Test Digital Zoom of Camera Preview
Test digital zoom with ipu for camera preview.
Board :sarbre-sd (imx6dq)
BSP   : android 13.4ga
In the above flow, one frame buffer is processed in four steps at camera preview.
Add the step to change the frame buffer before step 4 , the added step which  zoom one preview frame.
The figure below shows the crop function of ipu lib, we use this function scale the frame.
Test result:
preview zoom levle 0:
preview zoom level max:
When taking pictures with 5M pixels and the zoom is over level 1, the picture size is not 2592x1944 but 2016x1512.
The underlying reason for it is that ipu crop function only supports the 2048x2048 maximum output .
Thumbnails of test result :
ラベル(3)
タグ(2)
添付
コメント
hi:
       I am doing the work of digital zoom   on  the  imx6q board  using ov5640   , can you give me some help?
      The IPU driver should changed?How to modify to implent the digital zoom function?
     I have attached patch, it's for older version android.  You could see it to learn the way of zooming.
HI weiping.Liu:
thank you very much!
you mean i should deal the zoom function before the frame data
transfer to the display framebuffer?
hi  weiping liu:
    We now use the  imx6q-sabresd board(android4.4.2, the kernel version 3.0.35)。
   have you implemented digital zoom on this?
    我们现在用的是android4.4.2,imx6q-sabresd 板子,内核版本是3.0.35,请问,你在这上面实现过数码对焦吗?
  我们现在用的是android4.4.2,imx6q-sabresd 板子,内核版本是3.0.35,请问,你在这上面实现过数码变焦吗?
Hello Weiping Liu,
I am also implementing the same on the Sabresd board on the android lollipop , I am able to port changes as suggested , but have a issue with the 5MP i.e 2592*1944 frame , As you suggested I changed the frame size of the the output at the IPU  cropping level , but when the same comes to the JPEG , the Image is not storing properly, it is saved as a green color frame(picture). I Think that the code is failing at the  encoding section , ya here too I implemented the changes, with that too it fails. Wondering waht more changes may be required to implement the digital zoom correctly, can you help me on this ? . With other resolutions the zoom works fine.
All the changes I have mde is at the  HAL level.
The camera That I am using is ov5640_mipi.
Karan
Karan,  Is the  frame of 5Mp normal in preview after IPU cropping? If the copped frame is ok when in preview , i think the issue may be caused by  error format or length input for encoding function.
Hello Weiping Liu,
Yes the length was in correct. I have resolved it . But I have another question,  does the same implementation work with respect to video ? for me the buffers are missing and recording is like 1 frame without zoom and another frame with zoom , its not proper.
Can you please suggest ?
Karan
Hello karan bhagoji:
    Do you have realization
    Do you have realization digital zoom on android5.0? Would you like to share your changes on source code。
    Did you make changes only in the Hal layer?I refer to code_only_preview.zip  to modify,but it does‘t work。
%3CLINGO-SUB%20id%3D%22lingo-sub-1108727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%97%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E3%81%AE%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%82%BA%E3%83%BC%E3%83%A0%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%97%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E7%94%A8%E3%81%AEIPU%E3%81%A7%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%82%BA%E3%83%BC%E3%83%A0%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EBoard%20%3Asarbre-sd%20(imx6dq)%3CBR%20%2F%3EBSP%26nbsp%3B%26nbsp%3B%20%3A%20android%2013.4ga%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222871_2871.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222871_2871.png%22%20style%3D%22width%3A%20505px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117524i49F54F86531CF397%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222871_2871.png%22%20alt%3D%222871_2871.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22flow1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22flow1.png%22%20style%3D%22width%3A%20505px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F79754iE39148C77409035A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22flow1.png%22%20alt%3D%22flow1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%95%E3%83%AD%E3%83%BC%E3%81%A7%E3%81%AF%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%97%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E3%81%A71%E3%81%A4%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%8C4%E3%81%A4%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%A7%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%974%E3%81%AE%E5%89%8D%E3%81%AB%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81%E3%83%97%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%82%921%E3%81%A4%E3%82%BA%E3%83%BC%E3%83%A0%E3%81%99%E3%82%8B%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E4%B8%8B%E3%81%AE%E5%9B%B3%E3%81%AFipu%20lib%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%83%97%E6%A9%9F%E8%83%BD%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%82%92%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222872_2872.bmp%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222872_2872.bmp%22%20style%3D%22width%3A%20556px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117525iCD512D73A78E9A94%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222872_2872.bmp%22%20alt%3D%222872_2872.bmp%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22corp.bmp%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22corp.bmp%22%20style%3D%22width%3A%20556px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F137i157517A4C7E80712%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22corp.bmp%22%20alt%3D%22corp.bmp%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E7%B5%90%E6%9E%9C%3A%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BA%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%99%E3%83%AB0%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222873_2873.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222873_2873.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117526iAC579495DDB2BDA1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222873_2873.jpg%22%20alt%3D%222873_2873.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22p0.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22p0.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F58048i4AF8011AC6D77DF2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22p0.jpg%22%20alt%3D%22p0.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BA%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%99%E3%83%AB%E6%9C%80%E5%A4%A7%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222874_2874.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222874_2874.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117527i04041C0F9AA0F241%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222874_2874.jpg%22%20alt%3D%222874_2874.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22p10.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22p10.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F38227iAFFA6977A77BF73D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22p10.jpg%22%20alt%3D%22p10.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E5M%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%81%A7%E5%86%99%E7%9C%9F%E3%82%92%E6%92%AE%E3%82%8A%E3%80%81%E3%82%BA%E3%83%BC%E3%83%A0%E3%81%8C%E3%83%AC%E3%83%99%E3%83%AB1%E3%82%92%E8%B6%85%E3%81%88%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E7%94%BB%E5%83%8F%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF2592x1944%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F2016x1512%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E6%A0%B9%E6%9C%AC%E7%9A%84%E3%81%AA%E7%90%86%E7%94%B1%E3%81%AF%E3%80%81ipu%E3%82%AF%E3%83%AD%E3%83%83%E3%83%97%E6%A9%9F%E8%83%BD%E3%81%8C2048x2048%E3%81%AE%E6%9C%80%E5%A4%A7%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%8B%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22sent_en%22%3E%E3%83%86%E3%82%B9%E3%83%88%E7%B5%90%E6%9E%9C%E3%81%AE%E3%82%B5%E3%83%A0%E3%83%8D%E3%82%A4%E3%83%AB%20%3C%2FSPAN%3E%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222875_2875.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222875_2875.png%22%20style%3D%22width%3A%20344px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117528iA7FF044E52D11FFB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222875_2875.png%22%20alt%3D%222875_2875.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22picx2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22picx2.png%22%20style%3D%22width%3A%20344px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F10794i944F0C0E98A864DA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22picx2.png%22%20alt%3D%22picx2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1108727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%97%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E3%81%AE%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%82%BA%E3%83%BC%E3%83%A0%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EHello%26nbsp%3B%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%22-1%22%20data-containertype%3D%22-1%22%20data-objectid%3D%22280084%22%20data-objecttype%3D%223%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fkaranbhagoji%22%20style%3D%22color%3A%20%235e89c1%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20padding%3A%201px%200px%201px%20calc(12px%20%2B%200.35ex)%3B%22%20target%3D%22_blank%22%3Ekaran%20bhagoji%3C%2FA%3E%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%3Eandroid5.0%E3%81%A7%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%82%BA%E3%83%BC%E3%83%A0%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3F%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%E3%83%8F%E3%83%AB%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AE%E3%81%BF%E3%81%AB%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8Bcode_only_preview.zip%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%97%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E3%81%AE%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%82%BA%E3%83%BC%E3%83%A0%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%26nbsp%3B%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%22280084%22%20data-username%3D%22karanbhagoji%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fkaranbhagoji%22%20style%3D%22color%3A%20%235e89c1%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20font-size%3A%201.286rem%3B%22%20target%3D%22_blank%22%3Ekaran%20bhagoji%3C%2FA%3E%EF%BC%9A%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E6%B0%97%E3%81%A5%E3%81%8D%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108735%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%97%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E3%81%AE%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%82%BA%E3%83%BC%E3%83%A0%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108735%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81Weiping%20Liu%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E9%95%B7%E3%81%95%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF%E5%88%A5%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E5%90%8C%E3%81%98%E5%AE%9F%E8%A3%85%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%E7%A7%81%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%AF%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%8C%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E9%8C%B2%E7%94%BB%E3%81%AF%E3%82%BA%E3%83%BC%E3%83%A0%E3%81%AA%E3%81%97%E3%81%AE1%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%A8%E3%82%BA%E3%83%BC%E3%83%A0%E4%BB%98%E3%81%8D%E3%81%AE%E5%88%A5%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%82%E3%81%AE%E3%81%A7%E3%80%81%E9%81%A9%E5%88%87%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E6%8F%90%E6%A1%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EKaran%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108734%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%97%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E3%81%AE%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%82%BA%E3%83%BC%E3%83%A0%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108734%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%AB%E3%83%A9%E3%83%B3%E3%80%81IPU%E3%82%AF%E3%83%AD%E3%83%83%E3%83%97%E5%BE%8C%E3%81%AE%E3%83%97%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E3%81%A7%E3%81%AF5Mp%20%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%83%97%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E6%99%82%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E6%A9%9F%E8%83%BD%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E5%BD%A2%E5%BC%8F%E3%81%BE%E3%81%9F%E3%81%AF%E9%95%B7%E3%81%95%E5%85%A5%E5%8A%9B%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%97%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E3%81%AE%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%82%BA%E3%83%BC%E3%83%A0%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CSPAN%20class%3D%22%22%3E%3CA%20_jive_internal%3D%22true%22%20class%3D%22%22%20data-content-finding%3D%22Community%22%20data-userid%3D%22200920%22%20data-username%3D%22weiping.Liu%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fweiping.Liu%22%20target%3D%22_blank%22%3EWeiping%20Liu%3C%2FA%3E%3C%2FSPAN%3E%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%82%82Android%E3%81%AE%E3%83%AD%E3%83%AA%E3%83%9D%E3%83%83%E3%83%97%E3%81%AESabresd%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%90%8C%E3%81%98%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%E7%A7%81%E3%81%AF%E6%8F%90%E6%A1%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%82%92%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%815MP%E3%81%99%E3%81%AA%E3%82%8F%E3%81%A12592%20*%201944%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E6%8F%90%E6%A1%88%E3%81%97%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AFIPU%E3%82%AF%E3%83%AD%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%83%AC%E3%83%99%E3%83%AB%E3%81%A7%E5%87%BA%E5%8A%9B%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%90%8C%E3%81%98JPEG%E3%81%AB%E6%9D%A5%E3%82%8B%E3%81%A8%E3%80%81%20%E7%94%BB%E5%83%8F%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E7%B7%91%E8%89%B2%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0(%E7%94%BB%E5%83%8F)%E3%81%A8%E3%81%97%E3%81%A6%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%E3%82%82%E5%A4%89%E6%9B%B4%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%82%82%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%82%BA%E3%83%BC%E3%83%A0%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%95%E3%82%89%E3%81%AB%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%A4%89%E6%9B%B4%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%8B%E7%96%91%E5%95%8F%E3%81%AB%E6%80%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E7%A7%81%E3%82%92%E5%8A%A9%E3%81%91%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%20%E3%80%82%E4%BB%96%E3%81%AE%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%81%A7%E3%81%AF%E3%80%81%E3%82%BA%E3%83%BC%E3%83%A0%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AFHAL%E3%83%AC%E3%83%99%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AFov5640_mipi%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EKaran%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108732%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Test%20Digital%20Zoom%20of%20Camera%20Preview%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108732%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81Android%204.4.2%E3%80%81imx6q-sabresd%E3%83%9C%E3%83%BC%E3%83%89%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B33.0.35%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%82%BA%E3%83%BC%E3%83%A0%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%97%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E3%81%AE%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%82%BA%E3%83%BC%E3%83%A0%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%26nbsp%3B%20weiping%20liu%EF%BC%9A%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%81%AF%20imx6q-sabresd%20%E3%83%9C%E3%83%BC%E3%83%89%20(android4.4.2%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.35)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%82%BA%E3%83%BC%E3%83%A0%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E6%88%91%E4%BB%AC%E7%8E%B0%E5%9C%A8%E7%94%A8%E7%9A%84%E6%98%AFandroid4.4.2%EF%BC%8Cimx6q-sabresd%20%E6%9D%BF%E5%AD%90%EF%BC%8C%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%E6%98%AF3.0.35%EF%BC%8C%E8%AF%B7%E9%97%AE%EF%BC%8C%E4%BD%A0%E5%9C%A8%E8%BF%99%E4%B8%8A%E9%9D%A2%E5%AE%9E%E7%8E%B0%E8%BF%87%E6%95%B0%E7%A0%81%E5%AF%B9%E7%84%A6%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%97%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E3%81%AE%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%82%BA%E3%83%BC%E3%83%A0%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81weiping%E3%80%82%E5%8A%89%EF%BC%9A%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E5%89%8D%E3%81%AB%E3%82%BA%E3%83%BC%E3%83%A0%E6%A9%9F%E8%83%BD%E3%82%92%E6%89%B1%E3%81%86%E3%81%B9%E3%81%8D%E3%81%A0%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%AD%20%3C%2FP%3E%3CP%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AB%E8%BB%A2%E9%80%81%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%97%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E3%81%AE%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%82%BA%E3%83%BC%E3%83%A0%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%26nbsp%3B%20%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E5%8F%A4%E3%81%84%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AEAndroid%E7%94%A8%E3%81%A7%E3%81%99%E3%80%82%E3%82%BA%E3%83%BC%E3%83%A0%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E5%AD%A6%E3%81%B6%E3%81%9F%E3%82%81%E3%81%AB%E3%81%9D%E3%82%8C%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%97%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E3%81%AE%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%82%BA%E3%83%BC%E3%83%A0%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%3A%3C%2FP%3E%3CP%20class%3D%22textarea-wrap%22%20style%3D%22padding-bottom%3A%2012px%3B%22%3E%E7%A7%81%E3%81%AFov5640%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6imx6q%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%82%BA%E3%83%BC%E3%83%A0%E3%81%AE%E4%BD%9C%E6%A5%AD%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%BD%95%E3%81%8B%E5%8A%A9%E3%81%91%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%20class%3D%22textarea-wrap%22%20style%3D%22padding-bottom%3A%2012px%3B%22%3EIPU%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%82%BA%E3%83%BC%E3%83%A0%E6%A9%9F%E8%83%BD%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%20class%3D%22textarea-wrap%22%20style%3D%22padding-bottom%3A%2012px%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20class%3D%22textarea-wrap%22%20style%3D%22padding-bottom%3A%2012px%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22ordinary-output%20target-output%20clearfix%22%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎11-23-2012 02:21 AM
更新者:
