Useful bitbake commands
NOTE: Please suggest bitbake commands you find it useful!
bitbake command
Description
bitbake <image>Bake an image (add -k to continue building even errors are found in the tasks execution)
bitbake <package> -c <task>
Execute a particular package's task. Default Tasks names: fetch, unpack, patch, configure, compile, install, package, package_write, and build.
Example: To (force) compiling a kernel and then build, type:
$ bitbake  linux-imx -f -c compile
$ bitbake linux-imx
bitbake <image > -g -u depexp
Show the package dependency for image.
Example: To show all packages included on fsl-image-gui
$ bitbake fsl-image-gui -g -u depexp
NOTE: This command will open a UI window, so it must be execute on a console inside the host machine (either virtual or native).
bitbake <package> -c  devshellOpen a new shell where with neccesary system values already defined for package
hobbitbake frontend/GUI.
bitbake <package> -c listtasksList all tasks for package
bitbake virtual/kernel -c menuconfig
Interactive kernel configuration
bitbake <image> -c fetchallFetch sources for a particular image
bitbake-layers show-layersShow layers
bitbake-layers show-recipes "*-image-*"Show possible images to bake. Without "*-images-*", it shows ALL recipes
bitbake -g <image> && cat pn-depends.dot | grep -v -e '-native' | grep -v digraph | grep -v -e '-image' | awk '{print $1}' | sort | uniqShow image's packages
bitbake -g <pkg> && cat pn-depends.dot | grep -v -e '-native' | grep -v digraph | grep -v -e '-image' | awk '{print $1}' | sort | uniqShow package's dependencies
bitbake –v <image> 2>&1 | tee image_build.log Print (on console) and store verbose baking
bitbake -s | grep <pkg>Check if certain package is present on current Yocto Setup
评论
Seems I can't use bitbake-layers with Daisy.  Can you verify this?
Yes, it can be used for sure.
Are you getting an error?
In my case, for example, we have:
otavio@nano ~/hacking/ossystems/yocto/build % bitbake-layers show-layers
layer                 path                                      priority
meta                  /home/otavio/hacking/ossystems/yocto/sources/poky/meta  5
meta-yocto            /home/otavio/hacking/ossystems/yocto/sources/poky/meta-yocto  5
meta-yocto-bsp        /home/otavio/hacking/ossystems/yocto/sources/poky/meta-yocto-bsp  5
meta-oe               /home/otavio/hacking/ossystems/yocto/sources/meta-openembedded/meta-oe  1
meta-fsl-arm          /home/otavio/hacking/ossystems/yocto/sources/meta-fsl-arm  5
meta-fsl-arm-extra    /home/otavio/hacking/ossystems/yocto/sources/meta-fsl-arm-extra  4
meta-fsl-demos        /home/otavio/hacking/ossystems/yocto/sources/meta-fsl-demos  4
meta-qt5              /home/otavio/hacking/ossystems/yocto/sources/meta-qt5  7
meta-ossystems        /home/otavio/hacking/ossystems/yocto/sources/meta-ossystems  9
meta-ossystems-base   /home/otavio/hacking/ossystems/yocto/sources/meta-ossystems-base  8
There is a typo in the penultimate command, it should be "2>&1" instead of "2&>1".
There are even more tasks you can run like: configme, kernel_configcheck, compile_kernelmodules, clean, cleanall, cleansstate etc. I find myself the compile_kernelmodules is very useful for compiling the kernel drivers. You can take the driver and compile outside individually but most of them has lot of dependency, so...
LeonardoSandovalGonzalez‌ bitbake <image> -c fetchall not works for new version yocto, see:FutureMigrationGuide - Yocto Project
          -c fetchall is replaced by --runall=fetch
The bitbake -g command changed since yocto 2.3:
BitBake "-g" Output Changes: The package-depends.dot and pn-depends.dot files as previously generated using the bitbake -g command have been removed. A recipe-depends.dot file is now generated as a collapsed version of task-depends.dot instead.
%3CLINGO-SUB%20id%3D%22lingo-sub-1128559%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%9C%89%E7%94%A8%E7%9A%84%20bitbake%20%E5%91%BD%E4%BB%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128559%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E8%AF%B7%E6%8E%A8%E8%8D%90%E6%82%A8%E8%A7%89%E5%BE%97%E6%9C%89%E7%94%A8%E7%9A%84%20bitbake%20%E5%91%BD%E4%BB%A4%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20class%3D%22jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20width%3A%20100%25%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%202px%3B%22%20valign%3D%22middle%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3Ebitbake%20%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTH%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%202px%3B%22%20valign%3D%22middle%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%E6%8F%8F%E8%BF%B0%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTH%3E%3C%2FTR%3E%3CTR%3E%3CTD%20colspan%3D%221%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CEM%3Ebitbake%20%3CIMAGE%3E%3C%2FIMAGE%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20colspan%3D%221%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%E7%83%98%E7%84%99%3CEM%3E%E9%95%9C%E5%83%8F%3C%2FEM%3E%EF%BC%88%E6%B7%BB%E5%8A%A0%20%3CEM%3E-k%3C%2FEM%3E%20%E4%BB%A5%E5%9C%A8%E4%BB%BB%E5%8A%A1%E6%89%A7%E8%A1%8C%E4%B8%AD%E5%8F%91%E7%8E%B0%E9%94%99%E8%AF%AF%E6%97%B6%E4%B9%9F%E8%83%BD%E7%BB%A7%E7%BB%AD%E6%9E%84%E5%BB%BA%EF%BC%89%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CEM%3Ebitbake%20%3CPACKAGE%3E%20-c%20%3CTASK%3E%3C%2FTASK%3E%3C%2FPACKAGE%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CCODE%20class%3D%22filename%22%3E%E6%89%A7%E8%A1%8C%E7%89%B9%E5%AE%9A%3CEM%3E%E8%BD%AF%E4%BB%B6%E5%8C%85%3C%2FEM%3E%E7%9A%84%3CEM%3E%E4%BB%BB%E5%8A%A1%3C%2FEM%3E%E3%80%82%3C%2FCODE%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CCODE%20class%3D%22filename%22%3E%3C%2FCODE%3E%3C%2FSPAN%3E%3CCODE%20class%3D%22filename%22%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E9%BB%98%E8%AE%A4%E4%BB%BB%E5%8A%A1%E5%90%8D%E7%A7%B0%EF%BC%9A%3C%2FCODE%3E%3CCODE%20class%3D%22filename%22%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CEM%3E%E6%8F%90%E5%8F%96%E3%80%81%3C%2FEM%3E%3C%2FCODE%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CEM%3E%3CCODE%20class%3D%22filename%22%3E%E8%A7%A3%E5%8E%8B%E7%BC%A9%3C%2FCODE%3E%3C%2FEM%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CEM%3E%3CCODE%20class%3D%22filename%22%3E%E4%BF%AE%E8%A1%A5%3C%2FCODE%3E%3C%2FEM%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CEM%3E%3CCODE%20class%3D%22filename%22%3E%E9%85%8D%E7%BD%AE%3C%2FCODE%3E%3C%2FEM%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CEM%3E%3CCODE%20class%3D%22filename%22%3E%E7%BC%96%E8%AF%91%3C%2FCODE%3E%3C%2FEM%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CEM%3E%3CCODE%20class%3D%22filename%22%3E%E5%AE%89%E8%A3%85%3C%2FCODE%3E%3C%2FEM%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CEM%3E%3CCODE%20class%3D%22filename%22%3E%E8%BD%AF%E4%BB%B6%E5%8C%85%3C%2FCODE%3E%3C%2FEM%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CEM%3E%3CCODE%20class%3D%22filename%22%3Epackage_write%3C%2FCODE%3E%3C%2FEM%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%EF%BC%8C%E5%92%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CEM%3E%3CCODE%20class%3D%22filename%22%3E%E6%9E%84%E5%BB%BA%E3%80%82%3C%2FCODE%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CEM%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CEM%3E%E7%A4%BA%E4%BE%8B%EF%BC%9A%3C%2FEM%3E%E8%A6%81%EF%BC%88%E5%BC%BA%E5%88%B6%EF%BC%89%E7%BC%96%E8%AF%91%E5%86%85%E6%A0%B8%E7%84%B6%E5%90%8E%E8%BF%9B%E8%A1%8C%E6%9E%84%E5%BB%BA%EF%BC%8C%E8%AF%B7%E8%BE%93%E5%85%A5%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CEM%3E%24%20bitbake%26nbsp%3B%20%3C%2FEM%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CEM%3Elinux-imx%20%3C%2FEM%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CEM%3E-f%20-c%20compile%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CEM%3E%24%20bitbake%20linux-imx%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CEM%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3Ebitbake%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CIMAGE%3E%20%3C%2FIMAGE%3E%3C%2FSPAN%3E%3C%2FEM%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CEM%3E-g%20-u%20depexp%3C%2FEM%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%E6%98%BE%E7%A4%BA%3CEM%3E%E9%95%9C%E5%83%8F%3C%2FEM%3E%E7%9A%84%E5%8C%85%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%E7%A4%BA%E4%BE%8B%EF%BC%9A%E6%98%BE%E7%A4%BA%20fsl-image-gui%20%E4%B8%AD%E5%8C%85%E5%90%AB%E7%9A%84%E6%89%80%E6%9C%89%E8%BD%AF%E4%BB%B6%E5%8C%85%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%24%20bitbake%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3Efsl-image-gui%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E-g%20-u%20depexp%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%AD%A4%E5%91%BD%E4%BB%A4%E5%B0%86%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E7%94%A8%E6%88%B7%E7%95%8C%E9%9D%A2%E7%AA%97%E5%8F%A3%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%BF%85%E9%A1%BB%E5%9C%A8%E4%B8%BB%E6%9C%BA%EF%BC%88%E8%99%9A%E6%8B%9F%E6%88%96%E5%8E%9F%E7%94%9F%EF%BC%89%E7%9A%84%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%B8%AD%E6%89%A7%E8%A1%8C%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CEM%3Ebitbake%20%3CPACKAGE%3E%20-c%20devshell%3C%2FPACKAGE%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%20shell%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%B7%B2%E7%BB%8F%E4%B8%BA%3CEM%3E%E5%8C%85%3C%2FEM%3E%E5%AE%9A%E4%B9%89%E4%BA%86%E5%BF%85%E8%A6%81%E7%9A%84%E7%B3%BB%E7%BB%9F%E5%80%BC%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CEM%3Ehob%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3Ebitbake%20%E5%89%8D%E7%AB%AF%2FGUI%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CEM%3Ebitbake%20%3CPACKAGE%3E%20-c%20listtasks%3C%2FPACKAGE%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%E5%88%97%E5%87%BA%3CEM%3E%E5%8C%85%3C%2FEM%3E%E7%9A%84%E6%89%80%E6%9C%89%E4%BB%BB%E5%8A%A1%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CEM%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3Ebitbake%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3Evirtual%2Fkernel%20%3C%2FSPAN%3E%3C%2FEM%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CEM%3E-c%20menuconfig%3C%2FEM%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%E4%BA%A4%E4%BA%92%E5%BC%8F%E5%86%85%E6%A0%B8%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3Ebitbake%20%3CIMAGE%3E%20-c%20fetchall%3C%2FIMAGE%3E%3C%2FTD%3E%3CTD%3E%E8%8E%B7%E5%8F%96%E7%89%B9%E5%AE%9A%3CEM%3Eimage%3C%2FEM%3E%E7%9A%84%E6%9D%A5%E6%BA%90%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3Ebitbake-layers%20show-layers%3C%2FTD%3E%3CTD%3E%E6%98%BE%E7%A4%BA%E5%9B%BE%E5%B1%82%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3Ebitbake-layers%20show-recipes%20%22*-image-*%22%3C%2FTD%3E%3CTD%3E%E6%98%BE%E7%A4%BA%E5%8F%AF%E8%83%BD%E7%94%A8%E4%BA%8E%E7%83%98%E7%84%99%E7%9A%84%E5%9B%BE%E5%83%8F%E3%80%82%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%E2%80%9C*-images-*%E2%80%9D%EF%BC%8C%E5%88%99%E4%BC%9A%E6%98%BE%E7%A4%BA%E6%89%80%E6%9C%89%E9%A3%9F%E8%B0%B1%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3Ebitbake%20-g%20%26lt%3B%3CEM%3Eimage%26gt%3B%3C%2FEM%3E%20%26amp%3B%26amp%3B%20cat%20pn-depends.dot%20%7C%20grep%20-v%20-e%20'-native'%20%7C%20grep%20-v%20digraph%20%7C%20grep%20-v%20-e%20'-image'%20%7C%20awk%20'%7Bprint%20%241%7D'%20%7C%20sort%20%7C%20uniq%3C%2FTD%3E%3CTD%3E%E6%98%BE%E7%A4%BA%3CEM%3E%E5%9B%BE%E5%83%8F%3C%2FEM%3E%E7%9A%84%E5%8C%85%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3Ebitbake%20-g%20%26lt%3B%3CEM%3Epkg%26gt%3B%3C%2FEM%3E%20%26amp%3B%26amp%3B%20cat%20pn-depends.dot%20%7C%20grep%20-v%20-e%20'-native'%20%7C%20grep%20-v%20digraph%20%7C%20grep%20-v%20-e%20'-image'%20%7C%20awk%20'%7Bprint%20%241%7D'%20%7C%20sort%20%7C%20uniq%3C%2FTD%3E%3CTD%3E%E6%98%BE%E7%A4%BA%20%3CEM%3Epackage%3C%2FEM%3E%20%E7%9A%84%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Helvetica%3B%20color%3A%20black%3B%22%3Ebitbake%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Helvetica%3B%20color%3A%20black%3B%22%3E%20%E2%80%93v%20%3CEM%3E%3CIMAGE%3E%3C%2FIMAGE%3E%3C%2FEM%3E%202%26gt%3B%26amp%3B1%20%7C%20tee%20%3CEM%3Eimage_%3C%2FEM%3Ebuild.log%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%EF%BC%88%E5%9C%A8%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%B8%8A%EF%BC%89%E6%89%93%E5%8D%B0%E5%B9%B6%E5%AD%98%E5%82%A8%E8%AF%A6%E7%BB%86%E7%9A%84%E7%83%98%E7%84%99%E4%BF%A1%E6%81%AF%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3Ebitbake%20-s%20%7C%20grep%20%3CEM%3E%3CPKG%3E%3C%2FPKG%3E%3C%2FEM%3E%3C%2FTD%3E%3CTD%3E%E6%A3%80%E6%9F%A5%E5%BD%93%E5%89%8D%20Yocto%20%E8%AE%BE%E7%BD%AE%E4%B8%AD%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E7%89%B9%E5%AE%9A%3CEM%3E%E5%8C%85%3C%2FEM%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1128559%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128564%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9C%89%E7%94%A8%E7%9A%84%20bitbake%20%E5%91%BD%E4%BB%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128564%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FLeonardoSandovalGonzalez%22%20target%3D%22_blank%22%3ELeonardoSandovalGonzalez%3C%2FA%3E%E2%80%8C%26nbsp%3B%3CEM%3Ebitbake%3CIMAGE%3E%20-c%20fetchall%3C%2FIMAGE%3E%3C%2FEM%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%20%E5%9C%A8%E6%96%B0%E7%89%88%E6%9C%AC%E7%9A%84%20Yocto%20%E4%B8%AD%E6%97%A0%E6%B3%95%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%EF%BC%9A%3CSTRONG%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fwiki.yoctoproject.org%2Fwiki%2FFutureMigrationGuide%22%20title%3D%22https%3A%2F%2Fwiki.yoctoproject.org%2Fwiki%2FFutureMigrationGuide%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EFutureMigrationGuide%20-%20Yocto%20Project%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3CEM%3E%20-c%20fetchall%3C%2FEM%3E%20%E5%B7%B2%E8%A2%AB%20%3CEM%3E--runall%3Dfetch%3C%2FEM%3E%26nbsp%3B%E5%8F%96%E4%BB%A3%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Ebitbake%20-g%20%E5%91%BD%E4%BB%A4%E8%87%AA%20Yocto%202.3%20%E8%B5%B7%E5%8F%91%E7%94%9F%E4%BA%86%E5%8F%98%E5%8C%96%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3EBitBake%E2%80%9C-g%E2%80%9D%E8%BE%93%E5%87%BA%E6%9B%B4%E6%94%B9%EF%BC%9A%E4%B9%8B%E5%89%8D%E4%BD%BF%E7%94%A8%20bitbake%20-g%20%E5%91%BD%E4%BB%A4%E7%94%9F%E6%88%90%E7%9A%84%20package-depends.dot%20%E5%92%8C%20pn-depends.dot%20%E6%96%87%E4%BB%B6%E5%B7%B2%E8%A2%AB%E5%88%A0%E9%99%A4%E3%80%82%E7%8E%B0%E5%9C%A8%EF%BC%8Crecipe-depends.dot%20%E6%96%87%E4%BB%B6%E4%BC%9A%E4%BD%9C%E4%B8%BA%20task-depends.dot%20%E7%9A%84%E6%8A%98%E5%8F%A0%E7%89%88%E6%9C%AC%E7%94%9F%E6%88%90%E3%80%82%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9C%89%E7%94%A8%E7%9A%84%20bitbake%20%E5%91%BD%E4%BB%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E8%BF%98%E5%8F%AF%E4%BB%A5%E8%BF%90%E8%A1%8C%E6%9B%B4%E5%A4%9A%E4%BB%BB%E5%8A%A1%EF%BC%8C%E4%BE%8B%E5%A6%82%EF%BC%9Aconfigme%E3%80%81kernel_configcheck%E3%80%81compile_kernelmodules%E3%80%81clean%E3%80%81cleanall%E3%80%81cleansstate%20%E7%AD%89%E3%80%82%E6%88%91%E5%8F%91%E7%8E%B0%20compile_kernelmodules%20%E5%AF%B9%E4%BA%8E%E7%BC%96%E8%AF%91%E5%86%85%E6%A0%B8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%9D%9E%E5%B8%B8%E6%9C%89%E7%94%A8%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8D%95%E7%8B%AC%E6%8F%90%E5%8F%96%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B9%B6%E8%BF%9B%E8%A1%8C%E7%BC%96%E8%AF%91%EF%BC%8C%E4%BD%86%E5%A4%A7%E5%A4%9A%E6%95%B0%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%9C%89%E5%BE%88%E5%A4%9A%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%EF%BC%8C%E6%89%80%E4%BB%A5%E2%80%A6%E2%80%A6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128562%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9C%89%E7%94%A8%E7%9A%84%20bitbake%20%E5%91%BD%E4%BB%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128562%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%80%92%E6%95%B0%E7%AC%AC%E4%BA%8C%E6%9D%A1%E5%91%BD%E4%BB%A4%E6%9C%89%E6%8B%BC%E5%86%99%E9%94%99%E8%AF%AF%EF%BC%8C%E5%BA%94%E8%AF%A5%E6%98%AF%E2%80%9C2%26gt%3B%26amp%3B1%E2%80%9D%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E2%80%9C2%26amp%3B%26gt%3B1%E2%80%9D%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9C%89%E7%94%A8%E7%9A%84%20bitbake%20%E5%91%BD%E4%BB%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%82%A8%E8%82%AF%E5%AE%9A%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E9%81%87%E5%88%B0%E9%94%99%E8%AF%AF%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B0%B1%E6%88%91%E7%9A%84%E6%83%85%E5%86%B5%E8%80%8C%E8%A8%80%EF%BC%8C%E6%88%91%E4%BB%AC%E6%9C%89%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Eotavio%40nano%20~%2Fhacking%2Fossystems%2Fyocto%2Fbuild%20%25%20bitbake-layers%20show-layers%3C%2FP%3E%0A%3CP%3E%E5%B1%82%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E8%B7%AF%E5%BE%84%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E4%BC%98%E5%85%88%E7%BA%A7%3C%2FP%3E%0A%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%0A%3CP%3Emeta%20%2Fhome%2Fotavio%2Fhacking%2Fossystems%2Fyocto%2Fsources%2Fpoky%2Fmeta%205%3C%2FP%3E%0A%3CP%3Emeta-yocto%20%2Fhome%2Fotavio%2Fhacking%2Fossystems%2Fyocto%2Fsources%2Fpoky%2Fmeta-yocto%205%3C%2FP%3E%0A%3CP%3Emeta-yocto-bsp%20%2Fhome%2Fotavio%2Fhacking%2Fossystems%2Fyocto%2Fsources%2Fpoky%2Fmeta-yocto-bsp%205%3C%2FP%3E%0A%3CP%3Emeta-oe%20%2Fhome%2Fotavio%2Fhacking%2Fossystems%2Fyocto%2Fsources%2Fmeta-openembedded%2Fmeta-oe%201%3C%2FP%3E%0A%3CP%3Emeta-fsl-arm%20%2Fhome%2Fotavio%2Fhacking%2Fossystems%2Fyocto%2Fsources%2Fmeta-fsl-arm%205%3C%2FP%3E%0A%3CP%3Emeta-fsl-arm-extra%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2Fhome%2Fotavio%2Fhacking%2Fossystems%2Fyocto%2Fsources%2Fmeta-fsl-arm-extra%26nbsp%3B%204%3C%2FP%3E%0A%3CP%3Emeta-fsl-demos%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2Fhome%2Fotavio%2Fhacking%2Fossystems%2Fyocto%2Fsources%2Fmeta-fsl-demos%26nbsp%3B%204%3C%2FP%3E%0A%3CP%3Emeta-qt5%20%2Fhome%2Fotavio%2Fhacking%2Fossystems%2Fyocto%2Fsources%2Fmeta-qt5%207%3C%2FP%3E%0A%3CP%3Emeta-ossystems%20%2Fhome%2Fotavio%2Fhacking%2Fossystems%2Fyocto%2Fsources%2Fmeta-ossystems%209%3C%2FP%3E%0A%3CP%3Emeta-ossystems-base%20%2Fhome%2Fotavio%2Fhacking%2Fossystems%2Fyocto%2Fsources%2Fmeta-ossystems-base%208%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128560%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9C%89%E7%94%A8%E7%9A%84%20bitbake%20%E5%91%BD%E4%BB%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128560%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BC%BC%E4%B9%8E%E6%88%91%E6%97%A0%E6%B3%95%E5%B0%86%20bitbake-layers%20%E4%B8%8E%20Daisy%20%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%E3%80%82%E6%82%A8%E8%83%BD%E7%A1%AE%E8%AE%A4%E4%B8%80%E4%B8%8B%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
100% 有帮助 (1/1)
版本历史
最后更新:
‎06-07-2013 10:55 AM
更新人:
