Patch to support uboot logo keep from uboot to kernel for NXP Linux and Android BSP (HDMI, LCD and LVDS)
This patch made the display no interrupt from uboot to kernel to Android. The IPU and related hardware display interface will only be initialized once in Uboot, the kernel code will skip the IPU initialization.
1. Description
    1) Support HDMI, LVDS and LCD output in UBoot.
    2) Support UBoot logo keep from uboot to kernel to Android.
    3) For HDMI, both 720P and 1080P mode were supported.
    4) For LVDS, 1024x768 and 1080P dual channel panels were supported.
    5) The logo file is a 32 bpp bmp file.
2. File List
-- kernel_imx\0001-Keep-uboot-logo-for-Android-boot-supports-HDMI-LCD-a.patch
-- kernel_imx\0002-Bug-fix-for-uboot-logo-keep-patch.patch
   Kernel patch to support the logo keep feature.
-- uboot-imx\0001-Enable-uboot-logo-for-HDMI-LCD-and-LVDS.patch
   Uboot patch to support the logo display.
   Example 32bpp logo file.
-- readme.txt
   this file, please refer to it before use the patches
3. Requirement
- iMX6 SabreSD board.
- Android JB4.2.2_1.1.0-GA UBoot and kernel.
4. How to use
-- Copy the two patch files to Android kernel_imx and uboot-imx folder and apply them.
    $ cd ~/myandroid/kernel_imx/
    $ git apply ./0001-Keep-uboot-logo-for-Android-boot-supports-HDMI-LCD-a.patch
    $ cd ~/myandroid/bootable/bootloader/uboot-imx/
    $ git apply ./0001-Enable-uboot-logo-for-HDMI-LCD-and-LVDS.patch
    $ git apply ./0002-Bug-fix-for-uboot-logo-keep-patch.patch
-- Build the new uboot image:
    $ export CROSS_COMPILE=~/myandroid/prebuilt/gcc/linux-x86/arm/arm-eabi-4.6/bin/arm-eabi-
    $ export ARCH=arm
    $ make mx6q_sabresd_android_config
    $ make
-- Before build new UBoot image, the display type can be selected from file uboot-imx\include\configs\mx6q_sabresd.h
// Select one of the output mode
#define IPU_OUTPUT_MODE_HDMI
//#define IPU_OUTPUT_MODE_LVDS
//#define IPU_OUTPUT_MODE_LCD
-- Build the new kernel image:
    $ export ARCH=arm
    $ make imx6_android_defconfig
    $ make uImage
-- Before "make uImage", make menuconfig can be used to select the display type.
                System Type  --->
                   Freescale MXC Implementations  --->
                      MX6 clk setting for smooth UI transtion from bootloader to kernel  --->
                          Select Display Interface
                             ( )  Smooth UI transtion on LCD, IPU1, DI0
                             ( )  Smooth UI transtion on LVDS, IPU1, DI1
                             (X)  Smooth UI transtion on HDMI, IPU2, DI0
-- Uboot parameters for video mode
   1080P HDMI:
      "video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24,bpp=32 fb0base=0x27b00000 fbmem=28M hdmi_audio_clk=148500000"
   720P HDMI:
      "video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24,bpp=32 fb0base=0x27b00000 fbmem=28M hdmi_audio_clk=74250000"
   1024x768 LVDS:
      "video=mxcfb0:dev=ldb,LDB-XGA,if=RGB666,bpp=32 fb0base=0x27b00000 fbmem=28M"
   800x480 LCD:
      "video=mxcfb0:dev=lcd,CLAA-WVGA,if=RGB565,bpp=32 fb0base=0x27b00000 fbmem=28M"
-- dd the logo.bmp to SD card address 0x100000 and skip the 54 bytes bmp file header.
   sudo dd if=logo.bmp of=/dev/sdc bs=1 seek=1048576 skip=54
5. Note
    1) The logo.bmp file should be 32bpp or 16bpp, and it should be synced with video mode parameters "bpp=xx",
         and uboot config file mx6q_sabresd.h (#define DISPLAY_BPP  xx).
    2) The IPU number and DI number are hard coded in kernel file "board-mx6q_sabresd.c".
static struct fsl_mxc_hdmi_core_platform_data hdmi_core_data = {
  .ipu_id = 1,
  .disp_id = 0,
static struct fsl_mxc_lcd_platform_data lcdif_data = {
  .ipu_id = 0,
  .disp_id = 0,
  .default_ifmt = IPU_PIX_FMT_RGB565,
static struct fsl_mxc_ldb_platform_data ldb_data = {
  .ipu_id = 0,
  .disp_id = 1,
  .ext_ref = 1,
  .mode = LDB_SEP1,
  .sec_ipu_id = 0,
  .sec_disp_id = 0,
    3) The IPU number and DI number are defined by Macro in Uboot file "include\configs\mx6q_sabresd.h"
#define IPU_NUM   2  // 1 for IPU1, 2 for IPU2.
#define DI_NUM   0  // 0 for DI0, 1 for DI1.
    4) The display type used in uboot and kernel must be same, same type, same IPU number, same DI port and
       same resolution.
[2015-06-29 Update]: JB4.2.2_1.1.0_uboot_logo_keep_patch_2015-06-29.zip
Fix some LVDS issues for iMX6DL.
Also given an example for LVDS0 with DI0.
New Uboot patches:
     0002-Updated-lvds-clock-source-to-pll2_pfd0.-Same-as-kern.patch
     0003-Add-support-for-iMX6DL.patch
New kernel patches
     0003-Skip-lvds-re-initialization-for-logo-keep.patch
     0004-Add-examlpe-for-LVDS0-logo-keep.patch
[2015-08-07 Update]: JB4.2.2_1.1.0_uboot_logo_keep_patch_2015-08-07.zip
Added the new Uboot patch 0004-Correct-the-sequence-to-set-LDB-clock.patch
It can correct the LVDS clock set sequence whch is a known issue that caused no LVDS display sometimes.
[2015-09-18 Update]: JB4.3_1.1.1_uboot_logo_keep_patch_2015-09-18.zip
Added the patch for Android JB4.3_GA1.1.1 release.
Updated clock usecount, after blank the display, the related clock can be gated off correctly.
Support LVDS clock from PLL5.
[2015-12-21 Update]: Added 3.10.53_GA1.1.0 patch: L3.10.53_GA1.1.0_uboot_logo_keep_patch_2015-12-21.zip.
Verified on iMX6DL/Q SabreSD board. It supports LCD and LVDS panels, HDMI patch will be released later.
[2016-01-04 Update]: Added 3.10.53_GA1.1.0 patch: L3.10.53_GA1.1.0_uboot_logo_keep_patch_2016-01-04.zip.
Added HDMI display support. Now it supports LCD, LVDS and HDMI displays.
Fixed the video playback issue for boot up.
[2016-05-18 Update]: 0001-Fix-the-split-mode-LVDS-panel-no-TX3-signal-issue.patch
An issue was founded, when dual channel 4 lanes LVDS panel was used, in uboot there will be no LVDS TX3 signa on one LVDS port, the attach "0001-Fix-the-split-mode-LVDS-panel-no-TX3-signal-issue.patch" was used to fix this issue, it is based on JB4.3_1.1.1_uboot_logo_keep_patch_2015-09-18.zip, for other BSP, please port it manually.
[2016-08-29 Update]: 0001-After-reset-IPU-in-SRC-Control-Register-wait-for-res.patch
On some iMX6 chip, after reset the IPU in SRC Control Register, enable IPU at once will cause system hang up, to avoid such issue, software needs wait for IPU reset done by polling the SRC register.
The attach "0001-After-reset-IPU-in-SRC-Control-Register-wait-for-res.patch" was used to fix this issue, it is based on JB4.3_1.1.1_uboot_logo_keep_patch_2015-09-18.zip + "0001-Fix-the-split-mode-LVDS-panel-no-TX3-signal-issue.patch", for other BSP, please port it manually.
[2017-01-06 Update] Added patch for L4.1.15_GA1.2.0 BSP and Android M6.0.1_GA2.1.0 BSP.
Files: L4.1.15_GA1.2.0_uboot_logo_keep_patch_2017-01-06.zip; M6.0.1_2.1.0_uboot_logo_keep_patch_2017-01-06.zip
Comments
Hi,我的平台是i.mx6 双核标准版 的android4.4平台,我打了这些补丁后,uboot的logo可以保持到kernel启动完成,但是在跑android动画前面,会黑屏大概一秒。
   现在我们的产品需要让静态logo保持到开机完成,即android的动画也是换成同一张图片,因此会有在开机过程黑屏一秒左右的现象。
    1.问题初步定位:开机时,init启动surfacefinger 服务时,surfacefinger最终会加载gralloc.imx6.so/gralloc_viv.imx6.so库文件和调用framebuffer_open()函数,
         调用framebuffer_open函数时屏幕黑黑掉,因此从启动surfacefinger到bootanimation第一帧动画开始这段时间lcd会黑屏;
      2.但最终由于发现gralloc_viv.imx6.so我们没有源码无法继续跟踪和测试此问题。
      3.疑问:
         a,基于imx6的android平台是否可以做到开机只显示静态logo,开机到主页过程不闪黑屏?
         b,是否可在第一点我定位的位置去掉刷黑屏动作去解决此问题,如果不能,可否提供其他解决方案?
   uboot 的timing:
/* Select one of the output mode */
    //#define IPU_OUTPUT_MODE_HDMI
    #define LVDS_SPLIT_MODE 1     // For dual channel split mode.
    #define CONFIG_FB_BASE  (TEXT_BASE + 0x300000)
    #define UBOOT_LOGO_BMP_ADDR 0x00100000
    //#define CONFIG_IMX_PWM
    //#define IMX_PWM1_BASE     PWM1_BASE_ADDR
    //#define IMX_PWM2_BASE     PWM2_BASE_ADDR
    #define CONFIG_VIDEO_MX5
    #define CONFIG_LCD
    #define CONFIG_CMD_BMP
/* Select LVDS0 bit mapping mode , JEIDA or SPWG */
    #define LVDS_BIT_MAPPING_CH0_JEIDA 1
  //  #define LVDS_BIT_MAPPING_CH0_SPWG 1 /* first pixel */
/* Select LVDS1 bit mapping mode , JEIDA or SPWG */
    //#define LVDS_BIT_MAPPING_CH1_SPWG 1   /* lvds1 not used */
   // #define LVDS_BIT_MAPPING_CH1_SPWG 1   /* second pixel */
    #define DISPLAY_WIDTH       960
    #define DISPLAY_HEIGHT      1280
    #define DISPLAY_BPP         32
    #define DISPLAY_IF_BPP      24
    #define DISPLAY_HSYNC_START 20
    #define DISPLAY_HSYNC_END   20
    #define DISPLAY_HSYNC_WIDTH 20
    #define DISPLAY_VSYNC_START 15
    #define DISPLAY_VSYNC_END   15
    #define DISPLAY_VSYNC_WIDTH 10
    /* pixel clock 30062 */
    #define DISPLAY_PIX_CLOCK  80784000  //(DISPLAY_HSYNC_START + DISPLAY_HSYNC_END + DISPLAY_HSYNC_WIDTH + DISPLAY_WIDTH) * (DISPLAY_VSYNC_START + DISPLAY_VSYNC_END + DISPLAY_VSYNC_WIDTH + DISPLAY_HEIGHT) * refresh rate (60Hz)
    //#define LVDS_SPLIT_MODE  // For dual channel split mode.
    #define DISPLAY_VSYNC_POLARITY          0
    #define DISPLAY_HSYNC_POLARITY          0
    #define DISPLAY_CLOCK_POLARITY          0
    #define DISPLAY_DATA_POLARITY           0
    #define DISPLAY_DATA_ENABLE_POLARITY    1
    #define IPU_NUM            1  // 1 for IPU1, 2 for IPU2.
    #define LVDS_PORT        0  // 0 for LVDS0, 1 for LVDS1. For LVDS display, LVDS_PORT should be same as DI_NUM.
    #define DI_CLOCK_EXTERNAL_MODE  //When clock external mode was defined, the DI clock root will be PLL3 PFD1,
                                //without this macro, the DI root clock is IPU internal clock.
    #define LVDS_CLOCK_SRC_PLL5
kernel:
BOARD_KERNEL_CMDLINE := console=ttymxc0,115200 init=/init video=mxcfb0:dev=ldb,bpp=32  video=mxcfb1:off video=mxcfb2:off fbmem=20M vmalloc=400M  fb0base=0x27b00000 quiet androidboot.console=ttymxc0 androidboot.hardware=freescale
ldb参数:
    .ipu_id = 0,
#ifdef CONFIG_MX6_CLK_FOR_BOOTUI_TRANS_LVDS_IPU1_DI0
    .disp_id = 0,
        .ext_ref = 1,
        .mode = LDB_SEP0,
        .sec_ipu_id = 0,
        .sec_disp_id = 1,
#else
        .disp_id = 1,
        .ext_ref = 1,
        .mode = LDB_SEP1,
        .sec_ipu_id = 0,
        .sec_disp_id = 0,
#endif
已打补丁:0001-Keep-uboot-logo-for-Android-boot-supports-HDMI-LCD-a.patch
Thanks!
你可以实际测量一下display的信号,看看中间有没有中断过,如果有的话,应该是patch整合的不太对。Patch在开发板上验证过,中间没有黑屏一秒这种问题。
我量过i.mx6输出的lvds信号(LVDS_SPLIT_MODE),logo过度的黑屏期间:
tx0,tx1,tx4,tx5无信号;
tx2,tx3,tx6,tx7和clock一直有信号;
从lvds信号看像是输出一个黑屏信号
那应该就是Android层清了一下framebuffer,应该没有1秒那么久的。
Best Regards
发件人: zhangzewei
发送时间: 2018年2月28日 17:04
收件人: Qiang Li - Mpu Se <qiang.li@nxp.com>
主题: Re: - Patch to support uboot logo keep from uboot to kernel for NXP Linux and Android BSP (HDMI, LCD and LVDS)
NXP Community <https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fcommunity.freescale.com%2Fresources%2Fstatics%2F1000%2F35400-NXP-Community-Email-banner-600x75.jpg&data=02%7C01%7Cqiang.li%40nxp.com%7Ccdfb139419d54e0f6f6808d57e8a4790%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C636554054730397540&sdata=4xq7V%2FKhXL%2BEO0oAI%2BVdbrtpKYs%2FlrNYBNA4Iy4cgIU%3D&reserved=0>
new comment by zhang zewei<https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fzhangzewei%3Fet%3Dwatches.email.document_comment&data=02%7C01%7Cqiang.li%40nxp.com%7Ccdfb139419d54e0f6f6808d57e8a4790%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C636554054730397540&sdata=uCgQoFlFvjKxGClvTfMq1n3oJ%2FhdzlN7P1cuB6WVOv8%3D&reserved=0> View all comments on this document<https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-98109%3FcommentID%3D51463%26et%3Dwatches.email.document_comment%23comment-51463&data=02%7C01%7Cqiang.li%40nxp.com%7Ccdfb139419d54e0f6f6808d57e8a4790%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C636554054730397540&sdata=NTXe4qVuZEAAmmRyQMlXnMksEuU%2FcU%2F1d5qECmQq6Y4%3D&reserved=0>
不到一秒,860ms左右。
用开发板看了下,从静态logo到android动画出来之间也有一段时间是黑屏的,
但是是14年6月的镜像,如果如你所说,此问题已在开发板上解决,可否提供新的系统镜像验证这个问题?
跟踪过surfaceFinger源码,黑屏动作在framebuffer_open():
      1.SurfaceFlinger::init()->
         mHwc = new HWComposer(this,*static_cast<HWComposer::EventHandler *>(this));->
              HWComposer::loadFbHalModule()->
               framebuffer_open(module, &mFbDev);//此处黑屏
      2.loadFbHalModule()加载的是gralloc.imx6.so,
        framebuffer_open(module, &mFbDev);调用gralloc.imx6.so的gralloc_device_open();
        gralloc_device_open(),加载gralloc_viv.imx6.so
        gralloc_viv.imx6.so 此库我们没有源码,无法跟踪,因此需要FSL帮忙跟踪此问题。
hi,你好,我用的是im6q,Linux。版本是比较新的4.9.11-1.0.0。直接repo下来的。开发板freescale官方开发板。
在uboot里打补丁是失败的。后来手动去掉冲突,但是编译的时候,又报错。
是不是4.9.11-1.0.0不能用这个补丁。那新版我怎么样才能在uboot时候在HDMI的屏幕上显示logo呢?
I am running a Dual LVDS Display i.mx6dual system.   Prior to loading these patches, I have verified that I am able to have proper timing and graphics on both displays (1920x720 & 800x480).  I have loaded these patches, but find that only one of the two displays is initialized.   The one display (IPU1 DI0) is initialized, displays the UBOOT Boot Logo, Logo is sustained during Linux boot and then is replaced by the linux app video...
My question is:   Is there a way to have this solution with two displays??   Although I would like to have the graphics of DI1 (IPU2 DI1) blanked at power up in U-Boot, I feel this could be delayed until Linux boot.  The issue is I believe that these patches in the linux kernel were only meant for a single display (LCD, LVDS, or HDMI).  Does anyone have these patches working on a system with two displays??
Thanks in advance!!!
Mike Sims
   Null pointer appears in gpu test after use "uboot logo keep from uboot to kernel" patch.
   We use "cd /opt/viv_samples/vdk/ && ./tutorial5 -f 100"  to test Gpu function in the imx6q and linux version is 3.0.35.   If we didn't use "uboot logo keep from uboot to kernel" patch ,the gpu test work well; but when use this patch ,a null pointer will appear.
[ 86.290668] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 86.290677] pgd = ba370000
[ 86.290682] [00000000] *pgd=4a23d831, *pte=00000000, *ppte=00000000
[ 86.290697] Internal error: Oops: 817 [#1] PREEMPT SMP
[ 86.290705] Modules linked in:
[ 86.290715] CPU: 1 Not tainted (3.0.35-2508-g54750ff-HNS010700101-03 #15)
[ 86.290736] PC is at wait_for_common+0xec/0x1bc
[ 86.290745] LR is at wait_for_common+0xcc/0x1bc
[ 86.291336] [<8056a104>] (wait_for_common+0xec/0x1bc) from [<80259850>] (mxcfb_pan_display+0x250/0x55c)
[ 86.291367] [<80259850>] (mxcfb_pan_display+0x250/0x55c) from [<80247b80>] (fb_pan_display+0xbc/0x13c)
[ 86.291387] [<80247b80>] (fb_pan_display+0xbc/0x13c) from [<80248534>] (fb_set_var+0x138/0x290)
[ 86.291403] [<80248534>] (fb_set_var+0x138/0x290) from [<80248998>] (do_fb_ioctl+0x30c/0x5d0)
[ 86.291427] [<80248998>] (do_fb_ioctl+0x30c/0x5d0) from [<80100b54>] (do_vfs_ioctl+0x80/0x54c)
[ 86.291446] [<80100b54>] (do_vfs_ioctl+0x80/0x54c) from [<80101058>] (sys_ioctl+0x38/0x5c)
[ 86.291466] [<80101058>] (sys_ioctl+0x38/0x5c) from [<8003ef80>] (ret_fast_syscall+0x0/0x30)
Hi Qiang,
We applied  patch for our bsp Patch to support uboot logo keep from uboot to kernel for NXP Linux and Android BSP (HDMI, LCD and L...   0001-Fix-the-split-mode-LVDS-panel-no-TX3-signal-issue.patch L4.1.15_GA1.2.0_uboot_logo_keep_patch_2017-01-06.zip
Once enable LVDS_SPLIT_MODE in mx6sabre_common.h, LCD seems just display half(see below photo), if Disable LVDS_SPLIT_MODE, it seems display OK.
Linux Kernel use [ fsl,data-mapping = "spwg"], it display correct.
 Dear Frank:
I faced the same issue as you. can you show me which two pins ? thank you very much!
Dear Qiang Li:
   I have some problem when display logo in uboot. Would you give me some advise.
Our designs is based on mx6sabresd board but use IMX6QP,LCD pabel is connect to LVDS0.
I patched M6.0.1_2.1.0-GA UBoot with 0001-Enable-uboot-logo-for-HDMI-LCD-and-LVDS.patch, and port mx6sabre_common.h according the panel(1024*600, RGB888, lvds) which info is attached below.
port code is as below:
#ifdef CONFIG_UBOOT_LOGO_ENABLE
    /*#define IPU_OUTPUT_MODE_HDMI*/
    /*#define IPU_OUTPUT_MODE_LCD*/
#ifdef IPU_OUTPUT_MODE_LVDS
    /* For LVDS, 1024*600 resolution */
    #define DISPLAY_WIDTH    1024
    #define DISPLAY_HEIGHT    600
    #define DISPLAY_IF_BPP    24  /* RGB888 interface */
    #define DISPLAY_HSYNC_START    220
    #define DISPLAY_HSYNC_END    40
    #define DISPLAY_HSYNC_WIDTH    60
    #define DISPLAY_VSYNC_START    20
    #define DISPLAY_VSYNC_END    5
    #define DISPLAY_PIX_CLOCK    51200000  /*(DISPLAY_HSYNC_START + DISPLAY_HSYNC_END + DISPLAY_HSYNC_WIDTH + DISPLAY_WIDTH) * (DISPLAY_VSYNC_START + DISPLAY_VSYNC_END + DISPLAY_VSYNC_WIDTH + DISPLAY_HEIGHT) * refresh rate (60Hz) */
    #define IPU_NUM            1  /* 1 for IPU1, 2 for IPU2. */
    #define DI_NUM            0  /* 0 for DI0, 1 for DI1. */
    #define LVDS_PORT        0  /* 0 for LVDS0, 1 for LVDS1. */
    #define DI_CLOCK_EXTERNAL_MODE  /* When clock external mode was defined, the DI clock root will be PLL3 PFD1, without this macro, the DI root clock is IPU internal clock. */
But LCD panel display nothing in uboot. which can display correct when android run.
I measured the LVDS signal, LVDS0_TX2,LVDS0_TX3,LVDS0_CLK have wave,but LVDS0_TX0 & LVDS0_TX1 no wave, always a straight line.
@Qiang Canyou give me some advise?
Thanks & BR!
Is this patch available for the Android N7.1.2_2.0.0 BSP?
為什麼我用uboot2017.3月的打上補丁,有很多錯誤,用的是哪個版本的uboot.有源碼嗎
uboot 2017.3需要自行移植patch,无法直接使用的。
我查看了l4.1.15.1.2.0 BSP裡面的uboot,裡面,也沒找到 BM_ANADIG_PLL_VIDEO_TEST_DIV_SELECT這個宏的定義。
請問,這個patch是基於uboot2015.4月這個版本嗎? 或者還要加上其他頭文件嗎?
Patch is based on the released BSP L4.1.15.1.2.0, the uboot is based on v2015.04 + NXP uboot patches. It is not the default v2015.04 Uboot.
The macro "BM_ANADIG_PLL_VIDEO_TEST_DIV_SELECT" is in arch/arm/include/asm/arch-mx6/crm_regs.h.
If you are using the default v2015.04 Uboot without NXP codes, you can't find this file and macro.
thanks,i have found the code.
你好,我按照您的文檔,改了以後,現在我遇到了一個問題,我的LCD,上下左右,的顯示是倒置的,我嘗試改了
#define DISPLAY_CLOCK_POLARITY 1
這些參數,但是並沒有效果,我想問下,決定屏幕顯示方向的應該修改哪些?
To:
您好,請問,LCD顯示方向,除了跟如下參數有關,還跟什麼有關係?
#define DISPLAY_VSYNC_POLARITY 1
#define DISPLAY_HSYNC_POLARITY 1
#define DISPLAY_DATA_ENABLE_POLARITY 0
合肥極友軟件開発有限公司
JiYou Software Development Co., Ltd.张湃
差出人: Qiang_FSL
送信日時: 2019年5月14日 10:06
宛先: pai zhang <zhangpai@jiyou-soft.com>
件名: Re: - Patch to support uboot logo keep from uboot to kernel for NXP Linux and Android BSP (HDMI, LCD and LVDS)
<https://community.freescale.com/resources/statics/1000/35400-NXP-Community-Email-banner-600x75.jpg> NXP Community
new comment by Qiang Li - Mpu Se <https://community.nxp.com/people/Qiang_FSL?et=watches.email.document_comment> View all comments on this document <https://community.nxp.com/docs/DOC-98109?commentID=65323&et=watches.email.document_comment#comment-65323>
Hi pai zhang, 屏的显示方向是屏本身决定的,不是软件设置的。你的问题,应该是屏的方向物理上弄反掉了。
你好,我這uboot logo可以持續顯示到內核了,現在有個問題,不知道怎麼解決
在Starting Xserver,啟動瞬間閃屏一下,是什麼原因導致的?  哪裡配置的不對嗎??
Dear Qiang Li - Mpu Se,
We have an issue with this patch on the imx6 solo; it would seem the ipu or ldb is still reset somewhere in Linux.
We tried to fix it but the display is flickers on boot, which is not acceptable to our customer.
I made a post here https://community.nxp.com/message/1159480
If you could take a look it would be greatly appreciated.
support imx6ul plat?
iMX6UL has no IPU, so the patch can't support it.
hi qiang
   我使用您提供的linux-4.1.15的patch,可以成功的实现logo keep,但是我换成linux-4.9.11的时候,在uboot启动阶段是正常的,进入内核logo就消失了,但是GUI用户程序是可以正常显示的,我修改内核是您的基于linux-4.1.15的patch, 请问,在内核中修改的时候,主要是那几个关键点呢?
主要是相关的clock和IPU DI要避免被重新初始化。
arm-supply和soc-supplay这两个供电节点有影响吗?
clk-imx6q.c的差别比较大。我直接按照4.1的版本修改的,还是进入内核会消失,;
di选择根Uboot一样,ipu部分的代码,我做了比较,4.9和4.1也没有明显的差别.
您尝试过4.9.11的版本吗?
Hi liang yan, no patch for 4.9 and later version kernel, but for debug, you can use "while(1)" dead loop step by step to identify which code modification caused the dsplay disappeared.
HI qiang
   谢谢您的帮助,我在linux-4.9.11的内核上也成功可以保持开机logo了。
Hi Liang,
 do you mind to share the patch for 4.9? Thanks
Hi Qiang Li,
       We are using a board based on Sabresd but using iMX6QP. Managed to get the uboot screen logo until kernel but just during the kernel initialisation there is a blank for a fraction of second along with slight shift of the logo to the right. I disabled PRE/PRG but even then the issue persists. Can you provide your kind help on this. Thanks
4.9内核中的clk-imx6q.c中注释掉init_ipu_clk(),其他的根Qiang Li提供的patch的修改是一样的。
I am not able to download the patches ? Are they not active now ?
Pls advice where can I download patches? The ones attached to the topic are removed
Hi liang yan,
    Thanks for your help. I just want to clarify the init_ipu_clk function should be commented or not.
Hello, I want to implement the uboot-2014 partial startup logo, but there is no driver. I found this post by searching and found that you have issued several patches, but they have failed. Can you please send me a copy? thank you very much!
谢谢!
Does the patch work for iMX8M?
No, it is based on IPU hardware which is used on iMX6Solo,6DL,6D,6Q.
hi 强
请教一个关于IPU的问题,我现在这个的色彩空间模式是RGB->RGB, 不使能CSC的功能,在驱动上有修改提高色彩对比的可能性吗?
不能,只有做CSC的时候,才能通过调整系数矩阵的参数来进行处理。
我加了一些log 如下: 我感觉现在就是RGB->RGB, 您帮我看一下,我找了一个imx_csc.c的工具,它是yuv->rgb, 我实验了一下,颜色全部失真了。
我驱动用的lvds RGB24的显示接口, 有啥问题,请帮我指正一下:
Booting Linux on physical CPU 0x0
Linux version 4.9.11-g878147e-dirty (yanl1229@ThinkPad-T470) (gcc version 6.2.0 (GCC) ) #23 SMP PREEMPT Wed Jul 29 13:06:20 CST 2020
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
OF: fdt:Machine model: Freescale i.MX6 DualLite SABRE Smart Device Board
Reserved memory: created CMA memory pool at 0x3c000000, size 320 MiB
OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
Memory policy: Data cache writealloc
On node 0 totalpages: 262144
free_area_init_node: node 0, pgdat 80b69fc0, node_mem_map ab757000
Normal zone: 2048 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 262144 pages, LIFO batch:31
percpu: Embedded 12 pages/cpu @ab720000 s25868 r0 d23284 u49152
pcpu-alloc: s25868 r0 d23284 u49152 alloc=12*4096
pcpu-alloc: [0] 0 [0] 1
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096
Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk3p2 rootwait rw video=mxcfb0:dev=ldb,LDB-WXGA,if=RGB24,bpp=32 ldb=sin0 video=mxcfb1:off
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 699872K/1048576K available (7168K kernel code, 427K rwdata, 1668K rodata, 1024K init, 425K bss, 21024K reserved, 327680K cma-reserved, 0K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xc0800000 - 0xff800000 (1008 MB)
lowmem : 0x80000000 - 0xc0000000 (1024 MB)
pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
.text : 0x80008000 - 0x80800000 (8160 kB)
.init : 0x80a00000 - 0x80b00000 (1024 kB)
.data : 0x80b00000 - 0x80b6ad40 ( 428 kB)
.bss : 0x80b6c000 - 0x80bd651c ( 426 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Preemptible hierarchical RCU implementation.
Build-time adjustment of leaf fanout to 32.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
L2C: DT/platform modifies aux control register: 0x32050000 -> 0x32450000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 16 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 16 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76450001
Switching to timer-based delay loop, resolution 333ns
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
Console: colour dummy device 80x30
Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x10100000 - 0x10100058
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (12.00 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor menu
CPU identified as i.MX6DL, silicon rev 1.3
vddarm: bypassed regulator has no supply!
vddarm: failed to get the current voltage(-517)
vddsoc: bypassed regulator has no supply!
vddsoc: failed to get the current voltage(-517)
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
imx6dl-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
imx-gpc 20dc000.gpc: pu regulator not ready, retry
mxs-dma 110000.dma-apbh: initialized
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
2000000.aips-bus:usbphy_nop1 supply vcc not found, using dummy regulator
2000000.aips-bus:usbphy_nop2 supply vcc not found, using dummy regulator
i2c i2c-1: IMX I2C adapter registered
i2c i2c-1: can't use DMA, using PIO instead.
i2c i2c-2: IMX I2C adapter registered
i2c i2c-2: can't use DMA, using PIO instead.
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
imx-ipuv3 2400000.ipu: <ipu_probe>
imx-ipuv3 2400000.ipu: revision is IPUv3H
imx-ipuv3 2400000.ipu: IPU CM Regs = c0811000
imx-ipuv3 2400000.ipu: IPU IC Regs = c081d000
imx-ipuv3 2400000.ipu: IPU IDMAC Regs = c0841000
imx-ipuv3 2400000.ipu: IPU DP Regs = c0849000
imx-ipuv3 2400000.ipu: IPU DC Regs = c0851000
imx-ipuv3 2400000.ipu: IPU DMFC Regs = c0859000
imx-ipuv3 2400000.ipu: IPU DI0 Regs = c0861000
imx-ipuv3 2400000.ipu: IPU DI1 Regs = c0869000
imx-ipuv3 2400000.ipu: IPU SMFC Regs = c0871000
imx-ipuv3 2400000.ipu: IPU CSI0 Regs = c0879000
imx-ipuv3 2400000.ipu: IPU CSI1 Regs = c0881000
imx-ipuv3 2400000.ipu: IPU CPMem = c08a0000
imx-ipuv3 2400000.ipu: IPU TPMem = c08d0000
imx-ipuv3 2400000.ipu: IPU DC Template Mem = c0900000
imx-ipuv3 2400000.ipu: IPU VDI Regs = c0883000
imx-ipuv3 2400000.ipu: ipu_clk = 270000000
ipu_di0 read BS_CLKGEN0 div:16, final_rate:4320000000, prate:270000000
ipu_di1 read BS_CLKGEN0 div:0, final_rate:4320000000, prate:270000000
ipu_task_thread: sched_setaffinity cpu:0.
clocksource: Switched to clocksource mxc_timer1
VFS: Disk quotas dquot_6.6.0
VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
Bus freq driver module loaded
futex hash table entries: 512 (order: 3, 32768 bytes)
workingset: timestamp_bits=30 max_order=18 bucket_order=0
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
fuse init (API version 7.26)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
imx-weim 21b8000.weim: Driver registered.
backlight supply power not found, using dummy regulator
mxc_sdc_fb fb@0: registered mxc display driver ldb
imx-ipuv3 2400000.ipu: Channel already disabled 9
imx-ipuv3 2400000.ipu: Channel already uninitialized 9
imx-ipuv3 2400000.ipu: init channel = 9
imx-ipuv3 2400000.ipu: ipu busfreq high requst.
imx-ipuv3 2400000.ipu: bg_csc_type: 2, fg_csc_type: 0
imx-ipuv3 2400000.ipu: panel size = 1280 x 800
imx-ipuv3 2400000.ipu: pixel clk = 74002000
imx-ipuv3 2400000.ipu: use special clk parent
ipu_di0 read BS_CLKGEN0 div:16, final_rate:1206857136, prate:75428571
ipu_pixel_clk: di_clk_ext:0x0, di_gen reg:0x300000.
imx-ipuv3 2400000.ipu: round pixel clk:75428571
imx-ipuv3 2400000.ipu: div:1
imx-ipuv3 2400000.ipu: initializing idma ch 23 @ c08a05c0
imx-ipuv3 2400000.ipu: initializing idma ch 23 @ c08a1140 sub cpmem
imx-ipuv3 2400000.ipu: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
imx-ipuv3 2400000.ipu: ch 23 word 0 - 00000000 00000000 00000000 E0000000 000C7C9F
imx-ipuv3 2400000.ipu: ch 23 word 1 - 07820000 00F04000 00E3C000 FFF4FFC0 00006208
imx-ipuv3 2400000.ipu: PFS 0x7,
imx-ipuv3 2400000.ipu: BPP 0x0,
imx-ipuv3 2400000.ipu: NPB 0xf
imx-ipuv3 2400000.ipu: FW 1279,
imx-ipuv3 2400000.ipu: FH 799,
imx-ipuv3 2400000.ipu: EBA0 0x3c100000
imx-ipuv3 2400000.ipu: EBA1 0x3c100000
imx-ipuv3 2400000.ipu: Stride 5119
imx-ipuv3 2400000.ipu: scan_order 0
imx-ipuv3 2400000.ipu: uv_stride 8712
imx-ipuv3 2400000.ipu: u_offset 0x0
imx-ipuv3 2400000.ipu: v_offset 0x0
imx-ipuv3 2400000.ipu: Width0 7+1,
imx-ipuv3 2400000.ipu: Width1 7+1,
imx-ipuv3 2400000.ipu: Width2 7+1,
imx-ipuv3 2400000.ipu: Width3 7+1,
imx-ipuv3 2400000.ipu: Offset0 8,
imx-ipuv3 2400000.ipu: Offset1 16,
imx-ipuv3 2400000.ipu: Offset2 24,
imx-ipuv3 2400000.ipu: Offset3 0
imx-ipuv3 2400000.ipu: Channel already disabled 10
imx-ipuv3 2400000.ipu: Channel already uninitialized 10
imx-sdma 20ec000.sdma: no iram assigned, using external mem
imx-sdma 20ec000.sdma: loaded firmware 3.3
pfuze100-regulator 1-0008: Full layer: 2, Metal layer: 1
pfuze100-regulator 1-0008: FAB: 0, FIN: 0
pfuze100-regulator 1-0008: pfuze100 found.
vddpu: supplied by SW1C
usb_otg_vbus: supplied by SWBST
usb_h1_vbus: supplied by SWBST
2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 24, base_baud = 5000000) is a IMX
console [ttymxc0] enabled
[drm] Initialized
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
libphy: Fixed MDIO Bus: probed
2188000.ethernet supply phy not found, using dummy regulator
pps pps0: new PPS source ptp0
fec 2188000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
fec 2188000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: be:80:00:a2:6b:07
libphy: fec_enet_mii_bus: probed
fec 2188000.ethernet eth0: registered PHC device 0
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-mxc: Freescale On-Chip EHCI Host driver
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usb_ehset_test
2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
file system registered
mousedev: PS/2 mouse device common for all mice
rtc-ds3231 2-0068: Frequency stop was detected
rtc-ds3231 2-0068: IRQ 110 supplied
rtc-ds3231 2-0068: rtc core: registered ds3231 as rtc0
i2c /dev entries driver
IR NEC protocol handler initialized
mxc_v4l2_output v4l2_out: V4L2 device registered as video16
mxc_v4l2_output v4l2_out: V4L2 device registered as video17
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
gspca_main: v2.14.0 registered
imx2-wdt 20c0000.wdog: timeout 60 sec (nowayout=0)
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
sdhci-esdhc-imx 2198000.usdhc: Got CD GPIO
mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
mmc3: SDHCI controller on 219c000.usdhc [219c000.usdhc] using ADMA
mxc_vdoa 21e4000.vdoa: iram_base:0xc0820000,iram_paddr:0x905000,size:0x12000
mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
caam 2100000.caam: ERA source: CAAMVID.
caam 2100000.caam: AXI pipeline throttling enabled.
caam 2100000.caam: Entropy delay = 3200
caam 2100000.caam: Instantiated RNG4 SH0
mmc3: new DDR MMC card at address 0001
usb 1-1: new high-speed USB device number 2 using ci_hdrc
mmcblk3: mmc3:0001 DG4008 7.28 GiB
mmcblk3boot0: mmc3:0001 DG4008 partition 1 4.00 MiB
mmcblk3boot1: mmc3:0001 DG4008 partition 2 4.00 MiB
caam 2100000.caam: Instantiated RNG4 SH1
caam 2100000.caam: device ID = 0x0a16010000000100 (Era 4)
mmcblk3rpmb: mmc3:0001 DG4008 partition 3 4.00 MiB
mmcblk3: p1 p2
caam 2100000.caam: job rings = 2, qi = 0
caam algorithms registered in /proc/crypto
caam_jr 2101000.jr0: registering rng-caam
snvs-secvio 20cc000.caam-snvs: can't get snvs clock
snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
NET: Registered protocol family 26
NET: Registered protocol family 10
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
NET: Registered protocol family 17
Key type dns_resolver registered
hub 1-1:1.0: USB hub found
cpu cpu0: regulators not ready, retry
hub 1-1:1.0: 4 ports detected
random: fast init done
imx_epdc_fb 20f4000.epdc: can't get/select pinctrl
vddarm: supplied by SW1AB
vddsoc: supplied by SW1C
imx-gpc 20dc000.gpc: Registered imx-gpc
mxc_vpu 2040000.vpu_fsl: VPU initialized
galcore: clk_get vg clock failed, disable vg!
Galcore version 6.2.2.93313
cpu cpu0: Registered imx6q-cpufreq
imx_thermal 2000000.aips-bus:tempmon: Extended Commercial CPU temperature grade - max:105C critical:100C passive:95C
rtc-ds3231 2-0068: setting system clock to 2020-07-29 04:57:31 UTC (1595998651)
usb_otg_vbus: disabling
hdmi-5v-supply: disabling
CAN XCVR: disabling
SATA_EN: disabling
wifi_pwr_on: disabling
SW4: disabling
EXT4-fs (mmcblk3p2): couldn't mount as ext3 due to feature incompatibilities
EXT4-fs (mmcblk3p2): couldn't mount as ext2 due to feature incompatibilities
EXT4-fs (mmcblk3p2): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 179:34.
devtmpfs: mounted
Freeing unused kernel memory: 1024K (80a00000 - 80b00000)
udevd[203]: starting version 3.2
udevd[204]: starting eudev-3.2
EXT4-fs (mmcblk3p2): re-mounted. Opts: data=ordered
Generic PHY 2188000.ethernet:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=2188000.ethernet:01, irq=-1)
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
mxc_v4l2_output v4l2_out: Bypass IC.
imx-ipuv3 2400000.ipu: init channel = 10
imx-ipuv3 2400000.ipu: bg_csc_type: 2, fg_csc_type: 2
imx-ipuv3 2400000.ipu: initializing idma ch 27 @ c08a06c0
imx-ipuv3 2400000.ipu: initializing idma ch 27 @ c08a1180 sub cpmem
imx-ipuv3 2400000.ipu: ch 27 word 0 - 00000000 00000000 00000000 E0001800 000C7C9F
imx-ipuv3 2400000.ipu: ch 27 word 1 - 08DA0000 011B4000 00E7C000 F2C27FC0 00082CA0
imx-ipuv3 2400000.ipu: BPP 0x3,
imx-ipuv3 2400000.ipu: NPB 0x1f
imx-ipuv3 2400000.ipu: EBA0 0x46d00000
imx-ipuv3 2400000.ipu: EBA1 0x46d00000
imx-ipuv3 2400000.ipu: Stride 2559
imx-ipuv3 2400000.ipu: uv_stride 11424
imx-ipuv3 2400000.ipu: Width0 4+1,
imx-ipuv3 2400000.ipu: Width1 5+1,
imx-ipuv3 2400000.ipu: Width2 4+1,
imx-ipuv3 2400000.ipu: Offset0 0,
imx-ipuv3 2400000.ipu: Offset1 5,
imx-ipuv3 2400000.ipu: Offset2 11,
imx-ipuv3 2400000.ipu: Offset3 16
imx-ipuv3 2400000.ipu: DC stop timeout - 1 * 10ms
imx-ipuv3 2400000.ipu: ipu busfreq high release.
imx-ipuv3 2400000.ipu: bg_csc_type: 2, fg_csc_type: 4
imx-ipuv3 2400000.ipu: DMFC high resolution has set, will not change
imx-ipuv3 2400000.ipu: ch 23 word 1 - 08980000 01130000 00E3C000 FFF4FFC0 00006208
imx-ipuv3 2400000.ipu: EBA0 0x44c00000
imx-ipuv3 2400000.ipu: EBA1 0x44c00000
root@imx6dlsabresd:~# random: crng init done
如果你要用yuv->rgb,那么要求你的上层往framebuffer里面画内容的时候,要画成YUV格式,这个要求对UI来讲是不行,一般都是用于Video播放的时候,此时overlay是YUV格式的,解出的YUV420 video数据直接画到overlay里面,然后overlay就可以做yuv->rgb的CSC。
恩,谢谢,上层应用的Qt程序是不能修改格式的,这种情况下,看来想自己增强对比度是不可能了,现在本身就是RGB的,
我想请教一下,驱动中的默认输出的对比度是多少呢,是不是也是有一个控制器在控制。
默认输出就是原始的RGB数据,上层应用画的什么RGB数据,输出就是什么,没有任何数据变换。
谢谢您,明白了
%3CLINGO-SUB%20id%3D%22lingo-sub-1120770%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPatch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120770%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20patch%20made%20the%20display%20no%20interrupt%20from%20uboot%20to%20kernel%20to%20Android.%20The%20IPU%20and%20related%20hardware%20display%20interface%20will%20only%20be%20initialized%20once%20in%20Uboot%2C%20the%20kernel%20code%20will%20skip%20the%20IPU%20initialization.%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E1.%20Description%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%201)%20Support%20HDMI%2C%20LVDS%20and%20LCD%20output%20in%20UBoot.%20%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%202)%20Support%20UBoot%20logo%20keep%20from%20uboot%20to%20kernel%20to%20Android.%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%203)%20For%20HDMI%2C%20both%20720P%20and%201080P%20mode%20were%20supported.%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%204)%20For%20LVDS%2C%201024x768%20and%201080P%20dual%20channel%20panels%20were%20supported.%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%205)%20The%20logo%20file%20is%20a%2032%20bpp%20bmp%20file.%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E2.%20File%20List%3CBR%20%2F%3E--%20kernel_imx%5C0001-Keep-uboot-logo-for-Android-boot-supports-HDMI-LCD-a.patch%3C%2FP%3E%3CP%3E--%20kernel_imx%5C0002-Bug-fix-for-uboot-logo-keep-patch.patch%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%20Kernel%20patch%20to%20support%20the%20logo%20keep%20feature.%3C%2FP%3E%3CP%3E--%20uboot-imx%5C0001-Enable-uboot-logo-for-HDMI-LCD-and-LVDS.patch%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%20Uboot%20patch%20to%20support%20the%20logo%20display.%3C%2FP%3E%3CP%3E--%20logo.bmp%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%20Example%2032bpp%20logo%20file.%3C%2FP%3E%3CP%3E--%20readme.txt%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%20this%20file%2C%20please%20refer%20to%20it%20before%20use%20the%20patches%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E3.%20Requirement%3C%2FP%3E%3CP%3E-%20iMX6%20SabreSD%20board.%3C%2FP%3E%3CP%3E-%20Android%20JB4.2.2_1.1.0-GA%20UBoot%20and%20kernel.%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E4.%20How%20to%20use%3C%2FP%3E%3CP%3E--%20Copy%20the%20two%20patch%20files%20to%20Android%20kernel_imx%20and%20uboot-imx%20folder%20and%20apply%20them.%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20cd%20~%2Fmyandroid%2Fkernel_imx%2F%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20git%20apply%20.%2F0001-Keep-uboot-logo-for-Android-boot-supports-HDMI-LCD-a.patch%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20cd%20~%2Fmyandroid%2Fbootable%2Fbootloader%2Fuboot-imx%2F%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20git%20apply%20.%2F0001-Enable-uboot-logo-for-HDMI-LCD-and-LVDS.patch%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20git%20apply%20.%2F0002-Bug-fix-for-uboot-logo-keep-patch.patch%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E--%20Build%20the%20new%20uboot%20image%3A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20cd%20~%2Fmyandroid%2Fbootable%2Fbootloader%2Fuboot-imx%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20export%20CROSS_COMPILE%3D~%2Fmyandroid%2Fprebuilt%2Fgcc%2Flinux-x86%2Farm%2Farm-eabi-4.6%2Fbin%2Farm-eabi-%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20export%20ARCH%3Darm%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20make%20mx6q_sabresd_android_config%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20make%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E--%20Before%20build%20new%20UBoot%20image%2C%20the%20display%20type%20can%20be%20selected%20from%20file%20uboot-imx%5Cinclude%5Cconfigs%5Cmx6q_sabresd.h%3CBR%20%2F%3E%2F%2F%20Select%20one%20of%20the%20output%20mode%3CBR%20%2F%3E%23define%20IPU_OUTPUT_MODE_HDMI%3CBR%20%2F%3E%2F%2F%23define%20IPU_OUTPUT_MODE_LVDS%3CBR%20%2F%3E%2F%2F%23define%20IPU_OUTPUT_MODE_LCD%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E--%20Build%20the%20new%20kernel%20image%3A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20cd%20~%2Fmyandroid%2Fkernel_imx%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20export%20CROSS_COMPILE%3D~%2Fmyandroid%2Fprebuilt%2Fgcc%2Flinux-x86%2Farm%2Farm-eabi-4.6%2Fbin%2Farm-eabi-%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20export%20ARCH%3Darm%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20make%20imx6_android_defconfig%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20make%20uImage%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E--%20Before%20%22make%20uImage%22%2C%20make%20menuconfig%20can%20be%20used%20to%20select%20the%20display%20type.%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20System%20Type%26nbsp%3B%20---%26gt%3B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Freescale%20MXC%20Implementations%26nbsp%3B%20---%26gt%3B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6%20clk%20setting%20for%20smooth%20UI%20transtion%20from%20bootloader%20to%20kernel%26nbsp%3B%20---%26gt%3B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Select%20Display%20Interface%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20(%20)%26nbsp%3B%20Smooth%20UI%20transtion%20on%20LCD%2C%20IPU1%2C%20DI0%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20(%20)%26nbsp%3B%20Smooth%20UI%20transtion%20on%20LVDS%2C%20IPU1%2C%20DI1%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20(X)%26nbsp%3B%20Smooth%20UI%20transtion%20on%20HDMI%2C%20IPU2%2C%20DI0%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E--%20Uboot%20parameters%20for%20video%20mode%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%201080P%20HDMI%3A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%22video%3Dmxcfb0%3Adev%3Dhdmi%2C1920x1080M%4060%2Cif%3DRGB24%2Cbpp%3D32%20fb0base%3D0x27b00000%20fbmem%3D28M%20hdmi_audio_clk%3D148500000%22%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20720P%20HDMI%3A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%22video%3Dmxcfb0%3Adev%3Dhdmi%2C1920x1080M%4060%2Cif%3DRGB24%2Cbpp%3D32%20fb0base%3D0x27b00000%20fbmem%3D28M%20hdmi_audio_clk%3D74250000%22%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%201024x768%20LVDS%3A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%22video%3Dmxcfb0%3Adev%3Dldb%2CLDB-XGA%2Cif%3DRGB666%2Cbpp%3D32%20fb0base%3D0x27b00000%20fbmem%3D28M%22%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20800x480%20LCD%3A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%22video%3Dmxcfb0%3Adev%3Dlcd%2CCLAA-WVGA%2Cif%3DRGB565%2Cbpp%3D32%20fb0base%3D0x27b00000%20fbmem%3D28M%22%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E--%20dd%20the%20logo.bmp%20to%20SD%20card%20address%200x100000%20and%20skip%20the%2054%20bytes%20bmp%20file%20header.%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%20sudo%20dd%20if%3Dlogo.bmp%20of%3D%2Fdev%2Fsdc%20bs%3D1%20seek%3D1048576%20skip%3D54%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E5.%20Note%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%201)%20The%20logo.bmp%20file%20should%20be%2032bpp%20or%2016bpp%2C%20and%20it%20should%20be%20synced%20with%20video%20mode%20parameters%20%22bpp%3Dxx%22%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20and%20uboot%20config%20file%20mx6q_sabresd.h%20(%23define%20DISPLAY_BPP%26nbsp%3B%20xx).%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%202)%20The%20IPU%20number%20and%20DI%20number%20are%20hard%20coded%20in%20kernel%20file%20%22board-mx6q_sabresd.c%22.%3CBR%20%2F%3Estatic%20struct%20fsl_mxc_hdmi_core_platform_data%20hdmi_core_data%20%3D%20%7B%3CBR%20%2F%3E%26nbsp%3B%20.ipu_id%20%3D%201%2C%3CBR%20%2F%3E%26nbsp%3B%20.disp_id%20%3D%200%2C%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%3CP%3Estatic%20struct%20fsl_mxc_lcd_platform_data%20lcdif_data%20%3D%20%7B%3CBR%20%2F%3E%26nbsp%3B%20.ipu_id%20%3D%200%2C%3CBR%20%2F%3E%26nbsp%3B%20.disp_id%20%3D%200%2C%3CBR%20%2F%3E%26nbsp%3B%20.default_ifmt%20%3D%20IPU_PIX_FMT_RGB565%2C%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%3CP%3Estatic%20struct%20fsl_mxc_ldb_platform_data%20ldb_data%20%3D%20%7B%3CBR%20%2F%3E%26nbsp%3B%20.ipu_id%20%3D%200%2C%3CBR%20%2F%3E%26nbsp%3B%20.disp_id%20%3D%201%2C%3CBR%20%2F%3E%26nbsp%3B%20.ext_ref%20%3D%201%2C%3CBR%20%2F%3E%26nbsp%3B%20.mode%20%3D%20LDB_SEP1%2C%3CBR%20%2F%3E%26nbsp%3B%20.sec_ipu_id%20%3D%200%2C%3CBR%20%2F%3E%26nbsp%3B%20.sec_disp_id%20%3D%200%2C%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%203)%20The%20IPU%20number%20and%20DI%20number%20are%20defined%20by%20Macro%20in%20Uboot%20file%20%22include%5Cconfigs%5Cmx6q_sabresd.h%22%3CBR%20%2F%3E%23define%20IPU_NUM%26nbsp%3B%26nbsp%3B%202%26nbsp%3B%20%2F%2F%201%20for%20IPU1%2C%202%20for%20IPU2.%3CBR%20%2F%3E%23define%20DI_NUM%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%20%2F%2F%200%20for%20DI0%2C%201%20for%20DI1.%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%204)%20The%20display%20type%20used%20in%20uboot%20and%20kernel%20must%20be%20same%2C%20same%20type%2C%20same%20IPU%20number%2C%20same%20DI%20port%20and%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20same%20resolution.%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B2015-06-29%20Update%5D%3A%20JB4.2.2_1.1.0_uboot_logo_keep_patch_2015-06-29.zip%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EFix%20some%20LVDS%20issues%20for%20iMX6DL.%3C%2FP%3E%3CP%3EAlso%20given%20an%20example%20for%20LVDS0%20with%20DI0.%3C%2FP%3E%3CP%3ENew%20Uboot%20patches%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200002-Updated-lvds-clock-source-to-pll2_pfd0.-Same-as-kern.patch%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200003-Add-support-for-iMX6DL.patch%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3ENew%20kernel%20patches%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200003-Skip-lvds-re-initialization-for-logo-keep.patch%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200004-Add-examlpe-for-LVDS0-logo-keep.patch%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B2015-08-07%20Update%5D%3A%20JB4.2.2_1.1.0_uboot_logo_keep_patch_2015-08-07.zip%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EAdded%20the%20new%20Uboot%20patch%200004-Correct-the-sequence-to-set-LDB-clock.patch%3C%2FP%3E%3CP%3EIt%20can%20correct%20the%20LVDS%20clock%20set%20sequence%20whch%20is%20a%20known%20issue%20that%20caused%20no%20LVDS%20display%20sometimes.%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B2015-09-18%20Update%5D%3A%20JB4.3_1.1.1_uboot_logo_keep_patch_2015-09-18.zip%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EAdded%20the%20patch%20for%20Android%20JB4.3_GA1.1.1%20release.%3C%2FP%3E%3CP%3EUpdated%20clock%20usecount%2C%20after%20blank%20the%20display%2C%20the%20related%20clock%20can%20be%20gated%20off%20correctly.%3C%2FP%3E%3CP%3ESupport%20LVDS%20clock%20from%20PLL5.%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B2015-12-21%20Update%5D%3A%20Added%203.10.53_GA1.1.0%20patch%3A%20L3.10.53_GA1.1.0_uboot_logo_keep_patch_2015-12-21.zip.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EVerified%20on%20iMX6DL%2FQ%20SabreSD%20board.%20It%20supports%20LCD%20and%20LVDS%20panels%2C%20HDMI%20patch%20will%20be%20released%20later.%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B2016-01-04%20Update%5D%3A%20Added%203.10.53_GA1.1.0%20patch%3A%20L3.10.53_GA1.1.0_uboot_logo_keep_patch_2016-01-04.zip.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EAdded%20HDMI%20display%20support.%20Now%20it%20supports%20LCD%2C%20LVDS%20and%20HDMI%20displays.%3C%2FP%3E%3CP%3EFixed%20the%20video%20playback%20issue%20for%20boot%20up.%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B2016-05-18%20Update%5D%3A%200001-Fix-the-split-mode-LVDS-panel-no-TX3-signal-issue.patch%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EAn%20issue%20was%20founded%2C%20when%20dual%20channel%204%20lanes%20LVDS%20panel%20was%20used%2C%20in%20uboot%20there%20will%20be%20no%20LVDS%20TX3%20signa%20on%20one%20LVDS%20port%2C%20the%20attach%20%220001-Fix-the-split-mode-LVDS-panel-no-TX3-signal-issue.patch%22%20was%20used%20to%20fix%20this%20issue%2C%20it%20is%20based%20on%20JB4.3_1.1.1_uboot_logo_keep_patch_2015-09-18.zip%2C%20for%20other%20BSP%2C%20please%20port%20it%20manually.%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B2016-08-29%20Update%5D%3A%200001-After-reset-IPU-in-SRC-Control-Register-wait-for-res.patch%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EOn%20some%20iMX6%20chip%2C%20after%20reset%20the%20IPU%20in%20SRC%20Control%20Register%2C%20enable%20IPU%20at%20once%20will%20cause%20system%20hang%20up%2C%20to%20avoid%20such%20issue%2C%20software%20needs%20wait%20for%20IPU%20reset%20done%20by%20polling%20the%20SRC%20register.%3C%2FP%3E%3CP%3EThe%20attach%20%220001-After-reset-IPU-in-SRC-Control-Register-wait-for-res.patch%22%20was%20used%20to%20fix%20this%20issue%2C%20it%20is%20based%20on%20JB4.3_1.1.1_uboot_logo_keep_patch_2015-09-18.zip%20%2B%20%220001-Fix-the-split-mode-LVDS-panel-no-TX3-signal-issue.patch%22%2C%20for%20other%20BSP%2C%20please%20port%20it%20manually.%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%20min-height%3A%208pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B2017-01-06%20Update%5D%20Added%20patch%20for%20L4.1.15_GA1.2.0%20BSP%20and%20Android%20M6.0.1_GA2.1.0%20BSP.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EFiles%3A%20L4.1.15_GA1.2.0_uboot_logo_keep_patch_2017-01-06.zip%3B%20M6.0.1_2.1.0_uboot_logo_keep_patch_2017-01-06.zip%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1120770%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EGraphics%20%26amp%3B%20Display%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6DL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6S%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENo%2C%20it%20is%20based%20on%20IPU%20hardware%20which%20is%20used%20on%20iMX6Solo%2C6DL%2C6D%2C6Q.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDoes%20the%20patch%20work%20for%20iMX8M%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20your%20reply!%20%26nbsp%3BIf%20i%20don't%20use%20these%20patches%2Cmy%20board%20will%20be%20blank%20when%20kernel%20start-up%20and%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Ethe%20teminal%20console%20appear%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EMXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%26nbsp%3B%3C%2FSPAN%3Esometimes.%3C%2FP%3E%3CP%3EHow%20can%20i%20fix%20it%3F%3C%2FP%3E%3CP%3EIf%20i%20delete%20the%20ipu%20code%20in%20uboot%20and%20don't%20use%20patches%20%2Cit%20can%20be%20resolved%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120867%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120867%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20kernel%20patch%20can't%20support%20iMX6QP%2C%20iMX6QP%20has%20PRE%2FPRG%20hardware%2C%20which%20can't%20work%20with%20this%20patch.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F179116%22%20target%3D%22_blank%22%3E%40qiang%3C%2FA%3E%20Li%3C%2FP%3E%3CP%3E%26nbsp%3BThe%20path%20can%20be%20pathed%20to%20IMX6QP%20board.%20I%20have%20pathed%20the%20uboot%20and%20kernel%20patch.Uboot%20and%20Kernel%20%26nbsp%3Bcan%20display%20the%20same%20logo%20but%20when%20input%20android%20animation%20it's%20blank%20and%20the%20teminal%20console%20appear%26nbsp%3B%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EMXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120860%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120860%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3EHello%20ubootlogo%20can%20already%20be%20displayed%20on%20the%20screen%20I%20now%20want%20ubootlogo%20and%20kernellogo%20non-stop%20display%2C%20and%20now%20I%20hit%200001-Keep-uboot-logo-for-Linux-boot-supports-HDMI-LCD-and.patch%2C%20Kernel%20when%20the%20screen%20is%20black%20screen%2C%20how%20can%20I%20solve%3CBR%20%2F%3ELooking%20forward%20to%20your%20reply%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120859%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120859%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3EThank%20you%20logo%20is%20already%20on%20the%20screen%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120858%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120858%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F34784i174541E86A98CE57%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20alt%3D%22B12F0D1CF077978B703AEB6012E4E823.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EI%20will%20bmpReady%20%3D%200%3B%20uboot%20as%20shown%20above%20The%20question%20now%20is%20that%20I%20will%20bmpReady%20%3D%201uboot%20as%20a%20white%20screen%20dd%20if%20%3D%20logo.bmp%20of%20%3D%20%2F%20dev%20%2F%20mmcblk0p1%20bs%20%3D%201%20seek%20%3D%201048576%20skip%20%3D%2054%20write%20EMMC%2C%20the%20phenomenon%20is%20still%20Similarly%2C%20my%20understanding%20is%20that%20uboot%20did%20not%20find%20this%20picture%20bmp%2C%20I%20do%20not%20know%20the%20right%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120857%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120857%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ethank%20you%20for%20your%20reply%3CBR%20%2F%3EI've%20written%20logo.bmp%20into%20EMMC%2C%20but%20the%20uboot%20has%20not%20changed%20yet%3CBR%20%2F%3EI%20mean%20uboot%20is%20how%20to%20call%20emmc%20logo.bmp%20should%20not%20tell%20uboot%20address%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120855%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120855%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8C%26nbsp%3B%3C%2FP%3E%3CP%3EI%20finished%20patch%20now%20uboot%20is%20a%20white%20screen%20how%20I%20changed%3CBR%20%2F%3Esudo%20dd%20if%20%3D%20logo.bmp%20of%20%3D%20%2F%20dev%20%2F%20sdc%20bs%20%3D%201%20seek%20%3D%201048576%20skip%20%3D%2054%3CBR%20%2F%3EHow%20can%20I%20change%20if%20I%20change%20to%20another%20address%3F%3CBR%20%2F%3EThere%20should%20be%20a%20place%20to%20go%20back%20to%20read%20the%20memory%20bmp%20picture%2C%20where%20is%20his%20position%3CBR%20%2F%3ELooking%20forward%20to%20your%20reply%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120854%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120854%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHow%20do%20I%20understand%3C%2FP%3E%3CP%3Esudo%20dd%20if%20%3D%20logo.bmp%20of%20%3D%20%2F%20dev%20%2F%20sdc%20bs%20%3D%201%20seek%20%3D%201048576%20skip%20%3D%2054%3C%2FP%3E%3CP%3EIf%20I%20want%20to%20change%20to%20EMMC%20like%20how%20to%20amend%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120853%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120853%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWe%20will%20patch%20in%20L4.1.15_2.0.0_ga%20version%20yocto%20bsp.When%20I%20tried%20last%20patch%20will%20make%20system%20restart.%3C%2FP%3E%3CP%3Eis%20it%20possible%20to%20apply%20this%20L4.1.15_2.0.0_ga%20patches%20on%20yocto%20source%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20iMX6UL%20has%20no%20IPU%20hardware%2C%20so%20this%20patch%20will%20not%20work%20on%20it.%20%3C%2FP%3E%3CP%3EThe%20iMX6UL%20used%20LCDIF%2C%20it%20is%20a%26nbsp%3Bsimple%20display%20controller%2C%20you%20just%20need%20enable%20it%20in%20Uboot%20and%20avoid%20kernel%20re-initialize%20it.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%20Qiang%20%3C%2FP%3E%3CP%3EDo%26nbsp%3B%20you%20have%20the%20patch%20base%20on%20android%204.4.2%20version%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120815%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120815%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20a%20lot%20for%20the%20help%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20also%20removed%20bpp%3D%20in%20the%20bootargs%20and%20it%20is%20working%20well%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120813%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120813%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20LiQiang%2C%20when%20will%20you%20port%20this%20to%203.14.52%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120812%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120812%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPlease%20make%20sure%20you%20have%20the%20followed%20code%20modification%20in%20ipu_probe()%2C%20it%20is%20related%20to%20the%20color%20issue.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%40%40%20-357%2C7%20%2B370%2C12%20%40%40%20static%20int%20__devinit%20ipu_probe(struct%20platform_device%20*pdev)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%2F*%20Set%20MCU_T%20to%20divide%20MCU%20access%20window%20into%202%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20ipu_cm_write(ipu%2C%200x00400000L%20%7C%20(IPU_MCU_T_DEFAULT%20%26lt%3B%26lt%3B%2018)%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20IPU_DISP_GEN)%3B%3C%2FP%3E%3CP%3E%2B%23ifdef%20CONFIG_MX6_CLK_FOR_BOOTUI_TRANS%3C%2FP%3E%3CP%3E%2B%20%7D%20else%20%7B%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%20ipu-%26gt%3Bfg_csc_type%20%3D%20ipu-%26gt%3Bbg_csc_type%20%3D%20CSC_NONE%3B%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%20ipu-%26gt%3Bcolor_key_4rgb%20%3D%20true%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7D%3C%2FP%3E%3CP%3E%2B%23endif%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120811%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120811%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fqianli%22%20target%3D%22_blank%22%3Eqianli%3C%2FA%3E%E2%80%8B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20I%20have%20used%20your%20patch%20as%20base%20to%20keep%20splash%20logo%20on%20the%20LVDS%20(%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20Arial%2C%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2013.3333px%3B%22%3EI%20use%20dual%20channel%20split%20mode%20of%20LVDS%201920x720%20and%20D0%20)%20on%20Linux%26nbsp%3B%203.10.17%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20The%20splash%20logo%20is%20keep%20all%20time%20but%20when%20I%20tried%20to%20send%20an%20image%20to%20the%20fb0%20this%20image%20is%20shown%20with%20wrong%20colors%20and%20size%20%3CIMG%20id%3D%22smileysad%22%20class%3D%22emoticon%20emoticon-smileysad%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-sad.png%22%20alt%3D%22Smiley%20Sad%22%20title%3D%22Smiley%20Sad%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20I%20have%20noticed%20that%20If%20I%20enter%20%22echo%200%20%26gt%3B%20%2Fsys%2Fclass%2Fgraphics%2Ffb0%2Frotate%22%20before%20send%20image%20to%20fb0%20the%20splash%20logo%20is%20shown%20twice%20in%20different%20color%20but%20the%20image%20that%20I%20sent%20is%20showing%20correctly.%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Do%20you%20have%20any%20idea%20about%20how%20to%20solve%20this%20problem%3F%20I%20want%20to%20show%20my%20application%20image%20after%20the%20prompt%20is%20available%20without%20send%20%22echo%200%20%26gt%3B%20%2Fsys%2Fclass%2Fgraphics%2Ffb0%2Frotate%22%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120810%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120810%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%EF%BC%8C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Qiang%2CI%20am%20using%20the%20BSP%20L3.0.35.4.10%2CI%20would%20like%20to%20build%20a%20logo%20in%20UBOOT.I%20can%20using%20the%20above%20patch.How%20can%20i%20do%20this%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120809%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120809%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehai%20sir%20%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eis%20it%20possible%20to%20apply%20this%20jelly%20bean%20patches%20on%20lolipop%26nbsp%3B%20source%20.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%3C%2FP%3E%3CP%3ESachu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120808%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120808%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYou%20can%20set%20the%20pins%20to%20GPIO%20for%20suspend%2C%20and%20set%20it%20high%2Flow%20as%20you%20wanted.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120806%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120806%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20think%20you%20should%20check%20your%20display%20timing%20setting%20in%20your%20kernel%20file%20mxc_lcdif.c.%20After%20suspend%20and%20resume%2C%20the%20timing%20parameters%20in%20mxc_lcdif.c%20will%20be%20used.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBy%20the%20way%2C%20after%20booted%20up%2C%20if%20you%20run%20followed%20commands%2C%20what's%20the%20result%3A%3C%2FP%3E%3CP%3E%23%20echo%201%20%26gt%3B%20%2Fsys%2Fclass%2Fgraphics%2Ffb0%2Fblank%3C%2FP%3E%3CP%3E%23%20echo%200%20%26gt%3B%20%2Fsys%2Fclass%2Fgraphics%2Ffb0%2Fblank%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120803%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120803%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20think%20your%20porting%20is%20not%20correct%2C%20you%20can%20add%20dead%20loop%20%22while(1)%3B%22%20into%20your%20modified%20code%20step%20by%20step%20to%20identify%20the%20issue%20code.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehas%20anyone%20met%20the%20same%20problem%3F%26nbsp%3B%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120801%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120801%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYes%2C%20changed%20as%20you%20said%2C%20it%20works.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EB%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3Eut%20before%20kernel%20logo%20shows%2C%20there%20is%20a%20period%20that%20no%20logo%20and%20no%20backlight%20of%20the%20screen%2C%20that%20is%2C%20the%20uboot%20logo%20shows%20first%2C%20then%20disappear%2C%20and%20show%20again.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3EDo%20you%20know%20what%20is%20wrong%20with%20me%3F%20It%20seems%20the%20backlight%20is%20not%20always%20on%20during%20kernel%20booting.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120800%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120800%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYou%20must%20set%20fb0base%3D0x27b00000%20in%20your%20kernel%20command%20line%2C%20without%20this%20setting%2C%20kernel%20will%20alloc%20other%20memory%20for%20frame%20buffer.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120799%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120799%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20Liqiang.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20am%20testing%20with%20imx6q%2C%20in%20android4.4%20and%20kernel%203.0.35%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20downloaded%20%3CSTRONG%3EJB4.3_1.1.1_uboot_logo_keep_patch_2015-09-18%3C%2FSTRONG%3E%2C%20and%20applied%20just%20two%20patches%2C%3C%2FP%3E%3CP%3E%3CSTRONG%3E0001-Enable-uboot-logo-for-HDMI-LCD-and-LVDS.patch%20%3C%2FSTRONG%3Eto%20uboot%2C%3C%2FP%3E%3CP%3E%3CSTRONG%3E0001-Keep-uboot-logo-for-Android-boot-supports-HDMI-LCD-a.patch%3C%2FSTRONG%3E%20to%20kernel%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWhen%20testing%20with%20lvds%2C%20it%20works%20fine%2C%20logo%20can%20show%20during%20uboot%20and%20kernel%20booting.%20then%20show%20android%20UI.%3C%2FP%3E%3CP%3EWhen%20testing%20with%20hdmi%2C%20it%20doesn't%2C%20uboot%20can%20display%20logo%20well%2C%20but%20during%20kernel%20booting%2C%20nothing%20displayed%2C%20after%20a%20while%2C%20android%20UI%20shows.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3EMy%20Kernel%20command%20line%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Econsole%3Dttymxc0%2C115200%20androidboot.console%3Dttymxc0%20vmalloc%3D400M%20init%3D%2Finit%20video%3Dmxcfb0%3Adev%3Dhdmi%2C1920x1080M%4060%2Cif%3DRGB24%2Cbpp%3D32%20video%3Dmxcfb1%3Aoff%20video%3Dmxcfb2%3Aoff%20fbmem%3D28M%20androidboot.hardware%3Dfreescale%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBy%20testing%20HDMI%2C%20I%20found%20that%2C%20the%20screen%20first%20show%20logo%2C%20and%20soon%20logo%20dispeared%2C%20I%20noticed%20the%20backlight%20of%20hdmi%20is%20off%20at%20the%20same%20time.%20After%20a%20while%2C%20the%20backlight%20turns%20on%2C%20still%20no%20logo%20on%20the%20screen%2C%20just%20black.%20After%20a%20moment%2C%20android%20bootanimation%20starts%20on%20the%20screen.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDo%20you%20know%20what%20is%20the%20problem%3F%20Any%20suggestions%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120797%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120797%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EAny%20update%20is%20planned%20for%20pure%20Linux%20to%20the%20last%20BSP%203.14.38%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120796%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120796%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENo%2C%20it%20can't%20support%20dual%20display%20logo.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120795%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120795%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDoes%20this%20patch%20supports%20dual%20screen%20showing%20the%20same%20content%20(LVDS%20and%20HDMI%20channel)%20for%20JB4.3_1.1.0-ga%20BSP%20%3F%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%2C%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E1.I%20supplyed%20the%20patch%2C%20but%20it%20didn't%20work%2C%20the%20screen%20is%20white%2C%20only%20the%20backlight(I%20use%20dual%20channel%20split%20mode%20of%20LVDS%201920x1080%20).%20%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%2C%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%23ifdef%20CONFIG_UBOOT_LOGO_ENABLE%20%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20Select%20one%20of%20the%20output%20mode%20%3CBR%20%2F%3E%2F%2F%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20IPU_OUTPUT_MODE_HDMI%20%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20IPU_OUTPUT_MODE_LVDS%20%3CBR%20%2F%3E%2F%2F%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20IPU_OUTPUT_MODE_LCD%20%3CBR%20%2F%3E%3CBR%20%2F%3E%2F%2F%20For%20LVDS%2C%201920*1080%20resolution%2C%20dual%20channel%20%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_WIDTH%26nbsp%3B%26nbsp%3B%26nbsp%3B%201920%20%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_HEIGHT%26nbsp%3B%26nbsp%3B%26nbsp%3B%201080%20%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_BPP%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2032%20%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_IF_BPP%26nbsp%3B%26nbsp%3B%26nbsp%3B%2024%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20RGB24%20interface%20%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_HSYNC_START%26nbsp%3B%26nbsp%3B%26nbsp%3B%20100%20%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_HSYNC_END%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2040%20%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_HSYNC_WIDTH%26nbsp%3B%26nbsp%3B%26nbsp%3B%2010%20%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_VSYNC_START%26nbsp%3B%26nbsp%3B%26nbsp%3B%2020%20%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_VSYNC_END%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203%20%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_VSYNC_WIDTH%26nbsp%3B%26nbsp%3B%26nbsp%3B%202%20%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_PIX_CLOCK%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20135000000%20%2F%2F(DISPLAY_HSYNC_START%20%2B%20DISPLAY_HSYNC_END%20%2B%20DISPLAY_HSYNC_WIDTH%20%2B%20DISPLAY_WIDTH)%20*%20(DISPLAY_VSYNC_START%20%2B%20DISPLAY_VSYNC_END%20%2B%20DISPLAY_VSYNC_WIDTH%20%2B%20DISPLAY_HEIGHT)%20*%20refresh%20rate%20(60Hz)%20%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20LVDS_SPLIT_MODE%20%2F%2F%20For%20dual%20channel%20split%20mode.%20%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_VSYNC_POLARITY%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%20%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_HSYNC_POLARITY%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%20%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_CLOCK_POLARITY%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%20%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_DATA_POLARITY%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%20%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_DATA_ENABLE_POLARITY%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%20%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20IPU_NUM%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%20%2F%2F%201%20for%20IPU1%2C%202%20for%20IPU2.%20%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DI_NUM%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%20%2F%2F%200%20for%20DI0%2C%201%20for%20DI1.%20%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20LVDS_PORT%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%20%2F%2F%200%20for%20LVDS0%2C%201%20for%20LVDS1.%20%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DI_CLOCK_EXTERNAL_MODE%20%3CBR%20%2F%3E%3CBR%20%2F%3E2.The%20%3CSPAN%3Edata%20signal%3C%2FSPAN%3E%3CSPAN%3E%20of%20LVDS%20is%20not%20normal.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20Helvetica%2C%20sans-serif%3B%22%3E%3CSPAN%3E3.uboot%20log%3A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EU-Boot%202009.08-dirty%20(%205%E6%9C%88%2029%202014%20-%2018%3A44%3A23)%3C%2FP%3E%3CP%3ECPU%3A%20Freescale%20i.MX6%20family%20TO1.2%20at%20792%20MHz%3CBR%20%2F%3EThermal%20sensor%20with%20ratio%20%3D%20177%3CBR%20%2F%3ETemperature%3A%26nbsp%3B%26nbsp%3B%2065%20C%2C%20calibration%20data%200x5614c669%3CBR%20%2F%3Emx6q%20pll1%3A%20792MHz%3CBR%20%2F%3Emx6q%20pll2%3A%20528MHz%3CBR%20%2F%3Emx6q%20pll3%3A%20480MHz%3CBR%20%2F%3Emx6q%20pll8%3A%2050MHz%3CBR%20%2F%3Eipg%20clock%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%2066000000Hz%3CBR%20%2F%3Eipg%20per%20clock%20%3A%2066000000Hz%3CBR%20%2F%3Euart%20clock%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%2080000000Hz%3CBR%20%2F%3Ecspi%20clock%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%2060000000Hz%3CBR%20%2F%3Eahb%20clock%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%20132000000Hz%3CBR%20%2F%3Eaxi%20clock%26nbsp%3B%26nbsp%3B%20%3A%20264000000Hz%3CBR%20%2F%3Eemi_slow%20clock%3A%20132000000Hz%3CBR%20%2F%3Eddr%20clock%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%20528000000Hz%3CBR%20%2F%3Eusdhc1%20clock%26nbsp%3B%20%3A%20198000000Hz%3CBR%20%2F%3Eusdhc2%20clock%26nbsp%3B%20%3A%20198000000Hz%3CBR%20%2F%3Eusdhc3%20clock%26nbsp%3B%20%3A%20198000000Hz%3CBR%20%2F%3Eusdhc4%20clock%26nbsp%3B%20%3A%20198000000Hz%3CBR%20%2F%3Enfc%20clock%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%2024000000Hz%3CBR%20%2F%3EBoard%3A%20i.MX6Q-SABRESD%3A%20unknown-board%20Board%3A%200x63012%20%5BWDOG%20%5D%3CBR%20%2F%3EBoot%20Device%3A%20MMC%3CBR%20%2F%3EI2C%3A%26nbsp%3B%26nbsp%3B%20ready%3CBR%20%2F%3EDRAM%3A%26nbsp%3B%26nbsp%3B%201%20GB%3CBR%20%2F%3EMMC%3A%26nbsp%3B%26nbsp%3B%20FSL_USDHC%3A%200%2CFSL_USDHC%3A%201%2CFSL_USDHC%3A%202%2CFSL_USDHC%3A%203%3CBR%20%2F%3E***%20Warning%20-%20bad%20CRC%20or%20MMC%2C%20usr%3A%26nbsp%3B%26nbsp%3B%20serial%3CBR%20%2F%3E%3D%3Dboard_late_init%20line%20%3D%202261%3D%3D%3CBR%20%2F%3E%3D%3Dsetup_lvds_iomux%20line%20%3D%202144%3D%3D%3CBR%20%2F%3E%3D%3Dipu_display_setup%20line%20%3D%202696%20IPU_NUM%20%3D%201%20DI_NUM%20%3D%201%20%3D%3D%3CBR%20%2F%3E%3D%3Dipu_setup%20line%20%3D%202415%3D%3D%3CBR%20%2F%3E%3D%3Dipu_setup%20line%20%3D%202424%20reg%20%3D%200x3ff00000%3D%3D%3CBR%20%2F%3E%3D%3Dclk_config%20line%20%3D%201054%3D%3D%3CBR%20%2F%3Econfig_ipu_lvds_clk%3A%20freq%20%3D%20472500000.%3CBR%20%2F%3Econfig_ipu_lvds_clk%3A%20set%20pll3_pfd1%20clock%20to%20468MHz%2C%20divider%20%3D%2018.%3CBR%20%2F%3E%3D%3Dsetup_lvds%20line%20%3D%202608%3D%3D%3CBR%20%2F%3ENet%3A%26nbsp%3B%26nbsp%3B%20got%20MAC%20address%20from%20IIM%3A%2000%3A00%3A00%3A00y%20to%20stop%20autoboot%3A%26nbsp%3B%200%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20Regards%3C%2FP%3E%3CP%3EBrague%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Brague%2C%20the%20split%20mode%20LVDS%20timing%20parameters%20are%20for%20ChiMei%20M216H1-L01%20panel%2C%20for%20your%20own%20panel%2C%20you%20need%20update%20them%20based%20on%20the%20datasheet%20of%20your%20LVDS%20panel.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120773%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120773%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EQiang%EF%BC%8CI%20had%20modify%20the%20timing%20parameters%20for%20my%20LVDS%20panel%2Cbut%20it%20ditn't%20work%20yet.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%3EDo%20you%20have%20any%20other%3C%2FSPAN%3E%3CSPAN%3E%20ideas%3C%2FSPAN%3E%3CSPAN%3E%3F%3Asmileyconfused%3A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120774%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120774%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20think%20you%20need%20measure%20the%20hardware%20signals%2C%20such%20as%20LCD%20power%2C%20backlight%2C%20and%20so%20on.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120775%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120775%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%3CSPAN%3EI%20have%20done%3C%2FSPAN%3E%3CSPAN%3E%20as%20you%20said.T%3C%2FSPAN%3Ehe%20kernel%20were%20display%20the%20normal%20LOGO%2Cso%20t%3CSPAN%3Ehe%20problem%20is%20not%20in%20that.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3EOn%20my%20board%20I%20use%20800x480%20RGB%20LCD%20and%20the%20video%20parameters%20for%20kernel%20is%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%22video%3Dmxcfb0%3Adev%3Dlcd%2CCLAA-WVGA%2Cif%3DRGB24%2Cbpp%3D32%20fb0base%3D0x27b00000%20fbmem%3D28M%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWith%20this%20configuration%20the%20display%20works%20perfect%20in%20Android%2C%20but%20in%20uboot%20the%20logo%20is%20not%20correct.%20I%20checked%20the%20patch%20and%20found%20for%20LCD%20mode%20we%20have%20definition%3A%3C%2FP%3E%3CP%3E%23define%20DISPLAY_IF_BPP%26nbsp%3B%2016%26nbsp%3B%20%2F%2F%20RGB565%20interface%3C%2FP%3E%3CP%3ESo%20I%20changed%20the%20definition%20as%20follows%20and%20rebuilt%20uboot%2C%20but%20the%20problem%20is%20still%20there.%3C%2FP%3E%3CP%3E%23define%20DISPLAY_IF_BPP%26nbsp%3B%2024%26nbsp%3B%20%2F%2F%20RGB24%20interface%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20hard-coded%20the%20uboot%20code%20(by%20setting%20bmpReady%20to%200%20in%20board%2Ffreescale%2Fmx6q_sabresd%2Fmx6q_sabresd.c)%20to%20display%20red%2Cgreen%20and%20blue%20color%20bar%2C%20but%20the%20color%20is%20not%20correct%20as%20the%20following%20picture.%3C%2FP%3E%3CP%3EIf%20you%20have%20any%20advice%20on%20it%20please%20let%20me%20know.%20Thanks!%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20150408134849.jpg%22%20style%3D%22width%3A%20816px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F49435i80892D745FD43E5A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22IMG_20150408134849.jpg%22%20alt%3D%22IMG_20150408134849.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Frank%2C%20you%20should%20check%20the%20function%20ipu_iomux_config()%20in%20mx6q_sabresd.c%2C%20whether%20the%2024%20display%20data%20pins%20are%20set%20correctly%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120778%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120778%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3EAfter%20checking%20the%20pixel%20color%20carefully%2C%20I%20found%20the%20pixel%20color%20was%20reversed%20when%20displayed%20in%20uboot.%20For%20example%2C%20if%20the%20pixel%20data%20in%20display%20buffer%20is%20Red%20(0xFF0000)%2C%20the%20acutal%20display%20result%20is%200x00FFFF%20(Green%20%2B%20Blue).%20However%20after%20kernel%20and%20Android%20boots%20up%20(with%20logo%20smooth%20transition%20feature)%2C%20the%20color%20becomes%20correct!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20did%20a%20test%20by%20changing%3C%2FP%3E%3CP%3E%23define%20DISPLAY_DATA_POLARITY%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%3C%2FP%3E%3CP%3Eto%3C%2FP%3E%3CP%3E%23define%20DISPLAY_DATA_POLARITY%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%3C%2FP%3E%3CP%3EAfter%20this%20change%20the%20color%20in%20uboot%20looks%20correct%20but%20it%20is%20reversed%20after%20kernel%20and%20Android%20boots%20up.%20However%20the%20color%20in%20Android%20will%20be%20correct%20after%20the%20system%20wakes%20up%20from%20sleep.%20I%20guess%20there%20is%20IPU%20re-initialization%20during%20wakeup.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPerhaps%20I%20can%20workaround%20this%20issue%20by%20reversing%20pixel%20data%20in%20uboot%20display%20buffer%20before%20it%20is%20displayed%2C%20but%20don't%20know%20why%20there%20is%20such%20issue.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20also%20checked%20ipu_iomux_config()%20and%20it%20looks%20no%20problem.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPlease%20note%20in%20my%20case%20DISPLAY_IF_BPP%26nbsp%3B%20is%20set%20to%2024.%20If%20DISPLAY_IF_BPP%26nbsp%3B%20is%20set%20to%2016%2C%20the%20color%20in%20either%20uboot%20or%20Android%20is%20incorrect%20unless%20the%20system%20wakes%20up%20from%20sleep.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20POLARITY%20of%20VSYNC%2C%20HSYNC%2C%20Pixel%20clock%2C%20data%2C%20DE%20depend%20on%20your%20panel's%20datasheet.%20%3CBR%20%2F%3EYou%20should%20double%20check%20them%20and%20the%20same%20setting%20should%20be%20used%20in%20kernel%20and%20Uboot.%20Your%20issue%20is%20more%20like%20pixel%20clock%20polarity%20issue.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120780%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120780%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3EThanks%20for%20your%20reply!%20I%20will%20check%20if%20it's%20polarity%20issue.%20For%20now%20the%20puzzle%20for%20me%20is%20that%20why%20uboot%20and%20Android%20have%20different%20results%20while%20the%20smooth%20transition%20feature%20is%20enabled%20(uboot%20and%20kernel%20should%20have%20the%20same%20IPU%20configuration%3F).%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120781%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120781%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20video%20mode%20setting%20for%20UBoot%20and%20kernel%20should%20be%20same%2C%20and%20all%20these%20parameters%20should%20be%20from%20panel's%20datasheet.%20I%20haven't%20checked%20the%20LVDS%20and%20LCD%20panel%20polarity%2C%20maybe%20they%20are%20not%20aligned%20in%20default%20code%2C%20the%20followed%20is%20the%20align%20method%20for%20Uboot%20and%20kernel%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUboot%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Kernel%3C%2FP%3E%3CP%3E%22%23define%20DISPLAY_VSYNC_POLARITY%26nbsp%3B%26nbsp%3B%201%22%20%3D%20%22FB_SYNC_VERT_HIGH_ACT%22%3C%2FP%3E%3CP%3E%22%23define%20DISPLAY_HSYNC_POLARITY%26nbsp%3B%26nbsp%3B%201%22%20%3D%20%22FB_SYNC_HOR_HIGH_ACT%22%3C%2FP%3E%3CP%3E%22%23define%20DISPLAY_CLOCK_POLARITY%26nbsp%3B%26nbsp%3B%201%22%20%3D%20%22FB_SYNC_CLK_LAT_FALL%22%3C%2FP%3E%3CP%3E%22%23define%20DISPLAY_DATA_POLARITY%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%22%20%3D%20%22FB_SYNC_DATA_INVERT%22%3C%2FP%3E%3CP%3E%22%23define%20DISPLAY_DATA_ENABLE_POLARITY%26nbsp%3B%200%22%20%3D%20%22FB_SYNC_OE_LOW_ACT%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EExample%20for%20HDMI%201080P60%20setting%3A%3C%2FP%3E%3CP%3E%20%23define%20DISPLAY_VSYNC_POLARITY%26nbsp%3B%26nbsp%3B%201%3C%2FP%3E%3CP%3E%20%23define%20DISPLAY_HSYNC_POLARITY%26nbsp%3B%26nbsp%3B%201%3C%2FP%3E%3CP%3E%20%23define%20DISPLAY_CLOCK_POLARITY%26nbsp%3B%26nbsp%3B%200%3C%2FP%3E%3CP%3E%20%23define%20DISPLAY_DATA_POLARITY%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%3C%2FP%3E%3CP%3E%20%23define%20DISPLAY_DATA_ENABLE_POLARITY%26nbsp%3B%201%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESo%20in%20kernel%20video%20mode%3A%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%20NULL%2C%2060%2C%201920%2C%201080%2C%206734%2C%20148%2C%2088%2C%2036%2C%204%2C%2044%2C%205%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%3CSTRONG%3EFB_SYNC_HOR_HIGH_ACT%20%7C%20FB_SYNC_VERT_HIGH_ACT%2C%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20FB_VMODE_NONINTERLACED%2C%200%2C%3C%2FP%3E%3CP%3E%20%7D%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120782%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120782%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3EThe%20issue%20has%20been%20resolved%20by%20modifying%20iomux%20and%20pad%20configurations%20of%20two%20pins%20on%20my%20board.%20However%20those%20pins%20are%20not%20IPU-related%20or%20LCD%20panel%20related.%20The%20root%20cause%20may%20hardware%20or%20chip%20specific%20although%20I%20still%20don't%20understand%20it%20now.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAnyway%20all%20the%20IPU%20register%20settings%20or%20IPU%20pad%20configurations%20in%20your%20patch%20are%20correct%20except%20that%20I%20changed%20DISPLAY_IF_BPP%20from%2016%20to%2024%20for%20my%20case.%20The%20patch%20is%20perfect!%20Thanks%20for%20your%20help!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120784%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120784%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFor%20default%20Android%20BSP%2C%20for%20the%20the%20LVDS1%20signal%20will%20stop%20and%20re-enable%20in%20a%20short%20time%2C%20the%20LVDS%20panel%20that%20freescale%20reference%20board%20used%20can%20keep%20the%20screen%20in%20such%20short%20signal%20stop%2C%20but%20for%20most%20of%20other%20panels%2C%20screen%20will%20disappear%20for%20a%20short%20time.%20This%20patch%20was%20used%20to%20fix%20such%20issue.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20patch%20had%20given%20three%20examples%20for%20how%20to%20enable%20the%20logo%20keep%20on%20feature%2C%20so%20if%20you%20used%20different%20panel%20on%20different%20IPU%20DI%20port%2C%20you%20should%20reference%20to%20these%20example%20to%20modify%20the%20code.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120785%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120785%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMy%20environment%3A%20%3CSTRONG%3Eimx6dl%2C%20JB4.2.2_1.1.0%2C%20hdmi%2C%201920x1080%2C%20RGB24%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EI%20applied%20the%20patch%2C%20and%20test%20with%20lcd%2C%20it%20works%20well.%3C%2FP%3E%3CP%3ENow%2C%20I%20am%20testing%20with%20hdmi%2C%3C%2FP%3E%3CP%3EChanges%20I%20did%20as%20follows%2C%3C%2FP%3E%3CP%3Euboot-imx%2Finclude%2Fconfigs%2Fmx6dl_sabresd.h%3C%2FP%3E%3CP%3E%3CSTRONG%3E1.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E370%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20IPU_OUTPUT_MODE_HDMI%3C%2FP%3E%3CP%3E371%20%2F%2F%26nbsp%3B%20%23define%20IPU_OUTPUT_MODE_LVDS%3C%2FP%3E%3CP%3E372%20%2F%2F%26nbsp%3B%20%23define%20IPU_OUTPUT_MODE_LCD%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E2.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E381%20%23ifdef%20IPU_OUTPUT_MODE_HDMI%3C%2FP%3E%3CP%3E...%3C%2FP%3E%3CP%3E421%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20IPU_NUM%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%20%2F%2F%20original%20set%20to%202%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20changed%20IPU_NUM%20from%202%20to%201%2C%20because%20there%20is%20only%201%20ipu%20in%20imx6dl%2C%20I%20think%20it%20should%20be%20changed%3C%2FP%3E%3CP%3Eand%3C%2FP%3E%3CP%3E%3CSTRONG%3Eif%20I%20use%20%23define%20IPU_NUM%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Ethe%20system%20will%20halt%20on%20uboot%2C%20log%20as%20follow%2C%3C%2FP%3E%3CP%3E________________________________________%3C%2FP%3E%3CP%3E%3CEM%3EU-Boot%202009.08%20(%206%E9%8F%8818%202015%20-%2016%3A38%3A27)%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%3ECPU%3A%20Freescale%20i.MX6%20family%20TO1.2%20at%20792%20MHz%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3EThermal%20sensor%20with%20ratio%20%3D%20190%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3ETemperature%3A%26nbsp%3B%26nbsp%3B%2030%20C%2C%20calibration%20data%200x5b251d69%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Emx6q%20pll1%3A%20792MHz%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Emx6q%20pll2%3A%20528MHz%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Emx6q%20pll3%3A%20480MHz%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Emx6q%20pll8%3A%2050MHz%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Eipg%20clock%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%2066000000Hz%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Eipg%20per%20clock%20%3A%2066000000Hz%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Euart%20clock%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%2080000000Hz%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Ecspi%20clock%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%2060000000Hz%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Eahb%20clock%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%20132000000Hz%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Eaxi%20clock%26nbsp%3B%26nbsp%3B%20%3A%20198000000Hz%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Eemi_slow%20clock%3A%2099000000Hz%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Eddr%20clock%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%20396000000Hz%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Eusdhc1%20clock%26nbsp%3B%20%3A%20198000000Hz%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Eusdhc2%20clock%26nbsp%3B%20%3A%20198000000Hz%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Eusdhc3%20clock%26nbsp%3B%20%3A%20198000000Hz%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Eusdhc4%20clock%26nbsp%3B%20%3A%20198000000Hz%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Enfc%20clock%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%2024000000Hz%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3EBoard%3A%20i.MX6DL%2FSolo-SABRESD%3A%20unknown-board%20Board%3A%200x61012%20%5BPOR%20%5D%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3EBoot%20Device%3A%20MMC%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3EI2C%3A%26nbsp%3B%26nbsp%3B%20ready%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3EDRAM%3A%26nbsp%3B%26nbsp%3B%201%20GB%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3EMMC%3A%26nbsp%3B%26nbsp%3B%20FSL_USDHC%3A%200%2CFSL_USDHC%3A%201%2CFSL_USDHC%3A%202%2CFSL_USDHC%3A%203%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E***%20Warning%20-%20bad%20CRC%20or%20MMC%2C%20using%20default%20environment%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%3EIn%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%20serial%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3EOut%3A%26nbsp%3B%26nbsp%3B%20serial%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3EErr%3A%26nbsp%3B%26nbsp%3B%20serial%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%24%24%24%24%2C%20mmc_dev%3D3%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%24%24%24%24size%3D8294400%2Cmmc-%26gt%3Bread_bl_len%3D512%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%24%24%24%24start%3D32768%2Ccount%3D16200%2CCONFIG_FB_BASE%3D27b00000%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Econfig_ipu_di_clk%3A%20freq%20%3D%20148500000.%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Ewait%20for%20pll5%20lock.%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Econfig_ipu_di_clk%3A%20set%20pll5%20clock%20to%20297000000Hz.%3C%2FEM%3E%3C%2FP%3E%3CP%3E_____________________________________________%3C%2FP%3E%3CP%3E%3CSTRONG%3Eelse%20if%20I%20use%20%23define%20IPU_NUM%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Ethe%20system%20will%20start%20up%2C%20but%20on%20hdmi%2C%20it%20shows%20%22no%20siginal%20input%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E3.%3C%2FSTRONG%3E%20%3CSTRONG%3Emy%20KERNEL_CMDLINE%20is%20as%20follows%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EBOARD_KERNEL_CMDLINE%20%3A%3D%20console%3Dttymxc0%2C115200%20androidboot.console%3Dttymxc0%20vmalloc%3D400M%20init%3D%2Finit%20video%3Dmxcfb0%3Adev%3Dhdmi%2C1920x1080M%4060%2Cbpp%3D32%20video%3Dmxcfb1%3Aoff%20video%3Dmxcfb2%3Aoff%20fbmem%3D28%20androidboot.hardware%3Dfreescale%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDo%20you%20know%20what%20is%20the%20problem%20with%20my%20case%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120788%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120788%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20LVDS0%20example%20had%20been%20given%2C%20please%20use%20followed%20setting%20in%20Uboot%20file%20include%2Fconfigs%2Fmx6dl_sabresd.h%2C%20both%20DI_NUM%20and%20LVDS_PORT%20should%20be%200.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%23define%20DI_NUM%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%20%2F%2F%200%20for%20DI0%2C%201%20for%20DI1.%3C%2FP%3E%3CP%3E%20%23define%20LVDS_PORT%26nbsp%3B%200%26nbsp%3B%20%2F%2F%200%20for%20LVDS0%2C%201%20for%20LVDS1.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120789%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120789%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWould%20be%20possible%20to%20get%20this%20patch%20updated%20to%20u-boot%202014.04%20or%20the%20last%202015.04%20%3F%20I'm%20using%20your%20yocto%203.10.53%20recipes%20and%20the%20uboot%20generated%20is%202014.04.%20I%20think%20the%20kernel%20is%20ok%2C%20because%20your%20patch%20is%20for%20linux-3.0.35%2C%20the%20same%20used%20in%20yocto%203.10.53%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120790%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120790%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWould%20these%20patches%20be%20available%20for%20pure%20linux%20(not%20Android%20things..)%3F%20%3C%2FP%3E%3CP%3EI'm%20using%20u-boot%202015.04%20and%20kernel(%20boundary-imx_3.10.17_1.0.2_ga)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20in%20advance!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120791%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120791%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20applied%20the%20patch%20on%20uboot%20for%20Android%204.4.2%20sucessfully.%20I%20believe%20it%20is%20OK%20for%20other%20versions%20including%20pure%20linux.%20But%20you%20may%20need%20to%20review%20the%20patch%20and%20your%20uboot%2Flinux%20code%20carefully%20to%20check%20if%20there%20are%20conflicts%20between%20different%20versions%20that%20the%20patch%20is%20based%20on%20and%20the%20one%20you%20worked%20on.%20Also%20you%20may%20need%20to%20remove%20conflicts%20manually.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20%3CSTRONG%20style%3D%22font-size%3A%2012.6000003814697px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%20%3C%2FSTRONG%3E!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPlease%2C%20can%20you%20help%20me%20to%20turn%20this%20feature%20on%20for%20linux%203.14%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20can't%20apply%20this%20patch%2C%20but%20I%20see%20'late_init'%20parameter%20for%20framebuffer%20in%20device%20tree%20to%20prevent%20overwrite%20bootloader%20logo.%20I%20set%20this%20parameter%20to%20'1'%2C%20but%20nothing%20was%20changed.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWhat%20should%20I%20do%20for%20kernel%203.14%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120793%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120793%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESorry%2C%20I%20have%20no%20such%20plan.%20Basicly%2C%20what%20we%20should%20do%20in%20this%20use%20case%2C%20the%20IPU%20hardware%20shouldn't%20be%20re-initialized.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Edoes%20this%20patch%20supports%20mipi%20dsi%20connector%20for%20lcd%20in%20u-boot%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120818%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120818%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CSPAN%20class%3D%22jive-comment-meta%20font-color-meta-light%22%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%2236648%22%20data-username%3D%22Qiang_FSL%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang%20Li%2C%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22jive-comment-meta%20font-color-meta-light%22%3E%3CSPAN%20class%3D%22j-username-wrap%22%3EHow%20can%20our%20customer%20download%20the%20logo%20bmp%20file%20to%20emmc%20if%20they%20use%20emmc%20and%20no%20SD%20card%20design%3F%20In%20the%20path%20readme%20we%20use%20the%20dd%20the%20logo%20bmp%20file%20to%20SD%20card%20.%20Many%20thanks%20and%20looking%20forward%20your%20reply.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22jive-comment-meta%20font-color-meta-light%22%3E%3CSPAN%20class%3D%22j-username-wrap%22%3EHave%20a%20nice%20day%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22jive-comment-meta%20font-color-meta-light%22%3E%3CSPAN%20class%3D%22j-username-wrap%22%3EDan%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22jive-comment-meta%20font-color-meta-light%22%3E%3CSPAN%20class%3D%22j-username-wrap%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120819%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120819%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYou%20can%20reference%20to%20file%20%22ucl2.xml%22%20in%20MFGTool%2C%20there%20is%20example%20for%20how%20to%20use%20dd%20to%20burn%20the%20image%20files%20from%20PC%20to%20eMMC.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120820%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120820%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOK.%20Thanks%20a%20lot%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E~~%3CP%3E%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120821%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120821%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Li%2C%3C%2FP%3E%3CP%3Ewhen%20i%20patched%20this%200001-Enable-uboot-logo-for-HDMI-LCD-and-LVDS.patch(version%3A%20L3.0.35_4.1.0)%2C%20it%20shows%20some%20error%2C%20can%20you%20help%20me%3A%3C%2FP%3E%3CP%3E%24%20make%20mx6q_sabresd_config%3C%2FP%3E%3CP%3E%24%20make%3C%2FP%3E%3CP%3E....%3C%2FP%3E%3CP%3EMap%20u-boot.map%20-o%20u-boot%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_epdc_fb.o)%3A%20In%20function%20%60lcd_initcolregs'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_epdc_fb.c%3A52%3A%20multiple%20definition%20of%20%60lcd_initcolregs'%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_ipuv3_fb.o)%3A%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_ipuv3_fb.c%3A61%3A%20first%20defined%20here%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_epdc_fb.o)%3A%20In%20function%20%60lcd_setcolreg'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_epdc_fb.c%3A56%3A%20multiple%20definition%20of%20%60lcd_setcolreg'%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_ipuv3_fb.o)%3A%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_ipuv3_fb.c%3A65%3A%20first%20defined%20here%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_epdc_fb.o)%3A%20In%20function%20%60lcd_disable'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_epdc_fb.c%3A397%3A%20multiple%20definition%20of%20%60lcd_disable'%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_ipuv3_fb.o)%3A%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_ipuv3_fb.c%3A69%3A%20first%20defined%20here%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_epdc_fb.o)%3A%20In%20function%20%60lcd_panel_disable'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_epdc_fb.c%3A402%3A%20multiple%20definition%20of%20%60lcd_panel_disable'%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_ipuv3_fb.o)%3A%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_ipuv3_fb.c%3A73%3A%20first%20defined%20here%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_epdc_fb.o)%3A%20In%20function%20%60lcd_ctrl_init'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_epdc_fb.c%3A413%3A%20multiple%20definition%20of%20%60lcd_ctrl_init'%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_ipuv3_fb.o)%3A%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_ipuv3_fb.c%3A622%3A%20first%20defined%20here%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_epdc_fb.o)%3A%20In%20function%20%60calc_fbsize'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_epdc_fb.c%3A467%3A%20multiple%20definition%20of%20%60calc_fbsize'%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_ipuv3_fb.o)%3A%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_ipuv3_fb.c%3A610%3A%20first%20defined%20here%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_epdc_fb.o)%3A%20In%20function%20%60lcd_enable'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_epdc_fb.c%3A376%3A%20multiple%20definition%20of%20%60console_row'%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_ipuv3_fb.o)%3A%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_ipuv3_fb.c%3A80%3A%20first%20defined%20here%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_epdc_fb.o)%3A%20In%20function%20%60lcd_enable'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_epdc_fb.c%3A376%3A%20multiple%20definition%20of%20%60console_col'%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_ipuv3_fb.o)%3A%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_ipuv3_fb.c%3A80%3A%20first%20defined%20here%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_epdc_fb.o)%3A%20In%20function%20%60lcd_enable'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_epdc_fb.c%3A370%3A%20multiple%20definition%20of%20%60lcd_color_bg'%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_ipuv3_fb.o)%3A%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_ipuv3_fb.c%3A80%3A%20first%20defined%20here%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_epdc_fb.o)%3A%20In%20function%20%60lcd_setcolreg'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_epdc_fb.c%3A56%3A%20multiple%20definition%20of%20%60lcd_color_fg'%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_ipuv3_fb.o)%3A%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_ipuv3_fb.c%3A81%3A%20first%20defined%20here%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_epdc_fb.o)%3A%20In%20function%20%60lcd_enable'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_epdc_fb.c%3A373%3A%20multiple%20definition%20of%20%60lcd_line_length'%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_ipuv3_fb.o)%3A%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_ipuv3_fb.c%3A79%3A%20first%20defined%20here%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_epdc_fb.o)%3A%20In%20function%20%60lcd_enable'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_epdc_fb.c%3A376%3A%20multiple%20definition%20of%20%60lcd_console_address'%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_ipuv3_fb.o)%3A%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_ipuv3_fb.c%3A81%3A%20first%20defined%20here%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_epdc_fb.o)%3A%20In%20function%20%60lcd_initcolregs'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_epdc_fb.c%3A52%3A%20multiple%20definition%20of%20%60lcd_base'%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_ipuv3_fb.o)%3A%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fmxc_ipuv3_fb.c%3A79%3A%20first%20defined%20here%3C%2FP%3E%3CP%3Ecommon%2Flibcommon.a(lcd.o)%3A%20In%20function%20%60console_newline'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fcommon%2Flcd.c%3A159%3A%20undefined%20reference%20to%20%60panel_info'%3C%2FP%3E%3CP%3Ecommon%2Flibcommon.a(lcd.o)%3A%20In%20function%20%60lcd_putc'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fcommon%2Flcd.c%3A200%3A%20undefined%20reference%20to%20%60panel_info'%3C%2FP%3E%3CP%3Ecommon%2Flibcommon.a(lcd.o)%3A%20In%20function%20%60lcd_setmem'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fcommon%2Flcd.c%3A476%3A%20undefined%20reference%20to%20%60panel_info'%3C%2FP%3E%3CP%3Ecommon%2Flibcommon.a(lcd.o)%3A%20In%20function%20%60lcd_display_bitmap'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fcommon%2Flcd.c%3A829%3A%20undefined%20reference%20to%20%60panel_info'%3C%2FP%3E%3CP%3Ecommon%2Flibcommon.a(lcd.o)%3A%20In%20function%20%60lcd_clear'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fcommon%2Flcd.c%3A415%3A%20undefined%20reference%20to%20%60panel_info'%3C%2FP%3E%3CP%3Ecommon%2Flibcommon.a(lcd.o)%3A%2Fhome%2Ffulinux%2Fuboot-imx%2Fcommon%2Flcd.c%3A369%3A%20more%20undefined%20references%20to%20%60panel_info'%20follow%3C%2FP%3E%3CP%3Ecommon%2Flibcommon.a(cmd_fastboot.o)%3A%20In%20function%20%60rx_handler'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fcommon%2Fcmd_fastboot.c%3A1050%3A%20undefined%20reference%20to%20%60do_booti'%3C%2FP%3E%3CP%3Edrivers%2Ffastboot%2Flibfastboot.a(fastboot.o)%3A%20In%20function%20%60check_fastboot_mode'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Ffastboot%2Ffastboot.c%3A788%3A%20undefined%20reference%20to%20%60fastboot_check_and_clean_flag'%3C%2FP%3E%3CP%3Edrivers%2Fusb%2Fgadget%2Flibusb_gadget.a(imx_udc.o)%3A%20In%20function%20%60mxc_udc_init'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fusb%2Fgadget%2Fimx_udc.c%3A812%3A%20undefined%20reference%20to%20%60set_usboh3_clk'%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fusb%2Fgadget%2Fimx_udc.c%3A813%3A%20undefined%20reference%20to%20%60set_usb_phy1_clk'%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fusb%2Fgadget%2Fimx_udc.c%3A814%3A%20undefined%20reference%20to%20%60enable_usboh3_clk'%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fusb%2Fgadget%2Fimx_udc.c%3A818%3A%20undefined%20reference%20to%20%60enable_usb_phy1_clk'%3C%2FP%3E%3CP%3Edrivers%2Fusb%2Fgadget%2Flibusb_gadget.a(imx_udc.o)%3A%20In%20function%20%60usb_set_mode_device'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fusb%2Fgadget%2Fimx_udc.c%3A468%3A%20undefined%20reference%20to%20%60reset_usb_phy1'%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_ipuv3_fb.o)%3A%20In%20function%20%60calc_fbsize'%3A%3C%2FP%3E%3CP%3Emxc_ipuv3_fb.c%3A(.text%2B0xb4)%3A%20undefined%20reference%20to%20%60panel_info'%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_ipuv3_fb.o)%3A%20In%20function%20%60lcd_ctrl_init'%3A%3C%2FP%3E%3CP%3Emxc_ipuv3_fb.c%3A(.text%2B0xf8)%3A%20undefined%20reference%20to%20%60panel_info'%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_ipuv3_fb.o)%3A%20In%20function%20%60ipuv3_fb_init'%3A%3C%2FP%3E%3CP%3Emxc_ipuv3_fb.c%3A(.text%2B0x7d0)%3A%20undefined%20reference%20to%20%60panel_info'%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(ipu_common.o)%3A%20In%20function%20%60clk_ipu_enable'%3A%3C%2FP%3E%3CP%3E%2Fhome%2Ffulinux%2Fuboot-imx%2Fdrivers%2Fvideo%2Fipu_common.c%3A166%3A%20undefined%20reference%20to%20%60ipu_clk_enable'%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_epdc_fb.o)%3A%20In%20function%20%60lcd_enable'%3A%3C%2FP%3E%3CP%3Emxc_epdc_fb.c%3A(.text%2B0x14)%3A%20undefined%20reference%20to%20%60epdc_power_on'%3C%2FP%3E%3CP%3Emxc_epdc_fb.c%3A(.text%2B0x180)%3A%20undefined%20reference%20to%20%60panel_info'%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_epdc_fb.o)%3A%20In%20function%20%60lcd_panel_disable'%3A%3C%2FP%3E%3CP%3Emxc_epdc_fb.c%3A(.text%2B0x1a4)%3A%20undefined%20reference%20to%20%60epdc_power_off'%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_epdc_fb.o)%3A%20In%20function%20%60lcd_ctrl_init'%3A%3C%2FP%3E%3CP%3Emxc_epdc_fb.c%3A(.text%2B0x240)%3A%20undefined%20reference%20to%20%60setup_waveform_file'%3C%2FP%3E%3CP%3Emxc_epdc_fb.c%3A(.text%2B0x3ac)%3A%20undefined%20reference%20to%20%60panel_info'%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Flibvideo.a(mxc_epdc_fb.o)%3A%20In%20function%20%60calc_fbsize'%3A%3C%2FP%3E%3CP%3Emxc_epdc_fb.c%3A(.text%2B0x3e4)%3A%20undefined%20reference%20to%20%60panel_info'%3C%2FP%3E%3CP%3Emake%3A%20***%20%5Bu-boot%5D%20Error%201%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120822%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120822%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Li%2C%20this%20my%20lcd%20picture%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22P60512-160237.jpg%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22P60512-160237.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22P60512-160237.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22P60512-160237.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22P60512-160237.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22P60512-160237.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22P60512-160237.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22P60512-160237.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22P60512-160237.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22P60512-160237.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22P60512-160237.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22P60512-160237.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22P60512-160237.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22P60512-160237.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F57115i3829683B5757B2F1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22P60512-160237.jpg%22%20alt%3D%22P60512-160237.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eand%20this%20is%20my%20head%20file%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20For%20LVDS%2C%201920*1080%20resolution%2C%20dual%20channel%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_WIDTH%26nbsp%3B%26nbsp%3B%201920%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_HEIGHT%26nbsp%3B%201080%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_BPP%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2032%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_IF_BPP%26nbsp%3B%2024%26nbsp%3B%20%2F%2F%20RGB24%20interface%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_HSYNC_START%2080%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_HSYNC_END%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2068%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_HSYNC_WIDTH%2012%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_VSYNC_START%2015%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_VSYNC_END%26nbsp%3B%26nbsp%3B%2015%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_VSYNC_WIDTH%208%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_PIX_CLOCK%26nbsp%3B%26nbsp%3B%20140000000%26nbsp%3B%20%2F%2F(DISPLAY_HSYNC_START%20%2B%20DISPLAY_HSYNC_END%20%2B%20DISPLAY_HSYNC_WIDTH%20%2B%20DISPLAY_WIDTH)%20*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E(DISPLAY_VSYNC_START%20%2B%20DISPLAY_VSYNC_END%20%2B%20DISPLAY_VSYNC_WIDTH%20%2B%20DISPLAY_HEIGHT)%20*%20refresh%20rate%20(60Hz)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20LVDS_SPLIT_MODE%26nbsp%3B%20%2F%2F%20For%20dual%20channel%20split%20mode.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_VSYNC_POLARITY%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_HSYNC_POLARITY%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_CLOCK_POLARITY%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_DATA_POLARITY%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_DATA_ENABLE_POLARITY%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20IPU_NUM%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%20%2F%2F%201%20for%20IPU1%2C%202%20for%20IPU2.%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DI_NUM%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%20%2F%2F%200%20for%20DI0%2C%201%20for%20DI1.%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20LVDS_PORT%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%20%2F%2F%200%20for%20LVDS0%2C%201%20for%20LVDS1.%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DI_CLOCK_EXTERNAL_MODE%26nbsp%3B%20%2F%2FWhen%20clock%20external%20mode%20was%20defined%2C%20the%20DI%20clock%20root%20will%20be%20PLL3%20PFD1%2C%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2Fwithout%20this%20macro%2C%20the%20DI%20root%20clock%20is%20IPU%20internal%20clock.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ewhat%20should%20i%20do%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120823%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120823%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20all%2C%3C%2FP%3E%3CP%3EHave%20you%20had%20this%20problem%3F%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F392013%22%20target%3D%22_blank%22%3Euboot%20logo%20color%20is%20green%3C%2FA%3E%20what's%20wrong%20with%20it%3F%3C%2FP%3E%3CP%3Ewaiting%20for%20you%20help....%3C%2FP%3E%3CP%3Efulinux.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120825%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120825%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIt%20looks%20like%20the%20color%20space%20of%20your%20display%20is%20correct%20so%20your%20issue%20is%20different%20from%20my%20issue.%20Did%20you%20check%20if%20it%20display%20correctly%20in%20Linux%20or%20Android%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120826%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120826%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20ported%20the%20changes%20in%20the%203.10.53-patches%20to%20keep%20the%20logo%20for%20my%203.10.17%20kernel%2C%20and%20it%20works%20fine%20as%20the%20logo%20from%20the%20bootloader%20is%20shown%20all%20the%20way%20during%20the%20kernel%20initialization.%3C%2FP%3E%3CP%3EMy%20problem%3A%20as%20soon%20as%20the%20kernel%20is%20ready%20and%20switches%20to%20%2Fsbin%2Finit%2C%20I%20get%20garbage%20displayed%20on%20the%20screen.%3C%2FP%3E%3CP%3EI%20can%20then%20do%20a%20blank%2Funblank%20and%20use%20the%20display%20from%20userspace%20without%20problems%2C%20but%20the%20content%20from%20the%20bootloader%20is%20not%20kept%20until%20userspace%20is%20running.%3C%2FP%3E%3CP%3EQiang%20do%20you%20have%20any%20idea%20what%20could%20be%20wrong%3F%20Something%20with%20memory%20allocation%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%203.10.53%20patch%20has%20the%20reference%20code%20for%20how%20to%20let%20the%20kernel%20use%20the%20same%20framebuffer%20as%20Uboot.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120828%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120828%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20ported%20the%203.10.53%20patch%20to%20my%20kernel%2C%20but%20I%20still%20have%20the%20described%20issue%2C%20that%20the%20framebuffer%20content%20is%20erased%2Foverriden%2Fetc.%20after%20the%20kernel%20is%20initialized%20and%20switches%20to%20init.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120829%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120829%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3EWhen%20i%20patch%20this%20in%203.0.35%2C%20it%20runs%20well%2C%20but%20it%20will%20reboot%20without%20any%20log%20when%20i%20copy%20videos%20files%20to%20board%20from%20u%20disk%2C%26nbsp%3B%20it%20looks%20like%20pass%20reset%20key.%20have%20you%20met%20this%20problem%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A83.0.35%E7%89%88%E6%9C%AC%E7%9A%84%E5%86%85%E6%A0%B8%E4%B8%AD%E6%89%93%E4%B8%8A%E8%BF%99%E4%BA%9B%E8%A1%A5%E4%B8%81%E5%90%8E%EF%BC%8C%E5%85%B6%E4%BB%96%E5%8A%9F%E8%83%BD%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%EF%BC%8C%E5%92%8C%E4%B9%8B%E5%89%8D%E6%AF%94%E6%B2%A1%E6%9C%89%E5%87%BA%E7%8E%B0%E4%BB%80%E4%B9%88%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E4%BB%AC%E7%94%A8u%E7%9B%98%E5%8D%87%E7%BA%A7%E8%A7%86%E9%A2%91%E8%B5%84%E6%BA%90%E7%9A%84%E6%97%B6%E5%80%99%EF%BC%88%E5%B0%B1%E6%98%AF%E6%8B%B7%E8%B4%9D%E8%A7%86%E9%A2%91%E5%88%B0sd%E5%8D%A1%E4%B8%AD%EF%BC%89%E4%BC%9A%E5%87%BA%E7%8E%B0%E8%8E%AB%E5%90%8D%E5%85%B6%E5%A6%99%E7%9A%84%E9%87%8D%E5%90%AF%EF%BC%8C%E8%80%8C%E4%B8%94%E5%86%85%E6%A0%B8%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%8C%E5%B0%B1%E5%A5%BD%E5%83%8F%E6%8C%89%E4%BA%86%E5%A4%8D%E4%BD%8D%E6%8C%89%E9%94%AE%E4%B8%80%E6%A0%B7%E3%80%82%E6%88%91%E5%B0%86%E6%92%A4%E9%94%80%E8%BF%99%E4%B8%AAkeep%20logo%E5%8A%9F%E8%83%BD%E5%90%8E%E5%B0%B1%E4%B8%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%E8%BF%99%E4%B8%AA%E9%87%8D%E5%90%AF%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E4%BB%AC%E7%9A%84%E4%B8%8A%E5%B1%82%E6%98%AFQt5%2C%E4%B8%8D%E6%98%AF%E5%AE%89%E5%8D%93%EF%BC%8C%E4%BD%A0%E4%BB%AC%E6%9C%89%E6%B2%A1%E6%9C%89%E9%81%87%E5%88%B0%E7%B1%BB%E4%BC%BC%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120831%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120831%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Qiang%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20I%20patched%20u-boot%20and%20kernel%20using%20JB4.3_1.1.1_uboot_logo_keep_patch_2015-09-18%20and%200001-Fix-the-split-mode-LVDS-panel-no-TX3-signal-issue.patch.%20The%20logo%20display%20is%20OK.%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20But%20when%20I%20power%20off%20and%20then%20power%20on%20the%20board%2C%20sometimes%20the%20u-boot%20logo%20can't%20display%20with%20rate%2010~20%25.%20The%20LVDS%20panel%20will%20black%20forever.%20Only%20the%20backlight%20is%20light.%20The%20kernel%20will%20repeatedly%20print%20the%20error%20%22mxc_sdc_fb%20mxc_sdc_fb.0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%22%20after%20the%20android%20system%20booting.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%201.%20My%20platform%20as%20bellow%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%20SOC%3A%20iMX6%20Dual%20Lite%3C%2FP%3E%3CP%3E%26nbsp%3B%20U-Boot%20verson%3A%20U-Boot%202009.08%3C%2FP%3E%3CP%3E%26nbsp%3B%20Kernel%20version%3A%20Linux%203.0.35%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20Android%3A%204.4.2_r1%3C%2FP%3E%3CP%3E%26nbsp%3B%20LVDS%20Panel%3A%20AUO%20M190PW01%20V8%20(19inch%2C%20Resolution%3A%201440x900)%3C%2FP%3E%3CP%3E%26nbsp%3B%20Display%20Mode%3A%20Split%20Mode%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%202.%20The%20u-boot%20display%20setting%20as%20bellow%3A%3C%2FP%3E%3CP%3E%23ifdef%20IPU_OUTPUT_MODE_LVDS%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20For%20LVDS%2C%201440*900%20resolution%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_WIDTH%26nbsp%3B%26nbsp%3B%201440%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_HEIGHT%26nbsp%3B%20900%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_BPP%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2032%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_IF_BPP%26nbsp%3B%2024%26nbsp%3B%20%2F%2F%20RGB24%20interface%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_HSYNC_START%20232%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_HSYNC_END%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2080%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_HSYNC_WIDTH%20152%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_VSYNC_START%2025%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_VSYNC_END%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_VSYNC_WIDTH%206%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_PIX_CLOCK%26nbsp%3B%26nbsp%3B%20106500000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20LVDS_SPLIT_MODE%26nbsp%3B%20%2F%2F%20For%20dual%20channel%20split%20mode.%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_VSYNC_POLARITY%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_HSYNC_POLARITY%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_CLOCK_POLARITY%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_DATA_POLARITY%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DISPLAY_DATA_ENABLE_POLARITY%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20IPU_NUM%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%20%2F%2F%201%20for%20IPU1%2C%202%20for%20IPU2.%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DI_NUM%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%20%2F%2F%200%20for%20DI0%2C%201%20for%20DI1.%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20LVDS_PORT%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%20%2F%2F%200%20for%20LVDS0%2C%201%20for%20LVDS1.%20For%20LVDS%20display%2C%20LVDS_PORT%20should%20be%20same%20as%20DI_NUM.%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23define%20DI_CLOCK_EXTERNAL_MODE%26nbsp%3B%20%2F%2FWhen%20clock%20external%20mode%20was%20defined%2C%20the%20DI%20clock%20root%20will%20be%20PLL3%20PFD1%2C%3C%2FP%3E%3CP%3E%23endif%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120832%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120832%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20got%20these%20patches%20working%20well%20using%20PLL5%20as%20source%20clock%20for%20IPU2%20DI0.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20changed%20the%20source%20clock%20to%20PLL2%20because%20the%20project%20needs%20spread%20spectrum%20enabled%20and%20the%20logo%20is%20kept%20as%20expected%20but%20when%20I%20change%20the%20virtual%20size%20of%20the%20fb(%20from%201920%2C720%20to%201920%2C2160)%26nbsp%3B%20there%20is%20a%20kind%20of%20flicker%20when%20_setup_disp_channel2()%20executes%26nbsp%3B%20ipu_init_channel_buffer_late_init().%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThis%20problem%20is%20not%20happening%20when%20PLL5%20is%20used.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDid%20I%20miss%20something%20to%20change%20IPU2%20DI0%20clock%20source%20to%20pll2_pfd2_396m%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ecat%20%2Fsys%2Fkernel%2Fdebug%2Fclk%2Fclk_summary%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20clock%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20enable_cnt%26nbsp%3B%20prepare_cnt%26nbsp%3B%20rate%3C%2FP%3E%3CP%3E---------------------------------------------------------------------%3C%2FP%3E%3CP%3Eanaclk2%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20lvds2_in%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3Eanaclk1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20lvds1_in%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3Edummy%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20usbphy2_gate%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20usbphy1_gate%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3Eosc%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%206%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%206%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2024000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20periph_clk2_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2024000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20periph_clk2%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2024000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gpt_3m%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203000000%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pll4_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2024000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pll4_audio%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20688128000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pll4_post_div%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20688128000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pll4_audio_div%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20688128000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20esai_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20688128000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20esai_pred%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20344064000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20esai_podf%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2043008000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20esai%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2043008000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ssi3_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20688128000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ssi3_pred%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20172032000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ssi3_podf%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2086016000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ssi3%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2086016000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ssi2_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20688128000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ssi2_pred%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20172032000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ssi2_podf%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2086016000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ssi2%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2086016000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20cko2_sel%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2086016000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20cko2_podf%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2012288000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20cko2%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2012288000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20cko%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2012288000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ssi1_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20688128000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ssi1_pred%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20172032000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ssi1_podf%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2086016000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ssi1%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2086016000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pll7_usb_host%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20480000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20usbphy2%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20480000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pll6_enet%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20500000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20enet_ref%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20125000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pcie_ref%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20125000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pcie_ref_125m%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20125000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20sata_ref%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20100000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20lvds1_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20100000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20lvds1_out%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20100000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20sata_ref_100m%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20100000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pll5_video%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20288000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pll3_usb_otg%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20480000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gpu2d_core_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20480000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gpu2d_core_podf%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20480000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gpu2d_core%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20480000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20asrc_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20480000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20asrc_pred%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20240000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20asrc_podf%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2030000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20asrc%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2030000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20periph2_clk2_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20480000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20periph2_clk2%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20480000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pll3_60m%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2060000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ecspi_root%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2060000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ecspi5%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2060000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ecspi4%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2060000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ecspi3%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2060000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ecspi2%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2060000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ecspi1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2060000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20can_root%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2030000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20can2_serial%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2030000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20can1_serial%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2030000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pll3_80m%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2080000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20uart_serial_podf%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2080000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20uart_serial%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2080000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pll3_120m%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20120000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pll3_pfd3_454m%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20454736842%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20spdif_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20454736842%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20spdif_pred%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20227368421%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20spdif_podf%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2028421052%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20spdif%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2028421052%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pll3_pfd2_508m%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20508235294%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pll3_pfd1_540m%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20540000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20hdmi_isfr%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20540000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20video_27m%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2027000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pll3_pfd0_720m%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20720000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20usbphy1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20480000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pll2_bus%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20528000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20cko1_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20528000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20cko1_podf%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20528000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20cko1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20528000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20periph2_pre%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20528000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20periph2%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20528000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20mmdc_ch1_axi_podf%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20528000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20mmdc_ch1_axi%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20528000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ldb_di1_sel%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20528000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ldb_di1_div_7%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2075428571%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ldb_di1_div_sel%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2075428571%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ldb_di1%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2075428571%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ldb_di1_div_3_5%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20150857142%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20periph_pre%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20528000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20periph%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20528000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ahb%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%204%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%204%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20132000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20sdma%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%208%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20132000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20rom%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20132000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ocram%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20132000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20hdmi_iahb%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20132000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20caam_aclk%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20132000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20caam_mem%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20132000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipg%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%204%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%204%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20usboh3%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20uart_ipg%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ssi3_ipg%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ssi2_ipg%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ssi1_ipg%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20spba%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20sata%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20iim%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gpt_ipg%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20epit2%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20epit1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20enet%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20can2_ipg%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20can1_ipg%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20caam_ipg%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipg_per%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pwm4%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pwm3%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pwm2%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pwm1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20i2c3%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20i2c2%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20i2c1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gpt_ipg_per%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2066000000%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20mmdc_ch0_axi_podf%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20528000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20mmdc_ch0_axi%26nbsp%3B%26nbsp%3B%26nbsp%3B%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20528000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gpu3d_core_sel%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20528000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gpu3d_core_podf%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20528000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gpu3d_core%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20528000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu1_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20528000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu1_podf%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu1%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu1_pclk1_sel%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu1_pclk1_div%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu1_pclk_1%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu1_pclk0_sel%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu1_pclk0_div%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu1_pclk_0%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20dcic1%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu2_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20528000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu2_podf%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu2%26nbsp%3B%26nbsp%3B%203%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu2_pclk1_sel%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu2_pclk1_div%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu2_pclk_1%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu2_pclk0_sel%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu2_pclk0_div%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu2_pclk_0%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20dcic2%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20tzasc2%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20528000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20axi_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20528000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20axi%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20openvg_axi%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20mlb%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gpu2d_axi%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gpu3d_axi%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pcie_axi_sel%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pcie_axi%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20emi_slow_sel%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20emi_slow_podf%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20132000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20eim_slow%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20132000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vdo_axi_sel%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vdo_axi%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vdoa%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vpu_axi_sel%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vpu_axi_podf%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vpu_axi%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pll2_pfd2_396m%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%204%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%204%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20339428571%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu2_di1_pre_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20339428571%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu2_di1_pre%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20113142857%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu2_di1_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20113142857%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu2_di1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20113142857%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu2_di0_pre_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20339428571%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu2_di0_pre%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20113142857%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu1_di1_pre_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20339428571%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu1_di1_pre%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20113142857%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu1_di1_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20113142857%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu1_di1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20113142857%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu1_di0_pre_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20339428571%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu1_di0_pre%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20113142857%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu1_di0_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20113142857%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu1_di0%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20113142857%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20emi_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20339428571%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20emi_podf%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20169714285%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20enfc_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20339428571%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20enfc_pred%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2084857142%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20enfc_podf%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2084857142%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20enfc%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2084857142%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gpmi_io%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2084857142%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20usdhc4_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20339428571%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20usdhc4_podf%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20169714285%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20usdhc4%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20169714285%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gpmi_bch%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20169714285%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20usdhc3_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20339428571%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20usdhc3_podf%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20169714285%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20usdhc3%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%204%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%204%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20169714285%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20apbh_dma%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20169714285%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20per1_bch%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20169714285%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gpmi_bch_apb%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20169714285%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gpmi_apb%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20169714285%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20usdhc2_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20339428571%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20usdhc2_podf%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20169714285%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20usdhc2%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20169714285%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20usdhc1_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20339428571%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20usdhc1_podf%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20169714285%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20usdhc1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20169714285%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20hsi_tx_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20339428571%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20hsi_tx_podf%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20169714285%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20hsi_tx%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20169714285%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ldb_di0_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20339428571%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ldb_di0_div_7%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2048489795%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ldb_di0_div_3_5%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2096979591%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ldb_di0_div_sel%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2096979591%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ldb_di0%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2096979591%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu2_di0_sel%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2096979591%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ipu2_di0%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2096979591%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20step%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20339428571%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pll2_198m%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20169714285%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pll2_pfd1_594m%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20594000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gpu3d_shader_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20594000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gpu3d_shader%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20594000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pll2_pfd0_352m%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20352000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pll1_sys%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20852000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pll1_sw%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20852000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20arm%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20852000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20lvds2_sel%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20852000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20lvds2_out%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20852000000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20twd%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20426000000%3C%2FP%3E%3CP%3Eckih1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3Eckil%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2032768%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%23%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120834%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120834%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESorry%2C%20MIPI%20display%20is%20not%20supported%20by%20this%20patch.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EEach%20MIPI%20display%20has%20its%20own%20special%20setting%20and%20initialization%20code%2C%20that%20means%20even%20we%20create%20a%20reference%20patch%2C%20you%20can't%20re-use%20it.%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20key%20point%20for%20this%20patch%20is%20to%20avoid%20IPU%20and%20MIPI%20display%20re-initialization%20in%20kernel%2C%20the%20skip%20IPU%20code%20can%20be%20re-used%20here%2C%20and%20you%20need%20debug%20the%20code%20to%20avoid%20your%20MIPI%20display%20re-initialization.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20Qiang%20Li.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI'm%20using%20%3CSTRONG%3Eandroid_N7.1.1_1.0.0%3C%2FSTRONG%3E%20for%20%3CSTRONG%3Ei.MX6pq%20sabresd%3C%2FSTRONG%3E.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDisplay%20%3A%20800x1280%20LVDS%20(output%20to%20IPU1-DI0)%3C%2FP%3E%3CP%3EApply%20patch%20%3A%26nbsp%3B%3CSTRONG%3EM6.0.1_2.1.0_uboot_logo_keep_patch_2017-01-06.zip%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EProblem%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3Eu-boot%20%3A%20%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3Elockup%3C%2FSPAN%3E%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%3CP%3EU-Boot%202015.04%20(Jul%2004%202017%20-%2021%3A08%3A43)%3C%2FP%3E%3CP%3ECPU%3A%20Freescale%20i.MX6QP%20rev1.0%20at%20792%20MHz%3CBR%20%2F%3ECPU%3A%20Temperature%2045%20C%3CBR%20%2F%3EReset%20cause%3A%20POR%3CBR%20%2F%3EBoard%3A%20MX6-SabreSD%3CBR%20%2F%3EI2C%3A%20ready%3CBR%20%2F%3EDRAM%3A%202%20GiB%3CBR%20%2F%3EPMIC%3A%20PFUZE100%20ID%3D0x10%3CBR%20%2F%3EMMC%3A%20FSL_SDHC%3A%200%2C%20FSL_SDHC%3A%201%2C%20FSL_SDHC%3A%202%3CBR%20%2F%3E***%20Warning%20-%20bad%20CRC%2C%20using%20default%20environment%3C%2FP%3E%3CP%3EIn%3A%20serial%3CBR%20%2F%3EOut%3A%20serial%3CBR%20%2F%3EErr%3A%20serial%3CBR%20%2F%3Econfig_ipu_lvds_clk%3A%20freq%20%3D%20471018240.%3CBR%20%2F%3Econfig_ipu_lvds_clk%3A%20set%20pll2_pfd0%20clock%20to%20468MHz%2C%20divider%20%3D%2020.%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E...%20lockup%20...%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3ECorrection%20%3A%20%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%3CSTRONG%3Edelete%20IPU2%20QoS%20generator%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CP%3Evoid%20ipu_setup(unsigned%20int%20IPU%2C%20unsigned%20int%20DI)%3CBR%20%2F%3E%7B%3CBR%20%2F%3E...%3C%2FP%3E%3CP%3E%23ifdef%20CONFIG_MX6QP%3CBR%20%2F%3E%20reg%20%3D%20__raw_readl(%26amp%3Bimx_ccm-%26gt%3BCCGR6)%3B%3CBR%20%2F%3E%20reg%20%7C%3D%20MXC_CCM_CCGR6_PRG_CLK0_MASK%3B%3CBR%20%2F%3E%20__raw_writel(reg%2C%20%26amp%3Bimx_ccm-%26gt%3BCCGR6)%3B%3C%2FP%3E%3CP%3E%2F*%20Bypass%20IPU1%20QoS%20generator%20*%2F%3CBR%20%2F%3E%20__raw_writel(0x00000002%2C%200x00bb048c)%3B%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E--%20%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%2F*%20Bypass%20IPU2%20QoS%20generator%20*%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E--%20%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E__raw_writel(0x00000002%2C%200x00bb050c)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%20%2F*%20Bandwidth%20THR%20for%20of%20PRE0%20*%2F%3CBR%20%2F%3E%20__raw_writel(0x00000200%2C%200x00bb0690)%3B%3CBR%20%2F%3E%20%2F*%20Bandwidth%20THR%20for%20of%20PRE1%20*%2F%3CBR%20%2F%3E%20__raw_writel(0x00000200%2C%200x00bb0710)%3B%3CBR%20%2F%3E%20%2F*%20Bandwidth%20THR%20for%20of%20PRE2%20*%2F%3CBR%20%2F%3E%20__raw_writel(0x00000200%2C%200x00bb0790)%3B%3CBR%20%2F%3E%20%2F*%20Bandwidth%20THR%20for%20of%20PRE3%20*%2F%3CBR%20%2F%3E%20__raw_writel(0x00000200%2C%200x00bb0810)%3B%3CBR%20%2F%3E%20%2F*%20Saturation%20THR%20for%20of%20PRE0%20*%2F%3CBR%20%2F%3E%20__raw_writel(0x00000010%2C%200x00bb0694)%3B%3CBR%20%2F%3E%20%2F*%20Saturation%20THR%20for%20of%20PRE1%20*%2F%3CBR%20%2F%3E%20__raw_writel(0x00000010%2C%200x00bb0714)%3B%3CBR%20%2F%3E%20%2F*%20Saturation%20THR%20for%20of%20PRE2%20*%2F%3CBR%20%2F%3E%20__raw_writel(0x00000010%2C%200x00bb0794)%3B%3CBR%20%2F%3E%20%2F*%20Saturation%20THR%20for%20of%20PRE%20*%2F%3CBR%20%2F%3E%20__raw_writel(0x00000010%2C%200x00bb0814)%3B%3CBR%20%2F%3E%23endif%3C%2FP%3E%3CP%3E...%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3E%3CSTRONG%3E%3CSPAN%20style%3D%22background-color%3A%20%23efefef%3B%22%3Ekernel%20%3A%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3Elockup%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%3CP%3EU-Boot%202015.04%20(Jul%2004%202017%20-%2021%3A08%3A43)%3C%2FP%3E%3CP%3ECPU%3A%20Freescale%20i.MX6QP%20rev1.0%20at%20792%20MHz%3CBR%20%2F%3ECPU%3A%20Temperature%2045%20C%3CBR%20%2F%3EReset%20cause%3A%20POR%3CBR%20%2F%3EBoard%3A%20MX6-SabreSD%3CBR%20%2F%3EI2C%3A%20ready%3CBR%20%2F%3EDRAM%3A%202%20GiB%3CBR%20%2F%3EPMIC%3A%20PFUZE100%20ID%3D0x10%3CBR%20%2F%3EMMC%3A%20FSL_SDHC%3A%200%2C%20FSL_SDHC%3A%201%2C%20FSL_SDHC%3A%202%3CBR%20%2F%3E***%20Warning%20-%20bad%20CRC%2C%20using%20default%20environment%3C%2FP%3E%3CP%3EIn%3A%20serial%3CBR%20%2F%3EOut%3A%20serial%3CBR%20%2F%3EErr%3A%20serial%3CBR%20%2F%3Econfig_ipu_lvds_clk%3A%20freq%20%3D%20471018240.%3CBR%20%2F%3Econfig_ipu_lvds_clk%3A%20set%20pll2_pfd0%20clock%20to%20468MHz%2C%20divider%20%3D%2020.%3CBR%20%2F%3Eflash%20target%20is%20MMC%3A2%3CBR%20%2F%3EFastboot%3A%20Normal%3CBR%20%2F%3ENet%3A%20Phy%201%20not%20found%3CBR%20%2F%3EFEC%20%5BPRIME%5D%3CBR%20%2F%3EError%3A%20FEC%20address%20not%20set.%3C%2FP%3E%3CP%3EHit%20any%20key%20to%20stop%20autoboot%3A%200%3CBR%20%2F%3Eboota%20mmc2%3CBR%20%2F%3Ekernel%20%40%2014008000%20(8851024)%3CBR%20%2F%3Eramdisk%20%40%2015000000%20(1636188)%3CBR%20%2F%3Efdt%20%40%2014f00000%20(48851)%3CBR%20%2F%3E%23%23%20Booting%20Android%20Image%20at%200x12000000%20...%3CBR%20%2F%3EKernel%20load%20addr%200x14008000%20size%208644%20KiB%3CBR%20%2F%3EKernel%20command%20line%3A%20console%3Dttymxc0%2C115200%20init%3D%2Finit%20video%3Dmxcfb0%3Adev%3Dldb%2Cbpp%3D32%20video%3Dmxcfb1%3Aoff%20video%3Dmxcfb2%3Aoff%20video%3Dmxcfb3%3Aoff%20vmalloc%3D128M%20androidboot.console%3Dttymxc0%20consoleblank%3D0%20androidboot.hardware%3Dfreescale%20cma%3D448M%20buildvariant%3Deng%3CBR%20%2F%3E%23%23%20Flattened%20Device%20Tree%20blob%20at%2014f00000%3CBR%20%2F%3E%20Booting%20using%20the%20fdt%20blob%20at%200x14f00000%3CBR%20%2F%3E%20Loading%20Kernel%20Image%20...%20OK%3CBR%20%2F%3E%20Using%20Device%20Tree%20in%20place%20at%2014f00000%2C%20end%2014f0eed2%3CBR%20%2F%3Eswitch%20to%20ldo_bypass%20mode!%3C%2FP%3E%3CP%3EStarting%20kernel%20...%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E...%20lockup%20...%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3ECorrection%20%3A%20%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%3CSTRONG%3EAdded%20bypass_reset%20to%20ipu2%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CP%3Eimx6qp.dtsi%3C%2FP%3E%3CP%3E%2F%20%7B%3C%2FP%3E%3CP%3E...%3CBR%20%2F%3E%20soc%20%7B%3CBR%20%2F%3E%20ipu2%3A%20ipu%4002800000%20%7B%3CBR%20%2F%3E%20compatible%20%3D%20%22fsl%2Cimx6qp-ipu%22%2C%20%22fsl%2Cimx6q-ipu%22%3B%3CBR%20%2F%3E%20clocks%20%3D%20%26lt%3B%26amp%3Bclks%20IMX6QDL_CLK_IPU2%26gt%3B%2C%3CBR%20%2F%3E%20%26lt%3B%26amp%3Bclks%20IMX6QDL_CLK_IPU2_DI0%26gt%3B%2C%20%26lt%3B%26amp%3Bclks%20IMX6QDL_CLK_IPU2_DI1%26gt%3B%2C%3CBR%20%2F%3E%20%26lt%3B%26amp%3Bclks%20IMX6QDL_CLK_IPU2_DI0_SEL%26gt%3B%2C%20%26lt%3B%26amp%3Bclks%20IMX6QDL_CLK_IPU2_DI1_SEL%26gt%3B%2C%3CBR%20%2F%3E%20%26lt%3B%26amp%3Bclks%20IMX6QDL_CLK_LDB_DI0_DIV_SEL%26gt%3B%2C%20%26lt%3B%26amp%3Bclks%20IMX6QDL_CLK_LDB_DI1_DIV_SEL%26gt%3B%2C%3CBR%20%2F%3E%20%26lt%3B%26amp%3Bclks%20IMX6QDL_CLK_PRG1_APB%26gt%3B%3B%3CBR%20%2F%3E%20clock-names%20%3D%20%22bus%22%2C%3CBR%20%2F%3E%20%22di0%22%2C%20%22di1%22%2C%3CBR%20%2F%3E%20%22di0_sel%22%2C%20%22di1_sel%22%2C%3CBR%20%2F%3E%20%22ldb_di0%22%2C%20%22ldb_di1%22%2C%20%22prg%22%3B%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%2B%2B%3C%2FSPAN%3E%20bypass_reset%20%3D%20%26lt%3B1%26gt%3B%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E...%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2300ff00%3B%22%3E%3CSTRONG%3Ethe%20lvds%20output%20is%20good%20until%20the%20bootanimation.%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%20white-space%3A%20pre%3B%20font-size%3A%2022px%3B%22%3E%3CSTRONG%3EQuestion%20%3A%20fb0%20timeout%20problem%20occurred%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%20white-space%3A%20pre%3B%22%3Emxc_sdc_fb%20fb%400%3A%20timeout%20when%20waiting%20for%20flip%20irq%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230000ff%3B%22%3E%3CSPAN%20style%3D%22white-space%3A%20pre%3B%22%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22white-space%3A%20pre%3B%22%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%20white-space%3A%20pre%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%20white-space%3A%20pre%3B%22%3E%3CSTRONG%3EWhat's%20wrong%3F%20What%20should%20I%20do%3F%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eexpect%20some%20advice...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%3CTH%3Eserial%2C%20logcat%2C%20ls%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%3CP%3EU-Boot%202015.04%20(Jul%2004%202017%20-%2021%3A08%3A43)%3C%2FP%3E%3CP%3ECPU%3A%20Freescale%20i.MX6QP%20rev1.0%20at%20792%20MHz%3CBR%20%2F%3ECPU%3A%20Temperature%2045%20C%3CBR%20%2F%3EReset%20cause%3A%20POR%3CBR%20%2F%3EBoard%3A%20MX6-SabreSD%3CBR%20%2F%3EI2C%3A%20ready%3CBR%20%2F%3EDRAM%3A%202%20GiB%3CBR%20%2F%3EPMIC%3A%20PFUZE100%20ID%3D0x10%3CBR%20%2F%3EMMC%3A%20FSL_SDHC%3A%200%2C%20FSL_SDHC%3A%201%2C%20FSL_SDHC%3A%202%3CBR%20%2F%3E***%20Warning%20-%20bad%20CRC%2C%20using%20default%20environment%3C%2FP%3E%3CP%3EIn%3A%20serial%3CBR%20%2F%3EOut%3A%20serial%3CBR%20%2F%3EErr%3A%20serial%3CBR%20%2F%3Econfig_ipu_lvds_clk%3A%20freq%20%3D%20471018240.%3CBR%20%2F%3Econfig_ipu_lvds_clk%3A%20set%20pll2_pfd0%20clock%20to%20468MHz%2C%20divider%20%3D%2020.%3CBR%20%2F%3Eflash%20target%20is%20MMC%3A2%3CBR%20%2F%3EFastboot%3A%20Normal%3CBR%20%2F%3ENet%3A%20Phy%201%20not%20found%3CBR%20%2F%3EFEC%20%5BPRIME%5D%3CBR%20%2F%3EError%3A%20FEC%20address%20not%20set.%3C%2FP%3E%3CP%3EHit%20any%20key%20to%20stop%20autoboot%3A%200%3CBR%20%2F%3Eboota%20mmc2%3CBR%20%2F%3Ekernel%20%40%2014008000%20(8851024)%3CBR%20%2F%3Eramdisk%20%40%2015000000%20(1636188)%3CBR%20%2F%3Efdt%20%40%2014f00000%20(48851)%3CBR%20%2F%3E%23%23%20Booting%20Android%20Image%20at%200x12000000%20...%3CBR%20%2F%3EKernel%20load%20addr%200x14008000%20size%208644%20KiB%3CBR%20%2F%3EKernel%20command%20line%3A%20console%3Dttymxc0%2C115200%20init%3D%2Finit%20video%3Dmxcfb0%3Adev%3Dldb%2Cbpp%3D32%20video%3Dmxcfb1%3Aoff%20video%3Dmxcfb2%3Aoff%20video%3Dmxcfb3%3Aoff%20vmalloc%3D128M%20androidboot.console%3Dttymxc0%20consoleblank%3D0%20androidboot.hardware%3Dfreescale%20cma%3D448M%20buildvariant%3Deng%3CBR%20%2F%3E%23%23%20Flattened%20Device%20Tree%20blob%20at%2014f00000%3CBR%20%2F%3E%20Booting%20using%20the%20fdt%20blob%20at%200x14f00000%3CBR%20%2F%3E%20Loading%20Kernel%20Image%20...%20OK%3CBR%20%2F%3E%20Using%20Device%20Tree%20in%20place%20at%2014f00000%2C%20end%2014f0eed2%3CBR%20%2F%3Eswitch%20to%20ldo_bypass%20mode!%3C%2FP%3E%3CP%3EStarting%20kernel%20...%3C%2FP%3E%3CP%3EBooting%20Linux%20on%20physical%20CPU%200x0%3CBR%20%2F%3EInitializing%20cgroup%20subsys%20cpu%3CBR%20%2F%3EInitializing%20cgroup%20subsys%20cpuacct%3CBR%20%2F%3ELinux%20version%204.1.15%20(linus%40compile)%20(gcc%20version%204.9%2020150123%20(prerelease)%20(GCC)%20)%20%2323%20SMP%20PREEMPT%20Tue%20Jul%204%2022%3A26%3A03%20KST%202017%3CBR%20%2F%3ECPU%3A%20ARMv7%20Processor%20%5B412fc09a%5D%20revision%2010%20(ARMv7)%2C%20cr%3D10c53c7d%3CBR%20%2F%3ECPU%3A%20PIPT%20%2F%20VIPT%20nonaliasing%20data%20cache%2C%20VIPT%20aliasing%20instruction%20cache%3CBR%20%2F%3EMachine%20model%3A%20Freescale%20i.MX6%20Quad%20Plus%20SABRE%20Smart%20Device%20Board%3CBR%20%2F%3Ecma%3A%20Reserved%20448%20MiB%20at%200x2a000000%3CBR%20%2F%3EMemory%20policy%3A%20Data%20cache%20writealloc%3CBR%20%2F%3EPERCPU%3A%20Embedded%2013%20pages%2Fcpu%20%40f6eb9000%20s22144%20r8192%20d22912%20u53248%3CBR%20%2F%3EBuilt%201%20zonelists%20in%20Zone%20order%2C%20mobility%20grouping%20on.%20Total%20pages%3A%20516128%3CBR%20%2F%3EKernel%20command%20line%3A%20console%3Dttymxc0%2C115200%20init%3D%2Finit%20video%3Dmxcfb0%3Adev%3Dldb%2Cbpp%3D32%20video%3Dmxcfb1%3Aoff%20video%3Dmxcfb2%3Aoff%20video%3Dmxcfb3%3Aoff%20vmalloc%3D128M%20androidboot.console%3Dttymxc0%20consoleblank%3D0%20androidboot.hardware%3Dfreescale%20cma%3D448M%20buildvariant%3Deng%20androidboot.serialno%3D0e0321d4e3167aba%20androidboot.bootreason%3Dnormal%3CBR%20%2F%3EPID%20hash%20table%20entries%3A%204096%20(order%3A%202%2C%2016384%20bytes)%3CBR%20%2F%3EDentry%20cache%20hash%20table%20entries%3A%20131072%20(order%3A%207%2C%20524288%20bytes)%3CBR%20%2F%3EInode-cache%20hash%20table%20entries%3A%2065536%20(order%3A%206%2C%20262144%20bytes)%3CBR%20%2F%3EMemory%3A%201574608K%2F2071552K%20available%20(11264K%20kernel%20code%2C%201025K%20rwdata%2C%203712K%20rodata%2C%201024K%20init%2C%20641K%20bss%2C%2038192K%20reserved%2C%20458752K%20cma-reserved%2C%201195008K%20highmem)%3CBR%20%2F%3EVirtual%20kernel%20memory%20layout%3A%3CBR%20%2F%3E%20vector%20%3A%200xffff0000%20-%200xffff1000%20(%204%20kB)%3CBR%20%2F%3E%20fixmap%20%3A%200xffc00000%20-%200xfff00000%20(3072%20kB)%3CBR%20%2F%3E%20vmalloc%20%3A%200xf7800000%20-%200xff000000%20(%20120%20MB)%3CBR%20%2F%3E%20lowmem%20%3A%200xc0000000%20-%200xf7000000%20(%20880%20MB)%3CBR%20%2F%3E%20pkmap%20%3A%200xbfe00000%20-%200xc0000000%20(%202%20MB)%3CBR%20%2F%3E%20modules%20%3A%200xbf000000%20-%200xbfe00000%20(%2014%20MB)%3CBR%20%2F%3E%20.text%20%3A%200xc0008000%20-%200xc0c00000%20(12256%20kB)%3CBR%20%2F%3E%20.init%20%3A%200xc1000000%20-%200xc1100000%20(1024%20kB)%3CBR%20%2F%3E%20.data%20%3A%200xc1100000%20-%200xc12007b0%20(1026%20kB)%3CBR%20%2F%3E%20.bss%20%3A%200xc12007b0%20-%200xc12a0e24%20(%20642%20kB)%3CBR%20%2F%3ESLUB%3A%20HWalign%3D64%2C%20Order%3D0-3%2C%20MinObjects%3D0%2C%20CPUs%3D4%2C%20Nodes%3D1%3CBR%20%2F%3EPreemptible%20hierarchical%20RCU%20implementation.%3CBR%20%2F%3E%20Additional%20per-CPU%20info%20printed%20with%20stalls.%3CBR%20%2F%3ENR_IRQS%3A16%20nr_irqs%3A16%2016%3CBR%20%2F%3EL2C-310%20erratum%20769419%20enabled%3CBR%20%2F%3EL2C-310%20enabling%20early%20BRESP%20for%20Cortex-A9%3CBR%20%2F%3EL2C-310%20full%20line%20of%20zeros%20enabled%20for%20Cortex-A9%3CBR%20%2F%3EL2C-310%20ID%20prefetch%20enabled%2C%20offset%2016%20lines%3CBR%20%2F%3EL2C-310%20dynamic%20clock%20gating%20enabled%2C%20standby%20mode%20enabled%3CBR%20%2F%3EL2C-310%20cache%20controller%20enabled%2C%2016%20ways%2C%201024%20kB%3CBR%20%2F%3EL2C-310%3A%20CACHE_ID%200x410000c8%2C%20AUX_CTRL%200x76070001%3CBR%20%2F%3Efailed%20to%20set%20parent%20of%20clk%20ipu1_di0_sel%20to%20ldb_di0%3A%20-22%3CBR%20%2F%3Emxc_clocksource_init%203000000%3CBR%20%2F%3ESwitching%20to%20timer-based%20delay%20loop%2C%20resolution%20333ns%3CBR%20%2F%3Esched_clock%3A%2032%20bits%20at%203000kHz%2C%20resolution%20333ns%2C%20wraps%20every%20715827882841ns%3CBR%20%2F%3Eclocksource%20mxc_timer1%3A%20mask%3A%200xffffffff%20max_cycles%3A%200xffffffff%2C%20max_idle_ns%3A%20637086815595%20ns%3CBR%20%2F%3EConsole%3A%20colour%20dummy%20device%2080x30%3CBR%20%2F%3ECalibrating%20delay%20loop%20(skipped)%2C%20value%20calculated%20using%20timer%20frequency..%206.00%20BogoMIPS%20(lpj%3D30000)%3CBR%20%2F%3Epid_max%3A%20default%3A%2032768%20minimum%3A%20301%3CBR%20%2F%3ESecurity%20Framework%20initialized%3CBR%20%2F%3ESELinux%3A%20Initializing.%3CBR%20%2F%3EAppArmor%3A%20AppArmor%20disabled%20by%20boot%20time%20parameter%3CBR%20%2F%3EMount-cache%20hash%20table%20entries%3A%202048%20(order%3A%201%2C%208192%20bytes)%3CBR%20%2F%3EMountpoint-cache%20hash%20table%20entries%3A%202048%20(order%3A%201%2C%208192%20bytes)%3CBR%20%2F%3EInitializing%20cgroup%20subsys%20freezer%3CBR%20%2F%3EInitializing%20cgroup%20subsys%20debug%3CBR%20%2F%3ECPU%3A%20Testing%20write%20buffer%20coherency%3A%20ok%3CBR%20%2F%3ECPU0%3A%20thread%20-1%2C%20cpu%200%2C%20socket%200%2C%20mpidr%2080000000%3CBR%20%2F%3ESetting%20up%20static%20identity%20map%20for%200x10100000%20-%200x10100058%3CBR%20%2F%3ECPU1%3A%20thread%20-1%2C%20cpu%201%2C%20socket%200%2C%20mpidr%2080000001%3CBR%20%2F%3ECPU2%3A%20thread%20-1%2C%20cpu%202%2C%20socket%200%2C%20mpidr%2080000002%3CBR%20%2F%3ECPU3%3A%20thread%20-1%2C%20cpu%203%2C%20socket%200%2C%20mpidr%2080000003%3CBR%20%2F%3EBrought%20up%204%20CPUs%3CBR%20%2F%3ESMP%3A%20Total%20of%204%20processors%20activated%20(24.00%20BogoMIPS).%3CBR%20%2F%3ECPU%3A%20All%20CPU(s)%20started%20in%20SVC%20mode.%3CBR%20%2F%3Edevtmpfs%3A%20initialized%3CBR%20%2F%3EVFP%20support%20v0.3%3A%20implementor%2041%20architecture%203%20part%2030%20variant%209%20rev%204%3CBR%20%2F%3Eclocksource%20jiffies%3A%20mask%3A%200xffffffff%20max_cycles%3A%200xffffffff%2C%20max_idle_ns%3A%2019112604462750000%20ns%3CBR%20%2F%3Epinctrl%20core%3A%20initialized%20pinctrl%20subsystem%3CBR%20%2F%3ENET%3A%20Registered%20protocol%20family%2016%3CBR%20%2F%3EDMA%3A%20preallocated%20256%20KiB%20pool%20for%20atomic%20coherent%20allocations%3CBR%20%2F%3Ecpuidle%3A%20using%20governor%20ladder%3CBR%20%2F%3Ecpuidle%3A%20using%20governor%20menu%3CBR%20%2F%3ECPU%20identified%20as%20i.MX6QP%2C%20silicon%20rev%201.0%3CBR%20%2F%3Eanatop_regulator%2020c8000.anatop%3Aregulator-vddcore%40140%3A%20Failed%20to%20read%20a%20valid%20default%20voltage%20selector.%3CBR%20%2F%3Eanatop_regulator%3A%20probe%20of%2020c8000.anatop%3Aregulator-vddcore%40140%20failed%20with%20error%20-22%3CBR%20%2F%3Eanatop_regulator%2020c8000.anatop%3Aregulator-vddsoc%40140%3A%20Failed%20to%20read%20a%20valid%20default%20voltage%20selector.%3CBR%20%2F%3Eanatop_regulator%3A%20probe%20of%2020c8000.anatop%3Aregulator-vddsoc%40140%20failed%20with%20error%20-22%3CBR%20%2F%3E!!request%20miniPCIE%20Power%20On%20gpio%3CBR%20%2F%3Ehw-breakpoint%3A%20found%205%20(%2B1%20reserved)%20breakpoint%20and%201%20watchpoint%20registers.%3CBR%20%2F%3Ehw-breakpoint%3A%20maximum%20watchpoint%20size%20is%204%20bytes.%3CBR%20%2F%3Eimx6q-pinctrl%2020e0000.iomuxc%3A%20initialized%20IMX%20pinctrl%20driver%3CBR%20%2F%3Emxs-dma%20110000.dma-apbh%3A%20initialized%3CBR%20%2F%3EMPCIE_3V3%3A%20Failed%20to%20request%20enable%20GPIO83%3A%20-16%3CBR%20%2F%3Ereg-fixed-voltage%20regulators%3Aregulator%403%3A%20Failed%20to%20register%20regulator%3A%20-16%3CBR%20%2F%3Ereg-fixed-voltage%3A%20probe%20of%20regulators%3Aregulator%403%20failed%20with%20error%20-16%3CBR%20%2F%3ESCSI%20subsystem%20initialized%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20usbfs%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20hub%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20device%20driver%20usb%3CBR%20%2F%3E2000000.aips-bus%3Ausbphy_nop1%20supply%20vcc%20not%20found%2C%20using%20dummy%20regulator%3CBR%20%2F%3E2000000.aips-bus%3Ausbphy_nop2%20supply%20vcc%20not%20found%2C%20using%20dummy%20regulator%3CBR%20%2F%3Ei2c%20i2c-0%3A%20IMX%20I2C%20adapter%20registered%3CBR%20%2F%3Ei2c%20i2c-0%3A%20can't%20use%20DMA%3CBR%20%2F%3Ei2c%20i2c-1%3A%20IMX%20I2C%20adapter%20registered%3CBR%20%2F%3Ei2c%20i2c-1%3A%20can't%20use%20DMA%3CBR%20%2F%3Ei2c%20i2c-2%3A%20IMX%20I2C%20adapter%20registered%3CBR%20%2F%3Ei2c%20i2c-2%3A%20can't%20use%20DMA%3CBR%20%2F%3ELinux%20video%20capture%20interface%3A%20v2.00%3CBR%20%2F%3Epps_core%3A%20LinuxPPS%20API%20ver.%201%20registered%3CBR%20%2F%3E%3CSPAN%3Epps_core%3A%20Software%20ver.%205.3.6%20-%20Copyright%202005-2007%20Rodolfo%20Giometti%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Agiometti%40linux.it%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Egiometti%40linux.it%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CBR%20%2F%3EPTP%20clock%20support%20registered%3CBR%20%2F%3Eimx-prg%2021cc000.prg%3A%20driver%20probed%3CBR%20%2F%3Eimx-prg%2021cd000.prg%3A%20driver%20probed%3CBR%20%2F%3Eimx-pre%2021c8000.pre%3A%20driver%20probed%3CBR%20%2F%3Eimx-pre%2021c9000.pre%3A%20driver%20probed%3CBR%20%2F%3Eimx-pre%2021ca000.pre%3A%20driver%20probed%3CBR%20%2F%3Eimx-pre%2021cb000.pre%3A%20driver%20probed%3CBR%20%2F%3Emxc_mipi_csi2%2021dc000.mipi_csi%3A%20i.MX%20MIPI%20CSI2%20driver%20probed%3CBR%20%2F%3Emxc_mipi_csi2%2021dc000.mipi_csi%3A%20i.MX%20MIPI%20CSI2%20dphy%20version%20is%200x3130302a%3CBR%20%2F%3EMIPI%20CSI2%20driver%20module%20loaded%3CBR%20%2F%3EAdvanced%20Linux%20Sound%20Architecture%20Driver%20Initialized.%3CBR%20%2F%3EBluetooth%3A%20Core%20ver%202.20%3CBR%20%2F%3ENET%3A%20Registered%20protocol%20family%2031%3CBR%20%2F%3EBluetooth%3A%20HCI%20device%20and%20connection%20manager%20initialized%3CBR%20%2F%3EBluetooth%3A%20HCI%20socket%20layer%20initialized%3CBR%20%2F%3EBluetooth%3A%20L2CAP%20socket%20layer%20initialized%3CBR%20%2F%3EBluetooth%3A%20SCO%20socket%20layer%20initialized%3CBR%20%2F%3ESwitched%20to%20clocksource%20mxc_timer1%3CBR%20%2F%3ENET%3A%20Registered%20protocol%20family%202%3CBR%20%2F%3ETCP%20established%20hash%20table%20entries%3A%208192%20(order%3A%203%2C%2032768%20bytes)%3CBR%20%2F%3ETCP%20bind%20hash%20table%20entries%3A%208192%20(order%3A%204%2C%2065536%20bytes)%3CBR%20%2F%3ETCP%3A%20Hash%20tables%20configured%20(established%208192%20bind%208192)%3CBR%20%2F%3EUDP%20hash%20table%20entries%3A%20512%20(order%3A%202%2C%2016384%20bytes)%3CBR%20%2F%3EUDP-Lite%20hash%20table%20entries%3A%20512%20(order%3A%202%2C%2016384%20bytes)%3CBR%20%2F%3ENET%3A%20Registered%20protocol%20family%201%3CBR%20%2F%3ERPC%3A%20Registered%20named%20UNIX%20socket%20transport%20module.%3CBR%20%2F%3ERPC%3A%20Registered%20udp%20transport%20module.%3CBR%20%2F%3ERPC%3A%20Registered%20tcp%20transport%20module.%3CBR%20%2F%3ERPC%3A%20Registered%20tcp%20NFSv4.1%20backchannel%20transport%20module.%3CBR%20%2F%3ETrying%20to%20unpack%20rootfs%20image%20as%20initramfs...%3CBR%20%2F%3EFreeing%20initrd%20memory%3A%201600K%20(c5000000%20-%20c5190000)%3CBR%20%2F%3ECPU%20PMU%3A%20Failed%20to%20parse%20%2Fsoc%2Fpmu%2Finterrupt-affinity%5B0%5D%3CBR%20%2F%3Ehw%20perfevents%3A%20enabled%20with%20armv7_cortex_a9%20PMU%20driver%2C%207%20counters%20available%3CBR%20%2F%3Eimx%20rpmsg%20driver%20is%20registered.%3CBR%20%2F%3EBus%20freq%20driver%20module%20loaded%3CBR%20%2F%3Econsole%20%5Bpstore-1%5D%20enabled%3CBR%20%2F%3Epstore%3A%20Registered%20ramoops%20as%20persistent%20store%20backend%3CBR%20%2F%3Eramoops%3A%20attached%200x100000%400x8bf00000%2C%20ecc%3A%200%2F0%3CBR%20%2F%3Emxc_ramoops%20device%20success%20loaded%3CBR%20%2F%3Ebt%20power%20gpio%20is%3A2%3CBR%20%2F%3Erfkill%3A%20BT%20RF%20going%20to%20%3A%20on%3CBR%20%2F%3Emxc_bt_rfkill_reset%3CBR%20%2F%3Emxc_bt_rfkill%20driver%20success%20loaded%3CBR%20%2F%3Efutex%20hash%20table%20entries%3A%201024%20(order%3A%204%2C%2065536%20bytes)%3CBR%20%2F%3Eaudit%3A%20initializing%20netlink%20subsys%20(disabled)%3CBR%20%2F%3Eaudit%3A%20type%3D2000%20audit(0.490%3A1)%3A%20initialized%3CBR%20%2F%3EVFS%3A%20Disk%20quotas%20dquot_6.6.0%3CBR%20%2F%3EVFS%3A%20Dquot-cache%20hash%20table%20entries%3A%201024%20(order%200%2C%204096%20bytes)%3CBR%20%2F%3ENFS%3A%20Registering%20the%20id_resolver%20key%20type%3CBR%20%2F%3EKey%20type%20id_resolver%20registered%3CBR%20%2F%3EKey%20type%20id_legacy%20registered%3CBR%20%2F%3Entfs%3A%20driver%202.1.32%20%5BFlags%3A%20R%2FW%20DEBUG%5D.%3CBR%20%2F%3Ejffs2%3A%20version%202.2.%20(NAND)%20%E2%93%92%202001-2006%20Red%20Hat%2C%20Inc.%3CBR%20%2F%3Efuse%20init%20(API%20version%207.23)%3CBR%20%2F%3Ebounce%3A%20pool%20size%3A%2064%20pages%3CBR%20%2F%3Eio%20scheduler%20noop%20registered%3CBR%20%2F%3Eio%20scheduler%20deadline%20registered%3CBR%20%2F%3Eio%20scheduler%20cfq%20registered%20(default)%3CBR%20%2F%3Eimx-weim%2021b8000.weim%3A%20Driver%20registered.%3CBR%20%2F%3Eimx-pwm%202080000.pwm%3A%20PWM%20supports%20inversion%3CBR%20%2F%3Epwm-backlight%20supply%20power%20not%20found%2C%20using%20dummy%20regulator%3CBR%20%2F%3Eimx-pwm%202080000.pwm%3A%20imx_pwm_set_polarity%3A%20polarity%20set%20to%20inverted%3CBR%20%2F%3Emxc_mipi_dsi%2021e0000.mipi%3A%20i.MX%20MIPI%20DSI%20driver%20probed%3CBR%20%2F%3EMIPI%20DSI%20driver%20module%20loaded%3CBR%20%2F%3EMIPI%20DSI%20driver%20module%20loaded%3CBR%20%2F%3Emxc_sdc_fb%20fb%400%3A%20registered%20mxc%20display%20driver%20ldb%3CBR%20%2F%3Emxc_sdc_fb%20fb%401%3A%20get%20mxcfb%20of%20property%20fail%3CBR%20%2F%3Emxc_sdc_fb%3A%20probe%20of%20fb%401%20failed%20with%20error%20-22%3CBR%20%2F%3Emxc_sdc_fb%20fb%402%3A%20get%20mxcfb%20of%20property%20fail%3CBR%20%2F%3Emxc_sdc_fb%3A%20probe%20of%20fb%402%20failed%20with%20error%20-22%3CBR%20%2F%3Emxc_sdc_fb%20fb%403%3A%20get%20mxcfb%20of%20property%20fail%3CBR%20%2F%3Emxc_sdc_fb%3A%20probe%20of%20fb%403%20failed%20with%20error%20-22%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%3A%20no%20iram%20assigned%2C%20using%20external%20mem%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%3A%20no%20event%20needs%20to%20be%20remapped%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%3A%20initialized%3CBR%20%2F%3Eimx-sdma%2020ec000.sdma%3A%20loaded%20firmware%203.3%3CBR%20%2F%3Epfuze100-regulator%201-0008%3A%20Full%20layer%3A%202%2C%20Metal%20layer%3A%201%3CBR%20%2F%3Epfuze100-regulator%201-0008%3A%20FAB%3A%200%2C%20FIN%3A%200%3CBR%20%2F%3Epfuze100-regulator%201-0008%3A%20pfuze100%20found.%3CBR%20%2F%3E2020000.serial%3A%20ttymxc0%20at%20MMIO%200x2020000%20(irq%20%3D%2025%2C%20base_baud%20%3D%205000000)%20is%20a%20IMX%3CBR%20%2F%3Econsole%20%5Bttymxc0%5D%20enabled%3CBR%20%2F%3E21f4000.serial%3A%20ttymxc4%20at%20MMIO%200x21f4000%20(irq%20%3D%20300%2C%20base_baud%20%3D%205000000)%20is%20a%20IMX%3CBR%20%2F%3Eimx%20sema4%20driver%20is%20registered.%3CBR%20%2F%3E%5Bdrm%5D%20Initialized%20drm%201.1.0%2020060810%3CBR%20%2F%3E%5Bdrm%5D%20Initialized%20vivante%201.0.0%2020120216%20on%20minor%200%3CBR%20%2F%3Ebrd%3A%20module%20loaded%3CBR%20%2F%3Eloop%3A%20module%20loaded%3CBR%20%2F%3Ezram%3A%20Created%201%20device(s)%3CBR%20%2F%3Eimx6q-pinctrl%2020e0000.iomuxc%3A%20pin%20MX6Q_PAD_KEY_COL1%20already%20requested%20by%2021f4000.serial%3B%20cannot%20claim%20for%202008000.ecspi%3CBR%20%2F%3Eimx6q-pinctrl%2020e0000.iomuxc%3A%20pin-128%20(2008000.ecspi)%20status%20-22%3CBR%20%2F%3Eimx6q-pinctrl%2020e0000.iomuxc%3A%20could%20not%20request%20pin%20128%20(MX6Q_PAD_KEY_COL1)%20from%20group%20ecspi1grp%20on%20device%2020e0000.iomuxc%3CBR%20%2F%3Espi_imx%202008000.ecspi%3A%20Error%20applying%20setting%2C%20reverse%20things%20back%3CBR%20%2F%3Em25p80%20spi0.0%3A%20unrecognized%20JEDEC%20id%20bytes%3A%2000%2C%200%2C%200%3CBR%20%2F%3Espi_imx%202008000.ecspi%3A%20probed%3CBR%20%2F%3Etun%3A%20Universal%20TUN%2FTAP%20device%20driver%2C%201.6%3CBR%20%2F%3E%3CSPAN%3Etun%3A%20(C)%201999-2004%20Max%20Krasnyansky%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Amaxk%40qualcomm.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Emaxk%40qualcomm.com%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CBR%20%2F%3ECAN%20device%20driver%20interface%3CBR%20%2F%3E2188000.ethernet%20supply%20phy%20not%20found%2C%20using%20dummy%20regulator%3CBR%20%2F%3Epps%20pps0%3A%20new%20PPS%20source%20ptp0%3CBR%20%2F%3Efec%202188000.ethernet%20(unnamed%20net_device)%20(uninitialized)%3A%20Invalid%20MAC%20address%3A%2000%3A00%3A00%3A00%3A00%3A00%3CBR%20%2F%3Efec%202188000.ethernet%20(unnamed%20net_device)%20(uninitialized)%3A%20Using%20random%20MAC%20address%3A%20b6%3Ad9%3A69%3A8f%3A41%3A44%3CBR%20%2F%3Elibphy%3A%20fec_enet_mii_bus%3A%20probed%3CBR%20%2F%3Efec%202188000.ethernet%20eth0%3A%20registered%20PHC%20device%200%3CBR%20%2F%3EPPP%20generic%20driver%20version%202.4.2%3CBR%20%2F%3EPPP%20BSD%20Compression%20module%20registered%3CBR%20%2F%3EPPP%20Deflate%20Compression%20module%20registered%3CBR%20%2F%3EPPP%20MPPE%20Compression%20module%20registered%3CBR%20%2F%3ENET%3A%20Registered%20protocol%20family%2024%3CBR%20%2F%3Epegasus%3A%20v0.9.3%20(2013%2F04%2F25)%2C%20Pegasus%2FPegasus%20II%20USB%20Ethernet%20driver%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20pegasus%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20rtl8150%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20r8152%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20asix%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20ax88179_178a%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20cdc_ether%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20cdc_eem%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20net1080%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20cdc_subset%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20zaurus%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20cdc_ncm%3CBR%20%2F%3Eehci_hcd%3A%20USB%202.0%20'Enhanced'%20Host%20Controller%20(EHCI)%20Driver%3CBR%20%2F%3Eehci-mxc%3A%20Freescale%20On-Chip%20EHCI%20Host%20driver%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20cdc_acm%3CBR%20%2F%3Ecdc_acm%3A%20USB%20Abstract%20Control%20Model%20driver%20for%20USB%20modems%20and%20ISDN%20adapters%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20usb-storage%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20usbserial%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20usbserial_generic%3CBR%20%2F%3Eusbserial%3A%20USB%20Serial%20support%20registered%20for%20generic%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20ftdi_sio%3CBR%20%2F%3Eusbserial%3A%20USB%20Serial%20support%20registered%20for%20FTDI%20USB%20Serial%20Device%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20option%3CBR%20%2F%3Eusbserial%3A%20USB%20Serial%20support%20registered%20for%20GSM%20modem%20(1-port)%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20usb_ehset_test%3CBR%20%2F%3E2184800.usbmisc%20supply%20vbus-wakeup%20not%20found%2C%20using%20dummy%20regulator%3CBR%20%2F%3Eusb_otg_vbus%3A%20supplied%20by%20SWBST%3CBR%20%2F%3Eusb_h1_vbus%3A%20supplied%20by%20SWBST%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.1%3A%20EHCI%20Host%20Controller%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.1%3A%20new%20USB%20bus%20registered%2C%20assigned%20bus%20number%201%3CBR%20%2F%3Eci_hdrc%20ci_hdrc.1%3A%20USB%202.0%20started%2C%20EHCI%201.00%3CBR%20%2F%3Eusb%20usb1%3A%20New%20USB%20device%20found%2C%20idVendor%3D1d6b%2C%20idProduct%3D0002%3CBR%20%2F%3Eusb%20usb1%3A%20New%20USB%20device%20strings%3A%20Mfr%3D3%2C%20Product%3D2%2C%20SerialNumber%3D1%3CBR%20%2F%3Eusb%20usb1%3A%20Product%3A%20EHCI%20Host%20Controller%3CBR%20%2F%3Eusb%20usb1%3A%20Manufacturer%3A%20Linux%204.1.15%20ehci_hcd%3CBR%20%2F%3Eusb%20usb1%3A%20SerialNumber%3A%20ci_hdrc.1%3CBR%20%2F%3Ehub%201-0%3A1.0%3A%20USB%20hub%20found%3CBR%20%2F%3Ehub%201-0%3A1.0%3A%201%20port%20detected%3CBR%20%2F%3Emousedev%3A%20PS%2F2%20mouse%20device%20common%20for%20all%20mice%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20xpad%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20usb_acecad%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20aiptek%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20gtco%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20hanwang%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20kbtab%3CBR%20%2F%3Einput%3A%20ft5426_ts%20as%20%2Fdevices%2Fsoc0%2Fsoc%2F2100000.aips-bus%2F21a0000.i2c%2Fi2c-0%2F0-0038%2Finput%2Finput0%3CBR%20%2F%3E0-0038%20supply%20vdd%20not%20found%2C%20using%20dummy%20regulator%3CBR%20%2F%3E0-0038%20supply%20vcc_i2c%20not%20found%2C%20using%20dummy%20regulator%3CBR%20%2F%3Eft5426_ts%200-0038%3A%20%5BFTS%5D%20Firmware%20version%20%3D%200x8%3CBR%20%2F%3Eft5426_ts%200-0038%3A%20%5BFTS%5D%20report%20rate%20is%20100Hz.%3CBR%20%2F%3Eegalax_ts%201-0004%3A%20Failed%20to%20read%20firmware%20version%3CBR%20%2F%3Eegalax_ts%3A%20probe%20of%201-0004%20failed%20with%20error%20-5%3CBR%20%2F%3Eegalax_ts%202-0004%3A%20Failed%20to%20read%20firmware%20version%3CBR%20%2F%3Eegalax_ts%3A%20probe%20of%202-0004%20failed%20with%20error%20-5%3CBR%20%2F%3Einput%3A%20max11801_ts%20as%20%2Fdevices%2Fsoc0%2Fsoc%2F2100000.aips-bus%2F21a4000.i2c%2Fi2c-1%2F1-0048%2Finput%2Finput3%3CBR%20%2F%3Einput%3A%20isl29023%20light%20sensor%20as%20%2Fdevices%2Fvirtual%2Finput%2Finput4%3CBR%20%2F%3Eisl29023%202-0044%3A%20driver%20version%201.0%20enabled%3CBR%20%2F%3Esnvs_rtc%2020cc000.snvs%3Asnvs-rtc-lp%3A%20rtc%20core%3A%20registered%2020cc000.snvs%3Asnvs-r%20as%20rtc0%3CBR%20%2F%3Ei2c%20%2Fdev%20entries%20driver%3CBR%20%2F%3EIR%20NEC%20protocol%20handler%20initialized%3CBR%20%2F%3EIR%20RC5(x%2Fsz)%20protocol%20handler%20initialized%3CBR%20%2F%3EIR%20RC6%20protocol%20handler%20initialized%3CBR%20%2F%3EIR%20JVC%20protocol%20handler%20initialized%3CBR%20%2F%3EIR%20Sony%20protocol%20handler%20initialized%3CBR%20%2F%3EIR%20SANYO%20protocol%20handler%20initialized%3CBR%20%2F%3EIR%20Sharp%20protocol%20handler%20initialized%3CBR%20%2F%3EIR%20MCE%20Keyboard%2Fmouse%20protocol%20handler%20initialized%3CBR%20%2F%3EIR%20XMP%20protocol%20handler%20initialized%3CBR%20%2F%3Eov564x%200-0020%3A%20no%20sensor%20pwdn%20pin%20available%3CBR%20%2F%3Eov5642%200-0020%3A%20no%20sensor%20pwdn%20pin%20available%3CBR%20%2F%3Eov5642%3A%20probe%20of%200-0020%20failed%20with%20error%20-22%3CBR%20%2F%3ESW4%3A%20ramp_delay%20not%20set%3CBR%20%2F%3EVGEN3%3A%20operation%20not%20allowed%3CBR%20%2F%3Eov5640_read_reg%3Awrite%20reg%20error%3Areg%3D300a%3CBR%20%2F%3Ecamera%20ov5640_mipi%20is%20not%20found%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out%3A%20V4L2%20device%20registered%20as%20video16%3CBR%20%2F%3Emxc_v4l2_output%20v4l2_out%3A%20V4L2%20device%20registered%20as%20video17%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20uvcvideo%3CBR%20%2F%3EUSB%20Video%20Class%20driver%20(1.1.1)%3CBR%20%2F%3Emag3110%202-000e%3A%20check%20mag3110%20chip%20ID%3CBR%20%2F%3Emag3110%202-000e%3A%20read%20chip%20ID%200xfffffffb%20is%20not%20equal%20to%200xc4!%3CBR%20%2F%3Emag3110%3A%20probe%20of%202-000e%20failed%20with%20error%20-22%3CBR%20%2F%3Emma8x5x%200-001c%3A%20read%20chip%20ID%200xfffffffb%20is%20not%20equal%20to%200x1a%2C0x2a%2C0x3a%2C0x4a%2C0x5a!%3CBR%20%2F%3Emma8x5x%3A%20probe%20of%200-001c%20failed%20with%20error%20-22%3CBR%20%2F%3Eimx2-wdt%2020c0000.wdog%3A%20use%20WDOG_B%20to%20reboot.%3CBR%20%2F%3Eimx2-wdt%2020c0000.wdog%3A%20timeout%2060%20sec%20(nowayout%3D0)%3CBR%20%2F%3Edevice-mapper%3A%20uevent%3A%20version%201.0.3%3CBR%20%2F%3E%3CSPAN%3Edevice-mapper%3A%20ioctl%3A%204.31.0-ioctl%20(2015-3-12)%20initialised%3A%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Adm-devel%40redhat.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Edm-devel%40redhat.com%3C%2FA%3E%3CBR%20%2F%3EBluetooth%3A%20HCI%20UART%20driver%20ver%202.3%3CBR%20%2F%3EBluetooth%3A%20HCI%20UART%20protocol%20H4%20registered%3CBR%20%2F%3EBluetooth%3A%20HCI%20UART%20protocol%20BCSP%20registered%3CBR%20%2F%3EBluetooth%3A%20HCI%20UART%20protocol%20ATH3K%20registered%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20btusb%3CBR%20%2F%3Esdhci%3A%20Secure%20Digital%20Host%20Controller%20Interface%20driver%3CBR%20%2F%3Esdhci%3A%20Copyright(c)%20Pierre%20Ossman%3CBR%20%2F%3Esdhci-pltfm%3A%20SDHCI%20platform%20and%20OF%20driver%20helper%3CBR%20%2F%3E%2Fsoc%2Faips-bus%4002100000%2Fusdhc%4002194000%3A%20voltage-ranges%20unspecified%3CBR%20%2F%3Esdhci-esdhc-imx%202194000.usdhc%3A%20Got%20WP%20GPIO%3CBR%20%2F%3Esdhci-esdhc-imx%202194000.usdhc%3A%20assigned%20as%20wifi%20host%3CBR%20%2F%3Esdhci-esdhc-imx%202194000.usdhc%3A%20No%20vmmc%20regulator%20found%3CBR%20%2F%3Esdhci-esdhc-imx%202194000.usdhc%3A%20No%20vqmmc%20regulator%20found%3CBR%20%2F%3Emmc1%3A%20SDHCI%20controller%20on%202194000.usdhc%20%5B2194000.usdhc%5D%20using%20ADMA%3CBR%20%2F%3E%2Fsoc%2Faips-bus%4002100000%2Fusdhc%4002198000%3A%20voltage-ranges%20unspecified%3CBR%20%2F%3Esdhci-esdhc-imx%202198000.usdhc%3A%20Got%20CD%20GPIO%3CBR%20%2F%3Esdhci-esdhc-imx%202198000.usdhc%3A%20Got%20WP%20GPIO%3CBR%20%2F%3Esdhci-esdhc-imx%202198000.usdhc%3A%20No%20vmmc%20regulator%20found%3CBR%20%2F%3Esdhci-esdhc-imx%202198000.usdhc%3A%20No%20vqmmc%20regulator%20found%3CBR%20%2F%3Emmc2%3A%20SDHCI%20controller%20on%202198000.usdhc%20%5B2198000.usdhc%5D%20using%20ADMA%3CBR%20%2F%3E%2Fsoc%2Faips-bus%4002100000%2Fusdhc%400219c000%3A%20voltage-ranges%20unspecified%3CBR%20%2F%3Esdhci-esdhc-imx%20219c000.usdhc%3A%20No%20vmmc%20regulator%20found%3CBR%20%2F%3Esdhci-esdhc-imx%20219c000.usdhc%3A%20No%20vqmmc%20regulator%20found%3CBR%20%2F%3Emmc3%3A%20SDHCI%20controller%20on%20219c000.usdhc%20%5B219c000.usdhc%5D%20using%20ADMA%3CBR%20%2F%3Emxc_vpu%202040000.vpu_fsl%3A%20VPU%20initialized%3CBR%20%2F%3Emxc_vdoa%2021e4000.vdoa%3A%20i.MX%20Video%20Data%20Order%20Adapter(VDOA)%20driver%20probed%3CBR%20%2F%3EGalcore%20version%206.2.0.79565%3CBR%20%2F%3Emmc3%3A%20MAN_BKOPS_EN%20bit%20is%20not%20set%3CBR%20%2F%3Emmc3%3A%20new%20DDR%20MMC%20card%20at%20address%200001%3CBR%20%2F%3Emmcblk3%3A%20mmc3%3A0001%20Q2J55L%207.12%20GiB%3CBR%20%2F%3Emmcblk3boot0%3A%20mmc3%3A0001%20Q2J55L%20partition%201%202.00%20MiB%3CBR%20%2F%3Emmcblk3boot1%3A%20mmc3%3A0001%20Q2J55L%20partition%202%202.00%20MiB%3CBR%20%2F%3Emmcblk3rpmb%3A%20mmc3%3A0001%20Q2J55L%20partition%203%204.00%20MiB%3CBR%20%2F%3E%20mmcblk3%3A%20p1%20p2%20p3%20%26lt%3B%20p5%20p6%20p7%20p8%20p9%20p10%20p11%20p12%20p13%20p14%20%26gt%3B%20p4%3CBR%20%2F%3Eleds-gpio%3A%20probe%20of%20leds%20failed%20with%20error%20-2%3CBR%20%2F%3Ecaam%202100000.caam%3A%20Entropy%20delay%20%3D%203200%3CBR%20%2F%3Ecaam%202100000.caam%3A%20Instantiated%20RNG4%20SH0%3CBR%20%2F%3Ecaam%202100000.caam%3A%20Instantiated%20RNG4%20SH1%3CBR%20%2F%3Ecaam%202100000.caam%3A%20device%20ID%20%3D%200x0a16010000000000%20(Era%20-524)%3CBR%20%2F%3Ecaam%202100000.caam%3A%20job%20rings%20%3D%202%2C%20qi%20%3D%200%3CBR%20%2F%3Ecaam%20algorithms%20registered%20in%20%2Fproc%2Fcrypto%3CBR%20%2F%3Ecaam_jr%202101000.jr0%3A%20registering%20rng-caam%3CBR%20%2F%3Eplatform%20caam_sm%3A%20blkkey_ex%3A%204%20keystore%20units%20available%3CBR%20%2F%3Eplatform%20caam_sm%3A%2064-bit%20clear%20key%3A%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3Eplatform%20caam_sm%3A%2064-bit%20black%20key%3A%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0000%5D%20c0%2046%201d%2006%20e4%209b%20ce%2066%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0008%5D%20ba%20e1%20de%20dc%20b6%2038%203f%20b2%3CBR%20%2F%3Eplatform%20caam_sm%3A%20128-bit%20clear%20key%3A%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0008%5D%2008%2009%200a%200b%200c%200d%200e%200f%3CBR%20%2F%3Eplatform%20caam_sm%3A%20128-bit%20black%20key%3A%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0000%5D%2002%206c%208d%20c0%20f9%2042%2071%202a%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0008%5D%2063%20ae%2046%204c%209e%209a%2072%2098%3CBR%20%2F%3Eplatform%20caam_sm%3A%20192-bit%20clear%20key%3A%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0008%5D%2008%2009%200a%200b%200c%200d%200e%200f%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0016%5D%2010%2011%2012%2013%2014%2015%2016%2017%3CBR%20%2F%3Eplatform%20caam_sm%3A%20192-bit%20black%20key%3A%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0000%5D%204e%20ec%20a1%207c%203c%2067%20a6%20cc%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0008%5D%208b%205d%2004%20e4%20cd%203d%2080%2049%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0016%5D%2055%2012%20d6%2003%20b5%2056%2090%20e6%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0024%5D%205d%2004%209b%2081%206a%2047%208c%20b5%3CBR%20%2F%3Eplatform%20caam_sm%3A%20256-bit%20clear%20key%3A%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0008%5D%2008%2009%200a%200b%200c%200d%200e%200f%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0016%5D%2010%2011%2012%2013%2014%2015%2016%2017%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0024%5D%2018%2019%201a%201b%201c%201d%201e%201f%3CBR%20%2F%3Eplatform%20caam_sm%3A%20256-bit%20black%20key%3A%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0000%5D%2052%2085%20c0%201a%20d9%20cd%20ed%2092%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0008%5D%20a5%2051%2037%20d9%20f8%2013%205f%205a%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0016%5D%2071%2053%20e6%20b4%2057%2041%2091%207c%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0024%5D%209a%2044%206b%2088%20fd%20dd%20c2%20ad%3CBR%20%2F%3Eplatform%20caam_sm%3A%2064-bit%20unwritten%20blob%3A%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20128-bit%20unwritten%20blob%3A%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20196-bit%20unwritten%20blob%3A%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20256-bit%20unwritten%20blob%3A%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0000%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0016%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0032%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0040%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%2064-bit%20black%20key%20in%20blob%3A%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0000%5D%200b%20a3%20ea%2093%20e9%202c%2087%20f4%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0008%5D%2030%20bc%2062%2033%20c8%2021%208b%207c%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0016%5D%2075%20b4%20d4%2099%20b8%20cf%2009%2084%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0024%5D%2078%20e4%2053%20b6%2079%2031%2003%20df%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0032%5D%20be%207f%20d5%2021%202f%2029%20ce%2051%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0040%5D%2090%207b%207b%2081%2054%2001%2028%205f%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0048%5D%20e1%20b9%202c%2034%202b%20db%2095%205d%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20128-bit%20black%20key%20in%20blob%3A%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0000%5D%2075%2041%2094%2060%20c2%20ce%2095%20be%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0008%5D%20d0%2026%2049%2040%2011%2072%2085%2030%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0016%5D%20ac%2037%2087%2049%20b0%2099%20a2%2077%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0024%5D%2041%208a%2012%2012%2006%2036%2095%2009%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0032%5D%2068%2026%202a%20c1%20bc%2063%205c%20d3%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0040%5D%207e%207b%205f%20ae%203e%2039%2047%208c%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0048%5D%20da%20b6%2013%20f6%20e7%20ff%2038%20fc%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0056%5D%2039%2051%2038%2026%2082%206e%2017%208f%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20192-bit%20black%20key%20in%20blob%3A%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0000%5D%20a6%2049%20cf%2009%20be%200c%2028%20c4%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0008%5D%209a%2073%2073%20fa%200b%20cb%2036%203d%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0016%5D%2033%204f%2052%20a6%209f%20ff%20da%2045%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0024%5D%2095%203b%2021%2015%209d%207e%2087%20a8%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0032%5D%2091%20e0%20a6%2040%20be%2029%20f1%20c0%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0040%5D%2008%20bd%20de%20a0%2024%2003%2038%20b3%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0048%5D%20bf%208d%206b%2009%2020%2083%205b%20d8%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0056%5D%20f6%2028%205d%20a9%20c9%2019%202d%20af%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0064%5D%20c4%20e1%2087%201b%2079%207e%2082%2062%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20256-bit%20black%20key%20in%20blob%3A%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0000%5D%20d3%20e9%207c%2069%20c3%2077%2039%202f%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0008%5D%2028%20d4%2089%202e%20d9%20fa%20a9%201f%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0016%5D%20f6%20bb%20ed%20b7%204c%2095%2070%202c%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0024%5D%203a%203f%2003%2043%2052%2097%2092%20b4%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0032%5D%208b%208f%2045%20bd%2042%2060%205a%203c%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0040%5D%206d%203b%2077%2048%20f9%2013%2014%20f0%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0048%5D%20ba%2059%20fb%20b9%206f%2079%2029%20c1%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0056%5D%20db%2030%20ae%20a6%2028%2046%2032%206f%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0064%5D%205a%20b1%2091%2093%2069%2084%202c%2011%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0072%5D%20d0%2094%20ed%2006%20bb%20af%2042%200c%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3Eplatform%20caam_sm%3A%20restored%2064-bit%20black%20key%3A%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0000%5D%2020%2099%2097%209f%206e%2045%20f4%2010%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0008%5D%205c%205a%20df%209f%20ea%200d%20c7%2063%3CBR%20%2F%3Eplatform%20caam_sm%3A%20restored%20128-bit%20black%20key%3A%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0000%5D%2002%206c%208d%20c0%20f9%2042%2071%202a%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0008%5D%2063%20ae%2046%204c%209e%209a%2072%2098%3CBR%20%2F%3Eplatform%20caam_sm%3A%20restored%20192-bit%20black%20key%3A%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0000%5D%204e%20ec%20a1%207c%203c%2067%20a6%20cc%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0008%5D%208b%205d%2004%20e4%20cd%203d%2080%2049%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0016%5D%2051%208a%20a1%2091%20ba%2016%20ef%20b2%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0024%5D%20dd%20f9%20a3%2078%201e%20a0%206e%209d%3CBR%20%2F%3Eplatform%20caam_sm%3A%20restored%20256-bit%20black%20key%3A%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0000%5D%2052%2085%20c0%201a%20d9%20cd%20ed%2092%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0008%5D%20a5%2051%2037%20d9%20f8%2013%205f%205a%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0016%5D%2071%2053%20e6%20b4%2057%2041%2091%207c%3CBR%20%2F%3Eplatform%20caam_sm%3A%20%5B0024%5D%209a%2044%206b%2088%20fd%20dd%20c2%20ad%3CBR%20%2F%3Esnvs-secvio%2020cc000.caam-snvs%3A%20can't%20get%20snvs%20clock%3CBR%20%2F%3Esnvs-secvio%2020cc000.caam-snvs%3A%20violation%20handlers%20armed%20-%20non-secure%20state%3CBR%20%2F%3Ecaam_keyblob%20caam_keyblob%3A%20caam%20keyblob%20initialized%3CBR%20%2F%3Ehidraw%3A%20raw%20HID%20events%20driver%20(C)%20Jiri%20Kosina%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20usbhid%3CBR%20%2F%3Eusbhid%3A%20USB%20HID%20core%20driver%3CBR%20%2F%3Eashmem%3A%20initialized%3CBR%20%2F%3Eusbcore%3A%20registered%20new%20interface%20driver%20snd-usb-audio%3CBR%20%2F%3Ewm8962%200-001a%3A%20Failed%20to%20read%20ID%20register%3CBR%20%2F%3Ewm8962%3A%20probe%20of%200-001a%20failed%20with%20error%20-5%3CBR%20%2F%3Efsl-asrc%202034000.asrc%3A%20driver%20registered%3CBR%20%2F%3Eimx-wm8962%20sound%3A%20failed%20to%20find%20codec%20platform%20device%3CBR%20%2F%3Eimx-wm8962%3A%20probe%20of%20sound%20failed%20with%20error%20-22%3CBR%20%2F%3ENET%3A%20Registered%20protocol%20family%2026%3CBR%20%2F%3Eu32%20classifier%3CBR%20%2F%3E%20Actions%20configured%3CBR%20%2F%3ENetfilter%20messages%20via%20NETLINK%20v0.30.%3CBR%20%2F%3Enf_conntrack%20version%200.5.0%20(16384%20buckets%2C%2065536%20max)%3CBR%20%2F%3Ectnetlink%20v0.93%3A%20registering%20with%20nfnetlink.%3CBR%20%2F%3Ext_time%3A%20kernel%20timezone%20is%20-0000%3CBR%20%2F%3Eip_tables%3A%20(C)%202000-2006%20Netfilter%20Core%20Team%3CBR%20%2F%3Earp_tables%3A%20(C)%202002%20David%20S.%20Miller%3CBR%20%2F%3EInitializing%20XFRM%20netlink%20socket%3CBR%20%2F%3ENET%3A%20Registered%20protocol%20family%2010%3CBR%20%2F%3Emip6%3A%20Mobile%20IPv6%3CBR%20%2F%3Eip6_tables%3A%20(C)%202000-2006%20Netfilter%20Core%20Team%3CBR%20%2F%3Esit%3A%20IPv6%20over%20IPv4%20tunneling%20driver%3CBR%20%2F%3ENET%3A%20Registered%20protocol%20family%2017%3CBR%20%2F%3ENET%3A%20Registered%20protocol%20family%2015%3CBR%20%2F%3Ecan%3A%20controller%20area%20network%20core%20(rev%2020120528%20abi%209)%3CBR%20%2F%3ENET%3A%20Registered%20protocol%20family%2029%3CBR%20%2F%3Ecan%3A%20raw%20protocol%20(rev%2020120528)%3CBR%20%2F%3Ecan%3A%20broadcast%20manager%20protocol%20(rev%2020120528%20t)%3CBR%20%2F%3Ecan%3A%20netlink%20gateway%20(rev%2020130117)%20max_hops%3D1%3CBR%20%2F%3EBluetooth%3A%20RFCOMM%20TTY%20layer%20initialized%3CBR%20%2F%3EBluetooth%3A%20RFCOMM%20socket%20layer%20initialized%3CBR%20%2F%3EBluetooth%3A%20RFCOMM%20ver%201.11%3CBR%20%2F%3EBluetooth%3A%20BNEP%20(Ethernet%20Emulation)%20ver%201.3%3CBR%20%2F%3EBluetooth%3A%20BNEP%20filters%3A%20protocol%20multicast%3CBR%20%2F%3EBluetooth%3A%20BNEP%20socket%20layer%20initialized%3CBR%20%2F%3EBluetooth%3A%20HIDP%20(Human%20Interface%20Emulation)%20ver%201.2%3CBR%20%2F%3EBluetooth%3A%20HIDP%20socket%20layer%20initialized%3CBR%20%2F%3E8021q%3A%20802.1Q%20VLAN%20Support%20v1.8%3CBR%20%2F%3EKey%20type%20dns_resolver%20registered%3CBR%20%2F%3Edhd_module_init%20in%3CBR%20%2F%3EPower-up%20adapter%20'DHD%20generic%20adapter'%3CBR%20%2F%3Ewifi_platform_bus_enumerate%20device%20present%201%3CBR%20%2F%3Efailed%20to%20power%20up%20DHD%20generic%20adapter%2C%203%20retry%20left%3CBR%20%2F%3Ewifi_platform_bus_enumerate%20device%20present%200%3CBR%20%2F%3Ewifi_platform_bus_enumerate%20device%20present%201%3CBR%20%2F%3Efailed%20to%20power%20up%20DHD%20generic%20adapter%2C%202%20retry%20left%3CBR%20%2F%3Ewifi_platform_bus_enumerate%20device%20present%200%3CBR%20%2F%3Ewifi_platform_bus_enumerate%20device%20present%201%3CBR%20%2F%3Efailed%20to%20power%20up%20DHD%20generic%20adapter%2C%201%20retry%20left%3CBR%20%2F%3Ewifi_platform_bus_enumerate%20device%20present%200%3CBR%20%2F%3Ewifi_platform_bus_enumerate%20device%20present%201%3CBR%20%2F%3Efailed%20to%20power%20up%20DHD%20generic%20adapter%2C%200%20retry%20left%3CBR%20%2F%3Ewifi_platform_bus_enumerate%20device%20present%200%3CBR%20%2F%3Efailed%20to%20power%20up%20DHD%20generic%20adapter%2C%20max%20retry%20reached**%3CBR%20%2F%3Egpio-keys%20gpio-keys%3A%20Failed%20to%20request%20GPIO%205%2C%20error%20-16%3CBR%20%2F%3Egpio-keys%3A%20probe%20of%20gpio-keys%20failed%20with%20error%20-16%3CBR%20%2F%3Esnvs_rtc%2020cc000.snvs%3Asnvs-rtc-lp%3A%20setting%20system%20clock%20to%201970-01-01%2000%3A01%3A48%20UTC%20(108)%3CBR%20%2F%3Ewlreg_on%3A%20disabling%3CBR%20%2F%3Ehdmi-5v-supply%3A%20disabling%3CBR%20%2F%3Ewm8962-supply%3A%20disabling%3CBR%20%2F%3Eusb_otg_vbus%3A%20disabling%3CBR%20%2F%3EALSA%20device%20list%3A%3CBR%20%2F%3E%20No%20soundcards%20found.%3CBR%20%2F%3EFreeing%20unused%20kernel%20memory%3A%201024K%20(c1000000%20-%20c1100000)%3CBR%20%2F%3Einit%3A%20init%20first%20stage%20started!%3CBR%20%2F%3Eaudit%3A%20type%3D1403%20audit(108.600%3A2)%3A%20policy%20loaded%20auid%3D4294967295%20ses%3D4294967295%3CBR%20%2F%3Eaudit%3A%20type%3D1404%20audit(108.610%3A3)%3A%20enforcing%3D1%20old_enforcing%3D0%20auid%3D4294967295%20ses%3D4294967295%3CBR%20%2F%3Einit%3A%20(Initializing%20SELinux%20enforcing%20took%200.17s.)%3CBR%20%2F%3Einit%3A%20init%20second%20stage%20started!%3CBR%20%2F%3Einit%3A%20Running%20restorecon...%3CBR%20%2F%3Einit%3A%20waitpid%20failed%3A%20No%20child%20processes%3CBR%20%2F%3Einit%3A%20(Loading%20properties%20from%20%2Fdefault.prop%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Finit.environ.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Finit.usb.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20init.freescale.usb.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20init.freescale.i.MX6QP.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Finit.freescale.rc%20took%200.01s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Finit.usb.configfs.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Finit.zygote32.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Finit.rc%20took%200.04s.)%3CBR%20%2F%3Einit%3A%20Starting%20service%20'ueventd'...%3CBR%20%2F%3Einit%3A%20Waiting%20for%20%2Fdev%2F.coldboot_done...%3CBR%20%2F%3Eueventd%3A%20ueventd%20started!%3CBR%20%2F%3Eueventd%3A%20Coldboot%20took%200.30s.%3CBR%20%2F%3Einit%3A%20Waiting%20for%20%2Fdev%2F.coldboot_done%20took%200.32s.%3CBR%20%2F%3Einit%3A%20write_file%3A%20Unable%20to%20open%20'%2Fproc%2Fsys%2Fabi%2Fswp'%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3Efs_mgr%3A%20Failed%20to%20get%20verity%20metadata%20'%2Fdev%2Fblock%2Fmmcblk3p5'%20(No%20such%20file%20or%20directory)%3CBR%20%2F%3Einit%3A%20Starting%20service%20'watchdogd'...%3CBR%20%2F%3Einit%3A%20write_file%3A%20Unable%20to%20open%20'%2Fsys%2Fclass%2Fgraphics%2Ffbcon%2Fcursor_blink'%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3Ewatchdogd%3A%20started%20(interval%2010%2C%20margin%2020)!%3CBR%20%2F%3Einit%3A%20write_file%3A%20Unable%20to%20open%20'%2Fsys%2Fclass%2Fvtconsole%2Fvtcon1%2Fbind'%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3EEXT4-fs%20(mmcblk3p5)%3A%20mounted%20filesystem%20with%20ordered%20data%20mode.%20Opts%3A%20barrier%3D1%3CBR%20%2F%3Efs_mgr%3A%20__mount(source%3D%2Fdev%2Fblock%2Fmmcblk3p5%2Ctarget%3D%2Fsystem%2Ctype%3Dext4)%3D0%3CBR%20%2F%3EEXT4-fs%20(mmcblk3p4)%3A%20Ignoring%20removed%20nomblk_io_submit%20option%3CBR%20%2F%3EEXT4-fs%20(mmcblk3p4)%3A%20mounted%20filesystem%20with%20ordered%20data%20mode.%20Opts%3A%20nomblk_io_submit%2Cnoauto_da_alloc%2Cerrors%3Dpanic%3CBR%20%2F%3Efs_mgr%3A%20__mount(source%3D%2Fdev%2Fblock%2Fmmcblk3p4%2Ctarget%3D%2Fdata%2Ctype%3Dext4)%3D0%3CBR%20%2F%3EEXT4-fs%20(mmcblk3p6)%3A%20Ignoring%20removed%20nomblk_io_submit%20option%3CBR%20%2F%3EEXT4-fs%20(mmcblk3p6)%3A%20mounted%20filesystem%20with%20ordered%20data%20mode.%20Opts%3A%20nomblk_io_submit%3CBR%20%2F%3Efs_mgr%3A%20__mount(source%3D%2Fdev%2Fblock%2Fmmcblk3p6%2Ctarget%3D%2Fcache%2Ctype%3Dext4)%3D0%3CBR%20%2F%3EEXT4-fs%20(mmcblk3p7)%3A%20mounted%20filesystem%20with%20ordered%20data%20mode.%20Opts%3A%20(null)%3CBR%20%2F%3Efs_mgr%3A%20__mount(source%3D%2Fdev%2Fblock%2Fmmcblk3p7%2Ctarget%3D%2Fdevice%2Ctype%3Dext4)%3D0%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Fatrace.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Faudioserver.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Fbootanim.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Fbootstat.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Fcameraserver.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Fdebuggerd.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Fdrmserver.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Fdumpstate.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Fgatekeeperd.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Finit-debug.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Finstalld.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Fkeystore.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Flmkd.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Flogcatd.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Flogd.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Fmdnsd.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Fmediacodec.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Fmediadrmserver.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Fmediaextractor.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Fmediaserver.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Fmtpd.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Fnetd.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Fperfprofd.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Fracoon.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20ignored%20duplicate%20definition%20of%20service%20'ril-daemon'init%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Frild.rc%20took%200.01s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Fservicemanager.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Fsurfaceflinger.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Funcrypt.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Fvdc.rc%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Parsing%20%2Fsystem%2Fetc%2Finit%2Fvold.rc%20took%200.00s.)%3CBR%20%2F%3Efs_mgr%3A%20Failed%20to%20get%20verity%20metadata%20'%2Fdev%2Fblock%2Fmmcblk3p5'%20(No%20such%20file%20or%20directory)%3CBR%20%2F%3Efs_mgr%3A%20Failed%20to%20query%20DM_TABLE_STATUS%20for%20system%20(No%20such%20device%20or%20address)%3CBR%20%2F%3Efile%20system%20registered%3CBR%20%2F%3Einit%3A%20Starting%20service%20'logd'...%3CBR%20%2F%3Ezram0%3A%20detected%20capacity%20change%20from%200%20to%20314572800%3CBR%20%2F%3Erandom%3A%20logd%20urandom%20read%20with%2018%20bits%20of%20entropy%20available%3CBR%20%2F%3Elogd.auditd%3A%20start%3CBR%20%2F%3Elogd.klogd%3A%2015638045668%3CBR%20%2F%3EAdding%20307196k%20swap%20on%20%2Fdev%2Fblock%2Fzram0.%20Priority%3A-1%20extents%3A1%20across%3A307196k%20SS%3CBR%20%2F%3Einit%3A%20(Loading%20properties%20from%20%2Fsystem%2Fbuild.prop%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Loading%20properties%20from%20%2Fvendor%2Fbuild.prop%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20(Loading%20properties%20from%20%2Ffactory%2Ffactory.prop%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20Starting%20service%20'debuggerd'...%3CBR%20%2F%3Einit%3A%20do_start%3A%20Service%20debuggerd64%20not%20found%3CBR%20%2F%3Einit%3A%20Starting%20service%20'vold'...%3CBR%20%2F%3Einit%3A%20Not%20bootcharting.%3CBR%20%2F%3Einit%3A%20Starting%20service%20'exec%201%20(%2Fsystem%2Fbin%2Ftzdatacheck)'...%3CBR%20%2F%3Einit%3A%20Service%20'exec%201%20(%2Fsystem%2Fbin%2Ftzdatacheck)'%20(pid%20215)%20exited%20with%20status%200%3CBR%20%2F%3Einit%3A%20(Loading%20properties%20from%20%2Fdata%2Flocal.prop%20took%200.00s.)%3CBR%20%2F%3Einit%3A%20Starting%20service%20'logd-reinit'...%3CBR%20%2F%3Einit%3A%20Starting%20service%20'healthd'...%3CBR%20%2F%3Einit%3A%20Starting%20service%20'console'...%3CBR%20%2F%3Einit%3A%20Starting%20service%20'lmkd'...%3CBR%20%2F%3Ebinder%3A%20217%3A217%20transaction%20failed%2029189%2C%20size%200-0%3CBR%20%2F%3Einit%3A%20Starting%20service%20'servicemanager'...%3CBR%20%2F%3Elogd.daemon%3A%20reinit%3CBR%20%2F%3Einit%3A%20Starting%20service%20'surfaceflinger'...%3CBR%20%2F%3Einit%3A%20Service%20'logd-reinit'%20(pid%20216)%20exited%20with%20status%200%3CBR%20%2F%3Einit%3A%20write_file%3A%20Unable%20to%20open%20'%2Fsys%2Fblock%2Fmmcblk0%2Fqueue%2Fread_ahead_kb'%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3Einit%3A%20write_file%3A%20Unable%20to%20open%20'%2Fsys%2Fblock%2Fmmcblk1%2Fqueue%2Fread_ahead_kb'%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3Erfkill%3A%20BT%20RF%20going%20to%20%3A%20off%3CBR%20%2F%3Esabresd_6dq%3A%2F%20%23%20init%3A%20property_set(%22ro.ril.wake_lock_timeout%22%2C%20%22300%22)%20failed%3CBR%20%2F%3Einit%3A%20Starting%20service%20'adbd'...%3CBR%20%2F%3Einit%3A%20cannot%20find%20'%2Fsystem%2Fbin%2Fupdate_verifier'%20(No%20such%20file%20or%20directory)%2C%20disabling%20'exec%202%20(%2Fsystem%2Fbin%2Fupdate_verifier)'%3CBR%20%2F%3Eread%20descriptors%3CBR%20%2F%3Eread%20descriptors%3CBR%20%2F%3Eread%20strings%3CBR%20%2F%3Einit%3A%20cannot%20find%20'%2Fsystem%2Fbin%2Finstall-recovery.sh'%20(No%20such%20file%20or%20directory)%2C%20disabling%20'flash_recovery'%3CBR%20%2F%3Einit%3A%20Starting%20service%20'ril-daemon'...%3CBR%20%2F%3Einit%3A%20Starting%20service%20'zygote'...%3CBR%20%2F%3Einit%3A%20Starting%20service%20'audioserver'...%3CBR%20%2F%3Einit%3A%20Starting%20service%20'cameraserver'...%3CBR%20%2F%3Etype%3D1400%20audit(110.510%3A4)%3A%20avc%3A%20denied%20%7B%20getattr%20%7D%20for%20pid%3D229%20comm%3D%22audioserver%22%20path%3D%22%2Fvendor%22%20dev%3D%22rootfs%22%20ino%3D7112%20scontext%3Du%3Ar%3Aaudioserver%3As0%20tcontext%3Du%3Aobject_r%3Arootfs%3As0%20tclass%3Dlnk_file%20permissive%3D0%3CBR%20%2F%3Einit%3A%20couldn't%20write%20230%20to%20%2Fdev%2Fcpuset%2Fcamera-daemon%2Ftasks%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3Einit%3A%20Starting%20service%20'drm'...%3CBR%20%2F%3Einit%3A%20Starting%20service%20'installd'...%3CBR%20%2F%3Einit%3A%20Starting%20service%20'keystore'...%3CBR%20%2F%3Einit%3A%20Starting%20service%20'mediacodec'...%3CBR%20%2F%3Einit%3A%20Starting%20service%20'mediadrm'...%3CBR%20%2F%3Einit%3A%20Starting%20service%20'mediaextractor'...%3CBR%20%2F%3Etype%3D1400%20audit(110.560%3A5)%3A%20avc%3A%20denied%20%7B%20getattr%20%7D%20for%20pid%3D234%20comm%3D%22mediacodec%22%20path%3D%22%2Fvendor%22%20dev%3D%22rootfs%22%20ino%3D7112%20scontext%3Du%3Ar%3Amediacodec%3As0%20tcontext%3Du%3Aobject_r%3Arootfs%3As0%20tclass%3Dlnk_file%20permissive%3D0%3CBR%20%2F%3Einit%3A%20Starting%20service%20'media'...%3CBR%20%2F%3Einit%3A%20Starting%20service%20'netd'...%3CBR%20%2F%3Einit%3A%20Starting%20service%20'magd'...%3CBR%20%2F%3Einit%3A%20Starting%20service%20'gatekeeperd'...%3CBR%20%2F%3Etype%3D1400%20audit(110.560%3A6)%3A%20avc%3A%20denied%20%7B%20getattr%20%7D%20for%20pid%3D235%20comm%3D%22mediadrmserver%22%20path%3D%22%2Fvendor%22%20dev%3D%22rootfs%22%20ino%3D7112%20scontext%3Du%3Ar%3Amediadrmserver%3As0%20tcontext%3Du%3Aobject_r%3Arootfs%3As0%20tclass%3Dlnk_file%20permissive%3D0%3CBR%20%2F%3Etype%3D1400%20audit(110.620%3A7)%3A%20avc%3A%20denied%20%7B%20getattr%20%7D%20for%20pid%3D230%20comm%3D%22cameraserver%22%20path%3D%22%2Fvendor%22%20dev%3D%22rootfs%22%20ino%3D7112%20scontext%3Du%3Ar%3Acameraserver%3As0%20tcontext%3Du%3Aobject_r%3Arootfs%3As0%20tclass%3Dlnk_file%20permissive%3D0%3CBR%20%2F%3Etype%3D1400%20audit(110.820%3A8)%3A%20avc%3A%20denied%20%7B%20getattr%20%7D%20for%20pid%3D239%20comm%3D%22magd%22%20path%3D%22%2Fvendor%22%20dev%3D%22rootfs%22%20ino%3D7112%20scontext%3Du%3Ar%3Asensors%3As0%20tcontext%3Du%3Aobject_r%3Arootfs%3As0%20tclass%3Dlnk_file%20permissive%3D0%3CBR%20%2F%3Einit%3A%20Starting%20service%20'perfprofd'...%3CBR%20%2F%3Eandroid_work%3A%20did%20not%20send%20uevent%20(0%200%20(null))%3CBR%20%2F%3Econfigfs-gadget%20gadget%3A%20unbind%20function%20'mtp'%2Fd6d4ae00%3CBR%20%2F%3Econfigfs-gadget%20gadget%3A%20unbind%20function%20'Function%20FS%20Gadget'%2Fd6e24564%3CBR%20%2F%3Eandroid_work%3A%20did%20not%20send%20uevent%20(0%200%20(null))%3CBR%20%2F%3Econfigfs-gadget%20gadget%3A%20unbind%20function%20'mtp'%2Fd6d4ae00%3CBR%20%2F%3Econfigfs-gadget%20gadget%3A%20unbind%20function%20'Function%20FS%20Gadget'%2Fd6fef0e4%3CBR%20%2F%3Eandroid_work%3A%20sent%20uevent%20USB_STATE%3DCONNECTED%3CBR%20%2F%3Ehealthd%3A%20No%20battery%20devices%20found%3CBR%20%2F%3Econfigfs-gadget%20gadget%3A%20high-speed%20config%20%231%3A%20b%3CBR%20%2F%3Eandroid_work%3A%20sent%20uevent%20USB_STATE%3DCONFIGURED%3CBR%20%2F%3EERROR%3A%20v4l2%20capture%3A%20slave%20not%20found!%3CBR%20%2F%3EERROR%3A%20v4l2%20capture%3A%20slave%20not%20found!%3CBR%20%2F%3Etype%3D1400%20audit(111.500%3A9)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20pid%3D230%20comm%3D%22cameraserver%22%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Acameraserver%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3Einit%3A%20Service%20'magd'%20(pid%20239)%20exited%20with%20status%20255%3CBR%20%2F%3Eimx-ipuv3%202800000.ipu%3A%20Warning%3A%20channel%20already%20initialized%209%3CBR%20%2F%3Eimx-ipuv3%202800000.ipu%3A%20Warning%3A%20channel%20already%20enabled%209%3CBR%20%2F%3Etype%3D1400%20audit(111.890%3A10)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20pid%3D221%20comm%3D%22surfaceflinger%22%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Asurfaceflinger%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3Einit%3A%20Starting%20service%20'bootanim'...%3CBR%20%2F%3Etype%3D1400%20audit(112.290%3A11)%3A%20avc%3A%20denied%20%7B%20getattr%20%7D%20for%20pid%3D306%20comm%3D%22bootanimation%22%20path%3D%22%2Fvendor%22%20dev%3D%22rootfs%22%20ino%3D7112%20scontext%3Du%3Ar%3Abootanim%3As0%20tcontext%3Du%3Aobject_r%3Arootfs%3As0%20tclass%3Dlnk_file%20permissive%3D0%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Emxc_sdc_fb%20fb%400%3A%20timeout%20when%20waiting%20for%20flip%20irq%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Einit%3A%20Service%20'bootanim'%20(pid%20306)%20exited%20with%20status%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Erandom%3A%20nonblocking%20pool%20is%20initialized%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Ecapability%3A%20warning%3A%20%60main'%20uses%2032-bit%20capabilities%20(legacy%20support%20in%20use)%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Etype%3D1400%20audit(119.920%3A12)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20pid%3D497%20comm%3D%22dex2oat%22%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3CBR%20%2F%3Egraphics%20fb0%3A%20MXCFB_WAIT_FOR_VSYNC%3A%20timeout%200%3C%2FP%3E%3CP%3E...%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E---------%20beginning%20of%20main%3CBR%20%2F%3EW%20199%20auditd%20type%3D2000%20audit(0.0%3A1)%3A%20initialized%3CBR%20%2F%3EI%20199%20auditd%20type%3D1403%20audit(0.0%3A2)%3A%20policy%20loaded%20auid%3D4294967295%20ses%3D4294967295%3CBR%20%2F%3EW%20199%20auditd%20type%3D1404%20audit(0.0%3A3)%3A%20enforcing%3D1%20old_enforcing%3D0%20auid%3D4294967295%20ses%3D4294967295%3CBR%20%2F%3EI%20206%20debuggerd%3A%20starting%3CBR%20%2F%3E%20---------%20beginning%20of%20system%3CBR%20%2F%3EI%20207%20vold%20Vold%203.0%20(the%20awakening)%20firing%20up%3CBR%20%2F%3EV%20207%20vold%20Detected%20support%20for%3A%20ext4%20f2fs%20vfat%3CBR%20%2F%3EW%20207%20Vold%20Tearing%20down%20stale%20mount%20%2Fmnt%2Fshm%3CBR%20%2F%3ED%20207%20vold%20e4crypt_init_user0%3CBR%20%2F%3ED%20207%20vold%20e4crypt_prepare_user_storage%20for%20volume%20null%2C%20user%200%2C%20serial%200%2C%20flags%201%3CBR%20%2F%3ED%20207%20vold%20Preparing%3A%20%2Fdata%2Fsystem%2Fusers%2F0%3CBR%20%2F%3ED%20207%20vold%20Preparing%3A%20%2Fdata%2Fmisc%2Fprofiles%2Fcur%2F0%3CBR%20%2F%3ED%20207%20vold%20Preparing%3A%20%2Fdata%2Fmisc%2Fprofiles%2Fcur%2F0%2Fforeign-dex%3CBR%20%2F%3ED%20207%20vold%20Preparing%3A%20%2Fdata%2Fsystem_de%2F0%3CBR%20%2F%3ED%20207%20vold%20Preparing%3A%20%2Fdata%2Fmisc_de%2F0%3CBR%20%2F%3ED%20207%20vold%20Preparing%3A%20%2Fdata%2Fuser_de%2F0%3CBR%20%2F%3ED%20207%20vold%20e4crypt_unlock_user_key%200%20serial%3D0%20token_present%3D0%3CBR%20%2F%3EE%20207%20vold%20Failed%20to%20chmod%20%2Fdata%2Fsystem_ce%2F0%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3EE%20207%20vold%20Failed%20to%20chmod%20%2Fdata%2Fmisc_ce%2F0%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3EE%20207%20vold%20Failed%20to%20chmod%20%2Fdata%2Fmedia%2F0%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3EI%201%20vdc%20200%20211%20Command%20succeeded%3CBR%20%2F%3EI%20215%20%2Fsystem%2Fbin%2Ftzdatacheck%20tzdata%20file%20%2Fdata%2Fmisc%2Fzoneinfo%2Fcurrent%2Ftzdata%20does%20not%20exist.%20No%20action%20required.%3CBR%20%2F%3EI%20219%20lowmemorykiller%20Using%20in-kernel%20low%20memory%20killer%20interface%3CBR%20%2F%3EW%20229%20audioserver%20type%3D1400%20audit(0.0%3A4)%3A%20avc%3A%20denied%20%7B%20getattr%20%7D%20for%20path%3D%22%2Fvendor%22%20dev%3D%22rootfs%22%20ino%3D7112%20scontext%3Du%3Ar%3Aaudioserver%3As0%20tcontext%3Du%3Aobject_r%3Arootfs%3As0%20tclass%3Dlnk_file%20permissive%3D0%3CBR%20%2F%3EW%20234%20mediacodec%20type%3D1400%20audit(0.0%3A5)%3A%20avc%3A%20denied%20%7B%20getattr%20%7D%20for%20path%3D%22%2Fvendor%22%20dev%3D%22rootfs%22%20ino%3D7112%20scontext%3Du%3Ar%3Amediacodec%3As0%20tcontext%3Du%3Aobject_r%3Arootfs%3As0%20tclass%3Dlnk_file%20permissive%3D0%3CBR%20%2F%3EW%20235%20mediadrmserver%20type%3D1400%20audit(0.0%3A6)%3A%20avc%3A%20denied%20%7B%20getattr%20%7D%20for%20path%3D%22%2Fvendor%22%20dev%3D%22rootfs%22%20ino%3D7112%20scontext%3Du%3Ar%3Amediadrmserver%3As0%20tcontext%3Du%3Aobject_r%3Arootfs%3As0%20tclass%3Dlnk_file%20permissive%3D0%3CBR%20%2F%3EW%20230%20cameraserver%20type%3D1400%20audit(0.0%3A7)%3A%20avc%3A%20denied%20%7B%20getattr%20%7D%20for%20path%3D%22%2Fvendor%22%20dev%3D%22rootfs%22%20ino%3D7112%20scontext%3Du%3Ar%3Acameraserver%3As0%20tcontext%3Du%3Aobject_r%3Arootfs%3As0%20tclass%3Dlnk_file%20permissive%3D0%3CBR%20%2F%3EW%20239%20magd%20type%3D1400%20audit(0.0%3A8)%3A%20avc%3A%20denied%20%7B%20getattr%20%7D%20for%20path%3D%22%2Fvendor%22%20dev%3D%22rootfs%22%20ino%3D7112%20scontext%3Du%3Ar%3Asensors%3As0%20tcontext%3Du%3Aobject_r%3Arootfs%3As0%20tclass%3Dlnk_file%20permissive%3D0%3CBR%20%2F%3EI%20232%20installd%20firing%20up%3CBR%20%2F%3EE%20232%20cutils%20Failed%20to%20read%20%2Fdata%2F.layout_version%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3ED%20232%20Assuming%20that%20device%20has%20multi-user%20storage%20layout%3B%20upgrade%20no%20longer%20supported%3CBR%20%2F%3ED%20232%20Upgrading%20to%20%2Fdata%2Fmisc%2Fuser%20directories%3CBR%20%2F%3EI%20241%20perfprofd%20starting%20Android%20Wide%20Profiling%20daemon%3CBR%20%2F%3EE%20241%20perfprofd%20unable%20to%20open%20configuration%20file%20%2Fdata%2Fdata%2Fcom.google.android.gms%2Ffiles%2Fperfprofd.conf%3CBR%20%2F%3EI%20241%20perfprofd%20random%20seed%20set%20to%203634078034%3CBR%20%2F%3ED%20239%20MagDaemon%20init_sensors%3CBR%20%2F%3EI%20233%20keystore%20Found%20keymaster0%20module%20Keymaster%20OpenSSL%20HAL%2C%20version%202%3CBR%20%2F%3EI%20233%20SoftKeymaster%20system%2Fkeymaster%2Fsoft_keymaster_device.cpp%2C%20Line%20131%3A%20Creating%20device%3CBR%20%2F%3ED%20233%20SoftKeymaster%20system%2Fkeymaster%2Fsoft_keymaster_device.cpp%2C%20Line%20132%3A%20Device%20address%3A%200xafcb2000%3CBR%20%2F%3EI%20233%20keystore%20Keymaster0%20module%20is%20software-only.%20Using%20SoftKeymasterDevice%20instead.%3CBR%20%2F%3EI%20233%20SoftKeymaster%20system%2Fkeymaster%2Fsoft_keymaster_device.cpp%2C%20Line%20131%3A%20Creating%20device%3CBR%20%2F%3ED%20233%20SoftKeymaster%20system%2Fkeymaster%2Fsoft_keymaster_device.cpp%2C%20Line%20132%3A%20Device%20address%3A%200xafcb2200%3CBR%20%2F%3EI%20240%20gatekeeperd%20Starting%20gatekeeperd...%3CBR%20%2F%3EW%20240%20gatekeeperd%20falling%20back%20to%20software%20GateKeeper%3CBR%20%2F%3EI%20240%20gatekeeperd%20cold%20boot%3A%20clearing%20state%3CBR%20%2F%3EI%20221%20SurfaceFlinger%20SurfaceFlinger%20is%20starting%3CBR%20%2F%3EI%20221%20SurfaceFlinger%20SurfaceFlinger's%20main%20thread%20ready%20to%20run.%20Initializing%20graphics%20H%2FW...%3CBR%20%2F%3EI%20238%20Netd%20Netd%201.0%20starting%3CBR%20%2F%3ED%20238%20TetherController%20Setting%20IP%20forward%20enable%20%3D%200%3CBR%20%2F%3ED%20221%20libEGL%20loaded%20%2Fsystem%2Flib%2Fegl%2FlibEGL_VIVANTE.so%3CBR%20%2F%3EI%20229%20sMaxFastTracks%20%3D%208%3CBR%20%2F%3EI%20234%20mediacodec%20%40%40%40%20mediacodecservice%20starting%3CBR%20%2F%3EI%20229%20audioserver%20ServiceManager%3A%200xac119360%3CBR%20%2F%3EW%20229%20BatteryNotifier%20batterystats%20service%20unavailable!%3CBR%20%2F%3EI%20229%20AudioFlinger%20Using%20default%203000%20mSec%20as%20standby%20time.%3CBR%20%2F%3EW%20234%20%2Fsystem%2Fbin%2Fmediacodec%20libminijail%3A%20allowing%20syscall%3A%20clock_gettime%3CBR%20%2F%3EW%20234%20%2Fsystem%2Fbin%2Fmediacodec%20libminijail%3A%20allowing%20syscall%3A%20connect%3CBR%20%2F%3EW%20234%20%2Fsystem%2Fbin%2Fmediacodec%20libminijail%3A%20allowing%20syscall%3A%20fcntl64%3CBR%20%2F%3EW%20234%20%2Fsystem%2Fbin%2Fmediacodec%20libminijail%3A%20allowing%20syscall%3A%20socket%3CBR%20%2F%3EW%20234%20%2Fsystem%2Fbin%2Fmediacodec%20libminijail%3A%20allowing%20syscall%3A%20writev%3CBR%20%2F%3EI%20229%20AudioPolicyService%20AudioPolicyService%20CSTOR%20in%20new%20mode%3CBR%20%2F%3EW%20234%20%2Fsystem%2Fbin%2Fmediacodec%20libminijail%3A%20logging%20seccomp%20filter%20failures%3CBR%20%2F%3ED%20221%20libEGL%20loaded%20%2Fsystem%2Flib%2Fegl%2FlibGLESv1_CM_VIVANTE.so%3CBR%20%2F%3EI%20230%20cameraserver%20ServiceManager%3A%200xb2199360%3CBR%20%2F%3EI%20230%20CameraService%20CameraService%20started%20(pid%3D230)%3CBR%20%2F%3EI%20230%20CameraService%20CameraService%20process%20starting%3CBR%20%2F%3EE%20229%20audio_hw_primary%20no%20supported%20sound%20card%20found%2C%20aborting.%3CBR%20%2F%3EE%20229%20AudioFlinger%20int%20android%3A%3Aload_audio_interface(const%20char%20*%2C%20audio_hw_device_t%20**)%20couldn't%20open%20audio%20hw%20device%20in%20audio.primary%20(Invalid%20argument)%3CBR%20%2F%3EE%20229%20AudioFlinger%20loadHwModule()%20error%20-22%20loading%20module%20primary%3CBR%20%2F%3EW%20229%20APM_AudioPolicyManager%20could%20not%20open%20HW%20module%20primary%3CBR%20%2F%3EW%20230%20BatteryNotifier%20batterystats%20service%20unavailable!%3CBR%20%2F%3EW%20230%20BatteryNotifier%20batterystats%20service%20unavailable!%3CBR%20%2F%3EI%20229%20bt_a2dp_hw%20adev_open%3A%20adev_open%20in%20A2dp_hw%20module%3CBR%20%2F%3EI%20229%20AudioFlinger%20loadHwModule()%20Loaded%20a2dp%20audio%20interface%20from%20A2DP%20Audio%20HW%20HAL%20(audio)%20handle%2010%3CBR%20%2F%3EV%20236%20MediaUtils%20physMem%3A%202084847616%3CBR%20%2F%3EV%20236%20MediaUtils%20requested%20limit%3A%20416969520%3CBR%20%2F%3EV%20236%20MediaUtils%20actual%20limit%3A%203221225472%3CBR%20%2F%3EV%20236%20MediaUtils%20original%20limits%3A%204294967295%2F4294967295%3CBR%20%2F%3EV%20236%20MediaUtils%20new%20limits%3A%203221225472%2F4294967295%3CBR%20%2F%3EW%20236%20%2Fsystem%2Fbin%2Fmediaextractor%20libminijail%3A%20allowing%20syscall%3A%20clock_gettime%3CBR%20%2F%3EW%20236%20%2Fsystem%2Fbin%2Fmediaextractor%20libminijail%3A%20allowing%20syscall%3A%20connect%3CBR%20%2F%3EW%20236%20%2Fsystem%2Fbin%2Fmediaextractor%20libminijail%3A%20allowing%20syscall%3A%20fcntl64%3CBR%20%2F%3EW%20236%20%2Fsystem%2Fbin%2Fmediaextractor%20libminijail%3A%20allowing%20syscall%3A%20socket%3CBR%20%2F%3EW%20236%20%2Fsystem%2Fbin%2Fmediaextractor%20libminijail%3A%20allowing%20syscall%3A%20writev%3CBR%20%2F%3EW%20236%20%2Fsystem%2Fbin%2Fmediaextractor%20libminijail%3A%20logging%20seccomp%20filter%20failures%3CBR%20%2F%3EI%20229%20AudioFlinger%20loadHwModule()%20Loaded%20usb%20audio%20interface%20from%20USB%20audio%20HW%20HAL%20(audio)%20handle%2018%3CBR%20%2F%3EI%20229%20r_submix%20adev_open(name%3Daudio_hw_if)%3CBR%20%2F%3EI%20229%20r_submix%20adev_init_check()%3CBR%20%2F%3EI%20229%20AudioFlinger%20loadHwModule()%20Loaded%20r_submix%20audio%20interface%20from%20Wifi%20Display%20audio%20HAL%20(audio)%20handle%2026%3CBR%20%2F%3ED%20229%20r_submix%20adev_open_input_stream(addr%3D0)%3CBR%20%2F%3ED%20229%20r_submix%20submix_audio_device_create_pipe_l(addr%3D0%2C%20idx%3D9)%3CBR%20%2F%3ED%20229%20r_submix%20now%20using%20address%200%20for%20route%209%3CBR%20%2F%3EI%20229%20AudioFlinger%20AudioFlinger's%20thread%200xabc03c00%20ready%20to%20run%3CBR%20%2F%3ED%20229%20r_submix%20adev_close_input_stream()%3CBR%20%2F%3ED%20229%20r_submix%20submix_audio_device_release_pipe_l(idx%3D9)%20addr%3D0%3CBR%20%2F%3ED%20229%20r_submix%20submix_audio_device_destroy_pipe_l()%3A%20pipe%20destroyed%3CBR%20%2F%3EW%20229%20APM_AudioPolicyManager%20Output%20device%2000000002%20unreachable%3CBR%20%2F%3EW%20229%20APM_AudioPolicyManager%20Input%20device%2080000004%20unreachable%3CBR%20%2F%3EE%20229%20APM_AudioPolicyManager%20Default%20device%2000000002%20is%20unreachable%3CBR%20%2F%3EE%20229%20APM_AudioPolicyManager%20Failed%20to%20open%20primary%20output%3CBR%20%2F%3EI%20229%20RadioService%20RadioService%3CBR%20%2F%3EI%20229%20RadioService%20onFirstRef%3CBR%20%2F%3EE%20229%20RadioService%20couldn't%20load%20radio%20module%20radio.primary%20(No%20such%20file%20or%20directory)%3CBR%20%2F%3EE%20229%20SoundTriggerHwService%20couldn't%20load%20sound%20trigger%20module%20sound_trigger.primary%20(No%20such%20file%20or%20directory)%3CBR%20%2F%3EI%20230%20FslCameraHAL%20void%20CameraHAL%3A%3AenumSensorSet()%3CBR%20%2F%3EI%20230%20FslCameraHAL%20int32_t%20CameraHAL%3A%3AmatchDevNodes()%3CBR%20%2F%3EI%20230%20FslCameraHAL%20getNodeName%3A%20dev%20path%3A%2Fdev%2Fvideo0%3CBR%20%2F%3EW%20230%20FslCameraHAL%20int32_t%20CameraHAL%3A%3AgetNodeName(const%20char%20*%2C%20char%20*%2C%20size_t)%20open%20dev%20path%3A%2Fdev%2Fvideo0%20failed%3ATry%20again%3CBR%20%2F%3EI%20230%20FslCameraHAL%20getNodeName%3A%20dev%20path%3A%2Fdev%2Fvideo1%3CBR%20%2F%3EW%20230%20cameraserver%20type%3D1400%20audit(0.0%3A9)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Acameraserver%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EW%20230%20FslCameraHAL%20int32_t%20CameraHAL%3A%3AgetNodeName(const%20char%20*%2C%20char%20*%2C%20size_t)%20open%20dev%20path%3A%2Fdev%2Fvideo1%20failed%3ATry%20again%3CBR%20%2F%3EI%20230%20FslCameraHAL%20getNodeName%3A%20dev%20path%3A%2Fdev%2Fvideo16%3CBR%20%2F%3EW%20230%20FslCameraHAL%20int32_t%20CameraHAL%3A%3AgetNodeName(const%20char%20*%2C%20char%20*%2C%20size_t)%20open%20dev%20path%3A%2Fdev%2Fvideo16%20failed%3APermission%20denied%3CBR%20%2F%3EI%20230%20FslCameraHAL%20getNodeName%3A%20dev%20path%3A%2Fdev%2Fvideo17%3CBR%20%2F%3EW%20230%20FslCameraHAL%20int32_t%20CameraHAL%3A%3AgetNodeName(const%20char%20*%2C%20char%20*%2C%20size_t)%20dev%20path%3A%2Fdev%2Fvideo17%20is%20not%20capture%3CBR%20%2F%3EI%20230%20FslCameraHAL%20matchPropertyName%3A%20index%3A0%2C%20ov5640_camera%3CBR%20%2F%3EI%20230%20FslCameraHAL%20index%3A0%2C%20propName%3Aov5640_camera%3CBR%20%2F%3EI%20230%20FslCameraHAL%20int32_t%20CameraHAL%3A%3AmatchNodeName(const%20char%20*%2C%20nodeSet%20*%2C%20int32_t)%3CBR%20%2F%3EI%20230%20FslCameraHAL%20matchPropertyName%3A%20index%3A1%2C%20uvc%3CBR%20%2F%3EI%20230%20FslCameraHAL%20index%3A1%2C%20propName%3Auvc%3CBR%20%2F%3EI%20230%20FslCameraHAL%20int32_t%20CameraHAL%3A%3AmatchNodeName(const%20char%20*%2C%20nodeSet%20*%2C%20int32_t)%3CBR%20%2F%3EI%20230%20FslCameraHAL%20camera%20number%20is%200%3CBR%20%2F%3EE%20230%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EI%20230%20CameraService%20Loaded%20%22Default%20Camera%20HAL%22%20camera%20module%3CBR%20%2F%3EI%20230%20ServiceManager%20Waiting%20for%20service%20media.camera.proxy...%3CBR%20%2F%3EI%20237%20mediaserver%20ServiceManager%3A%200xb21193c0%3CBR%20%2F%3EI%20235%20mediaserver%20ServiceManager%3A%200xa8d193c0%3CBR%20%2F%3EW%20237%20BatteryNotifier%20batterystats%20service%20unavailable!%3CBR%20%2F%3ED%20221%20libEGL%20loaded%20%2Fsystem%2Flib%2Fegl%2FlibGLESv2_VIVANTE.so%3CBR%20%2F%3ED%20239%20MagDaemon%20couldn't%20find%20'FreescaleAccelerometer'%20input%20device%3CBR%20%2F%3ED%20239%20MagDaemon%20inital%20sensor%20error%3CBR%20%2F%3EI%20221%20imx6.gralloc%20open%20gpu%20gralloc%20module!%3CBR%20%2F%3EI%20221%20imx6.gralloc%20fb_device_open%20dispid%3A0%2C%20fb%3A0%3CBR%20%2F%3EI%20221%20imx6.gralloc%2032bpp%20setting%20of%20Framebuffer%20with%20RGBA8888%20format!%3CBR%20%2F%3EW%20221%20imx6.gralloc%20using%20(fd%3D12)%3CBR%20%2F%3EW%20221%20imx6.gralloc%20id%20%3D%20DISP4%20BG%3CBR%20%2F%3EW%20221%20imx6.gralloc%20xres%20%3D%20800%20px%3CBR%20%2F%3EW%20221%20imx6.gralloc%20yres%20%3D%201280%20px%3CBR%20%2F%3EW%20221%20imx6.gralloc%20xres_virtual%20%3D%20800%20px%3CBR%20%2F%3EW%20221%20imx6.gralloc%20yres_virtual%20%3D%203840%20px%3CBR%20%2F%3EW%20221%20imx6.gralloc%20bpp%20%3D%2032%3CBR%20%2F%3EW%20221%20imx6.gralloc%20r%20%3D%200%3A8%3CBR%20%2F%3EW%20221%20imx6.gralloc%20g%20%3D%208%3A8%3CBR%20%2F%3EW%20221%20imx6.gralloc%20b%20%3D%2016%3A8%3CBR%20%2F%3EW%20221%20imx6.gralloc%20width%20%3D%20127%20mm%20(160.000000%20dpi)%3CBR%20%2F%3EW%20221%20imx6.gralloc%20height%20%3D%20203%20mm%20(160.157639%20dpi)%3CBR%20%2F%3EW%20221%20imx6.gralloc%20refresh%20rate%20%3D%2059.54%20Hz%3CBR%20%2F%3EI%20221%20FslHwcomposer%20using%20fsl%20hwc!!!%3CBR%20%2F%3EI%20221%20FslHwcomposer%20hwc_device_open%2C579%3CBR%20%2F%3EI%20221%20FslHwcomposer%20using%20fsl%20hwc!%3CBR%20%2F%3EI%20221%20FslHwcomposer%20fb0%20is%20ldb%3CBR%20%2F%3EI%20221%20FslHwcomposer%20device%3CBR%20%2F%3EI%20221%20FslHwcomposer%20fb1%20is%20overlay%20device%3CBR%20%2F%3EW%20221%20FslHwcomposer%20open%20%2Fsys%2Fclass%2Fgraphics%2Ffb2%20failed%3CBR%20%2F%3EW%20221%20FslHwcomposer%20open%20%2Fsys%2Fclass%2Fgraphics%2Ffb3%20failed%3CBR%20%2F%3EW%20221%20FslHwcomposer%20open%20%2Fsys%2Fclass%2Fgraphics%2Ffb4%20failed%3CBR%20%2F%3EW%20221%20FslHwcomposer%20open%20%2Fsys%2Fclass%2Fgraphics%2Ffb5%20failed%3CBR%20%2F%3EI%20221%20FslHwcomposer%20hwcomposer%3A%20open%20framebuffer%20fb0%3CBR%20%2F%3EI%20221%20imx6.gralloc%20fb_device_open%20dispid%3A0%2C%20fb%3A0%3CBR%20%2F%3EI%20221%20imx6.gralloc%20display%20already%20initialized...%3CBR%20%2F%3EI%20221%20FslHwcomposer%20hwc_device_open%2C426%3CBR%20%2F%3EI%20221%20SurfaceFlinger%20Using%20composer%20version%201.3%3CBR%20%2F%3EE%20221%20FslHwcomposer%20unknown%20display%20attribute%206%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20no%20suitable%20EGLConfig%20found%2C%20trying%20a%20simpler%20query%3CBR%20%2F%3EI%20221%20SurfaceFlinger%20EGL%20information%3A%3CBR%20%2F%3EI%20221%20SurfaceFlinger%20vendor%20%3A%20Android%3CBR%20%2F%3EI%20221%20SurfaceFlinger%20version%20%3A%201.4%20Android%20META-EGL%3CBR%20%2F%3EI%20221%20SurfaceFlinger%20extensions%3A%20EGL_KHR_get_all_proc_addresses%20EGL_ANDROID_presentation_time%20EGL_KHR_swap_buffers_with_damage%20EGL_ANDROID_create_native_client_buffer%20EGL_ANDROID_front_buffer_auto_refresh%20EGL_KHR_image%20EGL_KHR_image_base%20EGL_KHR_image_pixmap%20EGL_KHR_lock_surface%20EGL_KHR_gl_texture_2D_image%20EGL_KHR_gl_texture_cubemap_image%20EGL_KHR_gl_renderbuffer_image%20EGL_KHR_reusable_sync%20EGL_KHR_fence_sync%20EGL_KHR_create_context%20EGL_KHR_surfaceless_context%20EGL_EXT_create_context_robustness%20EGL_ANDROID_image_native_buffer%20EGL_KHR_wait_sync%20EGL_ANDROID_recordable%20EGL_EXT_buffer_age%3CBR%20%2F%3EI%20221%20SurfaceFlinger%20Client%20API%3A%20OpenGL_ES%3CBR%20%2F%3EI%20221%20SurfaceFlinger%20EGLSurface%3A%208-8-8-8%2C%20config%3D0x15%3CBR%20%2F%3EW%20221%20surfaceflinger%20type%3D1400%20audit(0.0%3A10)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Asurfaceflinger%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20221%20SurfaceFlinger%20OpenGL%20ES%20informations%3A%3CBR%20%2F%3EI%20221%20SurfaceFlinger%20vendor%20%3A%20Vivante%20Corporation%3CBR%20%2F%3EI%20221%20SurfaceFlinger%20renderer%20%3A%20Vivante%20GC2000%2B%3CBR%20%2F%3EI%20221%20SurfaceFlinger%20version%20%3A%20OpenGL%20ES%203.1%20V6.2.0.p2.79565%3CBR%20%2F%3EI%20221%20SurfaceFlinger%20extensions%3A%20GL_EXT_debug_marker%20GL_OES_vertex_type_10_10_10_2%20GL_OES_vertex_half_float%20GL_OES_element_index_uint%20GL_OES_mapbuffer%20GL_OES_vertex_array_object%20GL_OES_compressed_ETC1_RGB8_texture%20GL_OES_compressed_paletted_texture%20GL_OES_texture_npot%20GL_OES_rgb8_rgba8%20GL_OES_depth_texture%20GL_OES_depth_texture_cube_map%20GL_OES_depth24%20GL_OES_depth32%20GL_OES_packed_depth_stencil%20GL_OES_fbo_render_mipmap%20GL_OES_get_program_binary%20GL_OES_fragment_precision_high%20GL_OES_standard_derivatives%20GL_OES_EGL_image%20GL_OES_EGL_image_external%20GL_OES_EGL_sync%20GL_OES_texture_stencil8%20GL_OES_shader_image_atomic%20GL_OES_texture_storage_multisample_2d_array%20GL_OES_required_internalformat%20GL_OES_surfaceless_context%20GL_OES_texture_half_float%20GL_OES_texture_float%20GL_KHR_texture_compression_astc_ldr%20GL_KHR_blend_equation_advanced%20GL_KHR_debug%20GL_KHR_robustness%20GL_EXT_texture_type_2_10_10_10_REV%20GL_EXT_texture_filter_anisotropic%20GL_EXT_texture_format_BGRA8888%20GL_EXT_read_format_bgra%20GL_EXT_multi_draw_arrays%20GL_EXT_frag_depth%20GL_EXT_discard%3CBR%20%2F%3EI%20221%20SurfaceFlinger%20GL_MAX_TEXTURE_SIZE%20%3D%208192%3CBR%20%2F%3EI%20221%20SurfaceFlinger%20GL_MAX_VIEWPORT_DIMS%20%3D%208192%3CBR%20%2F%3EE%20221%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EI%20221%20imx6.gralloc%20fb_device_open%20dispid%3A0%2C%20fb%3A0%3CBR%20%2F%3EI%20221%20imx6.gralloc%20display%20already%20initialized...%3CBR%20%2F%3EI%20221%20v_egl%20FramebufferSurface%3A%20bufferCount%3D3%3CBR%20%2F%3EE%20221%20libEGL%20eglSetSwapRectangleANDROID%3A1984%20error%20300d%20(EGL_BAD_SURFACE)%3CBR%20%2F%3ED%20221%20SurfaceFlinger%20shader%20cache%20generated%20-%2024%20shaders%20in%20378.285675%20ms%3CBR%20%2F%3ED%20221%20SurfaceFlinger%20Set%20power%20mode%3D2%2C%20type%3D0%20flinger%3D0xa8732000%3CBR%20%2F%3EW%20306%20bootanimation%20type%3D1400%20audit(0.0%3A11)%3A%20avc%3A%20denied%20%7B%20getattr%20%7D%20for%20path%3D%22%2Fvendor%22%20dev%3D%22rootfs%22%20ino%3D7112%20scontext%3Du%3Ar%3Abootanim%3As0%20tcontext%3Du%3Aobject_r%3Arootfs%3As0%20tclass%3Dlnk_file%20permissive%3D0%3CBR%20%2F%3EI%20221%20FslHwcomposer%20prepare%3A%20targetHandle%20is%20null%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20230%20ServiceManager%20Waiting%20for%20service%20media.camera.proxy...%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20228%20AndroidRuntime%20%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%20START%20com.android.internal.os.ZygoteInit%20uid%200%20%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20228%20AndroidRuntime%20CheckJNI%20is%20ON%3CBR%20%2F%3EI%20228%20art%20option%5B0%5D%3D-Xzygote%3CBR%20%2F%3EI%20228%20art%20option%5B1%5D%3D-Xcheck%3Ajni%3CBR%20%2F%3EI%20228%20art%20option%5B2%5D%3D-Xstacktracefile%3A%2Fdata%2Fanr%2Ftraces.txt%3CBR%20%2F%3EI%20228%20art%20option%5B3%5D%3Dexit%3CBR%20%2F%3EI%20228%20art%20option%5B4%5D%3Dvfprintf%3CBR%20%2F%3EI%20228%20art%20option%5B5%5D%3DsensitiveThread%3CBR%20%2F%3EI%20228%20art%20option%5B6%5D%3D-verbose%3Agc%3CBR%20%2F%3EI%20228%20art%20option%5B7%5D%3D-Xms8m%3CBR%20%2F%3EI%20228%20art%20option%5B8%5D%3D-Xmx384m%3CBR%20%2F%3EI%20228%20art%20option%5B9%5D%3D-XX%3AHeapGrowthLimit%3D128m%3CBR%20%2F%3EI%20228%20art%20option%5B10%5D%3D-XX%3AHeapMinFree%3D512k%3CBR%20%2F%3EI%20228%20art%20option%5B11%5D%3D-XX%3AHeapMaxFree%3D8m%3CBR%20%2F%3EI%20228%20art%20option%5B12%5D%3D-XX%3AHeapTargetUtilization%3D0.75%3CBR%20%2F%3EI%20228%20art%20option%5B13%5D%3D-Xusejit%3Atrue%3CBR%20%2F%3EI%20228%20art%20option%5B14%5D%3D-Xjitsaveprofilinginfo%3CBR%20%2F%3EI%20228%20art%20option%5B15%5D%3D-agentlib%3Ajdwp%3Dtransport%3Ddt_android_adb%2Csuspend%3Dn%2Cserver%3Dy%3CBR%20%2F%3EI%20228%20art%20option%5B16%5D%3D-Xlockprofthreshold%3A500%3CBR%20%2F%3EI%20228%20art%20option%5B17%5D%3D-Ximage-compiler-option%3CBR%20%2F%3EI%20228%20art%20option%5B18%5D%3D--runtime-arg%3CBR%20%2F%3EI%20228%20art%20option%5B19%5D%3D-Ximage-compiler-option%3CBR%20%2F%3EI%20228%20art%20option%5B20%5D%3D-Xms64m%3CBR%20%2F%3EI%20228%20art%20option%5B21%5D%3D-Ximage-compiler-option%3CBR%20%2F%3EI%20228%20art%20option%5B22%5D%3D--runtime-arg%3CBR%20%2F%3EI%20228%20art%20option%5B23%5D%3D-Ximage-compiler-option%3CBR%20%2F%3EI%20228%20art%20option%5B24%5D%3D-Xmx64m%3CBR%20%2F%3EI%20228%20art%20option%5B25%5D%3D-Ximage-compiler-option%3CBR%20%2F%3EI%20228%20art%20option%5B26%5D%3D--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EI%20228%20art%20option%5B27%5D%3D-Ximage-compiler-option%3CBR%20%2F%3EI%20228%20art%20option%5B28%5D%3D--image-classes%3D%2Fsystem%2Fetc%2Fpreloaded-classes%3CBR%20%2F%3EI%20228%20art%20option%5B29%5D%3D-Ximage-compiler-option%3CBR%20%2F%3EI%20228%20art%20option%5B30%5D%3D--compiled-classes%3D%2Fsystem%2Fetc%2Fcompiled-classes%3CBR%20%2F%3EI%20228%20art%20option%5B31%5D%3D-Xcompiler-option%3CBR%20%2F%3EI%20228%20art%20option%5B32%5D%3D--runtime-arg%3CBR%20%2F%3EI%20228%20art%20option%5B33%5D%3D-Xcompiler-option%3CBR%20%2F%3EI%20228%20art%20option%5B34%5D%3D-Xms64m%3CBR%20%2F%3EI%20228%20art%20option%5B35%5D%3D-Xcompiler-option%3CBR%20%2F%3EI%20228%20art%20option%5B36%5D%3D--runtime-arg%3CBR%20%2F%3EI%20228%20art%20option%5B37%5D%3D-Xcompiler-option%3CBR%20%2F%3EI%20228%20art%20option%5B38%5D%3D-Xmx512m%3CBR%20%2F%3EI%20228%20art%20option%5B39%5D%3D-Ximage-compiler-option%3CBR%20%2F%3EI%20228%20art%20option%5B40%5D%3D--instruction-set-variant%3Dcortex-a9%3CBR%20%2F%3EI%20228%20art%20option%5B41%5D%3D-Xcompiler-option%3CBR%20%2F%3EI%20228%20art%20option%5B42%5D%3D--instruction-set-variant%3Dcortex-a9%3CBR%20%2F%3EI%20228%20art%20option%5B43%5D%3D-Ximage-compiler-option%3CBR%20%2F%3EI%20228%20art%20option%5B44%5D%3D--instruction-set-features%3Ddefault%3CBR%20%2F%3EI%20228%20art%20option%5B45%5D%3D-Xcompiler-option%3CBR%20%2F%3EI%20228%20art%20option%5B46%5D%3D--instruction-set-features%3Ddefault%3CBR%20%2F%3EI%20228%20art%20option%5B47%5D%3D-Duser.locale%3Den-US%3CBR%20%2F%3EI%20228%20art%20option%5B48%5D%3D--cpu-abilist%3Darmeabi-v7a%2Carmeabi%3CBR%20%2F%3EI%20228%20art%20option%5B49%5D%3D-Xfingerprint%3AFreescale%2Fsabresd_6dq%2Fsabresd_6dq%3A7.1.1%2F1.0.0-ga-rc10%2F20170227%3Aeng%2Frelease-keys%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20228%20art%20Pruning%20dalvik-cache%20since%20we%20are%20relocating%20an%20image%20and%20will%20need%20to%20recompile%3CBR%20%2F%3EI%20228%20art%20RelocateImage%3A%20%2Fsystem%2Fbin%2Fpatchoat%20--input-image-location%3D%2Fsystem%2Fframework%2Fboot.art%20--output-image-file%3D%2Fdata%2Fdalvik-cache%2Farm%2Fsystem%40framework%40boot.art%20--instruction-set%3Darm%20--base-offset-delta%3D16191488%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20230%20ServiceManager%20Waiting%20for%20service%20media.camera.proxy...%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20306%20BootAnimation%20boot%20animation%20disabled%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20230%20ServiceManager%20Waiting%20for%20service%20media.camera.proxy...%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EV%20238%20NatController%20runCmd(%2Fsystem%2Fbin%2Fiptables%20-w%20-F%20natctrl_FORWARD)%20res%3D0%3CBR%20%2F%3EV%20238%20NatController%20runCmd(%2Fsystem%2Fbin%2Fip6tables%20-w%20-F%20natctrl_FORWARD)%20res%3D0%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EV%20238%20NatController%20runCmd(%2Fsystem%2Fbin%2Fiptables%20-w%20-A%20natctrl_FORWARD%20-j%20DROP)%20res%3D0%3CBR%20%2F%3EV%20238%20NatController%20runCmd(%2Fsystem%2Fbin%2Fiptables%20-w%20-t%20nat%20-F%20natctrl_nat_POSTROUTING)%20res%3D0%3CBR%20%2F%3EV%20238%20NatController%20runCmd(%2Fsystem%2Fbin%2Fip6tables%20-w%20-t%20raw%20-F%20natctrl_raw_PREROUTING)%20res%3D0%3CBR%20%2F%3EV%20238%20NatController%20runCmd(%2Fsystem%2Fbin%2Fiptables%20-w%20-F%20natctrl_tether_counters)%20res%3D1%3CBR%20%2F%3EV%20238%20NatController%20runCmd(%2Fsystem%2Fbin%2Fip6tables%20-w%20-F%20natctrl_tether_counters)%20res%3D1%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EV%20238%20NatController%20runCmd(%2Fsystem%2Fbin%2Fiptables%20-w%20-X%20natctrl_tether_counters)%20res%3D1%3CBR%20%2F%3EV%20238%20NatController%20runCmd(%2Fsystem%2Fbin%2Fip6tables%20-w%20-X%20natctrl_tether_counters)%20res%3D1%3CBR%20%2F%3EV%20238%20NatController%20runCmd(%2Fsystem%2Fbin%2Fiptables%20-w%20-N%20natctrl_tether_counters)%20res%3D0%3CBR%20%2F%3EV%20238%20NatController%20runCmd(%2Fsystem%2Fbin%2Fip6tables%20-w%20-N%20natctrl_tether_counters)%20res%3D0%3CBR%20%2F%3EV%20238%20NatController%20runCmd(%2Fsystem%2Fbin%2Fiptables%20-w%20-t%20mangle%20-A%20natctrl_mangle_FORWARD%20-p%20tcp%20--tcp-flags%20SYN%20SYN%20-j%20TCPMSS%20--clamp-mss-to-pmtu)%20res%3D0%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20228%20ICU%20No%20timezone%20override%20file%20found%3A%20%2Fdata%2Fmisc%2Fzoneinfo%2Fcurrent%2Ficu%2Ficu_tzdata.dat%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20230%20ServiceManager%20Waiting%20for%20service%20media.camera.proxy...%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EE%20238%20Netd%20cannot%20find%20interface%20dummy0%3CBR%20%2F%3EE%20238%20Netd%20Unable%20to%20create%20netlink%20socket%3A%20Protocol%20not%20supported%3CBR%20%2F%3EW%20238%20Netd%20Unable%20to%20open%20qlog%20quota%20socket%2C%20check%20if%20xt_quota2%20can%20send%20via%20UeventHandler%3CBR%20%2F%3ED%20238%20MDnsDS%20MDnsSdListener%3A%3AHander%20starting%20up%3CBR%20%2F%3ED%20238%20MDnsDS%20MDnsSdListener%20starting%20to%20monitor%3CBR%20%2F%3ED%20238%20MDnsDS%20Going%20to%20poll%20with%20pollCount%201%3CBR%20%2F%3EE%20228%20memtrack%20Couldn't%20load%20memtrack%20module%20(No%20such%20file%20or%20directory)%3CBR%20%2F%3EE%20228%20android.os.Debug%20failed%20to%20load%20memtrack%20module%3A%20-2%3CBR%20%2F%3EI%20228%20Radio-JNI%20register_android_hardware_Radio%20DONE%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20228%20SamplingProfilerIntegration%20Profiling%20disabled.%3CBR%20%2F%3ED%20228%20Zygote%20begin%20preload%3CBR%20%2F%3EI%20228%20Zygote%20Installing%20ICU%20cache%20reference%20pinning...%3CBR%20%2F%3EI%20228%20Zygote%20Preloading%20ICU%20data...%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20228%20Zygote%20Preloading%20classes...%3CBR%20%2F%3EW%20228%20Zygote%20Class%20not%20found%20for%20preloading%3A%20%5BLandroid.view.Display%24ColorTransform%3B%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EE%20228%20Typeface%20Error%20mapping%20font%20file%20%2Fsystem%2Ffonts%2FDroidSansFallback.ttf%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20228%20art%20Thread%5B1%2Ctid%3D228%2CNative%2CThread*%3D0xb0885400%2Cpeer%3D0x12c060d0%2C%22main%22%5D%20recursive%20attempt%20to%20load%20library%20%22%2Fsystem%2Flib%2Flibmedia_jni.so%22%3CBR%20%2F%3ED%20228%20MtpDeviceJNI%20register_android_mtp_MtpDevice%3CBR%20%2F%3EI%20228%20art%20Thread%5B1%2Ctid%3D228%2CNative%2CThread*%3D0xb0885400%2Cpeer%3D0x12c060d0%2C%22main%22%5D%20recursive%20attempt%20to%20load%20library%20%22%2Fsystem%2Flib%2Flibmedia_jni.so%22%3CBR%20%2F%3EI%20228%20art%20Thread%5B1%2Ctid%3D228%2CNative%2CThread*%3D0xb0885400%2Cpeer%3D0x12c060d0%2C%22main%22%5D%20recursive%20attempt%20to%20load%20library%20%22%2Fsystem%2Flib%2Flibmedia_jni.so%22%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20228%20Zygote%20Class%20not%20found%20for%20preloading%3A%20android.view.Display%24ColorTransform%3CBR%20%2F%3EW%20228%20Zygote%20Class%20not%20found%20for%20preloading%3A%20android.view.Display%24ColorTransform%241%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20228%20System%20Loaded%20time%20zone%20names%20for%20%22%22%20in%20108ms%20(104ms%20in%20ICU)%3CBR%20%2F%3EI%20228%20System%20Loaded%20time%20zone%20names%20for%20%22en_US%22%20in%2055ms%20(51ms%20in%20ICU)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20228%20Zygote%20...preloaded%204158%20classes%20in%202435ms.%3CBR%20%2F%3EI%20228%20art%20VMRuntime.preloadDexCaches%20starting%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20228%20art%20VMRuntime.preloadDexCaches%20strings%20total%3D283754%20before%3D39651%20after%3D39651%3CBR%20%2F%3EI%20228%20art%20VMRuntime.preloadDexCaches%20types%20total%3D23583%20before%3D7877%20after%3D7904%3CBR%20%2F%3EI%20228%20art%20VMRuntime.preloadDexCaches%20fields%20total%3D112010%20before%3D40900%20after%3D41114%3CBR%20%2F%3EI%20228%20art%20VMRuntime.preloadDexCaches%20methods%20total%3D197529%20before%3D82452%20after%3D83012%3CBR%20%2F%3EI%20228%20art%20VMRuntime.preloadDexCaches%20finished%3CBR%20%2F%3EI%20228%20Zygote%20Preloading%20resources...%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20228%20Resources%20Preloaded%20drawable%20resource%20%230x108025c%20(android%3Adrawable%2Fdialog_background_material)%20that%20varies%20with%20configuration!!%3CBR%20%2F%3EW%20228%20Resources%20Preloaded%20drawable%20resource%20%230x1080298%20(android%3Adrawable%2Feditbox_dropdown_background_dark)%20that%20varies%20with%20configuration!!%3CBR%20%2F%3EW%20228%20Resources%20Preloaded%20color%20resource%20%230x10600e2%20(android%3Acolor%2Fmaterial_grey_800)%20that%20varies%20with%20configuration!!%3CBR%20%2F%3EW%20228%20Resources%20Preloaded%20drawable%20resource%20%230x10802c9%20(android%3Adrawable%2Ffloating_popup_background_dark)%20that%20varies%20with%20configuration!!%3CBR%20%2F%3EW%20228%20Resources%20Preloaded%20drawable%20resource%20%230x108030b%20(android%3Adrawable%2Fic_clear_disabled)%20that%20varies%20with%20configuration!!%3CBR%20%2F%3EW%20228%20Resources%20Preloaded%20drawable%20resource%20%230x1080310%20(android%3Adrawable%2Fic_clear_normal)%20that%20varies%20with%20configuration!!%3CBR%20%2F%3EW%20228%20Resources%20Preloaded%20drawable%20resource%20%230x1080359%20(android%3Adrawable%2Fic_go)%20that%20varies%20with%20configuration!!%3CBR%20%2F%3EW%20228%20Resources%20Preloaded%20drawable%20resource%20%230x1080038%20(android%3Adrawable%2Fic_menu_close_clear_cancel)%20that%20varies%20with%20configuration!!%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20228%20Resources%20Preloaded%20drawable%20resource%20%230x1080045%20(android%3Adrawable%2Fic_menu_more)%20that%20varies%20with%20configuration!!%3CBR%20%2F%3EW%20228%20Resources%20Preloaded%20drawable%20resource%20%230x10804e8%20(android%3Adrawable%2Fmenu_background_fill_parent_width)%20that%20varies%20with%20configuration!!%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20228%20Resources%20Preloaded%20drawable%20resource%20%230x108077e%20(android%3Adrawable%2Ftext_edit_paste_window)%20that%20varies%20with%20configuration!!%3CBR%20%2F%3EW%20228%20Resources%20Preloaded%20drawable%20resource%20%230x1080096%20(android%3Adrawable%2Ftoast_frame)%20that%20varies%20with%20configuration!!%3CBR%20%2F%3EI%20228%20Zygote%20...preloaded%20114%20resources%20in%20298ms.%3CBR%20%2F%3EW%20228%20Resources%20Preloaded%20color%20resource%20%230x106010b%20(android%3Acolor%2Fbackground_cache_hint_selector_material_dark)%20that%20varies%20with%20configuration!!%3CBR%20%2F%3EW%20228%20Resources%20Preloaded%20color%20resource%20%230x1060110%20(android%3Acolor%2Fbtn_default_material_dark)%20that%20varies%20with%20configuration!!%3CBR%20%2F%3EI%20228%20Zygote%20...preloaded%2041%20resources%20in%2018ms.%3CBR%20%2F%3ED%20228%20libEGL%20loaded%20%2Fsystem%2Flib%2Fegl%2FlibEGL_VIVANTE.so%3CBR%20%2F%3ED%20228%20libEGL%20loaded%20%2Fsystem%2Flib%2Fegl%2FlibGLESv1_CM_VIVANTE.so%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20228%20libEGL%20loaded%20%2Fsystem%2Flib%2Fegl%2FlibGLESv2_VIVANTE.so%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20228%20Zygote%20Preloading%20shared%20libraries...%3CBR%20%2F%3EI%20228%20Zygote%20Uninstalled%20ICU%20cache%20reference%20pinning...%3CBR%20%2F%3EI%20228%20Zygote%20Installed%20AndroidKeyStoreProvider%20in%2011ms.%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20228%20Zygote%20Warmed%20up%20JCA%20providers%20in%2075ms.%3CBR%20%2F%3ED%20228%20Zygote%20end%20preload%3CBR%20%2F%3EI%20228%20art%20Starting%20a%20blocking%20GC%20Explicit%3CBR%20%2F%3EI%20228%20art%20Explicit%20concurrent%20mark%20sweep%20GC%20freed%202959(164KB)%20AllocSpace%20objects%2C%200(0B)%20LOS%20objects%2C%2039%25%20free%2C%202MB%2F3MB%2C%20paused%20348us%20total%2020.651ms%3CBR%20%2F%3EI%20228%20art%20Starting%20a%20blocking%20GC%20Explicit%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20228%20art%20Explicit%20concurrent%20mark%20sweep%20GC%20freed%205(128B)%20AllocSpace%20objects%2C%200(0B)%20LOS%20objects%2C%2039%25%20free%2C%202MB%2F3MB%2C%20paused%20342us%20total%2023.172ms%3CBR%20%2F%3EI%20228%20art%20Starting%20a%20blocking%20GC%20HeapTrim%3CBR%20%2F%3EI%20228%20art%20Starting%20a%20blocking%20GC%20Background%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20228%20Zygote%20System%20server%20process%20486%20has%20been%20created%3CBR%20%2F%3EI%20228%20Zygote%20Accepting%20command%20socket%20connections%3CBR%20%2F%3EI%20486%20InstallerConnection%20connecting...%3CBR%20%2F%3EI%20232%20new%20connection%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20497%20dex2oat%20type%3D1400%20audit(0.0%3A12)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20497%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20497%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20497%20dex2oat%20Compilation%20of%20void%20com.android.server.BluetoothManagerService%24BluetoothHandler.handleMessage(android.os.Message)%20took%20102.530ms%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20497%20dex2oat%20Compilation%20of%20void%20com.android.server.SystemServer.startOtherServices()%20took%20440.134ms%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20497%20dex2oat%20Compilation%20of%20void%20com.android.server.am.ActivityManagerService%24MainHandler.handleMessage(android.os.Message)%20took%20162.764ms%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20497%20dex2oat%20Compilation%20of%20android.app.IActivityManager%24ContentProviderHolder%20com.android.server.am.ActivityManagerService.getContentProviderImpl(android.app.IApplicationThread%2C%20java.lang.String%2C%20android.os.IBinder%2C%20boolean%2C%20int)%20took%20119.458ms%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20497%20dex2oat%20Compilation%20of%20int%20com.android.server.am.ActivityManagerService.broadcastIntentLocked(com.android.server.am.ProcessRecord%2C%20java.lang.String%2C%20android.content.Intent%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20int%2C%20java.lang.String%2C%20android.os.Bundle%2C%20java.lang.String%5B%5D%2C%20int%2C%20android.os.Bundle%2C%20boolean%2C%20boolean%2C%20int%2C%20int%2C%20int)%20took%20178.243ms%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20497%20dex2oat%20Compilation%20of%20void%20com.android.server.am.BroadcastQueue.processNextBroadcast(boolean)%20took%20242.035ms%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20497%20dex2oat%20Compilation%20of%20void%20com.android.server.am.ProcessStatsService.dumpInner(java.io.FileDescriptor%2C%20java.io.PrintWriter%2C%20java.lang.String%5B%5D)%20took%20133.502ms%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20497%20dex2oat%20Compilation%20of%20void%20com.android.server.am.ActivityManagerService.dumpApplicationMemoryUsage(java.io.FileDescriptor%2C%20java.io.PrintWriter%2C%20java.lang.String%2C%20java.lang.String%5B%5D%2C%20boolean%2C%20java.io.PrintWriter)%20took%20265.825ms%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20497%20dex2oat%20Compilation%20of%20void%20com.android.server.am.ActivityManagerService.dumpProcessesLocked(java.io.FileDescriptor%2C%20java.io.PrintWriter%2C%20java.lang.String%5B%5D%2C%20int%2C%20boolean%2C%20java.lang.String)%20took%20149.495ms%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20497%20dex2oat%20Compilation%20of%20void%20com.android.server.notification.NotificationRecord.dump(java.io.PrintWriter%2C%20java.lang.String%2C%20android.content.Context%2C%20boolean)%20took%20102.756ms%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20497%20dex2oat%20Compilation%20of%20void%20com.android.server.pm.DefaultPermissionGrantPolicy.grantDefaultSystemHandlerPermissions(int)%20took%20251.654ms%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20497%20dex2oat%20Compilation%20of%20void%20com.android.server.pm.PackageManagerService.%3CINIT%3E(android.content.Context%2C%20com.android.server.pm.Installer%2C%20boolean%2C%20boolean)%20took%20274.361ms%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20497%20dex2oat%20Compilation%20of%20void%20com.android.server.pm.Settings.readPackageLPw(org.xmlpull.v1.XmlPullParser)%20took%20103.315ms%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20497%20dex2oat%20Compilation%20of%20void%20com.android.server.pm.Settings.dumpPackageLPr(java.io.PrintWriter%2C%20java.lang.String%2C%20java.lang.String%2C%20android.util.ArraySet%2C%20com.android.server.pm.PackageSetting%2C%20java.text.SimpleDateFormat%2C%20java.util.Date%2C%20java.util.List%2C%20boolean)%20took%20105.865ms%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20497%20dex2oat%20Compilation%20of%20boolean%20com.android.server.pm.Settings.readLPw(java.util.List)%20took%20102.837ms%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20497%20dex2oat%20Compilation%20of%20void%20com.android.server.pm.PackageManagerService.installPackageLI(com.android.server.pm.PackageManagerService%24InstallArgs%2C%20com.android.server.pm.PackageManagerService%24PackageInstalledInfo)%20took%20134.236ms%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20497%20dex2oat%20Compilation%20of%20void%20com.android.server.power.PowerManagerService.dumpInternal(java.io.PrintWriter)%20took%20156.211ms%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20497%20dex2oat%20Compilation%20of%20android.content.pm.PackageParser%24Package%20com.android.server.pm.PackageManagerService.scanPackageDirtyLI(android.content.pm.PackageParser%24Package%2C%20int%2C%20int%2C%20long%2C%20android.os.UserHandle)%20took%20529.342ms%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20497%20dex2oat%20Compilation%20of%20void%20com.android.server.pm.PackageManagerService.dump(java.io.FileDescriptor%2C%20java.io.PrintWriter%2C%20java.lang.String%5B%5D)%20took%20508.211ms%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20497%20dex2oat%20Compilation%20of%20void%20com.android.server.wm.WindowManagerService%24H.handleMessage(android.os.Message)%20took%20113.744ms%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20497%20dex2oat%20Compilation%20of%20int%20com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.view.InputChannel)%20took%20151.344ms%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20497%20dex2oat%20dex2oat%20took%2018.828s%20(threads%3A%204)%20arena%20alloc%3D14MB%20(15449792B)%20java%20alloc%3D2MB%20(2361624B)%20native%20alloc%3D24MB%20(25822680B)%20free%3D17MB%20(18217512B)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20502%20dex2oat%20type%3D1400%20audit(0.0%3A13)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20502%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20502%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20502%20dex2oat%20dex2oat%20took%201.249s%20(threads%3A%204)%20arena%20alloc%3D1027KB%20(1052216B)%20java%20alloc%3D173KB%20(177160B)%20native%20alloc%3D1788KB%20(1831608B)%20free%3D2MB%20(2886984B)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20508%20dex2oat%20type%3D1400%20audit(0.0%3A14)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20508%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20508%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20508%20dex2oat%20Compilation%20of%20void%20com.android.server.wifi.WifiMetrics.dump(java.io.FileDescriptor%2C%20java.io.PrintWriter%2C%20java.lang.String%5B%5D)%20took%20109.194ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20508%20dex2oat%20Compilation%20of%20void%20com.android.server.wifi.WifiNetworkHistory%241.onWriteCalled(java.io.DataOutputStream)%20took%20134.846ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20508%20dex2oat%20Compilation%20of%20android.net.wifi.WifiConfiguration%20com.android.server.wifi.WifiQualifiedNetworkSelector.selectQualifiedNetwork(boolean%2C%20boolean%2C%20java.util.List%2C%20boolean%2C%20boolean%2C%20boolean%2C%20boolean)%20took%20102.984ms%3CBR%20%2F%3EW%20508%20dex2oat%20Compilation%20of%20boolean%20com.android.server.wifi.WifiStateMachine%24ConnectModeState.processMessage(android.os.Message)%20took%20152.738ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20508%20dex2oat%20dex2oat%20took%203.553s%20(threads%3A%204)%20arena%20alloc%3D6MB%20(7074992B)%20java%20alloc%3D462KB%20(473920B)%20native%20alloc%3D4MB%20(4315144B)%20free%3D9MB%20(9840632B)%3CBR%20%2F%3EI%20486%20system%20InstallerConnection%20disconnecting...%3CBR%20%2F%3EE%20232%20%2Fsystem%2Fbin%2Finstalld%20eof%3CBR%20%2F%3EE%20232%20%2Fsystem%2Fbin%2Finstalld%20failed%20to%20read%20size%3CBR%20%2F%3EI%20232%20%2Fsystem%2Fbin%2Finstalld%20closing%20connection%3CBR%20%2F%3EW%20486%20system%20SystemServer%20System%20clock%20is%20before%201970%3B%20setting%20to%201970.%3CBR%20%2F%3EI%20486%20system%20SystemServer%20Entered%20the%20Android%20system%20server!%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.pm.Installer%3CBR%20%2F%3EI%20486%20system%20Installer%20Waiting%20for%20installd%20to%20be%20ready.%3CBR%20%2F%3EI%20486%20system%20InstallerConnection%20connecting...%3CBR%20%2F%3EI%20232%20%2Fsystem%2Fbin%2Finstalld%20new%20connection%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.am.ActivityManagerService%24Lifecycle%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Memory%20class%3A%20128%3CBR%20%2F%3EI%20486%20system%20ServiceThread%20Enabled%20StrictMode%20logging%20for%20ActivityManager%20looper.%3CBR%20%2F%3EI%20486%20system%20ServiceThread%20Enabled%20StrictMode%20logging%20for%20android.ui%20looper.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20BatteryStatsImpl%20Reading%20daily%20items%20from%20%2Fdata%2Fsystem%2Fbatterystats-daily.xml%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20AppOps%20No%20existing%20app%20ops%20%2Fdata%2Fsystem%2Fappops.xml%3B%20starting%20empty%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20IntentFirewall%20Read%20new%20rules%20(A%3A0%20B%3A0%20S%3A0)%3CBR%20%2F%3EI%20486%20system%20ServiceThread%20Enabled%20StrictMode%20logging%20for%20android.display%20looper.%3CBR%20%2F%3ED%20486%20system%20AppOps%20AppOpsService%20published%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.power.PowerManagerService%3CBR%20%2F%3EI%20486%20system%20ServiceThread%20Enabled%20StrictMode%20logging%20for%20PowerManagerService%20looper.%3CBR%20%2F%3EE%20486%20system%20SWITCHPROFILE%20setprop%3A%20sys.interactive%20%3D%20active%3CBR%20%2F%3EW%20486%20system%20libsuspend%20Error%20writing%20'on'%20to%20%2Fsys%2Fpower%2Fstate%3A%20Invalid%20argument%3CBR%20%2F%3EI%20486%20system%20libsuspend%20Selected%20wakeup%20count%3CBR%20%2F%3EI%20486%20system%20SWITCHPROFILE%20Switchprofile%20thread%20received%20GOV_INTERACTIVE%20from%20Power%20HAL%3CBR%20%2F%3EE%20486%20system%20SWITCHPROFILE%20setprop%3A%20sys.interactive%20%3D%20active%3CBR%20%2F%3EE%20486%20system%20SWITCHPROFILE%20Could%20not%20open%20cpu%20gov%3A%2Fsys%2Fdevices%2Fsystem%2Fcpu%2Fcpufreq%2Finteractive%2Finput_boost%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.lights.LightsService%3CBR%20%2F%3EI%20486%20system%20lights%20max%20backlight%20file%20is%20%2Fsys%2Fclass%2Fbacklight%2Fpwm-backlight%2Fmax_brightness%3CBR%20%2F%3EI%20486%20system%20lights%20backlight%20brightness%20file%20is%20%2Fsys%2Fclass%2Fbacklight%2Fpwm-backlight%2Fbrightness%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.display.DisplayManagerService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20phase%20100%3CBR%20%2F%3EI%20486%20system%20DisplayManagerService%20Display%20device%20added%3A%20DisplayDeviceInfo%7B%22Built-in%20Screen%22%3A%20uniqueId%3D%22local%3A0%22%2C%201280%20x%20800%2C%20modeId%201%2C%20defaultModeId%201%2C%20supportedModes%20%5B%7Bid%3D1%2C%20width%3D1280%2C%20height%3D800%2C%20fps%3D59.0%7D%5D%2C%20colorMode%200%2C%20supportedColorModes%20%5B0%5D%2C%20HdrCapabilities%20android.view.Display%24HdrCapabilities%40a69d6308%2C%20density%20160%2C%20160.0%20x%20160.157%20dpi%2C%20appVsyncOff%201000000%2C%20presDeadline%2016949152%2C%20touch%20INTERNAL%2C%20rotation%200%2C%20type%20BUILT_IN%2C%20state%20UNKNOWN%2C%20FLAG_DEFAULT_DISPLAY%2C%20FLAG_ROTATES_WITH_CONTENT%2C%20FLAG_SECURE%2C%20FLAG_SUPPORTS_PROTECTED_BUFFERS%7D%3CBR%20%2F%3ED%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Set%20power%20mode%3D2%2C%20type%3D0%20flinger%3D0xa8732000%3CBR%20%2F%3ED%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Screen%20type%3D0%20is%20already%20mode%3D2%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartPackageManagerService%3CBR%20%2F%3EI%20486%20system%20DisplayManagerService%20Display%20device%20changed%20state%3A%20%22Built-in%20Screen%22%2C%20ON%3CBR%20%2F%3EW%20486%20system%20FileUtils%20Failed%20to%20chmod(%2Fdata%2Fsystem%2Fpackages.list)%3A%20android.system.ErrnoException%3A%20chmod%20failed%3A%20ENOENT%20(No%20such%20file%20or%20directory)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20SystemConfig%20No%20directory%20%2Fsystem%2Fetc%2Fsysconfig%2C%20skipping%3CBR%20%2F%3ED%20486%20system%20SELinuxMMAC%20Using%20policy%20file%20%2Fsystem%2Fetc%2Fsecurity%2Fmac_permissions.xml%3CBR%20%2F%3EI%20486%20system%20PackageManager%20No%20settings%20file%3B%20creating%20initial%20state%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20530%20dex2oat%20type%3D1400%20audit(0.0%3A15)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20530%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20530%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20530%20dex2oat%20dex2oat%20took%20273.275ms%20(threads%3A%204)%20arena%20alloc%3D347KB%20(355856B)%20java%20alloc%3D157KB%20(161480B)%20native%20alloc%3D1163KB%20(1191480B)%20free%3D1908KB%20(1954248B)%3CBR%20%2F%3EW%20536%20dex2oat%20type%3D1400%20audit(0.0%3A16)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20536%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20536%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20536%20dex2oat%20dex2oat%20took%20238.845ms%20(threads%3A%204)%20arena%20alloc%3D254KB%20(260456B)%20java%20alloc%3D51KB%20(53128B)%20native%20alloc%3D974KB%20(997704B)%20free%3D1073KB%20(1099448B)%3CBR%20%2F%3EW%20541%20dex2oat%20type%3D1400%20audit(0.0%3A17)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20541%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20541%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20541%20dex2oat%20dex2oat%20took%20349.684ms%20(threads%3A%204)%20arena%20alloc%3D1929KB%20(1976312B)%20java%20alloc%3D115KB%20(118616B)%20native%20alloc%3D1114KB%20(1141600B)%20free%3D3MB%20(4101280B)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20546%20dex2oat%20type%3D1400%20audit(0.0%3A18)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20546%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20546%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20546%20dex2oat%20dex2oat%20took%20215.087ms%20(threads%3A%204)%20arena%20alloc%3D21KB%20(22288B)%20java%20alloc%3D39KB%20(40680B)%20native%20alloc%3D781KB%20(800560B)%20free%3D1266KB%20(1296592B)%3CBR%20%2F%3EW%20551%20dex2oat%20type%3D1400%20audit(0.0%3A19)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20551%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20551%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20551%20dex2oat%20dex2oat%20took%20580.273ms%20(threads%3A%204)%20arena%20alloc%3D1211KB%20(1240768B)%20java%20alloc%3D267KB%20(273704B)%20native%20alloc%3D1553KB%20(1590696B)%20free%3D3MB%20(3652184B)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EE%20486%20system%20art%20DexFile_getDexOptNeeded%20file%20'%2Fsystem%2Fframework%2Forg.apache.http.legacy.jar'%20does%20not%20exist%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Library%20not%20found%3A%20%2Fsystem%2Fframework%2Forg.apache.http.legacy.jar%3CBR%20%2F%3EW%20556%20dex2oat%20type%3D1400%20audit(0.0%3A20)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20556%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20556%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20556%20dex2oat%20dex2oat%20took%20220.816ms%20(threads%3A%204)%20arena%20alloc%3D300KB%20(308168B)%20java%20alloc%3D80KB%20(82832B)%20native%20alloc%3D977KB%20(1001016B)%20free%3D2MB%20(2669000B)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20561%20dex2oat%20type%3D1400%20audit(0.0%3A21)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20561%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20561%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20561%20dex2oat%20dex2oat%20took%20218.184ms%20(threads%3A%204)%20arena%20alloc%3D84KB%20(86488B)%20java%20alloc%3D51KB%20(53192B)%20native%20alloc%3D925KB%20(948176B)%20free%3D1634KB%20(1673264B)%3CBR%20%2F%3ED%20486%20system%20PackageManager%20No%20files%20in%20app%20dir%20%2Fvendor%2Foverlay%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Failed%20to%20parse%20%2Fsystem%2Fframework%2Farm%3A%20Missing%20base%20APK%20in%20%2Fsystem%2Fframework%2Farm%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fframework%2Fframework-res.apk%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FBackupRestoreConfirmation%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FBleClient%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FBleServerEmulator%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FBlockedNumberProvider%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20New%20shared%20user%20android.uid.shared%3A%20id%3D10003%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FCalendarProvider%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20New%20shared%20user%20android.uid.calendar%3A%20id%3D10004%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FCallLogBackup%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FCarrierConfig%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FCellBroadcastReceiver%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20PackageParser%20No%20actions%20in%20intent%20filter%20at%20%2Fsystem%2Fpriv-app%2FContacts%2FContacts.apk%20Binary%20XML%20file%20line%20%23409%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FContacts%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FContactsProvider%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FCtsShimPrivPrebuilt%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FDefaultContainerService%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20PackageParser%20No%20actions%20in%20intent%20filter%20at%20%2Fsystem%2Fpriv-app%2FDialer%2FDialer.apk%20Binary%20XML%20file%20line%20%23186%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FDialer%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FDocumentsUI%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FDownloadProvider%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20New%20shared%20user%20android.media%3A%20id%3D10012%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Permission%20android.permission.DOWNLOAD_WITHOUT_NOTIFICATION%20from%20package%20com.android.providers.downloads%20in%20an%20unknown%20group%20android.permission-group.NETWORK%3CBR%20%2F%3EW%20486%20system%20art%20Suspending%20all%20threads%20took%3A%2022.232ms%3CBR%20%2F%3EI%20486%20system%20art%20Background%20partial%20concurrent%20mark%20sweep%20GC%20freed%209866(786KB)%20AllocSpace%20objects%2C%2014(864KB)%20LOS%20objects%2C%2033%25%20free%2C%202MB%2F3MB%2C%20paused%2023.995ms%20total%2055.415ms%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FEmergencyInfo%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20New%20shared%20user%20com.android.emergency.uid%3A%20id%3D10013%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FExtServices%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FExternalStorageProvider%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FFusedLocation%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FInputDevices%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FLauncher2%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Permission%20com.android.launcher.permission.PRELOAD_WORKSPACE%20from%20package%20com.android.launcher%20in%20an%20unknown%20group%20android.permission-group.SYSTEM_TOOLS%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Permission%20com.android.launcher.permission.INSTALL_SHORTCUT%20from%20package%20com.android.launcher%20in%20an%20unknown%20group%20android.permission-group.SYSTEM_TOOLS%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Permission%20com.android.launcher.permission.UNINSTALL_SHORTCUT%20from%20package%20com.android.launcher%20in%20an%20unknown%20group%20android.permission-group.SYSTEM_TOOLS%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Permission%20com.android.launcher.permission.READ_SETTINGS%20from%20package%20com.android.launcher%20in%20an%20unknown%20group%20android.permission-group.SYSTEM_TOOLS%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Permission%20com.android.launcher.permission.WRITE_SETTINGS%20from%20package%20com.android.launcher%20in%20an%20unknown%20group%20android.permission-group.SYSTEM_TOOLS%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FManagedProvisioning%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FMediaProvider%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FMmsService%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FMtpDocumentsProvider%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FMusicFX%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FOneTimeInitializer%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FPackageInstaller%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FProvision%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FProxyHandler%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20PackageParser%20Ignoring%20duplicate%20uses-permissions%2Fuses-permissions-sdk-m%3A%20android.permission.USE_CREDENTIALS%20in%20package%3A%20com.android.settings%20at%3A%20Binary%20XML%20file%20line%20%2353%3CBR%20%2F%3EW%20486%20system%20PackageParser%20Ignoring%20duplicate%20uses-permissions%2Fuses-permissions-sdk-m%3A%20android.permission.READ_SYNC_SETTINGS%20in%20package%3A%20com.android.settings%20at%3A%20Binary%20XML%20file%20line%20%2358%3CBR%20%2F%3EW%20486%20system%20PackageParser%20Ignoring%20duplicate%20uses-permissions%2Fuses-permissions-sdk-m%3A%20android.permission.WRITE_SYNC_SETTINGS%20in%20package%3A%20com.android.settings%20at%3A%20Binary%20XML%20file%20line%20%2359%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FSettings%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FSettingsProvider%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FSharedStorageBackup%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20PackageParser%20Ignoring%20duplicate%20uses-permissions%2Fuses-permissions-sdk-m%3A%20android.permission.INSTALL_GRANT_RUNTIME_PERMISSIONS%20in%20package%3A%20com.android.shell%20at%3A%20Binary%20XML%20file%20line%20%23103%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FShell%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FStatementService%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FStorageManager%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20PackageParser%20Ignoring%20duplicate%20uses-permissions%2Fuses-permissions-sdk-m%3A%20android.permission.CONFIGURE_WIFI_DISPLAY%20in%20package%3A%20com.android.systemui%20at%3A%20Binary%20XML%20file%20line%20%23123%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FSystemUI%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20New%20shared%20user%20android.uid.systemui%3A%20id%3D10026%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FTeleService%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FTelecom%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FTelephonyProvider%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FVpnDialogs%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fpriv-app%2FWallpaperCropper%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FA2dpSinkApp%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FBasicDreams%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20PackageParser%20Ignoring%20duplicate%20uses-permissions%2Fuses-permissions-sdk-m%3A%20android.permission.READ_CONTACTS%20in%20package%3A%20com.android.bluetooth%20at%3A%20Binary%20XML%20file%20line%20%2361%3CBR%20%2F%3EW%20486%20system%20PackageParser%20No%20actions%20in%20intent%20filter%20at%20%2Fsystem%2Fapp%2FBluetooth%2FBluetooth.apk%20Binary%20XML%20file%20line%20%23223%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FBluetooth%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FBluetoothMidiService%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FBookmarkProvider%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FBrowser2%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FCactusPlayer%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FCalendar%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Non-privileged%20app%3B%20cap%20priority%20to%200%3B%20package%3A%20com.android.calendar%20activity%3A%20com.android.calendar.GoogleCalendarUriIntentFilter%20origPrio%3A%2050%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FCamera2%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FCaptivePortalLogin%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FCertInstaller%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FCtsShimPrebuilt%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Non-privileged%20app%3B%20cap%20priority%20to%200%3B%20package%3A%20com.android.cts.ctsshim%20activity%3A%20com.android.cts.ctsshim.InstallPriority%20origPrio%3A%20100%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Non-privileged%20app%3B%20cap%20priority%20to%200%3B%20package%3A%20com.android.cts.ctsshim%20activity%3A%20com.android.cts.ctsshim.InstallPriority%20origPrio%3A%20100%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Non-privileged%20app%3B%20cap%20priority%20to%200%3B%20package%3A%20com.android.cts.ctsshim%20activity%3A%20com.android.cts.ctsshim.InstallPriority%20origPrio%3A%20100%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Non-privileged%20app%3B%20cap%20priority%20to%200%3B%20package%3A%20com.android.cts.ctsshim%20activity%3A%20com.android.cts.ctsshim.InstallPriority%20origPrio%3A%20100%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Non-privileged%20app%3B%20cap%20priority%20to%200%3B%20package%3A%20com.android.cts.ctsshim%20activity%3A%20com.android.cts.ctsshim.InstallPriority%20origPrio%3A%20100%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FCubeLiveWallpapers%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FDeskClock%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FDownloadProviderUi%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FEasterEgg%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20PackageParser%20Ignoring%20duplicate%20uses-permissions%2Fuses-permissions-sdk-m%3A%20android.permission.WRITE_CONTACTS%20in%20package%3A%20com.android.email%20at%3A%20Binary%20XML%20file%20line%20%2340%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FEmail%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FExactCalculator%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FExtShared%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FFSLOta%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20486%20system%20PackageParser%20Unknown%20element%20under%20%3CAPPLICATION%3E%3A%20permission%20at%20%2Fsystem%2Fapp%2FGallery2%2FGallery2.apk%20Binary%20XML%20file%20line%20%23253%3CBR%20%2F%3EW%20486%20system%20PackageParser%20Unknown%20element%20under%20%3CAPPLICATION%3E%3A%20permission%20at%20%2Fsystem%2Fapp%2FGallery2%2FGallery2.apk%20Binary%20XML%20file%20line%20%23256%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FGallery2%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FHTMLViewer%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FKeyChain%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FLatinIME%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FLiveWallpapersPicker%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FMusic%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FPacProcessor%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FPicoTts%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FPrintRecommendationService%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FPrintSpooler%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FQuickSearchBox%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FSoundRecorder%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FUserDictionaryProvider%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FWallpaperBackup%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2FWfdSink%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2Fethernet%20changed%3B%20collecting%20certs%3CBR%20%2F%3EI%20486%20system%20PackageManager%20%2Fsystem%2Fapp%2Fwebview%20changed%3B%20collecting%20certs%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20PackageManager%20No%20files%20in%20app%20dir%20%2Fsystem%2Fvendor%2Fapp%3CBR%20%2F%3ED%20486%20system%20PackageManager%20No%20files%20in%20app%20dir%20%2Foem%2Fapp%3CBR%20%2F%3ED%20486%20system%20PackageManager%20No%20files%20in%20app%20dir%20%2Fdata%2Fapp%3CBR%20%2F%3ED%20486%20system%20PackageManager%20No%20files%20in%20app%20dir%20%2Fdata%2Fapp-private%3CBR%20%2F%3ED%20486%20system%20PackageManager%20No%20files%20in%20app%20dir%20%2Fdata%2Fapp-ephemeral%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Protected%20action%3B%20cap%20priority%20to%200%3B%20package%3A%20com.android.cts.priv.ctsshim%20activity%3A%20com.android.cts.priv.ctsshim.InstallPriority%20origPrio%3A%20100%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Protected%20action%3B%20cap%20priority%20to%200%3B%20package%3A%20com.android.cts.priv.ctsshim%20activity%3A%20com.android.cts.priv.ctsshim.InstallPriority%20origPrio%3A%20100%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Protected%20action%3B%20cap%20priority%20to%200%3B%20package%3A%20com.android.cts.priv.ctsshim%20activity%3A%20com.android.cts.priv.ctsshim.InstallPriority%20origPrio%3A%20100%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Protected%20action%3B%20cap%20priority%20to%200%3B%20package%3A%20com.android.cts.priv.ctsshim%20activity%3A%20com.android.cts.priv.ctsshim.InstallPriority%20origPrio%3A%20100%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Package%20com.android.gallery3d%20desires%20unavailable%20shared%20library%20com.google.android.media.effects%3B%20ignoring!%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Package%20com.android.gallery3d%20desires%20unavailable%20shared%20library%20com.google.android.media.effects%3B%20ignoring!%3CBR%20%2F%3EI%20486%20system%20PackageManager%20Adjusting%20ABI%20for%20com.android.providers.media%20to%20armeabi-v7a%20(requirer%3Dcom.android.mtp%2C%20scannedPackage%3Dnull)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20Adjusting%20ABI%20for%20com.android.providers.downloads.ui%20to%20armeabi-v7a%20(requirer%3Dcom.android.mtp%2C%20scannedPackage%3Dnull)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20Adjusting%20ABI%20for%20com.android.providers.downloads%20to%20armeabi-v7a%20(requirer%3Dcom.android.mtp%2C%20scannedPackage%3Dnull)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20Adjusting%20ABI%20for%20com.fsl.android.ota%20to%20armeabi-v7a%20(requirer%3Dandroid%2C%20scannedPackage%3Dnull)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20Adjusting%20ABI%20for%20com.freescale.wfdsink%20to%20armeabi-v7a%20(requirer%3Dandroid%2C%20scannedPackage%3Dnull)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20Adjusting%20ABI%20for%20com.android.location.fused%20to%20armeabi-v7a%20(requirer%3Dandroid%2C%20scannedPackage%3Dnull)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20Adjusting%20ABI%20for%20com.android.providers.settings%20to%20armeabi-v7a%20(requirer%3Dandroid%2C%20scannedPackage%3Dnull)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20Adjusting%20ABI%20for%20com.android.inputdevices%20to%20armeabi-v7a%20(requirer%3Dandroid%2C%20scannedPackage%3Dnull)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20Adjusting%20ABI%20for%20com.android.keychain%20to%20armeabi-v7a%20(requirer%3Dandroid%2C%20scannedPackage%3Dnull)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20Adjusting%20ABI%20for%20com.android.settings%20to%20armeabi-v7a%20(requirer%3Dandroid%2C%20scannedPackage%3Dnull)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20Adjusting%20ABI%20for%20com.android.wallpaperbackup%20to%20armeabi-v7a%20(requirer%3Dandroid%2C%20scannedPackage%3Dnull)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20Adjusting%20ABI%20for%20com.android.server.telecom%20to%20armeabi-v7a%20(requirer%3Dandroid%2C%20scannedPackage%3Dnull)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20Adjusting%20ABI%20for%20com.fsl.ethernet%20to%20armeabi-v7a%20(requirer%3Dandroid%2C%20scannedPackage%3Dnull)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20Adjusting%20ABI%20for%20com.freescale.a2dpsinkapp%20to%20armeabi-v7a%20(requirer%3Dandroid%2C%20scannedPackage%3Dnull)%3CBR%20%2F%3EI%20486%20system%20PackageManager%20Time%20to%20scan%20packages%3A%2012.287%20seconds%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Unknown%20permission%20com.google.android.googleapps.permission.GOOGLE_AUTH%20in%20package%20com.android.providers.calendar%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Unknown%20permission%20com.google.android.googleapps.permission.GOOGLE_AUTH.cl%20in%20package%20com.android.providers.calendar%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Not%20granting%20permission%20android.permission.GLOBAL_SEARCH%20to%20package%20com.android.quicksearchbox%20(protectionLevel%3D18%20flags%3D0x3808be45)%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Not%20granting%20permission%20android.permission.BIND_WALLPAPER%20to%20package%20com.android.camera2%20(protectionLevel%3D18%20flags%3D0x3058bc45)%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Unknown%20permission%20com.google.android.googleapps.permission.GOOGLE_AUTH.mail%20in%20package%20com.android.calendar%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Not%20granting%20permission%20android.permission.WRITE_MEDIA_STORAGE%20to%20package%20com.android.gallery3d%20(protectionLevel%3D18%20flags%3D0x3858bc45)%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Unknown%20permission%20com.google.android.permission.INSTALL_WEARABLE_PACKAGES%20in%20package%20com.android.packageinstaller%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Not%20granting%20permission%20android.permission.DELETE_PACKAGES%20to%20package%20com.svox.pico%20(protectionLevel%3D18%20flags%3D0x3808be45)%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Unknown%20permission%20android.permission.RUN_INSTRUMENTATION%20in%20package%20org.chromium.webview_shell%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Unknown%20permission%20com.google.android.googleapps.permission.GOOGLE_AUTH%20in%20package%20com.android.settings%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Unknown%20permission%20com.android.smspush.WAPPUSH_MANAGER_BIND%20in%20package%20com.android.phone%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Unknown%20permission%20android.permission.ACCESS_ALL_EXTERNAL_STORAGE%20in%20package%20com.freescale.wfdsink%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Unknown%20permission%20com.google.android.gallery3d.permission.GALLERY_PROVIDER%20in%20package%20com.android.bluetooth%3CBR%20%2F%3EV%20486%20system%20PackageManager%20reconcileAppsData%20for%20null%20u0%200x3%3CBR%20%2F%3EI%20232%20%2Fsystem%2Fbin%2Finstalld%20SELinux%20SELinux%3A%20Loaded%20file_contexts%20contexts%20from%20%2Ffile_contexts.bin.%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.cts.priv.ctsshim%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.cts.priv.ctsshim%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.freescale.bleserver%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.freescale.bleserver%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.example.android.livecubes%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.example.android.livecubes%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aradio_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.android.providers.telephony%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aradio_data_file%3As0%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.providers.telephony%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Requested%20default%20storage%20%2Fdata%2Fuser_de%2F0%2Fcom.android.providers.telephony%20is%20not%20active%3B%20migrating%20from%20%2Fdata%2Fdata%2Fcom.android.providers.telephony%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aradio_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.android.providers.telephony%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.fsl.ethernet%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.fsl.ethernet%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.providers.calendar%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.providers.calendar%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.providers.media%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.providers.media%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.wallpapercropper%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.wallpapercropper%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.launcher%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.launcher%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.documentsui%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.documentsui%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.externalstorage%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.externalstorage%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.htmlviewer%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.htmlviewer%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.quicksearchbox%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.quicksearchbox%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aradio_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.android.mms.service%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aradio_data_file%3As0%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.mms.service%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.providers.downloads%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.providers.downloads%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.soundrecorder%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.soundrecorder%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.defcontainer%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.defcontainer%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Requested%20default%20storage%20%2Fdata%2Fuser_de%2F0%2Fcom.android.defcontainer%20is%20not%20active%3B%20migrating%20from%20%2Fdata%2Fdata%2Fcom.android.defcontainer%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.defcontainer%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.providers.downloads.ui%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.providers.downloads.ui%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.pacprocessor%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.pacprocessor%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.certinstaller%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.certinstaller%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.carrierconfig%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.carrierconfig%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fdata%2Fandroid%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fuser_de%2F0%2Fandroid%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Requested%20default%20storage%20%2Fdata%2Fuser_de%2F0%2Fandroid%20is%20not%20active%3B%20migrating%20from%20%2Fdata%2Fdata%2Fandroid%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fdata%2Fandroid%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.contacts%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.contacts%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.camera2%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.camera2%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.egg%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.egg%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.mtp%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.mtp%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.backupconfirm%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.backupconfirm%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.provision%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.provision%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.statementservice%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.statementservice%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.calendar%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.calendar%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.android.providers.settings%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.providers.settings%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Requested%20default%20storage%20%2Fdata%2Fuser_de%2F0%2Fcom.android.providers.settings%20is%20not%20active%3B%20migrating%20from%20%2Fdata%2Fdata%2Fcom.android.providers.settings%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.android.providers.settings%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.sharedstoragebackup%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.sharedstoragebackup%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.printspooler%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.printspooler%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.dreams.basic%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.dreams.basic%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.webview%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.webview%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.android.inputdevices%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.inputdevices%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Requested%20default%20storage%20%2Fdata%2Fuser_de%2F0%2Fcom.android.inputdevices%20is%20not%20active%3B%20migrating%20from%20%2Fdata%2Fdata%2Fcom.android.inputdevices%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.android.inputdevices%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.musicfx%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.musicfx%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.cellbroadcastreceiver%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.cellbroadcastreceiver%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Requested%20default%20storage%20%2Fdata%2Fuser_de%2F0%2Fcom.android.cellbroadcastreceiver%20is%20not%20active%3B%20migrating%20from%20%2Fdata%2Fdata%2Fcom.android.cellbroadcastreceiver%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.cellbroadcastreceiver%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fandroid.ext.shared%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fandroid.ext.shared%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Requested%20default%20storage%20%2Fdata%2Fuser_de%2F0%2Fandroid.ext.shared%20is%20not%20active%3B%20migrating%20from%20%2Fdata%2Fdata%2Fandroid.ext.shared%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fandroid.ext.shared%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.onetimeinitializer%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.onetimeinitializer%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.android.server.telecom%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.server.telecom%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Requested%20default%20storage%20%2Fdata%2Fuser_de%2F0%2Fcom.android.server.telecom%20is%20not%20active%3B%20migrating%20from%20%2Fdata%2Fdata%2Fcom.android.server.telecom%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.android.server.telecom%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.android.keychain%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.keychain%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.printservice.recommendation%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.printservice.recommendation%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.dialer%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.dialer%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.gallery3d%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.gallery3d%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fandroid.ext.services%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fandroid.ext.services%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Requested%20default%20storage%20%2Fdata%2Fuser_de%2F0%2Fandroid.ext.services%20is%20not%20active%3B%20migrating%20from%20%2Fdata%2Fdata%2Fandroid.ext.services%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fandroid.ext.services%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.calllogbackup%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.calllogbackup%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.packageinstaller%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.packageinstaller%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Requested%20default%20storage%20%2Fdata%2Fuser_de%2F0%2Fcom.android.packageinstaller%20is%20not%20active%3B%20migrating%20from%20%2Fdata%2Fdata%2Fcom.android.packageinstaller%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.packageinstaller%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.svox.pico%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.svox.pico%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.proxyhandler%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.proxyhandler%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Requested%20default%20storage%20%2Fdata%2Fuser_de%2F0%2Fcom.android.proxyhandler%20is%20not%20active%3B%20migrating%20from%20%2Fdata%2Fdata%2Fcom.android.proxyhandler%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.proxyhandler%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.inputmethod.latin%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.inputmethod.latin%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Requested%20default%20storage%20%2Fdata%2Fuser_de%2F0%2Fcom.android.inputmethod.latin%20is%20not%20active%3B%20migrating%20from%20%2Fdata%2Fdata%2Fcom.android.inputmethod.latin%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.inputmethod.latin%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Forg.chromium.webview_shell%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Forg.chromium.webview_shell%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.fsl.android.ota%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.fsl.android.ota%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.managedprovisioning%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.managedprovisioning%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.wallpaper.livepicker%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.wallpaper.livepicker%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.storagemanager%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.storagemanager%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.bookmarkprovider%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.bookmarkprovider%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.android.settings%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.settings%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Requested%20default%20storage%20%2Fdata%2Fuser_de%2F0%2Fcom.android.settings%20is%20not%20active%3B%20migrating%20from%20%2Fdata%2Fdata%2Fcom.android.settings%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.android.settings%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.freescale.a2dpsinkapp%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.freescale.a2dpsinkapp%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.calculator2%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.calculator2%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.freescale.cactusplayer%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.freescale.cactusplayer%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.cts.ctsshim%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.cts.ctsshim%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.vpndialogs%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.vpndialogs%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.email%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.email%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.music%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.music%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aradio_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.android.phone%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aradio_data_file%3As0%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.phone%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Requested%20default%20storage%20%2Fdata%2Fuser_de%2F0%2Fcom.android.phone%20is%20not%20active%3B%20migrating%20from%20%2Fdata%2Fdata%2Fcom.android.phone%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aradio_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.android.phone%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Ashell_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.android.shell%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Ashell_data_file%3As0%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.shell%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Requested%20default%20storage%20%2Fdata%2Fuser_de%2F0%2Fcom.android.shell%20is%20not%20active%3B%20migrating%20from%20%2Fdata%2Fdata%2Fcom.android.shell%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Ashell_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.android.shell%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.android.wallpaperbackup%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.wallpaperbackup%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.providers.blockednumber%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.providers.blockednumber%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Requested%20default%20storage%20%2Fdata%2Fuser_de%2F0%2Fcom.android.providers.blockednumber%20is%20not%20active%3B%20migrating%20from%20%2Fdata%2Fdata%2Fcom.android.providers.blockednumber%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.providers.blockednumber%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.providers.userdictionary%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.providers.userdictionary%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.emergency%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.emergency%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Requested%20default%20storage%20%2Fdata%2Fuser_de%2F0%2Fcom.android.emergency%20is%20not%20active%3B%20migrating%20from%20%2Fdata%2Fdata%2Fcom.android.emergency%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.emergency%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.android.location.fused%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.location.fused%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Requested%20default%20storage%20%2Fdata%2Fuser_de%2F0%2Fcom.android.location.fused%20is%20not%20active%3B%20migrating%20from%20%2Fdata%2Fdata%2Fcom.android.location.fused%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.android.location.fused%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.deskclock%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.deskclock%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.systemui%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.systemui%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Requested%20default%20storage%20%2Fdata%2Fuser_de%2F0%2Fcom.android.systemui%20is%20not%20active%3B%20migrating%20from%20%2Fdata%2Fdata%2Fcom.android.systemui%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.systemui%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.freescale.wfdsink%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Asystem_app_data_file%3As0%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.freescale.wfdsink%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.bluetoothmidiservice%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.bluetoothmidiservice%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.freescale.bleclient%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.freescale.bleclient%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Abluetooth_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.android.bluetooth%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Abluetooth_data_file%3As0%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.bluetooth%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EW%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Requested%20default%20storage%20%2Fdata%2Fuser_de%2F0%2Fcom.android.bluetooth%20is%20not%20active%3B%20migrating%20from%20%2Fdata%2Fdata%2Fcom.android.bluetooth%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Abluetooth_data_file%3As0%20at%20%2Fdata%2Fdata%2Fcom.android.bluetooth%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.providers.contacts%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.providers.contacts%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fdata%2Fcom.android.captiveportallogin%3B%20running%20recursive%20restorecon%3CBR%20%2F%3ED%20232%20%2Fsystem%2Fbin%2Finstalld%20installd%20Detected%20label%20change%20from%20u%3Aobject_r%3Asystem_data_file%3As0%20to%20u%3Aobject_r%3Aapp_data_file%3As0%3Ac512%2Cc768%20at%20%2Fdata%2Fuser_de%2F0%2Fcom.android.captiveportallogin%3B%20running%20recursive%20restorecon%3CBR%20%2F%3EV%20486%20system%20PackageManager%20reconcileAppsData%20finished%2080%20packages%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FTelephonyProvider%2FTelephonyProvider.apk%20pkg%3Dcom.android.providers.telephony%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dspeed%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20566%20dex2oat%20type%3D1400%20audit(0.0%3A22)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20566%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20566%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20566%20dex2oat%20dex2oat%20took%20833.819ms%20(threads%3A%204)%20arena%20alloc%3D4MB%20(5228488B)%20java%20alloc%3D225KB%20(231128B)%20native%20alloc%3D1673KB%20(1713864B)%20free%3D7MB%20(8247608B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FMmsService%2FMmsService.apk%20pkg%3Dcom.android.mms.service%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dspeed%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20571%20dex2oat%20type%3D1400%20audit(0.0%3A23)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20571%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20571%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20571%20dex2oat%20dex2oat%20took%20606.125ms%20(threads%3A%204)%20arena%20alloc%3D2MB%20(2423280B)%20java%20alloc%3D206KB%20(211608B)%20native%20alloc%3D1334KB%20(1366320B)%20free%3D4MB%20(4925136B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FDefaultContainerService%2FDefaultContainerService.apk%20pkg%3Dcom.android.defcontainer%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dspeed%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20576%20dex2oat%20type%3D1400%20audit(0.0%3A24)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20576%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20576%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20576%20dex2oat%20dex2oat%20took%20267.198ms%20(threads%3A%204)%20arena%20alloc%3D530KB%20(543008B)%20java%20alloc%3D96KB%20(99256B)%20native%20alloc%3D1010KB%20(1034784B)%20free%3D2MB%20(2110944B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FSettingsProvider%2FSettingsProvider.apk%20pkg%3Dcom.android.providers.settings%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dspeed%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20581%20dex2oat%20type%3D1400%20audit(0.0%3A25)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20581%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20581%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20581%20dex2oat%20Compilation%20of%20void%20com.android.providers.settings.DatabaseHelper.onUpgrade(android.database.sqlite.SQLiteDatabase%2C%20int%2C%20int)%20took%20237.820ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20581%20dex2oat%20dex2oat%20took%20724.957ms%20(threads%3A%204)%20arena%20alloc%3D6MB%20(6915736B)%20java%20alloc%3D195KB%20(200680B)%20native%20alloc%3D1714KB%20(1755240B)%20free%3D9MB%20(10303384B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FInputDevices%2FInputDevices.apk%20pkg%3Dcom.android.inputdevices%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dspeed%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20586%20dex2oat%20type%3D1400%20audit(0.0%3A26)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20586%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20586%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20586%20dex2oat%20dex2oat%20took%20219.996ms%20(threads%3A%204)%20arena%20alloc%3D10KB%20(10840B)%20java%20alloc%3D32KB%20(32784B)%20native%20alloc%3D747KB%20(765296B)%20free%3D1300KB%20(1331856B)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FExtShared%2FExtShared.apk%20pkg%3Dandroid.ext.shared%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dspeed%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20591%20dex2oat%20type%3D1400%20audit(0.0%3A27)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20591%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20591%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20591%20dex2oat%20dex2oat%20took%20217.334ms%20(threads%3A%204)%20arena%20alloc%3D60KB%20(61512B)%20java%20alloc%3D47KB%20(49016B)%20native%20alloc%3D774KB%20(793248B)%20free%3D1785KB%20(1828192B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FTelecom%2FTelecom.apk%20pkg%3Dcom.android.server.telecom%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dspeed%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20596%20dex2oat%20type%3D1400%20audit(0.0%3A28)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20596%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20596%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20596%20dex2oat%20dex2oat%20took%201.644s%20(threads%3A%204)%20arena%20alloc%3D1635KB%20(1674296B)%20java%20alloc%3D586KB%20(600168B)%20native%20alloc%3D2MB%20(2820968B)%20free%3D3MB%20(3470488B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FDialer%2FDialer.apk%20pkg%3Dcom.android.dialer%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dspeed%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20601%20dex2oat%20type%3D1400%20audit(0.0%3A29)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20601%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20601%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20601%20dex2oat%20Before%20Android%204.1%2C%20method%20android.graphics.PorterDuffColorFilter%20android.support.graphics.drawable.VectorDrawableCompat.updateTintFilter(android.graphics.PorterDuffColorFilter%2C%20android.content.res.ColorStateList%2C%20android.graphics.PorterDuff%24Mode)%20would%20have%20incorrectly%20overridden%20the%20package-private%20method%20in%20android.graphics.drawable.Drawable%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20601%20dex2oat%20dex2oat%20took%206.939s%20(threads%3A%204)%20arena%20alloc%3D3MB%20(3588176B)%20java%20alloc%3D3MB%20(3199504B)%20native%20alloc%3D10MB%20(11319256B)%20free%3D5MB%20(5982248B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FExtServices%2FExtServices.apk%20pkg%3Dandroid.ext.services%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dspeed%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20606%20dex2oat%20type%3D1400%20audit(0.0%3A30)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20606%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20606%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20606%20dex2oat%20dex2oat%20took%20267.083ms%20(threads%3A%204)%20arena%20alloc%3D312KB%20(320464B)%20java%20alloc%3D65KB%20(67000B)%20native%20alloc%3D1101KB%20(1128144B)%20free%3D2MB%20(2541872B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FPackageInstaller%2FPackageInstaller.apk%20pkg%3Dcom.android.packageinstaller%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dspeed%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20611%20dex2oat%20type%3D1400%20audit(0.0%3A31)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20611%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20611%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20611%20dex2oat%20Before%20Android%204.1%2C%20method%20android.graphics.PorterDuffColorFilter%20android.support.graphics.drawable.VectorDrawableCompat.updateTintFilter(android.graphics.PorterDuffColorFilter%2C%20android.content.res.ColorStateList%2C%20android.graphics.PorterDuff%24Mode)%20would%20have%20incorrectly%20overridden%20the%20package-private%20method%20in%20android.graphics.drawable.Drawable%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20611%20dex2oat%20Before%20Android%204.1%2C%20method%20int%20android.support.v7.widget.ListViewCompat.lookForSelectablePosition(int%2C%20boolean)%20would%20have%20incorrectly%20overridden%20the%20package-private%20method%20in%20android.widget.ListView%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20611%20dex2oat%20dex2oat%20took%203.533s%20(threads%3A%204)%20arena%20alloc%3D3MB%20(4100064B)%20java%20alloc%3D2MB%20(2271608B)%20native%20alloc%3D5MB%20(6001360B)%20free%3D5MB%20(6057264B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FProxyHandler%2FProxyHandler.apk%20pkg%3Dcom.android.proxyhandler%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dspeed%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20616%20dex2oat%20type%3D1400%20audit(0.0%3A32)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20616%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20616%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20616%20dex2oat%20dex2oat%20took%20288.031ms%20(threads%3A%204)%20arena%20alloc%3D1251KB%20(1281104B)%20java%20alloc%3D107KB%20(109928B)%20native%20alloc%3D1161KB%20(1189064B)%20free%3D2MB%20(3005240B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FLatinIME%2FLatinIME.apk%20pkg%3Dcom.android.inputmethod.latin%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dspeed%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20621%20dex2oat%20type%3D1400%20audit(0.0%3A33)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20621%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20621%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20621%20dex2oat%20dex2oat%20took%202.160s%20(threads%3A%204)%20arena%20alloc%3D1658KB%20(1698248B)%20java%20alloc%3D937KB%20(960016B)%20native%20alloc%3D3MB%20(3650272B)%20free%3D4MB%20(4214048B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FFSLOta%2FFSLOta.apk%20pkg%3Dcom.fsl.android.ota%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dspeed%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20626%20dex2oat%20type%3D1400%20audit(0.0%3A34)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20626%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20626%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20626%20dex2oat%20dex2oat%20took%20299.013ms%20(threads%3A%204)%20arena%20alloc%3D1621KB%20(1659992B)%20java%20alloc%3D101KB%20(103456B)%20native%20alloc%3D1027KB%20(1051752B)%20free%3D3MB%20(3666840B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FSettings%2FSettings.apk%20pkg%3Dcom.android.settings%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dspeed%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20631%20dex2oat%20type%3D1400%20audit(0.0%3A35)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20631%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20631%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20631%20dex2oat%20Before%20Android%204.1%2C%20method%20android.graphics.PorterDuffColorFilter%20android.support.graphics.drawable.VectorDrawableCompat.updateTintFilter(android.graphics.PorterDuffColorFilter%2C%20android.content.res.ColorStateList%2C%20android.graphics.PorterDuff%24Mode)%20would%20have%20incorrectly%20overridden%20the%20package-private%20method%20in%20android.graphics.drawable.Drawable%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20631%20dex2oat%20Before%20Android%204.1%2C%20method%20int%20android.support.v7.widget.ListViewCompat.lookForSelectablePosition(int%2C%20boolean)%20would%20have%20incorrectly%20overridden%20the%20package-private%20method%20in%20android.widget.ListView%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20631%20dex2oat%20Compilation%20of%20boolean%20com.android.settings.applications.RunningState.update(android.content.Context%2C%20android.app.ActivityManager)%20took%20125.030ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20631%20dex2oat%20Compilation%20of%20java.util.List%20com.android.settings.notification.NotificationStation.loadNotifications()%20took%20124.724ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20631%20dex2oat%20dex2oat%20took%207.693s%20(threads%3A%204)%20arena%20alloc%3D3MB%20(4187832B)%20java%20alloc%3D5MB%20(5498728B)%20native%20alloc%3D12MB%20(12723144B)%20free%3D6MB%20(6675512B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FCactusPlayer%2FCactusPlayer.apk%20pkg%3Dcom.freescale.cactusplayer%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dspeed%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20636%20dex2oat%20type%3D1400%20audit(0.0%3A36)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20636%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20636%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20636%20dex2oat%20dex2oat%20took%20488.533ms%20(threads%3A%204)%20arena%20alloc%3D1409KB%20(1443448B)%20java%20alloc%3D246KB%20(252120B)%20native%20alloc%3D1326KB%20(1358560B)%20free%3D3MB%20(3360032B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FTeleService%2FTeleService.apk%20pkg%3Dcom.android.phone%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dspeed%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20641%20dex2oat%20type%3D1400%20audit(0.0%3A37)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20641%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20641%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20641%20dex2oat%20Compilation%20of%20void%20com.android.phone.PhoneInterfaceManager%24MainThreadHandler.handleMessage(android.os.Message)%20took%20265.487ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20641%20dex2oat%20dex2oat%20took%203.652s%20(threads%3A%204)%20arena%20alloc%3D6MB%20(7090224B)%20java%20alloc%3D1370KB%20(1403728B)%20native%20alloc%3D5MB%20(5957408B)%20free%3D8MB%20(9246944B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FShell%2FShell.apk%20pkg%3Dcom.android.shell%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dspeed%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20646%20dex2oat%20type%3D1400%20audit(0.0%3A38)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20646%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20646%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20646%20dex2oat%20dex2oat%20took%20634.254ms%20(threads%3A%204)%20arena%20alloc%3D1743KB%20(1785808B)%20java%20alloc%3D260KB%20(266784B)%20native%20alloc%3D1450KB%20(1485560B)%20free%3D3MB%20(3757320B)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FFusedLocation%2FFusedLocation.apk%20pkg%3Dcom.android.location.fused%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dspeed%20oatDir%20%3D%20null%20sharedLibraries%3D%2Fsystem%2Fframework%2Fcom.android.location.provider.jar%3CBR%20%2F%3EW%20651%20dex2oat%20type%3D1400%20audit(0.0%3A39)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20651%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20651%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20651%20dex2oat%20dex2oat%20took%20267.018ms%20(threads%3A%204)%20arena%20alloc%3D296KB%20(304016B)%20java%20alloc%3D120KB%20(123800B)%20native%20alloc%3D1148KB%20(1176384B)%20free%3D1923KB%20(1969344B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FSystemUI%2FSystemUI.apk%20pkg%3Dcom.android.systemui%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dspeed%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20657%20dex2oat%20type%3D1400%20audit(0.0%3A40)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20657%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20657%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20657%20dex2oat%20Before%20Android%204.1%2C%20method%20android.graphics.PorterDuffColorFilter%20android.support.graphics.drawable.VectorDrawableCompat.updateTintFilter(android.graphics.PorterDuffColorFilter%2C%20android.content.res.ColorStateList%2C%20android.graphics.PorterDuff%24Mode)%20would%20have%20incorrectly%20overridden%20the%20package-private%20method%20in%20android.graphics.drawable.Drawable%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20657%20dex2oat%20Before%20Android%204.1%2C%20method%20int%20android.support.v7.widget.ListViewCompat.lookForSelectablePosition(int%2C%20boolean)%20would%20have%20incorrectly%20overridden%20the%20package-private%20method%20in%20android.widget.ListView%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20657%20dex2oat%20dex2oat%20took%209.120s%20(threads%3A%204)%20arena%20alloc%3D2MB%20(2235464B)%20java%20alloc%3D4MB%20(5224520B)%20native%20alloc%3D12MB%20(13187760B)%20free%3D4MB%20(5162320B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FWfdSink%2FWfdSink.apk%20pkg%3Dcom.freescale.wfdsink%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dspeed%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20665%20dex2oat%20type%3D1400%20audit(0.0%3A41)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20665%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dspeed%3CBR%20%2F%3EE%20665%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20665%20dex2oat%20dex2oat%20took%20409.145ms%20(threads%3A%204)%20arena%20alloc%3D811KB%20(830856B)%20java%20alloc%3D245KB%20(251880B)%20native%20alloc%3D1281KB%20(1311768B)%20free%3D2MB%20(2882536B)%3CBR%20%2F%3EE%20486%20system%20PackageManager%20There%20should%20probably%20be%20a%20verifier%2C%20but%2C%20none%20were%20found%3CBR%20%2F%3ED%20486%20system%20PackageManager%20Ephemeral%20resolver%20NOT%20found%3B%20no%20matching%20intent%20filters%3CBR%20%2F%3EI%20486%20system%20PackageManager%20Ephemeral%20deactivated%3B%20missing%20resolver%20and%20installer%3CBR%20%2F%3EI%20486%20system%20art%20Starting%20a%20blocking%20GC%20Explicit%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20main%20(486)%20at%20int%20android.net.LocalSocketImpl.readba_native(byte%5B%5D%2C%20int%2C%20int%2C%20java.io.FileDescriptor)(LocalSocketImpl.java%3A-2)%20waiters%3D0%20in%20void%20com.android.server.pm.Settings%24RuntimePermissionPersistence.writePermissionsSync(int)%20for%2041.554s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20main%20(486)%20at%20int%20android.net.LocalSocketImpl.readba_native(byte%5B%5D%2C%20int%2C%20int%2C%20java.io.FileDescriptor)(LocalSocketImpl.java%3A-2)%20waiters%3D1%20in%20void%20com.android.server.pm.PackageManagerService%24PackageHandler.doHandleMessage(android.os.Message)%20for%2032.766s%3CBR%20%2F%3EI%20486%20system%20art%20Explicit%20concurrent%20mark%20sweep%20GC%20freed%2018453(1021KB)%20AllocSpace%20objects%2C%205(100KB)%20LOS%20objects%2C%2033%25%20free%2C%203MB%2F4MB%2C%20paused%20916us%20total%2050.960ms%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartOtaDexOptService%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartUserManagerService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.pm.UserManagerService%24LifeCycle%3CBR%20%2F%3EI%20219%20%2Fsystem%2Fbin%2Flmkd%20lowmemorykiller%20ActivityManager%20connected%3CBR%20%2F%3ED%20486%20system%20SensorService%20nuSensorService%20starting...%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EE%20486%20system%20couldn't%20find%20'FreescaleAccelerometer'%20input%20device%3CBR%20%2F%3EE%20486%20system%20Couldn't%20open%20%2Fdev%2Fmma8x5x%20(No%20such%20file%20or%20directory)%3CBR%20%2F%3EE%20486%20system%20Can%60t%20find%20the%20Acc%20sensor!%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EE%20486%20system%20couldn't%20find%20'eCompass'%20input%20device%3CBR%20%2F%3EE%20486%20system%20Can%60t%20find%20the%20mag%20sensor!%3CBR%20%2F%3EE%20486%20system%20SensorService%20%26gt%3B%26gt%3B%26gt%3B%26gt%3B%20WARNING%20%26lt%3B%26lt%3B%26lt%3B%20Upgrade%20sensor%20HAL%20to%20version%201_3%3CBR%20%2F%3ED%20486%20system%20AccelSensor%20enable%200%20%2C%20handle%200%20%2CmEnabled%200%3CBR%20%2F%3ED%20486%20system%20AccelSensor%20enable%200%20%2C%20handle%201%20%2CmEnabled%200%3CBR%20%2F%3ED%20486%20system%20MagSensor%20mEnabled%200%2C%20OrientaionSensor%20mEnabled%200%3CBR%20%2F%3ED%20486%20system%20AccelSensor%20enable%200%20%2C%20handle%202%20%2CmEnabled%200%3CBR%20%2F%3ED%20486%20system%20MagSensor%20mEnabled%200%2C%20OrientaionSensor%20mEnabled%200%3CBR%20%2F%3EI%20486%20system%20SensorService%20Generated%20new%20HMAC%20key.%3CBR%20%2F%3ED%20486%20system%20SensorService%20nuSensorService%20thread%20starting...%3CBR%20%2F%3ED%20486%20system%20SensorService%20new%20thread%20SensorEventAckReceiver%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.BatteryService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.usage.UsageStatsService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.webkit.WebViewUpdateService%3CBR%20%2F%3EI%20486%20system%20SystemServer%20Reading%20configuration...%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartSchedulingPolicyService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.telecom.TelecomLoaderService%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartTelephonyRegistry%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartEntropyMixer%3CBR%20%2F%3EW%20486%20system%20EntropyMixer%20No%20existing%20entropy%20file%20--%20first%20boot%3F%3CBR%20%2F%3EI%20486%20system%20EntropyMixer%20Added%20HW%20RNG%20output%20to%20entropy%20pool%3CBR%20%2F%3EI%20486%20system%20EntropyMixer%20Writing%20entropy...%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20SystemServer%20Camera%20Service%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.camera.CameraService%3CBR%20%2F%3EI%20486%20system%20ServiceThread%20Enabled%20StrictMode%20logging%20for%20CameraService_proxy%20looper.%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartAccountManagerService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.accounts.AccountManagerService%24Lifecycle%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartContentService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.content.ContentService%24Lifecycle%3CBR%20%2F%3EI%20486%20system%20SystemServer%20InstallSystemProviders%3CBR%20%2F%3EW%20486%20system%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fpriv-app%2FSettingsProvider%2Flib%2Farm%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20SettingsState%20No%20settings%20state%20%2Fdata%2Fsystem%2Fusers%2F0%2Fsettings_system.xml%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20SettingsState%20No%20settings%20state%20%2Fdata%2Fsystem%2Fusers%2F0%2Fsettings_secure.xml%3CBR%20%2F%3ED%20486%20system%20SettingsProvider%20Generated%20and%20saved%20new%20ANDROID_ID%20%5Bb68006e854e52539%5D%20for%20user%200%3CBR%20%2F%3EI%20486%20system%20SettingsState%20No%20settings%20state%20%2Fdata%2Fsystem%2Fusers%2F0%2Fsettings_global.xml%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartVibratorService%3CBR%20%2F%3EE%20486%20system%20Vibrator%20file%20does%20not%20exist%20%3A%20-1%3CBR%20%2F%3EE%20486%20system%20Vibrator%20device%20does%20not%20exist.%20Cannot%20start%20vibrator%3CBR%20%2F%3EW%20486%20system%20VibratorService%20Tried%20to%20stop%20vibrating%20but%20there%20is%20no%20vibrator%20device.%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartConsumerIrService%3CBR%20%2F%3EE%20486%20system%20ConsumerIrService%20Can't%20open%20consumer%20IR%20HW%20Module%2C%20error%3A%20-2%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartAlarmManagerService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.AlarmManagerService%3CBR%20%2F%3EI%20486%20system%20SystemServer%20InitWatchdog%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartInputManagerService%3CBR%20%2F%3EI%20486%20system%20InputManager%20Initializing%20input%20manager%2C%20mUseDevInputEventForAudioJack%3Dfalse%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartWindowManagerService%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20WindowManager%20No%20existing%20display%20settings%20%2Fdata%2Fsystem%2Fdisplay_settings.xml%3B%20starting%20empty%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartVrManagerService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.vr.VrManagerService%3CBR%20%2F%3EW%20486%20system%20VrManagerService%20init_native%3A%20Could%20not%20open%20VR%20hardware%20module%2C%20error%20No%20such%20file%20or%20directory%20(-2).%3CBR%20%2F%3EI%20486%20system%20InputManager%20Starting%20input%20manager%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.BluetoothService%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Loading%20stored%20name%20and%20address%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Stored%20bluetooth%20Name%3Dnull%2CAddress%3Dnull%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Bluetooth%20persisted%20state%3A%200%3CBR%20%2F%3EI%20486%20system%20SystemServer%20ConnectivityMetricsLoggerService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.connectivity.MetricsLoggerService%3CBR%20%2F%3ED%20486%20system%20EventHub%20No%20input%20device%20configuration%20file%20found%20for%20device%20'isl29023%20light%20sensor'.%3CBR%20%2F%3EI%20486%20system%20SystemServer%20IpConnectivityMetrics%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.connectivity.IpConnectivityMetrics%3CBR%20%2F%3EI%20486%20system%20SystemServer%20PinnerService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.PinnerService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.InputMethodManagerService%24Lifecycle%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20System%20ClassLoader%20referenced%20unknown%20path%3A%3CBR%20%2F%3ED%20486%20system%20ApplicationLoaders%20ignored%20Vulkan%20layer%20search%20path%20%2Fsystem%2Fapp%2FLatinIME%2Flib%2Farm%3A%2Fsystem%2Ffake-libs%3A%2Fsystem%2Fapp%2FLatinIME%2FLatinIME.apk!%2Flib%2Farmeabi-v7a%3A%2Fsystem%2Flib%3A%2Fvendor%2Flib%20for%20namespace%200xb32cc0d0%3CBR%20%2F%3EE%20486%20system%20EventHub%20could%20not%20get%20driver%20version%20for%20%2Fdev%2Finput%2Fmice%2C%20Not%20a%20typewriter%3CBR%20%2F%3EE%20486%20system%20EventHub%20could%20not%20get%20driver%20version%20for%20%2Fdev%2Finput%2Fmouse0%2C%20Not%20a%20typewriter%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20InputMethodManagerService%20No%20IME%20selected.%20Choose%20the%20most%20applicable%20IME.%3CBR%20%2F%3EI%20486%20system%20InputMethodManagerService%20Default%20found%2C%20using%20com.android.inputmethod.latin%2F.LatinIME%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartAccessibilityManagerService%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Config%20changes%3D1df8%20%7B1.0%20%3Fmcc%3Fmnc%20%5Ben_US%5D%20ldltr%20sw800dp%20w1280dp%20h800dp%20160dpi%20xlrg%20land%20%3Fuimode%20%3Fnight%20-touch%20-keyb%2Fh%2Fh%20-nav%2Fh%20s.2%7D%3CBR%20%2F%3EI%20486%20system%20UsageStatsDatabase%20Upgrading%20from%20version%200%20to%203%3CBR%20%2F%3EI%20486%20system%20UsageStatsDatabase%20Deleting%20all%20usage%20stats%20files%3CBR%20%2F%3EI%20486%20system%20UsageStatsService%20User%5B0%5D%20Rollover%20scheduled%20%40%201970-01-02%2000%3A03%3A20(86600839)%3CBR%20%2F%3ED%20486%20system%20UsageStatsService%20Initializing%20defaults%20for%20system%20apps%20on%20user%200%3CBR%20%2F%3EE%20486%20system%20AppIdleHistory%20Unable%20to%20read%20app%20idle%20file%20for%20user%200%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Config%20changes%3D400%20%7B1.0%20%3Fmcc%3Fmnc%20%5Ben_US%5D%20ldltr%20sw800dp%20w1280dp%20h728dp%20160dpi%20xlrg%20land%20%3Fuimode%20%3Fnight%20-touch%20-keyb%2Fh%2Fh%20-nav%2Fh%20s.3%7D%3CBR%20%2F%3ED%20486%20system%20EventHub%20No%20input%20device%20configuration%20file%20found%20for%20device%20'max11801_ts'.%3CBR%20%2F%3EI%20486%20system%20EventHub%20New%20device%3A%20id%3D2%2C%20fd%3D96%2C%20path%3D'%2Fdev%2Finput%2Fevent1'%2C%20name%3D'max11801_ts'%2C%20classes%3D0x4%2C%20configuration%3D''%2C%20keyLayout%3D''%2C%20keyCharacterMap%3D''%2C%20builtinKeyboard%3Dfalse%2C%20wakeMechanism%3DEPOLLWAKEUP%2C%20usingClockIoctl%3Dtrue%3CBR%20%2F%3ED%20486%20system%20EventHub%20No%20input%20device%20configuration%20file%20found%20for%20device%20'ft5426_ts'.%3CBR%20%2F%3EI%20486%20system%20EventHub%20New%20device%3A%20id%3D3%2C%20fd%3D97%2C%20path%3D'%2Fdev%2Finput%2Fevent0'%2C%20name%3D'ft5426_ts'%2C%20classes%3D0x14%2C%20configuration%3D''%2C%20keyLayout%3D''%2C%20keyCharacterMap%3D''%2C%20builtinKeyboard%3Dfalse%2C%20wakeMechanism%3DEPOLLWAKEUP%2C%20usingClockIoctl%3Dtrue%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.MountService%24Lifecycle%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20InputReader%20Device%20added%3A%20id%3D-1%2C%20name%3D'Virtual'%2C%20sources%3D0x00000301%3CBR%20%2F%3EI%20486%20system%20InputReader%20Touch%20device%20'ft5426_ts'%20could%20not%20query%20the%20properties%20of%20its%20associated%20display.%20The%20device%20will%20be%20inoperable%20until%20the%20display%20size%20becomes%20available.%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.UiModeManagerService%3CBR%20%2F%3ED%20486%20system%20MountService%20Thinking%20about%20init%2C%20mSystemReady%3Dfalse%2C%20mDaemonConnected%3Dtrue%3CBR%20%2F%3EI%20486%20system%20InputReader%20Device%20added%3A%20id%3D3%2C%20name%3D'ft5426_ts'%2C%20sources%3D0x00001002%3CBR%20%2F%3ED%20486%20system%20MountService%20Thinking%20about%20reset%2C%20mSystemReady%3Dfalse%2C%20mDaemonConnected%3Dtrue%3CBR%20%2F%3EI%20486%20system%20InputReader%20Touch%20device%20'max11801_ts'%20could%20not%20query%20the%20properties%20of%20its%20associated%20display.%20The%20device%20will%20be%20inoperable%20until%20the%20display%20size%20becomes%20available.%3CBR%20%2F%3EI%20486%20system%20InputReader%20Device%20added%3A%20id%3D2%2C%20name%3D'max11801_ts'%2C%20sources%3D0x00002002%3CBR%20%2F%3ED%20486%20system%20MountService%20Thinking%20about%20init%2C%20mSystemReady%3Dfalse%2C%20mDaemonConnected%3Dtrue%3CBR%20%2F%3ED%20486%20system%20MountService%20Thinking%20about%20reset%2C%20mSystemReady%3Dfalse%2C%20mDaemonConnected%3Dtrue%3CBR%20%2F%3EI%20486%20system%20InputReader%20Reconfiguring%20input%20devices.%20changes%3D0x00000004%3CBR%20%2F%3ED%20486%20system%20CryptdConnector%20SND%20-%26gt%3B%20%7B1%20cryptfs%20getfield%20SystemLocale%7D%3CBR%20%2F%3ED%20486%20system%20CryptdConnector%20RCV%20%26lt%3B-%20%7B200%201%20-1%7D%3CBR%20%2F%3EW%20486%20system%20MountService%20No%20primary%20storage%20mounted!%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B1%20asec%20list%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%201%20asec%20operation%20succeeded%7D%3CBR%20%2F%3EI%20486%20system%20PackageManager%20No%20secure%20containers%20found%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Unknown%20permission%20com.google.android.googleapps.permission.GOOGLE_AUTH%20in%20package%20com.android.providers.calendar%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Unknown%20permission%20com.google.android.googleapps.permission.GOOGLE_AUTH.cl%20in%20package%20com.android.providers.calendar%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Not%20granting%20permission%20android.permission.GLOBAL_SEARCH%20to%20package%20com.android.quicksearchbox%20(protectionLevel%3D18%20flags%3D0x3888be45)%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Not%20granting%20permission%20android.permission.BIND_WALLPAPER%20to%20package%20com.android.camera2%20(protectionLevel%3D18%20flags%3D0x30d8bc45)%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Unknown%20permission%20com.google.android.googleapps.permission.GOOGLE_AUTH.mail%20in%20package%20com.android.calendar%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Not%20granting%20permission%20android.permission.WRITE_MEDIA_STORAGE%20to%20package%20com.android.gallery3d%20(protectionLevel%3D18%20flags%3D0x38d8bc45)%3CBR%20%2F%3EI%20486%20system%20InputReader%20Device%20reconfigured%3A%20id%3D2%2C%20name%3D'max11801_ts'%2C%20size%201280x800%2C%20orientation%200%2C%20mode%204%2C%20display%20id%200%3CBR%20%2F%3EI%20486%20system%20InputReader%20Device%20reconfigured%3A%20id%3D3%2C%20name%3D'ft5426_ts'%2C%20size%201280x800%2C%20orientation%200%2C%20mode%201%2C%20display%20id%200%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Unknown%20permission%20com.google.android.permission.INSTALL_WEARABLE_PACKAGES%20in%20package%20com.android.packageinstaller%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Not%20granting%20permission%20android.permission.DELETE_PACKAGES%20to%20package%20com.svox.pico%20(protectionLevel%3D18%20flags%3D0x3888be45)%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Unknown%20permission%20android.permission.RUN_INSTRUMENTATION%20in%20package%20org.chromium.webview_shell%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Config%20changes%3D8%20%7B1.0%20%3Fmcc%3Fmnc%20%5Ben_US%5D%20ldltr%20sw800dp%20w1280dp%20h728dp%20160dpi%20xlrg%20land%20%3Fuimode%20%3Fnight%20finger%20-keyb%2Fh%2Fh%20-nav%2Fh%20s.4%7D%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Unknown%20permission%20com.google.android.googleapps.permission.GOOGLE_AUTH%20in%20package%20com.android.settings%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Unknown%20permission%20com.android.smspush.WAPPUSH_MANAGER_BIND%20in%20package%20com.android.phone%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Unknown%20permission%20android.permission.ACCESS_ALL_EXTERNAL_STORAGE%20in%20package%20com.freescale.wfdsink%3CBR%20%2F%3EW%20486%20system%20PackageManager%20Unknown%20permission%20com.google.android.gallery3d.permission.GALLERY_PROVIDER%20in%20package%20com.android.bluetooth%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20MountService%20No%20primary%20storage%20defined%20yet%3B%20hacking%20together%20a%20stub%3CBR%20%2F%3EW%20486%20system%20MountService%20No%20primary%20storage%20defined%20yet%3B%20hacking%20together%20a%20stub%3CBR%20%2F%3EW%20486%20system%20MountService%20No%20primary%20storage%20mounted!%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B2%20asec%20list%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%202%20asec%20operation%20succeeded%7D%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Config%20changes%3D200%20%7B1.0%20%3Fmcc%3Fmnc%20%5Ben_US%5D%20ldltr%20sw800dp%20w1280dp%20h728dp%20160dpi%20xlrg%20land%20finger%20-keyb%2Fh%2Fh%20-nav%2Fh%20s.5%7D%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FBleServerEmulator%2FBleServerEmulator.apk%20pkg%3Dcom.freescale.bleserver%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20681%20dex2oat%20type%3D1400%20audit(0.0%3A42)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20681%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20681%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EI%20681%20dex2oat%20dex2oat%20took%20300.038ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32208B)%20native%20alloc%3D985KB%20(1008976B)%20free%3D1574KB%20(1612464B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FCubeLiveWallpapers%2FCubeLiveWallpapers.apk%20pkg%3Dcom.example.android.livecubes%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20686%20dex2oat%20type%3D1400%20audit(0.0%3A43)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20686%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20686%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20686%20dex2oat%20dex2oat%20took%20211.810ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32208B)%20native%20alloc%3D771KB%20(789520B)%20free%3D1276KB%20(1307632B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2Fethernet%2Fethernet.apk%20pkg%3Dcom.fsl.ethernet%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20691%20dex2oat%20type%3D1400%20audit(0.0%3A44)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20691%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20691%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20691%20dex2oat%20dex2oat%20took%20214.415ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D884KB%20(905808B)%20free%3D1163KB%20(1191344B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FCalendarProvider%2FCalendarProvider.apk%20pkg%3Dcom.android.providers.calendar%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3D%2Fsystem%2Fframework%2Fandroid.test.runner.jar%3CBR%20%2F%3EW%20696%20dex2oat%20type%3D1400%20audit(0.0%3A45)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20696%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20696%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20696%20dex2oat%20dex2oat%20took%20316.540ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D35KB%20(36168B)%20native%20alloc%3D897KB%20(918928B)%20free%3D1662KB%20(1702512B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FMediaProvider%2FMediaProvider.apk%20pkg%3Dcom.android.providers.media%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20701%20dex2oat%20type%3D1400%20audit(0.0%3A46)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20701%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20701%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20701%20dex2oat%20dex2oat%20took%20238.360ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32216B)%20native%20alloc%3D986KB%20(1010256B)%20free%3D1061KB%20(1086896B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FWallpaperCropper%2FWallpaperCropper.apk%20pkg%3Dcom.android.wallpapercropper%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20706%20dex2oat%20type%3D1400%20audit(0.0%3A47)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20706%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20706%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20706%20dex2oat%20dex2oat%20took%20253.909ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32216B)%20native%20alloc%3D960KB%20(983376B)%20free%3D1599KB%20(1638064B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FLauncher2%2FLauncher2.apk%20pkg%3Dcom.android.launcher%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20711%20dex2oat%20type%3D1400%20audit(0.0%3A48)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20711%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20711%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20711%20dex2oat%20dex2oat%20took%20319.207ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D991KB%20(1015056B)%20free%3D1568KB%20(1606384B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FDocumentsUI%2FDocumentsUI.apk%20pkg%3Dcom.android.documentsui%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20716%20dex2oat%20type%3D1400%20audit(0.0%3A49)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20716%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20716%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20716%20dex2oat%20dex2oat%20took%20591.544ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D788KB%20(807384B)%20free%3D2MB%20(2338344B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FExternalStorageProvider%2FExternalStorageProvider.apk%20pkg%3Dcom.android.externalstorage%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20721%20dex2oat%20type%3D1400%20audit(0.0%3A50)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20721%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20721%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20721%20dex2oat%20dex2oat%20took%20225.544ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D935KB%20(957968B)%20free%3D1112KB%20(1139184B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FHTMLViewer%2FHTMLViewer.apk%20pkg%3Dcom.android.htmlviewer%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20726%20dex2oat%20type%3D1400%20audit(0.0%3A51)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20726%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20726%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20726%20dex2oat%20dex2oat%20took%20218.355ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D764KB%20(782928B)%20free%3D1283KB%20(1314224B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FQuickSearchBox%2FQuickSearchBox.apk%20pkg%3Dcom.android.quicksearchbox%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20731%20dex2oat%20type%3D1400%20audit(0.0%3A52)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20731%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20731%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20731%20dex2oat%20dex2oat%20took%20307.519ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32216B)%20native%20alloc%3D969KB%20(992336B)%20free%3D1590KB%20(1629104B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FDownloadProvider%2FDownloadProvider.apk%20pkg%3Dcom.android.providers.downloads%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20736%20dex2oat%20type%3D1400%20audit(0.0%3A53)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20736%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20736%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20736%20dex2oat%20dex2oat%20took%20293.968ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32216B)%20native%20alloc%3D1018KB%20(1042448B)%20free%3D1541KB%20(1578992B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FSoundRecorder%2FSoundRecorder.apk%20pkg%3Dcom.android.soundrecorder%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20741%20dex2oat%20type%3D1400%20audit(0.0%3A54)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20741%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20741%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20741%20dex2oat%20dex2oat%20took%20223.212ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32216B)%20native%20alloc%3D744KB%20(762832B)%20free%3D1303KB%20(1334320B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FDownloadProviderUi%2FDownloadProviderUi.apk%20pkg%3Dcom.android.providers.downloads.ui%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20746%20dex2oat%20type%3D1400%20audit(0.0%3A55)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20746%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20746%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20746%20dex2oat%20dex2oat%20took%20237.534ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32208B)%20native%20alloc%3D746KB%20(764688B)%20free%3D1301KB%20(1332464B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FPacProcessor%2FPacProcessor.apk%20pkg%3Dcom.android.pacprocessor%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20752%20dex2oat%20type%3D1400%20audit(0.0%3A56)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20752%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20752%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20752%20dex2oat%20dex2oat%20took%20224.854ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D744KB%20(762384B)%20free%3D1303KB%20(1334768B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FCertInstaller%2FCertInstaller.apk%20pkg%3Dcom.android.certinstaller%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20757%20dex2oat%20type%3D1400%20audit(0.0%3A57)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20757%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20757%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20757%20dex2oat%20dex2oat%20took%20214.679ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32216B)%20native%20alloc%3D884KB%20(906192B)%20free%3D1163KB%20(1190960B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FCarrierConfig%2FCarrierConfig.apk%20pkg%3Dcom.android.carrierconfig%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20762%20dex2oat%20type%3D1400%20audit(0.0%3A58)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20762%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20762%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20762%20dex2oat%20dex2oat%20took%20218.509ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32216B)%20native%20alloc%3D744KB%20(762384B)%20free%3D1303KB%20(1334768B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FContacts%2FContacts.apk%20pkg%3Dcom.android.contacts%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20767%20dex2oat%20type%3D1400%20audit(0.0%3A59)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20767%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20767%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20767%20dex2oat%20dex2oat%20took%20583.420ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D501KB%20(513736B)%20free%3D2MB%20(2631992B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FCamera2%2FCamera2.apk%20pkg%3Dcom.android.camera2%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20772%20dex2oat%20type%3D1400%20audit(0.0%3A60)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20772%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20772%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20772%20dex2oat%20dex2oat%20took%20892.297ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D407KB%20(417024B)%20free%3D2MB%20(2728704B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FEasterEgg%2FEasterEgg.apk%20pkg%3Dcom.android.egg%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20777%20dex2oat%20type%3D1400%20audit(0.0%3A61)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20777%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20777%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20777%20dex2oat%20dex2oat%20took%20288.823ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D961KB%20(984848B)%20free%3D1598KB%20(1636592B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FMtpDocumentsProvider%2FMtpDocumentsProvider.apk%20pkg%3Dcom.android.mtp%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20782%20dex2oat%20type%3D1400%20audit(0.0%3A62)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20782%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20782%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20782%20dex2oat%20dex2oat%20took%20231.270ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32208B)%20native%20alloc%3D912KB%20(934320B)%20free%3D1135KB%20(1162832B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FBackupRestoreConfirmation%2FBackupRestoreConfirmation.apk%20pkg%3Dcom.android.backupconfirm%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20787%20dex2oat%20type%3D1400%20audit(0.0%3A63)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20787%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20787%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20787%20dex2oat%20dex2oat%20took%20225.173ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32240B)%20native%20alloc%3D747KB%20(765200B)%20free%3D1300KB%20(1331952B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FProvision%2FProvision.apk%20pkg%3Dcom.android.provision%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20792%20dex2oat%20type%3D1400%20audit(0.0%3A64)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20792%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20792%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20792%20dex2oat%20dex2oat%20took%20222.587ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D804KB%20(824144B)%20free%3D1243KB%20(1273008B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FStatementService%2FStatementService.apk%20pkg%3Dcom.android.statementservice%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20797%20dex2oat%20type%3D1400%20audit(0.0%3A65)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20797%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20797%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20797%20dex2oat%20dex2oat%20took%20226.139ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32216B)%20native%20alloc%3D978KB%20(1002448B)%20free%3D1069KB%20(1094704B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FCalendar%2FCalendar.apk%20pkg%3Dcom.android.calendar%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20802%20dex2oat%20type%3D1400%20audit(0.0%3A66)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20802%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20802%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20802%20dex2oat%20dex2oat%20took%20372.213ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D872KB%20(893648B)%20free%3D2MB%20(2252080B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FSharedStorageBackup%2FSharedStorageBackup.apk%20pkg%3Dcom.android.sharedstoragebackup%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20807%20dex2oat%20type%3D1400%20audit(0.0%3A67)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20807%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20807%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20807%20dex2oat%20dex2oat%20took%20217.376ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32208B)%20native%20alloc%3D746KB%20(764688B)%20free%3D1301KB%20(1332464B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FPrintSpooler%2FPrintSpooler.apk%20pkg%3Dcom.android.printspooler%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20812%20dex2oat%20type%3D1400%20audit(0.0%3A68)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20812%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20812%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20812%20dex2oat%20dex2oat%20took%20322.039ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D972KB%20(995920B)%20free%3D1587KB%20(1625520B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FBasicDreams%2FBasicDreams.apk%20pkg%3Dcom.android.dreams.basic%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20817%20dex2oat%20type%3D1400%20audit(0.0%3A69)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20817%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20817%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20817%20dex2oat%20dex2oat%20took%20225.695ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D784KB%20(803408B)%20free%3D1263KB%20(1293744B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2Fwebview%2Fwebview.apk%20pkg%3Dcom.android.webview%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20822%20dex2oat%20type%3D1400%20audit(0.0%3A70)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20822%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20822%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20822%20dex2oat%20dex2oat%20took%20414.505ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D564KB%20(577944B)%20free%3D2MB%20(2567784B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FMusicFX%2FMusicFX.apk%20pkg%3Dcom.android.musicfx%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20827%20dex2oat%20type%3D1400%20audit(0.0%3A71)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20827%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20827%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20827%20dex2oat%20dex2oat%20took%20223.481ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D884KB%20(906192B)%20free%3D1163KB%20(1190960B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FCellBroadcastReceiver%2FCellBroadcastReceiver.apk%20pkg%3Dcom.android.cellbroadcastreceiver%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20832%20dex2oat%20type%3D1400%20audit(0.0%3A72)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20832%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20832%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20832%20dex2oat%20dex2oat%20took%20230.698ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D941KB%20(964176B)%20free%3D1106KB%20(1132976B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FOneTimeInitializer%2FOneTimeInitializer.apk%20pkg%3Dcom.android.onetimeinitializer%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20837%20dex2oat%20type%3D1400%20audit(0.0%3A73)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20837%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20837%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20837%20dex2oat%20dex2oat%20took%20228.272ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32208B)%20native%20alloc%3D907KB%20(928784B)%20free%3D1140KB%20(1168368B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FKeyChain%2FKeyChain.apk%20pkg%3Dcom.android.keychain%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20842%20dex2oat%20type%3D1400%20audit(0.0%3A74)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20842%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20842%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20842%20dex2oat%20dex2oat%20took%20233.482ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D889KB%20(911184B)%20free%3D1158KB%20(1185968B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FPrintRecommendationService%2FPrintRecommendationService.apk%20pkg%3Dcom.android.printservice.recommendation%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20847%20dex2oat%20type%3D1400%20audit(0.0%3A75)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20847%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20847%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20847%20dex2oat%20dex2oat%20took%20233.439ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32240B)%20native%20alloc%3D946KB%20(969232B)%20free%3D1101KB%20(1127920B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FGallery2%2FGallery2.apk%20pkg%3Dcom.android.gallery3d%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20852%20dex2oat%20type%3D1400%20audit(0.0%3A76)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20852%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20852%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20852%20dex2oat%20dex2oat%20took%20784.921ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D467KB%20(478616B)%20free%3D2MB%20(2667112B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FCallLogBackup%2FCallLogBackup.apk%20pkg%3Dcom.android.calllogbackup%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20857%20dex2oat%20type%3D1400%20audit(0.0%3A77)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20857%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20857%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20857%20dex2oat%20dex2oat%20took%20226.852ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32216B)%20native%20alloc%3D768KB%20(786704B)%20free%3D1279KB%20(1310448B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FPicoTts%2FPicoTts.apk%20pkg%3Dcom.svox.pico%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20862%20dex2oat%20type%3D1400%20audit(0.0%3A78)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20862%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20862%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20862%20dex2oat%20dex2oat%20took%20230.924ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D769KB%20(787472B)%20free%3D1278KB%20(1309680B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FBrowser2%2FBrowser2.apk%20pkg%3Dorg.chromium.webview_shell%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3D%2Fsystem%2Fframework%2Fandroid.test.runner.jar%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20867%20dex2oat%20type%3D1400%20audit(0.0%3A79)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20867%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20867%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20867%20dex2oat%20dex2oat%20took%20242.392ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32192B)%20native%20alloc%3D965KB%20(988624B)%20free%3D1594KB%20(1632816B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FManagedProvisioning%2FManagedProvisioning.apk%20pkg%3Dcom.android.managedprovisioning%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20872%20dex2oat%20type%3D1400%20audit(0.0%3A80)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20872%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20872%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20872%20dex2oat%20dex2oat%20took%20270.101ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32208B)%20native%20alloc%3D960KB%20(983568B)%20free%3D1599KB%20(1637872B)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FLiveWallpapersPicker%2FLiveWallpapersPicker.apk%20pkg%3Dcom.android.wallpaper.livepicker%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20877%20dex2oat%20type%3D1400%20audit(0.0%3A81)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20877%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20877%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20877%20dex2oat%20dex2oat%20took%20434.611ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32208B)%20native%20alloc%3D904KB%20(926352B)%20free%3D2MB%20(2219376B)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FStorageManager%2FStorageManager.apk%20pkg%3Dcom.android.storagemanager%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20882%20dex2oat%20type%3D1400%20audit(0.0%3A82)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20882%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20882%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20882%20dex2oat%20dex2oat%20took%20510.795ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32216B)%20native%20alloc%3D810KB%20(830184B)%20free%3D2MB%20(2315544B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FBookmarkProvider%2FBookmarkProvider.apk%20pkg%3Dcom.android.bookmarkprovider%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20887%20dex2oat%20type%3D1400%20audit(0.0%3A83)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20887%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20887%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20887%20dex2oat%20dex2oat%20took%20229.979ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32216B)%20native%20alloc%3D764KB%20(782864B)%20free%3D1283KB%20(1314288B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FA2dpSinkApp%2FA2dpSinkApp.apk%20pkg%3Dcom.freescale.a2dpsinkapp%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20892%20dex2oat%20type%3D1400%20audit(0.0%3A84)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20892%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20892%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20892%20dex2oat%20dex2oat%20took%20224.664ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D747KB%20(765520B)%20free%3D1300KB%20(1331632B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FExactCalculator%2FExactCalculator.apk%20pkg%3Dcom.android.calculator2%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20897%20dex2oat%20type%3D1400%20audit(0.0%3A85)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20897%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20897%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20897%20dex2oat%20dex2oat%20took%20283.252ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32216B)%20native%20alloc%3D986KB%20(1009680B)%20free%3D1573KB%20(1611760B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FVpnDialogs%2FVpnDialogs.apk%20pkg%3Dcom.android.vpndialogs%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20902%20dex2oat%20type%3D1400%20audit(0.0%3A86)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20902%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20902%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20902%20dex2oat%20dex2oat%20took%20209.272ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D744KB%20(762448B)%20free%3D1303KB%20(1334704B)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FEmail%2FEmail.apk%20pkg%3Dcom.android.email%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20907%20dex2oat%20type%3D1400%20audit(0.0%3A87)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20907%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20907%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20907%20dex2oat%20dex2oat%20took%201.328s%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D507KB%20(519248B)%20free%3D2MB%20(2626480B)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FMusic%2FMusic.apk%20pkg%3Dcom.android.music%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20912%20dex2oat%20type%3D1400%20audit(0.0%3A88)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20912%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20912%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20912%20dex2oat%20dex2oat%20took%20262.012ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D961KB%20(985008B)%20free%3D1598KB%20(1636432B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FWallpaperBackup%2FWallpaperBackup.apk%20pkg%3Dcom.android.wallpaperbackup%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20917%20dex2oat%20type%3D1400%20audit(0.0%3A89)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20917%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20917%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20917%20dex2oat%20dex2oat%20took%20232.189ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32216B)%20native%20alloc%3D747KB%20(765456B)%20free%3D1300KB%20(1331696B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FBlockedNumberProvider%2FBlockedNumberProvider.apk%20pkg%3Dcom.android.providers.blockednumber%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20922%20dex2oat%20type%3D1400%20audit(0.0%3A90)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20922%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20922%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20922%20dex2oat%20dex2oat%20took%20296.047ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D959KB%20(982992B)%20free%3D1088KB%20(1114160B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FUserDictionaryProvider%2FUserDictionaryProvider.apk%20pkg%3Dcom.android.providers.userdictionary%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20927%20dex2oat%20type%3D1400%20audit(0.0%3A91)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20927%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20927%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20927%20dex2oat%20dex2oat%20took%20227.982ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D774KB%20(793360B)%20free%3D1273KB%20(1303792B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FEmergencyInfo%2FEmergencyInfo.apk%20pkg%3Dcom.android.emergency%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20932%20dex2oat%20type%3D1400%20audit(0.0%3A92)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20932%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20932%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20932%20dex2oat%20dex2oat%20took%20419.541ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32216B)%20native%20alloc%3D899KB%20(920720B)%20free%3D2MB%20(2225008B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FDeskClock%2FDeskClock.apk%20pkg%3Dcom.android.deskclock%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20937%20dex2oat%20type%3D1400%20audit(0.0%3A93)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20937%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20937%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20937%20dex2oat%20dex2oat%20took%20701.260ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D477KB%20(488728B)%20free%3D2MB%20(2657000B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FBluetoothMidiService%2FBluetoothMidiService.apk%20pkg%3Dcom.android.bluetoothmidiservice%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20942%20dex2oat%20type%3D1400%20audit(0.0%3A94)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20942%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20942%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20942%20dex2oat%20dex2oat%20took%20227.086ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32208B)%20native%20alloc%3D747KB%20(764944B)%20free%3D1300KB%20(1332208B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FBleClient%2FBleClient.apk%20pkg%3Dcom.freescale.bleclient%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20947%20dex2oat%20type%3D1400%20audit(0.0%3A95)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20947%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20947%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20947%20dex2oat%20dex2oat%20took%20244.598ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D27KB%20(28240B)%20native%20alloc%3D957KB%20(980400B)%20free%3D1090KB%20(1116752B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FBluetooth%2FBluetooth.apk%20pkg%3Dcom.android.bluetooth%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3D%2Fsystem%2Fframework%2Fjavax.obex.jar%3CBR%20%2F%3EW%20952%20dex2oat%20type%3D1400%20audit(0.0%3A96)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20952%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20952%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20952%20dex2oat%20dex2oat%20took%20896.902ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32240B)%20native%20alloc%3D478KB%20(490096B)%20free%3D2MB%20(2655632B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fpriv-app%2FContactsProvider%2FContactsProvider.apk%20pkg%3Dcom.android.providers.contacts%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20957%20dex2oat%20type%3D1400%20audit(0.0%3A97)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EI%20957%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20957%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20957%20dex2oat%20dex2oat%20took%20412.456ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32216B)%20native%20alloc%3D913KB%20(935824B)%20free%3D2MB%20(2209904B)%3CBR%20%2F%3EI%20486%20system%20PackageManager.DexOptimizer%20Running%20dexopt%20(dex2oat)%20on%3A%20%2Fsystem%2Fapp%2FCaptivePortalLogin%2FCaptivePortalLogin.apk%20pkg%3Dcom.android.captiveportallogin%20isa%3Darm%20vmSafeMode%3Dfalse%20debuggable%3Dfalse%20target-filter%3Dverify-at-runtime%20oatDir%20%3D%20null%20sharedLibraries%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20965%20%2Fsystem%2Fbin%2Fdex2oat%20dex2oat%20%2Fsystem%2Fbin%2Fdex2oat%20--compiler-filter%3Dverify-at-runtime%3CBR%20%2F%3EE%20965%20%2Fsystem%2Fbin%2Fdex2oat%20cutils-trace%20Error%20opening%20trace%20file%3A%20Permission%20denied%20(13)%3CBR%20%2F%3EW%20965%20%2Fsystem%2Fbin%2Fdex2oat%20dex2oat%20type%3D1400%20audit(0.0%3A98)%3A%20avc%3A%20denied%20%7B%20write%20%7D%20for%20name%3D%22trace_marker%22%20dev%3D%22tracefs%22%20ino%3D125%20scontext%3Du%3Ar%3Adex2oat%3As0%20tcontext%3Du%3Aobject_r%3Adebugfs_tracing%3As0%20tclass%3Dfile%20permissive%3D0%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20965%20%2Fsystem%2Fbin%2Fdex2oat%20dex2oat%20dex2oat%20took%20317.846ms%20(threads%3A%204)%20arena%20alloc%3D0B%20(0B)%20java%20alloc%3D31KB%20(32208B)%20native%20alloc%3D747KB%20(764944B)%20free%3D1300KB%20(1332208B)%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartLockSettingsService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.LockSettingsService%24Lifecycle%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.PersistentDataBlockService%3CBR%20%2F%3EE%20486%20system%20PersistentDataBlockService%20not%20able%20to%20find%20package%3CBR%20%2F%3EE%20486%20system%20PersistentDataBlockService%20android.content.pm.PackageManager%24NameNotFoundException%3A%3CBR%20%2F%3EE%20486%20system%20PersistentDataBlockService%20at%20android.app.ApplicationPackageManager.getPackageUidAsUser(ApplicationPackageManager.java%3A256)%3CBR%20%2F%3EE%20486%20system%20PersistentDataBlockService%20at%20com.android.server.PersistentDataBlockService.getAllowedUid(PersistentDataBlockService.java%3A102)%3CBR%20%2F%3EE%20486%20system%20PersistentDataBlockService%20at%20com.android.server.PersistentDataBlockService.%3CINIT%3E(PersistentDataBlockService.java%3A93)%3CBR%20%2F%3EE%20486%20system%20PersistentDataBlockService%20at%20java.lang.reflect.Constructor.newInstance0(Native%20Method)%3CBR%20%2F%3EE%20486%20system%20PersistentDataBlockService%20at%20java.lang.reflect.Constructor.newInstance(Constructor.java%3A430)%3CBR%20%2F%3EE%20486%20system%20PersistentDataBlockService%20at%20com.android.server.SystemServiceManager.startService(SystemServiceManager.java%3A92)%3CBR%20%2F%3EE%20486%20system%20PersistentDataBlockService%20at%20com.android.server.SystemServer.startOtherServices(SystemServer.java%3A749)%3CBR%20%2F%3EE%20486%20system%20PersistentDataBlockService%20at%20com.android.server.SystemServer.run(SystemServer.java%3A334)%3CBR%20%2F%3EE%20486%20system%20PersistentDataBlockService%20at%20com.android.server.SystemServer.main(SystemServer.java%3A219)%3CBR%20%2F%3EE%20486%20system%20PersistentDataBlockService%20at%20java.lang.reflect.Method.invoke(Native%20Method)%3CBR%20%2F%3EE%20486%20system%20PersistentDataBlockService%20at%20com.android.internal.os.ZygoteInit%24MethodAndArgsCaller.run(ZygoteInit.java%3A886)%3CBR%20%2F%3EE%20486%20system%20PersistentDataBlockService%20at%20com.android.internal.os.ZygoteInit.main(ZygoteInit.java%3A776)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.DeviceIdleController%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.devicepolicy.DevicePolicyManagerService%24Lifecycle%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartStatusBarManagerService%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartClipboardService%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartNetworkManagementService%3CBR%20%2F%3EI%20486%20system%20NetworkManagement%20onDaemonConnected()%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.TextServicesManagerService%24Lifecycle%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartNetworkScoreService%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartNetworkStatsService%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartNetworkPolicyManagerService%3CBR%20%2F%3EI%20486%20system%20SystemServer%20No%20Wi-Fi%20NAN%20Service%20(NAN%20support%20Not%20Present)%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.wifi.p2p.WifiP2pService%3CBR%20%2F%3EI%20486%20system%20WifiP2pService%20Registering%20wifip2p%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.wifi.WifiService%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20HS20%20Passpoint%20is%20disabled%3CBR%20%2F%3EE%20486%20system%20IpManager.wlan0%20Failed%20to%20disable%20IPv6java.lang.IllegalStateException%3A%20command%20'1%20interface%20ipv6%20wlan0%20disable'%20failed%20with%20'400%201%20Failed%20to%20change%20IPv6%20state%20(No%20such%20file%20or%20directory)'%3CBR%20%2F%3ED%20486%20system%20WifiApConfigStore%202G%20band%20allowed%20channels%20are%3A1%2C6%2C11%3CBR%20%2F%3EE%20486%20system%20WifiLogger%20no%20ring%20buffers%20found%3CBR%20%2F%3EE%20486%20system%20WifiLogger%20Failed%20to%20start%20packet%20fate%20monitoring%3CBR%20%2F%3EE%20486%20system%20WifiApConfigStore%20Error%20reading%20hotspot%20configuration%20java.io.FileNotFoundException%3A%20%2Fdata%2Fmisc%2Fwifi%2Fsoftap.conf%20(No%20such%20file%20or%20directory)%3CBR%20%2F%3ED%20486%20system%20WifiApConfigStore%20Fallback%20to%20use%20default%20AP%20configuration%3CBR%20%2F%3ED%20238%20%2Fsystem%2Fbin%2Fnetd%20CommandListener%20Clearing%20all%20IP%20addresses%20on%20wlan0%3CBR%20%2F%3ED%20486%20system%20WifiController%20isAirplaneModeOn%20%3D%20false%2C%20isWifiEnabled%20%3D%20false%2C%20isScanningAvailable%20%3D%20false%3CBR%20%2F%3EI%20486%20system%20WifiService%20Registering%20wifi%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.wifi.scanner.WifiScanningService%3CBR%20%2F%3EI%20486%20system%20WifiScanningService%20Creating%20wifiscanner%3CBR%20%2F%3EI%20486%20system%20WifiScanningService%20Publishing%20wifiscanner%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.wifi.RttService%3CBR%20%2F%3EI%20486%20system%20RttService%20Creating%20rttmanager%3CBR%20%2F%3EI%20486%20system%20RttService%20Starting%20rttmanager%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.ethernet.EthernetService%3CBR%20%2F%3EI%20486%20system%20EthernetServiceImpl%20Creating%20EthernetConfigStore%3CBR%20%2F%3EE%20486%20system%20IpConfigStore%20Error%20parsing%20configuration%3A%20java.io.FileNotFoundException%3A%20%2Fdata%2Fmisc%2Fethernet%2Fipconfig.txt%20(No%20such%20file%20or%20directory)%3CBR%20%2F%3EW%20486%20system%20EthernetConfigStore%20No%20Ethernet%20configuration%20found.%20Using%20default.%3CBR%20%2F%3EI%20486%20system%20EthernetServiceImpl%20Read%20stored%20IP%20configuration%3A%20IP%20assignment%3A%20DHCP%3CBR%20%2F%3EI%20486%20system%20EthernetServiceImpl%20Proxy%20settings%3A%20NONE%3CBR%20%2F%3EI%20486%20system%20EthernetService%20Registering%20service%20ethernet%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartConnectivityService%3CBR%20%2F%3ED%20486%20system%20ConnectivityService%20ConnectivityService%20starting%20up%3CBR%20%2F%3ED%20486%20system%20ConnectivityService%20wifiOnly%3Dfalse%3CBR%20%2F%3EE%20486%20system%20ConnectivityService%20Ignoring%20protectedNetwork%2014%3CBR%20%2F%3EE%20486%20system%20ConnectivityService%20Ignoring%20protectedNetwork%2015%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartNsdService%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartUpdateLockService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.RecoverySystemService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.notification.NotificationManagerService%3CBR%20%2F%3ED%20486%20system%20ConditionProviders.SCP%20new%20ScheduleConditionProvider()%3CBR%20%2F%3ED%20486%20system%20ZenLog%20set_zen_mode%3A%20off%2Cinit%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.storage.DeviceStorageMonitorService%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartLocationManagerService%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartCountryDetectorService%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartSearchManagerService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.search.SearchManagerService%24Lifecycle%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.DropBoxManagerService%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartWallpaperManagerService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.wallpaper.WallpaperManagerService%24Lifecycle%3CBR%20%2F%3EE%20486%20system%20BitmapFactory%20Unable%20to%20decode%20stream%3A%20java.io.FileNotFoundException%3A%20%2Fdata%2Fsystem%2Fusers%2F0%2Fwallpaper_orig%20(No%20such%20file%20or%20directory)%3CBR%20%2F%3EE%20486%20system%20WallpaperManagerService%20Invalid%20wallpaper%20data%3CBR%20%2F%3EE%20486%20system%20WallpaperManagerService%20Unable%20to%20apply%20new%20wallpaper%3CBR%20%2F%3EW%20486%20system%20WallpaperManagerService%20no%20current%20wallpaper%20--%20first%20boot%3F%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartAudioService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.audio.AudioService%24Lifecycle%3CBR%20%2F%3ED%20229%20%2Fsystem%2Fbin%2Faudioserver%20PermissionCache%20checking%20android.permission.MODIFY_AUDIO_SETTINGS%20for%20uid%3D1000%20%3D%26gt%3B%20granted%20(1106%20us)%3CBR%20%2F%3EW%20486%20system%20TelecomManager%20Telecom%20Service%20not%20found.%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.DockObserver%3CBR%20%2F%3EW%20486%20system%20DockObserver%20This%20kernel%20does%20not%20have%20dock%20station%20support%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartWiredAccessoryManager%3CBR%20%2F%3EW%20486%20system%20WiredAccessoryManager%20This%20kernel%20does%20not%20have%20wired%20headset%20support%3CBR%20%2F%3EW%20486%20system%20WiredAccessoryManager%20This%20kernel%20does%20not%20have%20usb%20audio%20support%3CBR%20%2F%3EW%20486%20system%20WiredAccessoryManager%20This%20kernel%20does%20not%20have%20HDMI%20audio%20support%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.usb.UsbService%24Lifecycle%3CBR%20%2F%3EE%20486%20system%20AlsaCardRecord%20Failed%20to%20parse%20line%200%20of%20%2Fproc%2Fasound%2Fcards%3A%20---%3CBR%20%2F%3EE%20486%20system%20UsbDeviceManager%20failed%20to%20write%20to%20%2Fsys%2Fclass%2Fandroid_usb%2Fandroid0%2Ff_rndis%2Fethaddr%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartSerialService%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EE%20486%20system%20HardwarePropertiesManagerService-JNI%20Couldn't%20load%20thermal%20module%20(No%20such%20file%20or%20directory)%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.twilight.TwilightService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.job.JobSchedulerService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.soundtrigger.SoundTriggerService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.backup.BackupManagerService%24Lifecycle%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.appwidget.AppWidgetService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.voiceinteraction.VoiceInteractionManagerService%3CBR%20%2F%3EI%20486%20system%20SystemServer%20Gesture%20Launcher%20Service%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.GestureLauncherService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.SensorNotificationService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.ContextHubSystemService%3CBR%20%2F%3EE%20486%20system%20ContextHubService%20**%20Could%20not%20load%20context_hub%20module%20%3A%20err%20No%20such%20file%20or%20directory%3CBR%20%2F%3EW%20486%20system%20ContextHubService%20No%20Context%20Hub%20Module%20present%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartDiskStatsService%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartSamplingProfilerService%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartNetworkTimeUpdateService%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartCommonTimeManagementService%3CBR%20%2F%3EI%20486%20system%20SystemServer%20CertBlacklister%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.emergency.EmergencyAffordanceService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.dreams.DreamManagerService%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartAssetAtlasService%3CBR%20%2F%3ED%20486%20system%20AssetAtlas%20Computing%20best%20atlas%20configuration...%3CBR%20%2F%3ED%20486%20system%20AssetAtlas%20Running%20Atlas%20Worker%20%231%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.print.PrintManagerService%3CBR%20%2F%3ED%20486%20system%20AssetAtlas%20Running%20Atlas%20Worker%20%232%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20AssetAtlas%20Running%20Atlas%20Worker%20%234%3CBR%20%2F%3ED%20486%20system%20AssetAtlas%20Running%20Atlas%20Worker%20%233%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.restrictions.RestrictionsManagerService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.media.MediaSessionService%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartMediaRouterService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.trust.TrustManagerService%3CBR%20%2F%3EI%20486%20system%20SystemServer%20StartBackgroundDexOptService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.pm.ShortcutService%24Lifecycle%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.pm.LauncherAppsService%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.media.projection.MediaProjectionManagerService%3CBR%20%2F%3EV%20486%20system%20MediaRouter%20Adding%20route%3A%20RouteInfo%7B%20name%3DTablet%2C%20description%3Dnull%2C%20status%3Dnull%2C%20category%3DRouteCategory%7B%20name%3Dnull%20types%3DROUTE_TYPE_LIVE_AUDIO%20ROUTE_TYPE_LIVE_VIDEO%20groupable%3Dfalse%20%7D%2C%20supportedTypes%3DROUTE_TYPE_LIVE_AUDIO%20ROUTE_TYPE_LIVE_VIDEO%20%2C%20presentationDisplay%3Dnull%20%7D%3CBR%20%2F%3EV%20486%20system%20MediaRouter%20Updating%20audio%20routes%3A%20AudioRoutesInfo%7B%20type%3DSPEAKER%20%7D%3CBR%20%2F%3EV%20486%20system%20MediaRouter%20Selecting%20route%3A%20RouteInfo%7B%20name%3DTablet%2C%20description%3Dnull%2C%20status%3Dnull%2C%20category%3DRouteCategory%7B%20name%3Dnull%20types%3DROUTE_TYPE_LIVE_AUDIO%20ROUTE_TYPE_LIVE_VIDEO%20groupable%3Dfalse%20%7D%2C%20supportedTypes%3DROUTE_TYPE_LIVE_AUDIO%20ROUTE_TYPE_LIVE_VIDEO%20%2C%20presentationDisplay%3Dnull%20%7D%3CBR%20%2F%3ED%20486%20system%20AssetAtlas%20Found%20best%20atlas%20configuration%20(out%20of%20576)%20in%200.07s%3CBR%20%2F%3ED%20486%20system%20AssetAtlas%20Loaded%20configuration%3A%20SliceMinArea%20(576x576)%20flags%3D0x2%20count%3D91%3CBR%20%2F%3EI%20486%20system%20WindowManager%20SAFE%20MODE%20not%20enabled%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.MmsServiceBroker%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20com.android.server.retaildemo.RetailDemoModeService%3CBR%20%2F%3EI%20486%20system%20ServiceThread%20Enabled%20StrictMode%20logging%20for%20RetailDemoModeService%20looper.%3CBR%20%2F%3EI%20486%20system%20imx6.gralloc%20open%20gpu%20gralloc%20module!%3CBR%20%2F%3EW%20486%20system%20VibratorService%20Tried%20to%20stop%20vibrating%20but%20there%20is%20no%20vibrator%20device.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20art%20Background%20partial%20concurrent%20mark%20sweep%20GC%20freed%20114531(3MB)%20AllocSpace%20objects%2C%203(60KB)%20LOS%20objects%2C%2033%25%20free%2C%205MB%2F8MB%2C%20paused%203.386ms%20total%20114.473ms%3CBR%20%2F%3EE%20486%20system%20SQLiteLog%20(1)%20no%20such%20table%3A%20locksettings%3CBR%20%2F%3EI%20486%20system%20LockSettingsService%20Migrated%20lock%20settings%20to%20new%20location%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20AssetAtlas%20Rendered%20atlas%20in%20109.12ms%20(41.27%2B67.84ms)%3CBR%20%2F%3EI%20486%20system%20LockSettingsService%20Migrated%20per-user%20lock%20settings%20to%20new%20location%3CBR%20%2F%3EI%20486%20system%20LockSettingsService%20Migrated%20biometric%20weak%20to%20use%20the%20fallback%20instead%3CBR%20%2F%3EI%20486%20system%20LockSettingsService%20Migrated%20lockscreen%20disabled%20flag%3CBR%20%2F%3EE%20486%20system%20LockSettingsStorage%20Cannot%20read%20file%20java.io.FileNotFoundException%3A%20%2Fdata%2Fsystem%2Fgatekeeper.password.key%3A%20open%20failed%3A%20ENOENT%20(No%20such%20file%20or%20directory)%3CBR%20%2F%3EE%20486%20system%20LockSettingsStorage%20Cannot%20read%20file%20java.io.FileNotFoundException%3A%20%2Fdata%2Fsystem%2Fpassword.key%3A%20open%20failed%3A%20ENOENT%20(No%20such%20file%20or%20directory)%3CBR%20%2F%3EE%20486%20system%20LockSettingsStorage%20Cannot%20read%20file%20java.io.FileNotFoundException%3A%20%2Fdata%2Fsystem%2Fgatekeeper.pattern.key%3A%20open%20failed%3A%20ENOENT%20(No%20such%20file%20or%20directory)%3CBR%20%2F%3EE%20486%20system%20LockSettingsStorage%20Cannot%20read%20file%20java.io.FileNotFoundException%3A%20%2Fdata%2Fsystem%2Fgatekeeper.gesture.key%3A%20open%20failed%3A%20ENOENT%20(No%20such%20file%20or%20directory)%3CBR%20%2F%3EE%20486%20system%20LockSettingsStorage%20Cannot%20read%20file%20java.io.FileNotFoundException%3A%20%2Fdata%2Fsystem%2Fgesture.key%3A%20open%20failed%3A%20ENOENT%20(No%20such%20file%20or%20directory)%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20phase%20480%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20phase%20500%3CBR%20%2F%3ED%20486%20system%20ConnectivityMetricsLoggerService%20onBootPhase%3A%20PHASE_SYSTEM_SERVICES_READY%3CBR%20%2F%3EI%20486%20system%20WifiService%20WifiService%20starting%20up%20with%20Wi-Fi%20disabled%3CBR%20%2F%3EI%20486%20system%20WifiScanningService%20Starting%20wifiscanner%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20RttService%20Registering%20rttmanager%3CBR%20%2F%3EI%20486%20system%20EthernetServiceImpl%20Starting%20Ethernet%20service%3CBR%20%2F%3ED%20486%20system%20Ethernet%20Registering%20NetworkFactory%3CBR%20%2F%3ED%20486%20system%20ConnectivityService%20Got%20NetworkFactory%20Messenger%20for%20Ethernet%3CBR%20%2F%3ED%20486%20system%20Ethernet%20got%20request%20NetworkRequest%20%5B%20REQUEST%20id%3D1%2C%20%5B%20Capabilities%3A%20INTERNET%26amp%3BNOT_RESTRICTED%26amp%3BTRUSTED%26amp%3BNOT_VPN%5D%20%5D%20with%20score%200%3CBR%20%2F%3ED%20486%20system%20EthernetNetworkFactory%20Started%20tracking%20interface%20eth0%3CBR%20%2F%3ED%20238%20%2Fsystem%2Fbin%2Fnetd%20CommandListener%20Setting%20iface%20cfg%3CBR%20%2F%3ED%20238%20%2Fsystem%2Fbin%2Fnetd%20CommandListener%20Trying%20to%20bring%20up%20eth0%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20ZenLog%20config%3A%20cleanUpZenRules%2CZenModeConfig%5Buser%3D0%2CallowCalls%3Dtrue%2CallowRepeatCallers%3Dfalse%2CallowMessages%3Dfalse%2CallowCallsFrom%3Dcontacts%2CallowMessagesFrom%3Dcontacts%2CallowReminders%3Dtrue%2CallowEvents%3Dtrue%2CallowWhenScreenOff%3Dtrue%2CallowWhenScreenOn%3Dtrue%2CautomaticRules%3D%7B52f7ad9de46840f68ab58fd3963db759%3DZenRule%5Benabled%3Dfalse%2Csnoozing%3Dfalse%2Cname%3DEvent%2CzenMode%3DZEN_MODE_ALARMS%2CconditionId%3Dcondition%3A%2F%2Fandroid%2Fevent%3FuserId%3D-10000%26amp%3Bcalendar%3D%26amp%3Breply%3D1%2Ccondition%3Dnull%2Ccomponent%3DComponentInfo%7Bandroid%2Fcom.android.server.notification.EventConditionProvider%7D%2Cid%3D52f7ad9de46840f68ab58fd3963db759%2CcreationTime%3D224631%2Cenabler%3Dnull%5D%2C%2047863810e54d4ba3a5eaf7b3dfc0b6d2%3DZenRule%5Benabled%3Dfalse%2Csnoozing%3Dfalse%2Cname%3DWeeknight%2CzenMode%3DZEN_MODE_ALARMS%2CconditionId%3Dcondition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D1.2.3.4.5%26amp%3Bstart%3D22.0%26amp%3Bend%3D7.0%26amp%3BexitAtAlarm%3Dfalse%2Ccondition%3Dnull%2Ccomponent%3DComponentInfo%7Bandroid%2Fcom.android.server.notification.ScheduleConditionProvider%7D%2Cid%3D47863810e54d4ba3a5eaf7b3dfc0b6d2%2CcreationTime%3D224629%2Cenabler%3Dnull%5D%2C%20115f643d6487490dbf893f006f26ae17%3DZenRule%5Benabled%3Dfalse%2Csnoozing%3Dfalse%2Cname%3DWeekend%2CzenMode%3DZEN_MODE_ALARMS%2CconditionId%3Dcondition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D6.7%26amp%3Bstart%3D23.30%26amp%3Bend%3D10.0%26amp%3BexitAtAlarm%3Dfalse%2Ccondition%3Dnull%2Ccomponent%3DComponentInfo%7Bandroid%2Fcom.android.server.notification.ScheduleConditionProvider%7D%2Cid%3D115f643d6487490dbf893f006f26ae17%2CcreationTime%3D224630%2Cenabler%3Dnull%5D%7D%2CmanualRule%3Dnull%5D%2CDiff%5B%5D%3CBR%20%2F%3ED%20486%20system%20ZenLog%20set_zen_mode%3A%20off%2ConSystemReady%3CBR%20%2F%3ED%20229%20%2Fsystem%2Fbin%2Faudioserver%20PermissionCache%20checking%20android.permission.CAPTURE_AUDIO_HOTWORD%20for%20uid%3D1000%20%3D%26gt%3B%20granted%20(322%20us)%3CBR%20%2F%3EW%20486%20system%20SoundTriggerHelper%20listModules%20status%3D0%2C%20%23%20of%20modules%3D0%3CBR%20%2F%3ED%20486%20system%20ContextHubSystemService%20onBootPhase%3A%20PHASE_SYSTEM_SERVICES_READY%3CBR%20%2F%3EI%20486%20system%20DefaultPermGrantPolicy%20Granting%20permissions%20to%20platform%20components%20for%20user%200%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B3%20volume%20remount_uid%201001%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%201001%20as%20mode%20none%3CBR%20%2F%3EW%20486%20system%20KeyguardServiceDelegate%20onScreenTurningOn()%3A%20no%20keyguard%20service!%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%203%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B4%20volume%20remount_uid%201001%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%201001%20as%20mode%20none%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%204%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B5%20volume%20remount_uid%201000%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%201000%20as%20mode%20none%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Found%20matching%20PID%20220%3CBR%20%2F%3EW%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Skipping%20due%20to%20root%20namespace%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Found%20matching%20PID%20221%3CBR%20%2F%3EW%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Skipping%20due%20to%20root%20namespace%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Found%20matching%20PID%20240%3CBR%20%2F%3EW%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Skipping%20due%20to%20root%20namespace%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Found%20matching%20PID%20486%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%205%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B6%20volume%20remount_uid%201000%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%201000%20as%20mode%20none%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Found%20matching%20PID%20220%3CBR%20%2F%3EW%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Skipping%20due%20to%20root%20namespace%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Found%20matching%20PID%20221%3CBR%20%2F%3EW%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Skipping%20due%20to%20root%20namespace%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Found%20matching%20PID%20240%3CBR%20%2F%3EW%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Skipping%20due%20to%20root%20namespace%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Found%20matching%20PID%20486%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%206%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B7%20volume%20remount_uid%202000%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%202000%20as%20mode%20none%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%207%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B8%20volume%20remount_uid%202000%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%202000%20as%20mode%20none%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%208%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B9%20volume%20remount_uid%2010026%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%2010026%20as%20mode%20none%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%209%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B10%20volume%20remount_uid%2010026%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%2010026%20as%20mode%20none%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%2010%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B11%20volume%20remount_uid%201002%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%201002%20as%20mode%20none%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%2011%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B12%20volume%20remount_uid%201002%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%201002%20as%20mode%20none%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%2012%20Command%20succeeded%7D%3CBR%20%2F%3EI%20486%20system%20DefaultPermGrantPolicy%20Granting%20permissions%20to%20default%20platform%20handlers%20for%20user%200%3CBR%20%2F%3EW%20486%20system%20VoiceInteractionManagerService%20no%20available%20voice%20interaction%20services%20found%20for%20user%200%3CBR%20%2F%3EW%20486%20system%20VoiceInteractionManagerService%20no%20available%20voice%20recognition%20services%20found%20for%20user%200%3CBR%20%2F%3EI%20486%20system%20SyncManager%20No%20initial%20accounts%3CBR%20%2F%3EI%20486%20system%20SyncManager%20No%20initial%20status%3CBR%20%2F%3EI%20486%20system%20SyncManager%20No%20initial%20statistics%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B13%20volume%20remount_uid%2010020%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%2010020%20as%20mode%20none%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%2013%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B14%20volume%20remount_uid%2010035%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%2010035%20as%20mode%20none%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%2014%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B15%20volume%20remount_uid%2010035%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%2010035%20as%20mode%20none%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%2015%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B16%20volume%20remount_uid%2010012%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%2010012%20as%20mode%20none%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%2016%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B17%20volume%20remount_uid%2010012%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%2010012%20as%20mode%20none%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%2017%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B18%20volume%20remount_uid%2010015%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%2010015%20as%20mode%20none%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%2018%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B19%20volume%20remount_uid%2010015%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%2010015%20as%20mode%20none%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%2019%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B20%20volume%20remount_uid%2010004%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%2010004%20as%20mode%20none%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%2020%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B21%20volume%20remount_uid%2010004%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%2010004%20as%20mode%20none%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%2021%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B22%20volume%20remount_uid%2010045%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%2010045%20as%20mode%20none%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%2022%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B23%20volume%20remount_uid%2010045%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%2010045%20as%20mode%20none%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%2023%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B24%20volume%20remount_uid%2010049%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%2010049%20as%20mode%20none%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%2024%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B25%20volume%20remount_uid%2010049%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%2010049%20as%20mode%20none%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%2025%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B26%20volume%20remount_uid%2010025%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%2010025%20as%20mode%20none%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%2026%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B27%20volume%20remount_uid%2010025%20none%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Remounting%2010025%20as%20mode%20none%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%2027%20Command%20succeeded%7D%3CBR%20%2F%3EV%20486%20system%20UserManagerService%20Found%20%2Fdata%2Fuser_de%2F0%20with%20serial%20number%20-1%3CBR%20%2F%3ED%20486%20system%20UserManagerService%20Serial%20number%20missing%20on%20%2Fdata%2Fuser_de%2F0%3B%20assuming%20current%20is%20valid%3CBR%20%2F%3EV%20486%20system%20UserManagerService%20Found%20%2Fdata%2Fuser%2F0%20with%20serial%20number%20-1%3CBR%20%2F%3ED%20486%20system%20UserManagerService%20Serial%20number%20missing%20on%20%2Fdata%2Fuser%2F0%3B%20assuming%20current%20is%20valid%3CBR%20%2F%3EV%20486%20system%20UserManagerService%20Found%20%2Fdata%2Fsystem_de%2F0%20with%20serial%20number%20-1%3CBR%20%2F%3ED%20486%20system%20UserManagerService%20Serial%20number%20missing%20on%20%2Fdata%2Fsystem_de%2F0%3B%20assuming%20current%20is%20valid%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20System%20now%20ready%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session%2C%20android.view.IWindow)%20for%20398ms%3CBR%20%2F%3EI%20486%20system%20SystemServer%20Making%20services%20ready%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20phase%20550%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Bluetooth%20boot%20completed%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Getting%20adapter%20name%20and%20address%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%20200%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20MESSAGE_GET_NAME_AND_ADDRESS%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Binding%20to%20service%20to%20get%20name%20and%20address%3CBR%20%2F%3EI%20486%20system%20Zygote%20Process%3A%20zygote%20socket%20opened%2C%20supported%20ABIS%3A%20armeabi-v7a%2Carmeabi%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201014%3Acom.android.bluetooth%2F1002%20for%20service%20com.android.bluetooth%2F.btservice.AdapterService%3CBR%20%2F%3EE%20486%20system%20InputMethodManagerService%20Ignoring%20updateSystemUiLocked%20due%20to%20an%20invalid%20token.%20uid%3A1000%20token%3Anull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20MountService%20No%20primary%20storage%20defined%20yet%3B%20hacking%20together%20a%20stub%3CBR%20%2F%3ED%201014%20AdapterServiceConfig%20Adding%20HeadsetService%3CBR%20%2F%3ED%201014%20AdapterServiceConfig%20Adding%20A2dpService%3CBR%20%2F%3ED%201014%20AdapterServiceConfig%20Adding%20A2dpSinkService%3CBR%20%2F%3ED%201014%20AdapterServiceConfig%20Adding%20HidService%3CBR%20%2F%3ED%201014%20AdapterServiceConfig%20Adding%20HealthService%3CBR%20%2F%3ED%201014%20AdapterServiceConfig%20Adding%20PanService%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%201014%20AdapterServiceConfig%20Adding%20GattService%3CBR%20%2F%3ED%201014%20AdapterServiceConfig%20Adding%20BluetoothMapService%3CBR%20%2F%3ED%201014%20AdapterServiceConfig%20Adding%20AvrcpControllerService%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%2020%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Added%20callback%3A%20android.bluetooth.IBluetoothManagerCallback%24Stub%24Proxy%40ce40445%3Atrue%3CBR%20%2F%3ED%201014%20com.android.bluetooth%20BluetoothAdapterService%20onCreate()%3CBR%20%2F%3ED%201014%20com.android.bluetooth%20BluetoothAdapterState%20make()%20-%20Creating%20AdapterState%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_btif%20init%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20BluetoothAdapterState%20Entering%20OffState%3CBR%20%2F%3EW%201014%20com.android.bluetooth%20bt_osi_thread%20run_thread%3A%20thread%20id%201033%2C%20thread%20name%20stack_manager%20started%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_stack_manager%20event_init_stack%20is%20initializing%20the%20stack%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_core_module%20module_init%20Initializing%20module%20%22osi_module%22%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_core_module%20module_init%20Initialized%20module%20%22osi_module%22%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_core_module%20module_init%20Initializing%20module%20%22bt_utils_module%22%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_core_module%20module_init%20Initialized%20module%20%22bt_utils_module%22%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_core_module%20module_init%20Initializing%20module%20%22btif_config_module%22%3CBR%20%2F%3EE%201014%20com.android.bluetooth%20bt_osi_config%20config_new%20unable%20to%20open%20file%20'%2Fdata%2Fmisc%2Fbluedroid%2Fbt_config.conf'%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3EW%201014%20com.android.bluetooth%20%25s%20unable%20to%20load%20config%20file%3A%20%25s%3B%20using%20backup.%20init%3CBR%20%2F%3EE%201014%20com.android.bluetooth%20bt_osi_config%20config_new%20unable%20to%20open%20file%20'%2Fdata%2Fmisc%2Fbluedroid%2Fbt_config.bak'%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3EW%201014%20com.android.bluetooth%20%25s%20unable%20to%20load%20backup%3B%20attempting%20to%20transcode%20legacy%20file.%20init%3CBR%20%2F%3EE%201014%20com.android.bluetooth%20%25s%20unable%20to%20load%20XML%20file%20'%25s'%3A%20%25d%20config_t%20*btif_config_transcode(const%20char%20*)%3CBR%20%2F%3EE%201014%20com.android.bluetooth%20%25s%20unable%20to%20transcode%20legacy%20file%3B%20creating%20empty%20config.%20init%3CBR%20%2F%3EW%201014%20com.android.bluetooth%20bt_osi_thread%20run_thread%3A%20thread%20id%201036%2C%20thread%20name%20alarm_default_ca%20started%3CBR%20%2F%3EW%201014%20com.android.bluetooth%20bt_osi_thread%20run_thread%3A%20thread%20id%201037%2C%20thread%20name%20alarm_dispatcher%20started%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_core_module%20module_init%20Initialized%20module%20%22btif_config_module%22%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_core_module%20module_init%20Initializing%20module%20%22interop_module%22%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_core_module%20module_init%20Initialized%20module%20%22interop_module%22%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_core_module%20module_init%20Initializing%20module%20%22stack_config_module%22%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_stack_config%20init%20attempt%20to%20load%20stack%20conf%20from%20%2Fetc%2Fbluetooth%2Fbt_stack.conf%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_core_module%20module_init%20Initialized%20module%20%22stack_config_module%22%3CBR%20%2F%3EW%201014%20com.android.bluetooth%20bt_osi_thread%20run_thread%3A%20thread%20id%201038%2C%20thread%20name%20bt_jni_workqueue%20started%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_stack_manager%20event_init_stack%20finished%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_osi_wakelock%20wakelock_set_os_callouts%20set%20to%20non-native%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_btif%20get_profile_interface%20socket%3CBR%20%2F%3ED%201014%20com.android.bluetooth%20BluetoothAdapterProperties%20Address%20is%3A22%3A22%3A51%3A75%3A5E%3A58%3CBR%20%2F%3ED%201014%20com.android.bluetooth%20BluetoothAdapterProperties%20Name%20is%3A%20iMX6%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_btif%20get_profile_interface%20sdp%3CBR%20%2F%3ED%201014%20com.android.bluetooth%20BluetoothAdapterService%20setAdapterService()%20-%20set%20to%3A%20null%3CBR%20%2F%3ED%201014%20com.android.bluetooth%20BluetoothAdapterService%20onBind()%3CBR%20%2F%3EW%20486%20system%20WindowManager%20Keyguard%20drawn%20timeout.%20Setting%20mKeyguardDrawComplete%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService%24LocalService.setOnHardKeyboardStatusChangeListener(android.view.WindowManagerInternal%24OnHardKeyboardStatusChangeListener)%20for%20476ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20InputMethodManagerService%20Reset%20the%20default%20IME%20as%20%22Resource%22%20is%20ready%20here.%3CBR%20%2F%3EI%20486%20system%20InputMethodManagerService%20Default%20found%2C%20using%20com.android.inputmethod.latin%2F.LatinIME%3CBR%20%2F%3EW%20486%20system%20InputMethodManagerService%20Illegal%20subtype%20state%3A%20old%20subtype%20%3D%20null%2C%20new%20subtype%20%3D%20android.view.inputmethod.InputMethodSubtype%40c9194f98%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201039%3Acom.android.inputmethod.latin%2Fu0a47%20for%20service%20com.android.inputmethod.latin%2F.LatinIME%3CBR%20%2F%3EV%20486%20system%20InputMethodManagerService%20Adding%20window%20token%3A%20android.os.Binder%40cb76fd%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201039%20LatinIME%20Hardware%20accelerated%20drawing%3A%20true%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowManagerService.showStrictModeViolation(int%2C%20int)(WindowManagerService.java%3A6257)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.addWindowToken(android.os.IBinder%2C%20int)%20for%20368ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20EthernetNetworkFactory%20updateInterface%3A%20eth0%20link%20up%3CBR%20%2F%3ED%20486%20system%20EthernetNetworkFactory%20starting%20ipProvisioningThread(eth0)%3A%20mNetworkInfo%3D%5Btype%3A%20Ethernet%5B%5D%2C%20state%3A%20UNKNOWN%2FIDLE%2C%20reason%3A%20(unspecified)%2C%20extra%3A%20b6%3Ad9%3A69%3A8f%3A41%3A44%2C%20failover%3A%20false%2C%20available%3A%20true%2C%20roaming%3A%20false%2C%20metered%3A%20false%5D%3CBR%20%2F%3ED%20238%20%2Fsystem%2Fbin%2Fnetd%20CommandListener%20Clearing%20all%20IP%20addresses%20on%20eth0%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20DhcpClient%20Receive%20thread%20started%3CBR%20%2F%3ED%20486%20system%20DhcpClient%20Broadcasting%20DHCPDISCOVER%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowManagerService%24H.handleMessage(android.os.Message)(WindowManagerService.java%3A8361)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.addWindowToken(android.os.IBinder%2C%20int)%20for%20535ms%3CBR%20%2F%3ED%20486%20system%20MountService%20Thinking%20about%20init%2C%20mSystemReady%3Dtrue%2C%20mDaemonConnected%3Dtrue%3CBR%20%2F%3EW%20486%20system%20WindowManager%20Timeout%20waiting%20for%20drawn%3A%20undrawn%3D%5BWindow%7Bdb0591e%20u0%20KeyguardScrim%7D%5D%3CBR%20%2F%3ED%20486%20system%20MountService%20Setting%20up%20emulation%20state%2C%20initlocked%3Dfalse%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20main%20(486)%20at%20void%20com.android.server.wm.WindowManagerService.addWindowToken(android.os.IBinder%2C%20int)(WindowManagerService.java%3A3434)%20waiters%3D0%20in%20java.util.List%20com.android.server.InputMethodManagerService.getInputMethodList()%20for%20780ms%3CBR%20%2F%3ED%20486%20system%20CryptdConnector%20SND%20-%26gt%3B%20%7B2%20cryptfs%20unlock_user_key%200%200%20!%20!%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20e4crypt_unlock_user_key%200%20serial%3D0%20token_present%3D0%3CBR%20%2F%3EE%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Failed%20to%20chmod%20%2Fdata%2Fsystem_ce%2F0%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3EE%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Failed%20to%20chmod%20%2Fdata%2Fmisc_ce%2F0%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3EE%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Failed%20to%20chmod%20%2Fdata%2Fmedia%2F0%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3ED%20486%20system%20CryptdConnector%20RCV%20%26lt%3B-%20%7B200%202%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20MountService%20Thinking%20about%20reset%2C%20mSystemReady%3Dtrue%2C%20mDaemonConnected%3Dtrue%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B28%20volume%20reset%7D%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Force%20stopping%20com.android.providers.media%20appid%3D10012%20user%3D-1%3A%20vold%20reset%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B651%20emulated%207%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B659%20emulated%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B650%20emulated%202%20%22%22%20%22%22%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B651%20emulated%200%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%2028%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B29%20volume%20user_added%200%200%7D%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%2020%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Added%20callback%3A%20android.bluetooth.BluetoothAdapter%241%4058b8595%3Atrue%3CBR%20%2F%3EV%20486%20system%20MountService%20Found%20primary%20storage%20at%20VolumeInfo%7Bemulated%7D%3A%3CBR%20%2F%3EV%20486%20system%20MountService%20type%3DEMULATED%20diskId%3Dnull%20partGuid%3Dnull%20mountFlags%3D0%20mountUserId%3D-1%3CBR%20%2F%3EV%20486%20system%20MountService%20state%3DUNMOUNTED%3CBR%20%2F%3EV%20486%20system%20MountService%20fsType%3Dnull%20fsUuid%3Dnull%20fsLabel%3Dnull%3CBR%20%2F%3EV%20486%20system%20MountService%20path%3Dnull%20internalPath%3Dnull%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%2030%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%2029%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Trying%20to%20bind%20to%20profile%3A%201%2C%20while%20Bluetooth%20was%20disabled%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B30%20volume%20mount%20emulated%203%20-1%7D%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%2030%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B651%20emulated%201%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B656%20emulated%20%2Fdata%2Fmedia%7D%3CBR%20%2F%3EV%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Waiting%20for%20FUSE%20to%20spin%20up...%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B655%20emulated%20%2Fstorage%2Femulated%7D%3CBR%20%2F%3EI%20486%20system%20SystemServer%20WebViewFactory%20preparation%3CBR%20%2F%3EI%20229%20%2Fsystem%2Fbin%2Faudioserver%20AudioFlinger%20systemReady%3CBR%20%2F%3ED%20486%20system%20WebViewFactory%20Setting%20new%20address%20space%20to%20104857600%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201063%20sdcard%20Device%20explicitly%20disabled%20sdcardfs%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B651%20emulated%202%7D%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%2030%20Command%20succeeded%7D%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201072%3AWebViewLoader-armeabi-v7a%2F1037%20%5Bandroid.webkit.WebViewFactory%24RelroFileCreator%5D%20for%3CBR%20%2F%3EE%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.streaming.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201080%3Acom.android.systemui%2Fu0a26%20for%20service%20com.android.systemui%2F.SystemUIService%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20NetworkManagement%20enabling%20bandwidth%20control%3CBR%20%2F%3EE%20234%20media.codec%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20234%20media.codec%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20234%20media.codec%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20234%20media.codec%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20234%20media.codec%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20234%20media.codec%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20234%20media.codec%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20234%20media.codec%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20234%20media.codec%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20234%20media.codec%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20234%20media.codec%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20234%20media.codec%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20234%20media.codec%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.streaming.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EE%20234%20media.codec%20OMXMaster%20A%20component%20of%20name%20'OMX.Freescale.std.parser.fsl.sw-based'%20already%20exists%2C%20ignoring%20this%20one.%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.gsm.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EV%201072%20der%20WebViewFactory%20RelroFileCreator%20(64bit%20%3D%20false)%2C%2032-bit%20lib%3A%20%2Fsystem%2Fapp%2Fwebview%2Fwebview.apk!%2Flib%2Farmeabi-v7a%2Flibwebviewchromium.so%2C%2064-bit%20lib%3A%3CBR%20%2F%3EW%201080%20com.android.systemui%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fpriv-app%2FSystemUI%2Flib%2Farm%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EV%201080%20com.android.systemui%20SystemUIService%20Starting%20SystemUI%20services%20for%20user%200.%3CBR%20%2F%3EI%201072%20der%20art%20System.exit%20called%2C%20status%3A%200%3CBR%20%2F%3EI%201072%20der%20AndroidRuntime%20VM%20exiting%20with%20result%20code%200%2C%20cleanup%20skipped.%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.video_encoder.mpeg4.hw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20NetworkManagement%20setDataSaverMode()%3A%20already%20false%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EV%201080%20com.android.systemui%20MediaRouter%20Adding%20route%3A%20RouteInfo%7B%20name%3DTablet%2C%20description%3Dnull%2C%20status%3Dnull%2C%20category%3DRouteCategory%7B%20name%3Dnull%20types%3DROUTE_TYPE_LIVE_AUDIO%20ROUTE_TYPE_LIVE_VIDEO%20groupable%3Dfalse%20%7D%2C%20supportedTypes%3DROUTE_TYPE_LIVE_AUDIO%20ROUTE_TYPE_LIVE_VIDEO%20%2C%20presentationDisplay%3Dnull%20%7D%3CBR%20%2F%3EW%201039%20com.android.inputmethod.latin%20InputAttributes%20No%20editor%20info%20for%20this%20field.%20Bug%3F%3CBR%20%2F%3EV%201080%20com.android.systemui%20MediaRouter%20Updating%20audio%20routes%3A%20AudioRoutesInfo%7B%20type%3DSPEAKER%20%7D%3CBR%20%2F%3EI%20234%20media.codec%20vpu-lib%20Product%20Info%3A%20i.MX6Q%2FD%2FS%3CBR%20%2F%3EV%201080%20com.android.systemui%20MediaRouter%20Selecting%20route%3A%20RouteInfo%7B%20name%3DTablet%2C%20description%3Dnull%2C%20status%3Dnull%2C%20category%3DRouteCategory%7B%20name%3Dnull%20types%3DROUTE_TYPE_LIVE_AUDIO%20ROUTE_TYPE_LIVE_VIDEO%20groupable%3Dfalse%20%7D%2C%20supportedTypes%3DROUTE_TYPE_LIVE_AUDIO%20ROUTE_TYPE_LIVE_VIDEO%20%2C%20presentationDisplay%3Dnull%20%7D%3CBR%20%2F%3EW%20237%20%2Fsystem%2Fbin%2Fmediaserver%20ACodec%20do%20not%20know%20color%20format%200x7f000789%20%3D%202130708361%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20GetConfig%20LINE%3A%201828%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20GetConfig%3A%20failure%3A%20unsupported%20index%3A%200x6F60000A%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getConfig(ea0002%3AFreescale.std._encoder.mpeg4.hw-based%2C%20ConfigAndroidIntraRefresh(0x6f60000a))%20ERROR%3A%20UnsupportedIndex(0x8000101a)%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20DeInitFilterComponent%20LINE%3A%202003%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20DeInitFilterComponent%3A%20vpu%20close%20failure%3A%20ret%3D0x3%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.video_encoder.h263.hw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20LatinIME%3ALogUtils%20Dictionary%20info%3A%20dictionary%20%3D%20userunigram.en_US%20%3B%20version%20%3D%20228%20%3B%20date%20%3D%20%3F%3CBR%20%2F%3EE%201039%20com.android.inputmethod.latin%20ActivityThread%20Failed%20to%20find%20provider%20info%20for%20user_dictionary%3CBR%20%2F%3EV%201080%20com.android.systemui%20FingerprintManager%20FingerprintManagerService%20was%20null%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20LatinIME%3ALogUtils%20Dictionary%20info%3A%20dictionary%20%3D%20UserHistoryDictionary.en_US%20%3B%20version%20%3D%20228%20%3B%20date%20%3D%20%3F%3CBR%20%2F%3EW%201080%20com.android.systemui%20FingerprintManager%20isFingerprintHardwareDetected()%3A%20Service%20not%20connected!%3CBR%20%2F%3EW%201080%20com.android.systemui%20FingerprintManager%20addLockoutResetCallback()%3A%20Service%20not%20connected!%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20NetworkPolicy%20setRestrictBackgroundUL()%3A%20false%3CBR%20%2F%3EW%20486%20system%20NetworkManagement%20setDataSaverMode()%3A%20already%20false%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20234%20media.codec%20vpu-lib%20Product%20Info%3A%20i.MX6Q%2FD%2FS%3CBR%20%2F%3EW%20237%20%2Fsystem%2Fbin%2Fmediaserver%20ACodec%20do%20not%20know%20color%20format%200x7f000789%20%3D%202130708361%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20GetConfig%20LINE%3A%201828%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20GetConfig%3A%20failure%3A%20unsupported%20index%3A%200x6F60000A%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getConfig(ea0003%3AFreescale.std._encoder.h263.hw-based%2C%20ConfigAndroidIntraRefresh(0x6f60000a))%20ERROR%3A%20UnsupportedIndex(0x8000101a)%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20DeInitFilterComponent%20LINE%3A%202003%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20DeInitFilterComponent%3A%20vpu%20close%20failure%3A%20ret%3D0x3%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.video_encoder.avc.hw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20BinaryDictionaryFileDumper%20reinitializeClientRecordInDictionaryContentProvider()%20%3A%20MetadataFileUri%20%3D%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201080%20com.android.systemui%20vol.Events%20writeEvent%20collection_started%3CBR%20%2F%3EI%201080%20com.android.systemui%20vol.Events%20writeEvent%20external_ringer_mode_changed%20normal%3CBR%20%2F%3EI%201080%20com.android.systemui%20vol.Events%20writeEvent%20internal_ringer_mode_changed%20normal%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20phase%20600%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20234%20media.codec%20vpu-lib%20Product%20Info%3A%20i.MX6Q%2FD%2FS%3CBR%20%2F%3EW%20237%20%2Fsystem%2Fbin%2Fmediaserver%20ACodec%20do%20not%20know%20color%20format%200x7f000789%20%3D%202130708361%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20GetConfig%20LINE%3A%201828%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20GetConfig%3A%20failure%3A%20unsupported%20index%3A%200x6F60000A%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getConfig(ea0004%3AFreescale.std._encoder.avc.hw-based%2C%20ConfigAndroidIntraRefresh(0x6f60000a))%20ERROR%3A%20UnsupportedIndex(0x8000101a)%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20DeInitFilterComponent%20LINE%3A%202003%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20DeInitFilterComponent%3A%20vpu%20close%20failure%3A%20ret%3D0x3%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.video_decoder.avc.v3.hw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20LatinIME%3ALogUtils%20Dictionary%20info%3A%20dictionary%20%3D%20main%3Ade%20%3B%20version%20%3D%2054%20%3B%20date%20%3D%201414726263%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20LatinIME%3ALogUtils%20Dictionary%20info%3A%20dictionary%20%3D%20main%3Aen%20%3B%20version%20%3D%2054%20%3B%20date%20%3D%201414726273%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20LatinIME%3ALogUtils%20Dictionary%20info%3A%20dictionary%20%3D%20main%3Aes%20%3B%20version%20%3D%2054%20%3B%20date%20%3D%201414726268%3CBR%20%2F%3ED%20486%20system%20SensorNotificationService%20Cannot%20obtain%20dynamic%20meta%20sensor%2C%20not%20supported.%3CBR%20%2F%3EI%20486%20system%20CameraManagerGlobal%20Connecting%20to%20camera%20service%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20LatinIME%3ALogUtils%20Dictionary%20info%3A%20dictionary%20%3D%20main%3Afr%20%3B%20version%20%3D%2054%20%3B%20date%20%3D%201414726264%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20LocationManagerService%20no%20network%20location%20provider%20found%3CBR%20%2F%3EE%20486%20system%20LocationManagerService%20no%20geocoder%20provider%20found%3CBR%20%2F%3EE%20486%20system%20FlpHardwareProvider%20Error%20hw_get_module%20'flp'%3A%20-2%3CBR%20%2F%3ED%20486%20system%20LocationManagerService%20FLP%20HAL%20not%20supported%3CBR%20%2F%3ED%20486%20system%20LocationManagerService%20Unable%20to%20bind%20FLP%20Geofence%20proxy.%3CBR%20%2F%3EE%20486%20system%20ActivityRecognitionHardware%20Error%20hw_get_module%3A%20-2%3CBR%20%2F%3ED%20486%20system%20LocationManagerService%20Hardware%20Activity-Recognition%20not%20supported.%3CBR%20%2F%3EE%20486%20system%20ActivityRecognitionProxy%20ServiceWatcher%20could%20not%20start.%3CBR%20%2F%3ED%20486%20system%20LocationManagerService%20Unable%20to%20bind%20ActivityRecognitionProxy.%3CBR%20%2F%3EI%20486%20system%20CommonTimeManagementService%20No%20common%20time%20service%20detected%20on%20this%20platform.%20Common%20time%20services%20will%20be%20unavailable.%3CBR%20%2F%3EI%20486%20system%20InputReader%20Reconfiguring%20input%20devices.%20changes%3D0x00000020%3CBR%20%2F%3EI%20486%20system%20MmsServiceBroker%20Delay%20connecting%20to%20MmsService%20until%20an%20API%20is%20called%3CBR%20%2F%3EW%20486%20system%20VoiceInteractionManagerService%20no%20available%20voice%20interaction%20services%20found%20for%20user%200%3CBR%20%2F%3EW%20486%20system%20VoiceInteractionManagerService%20no%20available%20voice%20recognition%20services%20found%20for%20user%200%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20LatinIME%3ALogUtils%20Dictionary%20info%3A%20dictionary%20%3D%20main%3Ait%20%3B%20version%20%3D%2054%20%3B%20date%20%3D%201414726258%3CBR%20%2F%3EI%20486%20system%20InputReader%20Reconfiguring%20input%20devices.%20changes%3D0x00000010%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201149%3Acom.android.phone%2F1001%20for%20added%20application%20com.android.phone%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20START%20u0%20%7Bact%3Dandroid.intent.action.MAIN%20cat%3D%5Bandroid.intent.category.HOME%5D%20flg%3D0x10000100%20cmp%3Dcom.android.settings%2F.CryptKeeper%7D%20from%20uid%200%20on%20display%200%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Loaded%20persisted%20task%20ids%20for%20user%200%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20DhcpClient%20Received%20packet%3A%20b6%3Ad9%3A69%3A8f%3A41%3A44%20OFFER%2C%20ip%20%2F192.168.10.226%2C%20mask%20%2F255.255.0.0%2C%20DNS%20servers%3A%20%2F203.248.252.2%20%2F164.124.101.2%20%2C%20gateways%20%5B%2F192.168.10.1%5D%20lease%20time%20604800%2C%20domain%20null%3CBR%20%2F%3ED%20486%20system%20DhcpClient%20Got%20pending%20lease%3A%20IP%20address%20192.168.10.226%2F16%20Gateway%20192.168.10.1%20DNS%20servers%3A%20%5B%20203.248.252.2%20164.124.101.2%20%5D%20Domains%20DHCP%20server%20%2F192.168.10.1%20Vendor%20info%20null%20lease%20604800%20seconds%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201163%3Acom.android.settings%3ACryptKeeper%2F1000%20for%20activity%20com.android.settings%2F.CryptKeeper%3CBR%20%2F%3EI%20486%20system%20SystemServer%20Enabled%20StrictMode%20for%20system%20server%20main%20thread.%3CBR%20%2F%3ED%20486%20system%20DhcpClient%20Broadcasting%20DHCPREQUEST%20ciaddr%3D0.0.0.0%20request%3D192.168.10.226%20serverid%3D192.168.10.1%3CBR%20%2F%3EW%20237%20%2Fsystem%2Fbin%2Fmediaserver%20ACodec%20%5BOMX.Freescale.std.video_decoder.avc.v3.hw-based%5D%20stopping%20checking%20profiles%20after%2032%3A%208%2F1%3CBR%20%2F%3ED%20486%20system%20ConditionProviders.SCP%20onConnected%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getExtensionIndex(ea0005%3AFreescale.std._decoder.avc.v3.hw-based%2C%20OMX.google.android.index.configureVideoTunnelMode)%20ERROR%3A%20NotImplemented(0x80001006)%3CBR%20%2F%3EW%20234%20media.codec%20OMXNodeInstance%20%5Bea0005%3AFreescale.std._decoder.avc.v3.hw-based%5D%20component%20does%20not%20support%20metadata%20mode%3B%20using%20fallback%3CBR%20%2F%3ED%20486%20system%20DhcpClient%20Received%20packet%3A%20b6%3Ad9%3A69%3A8f%3A41%3A44%20ACK%3A%20your%20new%20IP%20%2F192.168.10.226%2C%20netmask%20%2F255.255.0.0%2C%20gateways%20%5B%2F192.168.10.1%5D%20DNS%20servers%3A%20%2F203.248.252.2%20%2F164.124.101.2%20%2C%20lease%20time%20604800%3CBR%20%2F%3ED%20486%20system%20DhcpClient%20Confirmed%20lease%3A%20IP%20address%20192.168.10.226%2F16%20Gateway%20192.168.10.1%20DNS%20servers%3A%20%5B%20203.248.252.2%20164.124.101.2%20%5D%20Domains%20DHCP%20server%20%2F192.168.10.1%20Vendor%20info%20null%20lease%20604800%20seconds%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.video_decoder.mpeg4.hw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20238%20%2Fsystem%2Fbin%2Fnetd%20CommandListener%20Setting%20iface%20cfg%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20LatinIME%3ALogUtils%20Dictionary%20info%3A%20dictionary%20%3D%20main%3Aru%20%3B%20version%20%3D%2054%20%3B%20date%20%3D%201414726277%3CBR%20%2F%3EW%201149%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fpriv-app%2FTeleService%2Flib%2Farm%3CBR%20%2F%3ED%20486%20system%20RttService%20SCAN_AVAILABLE%20%3A%201%3CBR%20%2F%3EI%20486%20system%20WifiScanningService%20wifi%20driver%20unloaded%3CBR%20%2F%3ED%20486%20system%20ZenLog%20set_zen_mode%3A%20off%2CcleanUpZenRules%3CBR%20%2F%3ED%20486%20system%20RttService%20DefaultState%20got%7B%20when%3D0%20what%3D160513%20target%3Dcom.android.internal.util.StateMachine%24SmHandler%20%7D%3CBR%20%2F%3ED%20486%20system%20ConditionProviders%20Subscribing%20to%20condition%3A%2F%2Fandroid%2Fevent%3FuserId%3D-10000%26amp%3Bcalendar%3D%26amp%3Breply%3D1%20with%20ComponentInfo%7Bandroid%2Fcom.android.server.notification.EventConditionProvider%7D%3CBR%20%2F%3ED%20486%20system%20ZenLog%20subscribe%3A%20condition%3A%2F%2Fandroid%2Fevent%3FuserId%3D-10000%26amp%3Bcalendar%3D%26amp%3Breply%3D1%2Cok%3CBR%20%2F%3ED%20486%20system%20ConditionProviders%20Subscribing%20to%20condition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D1.2.3.4.5%26amp%3Bstart%3D22.0%26amp%3Bend%3D7.0%26amp%3BexitAtAlarm%3Dfalse%20with%20ComponentInfo%7Bandroid%2Fcom.android.server.notification.ScheduleConditionProvider%7D%3CBR%20%2F%3ED%20486%20system%20ZenLog%20subscribe%3A%20condition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D1.2.3.4.5%26amp%3Bstart%3D22.0%26amp%3Bend%3D7.0%26amp%3BexitAtAlarm%3Dfalse%2Cok%3CBR%20%2F%3ED%20486%20system%20ConditionProviders%20Subscribing%20to%20condition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D6.7%26amp%3Bstart%3D23.30%26amp%3Bend%3D10.0%26amp%3BexitAtAlarm%3Dfalse%20with%20ComponentInfo%7Bandroid%2Fcom.android.server.notification.ScheduleConditionProvider%7D%3CBR%20%2F%3ED%20486%20system%20ZenLog%20subscribe%3A%20condition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D6.7%26amp%3Bstart%3D23.30%26amp%3Bend%3D10.0%26amp%3BexitAtAlarm%3Dfalse%2Cok%3CBR%20%2F%3ED%20486%20system%20ConnectivityService%20registerNetworkAgent%20NetworkAgentInfo%7B%20ni%7B%5Btype%3A%20Ethernet%5B%5D%2C%20state%3A%20CONNECTED%2FCONNECTED%2C%20reason%3A%20(unspecified)%2C%20extra%3A%20b6%3Ad9%3A69%3A8f%3A41%3A44%2C%20failover%3A%20false%2C%20available%3A%20true%2C%20roaming%3A%20false%2C%20metered%3A%20false%5D%7D%20network%7B100%7D%20nethandle%7B429513165534%7D%20lp%7B%7BInterfaceName%3A%20eth0%20LinkAddresses%3A%20%5Bfe80%3A%3Ab4d9%3A69ff%3Afe8f%3A4144%2F64%2C192.168.10.226%2F16%2C%5D%20Routes%3A%20%5Bfe80%3A%3A%2F64%20-%26gt%3B%20%3A%3A%20eth0%2C192.168.0.0%2F16%20-%26gt%3B%200.0.0.0%20eth0%2C0.0.0.0%2F0%20-%26gt%3B%20192.168.10.1%20eth0%2C%5D%20DnsAddresses%3A%20%5B203.248.252.2%2C164.124.101.2%2C%5D%20Domains%3A%20null%20MTU%3A%200%20TcpBufferSizes%3A%20524288%2C1048576%2C3145728%2C524288%2C1048576%2C2097152%7D%7D%20nc%7B%5B%20Transports%3A%20ETHERNET%20Capabilities%3A%20INTERNET%26amp%3BNOT_RESTRICTED%26amp%3BTRUSTED%26amp%3BNOT_VPN%20LinkUpBandwidth%26gt%3B%3D100000Kbps%20LinkDnBandwidth%26gt%3B%3D100000Kbps%5D%7D%20Score%7B110%7D%20everValidated%7Bfalse%7D%20lastValidated%7Bfalse%7D%20created%7Bfalse%7D%20lingering%7Bfalse%7D%20explicitlySelected%7Bfalse%7D%20acceptUnvalidated%7Bfalse%7D%20everCaptivePortalDetected%7Bfalse%7D%20lastCaptivePortalDetected%7Bfalse%7D%20%7D%3CBR%20%2F%3ED%20486%20system%20EthernetNetworkFactory%20exiting%20ipProvisioningThread(eth0)%3A%20mNetworkInfo%3D%5Btype%3A%20Ethernet%5B%5D%2C%20state%3A%20CONNECTED%2FCONNECTED%2C%20reason%3A%20(unspecified)%2C%20extra%3A%20b6%3Ad9%3A69%3A8f%3A41%3A44%2C%20failover%3A%20false%2C%20available%3A%20true%2C%20roaming%3A%20false%2C%20metered%3A%20false%5D%3CBR%20%2F%3ED%20486%20system%20ConnectivityService%20NetworkAgentInfo%20%5BEthernet%20()%20-%20100%5D%20EVENT_NETWORK_INFO_CHANGED%2C%20going%20from%20null%20to%20CONNECTED%3CBR%20%2F%3ED%20486%20system%20ConnectivityService%20Adding%20iface%20eth0%20to%20network%20100%3CBR%20%2F%3EI%20486%20system%20art%20Background%20sticky%20concurrent%20mark%20sweep%20GC%20freed%2043462(2MB)%20AllocSpace%20objects%2C%2011(232KB)%20LOS%20objects%2C%2035%25%20free%2C%205MB%2F8MB%2C%20paused%2010.176ms%20total%20135.237ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20BinaryDictionaryFileDumper%20reinitializeClientRecordInDictionaryContentProvider()%20%3A%20Insert%20DictionaryInfo%20%3A%20Id%20%3D%20'main%3Ade'%20%3A%20Locale%3Dde%20%3A%20Version%3D54%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%20100%3CBR%20%2F%3EE%20486%20system%20BluetoothManagerService%20MESSAGE_TIMEOUT_BIND%3CBR%20%2F%3ED%20486%20system%20ConnectivityService%20Setting%20DNS%20servers%20for%20network%20100%20to%20%5B%2F203.248.252.2%2C%20%2F164.124.101.2%5D%3CBR%20%2F%3EI%20486%20system%20AccountManagerService%20Creating%20DE%20database%20for%20user%200%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getExtensionIndex(ea0006%3AFreescale.std._decoder.mpeg4.hw-based%2C%20OMX.google.android.index.configureVideoTunnelMode)%20ERROR%3A%20NotImplemented(0x80001006)%3CBR%20%2F%3EW%20234%20media.codec%20OMXNodeInstance%20%5Bea0006%3AFreescale.std._decoder.mpeg4.hw-based%5D%20component%20does%20not%20support%20metadata%20mode%3B%20using%20fallback%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.video_decoder.h263.hw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3ED%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20PermissionCache%20checking%20android.permission.READ_FRAME_BUFFER%20for%20uid%3D1000%20%3D%26gt%3B%20granted%20(3193%20us)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20ContextImpl%20Calling%20a%20method%20in%20the%20system%20process%20without%20a%20qualified%20user%3A%20android.app.ContextImpl.startService%3A1357%20com.android.server.content.SyncManager%2413.run%3A658%20android.os.Handler.handleCallback%3A751%20android.os.Handler.dispatchMessage%3A95%20android.os.Looper.loop%3A154%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getExtensionIndex(ea0007%3AFreescale.std._decoder.h263.hw-based%2C%20OMX.google.android.index.configureVideoTunnelMode)%20ERROR%3A%20NotImplemented(0x80001006)%3CBR%20%2F%3EW%20234%20media.codec%20OMXNodeInstance%20%5Bea0007%3AFreescale.std._decoder.h263.hw-based%5D%20component%20does%20not%20support%20metadata%20mode%3B%20using%20fallback%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.video_decoder.mpeg2.hw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getExtensionIndex(ea0008%3AFreescale.std._decoder.mpeg2.hw-based%2C%20OMX.google.android.index.configureVideoTunnelMode)%20ERROR%3A%20NotImplemented(0x80001006)%3CBR%20%2F%3EW%20234%20media.codec%20OMXNodeInstance%20%5Bea0008%3AFreescale.std._decoder.mpeg2.hw-based%5D%20component%20does%20not%20support%20metadata%20mode%3B%20using%20fallback%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.video_decoder.vpx.hw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getParameter(ea0009%3AFreescale.std._decoder.vpx.hw-based%2C%20ParamVideoProfileLevelQuerySupported(0x600000f))%20ERROR%3A%20UnsupportedIndex(0x8000101a)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getExtensionIndex(ea0009%3AFreescale.std._decoder.vpx.hw-based%2C%20OMX.google.android.index.configureVideoTunnelMode)%20ERROR%3A%20NotImplemented(0x80001006)%3CBR%20%2F%3EW%20234%20media.codec%20OMXNodeInstance%20%5Bea0009%3AFreescale.std._decoder.vpx.hw-based%5D%20component%20does%20not%20support%20metadata%20mode%3B%20using%20fallback%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.video_decoder.soft_hevc.sw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getParameter(ea000a%3AFreescale.std._decoder.soft_hevc.sw-based%2C%20ParamVideoProfileLevelQuerySupported(0x600000f))%20ERROR%3A%20UnsupportedIndex(0x8000101a)%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getExtensionIndex(ea000a%3AFreescale.std._decoder.soft_hevc.sw-based%2C%20OMX.google.android.index.configureVideoTunnelMode)%20ERROR%3A%20NotImplemented(0x80001006)%3CBR%20%2F%3EW%20234%20media.codec%20OMXNodeInstance%20%5Bea000a%3AFreescale.std._decoder.soft_hevc.sw-based%5D%20component%20does%20not%20support%20metadata%20mode%3B%20using%20fallback%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.video_decoder.wmv.sw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_2%20(514)%20at%20void%20com.android.server.wm.WindowManagerService.startAppFreezingScreen(android.os.IBinder%2C%20int)(WindowManagerService.java%3A4805)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)%20for%20713ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_2%20(514)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D0%20in%20int%20com.android.server.am.ActivityManagerService.getAppStartMode(int%2C%20java.lang.String)%20for%20876ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_2%20(514)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D1%20in%20android.content.pm.UserInfo%20com.android.server.am.UserController.getCurrentUser()%20for%20826ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_2%20(514)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D2%20in%20void%20com.android.server.am.PendingIntentRecord.completeFinalize()%20for%20818ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_2%20(514)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D3%20in%20void%20com.android.server.am.ActivityManagerService.addPackageDependency(java.lang.String)%20for%20798ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_2%20(514)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D4%20in%20int%20com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread%2C%20android.content.Intent%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20int%2C%20java.lang.String%2C%20android.os.Bundle%2C%20java.lang.String%5B%5D%2C%20int%2C%20android.os.Bundle%2C%20boolean%2C%20boolean%2C%20int)%20for%20740ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_2%20(514)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D5%20in%20int%20com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread%2C%20android.content.Intent%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20int%2C%20java.lang.String%2C%20android.os.Bundle%2C%20java.lang.String%5B%5D%2C%20int%2C%20android.os.Bundle%2C%20boolean%2C%20boolean%2C%20int)%20for%20726ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_2%20(514)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D6%20in%20android.content.ComponentName%20com.android.server.am.ActivityManagerService.startService(android.app.IApplicationThread%2C%20android.content.Intent%2C%20java.lang.String%2C%20java.lang.String%2C%20int)%20for%20584ms%3CBR%20%2F%3EW%201149%20com.android.phone%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fpriv-app%2FTelephonyProvider%2Flib%2Farm%3CBR%20%2F%3ED%201149%20com.android.phone%20ApplicationLoaders%20ignored%20Vulkan%20layer%20search%20path%20%2Fsystem%2Fpriv-app%2FTelephonyProvider%2Flib%2Farm%3A%2Fsystem%2Flib%3A%2Fvendor%2Flib%20for%20namespace%200xb34a1090%3CBR%20%2F%3ED%20486%20system%20DhcpClient%20Scheduling%20renewal%20in%20302399s%3CBR%20%2F%3ED%20486%20system%20DhcpClient%20Scheduling%20rebind%20in%20529199s%3CBR%20%2F%3ED%20486%20system%20DhcpClient%20Scheduling%20expiry%20in%20604799s%3CBR%20%2F%3EW%201163%20pre%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fpriv-app%2FSettings%2Flib%2Farm%3CBR%20%2F%3EW%20486%20system%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fpriv-app%2FTelecom%2Flib%2Farm%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20BinaryDictionaryFileDumper%20reinitializeClientRecordInDictionaryContentProvider()%20%3A%20Insert%20DictionaryInfo%20%3A%20Id%20%3D%20'main%3Aen'%20%3A%20Locale%3Den%20%3A%20Version%3D54%3CBR%20%2F%3ED%20486%20system%20ApplicationLoaders%20ignored%20Vulkan%20layer%20search%20path%20%2Fsystem%2Fpriv-app%2FTelecom%2Flib%2Farm%3A%2Fsystem%2Fpriv-app%2FTelecom%2FTelecom.apk!%2Flib%2Farmeabi-v7a%3A%2Fsystem%2Flib%3A%2Fvendor%2Flib%20for%20namespace%200xb32cc110%3CBR%20%2F%3ED%20486%20system%20ConnectivityService%20Switching%20to%20new%20default%20network%3A%20NetworkAgentInfo%7B%20ni%7B%5Btype%3A%20Ethernet%5B%5D%2C%20state%3A%20CONNECTED%2FCONNECTED%2C%20reason%3A%20(unspecified)%2C%20extra%3A%20b6%3Ad9%3A69%3A8f%3A41%3A44%2C%20failover%3A%20false%2C%20available%3A%20true%2C%20roaming%3A%20false%2C%20metered%3A%20false%5D%7D%20network%7B100%7D%20nethandle%7B429513165534%7D%20lp%7B%7BInterfaceName%3A%20eth0%20LinkAddresses%3A%20%5Bfe80%3A%3Ab4d9%3A69ff%3Afe8f%3A4144%2F64%2C192.168.10.226%2F16%2C%5D%20Routes%3A%20%5Bfe80%3A%3A%2F64%20-%26gt%3B%20%3A%3A%20eth0%2C192.168.0.0%2F16%20-%26gt%3B%200.0.0.0%20eth0%2C0.0.0.0%2F0%20-%26gt%3B%20192.168.10.1%20eth0%2C%5D%20DnsAddresses%3A%20%5B203.248.252.2%2C164.124.101.2%2C%5D%20Domains%3A%20null%20MTU%3A%200%20TcpBufferSizes%3A%20524288%2C1048576%2C3145728%2C524288%2C1048576%2C2097152%7D%7D%20nc%7B%5B%20Transports%3A%20ETHERNET%20Capabilities%3A%20INTERNET%26amp%3BNOT_RESTRICTED%26amp%3BTRUSTED%26amp%3BNOT_VPN%26amp%3BFOREGROUND%20LinkUpBandwidth%26gt%3B%3D100000Kbps%20LinkDnBandwidth%26gt%3B%3D100000Kbps%5D%7D%20Score%7B110%7D%20everValidated%7Bfalse%7D%20lastValidated%7Bfalse%7D%20created%7Btrue%7D%20lingering%7Bfalse%7D%20explicitlySelected%7Bfalse%7D%20acceptUnvalidated%7Bfalse%7D%20everCaptivePortalDetected%7Bfalse%7D%20lastCaptivePortalDetected%7Bfalse%7D%20%7D%3CBR%20%2F%3ED%20486%20system%20ConnectivityService%20Sending%20CONNECTED%20broadcast%20for%20type%209%20NetworkAgentInfo%20%5BEthernet%20()%20-%20100%5D%20isDefaultNetwork%3Dtrue%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%2030%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Trying%20to%20bind%20to%20profile%3A%201%2C%20while%20Bluetooth%20was%20disabled%3CBR%20%2F%3EI%20486%20system%20Telecom%20SystemStateProvider%3A%20Registering%20car%20mode%20receiver%3A%20android.content.IntentFilter%40c68015%3A%20TS.init%40AAA%3CBR%20%2F%3ED%20486%20system%20SntpClient%20round%20trip%3A%208ms%2C%20clock%20offset%3A%201499221972566ms%3CBR%20%2F%3EI%20486%20system%20Telecom%20Telecom%3A%20Non-call%20EVENT%3A%20AUDIO_ROUTE%2C%20Entering%20state%20QuiescentEarpieceRoute%3CBR%20%2F%3EI%20486%20system%20Telecom%20CallAudioModeStateMachine%3A%20Message%20received%3A%20null.%3A%20TS.init-%26gt%3BCAMSM.pM_1%40AAA_0%3CBR%20%2F%3EE%20486%20system%20ActivityThread%20Failed%20to%20find%20provider%20info%20for%20call_log%3CBR%20%2F%3EI%201080%20com.android.systemui%20vol.Events%20writeEvent%20level_changed%20STREAM_ALARM%206%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%2030%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Trying%20to%20bind%20to%20profile%3A%201%2C%20while%20Bluetooth%20was%20disabled%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20Can't%20open%20library%3A%20lib_WMV789_dec_v2_arm11_elinux.so%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20dlopen%20failed%3A%20library%20%22lib_WMV789_dec_v2_arm11_elinux.so%22%20not%20found%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20ConstructComponent%20LINE%3A%20574%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20Can't%20initialize%20component.%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20OMX_GetHandle%20LINE%3A%20498%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20Load%20and%20call%20entry%20function%20fail.%3CBR%20%2F%3EE%20234%20media.codec%20OMX%20FAILED%20to%20allocate%20omx%20component%20'OMX.Freescale.std.video_decoder.wmv.sw-based'%20err%3DComponentNotFound(0x80001003)%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%201080%20com.android.systemui%20vol.Events%20writeEvent%20level_changed%20STREAM_BLUETOOTH_SCO%207%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.video_decoder.wmv9.hw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EE%20234%20media.codec%20OMX%20FAILED%20to%20allocate%20omx%20component%20'OMX.Freescale.std.video_decoder.wmv9.hw-based'%20err%3DInvalidComponentName(0x80001002)%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.video_decoder.rv.hw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20486%20system%20Telecom%20Class%3A%20TelecomSystem.INSTANCE%20being%20set%3CBR%20%2F%3EW%20486%20system%20ContextImpl%20Calling%20a%20method%20in%20the%20system%20process%20without%20a%20qualified%20user%3A%20android.app.ContextImpl.startService%3A1357%20android.content.ContextWrapper.startService%3A613%20com.android.server.telecom.components.TelecomService.initializeTelecomSystem%3A176%20com.android.server.telecom.components.TelecomService.onBind%3A61%20android.app.ActivityThread.handleBindService%3A3218%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Bluetooth%20Adapter%20name%20changed%20to%20iMX6%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Stored%20Bluetooth%20name%3A%20iMX6%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20BluetoothServiceConnection%3A%20com.android.bluetooth.btservice.AdapterService%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%2040%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20MESSAGE_BLUETOOTH_SERVICE_CONNECTED%3A%201%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%20200%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20MESSAGE_GET_NAME_AND_ADDRESS%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Stored%20Bluetooth%20name%3A%20iMX6%3CBR%20%2F%3EI%201080%20com.android.systemui%20vol.Events%20writeEvent%20level_changed%20STREAM_MUSIC%2011%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Stored%20Bluetoothaddress%3A%2022%3A22%3A51%3A75%3A5E%3A58%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20unbindAndFinish()%3A%20android.bluetooth.IBluetooth%24Stub%24Proxy%4057ec68e%20mBinding%20%3D%20false%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Sending%20unbind%20request.%3CBR%20%2F%3ED%201014%20com.android.bluetooth%20BluetoothAdapterService%20onUnbind()%20-%20calling%20cleanup%3CBR%20%2F%3ED%201014%20com.android.bluetooth%20BluetoothAdapterService%20cleanup()%3CBR%20%2F%3EW%201014%20com.android.bluetooth%20BluetoothSdpJni%20Cleaning%20up%20Bluetooth%20SDP%20Interface...%3CBR%20%2F%3EW%201014%20com.android.bluetooth%20BluetoothSdpJni%20Cleaning%20up%20Bluetooth%20SDP%20object%3CBR%20%2F%3ED%201014%20com.android.bluetooth%20BluetoothAdapterService%20cleanup()%20-%20Cleaning%20up%20adapter%20native%3CBR%20%2F%3EI%201080%20com.android.systemui%20vol.Events%20writeEvent%20level_changed%20STREAM_RING%205%3CBR%20%2F%3EI%201080%20com.android.systemui%20vol.Events%20writeEvent%20level_changed%20STREAM_SYSTEM%205%3CBR%20%2F%3EW%20486%20system%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fpriv-app%2FFusedLocation%2Flib%2Farm%3CBR%20%2F%3ED%20486%20system%20ApplicationLoaders%20ignored%20Vulkan%20layer%20search%20path%20%2Fsystem%2Fpriv-app%2FFusedLocation%2Flib%2Farm%3A%2Fsystem%2Fpriv-app%2FFusedLocation%2FFusedLocation.apk!%2Flib%2Farmeabi-v7a%3A%2Fsystem%2Flib%3A%2Fvendor%2Flib%20for%20namespace%200xb32cc150%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_stack_manager%20event_clean_up_stack%20is%20cleaning%20up%20the%20stack%3CBR%20%2F%3EE%201014%20com.android.bluetooth%20BluetoothServiceJni%20Callback%20env%20check%20fail%3A%20env%3A%200x0%2C%20callback%3A%200xa9d05850%3CBR%20%2F%3EE%201014%20com.android.bluetooth%20BluetoothServiceJni%20Callback%3A%20'callback_thread_event'%20is%20not%20called%20on%20the%20correct%20thread%3CBR%20%2F%3EW%201014%20com.android.bluetooth%20bt_osi_thread%20run_thread%3A%20thread%20id%201038%2C%20thread%20name%20bt_jni_workqueue%20exited%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getParameter(ea000b%3AFreescale.std._decoder.rv.hw-based%2C%20ParamVideoProfileLevelQuerySupported(0x600000f))%20ERROR%3A%20UnsupportedIndex(0x8000101a)%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getExtensionIndex(ea000b%3AFreescale.std._decoder.rv.hw-based%2C%20OMX.google.android.index.configureVideoTunnelMode)%20ERROR%3A%20NotImplemented(0x80001006)%3CBR%20%2F%3EW%20234%20media.codec%20OMXNodeInstance%20%5Bea000b%3AFreescale.std._decoder.rv.hw-based%5D%20component%20does%20not%20support%20metadata%20mode%3B%20using%20fallback%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20BinaryDictionaryFileDumper%20reinitializeClientRecordInDictionaryContentProvider()%20%3A%20Insert%20DictionaryInfo%20%3A%20Id%20%3D%20'main%3Aes'%20%3A%20Locale%3Des%20%3A%20Version%3D54%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EV%20486%20system%20WiredAccessoryManager%20init()%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.video_decoder.divx.hw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EI%201080%20com.android.systemui%20vol.Events%20writeEvent%20level_changed%20STREAM_VOICE_CALL%204%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getParameter(ea000c%3AFreescale.std._decoder.divx.hw-based%2C%20ParamVideoProfileLevelQuerySupported(0x600000f))%20ERROR%3A%20UnsupportedIndex(0x8000101a)%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getExtensionIndex(ea000c%3AFreescale.std._decoder.divx.hw-based%2C%20OMX.google.android.index.configureVideoTunnelMode)%20ERROR%3A%20NotImplemented(0x80001006)%3CBR%20%2F%3EW%20234%20media.codec%20OMXNodeInstance%20%5Bea000c%3AFreescale.std._decoder.divx.hw-based%5D%20component%20does%20not%20support%20metadata%20mode%3B%20using%20fallback%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_core_module%20module_clean_up%20Cleaning%20up%20module%20%22stack_config_module%22%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_core_module%20module_clean_up%20Cleanup%20of%20module%20%22stack_config_module%22%20completed%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_core_module%20module_clean_up%20Cleaning%20up%20module%20%22interop_module%22%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_core_module%20module_clean_up%20Cleanup%20of%20module%20%22interop_module%22%20completed%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_core_module%20module_clean_up%20Cleaning%20up%20module%20%22btif_config_module%22%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.video_decoder.div4.hw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getParameter(ea000d%3AFreescale.std._decoder.div4.hw-based%2C%20ParamVideoProfileLevelQuerySupported(0x600000f))%20ERROR%3A%20UnsupportedIndex(0x8000101a)%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getExtensionIndex(ea000d%3AFreescale.std._decoder.div4.hw-based%2C%20OMX.google.android.index.configureVideoTunnelMode)%20ERROR%3A%20NotImplemented(0x80001006)%3CBR%20%2F%3EW%20234%20media.codec%20OMXNodeInstance%20%5Bea000d%3AFreescale.std._decoder.div4.hw-based%5D%20component%20does%20not%20support%20metadata%20mode%3B%20using%20fallback%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_core_module%20module_clean_up%20Cleanup%20of%20module%20%22btif_config_module%22%20completed%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_core_module%20module_clean_up%20Cleaning%20up%20module%20%22bt_utils_module%22%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_core_module%20module_clean_up%20Cleanup%20of%20module%20%22bt_utils_module%22%20completed%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_core_module%20module_clean_up%20Cleaning%20up%20module%20%22osi_module%22%3CBR%20%2F%3ED%201014%20com.android.bluetooth%20bt_osi_alarm%20callback_dispatch%20Callback%20thread%20exited%3CBR%20%2F%3EW%201014%20com.android.bluetooth%20bt_osi_thread%20run_thread%3A%20thread%20id%201037%2C%20thread%20name%20alarm_dispatcher%20exited%3CBR%20%2F%3EW%201014%20com.android.bluetooth%20bt_osi_thread%20run_thread%3A%20thread%20id%201036%2C%20thread%20name%20alarm_default_ca%20exited%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_core_module%20module_clean_up%20Cleanup%20of%20module%20%22osi_module%22%20completed%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20bt_stack_manager%20event_clean_up_stack%20finished%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20BluetoothServiceJni%20cleanupNative%3A%20return%20from%20cleanup%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.video_decoder.div3.hw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20art%20System.exit%20called%2C%20status%3A%200%3CBR%20%2F%3EI%201014%20com.android.bluetooth%20AndroidRuntime%20VM%20exiting%20with%20result%20code%200%2C%20cleanup%20skipped.%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20BinaryDictionaryFileDumper%20reinitializeClientRecordInDictionaryContentProvider()%20%3A%20Insert%20DictionaryInfo%20%3A%20Id%20%3D%20'main%3Afr'%20%3A%20Locale%3Dfr%20%3A%20Version%3D54%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getParameter(ea000e%3AFreescale.std._decoder.div3.hw-based%2C%20ParamVideoProfileLevelQuerySupported(0x600000f))%20ERROR%3A%20UnsupportedIndex(0x8000101a)%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getExtensionIndex(ea000e%3AFreescale.std._decoder.div3.hw-based%2C%20OMX.google.android.index.configureVideoTunnelMode)%20ERROR%3A%20NotImplemented(0x80001006)%3CBR%20%2F%3EW%20234%20media.codec%20OMXNodeInstance%20%5Bea000e%3AFreescale.std._decoder.div3.hw-based%5D%20component%20does%20not%20support%20metadata%20mode%3B%20using%20fallback%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.video_decoder.xvid.hw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getParameter(ea000f%3AFreescale.std._decoder.xvid.hw-based%2C%20ParamVideoProfileLevelQuerySupported(0x600000f))%20ERROR%3A%20UnsupportedIndex(0x8000101a)%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getExtensionIndex(ea000f%3AFreescale.std._decoder.xvid.hw-based%2C%20OMX.google.android.index.configureVideoTunnelMode)%20ERROR%3A%20NotImplemented(0x80001006)%3CBR%20%2F%3EW%20234%20media.codec%20OMXNodeInstance%20%5Bea000f%3AFreescale.std._decoder.xvid.hw-based%5D%20component%20does%20not%20support%20metadata%20mode%3B%20using%20fallback%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20BinaryDictionaryFileDumper%20reinitializeClientRecordInDictionaryContentProvider()%20%3A%20Insert%20DictionaryInfo%20%3A%20Id%20%3D%20'main%3Ait'%20%3A%20Locale%3Dit%20%3A%20Version%3D54%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.video_decoder.mjpeg.hw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getParameter(ea0010%3AFreescale.std._decoder.mjpeg.hw-based%2C%20ParamVideoProfileLevelQuerySupported(0x600000f))%20ERROR%3A%20UnsupportedIndex(0x8000101a)%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getExtensionIndex(ea0010%3AFreescale.std._decoder.mjpeg.hw-based%2C%20OMX.google.android.index.configureVideoTunnelMode)%20ERROR%3A%20NotImplemented(0x80001006)%3CBR%20%2F%3EW%20234%20media.codec%20OMXNodeInstance%20%5Bea0010%3AFreescale.std._decoder.mjpeg.hw-based%5D%20component%20does%20not%20support%20metadata%20mode%3B%20using%20fallback%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.video_decoder.sorenson.sw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getParameter(ea0011%3AFreescale.std._decoder.sorenson.sw-based%2C%20ParamVideoProfileLevelQuerySupported(0x600000f))%20ERROR%3A%20UnsupportedIndex(0x8000101a)%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getExtensionIndex(ea0011%3AFreescale.std._decoder.sorenson.sw-based%2C%20OMX.google.android.index.configureVideoTunnelMode)%20ERROR%3A%20NotImplemented(0x80001006)%3CBR%20%2F%3EW%20234%20media.codec%20OMXNodeInstance%20%5Bea0011%3AFreescale.std._decoder.sorenson.sw-based%5D%20component%20does%20not%20support%20metadata%20mode%3B%20using%20fallback%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20setParameter(ea0011%3AFreescale.std._decoder.sorenson.sw-based%2C%20OMX.google.android.index.prepareForAdaptivePlayback(0x7f00003d)%3A%20Output%3A1%20en%3D1%20max%3D1280x720)%20ERROR%3A%20UnsupportedIndex(0x8000101a)%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.audio_decoder.ac3.sw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20Can't%20open%20library%3A%20lib_ac3d_wrap_arm11_elinux_android.so%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20dlopen%20failed%3A%20library%20%22lib_ac3d_wrap_arm11_elinux_android.so%22%20not%20found%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20CreateDecoderInterface%20LINE%3A%20293%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20Fail%20to%20open%20Decoder%20library%20for%20)V%3F%3F%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20CreateDecoderInterface%20LINE%3A%20332%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20UniaDecoder%3A%3ACreateDecoderInterface%20ret%3D-2147479549%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20ConstructComponent%20LINE%3A%20574%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20Can't%20initialize%20component.%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20OMX_GetHandle%20LINE%3A%20498%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20Load%20and%20call%20entry%20function%20fail.%3CBR%20%2F%3EE%20234%20media.codec%20OMX%20FAILED%20to%20allocate%20omx%20component%20'OMX.Freescale.std.audio_decoder.ac3.sw-based'%20err%3DComponentNotFound(0x80001003)%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.audio_decoder.ec3.sw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20Unia%20-%26gt%3B%20EC3%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20Can't%20open%20library%3A%20lib_ddpd_wrap_arm12_elinux_android.so%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20dlopen%20failed%3A%20library%20%22lib_ddpd_wrap_arm12_elinux_android.so%22%20not%20found%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20CreateDecoderInterface%20LINE%3A%20293%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20Fail%20to%20open%20Decoder%20library%20for%20%5D%3F%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20CreateDecoderInterface%20LINE%3A%20332%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20UniaDecoder%3A%3ACreateDecoderInterface%20ret%3D-2147479549%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20ConstructComponent%20LINE%3A%20574%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20Can't%20initialize%20component.%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20OMX_GetHandle%20LINE%3A%20498%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20Load%20and%20call%20entry%20function%20fail.%3CBR%20%2F%3EE%20234%20media.codec%20OMX%20FAILED%20to%20allocate%20omx%20component%20'OMX.Freescale.std.audio_decoder.ec3.sw-based'%20err%3DComponentNotFound(0x80001003)%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.audio_decoder.wma.sw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20BinaryDictionaryFileDumper%20reinitializeClientRecordInDictionaryContentProvider()%20%3A%20Insert%20DictionaryInfo%20%3A%20Id%20%3D%20'main%3Aru'%20%3A%20Locale%3Dru%20%3A%20Version%3D54%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20Can't%20open%20library%3A%20lib_wma10d_wrap_arm12_elinux_android.so%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20dlopen%20failed%3A%20library%20%22lib_wma10d_wrap_arm12_elinux_android.so%22%20not%20found%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20CreateDecoderInterface%20LINE%3A%20293%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20Fail%20to%20open%20Decoder%20library%20for%20!%3F%3F%3F%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20CreateDecoderInterface%20LINE%3A%20332%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20UniaDecoder%3A%3ACreateDecoderInterface%20ret%3D-2147479549%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20ConstructComponent%20LINE%3A%20574%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20Can't%20initialize%20component.%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20OMX_GetHandle%20LINE%3A%20498%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20Load%20and%20call%20entry%20function%20fail.%3CBR%20%2F%3EE%20234%20media.codec%20OMX%20FAILED%20to%20allocate%20omx%20component%20'OMX.Freescale.std.audio_decoder.wma.sw-based'%20err%3DComponentNotFound(0x80001003)%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.audio_decoder.flac.sw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.audio_decoder.mp3.sw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Process%20com.android.bluetooth%20(pid%201014)%20has%20died%3CBR%20%2F%3ED%20486%20system%20ActivityManager%20cleanUpApplicationRecord%20--%201014%3CBR%20%2F%3ED%20486%20system%20ConnectivityService%20NetworkAgentInfo%20%5BEthernet%20()%20-%20100%5D%20validation%20failed%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.audio_decoder.amr.sw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20float%20com.android.server.wm.WindowManagerService.getCurrentAnimatorScale()%20for%20429ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20float%20com.android.server.wm.WindowManagerService.getCurrentAnimatorScale()%20for%20259ms%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D2%20in%20void%20com.android.server.wm.WindowManagerService.setScreenCaptureDisabled(int%2C%20boolean)%20for%20247ms%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.audio_decoder.amrwb.sw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.audio_decoder.aac.sw-based)%20in%20mediacodec%20process%3CBR%20%2F%3ED%201163%20pre%20CryptKeeper%20Disabling%20component%20ComponentInfo%7Bcom.android.settings%2Fcom.android.settings.CryptKeeper%7D%3CBR%20%2F%3EI%20486%20system%20WindowManager%20Screen%20frozen%20for%20%2B1s429ms%20due%20to%20AppWindowToken%7B32e09bb%20token%3DToken%7B8c5afb5%20ActivityRecord%7Ba8e1fec%20u0%20com.android.settings%2F.CryptKeeper%20t1%7D%7D%7D%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20Can't%20open%20library%3A%20lib_aacplusd_wrap_arm12_elinux_android.so%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20dlopen%20failed%3A%20library%20%22lib_aacplusd_wrap_arm12_elinux_android.so%22%20not%20found%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.audio_decoder.ra.sw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20Unia%20-%26gt%3B%20REAL%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20Can't%20open%20library%3A%20lib_realad_wrap_arm11_elinux_android.so%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20dlopen%20failed%3A%20library%20%22lib_realad_wrap_arm11_elinux_android.so%22%20not%20found%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20CreateDecoderInterface%20LINE%3A%20293%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20Fail%20to%20open%20Decoder%20library%20for%20D%C3%9E%3F%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20CreateDecoderInterface%20LINE%3A%20332%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20UniaDecoder%3A%3ACreateDecoderInterface%20ret%3D-2147479549%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20ConstructComponent%20LINE%3A%20574%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20Can't%20initialize%20component.%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20LEVEL%3A%201%20FUNCTION%3A%20OMX_GetHandle%20LINE%3A%20498%3CBR%20%2F%3EI%20234%20media.codec%20OMXPlayer%20Load%20and%20call%20entry%20function%20fail.%3CBR%20%2F%3EE%20234%20media.codec%20OMX%20FAILED%20to%20allocate%20omx%20component%20'OMX.Freescale.std.audio_decoder.ra.sw-based'%20err%3DComponentNotFound(0x80001003)%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.Freescale.std.audio_decoder.ape.sw-based)%20in%20mediacodec%20process%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.mpeg4.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getExtensionIndex(ea0018%3Agoogle.mpeg4.decoder%2C%20OMX.google.android.index.configureVideoTunnelMode)%20ERROR%3A%20UnsupportedIndex(0x8000101a)%3CBR%20%2F%3EW%20234%20media.codec%20OMXNodeInstance%20%5Bea0018%3Agoogle.mpeg4.decoder%5D%20component%20does%20not%20support%20metadata%20mode%3B%20using%20fallback%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.h263.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getExtensionIndex(ea0019%3Agoogle.h263.decoder%2C%20OMX.google.android.index.configureVideoTunnelMode)%20ERROR%3A%20UnsupportedIndex(0x8000101a)%3CBR%20%2F%3EW%20234%20media.codec%20OMXNodeInstance%20%5Bea0019%3Agoogle.h263.decoder%5D%20component%20does%20not%20support%20metadata%20mode%3B%20using%20fallback%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.h264.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EW%20237%20%2Fsystem%2Fbin%2Fmediaserver%20ACodec%20%5BOMX.google.h264.decoder%5D%20stopping%20checking%20profiles%20after%2032%3A%202%2F8000%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getExtensionIndex(ea001a%3Agoogle.h264.decoder%2C%20OMX.google.android.index.configureVideoTunnelMode)%20ERROR%3A%20UnsupportedIndex(0x8000101a)%3CBR%20%2F%3EW%20234%20media.codec%20OMXNodeInstance%20%5Bea001a%3Agoogle.h264.decoder%5D%20component%20does%20not%20support%20metadata%20mode%3B%20using%20fallback%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.hevc.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20486%20system%20art%20Background%20partial%20concurrent%20mark%20sweep%20GC%20freed%2029539(2MB)%20AllocSpace%20objects%2C%205(100KB)%20LOS%20objects%2C%2033%25%20free%2C%204MB%2F7MB%2C%20paused%202.512ms%20total%20120.865ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getExtensionIndex(ea001b%3Agoogle.hevc.decoder%2C%20OMX.google.android.index.configureVideoTunnelMode)%20ERROR%3A%20UnsupportedIndex(0x8000101a)%3CBR%20%2F%3EW%20234%20media.codec%20OMXNodeInstance%20%5Bea001b%3Agoogle.hevc.decoder%5D%20component%20does%20not%20support%20metadata%20mode%3B%20using%20fallback%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.vp8.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getExtensionIndex(ea001c%3Agoogle.vp8.decoder%2C%20OMX.google.android.index.configureVideoTunnelMode)%20ERROR%3A%20UnsupportedIndex(0x8000101a)%3CBR%20%2F%3EW%20234%20media.codec%20OMXNodeInstance%20%5Bea001c%3Agoogle.vp8.decoder%5D%20component%20does%20not%20support%20metadata%20mode%3B%20using%20fallback%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.vp9.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getExtensionIndex(ea001d%3Agoogle.vp9.decoder%2C%20OMX.google.android.index.configureVideoTunnelMode)%20ERROR%3A%20UnsupportedIndex(0x8000101a)%3CBR%20%2F%3EW%20234%20media.codec%20OMXNodeInstance%20%5Bea001d%3Agoogle.vp9.decoder%5D%20component%20does%20not%20support%20metadata%20mode%3B%20using%20fallback%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.h263.encoder)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20234%20media.codec%20SoftMPEG4Encoder%20Construct%20SoftMPEG4Encoder%3CBR%20%2F%3EW%20237%20%2Fsystem%2Fbin%2Fmediaserver%20ACodec%20do%20not%20know%20color%20format%200x7f000789%20%3D%202130708361%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getConfig(ea001e%3Agoogle.h263.encoder%2C%20ConfigAndroidIntraRefresh(0x6f60000a))%20ERROR%3A%20Undefined(0x80001001)%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.h264.encoder)%20in%20mediacodec%20process%3CBR%20%2F%3EW%20237%20%2Fsystem%2Fbin%2Fmediaserver%20ACodec%20do%20not%20know%20color%20format%200x7f000789%20%3D%202130708361%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.mpeg4.encoder)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20234%20media.codec%20SoftMPEG4Encoder%20Construct%20SoftMPEG4Encoder%3CBR%20%2F%3EW%20237%20%2Fsystem%2Fbin%2Fmediaserver%20ACodec%20do%20not%20know%20color%20format%200x7f000789%20%3D%202130708361%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getConfig(ea0020%3Agoogle.mpeg4.encoder%2C%20ConfigAndroidIntraRefresh(0x6f60000a))%20ERROR%3A%20Undefined(0x80001001)%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.vp8.encoder)%20in%20mediacodec%20process%3CBR%20%2F%3EW%20237%20%2Fsystem%2Fbin%2Fmediaserver%20ACodec%20do%20not%20know%20color%20format%200x7f000789%20%3D%202130708361%3CBR%20%2F%3EE%20234%20media.codec%20OMXNodeInstance%20getConfig(ea0021%3Agoogle.vp8.encoder%2C%20ConfigAndroidIntraRefresh(0x6f60000a))%20ERROR%3A%20Undefined(0x80001001)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.mp3.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.amrnb.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.amrwb.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.aac.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.g711.alaw.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.g711.mlaw.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.vorbis.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.opus.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.raw.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.aac.encoder)%20in%20mediacodec%20process%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.amrnb.encoder)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.amrwb.encoder)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.flac.encoder)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EW%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaCodecList%20unable%20to%20open%20media%20codecs%20configuration%20xml%20file%3A%20%2Fdata%2Fmisc%2Fmedia%2Fmedia_codecs_profiling_results.xml%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20486%20system%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%201080%20com.android.systemui%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.vorbis.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.vorbis.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20486%20system%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.vorbis.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3ED%201149%20com.android.phone%20TelephonyProvider%20dbh.onCreate%3A%2B%20db%3DSQLiteDatabase%3A%20%2Fdata%2Fuser_de%2F0%2Fcom.android.providers.telephony%2Fdatabases%2Ftelephony.db%3CBR%20%2F%3ED%201149%20com.android.phone%20TelephonyProvider%20dbh.createSimInfoTable%3A%2B%3CBR%20%2F%3ED%201149%20com.android.phone%20TelephonyProvider%20dbh.createSimInfoTable%3A-%3CBR%20%2F%3ED%201149%20com.android.phone%20TelephonyProvider%20dbh.createCarriersTable%3A%20carriers%3CBR%20%2F%3ED%201149%20com.android.phone%20TelephonyProvider%20dbh.createCarriersTable%3A-%3CBR%20%2F%3ED%201149%20com.android.phone%20TelephonyProvider%20No%20APNs%20in%20OEM%20image%20%3D%20%2Foem%2Ftelephony%2Fapns-conf.xml%20Load%20APNs%20from%20system%20image%3CBR%20%2F%3ED%201149%20com.android.phone%20TelephonyProvider%20No%20APNs%20in%20OEM%20image%20%3D%20%2Fdata%2Fmisc%2Fapns-conf.xml%20Load%20APNs%20from%20system%20image%3CBR%20%2F%3ED%201149%20com.android.phone%20TelephonyProvider%20confFile%20%3D%20%2Fsystem%2Fetc%2Fapns-conf.xml%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%201080%20com.android.systemui%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.vorbis.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3ED%201149%20com.android.phone%20TelephonyProvider%20Checksum%20for%20%2Fsystem%2Fetc%2Fapns-conf.xml%20is%201215094405%3CBR%20%2F%3ED%201149%20com.android.phone%20TelephonyProvider%20dbh.onCreate%3A-%20db%3DSQLiteDatabase%3A%20%2Fdata%2Fuser_de%2F0%2Fcom.android.providers.telephony%2Fdatabases%2Ftelephony.db%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20486%20system%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.vorbis.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3ED%201149%20com.android.phone%20TelephonyProvider%20dbh.onOpen%3A%20ok%2C%20queried%20table%3Dsiminfo%3CBR%20%2F%3ED%201149%20com.android.phone%20TelephonyProvider%20dbh.onOpen%3A%20ok%2C%20queried%20table%3Dcarriers%3CBR%20%2F%3ED%201149%20com.android.phone%20TelephonyProvider%20onCreate%3A%20build%20id%20changed%20from%20to%201.0.0-ga-rc10%3CBR%20%2F%3ED%201149%20com.android.phone%20TelephonyProvider%20No%20APNs%20in%20OEM%20image%20%3D%20%2Foem%2Ftelephony%2Fapns-conf.xml%20Load%20APNs%20from%20system%20image%3CBR%20%2F%3ED%201149%20com.android.phone%20TelephonyProvider%20No%20APNs%20in%20OEM%20image%20%3D%20%2Fdata%2Fmisc%2Fapns-conf.xml%20Load%20APNs%20from%20system%20image%3CBR%20%2F%3ED%201149%20com.android.phone%20TelephonyProvider%20Checksum%20for%20%2Fsystem%2Fetc%2Fapns-conf.xml%20is%201215094405%3CBR%20%2F%3ED%201149%20com.android.phone%20TelephonyProvider%20newChecksum%3A%201215094405%3CBR%20%2F%3ED%201149%20com.android.phone%20TelephonyProvider%20oldChecksum%3A%201215094405%3CBR%20%2F%3ED%201149%20com.android.phone%20TelephonyProvider%20Skipping%20apn%20db%20update%20since%20apn-conf%20has%20not%20changed.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%201080%20com.android.systemui%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.vorbis.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20486%20system%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.vorbis.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20486%20system%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.vorbis.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%20486%20system%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.vorbis.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20ConnectivityService%20NetworkAgentInfo%20%5BEthernet%20()%20-%20100%5D%20validation%20failed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20boolean%20com.android.server.am.ActivityManagerService.finishActivity(android.os.IBinder%2C%20int%2C%20android.content.Intent%2C%20int)(ActivityManagerService.java%3A4838)%20waiters%3D0%20in%20void%20com.android.server.am.ActivityManagerService.setRenderThread(int)%20for%202.165s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20boolean%20com.android.server.am.ActivityManagerService.finishActivity(android.os.IBinder%2C%20int%2C%20android.content.Intent%2C%20int)(ActivityManagerService.java%3A4838)%20waiters%3D1%20in%20void%20com.android.server.am.ActivityManagerService.updateLockTaskPackages(int%2C%20java.lang.String%5B%5D)%20for%202.145s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20boolean%20com.android.server.am.ActivityManagerService.finishActivity(android.os.IBinder%2C%20int%2C%20android.content.Intent%2C%20int)(ActivityManagerService.java%3A4838)%20waiters%3D2%20in%20int%20com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread%2C%20android.content.Intent%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20int%2C%20java.lang.String%2C%20android.os.Bundle%2C%20java.lang.String%5B%5D%2C%20int%2C%20android.os.Bundle%2C%20boolean%2C%20boolean%2C%20int)%20for%202.145s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20boolean%20com.android.server.am.ActivityManagerService.finishActivity(android.os.IBinder%2C%20int%2C%20android.content.Intent%2C%20int)(ActivityManagerService.java%3A4838)%20waiters%3D3%20in%20void%20com.android.server.am.ActivityManagerService%24MainHandler.handleMessage(android.os.Message)%20for%201.782s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20boolean%20com.android.server.am.ActivityManagerService.finishActivity(android.os.IBinder%2C%20int%2C%20android.content.Intent%2C%20int)(ActivityManagerService.java%3A4838)%20waiters%3D4%20in%20void%20com.android.server.am.ActivityManagerService.publishContentProviders(android.app.IApplicationThread%2C%20java.util.List)%20for%201.515s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20boolean%20com.android.server.am.ActivityManagerService.finishActivity(android.os.IBinder%2C%20int%2C%20android.content.Intent%2C%20int)(ActivityManagerService.java%3A4838)%20waiters%3D5%20in%20int%20com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread%2C%20android.content.Intent%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20int%2C%20java.lang.String%2C%20android.os.Bundle%2C%20java.lang.String%5B%5D%2C%20int%2C%20android.os.Bundle%2C%20boolean%2C%20boolean%2C%20int)%20for%201.310s%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20BinaryDictionaryFileDumper%20reinitializeClientRecordInDictionaryContentProvider()%20%3A%20Insert%20DictionaryInfo%20%3A%20Id%20%3D%20'main%3Aen_us'%20%3A%20Locale%3Den_US%20%3A%20Version%3D-1%3CBR%20%2F%3EI%201080%20com.android.systemui%20imx6.gralloc%20open%20gpu%20gralloc%20module!%3CBR%20%2F%3EW%20486%20system%20VibratorService%20Tried%20to%20stop%20vibrating%20but%20there%20is%20no%20vibrator%20device.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.resumeKeyDispatching(android.os.IBinder)%20for%20485ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2031%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20int%20com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.view.InputChannel)%20for%201.013s%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20ConnectivityService%20NetworkAgentInfo%20%5BEthernet%20()%20-%20100%5D%20validation%20failed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20void%20com.android.server.wm.WindowManagerService.resumeKeyDispatching(android.os.IBinder)%20for%201.090s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20int%20com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.view.InputChannel)%20for%20543ms%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20START%20u0%20%7Bact%3Dandroid.intent.action.MAIN%20cat%3D%5Bandroid.intent.category.HOME%5D%20flg%3D0x10000100%20cmp%3Dcom.android.settings%2F.FallbackHome%7D%20from%20uid%200%20on%20display%200%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201332%3Acom.android.settings%2F1000%20for%20activity%20com.android.settings%2F.FallbackHome%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_4%20(1106)%20at%20void%20com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java%3A6915)%20waiters%3D0%20in%20android.content.pm.UserInfo%20com.android.server.am.UserController.getCurrentUser()%20for%201.595s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_4%20(1106)%20at%20void%20com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java%3A6915)%20waiters%3D2%20in%20android.content.Intent%20com.android.server.am.ActivityManagerService.registerReceiver(android.app.IApplicationThread%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20android.content.IntentFilter%2C%20java.lang.String%2C%20int)%20for%201.569s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_4%20(1106)%20at%20void%20com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java%3A6915)%20waiters%3D1%20in%20int%20com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread%2C%20android.content.Intent%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20int%2C%20java.lang.String%2C%20android.os.Bundle%2C%20java.lang.String%5B%5D%2C%20int%2C%20android.os.Bundle%2C%20boolean%2C%20boolean%2C%20int)%20for%201.588s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_4%20(1106)%20at%20void%20com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java%3A6915)%20waiters%3D3%20in%20void%20com.android.server.am.ActivityManagerService%24MainHandler.handleMessage(android.os.Message)%20for%201.399s%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.prepareAppTransition(int%2C%20boolean)%20for%20486ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20ActivityManager%20(516)%20at%20void%20com.android.server.am.ActivityStackSupervisor%24ActivityStackSupervisorHandler.handleMessage(android.os.Message)(ActivityStackSupervisor.java%3A3884)%20waiters%3D1%20in%20int%20com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread%2C%20android.content.Intent%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20int%2C%20java.lang.String%2C%20android.os.Bundle%2C%20java.lang.String%5B%5D%2C%20int%2C%20android.os.Bundle%2C%20boolean%2C%20boolean%2C%20int)%20for%20486ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20ActivityManager%20(516)%20at%20void%20com.android.server.am.ActivityStackSupervisor%24ActivityStackSupervisorHandler.handleMessage(android.os.Message)(ActivityStackSupervisor.java%3A3884)%20waiters%3D1%20in%20android.content.Intent%20com.android.server.am.ActivityManagerService.registerReceiver(android.app.IApplicationThread%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20android.content.IntentFilter%2C%20java.lang.String%2C%20int)%20for%20489ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20ActivityManager%20(516)%20at%20void%20com.android.server.am.ActivityStackSupervisor%24ActivityStackSupervisorHandler.handleMessage(android.os.Message)(ActivityStackSupervisor.java%3A3884)%20waiters%3D4%20in%20int%20com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread%2C%20android.content.Intent%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20int%2C%20java.lang.String%2C%20android.os.Bundle%2C%20java.lang.String%5B%5D%2C%20int%2C%20android.os.Bundle%2C%20boolean%2C%20boolean%2C%20int)%20for%20485ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20ActivityManager%20(516)%20at%20void%20com.android.server.am.ActivityStackSupervisor%24ActivityStackSupervisorHandler.handleMessage(android.os.Message)(ActivityStackSupervisor.java%3A3884)%20waiters%3D3%20in%20int%20com.android.server.am.ActivityManagerService.getAppStartMode(int%2C%20java.lang.String)%20for%20489ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20ActivityManager%20(516)%20at%20void%20com.android.server.am.ActivityStackSupervisor%24ActivityStackSupervisorHandler.handleMessage(android.os.Message)(ActivityStackSupervisor.java%3A3884)%20waiters%3D2%20in%20android.content.Intent%20com.android.server.am.ActivityManagerService.registerReceiver(android.app.IApplicationThread%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20android.content.IntentFilter%2C%20java.lang.String%2C%20int)%20for%20492ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20ActivityManager%20(516)%20at%20void%20com.android.server.am.ActivityStackSupervisor%24ActivityStackSupervisorHandler.handleMessage(android.os.Message)(ActivityStackSupervisor.java%3A3884)%20waiters%3D6%20in%20void%20com.android.server.am.ActivityManagerService%24LocalService.notifyAppTransitionFinished()%20for%201.113s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20ActivityManager%20(516)%20at%20void%20com.android.server.am.ActivityManagerService%24MainHandler.handleMessage(android.os.Message)(ActivityManagerService.java%3A2082)%20waiters%3D6%20in%20int%20com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread%2C%20android.content.Intent%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20int%2C%20java.lang.String%2C%20android.os.Bundle%2C%20java.lang.String%5B%5D%2C%20int%2C%20android.os.Bundle%2C%20boolean%2C%20boolean%2C%20int)%20for%201.112s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20NetworkStats%20(975)%20at%20int%20com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread%2C%20android.content.Intent%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20int%2C%20java.lang.String%2C%20android.os.Bundle%2C%20java.lang.String%5B%5D%2C%20int%2C%20android.os.Bundle%2C%20boolean%2C%20boolean%2C%20int)(ActivityManagerService.java%3A18504)%20waiters%3D4%20in%20int%20com.android.server.am.ActivityManagerService.getAppStartMode(int%2C%20java.lang.String)%20for%201.110s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_5%20(1182)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D3%20in%20android.content.Intent%20com.android.server.am.ActivityManagerService.registerReceiver(android.app.IApplicationThread%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20android.content.IntentFilter%2C%20java.lang.String%2C%20int)%20for%201.108s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_5%20(1182)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D4%20in%20void%20com.android.server.am.BroadcastQueue.processNextBroadcast(boolean)%20for%201.109s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_5%20(1182)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D5%20in%20void%20com.android.server.am.ActivityManagerService.finishReceiver(android.os.IBinder%2C%20int%2C%20java.lang.String%2C%20android.os.Bundle%2C%20boolean%2C%20int)%20for%201.107s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_5%20(1182)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D6%20in%20android.content.Intent%20com.android.server.am.ActivityManagerService.registerReceiver(android.app.IApplicationThread%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20android.content.IntentFilter%2C%20java.lang.String%2C%20int)%20for%201.078s%3CBR%20%2F%3EW%201039%20com.android.inputmethod.latin%20BinaryDictionaryFileDumper%20Missing%20metadata.json%20resource%3CBR%20%2F%3ED%20486%20system%20ConditionProviders.SCP%20onSubscribe%20condition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D1.2.3.4.5%26amp%3Bstart%3D22.0%26amp%3Bend%3D7.0%26amp%3BexitAtAlarm%3Dfalse%3CBR%20%2F%3ED%20486%20system%20ConditionProviders.SCP%20setRegistered%20true%3CBR%20%2F%3ED%20486%20system%20ConditionProviders.SCP%20notifyCondition%20condition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D1.2.3.4.5%26amp%3Bstart%3D22.0%26amp%3Bend%3D7.0%26amp%3BexitAtAlarm%3Dfalse%20STATE_TRUE%20reason%3DmeetsSchedule%3CBR%20%2F%3ED%20486%20system%20ConditionProviders.SCP%20Scheduling%20evaluate%20for%20Thu%20Jan%2001%2007%3A00%3A00%20GMT%2B00%3A00%201970%20(25200000)%2C%20in%20%2B6h56m4s309ms%2C%20now%3DThu%20Jan%2001%2000%3A03%3A55%20GMT%2B00%3A00%201970%20(235691)%3CBR%20%2F%3ED%20486%20system%20ConditionProviders.SCP%20onSubscribe%20condition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D6.7%26amp%3Bstart%3D23.30%26amp%3Bend%3D10.0%26amp%3BexitAtAlarm%3Dfalse%3CBR%20%2F%3ED%20486%20system%20ConditionProviders.SCP%20notifyCondition%20condition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D6.7%26amp%3Bstart%3D23.30%26amp%3Bend%3D10.0%26amp%3BexitAtAlarm%3Dfalse%20STATE_FALSE%20reason%3D!meetsSchedule%3CBR%20%2F%3ED%20486%20system%20ConditionProviders.SCP%20notifyCondition%20condition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D1.2.3.4.5%26amp%3Bstart%3D22.0%26amp%3Bend%3D7.0%26amp%3BexitAtAlarm%3Dfalse%20STATE_TRUE%20reason%3DmeetsSchedule%3CBR%20%2F%3ED%20486%20system%20ConditionProviders.SCP%20Scheduling%20evaluate%20for%20Thu%20Jan%2001%2007%3A00%3A00%20GMT%2B00%3A00%201970%20(25200000)%2C%20in%20%2B6h56m4s303ms%2C%20now%3DThu%20Jan%2001%2000%3A03%3A55%20GMT%2B00%3A00%201970%20(235697)%3CBR%20%2F%3EI%20486%20system%20Telecom%20WiredHeadsetManager%3A%20ACTION_HEADSET_PLUG%20event%2C%20plugged%20in%3A%20false%2C%20%3A%20WHC.oADA%40AAE%3CBR%20%2F%3ED%201080%20com.android.systemui%20StorageNotification%20Notifying%20about%20private%20volume%3A%20VolumeInfo%7Bprivate%7D%3A%3CBR%20%2F%3ED%201080%20com.android.systemui%20StorageNotification%20type%3DPRIVATE%20diskId%3Dnull%20partGuid%3Dnull%20mountFlags%3D0%20mountUserId%3D-1%3CBR%20%2F%3ED%201080%20com.android.systemui%20StorageNotification%20state%3DMOUNTED%3CBR%20%2F%3ED%201080%20com.android.systemui%20StorageNotification%20fsType%3Dnull%20fsUuid%3Dnull%20fsLabel%3Dnull%3CBR%20%2F%3ED%201080%20com.android.systemui%20StorageNotification%20path%3D%2Fdata%20internalPath%3Dnull%3CBR%20%2F%3EW%201332%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fpriv-app%2FSettings%2Flib%2Farm%3CBR%20%2F%3EE%20486%20system%20ActivityThread%20Failed%20to%20find%20provider%20info%20for%20com.android.calendar%3CBR%20%2F%3EE%20486%20system%20ActivityThread%20Failed%20to%20find%20provider%20info%20for%20com.android.calendar%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20user%200%20is%20still%20locked.%20Cannot%20load%20recents%3CBR%20%2F%3EI%20486%20system%20SyncManager%20Got%20SyncJobService%20instance.%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20LatinIME%3ALogUtils%20Dictionary%20info%3A%20dictionary%20%3D%20main%3Aen%20%3B%20version%20%3D%2054%20%3B%20date%20%3D%201414726273%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20LatinIME%3ALogUtils%20Dictionary%20info%3A%20dictionary%20%3D%20main%3Aen%20%3B%20version%20%3D%2054%20%3B%20date%20%3D%201414726273%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20LatinIME%3ALogUtils%20Dictionary%20info%3A%20dictionary%20%3D%20main%3Aen%20%3B%20version%20%3D%2054%20%3B%20date%20%3D%201414726273%3CBR%20%2F%3EI%20486%20system%20DefaultPermGrantPolicy%20Granting%20permissions%20to%20default%20dialer%20app%20for%20user%3A0%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20Telecom%20PhoneAccountRegistrar%3A%20SimCallManager%20queried%2C%20returning%3A%20null%3A%20TSI.gSCM%40AAM%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20LatinIME%3ALogUtils%20Dictionary%20info%3A%20dictionary%20%3D%20main%3Aen%20%3B%20version%20%3D%2054%20%3B%20date%20%3D%201414726273%3CBR%20%2F%3ED%20486%20system%20ZenLog%20config%3A%20conditionChanged%2CZenModeConfig%5Buser%3D0%2CallowCalls%3Dtrue%2CallowRepeatCallers%3Dfalse%2CallowMessages%3Dfalse%2CallowCallsFrom%3Dcontacts%2CallowMessagesFrom%3Dcontacts%2CallowReminders%3Dtrue%2CallowEvents%3Dtrue%2CallowWhenScreenOff%3Dtrue%2CallowWhenScreenOn%3Dtrue%2CautomaticRules%3D%7B52f7ad9de46840f68ab58fd3963db759%3DZenRule%5Benabled%3Dfalse%2Csnoozing%3Dfalse%2Cname%3DEvent%2CzenMode%3DZEN_MODE_ALARMS%2CconditionId%3Dcondition%3A%2F%2Fandroid%2Fevent%3FuserId%3D-10000%26amp%3Bcalendar%3D%26amp%3Breply%3D1%2Ccondition%3Dnull%2Ccomponent%3DComponentInfo%7Bandroid%2Fcom.android.server.notification.EventConditionProvider%7D%2Cid%3D52f7ad9de46840f68ab58fd3963db759%2CcreationTime%3D224631%2Cenabler%3Dnull%5D%2C%2047863810e54d4ba3a5eaf7b3dfc0b6d2%3DZenRule%5Benabled%3Dfalse%2Csnoozing%3Dfalse%2Cname%3DWeeknight%2CzenMode%3DZEN_MODE_ALARMS%2CconditionId%3Dcondition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D1.2.3.4.5%26amp%3Bstart%3D22.0%26amp%3Bend%3D7.0%26amp%3BexitAtAlarm%3Dfalse%2Ccondition%3DCondition%5Bid%3Dcondition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D1.2.3.4.5%26amp%3Bstart%3D22.0%26amp%3Bend%3D7.0%26amp%3BexitAtAlarm%3Dfalse%2Csummary%3D...%2Cline1%3D...%2Cline2%3D...%2Cicon%3D0%2Cstate%3DSTATE_TRUE%2Cflags%3D2%5D%2Ccomponent%3DComponentInfo%7Bandroid%2Fcom.android.server.notification.ScheduleConditionProvider%7D%2Cid%3D47863810e54d4ba3a5eaf7b3dfc0b6d2%2CcreationTime%3D224629%2Cenabler%3Dnull%5D%2C%20115f643d6487490dbf893f006f26ae17%3DZenRule%5Benabled%3Dfalse%2Csnoozing%3Dfalse%2Cname%3DWeekend%2CzenMode%3DZEN_MODE_ALARMS%2CconditionId%3Dcondition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D6.7%26amp%3Bstart%3D23.30%26amp%3Bend%3D10.0%26amp%3BexitAtAlarm%3Dfalse%2Ccondition%3Dnull%2Ccomponent%3DComponentInfo%7Bandroid%2Fcom.android.server.notification.ScheduleConditionProvider%7D%2Cid%3D115f643d6487490dbf893f006f26ae17%2CcreationTime%3D224630%2Cenabler%3Dnull%5D%7D%2CmanualRule%3Dnull%5D%2CDiff%5BautomaticRule%5B47863810e54d4ba3a5eaf7b3dfc0b6d2%5D.condition%3Anull-%26gt%3BCondition%5Bid%3Dcondition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D1.2.3.4.5%26amp%3Bstart%3D22.0%26amp%3Bend%3D7.0%26amp%3BexitAtAlarm%3Dfalse%2Csummary%3D...%2Cline1%3D...%2Cline2%3D...%2Cicon%3D0%2Cstate%3DSTATE_TRUE%2Cflags%3D2%5D%5D%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20LatinIME%3ALogUtils%20Dictionary%20info%3A%20dictionary%20%3D%20main%3Aen%20%3B%20version%20%3D%2054%20%3B%20date%20%3D%201414726273%3CBR%20%2F%3ED%20486%20system%20ZenLog%20config%3A%20conditionChanged%2CZenModeConfig%5Buser%3D0%2CallowCalls%3Dtrue%2CallowRepeatCallers%3Dfalse%2CallowMessages%3Dfalse%2CallowCallsFrom%3Dcontacts%2CallowMessagesFrom%3Dcontacts%2CallowReminders%3Dtrue%2CallowEvents%3Dtrue%2CallowWhenScreenOff%3Dtrue%2CallowWhenScreenOn%3Dtrue%2CautomaticRules%3D%7B52f7ad9de46840f68ab58fd3963db759%3DZenRule%5Benabled%3Dfalse%2Csnoozing%3Dfalse%2Cname%3DEvent%2CzenMode%3DZEN_MODE_ALARMS%2CconditionId%3Dcondition%3A%2F%2Fandroid%2Fevent%3FuserId%3D-10000%26amp%3Bcalendar%3D%26amp%3Breply%3D1%2Ccondition%3Dnull%2Ccomponent%3DComponentInfo%7Bandroid%2Fcom.android.server.notification.EventConditionProvider%7D%2Cid%3D52f7ad9de46840f68ab58fd3963db759%2CcreationTime%3D224631%2Cenabler%3Dnull%5D%2C%2047863810e54d4ba3a5eaf7b3dfc0b6d2%3DZenRule%5Benabled%3Dfalse%2Csnoozing%3Dfalse%2Cname%3DWeeknight%2CzenMode%3DZEN_MODE_ALARMS%2CconditionId%3Dcondition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D1.2.3.4.5%26amp%3Bstart%3D22.0%26amp%3Bend%3D7.0%26amp%3BexitAtAlarm%3Dfalse%2Ccondition%3DCondition%5Bid%3Dcondition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D1.2.3.4.5%26amp%3Bstart%3D22.0%26amp%3Bend%3D7.0%26amp%3BexitAtAlarm%3Dfalse%2Csummary%3D...%2Cline1%3D...%2Cline2%3D...%2Cicon%3D0%2Cstate%3DSTATE_TRUE%2Cflags%3D2%5D%2Ccomponent%3DComponentInfo%7Bandroid%2Fcom.android.server.notification.ScheduleConditionProvider%7D%2Cid%3D47863810e54d4ba3a5eaf7b3dfc0b6d2%2CcreationTime%3D224629%2Cenabler%3Dnull%5D%2C%20115f643d6487490dbf893f006f26ae17%3DZenRule%5Benabled%3Dfalse%2Csnoozing%3Dfalse%2Cname%3DWeekend%2CzenMode%3DZEN_MODE_ALARMS%2CconditionId%3Dcondition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D6.7%26amp%3Bstart%3D23.30%26amp%3Bend%3D10.0%26amp%3BexitAtAlarm%3Dfalse%2Ccondition%3DCondition%5Bid%3Dcondition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D6.7%26amp%3Bstart%3D23.30%26amp%3Bend%3D10.0%26amp%3BexitAtAlarm%3Dfalse%2Csummary%3D...%2Cline1%3D...%2Cline2%3D...%2Cicon%3D0%2Cstate%3DSTATE_FALSE%2Cflags%3D2%5D%2Ccomponent%3DComponentInfo%7Bandroid%2Fcom.android.server.notification.ScheduleConditionProvider%7D%2Cid%3D115f643d6487490dbf893f006f26ae17%2CcreationTime%3D224630%2Cenabler%3Dnull%5D%7D%2CmanualRule%3Dnull%5D%2CDiff%5BautomaticRule%5B115f643d6487490dbf893f006f26ae17%5D.condition%3Anull-%26gt%3BCondition%5Bid%3Dcondition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D6.7%26amp%3Bstart%3D23.30%26amp%3Bend%3D10.0%26amp%3BexitAtAlarm%3Dfalse%2Csummary%3D...%2Cline1%3D...%2Cline2%3D...%2Cicon%3D0%2Cstate%3DSTATE_FALSE%2Cflags%3D2%5D%5D%3CBR%20%2F%3ED%20486%20system%20ZenLog%20config%3A%20conditionChanged%2CZenModeConfig%5Buser%3D0%2CallowCalls%3Dtrue%2CallowRepeatCallers%3Dfalse%2CallowMessages%3Dfalse%2CallowCallsFrom%3Dcontacts%2CallowMessagesFrom%3Dcontacts%2CallowReminders%3Dtrue%2CallowEvents%3Dtrue%2CallowWhenScreenOff%3Dtrue%2CallowWhenScreenOn%3Dtrue%2CautomaticRules%3D%7B52f7ad9de46840f68ab58fd3963db759%3DZenRule%5Benabled%3Dfalse%2Csnoozing%3Dfalse%2Cname%3DEvent%2CzenMode%3DZEN_MODE_ALARMS%2CconditionId%3Dcondition%3A%2F%2Fandroid%2Fevent%3FuserId%3D-10000%26amp%3Bcalendar%3D%26amp%3Breply%3D1%2Ccondition%3DCondition%5Bid%3Dcondition%3A%2F%2Fandroid%2Fevent%3FuserId%3D-10000%26amp%3Bcalendar%3D%26amp%3Breply%3D1%2Csummary%3D...%2Cline1%3D...%2Cline2%3D...%2Cicon%3D0%2Cstate%3DSTATE_FALSE%2Cflags%3D2%5D%2Ccomponent%3DComponentInfo%7Bandroid%2Fcom.android.server.notification.EventConditionProvider%7D%2Cid%3D52f7ad9de46840f68ab58fd3963db759%2CcreationTime%3D224631%2Cenabler%3Dnull%5D%2C%2047863810e54d4ba3a5eaf7b3dfc0b6d2%3DZenRule%5Benabled%3Dfalse%2Csnoozing%3Dfalse%2Cname%3DWeeknight%2CzenMode%3DZEN_MODE_ALARMS%2CconditionId%3Dcondition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D1.2.3.4.5%26amp%3Bstart%3D22.0%26amp%3Bend%3D7.0%26amp%3BexitAtAlarm%3Dfalse%2Ccondition%3DCondition%5Bid%3Dcondition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D1.2.3.4.5%26amp%3Bstart%3D22.0%26amp%3Bend%3D7.0%26amp%3BexitAtAlarm%3Dfalse%2Csummary%3D...%2Cline1%3D...%2Cline2%3D...%2Cicon%3D0%2Cstate%3DSTATE_TRUE%2Cflags%3D2%5D%2Ccomponent%3DComponentInfo%7Bandroid%2Fcom.android.server.notification.ScheduleConditionProvider%7D%2Cid%3D47863810e54d4ba3a5eaf7b3dfc0b6d2%2CcreationTime%3D224629%2Cenabler%3Dnull%5D%2C%20115f643d6487490dbf893f006f26ae17%3DZenRule%5Benabled%3Dfalse%2Csnoozing%3Dfalse%2Cname%3DWeekend%2CzenMode%3DZEN_MODE_ALARMS%2CconditionId%3Dcondition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D6.7%26amp%3Bstart%3D23.30%26amp%3Bend%3D10.0%26amp%3BexitAtAlarm%3Dfalse%2Ccondition%3DCondition%5Bid%3Dcondition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D6.7%26amp%3Bstart%3D23.30%26amp%3Bend%3D10.0%26amp%3BexitAtAlarm%3Dfalse%2Csummary%3D...%2Cline1%3D...%2Cline2%3D...%2Cicon%3D0%2Cstate%3DSTATE_FALSE%2Cflags%3D2%5D%2Ccomponent%3DComponentInfo%7Bandroid%2Fcom.android.server.notification.ScheduleConditionProvider%7D%2Cid%3D115f643d6487490dbf893f006f26ae17%2CcreationTime%3D224630%2Cenabler%3Dnull%5D%7D%2CmanualRule%3Dnull%5D%2CDiff%5BautomaticRule%5B52f7ad9de46840f68ab58fd3963db759%5D.condition%3Anull-%26gt%3BCondition%5Bid%3Dcondition%3A%2F%2Fandroid%2Fevent%3FuserId%3D-10000%26amp%3Bcalendar%3D%26amp%3Breply%3D1%2Csummary%3D...%2Cline1%3D...%2Cline2%3D...%2Cicon%3D0%2Cstate%3DSTATE_FALSE%2Cflags%3D2%5D%5D%3CBR%20%2F%3EI%20486%20system%20FusedLocation%20engine%20started%20(com.android.location.fused)%3CBR%20%2F%3ED%20486%20system%20ZenLog%20set_zen_mode%3A%20off%2CconditionChanged%3CBR%20%2F%3ED%20486%20system%20DhcpClient%20Received%20packet%3A%2020%3Ad5%3Aab%3Ae9%3Ad9%3Acd%20ACK%3A%20your%20new%20IP%20%2F192.168.10.189%2C%20netmask%20%2F255.255.0.0%2C%20gateways%20%5B%2F192.168.10.1%5D%20DNS%20servers%3A%20%2F203.248.252.2%20%2F164.124.101.2%20%2C%20lease%20time%20604800%3CBR%20%2F%3ED%20486%20system%20ZenLog%20set_zen_mode%3A%20off%2CconditionChanged%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20LatinIME%3ALogUtils%20Dictionary%20info%3A%20dictionary%20%3D%20main%3Aen%20%3B%20version%20%3D%2054%20%3B%20date%20%3D%201414726273%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201368%3Acom.android.cellbroadcastreceiver%2Fu0a6%20for%20broadcast%20com.android.cellbroadcastreceiver%2F.CellBroadcastReceiver%3CBR%20%2F%3ED%20486%20system%20ZenLog%20set_zen_mode%3A%20off%2CconditionChanged%3CBR%20%2F%3EI%201332%20com.android.settings%20imx6.gralloc%20open%20gpu%20gralloc%20module!%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20LatinIME%3ALogUtils%20Dictionary%20info%3A%20dictionary%20%3D%20main%3Aen%20%3B%20version%20%3D%2054%20%3B%20date%20%3D%201414726273%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20LatinIME%3ALogUtils%20Dictionary%20info%3A%20dictionary%20%3D%20main%3Aen%20%3B%20version%20%3D%2054%20%3B%20date%20%3D%201414726273%3CBR%20%2F%3EI%201080%20com.android.systemui%20Choreographer%20Skipped%20207%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EI%20486%20system%20art%20Background%20sticky%20concurrent%20mark%20sweep%20GC%20freed%2023626(1943KB)%20AllocSpace%20objects%2C%208(204KB)%20LOS%20objects%2C%2023%25%20free%2C%205MB%2F7MB%2C%20paused%205.980ms%20total%20154.708ms%3CBR%20%2F%3EW%201368%20com.android.cellbroadcastreceiver%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fpriv-app%2FCellBroadcastReceiver%2Flib%2Farm%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201149%20com.android.phone%20SystemConfig%20No%20directory%20%2Fsystem%2Fetc%2Fsysconfig%2C%20skipping%3CBR%20%2F%3ED%201149%20com.android.phone%20PhoneSwitcherNetworkRequstListener%20Registering%20NetworkFactory%3CBR%20%2F%3ED%20486%20system%20ConnectivityService%20Got%20NetworkFactory%20Messenger%20for%20PhoneSwitcherNetworkRequstListener%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3ED%20486%20system%20ConnectivityService%20Got%20NetworkFactory%20Messenger%20for%20TelephonyNetworkFactory%5B0%5D%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20AlarmManagerService%20Setting%20time%20of%20day%20to%20sec%3D1499222209%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3ED%20486%20system%20ConditionProviders.SCP%20onReceive%20android.intent.action.TIME_SET%3CBR%20%2F%3ED%20486%20system%20ConditionProviders.SCP%20notifyCondition%20condition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D6.7%26amp%3Bstart%3D23.30%26amp%3Bend%3D10.0%26amp%3BexitAtAlarm%3Dfalse%20STATE_FALSE%20reason%3D!meetsSchedule%3CBR%20%2F%3ED%20486%20system%20ConditionProviders.SCP%20notifyCondition%20condition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D1.2.3.4.5%26amp%3Bstart%3D22.0%26amp%3Bend%3D7.0%26amp%3BexitAtAlarm%3Dfalse%20STATE_TRUE%20reason%3DmeetsSchedule%3CBR%20%2F%3ED%20486%20system%20ConditionProviders.SCP%20Scheduling%20evaluate%20for%20Wed%20Jul%2005%2007%3A00%3A00%20GMT%2B00%3A00%202017%20(1499238000000)%2C%20in%20%2B4h23m10s690ms%2C%20now%3DWed%20Jul%2005%2002%3A36%3A49%20GMT%2B00%3A00%202017%20(1499222209310)%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_4%20(1106)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.showStrictModeViolation(int%2C%20int)%20for%20744ms%3CBR%20%2F%3ED%20486%20system%20ConditionProviders.SCP%20onReceive%20ScheduleConditionProvider.EVALUATE%3CBR%20%2F%3ED%20486%20system%20ConditionProviders.SCP%20notifyCondition%20condition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D6.7%26amp%3Bstart%3D23.30%26amp%3Bend%3D10.0%26amp%3BexitAtAlarm%3Dfalse%20STATE_FALSE%20reason%3D!meetsSchedule%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_4%20(1106)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D2%20in%20float%20com.android.server.wm.WindowManagerService.getCurrentAnimatorScale()%20for%20556ms%3CBR%20%2F%3ED%20486%20system%20ConditionProviders.SCP%20notifyCondition%20condition%3A%2F%2Fandroid%2Fschedule%3Fdays%3D1.2.3.4.5%26amp%3Bstart%3D22.0%26amp%3Bend%3D7.0%26amp%3BexitAtAlarm%3Dfalse%20STATE_TRUE%20reason%3DmeetsSchedule%3CBR%20%2F%3ED%20486%20system%20ConditionProviders.SCP%20Scheduling%20evaluate%20for%20Wed%20Jul%2005%2007%3A00%3A00%20GMT%2B00%3A00%202017%20(1499238000000)%2C%20in%20%2B4h23m10s682ms%2C%20now%3DWed%20Jul%2005%2002%3A36%3A49%20GMT%2B00%3A00%202017%20(1499222209318)%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_4%20(1106)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D1%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20749ms%3CBR%20%2F%3EE%20486%20system%20ActivityThread%20Failed%20to%20find%20provider%20info%20for%20com.android.calendar%3CBR%20%2F%3EE%20486%20system%20ActivityThread%20Failed%20to%20find%20provider%20info%20for%20com.android.calendar%3CBR%20%2F%3EE%20486%20system%20ActivityThread%20Failed%20to%20find%20provider%20info%20for%20com.android.calendar%3CBR%20%2F%3EE%20486%20system%20ActivityThread%20Failed%20to%20find%20provider%20info%20for%20com.android.calendar%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201332%20com.android.settings%20OpenGLRenderer%20Initialized%20EGL%2C%20version%201.4%3CBR%20%2F%3ED%201332%20com.android.settings%20OpenGLRenderer%20Swap%20behavior%202%3CBR%20%2F%3EE%201149%20com.android.phone%20ActivityThread%20Failed%20to%20find%20provider%20info%20for%20com.android.contacts%3CBR%20%2F%3EW%201149%20com.android.phone%20CallerInfoCache%20cursor%20is%20null%3CBR%20%2F%3ED%201149%20com.android.phone%20CarrierConfigLoader%20CarrierConfigLoader%20has%20started%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%2020%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Added%20callback%3A%20android.bluetooth.IBluetoothManagerCallback%24Stub%24Proxy%40dc31793%3Atrue%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%2030%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Trying%20to%20bind%20to%20profile%3A%201%2C%20while%20Bluetooth%20was%20disabled%3CBR%20%2F%3EI%201149%20com.android.phone%20Telephony%20TtyManager%3A%20updateUiTtyMode%20-1%20-%26gt%3B%200%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%201149%20com.android.phone%20PhoneSwitcherNetworkRequstListener%20got%20request%20NetworkRequest%20%5B%20REQUEST%20id%3D1%2C%20%5B%20Capabilities%3A%20INTERNET%26amp%3BNOT_RESTRICTED%26amp%3BTRUSTED%26amp%3BNOT_VPN%5D%20%5D%20with%20score%20110%3CBR%20%2F%3ED%201149%20com.android.phone%20TelephonyDebugService%20TelephonyDebugService()%3CBR%20%2F%3ED%201149%20com.android.phone%20CarrierConfigLoader%20mHandler%3A%2012%20phoneId%3A%200%3CBR%20%2F%3ED%201149%20com.android.phone%20CarrierConfigLoader%20Build%20fingerprint%20changed.%20old%3A%20null%20new%3A%20Freescale%2Fsabresd_6dq%2Fsabresd_6dq%3A7.1.1%2F1.0.0-ga-rc10%2F20170227%3Aeng%2Frelease-keys%3CBR%20%2F%3EE%201149%20com.android.phone%20PhoneInterfaceManager%20%5BPhoneIntfMgr%5D%20getIccId%3A%20No%20UICC%3CBR%20%2F%3EW%20486%20system%20Telecom%20%3A%20registerPhoneAccount%20not%20allowed%20on%20non-voice%20capable%20device.%3A%20TSI.rPA%40AAU%3CBR%20%2F%3EI%201149%20com.android.phone%20Telephony%20AccountEntry%3A%20Registered%20phoneAccount%3A%20%5B%5B%20%5D%20PhoneAccount%3A%20ComponentInfo%7Bcom.android.phone%2Fcom.android.services.telephony.TelephonyConnectionService%7D%2C%20%5Be0184adedf913b076626646d3f52c3b49c39ad6d%5D%2C%20UserHandle%7B0%7D%20Capabilities%3A%20CallProvider%20MultiUser%20PlaceEmerg%20SimSub%20Schemes%3A%20tel%20voicemail%20Extras%3A%20null%20GroupId%3A%20%5Bda39a3ee5e6b4b0d3255bfef95601890afd80709%5D%5D%20with%20handle%3A%20ComponentInfo%7Bcom.android.phone%2Fcom.android.services.telephony.TelephonyConnectionService%7D%2C%20%5Be0184adedf913b076626646d3f52c3b49c39ad6d%5D%2C%20UserHandle%7B0%7D%3CBR%20%2F%3EI%201149%20com.android.phone%20Telephony%20PstnIncomingCallNotifier%3A%20Registering%3A%20Handler%20(com.android.internal.telephony.GsmCdmaPhone)%20%7B167db5c%7D%3CBR%20%2F%3EE%201149%20com.android.phone%20PhoneInterfaceManager%20%5BPhoneIntfMgr%5D%20getIccId%3A%20No%20UICC%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20Telecom%20%3A%20registerPhoneAccount%20not%20allowed%20on%20non-voice%20capable%20device.%3A%20TSI.rPA%40AAg%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.setInsetsWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Region)%20for%20493ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20void%20com.android.server.wm.WindowManagerService.setDockedStackDividerTouchRegion(android.graphics.Rect)%20for%20494ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D2%20in%20void%20com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session%2C%20android.view.IWindow)%20for%20435ms%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201400%3Acom.android.deskclock%2Fu0a40%20for%20broadcast%20com.android.deskclock%2F.AlarmInitReceiver%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Displayed%20com.android.settings%2F.FallbackHome%3A%20%2B3s283ms%20(total%20%2B8s668ms)%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20user%200%20is%20still%20locked.%20Cannot%20load%20recents%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20WindowManager%20App%20freeze%20timeout%20expired.%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.notifyAppRelaunchesCleared(android.os.IBinder)%20for%20509ms%3CBR%20%2F%3EI%20486%20system%20WindowManager%20Screen%20frozen%20for%20%2B3s278ms%20due%20to%20Window%7Bdb0591e%20u0%20KeyguardScrim%7D%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20NetworkNotificationManager%20clearNotification%20id%3D100%3CBR%20%2F%3ED%20486%20system%20ConnectivityService%20NetworkAgentInfo%20%5BEthernet%20()%20-%20100%5D%20validation%20passed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowManagerService%24H.handleMessage(android.os.Message)(WindowManagerService.java%3A8361)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.notifyAppRelaunchesCleared(android.os.IBinder)%20for%202.171s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_7%20(1320)%20at%20void%20com.android.server.am.ActivityManagerService.activityDestroyed(android.os.IBinder)(ActivityManagerService.java%3A6951)%20waiters%3D0%20in%20void%20com.android.server.am.ActivityManagerService.dispatchUidsChanged()%20for%202.685s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_7%20(1320)%20at%20void%20com.android.server.am.ActivityManagerService.activityDestroyed(android.os.IBinder)(ActivityManagerService.java%3A6951)%20waiters%3D1%20in%20int%20com.android.server.am.ActivityManagerService.bindService(android.app.IApplicationThread%2C%20android.os.IBinder%2C%20android.content.Intent%2C%20java.lang.String%2C%20android.app.IServiceConnection%2C%20int%2C%20java.lang.String%2C%20int)%20for%202.684s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_7%20(1320)%20at%20void%20com.android.server.am.ActivityManagerService.activityDestroyed(android.os.IBinder)(ActivityManagerService.java%3A6951)%20waiters%3D3%20in%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)%20for%202.663s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_7%20(1320)%20at%20void%20com.android.server.am.ActivityManagerService.activityDestroyed(android.os.IBinder)(ActivityManagerService.java%3A6951)%20waiters%3D2%20in%20android.content.pm.UserInfo%20com.android.server.am.UserController.getCurrentUser()%20for%202.680s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_7%20(1320)%20at%20void%20com.android.server.am.ActivityManagerService.activityDestroyed(android.os.IBinder)(ActivityManagerService.java%3A6951)%20waiters%3D4%20in%20int%20com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread%2C%20android.content.Intent%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20int%2C%20java.lang.String%2C%20android.os.Bundle%2C%20java.lang.String%5B%5D%2C%20int%2C%20android.os.Bundle%2C%20boolean%2C%20boolean%2C%20int)%20for%202.038s%3CBR%20%2F%3EV%20486%20system%20KeyguardServiceDelegate%20***%20Keyguard%20started%3CBR%20%2F%3ED%20486%20system%20AccelSensor%20enable%201%20%2C%20handle%200%20%2CmEnabled%201%3CBR%20%2F%3EE%20486%20system%20SensorService%20Error%20activating%20sensor%200%20(Operation%20not%20permitted)%3CBR%20%2F%3EW%20486%20system%20KeyguardServiceDelegate%20onScreenTurningOn()%3A%20no%20keyguard%20service!%3CBR%20%2F%3EW%201400%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fapp%2FDeskClock%2Flib%2Farm%3CBR%20%2F%3EI%20486%20system%20StatusBarManagerService%20registerStatusBar%20bar%3Dcom.android.internal.statusbar.IStatusBar%24Stub%24Proxy%4079f0056%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201400%20art%20Before%20Android%204.1%2C%20method%20android.graphics.PorterDuffColorFilter%20android.support.graphics.drawable.VectorDrawableCompat.updateTintFilter(android.graphics.PorterDuffColorFilter%2C%20android.content.res.ColorStateList%2C%20android.graphics.PorterDuff%24Mode)%20would%20have%20incorrectly%20overridden%20the%20package-private%20method%20in%20android.graphics.drawable.Drawable%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201400%20AlarmClock%20AlarmInitReceiver%20android.intent.action.TIME_SET%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201400%20AlarmClock%20Alarms%20Table%20created%3CBR%20%2F%3EI%201400%20AlarmClock%20Instance%20table%20created%3CBR%20%2F%3EI%201400%20AlarmClock%20Inserting%20default%20alarms%3CBR%20%2F%3EE%201149%20com.android.phone%20PhoneInterfaceManager%20%5BPhoneIntfMgr%5D%20getCarrierPackageNamesForIntent%3A%20No%20UICC%3CBR%20%2F%3ED%201149%20com.android.phone%20CarrierSvcBindHelper%20No%20carrier%20app%20for%3A%200%3CBR%20%2F%3EV%201400%20AlarmClock%20AlarmInitReceiver%20finished%3CBR%20%2F%3ED%201368%20com.android.cellbroadcastreceiver%20CellBroadcastReceiver%20Service%20state%20changed!%201%20Full%3A%201%201%20voice%20home%20data%20home%20null%20null%20null%20null%20null%20null%20Unknown%20Unknown%20CSS%20not%20supported%20-1%20-1%20RoamInd%3D-1%20DefRoamInd%3D-1%20EmergOnly%3Dfalse%20IsDataRoamingFromRegistration%3Dfalse%20IsUsingCarrierAggregation%3Dfalse%20Current%20state%3D-1%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201080%20com.android.systemui%20art%20Background%20partial%20concurrent%20mark%20sweep%20GC%20freed%208536(960KB)%20AllocSpace%20objects%2C%201(20KB)%20LOS%20objects%2C%2039%25%20free%2C%202MB%2F4MB%2C%20paused%209.799ms%20total%2048.264ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%201080%20com.android.systemui%20System%20ClassLoader%20referenced%20unknown%20path%3A%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%201080%20com.android.systemui%20ApplicationLoaders%20ignored%20Vulkan%20layer%20search%20path%20%2Fsystem%2Fapp%2FCamera2%2Flib%2Farm%3A%2Fsystem%2Fapp%2FCamera2%2FCamera2.apk!%2Flib%2Farmeabi-v7a%3A%2Fsystem%2Flib%3A%2Fvendor%2Flib%20for%20namespace%200xb34a1090%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%2020%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Added%20callback%3A%20android.bluetooth.IBluetoothManagerCallback%24Stub%24Proxy%4055b24c1%3Atrue%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%2030%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%2030%3CBR%20%2F%3ED%201080%20com.android.systemui%20LocalBluetoothProfileManager%20Adding%20local%20MAP%20profile%3CBR%20%2F%3ED%201080%20com.android.systemui%20BluetoothMap%20Create%20BluetoothMap%20proxy%20object%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%2030%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%2030%3CBR%20%2F%3EI%20486%20system%20art%20Background%20partial%20concurrent%20mark%20sweep%20GC%20freed%2022625(1505KB)%20AllocSpace%20objects%2C%207(236KB)%20LOS%20objects%2C%2033%25%20free%2C%205MB%2F7MB%2C%20paused%204.119ms%20total%20101.485ms%3CBR%20%2F%3ED%201080%20com.android.systemui%20LocalBluetoothProfileManager%20LocalBluetoothProfileManager%20construction%20complete%3CBR%20%2F%3EI%201080%20com.android.systemui%20CameraManagerGlobal%20Connecting%20to%20camera%20service%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EE%201080%20com.android.systemui%20ActivityThread%20Failed%20to%20find%20provider%20info%20for%20com.android.contacts%3CBR%20%2F%3ED%201080%20com.android.systemui%20OpenGLRenderer%20profile%20bars%20disabled%3CBR%20%2F%3ED%201080%20com.android.systemui%20OpenGLRenderer%20ambientRatio%20%3D%201.50%3CBR%20%2F%3EW%20486%20system%20WindowManager%20Keyguard%20drawn%20timeout.%20Setting%20mKeyguardDrawComplete%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3ED%201080%20com.android.systemui%20PhoneStatusBar%20disable%3A%20%26lt%3B%20EXPAND*%20icons%20alerts%20system_info%20BACK*%20HOME*%20RECENT*%20clock%20SEARCH*%20quick_settings%20%26gt%3B%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2033%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EI%20486%20system%20InputReader%20Reconfiguring%20input%20devices.%20changes%3D0x00000010%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20int%20com.android.server.wm.WindowManagerService.watchRotation(android.view.IRotationWatcher)%20for%20516ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EI%20486%20system%20art%20Starting%20a%20blocking%20GC%20Explicit%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20int%20com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.view.InputChannel)%20for%20510ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20516ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%201080%20com.android.systemui%20PhoneStatusBar%20heads%20up%20is%20enabled%3CBR%20%2F%3ED%201080%20com.android.systemui%20StatusBar%20user%20hasn't%20seen%20notification%20about%20hidden%20notifications%3CBR%20%2F%3ED%201080%20com.android.systemui%20StatusBar%20insecure%20lockscreen%2C%20skipping%20notification%3CBR%20%2F%3EI%20486%20system%20art%20Explicit%20concurrent%20mark%20sweep%20GC%20freed%202946(181KB)%20AllocSpace%20objects%2C%204(296KB)%20LOS%20objects%2C%2033%25%20free%2C%205MB%2F7MB%2C%20paused%202.394ms%20total%2089.837ms%3CBR%20%2F%3EW%20486%20system%20WindowManager%20Timeout%20waiting%20for%20drawn%3A%20undrawn%3D%5BWindow%7Bdb0591e%20u0%20KeyguardScrim%7D%5D%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20int%20com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.view.InputChannel)%20for%20408ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20419ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_5%20(1182)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D2%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20527ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.ui%20(517)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D1%20in%20void%20com.android.server.wm.WindowManagerService.performEnableScreen()%20for%201.589s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.ui%20(517)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D2%20in%20void%20com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session%2C%20android.view.IWindow)%20for%201.584s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_4%20(1106)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D2%20in%20void%20com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session%2C%20android.view.IWindow)%20for%201.016s%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2093%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20486%20system%20WindowManager%20Window%20freeze%20timeout%20expired.%3CBR%20%2F%3EW%20486%20system%20WindowManager%20Force%20clearing%20orientation%20change%3A%20Window%7Bdb0591e%20u0%20KeyguardScrim%7D%3CBR%20%2F%3EW%20486%20system%20WindowManager%20Force%20clearing%20orientation%20change%3A%20Window%7B5dd23b0%20u0%20com.android.systemui.ImageWallpaper%7D%3CBR%20%2F%3EI%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Boot%20is%20finished%20(133195%20ms)%3CBR%20%2F%3EV%20486%20system%20KeyguardServiceDelegate%20***%20Keyguard%20connected%20(yay!)%3CBR%20%2F%3EI%201080%20com.android.systemui%20Choreographer%20Skipped%20213%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EE%20232%20%2Fsystem%2Fbin%2Finstalld%20Unable%20to%20unlink%20boot%20marker%20at%20%2Fdata%2F%2Fdalvik-cache%2Farm%2F.booting%2C%20error%3DNo%20such%20file%20or%20directory%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20mark%20boot%20complete%20for%20abi%3A%20armeabi-v7a%20(Failed%20to%20execute%20markbootcomplete%20%5Barm%5D%3A%20-1)%3CBR%20%2F%3EI%20486%20system%20SystemServiceManager%20Starting%20phase%201000%3CBR%20%2F%3ED%201080%20com.android.systemui%20ViewRootImpl%5BStatusBar%5D%20changeCanvasOpacity%3A%20opaque%3Dtrue%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201437%3Aandroid.ext.services%2Fu0a14%20for%20on-hold%3CBR%20%2F%3ED%20486%20system%20ActivityManager%20Finishing%20user%20boot%200%3CBR%20%2F%3ED%20486%20system%20CryptdConnector%20SND%20-%26gt%3B%20%7B3%20cryptfs%20prepare_user_storage%20!%200%200%202%7D%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20e4crypt_prepare_user_storage%20for%20volume%20null%2C%20user%200%2C%20serial%200%2C%20flags%202%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Preparing%3A%20%2Fdata%2Fsystem_ce%2F0%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Preparing%3A%20%2Fdata%2Fmisc_ce%2F0%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Preparing%3A%20%2Fdata%2Fmedia%2F0%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Preparing%3A%20%2Fdata%2Fdata%3CBR%20%2F%3ED%20486%20system%20CryptdConnector%20RCV%20%26lt%3B-%20%7B200%203%20Command%20succeeded%7D%3CBR%20%2F%3EV%20486%20system%20UserManagerService%20Found%20%2Fdata%2Fuser%2F0%20with%20serial%20number%200%3CBR%20%2F%3EV%20486%20system%20UserManagerService%20Found%20%2Fdata%2Fsystem_ce%2F0%20with%20serial%20number%20-1%3CBR%20%2F%3ED%20486%20system%20UserManagerService%20Serial%20number%20missing%20on%20%2Fdata%2Fsystem_ce%2F0%3B%20assuming%20current%20is%20valid%3CBR%20%2F%3EV%20486%20system%20PackageManager%20reconcileAppsData%20for%20null%20u0%200x2%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EV%20486%20system%20PackageManager%20reconcileAppsData%20finished%2080%20packages%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.am.ActivityManagerService.finishBooting()(ActivityManagerService.java%3A6822)%20waiters%3D0%20in%20android.content.Intent%20com.android.server.am.ActivityManagerService.registerReceiver(android.app.IApplicationThread%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20android.content.IntentFilter%2C%20java.lang.String%2C%20int)%20for%20396ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.am.ActivityManagerService.finishBooting()(ActivityManagerService.java%3A6822)%20waiters%3D1%20in%20void%20com.android.server.am.BroadcastQueue.processNextBroadcast(boolean)%20for%20389ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.am.ActivityManagerService.finishBooting()(ActivityManagerService.java%3A6822)%20waiters%3D2%20in%20android.content.pm.UserInfo%20com.android.server.am.UserController.getCurrentUser()%20for%20388ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.am.ActivityManagerService.finishBooting()(ActivityManagerService.java%3A6822)%20waiters%3D3%20in%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)%20for%20367ms%3CBR%20%2F%3EI%20486%20system%20UsageStatsService%20Time%20changed%20in%20UsageStats%20by%201499221972%20seconds%3CBR%20%2F%3EI%20486%20system%20UsageStatsService%20User%5B0%5D%20Flushing%20usage%20stats%20to%20disk%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20User%200%20unlocked%3CBR%20%2F%3ED%20486%20system%20MountService%20onUnlockUser%200%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20SND%20-%26gt%3B%20%7B31%20volume%20user_started%200%7D%3CBR%20%2F%3ED%20486%20system%20WIFI%20Registering%20NetworkFactory%3CBR%20%2F%3ED%20486%20system%20WIFI_UT%20Registering%20NetworkFactory%3CBR%20%2F%3ED%20486%20system%20ConnectivityService%20Got%20NetworkFactory%20Messenger%20for%20WIFI%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%20301%3CBR%20%2F%3ED%20486%20system%20ConnectivityService%20Got%20NetworkFactory%20Messenger%20for%20WIFI_UT%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20MESSAGE_USER_UNLOCKED%3CBR%20%2F%3ED%20486%20system%20WIFI%20got%20request%20NetworkRequest%20%5B%20REQUEST%20id%3D1%2C%20%5B%20Capabilities%3A%20INTERNET%26amp%3BNOT_RESTRICTED%26amp%3BTRUSTED%26amp%3BNOT_VPN%5D%20%5D%20with%20score%20150%3CBR%20%2F%3ED%20486%20system%20WIFI_UT%20got%20request%20NetworkRequest%20%5B%20REQUEST%20id%3D1%2C%20%5B%20Capabilities%3A%20INTERNET%26amp%3BNOT_RESTRICTED%26amp%3BTRUSTED%26amp%3BNOT_VPN%5D%20%5D%20with%20score%20150%3CBR%20%2F%3ED%20207%20%2Fsystem%2Fbin%2Fvold%20vold%20Linking%20%2Fstorage%2Femulated%2F0%20to%20%2Fmnt%2Fuser%2F0%2Fprimary%3CBR%20%2F%3ED%20486%20system%20VoldConnector%20RCV%20%26lt%3B-%20%7B200%2031%20Command%20succeeded%7D%3CBR%20%2F%3ED%20486%20system%20MountService%20Volume%20emulated%20broadcasting%20mounted%20to%20UserHandle%7B0%7D%3CBR%20%2F%3EI%201400%20com.android.deskclock%20AlarmClock%20AlarmInitReceiver%20android.intent.action.LOCKED_BOOT_COMPLETED%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2032%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20InputMethodManagerService%20All%20the%20enabled%20IMEs%20are%20gone.%20Reset%20default%20enabled%20IMEs.%3CBR%20%2F%3EI%20486%20system%20SELinux%20SELinux%3A%20Loaded%20file_contexts%20contexts%20from%20%2Ffile_contexts.bin.%3CBR%20%2F%3EW%201437%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fpriv-app%2FExtServices%2Flib%2Farm%3CBR%20%2F%3EV%20486%20system%20BackupManagerService%20No%20ancestral%20data%3CBR%20%2F%3EV%20486%20system%20BackupManagerService%20Starting%20with%20transport%20android%2Fcom.android.internal.backup.LocalTransport%3CBR%20%2F%3EV%20486%20system%20BackupManagerService%20Found%20transports%3A%201%3CBR%20%2F%3EI%20486%20system%20BackupManagerService%20Backup%20enable%20apparently%20not%20migrated%3CBR%20%2F%3EI%20486%20system%20BackupManagerService%20Migrating%20enable%20state%20false%3CBR%20%2F%3EI%20486%20system%20BackupManagerService%20Backup%20enabled%20%3D%26gt%3B%20false%3CBR%20%2F%3EI%20486%20system%20art%20Background%20sticky%20concurrent%20mark%20sweep%20GC%20freed%2027555(2MB)%20AllocSpace%20objects%2C%206(136KB)%20LOS%20objects%2C%2027%25%20free%2C%205MB%2F7MB%2C%20paused%2010.499ms%20total%2095.929ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20AppWidgetServiceImpl%20Failed%20to%20read%20state%3A%20java.io.FileNotFoundException%3A%20%2Fdata%2Fsystem%2Fusers%2F0%2Fappwidgets.xml%20(No%20such%20file%20or%20directory)%3CBR%20%2F%3EV%20486%20system%20AppWidgetServiceImpl%20Upgrading%20widget%20database%20from%200%20to%201%3CBR%20%2F%3EW%20486%20system%20VoiceInteractionManagerService%20no%20available%20voice%20interaction%20services%20found%20for%20user%200%3CBR%20%2F%3EW%20486%20system%20VoiceInteractionManagerService%20no%20available%20voice%20recognition%20services%20found%20for%20user%200%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Loading%20recents%20for%20user%200%20into%20memory.%3CBR%20%2F%3EI%20486%20system%20PreBootBroadcaster%20Pre-boot%20of%20%7Bcom.android.managedprovisioning%2Fcom.android.managedprovisioning.PreBootListener%7D%20for%20user%200%3CBR%20%2F%3ED%201149%20com.android.phone%20CarrierSvcBindHelper%20Received%20android.intent.action.USER_UNLOCKED%3CBR%20%2F%3ED%201332%20com.android.settings%20FallbackHome%20User%20unlocked%20and%20real%20home%20found%3B%20let's%20go!%3CBR%20%2F%3EE%201149%20com.android.phone%20PhoneInterfaceManager%20%5BPhoneIntfMgr%5D%20getCarrierPackageNamesForIntent%3A%20No%20UICC%3CBR%20%2F%3ED%201149%20com.android.phone%20CarrierSvcBindHelper%20No%20carrier%20app%20for%3A%200%3CBR%20%2F%3EW%20486%20system%20ResourceType%20No%20known%20package%20when%20getting%20value%20for%20resource%20number%200x7f0200fc%3CBR%20%2F%3EW%20486%20system%20ResourceType%20No%20known%20package%20when%20getting%20value%20for%20resource%20number%200x7f0e03a1%3CBR%20%2F%3EW%20486%20system%20ResourceType%20No%20known%20package%20when%20getting%20value%20for%20resource%20number%200x7f0200fb%3CBR%20%2F%3EW%20486%20system%20ResourceType%20No%20known%20package%20when%20getting%20value%20for%20resource%20number%200x7f0e092f%3CBR%20%2F%3EW%20486%20system%20ResourceType%20No%20known%20package%20when%20getting%20value%20for%20resource%20number%200x7f0200fa%3CBR%20%2F%3EW%20486%20system%20ResourceType%20No%20known%20package%20when%20getting%20value%20for%20resource%20number%200x7f0e07dd%3CBR%20%2F%3EI%20486%20system%20UsageStatsDatabase%20Time%20changed%20by%20%2B17352d2h32m52s565ms.%20files%20deleted%3A%200%20files%20moved%3A%204%3CBR%20%2F%3ED%201400%20com.android.deskclock%20Events%20%5BStopwatch%5D%20%5BReset%5D%20%5BReboot%5D%3CBR%20%2F%3EV%20486%20system%20KeyValueBackupJob%20Scheduling%20k%2Fv%20pass%20in%20246%20minutes%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20UsageStatsService%20User%5B0%5D%20Rollover%20scheduled%20%40%202017-07-06%2002%3A36%3A13(1499308573404)%3CBR%20%2F%3EW%20486%20system%20ResourceType%20No%20known%20package%20when%20getting%20value%20for%20resource%20number%200x7f020018%3CBR%20%2F%3EW%20486%20system%20ResourceType%20No%20known%20package%20when%20getting%20value%20for%20resource%20number%200x7f0b016c%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.policy.PhoneWindowManager.updateSettings()%20for%20320ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_7%20(1320)%20at%20boolean%20com.android.server.am.ActivityManagerService.finishActivity(android.os.IBinder%2C%20int%2C%20android.content.Intent%2C%20int)(ActivityManagerService.java%3A4838)%20waiters%3D0%20in%20void%20com.android.server.am.ActivityManagerService.serviceDoneExecuting(android.os.IBinder%2C%20int%2C%20int%2C%20int)%20for%20313ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_7%20(1320)%20at%20boolean%20com.android.server.am.ActivityManagerService.finishActivity(android.os.IBinder%2C%20int%2C%20android.content.Intent%2C%20int)(ActivityManagerService.java%3A4838)%20waiters%3D1%20in%20android.content.pm.UserInfo%20com.android.server.am.UserController.getCurrentUser()%20for%20310ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_7%20(1320)%20at%20boolean%20com.android.server.am.ActivityManagerService.finishActivity(android.os.IBinder%2C%20int%2C%20android.content.Intent%2C%20int)(ActivityManagerService.java%3A4838)%20waiters%3D3%20in%20int%20com.android.server.am.ActivityManagerService.getAppStartMode(int%2C%20java.lang.String)%20for%20293ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_7%20(1320)%20at%20boolean%20com.android.server.am.ActivityManagerService.finishActivity(android.os.IBinder%2C%20int%2C%20android.content.Intent%2C%20int)(ActivityManagerService.java%3A4838)%20waiters%3D6%20in%20android.content.IIntentSender%20com.android.server.am.ActivityManagerService.getIntentSender(int%2C%20java.lang.String%2C%20android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.Intent%5B%5D%2C%20java.lang.String%5B%5D%2C%20int%2C%20android.os.Bundle%2C%20int)%20for%20256ms%3CBR%20%2F%3EV%201400%20com.android.deskclock%20AlarmClock%20AlarmInitReceiver%20finished%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.resumeKeyDispatching(android.os.IBinder)%20for%20513ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.resumeKeyDispatching(android.os.IBinder)%20for%20531ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20START%20u0%20%7Bact%3Dandroid.intent.action.MAIN%20cat%3D%5Bandroid.intent.category.HOME%5D%20flg%3D0x10000100%20cmp%3Dcom.android.provision%2F.DefaultActivity%7D%20from%20uid%200%20on%20display%200%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.deferSurfaceLayout()%20for%20515ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.deferSurfaceLayout()%20for%20528ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.deferSurfaceLayout()%20for%20537ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2031%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.deferSurfaceLayout()%20for%20535ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.deferSurfaceLayout()%20for%20527ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.prepareAppTransition(int%2C%20boolean)%20for%20530ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.prepareAppTransition(int%2C%20boolean)%20for%20535ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.prepareAppTransition(int%2C%20boolean)%20for%20529ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.prepareAppTransition(int%2C%20boolean)%20for%20533ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.addAppToken(int%2C%20android.view.IApplicationToken%2C%20int%2C%20int%2C%20int%2C%20boolean%2C%20boolean%2C%20int%2C%20int%2C%20boolean%2C%20boolean%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20int%2C%20boolean%2C%20boolean%2C%20int%2C%20int)%20for%20534ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2031%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20526ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20532ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20536ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20527ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20534ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2031%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20546ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2031%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20542ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2031%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20533ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2031%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20529ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20532ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20534ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20530ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20533ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20534ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20529ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20535ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20534ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2031%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20529ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20534ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2031%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20534ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20529ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2031%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20534ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2031%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20535ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20532ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20530ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2031%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20boolean%20com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.res.CompatibilityInfo%2C%20java.lang.CharSequence%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.os.IBinder%2C%20boolean)%20for%20534ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.continueSurfaceLayout()%20for%20525ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201458%3Acom.android.provision%2Fu0a21%20for%20activity%20com.android.provision%2F.DefaultActivity%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_5%20(1182)%20at%20android.content.pm.UserInfo%20com.android.server.am.UserController.getCurrentUser()(UserController.java%3A1438)%20waiters%3D5%20in%20android.content.Intent%20com.android.server.am.ActivityManagerService.registerReceiver(android.app.IApplicationThread%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20android.content.IntentFilter%2C%20java.lang.String%2C%20int)%20for%2020.839s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_5%20(1182)%20at%20android.content.pm.UserInfo%20com.android.server.am.UserController.getCurrentUser()(UserController.java%3A1438)%20waiters%3D6%20in%20boolean%20com.android.server.am.ActivityManagerService.isUserRunning(int%2C%20int)%20for%2020.839s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_5%20(1182)%20at%20android.content.pm.UserInfo%20com.android.server.am.UserController.getCurrentUser()(UserController.java%3A1438)%20waiters%3D7%20in%20void%20com.android.server.am.ActivityManagerService.updateConfiguration(android.content.res.Configuration)%20for%2020.837s%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Config%20changes%3D20%20%7B1.0%20%3Fmcc%3Fmnc%20%5Ben_US%5D%20ldltr%20sw800dp%20w1280dp%20h728dp%20160dpi%20xlrg%20land%20finger%20-keyb%2Fv%2Fh%20-nav%2Fh%20s.6%7D%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2036%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20android.content.IIntentSender%20com.android.server.am.ActivityManagerService.getIntentSender(int%2C%20java.lang.String%2C%20android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20android.content.Intent%5B%5D%2C%20java.lang.String%5B%5D%2C%20int%2C%20android.os.Bundle%2C%20int)(ActivityManagerService.java%3A7102)%20waiters%3D4%20in%20void%20com.android.server.am.ActivityManagerService.appendDropBoxProcessHeaders(com.android.server.am.ProcessRecord%2C%20java.lang.String%2C%20java.lang.StringBuilder)%20for%2020.902s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_2%20(514)%20at%20void%20com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java%3A6915)%20waiters%3D4%20in%20void%20com.android.server.am.ActivityManagerService.finishReceiver(android.os.IBinder%2C%20int%2C%20java.lang.String%2C%20android.os.Bundle%2C%20boolean%2C%20int)%20for%2020.900s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_2%20(514)%20at%20void%20com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java%3A6915)%20waiters%3D5%20in%20boolean%20com.android.server.am.ActivityManagerService.isUserRunning(int%2C%20int)%20for%2020.875s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_4%20(1106)%20at%20void%20com.android.server.am.ActivityManagerService.appendDropBoxProcessHeaders(com.android.server.am.ProcessRecord%2C%20java.lang.String%2C%20java.lang.StringBuilder)(ActivityManagerService.java%3A13709)%20waiters%3D0%20in%20void%20com.android.server.am.ActivityManagerService%2420.run()%20for%2019.014s%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20NotificationSQLiteLog%20Pruned%20event%20entries%3A%202%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201473%3Aandroid.process.media%2Fu0a12%20for%20broadcast%20com.android.providers.downloads%2F.DownloadReceiver%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_2%20(514)%20at%20void%20com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java%3A6915)%20waiters%3D6%20in%20android.content.pm.UserInfo%20com.android.server.am.UserController.getCurrentUser()%20for%2020.897s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_2%20(514)%20at%20void%20com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java%3A6915)%20waiters%3D7%20in%20void%20com.android.server.am.ActivityManagerService%24MainHandler.handleMessage(android.os.Message)%20for%2020.464s%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Launch%20timeout%20has%20expired%2C%20giving%20up%20wake%20lock!%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_2%20(514)%20at%20void%20com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java%3A6915)%20waiters%3D9%20in%20int%20com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread%2C%20android.content.Intent%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20int%2C%20java.lang.String%2C%20android.os.Bundle%2C%20java.lang.String%5B%5D%2C%20int%2C%20android.os.Bundle%2C%20boolean%2C%20boolean%2C%20int)%20for%208.714s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_2%20(514)%20at%20void%20com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java%3A6915)%20waiters%3D8%20in%20int%20com.android.server.am.PendingIntentRecord.sendInner(int%2C%20android.content.Intent%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20java.lang.String%2C%20android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20int%2C%20int%2C%20android.os.Bundle%2C%20android.app.IActivityContainer)%20for%2018.869s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_2%20(514)%20at%20void%20com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java%3A6915)%20waiters%3D10%20in%20void%20com.android.server.am.ActivityManagerService.monitor()%20for%207.881s%3CBR%20%2F%3EI%20486%20system%20AccountManagerService%20User%200%20is%20unlocked%20-%20opening%20CE%20database%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20AccountManagerService%20Creating%20CE%20database%20%2Fdata%2Fsystem_ce%2F0%2Faccounts_ce.db%3CBR%20%2F%3EV%20486%20system%20BackupManagerService%20Connected%20to%20transport%20ComponentInfo%7Bandroid%2Fcom.android.internal.backup.LocalTransportService%7D%3CBR%20%2F%3EV%20486%20system%20BackupManagerService%20Registering%20transport%20android%2Fcom.android.internal.backup.LocalTransportService%3A%3Aandroid%2Fcom.android.internal.backup.LocalTransport%20%3D%20android.app.backup.BackupTransport%24TransportImpl%402ff8acf%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.ui%20(517)%20at%20void%20com.android.server.wm.WindowManagerService.continueSurfaceLayout()(WindowManagerService.java%3A5447)%20waiters%3D1%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20434ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20void%20com.android.server.wm.WindowManagerService.updateRotationUnchecked(boolean%2C%20boolean)%20for%201.506s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D2%20in%20void%20com.android.server.wm.WindowManagerService.startAppFreezingScreen(android.os.IBinder%2C%20int)%20for%201.471s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_6%20(1183)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D2%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%201.080s%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201080%20com.android.systemui%20OpenGLRenderer%20Initialized%20EGL%2C%20version%201.4%3CBR%20%2F%3ED%201080%20com.android.systemui%20OpenGLRenderer%20Swap%20behavior%202%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.executeAppTransition()%20for%201.050s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D1%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%201.007s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20ActivityManager%20(516)%20at%20void%20com.android.server.am.ActivityStackSupervisor%24ActivityStackSupervisorHandler.handleMessage(android.os.Message)(ActivityStackSupervisor.java%3A3903)%20waiters%3D7%20in%20int%20com.android.server.am.PendingIntentRecord.sendInner(int%2C%20android.content.Intent%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20java.lang.String%2C%20android.os.IBinder%2C%20java.lang.String%2C%20int%2C%20int%2C%20int%2C%20android.os.Bundle%2C%20android.app.IActivityContainer)%20for%202.541s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20main%20(486)%20at%20android.content.pm.UserInfo%20com.android.server.am.UserController.getCurrentUser()(UserController.java%3A1438)%20waiters%3D7%20in%20void%20com.android.server.am.ActivityStackSupervisor%24ActivityStackSupervisorHandler.handleMessage(android.os.Message)%20for%202.542s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20main%20(486)%20at%20android.content.pm.UserInfo%20com.android.server.am.UserController.getCurrentUser()(UserController.java%3A1438)%20waiters%3D7%20in%20void%20com.android.server.am.ActivityManagerService.monitor()%20for%202.542s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.bg%20(515)%20at%20boolean%20com.android.server.am.ActivityManagerService.isUserRunning(int%2C%20int)(ActivityManagerService.java%3A21694)%20waiters%3D7%20in%20boolean%20com.android.server.am.ActivityManagerService.isUserRunning(int%2C%20int)%20for%202.542s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_7%20(1320)%20at%20android.content.pm.UserInfo%20com.android.server.am.UserController.getCurrentUser()(UserController.java%3A1438)%20waiters%3D6%20in%20void%20com.android.server.am.ActivityManagerService.appendDropBoxProcessHeaders(com.android.server.am.ProcessRecord%2C%20java.lang.String%2C%20java.lang.StringBuilder)%20for%202.542s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_2%20(514)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D5%20in%20int%20com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread%2C%20android.content.Intent%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20int%2C%20java.lang.String%2C%20android.os.Bundle%2C%20java.lang.String%5B%5D%2C%20int%2C%20android.os.Bundle%2C%20boolean%2C%20boolean%2C%20int)%20for%202.541s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_2%20(514)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D6%20in%20boolean%20com.android.server.am.ActivityManagerService.isUserRunning(int%2C%20int)%20for%202.543s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_2%20(514)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D7%20in%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)%20for%202.520s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_2%20(514)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D8%20in%20int%20com.android.server.am.ActivityManagerService.getMemoryTrimLevel()%20for%202.385s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_2%20(514)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D9%20in%20void%20com.android.server.am.ActivityManagerService.dispatchUidsChanged()%20for%201.087s%3CBR%20%2F%3EW%201458%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fpriv-app%2FProvision%2Flib%2Farm%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201473%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fpriv-app%2FDownloadProvider%2Flib%2Farm%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201490%3Acom.android.printspooler%2Fu0a53%20for%20service%20com.android.printspooler%2F.model.PrintSpoolerService%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%20155%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EI%201080%20com.android.systemui%20vol.Events%20writeEvent%20level_changed%20STREAM_MUSIC%2010%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201504%3Acom.android.keychain%2F1000%20for%20service%20com.android.keychain%2F.KeyChainService%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.pauseKeyDispatching(android.os.IBinder)%20for%20374ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D1%20in%20void%20com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session%2C%20android.view.IWindow)%20for%20315ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20AsyncTask%20%234%20(1478)%20at%20int%20com.android.server.am.ActivityManagerService.bindService(android.app.IApplicationThread%2C%20android.os.IBinder%2C%20android.content.Intent%2C%20java.lang.String%2C%20android.app.IServiceConnection%2C%20int%2C%20java.lang.String%2C%20int)(ActivityManagerService.java%3A17254)%20waiters%3D2%20in%20boolean%20com.android.server.am.ActivityManagerService.isUserRunning(int%2C%20int)%20for%20403ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_5%20(1182)%20at%20boolean%20com.android.server.am.ActivityManagerService.finishActivity(android.os.IBinder%2C%20int%2C%20android.content.Intent%2C%20int)(ActivityManagerService.java%3A4838)%20waiters%3D3%20in%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)%20for%20323ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20WifiService%20New%20client%20listening%20to%20asynchronous%20messages%3CBR%20%2F%3EW%201473%20android.process.media%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fpriv-app%2FMediaProvider%2Flib%2Farm%3CBR%20%2F%3ED%201473%20android.process.media%20ApplicationLoaders%20ignored%20Vulkan%20layer%20search%20path%20%2Fsystem%2Fpriv-app%2FMediaProvider%2Flib%2Farm%3A%2Fsystem%2Fpriv-app%2FMediaProvider%2FMediaProvider.apk!%2Flib%2Farmeabi-v7a%3A%2Fsystem%2Flib%3A%2Fvendor%2Flib%20for%20namespace%200xb34a1090%3CBR%20%2F%3EW%201504%20pre%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fapp%2FKeyChain%2Flib%2Farm%3CBR%20%2F%3EI%20486%20system%20DevicePolicyManagerService%20Set%20ro.device_owner%20property%20to%20false%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20DownloadManager%20Upgrading%20downloads%20database%20from%20version%200%20to%20version%20110%2C%20which%20will%20destroy%20all%20old%20data%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20START%20u0%20%7Bact%3Dandroid.intent.action.MAIN%20cat%3D%5Bandroid.intent.category.HOME%5D%20flg%3D0x10000100%20cmp%3Dcom.android.launcher%2Fcom.android.launcher2.Launcher%7D%20from%20uid%200%20on%20display%200%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.deferSurfaceLayout()%20for%20516ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.moveTaskToTop(int)%20for%20523ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.addAppToken(int%2C%20android.view.IApplicationToken%2C%20int%2C%20int%2C%20int%2C%20boolean%2C%20boolean%2C%20int%2C%20int%2C%20boolean%2C%20boolean%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20int%2C%20boolean%2C%20boolean%2C%20int%2C%20int)%20for%20528ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.continueSurfaceLayout()%20for%20523ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.continueSurfaceLayout()%20for%20534ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.stopAppFreezingScreen(android.os.IBinder%2C%20boolean)%20for%20520ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201525%3Acom.android.launcher%2Fu0a16%20for%20activity%20com.android.launcher%2Fcom.android.launcher2.Launcher%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20void%20com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java%3A6915)%20waiters%3D0%20in%20com.android.server.am.ProcessRecord%20com.android.server.am.ActivityManagerService.findAppProcess(android.os.IBinder%2C%20java.lang.String)%20for%203.612s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20void%20com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java%3A6915)%20waiters%3D1%20in%20com.android.server.am.ProcessRecord%20com.android.server.am.ActivityManagerService.findAppProcess(android.os.IBinder%2C%20java.lang.String)%20for%203.605s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20void%20com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java%3A6915)%20waiters%3D2%20in%20android.content.pm.UserInfo%20com.android.server.am.UserController.getCurrentUser()%20for%203.597s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20void%20com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java%3A6915)%20waiters%3D3%20in%20android.content.Intent%20com.android.server.am.ActivityManagerService.registerReceiver(android.app.IApplicationThread%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20android.content.IntentFilter%2C%20java.lang.String%2C%20int)%20for%203.418s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20void%20com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java%3A6915)%20waiters%3D4%20in%20void%20com.android.server.am.ActivityStack%24ActivityStackHandler.handleMessage(android.os.Message)%20for%203.223s%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2032%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%201080%20com.android.systemui%20KeyguardUpdateMonitor%20invalid%20subId%20in%20handleSimStateChange()%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaProvider%20Upgrading%20media%20database%20from%20version%200%20to%20800%2C%20which%20will%20destroy%20all%20old%20data%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%201473%20android.process.media%20MediaProvider%20Adjusting%20external%20storage%20paths%20to%3A%20%2Fstorage%2Femulated%2F0%3CBR%20%2F%3EE%201473%20android.process.media%20SQLiteLog%20(1)%20no%20such%20table%3A%20album_info%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.prepareAppTransition(int%2C%20boolean)%20for%20495ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20void%20com.android.server.wm.WindowManagerService.statusBarVisibilityChanged(int)%20for%20482ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D2%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20482ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20ActivityManager%20(516)%20at%20void%20com.android.server.am.ActivityStackSupervisor%24ActivityStackSupervisorHandler.handleMessage(android.os.Message)(ActivityStackSupervisor.java%3A3884)%20waiters%3D0%20in%20com.android.server.am.ProcessRecord%20com.android.server.am.ActivityManagerService.findAppProcess(android.os.IBinder%2C%20java.lang.String)%20for%20496ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20ActivityManager%20(516)%20at%20void%20com.android.server.am.ActivityStackSupervisor%24ActivityStackSupervisorHandler.handleMessage(android.os.Message)(ActivityStackSupervisor.java%3A3884)%20waiters%3D1%20in%20com.android.server.am.ProcessRecord%20com.android.server.am.ActivityManagerService.findAppProcess(android.os.IBinder%2C%20java.lang.String)%20for%20496ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20ActivityManager%20(516)%20at%20void%20com.android.server.am.ActivityStackSupervisor%24ActivityStackSupervisorHandler.handleMessage(android.os.Message)(ActivityStackSupervisor.java%3A3884)%20waiters%3D2%20in%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)%20for%20475ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_4%20(1106)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D1%20in%20void%20com.android.server.wm.WindowManagerService.startAppFreezingScreen(android.os.IBinder%2C%20int)%20for%20525ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20391ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_3%20(1056)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.setAppVisibility(android.os.IBinder%2C%20boolean)%20for%20540ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D0%20in%20com.android.server.am.ProcessRecord%20com.android.server.am.ActivityManagerService.findAppProcess(android.os.IBinder%2C%20java.lang.String)%20for%201.085s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D1%20in%20void%20com.android.server.am.ActivityManagerService.serviceDoneExecuting(android.os.IBinder%2C%20int%2C%20int%2C%20int)%20for%201.029s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D2%20in%20com.android.server.am.ProcessRecord%20com.android.server.am.ActivityManagerService.findAppProcess(android.os.IBinder%2C%20java.lang.String)%20for%201.029s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D4%20in%20int%20com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread%2C%20android.content.Intent%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20int%2C%20java.lang.String%2C%20android.os.Bundle%2C%20java.lang.String%5B%5D%2C%20int%2C%20android.os.Bundle%2C%20boolean%2C%20boolean%2C%20int)%20for%20824ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D5%20in%20void%20com.android.server.am.ActivityStack%24ActivityStackHandler.handleMessage(android.os.Message)%20for%20563ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D3%20in%20void%20com.android.server.am.ActivityManagerService.publishContentProviders(android.app.IApplicationThread%2C%20java.util.List)%20for%20969ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20void%20com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java%3A6668)%20waiters%3D6%20in%20void%20com.android.server.am.ActivityManagerService%24LocalService.notifyStartingWindowDrawn()%20for%20564ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2062%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%201525%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fpriv-app%2FLauncher2%2Flib%2Farm%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%201473%20android.process.media%20MediaScannerReceiver%20action%3A%20android.intent.action.MEDIA_MOUNTED%20path%3A%20%2Fstorage%2Femulated%2F0%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201547%3Acom.android.managedprovisioning%2Fu0a17%20for%20broadcast%20com.android.managedprovisioning%2F.PreBootListener%3CBR%20%2F%3EW%201547%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fpriv-app%2FManagedProvisioning%2Flib%2Farm%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PreBootBroadcaster%20Pre-boot%20of%20%7Bcom.android.providers.calendar%2Fcom.android.providers.calendar.CalendarUpgradeReceiver%7D%20for%20user%200%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201567%3Acom.android.providers.calendar%2Fu0a4%20for%20broadcast%20com.android.providers.calendar%2F.CalendarUpgradeReceiver%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201567%20pre%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fpriv-app%2FCalendarProvider%2Flib%2Farm%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20405ms%3CBR%20%2F%3EV%201473%20android.process.media%20MediaScanner%20pruneDeadThumbnailFiles...%20android.content.ContentProviderClient%24CursorWrapperInner%40f8ad4d2%3CBR%20%2F%3EV%201473%20android.process.media%20MediaScanner%20%2FpruneDeadThumbnailFiles...%20android.content.ContentProviderClient%24CursorWrapperInner%40f8ad4d2%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201567%20pre%20CalendarDatabaseHelper%20Bootstrapping%20database%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201567%20pre%20CalendarProvider2%20Created%20com.android.providers.calendar.CalendarAlarmManager%405914b6e(com.android.providers.calendar.CalendarProvider2%408ecd20f)%3CBR%20%2F%3EI%20486%20system%20RetailDemoModeService%20Deleting%20contents%20of%20%2Fdata%2Fpreloads%3CBR%20%2F%3EI%201567%20pre%20CalendarUpgradeReceiver%20Creating%20or%20opening%20calendar%20database%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PreBootBroadcaster%20Pre-boot%20of%20%7Bcom.android.providers.contacts%2Fcom.android.providers.contacts.ContactsUpgradeReceiver%7D%20for%20user%200%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201585%3Aandroid.process.acore%2Fu0a3%20for%20broadcast%20com.android.providers.contacts%2F.ContactsUpgradeReceiver%3CBR%20%2F%3EW%201585%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fpriv-app%2FContactsProvider%2Flib%2Farm%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20535ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20float%20com.android.server.wm.WindowManagerService.getCurrentAnimatorScale()%20for%20535ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2031%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%201080%20com.android.systemui%20KeyguardUpdateMonitor%20invalid%20subId%20in%20handleServiceStateChange()%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EV%20486%20system%20KeyguardServiceDelegate%20****%20SHOWN%20CALLED%20****%3CBR%20%2F%3EI%201080%20com.android.systemui%20Choreographer%20Skipped%201856%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201585%20android.process.acore%20ContactsPerf%20VoicemailContentProvider.onCreate%20start%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201585%20android.process.acore%20ContactsPerf%20VoicemailContentProvider.onCreate%20finish%3CBR%20%2F%3EW%201585%20android.process.acore%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fpriv-app%2FBlockedNumberProvider%2Flib%2Farm%3CBR%20%2F%3ED%201585%20android.process.acore%20ApplicationLoaders%20ignored%20Vulkan%20layer%20search%20path%20%2Fsystem%2Fpriv-app%2FBlockedNumberProvider%2Flib%2Farm%3A%2Fsystem%2Flib%3A%2Fvendor%2Flib%20for%20namespace%200xb34a1090%3CBR%20%2F%3EI%201585%20android.process.acore%20ContactsDatabaseHelper%20Bootstrapping%20database%20version%3A%201111%3CBR%20%2F%3EW%201585%20android.process.acore%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fapp%2FUserDictionaryProvider%2Flib%2Farm%3CBR%20%2F%3ED%201585%20android.process.acore%20ApplicationLoaders%20ignored%20Vulkan%20layer%20search%20path%20%2Fsystem%2Fapp%2FUserDictionaryProvider%2Flib%2Farm%3A%2Fsystem%2Flib%3A%2Fvendor%2Flib%20for%20namespace%200xb34a10d0%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20StrictMode%20policy%20violation%3B%20~duration%3D184%20ms%3A%20android.os.StrictMode%24StrictModeDiskWriteViolation%3A%20policy%3D65565%20violation%3D1%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.os.StrictMode%24AndroidBlockGuardPolicy.onWriteToDisk(StrictMode.java%3A1253)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20libcore.io.BlockGuardOs.mkdir(BlockGuardOs.java%3A173)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.system.Os.mkdir(Os.java%3A282)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.app.ContextImpl.ensurePrivateDirExists(ContextImpl.java%3A514)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.app.ContextImpl.getPreferencesDir(ContextImpl.java%3A468)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.app.ContextImpl.getSharedPreferencesPath(ContextImpl.java%3A627)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.app.ContextImpl.getSharedPreferences(ContextImpl.java%3A345)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.content.ContextWrapper.getSharedPreferences(ContextWrapper.java%3A164)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.preference.PreferenceManager.getDefaultSharedPreferences(PreferenceManager.java%3A487)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20com.android.providers.contacts.FastScrollingIndexCache.getInstance(FastScrollingIndexCache.java%3A95)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20com.android.providers.contacts.ContactsProvider2.initialize(ContactsProvider2.java%3A1573)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20com.android.providers.contacts.ContactsProvider2.onCreate(ContactsProvider2.java%3A1548)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.content.ContentProvider.attachInfo(ContentProvider.java%3A1751)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.content.ContentProvider.attachInfo(ContentProvider.java%3A1726)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.app.ActivityThread.installProvider(ActivityThread.java%3A5853)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.app.ActivityThread.installContentProviders(ActivityThread.java%3A5445)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.app.ActivityThread.handleBindApplication(ActivityThread.java%3A5384)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.app.ActivityThread.-wrap2(ActivityThread.java)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.app.ActivityThread%24H.handleMessage(ActivityThread.java%3A1545)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.os.Handler.dispatchMessage(Handler.java%3A102)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.os.Looper.loop(Looper.java%3A154)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.app.ActivityThread.main(ActivityThread.java%3A6119)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20java.lang.reflect.Method.invoke(Native%20Method)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20com.android.internal.os.ZygoteInit%24MethodAndArgsCaller.run(ZygoteInit.java%3A886)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20com.android.internal.os.ZygoteInit.main(ZygoteInit.java%3A776)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20StrictMode%20policy%20violation%3B%20~duration%3D177%20ms%3A%20android.os.StrictMode%24StrictModeDiskWriteViolation%3A%20policy%3D65565%20violation%3D1%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.os.StrictMode%24AndroidBlockGuardPolicy.onWriteToDisk(StrictMode.java%3A1253)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20libcore.io.BlockGuardOs.chmod(BlockGuardOs.java%3A73)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.system.Os.chmod(Os.java%3A68)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.app.ContextImpl.ensurePrivateDirExists(ContextImpl.java%3A515)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.app.ContextImpl.getPreferencesDir(ContextImpl.java%3A468)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.app.ContextImpl.getSharedPreferencesPath(ContextImpl.java%3A627)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.app.ContextImpl.getSharedPreferences(ContextImpl.java%3A345)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.content.ContextWrapper.getSharedPreferences(ContextWrapper.java%3A164)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.preference.PreferenceManager.getDefaultSharedPreferences(PreferenceManager.java%3A487)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20com.android.providers.contacts.FastScrollingIndexCache.getInstance(FastScrollingIndexCache.java%3A95)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20com.android.providers.contacts.ContactsProvider2.initialize(ContactsProvider2.java%3A1573)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20com.android.providers.contacts.ContactsProvider2.onCreate(ContactsProvider2.java%3A1548)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.content.ContentProvider.attachInfo(ContentProvider.java%3A1751)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.content.ContentProvider.attachInfo(ContentProvider.java%3A1726)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.app.ActivityThread.installProvider(ActivityThread.java%3A5853)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.app.ActivityThread.installContentProviders(ActivityThread.java%3A5445)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.app.ActivityThread.handleBindApplication(ActivityThread.java%3A5384)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.app.ActivityThread.-wrap2(ActivityThread.java)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.app.ActivityThread%24H.handleMessage(ActivityThread.java%3A1545)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.os.Handler.dispatchMessage(Handler.java%3A102)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.os.Looper.loop(Looper.java%3A154)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20android.app.ActivityThread.main(ActivityThread.java%3A6119)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20java.lang.reflect.Method.invoke(Native%20Method)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20com.android.internal.os.ZygoteInit%24MethodAndArgsCaller.run(ZygoteInit.java%3A886)%3CBR%20%2F%3ED%201585%20android.process.acore%20StrictMode%20at%20com.android.internal.os.ZygoteInit.main(ZygoteInit.java%3A776)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201585%20android.process.acore%20ContactsUpgradeReceiver%20Creating%20or%20opening%20contacts%20database%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20473ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20A%20resource%20was%20acquired%20at%20attached%20stack%20trace%20but%20never%20released.%20See%20java.io.Closeable%20for%20information%20on%20avoiding%20resource%20leaks.%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20java.lang.Throwable%3A%20Explicit%20termination%20method%20'close'%20not%20called%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20dalvik.system.CloseGuard.open(CloseGuard.java%3A180)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20android.content.ContentResolver%24CursorWrapperInner.%3CINIT%3E(ContentResolver.java%3A2627)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20android.content.ContentResolver.query(ContentResolver.java%3A558)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20android.content.ContentResolver.query(ContentResolver.java%3A474)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20com.android.launcher2.LauncherProvider%24DatabaseHelper.convertDatabase(LauncherProvider.java%3A413)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20com.android.launcher2.LauncherProvider%24DatabaseHelper.onCreate(LauncherProvider.java%3A389)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20android.database.sqlite.SQLiteOpenHelper.getDatabaseLocked(SQLiteOpenHelper.java%3A251)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20android.database.sqlite.SQLiteOpenHelper.getWritableDatabase(SQLiteOpenHelper.java%3A163)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20com.android.launcher2.LauncherProvider%24DatabaseHelper.%3CINIT%3E(LauncherProvider.java%3A335)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20com.android.launcher2.LauncherProvider.onCreate(LauncherProvider.java%3A103)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20android.content.ContentProvider.attachInfo(ContentProvider.java%3A1751)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20android.content.ContentProvider.attachInfo(ContentProvider.java%3A1726)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20android.app.ActivityThread.installProvider(ActivityThread.java%3A5853)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20android.app.ActivityThread.installContentProviders(ActivityThread.java%3A5445)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20android.app.ActivityThread.handleBindApplication(ActivityThread.java%3A5384)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20android.app.ActivityThread.-wrap2(ActivityThread.java)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20android.app.ActivityThread%24H.handleMessage(ActivityThread.java%3A1545)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20android.os.Handler.dispatchMessage(Handler.java%3A102)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20android.os.Looper.loop(Looper.java%3A154)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20android.app.ActivityThread.main(ActivityThread.java%3A6119)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20java.lang.reflect.Method.invoke(Native%20Method)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20com.android.internal.os.ZygoteInit%24MethodAndArgsCaller.run(ZygoteInit.java%3A886)%3CBR%20%2F%3EE%201525%20com.android.launcher%20StrictMode%20at%20com.android.internal.os.ZygoteInit.main(ZygoteInit.java%3A776)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201585%20android.process.acore%20ContactsProviderV1%20Bootstrapping%20database%20legacy%20support%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201567%20com.android.providers.calendar%20CalendarProvider2%20Sending%20notification%20intent%3A%20Intent%20%7B%20act%3Dandroid.intent.action.PROVIDER_CHANGED%20dat%3Dcontent%3A%2F%2Fcom.android.calendar%20flg%3D0x20000000%20%7D%3CBR%20%2F%3EW%201567%20com.android.providers.calendar%20ContentResolver%20Failed%20to%20get%20type%20for%3A%20content%3A%2F%2Fcom.android.calendar%20(Unknown%20URL%20content%3A%2F%2Fcom.android.calendar)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20523ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20void%20com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session%2C%20android.view.IWindow)%20for%20519ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20void%20com.android.server.am.ActivityManagerService.setRequestedOrientation(android.os.IBinder%2C%20int)(ActivityManagerService.java%3A4784)%20waiters%3D0%20in%20boolean%20com.android.server.am.ActivityManagerService.isUserRunning(int%2C%20int)%20for%20328ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_1%20(513)%20at%20void%20com.android.server.am.ActivityManagerService.setRequestedOrientation(android.os.IBinder%2C%20int)(ActivityManagerService.java%3A4784)%20waiters%3D2%20in%20int%20com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread%2C%20android.content.Intent%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20int%2C%20java.lang.String%2C%20android.os.Bundle%2C%20java.lang.String%5B%5D%2C%20int%2C%20android.os.Bundle%2C%20boolean%2C%20boolean%2C%20int)%20for%20292ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2031%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%201080%20com.android.systemui%20FingerprintManager%20isFingerprintHardwareDetected()%3A%20Service%20not%20connected!%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201585%20android.process.acore%20art%20Long%20monitor%20contention%20with%20owner%20ContactsProviderWorker%20(1605)%20at%20long%20android.database.sqlite.SQLiteConnection.nativePrepareStatement(long%2C%20java.lang.String)(SQLiteConnection.java%3A-2)%20waiters%3D1%20in%20android.database.sqlite.SQLiteDatabase%20android.database.sqlite.SQLiteOpenHelper.getWritableDatabase()%20for%201.067s%3CBR%20%2F%3EW%201585%20android.process.acore%20art%20Long%20monitor%20contention%20with%20owner%20ContactsProviderWorker%20(1605)%20at%20long%20android.database.sqlite.SQLiteConnection.nativePrepareStatement(long%2C%20java.lang.String)(SQLiteConnection.java%3A-2)%20waiters%3D0%20in%20android.database.sqlite.SQLiteDatabase%20android.database.sqlite.SQLiteOpenHelper.getWritableDatabase()%20for%201.099s%3CBR%20%2F%3EI%201585%20android.process.acore%20CallLogDatabaseHelper%20Migrating%20from%20old%20tables...%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201585%20android.process.acore%20CallLogDatabaseHelper%20Source%20tables%20don't%20exist.%3CBR%20%2F%3EI%201585%20android.process.acore%20ContactsDatabaseHelper%20Bootstrapping%20database%20version%3A%201111%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201585%20android.process.acore%20CallLogDatabaseHelper%20Migrating%20from%20old%20tables...%3CBR%20%2F%3EI%201585%20android.process.acore%20CallLogDatabaseHelper%20Source%20tables%20don't%20exist.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20511ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20float%20com.android.server.wm.WindowManagerService.getCurrentAnimatorScale()%20for%20491ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201585%20android.process.acore%20ContactLocale%20AddressBook%20Labels%20%5B%5Ben_US%5D%5D%3A%20%5B%E2%80%A6%2C%20A%2C%20B%2C%20C%2C%20D%2C%20E%2C%20F%2C%20G%2C%20H%2C%20I%2C%20J%2C%20K%2C%20L%2C%20M%2C%20N%2C%20O%2C%20P%2C%20Q%2C%20R%2C%20S%2C%20T%2C%20U%2C%20V%2C%20W%2C%20X%2C%20Y%2C%20Z%2C%20%CE%91%2C%20%CE%92%2C%20%CE%93%2C%20%CE%94%2C%20%CE%95%2C%20%CE%96%2C%20%CE%97%2C%20%CE%98%2C%20%CE%99%2C%20%CE%9A%2C%20%CE%9B%2C%20%CE%9C%2C%20%CE%9D%2C%20%CE%9E%2C%20%CE%9F%2C%20%CE%A0%2C%20%CE%A1%2C%20%CE%A3%2C%20%CE%A4%2C%20%CE%A5%2C%20%CE%A6%2C%20%CE%A7%2C%20%CE%A8%2C%20%CE%A9%2C%20%E2%80%A6%2C%20%D0%90%2C%20%D0%91%2C%20%D0%92%2C%20%D0%93%2C%20%D0%94%2C%20%3F%2C%20%D0%95%2C%20%3F%2C%20%D0%96%2C%20%D0%97%2C%20%D0%98%2C%20%3F%2C%20%D0%99%2C%20%3F%2C%20%D0%9A%2C%20%D0%9B%2C%20%3F%2C%20%D0%9C%2C%20%D0%9D%2C%20%3F%2C%20%D0%9E%2C%20%D0%9F%2C%20%D0%A0%2C%20%D0%A1%2C%20%D0%A2%2C%20%3F%2C%20%D0%A3%2C%20%D0%A4%2C%20%D0%A5%2C%20%D0%A6%2C%20%D0%A7%2C%20%3F%2C%20%D0%A8%2C%20%D0%A9%2C%20%D0%AE%2C%20%D0%AF%2C%20%E2%80%A6%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%E2%80%A6%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%E2%80%A6%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%3F%2C%20%E2%80%A6%2C%20%E3%84%B1%2C%20%E3%84%B4%2C%20%E3%84%B7%2C%20%E3%84%B9%2C%20%E3%85%81%2C%20%E3%85%82%2C%20%E3%85%85%2C%20%E3%85%87%2C%20%E3%85%88%2C%20%E3%85%8A%2C%20%E3%85%8B%2C%20%E3%85%8C%2C%20%E3%85%8D%2C%20%E3%85%8E%2C%20%E2%80%A6%2C%20%E3%81%82%2C%20%E3%81%8B%2C%20%E3%81%95%2C%20%E3%81%9F%2C%20%E3%81%AA%2C%20%E3%81%AF%2C%20%E3%81%BE%2C%20%E3%82%84%2C%20%E3%82%89%2C%20%E3%82%8F%2C%20%23%2C%20%E2%80%A6%5D%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201585%20android.process.acore%20ContactsProviderV1%20Bootstrapping%20database%20legacy%20support%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201585%20android.process.acore%20ContactsProvider%20Locale%20has%20changed%20from%20null%20to%20%5Ben_US%5D%3CBR%20%2F%3EI%201585%20android.process.acore%20ContactsDatabaseHelper%20Switching%20to%20locale%20%5Ben_US%5D%20(ICU%20v56.1)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D2%20in%20int%20com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.view.InputChannel)%20for%20982ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowManagerService%24H.handleMessage(android.os.Message)(WindowManagerService.java%3A8850)%20waiters%3D2%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20536ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201585%20android.process.acore%20ContactsDatabaseHelper%20Locale%20change%20completed%20in%20252ms%3CBR%20%2F%3EI%201585%20android.process.acore%20ContactsDatabaseHelper%20Switching%20to%20locale%20%5Ben_US%5D%20(ICU%20v56.1)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201585%20android.process.acore%20ContactsDatabaseHelper%20Locale%20change%20completed%20in%20223ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D2%20in%20float%20com.android.server.wm.WindowManagerService.getCurrentAnimatorScale()%20for%201.058s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowManagerService%24H.handleMessage(android.os.Message)(WindowManagerService.java%3A8361)%20waiters%3D3%20in%20int%20com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.view.InputChannel)%20for%20533ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D3%20in%20void%20com.android.server.wm.WindowManagerService.notifyAppRelaunchesCleared(android.os.IBinder)%20for%20628ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D3%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20530ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20ActivityManager%20(516)%20at%20void%20com.android.server.am.ActivityStackSupervisor%24ActivityStackSupervisorHandler.activityIdleInternal(com.android.server.am.ActivityRecord)(ActivityStackSupervisor.java%3A3841)%20waiters%3D0%20in%20android.content.Intent%20com.android.server.am.ActivityManagerService.registerReceiver(android.app.IApplicationThread%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20android.content.IntentFilter%2C%20java.lang.String%2C%20int)%20for%20470ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2032%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EI%201525%20com.android.launcher%20imx6.gralloc%20open%20gpu%20gralloc%20module!%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201585%20android.process.acore%20ContactDirectoryManager%20deleted%200%20stale%20rows%20which%20don't%20have%20any%20relevant%20directory%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201585%20android.process.acore%20ContactDirectoryManager%20Discovered%200%20contact%20directories%20in%20127ms%3CBR%20%2F%3EI%201585%20android.process.acore%20ContactsProvider%20Upgrading%20aggregation%20algorithm%3CBR%20%2F%3EI%201585%20android.process.acore%20ContactAggregator%20Marked%20all%20visible%20contacts%20for%20aggregation%3A%200%20raw%20contacts%2C%202%20ms%3CBR%20%2F%3EI%201585%20android.process.acore%20ContactsProvider%20Aggregation%20algorithm%20upgraded%20for%200%20raw%20contacts%20in%2037ms%3CBR%20%2F%3EI%201585%20android.process.acore%20ContactsFTS%20Rebuild%20contact%20search%20index%20in%2034ms%2C%200%20contacts%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.notifyAppRelaunchesCleared(android.os.IBinder)%20for%20507ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20int%20com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.view.InputChannel)%20for%20477ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_4%20(1106)%20at%20android.content.Intent%20com.android.server.am.ActivityManagerService.registerReceiver(android.app.IApplicationThread%2C%20java.lang.String%2C%20android.content.IIntentReceiver%2C%20android.content.IntentFilter%2C%20java.lang.String%2C%20int)(ActivityManagerService.java%3A17578)%20waiters%3D4%20in%20void%20com.android.server.am.ActivityManagerService%243.handleMessage(android.os.Message)%20for%20522ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_8%20(1472)%20at%20void%20com.android.server.am.ActivityManagerService.activityDestroyed(android.os.IBinder)(ActivityManagerService.java%3A6951)%20waiters%3D1%20in%20void%20com.android.server.am.ActivityManagerService%24MainHandler.handleMessage(android.os.Message)%20for%20520ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_8%20(1472)%20at%20void%20com.android.server.am.ActivityManagerService.activityDestroyed(android.os.IBinder)(ActivityManagerService.java%3A6951)%20waiters%3D2%20in%20int%20com.android.server.am.ActivityManagerService.getLockTaskModeState()%20for%20520ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_8%20(1472)%20at%20void%20com.android.server.am.ActivityManagerService.activityDestroyed(android.os.IBinder)(ActivityManagerService.java%3A6951)%20waiters%3D4%20in%20com.android.server.am.ProcessRecord%20com.android.server.am.ActivityManagerService.findAppProcess(android.os.IBinder%2C%20java.lang.String)%20for%20487ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_8%20(1472)%20at%20void%20com.android.server.am.ActivityManagerService.activityDestroyed(android.os.IBinder)(ActivityManagerService.java%3A6951)%20waiters%3D3%20in%20void%20com.android.server.am.ActivityManagerService.unregisterReceiver(android.content.IIntentReceiver)%20for%20500ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EI%20486%20system%20PreBootBroadcaster%20Pre-boot%20of%20%7Bcom.android.providers.media%2Fcom.android.providers.media.MediaUpgradeReceiver%7D%20for%20user%200%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%201400%20com.android.deskclock%20Events%20%5BAnalog%20Widget%5D%20%5BCreate%5D%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201618%3Acom.android.calendar%2Fu0a34%20for%20broadcast%20com.android.calendar%2F.alerts.AlertReceiver%3CBR%20%2F%3EI%20486%20system%20art%20Background%20sticky%20concurrent%20mark%20sweep%20GC%20freed%2015898(1264KB)%20AllocSpace%20objects%2C%2017(516KB)%20LOS%20objects%2C%2022%25%20free%2C%206MB%2F7MB%2C%20paused%208.368ms%20total%2066.283ms%3CBR%20%2F%3EE%201149%20com.android.phone%20PhoneInterfaceManager%20%5BPhoneIntfMgr%5D%20getCarrierPackageNamesForIntent%3A%20No%20UICC%3CBR%20%2F%3ED%201149%20com.android.phone%20CarrierSvcBindHelper%20No%20carrier%20app%20for%3A%200%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201618%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fapp%2FCalendar%2Flib%2Farm%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%201618%20com.android.calendar%20ExtensionsFactory%20No%20custom%20extensions.%3CBR%20%2F%3ED%201618%20com.android.calendar%20AlertReceiver%20onReceive%3A%20a%3Dandroid.intent.action.PROVIDER_CHANGED%20Intent%20%7B%20act%3Dandroid.intent.action.PROVIDER_CHANGED%20dat%3Dcontent%3A%2F%2Fcom.android.calendar%20flg%3D0x20000010%20cmp%3Dcom.android.calendar%2F.alerts.AlertReceiver%20%7D%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%201618%20com.android.calendar%20AlertUtils%20Flushing%20old%20alerts%20from%20shared%20prefs%20table%3CBR%20%2F%3ED%201618%20com.android.calendar%20AlertService%200%20Action%20%3D%20android.intent.action.PROVIDER_CHANGED%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Launch%20timeout%20has%20expired%2C%20giving%20up%20wake%20lock!%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaUpgradeReceiver%20---%26gt%3B%20Start%20upgrade%20of%20media%20database%20external.db%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20Timeout%20of%20broadcast%20BroadcastRecord%7B8cf6977%20u-1%20android.intent.action.TIME_TICK%7D%20-%20receiver%3Dandroid.os.BinderProxy%40293899d%2C%20started%2010000ms%20ago%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20Receiver%20during%20timeout%3A%20BroadcastFilter%7B281f9e3%20u0%20ReceiverList%7B92d9e12%201080%20com.android.systemui%2F10026%2Fu0%20remote%3A293899d%7D%7D%3CBR%20%2F%3EI%201473%20android.process.media%20MediaUpgradeReceiver%20%26lt%3B---%20Finished%20upgrade%20of%20media%20database%20external.db%20in%2039ms%3CBR%20%2F%3EI%20486%20system%20PreBootBroadcaster%20Pre-boot%20of%20%7Bcom.android.settings%2Fcom.android.settings.SettingsInitialize%7D%20for%20user%200%3CBR%20%2F%3EI%20486%20system%20Process%20Sending%20signal.%20PID%3A%201080%20SIG%3A%203%3CBR%20%2F%3EI%201080%20com.android.systemui%20art%20Thread%5B3%2Ctid%3D1091%2CWaitingInMainSignalCatcherLoop%2CThread*%3D0xa72bb800%2Cpeer%3D0x12c00af0%2C%22Signal%20Catcher%22%5D%3A%20reacting%20to%20signal%203%3CBR%20%2F%3EI%201080%20com.android.systemui%20art%20%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.removeWindow(com.android.server.wm.Session%2C%20android.view.IWindow)%20for%20518ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20int%20com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.view.InputChannel)%20for%20488ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D2%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20486ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2032%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201080%20com.android.systemui%20art%20Wrote%20stack%20traces%20to%20'%2Fdata%2Fanr%2Ftraces.txt'%3CBR%20%2F%3EE%20486%20system%20ActivityManager%20ANR%20in%20com.android.systemui%3CBR%20%2F%3EE%20486%20system%20ActivityManager%20PID%3A%201080%3CBR%20%2F%3EE%20486%20system%20ActivityManager%20Reason%3A%20Broadcast%20of%20Intent%20%7B%20act%3Dandroid.intent.action.TIME_TICK%20flg%3D0x50000014%20(has%20extras)%20%7D%3CBR%20%2F%3EE%20486%20system%20ActivityManager%20Load%3A%200.0%20%2F%200.0%20%2F%200.0%3CBR%20%2F%3EE%20486%20system%20ActivityManager%20CPU%20usage%20from%206352ms%20to%200ms%20ago%20(2017-07-05%2002%3A37%3A25.654%20to%202017-07-05%2002%3A37%3A32.006)%3A%3CBR%20%2F%3EE%20486%20system%20ActivityManager%2026%25%20486%2Fsystem_server%3A%2016%25%20user%20%2B%2010%25%20kernel%20%2F%20faults%3A%20738%20minor%3CBR%20%2F%3EE%20486%20system%20ActivityManager%2014%25%20108%2Fmmcqd%2F3%3A%200%25%20user%20%2B%2014%25%20kernel%3CBR%20%2F%3EE%20486%20system%20ActivityManager%209.9%25%201473%2Fandroid.process.media%3A%208.3%25%20user%20%2B%201.5%25%20kernel%20%2F%20faults%3A%201786%20minor%3CBR%20%2F%3EE%20486%20system%20ActivityManager%205.8%25%201080%2Fcom.android.systemui%3A%204.5%25%20user%20%2B%201.2%25%20kernel%20%2F%20faults%3A%205700%20minor%3CBR%20%2F%3EE%20486%20system%20ActivityManager%204.8%25%20223%2Fadbd%3A%201.1%25%20user%20%2B%203.7%25%20kernel%20%2F%20faults%3A%201164%20minor%3CBR%20%2F%3EE%20486%20system%20ActivityManager%202.3%25%20653%2Fkworker%2F0%3A1H%3A%200%25%20user%20%2B%202.3%25%20kernel%3CBR%20%2F%3EE%20486%20system%20ActivityManager%201.5%25%201490%2Fcom.android.printspooler%3A%201.1%25%20user%20%2B%200.4%25%20kernel%20%2F%20faults%3A%20406%20minor%3CBR%20%2F%3EE%20486%20system%20ActivityManager%201.4%25%20199%2Flogd%3A%200.9%25%20user%20%2B%200.4%25%20kernel%20%2F%20faults%3A%2013%20minor%3CBR%20%2F%3EE%20486%20system%20ActivityManager%201.2%25%20228%2Fzygote%3A%200%25%20user%20%2B%201.2%25%20kernel%20%2F%20faults%3A%20631%20minor%3CBR%20%2F%3EE%20486%20system%20ActivityManager%200.9%25%201400%2Fcom.android.deskclock%3A%200.4%25%20user%20%2B%200.4%25%20kernel%20%2F%20faults%3A%20184%20minor%3CBR%20%2F%3EE%20486%20system%20ActivityManager%200.6%25%20959%2Flogcat%3A%200.4%25%20user%20%2B%200.1%25%20kernel%20%2F%20faults%3A%202%20minor%3CBR%20%2F%3EE%20486%20system%20ActivityManager%200.4%25%20191%2Fjbd2%2Fmmcblk3p4-%3A%200%25%20user%20%2B%200.4%25%20kernel%3CBR%20%2F%3EE%20486%20system%20ActivityManager%200.4%25%20220%2Fservicemanager%3A%200%25%20user%20%2B%200.4%25%20kernel%3CBR%20%2F%3EE%20486%20system%20ActivityManager%200.4%25%201332%2Fcom.android.settings%3A%200.4%25%20user%20%2B%200%25%20kernel%20%2F%20faults%3A%208%20minor%3CBR%20%2F%3EE%20486%20system%20ActivityManager%200.4%25%201504%2Fcom.android.keychain%3A%200.3%25%20user%20%2B%200.1%25%20kernel%20%2F%20faults%3A%20151%20minor%3CBR%20%2F%3EE%20486%20system%20ActivityManager%200%25%203%2Fksoftirqd%2F0%3A%200%25%20user%20%2B%200%25%20kernel%3CBR%20%2F%3EE%20486%20system%20ActivityManager%200%25%20219%2Flmkd%3A%200%25%20user%20%2B%200%25%20kernel%3CBR%20%2F%3EE%20486%20system%20ActivityManager%200%25%201063%2Fsdcard%3A%200%25%20user%20%2B%200%25%20kernel%20%2F%20faults%3A%204%20minor%3CBR%20%2F%3EE%20486%20system%20ActivityManager%200.1%25%206%2Fkworker%2Fu8%3A0%3A%200%25%20user%20%2B%200.1%25%20kernel%3CBR%20%2F%3EE%20486%20system%20ActivityManager%200.1%25%207%2Frcu_preempt%3A%200%25%20user%20%2B%200.1%25%20kernel%3CBR%20%2F%3EE%20486%20system%20ActivityManager%200.1%25%2039%2Fcfinteractive%3A%200%25%20user%20%2B%200.1%25%20kernel%3CBR%20%2F%3EE%20486%20system%20ActivityManager%200%25%20113%2Fgalcore%20deamon%20%3A%200%25%20user%20%2B%200%25%20kernel%3CBR%20%2F%3EE%20486%20system%20ActivityManager%200%25%20185%2Fkworker%2F3%3A1%3A%200%25%20user%20%2B%200%25%20kernel%3CBR%20%2F%3EE%20486%20system%20ActivityManager%200.1%25%201149%2Fcom.android.phone%3A%200%25%20user%20%2B%200.1%25%20kernel%20%2F%20faults%3A%203%20minor%3CBR%20%2F%3EE%20486%20system%20ActivityManager%200.1%25%201437%2Fandroid.ext.services%3A%200.1%25%20user%20%2B%200%25%20kernel%20%2F%20faults%3A%208%20minor%3CBR%20%2F%3EE%20486%20system%20ActivityManager%200.1%25%201458%2Fcom.android.provision%3A%200.1%25%20user%20%2B%200%25%20kernel%3CBR%20%2F%3EE%20486%20system%20ActivityManager%20%2B0%25%201525%2Fcom.android.launcher%3A%200%25%20user%20%2B%200%25%20kernel%3CBR%20%2F%3EE%20486%20system%20ActivityManager%20%2B0%25%201547%2Fcom.android.managedprovisioning%3A%200%25%20user%20%2B%200%25%20kernel%3CBR%20%2F%3EE%20486%20system%20ActivityManager%20%2B0%25%201567%2Fcom.android.providers.calendar%3A%200%25%20user%20%2B%200%25%20kernel%3CBR%20%2F%3EE%20486%20system%20ActivityManager%20%2B0%25%201585%2Fandroid.process.acore%3A%200%25%20user%20%2B%200%25%20kernel%3CBR%20%2F%3EE%20486%20system%20ActivityManager%20%2B0%25%201618%2Fcom.android.calendar%3A%200%25%20user%20%2B%200%25%20kernel%3CBR%20%2F%3EE%20486%20system%20ActivityManager%2041%25%20TOTAL%3A%2022%25%20user%20%2B%2013%25%20kernel%20%2B%204.6%25%20iowait%20%2B%201.2%25%20softirq%3CBR%20%2F%3EE%20486%20system%20ActivityManager%20CPU%20usage%20from%20185394ms%20to%20185394ms%20ago%20(1970-01-01%2000%3A00%3A00.000%20to%201970-01-01%2000%3A00%3A00.000)%20with%200%25%20awake%3A%3CBR%20%2F%3EE%20486%20system%20ActivityManager%200%25%20TOTAL%3A%200%25%20user%20%2B%200%25%20kernel%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_3%20(1056)%20at%20int%20com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.view.InputChannel)(WindowManagerService.java%3A1884)%20waiters%3D2%20in%20void%20com.android.server.wm.WindowManagerService.notifyAppRelaunchesCleared(android.os.IBinder)%20for%20509ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_8%20(1472)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D2%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20365ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_8%20(1472)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D1%20in%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)%20for%20515ms%3CBR%20%2F%3EI%201525%20com.android.launcher%20OpenGLRenderer%20Initialized%20EGL%2C%20version%201.4%3CBR%20%2F%3ED%201525%20com.android.launcher%20OpenGLRenderer%20Swap%20behavior%202%3CBR%20%2F%3EI%201525%20com.android.launcher%20Choreographer%20Skipped%2060%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3ED%20486%20system%20ActivityManager%20Sending%20BOOT_COMPLETE%20user%20%230%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Killing%201080%3Acom.android.systemui%2Fu0a26%20(adj%20-800)%3A%20bg%20anr%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EV%20486%20system%20KeyguardServiceDelegate%20***%20Keyguard%20disconnected%20(boo!)%3CBR%20%2F%3EW%20486%20system%20InputDispatcher%20channel%20'c707108%20DockedStackDivider%20(server)'%20~%20Consumer%20closed%20input%20channel%20or%20an%20error%20occurred.%20events%3D0x9%3CBR%20%2F%3EE%20486%20system%20InputDispatcher%20channel%20'c707108%20DockedStackDivider%20(server)'%20~%20Channel%20is%20unrecoverably%20broken%20and%20will%20be%20disposed!%3CBR%20%2F%3EW%20486%20system%20InputDispatcher%20channel%20'6a3fa81%20StatusBar%20(server)'%20~%20Consumer%20closed%20input%20channel%20or%20an%20error%20occurred.%20events%3D0x9%3CBR%20%2F%3EE%20486%20system%20InputDispatcher%20channel%20'6a3fa81%20StatusBar%20(server)'%20~%20Channel%20is%20unrecoverably%20broken%20and%20will%20be%20disposed!%3CBR%20%2F%3EW%20486%20system%20InputDispatcher%20channel%20'33a5eac%20AssistPreviewPanel%20(server)'%20~%20Consumer%20closed%20input%20channel%20or%20an%20error%20occurred.%20events%3D0x9%3CBR%20%2F%3EE%20486%20system%20InputDispatcher%20channel%20'33a5eac%20AssistPreviewPanel%20(server)'%20~%20Channel%20is%20unrecoverably%20broken%20and%20will%20be%20disposed!%3CBR%20%2F%3EW%20486%20system%20InputDispatcher%20channel%20'498630a%20NavigationBar%20(server)'%20~%20Consumer%20closed%20input%20channel%20or%20an%20error%20occurred.%20events%3D0x9%3CBR%20%2F%3EE%20486%20system%20InputDispatcher%20channel%20'498630a%20NavigationBar%20(server)'%20~%20Channel%20is%20unrecoverably%20broken%20and%20will%20be%20disposed!%3CBR%20%2F%3EW%20486%20system%20InputDispatcher%20channel%20'5dd23b0%20com.android.systemui.ImageWallpaper%20(server)'%20~%20Consumer%20closed%20input%20channel%20or%20an%20error%20occurred.%20events%3D0x9%3CBR%20%2F%3EE%20486%20system%20InputDispatcher%20channel%20'5dd23b0%20com.android.systemui.ImageWallpaper%20(server)'%20~%20Channel%20is%20unrecoverably%20broken%20and%20will%20be%20disposed!%3CBR%20%2F%3EW%20486%20system%20InputDispatcher%20channel%20'eecbb69%20DockedStackDivider%20(server)'%20~%20Consumer%20closed%20input%20channel%20or%20an%20error%20occurred.%20events%3D0x9%3CBR%20%2F%3EE%20486%20system%20InputDispatcher%20channel%20'eecbb69%20DockedStackDivider%20(server)'%20~%20Channel%20is%20unrecoverably%20broken%20and%20will%20be%20disposed!%3CBR%20%2F%3EW%20486%20system%20InputDispatcher%20channel%20'7db448b%20AssistPreviewPanel%20(server)'%20~%20Consumer%20closed%20input%20channel%20or%20an%20error%20occurred.%20events%3D0x9%3CBR%20%2F%3EE%20486%20system%20InputDispatcher%20channel%20'7db448b%20AssistPreviewPanel%20(server)'%20~%20Channel%20is%20unrecoverably%20broken%20and%20will%20be%20disposed!%3CBR%20%2F%3ED%20486%20system%20WifiService%20Client%20connection%20lost%20with%20reason%3A%204%3CBR%20%2F%3ED%20486%20system%20GraphicsStats%20Buffer%20count%3A%202%3CBR%20%2F%3EW%20486%20system%20AudioService%20Current%20remote%20volume%20controller%20died%2C%20unregistering%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Process%20com.android.systemui%20(pid%201080)%20has%20died%3CBR%20%2F%3ED%20486%20system%20ActivityManager%20cleanUpApplicationRecord%20--%201080%3CBR%20%2F%3EW%20486%20system%20WallpaperManagerService%20Wallpaper%20service%20gone%3A%20ComponentInfo%7Bcom.android.systemui%2Fcom.android.systemui.ImageWallpaper%7D%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Scheduling%20restart%20of%20crashed%20service%20com.android.systemui%2F.ImageWallpaper%20in%200ms%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Scheduling%20restart%20of%20crashed%20service%20com.android.systemui%2F.keyguard.KeyguardService%20in%200ms%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Scheduling%20restart%20of%20crashed%20service%20com.android.systemui%2F.SystemUIService%20in%200ms%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Re-adding%20persistent%20process%20ProcessRecord%7Bc7eaaf9%201080%3Acom.android.systemui%2Fu0a26%7D%3CBR%20%2F%3EW%20486%20system%20VolumeController%20Error%20calling%20dismiss%3CBR%20%2F%3EW%20486%20system%20VolumeController%20android.os.DeadObjectException%3CBR%20%2F%3EW%20486%20system%20VolumeController%20at%20android.os.BinderProxy.transactNative(Native%20Method)%3CBR%20%2F%3EW%20486%20system%20VolumeController%20at%20android.os.BinderProxy.transact(Binder.java%3A615)%3CBR%20%2F%3EW%20486%20system%20VolumeController%20at%20android.media.IVolumeController%24Stub%24Proxy.dismiss(IVolumeController.java%3A162)%3CBR%20%2F%3EW%20486%20system%20VolumeController%20at%20com.android.server.audio.AudioService%24VolumeController.postDismiss(AudioService.java%3A6138)%3CBR%20%2F%3EW%20486%20system%20VolumeController%20at%20com.android.server.audio.AudioService.setVolumeController(AudioService.java%3A5986)%3CBR%20%2F%3EW%20486%20system%20VolumeController%20at%20com.android.server.audio.AudioService%244.binderDied(AudioService.java%3A5995)%3CBR%20%2F%3EW%20486%20system%20VolumeController%20at%20android.os.BinderProxy.sendDeathNotice(Binder.java%3A688)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20libprocessgroup%20failed%20to%20open%20%2Facct%2Fuid_10026%2Fpid_1080%2Fcgroup.procs%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3ED%20486%20system%20ConnectivityService%20ConnectivityService%20NetworkRequestInfo%20binderDied(NetworkRequest%20%5B%20LISTEN%20id%3D4%2C%20%5B%5D%20%5D%2C%20android.os.BinderProxy%4033f4d80)%3CBR%20%2F%3EE%20486%20system%20ConnectivityService%20RemoteException%20caught%20trying%20to%20send%20a%20callback%20msg%20for%20NetworkRequest%20%5B%20LISTEN%20id%3D4%2C%20%5B%5D%20%5D%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201658%3Acom.android.systemui%2Fu0a26%20for%20restart%20com.android.systemui%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20Failure%20sending%20broadcast%20Intent%20%7B%20act%3Dandroid.intent.action.TIME_TICK%20flg%3D0x50000014%20(has%20extras)%20%7D%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20android.os.RemoteException%3A%20app.thread%20must%20not%20be%20null%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20com.android.server.am.BroadcastQueue.performReceiveLocked(BroadcastQueue.java%3A492)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20com.android.server.am.BroadcastQueue.deliverToRegisteredReceiverLocked(BroadcastQueue.java%3A666)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20com.android.server.am.BroadcastQueue.processNextBroadcast(BroadcastQueue.java%3A951)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20com.android.server.am.BroadcastQueue%24BroadcastHandler.handleMessage(BroadcastQueue.java%3A172)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20android.os.Handler.dispatchMessage(Handler.java%3A102)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20android.os.Looper.loop(Looper.java%3A154)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20android.os.HandlerThread.run(HandlerThread.java%3A61)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20com.android.server.ServiceThread.run(ServiceThread.java%3A46)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20Failure%20sending%20broadcast%20Intent%20%7B%20act%3Dandroid.intent.action.BOOT_COMPLETED%20flg%3D0x9000010%20(has%20extras)%20%7D%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20android.os.RemoteException%3A%20app.thread%20must%20not%20be%20null%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20com.android.server.am.BroadcastQueue.performReceiveLocked(BroadcastQueue.java%3A492)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20com.android.server.am.BroadcastQueue.deliverToRegisteredReceiverLocked(BroadcastQueue.java%3A666)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20com.android.server.am.BroadcastQueue.processNextBroadcast(BroadcastQueue.java%3A951)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20com.android.server.am.BroadcastQueue%24BroadcastHandler.handleMessage(BroadcastQueue.java%3A172)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20android.os.Handler.dispatchMessage(Handler.java%3A102)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20android.os.Looper.loop(Looper.java%3A154)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20android.os.HandlerThread.run(HandlerThread.java%3A61)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20com.android.server.ServiceThread.run(ServiceThread.java%3A46)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20Failure%20sending%20broadcast%20Intent%20%7B%20act%3Dandroid.intent.action.TIME_TICK%20flg%3D0x50000014%20(has%20extras)%20%7D%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20android.os.RemoteException%3A%20app.thread%20must%20not%20be%20null%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20com.android.server.am.BroadcastQueue.performReceiveLocked(BroadcastQueue.java%3A492)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20com.android.server.am.BroadcastQueue.deliverToRegisteredReceiverLocked(BroadcastQueue.java%3A666)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20com.android.server.am.BroadcastQueue.processNextBroadcast(BroadcastQueue.java%3A951)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20com.android.server.am.BroadcastQueue%24BroadcastHandler.handleMessage(BroadcastQueue.java%3A172)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20android.os.Handler.dispatchMessage(Handler.java%3A102)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20android.os.Looper.loop(Looper.java%3A154)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20android.os.HandlerThread.run(HandlerThread.java%3A61)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20com.android.server.ServiceThread.run(ServiceThread.java%3A46)%3CBR%20%2F%3EE%20486%20system%20BootReceiver%20Error%20reading%20%2Fdata%2Fsystem%2Flast-header.txt%3CBR%20%2F%3EE%20486%20system%20BootReceiver%20java.io.FileNotFoundException%3A%20%2Fdata%2Fsystem%2Flast-header.txt%20(No%20such%20file%20or%20directory)%3CBR%20%2F%3EE%20486%20system%20BootReceiver%20at%20java.io.FileInputStream.open(Native%20Method)%3CBR%20%2F%3EE%20486%20system%20BootReceiver%20at%20java.io.FileInputStream.%3CINIT%3E(FileInputStream.java%3A146)%3CBR%20%2F%3EE%20486%20system%20BootReceiver%20at%20android.os.FileUtils.readTextFile(FileUtils.java%3A263)%3CBR%20%2F%3EE%20486%20system%20BootReceiver%20at%20com.android.server.BootReceiver.getPreviousBootHeaders(BootReceiver.java%3A121)%3CBR%20%2F%3EE%20486%20system%20BootReceiver%20at%20com.android.server.BootReceiver.getBootHeadersToLogAndUpdate(BootReceiver.java%3A143)%3CBR%20%2F%3EE%20486%20system%20BootReceiver%20at%20com.android.server.BootReceiver.logBootEvents(BootReceiver.java%3A163)%3CBR%20%2F%3EE%20486%20system%20BootReceiver%20at%20com.android.server.BootReceiver.-wrap2(BootReceiver.java)%3CBR%20%2F%3EE%20486%20system%20BootReceiver%20at%20com.android.server.BootReceiver%241.run(BootReceiver.java%3A93)%3CBR%20%2F%3EI%20486%20system%20RecoverySystem%20No%20recovery%20log%20file%3CBR%20%2F%3EI%20486%20system%20BootReceiver%20No%20existing%20last%20log%20timestamp%20file%20%2Fdata%2Fsystem%2Flog-files.xml%3B%20starting%20empty%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201673%3Acom.android.dialer%2Fu0a10%20for%20broadcast%20com.android.dialer%2F.calllog.CallLogReceiver%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20Failure%20sending%20broadcast%20Intent%20%7B%20act%3Dandroid.intent.action.TIME_TICK%20flg%3D0x50000014%20(has%20extras)%20%7D%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20android.os.RemoteException%3A%20app.thread%20must%20not%20be%20null%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20com.android.server.am.BroadcastQueue.performReceiveLocked(BroadcastQueue.java%3A492)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20com.android.server.am.BroadcastQueue.deliverToRegisteredReceiverLocked(BroadcastQueue.java%3A666)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20com.android.server.am.BroadcastQueue.processNextBroadcast(BroadcastQueue.java%3A951)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20com.android.server.am.BroadcastQueue%24BroadcastHandler.handleMessage(BroadcastQueue.java%3A172)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20android.os.Handler.dispatchMessage(Handler.java%3A102)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20android.os.Looper.loop(Looper.java%3A154)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20android.os.HandlerThread.run(HandlerThread.java%3A61)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20at%20com.android.server.ServiceThread.run(ServiceThread.java%3A46)%3CBR%20%2F%3EI%20486%20system%20BootReceiver%20Copying%20audit%20failures%20to%20DropBox%3CBR%20%2F%3EI%20486%20system%20BootReceiver%20Checking%20for%20fsck%20errors%3CBR%20%2F%3EW%201658%20Binder%20Binder%20call%20failed.%3CBR%20%2F%3EW%201658%20Binder%20android.os.DeadObjectException%3CBR%20%2F%3EW%201658%20Binder%20at%20android.os.BinderProxy.transactNative(Native%20Method)%3CBR%20%2F%3EW%201658%20Binder%20at%20android.os.BinderProxy.transact(Binder.java%3A615)%3CBR%20%2F%3EW%201658%20Binder%20at%20android.content.IIntentReceiver%24Stub%24Proxy.performReceive(IIntentReceiver.java%3A124)%3CBR%20%2F%3EW%201658%20Binder%20at%20android.app.ActivityThread%24ApplicationThread.scheduleRegisteredReceiver(ActivityThread.java%3A946)%3CBR%20%2F%3EW%201658%20Binder%20at%20android.app.ApplicationThreadNative.onTransact(ApplicationThreadNative.java%3A404)%3CBR%20%2F%3EW%201658%20Binder%20at%20android.os.Binder.execTransact(Binder.java%3A565)%3CBR%20%2F%3EW%201658%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fpriv-app%2FSystemUI%2Flib%2Farm%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20art%20Background%20partial%20concurrent%20mark%20sweep%20GC%20freed%2013083(1324KB)%20AllocSpace%20objects%2C%2018(1224KB)%20LOS%20objects%2C%2033%25%20free%2C%205MB%2F8MB%2C%20paused%205.336ms%20total%20151.061ms%3CBR%20%2F%3EV%201658%20com.android.systemui%20SystemUIService%20Starting%20SystemUI%20services%20for%20user%200.%3CBR%20%2F%3EW%201673%20com.android.dialer%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fpriv-app%2FDialer%2Flib%2Farm%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%201673%20com.android.dialer%20ExtensionsFactory%20No%20custom%20extensions.%3CBR%20%2F%3EI%201673%20com.android.dialer%20BlockedNumbersAuto%20Updating%20state%20as%20already%20checked%20for%20auto-migrate.%3CBR%20%2F%3EI%201673%20com.android.dialer%20BlockedNumbersAuto%20Attempting%20to%20auto-migrate.%3CBR%20%2F%3ED%201149%20com.android.phone%20CarrierConfigLoader%20mHandler%3A%2013%20phoneId%3A%200%3CBR%20%2F%3ED%201149%20com.android.phone%20CarrierConfigLoader%20mHandler%3A%207%20phoneId%3A%200%3CBR%20%2F%3EE%201149%20com.android.phone%20CarrierConfigLoader%20Cannot%20restore%20config%20with%20null%20packageName%20or%20iccid.%3CBR%20%2F%3ED%201149%20com.android.phone%20CarrierConfigLoader%20Binding%20to%20com.android.carrierconfig%20for%20phone%200%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201673%20com.android.dialer%20CountryDetector%20No%20location%20permissions%2C%20not%20registering%20for%20location%20updates.%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201698%3Acom.android.carrierconfig%2Fu0a5%20for%20service%20com.android.carrierconfig%2F.DefaultCarrierConfigService%3CBR%20%2F%3ED%201618%20com.android.calendar%20AlertReceiver%20onReceive%3A%20a%3Dandroid.intent.action.BOOT_COMPLETED%20Intent%20%7B%20act%3Dandroid.intent.action.BOOT_COMPLETED%20flg%3D0x9000010%20cmp%3Dcom.android.calendar%2F.alerts.AlertReceiver%20(has%20extras)%20%7D%3CBR%20%2F%3EI%201400%20com.android.deskclock%20AlarmClock%20AlarmInitReceiver%20android.intent.action.BOOT_COMPLETED%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201698%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fpriv-app%2FCarrierConfig%2Flib%2Farm%3CBR%20%2F%3EI%201673%20com.android.dialer%20BlockedNumbersAuto%20Auto-migrating%3A%20no%20blocked%20numbers.%3CBR%20%2F%3EV%201400%20com.android.deskclock%20AlarmClock%20AlarmInitReceiver%20finished%3CBR%20%2F%3ED%201698%20DefaultCarrierConfigService%20Service%20created%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201717%3Acom.android.email%2Fu0a42%20for%20broadcast%20com.android.email%2F.service.EmailUpgradeBroadcastReceiver%3CBR%20%2F%3ED%201149%20com.android.phone%20CarrierConfigLoader%20Connected%20to%20config%20app%3A%20com.android.carrierconfig%2Fcom.android.carrierconfig.DefaultCarrierConfigService%3CBR%20%2F%3ED%201149%20com.android.phone%20CarrierConfigLoader%20mHandler%3A%203%20phoneId%3A%200%3CBR%20%2F%3ED%201698%20DefaultCarrierConfigService%20Config%20being%20fetched%3CBR%20%2F%3ED%201698%20DefaultCarrierConfigService%20java.io.FileNotFoundException%3A%20carrier_config_.xml%3CBR%20%2F%3EE%201149%20com.android.phone%20CarrierConfigLoader%20Cannot%20save%20config%20with%20null%20packageName%20or%20iccid.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%201149%20com.android.phone%20CarrierConfigLoader%20mHandler%3A%205%20phoneId%3A%200%3CBR%20%2F%3EE%201149%20com.android.phone%20PhoneInterfaceManager%20%5BPhoneIntfMgr%5D%20getCarrierPackageNamesForIntent%3A%20No%20UICC%3CBR%20%2F%3EI%20486%20system%20Telecom%20PhoneAccountRegistrar%3A%20SimCallManager%20queried%2C%20returning%3A%20null%3A%20TSI.gSCMFU%40AA8%3CBR%20%2F%3EW%201717%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fapp%2FEmail%2Flib%2Farm%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20act%3Dcom.android.email.EXCHANGE_INTENT%20pkg%3Dcom.android.exchange%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3ED%201717%20com.android.email%20ActivityThread%20Loading%20provider%20com.android.email.provider%3Bcom.android.email.notifier%3A%20com.android.email.provider.EmailProvider%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20act%3Dcom.android.email.EXCHANGE_INTENT%20pkg%3Dcom.android.exchange%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3ED%201717%20com.android.email%20ActivityThread%20Loading%20provider%20com.android.email.provider%3Bcom.android.email.notifier%3A%20com.android.email.provider.EmailProvider%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20act%3Dcom.android.email.EXCHANGE_INTENT%20pkg%3Dcom.android.exchange%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3ED%201717%20com.android.email%20ActivityThread%20Loading%20provider%20com.android.email.provider%3Bcom.android.email.notifier%3A%20com.android.email.provider.EmailProvider%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20act%3Dcom.android.email.EXCHANGE_INTENT%20pkg%3Dcom.android.exchange%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3ED%201717%20com.android.email%20ActivityThread%20Loading%20provider%20com.android.email.provider%3Bcom.android.email.notifier%3A%20com.android.email.provider.EmailProvider%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20act%3Dcom.android.email.EXCHANGE_INTENT%20pkg%3Dcom.android.exchange%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.Session.setWallpaperPosition(android.os.IBinder%2C%20float%2C%20float%2C%20float%2C%20float)%20for%201.015s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20void%20com.android.server.wm.WindowState%24DeathRecipient.binderDied()%20for%20941ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D2%20in%20void%20com.android.server.wm.WindowState%24DeathRecipient.binderDied()%20for%20942ms%3CBR%20%2F%3EI%20486%20system%20WindowManager%20WIN%20DEATH%3A%20Window%7B7db448b%20u0%20AssistPreviewPanel%7D%3CBR%20%2F%3EW%20486%20system%20InputDispatcher%20Attempted%20to%20unregister%20already%20unregistered%20input%20channel%20'7db448b%20AssistPreviewPanel%20(server)'%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D3%20in%20void%20com.android.server.wm.WindowState%24DeathRecipient.binderDied()%20for%20955ms%3CBR%20%2F%3EI%20486%20system%20InputReader%20Reconfiguring%20input%20devices.%20changes%3D0x00000010%3CBR%20%2F%3EI%20486%20system%20WindowManager%20WIN%20DEATH%3A%20Window%7B5dd23b0%20u0%20com.android.systemui.ImageWallpaper%7D%3CBR%20%2F%3EW%20486%20system%20InputDispatcher%20Attempted%20to%20unregister%20already%20unregistered%20input%20channel%20'5dd23b0%20com.android.systemui.ImageWallpaper%20(server)'%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D4%20in%20void%20com.android.server.wm.WindowState%24DeathRecipient.binderDied()%20for%20959ms%3CBR%20%2F%3EI%20486%20system%20WindowManager%20WIN%20DEATH%3A%20Window%7B6a3fa81%20u0%20StatusBar%7D%3CBR%20%2F%3EW%20486%20system%20InputDispatcher%20Attempted%20to%20unregister%20already%20unregistered%20input%20channel%20'6a3fa81%20StatusBar%20(server)'%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D5%20in%20void%20com.android.server.wm.WindowManagerService%249.binderDied()%20for%20966ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D6%20in%20void%20com.android.server.wm.WindowState%24DeathRecipient.binderDied()%20for%20965ms%3CBR%20%2F%3EI%20486%20system%20WindowManager%20WIN%20DEATH%3A%20Window%7B33a5eac%20u0%20AssistPreviewPanel%7D%3CBR%20%2F%3EW%20486%20system%20InputDispatcher%20Attempted%20to%20unregister%20already%20unregistered%20input%20channel%20'33a5eac%20AssistPreviewPanel%20(server)'%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D7%20in%20void%20com.android.server.wm.WindowState%24DeathRecipient.binderDied()%20for%20970ms%3CBR%20%2F%3EI%20486%20system%20WindowManager%20WIN%20DEATH%3A%20Window%7B498630a%20u0%20NavigationBar%7D%3CBR%20%2F%3EW%20486%20system%20InputDispatcher%20Attempted%20to%20unregister%20already%20unregistered%20input%20channel%20'498630a%20NavigationBar%20(server)'%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D8%20in%20void%20com.android.server.wm.WindowState%24DeathRecipient.binderDied()%20for%20968ms%3CBR%20%2F%3EI%20486%20system%20WindowManager%20WIN%20DEATH%3A%20Window%7Bc707108%20u0%20DockedStackDivider%7D%3CBR%20%2F%3EW%20486%20system%20InputDispatcher%20Attempted%20to%20unregister%20already%20unregistered%20input%20channel%20'c707108%20DockedStackDivider%20(server)'%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D9%20in%20void%20com.android.server.wm.Session.binderDied()%20for%20970ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D10%20in%20float%20com.android.server.wm.WindowManagerService.getCurrentAnimatorScale()%20for%20769ms%3CBR%20%2F%3EI%20486%20system%20WindowManager%20WIN%20DEATH%3A%20Window%7Beecbb69%20u0%20DockedStackDivider%7D%3CBR%20%2F%3EW%20486%20system%20InputDispatcher%20Attempted%20to%20unregister%20already%20unregistered%20input%20channel%20'eecbb69%20DockedStackDivider%20(server)'%3CBR%20%2F%3EV%201658%20com.android.systemui%20MediaRouter%20Adding%20route%3A%20RouteInfo%7B%20name%3DTablet%2C%20description%3Dnull%2C%20status%3Dnull%2C%20category%3DRouteCategory%7B%20name%3Dnull%20types%3DROUTE_TYPE_LIVE_AUDIO%20ROUTE_TYPE_LIVE_VIDEO%20groupable%3Dfalse%20%7D%2C%20supportedTypes%3DROUTE_TYPE_LIVE_AUDIO%20ROUTE_TYPE_LIVE_VIDEO%20%2C%20presentationDisplay%3Dnull%20%7D%3CBR%20%2F%3EV%201658%20com.android.systemui%20MediaRouter%20Updating%20audio%20routes%3A%20AudioRoutesInfo%7B%20type%3DSPEAKER%20%7D%3CBR%20%2F%3EV%201658%20com.android.systemui%20MediaRouter%20Selecting%20route%3A%20RouteInfo%7B%20name%3DTablet%2C%20description%3Dnull%2C%20status%3Dnull%2C%20category%3DRouteCategory%7B%20name%3Dnull%20types%3DROUTE_TYPE_LIVE_AUDIO%20ROUTE_TYPE_LIVE_VIDEO%20groupable%3Dfalse%20%7D%2C%20supportedTypes%3DROUTE_TYPE_LIVE_AUDIO%20ROUTE_TYPE_LIVE_VIDEO%20%2C%20presentationDisplay%3Dnull%20%7D%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2035%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20WindowManager%20On%20display%3D0%20Rebuild%20removed%202%20windows%20but%20added%201%20rebuildAppWindowListLocked()%20callers%3Dcom.android.server.wm.WindowManagerService.rebuildAppWindowListLocked%3A9438%20com.android.server.wm.WindowManagerService.handleAnimatingStoppedAndTransitionLocked%3A9582%20com.android.server.wm.WindowSurfacePlacer.performSurfacePlacementInner%3A350%20com.android.server.wm.WindowSurfacePlacer.performSurfacePlacementLoop%3A236%20com.android.server.wm.WindowSurfacePlacer.performSurfacePlacement%3A184%20com.android.server.wm.WindowManagerService.removeWindowInnerLocked%3A2639%20com.android.server.wm.AppWindowToken.destroySurfaces%3A422%20com.android.server.wm.AppWindowToken.destroySurfaces%3A384%20com.android.server.wm.WindowStateAnimator.finishExit%3A566%20com.android.server.wm.WindowStateAnimator.stepAnimationLocked%3A492%3CBR%20%2F%3EW%20486%20system%20WindowManager%20This%20window%20was%20lost%3A%20Window%7Bc135c0e%20u0%20com.android.settings%2Fcom.android.settings.FallbackHome%7D%3CBR%20%2F%3EW%20486%20system%20WindowManager%20mDisplayId%3D0%20mSession%3DSession%7Ba56f3f%201332%3A1000%7D%20mClient%3Dandroid.os.BinderProxy%40fb9d209%3CBR%20%2F%3EW%20486%20system%20WindowManager%20mOwnerUid%3D1000%20mShowToOwnerOnly%3Dtrue%20package%3Dcom.android.settings%20appop%3DNONE%3CBR%20%2F%3EW%20486%20system%20WindowManager%20mAttrs%3DWM.LayoutParams%7B(0%2C0)(fillxfill)%20sim%3D%2320%20ty%3D1%20fl%3D%2381810500%20pfl%3D0x20000%20wanim%3D0x1030468%20vsysui%3D0x1606%20needsMenuKey%3D2%7D%3CBR%20%2F%3EW%20486%20system%20WindowManager%20Requested%20w%3D1280%20h%3D800%20mLayoutSeq%3D30%3CBR%20%2F%3EW%20486%20system%20WindowManager%20mBaseLayer%3D21000%20mSubLayer%3D0%20mAnimLayer%3D21000%2B0%3D21000%20mLastLayer%3D21005%3CBR%20%2F%3EW%20486%20system%20WindowManager%20mToken%3DAppWindowToken%7B247c5dd%20token%3DToken%7B90942c6%20ActivityRecord%7B280c0a1%20u0%20com.android.settings%2F.FallbackHome%20t2%7D%7D%7D%3CBR%20%2F%3EW%20486%20system%20WindowManager%20mRootToken%3DAppWindowToken%7B247c5dd%20token%3DToken%7B90942c6%20ActivityRecord%7B280c0a1%20u0%20com.android.settings%2F.FallbackHome%20t2%7D%7D%7D%3CBR%20%2F%3EW%20486%20system%20WindowManager%20mAppToken%3DAppWindowToken%7B247c5dd%20token%3DToken%7B90942c6%20ActivityRecord%7B280c0a1%20u0%20com.android.settings%2F.FallbackHome%20t2%7D%7D%7D%3CBR%20%2F%3EW%20486%20system%20WindowManager%20isAnimatingWithSavedSurface()%3Dfalse%20mAppDied%3Dfalse%3CBR%20%2F%3EW%20486%20system%20WindowManager%20mViewVisibility%3D0x8%20mHaveFrame%3Dtrue%20mObscured%3Dfalse%3CBR%20%2F%3EW%20486%20system%20WindowManager%20mSeq%3D0%20mSystemUiVisibility%3D0x1606%3CBR%20%2F%3EW%20486%20system%20WindowManager%20mGivenContentInsets%3D%5B0%2C0%5D%5B0%2C0%5D%20mGivenVisibleInsets%3D%5B0%2C0%5D%5B0%2C0%5D%3CBR%20%2F%3EW%20486%20system%20WindowManager%20mMergedConfiguration%3D%7B1.0%20%3Fmcc%3Fmnc%20%5Ben_US%5D%20ldltr%20sw800dp%20w1280dp%20h728dp%20160dpi%20xlrg%20land%20finger%20-keyb%2Fh%2Fh%20-nav%2Fh%20s.5%7D%3CBR%20%2F%3EW%20486%20system%20WindowManager%20mHasSurface%3Dtrue%20mShownPosition%3D%5B0%2C0%5D%20isReadyForDisplay()%3Dfalse%20hasSavedSurface()%3Dfalse%20mWindowRemovalAllowed%3Dtrue%3CBR%20%2F%3EW%20486%20system%20WindowManager%20mFrame%3D%5B0%2C0%5D%5B1280%2C800%5D%20last%3D%5B0%2C0%5D%5B1280%2C800%5D%3CBR%20%2F%3EW%20486%20system%20WindowManager%20Frames%3A%20containing%3D%5B0%2C0%5D%5B1280%2C800%5D%20parent%3D%5B0%2C0%5D%5B1280%2C800%5D%3CBR%20%2F%3EW%20486%20system%20WindowManager%20display%3D%5B0%2C0%5D%5B1280%2C800%5D%20overscan%3D%5B0%2C0%5D%5B1280%2C800%5D%3CBR%20%2F%3EW%20486%20system%20WindowManager%20content%3D%5B0%2C0%5D%5B1280%2C752%5D%20visible%3D%5B0%2C0%5D%5B1280%2C752%5D%3CBR%20%2F%3EW%20486%20system%20WindowManager%20decor%3D%5B0%2C0%5D%5B1280%2C800%5D%3CBR%20%2F%3EW%20486%20system%20WindowManager%20outset%3D%5B0%2C0%5D%5B1280%2C752%5D%3CBR%20%2F%3EW%20486%20system%20WindowManager%20Cur%20insets%3A%20overscan%3D%5B0%2C0%5D%5B0%2C0%5D%20content%3D%5B0%2C0%5D%5B0%2C48%5D%20visible%3D%5B0%2C0%5D%5B0%2C48%5D%20stable%3D%5B0%2C24%5D%5B0%2C48%5D%20surface%3D%5B0%2C0%5D%5B0%2C0%5D%20outsets%3D%5B0%2C0%5D%5B0%2C0%5D%3CBR%20%2F%3EW%20486%20system%20WindowManager%20Lst%20insets%3A%20overscan%3D%5B0%2C0%5D%5B0%2C0%5D%20content%3D%5B0%2C0%5D%5B0%2C48%5D%20visible%3D%5B0%2C0%5D%5B0%2C48%5D%20stable%3D%5B0%2C24%5D%5B0%2C48%5D%20physical%3D%5B0%2C0%5D%5B0%2C0%5D%20outset%3D%5B0%2C0%5D%5B0%2C0%5D%3CBR%20%2F%3EW%20486%20system%20WindowManager%20WindowStateAnimator%7B9989236%20com.android.settings%2Fcom.android.settings.FallbackHome%7D%3A%3CBR%20%2F%3EW%20486%20system%20WindowManager%20mSurface%3DSurface(name%3Dcom.android.settings%2Fcom.android.settings.FallbackHome)%3CBR%20%2F%3EW%20486%20system%20WindowManager%20Surface%3A%20shown%3Dfalse%20layer%3D21005%20alpha%3D1.0%20rect%3D(0.0%2C0.0)%201280.0%20x%20800.0%3CBR%20%2F%3EW%20486%20system%20WindowManager%20mDrawState%3DHAS_DRAWN%20mLastHidden%3Dtrue%3CBR%20%2F%3EW%20486%20system%20WindowManager%20mSystemDecorRect%3D%5B0%2C0%5D%5B1280%2C800%5D%20last%3D%5B0%2C0%5D%5B0%2C0%5D%20mHasClipRect%3Dfalse%20mLastClipRect%3D%5B0%2C0%5D%5B1280%2C800%5D%3CBR%20%2F%3EW%20486%20system%20WindowManager%20mGlobalScale%3D1.0%20mDsDx%3D1.0%20mDtDx%3D0.0%20mDsDy%3D0.0%20mDtDy%3D1.0%3CBR%20%2F%3EW%20486%20system%20WindowManager%20mAnimatingExit%3Dfalse%20mRemoveOnExit%3Dtrue%20mDestroying%3Dtrue%20mRemoved%3Dfalse%3CBR%20%2F%3EW%20486%20system%20WindowManager%20Current%20app%20token%20list%3A%3CBR%20%2F%3EV%20486%20system%20WindowManager%20Stack%20%230%20tasks%20from%20bottom%20to%20top%3A%3CBR%20%2F%3EV%20486%20system%20WindowManager%20Task%20%233%20activities%20from%20bottom%20to%20top%3A%3CBR%20%2F%3EV%20486%20system%20WindowManager%20activity%20%230%3A%20Token%7Be0a76d0%20null%7D%3CBR%20%2F%3EV%20486%20system%20WindowManager%20Task%20%234%20activities%20from%20bottom%20to%20top%3A%3CBR%20%2F%3EV%20486%20system%20WindowManager%20activity%20%230%3A%20Token%7Bd5c6d78%20ActivityRecord%7B623fedb%20u0%20com.android.launcher%2Fcom.android.launcher2.Launcher%20t4%7D%7D%3CBR%20%2F%3EW%20486%20system%20WindowManager%20Final%20window%20list%3A%3CBR%20%2F%3EV%20486%20system%20WindowManager%20Display%20%230%3CBR%20%2F%3EV%20486%20system%20WindowManager%20%233%3A%20Window%7B498630a%20u0%20NavigationBar%20EXITING%7D%3CBR%20%2F%3EV%20486%20system%20WindowManager%20%232%3A%20Window%7B6a3fa81%20u0%20StatusBar%20EXITING%7D%3CBR%20%2F%3EV%20486%20system%20WindowManager%20%231%3A%20Window%7Bdb0591e%20u0%20KeyguardScrim%7D%3CBR%20%2F%3EV%20486%20system%20WindowManager%20%230%3A%20Window%7Bd1c6fa%20u0%20com.android.launcher%2Fcom.android.launcher2.Launcher%7D%3CBR%20%2F%3ED%20486%20system%20TrustManagerService%20Removing%20dead%20TrustListener.%3CBR%20%2F%3EV%201658%20com.android.systemui%20FingerprintManager%20FingerprintManagerService%20was%20null%3CBR%20%2F%3EW%201658%20com.android.systemui%20FingerprintManager%20isFingerprintHardwareDetected()%3A%20Service%20not%20connected!%3CBR%20%2F%3EW%201658%20com.android.systemui%20FingerprintManager%20addLockoutResetCallback()%3A%20Service%20not%20connected!%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%201658%20com.android.systemui%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.vorbis.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%201658%20com.android.systemui%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.vorbis.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20act%3Dcom.android.mail.action.BACKUP_DATA_CHANGED%20pkg%3Dcom.android.email%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20act%3Dcom.android.mail.action.BACKUP_DATA_CHANGED%20pkg%3Dcom.android.email%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20act%3Dcom.android.mail.action.BACKUP_DATA_CHANGED%20pkg%3Dcom.android.email%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20act%3Dcom.android.mail.action.BACKUP_DATA_CHANGED%20pkg%3Dcom.android.email%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20act%3Dcom.android.mail.action.BACKUP_DATA_CHANGED%20pkg%3Dcom.android.email%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201658%20com.android.systemui%20vol.Events%20writeEvent%20collection_started%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20act%3Dcom.android.mail.action.BACKUP_DATA_CHANGED%20pkg%3Dcom.android.email%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20act%3Dcom.android.mail.action.BACKUP_DATA_CHANGED%20pkg%3Dcom.android.email%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3EI%201658%20com.android.systemui%20vol.Events%20writeEvent%20external_ringer_mode_changed%20normal%3CBR%20%2F%3EI%201658%20com.android.systemui%20vol.Events%20writeEvent%20internal_ringer_mode_changed%20normal%3CBR%20%2F%3EI%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MediaPlayerService%20MediaPlayerService%3A%3AgetOMX%3CBR%20%2F%3EI%201658%20com.android.systemui%20OMXClient%20MuxOMX%20ctor%3CBR%20%2F%3EI%20234%20media.codec%20OMXMaster%20makeComponentInstance(OMX.google.vorbis.decoder)%20in%20mediacodec%20process%3CBR%20%2F%3EW%201717%20com.android.email%20art%20Long%20monitor%20contention%20with%20owner%20AsyncTask%20%231%20(1735)%20at%20com.android.mail.preferences.MailPrefs%20com.android.mail.preferences.MailPrefs.get(android.content.Context)(MailPrefs.java%3A-1)%20waiters%3D0%20in%20com.android.mail.preferences.MailPrefs%20com.android.mail.preferences.MailPrefs.get(android.content.Context)%20for%20567ms%3CBR%20%2F%3EW%201717%20com.android.email%20art%20Long%20monitor%20contention%20with%20owner%20AsyncTask%20%231%20(1735)%20at%20com.android.mail.preferences.MailPrefs%20com.android.mail.preferences.MailPrefs.get(android.content.Context)(MailPrefs.java%3A-1)%20waiters%3D1%20in%20com.android.mail.preferences.MailPrefs%20com.android.mail.preferences.MailPrefs.get(android.content.Context)%20for%20557ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201717%20com.android.email%20art%20Long%20monitor%20contention%20with%20owner%20AsyncTask%20%231%20(1735)%20at%20com.android.mail.preferences.MailPrefs%20com.android.mail.preferences.MailPrefs.get(android.content.Context)(MailPrefs.java%3A-1)%20waiters%3D2%20in%20com.android.mail.preferences.MailPrefs%20com.android.mail.preferences.MailPrefs.get(android.content.Context)%20for%20571ms%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20cmp%3Dcom.android.email%2F.service.AttachmentService%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20act%3Dcom.android.email.EXCHANGE_INTENT%20pkg%3Dcom.android.exchange%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20cmp%3Dcom.android.email%2F.service.AttachmentService%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EI%201717%20com.android.email%20Email%20Observing%20account%20changes%20for%20notifications%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20cmp%3Dcom.android.email%2F.service.AttachmentService%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20act%3Dcom.android.email.EXCHANGE_INTENT%20pkg%3Dcom.android.exchange%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20cmp%3Dcom.android.email%2F.service.AttachmentService%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20cmp%3Dcom.android.email%2F.service.AttachmentService%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20act%3Dcom.android.email.EXCHANGE_INTENT%20pkg%3Dcom.android.exchange%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201763%3Acom.android.gallery3d%2Fu0a45%20for%20broadcast%20com.android.gallery3d%2Fcom.android.camera.DisableCameraReceiver%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20act%3Dcom.android.email.EXCHANGE_INTENT%20pkg%3Dcom.android.exchange%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3EI%201717%20com.android.email%20Email%20Onetime%20initialization%3A%201%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20act%3Dcom.android.email.EXCHANGE_INTENT%20pkg%3Dcom.android.exchange%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201717%20com.android.email%20Email%20Onetime%20initialization%3A%202%3CBR%20%2F%3EI%201717%20com.android.email%20Email%20Onetime%20initialization%3A%20completed.%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20act%3Dcom.android.email.EXCHANGE_INTENT%20pkg%3Dcom.android.exchange%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unable%20to%20start%20service%20Intent%20%7B%20act%3Dcom.android.email.EXCHANGE_INTENT%20pkg%3Dcom.android.exchange%20%7D%20U%3D0%3A%20not%20found%3CBR%20%2F%3EE%201717%20com.android.email%20ActivityThread%20Service%20com.android.email.service.EmailBroadcastProcessorService%20has%20leaked%20ServiceConnection%20com.android.emailcommon.service.ServiceProxy%24ProxyConnection%40df185d0%20that%20was%20originally%20bound%20here%3CBR%20%2F%3EE%201717%20com.android.email%20ActivityThread%20android.app.ServiceConnectionLeaked%3A%20Service%20com.android.email.service.EmailBroadcastProcessorService%20has%20leaked%20ServiceConnection%20com.android.emailcommon.service.ServiceProxy%24ProxyConnection%40df185d0%20that%20was%20originally%20bound%20here%3CBR%20%2F%3EE%201717%20com.android.email%20ActivityThread%20at%20android.app.LoadedApk%24ServiceDispatcher.%3CINIT%3E(LoadedApk.java%3A1336)%3CBR%20%2F%3EE%201717%20com.android.email%20ActivityThread%20at%20android.app.LoadedApk.getServiceDispatcher(LoadedApk.java%3A1231)%3CBR%20%2F%3EE%201717%20com.android.email%20ActivityThread%20at%20android.app.ContextImpl.bindServiceCommon(ContextImpl.java%3A1450)%3CBR%20%2F%3EE%201717%20com.android.email%20ActivityThread%20at%20android.app.ContextImpl.bindService(ContextImpl.java%3A1422)%3CBR%20%2F%3EE%201717%20com.android.email%20ActivityThread%20at%20android.content.ContextWrapper.bindService(ContextWrapper.java%3A636)%3CBR%20%2F%3EE%201717%20com.android.email%20ActivityThread%20at%20com.android.emailcommon.service.ServiceProxy.setTask(ServiceProxy.java%3A181)%3CBR%20%2F%3EE%201717%20com.android.email%20ActivityThread%20at%20com.android.emailcommon.service.ServiceProxy.test(ServiceProxy.java%3A224)%3CBR%20%2F%3EE%201717%20com.android.email%20ActivityThread%20at%20com.android.email.service.EmailServiceUtils.isServiceAvailable(EmailServiceUtils.java%3A160)%3CBR%20%2F%3EE%201717%20com.android.email%20ActivityThread%20at%20com.android.email.provider.AccountReconciler.reconcileAccountsInternal(AccountReconciler.java%3A171)%3CBR%20%2F%3EE%201717%20com.android.email%20ActivityThread%20at%20com.android.email.provider.AccountReconciler.reconcileAccounts(AccountReconciler.java%3A115)%3CBR%20%2F%3EE%201717%20com.android.email%20ActivityThread%20at%20com.android.email.service.EmailBroadcastProcessorService.reconcileAndStartServices(EmailBroadcastProcessorService.java%3A305)%3CBR%20%2F%3EE%201717%20com.android.email%20ActivityThread%20at%20com.android.email.service.EmailBroadcastProcessorService.onBootCompleted(EmailBroadcastProcessorService.java%3A295)%3CBR%20%2F%3EE%201717%20com.android.email%20ActivityThread%20at%20com.android.email.service.EmailBroadcastProcessorService.onHandleIntent(EmailBroadcastProcessorService.java%3A130)%3CBR%20%2F%3EE%201717%20com.android.email%20ActivityThread%20at%20android.app.IntentService%24ServiceHandler.handleMessage(IntentService.java%3A68)%3CBR%20%2F%3EE%201717%20com.android.email%20ActivityThread%20at%20android.os.Handler.dispatchMessage(Handler.java%3A102)%3CBR%20%2F%3EE%201717%20com.android.email%20ActivityThread%20at%20android.os.Looper.loop(Looper.java%3A154)%3CBR%20%2F%3EE%201717%20com.android.email%20ActivityThread%20at%20android.os.HandlerThread.run(HandlerThread.java%3A61)%3CBR%20%2F%3EW%20486%20system%20ActivityManager%20Unbind%20failed%3A%20could%20not%20find%20connection%20for%20android.os.BinderProxy%40987f4e6%3CBR%20%2F%3EI%201658%20com.android.systemui%20vol.Events%20writeEvent%20level_changed%20STREAM_ALARM%206%3CBR%20%2F%3EI%201658%20com.android.systemui%20vol.Events%20writeEvent%20level_changed%20STREAM_BLUETOOTH_SCO%207%3CBR%20%2F%3EI%201658%20com.android.systemui%20vol.Events%20writeEvent%20level_changed%20STREAM_MUSIC%2011%3CBR%20%2F%3EI%201658%20com.android.systemui%20vol.Events%20writeEvent%20level_changed%20STREAM_RING%205%3CBR%20%2F%3EI%201658%20com.android.systemui%20vol.Events%20writeEvent%20level_changed%20STREAM_SYSTEM%205%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201658%20com.android.systemui%20vol.Events%20writeEvent%20level_changed%20STREAM_VOICE_CALL%204%3CBR%20%2F%3EI%201763%20G%3ADisableCameraReceiver%20no%20back%20camera%3CBR%20%2F%3EI%201763%20G%3ADisableCameraReceiver%20disable%20all%20camera%20activities%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20SystemBroadcastReceiver%20Boot%20has%20been%20completed%3CBR%20%2F%3EI%201039%20com.android.inputmethod.latin%20SystemBroadcastReceiver%20toggleAppIcon()%20%3A%20FLAG_SYSTEM%20%3D%20true%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Start%20proc%201779%3Acom.android.onetimeinitializer%2Fu0a19%20for%20broadcast%20com.android.onetimeinitializer%2F.OneTimeInitializerReceiver%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201779%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fpriv-app%2FOneTimeInitializer%2Flib%2Farm%3CBR%20%2F%3EV%201779%20com.android.onetimeinitializer%20OneTimeInitializerRece%20OneTimeInitializerReceiver.onReceive%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20float%20com.android.server.wm.WindowManagerService.getCurrentAnimatorScale()%20for%20248ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session%2C%20android.view.IWindow)%20for%20520ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EV%201149%20com.android.phone%20VvmBootCompletedRcvr%20processing%20subId%20list%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201779%20com.android.onetimeinitializer%20OneTimeInitializerServ%20Updating%20to%20version%201.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201149%20com.android.phone%20VvmSimChangeReceiver%20Received%20SIM%20change%20for%20invalid%20subscription%20id.%3CBR%20%2F%3ED%201473%20android.process.media%20MtpService%20starting%20MTP%20server%20in%20MTP%20mode%3CBR%20%2F%3EI%201473%20android.process.media%20MediaProvider%20Upgrading%20media%20database%20from%20version%200%20to%20800%2C%20which%20will%20destroy%20all%20old%20data%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%201473%20android.process.media%20MediaProvider%20Adjusting%20external%20storage%20paths%20to%3A%20%2Fstorage%2Femulated%2F0%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EE%201473%20android.process.media%20SQLiteLog%20(1)%20no%20such%20table%3A%20files%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FAlarm_Beep_01.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FAlarm_Beep_02.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FAlarm_Beep_03.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowManagerService%24H.handleMessage(android.os.Message)(WindowManagerService.java%3A8361)%20waiters%3D1%20in%20void%20com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session%2C%20android.view.IWindow)%20for%20520ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20float%20com.android.server.wm.WindowManagerService.getCurrentAnimatorScale()%20for%20514ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Displayed%20com.android.launcher%2Fcom.android.launcher2.Launcher%3A%20%2B9s636ms%20(total%20%2B16s539ms)%3CBR%20%2F%3EI%201525%20com.android.launcher%20Choreographer%20Skipped%20156%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EI%201658%20com.android.systemui%20imx6.gralloc%20open%20gpu%20gralloc%20module!%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FAlarm_Buzzer.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FAlarm_Classic.oggsince%20ringtone%20setting%20didn't%20finish%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%3B%20assuming%20invalid%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FAlarm_Beep_01.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FAlarm_Beep_02.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FAlarm_Beep_03.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EE%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MetadataRetrieverClient%20failed%20to%20extract%20an%20album%20art%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FAlarm_Buzzer.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FAlarm_Classic.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201400%20com.android.deskclock%20AlarmClock%20Detected%20change%20to%20system%20default%20alarm%20ringtone%3B%20clearing%20caches%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FAlarm_Rooster_02.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FArgon.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FBarium.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FCarbon.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FCesium.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FFermium.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FHassium.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FHelium.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FKrypton.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FNeon.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FNeptunium.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FNobelium.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FOsmium.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FOxygen.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FPlatinum.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FPlutonium.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FPromethium.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FScandium.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FAdara.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FAldebaran.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FAltair.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FAlya.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.ui%20(517)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)%20for%201.040s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.ui%20(517)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D1%20in%20void%20com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session%2C%20android.view.IWindow)%20for%201.014s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.ui%20(517)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D2%20in%20int%20com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.view.InputChannel)%20for%201.014s%3CBR%20%2F%3EW%20486%20system%20InputMethodManagerService%20Focus%20gain%20on%20non-focused%20client%20com.android.internal.view.IInputMethodClient%24Stub%24Proxy%40423de46%20(uid%3D10016%20pid%3D1525)%3CBR%20%2F%3EW%201525%20com.android.launcher%20System%20ClassLoader%20referenced%20unknown%20path%3A%3CBR%20%2F%3EW%201525%20com.android.launcher%20System%20ClassLoader%20referenced%20unknown%20path%3A%20%2Fsystem%2Fapp%2FDeskClock%2Flib%2Farm%3CBR%20%2F%3ED%201525%20com.android.launcher%20ApplicationLoaders%20ignored%20Vulkan%20layer%20search%20path%20%2Fsystem%2Fapp%2FDeskClock%2Flib%2Farm%3A%2Fsystem%2Flib%3A%2Fvendor%2Flib%20for%20namespace%200xb34a1090%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FAntares.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3ED%201658%20com.android.systemui%20StorageNotification%20Notifying%20about%20private%20volume%3A%20VolumeInfo%7Bprivate%7D%3A%3CBR%20%2F%3ED%201658%20com.android.systemui%20StorageNotification%20type%3DPRIVATE%20diskId%3Dnull%20partGuid%3Dnull%20mountFlags%3D0%20mountUserId%3D-1%3CBR%20%2F%3ED%201658%20com.android.systemui%20StorageNotification%20state%3DMOUNTED%3CBR%20%2F%3ED%201658%20com.android.systemui%20StorageNotification%20fsType%3Dnull%20fsUuid%3Dnull%20fsLabel%3Dnull%3CBR%20%2F%3ED%201658%20com.android.systemui%20StorageNotification%20path%3D%2Fdata%20internalPath%3Dnull%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201525%20com.android.launcher%20Choreographer%20Skipped%2070%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FAntimony.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%20486%20system%20art%20Background%20partial%20concurrent%20mark%20sweep%20GC%20freed%2014928(1296KB)%20AllocSpace%20objects%2C%208(204KB)%20LOS%20objects%2C%2033%25%20free%2C%206MB%2F9MB%2C%20paused%203.581ms%20total%20140.949ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FArcturus.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FArgon.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FBeat_Box_Android.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FBellatrix.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FBeryllium.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FBetelgeuse.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FCaffeineSnake.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FCanopus.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FCapella.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FCastor.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FCetiAlpha.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D2%20in%20int%20com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.view.InputChannel)%20for%20325ms%3CBR%20%2F%3EW%20486%20system%20InputMethodManagerService%20Window%20already%20focused%2C%20ignoring%20focus%20gain%20of%3A%20android.view.inputmethod.InputMethodManager%241%40a7922a3%20attribute%3Dnull%2C%20token%20%3D%20android.view.ViewRootImpl%24W%40a7145ff%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20363ms%3CBR%20%2F%3EV%20486%20system%20KeyguardServiceDelegate%20***%20Keyguard%20connected%20(yay!)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FCobalt.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201618%20com.android.calendar%20GlobalDismissManager%20no%20sender%20configured%3CBR%20%2F%3ED%201618%20com.android.calendar%20AlertService%20Beginning%20updateAlertNotification%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FCricket.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3ED%201618%20com.android.calendar%20AlertService%20No%20fired%20or%20scheduled%20alerts%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FDearDeer.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3ED%201618%20com.android.calendar%20AlertService%20Scheduling%20next%20alarm%20with%20AlarmScheduler.%20sEventReminderReceived%3A%20null%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FDeneb.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3ED%201618%20com.android.calendar%20AlarmScheduler%20No%20events%20found%20starting%20within%201%20week.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%201618%20com.android.calendar%20AlertService%200%20Action%20%3D%20android.intent.action.BOOT_COMPLETED%3CBR%20%2F%3ED%201618%20com.android.calendar%20AlertService%20Scheduling%20next%20alarm%20with%20AlarmScheduler.%20sEventReminderReceived%3A%20null%3CBR%20%2F%3ED%201618%20com.android.calendar%20AlarmScheduler%20No%20events%20found%20starting%20within%201%20week.%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FDoink.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FDontPanic.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FDrip.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FElectra.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FF1_MissedCall.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FF1_New_MMS.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FF1_New_SMS.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FFluorine.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FFomalhaut.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20art%20Do%20partial%20code%20cache%20collection%2C%20code%3D8KB%2C%20data%3D22KB%3CBR%20%2F%3EI%201473%20android.process.media%20art%20After%20code%20cache%20collection%2C%20code%3D8KB%2C%20data%3D22KB%3CBR%20%2F%3EI%201473%20android.process.media%20art%20Increasing%20code%20cache%20capacity%20to%20128KB%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FGallium.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FHeaven.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FHelium.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FHighwire.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FHojus.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowManagerService.showStrictModeViolation(int%2C%20int)(WindowManagerService.java%3A6257)%20waiters%3D1%20in%20int%20com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.view.InputChannel)%20for%20532ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_F%20(1657)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D1%20in%20void%20com.android.server.wm.WindowManagerService.showStrictModeViolation(int%2C%20int)%20for%20538ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_F%20(1657)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D2%20in%20void%20com.android.server.policy.PhoneWindowManager.onKeyguardShowingStateChanged(boolean)%20for%20539ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2031%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_F%20(1657)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D3%20in%20void%20com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session%2C%20android.view.IWindow)%20for%20527ms%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FIridium.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FKrypton.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FKzurbSonar.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FLalande.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FMerope.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FMira.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FOnTheHunt.oggsince%20ringtone%20setting%20didn't%20finish%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%3B%20assuming%20invalid%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FAlarm_Rooster_02.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FArgon.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FBarium.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FCarbon.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FCesium.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FFermium.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FHassium.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FHelium.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FKrypton.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FNeon.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FNeptunium.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FNobelium.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FOsmium.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FOxygen.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FPlatinum.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FPlutonium.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FPromethium.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Falarms%2FScandium.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FAdara.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EE%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MetadataRetrieverClient%20failed%20to%20extract%20an%20album%20art%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FAldebaran.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FAltair.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20art%20Waiting%20for%20a%20blocking%20GC%20DisableMovingGc%3CBR%20%2F%3EI%201473%20android.process.media%20art%20Starting%20a%20blocking%20GC%20DisableMovingGc%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FAlya.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FAntares.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FAntimony.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FArcturus.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FArgon.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FBeat_Box_Android.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FBellatrix.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FBeryllium.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FBetelgeuse.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FCaffeineSnake.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FCanopus.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FCapella.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FCastor.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FCetiAlpha.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FCobalt.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FCricket.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FDearDeer.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FDeneb.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FDoink.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FDontPanic.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FDrip.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FElectra.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FF1_MissedCall.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FF1_New_MMS.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FF1_New_SMS.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FFluorine.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FFomalhaut.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FGallium.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FHeaven.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FHelium.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FHighwire.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FHojus.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FIridium.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FKrypton.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FKzurbSonar.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FLalande.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FMerope.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FMira.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20Finalizing%20a%20Cursor%20that%20has%20not%20been%20deactivated%20or%20closed.%20database%20%3D%20%2Fdata%2Fuser%2F0%2Fcom.android.dialer%2Fdatabases%2Fdialer.db%2C%20table%20%3D%20filtered_numbers_table%2C%20query%20%3D%20SELECT%20_id%20FROM%20filtered_numbers_table%20WHERE%20(type%3D1)%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20android.database.sqlite.DatabaseObjectNotClosedException%3A%20Application%20did%20not%20close%20the%20cursor%20or%20database%20object%20that%20was%20opened%20here%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20at%20android.database.sqlite.SQLiteCursor.%3CINIT%3E(SQLiteCursor.java%3A98)%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20at%20android.database.sqlite.SQLiteDirectCursorDriver.query(SQLiteDirectCursorDriver.java%3A50)%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20at%20android.database.sqlite.SQLiteDatabase.rawQueryWithFactory(SQLiteDatabase.java%3A1318)%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20at%20android.database.sqlite.SQLiteQueryBuilder.query(SQLiteQueryBuilder.java%3A399)%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20at%20android.database.sqlite.SQLiteQueryBuilder.query(SQLiteQueryBuilder.java%3A294)%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20at%20com.android.dialer.database.FilteredNumberProvider.query(FilteredNumberProvider.java%3A96)%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20at%20android.content.ContentProvider.query(ContentProvider.java%3A1020)%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20at%20android.content.ContentProvider%24Transport.query(ContentProvider.java%3A239)%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20at%20android.content.ContentResolver.query(ContentResolver.java%3A532)%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20at%20android.content.ContentResolver.query(ContentResolver.java%3A474)%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20at%20android.content.AsyncQueryHandler%24WorkerHandler.handleMessage(AsyncQueryHandler.java%3A79)%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20at%20android.os.Handler.dispatchMessage(Handler.java%3A102)%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20at%20android.os.Looper.loop(Looper.java%3A154)%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20at%20android.os.HandlerThread.run(HandlerThread.java%3A61)%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20A%20resource%20was%20acquired%20at%20attached%20stack%20trace%20but%20never%20released.%20See%20java.io.Closeable%20for%20information%20on%20avoiding%20resource%20leaks.%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20java.lang.Throwable%3A%20Explicit%20termination%20method%20'close'%20not%20called%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20at%20dalvik.system.CloseGuard.open(CloseGuard.java%3A180)%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20at%20android.content.ContentResolver%24CursorWrapperInner.%3CINIT%3E(ContentResolver.java%3A2627)%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20at%20android.content.ContentResolver.query(ContentResolver.java%3A558)%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20at%20android.content.ContentResolver.query(ContentResolver.java%3A474)%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20at%20android.content.AsyncQueryHandler%24WorkerHandler.handleMessage(AsyncQueryHandler.java%3A79)%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20at%20android.os.Handler.dispatchMessage(Handler.java%3A102)%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20at%20android.os.Looper.loop(Looper.java%3A154)%3CBR%20%2F%3EE%201673%20com.android.dialer%20StrictMode%20at%20android.os.HandlerThread.run(HandlerThread.java%3A61)%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FOnTheHunt.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FPalladium.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FPlastic_Pipe.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FPolaris.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FPollux.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FProcyon.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FProxima.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FRadon.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FRubidium.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FSelenium.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_E%20(1656)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D1%20in%20void%20com.android.server.wm.WindowManagerService%24H.handleMessage(android.os.Message)%20for%201.052s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_E%20(1656)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D1%20in%20void%20com.android.server.policy.PhoneWindowManager.onKeyguardShowingStateChanged(boolean)%20for%201.053s%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_E%20(1656)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D2%20in%20void%20com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session%2C%20android.view.IWindow)%20for%20923ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201525%20com.android.launcher%20Choreographer%20Skipped%2062%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EI%201658%20com.android.systemui%20Choreographer%20Skipped%20188%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FShaula.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FSirrah.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FSpaceSeed.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FSpica.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FStrontium.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FSyrma.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FTaDa.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FTalitha.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FTejat.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FThallium.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FTinkerbell.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FUpsilon.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FVega.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FVoila.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FXenon.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20460ms%3CBR%20%2F%3EW%201525%20com.android.launcher%20OpenGLRenderer%20Incorrectly%20called%20buildLayer%20on%20View%3A%20ShortcutAndWidgetContainer%2C%20destroying%20layer...%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FZirconium.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2Farcturus.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2Fmoonbeam.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2Fpixiedust.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2Fpizzicato.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2Fregulus.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2Fsirius.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2Ftweeters.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2Fvega.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FANDROMEDA.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FPalladium.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FPlastic_Pipe.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FPolaris.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FPollux.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FProcyon.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EE%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MetadataRetrieverClient%20failed%20to%20extract%20an%20album%20art%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FProxima.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FRadon.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FRubidium.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FSelenium.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FShaula.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FSirrah.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FSpaceSeed.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FSpica.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FStrontium.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FSyrma.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FTaDa.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FTalitha.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FTejat.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FThallium.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FTinkerbell.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FUpsilon.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FVega.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FVoila.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FXenon.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2FZirconium.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2Farcturus.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2Fmoonbeam.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2Fpixiedust.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2Fpizzicato.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2Fregulus.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2Fsirius.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2Ftweeters.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fnotifications%2Fvega.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FANDROMEDA.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EE%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MetadataRetrieverClient%20failed%20to%20extract%20an%20album%20art%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2031%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20535ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FAndromeda.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FAquila.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FArgoNavis.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FAtria.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FBOOTES.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FBackroad.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FBeatPlucker.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FBentleyDubs.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FBig_Easy.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FBirdLoop.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FBollywood.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FBussaMove.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCANISMAJOR.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCASSIOPEIA.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCairo.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCalypso_Steel.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20528ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCanisMajor.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCaribbeanIce.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCarina.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCentaurus.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FChampagne_Edition.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FClub_Cubano.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCrayonRock.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCrazyDream.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCurveBall.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCygnus.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FDancinFool.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FDing.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FDonMessWivIt.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FDraco.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FDreamTheme.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FEastern_Sky.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FEnter_the_Nexus.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FEridani.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.setInsetsWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Region)%20for%20522ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20void%20com.android.server.wm.WindowManagerService.setDockedStackDividerTouchRegion(android.graphics.Rect)%20for%20527ms%3CBR%20%2F%3EI%20486%20system%20StatusBarManagerService%20registerStatusBar%20bar%3Dcom.android.internal.statusbar.IStatusBar%24Stub%24Proxy%40a254983%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FEtherShake.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FFreeFlight.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FFriendlyGhost.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FFunk_Yall.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FGameOverGuitar.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FGimme_Mo_Town.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FGirtab.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FGlacial_Groove.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FGrowl.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FHalfwayHome.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FHydra.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FInsertCoin.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%201658%20com.android.systemui%20System%20ClassLoader%20referenced%20unknown%20path%3A%3CBR%20%2F%3ED%201658%20com.android.systemui%20ApplicationLoaders%20ignored%20Vulkan%20layer%20search%20path%20%2Fsystem%2Fapp%2FCamera2%2Flib%2Farm%3A%2Fsystem%2Fapp%2FCamera2%2FCamera2.apk!%2Flib%2Farmeabi-v7a%3A%2Fsystem%2Flib%3A%2Fvendor%2Flib%20for%20namespace%200xb34a1090%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FKuma.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FLoopyLounge.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FLoveFlute.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FLyra.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FMachina.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%2020%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Added%20callback%3A%20android.bluetooth.IBluetoothManagerCallback%24Stub%24Proxy%40cabcfe1%3Atrue%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%2030%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FMidEvilJaunt.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%2030%3CBR%20%2F%3ED%201658%20com.android.systemui%20LocalBluetoothProfileManager%20Adding%20local%20MAP%20profile%3CBR%20%2F%3ED%201658%20com.android.systemui%20BluetoothMap%20Create%20BluetoothMap%20proxy%20object%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%2030%3CBR%20%2F%3ED%20486%20system%20BluetoothManagerService%20Message%3A%2030%3CBR%20%2F%3ED%201658%20com.android.systemui%20LocalBluetoothProfileManager%20LocalBluetoothProfileManager%20construction%20complete%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FMildlyAlarming.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201658%20com.android.systemui%20CameraManagerGlobal%20Connecting%20to%20camera%20service%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FNairobi.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FNassau.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FNewPlayer.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FNo_Limits.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3ED%201658%20com.android.systemui%20OpenGLRenderer%20profile%20bars%20disabled%3CBR%20%2F%3ED%201658%20com.android.systemui%20OpenGLRenderer%20ambientRatio%20%3D%201.50%3CBR%20%2F%3ED%201658%20com.android.systemui%20PhoneStatusBar%20disable%3A%20%26lt%3B%20EXPAND*%20icons%20alerts%20system_info%20BACK*%20HOME*%20RECENT*%20clock%20SEARCH*%20quick_settings%20%26gt%3B%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FNoises1.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FNoises2.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%201658%20com.android.systemui%20PhoneStatusBar%20heads%20up%20is%20enabled%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FNoises3.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FOrganDub.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FOrion.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FPERSEUS.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FParadise_Island.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FPegasus.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FPerseus.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FPlaya.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FPyxis.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FRasalas.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FRevelation.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FRigel.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FRing_Classic_02.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FRing_Digital_02.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FRing_Synth_02.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EE%201149%20com.android.phone%20PhoneInterfaceManager%20%5BPhoneIntfMgr%5D%20getCarrierPackageNamesForIntent%3A%20No%20UICC%3CBR%20%2F%3ED%201149%20com.android.phone%20CarrierSvcBindHelper%20No%20carrier%20app%20for%3A%200%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EE%201149%20com.android.phone%20PhoneInterfaceManager%20%5BPhoneIntfMgr%5D%20getCarrierPackageNamesForIntent%3A%20No%20UICC%3CBR%20%2F%3ED%201149%20com.android.phone%20CarrierSvcBindHelper%20No%20carrier%20app%20for%3A%200%3CBR%20%2F%3EE%201149%20com.android.phone%20PhoneInterfaceManager%20%5BPhoneIntfMgr%5D%20getCarrierPackageNamesForIntent%3A%20No%20UICC%3CBR%20%2F%3ED%201149%20com.android.phone%20CarrierSvcBindHelper%20No%20carrier%20app%20for%3A%200%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EE%201149%20com.android.phone%20PhoneInterfaceManager%20%5BPhoneIntfMgr%5D%20getCarrierPackageNamesForIntent%3A%20No%20UICC%3CBR%20%2F%3ED%201149%20com.android.phone%20CarrierSvcBindHelper%20No%20carrier%20app%20for%3A%200%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.ui%20(517)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService%24H.handleMessage(android.os.Message)%20for%20519ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.ui%20(517)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D1%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20519ms%3CBR%20%2F%3EI%20486%20system%20InputReader%20Reconfiguring%20input%20devices.%20changes%3D0x00000010%3CBR%20%2F%3EE%201149%20com.android.phone%20PhoneInterfaceManager%20%5BPhoneIntfMgr%5D%20getCarrierPackageNamesForIntent%3A%20No%20UICC%3CBR%20%2F%3ED%201149%20com.android.phone%20CarrierSvcBindHelper%20No%20carrier%20app%20for%3A%200%3CBR%20%2F%3EI%20486%20system%20InputReader%20Reconfiguring%20input%20devices.%20changes%3D0x00000010%3CBR%20%2F%3EI%20486%20system%20InputReader%20Reconfiguring%20input%20devices.%20changes%3D0x00000010%3CBR%20%2F%3EI%20486%20system%20InputReader%20Reconfiguring%20input%20devices.%20changes%3D0x00000010%3CBR%20%2F%3EI%20486%20system%20InputReader%20Reconfiguring%20input%20devices.%20changes%3D0x00000010%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FRing_Synth_04.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FRoad_Trip.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20486%20system%20ResourceType%20No%20known%20package%20when%20getting%20value%20for%20resource%20number%200x7f0200fc%3CBR%20%2F%3EW%20486%20system%20ResourceType%20No%20known%20package%20when%20getting%20value%20for%20resource%20number%200x7f0e03a1%3CBR%20%2F%3EW%20486%20system%20ResourceType%20No%20known%20package%20when%20getting%20value%20for%20resource%20number%200x7f0200fb%3CBR%20%2F%3EW%20486%20system%20ResourceType%20No%20known%20package%20when%20getting%20value%20for%20resource%20number%200x7f0e092f%3CBR%20%2F%3EW%20486%20system%20ResourceType%20No%20known%20package%20when%20getting%20value%20for%20resource%20number%200x7f0200fa%3CBR%20%2F%3EW%20486%20system%20ResourceType%20No%20known%20package%20when%20getting%20value%20for%20resource%20number%200x7f0e07dd%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FRomancingTheTone.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FSafari.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FSavannah.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FScarabaeus.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FSceptrum.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FSeville.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FShes_All_That.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FSilkyWay.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FSitarVsSitar.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FSolarium.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FSpringyJalopy.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.ui%20(517)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D2%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20935ms%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FSteppin_Out.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FTerminated.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20Timeout%20of%20broadcast%20BroadcastRecord%7B8cf6977%20u-1%20android.intent.action.TIME_TICK%7D%20-%20receiver%3Dandroid.os.BinderProxy%407989041%2C%20started%2010001ms%20ago%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20Receiver%20during%20timeout%3A%20BroadcastFilter%7B3585b27%20u0%20ReceiverList%7Bb2f69e6%201080%20com.android.systemui%2F10026%2Fu0%20remote%3A7989041%7D%7D%3CBR%20%2F%3EW%201658%20com.android.systemui%20Binder%20Binder%20call%20failed.%3CBR%20%2F%3EW%201658%20com.android.systemui%20Binder%20android.os.DeadObjectException%3CBR%20%2F%3EW%201658%20com.android.systemui%20Binder%20at%20android.os.BinderProxy.transactNative(Native%20Method)%3CBR%20%2F%3EW%201658%20com.android.systemui%20Binder%20at%20android.os.BinderProxy.transact(Binder.java%3A615)%3CBR%20%2F%3EW%201658%20com.android.systemui%20Binder%20at%20android.content.IIntentReceiver%24Stub%24Proxy.performReceive(IIntentReceiver.java%3A124)%3CBR%20%2F%3EW%201658%20com.android.systemui%20Binder%20at%20android.app.ActivityThread%24ApplicationThread.scheduleRegisteredReceiver(ActivityThread.java%3A946)%3CBR%20%2F%3EW%201658%20com.android.systemui%20Binder%20at%20android.app.ApplicationThreadNative.onTransact(ApplicationThreadNative.java%3A404)%3CBR%20%2F%3EW%201658%20com.android.systemui%20Binder%20at%20android.os.Binder.execTransact(Binder.java%3A565)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FTestudo.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FThemos.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FThird_Eye.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FThunderfoot.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FTwirlAway.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FURSAMINOR.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FUrsaMinor.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FVeryAlarmed.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20Binder%3A486_4%20(1106)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D1%20in%20void%20com.android.server.wm.WindowManagerService%24H.handleMessage(android.os.Message)%20for%201.019s%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2062%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FVespa.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FWorld.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201658%20com.android.systemui%20KeyguardUpdateMonitor%20invalid%20subId%20in%20handleSimStateChange()%3CBR%20%2F%3EW%201658%20com.android.systemui%20KeyguardUpdateMonitor%20invalid%20subId%20in%20handleServiceStateChange()%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FZeta.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EV%20486%20system%20KeyguardServiceDelegate%20****%20SHOWN%20CALLED%20****%3CBR%20%2F%3EI%201658%20com.android.systemui%20Choreographer%20Skipped%20128%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3ED%201658%20com.android.systemui%20ViewRootImpl%5BStatusBar%5D%20changeCanvasOpacity%3A%20opaque%3Dtrue%3CBR%20%2F%3EI%201473%20android.process.media%20MediaScanner%20forcing%20rescan%20of%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2Fhydra.ogg%20since%20build%20fingerprint%20changed%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20389ms%3CBR%20%2F%3EW%201473%20android.process.media%20MediaScanner%20Error%20opening%20directory%20'%2Foem%2Fmedia%2F'%2C%20skipping%3A%20No%20such%20file%20or%20directory.%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fui%3B%20assuming%20invalid%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FAndromeda.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FAquila.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FArgoNavis.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FAtria.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FBOOTES.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FBackroad.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FBeatPlucker.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FBentleyDubs.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FBig_Easy.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FBirdLoop.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FBollywood.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FBussaMove.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCANISMAJOR.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCASSIOPEIA.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCairo.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCalypso_Steel.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCanisMajor.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCaribbeanIce.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCarina.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCentaurus.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FChampagne_Edition.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FClub_Cubano.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCrayonRock.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCrazyDream.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCurveBall.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FCygnus.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FDancinFool.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FDing.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FDonMessWivIt.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FDraco.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FDreamTheme.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FEastern_Sky.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FEnter_the_Nexus.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FEridani.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FEtherShake.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FFreeFlight.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FFriendlyGhost.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FFunk_Yall.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FGameOverGuitar.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FGimme_Mo_Town.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FGirtab.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FGlacial_Groove.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FGrowl.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FHalfwayHome.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FHydra.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FInsertCoin.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FKuma.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FLoopyLounge.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FLoveFlute.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FLyra.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FMachina.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FMidEvilJaunt.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FMildlyAlarming.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FNairobi.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FNassau.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FNewPlayer.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FNo_Limits.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FNoises1.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FNoises2.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FNoises3.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FOrganDub.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FOrion.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FPERSEUS.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FParadise_Island.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FPegasus.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FPerseus.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FPlaya.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FPyxis.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FRasalas.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EE%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MetadataRetrieverClient%20failed%20to%20extract%20an%20album%20art%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FRevelation.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FRigel.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FRing_Classic_02.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FRing_Digital_02.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FRing_Synth_02.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FRing_Synth_04.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FRoad_Trip.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FRomancingTheTone.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FSafari.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FSavannah.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FScarabaeus.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FSceptrum.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FSeville.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FShes_All_That.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FSilkyWay.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FSitarVsSitar.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FSolarium.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FSpringyJalopy.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FSteppin_Out.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FTerminated.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FTestudo.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FThemos.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FThird_Eye.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FThunderfoot.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FTwirlAway.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FURSAMINOR.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FUrsaMinor.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FVeryAlarmed.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FVespa.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FWorld.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2FZeta.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fringtones%2Fhydra.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fui%2FDock.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fui%2FEffect_Tick.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EE%20237%20%2Fsystem%2Fbin%2Fmediaserver%20MetadataRetrieverClient%20failed%20to%20extract%20an%20album%20art%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fui%2FKeypressDelete.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fui%2FKeypressInvalid.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fui%2FKeypressReturn.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fui%2FKeypressSpacebar.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fui%2FKeypressStandard.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fui%2FLock.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fui%2FLowBattery.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fui%2FTrusted.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fui%2FUndock.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fui%2FUnlock.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fui%2FVideoRecord.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fui%2FVideoStop.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fui%2FWirelessChargingStarted.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fui%2Fcamera_click.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%201473%20android.process.media%20MediaProvider%20Missing%20volume%20for%20%2Fsystem%2Fmedia%2Faudio%2Fui%2Fcamera_focus.ogg%3B%20assuming%20invalid%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EV%201473%20android.process.media%20MediaScanner%20pruneDeadThumbnailFiles...%20android.content.ContentProviderClient%24CursorWrapperInner%409a2673a%3CBR%20%2F%3EV%201473%20android.process.media%20MediaScanner%20%2FpruneDeadThumbnailFiles...%20android.content.ContentProviderClient%24CursorWrapperInner%409a2673a%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.ui%20(517)%20at%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)(WindowManagerService.java%3A2850)%20waiters%3D1%20in%20void%20com.android.server.wm.WindowManagerService%24H.handleMessage(android.os.Message)%20for%201.075s%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201658%20com.android.systemui%20OpenGLRenderer%20Initialized%20EGL%2C%20version%201.4%3CBR%20%2F%3ED%201658%20com.android.systemui%20OpenGLRenderer%20Swap%20behavior%202%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20477ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20boolean%20com.android.server.wm.WindowManagerService.inputMethodClientHasFocus(com.android.internal.view.IInputMethodClient)%20for%20418ms%3CBR%20%2F%3EI%201525%20com.android.launcher%20Choreographer%20Skipped%2031%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20486%20system%20IInputConnectionWrapper%20reportFullscreenMode%20on%20inexistent%20InputConnection%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20485ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EI%201525%20com.android.launcher%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20WifiService%20New%20client%20listening%20to%20asynchronous%20messages%3CBR%20%2F%3EI%201658%20com.android.systemui%20Choreographer%20Skipped%20186%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session%2C%20android.view.IWindow)%20for%20352ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session%2C%20android.view.IWindow)%20for%20500ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session%2C%20android.view.IWindow)%20for%20532ms%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2031%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3ED%201658%20com.android.systemui%20PhoneStatusBar%20disable%3A%20%26lt%3B%20expand*%20icons%20alerts%20system_info%20back*%20home*%20recent*%20clock%20search*%20quick_settings%20%26gt%3B%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.statusBarVisibilityChanged(int)%20for%20509ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20519ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowManagerService%24H.handleMessage(android.os.Message)(WindowManagerService.java%3A8850)%20waiters%3D1%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20518ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20void%20com.android.server.wm.WindowManagerService.statusBarVisibilityChanged(int)%20for%201.051s%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2031%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20541ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowManagerService%24H.handleMessage(android.os.Message)(WindowManagerService.java%3A8361)%20waiters%3D1%20in%20void%20com.android.server.wm.WindowManagerService.statusBarVisibilityChanged(int)%20for%20534ms%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D1%20in%20int%20com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session%2C%20android.view.IWindow%2C%20int%2C%20android.view.WindowManager%24LayoutParams%2C%20int%2C%20int%2C%20int%2C%20int%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.graphics.Rect%2C%20android.content.res.Configuration%2C%20android.view.Surface)%20for%20530ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%201658%20com.android.systemui%20Choreographer%20Skipped%20225%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20486%20system%20art%20Long%20monitor%20contention%20with%20owner%20android.display%20(523)%20at%20void%20com.android.server.wm.WindowAnimator%241.doFrame(long)(WindowAnimator.java%3A144)%20waiters%3D0%20in%20void%20com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session%2C%20android.view.IWindow)%20for%20264ms%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20ActivityManager%20Waited%20long%20enough%20for%3A%20ServiceRecord%7B5011cce%20u0%20com.android.calendar%2F.alerts.InitAlarmsService%7D%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%20486%20system%20DhcpClient%20Received%20packet%3A%2020%3Ad5%3Aab%3Ae9%3Ad9%3Acd%20ACK%3A%20your%20new%20IP%20%2F192.168.10.189%2C%20netmask%20%2F255.255.0.0%2C%20gateways%20%5B%2F192.168.10.1%5D%20DNS%20servers%3A%20%2F203.248.252.2%20%2F164.124.101.2%20%2C%20lease%20time%20604800%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20Timeout%20of%20broadcast%20BroadcastRecord%7B8cf6977%20u-1%20android.intent.action.TIME_TICK%7D%20-%20receiver%3Dandroid.os.BinderProxy%4069cef7d%2C%20started%2010001ms%20ago%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20Receiver%20during%20timeout%3A%20BroadcastFilter%7B96582c3%20u0%20ReceiverList%7B9783e72%201080%20com.android.systemui%2F10026%2Fu0%20remote%3A69cef7d%7D%7D%3CBR%20%2F%3EW%201658%20com.android.systemui%20Binder%20Binder%20call%20failed.%3CBR%20%2F%3EW%201658%20com.android.systemui%20Binder%20android.os.DeadObjectException%3CBR%20%2F%3EW%201658%20com.android.systemui%20Binder%20at%20android.os.BinderProxy.transactNative(Native%20Method)%3CBR%20%2F%3EW%201658%20com.android.systemui%20Binder%20at%20android.os.BinderProxy.transact(Binder.java%3A615)%3CBR%20%2F%3EW%201658%20com.android.systemui%20Binder%20at%20android.content.IIntentReceiver%24Stub%24Proxy.performReceive(IIntentReceiver.java%3A124)%3CBR%20%2F%3EW%201658%20com.android.systemui%20Binder%20at%20android.app.ActivityThread%24ApplicationThread.scheduleRegisteredReceiver(ActivityThread.java%3A946)%3CBR%20%2F%3EW%201658%20com.android.systemui%20Binder%20at%20android.app.ApplicationThreadNative.onTransact(ApplicationThreadNative.java%3A404)%3CBR%20%2F%3EW%201658%20com.android.systemui%20Binder%20at%20android.os.Binder.execTransact(Binder.java%3A565)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20Timeout%20of%20broadcast%20BroadcastRecord%7B8cf6977%20u-1%20android.intent.action.TIME_TICK%7D%20-%20receiver%3Dandroid.os.BinderProxy%403785c17%2C%20started%2010001ms%20ago%3CBR%20%2F%3EW%20486%20system%20BroadcastQueue%20Receiver%20during%20timeout%3A%20BroadcastFilter%7Bc2db1ed%20u0%20ReceiverList%7B7186804%201080%20com.android.systemui%2F10026%2Fu0%20remote%3A3785c17%7D%7D%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3ED%201618%20com.android.calendar%20InitAlarmsService%20Clearing%20and%20rescheduling%20alarms.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EI%20486%20system%20PowerManagerService%20Going%20to%20sleep%20due%20to%20screen%20timeout%20(uid%201000)...%3CBR%20%2F%3EW%201658%20com.android.systemui%20FingerprintManager%20isFingerprintHardwareDetected()%3A%20Service%20not%20connected!%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2030%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EV%20486%20system%20KeyguardServiceDelegate%20onScreenTurnedOff()%3CBR%20%2F%3EE%20486%20system%20Surface%20getSlotFromBufferLocked%3A%20unknown%20buffer%3A%200x83aaf040%3CBR%20%2F%3EE%20486%20system%20libEGL%20call%20to%20OpenGL%20ES%20API%20with%20no%20current%20context%20(logged%20once%20per%20thread)%3CBR%20%2F%3EI%20486%20system%20Choreographer%20Skipped%2033%20frames!%20The%20application%20may%20be%20doing%20too%20much%20work%20on%20its%20main%20thread.%3CBR%20%2F%3EI%20486%20system%20DisplayManagerService%20Display%20device%20changed%20state%3A%20%22Built-in%20Screen%22%2C%20OFF%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20imx6.gralloc%20FBIOPAN_DISPLAY%20failed%3A%20Connection%20timed%20out%3CBR%20%2F%3ED%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Set%20power%20mode%3D0%2C%20type%3D0%20flinger%3D0xa8732000%3CBR%20%2F%3EW%20221%20%2Fsystem%2Fbin%2Fsurfaceflinger%20SurfaceFlinger%20Ignoring%20duplicate%20VSYNC%20event%20from%20HWC%20(t%3D0)%3CBR%20%2F%3E...%3C%2FINIT%3E%3C%2FINIT%3E%3C%2FINIT%3E%3C%2FINIT%3E%3C%2FINIT%3E%3C%2FINIT%3E%3C%2FINIT%3E%3C%2FAPPLICATION%3E%3C%2FAPPLICATION%3E%3C%2FINIT%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3Esabresd_6dq%3A%2F%20%23%20ls%20-al%20%2Fdev%2Fgraphics%2F%3CBR%20%2F%3Els%20-al%20%2Fdev%2Fgraphics%2F%3CBR%20%2F%3Etotal%200%3CBR%20%2F%3Edrwxr-xr-x%202%20root%20root%2080%201970-01-01%2000%3A01%20.%3CBR%20%2F%3Edrwxr-xr-x%2017%20root%20root%202800%201970-01-01%2000%3A01%20..%3CBR%20%2F%3Ecrw-rw----%201%20system%20graphics%2029%2C%200%201970-01-01%2000%3A01%20fb0%3CBR%20%2F%3Ecrw-rw----%201%20root%20graphics%2029%2C%201%201970-01-01%2000%3A01%20fb1%3CBR%20%2F%3Esabresd_6dq%3A%2F%20%23%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120848%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20support%20uboot%20logo%20keep%20from%20uboot%20to%20kernel%20for%20NXP%20Linux%20and%20Android%20BSP%20(HDMI%2C%20LCD%20and%20LVDS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120848%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20for%20your%20quickly%20response%2C%20I%20will%20try%20it.%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎11-05-2013 01:31 AM
Updated by:
