i.MX51 EVK Board Video
Search instead for
No ratings
How to load the camera driver
modprobe ov3640_camera
modprobe mxc_v4l2_capture
How to encode audio
gst-launch alsasrc ! mfw_mp3encoder ! filesink location= audio.mp3
Encoding an AVI audio only
gst-launch alsasrc ! mfw_mp3encoder ! avimux ! filesink location=audio.avi
You can use audiotestsrc instead of alsasrc
Encoding Audio and Video (testsrc only)
Raw video and Raw audio
gst-launch videotestsrc num-buffers=250 ! 'video/x-raw-yuv,format=fourcc)I420,width=320,height=240,framerate=(fraction)25/1' ! queue ! mux. audiotestsrc num-buffers=440 ! audioconvert ! 'audio/x-raw-int,rate=44100,channels=2' ! queue ! mux. avimux name=mux ! filesink location=test.avi
H.263 video and Raw audio
gst-launch videotestsrc num-buffers=250 ! mfw_vpuencoder codec-type=1 ! queue ! mux. audiotestsrc num-buffers=440 ! audioconvert ! 'audio/x-raw-int,rate=44100,channels=2' ! queue ! mux. avimux name=mux ! filesink location=test.avi
H.263 video and MP3 audio
gst-launch videotestsrc num-buffers=250 ! mfw_vpuencoder codec-type=1 ! queue ! mux. audiotestsrc num-buffers=440 ! audioconvert ! mfw_mp3encoder ! queue ! mux. avimux name=mux ! filesink location=test.avi
Real Source
gst-launch-0.10 mfw_v4lsrc capture-mode=5 num-buffers=300 capture-width=320 capture-height=240 fps-n=15 blocksize=115200 ! queue2 max-size-buffers=1000 max-size-bytes=0 max-size-time=0 ! mfw_vpuencoder framerate=15 codec-type=2 name=venc  alsasrc num-buffers=300 ! audio/x-raw-int,rate=32000,channels=1,depth=16 ! audioconvert ! queue2 max-size-buffers=1000 max-size-bytes=0 max-size-time=0 ! mfw_mp3encoder name=aenc avimux name=mux ! filesink location=all_in_one.avi aenc. ! mux. venc. ! mux.
The movie isn't that good, but you can improve that increasing num-buffers, width and heigh, and even framerate!
STAMP
If you face synchronization issues, you can try to use a non-standard plugin called stamp.
Use the spec file gst-entrans.spec
and this command line:
gst-launch-0.10 mfw_v4lsrc capture-mode=5 num-buffers=160 capture-width=320 capture-height=240 fps-n=15 blocksize=115200 !  stamp sync-margin=1 sync-interval=1 ! queue2 max-size-buffers=1000 max-size-bytes=0 max-size-time=0  !  mfw_vpuencoder framerate=15 codec-type=2 name=venc  alsasrc num-buffers=160  !  audio/x-raw-int,rate=32000,channels=1,depth=16     !  audioconvert ! queue2 max-size-buffers=1000 max-size-bytes=0 max-size-time=0      !  mfw_mp3encoder name=aenc avimux name=mux ! filesink location=test_ALL.avi aenc. ! mux. venc. ! mux.
Donwload the package from here:
http://gentrans.sourceforge.net/
(source for stamp topic: http://blog.buberel.org/2008/03/using-a-usb-web.html)
Tags (2)
Version history
Revision #:
2 of 2
Last update:
‎09-10-2020 02:05 AM
Updated by:
