Q&A: How to make 16bit DDR + OpenGL/OpenVG working on imx6 solo?
Q:
Can OpenGL/OpenVG work on any of our boards with a 16-bit DDR bus?
Here is GPU state dump when run some of the GPU SDK tutorials on their imx6 solo board with a 16-bit DDR bus:
Mounting rootfs
VFS: Mounted root (nfs filesystem) readonly on device 0:12.
Freeing init memory: 156K
Starting init
GPU[0]:
***   GPU STATE DUMP   ***
  axi      = 0x000000B1
  idle     = 0x7FFFFF86
    FE not idle
    SH not idle
    PA not idle
    SE not idle
    RA not idle
  DMA appears to be stuck at this address:
    0x1882F230
  dmaLow   = 0x08010583
  dmaHigh  = 0x80003400
  dmaState = 0x00000904
    command state       = 4 (PAR_ADR1_ST)
    command DMA state   = 1 (CMD_START_ST)
    command fetch state = 2 (FET_VALID_ST)
    DMA request state   = 0 (REQ_IDLE_ST)
    cal state           = 0 (CAL_IDLE_ST)
    VE request state    = 0 (VER_IDLE_ST)
  RA debug registers:
    [0x00] 0x0108C378
    [0x01] 0x0042FB12
    [0x02] 0x0042FB11
    [0x03] 0x0000022C
    [0x04] 0x10220033
    [0x05] 0x0885C800
    [0x06] 0xC054CBFE
    [0x07] 0x68100000
    [0x08] 0x00000000
    [0x09] 0x00000000
    [0x0A] 0x00000000
    [0x0B] 0x00000000
    [0x0C] 0x12344321
    [0x0D] 0x12344321
    [0x0E] 0x12344321
    [0x0F] 0x12344321
    signature = 0x12344321 (1 read attempt(s))
  TX debug registers:
    [0x00] 0x00000000
    [0x01] 0x00000000
    [0x02] 0x00000000
    [0x03] 0x00000000
    [0x04] 0x00000000
    [0x05] 0x00000000
    [0x06] 0x00000000
    [0x07] 0x00000000
    [0x08] 0x00000000
    [0x09] 0x00000000
    [0x0A] 0x00000000
    [0x0B] 0x00000000
    [0x0C] 0x00000000
    [0x0D] 0x00000000
    [0x0E] 0x00000000
    [0x0F] 0x00000000
    failed to obtain the signature (read 0x00000000).
  FE debug registers:
    [0x00] 0x1882F450
    [0x01] 0x08010594
    [0x02] 0x00000001
    [0x03] 0x00000256
    [0x04] 0x00080049
    [0x05] 0x0000000D
    [0x06] 0x00009571
    [0x07] 0x00007445
    [0x08] 0x00000004
    [0x09] 0x00000000
    [0x0A] 0x00000000
    [0x0B] 0x00000000
    [0x0C] 0x00000000
    [0x0D] 0xA3105D67
    [0x0E] 0x000000D0
    [0x0F] 0xBABEF00D
    signature = 0xBABEF00D (1 read attempt(s))
  PE debug registers:
    [0x00] 0x0108C369
    [0x01] 0x00000000
    [0x02] 0x0108C369
    [0x03] 0x00000000
    [0x04] 0xA0000000
    [0x05] 0xABC00000
    [0x06] 0xBC000000
    [0x07] 0xCDE00000
    [0x08] 0xD04045C0
    [0x09] 0x204045C0
    [0x0A] 0x0D863084
    [0x0B] 0x00000000
    [0x0C] 0xBABEF00D
    [0x0D] 0xBABEF00D
    [0x0E] 0xBABEF00D
    [0x0F] 0xBABEF00D
  DE debug registers:
    [0x00] 0x00000000
    [0x01] 0x00000000
    [0x02] 0x00000000
    [0x03] 0x00000000
    [0x04] 0x00000000
    [0x05] 0x00000000
    [0x06] 0x00000000
    [0x07] 0x00000000
    [0x08] 0x00000000
    [0x09] 0x00000000
    [0x0A] 0x00000000
    [0x0B] 0x00000000
    [0x0C] 0x00000000
    [0x0D] 0x00000000
    [0x0E] 0x00000000
    [0x0F] 0x00000000
  SH debug registers:
    [0x00] 0x0049AB4C
    [0x01] 0x0000000B
    [0x02] 0x00000411
    [0x03] 0x00020A95
    [0x04] 0x00000000
    [0x05] 0x000F024E
    [0x06] 0x000F424C
    [0x07] 0x010BEC30
    [0x08] 0x0108C368
    [0x09] 0x000020DF
    [0x0A] 0x00000693
    [0x0B] 0x00000000
    [0x0C] 0x00000000
    [0x0D] 0x00000000
    [0x0E] 0x00000000
    [0x0F] 0xDEADBEEF
    signature = 0xDEADBEEF (1 read attempt(s))
  PA debug registers:
    [0x00] 0x640006FE
    [0x01] 0x64000000
    [0x02] 0x00000810
    [0x03] 0x00000690
    [0x04] 0x00000230
    [0x05] 0x0000022D
    [0x06] 0x00000000
    [0x07] 0x00000000
    [0x08] 0x00000003
    [0x09] 0x0000AAAA
    [0x0A] 0x0000AAAA
    [0x0B] 0x0000AAAA
    [0x0C] 0x0000AAAA
    [0x0D] 0x0000AAAA
    [0x0E] 0x0000AAAA
    [0x0F] 0x0000AAAA
    signature = 0x0000AAAA (1 read attempt(s))
  SE debug registers:
    [0x00] 0x00000000
    [0x01] 0x00000000
    [0x02] 0x00000000
    [0x03] 0x00000000
    [0x04] 0x00000000
    [0x05] 0x00000000
    [0x06] 0x00000000
    [0x07] 0x00000000
    [0x08] 0x00000000
    [0x09] 0x00000000
    [0x0A] 0x00000000
    [0x0B] 0x00000000
    [0x0C] 0x00000000
    [0x0D] 0x00000000
    [0x0E] 0x00000000
    [0x0F] 0x00000000
  MC debug registers:
    [0x00] 0x00000000
    [0x01] 0x00000000
    [0x02] 0x00000000
    [0x03] 0x00000000
    [0x04] 0x12345678
    [0x05] 0x12345678
    [0x06] 0x12345678
    [0x07] 0x12345678
    [0x08] 0x12345678
    [0x09] 0x12345678
    [0x0A] 0x12345678
    [0x0B] 0x12345678
    [0x0C] 0x12345678
    [0x0D] 0x12345678
    [0x0E] 0x12345678
    [0x0F] 0x12345678
    signature = 0x12345678 (1 read attempt(s))
  HI debug registers:
    [0x00] 0x0000F719
    [0x01] 0x19C020C8
    [0x02] 0x1EBC2426
    [0x03] 0xAAAAAAAA
    [0x04] 0xAAAAAAAA
    [0x05] 0xAAAAAAAA
    [0x06] 0xAAAAAAAA
    [0x07] 0xAAAAAAAA
    [0x08] 0xAAAAAAAA
    [0x09] 0xAAAAAAAA
    [0x0A] 0xAAAAAAAA
    [0x0B] 0xAAAAAAAA
    [0x0C] 0xAAAAAAAA
    [0x0D] 0xAAAAAAAA
    [0x0E] 0xAAAAAAAA
    [0x0F] 0xAAAAAAAA
    signature = 0xAAAAAAAA (1 read attempt(s))
  Other Registers:
    [0x0040] 0x00924A66
    [0x0044] 0x06F47370
    [0x004C] 0x06F47370
    [0x0050] 0x00DE8E6E
    [0x0054] 0x00DE8E6E
    [0x0058] 0x00924A66
    [0x005C] 0x001254D6
    [0x0060] 0x001254D6
    [0x043C] 0x00000000
    [0x0440] 0x00000000
    [0x0444] 0x00000000
    [0x0414] 0x3C000000
[<8003b21c>] (unwind_backtrace+0x0/0xfc) from [<80308114>] (_DumpGPUState+0x4ec/0x6b4)
[<80308114>] (_DumpGPUState+0x4ec/0x6b4) from [<80308324>] (gckOS_Broadcast+0x38/0xe8)
[<80308324>] (gckOS_Broadcast+0x38/0xe8) from [<80311008>] (gckEVENT_GetEvent+0x184/0x1b4)
[<80311008>] (gckEVENT_GetEvent+0x184/0x1b4) from [<80311294>] (gckEVENT_Submit+0x8c/0x328)
[<80311294>] (gckEVENT_Submit+0x8c/0x328) from [<8030dedc>] (gckCOMMAND_Commit+0x4d4/0xa28)
[<8030dedc>] (gckCOMMAND_Commit+0x4d4/0xa28) from [<8030c1d0>] (gckKERNEL_Dispatch+0x4b4/0x112c)
[<8030c1d0>] (gckKERNEL_Dispatch+0x4b4/0x112c) from [<80306580>] (drv_ioctl+0x108/0x250)
[<80306580>] (drv_ioctl+0x108/0x250) from [<800ed704>] (do_vfs_ioctl+0x80/0x5e0)
[<800ed704>] (do_vfs_ioctl+0x80/0x5e0) from [<800edc9c>] (sys_ioctl+0x38/0x60)
[<800edc9c>] (sys_ioctl+0x38/0x60) from [<80035580>] (ret_fast_syscall+0x0/0x30)
A:
This GPU driver stack dump indicates GPU stuck when VDDPU_CAP was under spec values (1.2V) so GPU was not correctly powered. Was fixed by adjusting PMU_REG_CORE[REG1_TARG].
AFAIK, GPU drivers have some DDR bank configuration, so you may see a different problem though.
Tags (2)
%3CLINGO-SUB%20id%3D%22lingo-sub-1115335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EQ%26amp%3BA%3A%20How%20to%20make%2016bit%20DDR%20%2B%20OpenGL%2FOpenVG%20working%20on%20imx6%20solo%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3EQ%3A%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3ECan%20OpenGL%2FOpenVG%20work%20on%20any%20of%20our%20boards%20with%20a%2016-bit%20DDR%20bus%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3EHere%20is%20GPU%20state%20dump%20when%20run%20some%20of%20the%20GPU%20SDK%20tutorials%20on%20their%20imx6%20solo%20board%20with%20a%2016-bit%20DDR%20bus%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3EMounting%20rootfs%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3EVFS%3A%20Mounted%20root%20(nfs%20filesystem)%20readonly%20on%20device%200%3A12.%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3EFreeing%20init%20memory%3A%20156K%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3EStarting%20init%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3EGPU%5B0%5D%3A%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E**************************%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E***%26nbsp%3B%26nbsp%3B%20GPU%20STATE%20DUMP%26nbsp%3B%26nbsp%3B%20***%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E**************************%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%20axi%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%200x000000B1%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%20idle%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%200x7FFFFF86%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20FE%20not%20idle%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20SH%20not%20idle%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PA%20not%20idle%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20SE%20not%20idle%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20RA%20not%20idle%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%20DMA%20appears%20to%20be%20stuck%20at%20this%20address%3A%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x1882F230%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%20dmaLow%26nbsp%3B%26nbsp%3B%20%3D%200x08010583%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%20dmaHigh%26nbsp%3B%20%3D%200x80003400%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%20dmaState%20%3D%200x00000904%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20command%20state%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%204%20(PAR_ADR1_ST)%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20command%20DMA%20state%26nbsp%3B%26nbsp%3B%20%3D%201%20(CMD_START_ST)%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20command%20fetch%20state%20%3D%202%20(FET_VALID_ST)%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20DMA%20request%20state%26nbsp%3B%26nbsp%3B%20%3D%200%20(REQ_IDLE_ST)%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20cal%20state%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%200%20(CAL_IDLE_ST)%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20VE%20request%20state%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%200%20(VER_IDLE_ST)%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%20RA%20debug%20registers%3A%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x00%5D%200x0108C378%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x01%5D%200x0042FB12%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x02%5D%200x0042FB11%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x03%5D%200x0000022C%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x04%5D%200x10220033%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x05%5D%200x0885C800%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x06%5D%200xC054CBFE%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x07%5D%200x68100000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x08%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x09%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0A%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0B%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0C%5D%200x12344321%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0D%5D%200x12344321%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0E%5D%200x12344321%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0F%5D%200x12344321%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20signature%20%3D%200x12344321%20(1%20read%20attempt(s))%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%20TX%20debug%20registers%3A%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x00%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x01%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x02%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x03%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x04%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x05%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x06%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x07%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x08%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x09%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0A%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0B%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0C%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0D%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0E%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0F%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20failed%20to%20obtain%20the%20signature%20(read%200x00000000).%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%20FE%20debug%20registers%3A%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x00%5D%200x1882F450%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x01%5D%200x08010594%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x02%5D%200x00000001%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x03%5D%200x00000256%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x04%5D%200x00080049%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x05%5D%200x0000000D%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x06%5D%200x00009571%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x07%5D%200x00007445%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x08%5D%200x00000004%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x09%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0A%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0B%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0C%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0D%5D%200xA3105D67%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0E%5D%200x000000D0%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0F%5D%200xBABEF00D%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20signature%20%3D%200xBABEF00D%20(1%20read%20attempt(s))%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%20PE%20debug%20registers%3A%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x00%5D%200x0108C369%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x01%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x02%5D%200x0108C369%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x03%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x04%5D%200xA0000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x05%5D%200xABC00000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x06%5D%200xBC000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x07%5D%200xCDE00000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x08%5D%200xD04045C0%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x09%5D%200x204045C0%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0A%5D%200x0D863084%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0B%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0C%5D%200xBABEF00D%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0D%5D%200xBABEF00D%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0E%5D%200xBABEF00D%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0F%5D%200xBABEF00D%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20signature%20%3D%200xBABEF00D%20(1%20read%20attempt(s))%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%20DE%20debug%20registers%3A%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x00%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x01%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x02%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x03%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x04%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x05%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x06%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x07%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x08%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x09%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0A%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0B%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0C%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0D%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0E%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0F%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20failed%20to%20obtain%20the%20signature%20(read%200x00000000).%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%20SH%20debug%20registers%3A%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x00%5D%200x0049AB4C%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x01%5D%200x0000000B%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x02%5D%200x00000411%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x03%5D%200x00020A95%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x04%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x05%5D%200x000F024E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x06%5D%200x000F424C%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x07%5D%200x010BEC30%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x08%5D%200x0108C368%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x09%5D%200x000020DF%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0A%5D%200x00000693%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0B%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0C%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0D%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0E%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0F%5D%200xDEADBEEF%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20signature%20%3D%200xDEADBEEF%20(1%20read%20attempt(s))%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%20PA%20debug%20registers%3A%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x00%5D%200x640006FE%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x01%5D%200x64000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x02%5D%200x00000810%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x03%5D%200x00000690%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x04%5D%200x00000230%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x05%5D%200x0000022D%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x06%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x07%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x08%5D%200x00000003%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x09%5D%200x0000AAAA%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0A%5D%200x0000AAAA%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0B%5D%200x0000AAAA%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0C%5D%200x0000AAAA%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0D%5D%200x0000AAAA%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0E%5D%200x0000AAAA%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0F%5D%200x0000AAAA%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20signature%20%3D%200x0000AAAA%20(1%20read%20attempt(s))%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%20SE%20debug%20registers%3A%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x00%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x01%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x02%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x03%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x04%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x05%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x06%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x07%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x08%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x09%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0A%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0B%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0C%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0D%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0E%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0F%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20failed%20to%20obtain%20the%20signature%20(read%200x00000000).%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%20MC%20debug%20registers%3A%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x00%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x01%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x02%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x03%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x04%5D%200x12345678%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x05%5D%200x12345678%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x06%5D%200x12345678%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x07%5D%200x12345678%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x08%5D%200x12345678%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x09%5D%200x12345678%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0A%5D%200x12345678%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0B%5D%200x12345678%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0C%5D%200x12345678%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0D%5D%200x12345678%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0E%5D%200x12345678%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0F%5D%200x12345678%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20signature%20%3D%200x12345678%20(1%20read%20attempt(s))%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%20HI%20debug%20registers%3A%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x00%5D%200x0000F719%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x01%5D%200x19C020C8%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x02%5D%200x1EBC2426%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x03%5D%200xAAAAAAAA%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x04%5D%200xAAAAAAAA%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x05%5D%200xAAAAAAAA%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x06%5D%200xAAAAAAAA%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x07%5D%200xAAAAAAAA%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x08%5D%200xAAAAAAAA%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x09%5D%200xAAAAAAAA%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0A%5D%200xAAAAAAAA%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0B%5D%200xAAAAAAAA%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0C%5D%200xAAAAAAAA%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0D%5D%200xAAAAAAAA%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0E%5D%200xAAAAAAAA%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0F%5D%200xAAAAAAAA%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20signature%20%3D%200xAAAAAAAA%20(1%20read%20attempt(s))%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%20Other%20Registers%3A%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0040%5D%200x00924A66%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0044%5D%200x06F47370%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x004C%5D%200x06F47370%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0050%5D%200x00DE8E6E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0054%5D%200x00DE8E6E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0058%5D%200x00924A66%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x005C%5D%200x001254D6%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0060%5D%200x001254D6%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x043C%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0440%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0444%5D%200x00000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B0x0414%5D%200x3C000000%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%5B%26lt%3B8003b21c%26gt%3B%5D%20(unwind_backtrace%2B0x0%2F0xfc)%20from%20%5B%26lt%3B80308114%26gt%3B%5D%20(_DumpGPUState%2B0x4ec%2F0x6b4)%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%5B%26lt%3B80308114%26gt%3B%5D%20(_DumpGPUState%2B0x4ec%2F0x6b4)%20from%20%5B%26lt%3B80308324%26gt%3B%5D%20(gckOS_Broadcast%2B0x38%2F0xe8)%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%5B%26lt%3B80308324%26gt%3B%5D%20(gckOS_Broadcast%2B0x38%2F0xe8)%20from%20%5B%26lt%3B80311008%26gt%3B%5D%20(gckEVENT_GetEvent%2B0x184%2F0x1b4)%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%5B%26lt%3B80311008%26gt%3B%5D%20(gckEVENT_GetEvent%2B0x184%2F0x1b4)%20from%20%5B%26lt%3B80311294%26gt%3B%5D%20(gckEVENT_Submit%2B0x8c%2F0x328)%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%5B%26lt%3B80311294%26gt%3B%5D%20(gckEVENT_Submit%2B0x8c%2F0x328)%20from%20%5B%26lt%3B8030dedc%26gt%3B%5D%20(gckCOMMAND_Commit%2B0x4d4%2F0xa28)%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%5B%26lt%3B8030dedc%26gt%3B%5D%20(gckCOMMAND_Commit%2B0x4d4%2F0xa28)%20from%20%5B%26lt%3B8030c1d0%26gt%3B%5D%20(gckKERNEL_Dispatch%2B0x4b4%2F0x112c)%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%5B%26lt%3B8030c1d0%26gt%3B%5D%20(gckKERNEL_Dispatch%2B0x4b4%2F0x112c)%20from%20%5B%26lt%3B80306580%26gt%3B%5D%20(drv_ioctl%2B0x108%2F0x250)%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%5B%26lt%3B80306580%26gt%3B%5D%20(drv_ioctl%2B0x108%2F0x250)%20from%20%5B%26lt%3B800ed704%26gt%3B%5D%20(do_vfs_ioctl%2B0x80%2F0x5e0)%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%5B%26lt%3B800ed704%26gt%3B%5D%20(do_vfs_ioctl%2B0x80%2F0x5e0)%20from%20%5B%26lt%3B800edc9c%26gt%3B%5D%20(sys_ioctl%2B0x38%2F0x60)%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%5B%26lt%3B800edc9c%26gt%3B%5D%20(sys_ioctl%2B0x38%2F0x60)%20from%20%5B%26lt%3B80035580%26gt%3B%5D%20(ret_fast_syscall%2B0x0%2F0x30)%3C%2FP%3E%3CDIV%3E%3CP%3E%3C%2FP%3E%3CP%3EA%3A%3C%2FP%3E%3CP%3EThis%20GPU%20driver%20stack%20dump%20indicates%20GPU%20stuck%20when%20VDDPU_CAP%20was%20under%20spec%20values%20(1.2V)%20so%20GPU%20was%20not%20correctly%20powered.%20Was%20fixed%20by%20adjusting%20PMU_REG_CORE%5BREG1_TARG%5D.%3C%2FP%3E%3CP%3EAFAIK%2C%20GPU%20drivers%20have%20some%20DDR%20bank%20configuration%2C%20so%20you%20may%20see%20a%20different%20problem%20though.%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1115335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_All%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎08-23-2013 12:40 AM
Updated by:
