82%B0%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E.%2Fmxc_v4l2_tvin.out%3A%20%E5%85%B1%E6%9C%89%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E4%B8%AD%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%3A%20libg2d.so.0.8%3A%20%E5%85%B1%E6%9C%89%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%3A%20%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116515%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116515%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20font-size%3A%2014px%3B%22%3EHi%20Qiang%20Li%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20font-size%3A%2014px%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203.14.52%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E9%81%A9%E7%94%A8%E6%B8%88%E3%81%BF%E3%81%A7%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F328548-7-363516%2Fmxc_v4l2_tvin_max9286.tar.gz%22%20style%3D%22font-size%3A%2012px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%23017bba%3B%20background-color%3A%20%23fdfdfd%3B%22%20target%3D%22_blank%22%3Emxc_v4l2_tvin_max9286.tar.gz%3C%2FA%3E%E3%81%AFrootfs%E3%81%AB%E5%90%AB%E3%82%81%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%ABunit_tests%2F%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20font-size%3A%2014px%3B%22%3Emxc_v4l2_tvin.out%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E7%94%BB%E9%9D%A2%E3%81%AB%E3%81%AF%E4%BD%95%E3%82%82%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E3%81%8A%E9%A1%98%E3%81%84%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%BE%E3%81%9F%E3%80%813.14.52%E3%81%AEYocto%E7%92%B0%E5%A2%83%E3%81%A7%E3%81%AF%E3%80%81%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F328548-7-363516%2Fmxc_v4l2_tvin_max9286.tar.gz%22%20style%3D%22font-size%3A%2012px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%23017bba%3B%20background-color%3A%20%23fdfdfd%3B%22%20target%3D%22_blank%22%3Emxc_v4l2_tvin_max9286.tar.gz%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FA%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116514%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116514%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3L3.0.35_4.1.0%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%82%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116513%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116513%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82L3.0.35_4.1.0%20%E3%81%A7%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E4%B8%80%E7%B7%92%E3%81%AB%E8%A9%B1%E3%81%97%E5%90%88%E3%81%84%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%AA%E3%82%8B%E3%81%BB%E3%81%A9%E3%80%82%3C%2FP%3E%3CP%3Eimx6qdl-sabreauto.dtsi%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%86%85%E3%81%AEadv7180%E3%81%AF%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%A2%E3%82%A6%E3%83%88%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EZongbiaoLiao%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%AD%E3%82%B0%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E---------------------------------------%3C%2FP%3E%3CP%3Eroot%40imx6qsabreauto%3A%2Funit_tests%23%20.%2Fmax9286.sh%3C%2FP%3E%3CP%3Eroot%40imx6qsabreauto%3A%2Funit_tests%23%20g_in_width%20%3D%201280%E3%80%81g_in_height%20%3D%20800%E3%80%82%3C%2FP%3E%3CP%3Efb_fix.id%20%3D%20DISP3%20FG%E3%80%82%3C%2FP%3E%3CP%3Eg_in_width%20%3D%201280%E3%80%81g_in_height%20%3D%20800%E3%80%82%3C%2FP%3E%3CP%3Eg_in_width%20%3D%201280%E3%80%81g_in_height%20%3D%20800%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20smem_start%20%3D%200x72c00000%E3%80%81smem_len%20%3D%200xbdd800%E3%80%82%3C%2FP%3E%3CP%3Efb_fix.id%20%3D%20DISP3%20FG%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%20%3D%200x3f4800%20%E3%83%90%E3%82%A4%E3%83%88%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_screen_info.xres%20%3D%201920%E3%80%81g_screen_info.yres%20%3D%201080%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_left%20%3D%20960%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_top%20%3D%200.%3C%2FP%3E%3CP%3Efb%3A%20g_display_width%20%3D%20960%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_height%20%3D%20540%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20smem_start%20%3D%200x72c00000%E3%80%81smem_len%20%3D%200xbdd800%E3%80%82%3C%2FP%3E%3CP%3E%E9%96%8B%E5%A7%8B%E6%99%82%E9%96%93%20%3D%201457509993%E7%A7%92%E3%80%81697691%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E7%A7%92%3C%2FP%3E%3CP%3Efb%3A%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%20%3D%200x3f4800%20%E3%83%90%E3%82%A4%E3%83%88%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_screen_info.xres%20%3D%201920%E3%80%81g_screen_info.yres%20%3D%201080%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_left%20%3D%200%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_top%20%3D%20540.%3C%2FP%3E%3CP%3Efb_fix.id%20%3D%20DISP3%20FG%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_width%20%3D%20960%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_height%20%3D%20540%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20smem_start%20%3D%200x72c00000%E3%80%81smem_len%20%3D%200xbdd800%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%20%3D%200x3f4800%20%E3%83%90%E3%82%A4%E3%83%88%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_screen_info.xres%20%3D%201920%E3%80%81g_screen_info.yres%20%3D%201080%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_left%20%3D%20960%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_top%20%3D%20540.%3C%2FP%3E%3CP%3Efb%3A%20g_display_width%20%3D%20960%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_height%20%3D%20540%E3%80%82%3C%2FP%3E%3CP%3E%E9%96%8B%E5%A7%8B%E6%99%82%E9%96%93%20%3D%201457509993%E7%A7%92%E3%80%81717597%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E7%A7%92%3C%2FP%3E%3CP%3E%E9%96%8B%E5%A7%8B%E6%99%82%E9%96%93%20%3D%201457509993%E7%A7%92%E3%80%81717698%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E7%A7%92%3C%2FP%3E%3CP%3Eg_in_width%20%3D%20720%E3%80%81g_in_height%20%3D%20624%E3%80%82%3C%2FP%3E%3CP%3Efb_fix.id%20%3D%20DISP3%20FG%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20smem_start%20%3D%200x72c00000%E3%80%81smem_len%20%3D%200xbdd800%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%20%3D%200x3f4800%20%E3%83%90%E3%82%A4%E3%83%88%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_screen_info.xres%20%3D%201920%E3%80%81g_screen_info.yres%20%3D%201080%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_left%20%3D%200%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_top%20%3D%200.%3C%2FP%3E%3CP%3Efb%3A%20g_display_width%20%3D%20960%E3%80%82%3C%2FP%3E%3CP%3Efb%3A%20g_display_height%20%3D%20540%E3%80%82%3C%2FP%3E%3CP%3E%E9%96%8B%E5%A7%8B%E6%99%82%E9%96%93%20%3D%201457509994%E7%A7%92%E3%80%8145827%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E7%A7%92%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20v4l2%20%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%3A%20mxc_v4l_dqueue%20%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%20enc_counter%200%3C%2FP%3E%3CP%3EVIDIOC_DQBUF%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E------------------------------------------------------%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81HDMI%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9F%E5%86%85%E5%AE%B9%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_0587.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_0587.JPG%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F1492i4FA85BE853664257%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22IMG_0587.JPG%22%20alt%3D%22IMG_0587.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E5%88%9D%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AB%E3%81%AF%E4%BD%95%E3%82%82%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9A%E3%80%81%E6%95%B0%E7%A7%92%E5%BE%8C%E3%81%AB%E3%80%8CERROR%3A%20v4l2%20capture%3A%20mxc_v4l_dqueue%20timeout%20enc_counter%200%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%80%81%20%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E6%AE%8B%E3%82%8A%E3%81%AE3%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%82%E5%81%9C%E6%AD%A2%E3%81%97%E3%80%81%E4%BD%95%E3%82%82%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EZongbiaoLiao%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116507%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116507%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20Qiang%20Li%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3EMAX9271%3C%2FSPAN%3E%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%A0%E3%81%91%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%9B%E3%81%9A%E3%80%81%E4%BB%96%E3%81%AE3%E5%8F%B0%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3EZongbiaoLiao%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3EL3.14.52_GA1.1.0%E7%94%A8%E3%83%91%E3%83%83%E3%83%81%3C%2FSPAN%3E%E3%82%92%E5%85%AC%E9%96%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E6%9C%80%E5%88%9D%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%EF%BC%88%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3Emxc_v4l2_tvin.out%20-ol%200%20-ot%200%20-ow%20960%20-oh%20540%20-d%201%20-x%200%20-g2d%20%26amp%3B%3C%2FSPAN%3E%EF%BC%89%E3%81%AF%E4%BD%95%E3%82%82%E8%A1%A8%E7%A4%BA%E3%81%9B%E3%81%9A%E3%80%81%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E6%95%B0%E7%A7%92%E5%BE%8C%E3%81%AB%E3%80%8CVIDIOC_DQBUF%20failed%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E4%BB%96%E3%81%AE3%E5%8F%B0%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%82%E3%81%99%E3%81%B9%E3%81%A6%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%813.10.53%E7%94%A8%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3EZongbiaoLiao%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116504%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20camera%20surround%20view%20solution%20for%20Linux%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116504%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%E8%89%B2%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99!%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%BC%E3%83%AB%E3%82%92%E6%8B%9D%E8%A6%8B%E3%81%97%E3%80%81%E5%85%83%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%A1%E3%83%BC%E3%83%AB%E5%86%85%E3%81%AEov10635_setting%E3%81%AF%E5%85%83%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E5%86%85%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A8%E5%85%A8%E3%81%8F%E5%90%8C%E3%81%98%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EMAX9286_OV10635_1280x800_Quad_FSIN_MOD.C%E3%81%A8%E3%81%84%E3%81%86%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A4%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%85%83%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20iMX6DQ%20MAX9286%20MIPI%20CSI2%20720P%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%B5%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20Linux%20BSP%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi~Li%20Qiang!%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E3%81%94%E6%8F%90%E4%BE%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%93%E3%81%A1%E3%82%89%E3%81%AECPU%E3%81%AF%3CSTRONG%3EIMX6Q-Sabresd%3C%2FSTRONG%3E%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AF%3CSTRONG%3EOV10635%3C%2FSTRONG%3E%E3%81%A7%E3%81%99%E3%80%82LTIB%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Arial%3B%20text-align%3A%20justify%3B%22%3E%E3%81%AF%3C%2FSPAN%3E%3CSTRONG%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Arial%3B%20text-align%3A%20justify%3B%22%3EL3.0.35_4.1.0%3C%2FSTRONG%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎04-26-2021 01:39 AM
更新者:
