i.MX27 ADS
i.MX27 ADS
i.MX27 ADS
The i.MX27 Application Development System (MCIMX27ADSE) is a development tool which is designed to run software applications designed for the i.MX27 processor.
Features
  • i.MX27 Multimedia Application Processor
  • Two clock-source crystals, 32 KHz and 26 MHz
  • Power management & Audio IC (MC13783) included battery charging, 10bit ADC, buck switchers, boost switcher, regulators, amplifiers, CODEC, SSI audio bus, real time clock, SPI control bus, USB OTG transceiver & touchscreen interface
  • Multi-ICE debug support
  • Two 512Mbit DDR-SDRAM devices, configured as one 128MB, 32-bit device
  • One 256Mbit Burst Flash with 128Mbit Pseudo Static RAM (PSRAM) memory device, configured as one 16MB flash with 8MB PSRAM, 16-bit device
  • An single board system with connections for LCD display panel, Keypad and Image sensor.
  • Complex Programmable Logic Device (CPLD) for reducing glue logic interface
  • Software readable board revisions
  • Configuration and user definable DIP switches
  • Two SD/MMC, MS memory card connectors
  • PCMCIA & ATA Hard Disk Drive (HDD)
  • Two RS-232 transceivers and DB9 connectors (one configured for DCE and one for DTE operation) supporting on-chip UART ports
  • External UART with RS-232 transceiver and DB9 connector
  • Infrared transceiver that conforms to Specification 1.4 of the Infrared Data Association
  • USB Host (HS & FS), USB OTG (HS & HS) interface
  • Separate LCD panel assembly that connects to the main board
  • Separate keypad unit with 36 push button keys
  • Separate CMOS Image Sensor Card
  • A 3.5 mm headset jack, a 3.5 mm line out jack, a 3.5 mm line in jack, a 3.5 mm microphone jack and a 2.5 mm microphone and headset jack
  • Cirrus Logic CS8900A-CQ3Z Ethernet controller (10BASE-T), with RJ-45 connector
  • AMD AM79C874 NetPHY (10BASE-T & 100BASE-X), with RJ-45 connector
  • Two 32 × 3-pin DIN expansion connectors with most i.MX27 I/O signals
  • Variable resistor for emulation of a battery voltage level
  • NAND Flash card (Plugs into Main Board) which is included in the ADS kit
  • LED indicators for power, Ethernet activity, and two LEDs for user defined status indication
  • Universal power supply with 5 volt output @ 5 Amperes
  • USB, RS-232 and RJ45 cables available in kit
Kit Contains
  • a main board
  • an LCD display panel
  • a keypad
  • a NAND flash card
  • an image sensor
  • a TV encoder card, etc
It supports application software, target-board debugging or optional extra memory.
タグ(2)
%3CLINGO-SUB%20id%3D%22lingo-sub-1104809%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX27%20ADS%E3%81%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104809%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ei.MX27%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E9%96%8B%E7%99%BA%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0(MCIMX27ADSE)%E3%81%AF%E3%80%81i.MX27%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E7%94%A8%E3%81%AB%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%9F%E9%96%8B%E7%99%BA%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH5%20id%3D%22toc-hId-1782740992%22%20id%3D%22toc-hId--1588649536%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%E7%89%B9%E9%95%B7%3C%2FSPAN%3E%3C%2FH5%3E%3CUL%3E%3CLI%3Ei.MX27%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%83%BB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%BB%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FLI%3E%3CLI%3E2%E3%81%A4%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%E6%B0%B4%E6%99%B6%E6%8C%AF%E5%8B%95%E5%AD%90%E3%80%8132KHz%E3%81%8A%E3%82%88%E3%81%B326MHz%3C%2FLI%3E%3CLI%3E%E3%83%91%E3%83%AF%E3%83%BC%E3%83%9E%E3%83%8D%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88%26amp%3B%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AAIC(MC13783)%E3%81%AB%E3%81%AF%E3%80%81%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E5%85%85%E9%9B%BB%E3%80%8110%E3%83%93%E3%83%83%E3%83%88ADC%E3%80%81%E3%83%90%E3%83%83%E3%82%AF%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%83%A3%E3%83%BC%E3%80%81%E3%83%96%E3%83%BC%E3%82%B9%E3%83%88%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%83%A3%E3%83%BC%E3%80%81%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%80%81%E3%82%A2%E3%83%B3%E3%83%97%E3%80%81CODEC%E3%80%81SSI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%90%E3%82%B9%E3%80%81%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%80%81SPI%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%83%90%E3%82%B9%E3%80%81USB%20OTG%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%E3%83%BC%E3%80%81%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%3C%2FLI%3E%3CLI%3EMulti-ICE%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FLI%3E%3CLI%3E2%20%E3%81%A4%E3%81%AE%20512%20Mbit%20DDR-SDRAM%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%201%20%E3%81%A4%E3%81%AE%20128MB%E3%80%8132%20%E3%83%93%E3%83%83%E3%83%88%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%3C%2FLI%3E%3CLI%3E1%20%E3%81%A4%E3%81%AE%20256%20M%E3%83%93%E3%83%83%E3%83%88%20%E3%83%90%E3%83%BC%E3%82%B9%E3%83%88%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A8%20128%20Mbit%20%E6%93%AC%E4%BC%BC%E3%82%B9%E3%82%BF%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%20RAM(PSRAM)%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%80%811%20%E3%81%A4%E3%81%AE%2016%20MB%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A8%208%20MB%20PSRAM%E3%80%8116%20%E3%83%93%E3%83%83%E3%83%88%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%3C%2FLI%3E%3CLI%3ELCD%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%91%E3%83%8D%E3%83%AB%E3%80%81%E3%82%AD%E3%83%BC%E3%83%91%E3%83%83%E3%83%89%E3%80%81%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%9C%E3%83%BC%E3%83%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3EComplex%20Programmable%20Logic%20Device(CPLD)%E3%81%AB%E3%82%88%E3%82%8B%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%BB%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AE%E5%89%8A%E6%B8%9B%3C%2FLI%3E%3CLI%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%9C%E3%83%BC%E3%83%89%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FLI%3E%3CLI%3E%E6%A7%8B%E6%88%90%E3%81%8A%E3%82%88%E3%81%B3%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E5%AE%9A%E7%BE%A9%E5%8F%AF%E8%83%BD%E3%81%AADIP%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%3C%2FLI%3E%3CLI%3ESD%2FMMC%E3%80%81MS%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%AB%E3%83%BC%E3%83%89%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%20%C3%97%202%3C%2FLI%3E%3CLI%3EPCMCIA%E3%81%8A%E3%82%88%E3%81%B3ATA%E3%83%8F%E3%83%BC%E3%83%89%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96(HDD)%3C%2FLI%3E%3CLI%3E2%E3%81%A4%E3%81%AERS-232%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%E3%81%A8DB9%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF(1%E3%81%A4%E3%81%AFDCE%E7%94%A8%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%80%81%E3%82%82%E3%81%861%E3%81%A4%E3%81%AFDTE%E5%8B%95%E4%BD%9C%E7%94%A8%E3%81%AB%E6%A7%8B%E6%88%90)%E3%81%AF%E3%80%81%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97UART%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FLI%3E%3CLI%3ERS-232%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%E3%83%BC%E3%81%A8DB9%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E5%A4%96%E9%83%A8UART%3C%2FLI%3E%3CLI%3EInfrared%20Data%20Association%20%E3%81%AE%20Specification%201.4%20%E3%81%AB%E6%BA%96%E6%8B%A0%E3%81%97%E3%81%9F%E8%B5%A4%E5%A4%96%E7%B7%9A%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%E3%83%BC%3C%2FLI%3E%3CLI%3EUSB%E3%83%9B%E3%82%B9%E3%83%88(HS%26amp%3BFS)%E3%80%81USB%20OTG(HS%26amp%3BHS)%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3C%2FLI%3E%3CLI%3E%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E7%8B%AC%E7%AB%8B%E3%81%97%E3%81%9FLCD%E3%83%91%E3%83%8D%E3%83%AB%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%AA%3C%2FLI%3E%3CLI%3E36%E5%80%8B%E3%81%AE%E3%83%97%E3%83%83%E3%82%B7%E3%83%A5%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%AD%E3%83%BC%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E7%8B%AC%E7%AB%8B%E3%81%97%E3%81%9F%E3%82%AD%E3%83%BC%E3%83%91%E3%83%83%E3%83%89%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%3C%2FLI%3E%3CLI%3E%E3%82%BB%E3%83%91%E3%83%AC%E3%83%BC%E3%83%88CMOS%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%82%AB%E3%83%BC%E3%83%89%3C%2FLI%3E%3CLI%3E3.5%20mm%E3%83%98%E3%83%83%E3%83%89%E3%82%BB%E3%83%83%E3%83%88%E3%82%B8%E3%83%A3%E3%83%83%E3%82%AF%E3%80%813.5%20mm%E3%83%A9%E3%82%A4%E3%83%B3%E5%87%BA%E5%8A%9B%E3%82%B8%E3%83%A3%E3%83%83%E3%82%AF%E3%80%813.5%20mm%E3%83%A9%E3%82%A4%E3%83%B3%E5%85%A5%E5%8A%9B%E3%82%B8%E3%83%A3%E3%83%83%E3%82%AF%E3%80%813.5%20mm%E3%83%9E%E3%82%A4%E3%82%AF%E3%82%B8%E3%83%A3%E3%83%83%E3%82%AF%E3%80%812.5%20mm%E3%83%9E%E3%82%A4%E3%82%AF%E3%81%8A%E3%82%88%E3%81%B3%E3%83%98%E3%83%83%E3%83%89%E3%82%BB%E3%83%83%E3%83%88%E3%82%B8%E3%83%A3%E3%83%83%E3%82%AF%3C%2FLI%3E%3CLI%3ECirrus%20Logic%20CS8900A-CQ3Z%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20(10BASE-T)%E3%80%81RJ-45%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%83%BC%E4%BB%98%E3%81%8D%3C%2FLI%3E%3CLI%3EAMD%20AM79C874%20NetPHY%20(10BASE-T%20%26amp%3B%20100BASE-X)%E3%80%81RJ-45%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E4%BB%98%E3%81%8D%3C%2FLI%3E%3CLI%3E2%E3%81%A4%E3%81%AE32%20%C3%97%203%E3%83%94%E3%83%B3DIN%E6%8B%A1%E5%BC%B5%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF(%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AEi.MX27%20I%2FO%E4%BF%A1%E5%8F%B7%E4%BB%98%E3%81%8D)%3C%2FLI%3E%3CLI%3E%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E9%9B%BB%E5%9C%A7%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E7%94%A8%E3%81%AE%E5%8F%AF%E5%A4%89%E6%8A%B5%E6%8A%97%E5%99%A8%3C%2FLI%3E%3CLI%3EADS%E3%82%AD%E3%83%83%E3%83%88%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8BNAND%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%AB%E3%83%BC%E3%83%89(%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%B7%AE%E3%81%97%E8%BE%BC%E3%82%80)%3C%2FLI%3E%3CLI%3E%E9%9B%BB%E6%BA%90%E3%80%81%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E5%AE%9A%E7%BE%A9%E3%81%AE%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E8%A1%A8%E7%A4%BA%E7%94%A8%E3%81%AE2%E3%81%A4%E3%81%AELED%E3%82%A4%E3%83%B3%E3%82%B8%E3%82%B1%E3%83%BC%E3%82%BF%3C%2FLI%3E%3CLI%3E5%E3%83%9C%E3%83%AB%E3%83%88%E5%87%BA%E5%8A%9B%40%205%E3%82%A2%E3%83%B3%E3%83%9A%E3%82%A2%E3%81%AE%E3%83%A6%E3%83%8B%E3%83%90%E3%83%BC%E3%82%B5%E3%83%AB%E9%9B%BB%E6%BA%90%3C%2FLI%3E%3CLI%3EUSB%E3%80%81RS-232%E3%80%81RJ45%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB(%E3%82%AD%E3%83%83%E3%83%88%E4%BB%98%E5%B1%9E)%3C%2FLI%3E%3C%2FUL%3E%3CH5%20id%3D%22toc-hId--24713471%22%20id%3D%22toc-hId-898863297%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%E3%82%AD%E3%83%83%E3%83%88%E3%81%AE%E5%86%85%E5%AE%B9%3C%2FSPAN%3E%3C%2FH5%3E%3CUL%3E%3CLI%3E%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%3C%2FLI%3E%3CLI%3ELCD%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%91%E3%83%8D%E3%83%AB%3C%2FLI%3E%3CLI%3Ea%20keypad%3C%2FLI%3E%3CLI%3ENAND%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%AB%E3%83%BC%E3%83%89%3C%2FLI%3E%3CLI%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%3C%2FLI%3E%3CLI%3ETV%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AA%E3%81%A9%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E8%BF%BD%E5%8A%A0%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1104809%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX2x%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎08-21-2012 02:59 PM
更新者:
