i.MX21 ADS
i.MX21 ADS
i.MX21 ADS
The i.MX21 Application Development System (MCIMX21ADSE) is a development tool which is designed to run software applications designed for the i.MX21 processor.
Features
  •   i.MX21 Processor
  •   Two clock-source crystals, 32.768 KHz and 26 MHz
  •   Power connector for +5.0-volts in from an external, regulated power supply, an in-line fuse, and a power on/off switch.
  •   Voltage regulators that step down the 5.0-volt input to Vcc (3.0-volts), 2.5-volts, 1.8-volts, and 1.5-volts.
  •   Multi-ICE debug support
  •   Two 8M × 16-bit Burst Flash memory devices, configured as one 32MB, 32-bit device
  •   Two 16M × 16-bit SDRAM devices, configured as one 64MB, 32-bit device
  •   High speed expansion connectors for optional add on cards
  •   Two-board system: modular CPU board plugs into Base board; Base board has connections for LCD display panel and keypad and TV encoder card
  •   Memory mapped expansion I/O
  •   Configuration and user definable DIP switches
  •   SD/MMC memory card connector
  •   Two RS232 transceivers and DB9 connectors (one configured for DCE and one for DTE operation) supporting on-chip UART ports
  •   External UART with RS232 transceiver and DB9 connector
  •   IrDA transceiver that conforms to Specification 1.4 of the Infra-red Data Association
  •   USB OTG (On The Go) interface transceiver and USB mini AB connector
  •   Separate LCD panel assembly with a ribbon cable that connects to the Base board and interfaces directly with the M9328MX21ADS
  •   Touch panel controller for use with the LCD
  •   Separate Keypad unit with 36 push button keys
  •   Separate CMOS Image Sensor Card
  •   Audio CODEC includes an 11.28MHz crystal oscillator, a 3.5mm audio input jack, a 3.5mm microphone jack, and a 3.5mm headphone jack
  •   Cirrus Logic CS8900A Ethernet controller, with RJ-45 connector for connecting to a system hub
  •   Two 32 × 3-pin DIN expansion connectors with most i.MX21 I/O signals
  •   Variable resistor for emulation of a battery voltage level
  •   NAND Flash card (Plugs into CPU)
  •   LED indicators for power, external bus activity, Ethernet activity, and two LEDs for user defined status indiction
  •   Universal power supply with 5.0-volt output @ 2.4A
  •   USB cable
  •   RS232 serial cable
  •   Two RJ-45 Ethernet cables, network and crossover
タグ(2)
%3CLINGO-SUB%20id%3D%22lingo-sub-1104472%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX21%20ADS%E3%81%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104472%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3Ei.MX21%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E9%96%8B%E7%99%BA%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0(MCIMX21ADSE)%E3%81%AF%E3%80%81i.MX21%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E7%94%A8%E3%81%AB%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%9F%E9%96%8B%E7%99%BA%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH5%20id%3D%22toc-hId-1782737358%22%20id%3D%22toc-hId--1595144846%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%E7%89%B9%E9%95%B7%3C%2FSPAN%3E%3C%2FH5%3E%3CUL%3E%3CLI%3Ei.MX21%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FLI%3E%3CLI%3E2%E3%81%A4%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%E6%B0%B4%E6%99%B6%E6%8C%AF%E5%8B%95%E5%AD%90%E3%80%8132.768KHz%E3%81%8A%E3%82%88%E3%81%B326MHz%3C%2FLI%3E%3CLI%3E%E5%A4%96%E9%83%A8%E3%81%AE%E5%AE%89%E5%AE%9A%E5%8C%96%E9%9B%BB%E6%BA%90%E3%80%81%E3%82%A4%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E9%9B%BB%E6%BA%90%E3%82%AA%E3%83%B3%2F%E3%82%AA%E3%83%95%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%8B%E3%82%89%E3%81%AE%2B5.0%E3%83%9C%E3%83%AB%E3%83%88%E5%85%A5%E5%8A%9B%E7%94%A8%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%80%82%3C%2FLI%3E%3CLI%3E5.0%20%E3%83%9C%E3%83%AB%E3%83%88%E3%81%AE%E5%85%A5%E5%8A%9B%E3%82%92%20Vcc%20(3.0%20%E3%83%9C%E3%83%AB%E3%83%88)%E3%80%812.5%20%E3%83%9C%E3%83%AB%E3%83%88%E3%80%811.8%20%E3%83%9C%E3%83%AB%E3%83%88%E3%80%811.5%20%E3%83%9C%E3%83%AB%E3%83%88%E3%81%AB%E9%99%8D%E5%9C%A7%E3%81%99%E3%82%8B%E9%9B%BB%E5%9C%A7%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%80%82%3C%2FLI%3E%3CLI%3EMulti-ICE%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FLI%3E%3CLI%3E2%20%E3%81%A4%E3%81%AE%208M%20%C3%97%2016%20%E3%83%93%E3%83%83%E3%83%88%20%E3%83%90%E3%83%BC%E3%82%B9%E3%83%88%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9(1%20%E3%81%A4%E3%81%AE%2032MB%E3%80%8132%20%E3%83%93%E3%83%83%E3%83%88%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90)%3C%2FLI%3E%3CLI%3E2%20%E3%81%A4%E3%81%AE%2016M%20%C3%97%2016%20%E3%83%93%E3%83%83%E3%83%88%20SDRAM%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%80%811%20%E3%81%A4%E3%81%AE%2064MB%E3%80%8132%20%E3%83%93%E3%83%83%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%3C%2FLI%3E%3CLI%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%82%A2%E3%83%89%E3%82%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AE%E9%AB%98%E9%80%9F%E6%8B%A1%E5%BC%B5%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%3C%2FLI%3E%3CLI%3E2%E3%83%9C%E3%83%BC%E3%83%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3A%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%A9%E3%83%BCCPU%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%83%99%E3%83%BC%E3%82%B9%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%B7%AE%E3%81%97%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%E3%83%99%E3%83%BC%E3%82%B9%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%E3%80%81LCD%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%91%E3%83%8D%E3%83%AB%E3%81%A8%E3%82%AD%E3%83%BC%E3%83%91%E3%83%83%E3%83%89%E3%80%81TV%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%82%AB%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3E%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%9E%E3%83%83%E3%83%97%E3%83%89%E6%8B%A1%E5%BC%B5%20I%2FO%3C%2FLI%3E%3CLI%3E%E6%A7%8B%E6%88%90%E3%81%8A%E3%82%88%E3%81%B3%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E5%AE%9A%E7%BE%A9%E5%8F%AF%E8%83%BD%E3%81%AADIP%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%3C%2FLI%3E%3CLI%3ESD%2FMMC%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%AB%E3%83%BC%E3%83%89%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%3C%2FLI%3E%3CLI%3E2%E3%81%A4%E3%81%AERS232%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%E3%81%A8DB9%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF(1%E3%81%A4%E3%81%AFDCE%E7%94%A8%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%80%81%E3%82%82%E3%81%861%E3%81%A4%E3%81%AFDTE%E5%8B%95%E4%BD%9C%E7%94%A8%E3%81%AB%E6%A7%8B%E6%88%90)%E3%81%AF%E3%80%81%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97UART%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FLI%3E%3CLI%3ERS232%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%E3%83%BC%E3%81%A8DB9%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E5%A4%96%E9%83%A8UART%3C%2FLI%3E%3CLI%3EInfra-red%20Data%20Association%E3%81%AESpecification%201.4%E3%81%AB%E6%BA%96%E6%8B%A0%E3%81%97%E3%81%9FIrDA%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%E3%83%BC%3C%2FLI%3E%3CLI%3EUSB%20OTG(On%20The%20Go)%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%E3%83%BC%E3%81%A8USB%E3%83%9F%E3%83%8BAB%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%3C%2FLI%3E%3CLI%3E%E3%83%99%E3%83%BC%E3%82%B9%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81M9328MX21ADS%E3%81%AB%E7%9B%B4%E6%8E%A5%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%83%AA%E3%83%9C%E3%83%B3%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E7%8B%AC%E7%AB%8B%E3%81%97%E3%81%9FLCD%E3%83%91%E3%83%8D%E3%83%AB%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%AA%3C%2FLI%3E%3CLI%3ELCD%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%BF%E3%83%83%E3%83%81%E3%83%91%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%3C%2FLI%3E%3CLI%3E36%E5%80%8B%E3%81%AE%E3%83%97%E3%83%83%E3%82%B7%E3%83%A5%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%AD%E3%83%BC%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E7%8B%AC%E7%AB%8B%E3%81%97%E3%81%9F%E3%82%AD%E3%83%BC%E3%83%91%E3%83%83%E3%83%89%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%3C%2FLI%3E%3CLI%3E%E3%82%BB%E3%83%91%E3%83%AC%E3%83%BC%E3%83%88CMOS%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%82%AB%E3%83%BC%E3%83%89%3C%2FLI%3E%3CLI%3E%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%81%AB%E3%81%AF%E3%80%8111.28MHz%E6%B0%B4%E6%99%B6%E7%99%BA%E6%8C%AF%E5%99%A8%E3%80%813.5mm%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E5%85%A5%E5%8A%9B%E3%82%B8%E3%83%A3%E3%83%83%E3%82%AF%E3%80%813.5mm%E3%83%9E%E3%82%A4%E3%82%AF%E3%82%B8%E3%83%A3%E3%83%83%E3%82%AF%E3%80%81%E3%81%8A%E3%82%88%E3%81%B33.5mm%E3%83%98%E3%83%83%E3%83%89%E3%83%95%E3%82%A9%E3%83%B3%E3%82%B8%E3%83%A3%E3%83%83%E3%82%AF%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3ECirrus%20Logic%20CS8900A%20Ethernet%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%BB%E3%83%8F%E3%83%96%E6%8E%A5%E7%B6%9A%E7%94%A8RJ-45%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E4%BB%98%E3%81%8D%3C%2FLI%3E%3CLI%3E2%E3%81%A4%E3%81%AE32%20%C3%97%203%E3%83%94%E3%83%B3DIN%E6%8B%A1%E5%BC%B5%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF(%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AEi.MX21%20I%2FO%E4%BF%A1%E5%8F%B7%E4%BB%98%E3%81%8D)%3C%2FLI%3E%3CLI%3E%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E9%9B%BB%E5%9C%A7%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E7%94%A8%E3%81%AE%E5%8F%AF%E5%A4%89%E6%8A%B5%E6%8A%97%E5%99%A8%3C%2FLI%3E%3CLI%3ENAND%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%AB%E3%83%BC%E3%83%89(CPU%E3%81%AB%E5%B7%AE%E3%81%97%E8%BE%BC%E3%82%80)%3C%2FLI%3E%3CLI%3E%E9%9B%BB%E6%BA%90%E3%80%81%E5%A4%96%E9%83%A8%E3%83%90%E3%82%B9%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%E3%80%81%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E5%AE%9A%E7%BE%A9%E3%81%AE%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%A4%E3%83%B3%E3%82%B8%E3%82%B1%E3%83%BC%E3%82%BF%E7%94%A8%E3%81%AE2%E3%81%A4%E3%81%AELED%E3%82%A4%E3%83%B3%E3%82%B8%E3%82%B1%E3%83%BC%E3%82%BF%3C%2FLI%3E%3CLI%3E5.0%E3%83%9C%E3%83%AB%E3%83%88%E5%87%BA%E5%8A%9B%40%202.4A%E3%81%AE%E3%83%A6%E3%83%8B%E3%83%90%E3%83%BC%E3%82%B5%E3%83%AB%E9%9B%BB%E6%BA%90%3C%2FLI%3E%3CLI%3EUSB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%3C%2FLI%3E%3CLI%3ERS232%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%3C%2FLI%3E%3CLI%3ERJ-45%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%202%20%E6%9C%AC%E3%80%81%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%8A%E3%82%88%E3%81%B3%E3%82%AF%E3%83%AD%E3%82%B9%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎07-30-2012 02:54 PM
更新者:
