Q&A: How to converter RealView scripts to Lauterbach CMM scripts for mx53
Q:
Does anyone have the Lauterbach script files for connecting to the mx53?  Also,  does anyone know of a converter to convert RealView scripts to Lauterbach?
A:
Please see below attach.cmm and load_simbols.cmm for i.MX53.
attach.cmm
; Script to attach to a running system, halt the CPU,
; and display the ASM code
screen.on
; Debugger Reset
winpage.reset
area.reset
WINPOS 0. 26. 75. 8. 0. 0. W000
area
print "resetting ICD..."
System.Down
Break.Delete
MAP.RESet
TASK.RESet
sYmbol.RESet
Data.PROLOG.RESet
Data.EPILOG.RESet
sYmbol.AutoLoad.CHECK OFF      ; disable dynamic autoloader
sYmbol.AutoLoad.RESet          ; reset autoloader list
MMU.RESet
; setup of ICD JTAG
print "initializing JTAG..."
SYStem.CPU CORTEXA8
SYStem.MultiCore IRPOST 0x0
SYStem.MultiCore IRPRE 0x0
SYStem.MultiCore DRPOST 0x0
SYStem.MultiCore DRPRE 0x0
SYStem.MultiCore DAPIRPOST 0x09
SYStem.MultiCore DAPIRPRE 0x0
SYStem.MultiCore DAPDRPOST 0x02
SYStem.MultiCore DAPDRPRE 0x0
SYStem.MultiCore MEMORYACCESSPORT 0
SYStem.MultiCore DEBUGACCESSPORT 1
SYStem.MultiCore COREBASE APB:0xC0008000
SYStem.Option DACR ON          ; give Debugger global write permissions
TrOnchip.Set DABORT OFF        ; used by Linux OS for page miss!
TrOnchip.Set PABORT OFF        ; used by Linux OS for page miss!
TrOnchip.Set UNDEF OFF         ; let UNDEF be handled by Linux OS
SYStem.Option MMU ON           ; enable space ids to virtual addresses
SYStem.JtagClock 20.0MHz
SETUP.IMASKASM ON              ; lock interrupts while single stepping
; Use on-chip breakpoints
Break.SELect PROGRAM ONCHIP
Break.SELect READ ONCHIP
Break.SELect WRITE ONCHIP
Break.SELect ALPHA ONCHIP
Break.SELect BETA ONCHIP
Break.SELect CHARLY ONCHIP
Break.SELect DELTA ONCHIP
Break.SELect ECHO ONCHIP
SYStem.Option EnReset OFF
SYS.m attach
; wait until reset is complete
wait 2.s
if run()
    Break
; Open a Code Window -- we like to see something
WINPOS 0. 0. 75. 20.
Data.List
enddo
load.symbols.cmm
; Script to load the Linux kernel symbols into the debugger
print "loading Linux kernel symbols..."
&linuxpath="S:\git\kernel\linux-2.6-imx-0"
&kbuildpath="build"
sYmbol.SourcePATH.SET &linuxpath
Data.LOAD.Elf &linuxpath\&kbuildpath\imx5\vmlinux /StripPART 3 /gnu /nocode
; Map the virtual kernel symbols to physical addresses
; to give the debugger access to it before CPU MMU is
; initialized
print "setting system MMU..."
MMU.FORMAT Linux swapper_pg_dir 0xc0000000--0xc1ffffff 0x70000000
MMU.Create 0xc0000000--0xc1ffffff 0x70000000 ; map kernel pages at RAM start
MMU.COMMON 0xc0000000--0xffffffff            ; common area for kernel and processes
;MMU.TableWalk OFF   ; debugger uses a table walk to decode virtual addresses
MMU.ON             ; switch on debugger(!) address translation
; Initialize Mutitasking Support
print "initializing multitask support..."
TASK.CONFIG ../linux       ; loads Linux awareness (linux.t32)
MENU.ReProgram ../linux    ; loads Linux menu (linux.men)
HELP.FILTER.Add rtoslinux  ; add linux awareness manual to help filter
enddo
This document was generated from the following discussion: Lauterbach CMM scripts for mx53
%3CLINGO-SUB%20id%3D%22lingo-sub-1114096%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EQ%26amp%3BA%3A%20RealView%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%20mx53%20%E3%81%AE%20Lauterbach%20CMM%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114096%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EQ%EF%BC%9A%3C%2FP%3E%3CP%3Emx53%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%A9%E3%82%A6%E3%82%BF%E3%83%BC%E3%83%90%E3%83%83%E3%83%8F%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%BE%E3%81%9F%E3%80%81RealView%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92Lauterbach%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8B%EF%BC%9A%3C%2FP%3E%3CP%3Ei.MX53%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E4%B8%8B%E8%A8%98attach.cmm%E3%81%8A%E3%82%88%E3%81%B3load_simbols.cmm%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3Eattach.cmm%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3B%3C%2FP%3E%3CP%3E%3B%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E3%82%A2%E3%82%BF%E3%83%83%E3%83%81%E3%81%99%E3%82%8B%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%80%81CPU%E3%82%92%E5%81%9C%E6%AD%A2%E3%80%81%3C%2FP%3E%3CP%3E%3BASM%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Escreen.%E3%82%AA%E3%83%B3%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3B%20Debugger%20Reset%3C%2FP%3E%3CP%3Ewinpage.reset%20%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%AA%E3%82%A2.%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FP%3E%3CP%3EWINPOS%200.26.75.8.%200.0.W000%3C%2FP%3E%3CP%3E%E9%9D%A2%E7%A9%8D%3C%2FP%3E%3CP%3E%E3%80%8CICD%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%22%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%80%E3%82%A6%E3%83%B3%3C%2FP%3E%3CP%3E%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF.%E5%89%8A%E9%99%A4%3C%2FP%3E%3CP%3EMAP.RESet%3C%2FP%3E%3CP%3E%E3%82%BF%E3%82%B9%E3%82%AF%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FP%3E%3CP%3EsYmbol.RESet%3C%2FP%3E%3CP%3EData.PROLOG.RESet%3C%2FP%3E%3CP%3EData.EPILOG.RESet%3C%2FP%3E%3CP%3EsYmbol.AutoLoad.%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%AA%E3%83%95%3B%E3%83%80%E3%82%A4%E3%83%8A%E3%83%9F%E3%83%83%E3%82%AF%20%E3%82%AA%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%81%AE%E7%84%A1%E5%8A%B9%E5%8C%96%3C%2FP%3E%3CP%3EsYmbol.AutoLoad.RESet%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3B%20reset%20autoloader%20list%3C%2FP%3E%3CP%3EMMU.RESet%3C%2FP%3E%3CP%3E%3BICD%20JTAG%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FP%3E%3CP%3Eprint%20%22%E5%88%9D%E6%9C%9F%E5%8C%96%E4%B8%ADJTAG...%22%3C%2FP%3E%3CP%3ESYStem.CPU%20CORTEXA8%3C%2FP%3E%3CP%3ESYStem.MultiCore%20IRPOST%200x0%3C%2FP%3E%3CP%3ESYStem.MultiCore%20IRPRE%200x0%3C%2FP%3E%3CP%3ESYStem.MultiCore%20DRPOST%200x0%3C%2FP%3E%3CP%3ESYStem.MultiCore%20DRPRE%200x0%3C%2FP%3E%3CP%3ESYStem.MultiCore%20DAPIRPOST%200x09%3C%2FP%3E%3CP%3ESYStem.MultiCore%20DAPIRPRE%200x0%3C%2FP%3E%3CP%3ESYStem.MultiCore%20DAPDRPOST%200x02%3C%2FP%3E%3CP%3ESYStem.MultiCore%20DAPDRPRE%200x0%3C%2FP%3E%3CP%3ESYStem.MultiCore%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%200%3C%2FP%3E%3CP%3ESYStem.MultiCore%20DEBUGACCESSPORT%201%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%9E%E3%83%AB%E3%83%81%E3%82%B3%E3%82%A2%20COREBASE%20APB%3A0xC0008000%3C%2FP%3E%3CP%3ESYStem.Option%20DACR%20ON%20%3B%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%81%AB%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%E3%81%AA%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E6%A8%A9%E9%99%90%E3%82%92%E4%BB%98%E4%B8%8E%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3ETrOnchip.Set%20DABORT%20OFF%20%3B%E3%83%9A%E3%83%BC%E3%82%B8%E3%83%9F%E3%82%B9%E3%81%AE%E3%81%9F%E3%82%81%E3%81%ABLinuxOS%E3%81%A7%E4%BD%BF%E7%94%A8!%3C%2FP%3E%3CP%3ETrOnchip.Set%20PABORT%20OFF%20%3B%E3%83%9A%E3%83%BC%E3%82%B8%E3%83%9F%E3%82%B9%E3%81%AE%E3%81%9F%E3%82%81%E3%81%ABLinuxOS%E3%81%A7%E4%BD%BF%E7%94%A8!%3C%2FP%3E%3CP%3ETrOnchip.Set%20UNDEF%20OFF%20%3BUNDEF%E3%82%92Linux%20OS%E3%81%A7%E5%87%A6%E7%90%86%E3%81%95%E3%81%9B%E3%82%8B%3C%2FP%3E%3CP%3ESYStem.Option%20MMU%20ON%20%3B%E4%BB%AE%E6%83%B3%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%B8%E3%81%AE%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9ID%E3%81%AE%E6%9C%89%E5%8A%B9%E5%8C%96%3C%2FP%3E%3CP%3ESYStem.JtagClock%2020.0MHz%3C%2FP%3E%3CP%3E%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%80%82IMASKASM%E3%82%AA%E3%83%B3%3B%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E6%99%82%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3B%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97%20%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EBreak.SELect%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%20%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97%3C%2FP%3E%3CP%3EBreak.SELect%20READ%20%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97%3C%2FP%3E%3CP%3EBreak.SELect%20WRITE%20%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97%3C%2FP%3E%3CP%3EBreak.SELect%20ALPHA%20%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97%3C%2FP%3E%3CP%3EBreak.SELect%20%E3%83%99%E3%83%BC%E3%82%BF%20%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97%3C%2FP%3E%3CP%3EBreak.SELect%20%E3%83%81%E3%83%A3%E3%83%BC%E3%83%AA%E3%83%BC%E3%83%BB%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97%3C%2FP%3E%3CP%3EBreak.SELect%20DELTA%20%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97%3C%2FP%3E%3CP%3EBreak.SELect%20%E3%82%A8%E3%82%B3%E3%83%BC%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97%3C%2FP%3E%3CP%3ESYStem.Option%20EnReset%20OFF%3C%2FP%3E%3CP%3ESYS.m%20%E3%82%A2%E3%82%BF%E3%83%83%E3%83%81%3C%2FP%3E%3CP%3E%3B%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%99%E3%82%8B%E3%81%BE%E3%81%A7%E5%BE%85%E3%81%A1%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E2.%E7%A7%92%E5%BE%85%E3%81%A4%3C%2FP%3E%3CP%3Erun()%20%E3%81%AE%E5%A0%B4%E5%90%88%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Break%3C%2FP%3E%3CP%3E%3B%E3%82%B3%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%82%92%E9%96%8B%E3%81%8F%20--%20%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E4%BD%95%E3%81%8B%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%AE%E3%81%8C%E5%A5%BD%E3%81%8D%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWINPOS%200.0.%2075.20.%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%BC%E3%82%BF.%E3%83%AA%E3%82%B9%E3%83%88%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eenddo%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3Eload.symbols.cmm%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3B%3C%2FP%3E%3CP%3E%3BLinux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AB%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%81%AB%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3C%2FP%3E%3CP%3E%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eprint%20%22Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99...%22%3C%2FP%3E%3CP%3E%26amp%3Blinuxpath%3D%22S%3A%5Cgit%5Ckernel%5Clinux-2.6-imx-0%22%3C%2FP%3E%3CP%3E%26amp%3Bkbuildpath%3D%22%E3%83%93%E3%83%AB%E3%83%89%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EsYmbol.SourcePATH.SET%20%26amp%3B%20linuxpath%3C%2FP%3E%3CP%3EData.LOAD.Elf%20%26amp%3Blinuxpath%5C%26amp%3Bkbuildpath%5Cimx5%5Cvmlinux%20%2FStripPART%203%20%2Fgnu%20%2Fnocode%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3B%E4%BB%AE%E6%83%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AB%E3%82%92%E7%89%A9%E7%90%86%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3BCPU%20MMU%20%E3%81%8C%3C%2FP%3E%3CP%3E%3B%E5%88%9D%E6%9C%9F%E5%8C%96%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%80%8C%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0MMU%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%80%8D%E3%82%92%E5%8D%B0%E5%88%B7%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMMU%E3%81%A7%E3%81%99%E3%80%82FORMAT%20Linux%20swapper_pg_dir%200xc0000000--0xc1ffffff%200x70000000%3C%2FP%3E%3CP%3EMMU%E3%81%A7%E3%81%99%E3%80%82%E4%BD%9C%E6%88%900xc0000000--0xc1ffffff%200x70000000%20%3BRAM%E9%96%8B%E5%A7%8B%E6%99%82%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AE%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%3C%2FP%3E%3CP%3EMMU%E3%81%A7%E3%81%99%E3%80%82%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA0xc0000000--0xffffffff%3B%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A8%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AE%E5%85%B1%E9%80%9A%E9%A0%98%E5%9F%9F%3C%2FP%3E%3CP%3E%3BMMU%E3%81%A7%E3%81%99%E3%80%82%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A6%E3%82%A9%E3%83%BC%E3%82%AF%E3%82%AA%E3%83%95%20%3B%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%81%AF%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A6%E3%82%A9%E3%83%BC%E3%82%AF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E4%BB%AE%E6%83%B3%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EMMU%E3%81%A7%E3%81%99%E3%80%82%E3%82%AA%E3%83%B3%3B%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%81%AE%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%92%E5%85%A5%E3%82%8C%E3%81%BE%E3%81%99(!%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E5%A4%89%E6%8F%9B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3B%E5%88%9D%E6%9C%9F%E5%8C%96%E3%83%9E%E3%83%AB%E3%83%81%E3%82%BF%E3%82%B9%E3%82%AD%E3%83%B3%E3%82%B0%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPrint%20%22%E3%83%9E%E3%83%AB%E3%83%81%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E4%B8%AD...%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETASK.CONFIG%20..%2Flinux%20%3BLinux%E3%81%AE%E8%AA%8D%E8%AD%98(linux.t32)%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EMENU.ReProgram%20..%2Flinux%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3B%20loads%20Linux%20menu%20(linux.men)%3C%2FP%3E%3CP%3E%E3%83%98%E3%83%AB%E3%83%97%E3%80%82%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%E3%80%82rtoslinux%20%E3%82%92%E8%BF%BD%E5%8A%A0%20%3B%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A4Linux%E8%AA%8D%E8%AD%98%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eenddo%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8B%E3%82%89%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F310127%22%20target%3D%22_blank%22%3Emx53%20%E3%81%AE%20Lauterbach%20CMM%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1114096%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX53%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎09-02-2013 12:56 AM
更新者:
