This patch made the display no interrupt from uboot to kernel to Android. The IPU and related hardware display interface will only be initialized once in Uboot, the kernel code will skip the IPU initialization.
1. Description
1) Support HDMI, LVDS and LCD output in UBoot.
2) Support UBoot logo keep from uboot to kernel to Android.
3) For HDMI, both 720P and 1080P mode were supported.
4) For LVDS, 1024x768 and 1080P dual channel panels were supported.
5) The logo file is a 32 bpp bmp file.
2. File List
-- kernel_imx\0001-Keep-uboot-logo-for-Android-boot-supports-HDMI-LCD-a.patch
-- kernel_imx\0002-Bug-fix-for-uboot-logo-keep-patch.patch
Kernel patch to support the logo keep feature.
-- uboot-imx\0001-Enable-uboot-logo-for-HDMI-LCD-and-LVDS.patch
Uboot patch to support the logo display.
Example 32bpp logo file.
-- readme.txt
this file, please refer to it before use the patches
3. Requirement
- iMX6 SabreSD board.
- Android JB4.2.2_1.1.0-GA UBoot and kernel.
4. How to use
-- Copy the two patch files to Android kernel_imx and uboot-imx folder and apply them.
$ cd ~/myandroid/kernel_imx/
$ git apply ./0001-Keep-uboot-logo-for-Android-boot-supports-HDMI-LCD-a.patch
$ cd ~/myandroid/bootable/bootloader/uboot-imx/
$ git apply ./0001-Enable-uboot-logo-for-HDMI-LCD-and-LVDS.patch
$ git apply ./0002-Bug-fix-for-uboot-logo-keep-patch.patch
-- Build the new uboot image:
$ export CROSS_COMPILE=~/myandroid/prebuilt/gcc/linux-x86/arm/arm-eabi-4.6/bin/arm-eabi-
$ export ARCH=arm
$ make mx6q_sabresd_android_config
$ make
-- Before build new UBoot image, the display type can be selected from file uboot-imx\include\configs\mx6q_sabresd.h
// Select one of the output mode
#define IPU_OUTPUT_MODE_HDMI
//#define IPU_OUTPUT_MODE_LVDS
//#define IPU_OUTPUT_MODE_LCD
-- Build the new kernel image:
$ export ARCH=arm
$ make imx6_android_defconfig
$ make uImage
-- Before "make uImage", make menuconfig can be used to select the display type.
System Type --->
Freescale MXC Implementations --->
MX6 clk setting for smooth UI transtion from bootloader to kernel --->
Select Display Interface
( ) Smooth UI transtion on LCD, IPU1, DI0
( ) Smooth UI transtion on LVDS, IPU1, DI1
(X) Smooth UI transtion on HDMI, IPU2, DI0
-- Uboot parameters for video mode
1080P HDMI:
"video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24,bpp=32 fb0base=0x27b00000 fbmem=28M hdmi_audio_clk=148500000"
720P HDMI:
"video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24,bpp=32 fb0base=0x27b00000 fbmem=28M hdmi_audio_clk=74250000"
1024x768 LVDS:
"video=mxcfb0:dev=ldb,LDB-XGA,if=RGB666,bpp=32 fb0base=0x27b00000 fbmem=28M"
800x480 LCD:
"video=mxcfb0:dev=lcd,CLAA-WVGA,if=RGB565,bpp=32 fb0base=0x27b00000 fbmem=28M"
-- dd the logo.bmp to SD card address 0x100000 and skip the 54 bytes bmp file header.
sudo dd if=logo.bmp of=/dev/sdc bs=1 seek=1048576 skip=54
5. Note
1) The logo.bmp file should be 32bpp or 16bpp, and it should be synced with video mode parameters "bpp=xx",
and uboot config file mx6q_sabresd.h (#define DISPLAY_BPP xx).
2) The IPU number and DI number are hard coded in kernel file "board-mx6q_sabresd.c".
static struct fsl_mxc_hdmi_core_platform_data hdmi_core_data = {
.ipu_id = 1,
.disp_id = 0,
static struct fsl_mxc_lcd_platform_data lcdif_data = {
.ipu_id = 0,
.disp_id = 0,
.default_ifmt = IPU_PIX_FMT_RGB565,
static struct fsl_mxc_ldb_platform_data ldb_data = {
.ipu_id = 0,
.disp_id = 1,
.ext_ref = 1,
.mode = LDB_SEP1,
.sec_ipu_id = 0,
.sec_disp_id = 0,
3) The IPU number and DI number are defined by Macro in Uboot file "include\configs\mx6q_sabresd.h"
#define IPU_NUM 2 // 1 for IPU1, 2 for IPU2.
#define DI_NUM 0 // 0 for DI0, 1 for DI1.
4) The display type used in uboot and kernel must be same, same type, same IPU number, same DI port and
same resolution.
[2015-06-29 Update]: JB4.2.2_1.1.0_uboot_logo_keep_patch_2015-06-29.zip
Fix some LVDS issues for iMX6DL.
Also given an example for LVDS0 with DI0.
New Uboot patches:
0002-Updated-lvds-clock-source-to-pll2_pfd0.-Same-as-kern.patch
0003-Add-support-for-iMX6DL.patch
New kernel patches
0003-Skip-lvds-re-initialization-for-logo-keep.patch
0004-Add-examlpe-for-LVDS0-logo-keep.patch
[2015-08-07 Update]: JB4.2.2_1.1.0_uboot_logo_keep_patch_2015-08-07.zip
Added the new Uboot patch 0004-Correct-the-sequence-to-set-LDB-clock.patch
It can correct the LVDS clock set sequence whch is a known issue that caused no LVDS display sometimes.
[2015-09-18 Update]: JB4.3_1.1.1_uboot_logo_keep_patch_2015-09-18.zip
Added the patch for Android JB4.3_GA1.1.1 release.
Updated clock usecount, after blank the display, the related clock can be gated off correctly.
Support LVDS clock from PLL5.
[2015-12-21 Update]: Added 3.10.53_GA1.1.0 patch: L3.10.53_GA1.1.0_uboot_logo_keep_patch_2015-12-21.zip.
Verified on iMX6DL/Q SabreSD board. It supports LCD and LVDS panels, HDMI patch will be released later.
[2016-01-04 Update]: Added 3.10.53_GA1.1.0 patch: L3.10.53_GA1.1.0_uboot_logo_keep_patch_2016-01-04.zip.
Added HDMI display support. Now it supports LCD, LVDS and HDMI displays.
Fixed the video playback issue for boot up.
[2016-05-18 Update]: 0001-Fix-the-split-mode-LVDS-panel-no-TX3-signal-issue.patch
An issue was founded, when dual channel 4 lanes LVDS panel was used, in uboot there will be no LVDS TX3 signa on one LVDS port, the attach "0001-Fix-the-split-mode-LVDS-panel-no-TX3-signal-issue.patch" was used to fix this issue, it is based on JB4.3_1.1.1_uboot_logo_keep_patch_2015-09-18.zip, for other BSP, please port it manually.
[2016-08-29 Update]: 0001-After-reset-IPU-in-SRC-Control-Register-wait-for-res.patch
On some iMX6 chip, after reset the IPU in SRC Control Register, enable IPU at once will cause system hang up, to avoid such issue, software needs wait for IPU reset done by polling the SRC register.
The attach "0001-After-reset-IPU-in-SRC-Control-Register-wait-for-res.patch" was used to fix this issue, it is based on JB4.3_1.1.1_uboot_logo_keep_patch_2015-09-18.zip + "0001-Fix-the-split-mode-LVDS-panel-no-TX3-signal-issue.patch", for other BSP, please port it manually.
[2017-01-06 Update] Added patch for L4.1.15_GA1.2.0 BSP and Android M6.0.1_GA2.1.0 BSP.
Files: L4.1.15_GA1.2.0_uboot_logo_keep_patch_2017-01-06.zip; M6.0.1_2.1.0_uboot_logo_keep_patch_2017-01-06.zip
Dear Li,
when i patched this 0001-Enable-uboot-logo-for-HDMI-LCD-and-LVDS.patch(version: L3.0.35_4.1.0), it shows some error, can you help me:
$ make mx6q_sabresd_config
$ make
Map u-boot.map -o u-boot
drivers/video/libvideo.a(mxc_epdc_fb.o): In function `lcd_initcolregs':
/home/fulinux/uboot-imx/drivers/video/mxc_epdc_fb.c:52: multiple definition of `lcd_initcolregs'
drivers/video/libvideo.a(mxc_ipuv3_fb.o):/home/fulinux/uboot-imx/drivers/video/mxc_ipuv3_fb.c:61: first defined here
drivers/video/libvideo.a(mxc_epdc_fb.o): In function `lcd_setcolreg':
/home/fulinux/uboot-imx/drivers/video/mxc_epdc_fb.c:56: multiple definition of `lcd_setcolreg'
drivers/video/libvideo.a(mxc_ipuv3_fb.o):/home/fulinux/uboot-imx/drivers/video/mxc_ipuv3_fb.c:65: first defined here
drivers/video/libvideo.a(mxc_epdc_fb.o): In function `lcd_disable':
/home/fulinux/uboot-imx/drivers/video/mxc_epdc_fb.c:397: multiple definition of `lcd_disable'
drivers/video/libvideo.a(mxc_ipuv3_fb.o):/home/fulinux/uboot-imx/drivers/video/mxc_ipuv3_fb.c:69: first defined here
drivers/video/libvideo.a(mxc_epdc_fb.o): In function `lcd_panel_disable':
/home/fulinux/uboot-imx/drivers/video/mxc_epdc_fb.c:402: multiple definition of `lcd_panel_disable'
drivers/video/libvideo.a(mxc_ipuv3_fb.o):/home/fulinux/uboot-imx/drivers/video/mxc_ipuv3_fb.c:73: first defined here
drivers/video/libvideo.a(mxc_epdc_fb.o): In function `lcd_ctrl_init':
/home/fulinux/uboot-imx/drivers/video/mxc_epdc_fb.c:413: multiple definition of `lcd_ctrl_init'
drivers/video/libvideo.a(mxc_ipuv3_fb.o):/home/fulinux/uboot-imx/drivers/video/mxc_ipuv3_fb.c:622: first defined here
drivers/video/libvideo.a(mxc_epdc_fb.o): In function `calc_fbsize':
/home/fulinux/uboot-imx/drivers/video/mxc_epdc_fb.c:467: multiple definition of `calc_fbsize'
drivers/video/libvideo.a(mxc_ipuv3_fb.o):/home/fulinux/uboot-imx/drivers/video/mxc_ipuv3_fb.c:610: first defined here
drivers/video/libvideo.a(mxc_epdc_fb.o): In function `lcd_enable':
/home/fulinux/uboot-imx/drivers/video/mxc_epdc_fb.c:376: multiple definition of `console_row'
drivers/video/libvideo.a(mxc_ipuv3_fb.o):/home/fulinux/uboot-imx/drivers/video/mxc_ipuv3_fb.c:80: first defined here
/home/fulinux/uboot-imx/drivers/video/mxc_epdc_fb.c:376: multiple definition of `console_col'
/home/fulinux/uboot-imx/drivers/video/mxc_epdc_fb.c:370: multiple definition of `lcd_color_bg'
/home/fulinux/uboot-imx/drivers/video/mxc_epdc_fb.c:56: multiple definition of `lcd_color_fg'
drivers/video/libvideo.a(mxc_ipuv3_fb.o):/home/fulinux/uboot-imx/drivers/video/mxc_ipuv3_fb.c:81: first defined here
/home/fulinux/uboot-imx/drivers/video/mxc_epdc_fb.c:373: multiple definition of `lcd_line_length'
drivers/video/libvideo.a(mxc_ipuv3_fb.o):/home/fulinux/uboot-imx/drivers/video/mxc_ipuv3_fb.c:79: first defined here
/home/fulinux/uboot-imx/drivers/video/mxc_epdc_fb.c:376: multiple definition of `lcd_console_address'
/home/fulinux/uboot-imx/drivers/video/mxc_epdc_fb.c:52: multiple definition of `lcd_base'
common/libcommon.a(lcd.o): In function `console_newline':
/home/fulinux/uboot-imx/common/lcd.c:159: undefined reference to `panel_info'
common/libcommon.a(lcd.o): In function `lcd_putc':
/home/fulinux/uboot-imx/common/lcd.c:200: undefined reference to `panel_info'
common/libcommon.a(lcd.o): In function `lcd_setmem':
/home/fulinux/uboot-imx/common/lcd.c:476: undefined reference to `panel_info'
common/libcommon.a(lcd.o): In function `lcd_display_bitmap':
/home/fulinux/uboot-imx/common/lcd.c:829: undefined reference to `panel_info'
common/libcommon.a(lcd.o): In function `lcd_clear':
/home/fulinux/uboot-imx/common/lcd.c:415: undefined reference to `panel_info'
common/libcommon.a(lcd.o):/home/fulinux/uboot-imx/common/lcd.c:369: more undefined references to `panel_info' follow
common/libcommon.a(cmd_fastboot.o): In function `rx_handler':
/home/fulinux/uboot-imx/common/cmd_fastboot.c:1050: undefined reference to `do_booti'
drivers/fastboot/libfastboot.a(fastboot.o): In function `check_fastboot_mode':
/home/fulinux/uboot-imx/drivers/fastboot/fastboot.c:788: undefined reference to `fastboot_check_and_clean_flag'
drivers/usb/gadget/libusb_gadget.a(imx_udc.o): In function `mxc_udc_init':
/home/fulinux/uboot-imx/drivers/usb/gadget/imx_udc.c:812: undefined reference to `set_usboh3_clk'
/home/fulinux/uboot-imx/drivers/usb/gadget/imx_udc.c:813: undefined reference to `set_usb_phy1_clk'
/home/fulinux/uboot-imx/drivers/usb/gadget/imx_udc.c:814: undefined reference to `enable_usboh3_clk'
/home/fulinux/uboot-imx/drivers/usb/gadget/imx_udc.c:818: undefined reference to `enable_usb_phy1_clk'
drivers/usb/gadget/libusb_gadget.a(imx_udc.o): In function `usb_set_mode_device':
/home/fulinux/uboot-imx/drivers/usb/gadget/imx_udc.c:468: undefined reference to `reset_usb_phy1'
drivers/video/libvideo.a(mxc_ipuv3_fb.o): In function `calc_fbsize':
mxc_ipuv3_fb.c:(.text+0xb4): undefined reference to `panel_info'
drivers/video/libvideo.a(mxc_ipuv3_fb.o): In function `lcd_ctrl_init':
mxc_ipuv3_fb.c:(.text+0xf8): undefined reference to `panel_info'
drivers/video/libvideo.a(mxc_ipuv3_fb.o): In function `ipuv3_fb_init':
mxc_ipuv3_fb.c:(.text+0x7d0): undefined reference to `panel_info'
drivers/video/libvideo.a(ipu_common.o): In function `clk_ipu_enable':
/home/fulinux/uboot-imx/drivers/video/ipu_common.c:166: undefined reference to `ipu_clk_enable'
mxc_epdc_fb.c:(.text+0x14): undefined reference to `epdc_power_on'
mxc_epdc_fb.c:(.text+0x180): undefined reference to `panel_info'
mxc_epdc_fb.c:(.text+0x1a4): undefined reference to `epdc_power_off'
mxc_epdc_fb.c:(.text+0x240): undefined reference to `setup_waveform_file'
mxc_epdc_fb.c:(.text+0x3ac): undefined reference to `panel_info'
mxc_epdc_fb.c:(.text+0x3e4): undefined reference to `panel_info'
make: *** [u-boot] Error 1
Dear Li, this my lcd picture:
and this is my head file:
// For LVDS, 1920*1080 resolution, dual channel
#define DISPLAY_WIDTH 1920
#define DISPLAY_HEIGHT 1080
#define DISPLAY_BPP 32
#define DISPLAY_IF_BPP 24 // RGB24 interface
#define DISPLAY_HSYNC_START 80
#define DISPLAY_HSYNC_END 68
#define DISPLAY_HSYNC_WIDTH 12
#define DISPLAY_VSYNC_START 15
#define DISPLAY_VSYNC_END 15
#define DISPLAY_VSYNC_WIDTH 8
#define DISPLAY_PIX_CLOCK 140000000 //(DISPLAY_HSYNC_START + DISPLAY_HSYNC_END + DISPLAY_HSYNC_WIDTH + DISPLAY_WIDTH) *
(DISPLAY_VSYNC_START + DISPLAY_VSYNC_END + DISPLAY_VSYNC_WIDTH + DISPLAY_HEIGHT) * refresh rate (60Hz)
#define LVDS_SPLIT_MODE // For dual channel split mode.
#define DISPLAY_VSYNC_POLARITY 1
#define DISPLAY_HSYNC_POLARITY 1
#define DISPLAY_CLOCK_POLARITY 1
#define DISPLAY_DATA_POLARITY 0
#define DISPLAY_DATA_ENABLE_POLARITY 1
#define IPU_NUM 1 // 1 for IPU1, 2 for IPU2.
#define LVDS_PORT 0 // 0 for LVDS0, 1 for LVDS1.
#define DI_CLOCK_EXTERNAL_MODE //When clock external mode was defined, the DI clock root will be PLL3 PFD1,
//without this macro, the DI root clock is IPU internal clock.
what should i do ?
Dear all,
Have you had this problem? uboot logo color is green what's wrong with it?
waiting for you help....
fulinux.
Hi Frank,
i have the same problem as you:
How did you solve it? is it wrong with backlight gpio sets? can you tell me you email or QQ?
fulinux.
It looks like the color space of your display is correct so your issue is different from my issue. Did you check if it display correctly in Linux or Android?
I ported the changes in the 3.10.53-patches to keep the logo for my 3.10.17 kernel, and it works fine as the logo from the bootloader is shown all the way during the kernel initialization.
My problem: as soon as the kernel is ready and switches to /sbin/init, I get garbage displayed on the screen.
I can then do a blank/unblank and use the display from userspace without problems, but the content from the bootloader is not kept until userspace is running.
Qiang do you have any idea what could be wrong? Something with memory allocation?
Thanks!
The 3.10.53 patch has the reference code for how to let the kernel use the same framebuffer as Uboot.
I ported the 3.10.53 patch to my kernel, but I still have the described issue, that the framebuffer content is erased/overriden/etc. after the kernel is initialized and switches to init.
Hi Qiang,
When i patch this in 3.0.35, it runs well, but it will reboot without any log when i copy videos files to board from u disk, it looks like pass reset key. have you met this problem?
我在3.0.35版本的内核中打上这些补丁后,其他功能运行正常,和之前比没有出现什么问题,但是当我们用u盘升级视频资源的时候(就是拷贝视频到sd卡中)会出现莫名其妙的重启,而且内核没有任何的信息,就好像按了复位按键一样。我将撤销这个keep logo功能后就不会出现这个重启的问题。我们的上层是Qt5,不是安卓,你们有没有遇到类似的问题?
你好,我使用3.0.35内核,在没有加这些补丁之前,播放视频没有任何问题,但是加了之后logo显示什么都正常,但是播放视频会出现重启的现象,而且是必然复现的现象,而且没有任何log,而且已经烧掉了两个板子上的稳压管,我感觉是加了logo这个功能的时候时钟什么的设置上有错误,导致功耗发生了变化。现在这样的情况就不能量产,公司现在很着急,天天催我,已经被这个问题困扰了2个月了。我们的屏是1920x1080, 所以用了ipu1的split mode, 我看见uboot和kernel的补丁在设置di的时候只是单独设置di0或者di1, split mode 模式下不是应该同时用了di0和di1的吗?不应该同时设置di0和di1的时钟什么的吗? 现在这个问题很棘手,我也在这个issue:system reboot abnormally when i patch 'upport uboot logo keep from uboot to kernel' 上有提到.麻烦Qiang能帮我看看。需要什么信息请告诉我。
Hi Qiang:
I patched u-boot and kernel using JB4.3_1.1.1_uboot_logo_keep_patch_2015-09-18 and 0001-Fix-the-split-mode-LVDS-panel-no-TX3-signal-issue.patch. The logo display is OK.
But when I power off and then power on the board, sometimes the u-boot logo can't display with rate 10~20%. The LVDS panel will black forever. Only the backlight is light. The kernel will repeatedly print the error "mxc_sdc_fb mxc_sdc_fb.0: MXCFB_WAIT_FOR_VSYNC: timeout 0" after the android system booting.
1. My platform as bellow:
SOC: iMX6 Dual Lite
U-Boot verson: U-Boot 2009.08
Kernel version: Linux 3.0.35
Android: 4.4.2_r1
LVDS Panel: AUO M190PW01 V8 (19inch, Resolution: 1440x900)
Display Mode: Split Mode
2. The u-boot display setting as bellow:
#ifdef IPU_OUTPUT_MODE_LVDS
// For LVDS, 1440*900 resolution
#define DISPLAY_WIDTH 1440
#define DISPLAY_HEIGHT 900
#define DISPLAY_HSYNC_START 232
#define DISPLAY_HSYNC_END 80
#define DISPLAY_HSYNC_WIDTH 152
#define DISPLAY_VSYNC_START 25
#define DISPLAY_VSYNC_END 3
#define DISPLAY_VSYNC_WIDTH 6
#define DISPLAY_PIX_CLOCK 106500000
#define LVDS_PORT 0 // 0 for LVDS0, 1 for LVDS1. For LVDS display, LVDS_PORT should be same as DI_NUM.
#endif
I got these patches working well using PLL5 as source clock for IPU2 DI0.
I changed the source clock to PLL2 because the project needs spread spectrum enabled and the logo is kept as expected but when I change the virtual size of the fb( from 1920,720 to 1920,2160) there is a kind of flicker when _setup_disp_channel2() executes ipu_init_channel_buffer_late_init().
This problem is not happening when PLL5 is used.
Did I miss something to change IPU2 DI0 clock source to pll2_pfd2_396m?
cat /sys/kernel/debug/clk/clk_summary
clock enable_cnt prepare_cnt rate
anaclk2 0 0 0
lvds2_in 0 0 0
anaclk1 0 0 0
lvds1_in 0 0 0
dummy 2 3 0
usbphy2_gate 1 1 0
usbphy1_gate 1 1 0
osc 6 6 24000000
periph_clk2_sel 0 0 24000000
periph_clk2 0 0 24000000
gpt_3m 1 1 3000000
pll4_sel 1 1 24000000
pll4_audio 1 1 688128000
pll4_post_div 1 1 688128000
pll4_audio_div 1 1 688128000
esai_sel 0 0 688128000
esai_pred 0 0 344064000
esai_podf 0 0 43008000
esai 0 0 43008000
ssi3_sel 0 0 688128000
ssi3_pred 0 0 172032000
ssi3_podf 0 0 86016000
ssi3 0 0 86016000
ssi2_sel 1 1 688128000
ssi2_pred 1 1 172032000
ssi2_podf 1 1 86016000
ssi2 1 1 86016000
cko2_sel 1 1 86016000
cko2_podf 1 1 12288000
cko2 1 1 12288000
cko 1 1 12288000
ssi1_sel 0 0 688128000
ssi1_pred 0 0 172032000
ssi1_podf 0 0 86016000
ssi1 0 0 86016000
pll7_usb_host 0 0 480000000
usbphy2 0 0 480000000
pll6_enet 1 1 500000000
enet_ref 3 3 125000000
pcie_ref 0 0 125000000
pcie_ref_125m 0 0 125000000
sata_ref 0 0 100000000
lvds1_sel 0 0 100000000
lvds1_out 0 0 100000000
sata_ref_100m 0 0 100000000
pll5_video 0 0 288000000
pll3_usb_otg 2 3 480000000
gpu2d_core_sel 0 0 480000000
gpu2d_core_podf 0 0 480000000
gpu2d_core 0 0 480000000
asrc_sel 0 1 480000000
asrc_pred 0 1 240000000
asrc_podf 0 1 30000000
asrc 0 1 30000000
periph2_clk2_sel 0 0 480000000
periph2_clk2 0 0 480000000
pll3_60m 0 0 60000000
ecspi_root 0 0 60000000
ecspi5 0 0 60000000
ecspi4 0 0 60000000
ecspi3 0 0 60000000
ecspi2 0 0 60000000
ecspi1 0 0 60000000
can_root 0 0 30000000
can2_serial 0 0 30000000
can1_serial 0 0 30000000
pll3_80m 1 1 80000000
uart_serial_podf 1 1 80000000
uart_serial 2 3 80000000
pll3_120m 0 0 120000000
pll3_pfd3_454m 0 0 454736842
spdif_sel 0 0 454736842
spdif_pred 0 0 227368421
spdif_podf 0 0 28421052
spdif 0 0 28421052
pll3_pfd2_508m 0 0 508235294
pll3_pfd1_540m 0 0 540000000
hdmi_isfr 0 0 540000000
video_27m 0 0 27000000
pll3_pfd0_720m 0 0 720000000
usbphy1 1 1 480000000
pll2_bus 2 2 528000000
cko1_sel 0 0 528000000
cko1_podf 0 0 528000000
cko1 0 0 528000000
periph2_pre 0 0 528000000
periph2 0 0 528000000
mmdc_ch1_axi_podf 0 0 528000000
mmdc_ch1_axi 0 0 528000000
ldb_di1_sel 0 0 528000000
ldb_di1_div_7 0 0 75428571
ldb_di1_div_sel 0 0 75428571
ldb_di1 0 0 75428571
ldb_di1_div_3_5 0 0 150857142
periph_pre 1 1 528000000
periph 3 3 528000000
ahb 4 4 132000000
sdma 8 2 132000000
rom 1 1 132000000
ocram 1 1 132000000
hdmi_iahb 0 0 132000000
caam_aclk 0 0 132000000
caam_mem 0 0 132000000
ipg 4 4 66000000
usboh3 1 1 66000000
uart_ipg 2 3 66000000
ssi3_ipg 0 0 66000000
ssi2_ipg 0 0 66000000
ssi1_ipg 0 0 66000000
spba 0 0 66000000
sata 0 0 66000000
iim 0 0 66000000
gpt_ipg 1 1 66000000
epit2 0 0 66000000
epit1 0 0 66000000
enet 2 2 66000000
can2_ipg 0 0 66000000
can1_ipg 0 0 66000000
caam_ipg 0 0 66000000
ipg_per 0 0 66000000
pwm4 0 0 66000000
pwm3 0 0 66000000
pwm2 0 0 66000000
pwm1 0 0 66000000
i2c3 0 0 66000000
i2c2 0 0 66000000
i2c1 0 0 66000000
gpt_ipg_per 0 0 66000000
mmdc_ch0_axi_podf 1 1 528000000
mmdc_ch0_axi 2 3 528000000
gpu3d_core_sel 0 0 528000000
gpu3d_core_podf 0 0 528000000
gpu3d_core 0 0 528000000
ipu1_sel 0 1 528000000
ipu1_podf 0 1 264000000
ipu1 0 1 264000000
ipu1_pclk1_sel 0 0 264000000
ipu1_pclk1_div 0 0 0
ipu1_pclk_1 0 0 0
ipu1_pclk0_sel 0 0 264000000
ipu1_pclk0_div 0 0 0
ipu1_pclk_0 0 0 0
dcic1 0 0 264000000
ipu2_sel 1 1 528000000
ipu2_podf 1 1 264000000
ipu2 3 2 264000000
ipu2_pclk1_sel 0 0 264000000
ipu2_pclk1_div 0 0 0
ipu2_pclk_1 0 0 0
ipu2_pclk0_sel 1 1 264000000
ipu2_pclk0_div 1 1 264000000
ipu2_pclk_0 1 1 264000000
dcic2 0 0 264000000
tzasc2 0 0 528000000
axi_sel 1 1 528000000
axi 1 1 264000000
openvg_axi 0 0 264000000
mlb 0 0 264000000
gpu2d_axi 0 0 264000000
gpu3d_axi 0 0 264000000
pcie_axi_sel 0 0 264000000
pcie_axi 0 0 264000000
emi_slow_sel 1 1 264000000
emi_slow_podf 1 1 132000000
eim_slow 1 1 132000000
vdo_axi_sel 0 0 264000000
vdo_axi 0 0 264000000
vdoa 0 0 264000000
vpu_axi_sel 0 0 264000000
vpu_axi_podf 0 0 264000000
vpu_axi 0 0 264000000
pll2_pfd2_396m 4 4 339428571
ipu2_di1_pre_sel 0 0 339428571
ipu2_di1_pre 0 0 113142857
ipu2_di1_sel 0 0 113142857
ipu2_di1 0 0 113142857
ipu2_di0_pre_sel 0 0 339428571
ipu2_di0_pre 0 0 113142857
ipu1_di1_pre_sel 0 0 339428571
ipu1_di1_pre 0 0 113142857
ipu1_di1_sel 0 0 113142857
ipu1_di1 0 0 113142857
ipu1_di0_pre_sel 0 0 339428571
ipu1_di0_pre 0 0 113142857
ipu1_di0_sel 0 0 113142857
ipu1_di0 0 0 113142857
emi_sel 0 0 339428571
emi_podf 0 0 169714285
enfc_sel 1 1 339428571
enfc_pred 1 1 84857142
enfc_podf 1 1 84857142
enfc 1 1 84857142
gpmi_io 1 1 84857142
usdhc4_sel 1 1 339428571
usdhc4_podf 1 1 169714285
usdhc4 1 1 169714285
gpmi_bch 1 1 169714285
usdhc3_sel 1 1 339428571
usdhc3_podf 1 1 169714285
usdhc3 4 4 169714285
apbh_dma 1 1 169714285
per1_bch 1 1 169714285
gpmi_bch_apb 1 1 169714285
gpmi_apb 1 1 169714285
usdhc2_sel 0 0 339428571
usdhc2_podf 0 0 169714285
usdhc2 0 0 169714285
usdhc1_sel 0 0 339428571
usdhc1_podf 0 0 169714285
usdhc1 0 0 169714285
hsi_tx_sel 0 0 339428571
hsi_tx_podf 0 0 169714285
hsi_tx 0 0 169714285
ldb_di0_sel 1 1 339428571
ldb_di0_div_7 0 0 48489795
ldb_di0_div_3_5 1 1 96979591
ldb_di0_div_sel 1 1 96979591
ldb_di0 1 1 96979591
ipu2_di0_sel 1 1 96979591
ipu2_di0 1 1 96979591
step 0 0 339428571
pll2_198m 0 0 169714285
pll2_pfd1_594m 0 0 594000000
gpu3d_shader_sel 0 0 594000000
gpu3d_shader 0 0 594000000
pll2_pfd0_352m 0 0 352000000
pll1_sys 1 1 852000000
pll1_sw 1 1 852000000
arm 2 2 852000000
lvds2_sel 0 0 852000000
lvds2_out 0 0 852000000
twd 1 1 426000000
ckih1 0 0 0
ckil 0 0 32768
Hi Qiang:
是否有mipi屏显示从uboot到kernel的相关patch?
我现在用uboot 2014-04 kernel 3.10.53,需要用mipi屏,但是现在uboot部分显示存在问题,并且不能很好的过渡到kernel中。
能否提供帮助?谢谢!
Sorry, MIPI display is not supported by this patch.
Hi LiQiang,
Could you have a look at this problem, https://community.nxp.com/message/835176 ,
I think you are expert on display, maybe you can give me some advice.
请问为什么 mipi dsi不能支持..我也需要mipi的补丁..
Each MIPI display has its own special setting and initialization code, that means even we create a reference patch, you can't re-use it.
The key point for this patch is to avoid IPU and MIPI display re-initialization in kernel, the skip IPU code can be re-used here, and you need debug the code to avoid your MIPI display re-initialization.
但,你们可以根据官方推荐的hx8963做一个demo,这样的话,我们调试没那么麻烦
我个人认为imx6是支持mipi屏接口,而当今mipi屏也是主流,为什么不能对mipi屏作一个好的支持
请问有针对Linux3.14.52内核的补丁吗?
有没有l5.1.1_2.1.1 的patch啊?
我按照m6.0.1的补丁,进入内核后一直停在start kernel.......
前面停留在start kernel 是忘记加bypass_reset = <1>;
加了bypass_reset = <1>;后
出现错误:
mxc_sdc_fb fb.23: MXCFB_WAIT_FOR_VSYNC: timeout 0
mxc_sdc_fb fb.23: timeout when waiting for flip irq
random: nonblocking pool is initialized
I'm trying to apply your latest patches to imx_4.1.15_2.0.0_ga but they don't apply. Am I doing something wrong?
chris:linux-imx$ git status .
On branch imx_4.1.15_2.0.0_ga
Your branch is up-to-date with 'origin/imx_4.1.15_2.0.0_ga'.
nothing to commit, working directory clean
chris:linux-imx$ git apply -v ~/tmp/L4.1.15_GA1.2.0/kernel/0002-Keep-uboot-logo-for-linux-boot-supports-LCD.patchChecking patch arch/arm/boot/dts/Makefile...
Hunk #2 succeeded at 324 (offset 1 line).
Checking patch arch/arm/boot/dts/imx6dl-sabresd-logo-lcd-ipu1-di0.dts...
/home/chris/tmp/L4.1.15_GA1.2.0/kernel/0002-Keep-uboot-logo-for-linux-boot-supports-LCD.patch:83: new blank line at EOF.
Checking patch arch/arm/boot/dts/imx6q-sabresd-logo-lcd-ipu1-di0.dts...
/home/chris/tmp/L4.1.15_GA1.2.0/kernel/0002-Keep-uboot-logo-for-linux-boot-supports-LCD.patch:123: new blank line at EOF.
Checking patch arch/arm/boot/dts/imx6qdl-sabresd.dtsi...
Hunk #1 succeeded at 242 (offset 11 lines).
Checking patch arch/arm/configs/imx_v7_defconfig...
error: while searching for:
CONFIG_SOC_IMX50=y
CONFIG_SOC_IMX53=y
CONFIG_SOC_IMX6Q=y
CONFIG_SOC_IMX6SL=y
CONFIG_SOC_IMX6SX=y
CONFIG_SOC_IMX6UL=y
error: patch failed: arch/arm/configs/imx_v7_defconfig:22
error: arch/arm/configs/imx_v7_defconfig: patch does not apply
Checking patch arch/arm/mach-imx/Kconfig...
Checking patch arch/arm/mach-imx/clk-imx6q.c...
Hunk #1 succeeded at 323 (offset 4 lines).
Hunk #2 succeeded at 347 (offset 4 lines).
#endif
imx6q_set_lpm(WAIT_CLOCKED);
CLK_OF_DECLARE(imx6q, "fsl,imx6q-ccm", imx6q_clocks_init);
error: patch failed: arch/arm/mach-imx/clk-imx6q.c:898
error: arch/arm/mach-imx/clk-imx6q.c: patch does not apply
Checking patch arch/arm/mach-imx/mach-imx6q.c...
Checking patch drivers/mxc/ipu3/ipu_common.c...
/home/chris/tmp/L4.1.15_GA1.2.0/kernel/0002-Keep-uboot-logo-for-linux-boot-supports-LCD.patch:861: new blank line at EOF.
Checking patch drivers/mxc/ipu3/ipu_disp.c...
/home/chris/tmp/L4.1.15_GA1.2.0/kernel/0002-Keep-uboot-logo-for-linux-boot-supports-LCD.patch:1026: new blank line at EOF.
Checking patch drivers/video/fbdev/mxc/mxc_dispdrv.h...
Checking patch drivers/video/fbdev/mxc/mxc_ipuv3_fb.c...
Checking patch include/linux/ipu-v3.h...
Hi, Qiang Li.
I'm using android_N7.1.1_1.0.0 for i.MX6pq sabresd.
Display : 800x1280 LVDS (output to IPU1-DI0)
Apply patch : M6.0.1_2.1.0_uboot_logo_keep_patch_2017-01-06.zip
Problem
| u-boot : lockup |
U-Boot 2015.04 (Jul 04 2017 - 21:08:43) CPU: Freescale i.MX6QP rev1.0 at 792 MHz In: serial ... lockup ... |
| Correction : delete IPU2 QoS generator |
void ipu_setup(unsigned int IPU, unsigned int DI) #ifdef CONFIG_MX6QP /* Bypass IPU1 QoS generator */ ... } |
| kernel : lockup |
U-Boot 2015.04 (Jul 04 2017 - 21:08:43) CPU: Freescale i.MX6QP rev1.0 at 792 MHz In: serial Hit any key to stop autoboot: 0 Starting kernel ... ... lockup ... |
| Correction : Added bypass_reset to ipu2 |
imx6qp.dtsi / { ... |
the lvds output is good until the bootanimation.
Question : fb0 timeout problem occurred
mxc_sdc_fb fb@0: timeout when waiting for flip irq
graphics fb0: MXCFB_WAIT_FOR_VSYNC: timeout 0
W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0)
W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out
What's wrong? What should I do?
expect some advice...
| serial, logcat, ls |
U-Boot 2015.04 (Jul 04 2017 - 21:08:43) CPU: Freescale i.MX6QP rev1.0 at 792 MHz In: serial Hit any key to stop autoboot: 0 Starting kernel ... Booting Linux on physical CPU 0x0 ... |
| --------- beginning of main W 199 auditd type=2000 audit(0.0:1): initialized I 199 auditd type=1403 audit(0.0:2): policy loaded auid=4294967295 ses=4294967295 W 199 auditd type=1404 audit(0.0:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295 I 206 debuggerd: starting --------- beginning of system I 207 vold Vold 3.0 (the awakening) firing up V 207 vold Detected support for: ext4 f2fs vfat W 207 Vold Tearing down stale mount /mnt/shm D 207 vold e4crypt_init_user0 D 207 vold e4crypt_prepare_user_storage for volume null, user 0, serial 0, flags 1 D 207 vold Preparing: /data/system/users/0 D 207 vold Preparing: /data/misc/profiles/cur/0 D 207 vold Preparing: /data/misc/profiles/cur/0/foreign-dex D 207 vold Preparing: /data/system_de/0 D 207 vold Preparing: /data/misc_de/0 D 207 vold Preparing: /data/user_de/0 D 207 vold e4crypt_unlock_user_key 0 serial=0 token_present=0 E 207 vold Failed to chmod /data/system_ce/0: No such file or directory E 207 vold Failed to chmod /data/misc_ce/0: No such file or directory E 207 vold Failed to chmod /data/media/0: No such file or directory I 1 vdc 200 211 Command succeeded I 215 /system/bin/tzdatacheck tzdata file /data/misc/zoneinfo/current/tzdata does not exist. No action required. I 219 lowmemorykiller Using in-kernel low memory killer interface W 229 audioserver type=1400 audit(0.0:4): avc: denied { getattr } for path="/vendor" dev="rootfs" ino=7112 scontext=u:r:audioserver:s0 tcontext=u:object_r:rootfs:s0 tclass=lnk_file permissive=0 W 234 mediacodec type=1400 audit(0.0:5): avc: denied { getattr } for path="/vendor" dev="rootfs" ino=7112 scontext=u:r:mediacodec:s0 tcontext=u:object_r:rootfs:s0 tclass=lnk_file permissive=0 W 235 mediadrmserver type=1400 audit(0.0:6): avc: denied { getattr } for path="/vendor" dev="rootfs" ino=7112 scontext=u:r:mediadrmserver:s0 tcontext=u:object_r:rootfs:s0 tclass=lnk_file permissive=0 W 230 cameraserver type=1400 audit(0.0:7): avc: denied { getattr } for path="/vendor" dev="rootfs" ino=7112 scontext=u:r:cameraserver:s0 tcontext=u:object_r:rootfs:s0 tclass=lnk_file permissive=0 W 239 magd type=1400 audit(0.0:8): avc: denied { getattr } for path="/vendor" dev="rootfs" ino=7112 scontext=u:r:sensors:s0 tcontext=u:object_r:rootfs:s0 tclass=lnk_file permissive=0 I 232 installd firing up E 232 cutils Failed to read /data/.layout_version: No such file or directory D 232 Assuming that device has multi-user storage layout; upgrade no longer supported D 232 Upgrading to /data/misc/user directories I 241 perfprofd starting Android Wide Profiling daemon E 241 perfprofd unable to open configuration file /data/data/com.google.android.gms/files/perfprofd.conf I 241 perfprofd random seed set to 3634078034 D 239 MagDaemon init_sensors I 233 keystore Found keymaster0 module Keymaster OpenSSL HAL, version 2 I 233 SoftKeymaster system/keymaster/soft_keymaster_device.cpp, Line 131: Creating device D 233 SoftKeymaster system/keymaster/soft_keymaster_device.cpp, Line 132: Device address: 0xafcb2000 I 233 keystore Keymaster0 module is software-only. Using SoftKeymasterDevice instead. I 233 SoftKeymaster system/keymaster/soft_keymaster_device.cpp, Line 131: Creating device D 233 SoftKeymaster system/keymaster/soft_keymaster_device.cpp, Line 132: Device address: 0xafcb2200 I 240 gatekeeperd Starting gatekeeperd... W 240 gatekeeperd falling back to software GateKeeper I 240 gatekeeperd cold boot: clearing state I 221 SurfaceFlinger SurfaceFlinger is starting I 221 SurfaceFlinger SurfaceFlinger's main thread ready to run. Initializing graphics H/W... I 238 Netd Netd 1.0 starting D 238 TetherController Setting IP forward enable = 0 D 221 libEGL loaded /system/lib/egl/libEGL_VIVANTE.so I 229 sMaxFastTracks = 8 I 234 mediacodec @@@ mediacodecservice starting I 229 audioserver ServiceManager: 0xac119360 W 229 BatteryNotifier batterystats service unavailable! I 229 AudioFlinger Using default 3000 mSec as standby time. W 234 /system/bin/mediacodec libminijail: allowing syscall: clock_gettime W 234 /system/bin/mediacodec libminijail: allowing syscall: connect W 234 /system/bin/mediacodec libminijail: allowing syscall: fcntl64 W 234 /system/bin/mediacodec libminijail: allowing syscall: socket W 234 /system/bin/mediacodec libminijail: allowing syscall: writev I 229 AudioPolicyService AudioPolicyService CSTOR in new mode W 234 /system/bin/mediacodec libminijail: logging seccomp filter failures D 221 libEGL loaded /system/lib/egl/libGLESv1_CM_VIVANTE.so I 230 cameraserver ServiceManager: 0xb2199360 I 230 CameraService CameraService started (pid=230) I 230 CameraService CameraService process starting E 229 audio_hw_primary no supported sound card found, aborting. E 229 AudioFlinger int android::load_audio_interface(const char *, audio_hw_device_t **) couldn't open audio hw device in audio.primary (Invalid argument) E 229 AudioFlinger loadHwModule() error -22 loading module primary W 229 APM_AudioPolicyManager could not open HW module primary W 230 BatteryNotifier batterystats service unavailable! W 230 BatteryNotifier batterystats service unavailable! I 229 bt_a2dp_hw adev_open: adev_open in A2dp_hw module I 229 AudioFlinger loadHwModule() Loaded a2dp audio interface from A2DP Audio HW HAL (audio) handle 10 V 236 MediaUtils physMem: 2084847616 V 236 MediaUtils requested limit: 416969520 V 236 MediaUtils actual limit: 3221225472 V 236 MediaUtils original limits: 4294967295/4294967295 V 236 MediaUtils new limits: 3221225472/4294967295 W 236 /system/bin/mediaextractor libminijail: allowing syscall: clock_gettime W 236 /system/bin/mediaextractor libminijail: allowing syscall: connect W 236 /system/bin/mediaextractor libminijail: allowing syscall: fcntl64 W 236 /system/bin/mediaextractor libminijail: allowing syscall: socket W 236 /system/bin/mediaextractor libminijail: allowing syscall: writev W 236 /system/bin/mediaextractor libminijail: logging seccomp filter failures I 229 AudioFlinger loadHwModule() Loaded usb audio interface from USB audio HW HAL (audio) handle 18 I 229 r_submix adev_open(name=audio_hw_if) I 229 r_submix adev_init_check() I 229 AudioFlinger loadHwModule() Loaded r_submix audio interface from Wifi Display audio HAL (audio) handle 26 D 229 r_submix adev_open_input_stream(addr=0) D 229 r_submix submix_audio_device_create_pipe_l(addr=0, idx=9) D 229 r_submix now using address 0 for route 9 I 229 AudioFlinger AudioFlinger's thread 0xabc03c00 ready to run D 229 r_submix adev_close_input_stream() D 229 r_submix submix_audio_device_release_pipe_l(idx=9) addr=0 D 229 r_submix submix_audio_device_destroy_pipe_l(): pipe destroyed W 229 APM_AudioPolicyManager Output device 00000002 unreachable W 229 APM_AudioPolicyManager Input device 80000004 unreachable E 229 APM_AudioPolicyManager Default device 00000002 is unreachable E 229 APM_AudioPolicyManager Failed to open primary output I 229 RadioService RadioService I 229 RadioService onFirstRef E 229 RadioService couldn't load radio module radio.primary (No such file or directory) E 229 SoundTriggerHwService couldn't load sound trigger module sound_trigger.primary (No such file or directory) I 230 FslCameraHAL void CameraHAL::enumSensorSet() I 230 FslCameraHAL int32_t CameraHAL::matchDevNodes() I 230 FslCameraHAL getNodeName: dev path:/dev/video0 W 230 FslCameraHAL int32_t CameraHAL::getNodeName(const char *, char *, size_t) open dev path:/dev/video0 failed:Try again I 230 FslCameraHAL getNodeName: dev path:/dev/video1 W 230 cameraserver type=1400 audit(0.0:9): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:cameraserver:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 W 230 FslCameraHAL int32_t CameraHAL::getNodeName(const char *, char *, size_t) open dev path:/dev/video1 failed:Try again I 230 FslCameraHAL getNodeName: dev path:/dev/video16 W 230 FslCameraHAL int32_t CameraHAL::getNodeName(const char *, char *, size_t) open dev path:/dev/video16 failed:Permission denied I 230 FslCameraHAL getNodeName: dev path:/dev/video17 W 230 FslCameraHAL int32_t CameraHAL::getNodeName(const char *, char *, size_t) dev path:/dev/video17 is not capture I 230 FslCameraHAL matchPropertyName: index:0, ov5640_camera I 230 FslCameraHAL index:0, propName:ov5640_camera I 230 FslCameraHAL int32_t CameraHAL::matchNodeName(const char *, nodeSet *, int32_t) I 230 FslCameraHAL matchPropertyName: index:1, uvc I 230 FslCameraHAL index:1, propName:uvc I 230 FslCameraHAL int32_t CameraHAL::matchNodeName(const char *, nodeSet *, int32_t) I 230 FslCameraHAL camera number is 0 E 230 cutils-trace Error opening trace file: Permission denied (13) I 230 CameraService Loaded "Default Camera HAL" camera module I 230 ServiceManager Waiting for service media.camera.proxy... I 237 mediaserver ServiceManager: 0xb21193c0 I 235 mediaserver ServiceManager: 0xa8d193c0 W 237 BatteryNotifier batterystats service unavailable! D 221 libEGL loaded /system/lib/egl/libGLESv2_VIVANTE.so D 239 MagDaemon couldn't find 'FreescaleAccelerometer' input device D 239 MagDaemon inital sensor error I 221 imx6.gralloc open gpu gralloc module! I 221 imx6.gralloc fb_device_open dispid:0, fb:0 I 221 imx6.gralloc 32bpp setting of Framebuffer with RGBA8888 format! W 221 imx6.gralloc using (fd=12) W 221 imx6.gralloc id = DISP4 BG W 221 imx6.gralloc xres = 800 px W 221 imx6.gralloc yres = 1280 px W 221 imx6.gralloc xres_virtual = 800 px W 221 imx6.gralloc yres_virtual = 3840 px W 221 imx6.gralloc bpp = 32 W 221 imx6.gralloc r = 0:8 W 221 imx6.gralloc g = 8:8 W 221 imx6.gralloc b = 16:8 W 221 imx6.gralloc width = 127 mm (160.000000 dpi) W 221 imx6.gralloc height = 203 mm (160.157639 dpi) W 221 imx6.gralloc refresh rate = 59.54 Hz I 221 FslHwcomposer using fsl hwc!!! I 221 FslHwcomposer hwc_device_open,579 I 221 FslHwcomposer using fsl hwc! I 221 FslHwcomposer fb0 is ldb I 221 FslHwcomposer device I 221 FslHwcomposer fb1 is overlay device W 221 FslHwcomposer open /sys/class/graphics/fb2 failed W 221 FslHwcomposer open /sys/class/graphics/fb3 failed W 221 FslHwcomposer open /sys/class/graphics/fb4 failed W 221 FslHwcomposer open /sys/class/graphics/fb5 failed I 221 FslHwcomposer hwcomposer: open framebuffer fb0 I 221 imx6.gralloc fb_device_open dispid:0, fb:0 I 221 imx6.gralloc display already initialized... I 221 FslHwcomposer hwc_device_open,426 I 221 SurfaceFlinger Using composer version 1.3 E 221 FslHwcomposer unknown display attribute 6 W 221 SurfaceFlinger no suitable EGLConfig found, trying a simpler query I 221 SurfaceFlinger EGL information: I 221 SurfaceFlinger vendor : Android I 221 SurfaceFlinger version : 1.4 Android META-EGL I 221 SurfaceFlinger extensions: EGL_KHR_get_all_proc_addresses EGL_ANDROID_presentation_time EGL_KHR_swap_buffers_with_damage EGL_ANDROID_create_native_client_buffer EGL_ANDROID_front_buffer_auto_refresh EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_lock_surface EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_reusable_sync EGL_KHR_fence_sync EGL_KHR_create_context EGL_KHR_surfaceless_context EGL_EXT_create_context_robustness EGL_ANDROID_image_native_buffer EGL_KHR_wait_sync EGL_ANDROID_recordable EGL_EXT_buffer_age I 221 SurfaceFlinger Client API: OpenGL_ES I 221 SurfaceFlinger EGLSurface: 8-8-8-8, config=0x15 W 221 surfaceflinger type=1400 audit(0.0:10): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:surfaceflinger:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 221 SurfaceFlinger OpenGL ES informations: I 221 SurfaceFlinger vendor : Vivante Corporation I 221 SurfaceFlinger renderer : Vivante GC2000+ I 221 SurfaceFlinger version : OpenGL ES 3.1 V6.2.0.p2.79565 I 221 SurfaceFlinger extensions: GL_EXT_debug_marker GL_OES_vertex_type_10_10_10_2 GL_OES_vertex_half_float GL_OES_element_index_uint GL_OES_mapbuffer GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_rgb8_rgba8 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_depth24 GL_OES_depth32 GL_OES_packed_depth_stencil GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_fragment_precision_high GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_texture_stencil8 GL_OES_shader_image_atomic GL_OES_texture_storage_multisample_2d_array GL_OES_required_internalformat GL_OES_surfaceless_context GL_OES_texture_half_float GL_OES_texture_float GL_KHR_texture_compression_astc_ldr GL_KHR_blend_equation_advanced GL_KHR_debug GL_KHR_robustness GL_EXT_texture_type_2_10_10_10_REV GL_EXT_texture_filter_anisotropic GL_EXT_texture_format_BGRA8888 GL_EXT_read_format_bgra GL_EXT_multi_draw_arrays GL_EXT_frag_depth GL_EXT_discard I 221 SurfaceFlinger GL_MAX_TEXTURE_SIZE = 8192 I 221 SurfaceFlinger GL_MAX_VIEWPORT_DIMS = 8192 E 221 cutils-trace Error opening trace file: Permission denied (13) I 221 imx6.gralloc fb_device_open dispid:0, fb:0 I 221 imx6.gralloc display already initialized... I 221 v_egl FramebufferSurface: bufferCount=3 E 221 libEGL eglSetSwapRectangleANDROID:1984 error 300d (EGL_BAD_SURFACE) D 221 SurfaceFlinger shader cache generated - 24 shaders in 378.285675 ms D 221 SurfaceFlinger Set power mode=2, type=0 flinger=0xa8732000 W 306 bootanimation type=1400 audit(0.0:11): avc: denied { getattr } for path="/vendor" dev="rootfs" ino=7112 scontext=u:r:bootanim:s0 tcontext=u:object_r:rootfs:s0 tclass=lnk_file permissive=0 I 221 FslHwcomposer prepare: targetHandle is null W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 230 ServiceManager Waiting for service media.camera.proxy... W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 228 AndroidRuntime >>>>>> START com.android.internal.os.ZygoteInit uid 0 <<<<<< W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 228 AndroidRuntime CheckJNI is ON I 228 art option[0]=-Xzygote I 228 art option[1]=-Xcheck:jni I 228 art option[2]=-Xstacktracefile:/data/anr/traces.txt I 228 art option[3]=exit I 228 art option[4]=vfprintf I 228 art option[5]=sensitiveThread I 228 art option[6]=-verbose:gc I 228 art option[7]=-Xms8m I 228 art option[8]=-Xmx384m I 228 art option[9]=-XX:HeapGrowthLimit=128m I 228 art option[10]=-XX:HeapMinFree=512k I 228 art option[11]=-XX:HeapMaxFree=8m I 228 art option[12]=-XX:HeapTargetUtilization=0.75 I 228 art option[13]=-Xusejit:true I 228 art option[14]=-Xjitsaveprofilinginfo I 228 art option[15]=-agentlib:jdwp=transport=dt_android_adb,suspend=n,server=y I 228 art option[16]=-Xlockprofthreshold:500 I 228 art option[17]=-Ximage-compiler-option I 228 art option[18]=--runtime-arg I 228 art option[19]=-Ximage-compiler-option I 228 art option[20]=-Xms64m I 228 art option[21]=-Ximage-compiler-option I 228 art option[22]=--runtime-arg I 228 art option[23]=-Ximage-compiler-option I 228 art option[24]=-Xmx64m I 228 art option[25]=-Ximage-compiler-option I 228 art option[26]=--compiler-filter=verify-at-runtime I 228 art option[27]=-Ximage-compiler-option I 228 art option[28]=--image-classes=/system/etc/preloaded-classes I 228 art option[29]=-Ximage-compiler-option I 228 art option[30]=--compiled-classes=/system/etc/compiled-classes I 228 art option[31]=-Xcompiler-option I 228 art option[32]=--runtime-arg I 228 art option[33]=-Xcompiler-option I 228 art option[34]=-Xms64m I 228 art option[35]=-Xcompiler-option I 228 art option[36]=--runtime-arg I 228 art option[37]=-Xcompiler-option I 228 art option[38]=-Xmx512m I 228 art option[39]=-Ximage-compiler-option I 228 art option[40]=--instruction-set-variant=cortex-a9 I 228 art option[41]=-Xcompiler-option I 228 art option[42]=--instruction-set-variant=cortex-a9 I 228 art option[43]=-Ximage-compiler-option I 228 art option[44]=--instruction-set-features=default I 228 art option[45]=-Xcompiler-option I 228 art option[46]=--instruction-set-features=default I 228 art option[47]=-Duser.locale=en-US I 228 art option[48]=--cpu-abilist=armeabi-v7a,armeabi I 228 art option[49]=-Xfingerprint:Freescale/sabresd_6dq/sabresd_6dq:7.1.1/1.0.0-ga-rc10/20170227:eng/release-keys W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 228 art Pruning dalvik-cache since we are relocating an image and will need to recompile I 228 art RelocateImage: /system/bin/patchoat --input-image-location=/system/framework/boot.art --output-image-file=/data/dalvik-cache/arm/system@framework@boot.art --instruction-set=arm --base-offset-delta=16191488 W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 230 ServiceManager Waiting for service media.camera.proxy... W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 306 BootAnimation boot animation disabled W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 230 ServiceManager Waiting for service media.camera.proxy... W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) V 238 NatController runCmd(/system/bin/iptables -w -F natctrl_FORWARD) res=0 V 238 NatController runCmd(/system/bin/ip6tables -w -F natctrl_FORWARD) res=0 W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) V 238 NatController runCmd(/system/bin/iptables -w -A natctrl_FORWARD -j DROP) res=0 V 238 NatController runCmd(/system/bin/iptables -w -t nat -F natctrl_nat_POSTROUTING) res=0 V 238 NatController runCmd(/system/bin/ip6tables -w -t raw -F natctrl_raw_PREROUTING) res=0 V 238 NatController runCmd(/system/bin/iptables -w -F natctrl_tether_counters) res=1 V 238 NatController runCmd(/system/bin/ip6tables -w -F natctrl_tether_counters) res=1 W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) V 238 NatController runCmd(/system/bin/iptables -w -X natctrl_tether_counters) res=1 V 238 NatController runCmd(/system/bin/ip6tables -w -X natctrl_tether_counters) res=1 V 238 NatController runCmd(/system/bin/iptables -w -N natctrl_tether_counters) res=0 V 238 NatController runCmd(/system/bin/ip6tables -w -N natctrl_tether_counters) res=0 V 238 NatController runCmd(/system/bin/iptables -w -t mangle -A natctrl_mangle_FORWARD -p tcp --tcp-flags SYN SYN -j TCPMSS --clamp-mss-to-pmtu) res=0 W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 228 ICU No timezone override file found: /data/misc/zoneinfo/current/icu/icu_tzdata.dat W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 230 ServiceManager Waiting for service media.camera.proxy... W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) E 238 Netd cannot find interface dummy0 E 238 Netd Unable to create netlink socket: Protocol not supported W 238 Netd Unable to open qlog quota socket, check if xt_quota2 can send via UeventHandler D 238 MDnsDS MDnsSdListener::Hander starting up D 238 MDnsDS MDnsSdListener starting to monitor D 238 MDnsDS Going to poll with pollCount 1 E 228 memtrack Couldn't load memtrack module (No such file or directory) E 228 android.os.Debug failed to load memtrack module: -2 I 228 Radio-JNI register_android_hardware_Radio DONE W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 228 SamplingProfilerIntegration Profiling disabled. D 228 Zygote begin preload I 228 Zygote Installing ICU cache reference pinning... I 228 Zygote Preloading ICU data... W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 228 Zygote Preloading classes... W 228 Zygote Class not found for preloading: [Landroid.view.Display$ColorTransform; W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) E 228 Typeface Error mapping font file /system/fonts/DroidSansFallback.ttf W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 228 art Thread[1,tid=228,Native,Thread*=0xb0885400,peer=0x12c060d0,"main"] recursive attempt to load library "/system/lib/libmedia_jni.so" D 228 MtpDeviceJNI register_android_mtp_MtpDevice I 228 art Thread[1,tid=228,Native,Thread*=0xb0885400,peer=0x12c060d0,"main"] recursive attempt to load library "/system/lib/libmedia_jni.so" I 228 art Thread[1,tid=228,Native,Thread*=0xb0885400,peer=0x12c060d0,"main"] recursive attempt to load library "/system/lib/libmedia_jni.so" W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 228 Zygote Class not found for preloading: android.view.Display$ColorTransform W 228 Zygote Class not found for preloading: android.view.Display$ColorTransform$1 W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 228 System Loaded time zone names for "" in 108ms (104ms in ICU) I 228 System Loaded time zone names for "en_US" in 55ms (51ms in ICU) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 228 Zygote ...preloaded 4158 classes in 2435ms. I 228 art VMRuntime.preloadDexCaches starting W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 228 art VMRuntime.preloadDexCaches strings total=283754 before=39651 after=39651 I 228 art VMRuntime.preloadDexCaches types total=23583 before=7877 after=7904 I 228 art VMRuntime.preloadDexCaches fields total=112010 before=40900 after=41114 I 228 art VMRuntime.preloadDexCaches methods total=197529 before=82452 after=83012 I 228 art VMRuntime.preloadDexCaches finished I 228 Zygote Preloading resources... W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 228 Resources Preloaded drawable resource #0x108025c (android:drawable/dialog_background_material) that varies with configuration!! W 228 Resources Preloaded drawable resource #0x1080298 (android:drawable/editbox_dropdown_background_dark) that varies with configuration!! W 228 Resources Preloaded color resource #0x10600e2 (android:color/material_grey_800) that varies with configuration!! W 228 Resources Preloaded drawable resource #0x10802c9 (android:drawable/floating_popup_background_dark) that varies with configuration!! W 228 Resources Preloaded drawable resource #0x108030b (android:drawable/ic_clear_disabled) that varies with configuration!! W 228 Resources Preloaded drawable resource #0x1080310 (android:drawable/ic_clear_normal) that varies with configuration!! W 228 Resources Preloaded drawable resource #0x1080359 (android:drawable/ic_go) that varies with configuration!! W 228 Resources Preloaded drawable resource #0x1080038 (android:drawable/ic_menu_close_clear_cancel) that varies with configuration!! W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 228 Resources Preloaded drawable resource #0x1080045 (android:drawable/ic_menu_more) that varies with configuration!! W 228 Resources Preloaded drawable resource #0x10804e8 (android:drawable/menu_background_fill_parent_width) that varies with configuration!! W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 228 Resources Preloaded drawable resource #0x108077e (android:drawable/text_edit_paste_window) that varies with configuration!! W 228 Resources Preloaded drawable resource #0x1080096 (android:drawable/toast_frame) that varies with configuration!! I 228 Zygote ...preloaded 114 resources in 298ms. W 228 Resources Preloaded color resource #0x106010b (android:color/background_cache_hint_selector_material_dark) that varies with configuration!! W 228 Resources Preloaded color resource #0x1060110 (android:color/btn_default_material_dark) that varies with configuration!! I 228 Zygote ...preloaded 41 resources in 18ms. D 228 libEGL loaded /system/lib/egl/libEGL_VIVANTE.so D 228 libEGL loaded /system/lib/egl/libGLESv1_CM_VIVANTE.so W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 228 libEGL loaded /system/lib/egl/libGLESv2_VIVANTE.so W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 228 Zygote Preloading shared libraries... I 228 Zygote Uninstalled ICU cache reference pinning... I 228 Zygote Installed AndroidKeyStoreProvider in 11ms. W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 228 Zygote Warmed up JCA providers in 75ms. D 228 Zygote end preload I 228 art Starting a blocking GC Explicit I 228 art Explicit concurrent mark sweep GC freed 2959(164KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 2MB/3MB, paused 348us total 20.651ms I 228 art Starting a blocking GC Explicit W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 228 art Explicit concurrent mark sweep GC freed 5(128B) AllocSpace objects, 0(0B) LOS objects, 39% free, 2MB/3MB, paused 342us total 23.172ms I 228 art Starting a blocking GC HeapTrim I 228 art Starting a blocking GC Background W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 228 Zygote System server process 486 has been created I 228 Zygote Accepting command socket connections I 486 InstallerConnection connecting... I 232 new connection W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 497 dex2oat type=1400 audit(0.0:12): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 497 dex2oat /system/bin/dex2oat --compiler-filter=speed E 497 cutils-trace Error opening trace file: Permission denied (13) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 497 dex2oat Compilation of void com.android.server.BluetoothManagerService$BluetoothHandler.handleMessage(android.os.Message) took 102.530ms W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 497 dex2oat Compilation of void com.android.server.SystemServer.startOtherServices() took 440.134ms W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 497 dex2oat Compilation of void com.android.server.am.ActivityManagerService$MainHandler.handleMessage(android.os.Message) took 162.764ms W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 497 dex2oat Compilation of android.app.IActivityManager$ContentProviderHolder com.android.server.am.ActivityManagerService.getContentProviderImpl(android.app.IApplicationThread, java.lang.String, android.os.IBinder, boolean, int) took 119.458ms W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 497 dex2oat Compilation of int com.android.server.am.ActivityManagerService.broadcastIntentLocked(com.android.server.am.ProcessRecord, java.lang.String, android.content.Intent, java.lang.String, android.content.IIntentReceiver, int, java.lang.String, android.os.Bundle, java.lang.String[], int, android.os.Bundle, boolean, boolean, int, int, int) took 178.243ms W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 497 dex2oat Compilation of void com.android.server.am.BroadcastQueue.processNextBroadcast(boolean) took 242.035ms W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 497 dex2oat Compilation of void com.android.server.am.ProcessStatsService.dumpInner(java.io.FileDescriptor, java.io.PrintWriter, java.lang.String[]) took 133.502ms W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 497 dex2oat Compilation of void com.android.server.am.ActivityManagerService.dumpApplicationMemoryUsage(java.io.FileDescriptor, java.io.PrintWriter, java.lang.String, java.lang.String[], boolean, java.io.PrintWriter) took 265.825ms W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 497 dex2oat Compilation of void com.android.server.am.ActivityManagerService.dumpProcessesLocked(java.io.FileDescriptor, java.io.PrintWriter, java.lang.String[], int, boolean, java.lang.String) took 149.495ms W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 497 dex2oat Compilation of void com.android.server.notification.NotificationRecord.dump(java.io.PrintWriter, java.lang.String, android.content.Context, boolean) took 102.756ms W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 497 dex2oat Compilation of void com.android.server.pm.DefaultPermissionGrantPolicy.grantDefaultSystemHandlerPermissions(int) took 251.654ms W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 497 dex2oat Compilation of void com.android.server.pm.PackageManagerService.<init>(android.content.Context, com.android.server.pm.Installer, boolean, boolean) took 274.361ms W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 497 dex2oat Compilation of void com.android.server.pm.Settings.readPackageLPw(org.xmlpull.v1.XmlPullParser) took 103.315ms W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 497 dex2oat Compilation of void com.android.server.pm.Settings.dumpPackageLPr(java.io.PrintWriter, java.lang.String, java.lang.String, android.util.ArraySet, com.android.server.pm.PackageSetting, java.text.SimpleDateFormat, java.util.Date, java.util.List, boolean) took 105.865ms W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 497 dex2oat Compilation of boolean com.android.server.pm.Settings.readLPw(java.util.List) took 102.837ms W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 497 dex2oat Compilation of void com.android.server.pm.PackageManagerService.installPackageLI(com.android.server.pm.PackageManagerService$InstallArgs, com.android.server.pm.PackageManagerService$PackageInstalledInfo) took 134.236ms W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 497 dex2oat Compilation of void com.android.server.power.PowerManagerService.dumpInternal(java.io.PrintWriter) took 156.211ms W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 497 dex2oat Compilation of android.content.pm.PackageParser$Package com.android.server.pm.PackageManagerService.scanPackageDirtyLI(android.content.pm.PackageParser$Package, int, int, long, android.os.UserHandle) took 529.342ms W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 497 dex2oat Compilation of void com.android.server.pm.PackageManagerService.dump(java.io.FileDescriptor, java.io.PrintWriter, java.lang.String[]) took 508.211ms W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 497 dex2oat Compilation of void com.android.server.wm.WindowManagerService$H.handleMessage(android.os.Message) took 113.744ms W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 497 dex2oat Compilation of int com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.view.InputChannel) took 151.344ms W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 497 dex2oat dex2oat took 18.828s (threads: 4) arena alloc=14MB (15449792B) java alloc=2MB (2361624B) native alloc=24MB (25822680B) free=17MB (18217512B) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 502 dex2oat type=1400 audit(0.0:13): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 502 dex2oat /system/bin/dex2oat --compiler-filter=speed E 502 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 502 dex2oat dex2oat took 1.249s (threads: 4) arena alloc=1027KB (1052216B) java alloc=173KB (177160B) native alloc=1788KB (1831608B) free=2MB (2886984B) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 508 dex2oat type=1400 audit(0.0:14): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 508 dex2oat /system/bin/dex2oat --compiler-filter=speed E 508 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 508 dex2oat Compilation of void com.android.server.wifi.WifiMetrics.dump(java.io.FileDescriptor, java.io.PrintWriter, java.lang.String[]) took 109.194ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 508 dex2oat Compilation of void com.android.server.wifi.WifiNetworkHistory$1.onWriteCalled(java.io.DataOutputStream) took 134.846ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 508 dex2oat Compilation of android.net.wifi.WifiConfiguration com.android.server.wifi.WifiQualifiedNetworkSelector.selectQualifiedNetwork(boolean, boolean, java.util.List, boolean, boolean, boolean, boolean) took 102.984ms W 508 dex2oat Compilation of boolean com.android.server.wifi.WifiStateMachine$ConnectModeState.processMessage(android.os.Message) took 152.738ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 508 dex2oat dex2oat took 3.553s (threads: 4) arena alloc=6MB (7074992B) java alloc=462KB (473920B) native alloc=4MB (4315144B) free=9MB (9840632B) I 486 system InstallerConnection disconnecting... E 232 /system/bin/installd eof E 232 /system/bin/installd failed to read size I 232 /system/bin/installd closing connection W 486 system SystemServer System clock is before 1970; setting to 1970. I 486 system SystemServer Entered the Android system server! W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system SystemServiceManager Starting com.android.server.pm.Installer I 486 system Installer Waiting for installd to be ready. I 486 system InstallerConnection connecting... I 232 /system/bin/installd new connection I 486 system SystemServiceManager Starting com.android.server.am.ActivityManagerService$Lifecycle I 486 system ActivityManager Memory class: 128 I 486 system ServiceThread Enabled StrictMode logging for ActivityManager looper. I 486 system ServiceThread Enabled StrictMode logging for android.ui looper. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system BatteryStatsImpl Reading daily items from /data/system/batterystats-daily.xml W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system AppOps No existing app ops /data/system/appops.xml; starting empty W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system IntentFirewall Read new rules (A:0 B:0 S:0) I 486 system ServiceThread Enabled StrictMode logging for android.display looper. D 486 system AppOps AppOpsService published I 486 system SystemServiceManager Starting com.android.server.power.PowerManagerService I 486 system ServiceThread Enabled StrictMode logging for PowerManagerService looper. E 486 system SWITCHPROFILE setprop: sys.interactive = active W 486 system libsuspend Error writing 'on' to /sys/power/state: Invalid argument I 486 system libsuspend Selected wakeup count I 486 system SWITCHPROFILE Switchprofile thread received GOV_INTERACTIVE from Power HAL E 486 system SWITCHPROFILE setprop: sys.interactive = active E 486 system SWITCHPROFILE Could not open cpu gov:/sys/devices/system/cpu/cpufreq/interactive/input_boost I 486 system SystemServiceManager Starting com.android.server.lights.LightsService I 486 system lights max backlight file is /sys/class/backlight/pwm-backlight/max_brightness I 486 system lights backlight brightness file is /sys/class/backlight/pwm-backlight/brightness I 486 system SystemServiceManager Starting com.android.server.display.DisplayManagerService I 486 system SystemServiceManager Starting phase 100 I 486 system DisplayManagerService Display device added: DisplayDeviceInfo{"Built-in Screen": uniqueId="local:0", 1280 x 800, modeId 1, defaultModeId 1, supportedModes [{id=1, width=1280, height=800, fps=59.0}], colorMode 0, supportedColorModes [0], HdrCapabilities android.view.Display$HdrCapabilities@a69d6308, density 160, 160.0 x 160.157 dpi, appVsyncOff 1000000, presDeadline 16949152, touch INTERNAL, rotation 0, type BUILT_IN, state UNKNOWN, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS} D 221 /system/bin/surfaceflinger SurfaceFlinger Set power mode=2, type=0 flinger=0xa8732000 D 221 /system/bin/surfaceflinger SurfaceFlinger Screen type=0 is already mode=2 I 486 system SystemServer StartPackageManagerService I 486 system DisplayManagerService Display device changed state: "Built-in Screen", ON W 486 system FileUtils Failed to chmod(/data/system/packages.list): android.system.ErrnoException: chmod failed: ENOENT (No such file or directory) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system SystemConfig No directory /system/etc/sysconfig, skipping D 486 system SELinuxMMAC Using policy file /system/etc/security/mac_permissions.xml I 486 system PackageManager No settings file; creating initial state W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 530 dex2oat type=1400 audit(0.0:15): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 530 dex2oat /system/bin/dex2oat --compiler-filter=speed E 530 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 530 dex2oat dex2oat took 273.275ms (threads: 4) arena alloc=347KB (355856B) java alloc=157KB (161480B) native alloc=1163KB (1191480B) free=1908KB (1954248B) W 536 dex2oat type=1400 audit(0.0:16): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 536 dex2oat /system/bin/dex2oat --compiler-filter=speed E 536 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 536 dex2oat dex2oat took 238.845ms (threads: 4) arena alloc=254KB (260456B) java alloc=51KB (53128B) native alloc=974KB (997704B) free=1073KB (1099448B) W 541 dex2oat type=1400 audit(0.0:17): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 541 dex2oat /system/bin/dex2oat --compiler-filter=speed E 541 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 541 dex2oat dex2oat took 349.684ms (threads: 4) arena alloc=1929KB (1976312B) java alloc=115KB (118616B) native alloc=1114KB (1141600B) free=3MB (4101280B) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 546 dex2oat type=1400 audit(0.0:18): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 546 dex2oat /system/bin/dex2oat --compiler-filter=speed E 546 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 546 dex2oat dex2oat took 215.087ms (threads: 4) arena alloc=21KB (22288B) java alloc=39KB (40680B) native alloc=781KB (800560B) free=1266KB (1296592B) W 551 dex2oat type=1400 audit(0.0:19): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 551 dex2oat /system/bin/dex2oat --compiler-filter=speed E 551 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 551 dex2oat dex2oat took 580.273ms (threads: 4) arena alloc=1211KB (1240768B) java alloc=267KB (273704B) native alloc=1553KB (1590696B) free=3MB (3652184B) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) E 486 system art DexFile_getDexOptNeeded file '/system/framework/org.apache.http.legacy.jar' does not exist W 486 system PackageManager Library not found: /system/framework/org.apache.http.legacy.jar W 556 dex2oat type=1400 audit(0.0:20): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 556 dex2oat /system/bin/dex2oat --compiler-filter=speed E 556 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 556 dex2oat dex2oat took 220.816ms (threads: 4) arena alloc=300KB (308168B) java alloc=80KB (82832B) native alloc=977KB (1001016B) free=2MB (2669000B) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 561 dex2oat type=1400 audit(0.0:21): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 561 dex2oat /system/bin/dex2oat --compiler-filter=speed E 561 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 561 dex2oat dex2oat took 218.184ms (threads: 4) arena alloc=84KB (86488B) java alloc=51KB (53192B) native alloc=925KB (948176B) free=1634KB (1673264B) D 486 system PackageManager No files in app dir /vendor/overlay W 486 system PackageManager Failed to parse /system/framework/arm: Missing base APK in /system/framework/arm W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/framework/framework-res.apk changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/priv-app/BackupRestoreConfirmation changed; collecting certs I 486 system PackageManager /system/priv-app/BleClient changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/priv-app/BleServerEmulator changed; collecting certs I 486 system PackageManager /system/priv-app/BlockedNumberProvider changed; collecting certs I 486 system PackageManager New shared user android.uid.shared: id=10003 I 486 system PackageManager /system/priv-app/CalendarProvider changed; collecting certs I 486 system PackageManager New shared user android.uid.calendar: id=10004 I 486 system PackageManager /system/priv-app/CallLogBackup changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/priv-app/CarrierConfig changed; collecting certs I 486 system PackageManager /system/priv-app/CellBroadcastReceiver changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system PackageParser No actions in intent filter at /system/priv-app/Contacts/Contacts.apk Binary XML file line #409 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/priv-app/Contacts changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/priv-app/ContactsProvider changed; collecting certs I 486 system PackageManager /system/priv-app/CtsShimPrivPrebuilt changed; collecting certs I 486 system PackageManager /system/priv-app/DefaultContainerService changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system PackageParser No actions in intent filter at /system/priv-app/Dialer/Dialer.apk Binary XML file line #186 I 486 system PackageManager /system/priv-app/Dialer changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/priv-app/DocumentsUI changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/priv-app/DownloadProvider changed; collecting certs I 486 system PackageManager New shared user android.media: id=10012 W 486 system PackageManager Permission android.permission.DOWNLOAD_WITHOUT_NOTIFICATION from package com.android.providers.downloads in an unknown group android.permission-group.NETWORK W 486 system art Suspending all threads took: 22.232ms I 486 system art Background partial concurrent mark sweep GC freed 9866(786KB) AllocSpace objects, 14(864KB) LOS objects, 33% free, 2MB/3MB, paused 23.995ms total 55.415ms I 486 system PackageManager /system/priv-app/EmergencyInfo changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager New shared user com.android.emergency.uid: id=10013 I 486 system PackageManager /system/priv-app/ExtServices changed; collecting certs I 486 system PackageManager /system/priv-app/ExternalStorageProvider changed; collecting certs I 486 system PackageManager /system/priv-app/FusedLocation changed; collecting certs I 486 system PackageManager /system/priv-app/InputDevices changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/priv-app/Launcher2 changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system PackageManager Permission com.android.launcher.permission.PRELOAD_WORKSPACE from package com.android.launcher in an unknown group android.permission-group.SYSTEM_TOOLS W 486 system PackageManager Permission com.android.launcher.permission.INSTALL_SHORTCUT from package com.android.launcher in an unknown group android.permission-group.SYSTEM_TOOLS W 486 system PackageManager Permission com.android.launcher.permission.UNINSTALL_SHORTCUT from package com.android.launcher in an unknown group android.permission-group.SYSTEM_TOOLS W 486 system PackageManager Permission com.android.launcher.permission.READ_SETTINGS from package com.android.launcher in an unknown group android.permission-group.SYSTEM_TOOLS W 486 system PackageManager Permission com.android.launcher.permission.WRITE_SETTINGS from package com.android.launcher in an unknown group android.permission-group.SYSTEM_TOOLS I 486 system PackageManager /system/priv-app/ManagedProvisioning changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/priv-app/MediaProvider changed; collecting certs I 486 system PackageManager /system/priv-app/MmsService changed; collecting certs I 486 system PackageManager /system/priv-app/MtpDocumentsProvider changed; collecting certs I 486 system PackageManager /system/priv-app/MusicFX changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/priv-app/OneTimeInitializer changed; collecting certs I 486 system PackageManager /system/priv-app/PackageInstaller changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/priv-app/Provision changed; collecting certs I 486 system PackageManager /system/priv-app/ProxyHandler changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system PackageParser Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.USE_CREDENTIALS in package: com.android.settings at: Binary XML file line #53 W 486 system PackageParser Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.READ_SYNC_SETTINGS in package: com.android.settings at: Binary XML file line #58 W 486 system PackageParser Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.WRITE_SYNC_SETTINGS in package: com.android.settings at: Binary XML file line #59 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/priv-app/Settings changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/priv-app/SettingsProvider changed; collecting certs I 486 system PackageManager /system/priv-app/SharedStorageBackup changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system PackageParser Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.INSTALL_GRANT_RUNTIME_PERMISSIONS in package: com.android.shell at: Binary XML file line #103 I 486 system PackageManager /system/priv-app/Shell changed; collecting certs I 486 system PackageManager /system/priv-app/StatementService changed; collecting certs I 486 system PackageManager /system/priv-app/StorageManager changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system PackageParser Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.CONFIGURE_WIFI_DISPLAY in package: com.android.systemui at: Binary XML file line #123 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/priv-app/SystemUI changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager New shared user android.uid.systemui: id=10026 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/priv-app/TeleService changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/priv-app/Telecom changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/priv-app/TelephonyProvider changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/priv-app/VpnDialogs changed; collecting certs I 486 system PackageManager /system/priv-app/WallpaperCropper changed; collecting certs I 486 system PackageManager /system/app/A2dpSinkApp changed; collecting certs I 486 system PackageManager /system/app/BasicDreams changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system PackageParser Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.READ_CONTACTS in package: com.android.bluetooth at: Binary XML file line #61 W 486 system PackageParser No actions in intent filter at /system/app/Bluetooth/Bluetooth.apk Binary XML file line #223 I 486 system PackageManager /system/app/Bluetooth changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/app/BluetoothMidiService changed; collecting certs I 486 system PackageManager /system/app/BookmarkProvider changed; collecting certs I 486 system PackageManager /system/app/Browser2 changed; collecting certs I 486 system PackageManager /system/app/CactusPlayer changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/app/Calendar changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system PackageManager Non-privileged app; cap priority to 0; package: com.android.calendar activity: com.android.calendar.GoogleCalendarUriIntentFilter origPrio: 50 I 486 system PackageManager /system/app/Camera2 changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/app/CaptivePortalLogin changed; collecting certs I 486 system PackageManager /system/app/CertInstaller changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/app/CtsShimPrebuilt changed; collecting certs W 486 system PackageManager Non-privileged app; cap priority to 0; package: com.android.cts.ctsshim activity: com.android.cts.ctsshim.InstallPriority origPrio: 100 W 486 system PackageManager Non-privileged app; cap priority to 0; package: com.android.cts.ctsshim activity: com.android.cts.ctsshim.InstallPriority origPrio: 100 W 486 system PackageManager Non-privileged app; cap priority to 0; package: com.android.cts.ctsshim activity: com.android.cts.ctsshim.InstallPriority origPrio: 100 W 486 system PackageManager Non-privileged app; cap priority to 0; package: com.android.cts.ctsshim activity: com.android.cts.ctsshim.InstallPriority origPrio: 100 W 486 system PackageManager Non-privileged app; cap priority to 0; package: com.android.cts.ctsshim activity: com.android.cts.ctsshim.InstallPriority origPrio: 100 I 486 system PackageManager /system/app/CubeLiveWallpapers changed; collecting certs I 486 system PackageManager /system/app/DeskClock changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/app/DownloadProviderUi changed; collecting certs I 486 system PackageManager /system/app/EasterEgg changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system PackageParser Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.WRITE_CONTACTS in package: com.android.email at: Binary XML file line #40 I 486 system PackageManager /system/app/Email changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/app/ExactCalculator changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/app/ExtShared changed; collecting certs I 486 system PackageManager /system/app/FSLOta changed; collecting certs W 486 system PackageParser Unknown element under <application>: permission at /system/app/Gallery2/Gallery2.apk Binary XML file line #253 W 486 system PackageParser Unknown element under <application>: permission at /system/app/Gallery2/Gallery2.apk Binary XML file line #256 I 486 system PackageManager /system/app/Gallery2 changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/app/HTMLViewer changed; collecting certs I 486 system PackageManager /system/app/KeyChain changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/app/LatinIME changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/app/LiveWallpapersPicker changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/app/Music changed; collecting certs I 486 system PackageManager /system/app/PacProcessor changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/app/PicoTts changed; collecting certs I 486 system PackageManager /system/app/PrintRecommendationService changed; collecting certs I 486 system PackageManager /system/app/PrintSpooler changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/app/QuickSearchBox changed; collecting certs I 486 system PackageManager /system/app/SoundRecorder changed; collecting certs I 486 system PackageManager /system/app/UserDictionaryProvider changed; collecting certs I 486 system PackageManager /system/app/WallpaperBackup changed; collecting certs I 486 system PackageManager /system/app/WfdSink changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager /system/app/ethernet changed; collecting certs I 486 system PackageManager /system/app/webview changed; collecting certs W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system PackageManager No files in app dir /system/vendor/app D 486 system PackageManager No files in app dir /oem/app D 486 system PackageManager No files in app dir /data/app D 486 system PackageManager No files in app dir /data/app-private D 486 system PackageManager No files in app dir /data/app-ephemeral W 486 system PackageManager Protected action; cap priority to 0; package: com.android.cts.priv.ctsshim activity: com.android.cts.priv.ctsshim.InstallPriority origPrio: 100 W 486 system PackageManager Protected action; cap priority to 0; package: com.android.cts.priv.ctsshim activity: com.android.cts.priv.ctsshim.InstallPriority origPrio: 100 W 486 system PackageManager Protected action; cap priority to 0; package: com.android.cts.priv.ctsshim activity: com.android.cts.priv.ctsshim.InstallPriority origPrio: 100 W 486 system PackageManager Protected action; cap priority to 0; package: com.android.cts.priv.ctsshim activity: com.android.cts.priv.ctsshim.InstallPriority origPrio: 100 W 486 system PackageManager Package com.android.gallery3d desires unavailable shared library com.google.android.media.effects; ignoring! W 486 system PackageManager Package com.android.gallery3d desires unavailable shared library com.google.android.media.effects; ignoring! I 486 system PackageManager Adjusting ABI for com.android.providers.media to armeabi-v7a (requirer=com.android.mtp, scannedPackage=null) I 486 system PackageManager Adjusting ABI for com.android.providers.downloads.ui to armeabi-v7a (requirer=com.android.mtp, scannedPackage=null) I 486 system PackageManager Adjusting ABI for com.android.providers.downloads to armeabi-v7a (requirer=com.android.mtp, scannedPackage=null) I 486 system PackageManager Adjusting ABI for com.fsl.android.ota to armeabi-v7a (requirer=android, scannedPackage=null) I 486 system PackageManager Adjusting ABI for com.freescale.wfdsink to armeabi-v7a (requirer=android, scannedPackage=null) I 486 system PackageManager Adjusting ABI for com.android.location.fused to armeabi-v7a (requirer=android, scannedPackage=null) I 486 system PackageManager Adjusting ABI for com.android.providers.settings to armeabi-v7a (requirer=android, scannedPackage=null) I 486 system PackageManager Adjusting ABI for com.android.inputdevices to armeabi-v7a (requirer=android, scannedPackage=null) I 486 system PackageManager Adjusting ABI for com.android.keychain to armeabi-v7a (requirer=android, scannedPackage=null) I 486 system PackageManager Adjusting ABI for com.android.settings to armeabi-v7a (requirer=android, scannedPackage=null) I 486 system PackageManager Adjusting ABI for com.android.wallpaperbackup to armeabi-v7a (requirer=android, scannedPackage=null) I 486 system PackageManager Adjusting ABI for com.android.server.telecom to armeabi-v7a (requirer=android, scannedPackage=null) I 486 system PackageManager Adjusting ABI for com.fsl.ethernet to armeabi-v7a (requirer=android, scannedPackage=null) I 486 system PackageManager Adjusting ABI for com.freescale.a2dpsinkapp to armeabi-v7a (requirer=android, scannedPackage=null) I 486 system PackageManager Time to scan packages: 12.287 seconds W 486 system PackageManager Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar W 486 system PackageManager Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar W 486 system PackageManager Not granting permission android.permission.GLOBAL_SEARCH to package com.android.quicksearchbox (protectionLevel=18 flags=0x3808be45) W 486 system PackageManager Not granting permission android.permission.BIND_WALLPAPER to package com.android.camera2 (protectionLevel=18 flags=0x3058bc45) W 486 system PackageManager Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar W 486 system PackageManager Not granting permission android.permission.WRITE_MEDIA_STORAGE to package com.android.gallery3d (protectionLevel=18 flags=0x3858bc45) W 486 system PackageManager Unknown permission com.google.android.permission.INSTALL_WEARABLE_PACKAGES in package com.android.packageinstaller W 486 system PackageManager Not granting permission android.permission.DELETE_PACKAGES to package com.svox.pico (protectionLevel=18 flags=0x3808be45) W 486 system PackageManager Unknown permission android.permission.RUN_INSTRUMENTATION in package org.chromium.webview_shell W 486 system PackageManager Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings W 486 system PackageManager Unknown permission com.android.smspush.WAPPUSH_MANAGER_BIND in package com.android.phone W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system PackageManager Unknown permission android.permission.ACCESS_ALL_EXTERNAL_STORAGE in package com.freescale.wfdsink W 486 system PackageManager Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.bluetooth V 486 system PackageManager reconcileAppsData for null u0 0x3 I 232 /system/bin/installd SELinux SELinux: Loaded file_contexts contexts from /file_contexts.bin. D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.cts.priv.ctsshim; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.cts.priv.ctsshim; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.freescale.bleserver; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.freescale.bleserver; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.example.android.livecubes; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.example.android.livecubes; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:radio_data_file:s0 at /data/data/com.android.providers.telephony; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:radio_data_file:s0 at /data/user_de/0/com.android.providers.telephony; running recursive restorecon W 232 /system/bin/installd installd Requested default storage /data/user_de/0/com.android.providers.telephony is not active; migrating from /data/data/com.android.providers.telephony D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:radio_data_file:s0 at /data/data/com.android.providers.telephony; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/data/com.fsl.ethernet; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/user_de/0/com.fsl.ethernet; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.providers.calendar; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.providers.calendar; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.providers.media; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.providers.media; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.wallpapercropper; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.wallpapercropper; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.launcher; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.launcher; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.documentsui; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.documentsui; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.externalstorage; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.externalstorage; running recursive restorecon W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.htmlviewer; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.htmlviewer; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.quicksearchbox; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.quicksearchbox; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:radio_data_file:s0 at /data/data/com.android.mms.service; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:radio_data_file:s0 at /data/user_de/0/com.android.mms.service; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.providers.downloads; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.providers.downloads; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.soundrecorder; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.soundrecorder; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.defcontainer; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.defcontainer; running recursive restorecon W 232 /system/bin/installd installd Requested default storage /data/user_de/0/com.android.defcontainer is not active; migrating from /data/data/com.android.defcontainer D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.defcontainer; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.providers.downloads.ui; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.providers.downloads.ui; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.pacprocessor; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.pacprocessor; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.certinstaller; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.certinstaller; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.carrierconfig; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.carrierconfig; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/data/android; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/user_de/0/android; running recursive restorecon W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 232 /system/bin/installd installd Requested default storage /data/user_de/0/android is not active; migrating from /data/data/android D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/data/android; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.contacts; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.contacts; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.camera2; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.camera2; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.egg; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.egg; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.mtp; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.mtp; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.backupconfirm; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.backupconfirm; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.provision; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.provision; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.statementservice; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.statementservice; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.calendar; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.calendar; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/data/com.android.providers.settings; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/user_de/0/com.android.providers.settings; running recursive restorecon W 232 /system/bin/installd installd Requested default storage /data/user_de/0/com.android.providers.settings is not active; migrating from /data/data/com.android.providers.settings D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/data/com.android.providers.settings; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.sharedstoragebackup; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.sharedstoragebackup; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.printspooler; running recursive restorecon W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.printspooler; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.dreams.basic; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.dreams.basic; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.webview; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.webview; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/data/com.android.inputdevices; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/user_de/0/com.android.inputdevices; running recursive restorecon W 232 /system/bin/installd installd Requested default storage /data/user_de/0/com.android.inputdevices is not active; migrating from /data/data/com.android.inputdevices D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/data/com.android.inputdevices; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.musicfx; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.musicfx; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.cellbroadcastreceiver; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.cellbroadcastreceiver; running recursive restorecon W 232 /system/bin/installd installd Requested default storage /data/user_de/0/com.android.cellbroadcastreceiver is not active; migrating from /data/data/com.android.cellbroadcastreceiver D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.cellbroadcastreceiver; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/android.ext.shared; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/android.ext.shared; running recursive restorecon W 232 /system/bin/installd installd Requested default storage /data/user_de/0/android.ext.shared is not active; migrating from /data/data/android.ext.shared D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/android.ext.shared; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.onetimeinitializer; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.onetimeinitializer; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/data/com.android.server.telecom; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/user_de/0/com.android.server.telecom; running recursive restorecon W 232 /system/bin/installd installd Requested default storage /data/user_de/0/com.android.server.telecom is not active; migrating from /data/data/com.android.server.telecom D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/data/com.android.server.telecom; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/data/com.android.keychain; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/user_de/0/com.android.keychain; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.printservice.recommendation; running recursive restorecon W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.printservice.recommendation; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.dialer; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.dialer; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.gallery3d; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.gallery3d; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/android.ext.services; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/android.ext.services; running recursive restorecon W 232 /system/bin/installd installd Requested default storage /data/user_de/0/android.ext.services is not active; migrating from /data/data/android.ext.services D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/android.ext.services; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.calllogbackup; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.calllogbackup; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.packageinstaller; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.packageinstaller; running recursive restorecon W 232 /system/bin/installd installd Requested default storage /data/user_de/0/com.android.packageinstaller is not active; migrating from /data/data/com.android.packageinstaller D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.packageinstaller; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.svox.pico; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.svox.pico; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.proxyhandler; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.proxyhandler; running recursive restorecon W 232 /system/bin/installd installd Requested default storage /data/user_de/0/com.android.proxyhandler is not active; migrating from /data/data/com.android.proxyhandler D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.proxyhandler; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.inputmethod.latin; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.inputmethod.latin; running recursive restorecon W 232 /system/bin/installd installd Requested default storage /data/user_de/0/com.android.inputmethod.latin is not active; migrating from /data/data/com.android.inputmethod.latin D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.inputmethod.latin; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/org.chromium.webview_shell; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/org.chromium.webview_shell; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/data/com.fsl.android.ota; running recursive restorecon W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/user_de/0/com.fsl.android.ota; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.managedprovisioning; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.managedprovisioning; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.wallpaper.livepicker; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.wallpaper.livepicker; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.storagemanager; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.storagemanager; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.bookmarkprovider; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.bookmarkprovider; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/data/com.android.settings; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/user_de/0/com.android.settings; running recursive restorecon W 232 /system/bin/installd installd Requested default storage /data/user_de/0/com.android.settings is not active; migrating from /data/data/com.android.settings D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/data/com.android.settings; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/data/com.freescale.a2dpsinkapp; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/user_de/0/com.freescale.a2dpsinkapp; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.calculator2; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.calculator2; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.freescale.cactusplayer; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.freescale.cactusplayer; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.cts.ctsshim; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.cts.ctsshim; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.vpndialogs; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.vpndialogs; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.email; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.email; running recursive restorecon W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.music; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.music; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:radio_data_file:s0 at /data/data/com.android.phone; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:radio_data_file:s0 at /data/user_de/0/com.android.phone; running recursive restorecon W 232 /system/bin/installd installd Requested default storage /data/user_de/0/com.android.phone is not active; migrating from /data/data/com.android.phone D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:radio_data_file:s0 at /data/data/com.android.phone; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:shell_data_file:s0 at /data/data/com.android.shell; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:shell_data_file:s0 at /data/user_de/0/com.android.shell; running recursive restorecon W 232 /system/bin/installd installd Requested default storage /data/user_de/0/com.android.shell is not active; migrating from /data/data/com.android.shell D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:shell_data_file:s0 at /data/data/com.android.shell; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/data/com.android.wallpaperbackup; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/user_de/0/com.android.wallpaperbackup; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.providers.blockednumber; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.providers.blockednumber; running recursive restorecon W 232 /system/bin/installd installd Requested default storage /data/user_de/0/com.android.providers.blockednumber is not active; migrating from /data/data/com.android.providers.blockednumber D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.providers.blockednumber; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.providers.userdictionary; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.providers.userdictionary; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.emergency; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.emergency; running recursive restorecon W 232 /system/bin/installd installd Requested default storage /data/user_de/0/com.android.emergency is not active; migrating from /data/data/com.android.emergency D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.emergency; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/data/com.android.location.fused; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/user_de/0/com.android.location.fused; running recursive restorecon W 232 /system/bin/installd installd Requested default storage /data/user_de/0/com.android.location.fused is not active; migrating from /data/data/com.android.location.fused D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/data/com.android.location.fused; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.deskclock; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.deskclock; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.systemui; running recursive restorecon W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.systemui; running recursive restorecon W 232 /system/bin/installd installd Requested default storage /data/user_de/0/com.android.systemui is not active; migrating from /data/data/com.android.systemui D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.systemui; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/data/com.freescale.wfdsink; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:system_app_data_file:s0 at /data/user_de/0/com.freescale.wfdsink; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.bluetoothmidiservice; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.bluetoothmidiservice; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.freescale.bleclient; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.freescale.bleclient; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:bluetooth_data_file:s0 at /data/data/com.android.bluetooth; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:bluetooth_data_file:s0 at /data/user_de/0/com.android.bluetooth; running recursive restorecon W 232 /system/bin/installd installd Requested default storage /data/user_de/0/com.android.bluetooth is not active; migrating from /data/data/com.android.bluetooth D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:bluetooth_data_file:s0 at /data/data/com.android.bluetooth; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.providers.contacts; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.providers.contacts; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/data/com.android.captiveportallogin; running recursive restorecon D 232 /system/bin/installd installd Detected label change from u:object_r:system_data_file:s0 to u:object_r:app_data_file:s0:c512,c768 at /data/user_de/0/com.android.captiveportallogin; running recursive restorecon V 486 system PackageManager reconcileAppsData finished 80 packages W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/TelephonyProvider/TelephonyProvider.apk pkg=com.android.providers.telephony isa=arm vmSafeMode=false debuggable=false target-filter=speed oatDir = null sharedLibraries=null W 566 dex2oat type=1400 audit(0.0:22): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 566 dex2oat /system/bin/dex2oat --compiler-filter=speed E 566 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 566 dex2oat dex2oat took 833.819ms (threads: 4) arena alloc=4MB (5228488B) java alloc=225KB (231128B) native alloc=1673KB (1713864B) free=7MB (8247608B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/MmsService/MmsService.apk pkg=com.android.mms.service isa=arm vmSafeMode=false debuggable=false target-filter=speed oatDir = null sharedLibraries=null W 571 dex2oat type=1400 audit(0.0:23): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 571 dex2oat /system/bin/dex2oat --compiler-filter=speed E 571 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 571 dex2oat dex2oat took 606.125ms (threads: 4) arena alloc=2MB (2423280B) java alloc=206KB (211608B) native alloc=1334KB (1366320B) free=4MB (4925136B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/DefaultContainerService/DefaultContainerService.apk pkg=com.android.defcontainer isa=arm vmSafeMode=false debuggable=false target-filter=speed oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 576 dex2oat type=1400 audit(0.0:24): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 576 dex2oat /system/bin/dex2oat --compiler-filter=speed E 576 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 576 dex2oat dex2oat took 267.198ms (threads: 4) arena alloc=530KB (543008B) java alloc=96KB (99256B) native alloc=1010KB (1034784B) free=2MB (2110944B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/SettingsProvider/SettingsProvider.apk pkg=com.android.providers.settings isa=arm vmSafeMode=false debuggable=false target-filter=speed oatDir = null sharedLibraries=null W 581 dex2oat type=1400 audit(0.0:25): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 581 dex2oat /system/bin/dex2oat --compiler-filter=speed E 581 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 581 dex2oat Compilation of void com.android.providers.settings.DatabaseHelper.onUpgrade(android.database.sqlite.SQLiteDatabase, int, int) took 237.820ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 581 dex2oat dex2oat took 724.957ms (threads: 4) arena alloc=6MB (6915736B) java alloc=195KB (200680B) native alloc=1714KB (1755240B) free=9MB (10303384B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/InputDevices/InputDevices.apk pkg=com.android.inputdevices isa=arm vmSafeMode=false debuggable=false target-filter=speed oatDir = null sharedLibraries=null W 586 dex2oat type=1400 audit(0.0:26): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 586 dex2oat /system/bin/dex2oat --compiler-filter=speed E 586 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 586 dex2oat dex2oat took 219.996ms (threads: 4) arena alloc=10KB (10840B) java alloc=32KB (32784B) native alloc=747KB (765296B) free=1300KB (1331856B) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/ExtShared/ExtShared.apk pkg=android.ext.shared isa=arm vmSafeMode=false debuggable=false target-filter=speed oatDir = null sharedLibraries=null W 591 dex2oat type=1400 audit(0.0:27): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 591 dex2oat /system/bin/dex2oat --compiler-filter=speed E 591 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 591 dex2oat dex2oat took 217.334ms (threads: 4) arena alloc=60KB (61512B) java alloc=47KB (49016B) native alloc=774KB (793248B) free=1785KB (1828192B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/Telecom/Telecom.apk pkg=com.android.server.telecom isa=arm vmSafeMode=false debuggable=false target-filter=speed oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 596 dex2oat type=1400 audit(0.0:28): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 596 dex2oat /system/bin/dex2oat --compiler-filter=speed E 596 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 596 dex2oat dex2oat took 1.644s (threads: 4) arena alloc=1635KB (1674296B) java alloc=586KB (600168B) native alloc=2MB (2820968B) free=3MB (3470488B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/Dialer/Dialer.apk pkg=com.android.dialer isa=arm vmSafeMode=false debuggable=false target-filter=speed oatDir = null sharedLibraries=null W 601 dex2oat type=1400 audit(0.0:29): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 601 dex2oat /system/bin/dex2oat --compiler-filter=speed E 601 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 601 dex2oat Before Android 4.1, method android.graphics.PorterDuffColorFilter android.support.graphics.drawable.VectorDrawableCompat.updateTintFilter(android.graphics.PorterDuffColorFilter, android.content.res.ColorStateList, android.graphics.PorterDuff$Mode) would have incorrectly overridden the package-private method in android.graphics.drawable.Drawable W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 601 dex2oat dex2oat took 6.939s (threads: 4) arena alloc=3MB (3588176B) java alloc=3MB (3199504B) native alloc=10MB (11319256B) free=5MB (5982248B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/ExtServices/ExtServices.apk pkg=android.ext.services isa=arm vmSafeMode=false debuggable=false target-filter=speed oatDir = null sharedLibraries=null W 606 dex2oat type=1400 audit(0.0:30): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 606 dex2oat /system/bin/dex2oat --compiler-filter=speed E 606 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 606 dex2oat dex2oat took 267.083ms (threads: 4) arena alloc=312KB (320464B) java alloc=65KB (67000B) native alloc=1101KB (1128144B) free=2MB (2541872B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/PackageInstaller/PackageInstaller.apk pkg=com.android.packageinstaller isa=arm vmSafeMode=false debuggable=false target-filter=speed oatDir = null sharedLibraries=null W 611 dex2oat type=1400 audit(0.0:31): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 611 dex2oat /system/bin/dex2oat --compiler-filter=speed E 611 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 611 dex2oat Before Android 4.1, method android.graphics.PorterDuffColorFilter android.support.graphics.drawable.VectorDrawableCompat.updateTintFilter(android.graphics.PorterDuffColorFilter, android.content.res.ColorStateList, android.graphics.PorterDuff$Mode) would have incorrectly overridden the package-private method in android.graphics.drawable.Drawable W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 611 dex2oat Before Android 4.1, method int android.support.v7.widget.ListViewCompat.lookForSelectablePosition(int, boolean) would have incorrectly overridden the package-private method in android.widget.ListView W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 611 dex2oat dex2oat took 3.533s (threads: 4) arena alloc=3MB (4100064B) java alloc=2MB (2271608B) native alloc=5MB (6001360B) free=5MB (6057264B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/ProxyHandler/ProxyHandler.apk pkg=com.android.proxyhandler isa=arm vmSafeMode=false debuggable=false target-filter=speed oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 616 dex2oat type=1400 audit(0.0:32): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 616 dex2oat /system/bin/dex2oat --compiler-filter=speed E 616 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 616 dex2oat dex2oat took 288.031ms (threads: 4) arena alloc=1251KB (1281104B) java alloc=107KB (109928B) native alloc=1161KB (1189064B) free=2MB (3005240B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/LatinIME/LatinIME.apk pkg=com.android.inputmethod.latin isa=arm vmSafeMode=false debuggable=false target-filter=speed oatDir = null sharedLibraries=null W 621 dex2oat type=1400 audit(0.0:33): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 621 dex2oat /system/bin/dex2oat --compiler-filter=speed E 621 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 621 dex2oat dex2oat took 2.160s (threads: 4) arena alloc=1658KB (1698248B) java alloc=937KB (960016B) native alloc=3MB (3650272B) free=4MB (4214048B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/FSLOta/FSLOta.apk pkg=com.fsl.android.ota isa=arm vmSafeMode=false debuggable=false target-filter=speed oatDir = null sharedLibraries=null W 626 dex2oat type=1400 audit(0.0:34): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 626 dex2oat /system/bin/dex2oat --compiler-filter=speed E 626 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 626 dex2oat dex2oat took 299.013ms (threads: 4) arena alloc=1621KB (1659992B) java alloc=101KB (103456B) native alloc=1027KB (1051752B) free=3MB (3666840B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/Settings/Settings.apk pkg=com.android.settings isa=arm vmSafeMode=false debuggable=false target-filter=speed oatDir = null sharedLibraries=null W 631 dex2oat type=1400 audit(0.0:35): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 631 dex2oat /system/bin/dex2oat --compiler-filter=speed E 631 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 631 dex2oat Before Android 4.1, method android.graphics.PorterDuffColorFilter android.support.graphics.drawable.VectorDrawableCompat.updateTintFilter(android.graphics.PorterDuffColorFilter, android.content.res.ColorStateList, android.graphics.PorterDuff$Mode) would have incorrectly overridden the package-private method in android.graphics.drawable.Drawable W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 631 dex2oat Before Android 4.1, method int android.support.v7.widget.ListViewCompat.lookForSelectablePosition(int, boolean) would have incorrectly overridden the package-private method in android.widget.ListView W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 631 dex2oat Compilation of boolean com.android.settings.applications.RunningState.update(android.content.Context, android.app.ActivityManager) took 125.030ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 631 dex2oat Compilation of java.util.List com.android.settings.notification.NotificationStation.loadNotifications() took 124.724ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 631 dex2oat dex2oat took 7.693s (threads: 4) arena alloc=3MB (4187832B) java alloc=5MB (5498728B) native alloc=12MB (12723144B) free=6MB (6675512B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/CactusPlayer/CactusPlayer.apk pkg=com.freescale.cactusplayer isa=arm vmSafeMode=false debuggable=false target-filter=speed oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 636 dex2oat type=1400 audit(0.0:36): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 636 dex2oat /system/bin/dex2oat --compiler-filter=speed E 636 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 636 dex2oat dex2oat took 488.533ms (threads: 4) arena alloc=1409KB (1443448B) java alloc=246KB (252120B) native alloc=1326KB (1358560B) free=3MB (3360032B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/TeleService/TeleService.apk pkg=com.android.phone isa=arm vmSafeMode=false debuggable=false target-filter=speed oatDir = null sharedLibraries=null W 641 dex2oat type=1400 audit(0.0:37): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 641 dex2oat /system/bin/dex2oat --compiler-filter=speed E 641 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 641 dex2oat Compilation of void com.android.phone.PhoneInterfaceManager$MainThreadHandler.handleMessage(android.os.Message) took 265.487ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 641 dex2oat dex2oat took 3.652s (threads: 4) arena alloc=6MB (7090224B) java alloc=1370KB (1403728B) native alloc=5MB (5957408B) free=8MB (9246944B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/Shell/Shell.apk pkg=com.android.shell isa=arm vmSafeMode=false debuggable=false target-filter=speed oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 646 dex2oat type=1400 audit(0.0:38): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 646 dex2oat /system/bin/dex2oat --compiler-filter=speed E 646 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 646 dex2oat dex2oat took 634.254ms (threads: 4) arena alloc=1743KB (1785808B) java alloc=260KB (266784B) native alloc=1450KB (1485560B) free=3MB (3757320B) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/FusedLocation/FusedLocation.apk pkg=com.android.location.fused isa=arm vmSafeMode=false debuggable=false target-filter=speed oatDir = null sharedLibraries=/system/framework/com.android.location.provider.jar W 651 dex2oat type=1400 audit(0.0:39): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 651 dex2oat /system/bin/dex2oat --compiler-filter=speed E 651 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 651 dex2oat dex2oat took 267.018ms (threads: 4) arena alloc=296KB (304016B) java alloc=120KB (123800B) native alloc=1148KB (1176384B) free=1923KB (1969344B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/SystemUI/SystemUI.apk pkg=com.android.systemui isa=arm vmSafeMode=false debuggable=false target-filter=speed oatDir = null sharedLibraries=null W 657 dex2oat type=1400 audit(0.0:40): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 657 dex2oat /system/bin/dex2oat --compiler-filter=speed E 657 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 657 dex2oat Before Android 4.1, method android.graphics.PorterDuffColorFilter android.support.graphics.drawable.VectorDrawableCompat.updateTintFilter(android.graphics.PorterDuffColorFilter, android.content.res.ColorStateList, android.graphics.PorterDuff$Mode) would have incorrectly overridden the package-private method in android.graphics.drawable.Drawable W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 657 dex2oat Before Android 4.1, method int android.support.v7.widget.ListViewCompat.lookForSelectablePosition(int, boolean) would have incorrectly overridden the package-private method in android.widget.ListView W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 657 dex2oat dex2oat took 9.120s (threads: 4) arena alloc=2MB (2235464B) java alloc=4MB (5224520B) native alloc=12MB (13187760B) free=4MB (5162320B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/WfdSink/WfdSink.apk pkg=com.freescale.wfdsink isa=arm vmSafeMode=false debuggable=false target-filter=speed oatDir = null sharedLibraries=null W 665 dex2oat type=1400 audit(0.0:41): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 665 dex2oat /system/bin/dex2oat --compiler-filter=speed E 665 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 665 dex2oat dex2oat took 409.145ms (threads: 4) arena alloc=811KB (830856B) java alloc=245KB (251880B) native alloc=1281KB (1311768B) free=2MB (2882536B) E 486 system PackageManager There should probably be a verifier, but, none were found D 486 system PackageManager Ephemeral resolver NOT found; no matching intent filters I 486 system PackageManager Ephemeral deactivated; missing resolver and installer I 486 system art Starting a blocking GC Explicit W 486 system art Long monitor contention with owner main (486) at int android.net.LocalSocketImpl.readba_native(byte[], int, int, java.io.FileDescriptor)(LocalSocketImpl.java:-2) waiters=0 in void com.android.server.pm.Settings$RuntimePermissionPersistence.writePermissionsSync(int) for 41.554s W 486 system art Long monitor contention with owner main (486) at int android.net.LocalSocketImpl.readba_native(byte[], int, int, java.io.FileDescriptor)(LocalSocketImpl.java:-2) waiters=1 in void com.android.server.pm.PackageManagerService$PackageHandler.doHandleMessage(android.os.Message) for 32.766s I 486 system art Explicit concurrent mark sweep GC freed 18453(1021KB) AllocSpace objects, 5(100KB) LOS objects, 33% free, 3MB/4MB, paused 916us total 50.960ms I 486 system SystemServer StartOtaDexOptService W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system SystemServer StartUserManagerService I 486 system SystemServiceManager Starting com.android.server.pm.UserManagerService$LifeCycle I 219 /system/bin/lmkd lowmemorykiller ActivityManager connected D 486 system SensorService nuSensorService starting... W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) E 486 system couldn't find 'FreescaleAccelerometer' input device E 486 system Couldn't open /dev/mma8x5x (No such file or directory) E 486 system Can`t find the Acc sensor! W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) E 486 system couldn't find 'eCompass' input device E 486 system Can`t find the mag sensor! E 486 system SensorService >>>> WARNING <<< Upgrade sensor HAL to version 1_3 D 486 system AccelSensor enable 0 , handle 0 ,mEnabled 0 D 486 system AccelSensor enable 0 , handle 1 ,mEnabled 0 D 486 system MagSensor mEnabled 0, OrientaionSensor mEnabled 0 D 486 system AccelSensor enable 0 , handle 2 ,mEnabled 0 D 486 system MagSensor mEnabled 0, OrientaionSensor mEnabled 0 I 486 system SensorService Generated new HMAC key. D 486 system SensorService nuSensorService thread starting... D 486 system SensorService new thread SensorEventAckReceiver W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system SystemServiceManager Starting com.android.server.BatteryService I 486 system SystemServiceManager Starting com.android.server.usage.UsageStatsService I 486 system SystemServiceManager Starting com.android.server.webkit.WebViewUpdateService I 486 system SystemServer Reading configuration... I 486 system SystemServer StartSchedulingPolicyService I 486 system SystemServiceManager Starting com.android.server.telecom.TelecomLoaderService I 486 system SystemServer StartTelephonyRegistry I 486 system SystemServer StartEntropyMixer W 486 system EntropyMixer No existing entropy file -- first boot? I 486 system EntropyMixer Added HW RNG output to entropy pool I 486 system EntropyMixer Writing entropy... W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system SystemServer Camera Service I 486 system SystemServiceManager Starting com.android.server.camera.CameraService I 486 system ServiceThread Enabled StrictMode logging for CameraService_proxy looper. I 486 system SystemServer StartAccountManagerService I 486 system SystemServiceManager Starting com.android.server.accounts.AccountManagerService$Lifecycle I 486 system SystemServer StartContentService I 486 system SystemServiceManager Starting com.android.server.content.ContentService$Lifecycle I 486 system SystemServer InstallSystemProviders W 486 system System ClassLoader referenced unknown path: /system/priv-app/SettingsProvider/lib/arm W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system SettingsState No settings state /data/system/users/0/settings_system.xml W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system SettingsState No settings state /data/system/users/0/settings_secure.xml D 486 system SettingsProvider Generated and saved new ANDROID_ID [b68006e854e52539] for user 0 I 486 system SettingsState No settings state /data/system/users/0/settings_global.xml I 486 system SystemServer StartVibratorService E 486 system Vibrator file does not exist : -1 E 486 system Vibrator device does not exist. Cannot start vibrator W 486 system VibratorService Tried to stop vibrating but there is no vibrator device. I 486 system SystemServer StartConsumerIrService E 486 system ConsumerIrService Can't open consumer IR HW Module, error: -2 I 486 system SystemServer StartAlarmManagerService I 486 system SystemServiceManager Starting com.android.server.AlarmManagerService I 486 system SystemServer InitWatchdog I 486 system SystemServer StartInputManagerService I 486 system InputManager Initializing input manager, mUseDevInputEventForAudioJack=false I 486 system SystemServer StartWindowManagerService W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system WindowManager No existing display settings /data/system/display_settings.xml; starting empty I 486 system SystemServer StartVrManagerService I 486 system SystemServiceManager Starting com.android.server.vr.VrManagerService W 486 system VrManagerService init_native: Could not open VR hardware module, error No such file or directory (-2). I 486 system InputManager Starting input manager I 486 system SystemServiceManager Starting com.android.server.BluetoothService D 486 system BluetoothManagerService Loading stored name and address D 486 system BluetoothManagerService Stored bluetooth Name=null,Address=null D 486 system BluetoothManagerService Bluetooth persisted state: 0 I 486 system SystemServer ConnectivityMetricsLoggerService I 486 system SystemServiceManager Starting com.android.server.connectivity.MetricsLoggerService D 486 system EventHub No input device configuration file found for device 'isl29023 light sensor'. I 486 system SystemServer IpConnectivityMetrics I 486 system SystemServiceManager Starting com.android.server.connectivity.IpConnectivityMetrics I 486 system SystemServer PinnerService I 486 system SystemServiceManager Starting com.android.server.PinnerService I 486 system SystemServiceManager Starting com.android.server.InputMethodManagerService$Lifecycle W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system System ClassLoader referenced unknown path: D 486 system ApplicationLoaders ignored Vulkan layer search path /system/app/LatinIME/lib/arm:/system/fake-libs:/system/app/LatinIME/LatinIME.apk!/lib/armeabi-v7a:/system/lib:/vendor/lib for namespace 0xb32cc0d0 E 486 system EventHub could not get driver version for /dev/input/mice, Not a typewriter E 486 system EventHub could not get driver version for /dev/input/mouse0, Not a typewriter W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system InputMethodManagerService No IME selected. Choose the most applicable IME. I 486 system InputMethodManagerService Default found, using com.android.inputmethod.latin/.LatinIME I 486 system SystemServer StartAccessibilityManagerService I 486 system ActivityManager Config changes=1df8 {1.0 ?mcc?mnc [en_US] ldltr sw800dp w1280dp h800dp 160dpi xlrg land ?uimode ?night -touch -keyb/h/h -nav/h s.2} I 486 system UsageStatsDatabase Upgrading from version 0 to 3 I 486 system UsageStatsDatabase Deleting all usage stats files I 486 system UsageStatsService User[0] Rollover scheduled @ 1970-01-02 00:03:20(86600839) D 486 system UsageStatsService Initializing defaults for system apps on user 0 E 486 system AppIdleHistory Unable to read app idle file for user 0 I 486 system ActivityManager Config changes=400 {1.0 ?mcc?mnc [en_US] ldltr sw800dp w1280dp h728dp 160dpi xlrg land ?uimode ?night -touch -keyb/h/h -nav/h s.3} D 486 system EventHub No input device configuration file found for device 'max11801_ts'. I 486 system EventHub New device: id=2, fd=96, path='/dev/input/event1', name='max11801_ts', classes=0x4, configuration='', keyLayout='', keyCharacterMap='', builtinKeyboard=false, wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true D 486 system EventHub No input device configuration file found for device 'ft5426_ts'. I 486 system EventHub New device: id=3, fd=97, path='/dev/input/event0', name='ft5426_ts', classes=0x14, configuration='', keyLayout='', keyCharacterMap='', builtinKeyboard=false, wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true I 486 system SystemServiceManager Starting com.android.server.MountService$Lifecycle W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system InputReader Device added: id=-1, name='Virtual', sources=0x00000301 I 486 system InputReader Touch device 'ft5426_ts' could not query the properties of its associated display. The device will be inoperable until the display size becomes available. I 486 system SystemServiceManager Starting com.android.server.UiModeManagerService D 486 system MountService Thinking about init, mSystemReady=false, mDaemonConnected=true I 486 system InputReader Device added: id=3, name='ft5426_ts', sources=0x00001002 D 486 system MountService Thinking about reset, mSystemReady=false, mDaemonConnected=true I 486 system InputReader Touch device 'max11801_ts' could not query the properties of its associated display. The device will be inoperable until the display size becomes available. I 486 system InputReader Device added: id=2, name='max11801_ts', sources=0x00002002 D 486 system MountService Thinking about init, mSystemReady=false, mDaemonConnected=true D 486 system MountService Thinking about reset, mSystemReady=false, mDaemonConnected=true I 486 system InputReader Reconfiguring input devices. changes=0x00000004 D 486 system CryptdConnector SND -> {1 cryptfs getfield SystemLocale} D 486 system CryptdConnector RCV <- {200 1 -1} W 486 system MountService No primary storage mounted! D 486 system VoldConnector SND -> {1 asec list} D 486 system VoldConnector RCV <- {200 1 asec operation succeeded} I 486 system PackageManager No secure containers found W 486 system PackageManager Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar W 486 system PackageManager Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar W 486 system PackageManager Not granting permission android.permission.GLOBAL_SEARCH to package com.android.quicksearchbox (protectionLevel=18 flags=0x3888be45) W 486 system PackageManager Not granting permission android.permission.BIND_WALLPAPER to package com.android.camera2 (protectionLevel=18 flags=0x30d8bc45) W 486 system PackageManager Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar W 486 system PackageManager Not granting permission android.permission.WRITE_MEDIA_STORAGE to package com.android.gallery3d (protectionLevel=18 flags=0x38d8bc45) I 486 system InputReader Device reconfigured: id=2, name='max11801_ts', size 1280x800, orientation 0, mode 4, display id 0 I 486 system InputReader Device reconfigured: id=3, name='ft5426_ts', size 1280x800, orientation 0, mode 1, display id 0 W 486 system PackageManager Unknown permission com.google.android.permission.INSTALL_WEARABLE_PACKAGES in package com.android.packageinstaller W 486 system PackageManager Not granting permission android.permission.DELETE_PACKAGES to package com.svox.pico (protectionLevel=18 flags=0x3888be45) W 486 system PackageManager Unknown permission android.permission.RUN_INSTRUMENTATION in package org.chromium.webview_shell I 486 system ActivityManager Config changes=8 {1.0 ?mcc?mnc [en_US] ldltr sw800dp w1280dp h728dp 160dpi xlrg land ?uimode ?night finger -keyb/h/h -nav/h s.4} W 486 system PackageManager Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings W 486 system PackageManager Unknown permission com.android.smspush.WAPPUSH_MANAGER_BIND in package com.android.phone W 486 system PackageManager Unknown permission android.permission.ACCESS_ALL_EXTERNAL_STORAGE in package com.freescale.wfdsink W 486 system PackageManager Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.bluetooth W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system MountService No primary storage defined yet; hacking together a stub W 486 system MountService No primary storage defined yet; hacking together a stub W 486 system MountService No primary storage mounted! D 486 system VoldConnector SND -> {2 asec list} D 486 system VoldConnector RCV <- {200 2 asec operation succeeded} I 486 system ActivityManager Config changes=200 {1.0 ?mcc?mnc [en_US] ldltr sw800dp w1280dp h728dp 160dpi xlrg land finger -keyb/h/h -nav/h s.5} W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/BleServerEmulator/BleServerEmulator.apk pkg=com.freescale.bleserver isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 681 dex2oat type=1400 audit(0.0:42): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 681 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 681 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out I 681 dex2oat dex2oat took 300.038ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32208B) native alloc=985KB (1008976B) free=1574KB (1612464B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/CubeLiveWallpapers/CubeLiveWallpapers.apk pkg=com.example.android.livecubes isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 686 dex2oat type=1400 audit(0.0:43): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 686 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 686 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 686 dex2oat dex2oat took 211.810ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32208B) native alloc=771KB (789520B) free=1276KB (1307632B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/ethernet/ethernet.apk pkg=com.fsl.ethernet isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 691 dex2oat type=1400 audit(0.0:44): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 691 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 691 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 691 dex2oat dex2oat took 214.415ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=884KB (905808B) free=1163KB (1191344B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/CalendarProvider/CalendarProvider.apk pkg=com.android.providers.calendar isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=/system/framework/android.test.runner.jar W 696 dex2oat type=1400 audit(0.0:45): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 696 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 696 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 696 dex2oat dex2oat took 316.540ms (threads: 4) arena alloc=0B (0B) java alloc=35KB (36168B) native alloc=897KB (918928B) free=1662KB (1702512B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/MediaProvider/MediaProvider.apk pkg=com.android.providers.media isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 701 dex2oat type=1400 audit(0.0:46): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 701 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 701 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 701 dex2oat dex2oat took 238.360ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32216B) native alloc=986KB (1010256B) free=1061KB (1086896B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/WallpaperCropper/WallpaperCropper.apk pkg=com.android.wallpapercropper isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 706 dex2oat type=1400 audit(0.0:47): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 706 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 706 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 706 dex2oat dex2oat took 253.909ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32216B) native alloc=960KB (983376B) free=1599KB (1638064B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/Launcher2/Launcher2.apk pkg=com.android.launcher isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 711 dex2oat type=1400 audit(0.0:48): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 711 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 711 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 711 dex2oat dex2oat took 319.207ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=991KB (1015056B) free=1568KB (1606384B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/DocumentsUI/DocumentsUI.apk pkg=com.android.documentsui isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 716 dex2oat type=1400 audit(0.0:49): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 716 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 716 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 716 dex2oat dex2oat took 591.544ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=788KB (807384B) free=2MB (2338344B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/ExternalStorageProvider/ExternalStorageProvider.apk pkg=com.android.externalstorage isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 721 dex2oat type=1400 audit(0.0:50): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 721 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 721 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 721 dex2oat dex2oat took 225.544ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=935KB (957968B) free=1112KB (1139184B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/HTMLViewer/HTMLViewer.apk pkg=com.android.htmlviewer isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 726 dex2oat type=1400 audit(0.0:51): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 726 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 726 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 726 dex2oat dex2oat took 218.355ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=764KB (782928B) free=1283KB (1314224B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/QuickSearchBox/QuickSearchBox.apk pkg=com.android.quicksearchbox isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 731 dex2oat type=1400 audit(0.0:52): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 731 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 731 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 731 dex2oat dex2oat took 307.519ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32216B) native alloc=969KB (992336B) free=1590KB (1629104B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/DownloadProvider/DownloadProvider.apk pkg=com.android.providers.downloads isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 736 dex2oat type=1400 audit(0.0:53): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 736 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 736 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 736 dex2oat dex2oat took 293.968ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32216B) native alloc=1018KB (1042448B) free=1541KB (1578992B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/SoundRecorder/SoundRecorder.apk pkg=com.android.soundrecorder isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 741 dex2oat type=1400 audit(0.0:54): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 741 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 741 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 741 dex2oat dex2oat took 223.212ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32216B) native alloc=744KB (762832B) free=1303KB (1334320B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/DownloadProviderUi/DownloadProviderUi.apk pkg=com.android.providers.downloads.ui isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 746 dex2oat type=1400 audit(0.0:55): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 746 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 746 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 746 dex2oat dex2oat took 237.534ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32208B) native alloc=746KB (764688B) free=1301KB (1332464B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/PacProcessor/PacProcessor.apk pkg=com.android.pacprocessor isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 752 dex2oat type=1400 audit(0.0:56): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 752 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 752 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 752 dex2oat dex2oat took 224.854ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=744KB (762384B) free=1303KB (1334768B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/CertInstaller/CertInstaller.apk pkg=com.android.certinstaller isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 757 dex2oat type=1400 audit(0.0:57): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 757 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 757 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 757 dex2oat dex2oat took 214.679ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32216B) native alloc=884KB (906192B) free=1163KB (1190960B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/CarrierConfig/CarrierConfig.apk pkg=com.android.carrierconfig isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 762 dex2oat type=1400 audit(0.0:58): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 762 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 762 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 762 dex2oat dex2oat took 218.509ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32216B) native alloc=744KB (762384B) free=1303KB (1334768B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/Contacts/Contacts.apk pkg=com.android.contacts isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 767 dex2oat type=1400 audit(0.0:59): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 767 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 767 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 767 dex2oat dex2oat took 583.420ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=501KB (513736B) free=2MB (2631992B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/Camera2/Camera2.apk pkg=com.android.camera2 isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 772 dex2oat type=1400 audit(0.0:60): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 772 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 772 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 772 dex2oat dex2oat took 892.297ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=407KB (417024B) free=2MB (2728704B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/EasterEgg/EasterEgg.apk pkg=com.android.egg isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 777 dex2oat type=1400 audit(0.0:61): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 777 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 777 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 777 dex2oat dex2oat took 288.823ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=961KB (984848B) free=1598KB (1636592B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/MtpDocumentsProvider/MtpDocumentsProvider.apk pkg=com.android.mtp isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 782 dex2oat type=1400 audit(0.0:62): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 782 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 782 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 782 dex2oat dex2oat took 231.270ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32208B) native alloc=912KB (934320B) free=1135KB (1162832B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/BackupRestoreConfirmation/BackupRestoreConfirmation.apk pkg=com.android.backupconfirm isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 787 dex2oat type=1400 audit(0.0:63): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 787 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 787 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 787 dex2oat dex2oat took 225.173ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32240B) native alloc=747KB (765200B) free=1300KB (1331952B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/Provision/Provision.apk pkg=com.android.provision isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 792 dex2oat type=1400 audit(0.0:64): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 792 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 792 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 792 dex2oat dex2oat took 222.587ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=804KB (824144B) free=1243KB (1273008B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/StatementService/StatementService.apk pkg=com.android.statementservice isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 797 dex2oat type=1400 audit(0.0:65): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 797 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 797 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 797 dex2oat dex2oat took 226.139ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32216B) native alloc=978KB (1002448B) free=1069KB (1094704B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/Calendar/Calendar.apk pkg=com.android.calendar isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 802 dex2oat type=1400 audit(0.0:66): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 802 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 802 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 802 dex2oat dex2oat took 372.213ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=872KB (893648B) free=2MB (2252080B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/SharedStorageBackup/SharedStorageBackup.apk pkg=com.android.sharedstoragebackup isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 807 dex2oat type=1400 audit(0.0:67): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 807 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 807 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 807 dex2oat dex2oat took 217.376ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32208B) native alloc=746KB (764688B) free=1301KB (1332464B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/PrintSpooler/PrintSpooler.apk pkg=com.android.printspooler isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 812 dex2oat type=1400 audit(0.0:68): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 812 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 812 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 812 dex2oat dex2oat took 322.039ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=972KB (995920B) free=1587KB (1625520B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/BasicDreams/BasicDreams.apk pkg=com.android.dreams.basic isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 817 dex2oat type=1400 audit(0.0:69): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 817 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 817 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 817 dex2oat dex2oat took 225.695ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=784KB (803408B) free=1263KB (1293744B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/webview/webview.apk pkg=com.android.webview isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 822 dex2oat type=1400 audit(0.0:70): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 822 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 822 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 822 dex2oat dex2oat took 414.505ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=564KB (577944B) free=2MB (2567784B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/MusicFX/MusicFX.apk pkg=com.android.musicfx isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 827 dex2oat type=1400 audit(0.0:71): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 827 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 827 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 827 dex2oat dex2oat took 223.481ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=884KB (906192B) free=1163KB (1190960B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/CellBroadcastReceiver/CellBroadcastReceiver.apk pkg=com.android.cellbroadcastreceiver isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 832 dex2oat type=1400 audit(0.0:72): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 832 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 832 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 832 dex2oat dex2oat took 230.698ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=941KB (964176B) free=1106KB (1132976B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/OneTimeInitializer/OneTimeInitializer.apk pkg=com.android.onetimeinitializer isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 837 dex2oat type=1400 audit(0.0:73): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 837 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 837 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 837 dex2oat dex2oat took 228.272ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32208B) native alloc=907KB (928784B) free=1140KB (1168368B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/KeyChain/KeyChain.apk pkg=com.android.keychain isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 842 dex2oat type=1400 audit(0.0:74): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 842 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 842 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 842 dex2oat dex2oat took 233.482ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=889KB (911184B) free=1158KB (1185968B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/PrintRecommendationService/PrintRecommendationService.apk pkg=com.android.printservice.recommendation isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 847 dex2oat type=1400 audit(0.0:75): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 847 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 847 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 847 dex2oat dex2oat took 233.439ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32240B) native alloc=946KB (969232B) free=1101KB (1127920B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/Gallery2/Gallery2.apk pkg=com.android.gallery3d isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 852 dex2oat type=1400 audit(0.0:76): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 852 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 852 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 852 dex2oat dex2oat took 784.921ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=467KB (478616B) free=2MB (2667112B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/CallLogBackup/CallLogBackup.apk pkg=com.android.calllogbackup isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 857 dex2oat type=1400 audit(0.0:77): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 857 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 857 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 857 dex2oat dex2oat took 226.852ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32216B) native alloc=768KB (786704B) free=1279KB (1310448B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/PicoTts/PicoTts.apk pkg=com.svox.pico isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 862 dex2oat type=1400 audit(0.0:78): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 862 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 862 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 862 dex2oat dex2oat took 230.924ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=769KB (787472B) free=1278KB (1309680B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/Browser2/Browser2.apk pkg=org.chromium.webview_shell isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=/system/framework/android.test.runner.jar W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 867 dex2oat type=1400 audit(0.0:79): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 867 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 867 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 867 dex2oat dex2oat took 242.392ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32192B) native alloc=965KB (988624B) free=1594KB (1632816B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/ManagedProvisioning/ManagedProvisioning.apk pkg=com.android.managedprovisioning isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 872 dex2oat type=1400 audit(0.0:80): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 872 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 872 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 872 dex2oat dex2oat took 270.101ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32208B) native alloc=960KB (983568B) free=1599KB (1637872B) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/LiveWallpapersPicker/LiveWallpapersPicker.apk pkg=com.android.wallpaper.livepicker isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 877 dex2oat type=1400 audit(0.0:81): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 877 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 877 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 877 dex2oat dex2oat took 434.611ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32208B) native alloc=904KB (926352B) free=2MB (2219376B) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/StorageManager/StorageManager.apk pkg=com.android.storagemanager isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 882 dex2oat type=1400 audit(0.0:82): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 882 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 882 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 882 dex2oat dex2oat took 510.795ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32216B) native alloc=810KB (830184B) free=2MB (2315544B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/BookmarkProvider/BookmarkProvider.apk pkg=com.android.bookmarkprovider isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 887 dex2oat type=1400 audit(0.0:83): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 887 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 887 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 887 dex2oat dex2oat took 229.979ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32216B) native alloc=764KB (782864B) free=1283KB (1314288B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/A2dpSinkApp/A2dpSinkApp.apk pkg=com.freescale.a2dpsinkapp isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 892 dex2oat type=1400 audit(0.0:84): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 892 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 892 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 892 dex2oat dex2oat took 224.664ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=747KB (765520B) free=1300KB (1331632B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/ExactCalculator/ExactCalculator.apk pkg=com.android.calculator2 isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 897 dex2oat type=1400 audit(0.0:85): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 897 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 897 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 897 dex2oat dex2oat took 283.252ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32216B) native alloc=986KB (1009680B) free=1573KB (1611760B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/VpnDialogs/VpnDialogs.apk pkg=com.android.vpndialogs isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 902 dex2oat type=1400 audit(0.0:86): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 902 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 902 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 902 dex2oat dex2oat took 209.272ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=744KB (762448B) free=1303KB (1334704B) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/Email/Email.apk pkg=com.android.email isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 907 dex2oat type=1400 audit(0.0:87): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 907 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 907 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 907 dex2oat dex2oat took 1.328s (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=507KB (519248B) free=2MB (2626480B) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/Music/Music.apk pkg=com.android.music isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 912 dex2oat type=1400 audit(0.0:88): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 912 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 912 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 912 dex2oat dex2oat took 262.012ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=961KB (985008B) free=1598KB (1636432B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/WallpaperBackup/WallpaperBackup.apk pkg=com.android.wallpaperbackup isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 917 dex2oat type=1400 audit(0.0:89): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 917 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 917 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 917 dex2oat dex2oat took 232.189ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32216B) native alloc=747KB (765456B) free=1300KB (1331696B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/BlockedNumberProvider/BlockedNumberProvider.apk pkg=com.android.providers.blockednumber isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 922 dex2oat type=1400 audit(0.0:90): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 922 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 922 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 922 dex2oat dex2oat took 296.047ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=959KB (982992B) free=1088KB (1114160B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/UserDictionaryProvider/UserDictionaryProvider.apk pkg=com.android.providers.userdictionary isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 927 dex2oat type=1400 audit(0.0:91): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 927 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 927 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 927 dex2oat dex2oat took 227.982ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=774KB (793360B) free=1273KB (1303792B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/EmergencyInfo/EmergencyInfo.apk pkg=com.android.emergency isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 932 dex2oat type=1400 audit(0.0:92): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 932 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 932 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 932 dex2oat dex2oat took 419.541ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32216B) native alloc=899KB (920720B) free=2MB (2225008B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/DeskClock/DeskClock.apk pkg=com.android.deskclock isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 937 dex2oat type=1400 audit(0.0:93): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 937 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 937 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 937 dex2oat dex2oat took 701.260ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=477KB (488728B) free=2MB (2657000B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/BluetoothMidiService/BluetoothMidiService.apk pkg=com.android.bluetoothmidiservice isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 942 dex2oat type=1400 audit(0.0:94): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 942 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 942 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 942 dex2oat dex2oat took 227.086ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32208B) native alloc=747KB (764944B) free=1300KB (1332208B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/BleClient/BleClient.apk pkg=com.freescale.bleclient isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 947 dex2oat type=1400 audit(0.0:95): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 947 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 947 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 947 dex2oat dex2oat took 244.598ms (threads: 4) arena alloc=0B (0B) java alloc=27KB (28240B) native alloc=957KB (980400B) free=1090KB (1116752B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/Bluetooth/Bluetooth.apk pkg=com.android.bluetooth isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=/system/framework/javax.obex.jar W 952 dex2oat type=1400 audit(0.0:96): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 952 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 952 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 952 dex2oat dex2oat took 896.902ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32240B) native alloc=478KB (490096B) free=2MB (2655632B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/priv-app/ContactsProvider/ContactsProvider.apk pkg=com.android.providers.contacts isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 957 dex2oat type=1400 audit(0.0:97): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 I 957 dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 957 cutils-trace Error opening trace file: Permission denied (13) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 957 dex2oat dex2oat took 412.456ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32216B) native alloc=913KB (935824B) free=2MB (2209904B) I 486 system PackageManager.DexOptimizer Running dexopt (dex2oat) on: /system/app/CaptivePortalLogin/CaptivePortalLogin.apk pkg=com.android.captiveportallogin isa=arm vmSafeMode=false debuggable=false target-filter=verify-at-runtime oatDir = null sharedLibraries=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 965 /system/bin/dex2oat dex2oat /system/bin/dex2oat --compiler-filter=verify-at-runtime E 965 /system/bin/dex2oat cutils-trace Error opening trace file: Permission denied (13) W 965 /system/bin/dex2oat dex2oat type=1400 audit(0.0:98): avc: denied { write } for name="trace_marker" dev="tracefs" ino=125 scontext=u:r:dex2oat:s0 tcontext=u:object_r:debugfs_tracing:s0 tclass=file permissive=0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 965 /system/bin/dex2oat dex2oat dex2oat took 317.846ms (threads: 4) arena alloc=0B (0B) java alloc=31KB (32208B) native alloc=747KB (764944B) free=1300KB (1332208B) I 486 system SystemServer StartLockSettingsService I 486 system SystemServiceManager Starting com.android.server.LockSettingsService$Lifecycle I 486 system SystemServiceManager Starting com.android.server.PersistentDataBlockService E 486 system PersistentDataBlockService not able to find package E 486 system PersistentDataBlockService android.content.pm.PackageManager$NameNotFoundException: E 486 system PersistentDataBlockService at android.app.ApplicationPackageManager.getPackageUidAsUser(ApplicationPackageManager.java:256) E 486 system PersistentDataBlockService at com.android.server.PersistentDataBlockService.getAllowedUid(PersistentDataBlockService.java:102) E 486 system PersistentDataBlockService at com.android.server.PersistentDataBlockService.<init>(PersistentDataBlockService.java:93) E 486 system PersistentDataBlockService at java.lang.reflect.Constructor.newInstance0(Native Method) E 486 system PersistentDataBlockService at java.lang.reflect.Constructor.newInstance(Constructor.java:430) E 486 system PersistentDataBlockService at com.android.server.SystemServiceManager.startService(SystemServiceManager.java:92) E 486 system PersistentDataBlockService at com.android.server.SystemServer.startOtherServices(SystemServer.java:749) E 486 system PersistentDataBlockService at com.android.server.SystemServer.run(SystemServer.java:334) E 486 system PersistentDataBlockService at com.android.server.SystemServer.main(SystemServer.java:219) E 486 system PersistentDataBlockService at java.lang.reflect.Method.invoke(Native Method) E 486 system PersistentDataBlockService at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:886) E 486 system PersistentDataBlockService at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:776) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system SystemServiceManager Starting com.android.server.DeviceIdleController I 486 system SystemServiceManager Starting com.android.server.devicepolicy.DevicePolicyManagerService$Lifecycle W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system SystemServer StartStatusBarManagerService I 486 system SystemServer StartClipboardService I 486 system SystemServer StartNetworkManagementService I 486 system NetworkManagement onDaemonConnected() I 486 system SystemServiceManager Starting com.android.server.TextServicesManagerService$Lifecycle I 486 system SystemServer StartNetworkScoreService I 486 system SystemServer StartNetworkStatsService I 486 system SystemServer StartNetworkPolicyManagerService I 486 system SystemServer No Wi-Fi NAN Service (NAN support Not Present) I 486 system SystemServiceManager Starting com.android.server.wifi.p2p.WifiP2pService I 486 system WifiP2pService Registering wifip2p I 486 system SystemServiceManager Starting com.android.server.wifi.WifiService W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system HS20 Passpoint is disabled E 486 system IpManager.wlan0 Failed to disable IPv6java.lang.IllegalStateException: command '1 interface ipv6 wlan0 disable' failed with '400 1 Failed to change IPv6 state (No such file or directory)' D 486 system WifiApConfigStore 2G band allowed channels are:1,6,11 E 486 system WifiLogger no ring buffers found E 486 system WifiLogger Failed to start packet fate monitoring E 486 system WifiApConfigStore Error reading hotspot configuration java.io.FileNotFoundException: /data/misc/wifi/softap.conf (No such file or directory) D 486 system WifiApConfigStore Fallback to use default AP configuration D 238 /system/bin/netd CommandListener Clearing all IP addresses on wlan0 D 486 system WifiController isAirplaneModeOn = false, isWifiEnabled = false, isScanningAvailable = false I 486 system WifiService Registering wifi I 486 system SystemServiceManager Starting com.android.server.wifi.scanner.WifiScanningService I 486 system WifiScanningService Creating wifiscanner I 486 system WifiScanningService Publishing wifiscanner I 486 system SystemServiceManager Starting com.android.server.wifi.RttService I 486 system RttService Creating rttmanager I 486 system RttService Starting rttmanager I 486 system SystemServiceManager Starting com.android.server.ethernet.EthernetService I 486 system EthernetServiceImpl Creating EthernetConfigStore E 486 system IpConfigStore Error parsing configuration: java.io.FileNotFoundException: /data/misc/ethernet/ipconfig.txt (No such file or directory) W 486 system EthernetConfigStore No Ethernet configuration found. Using default. I 486 system EthernetServiceImpl Read stored IP configuration: IP assignment: DHCP I 486 system EthernetServiceImpl Proxy settings: NONE I 486 system EthernetService Registering service ethernet I 486 system SystemServer StartConnectivityService D 486 system ConnectivityService ConnectivityService starting up D 486 system ConnectivityService wifiOnly=false E 486 system ConnectivityService Ignoring protectedNetwork 14 E 486 system ConnectivityService Ignoring protectedNetwork 15 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system SystemServer StartNsdService I 486 system SystemServer StartUpdateLockService I 486 system SystemServiceManager Starting com.android.server.RecoverySystemService I 486 system SystemServiceManager Starting com.android.server.notification.NotificationManagerService D 486 system ConditionProviders.SCP new ScheduleConditionProvider() D 486 system ZenLog set_zen_mode: off,init I 486 system SystemServiceManager Starting com.android.server.storage.DeviceStorageMonitorService I 486 system SystemServer StartLocationManagerService W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system SystemServer StartCountryDetectorService I 486 system SystemServer StartSearchManagerService I 486 system SystemServiceManager Starting com.android.server.search.SearchManagerService$Lifecycle I 486 system SystemServiceManager Starting com.android.server.DropBoxManagerService I 486 system SystemServer StartWallpaperManagerService I 486 system SystemServiceManager Starting com.android.server.wallpaper.WallpaperManagerService$Lifecycle E 486 system BitmapFactory Unable to decode stream: java.io.FileNotFoundException: /data/system/users/0/wallpaper_orig (No such file or directory) E 486 system WallpaperManagerService Invalid wallpaper data E 486 system WallpaperManagerService Unable to apply new wallpaper W 486 system WallpaperManagerService no current wallpaper -- first boot? I 486 system SystemServer StartAudioService I 486 system SystemServiceManager Starting com.android.server.audio.AudioService$Lifecycle D 229 /system/bin/audioserver PermissionCache checking android.permission.MODIFY_AUDIO_SETTINGS for uid=1000 => granted (1106 us) W 486 system TelecomManager Telecom Service not found. I 486 system SystemServiceManager Starting com.android.server.DockObserver W 486 system DockObserver This kernel does not have dock station support I 486 system SystemServer StartWiredAccessoryManager W 486 system WiredAccessoryManager This kernel does not have wired headset support W 486 system WiredAccessoryManager This kernel does not have usb audio support W 486 system WiredAccessoryManager This kernel does not have HDMI audio support I 486 system SystemServiceManager Starting com.android.server.usb.UsbService$Lifecycle E 486 system AlsaCardRecord Failed to parse line 0 of /proc/asound/cards: --- E 486 system UsbDeviceManager failed to write to /sys/class/android_usb/android0/f_rndis/ethaddr I 486 system SystemServer StartSerialService W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) E 486 system HardwarePropertiesManagerService-JNI Couldn't load thermal module (No such file or directory) I 486 system SystemServiceManager Starting com.android.server.twilight.TwilightService I 486 system SystemServiceManager Starting com.android.server.job.JobSchedulerService I 486 system SystemServiceManager Starting com.android.server.soundtrigger.SoundTriggerService I 486 system SystemServiceManager Starting com.android.server.backup.BackupManagerService$Lifecycle I 486 system SystemServiceManager Starting com.android.server.appwidget.AppWidgetService I 486 system SystemServiceManager Starting com.android.server.voiceinteraction.VoiceInteractionManagerService I 486 system SystemServer Gesture Launcher Service I 486 system SystemServiceManager Starting com.android.server.GestureLauncherService I 486 system SystemServiceManager Starting com.android.server.SensorNotificationService I 486 system SystemServiceManager Starting com.android.server.ContextHubSystemService E 486 system ContextHubService ** Could not load context_hub module : err No such file or directory W 486 system ContextHubService No Context Hub Module present I 486 system SystemServer StartDiskStatsService I 486 system SystemServer StartSamplingProfilerService I 486 system SystemServer StartNetworkTimeUpdateService I 486 system SystemServer StartCommonTimeManagementService I 486 system SystemServer CertBlacklister I 486 system SystemServiceManager Starting com.android.server.emergency.EmergencyAffordanceService I 486 system SystemServiceManager Starting com.android.server.dreams.DreamManagerService I 486 system SystemServer StartAssetAtlasService D 486 system AssetAtlas Computing best atlas configuration... D 486 system AssetAtlas Running Atlas Worker #1 I 486 system SystemServiceManager Starting com.android.server.print.PrintManagerService D 486 system AssetAtlas Running Atlas Worker #2 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system AssetAtlas Running Atlas Worker #4 D 486 system AssetAtlas Running Atlas Worker #3 I 486 system SystemServiceManager Starting com.android.server.restrictions.RestrictionsManagerService I 486 system SystemServiceManager Starting com.android.server.media.MediaSessionService I 486 system SystemServer StartMediaRouterService I 486 system SystemServiceManager Starting com.android.server.trust.TrustManagerService I 486 system SystemServer StartBackgroundDexOptService I 486 system SystemServiceManager Starting com.android.server.pm.ShortcutService$Lifecycle I 486 system SystemServiceManager Starting com.android.server.pm.LauncherAppsService I 486 system SystemServiceManager Starting com.android.server.media.projection.MediaProjectionManagerService V 486 system MediaRouter Adding route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=null types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null } V 486 system MediaRouter Updating audio routes: AudioRoutesInfo{ type=SPEAKER } V 486 system MediaRouter Selecting route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=null types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null } D 486 system AssetAtlas Found best atlas configuration (out of 576) in 0.07s D 486 system AssetAtlas Loaded configuration: SliceMinArea (576x576) flags=0x2 count=91 I 486 system WindowManager SAFE MODE not enabled I 486 system SystemServiceManager Starting com.android.server.MmsServiceBroker I 486 system SystemServiceManager Starting com.android.server.retaildemo.RetailDemoModeService I 486 system ServiceThread Enabled StrictMode logging for RetailDemoModeService looper. I 486 system imx6.gralloc open gpu gralloc module! W 486 system VibratorService Tried to stop vibrating but there is no vibrator device. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system art Background partial concurrent mark sweep GC freed 114531(3MB) AllocSpace objects, 3(60KB) LOS objects, 33% free, 5MB/8MB, paused 3.386ms total 114.473ms E 486 system SQLiteLog (1) no such table: locksettings I 486 system LockSettingsService Migrated lock settings to new location W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system AssetAtlas Rendered atlas in 109.12ms (41.27+67.84ms) I 486 system LockSettingsService Migrated per-user lock settings to new location I 486 system LockSettingsService Migrated biometric weak to use the fallback instead I 486 system LockSettingsService Migrated lockscreen disabled flag E 486 system LockSettingsStorage Cannot read file java.io.FileNotFoundException: /data/system/gatekeeper.password.key: open failed: ENOENT (No such file or directory) E 486 system LockSettingsStorage Cannot read file java.io.FileNotFoundException: /data/system/password.key: open failed: ENOENT (No such file or directory) E 486 system LockSettingsStorage Cannot read file java.io.FileNotFoundException: /data/system/gatekeeper.pattern.key: open failed: ENOENT (No such file or directory) E 486 system LockSettingsStorage Cannot read file java.io.FileNotFoundException: /data/system/gatekeeper.gesture.key: open failed: ENOENT (No such file or directory) E 486 system LockSettingsStorage Cannot read file java.io.FileNotFoundException: /data/system/gesture.key: open failed: ENOENT (No such file or directory) I 486 system SystemServiceManager Starting phase 480 I 486 system SystemServiceManager Starting phase 500 D 486 system ConnectivityMetricsLoggerService onBootPhase: PHASE_SYSTEM_SERVICES_READY I 486 system WifiService WifiService starting up with Wi-Fi disabled I 486 system WifiScanningService Starting wifiscanner W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system RttService Registering rttmanager I 486 system EthernetServiceImpl Starting Ethernet service D 486 system Ethernet Registering NetworkFactory D 486 system ConnectivityService Got NetworkFactory Messenger for Ethernet D 486 system Ethernet got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0 D 486 system EthernetNetworkFactory Started tracking interface eth0 D 238 /system/bin/netd CommandListener Setting iface cfg D 238 /system/bin/netd CommandListener Trying to bring up eth0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system ZenLog config: cleanUpZenRules,ZenModeConfig[user=0,allowCalls=true,allowRepeatCallers=false,allowMessages=false,allowCallsFrom=contacts,allowMessagesFrom=contacts,allowReminders=true,allowEvents=true,allowWhenScreenOff=true,allowWhenScreenOn=true,automaticRules={52f7ad9de46840f68ab58fd3963db759=ZenRule[enabled=false,snoozing=false,name=Event,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/event?userId=-10000&calendar=&reply=1,condition=null,component=ComponentInfo{android/com.android.server.notification.EventConditionProvider},id=52f7ad9de46840f68ab58fd3963db759,creationTime=224631,enabler=null], 47863810e54d4ba3a5eaf7b3dfc0b6d2=ZenRule[enabled=false,snoozing=false,name=Weeknight,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,condition=null,component=ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider},id=47863810e54d4ba3a5eaf7b3dfc0b6d2,creationTime=224629,enabler=null], 115f643d6487490dbf893f006f26ae17=ZenRule[enabled=false,snoozing=false,name=Weekend,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false,condition=null,component=ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider},id=115f643d6487490dbf893f006f26ae17,creationTime=224630,enabler=null]},manualRule=null],Diff[] D 486 system ZenLog set_zen_mode: off,onSystemReady D 229 /system/bin/audioserver PermissionCache checking android.permission.CAPTURE_AUDIO_HOTWORD for uid=1000 => granted (322 us) W 486 system SoundTriggerHelper listModules status=0, # of modules=0 D 486 system ContextHubSystemService onBootPhase: PHASE_SYSTEM_SERVICES_READY I 486 system DefaultPermGrantPolicy Granting permissions to platform components for user 0 D 486 system VoldConnector SND -> {3 volume remount_uid 1001 none} D 207 /system/bin/vold vold Remounting 1001 as mode none W 486 system KeyguardServiceDelegate onScreenTurningOn(): no keyguard service! D 486 system VoldConnector RCV <- {200 3 Command succeeded} D 486 system VoldConnector SND -> {4 volume remount_uid 1001 none} D 207 /system/bin/vold vold Remounting 1001 as mode none W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system VoldConnector RCV <- {200 4 Command succeeded} D 486 system VoldConnector SND -> {5 volume remount_uid 1000 none} D 207 /system/bin/vold vold Remounting 1000 as mode none D 207 /system/bin/vold vold Found matching PID 220 W 207 /system/bin/vold vold Skipping due to root namespace D 207 /system/bin/vold vold Found matching PID 221 W 207 /system/bin/vold vold Skipping due to root namespace D 207 /system/bin/vold vold Found matching PID 240 W 207 /system/bin/vold vold Skipping due to root namespace D 207 /system/bin/vold vold Found matching PID 486 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system VoldConnector RCV <- {200 5 Command succeeded} D 486 system VoldConnector SND -> {6 volume remount_uid 1000 none} D 207 /system/bin/vold vold Remounting 1000 as mode none D 207 /system/bin/vold vold Found matching PID 220 W 207 /system/bin/vold vold Skipping due to root namespace D 207 /system/bin/vold vold Found matching PID 221 W 207 /system/bin/vold vold Skipping due to root namespace D 207 /system/bin/vold vold Found matching PID 240 W 207 /system/bin/vold vold Skipping due to root namespace D 207 /system/bin/vold vold Found matching PID 486 D 486 system VoldConnector RCV <- {200 6 Command succeeded} D 486 system VoldConnector SND -> {7 volume remount_uid 2000 none} D 207 /system/bin/vold vold Remounting 2000 as mode none D 486 system VoldConnector RCV <- {200 7 Command succeeded} D 486 system VoldConnector SND -> {8 volume remount_uid 2000 none} D 207 /system/bin/vold vold Remounting 2000 as mode none D 486 system VoldConnector RCV <- {200 8 Command succeeded} D 486 system VoldConnector SND -> {9 volume remount_uid 10026 none} D 207 /system/bin/vold vold Remounting 10026 as mode none W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system VoldConnector RCV <- {200 9 Command succeeded} D 486 system VoldConnector SND -> {10 volume remount_uid 10026 none} D 207 /system/bin/vold vold Remounting 10026 as mode none D 486 system VoldConnector RCV <- {200 10 Command succeeded} D 486 system VoldConnector SND -> {11 volume remount_uid 1002 none} D 207 /system/bin/vold vold Remounting 1002 as mode none D 486 system VoldConnector RCV <- {200 11 Command succeeded} D 486 system VoldConnector SND -> {12 volume remount_uid 1002 none} D 207 /system/bin/vold vold Remounting 1002 as mode none D 486 system VoldConnector RCV <- {200 12 Command succeeded} I 486 system DefaultPermGrantPolicy Granting permissions to default platform handlers for user 0 W 486 system VoiceInteractionManagerService no available voice interaction services found for user 0 W 486 system VoiceInteractionManagerService no available voice recognition services found for user 0 I 486 system SyncManager No initial accounts I 486 system SyncManager No initial status I 486 system SyncManager No initial statistics W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system VoldConnector SND -> {13 volume remount_uid 10020 none} D 207 /system/bin/vold vold Remounting 10020 as mode none D 486 system VoldConnector RCV <- {200 13 Command succeeded} D 486 system VoldConnector SND -> {14 volume remount_uid 10035 none} D 207 /system/bin/vold vold Remounting 10035 as mode none D 486 system VoldConnector RCV <- {200 14 Command succeeded} D 486 system VoldConnector SND -> {15 volume remount_uid 10035 none} D 207 /system/bin/vold vold Remounting 10035 as mode none D 486 system VoldConnector RCV <- {200 15 Command succeeded} D 486 system VoldConnector SND -> {16 volume remount_uid 10012 none} D 207 /system/bin/vold vold Remounting 10012 as mode none D 486 system VoldConnector RCV <- {200 16 Command succeeded} D 486 system VoldConnector SND -> {17 volume remount_uid 10012 none} D 207 /system/bin/vold vold Remounting 10012 as mode none D 486 system VoldConnector RCV <- {200 17 Command succeeded} D 486 system VoldConnector SND -> {18 volume remount_uid 10015 none} D 207 /system/bin/vold vold Remounting 10015 as mode none D 486 system VoldConnector RCV <- {200 18 Command succeeded} D 486 system VoldConnector SND -> {19 volume remount_uid 10015 none} D 207 /system/bin/vold vold Remounting 10015 as mode none D 486 system VoldConnector RCV <- {200 19 Command succeeded} D 486 system VoldConnector SND -> {20 volume remount_uid 10004 none} D 207 /system/bin/vold vold Remounting 10004 as mode none D 486 system VoldConnector RCV <- {200 20 Command succeeded} D 486 system VoldConnector SND -> {21 volume remount_uid 10004 none} D 207 /system/bin/vold vold Remounting 10004 as mode none D 486 system VoldConnector RCV <- {200 21 Command succeeded} D 486 system VoldConnector SND -> {22 volume remount_uid 10045 none} D 207 /system/bin/vold vold Remounting 10045 as mode none D 486 system VoldConnector RCV <- {200 22 Command succeeded} D 486 system VoldConnector SND -> {23 volume remount_uid 10045 none} D 207 /system/bin/vold vold Remounting 10045 as mode none D 486 system VoldConnector RCV <- {200 23 Command succeeded} D 486 system VoldConnector SND -> {24 volume remount_uid 10049 none} D 207 /system/bin/vold vold Remounting 10049 as mode none W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system VoldConnector RCV <- {200 24 Command succeeded} D 486 system VoldConnector SND -> {25 volume remount_uid 10049 none} D 207 /system/bin/vold vold Remounting 10049 as mode none D 486 system VoldConnector RCV <- {200 25 Command succeeded} D 486 system VoldConnector SND -> {26 volume remount_uid 10025 none} D 207 /system/bin/vold vold Remounting 10025 as mode none D 486 system VoldConnector RCV <- {200 26 Command succeeded} D 486 system VoldConnector SND -> {27 volume remount_uid 10025 none} D 207 /system/bin/vold vold Remounting 10025 as mode none D 486 system VoldConnector RCV <- {200 27 Command succeeded} V 486 system UserManagerService Found /data/user_de/0 with serial number -1 D 486 system UserManagerService Serial number missing on /data/user_de/0; assuming current is valid V 486 system UserManagerService Found /data/user/0 with serial number -1 D 486 system UserManagerService Serial number missing on /data/user/0; assuming current is valid V 486 system UserManagerService Found /data/system_de/0 with serial number -1 D 486 system UserManagerService Serial number missing on /data/system_de/0; assuming current is valid I 486 system ActivityManager System now ready W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session, android.view.IWindow) for 398ms I 486 system SystemServer Making services ready I 486 system SystemServiceManager Starting phase 550 D 486 system BluetoothManagerService Bluetooth boot completed D 486 system BluetoothManagerService Getting adapter name and address D 486 system BluetoothManagerService Message: 200 D 486 system BluetoothManagerService MESSAGE_GET_NAME_AND_ADDRESS D 486 system BluetoothManagerService Binding to service to get name and address I 486 system Zygote Process: zygote socket opened, supported ABIS: armeabi-v7a,armeabi I 486 system ActivityManager Start proc 1014:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService E 486 system InputMethodManagerService Ignoring updateSystemUiLocked due to an invalid token. uid:1000 token:null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system MountService No primary storage defined yet; hacking together a stub D 1014 AdapterServiceConfig Adding HeadsetService D 1014 AdapterServiceConfig Adding A2dpService D 1014 AdapterServiceConfig Adding A2dpSinkService D 1014 AdapterServiceConfig Adding HidService D 1014 AdapterServiceConfig Adding HealthService D 1014 AdapterServiceConfig Adding PanService W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 1014 AdapterServiceConfig Adding GattService D 1014 AdapterServiceConfig Adding BluetoothMapService D 1014 AdapterServiceConfig Adding AvrcpControllerService W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system BluetoothManagerService Message: 20 D 486 system BluetoothManagerService Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@ce40445:true D 1014 com.android.bluetooth BluetoothAdapterService onCreate() D 1014 com.android.bluetooth BluetoothAdapterState make() - Creating AdapterState I 1014 com.android.bluetooth bt_btif init I 1014 com.android.bluetooth BluetoothAdapterState Entering OffState W 1014 com.android.bluetooth bt_osi_thread run_thread: thread id 1033, thread name stack_manager started I 1014 com.android.bluetooth bt_stack_manager event_init_stack is initializing the stack I 1014 com.android.bluetooth bt_core_module module_init Initializing module "osi_module" I 1014 com.android.bluetooth bt_core_module module_init Initialized module "osi_module" I 1014 com.android.bluetooth bt_core_module module_init Initializing module "bt_utils_module" I 1014 com.android.bluetooth bt_core_module module_init Initialized module "bt_utils_module" I 1014 com.android.bluetooth bt_core_module module_init Initializing module "btif_config_module" E 1014 com.android.bluetooth bt_osi_config config_new unable to open file '/data/misc/bluedroid/bt_config.conf': No such file or directory W 1014 com.android.bluetooth %s unable to load config file: %s; using backup. init E 1014 com.android.bluetooth bt_osi_config config_new unable to open file '/data/misc/bluedroid/bt_config.bak': No such file or directory W 1014 com.android.bluetooth %s unable to load backup; attempting to transcode legacy file. init E 1014 com.android.bluetooth %s unable to load XML file '%s': %d config_t *btif_config_transcode(const char *) E 1014 com.android.bluetooth %s unable to transcode legacy file; creating empty config. init W 1014 com.android.bluetooth bt_osi_thread run_thread: thread id 1036, thread name alarm_default_ca started W 1014 com.android.bluetooth bt_osi_thread run_thread: thread id 1037, thread name alarm_dispatcher started I 1014 com.android.bluetooth bt_core_module module_init Initialized module "btif_config_module" I 1014 com.android.bluetooth bt_core_module module_init Initializing module "interop_module" I 1014 com.android.bluetooth bt_core_module module_init Initialized module "interop_module" I 1014 com.android.bluetooth bt_core_module module_init Initializing module "stack_config_module" I 1014 com.android.bluetooth bt_stack_config init attempt to load stack conf from /etc/bluetooth/bt_stack.conf I 1014 com.android.bluetooth bt_core_module module_init Initialized module "stack_config_module" W 1014 com.android.bluetooth bt_osi_thread run_thread: thread id 1038, thread name bt_jni_workqueue started I 1014 com.android.bluetooth bt_stack_manager event_init_stack finished I 1014 com.android.bluetooth bt_osi_wakelock wakelock_set_os_callouts set to non-native I 1014 com.android.bluetooth bt_btif get_profile_interface socket D 1014 com.android.bluetooth BluetoothAdapterProperties Address is:22:22:51:75:5E:58 D 1014 com.android.bluetooth BluetoothAdapterProperties Name is: iMX6 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1014 com.android.bluetooth bt_btif get_profile_interface sdp D 1014 com.android.bluetooth BluetoothAdapterService setAdapterService() - set to: null D 1014 com.android.bluetooth BluetoothAdapterService onBind() W 486 system WindowManager Keyguard drawn timeout. Setting mKeyguardDrawComplete W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService$LocalService.setOnHardKeyboardStatusChangeListener(android.view.WindowManagerInternal$OnHardKeyboardStatusChangeListener) for 476ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system InputMethodManagerService Reset the default IME as "Resource" is ready here. I 486 system InputMethodManagerService Default found, using com.android.inputmethod.latin/.LatinIME W 486 system InputMethodManagerService Illegal subtype state: old subtype = null, new subtype = android.view.inputmethod.InputMethodSubtype@c9194f98 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system ActivityManager Start proc 1039:com.android.inputmethod.latin/u0a47 for service com.android.inputmethod.latin/.LatinIME V 486 system InputMethodManagerService Adding window token: android.os.Binder@cb76fd W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1039 LatinIME Hardware accelerated drawing: true W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowManagerService.showStrictModeViolation(int, int)(WindowManagerService.java:6257) waiters=0 in void com.android.server.wm.WindowManagerService.addWindowToken(android.os.IBinder, int) for 368ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system EthernetNetworkFactory updateInterface: eth0 link up D 486 system EthernetNetworkFactory starting ipProvisioningThread(eth0): mNetworkInfo=[type: Ethernet[], state: UNKNOWN/IDLE, reason: (unspecified), extra: b6:d9:69:8f:41:44, failover: false, available: true, roaming: false, metered: false] D 238 /system/bin/netd CommandListener Clearing all IP addresses on eth0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system DhcpClient Receive thread started D 486 system DhcpClient Broadcasting DHCPDISCOVER W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowManagerService$H.handleMessage(android.os.Message)(WindowManagerService.java:8361) waiters=0 in void com.android.server.wm.WindowManagerService.addWindowToken(android.os.IBinder, int) for 535ms D 486 system MountService Thinking about init, mSystemReady=true, mDaemonConnected=true W 486 system WindowManager Timeout waiting for drawn: undrawn=[Window{db0591e u0 KeyguardScrim}] D 486 system MountService Setting up emulation state, initlocked=false W 486 system art Long monitor contention with owner main (486) at void com.android.server.wm.WindowManagerService.addWindowToken(android.os.IBinder, int)(WindowManagerService.java:3434) waiters=0 in java.util.List com.android.server.InputMethodManagerService.getInputMethodList() for 780ms D 486 system CryptdConnector SND -> {2 cryptfs unlock_user_key 0 0 ! !} D 207 /system/bin/vold vold e4crypt_unlock_user_key 0 serial=0 token_present=0 E 207 /system/bin/vold vold Failed to chmod /data/system_ce/0: No such file or directory E 207 /system/bin/vold vold Failed to chmod /data/misc_ce/0: No such file or directory E 207 /system/bin/vold vold Failed to chmod /data/media/0: No such file or directory D 486 system CryptdConnector RCV <- {200 2 Command succeeded} D 486 system MountService Thinking about reset, mSystemReady=true, mDaemonConnected=true D 486 system VoldConnector SND -> {28 volume reset} I 486 system ActivityManager Force stopping com.android.providers.media appid=10012 user=-1: vold reset D 486 system VoldConnector RCV <- {651 emulated 7} D 486 system VoldConnector RCV <- {659 emulated} D 486 system VoldConnector RCV <- {650 emulated 2 "" ""} D 486 system VoldConnector RCV <- {651 emulated 0} D 486 system VoldConnector RCV <- {200 28 Command succeeded} D 486 system VoldConnector SND -> {29 volume user_added 0 0} D 486 system BluetoothManagerService Message: 20 D 486 system BluetoothManagerService Added callback: android.bluetooth.BluetoothAdapter$1@58b8595:true V 486 system MountService Found primary storage at VolumeInfo{emulated}: V 486 system MountService type=EMULATED diskId=null partGuid=null mountFlags=0 mountUserId=-1 V 486 system MountService state=UNMOUNTED V 486 system MountService fsType=null fsUuid=null fsLabel=null V 486 system MountService path=null internalPath=null D 486 system BluetoothManagerService Message: 30 D 486 system VoldConnector RCV <- {200 29 Command succeeded} D 486 system BluetoothManagerService Trying to bind to profile: 1, while Bluetooth was disabled D 486 system VoldConnector SND -> {30 volume mount emulated 3 -1} D 486 system BluetoothManagerService Message: 30 D 486 system VoldConnector RCV <- {651 emulated 1} D 486 system VoldConnector RCV <- {656 emulated /data/media} V 207 /system/bin/vold vold Waiting for FUSE to spin up... D 486 system VoldConnector RCV <- {655 emulated /storage/emulated} I 486 system SystemServer WebViewFactory preparation I 229 /system/bin/audioserver AudioFlinger systemReady D 486 system WebViewFactory Setting new address space to 104857600 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1063 sdcard Device explicitly disabled sdcardfs D 486 system VoldConnector RCV <- {651 emulated 2} D 486 system VoldConnector RCV <- {200 30 Command succeeded} I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 486 system ActivityManager Start proc 1072:WebViewLoader-armeabi-v7a/1037 [android.webkit.WebViewFactory$RelroFileCreator] for E 237 /system/bin/mediaserver OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 237 /system/bin/mediaserver OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 237 /system/bin/mediaserver OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 237 /system/bin/mediaserver OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 237 /system/bin/mediaserver OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 237 /system/bin/mediaserver OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 237 /system/bin/mediaserver OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 237 /system/bin/mediaserver OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 237 /system/bin/mediaserver OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 237 /system/bin/mediaserver OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 237 /system/bin/mediaserver OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 237 /system/bin/mediaserver OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 237 /system/bin/mediaserver OMXMaster A component of name 'OMX.Freescale.std.parser.streaming.sw-based' already exists, ignoring this one. E 237 /system/bin/mediaserver OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. I 486 system ActivityManager Start proc 1080:com.android.systemui/u0a26 for service com.android.systemui/.SystemUIService W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system NetworkManagement enabling bandwidth control E 234 media.codec OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 234 media.codec OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 234 media.codec OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 234 media.codec OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 234 media.codec OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 234 media.codec OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 234 media.codec OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 234 media.codec OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 234 media.codec OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 234 media.codec OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 234 media.codec OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 234 media.codec OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. E 234 media.codec OMXMaster A component of name 'OMX.Freescale.std.parser.streaming.sw-based' already exists, ignoring this one. E 234 media.codec OMXMaster A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one. I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.gsm.decoder) in mediacodec process V 1072 der WebViewFactory RelroFileCreator (64bit = false), 32-bit lib: /system/app/webview/webview.apk!/lib/armeabi-v7a/libwebviewchromium.so, 64-bit lib: W 1080 com.android.systemui System ClassLoader referenced unknown path: /system/priv-app/SystemUI/lib/arm W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) V 1080 com.android.systemui SystemUIService Starting SystemUI services for user 0. I 1072 der art System.exit called, status: 0 I 1072 der AndroidRuntime VM exiting with result code 0, cleanup skipped. I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.video_encoder.mpeg4.hw-based) in mediacodec process W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system NetworkManagement setDataSaverMode(): already false W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out V 1080 com.android.systemui MediaRouter Adding route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=null types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null } W 1039 com.android.inputmethod.latin InputAttributes No editor info for this field. Bug? V 1080 com.android.systemui MediaRouter Updating audio routes: AudioRoutesInfo{ type=SPEAKER } I 234 media.codec vpu-lib Product Info: i.MX6Q/D/S V 1080 com.android.systemui MediaRouter Selecting route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=null types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null } W 237 /system/bin/mediaserver ACodec do not know color format 0x7f000789 = 2130708361 I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: GetConfig LINE: 1828 I 234 media.codec OMXPlayer GetConfig: failure: unsupported index: 0x6F60000A W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) E 234 media.codec OMXNodeInstance getConfig(ea0002:Freescale.std._encoder.mpeg4.hw-based, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: UnsupportedIndex(0x8000101a) I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: DeInitFilterComponent LINE: 2003 I 234 media.codec OMXPlayer DeInitFilterComponent: vpu close failure: ret=0x3 I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.video_encoder.h263.hw-based) in mediacodec process I 1039 com.android.inputmethod.latin LatinIME:LogUtils Dictionary info: dictionary = userunigram.en_US ; version = 228 ; date = ? E 1039 com.android.inputmethod.latin ActivityThread Failed to find provider info for user_dictionary V 1080 com.android.systemui FingerprintManager FingerprintManagerService was null I 1039 com.android.inputmethod.latin LatinIME:LogUtils Dictionary info: dictionary = UserHistoryDictionary.en_US ; version = 228 ; date = ? W 1080 com.android.systemui FingerprintManager isFingerprintHardwareDetected(): Service not connected! W 1080 com.android.systemui FingerprintManager addLockoutResetCallback(): Service not connected! W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system NetworkPolicy setRestrictBackgroundUL(): false W 486 system NetworkManagement setDataSaverMode(): already false W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 234 media.codec vpu-lib Product Info: i.MX6Q/D/S W 237 /system/bin/mediaserver ACodec do not know color format 0x7f000789 = 2130708361 I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: GetConfig LINE: 1828 I 234 media.codec OMXPlayer GetConfig: failure: unsupported index: 0x6F60000A E 234 media.codec OMXNodeInstance getConfig(ea0003:Freescale.std._encoder.h263.hw-based, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: UnsupportedIndex(0x8000101a) I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: DeInitFilterComponent LINE: 2003 I 234 media.codec OMXPlayer DeInitFilterComponent: vpu close failure: ret=0x3 I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.video_encoder.avc.hw-based) in mediacodec process I 1039 com.android.inputmethod.latin BinaryDictionaryFileDumper reinitializeClientRecordInDictionaryContentProvider() : MetadataFileUri = W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1080 com.android.systemui vol.Events writeEvent collection_started I 1080 com.android.systemui vol.Events writeEvent external_ringer_mode_changed normal I 1080 com.android.systemui vol.Events writeEvent internal_ringer_mode_changed normal I 486 system SystemServiceManager Starting phase 600 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 234 media.codec vpu-lib Product Info: i.MX6Q/D/S W 237 /system/bin/mediaserver ACodec do not know color format 0x7f000789 = 2130708361 I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: GetConfig LINE: 1828 I 234 media.codec OMXPlayer GetConfig: failure: unsupported index: 0x6F60000A E 234 media.codec OMXNodeInstance getConfig(ea0004:Freescale.std._encoder.avc.hw-based, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: UnsupportedIndex(0x8000101a) I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: DeInitFilterComponent LINE: 2003 I 234 media.codec OMXPlayer DeInitFilterComponent: vpu close failure: ret=0x3 I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.video_decoder.avc.v3.hw-based) in mediacodec process I 1039 com.android.inputmethod.latin LatinIME:LogUtils Dictionary info: dictionary = main:de ; version = 54 ; date = 1414726263 W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out I 1039 com.android.inputmethod.latin LatinIME:LogUtils Dictionary info: dictionary = main:en ; version = 54 ; date = 1414726273 I 1039 com.android.inputmethod.latin LatinIME:LogUtils Dictionary info: dictionary = main:es ; version = 54 ; date = 1414726268 D 486 system SensorNotificationService Cannot obtain dynamic meta sensor, not supported. I 486 system CameraManagerGlobal Connecting to camera service I 1039 com.android.inputmethod.latin LatinIME:LogUtils Dictionary info: dictionary = main:fr ; version = 54 ; date = 1414726264 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system LocationManagerService no network location provider found E 486 system LocationManagerService no geocoder provider found E 486 system FlpHardwareProvider Error hw_get_module 'flp': -2 D 486 system LocationManagerService FLP HAL not supported D 486 system LocationManagerService Unable to bind FLP Geofence proxy. E 486 system ActivityRecognitionHardware Error hw_get_module: -2 D 486 system LocationManagerService Hardware Activity-Recognition not supported. E 486 system ActivityRecognitionProxy ServiceWatcher could not start. D 486 system LocationManagerService Unable to bind ActivityRecognitionProxy. I 486 system CommonTimeManagementService No common time service detected on this platform. Common time services will be unavailable. I 486 system InputReader Reconfiguring input devices. changes=0x00000020 I 486 system MmsServiceBroker Delay connecting to MmsService until an API is called W 486 system VoiceInteractionManagerService no available voice interaction services found for user 0 W 486 system VoiceInteractionManagerService no available voice recognition services found for user 0 I 1039 com.android.inputmethod.latin LatinIME:LogUtils Dictionary info: dictionary = main:it ; version = 54 ; date = 1414726258 I 486 system InputReader Reconfiguring input devices. changes=0x00000010 I 486 system ActivityManager Start proc 1149:com.android.phone/1001 for added application com.android.phone I 486 system ActivityManager START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000100 cmp=com.android.settings/.CryptKeeper} from uid 0 on display 0 I 486 system ActivityManager Loaded persisted task ids for user 0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system DhcpClient Received packet: b6:d9:69:8f:41:44 OFFER, ip /192.168.10.226, mask /255.255.0.0, DNS servers: /203.248.252.2 /164.124.101.2 , gateways [/192.168.10.1] lease time 604800, domain null D 486 system DhcpClient Got pending lease: IP address 192.168.10.226/16 Gateway 192.168.10.1 DNS servers: [ 203.248.252.2 164.124.101.2 ] Domains DHCP server /192.168.10.1 Vendor info null lease 604800 seconds I 486 system ActivityManager Start proc 1163:com.android.settings:CryptKeeper/1000 for activity com.android.settings/.CryptKeeper I 486 system SystemServer Enabled StrictMode for system server main thread. D 486 system DhcpClient Broadcasting DHCPREQUEST ciaddr=0.0.0.0 request=192.168.10.226 serverid=192.168.10.1 W 237 /system/bin/mediaserver ACodec [OMX.Freescale.std.video_decoder.avc.v3.hw-based] stopping checking profiles after 32: 8/1 D 486 system ConditionProviders.SCP onConnected E 234 media.codec OMXNodeInstance getExtensionIndex(ea0005:Freescale.std._decoder.avc.v3.hw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006) W 234 media.codec OMXNodeInstance [ea0005:Freescale.std._decoder.avc.v3.hw-based] component does not support metadata mode; using fallback D 486 system DhcpClient Received packet: b6:d9:69:8f:41:44 ACK: your new IP /192.168.10.226, netmask /255.255.0.0, gateways [/192.168.10.1] DNS servers: /203.248.252.2 /164.124.101.2 , lease time 604800 D 486 system DhcpClient Confirmed lease: IP address 192.168.10.226/16 Gateway 192.168.10.1 DNS servers: [ 203.248.252.2 164.124.101.2 ] Domains DHCP server /192.168.10.1 Vendor info null lease 604800 seconds I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.video_decoder.mpeg4.hw-based) in mediacodec process W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 238 /system/bin/netd CommandListener Setting iface cfg I 1039 com.android.inputmethod.latin LatinIME:LogUtils Dictionary info: dictionary = main:ru ; version = 54 ; date = 1414726277 W 1149 System ClassLoader referenced unknown path: /system/priv-app/TeleService/lib/arm D 486 system RttService SCAN_AVAILABLE : 1 I 486 system WifiScanningService wifi driver unloaded D 486 system ZenLog set_zen_mode: off,cleanUpZenRules D 486 system RttService DefaultState got{ when=0 what=160513 target=com.android.internal.util.StateMachine$SmHandler } D 486 system ConditionProviders Subscribing to condition://android/event?userId=-10000&calendar=&reply=1 with ComponentInfo{android/com.android.server.notification.EventConditionProvider} D 486 system ZenLog subscribe: condition://android/event?userId=-10000&calendar=&reply=1,ok D 486 system ConditionProviders Subscribing to condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false with ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider} D 486 system ZenLog subscribe: condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,ok D 486 system ConditionProviders Subscribing to condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false with ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider} D 486 system ZenLog subscribe: condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false,ok D 486 system ConnectivityService registerNetworkAgent NetworkAgentInfo{ ni{[type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: b6:d9:69:8f:41:44, failover: false, available: true, roaming: false, metered: false]} network{100} nethandle{429513165534} lp{{InterfaceName: eth0 LinkAddresses: [fe80::b4d9:69ff:fe8f:4144/64,192.168.10.226/16,] Routes: [fe80::/64 -> :: eth0,192.168.0.0/16 -> 0.0.0.0 eth0,0.0.0.0/0 -> 192.168.10.1 eth0,] DnsAddresses: [203.248.252.2,164.124.101.2,] Domains: null MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}} nc{[ Transports: ETHERNET Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN LinkUpBandwidth>=100000Kbps LinkDnBandwidth>=100000Kbps]} Score{110} everValidated{false} lastValidated{false} created{false} lingering{false} explicitlySelected{false} acceptUnvalidated{false} everCaptivePortalDetected{false} lastCaptivePortalDetected{false} } D 486 system EthernetNetworkFactory exiting ipProvisioningThread(eth0): mNetworkInfo=[type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: b6:d9:69:8f:41:44, failover: false, available: true, roaming: false, metered: false] D 486 system ConnectivityService NetworkAgentInfo [Ethernet () - 100] EVENT_NETWORK_INFO_CHANGED, going from null to CONNECTED D 486 system ConnectivityService Adding iface eth0 to network 100 I 486 system art Background sticky concurrent mark sweep GC freed 43462(2MB) AllocSpace objects, 11(232KB) LOS objects, 35% free, 5MB/8MB, paused 10.176ms total 135.237ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1039 com.android.inputmethod.latin BinaryDictionaryFileDumper reinitializeClientRecordInDictionaryContentProvider() : Insert DictionaryInfo : Id = 'main:de' : Locale=de : Version=54 D 486 system BluetoothManagerService Message: 100 E 486 system BluetoothManagerService MESSAGE_TIMEOUT_BIND D 486 system ConnectivityService Setting DNS servers for network 100 to [/203.248.252.2, /164.124.101.2] I 486 system AccountManagerService Creating DE database for user 0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) E 234 media.codec OMXNodeInstance getExtensionIndex(ea0006:Freescale.std._decoder.mpeg4.hw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006) W 234 media.codec OMXNodeInstance [ea0006:Freescale.std._decoder.mpeg4.hw-based] component does not support metadata mode; using fallback I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.video_decoder.h263.hw-based) in mediacodec process W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out D 221 /system/bin/surfaceflinger PermissionCache checking android.permission.READ_FRAME_BUFFER for uid=1000 => granted (3193 us) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system ContextImpl Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1357 com.android.server.content.SyncManager$13.run:658 android.os.Handler.handleCallback:751 android.os.Handler.dispatchMessage:95 android.os.Looper.loop:154 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) E 234 media.codec OMXNodeInstance getExtensionIndex(ea0007:Freescale.std._decoder.h263.hw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006) W 234 media.codec OMXNodeInstance [ea0007:Freescale.std._decoder.h263.hw-based] component does not support metadata mode; using fallback I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.video_decoder.mpeg2.hw-based) in mediacodec process W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) E 234 media.codec OMXNodeInstance getExtensionIndex(ea0008:Freescale.std._decoder.mpeg2.hw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006) W 234 media.codec OMXNodeInstance [ea0008:Freescale.std._decoder.mpeg2.hw-based] component does not support metadata mode; using fallback I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.video_decoder.vpx.hw-based) in mediacodec process W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) E 234 media.codec OMXNodeInstance getParameter(ea0009:Freescale.std._decoder.vpx.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) E 234 media.codec OMXNodeInstance getExtensionIndex(ea0009:Freescale.std._decoder.vpx.hw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006) W 234 media.codec OMXNodeInstance [ea0009:Freescale.std._decoder.vpx.hw-based] component does not support metadata mode; using fallback I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.video_decoder.soft_hevc.sw-based) in mediacodec process W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out E 234 media.codec OMXNodeInstance getParameter(ea000a:Freescale.std._decoder.soft_hevc.sw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a) E 234 media.codec OMXNodeInstance getExtensionIndex(ea000a:Freescale.std._decoder.soft_hevc.sw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006) W 234 media.codec OMXNodeInstance [ea000a:Freescale.std._decoder.soft_hevc.sw-based] component does not support metadata mode; using fallback I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.video_decoder.wmv.sw-based) in mediacodec process W 486 system art Long monitor contention with owner Binder:486_2 (514) at void com.android.server.wm.WindowManagerService.startAppFreezingScreen(android.os.IBinder, int)(WindowManagerService.java:4805) waiters=0 in void com.android.server.wm.WindowAnimator$1.doFrame(long) for 713ms W 486 system art Long monitor contention with owner Binder:486_2 (514) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=0 in int com.android.server.am.ActivityManagerService.getAppStartMode(int, java.lang.String) for 876ms W 486 system art Long monitor contention with owner Binder:486_2 (514) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=1 in android.content.pm.UserInfo com.android.server.am.UserController.getCurrentUser() for 826ms W 486 system art Long monitor contention with owner Binder:486_2 (514) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=2 in void com.android.server.am.PendingIntentRecord.completeFinalize() for 818ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system art Long monitor contention with owner Binder:486_2 (514) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=3 in void com.android.server.am.ActivityManagerService.addPackageDependency(java.lang.String) for 798ms W 486 system art Long monitor contention with owner Binder:486_2 (514) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=4 in int com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread, android.content.Intent, java.lang.String, android.content.IIntentReceiver, int, java.lang.String, android.os.Bundle, java.lang.String[], int, android.os.Bundle, boolean, boolean, int) for 740ms W 486 system art Long monitor contention with owner Binder:486_2 (514) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=5 in int com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread, android.content.Intent, java.lang.String, android.content.IIntentReceiver, int, java.lang.String, android.os.Bundle, java.lang.String[], int, android.os.Bundle, boolean, boolean, int) for 726ms W 486 system art Long monitor contention with owner Binder:486_2 (514) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=6 in android.content.ComponentName com.android.server.am.ActivityManagerService.startService(android.app.IApplicationThread, android.content.Intent, java.lang.String, java.lang.String, int) for 584ms W 1149 com.android.phone System ClassLoader referenced unknown path: /system/priv-app/TelephonyProvider/lib/arm D 1149 com.android.phone ApplicationLoaders ignored Vulkan layer search path /system/priv-app/TelephonyProvider/lib/arm:/system/lib:/vendor/lib for namespace 0xb34a1090 D 486 system DhcpClient Scheduling renewal in 302399s D 486 system DhcpClient Scheduling rebind in 529199s D 486 system DhcpClient Scheduling expiry in 604799s W 1163 pre System ClassLoader referenced unknown path: /system/priv-app/Settings/lib/arm W 486 system System ClassLoader referenced unknown path: /system/priv-app/Telecom/lib/arm I 1039 com.android.inputmethod.latin BinaryDictionaryFileDumper reinitializeClientRecordInDictionaryContentProvider() : Insert DictionaryInfo : Id = 'main:en' : Locale=en : Version=54 D 486 system ApplicationLoaders ignored Vulkan layer search path /system/priv-app/Telecom/lib/arm:/system/priv-app/Telecom/Telecom.apk!/lib/armeabi-v7a:/system/lib:/vendor/lib for namespace 0xb32cc110 D 486 system ConnectivityService Switching to new default network: NetworkAgentInfo{ ni{[type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: b6:d9:69:8f:41:44, failover: false, available: true, roaming: false, metered: false]} network{100} nethandle{429513165534} lp{{InterfaceName: eth0 LinkAddresses: [fe80::b4d9:69ff:fe8f:4144/64,192.168.10.226/16,] Routes: [fe80::/64 -> :: eth0,192.168.0.0/16 -> 0.0.0.0 eth0,0.0.0.0/0 -> 192.168.10.1 eth0,] DnsAddresses: [203.248.252.2,164.124.101.2,] Domains: null MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}} nc{[ Transports: ETHERNET Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN&FOREGROUND LinkUpBandwidth>=100000Kbps LinkDnBandwidth>=100000Kbps]} Score{110} everValidated{false} lastValidated{false} created{true} lingering{false} explicitlySelected{false} acceptUnvalidated{false} everCaptivePortalDetected{false} lastCaptivePortalDetected{false} } D 486 system ConnectivityService Sending CONNECTED broadcast for type 9 NetworkAgentInfo [Ethernet () - 100] isDefaultNetwork=true W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system BluetoothManagerService Message: 30 D 486 system BluetoothManagerService Trying to bind to profile: 1, while Bluetooth was disabled I 486 system Telecom SystemStateProvider: Registering car mode receiver: android.content.IntentFilter@c68015: TS.init@AAA D 486 system SntpClient round trip: 8ms, clock offset: 1499221972566ms I 486 system Telecom Telecom: Non-call EVENT: AUDIO_ROUTE, Entering state QuiescentEarpieceRoute I 486 system Telecom CallAudioModeStateMachine: Message received: null.: TS.init->CAMSM.pM_1@AAA_0 E 486 system ActivityThread Failed to find provider info for call_log I 1080 com.android.systemui vol.Events writeEvent level_changed STREAM_ALARM 6 D 486 system BluetoothManagerService Message: 30 D 486 system BluetoothManagerService Trying to bind to profile: 1, while Bluetooth was disabled I 234 media.codec OMXPlayer Can't open library: lib_WMV789_dec_v2_arm11_elinux.so I 234 media.codec OMXPlayer dlopen failed: library "lib_WMV789_dec_v2_arm11_elinux.so" not found I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: ConstructComponent LINE: 574 I 234 media.codec OMXPlayer Can't initialize component. I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: OMX_GetHandle LINE: 498 I 234 media.codec OMXPlayer Load and call entry function fail. E 234 media.codec OMX FAILED to allocate omx component 'OMX.Freescale.std.video_decoder.wmv.sw-based' err=ComponentNotFound(0x80001003) I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 1080 com.android.systemui vol.Events writeEvent level_changed STREAM_BLUETOOTH_SCO 7 I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.video_decoder.wmv9.hw-based) in mediacodec process E 234 media.codec OMX FAILED to allocate omx component 'OMX.Freescale.std.video_decoder.wmv9.hw-based' err=InvalidComponentName(0x80001002) I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.video_decoder.rv.hw-based) in mediacodec process I 486 system Telecom Class: TelecomSystem.INSTANCE being set W 486 system ContextImpl Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1357 android.content.ContextWrapper.startService:613 com.android.server.telecom.components.TelecomService.initializeTelecomSystem:176 com.android.server.telecom.components.TelecomService.onBind:61 android.app.ActivityThread.handleBindService:3218 D 486 system BluetoothManagerService Bluetooth Adapter name changed to iMX6 D 486 system BluetoothManagerService Stored Bluetooth name: iMX6 D 486 system BluetoothManagerService BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService D 486 system BluetoothManagerService Message: 40 D 486 system BluetoothManagerService MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1 D 486 system BluetoothManagerService Message: 200 D 486 system BluetoothManagerService MESSAGE_GET_NAME_AND_ADDRESS D 486 system BluetoothManagerService Stored Bluetooth name: iMX6 I 1080 com.android.systemui vol.Events writeEvent level_changed STREAM_MUSIC 11 D 486 system BluetoothManagerService Stored Bluetoothaddress: 22:22:51:75:5E:58 D 486 system BluetoothManagerService unbindAndFinish(): android.bluetooth.IBluetooth$Stub$Proxy@57ec68e mBinding = false D 486 system BluetoothManagerService Sending unbind request. D 1014 com.android.bluetooth BluetoothAdapterService onUnbind() - calling cleanup D 1014 com.android.bluetooth BluetoothAdapterService cleanup() W 1014 com.android.bluetooth BluetoothSdpJni Cleaning up Bluetooth SDP Interface... W 1014 com.android.bluetooth BluetoothSdpJni Cleaning up Bluetooth SDP object D 1014 com.android.bluetooth BluetoothAdapterService cleanup() - Cleaning up adapter native I 1080 com.android.systemui vol.Events writeEvent level_changed STREAM_RING 5 I 1080 com.android.systemui vol.Events writeEvent level_changed STREAM_SYSTEM 5 W 486 system System ClassLoader referenced unknown path: /system/priv-app/FusedLocation/lib/arm D 486 system ApplicationLoaders ignored Vulkan layer search path /system/priv-app/FusedLocation/lib/arm:/system/priv-app/FusedLocation/FusedLocation.apk!/lib/armeabi-v7a:/system/lib:/vendor/lib for namespace 0xb32cc150 I 1014 com.android.bluetooth bt_stack_manager event_clean_up_stack is cleaning up the stack E 1014 com.android.bluetooth BluetoothServiceJni Callback env check fail: env: 0x0, callback: 0xa9d05850 E 1014 com.android.bluetooth BluetoothServiceJni Callback: 'callback_thread_event' is not called on the correct thread W 1014 com.android.bluetooth bt_osi_thread run_thread: thread id 1038, thread name bt_jni_workqueue exited E 234 media.codec OMXNodeInstance getParameter(ea000b:Freescale.std._decoder.rv.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a) E 234 media.codec OMXNodeInstance getExtensionIndex(ea000b:Freescale.std._decoder.rv.hw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006) W 234 media.codec OMXNodeInstance [ea000b:Freescale.std._decoder.rv.hw-based] component does not support metadata mode; using fallback I 1039 com.android.inputmethod.latin BinaryDictionaryFileDumper reinitializeClientRecordInDictionaryContentProvider() : Insert DictionaryInfo : Id = 'main:es' : Locale=es : Version=54 I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX V 486 system WiredAccessoryManager init() I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.video_decoder.divx.hw-based) in mediacodec process I 1080 com.android.systemui vol.Events writeEvent level_changed STREAM_VOICE_CALL 4 E 234 media.codec OMXNodeInstance getParameter(ea000c:Freescale.std._decoder.divx.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a) E 234 media.codec OMXNodeInstance getExtensionIndex(ea000c:Freescale.std._decoder.divx.hw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006) W 234 media.codec OMXNodeInstance [ea000c:Freescale.std._decoder.divx.hw-based] component does not support metadata mode; using fallback I 1014 com.android.bluetooth bt_core_module module_clean_up Cleaning up module "stack_config_module" I 1014 com.android.bluetooth bt_core_module module_clean_up Cleanup of module "stack_config_module" completed I 1014 com.android.bluetooth bt_core_module module_clean_up Cleaning up module "interop_module" I 1014 com.android.bluetooth bt_core_module module_clean_up Cleanup of module "interop_module" completed I 1014 com.android.bluetooth bt_core_module module_clean_up Cleaning up module "btif_config_module" I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.video_decoder.div4.hw-based) in mediacodec process W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) E 234 media.codec OMXNodeInstance getParameter(ea000d:Freescale.std._decoder.div4.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a) E 234 media.codec OMXNodeInstance getExtensionIndex(ea000d:Freescale.std._decoder.div4.hw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006) W 234 media.codec OMXNodeInstance [ea000d:Freescale.std._decoder.div4.hw-based] component does not support metadata mode; using fallback I 1014 com.android.bluetooth bt_core_module module_clean_up Cleanup of module "btif_config_module" completed I 1014 com.android.bluetooth bt_core_module module_clean_up Cleaning up module "bt_utils_module" I 1014 com.android.bluetooth bt_core_module module_clean_up Cleanup of module "bt_utils_module" completed I 1014 com.android.bluetooth bt_core_module module_clean_up Cleaning up module "osi_module" D 1014 com.android.bluetooth bt_osi_alarm callback_dispatch Callback thread exited W 1014 com.android.bluetooth bt_osi_thread run_thread: thread id 1037, thread name alarm_dispatcher exited W 1014 com.android.bluetooth bt_osi_thread run_thread: thread id 1036, thread name alarm_default_ca exited I 1014 com.android.bluetooth bt_core_module module_clean_up Cleanup of module "osi_module" completed I 1014 com.android.bluetooth bt_stack_manager event_clean_up_stack finished I 1014 com.android.bluetooth BluetoothServiceJni cleanupNative: return from cleanup I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.video_decoder.div3.hw-based) in mediacodec process I 1014 com.android.bluetooth art System.exit called, status: 0 I 1014 com.android.bluetooth AndroidRuntime VM exiting with result code 0, cleanup skipped. I 1039 com.android.inputmethod.latin BinaryDictionaryFileDumper reinitializeClientRecordInDictionaryContentProvider() : Insert DictionaryInfo : Id = 'main:fr' : Locale=fr : Version=54 E 234 media.codec OMXNodeInstance getParameter(ea000e:Freescale.std._decoder.div3.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a) E 234 media.codec OMXNodeInstance getExtensionIndex(ea000e:Freescale.std._decoder.div3.hw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006) W 234 media.codec OMXNodeInstance [ea000e:Freescale.std._decoder.div3.hw-based] component does not support metadata mode; using fallback I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.video_decoder.xvid.hw-based) in mediacodec process E 234 media.codec OMXNodeInstance getParameter(ea000f:Freescale.std._decoder.xvid.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a) E 234 media.codec OMXNodeInstance getExtensionIndex(ea000f:Freescale.std._decoder.xvid.hw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006) W 234 media.codec OMXNodeInstance [ea000f:Freescale.std._decoder.xvid.hw-based] component does not support metadata mode; using fallback I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 1039 com.android.inputmethod.latin BinaryDictionaryFileDumper reinitializeClientRecordInDictionaryContentProvider() : Insert DictionaryInfo : Id = 'main:it' : Locale=it : Version=54 I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.video_decoder.mjpeg.hw-based) in mediacodec process E 234 media.codec OMXNodeInstance getParameter(ea0010:Freescale.std._decoder.mjpeg.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a) E 234 media.codec OMXNodeInstance getExtensionIndex(ea0010:Freescale.std._decoder.mjpeg.hw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006) W 234 media.codec OMXNodeInstance [ea0010:Freescale.std._decoder.mjpeg.hw-based] component does not support metadata mode; using fallback I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.video_decoder.sorenson.sw-based) in mediacodec process E 234 media.codec OMXNodeInstance getParameter(ea0011:Freescale.std._decoder.sorenson.sw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a) E 234 media.codec OMXNodeInstance getExtensionIndex(ea0011:Freescale.std._decoder.sorenson.sw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006) W 234 media.codec OMXNodeInstance [ea0011:Freescale.std._decoder.sorenson.sw-based] component does not support metadata mode; using fallback W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) E 234 media.codec OMXNodeInstance setParameter(ea0011:Freescale.std._decoder.sorenson.sw-based, OMX.google.android.index.prepareForAdaptivePlayback(0x7f00003d): Output:1 en=1 max=1280x720) ERROR: UnsupportedIndex(0x8000101a) I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.audio_decoder.ac3.sw-based) in mediacodec process I 234 media.codec OMXPlayer Can't open library: lib_ac3d_wrap_arm11_elinux_android.so I 234 media.codec OMXPlayer dlopen failed: library "lib_ac3d_wrap_arm11_elinux_android.so" not found I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: CreateDecoderInterface LINE: 293 I 234 media.codec OMXPlayer Fail to open Decoder library for )V?? I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: CreateDecoderInterface LINE: 332 I 234 media.codec OMXPlayer UniaDecoder::CreateDecoderInterface ret=-2147479549 I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: ConstructComponent LINE: 574 I 234 media.codec OMXPlayer Can't initialize component. I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: OMX_GetHandle LINE: 498 I 234 media.codec OMXPlayer Load and call entry function fail. E 234 media.codec OMX FAILED to allocate omx component 'OMX.Freescale.std.audio_decoder.ac3.sw-based' err=ComponentNotFound(0x80001003) I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.audio_decoder.ec3.sw-based) in mediacodec process I 234 media.codec OMXPlayer Unia -> EC3 I 234 media.codec OMXPlayer Can't open library: lib_ddpd_wrap_arm12_elinux_android.so I 234 media.codec OMXPlayer dlopen failed: library "lib_ddpd_wrap_arm12_elinux_android.so" not found I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: CreateDecoderInterface LINE: 293 I 234 media.codec OMXPlayer Fail to open Decoder library for ]? I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: CreateDecoderInterface LINE: 332 I 234 media.codec OMXPlayer UniaDecoder::CreateDecoderInterface ret=-2147479549 I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: ConstructComponent LINE: 574 I 234 media.codec OMXPlayer Can't initialize component. I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: OMX_GetHandle LINE: 498 I 234 media.codec OMXPlayer Load and call entry function fail. E 234 media.codec OMX FAILED to allocate omx component 'OMX.Freescale.std.audio_decoder.ec3.sw-based' err=ComponentNotFound(0x80001003) I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.audio_decoder.wma.sw-based) in mediacodec process I 1039 com.android.inputmethod.latin BinaryDictionaryFileDumper reinitializeClientRecordInDictionaryContentProvider() : Insert DictionaryInfo : Id = 'main:ru' : Locale=ru : Version=54 I 234 media.codec OMXPlayer Can't open library: lib_wma10d_wrap_arm12_elinux_android.so I 234 media.codec OMXPlayer dlopen failed: library "lib_wma10d_wrap_arm12_elinux_android.so" not found I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: CreateDecoderInterface LINE: 293 I 234 media.codec OMXPlayer Fail to open Decoder library for !??? I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: CreateDecoderInterface LINE: 332 I 234 media.codec OMXPlayer UniaDecoder::CreateDecoderInterface ret=-2147479549 I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: ConstructComponent LINE: 574 I 234 media.codec OMXPlayer Can't initialize component. I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: OMX_GetHandle LINE: 498 I 234 media.codec OMXPlayer Load and call entry function fail. E 234 media.codec OMX FAILED to allocate omx component 'OMX.Freescale.std.audio_decoder.wma.sw-based' err=ComponentNotFound(0x80001003) I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.audio_decoder.flac.sw-based) in mediacodec process I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.audio_decoder.mp3.sw-based) in mediacodec process I 486 system ActivityManager Process com.android.bluetooth (pid 1014) has died D 486 system ActivityManager cleanUpApplicationRecord -- 1014 D 486 system ConnectivityService NetworkAgentInfo [Ethernet () - 100] validation failed I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.audio_decoder.amr.sw-based) in mediacodec process W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in float com.android.server.wm.WindowManagerService.getCurrentAnimatorScale() for 429ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in float com.android.server.wm.WindowManagerService.getCurrentAnimatorScale() for 259ms I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=2 in void com.android.server.wm.WindowManagerService.setScreenCaptureDisabled(int, boolean) for 247ms I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.audio_decoder.amrwb.sw-based) in mediacodec process I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.audio_decoder.aac.sw-based) in mediacodec process D 1163 pre CryptKeeper Disabling component ComponentInfo{com.android.settings/com.android.settings.CryptKeeper} I 486 system WindowManager Screen frozen for +1s429ms due to AppWindowToken{32e09bb token=Token{8c5afb5 ActivityRecord{a8e1fec u0 com.android.settings/.CryptKeeper t1}}} I 234 media.codec OMXPlayer Can't open library: lib_aacplusd_wrap_arm12_elinux_android.so I 234 media.codec OMXPlayer dlopen failed: library "lib_aacplusd_wrap_arm12_elinux_android.so" not found I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.audio_decoder.ra.sw-based) in mediacodec process I 234 media.codec OMXPlayer Unia -> REAL I 234 media.codec OMXPlayer Can't open library: lib_realad_wrap_arm11_elinux_android.so I 234 media.codec OMXPlayer dlopen failed: library "lib_realad_wrap_arm11_elinux_android.so" not found I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: CreateDecoderInterface LINE: 293 I 234 media.codec OMXPlayer Fail to open Decoder library for DÞ? I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: CreateDecoderInterface LINE: 332 I 234 media.codec OMXPlayer UniaDecoder::CreateDecoderInterface ret=-2147479549 I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: ConstructComponent LINE: 574 I 234 media.codec OMXPlayer Can't initialize component. I 234 media.codec OMXPlayer LEVEL: 1 FUNCTION: OMX_GetHandle LINE: 498 I 234 media.codec OMXPlayer Load and call entry function fail. E 234 media.codec OMX FAILED to allocate omx component 'OMX.Freescale.std.audio_decoder.ra.sw-based' err=ComponentNotFound(0x80001003) I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.Freescale.std.audio_decoder.ape.sw-based) in mediacodec process W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.mpeg4.decoder) in mediacodec process E 234 media.codec OMXNodeInstance getExtensionIndex(ea0018:google.mpeg4.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a) W 234 media.codec OMXNodeInstance [ea0018:google.mpeg4.decoder] component does not support metadata mode; using fallback I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.h263.decoder) in mediacodec process E 234 media.codec OMXNodeInstance getExtensionIndex(ea0019:google.h263.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a) W 234 media.codec OMXNodeInstance [ea0019:google.h263.decoder] component does not support metadata mode; using fallback I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.h264.decoder) in mediacodec process W 237 /system/bin/mediaserver ACodec [OMX.google.h264.decoder] stopping checking profiles after 32: 2/8000 E 234 media.codec OMXNodeInstance getExtensionIndex(ea001a:google.h264.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a) W 234 media.codec OMXNodeInstance [ea001a:google.h264.decoder] component does not support metadata mode; using fallback I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.hevc.decoder) in mediacodec process I 486 system art Background partial concurrent mark sweep GC freed 29539(2MB) AllocSpace objects, 5(100KB) LOS objects, 33% free, 4MB/7MB, paused 2.512ms total 120.865ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) E 234 media.codec OMXNodeInstance getExtensionIndex(ea001b:google.hevc.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a) W 234 media.codec OMXNodeInstance [ea001b:google.hevc.decoder] component does not support metadata mode; using fallback I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.vp8.decoder) in mediacodec process E 234 media.codec OMXNodeInstance getExtensionIndex(ea001c:google.vp8.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a) W 234 media.codec OMXNodeInstance [ea001c:google.vp8.decoder] component does not support metadata mode; using fallback I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.vp9.decoder) in mediacodec process E 234 media.codec OMXNodeInstance getExtensionIndex(ea001d:google.vp9.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a) W 234 media.codec OMXNodeInstance [ea001d:google.vp9.decoder] component does not support metadata mode; using fallback I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.h263.encoder) in mediacodec process I 234 media.codec SoftMPEG4Encoder Construct SoftMPEG4Encoder W 237 /system/bin/mediaserver ACodec do not know color format 0x7f000789 = 2130708361 E 234 media.codec OMXNodeInstance getConfig(ea001e:google.h263.encoder, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: Undefined(0x80001001) I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.h264.encoder) in mediacodec process W 237 /system/bin/mediaserver ACodec do not know color format 0x7f000789 = 2130708361 I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.mpeg4.encoder) in mediacodec process I 234 media.codec SoftMPEG4Encoder Construct SoftMPEG4Encoder W 237 /system/bin/mediaserver ACodec do not know color format 0x7f000789 = 2130708361 E 234 media.codec OMXNodeInstance getConfig(ea0020:google.mpeg4.encoder, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: Undefined(0x80001001) I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.vp8.encoder) in mediacodec process W 237 /system/bin/mediaserver ACodec do not know color format 0x7f000789 = 2130708361 E 234 media.codec OMXNodeInstance getConfig(ea0021:google.vp8.encoder, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: Undefined(0x80001001) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.mp3.decoder) in mediacodec process I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.amrnb.decoder) in mediacodec process I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.amrwb.decoder) in mediacodec process I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.aac.decoder) in mediacodec process I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.g711.alaw.decoder) in mediacodec process I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.g711.mlaw.decoder) in mediacodec process I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.opus.decoder) in mediacodec process I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.raw.decoder) in mediacodec process I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.aac.encoder) in mediacodec process W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.amrnb.encoder) in mediacodec process I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.amrwb.encoder) in mediacodec process I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.flac.encoder) in mediacodec process I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver OMXClient MuxOMX ctor W 237 /system/bin/mediaserver MediaCodecList unable to open media codecs configuration xml file: /data/misc/media/media_codecs_profiling_results.xml I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 486 system OMXClient MuxOMX ctor I 1080 com.android.systemui OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process I 234 media.codec OMXMaster makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 486 system OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process D 1149 com.android.phone TelephonyProvider dbh.onCreate:+ db=SQLiteDatabase: /data/user_de/0/com.android.providers.telephony/databases/telephony.db D 1149 com.android.phone TelephonyProvider dbh.createSimInfoTable:+ D 1149 com.android.phone TelephonyProvider dbh.createSimInfoTable:- D 1149 com.android.phone TelephonyProvider dbh.createCarriersTable: carriers D 1149 com.android.phone TelephonyProvider dbh.createCarriersTable:- D 1149 com.android.phone TelephonyProvider No APNs in OEM image = /oem/telephony/apns-conf.xml Load APNs from system image D 1149 com.android.phone TelephonyProvider No APNs in OEM image = /data/misc/apns-conf.xml Load APNs from system image D 1149 com.android.phone TelephonyProvider confFile = /system/etc/apns-conf.xml W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 1080 com.android.systemui OMXClient MuxOMX ctor W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 234 media.codec OMXMaster makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process D 1149 com.android.phone TelephonyProvider Checksum for /system/etc/apns-conf.xml is 1215094405 D 1149 com.android.phone TelephonyProvider dbh.onCreate:- db=SQLiteDatabase: /data/user_de/0/com.android.providers.telephony/databases/telephony.db I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 486 system OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process D 1149 com.android.phone TelephonyProvider dbh.onOpen: ok, queried table=siminfo D 1149 com.android.phone TelephonyProvider dbh.onOpen: ok, queried table=carriers D 1149 com.android.phone TelephonyProvider onCreate: build id changed from to 1.0.0-ga-rc10 D 1149 com.android.phone TelephonyProvider No APNs in OEM image = /oem/telephony/apns-conf.xml Load APNs from system image D 1149 com.android.phone TelephonyProvider No APNs in OEM image = /data/misc/apns-conf.xml Load APNs from system image D 1149 com.android.phone TelephonyProvider Checksum for /system/etc/apns-conf.xml is 1215094405 D 1149 com.android.phone TelephonyProvider newChecksum: 1215094405 D 1149 com.android.phone TelephonyProvider oldChecksum: 1215094405 D 1149 com.android.phone TelephonyProvider Skipping apn db update since apn-conf has not changed. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 1080 com.android.systemui OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 486 system OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 486 system OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 486 system OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system ConnectivityService NetworkAgentInfo [Ethernet () - 100] validation failed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner Binder:486_1 (513) at boolean com.android.server.am.ActivityManagerService.finishActivity(android.os.IBinder, int, android.content.Intent, int)(ActivityManagerService.java:4838) waiters=0 in void com.android.server.am.ActivityManagerService.setRenderThread(int) for 2.165s W 486 system art Long monitor contention with owner Binder:486_1 (513) at boolean com.android.server.am.ActivityManagerService.finishActivity(android.os.IBinder, int, android.content.Intent, int)(ActivityManagerService.java:4838) waiters=1 in void com.android.server.am.ActivityManagerService.updateLockTaskPackages(int, java.lang.String[]) for 2.145s W 486 system art Long monitor contention with owner Binder:486_1 (513) at boolean com.android.server.am.ActivityManagerService.finishActivity(android.os.IBinder, int, android.content.Intent, int)(ActivityManagerService.java:4838) waiters=2 in int com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread, android.content.Intent, java.lang.String, android.content.IIntentReceiver, int, java.lang.String, android.os.Bundle, java.lang.String[], int, android.os.Bundle, boolean, boolean, int) for 2.145s W 486 system art Long monitor contention with owner Binder:486_1 (513) at boolean com.android.server.am.ActivityManagerService.finishActivity(android.os.IBinder, int, android.content.Intent, int)(ActivityManagerService.java:4838) waiters=3 in void com.android.server.am.ActivityManagerService$MainHandler.handleMessage(android.os.Message) for 1.782s W 486 system art Long monitor contention with owner Binder:486_1 (513) at boolean com.android.server.am.ActivityManagerService.finishActivity(android.os.IBinder, int, android.content.Intent, int)(ActivityManagerService.java:4838) waiters=4 in void com.android.server.am.ActivityManagerService.publishContentProviders(android.app.IApplicationThread, java.util.List) for 1.515s W 486 system art Long monitor contention with owner Binder:486_1 (513) at boolean com.android.server.am.ActivityManagerService.finishActivity(android.os.IBinder, int, android.content.Intent, int)(ActivityManagerService.java:4838) waiters=5 in int com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread, android.content.Intent, java.lang.String, android.content.IIntentReceiver, int, java.lang.String, android.os.Bundle, java.lang.String[], int, android.os.Bundle, boolean, boolean, int) for 1.310s I 1039 com.android.inputmethod.latin BinaryDictionaryFileDumper reinitializeClientRecordInDictionaryContentProvider() : Insert DictionaryInfo : Id = 'main:en_us' : Locale=en_US : Version=-1 I 1080 com.android.systemui imx6.gralloc open gpu gralloc module! W 486 system VibratorService Tried to stop vibrating but there is no vibrator device. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.resumeKeyDispatching(android.os.IBinder) for 485ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out I 486 system Choreographer Skipped 31 frames! The application may be doing too much work on its main thread. W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in int com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.view.InputChannel) for 1.013s W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system ConnectivityService NetworkAgentInfo [Ethernet () - 100] validation failed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in void com.android.server.wm.WindowManagerService.resumeKeyDispatching(android.os.IBinder) for 1.090s W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in int com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.view.InputChannel) for 543ms I 486 system ActivityManager START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000100 cmp=com.android.settings/.FallbackHome} from uid 0 on display 0 I 486 system ActivityManager Start proc 1332:com.android.settings/1000 for activity com.android.settings/.FallbackHome W 486 system art Long monitor contention with owner Binder:486_4 (1106) at void com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java:6915) waiters=0 in android.content.pm.UserInfo com.android.server.am.UserController.getCurrentUser() for 1.595s W 486 system art Long monitor contention with owner Binder:486_4 (1106) at void com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java:6915) waiters=2 in android.content.Intent com.android.server.am.ActivityManagerService.registerReceiver(android.app.IApplicationThread, java.lang.String, android.content.IIntentReceiver, android.content.IntentFilter, java.lang.String, int) for 1.569s W 486 system art Long monitor contention with owner Binder:486_4 (1106) at void com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java:6915) waiters=1 in int com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread, android.content.Intent, java.lang.String, android.content.IIntentReceiver, int, java.lang.String, android.os.Bundle, java.lang.String[], int, android.os.Bundle, boolean, boolean, int) for 1.588s W 486 system art Long monitor contention with owner Binder:486_4 (1106) at void com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java:6915) waiters=3 in void com.android.server.am.ActivityManagerService$MainHandler.handleMessage(android.os.Message) for 1.399s W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.prepareAppTransition(int, boolean) for 486ms W 486 system art Long monitor contention with owner ActivityManager (516) at void com.android.server.am.ActivityStackSupervisor$ActivityStackSupervisorHandler.handleMessage(android.os.Message)(ActivityStackSupervisor.java:3884) waiters=1 in int com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread, android.content.Intent, java.lang.String, android.content.IIntentReceiver, int, java.lang.String, android.os.Bundle, java.lang.String[], int, android.os.Bundle, boolean, boolean, int) for 486ms W 486 system art Long monitor contention with owner ActivityManager (516) at void com.android.server.am.ActivityStackSupervisor$ActivityStackSupervisorHandler.handleMessage(android.os.Message)(ActivityStackSupervisor.java:3884) waiters=1 in android.content.Intent com.android.server.am.ActivityManagerService.registerReceiver(android.app.IApplicationThread, java.lang.String, android.content.IIntentReceiver, android.content.IntentFilter, java.lang.String, int) for 489ms W 486 system art Long monitor contention with owner ActivityManager (516) at void com.android.server.am.ActivityStackSupervisor$ActivityStackSupervisorHandler.handleMessage(android.os.Message)(ActivityStackSupervisor.java:3884) waiters=4 in int com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread, android.content.Intent, java.lang.String, android.content.IIntentReceiver, int, java.lang.String, android.os.Bundle, java.lang.String[], int, android.os.Bundle, boolean, boolean, int) for 485ms W 486 system art Long monitor contention with owner ActivityManager (516) at void com.android.server.am.ActivityStackSupervisor$ActivityStackSupervisorHandler.handleMessage(android.os.Message)(ActivityStackSupervisor.java:3884) waiters=3 in int com.android.server.am.ActivityManagerService.getAppStartMode(int, java.lang.String) for 489ms W 486 system art Long monitor contention with owner ActivityManager (516) at void com.android.server.am.ActivityStackSupervisor$ActivityStackSupervisorHandler.handleMessage(android.os.Message)(ActivityStackSupervisor.java:3884) waiters=2 in android.content.Intent com.android.server.am.ActivityManagerService.registerReceiver(android.app.IApplicationThread, java.lang.String, android.content.IIntentReceiver, android.content.IntentFilter, java.lang.String, int) for 492ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system art Long monitor contention with owner ActivityManager (516) at void com.android.server.am.ActivityStackSupervisor$ActivityStackSupervisorHandler.handleMessage(android.os.Message)(ActivityStackSupervisor.java:3884) waiters=6 in void com.android.server.am.ActivityManagerService$LocalService.notifyAppTransitionFinished() for 1.113s W 486 system art Long monitor contention with owner ActivityManager (516) at void com.android.server.am.ActivityManagerService$MainHandler.handleMessage(android.os.Message)(ActivityManagerService.java:2082) waiters=6 in int com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread, android.content.Intent, java.lang.String, android.content.IIntentReceiver, int, java.lang.String, android.os.Bundle, java.lang.String[], int, android.os.Bundle, boolean, boolean, int) for 1.112s W 486 system art Long monitor contention with owner NetworkStats (975) at int com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread, android.content.Intent, java.lang.String, android.content.IIntentReceiver, int, java.lang.String, android.os.Bundle, java.lang.String[], int, android.os.Bundle, boolean, boolean, int)(ActivityManagerService.java:18504) waiters=4 in int com.android.server.am.ActivityManagerService.getAppStartMode(int, java.lang.String) for 1.110s W 486 system art Long monitor contention with owner Binder:486_5 (1182) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=3 in android.content.Intent com.android.server.am.ActivityManagerService.registerReceiver(android.app.IApplicationThread, java.lang.String, android.content.IIntentReceiver, android.content.IntentFilter, java.lang.String, int) for 1.108s W 486 system art Long monitor contention with owner Binder:486_5 (1182) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=4 in void com.android.server.am.BroadcastQueue.processNextBroadcast(boolean) for 1.109s W 486 system art Long monitor contention with owner Binder:486_5 (1182) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=5 in void com.android.server.am.ActivityManagerService.finishReceiver(android.os.IBinder, int, java.lang.String, android.os.Bundle, boolean, int) for 1.107s W 486 system art Long monitor contention with owner Binder:486_5 (1182) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=6 in android.content.Intent com.android.server.am.ActivityManagerService.registerReceiver(android.app.IApplicationThread, java.lang.String, android.content.IIntentReceiver, android.content.IntentFilter, java.lang.String, int) for 1.078s W 1039 com.android.inputmethod.latin BinaryDictionaryFileDumper Missing metadata.json resource D 486 system ConditionProviders.SCP onSubscribe condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false D 486 system ConditionProviders.SCP setRegistered true D 486 system ConditionProviders.SCP notifyCondition condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false STATE_TRUE reason=meetsSchedule D 486 system ConditionProviders.SCP Scheduling evaluate for Thu Jan 01 07:00:00 GMT+00:00 1970 (25200000), in +6h56m4s309ms, now=Thu Jan 01 00:03:55 GMT+00:00 1970 (235691) D 486 system ConditionProviders.SCP onSubscribe condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false D 486 system ConditionProviders.SCP notifyCondition condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false STATE_FALSE reason=!meetsSchedule D 486 system ConditionProviders.SCP notifyCondition condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false STATE_TRUE reason=meetsSchedule D 486 system ConditionProviders.SCP Scheduling evaluate for Thu Jan 01 07:00:00 GMT+00:00 1970 (25200000), in +6h56m4s303ms, now=Thu Jan 01 00:03:55 GMT+00:00 1970 (235697) I 486 system Telecom WiredHeadsetManager: ACTION_HEADSET_PLUG event, plugged in: false, : WHC.oADA@AAE D 1080 com.android.systemui StorageNotification Notifying about private volume: VolumeInfo{private}: D 1080 com.android.systemui StorageNotification type=PRIVATE diskId=null partGuid=null mountFlags=0 mountUserId=-1 D 1080 com.android.systemui StorageNotification state=MOUNTED D 1080 com.android.systemui StorageNotification fsType=null fsUuid=null fsLabel=null D 1080 com.android.systemui StorageNotification path=/data internalPath=null W 1332 System ClassLoader referenced unknown path: /system/priv-app/Settings/lib/arm E 486 system ActivityThread Failed to find provider info for com.android.calendar E 486 system ActivityThread Failed to find provider info for com.android.calendar I 486 system ActivityManager user 0 is still locked. Cannot load recents I 486 system SyncManager Got SyncJobService instance. I 1039 com.android.inputmethod.latin LatinIME:LogUtils Dictionary info: dictionary = main:en ; version = 54 ; date = 1414726273 I 1039 com.android.inputmethod.latin LatinIME:LogUtils Dictionary info: dictionary = main:en ; version = 54 ; date = 1414726273 I 1039 com.android.inputmethod.latin LatinIME:LogUtils Dictionary info: dictionary = main:en ; version = 54 ; date = 1414726273 I 486 system DefaultPermGrantPolicy Granting permissions to default dialer app for user:0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system Telecom PhoneAccountRegistrar: SimCallManager queried, returning: null: TSI.gSCM@AAM I 1039 com.android.inputmethod.latin LatinIME:LogUtils Dictionary info: dictionary = main:en ; version = 54 ; date = 1414726273 D 486 system ZenLog config: conditionChanged,ZenModeConfig[user=0,allowCalls=true,allowRepeatCallers=false,allowMessages=false,allowCallsFrom=contacts,allowMessagesFrom=contacts,allowReminders=true,allowEvents=true,allowWhenScreenOff=true,allowWhenScreenOn=true,automaticRules={52f7ad9de46840f68ab58fd3963db759=ZenRule[enabled=false,snoozing=false,name=Event,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/event?userId=-10000&calendar=&reply=1,condition=null,component=ComponentInfo{android/com.android.server.notification.EventConditionProvider},id=52f7ad9de46840f68ab58fd3963db759,creationTime=224631,enabler=null], 47863810e54d4ba3a5eaf7b3dfc0b6d2=ZenRule[enabled=false,snoozing=false,name=Weeknight,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,condition=Condition[id=condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,summary=...,line1=...,line2=...,icon=0,state=STATE_TRUE,flags=2],component=ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider},id=47863810e54d4ba3a5eaf7b3dfc0b6d2,creationTime=224629,enabler=null], 115f643d6487490dbf893f006f26ae17=ZenRule[enabled=false,snoozing=false,name=Weekend,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false,condition=null,component=ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider},id=115f643d6487490dbf893f006f26ae17,creationTime=224630,enabler=null]},manualRule=null],Diff[automaticRule[47863810e54d4ba3a5eaf7b3dfc0b6d2].condition:null->Condition[id=condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,summary=...,line1=...,line2=...,icon=0,state=STATE_TRUE,flags=2]] I 1039 com.android.inputmethod.latin LatinIME:LogUtils Dictionary info: dictionary = main:en ; version = 54 ; date = 1414726273 D 486 system ZenLog config: conditionChanged,ZenModeConfig[user=0,allowCalls=true,allowRepeatCallers=false,allowMessages=false,allowCallsFrom=contacts,allowMessagesFrom=contacts,allowReminders=true,allowEvents=true,allowWhenScreenOff=true,allowWhenScreenOn=true,automaticRules={52f7ad9de46840f68ab58fd3963db759=ZenRule[enabled=false,snoozing=false,name=Event,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/event?userId=-10000&calendar=&reply=1,condition=null,component=ComponentInfo{android/com.android.server.notification.EventConditionProvider},id=52f7ad9de46840f68ab58fd3963db759,creationTime=224631,enabler=null], 47863810e54d4ba3a5eaf7b3dfc0b6d2=ZenRule[enabled=false,snoozing=false,name=Weeknight,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,condition=Condition[id=condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,summary=...,line1=...,line2=...,icon=0,state=STATE_TRUE,flags=2],component=ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider},id=47863810e54d4ba3a5eaf7b3dfc0b6d2,creationTime=224629,enabler=null], 115f643d6487490dbf893f006f26ae17=ZenRule[enabled=false,snoozing=false,name=Weekend,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false,condition=Condition[id=condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false,summary=...,line1=...,line2=...,icon=0,state=STATE_FALSE,flags=2],component=ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider},id=115f643d6487490dbf893f006f26ae17,creationTime=224630,enabler=null]},manualRule=null],Diff[automaticRule[115f643d6487490dbf893f006f26ae17].condition:null->Condition[id=condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false,summary=...,line1=...,line2=...,icon=0,state=STATE_FALSE,flags=2]] D 486 system ZenLog config: conditionChanged,ZenModeConfig[user=0,allowCalls=true,allowRepeatCallers=false,allowMessages=false,allowCallsFrom=contacts,allowMessagesFrom=contacts,allowReminders=true,allowEvents=true,allowWhenScreenOff=true,allowWhenScreenOn=true,automaticRules={52f7ad9de46840f68ab58fd3963db759=ZenRule[enabled=false,snoozing=false,name=Event,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/event?userId=-10000&calendar=&reply=1,condition=Condition[id=condition://android/event?userId=-10000&calendar=&reply=1,summary=...,line1=...,line2=...,icon=0,state=STATE_FALSE,flags=2],component=ComponentInfo{android/com.android.server.notification.EventConditionProvider},id=52f7ad9de46840f68ab58fd3963db759,creationTime=224631,enabler=null], 47863810e54d4ba3a5eaf7b3dfc0b6d2=ZenRule[enabled=false,snoozing=false,name=Weeknight,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,condition=Condition[id=condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,summary=...,line1=...,line2=...,icon=0,state=STATE_TRUE,flags=2],component=ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider},id=47863810e54d4ba3a5eaf7b3dfc0b6d2,creationTime=224629,enabler=null], 115f643d6487490dbf893f006f26ae17=ZenRule[enabled=false,snoozing=false,name=Weekend,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false,condition=Condition[id=condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false,summary=...,line1=...,line2=...,icon=0,state=STATE_FALSE,flags=2],component=ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider},id=115f643d6487490dbf893f006f26ae17,creationTime=224630,enabler=null]},manualRule=null],Diff[automaticRule[52f7ad9de46840f68ab58fd3963db759].condition:null->Condition[id=condition://android/event?userId=-10000&calendar=&reply=1,summary=...,line1=...,line2=...,icon=0,state=STATE_FALSE,flags=2]] I 486 system FusedLocation engine started (com.android.location.fused) D 486 system ZenLog set_zen_mode: off,conditionChanged D 486 system DhcpClient Received packet: 20:d5:ab:e9:d9:cd ACK: your new IP /192.168.10.189, netmask /255.255.0.0, gateways [/192.168.10.1] DNS servers: /203.248.252.2 /164.124.101.2 , lease time 604800 D 486 system ZenLog set_zen_mode: off,conditionChanged W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1039 com.android.inputmethod.latin LatinIME:LogUtils Dictionary info: dictionary = main:en ; version = 54 ; date = 1414726273 I 486 system ActivityManager Start proc 1368:com.android.cellbroadcastreceiver/u0a6 for broadcast com.android.cellbroadcastreceiver/.CellBroadcastReceiver D 486 system ZenLog set_zen_mode: off,conditionChanged I 1332 com.android.settings imx6.gralloc open gpu gralloc module! I 1039 com.android.inputmethod.latin LatinIME:LogUtils Dictionary info: dictionary = main:en ; version = 54 ; date = 1414726273 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1039 com.android.inputmethod.latin LatinIME:LogUtils Dictionary info: dictionary = main:en ; version = 54 ; date = 1414726273 I 1080 com.android.systemui Choreographer Skipped 207 frames! The application may be doing too much work on its main thread. I 486 system art Background sticky concurrent mark sweep GC freed 23626(1943KB) AllocSpace objects, 8(204KB) LOS objects, 23% free, 5MB/7MB, paused 5.980ms total 154.708ms W 1368 com.android.cellbroadcastreceiver System ClassLoader referenced unknown path: /system/priv-app/CellBroadcastReceiver/lib/arm W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1149 com.android.phone SystemConfig No directory /system/etc/sysconfig, skipping D 1149 com.android.phone PhoneSwitcherNetworkRequstListener Registering NetworkFactory D 486 system ConnectivityService Got NetworkFactory Messenger for PhoneSwitcherNetworkRequstListener W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out D 486 system ConnectivityService Got NetworkFactory Messenger for TelephonyNetworkFactory[0] W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system AlarmManagerService Setting time of day to sec=1499222209 W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out D 486 system ConditionProviders.SCP onReceive android.intent.action.TIME_SET D 486 system ConditionProviders.SCP notifyCondition condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false STATE_FALSE reason=!meetsSchedule D 486 system ConditionProviders.SCP notifyCondition condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false STATE_TRUE reason=meetsSchedule D 486 system ConditionProviders.SCP Scheduling evaluate for Wed Jul 05 07:00:00 GMT+00:00 2017 (1499238000000), in +4h23m10s690ms, now=Wed Jul 05 02:36:49 GMT+00:00 2017 (1499222209310) W 486 system art Long monitor contention with owner Binder:486_4 (1106) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=0 in void com.android.server.wm.WindowManagerService.showStrictModeViolation(int, int) for 744ms D 486 system ConditionProviders.SCP onReceive ScheduleConditionProvider.EVALUATE D 486 system ConditionProviders.SCP notifyCondition condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false STATE_FALSE reason=!meetsSchedule W 486 system art Long monitor contention with owner Binder:486_4 (1106) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=2 in float com.android.server.wm.WindowManagerService.getCurrentAnimatorScale() for 556ms D 486 system ConditionProviders.SCP notifyCondition condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false STATE_TRUE reason=meetsSchedule D 486 system ConditionProviders.SCP Scheduling evaluate for Wed Jul 05 07:00:00 GMT+00:00 2017 (1499238000000), in +4h23m10s682ms, now=Wed Jul 05 02:36:49 GMT+00:00 2017 (1499222209318) W 486 system art Long monitor contention with owner Binder:486_4 (1106) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=1 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 749ms E 486 system ActivityThread Failed to find provider info for com.android.calendar E 486 system ActivityThread Failed to find provider info for com.android.calendar E 486 system ActivityThread Failed to find provider info for com.android.calendar E 486 system ActivityThread Failed to find provider info for com.android.calendar W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1332 com.android.settings OpenGLRenderer Initialized EGL, version 1.4 D 1332 com.android.settings OpenGLRenderer Swap behavior 2 E 1149 com.android.phone ActivityThread Failed to find provider info for com.android.contacts W 1149 com.android.phone CallerInfoCache cursor is null D 1149 com.android.phone CarrierConfigLoader CarrierConfigLoader has started D 486 system BluetoothManagerService Message: 20 D 486 system BluetoothManagerService Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@dc31793:true D 486 system BluetoothManagerService Message: 30 D 486 system BluetoothManagerService Trying to bind to profile: 1, while Bluetooth was disabled I 1149 com.android.phone Telephony TtyManager: updateUiTtyMode -1 -> 0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 1149 com.android.phone PhoneSwitcherNetworkRequstListener got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 110 D 1149 com.android.phone TelephonyDebugService TelephonyDebugService() D 1149 com.android.phone CarrierConfigLoader mHandler: 12 phoneId: 0 D 1149 com.android.phone CarrierConfigLoader Build fingerprint changed. old: null new: Freescale/sabresd_6dq/sabresd_6dq:7.1.1/1.0.0-ga-rc10/20170227:eng/release-keys E 1149 com.android.phone PhoneInterfaceManager [PhoneIntfMgr] getIccId: No UICC W 486 system Telecom : registerPhoneAccount not allowed on non-voice capable device.: TSI.rPA@AAU I 1149 com.android.phone Telephony AccountEntry: Registered phoneAccount: [[ ] PhoneAccount: ComponentInfo{com.android.phone/com.android.services.telephony.TelephonyConnectionService}, [e0184adedf913b076626646d3f52c3b49c39ad6d], UserHandle{0} Capabilities: CallProvider MultiUser PlaceEmerg SimSub Schemes: tel voicemail Extras: null GroupId: [da39a3ee5e6b4b0d3255bfef95601890afd80709]] with handle: ComponentInfo{com.android.phone/com.android.services.telephony.TelephonyConnectionService}, [e0184adedf913b076626646d3f52c3b49c39ad6d], UserHandle{0} I 1149 com.android.phone Telephony PstnIncomingCallNotifier: Registering: Handler (com.android.internal.telephony.GsmCdmaPhone) {167db5c} E 1149 com.android.phone PhoneInterfaceManager [PhoneIntfMgr] getIccId: No UICC W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system Telecom : registerPhoneAccount not allowed on non-voice capable device.: TSI.rPA@AAg W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.setInsetsWindow(com.android.server.wm.Session, android.view.IWindow, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Region) for 493ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in void com.android.server.wm.WindowManagerService.setDockedStackDividerTouchRegion(android.graphics.Rect) for 494ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=2 in void com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session, android.view.IWindow) for 435ms I 486 system ActivityManager Start proc 1400:com.android.deskclock/u0a40 for broadcast com.android.deskclock/.AlarmInitReceiver I 486 system ActivityManager Displayed com.android.settings/.FallbackHome: +3s283ms (total +8s668ms) I 486 system ActivityManager user 0 is still locked. Cannot load recents W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system WindowManager App freeze timeout expired. W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.notifyAppRelaunchesCleared(android.os.IBinder) for 509ms I 486 system WindowManager Screen frozen for +3s278ms due to Window{db0591e u0 KeyguardScrim} W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system NetworkNotificationManager clearNotification id=100 D 486 system ConnectivityService NetworkAgentInfo [Ethernet () - 100] validation passed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowManagerService$H.handleMessage(android.os.Message)(WindowManagerService.java:8361) waiters=0 in void com.android.server.wm.WindowManagerService.notifyAppRelaunchesCleared(android.os.IBinder) for 2.171s W 486 system art Long monitor contention with owner Binder:486_7 (1320) at void com.android.server.am.ActivityManagerService.activityDestroyed(android.os.IBinder)(ActivityManagerService.java:6951) waiters=0 in void com.android.server.am.ActivityManagerService.dispatchUidsChanged() for 2.685s W 486 system art Long monitor contention with owner Binder:486_7 (1320) at void com.android.server.am.ActivityManagerService.activityDestroyed(android.os.IBinder)(ActivityManagerService.java:6951) waiters=1 in int com.android.server.am.ActivityManagerService.bindService(android.app.IApplicationThread, android.os.IBinder, android.content.Intent, java.lang.String, android.app.IServiceConnection, int, java.lang.String, int) for 2.684s W 486 system art Long monitor contention with owner Binder:486_7 (1320) at void com.android.server.am.ActivityManagerService.activityDestroyed(android.os.IBinder)(ActivityManagerService.java:6951) waiters=3 in void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread) for 2.663s W 486 system art Long monitor contention with owner Binder:486_7 (1320) at void com.android.server.am.ActivityManagerService.activityDestroyed(android.os.IBinder)(ActivityManagerService.java:6951) waiters=2 in android.content.pm.UserInfo com.android.server.am.UserController.getCurrentUser() for 2.680s W 486 system art Long monitor contention with owner Binder:486_7 (1320) at void com.android.server.am.ActivityManagerService.activityDestroyed(android.os.IBinder)(ActivityManagerService.java:6951) waiters=4 in int com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread, android.content.Intent, java.lang.String, android.content.IIntentReceiver, int, java.lang.String, android.os.Bundle, java.lang.String[], int, android.os.Bundle, boolean, boolean, int) for 2.038s V 486 system KeyguardServiceDelegate *** Keyguard started D 486 system AccelSensor enable 1 , handle 0 ,mEnabled 1 E 486 system SensorService Error activating sensor 0 (Operation not permitted) W 486 system KeyguardServiceDelegate onScreenTurningOn(): no keyguard service! W 1400 System ClassLoader referenced unknown path: /system/app/DeskClock/lib/arm I 486 system StatusBarManagerService registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@79f0056 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1400 art Before Android 4.1, method android.graphics.PorterDuffColorFilter android.support.graphics.drawable.VectorDrawableCompat.updateTintFilter(android.graphics.PorterDuffColorFilter, android.content.res.ColorStateList, android.graphics.PorterDuff$Mode) would have incorrectly overridden the package-private method in android.graphics.drawable.Drawable W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1400 AlarmClock AlarmInitReceiver android.intent.action.TIME_SET W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1400 AlarmClock Alarms Table created I 1400 AlarmClock Instance table created I 1400 AlarmClock Inserting default alarms E 1149 com.android.phone PhoneInterfaceManager [PhoneIntfMgr] getCarrierPackageNamesForIntent: No UICC D 1149 com.android.phone CarrierSvcBindHelper No carrier app for: 0 V 1400 AlarmClock AlarmInitReceiver finished D 1368 com.android.cellbroadcastreceiver CellBroadcastReceiver Service state changed! 1 Full: 1 1 voice home data home null null null null null null Unknown Unknown CSS not supported -1 -1 RoamInd=-1 DefRoamInd=-1 EmergOnly=false IsDataRoamingFromRegistration=false IsUsingCarrierAggregation=false Current state=-1 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1080 com.android.systemui art Background partial concurrent mark sweep GC freed 8536(960KB) AllocSpace objects, 1(20KB) LOS objects, 39% free, 2MB/4MB, paused 9.799ms total 48.264ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 1080 com.android.systemui System ClassLoader referenced unknown path: W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 1080 com.android.systemui ApplicationLoaders ignored Vulkan layer search path /system/app/Camera2/lib/arm:/system/app/Camera2/Camera2.apk!/lib/armeabi-v7a:/system/lib:/vendor/lib for namespace 0xb34a1090 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system BluetoothManagerService Message: 20 D 486 system BluetoothManagerService Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@55b24c1:true W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system BluetoothManagerService Message: 30 D 486 system BluetoothManagerService Message: 30 D 1080 com.android.systemui LocalBluetoothProfileManager Adding local MAP profile D 1080 com.android.systemui BluetoothMap Create BluetoothMap proxy object D 486 system BluetoothManagerService Message: 30 D 486 system BluetoothManagerService Message: 30 I 486 system art Background partial concurrent mark sweep GC freed 22625(1505KB) AllocSpace objects, 7(236KB) LOS objects, 33% free, 5MB/7MB, paused 4.119ms total 101.485ms D 1080 com.android.systemui LocalBluetoothProfileManager LocalBluetoothProfileManager construction complete I 1080 com.android.systemui CameraManagerGlobal Connecting to camera service W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) E 1080 com.android.systemui ActivityThread Failed to find provider info for com.android.contacts D 1080 com.android.systemui OpenGLRenderer profile bars disabled D 1080 com.android.systemui OpenGLRenderer ambientRatio = 1.50 W 486 system WindowManager Keyguard drawn timeout. Setting mKeyguardDrawComplete W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out D 1080 com.android.systemui PhoneStatusBar disable: < EXPAND* icons alerts system_info BACK* HOME* RECENT* clock SEARCH* quick_settings > I 486 system Choreographer Skipped 33 frames! The application may be doing too much work on its main thread. I 486 system InputReader Reconfiguring input devices. changes=0x00000010 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in int com.android.server.wm.WindowManagerService.watchRotation(android.view.IRotationWatcher) for 516ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out I 486 system art Starting a blocking GC Explicit W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in int com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.view.InputChannel) for 510ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 516ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 1080 com.android.systemui PhoneStatusBar heads up is enabled D 1080 com.android.systemui StatusBar user hasn't seen notification about hidden notifications D 1080 com.android.systemui StatusBar insecure lockscreen, skipping notification I 486 system art Explicit concurrent mark sweep GC freed 2946(181KB) AllocSpace objects, 4(296KB) LOS objects, 33% free, 5MB/7MB, paused 2.394ms total 89.837ms W 486 system WindowManager Timeout waiting for drawn: undrawn=[Window{db0591e u0 KeyguardScrim}] W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in int com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.view.InputChannel) for 408ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 419ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner Binder:486_5 (1182) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=2 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 527ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.ui (517) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=1 in void com.android.server.wm.WindowManagerService.performEnableScreen() for 1.589s W 486 system art Long monitor contention with owner android.ui (517) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=2 in void com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session, android.view.IWindow) for 1.584s W 486 system art Long monitor contention with owner Binder:486_4 (1106) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=2 in void com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session, android.view.IWindow) for 1.016s I 486 system Choreographer Skipped 93 frames! The application may be doing too much work on its main thread. W 486 system WindowManager Window freeze timeout expired. W 486 system WindowManager Force clearing orientation change: Window{db0591e u0 KeyguardScrim} W 486 system WindowManager Force clearing orientation change: Window{5dd23b0 u0 com.android.systemui.ImageWallpaper} I 221 /system/bin/surfaceflinger SurfaceFlinger Boot is finished (133195 ms) V 486 system KeyguardServiceDelegate *** Keyguard connected (yay!) I 1080 com.android.systemui Choreographer Skipped 213 frames! The application may be doing too much work on its main thread. E 232 /system/bin/installd Unable to unlink boot marker at /data//dalvik-cache/arm/.booting, error=No such file or directory W 486 system ActivityManager Unable to mark boot complete for abi: armeabi-v7a (Failed to execute markbootcomplete [arm]: -1) I 486 system SystemServiceManager Starting phase 1000 D 1080 com.android.systemui ViewRootImpl[StatusBar] changeCanvasOpacity: opaque=true W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system ActivityManager Start proc 1437:android.ext.services/u0a14 for on-hold D 486 system ActivityManager Finishing user boot 0 D 486 system CryptdConnector SND -> {3 cryptfs prepare_user_storage ! 0 0 2} D 207 /system/bin/vold vold e4crypt_prepare_user_storage for volume null, user 0, serial 0, flags 2 D 207 /system/bin/vold vold Preparing: /data/system_ce/0 D 207 /system/bin/vold vold Preparing: /data/misc_ce/0 D 207 /system/bin/vold vold Preparing: /data/media/0 D 207 /system/bin/vold vold Preparing: /data/data D 486 system CryptdConnector RCV <- {200 3 Command succeeded} V 486 system UserManagerService Found /data/user/0 with serial number 0 V 486 system UserManagerService Found /data/system_ce/0 with serial number -1 D 486 system UserManagerService Serial number missing on /data/system_ce/0; assuming current is valid V 486 system PackageManager reconcileAppsData for null u0 0x2 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out V 486 system PackageManager reconcileAppsData finished 80 packages W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.am.ActivityManagerService.finishBooting()(ActivityManagerService.java:6822) waiters=0 in android.content.Intent com.android.server.am.ActivityManagerService.registerReceiver(android.app.IApplicationThread, java.lang.String, android.content.IIntentReceiver, android.content.IntentFilter, java.lang.String, int) for 396ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.am.ActivityManagerService.finishBooting()(ActivityManagerService.java:6822) waiters=1 in void com.android.server.am.BroadcastQueue.processNextBroadcast(boolean) for 389ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.am.ActivityManagerService.finishBooting()(ActivityManagerService.java:6822) waiters=2 in android.content.pm.UserInfo com.android.server.am.UserController.getCurrentUser() for 388ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.am.ActivityManagerService.finishBooting()(ActivityManagerService.java:6822) waiters=3 in void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread) for 367ms I 486 system UsageStatsService Time changed in UsageStats by 1499221972 seconds I 486 system UsageStatsService User[0] Flushing usage stats to disk D 486 system BluetoothManagerService User 0 unlocked D 486 system MountService onUnlockUser 0 D 486 system VoldConnector SND -> {31 volume user_started 0} D 486 system WIFI Registering NetworkFactory D 486 system WIFI_UT Registering NetworkFactory D 486 system ConnectivityService Got NetworkFactory Messenger for WIFI D 486 system BluetoothManagerService Message: 301 D 486 system ConnectivityService Got NetworkFactory Messenger for WIFI_UT D 486 system BluetoothManagerService MESSAGE_USER_UNLOCKED D 486 system WIFI got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 150 D 486 system WIFI_UT got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 150 D 207 /system/bin/vold vold Linking /storage/emulated/0 to /mnt/user/0/primary D 486 system VoldConnector RCV <- {200 31 Command succeeded} D 486 system MountService Volume emulated broadcasting mounted to UserHandle{0} I 1400 com.android.deskclock AlarmClock AlarmInitReceiver android.intent.action.LOCKED_BOOT_COMPLETED I 486 system Choreographer Skipped 32 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system InputMethodManagerService All the enabled IMEs are gone. Reset default enabled IMEs. I 486 system SELinux SELinux: Loaded file_contexts contexts from /file_contexts.bin. W 1437 System ClassLoader referenced unknown path: /system/priv-app/ExtServices/lib/arm V 486 system BackupManagerService No ancestral data V 486 system BackupManagerService Starting with transport android/com.android.internal.backup.LocalTransport V 486 system BackupManagerService Found transports: 1 I 486 system BackupManagerService Backup enable apparently not migrated I 486 system BackupManagerService Migrating enable state false I 486 system BackupManagerService Backup enabled => false I 486 system art Background sticky concurrent mark sweep GC freed 27555(2MB) AllocSpace objects, 6(136KB) LOS objects, 27% free, 5MB/7MB, paused 10.499ms total 95.929ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system AppWidgetServiceImpl Failed to read state: java.io.FileNotFoundException: /data/system/users/0/appwidgets.xml (No such file or directory) V 486 system AppWidgetServiceImpl Upgrading widget database from 0 to 1 W 486 system VoiceInteractionManagerService no available voice interaction services found for user 0 W 486 system VoiceInteractionManagerService no available voice recognition services found for user 0 I 486 system ActivityManager Loading recents for user 0 into memory. I 486 system PreBootBroadcaster Pre-boot of {com.android.managedprovisioning/com.android.managedprovisioning.PreBootListener} for user 0 D 1149 com.android.phone CarrierSvcBindHelper Received android.intent.action.USER_UNLOCKED D 1332 com.android.settings FallbackHome User unlocked and real home found; let's go! E 1149 com.android.phone PhoneInterfaceManager [PhoneIntfMgr] getCarrierPackageNamesForIntent: No UICC D 1149 com.android.phone CarrierSvcBindHelper No carrier app for: 0 W 486 system ResourceType No known package when getting value for resource number 0x7f0200fc W 486 system ResourceType No known package when getting value for resource number 0x7f0e03a1 W 486 system ResourceType No known package when getting value for resource number 0x7f0200fb W 486 system ResourceType No known package when getting value for resource number 0x7f0e092f W 486 system ResourceType No known package when getting value for resource number 0x7f0200fa W 486 system ResourceType No known package when getting value for resource number 0x7f0e07dd I 486 system UsageStatsDatabase Time changed by +17352d2h32m52s565ms. files deleted: 0 files moved: 4 D 1400 com.android.deskclock Events [Stopwatch] [Reset] [Reboot] V 486 system KeyValueBackupJob Scheduling k/v pass in 246 minutes W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system UsageStatsService User[0] Rollover scheduled @ 2017-07-06 02:36:13(1499308573404) W 486 system ResourceType No known package when getting value for resource number 0x7f020018 W 486 system ResourceType No known package when getting value for resource number 0x7f0b016c W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.policy.PhoneWindowManager.updateSettings() for 320ms W 486 system art Long monitor contention with owner Binder:486_7 (1320) at boolean com.android.server.am.ActivityManagerService.finishActivity(android.os.IBinder, int, android.content.Intent, int)(ActivityManagerService.java:4838) waiters=0 in void com.android.server.am.ActivityManagerService.serviceDoneExecuting(android.os.IBinder, int, int, int) for 313ms W 486 system art Long monitor contention with owner Binder:486_7 (1320) at boolean com.android.server.am.ActivityManagerService.finishActivity(android.os.IBinder, int, android.content.Intent, int)(ActivityManagerService.java:4838) waiters=1 in android.content.pm.UserInfo com.android.server.am.UserController.getCurrentUser() for 310ms W 486 system art Long monitor contention with owner Binder:486_7 (1320) at boolean com.android.server.am.ActivityManagerService.finishActivity(android.os.IBinder, int, android.content.Intent, int)(ActivityManagerService.java:4838) waiters=3 in int com.android.server.am.ActivityManagerService.getAppStartMode(int, java.lang.String) for 293ms W 486 system art Long monitor contention with owner Binder:486_7 (1320) at boolean com.android.server.am.ActivityManagerService.finishActivity(android.os.IBinder, int, android.content.Intent, int)(ActivityManagerService.java:4838) waiters=6 in android.content.IIntentSender com.android.server.am.ActivityManagerService.getIntentSender(int, java.lang.String, android.os.IBinder, java.lang.String, int, android.content.Intent[], java.lang.String[], int, android.os.Bundle, int) for 256ms V 1400 com.android.deskclock AlarmClock AlarmInitReceiver finished W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.resumeKeyDispatching(android.os.IBinder) for 513ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.resumeKeyDispatching(android.os.IBinder) for 531ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. I 486 system ActivityManager START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000100 cmp=com.android.provision/.DefaultActivity} from uid 0 on display 0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.deferSurfaceLayout() for 515ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.deferSurfaceLayout() for 528ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.deferSurfaceLayout() for 537ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out I 486 system Choreographer Skipped 31 frames! The application may be doing too much work on its main thread. W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.deferSurfaceLayout() for 535ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.deferSurfaceLayout() for 527ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.prepareAppTransition(int, boolean) for 530ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.prepareAppTransition(int, boolean) for 535ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.prepareAppTransition(int, boolean) for 529ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.prepareAppTransition(int, boolean) for 533ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.addAppToken(int, android.view.IApplicationToken, int, int, int, boolean, boolean, int, int, boolean, boolean, android.graphics.Rect, android.content.res.Configuration, int, boolean, boolean, int, int) for 534ms I 486 system Choreographer Skipped 31 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 526ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 532ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 536ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 527ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 534ms I 486 system Choreographer Skipped 31 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 546ms I 486 system Choreographer Skipped 31 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 542ms I 486 system Choreographer Skipped 31 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 533ms I 486 system Choreographer Skipped 31 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 529ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 532ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 534ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 530ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 533ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 534ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 529ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 535ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 534ms I 486 system Choreographer Skipped 31 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 529ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 534ms I 486 system Choreographer Skipped 31 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 534ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 529ms I 486 system Choreographer Skipped 31 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 534ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out I 486 system Choreographer Skipped 31 frames! The application may be doing too much work on its main thread. W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 535ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 532ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 530ms I 486 system Choreographer Skipped 31 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in boolean com.android.server.wm.WindowManagerService.setAppStartingWindow(android.os.IBinder, java.lang.String, int, android.content.res.CompatibilityInfo, java.lang.CharSequence, int, int, int, int, android.os.IBinder, boolean) for 534ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.continueSurfaceLayout() for 525ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system ActivityManager Start proc 1458:com.android.provision/u0a21 for activity com.android.provision/.DefaultActivity W 486 system art Long monitor contention with owner Binder:486_5 (1182) at android.content.pm.UserInfo com.android.server.am.UserController.getCurrentUser()(UserController.java:1438) waiters=5 in android.content.Intent com.android.server.am.ActivityManagerService.registerReceiver(android.app.IApplicationThread, java.lang.String, android.content.IIntentReceiver, android.content.IntentFilter, java.lang.String, int) for 20.839s W 486 system art Long monitor contention with owner Binder:486_5 (1182) at android.content.pm.UserInfo com.android.server.am.UserController.getCurrentUser()(UserController.java:1438) waiters=6 in boolean com.android.server.am.ActivityManagerService.isUserRunning(int, int) for 20.839s W 486 system art Long monitor contention with owner Binder:486_5 (1182) at android.content.pm.UserInfo com.android.server.am.UserController.getCurrentUser()(UserController.java:1438) waiters=7 in void com.android.server.am.ActivityManagerService.updateConfiguration(android.content.res.Configuration) for 20.837s I 486 system ActivityManager Config changes=20 {1.0 ?mcc?mnc [en_US] ldltr sw800dp w1280dp h728dp 160dpi xlrg land finger -keyb/v/h -nav/h s.6} I 486 system Choreographer Skipped 36 frames! The application may be doing too much work on its main thread. W 486 system art Long monitor contention with owner Binder:486_1 (513) at android.content.IIntentSender com.android.server.am.ActivityManagerService.getIntentSender(int, java.lang.String, android.os.IBinder, java.lang.String, int, android.content.Intent[], java.lang.String[], int, android.os.Bundle, int)(ActivityManagerService.java:7102) waiters=4 in void com.android.server.am.ActivityManagerService.appendDropBoxProcessHeaders(com.android.server.am.ProcessRecord, java.lang.String, java.lang.StringBuilder) for 20.902s W 486 system art Long monitor contention with owner Binder:486_2 (514) at void com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java:6915) waiters=4 in void com.android.server.am.ActivityManagerService.finishReceiver(android.os.IBinder, int, java.lang.String, android.os.Bundle, boolean, int) for 20.900s W 486 system art Long monitor contention with owner Binder:486_2 (514) at void com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java:6915) waiters=5 in boolean com.android.server.am.ActivityManagerService.isUserRunning(int, int) for 20.875s W 486 system art Long monitor contention with owner Binder:486_4 (1106) at void com.android.server.am.ActivityManagerService.appendDropBoxProcessHeaders(com.android.server.am.ProcessRecord, java.lang.String, java.lang.StringBuilder)(ActivityManagerService.java:13709) waiters=0 in void com.android.server.am.ActivityManagerService$20.run() for 19.014s W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system NotificationSQLiteLog Pruned event entries: 2 I 486 system ActivityManager Start proc 1473:android.process.media/u0a12 for broadcast com.android.providers.downloads/.DownloadReceiver W 486 system art Long monitor contention with owner Binder:486_2 (514) at void com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java:6915) waiters=6 in android.content.pm.UserInfo com.android.server.am.UserController.getCurrentUser() for 20.897s W 486 system art Long monitor contention with owner Binder:486_2 (514) at void com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java:6915) waiters=7 in void com.android.server.am.ActivityManagerService$MainHandler.handleMessage(android.os.Message) for 20.464s W 486 system ActivityManager Launch timeout has expired, giving up wake lock! W 486 system art Long monitor contention with owner Binder:486_2 (514) at void com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java:6915) waiters=9 in int com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread, android.content.Intent, java.lang.String, android.content.IIntentReceiver, int, java.lang.String, android.os.Bundle, java.lang.String[], int, android.os.Bundle, boolean, boolean, int) for 8.714s W 486 system art Long monitor contention with owner Binder:486_2 (514) at void com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java:6915) waiters=8 in int com.android.server.am.PendingIntentRecord.sendInner(int, android.content.Intent, java.lang.String, android.content.IIntentReceiver, java.lang.String, android.os.IBinder, java.lang.String, int, int, int, android.os.Bundle, android.app.IActivityContainer) for 18.869s W 486 system art Long monitor contention with owner Binder:486_2 (514) at void com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java:6915) waiters=10 in void com.android.server.am.ActivityManagerService.monitor() for 7.881s I 486 system AccountManagerService User 0 is unlocked - opening CE database W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system AccountManagerService Creating CE database /data/system_ce/0/accounts_ce.db V 486 system BackupManagerService Connected to transport ComponentInfo{android/com.android.internal.backup.LocalTransportService} V 486 system BackupManagerService Registering transport android/com.android.internal.backup.LocalTransportService::android/com.android.internal.backup.LocalTransport = android.app.backup.BackupTransport$TransportImpl@2ff8acf W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.ui (517) at void com.android.server.wm.WindowManagerService.continueSurfaceLayout()(WindowManagerService.java:5447) waiters=1 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 434ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in void com.android.server.wm.WindowManagerService.updateRotationUnchecked(boolean, boolean) for 1.506s W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=2 in void com.android.server.wm.WindowManagerService.startAppFreezingScreen(android.os.IBinder, int) for 1.471s W 486 system art Long monitor contention with owner Binder:486_6 (1183) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=2 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 1.080s W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1080 com.android.systemui OpenGLRenderer Initialized EGL, version 1.4 D 1080 com.android.systemui OpenGLRenderer Swap behavior 2 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=0 in void com.android.server.wm.WindowManagerService.executeAppTransition() for 1.050s W 486 system art Long monitor contention with owner android.display (523) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=1 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 1.007s W 486 system art Long monitor contention with owner ActivityManager (516) at void com.android.server.am.ActivityStackSupervisor$ActivityStackSupervisorHandler.handleMessage(android.os.Message)(ActivityStackSupervisor.java:3903) waiters=7 in int com.android.server.am.PendingIntentRecord.sendInner(int, android.content.Intent, java.lang.String, android.content.IIntentReceiver, java.lang.String, android.os.IBinder, java.lang.String, int, int, int, android.os.Bundle, android.app.IActivityContainer) for 2.541s W 486 system art Long monitor contention with owner main (486) at android.content.pm.UserInfo com.android.server.am.UserController.getCurrentUser()(UserController.java:1438) waiters=7 in void com.android.server.am.ActivityStackSupervisor$ActivityStackSupervisorHandler.handleMessage(android.os.Message) for 2.542s W 486 system art Long monitor contention with owner main (486) at android.content.pm.UserInfo com.android.server.am.UserController.getCurrentUser()(UserController.java:1438) waiters=7 in void com.android.server.am.ActivityManagerService.monitor() for 2.542s W 486 system art Long monitor contention with owner android.bg (515) at boolean com.android.server.am.ActivityManagerService.isUserRunning(int, int)(ActivityManagerService.java:21694) waiters=7 in boolean com.android.server.am.ActivityManagerService.isUserRunning(int, int) for 2.542s W 486 system art Long monitor contention with owner Binder:486_7 (1320) at android.content.pm.UserInfo com.android.server.am.UserController.getCurrentUser()(UserController.java:1438) waiters=6 in void com.android.server.am.ActivityManagerService.appendDropBoxProcessHeaders(com.android.server.am.ProcessRecord, java.lang.String, java.lang.StringBuilder) for 2.542s W 486 system art Long monitor contention with owner Binder:486_2 (514) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=5 in int com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread, android.content.Intent, java.lang.String, android.content.IIntentReceiver, int, java.lang.String, android.os.Bundle, java.lang.String[], int, android.os.Bundle, boolean, boolean, int) for 2.541s W 486 system art Long monitor contention with owner Binder:486_2 (514) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=6 in boolean com.android.server.am.ActivityManagerService.isUserRunning(int, int) for 2.543s W 486 system art Long monitor contention with owner Binder:486_2 (514) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=7 in void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread) for 2.520s W 486 system art Long monitor contention with owner Binder:486_2 (514) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=8 in int com.android.server.am.ActivityManagerService.getMemoryTrimLevel() for 2.385s W 486 system art Long monitor contention with owner Binder:486_2 (514) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=9 in void com.android.server.am.ActivityManagerService.dispatchUidsChanged() for 1.087s W 1458 System ClassLoader referenced unknown path: /system/priv-app/Provision/lib/arm W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1473 System ClassLoader referenced unknown path: /system/priv-app/DownloadProvider/lib/arm I 486 system ActivityManager Start proc 1490:com.android.printspooler/u0a53 for service com.android.printspooler/.model.PrintSpoolerService I 486 system Choreographer Skipped 155 frames! The application may be doing too much work on its main thread. I 1080 com.android.systemui vol.Events writeEvent level_changed STREAM_MUSIC 10 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system ActivityManager Start proc 1504:com.android.keychain/1000 for service com.android.keychain/.KeyChainService W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner Binder:486_1 (513) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=0 in void com.android.server.wm.WindowManagerService.pauseKeyDispatching(android.os.IBinder) for 374ms W 486 system art Long monitor contention with owner Binder:486_1 (513) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=1 in void com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session, android.view.IWindow) for 315ms W 486 system art Long monitor contention with owner AsyncTask #4 (1478) at int com.android.server.am.ActivityManagerService.bindService(android.app.IApplicationThread, android.os.IBinder, android.content.Intent, java.lang.String, android.app.IServiceConnection, int, java.lang.String, int)(ActivityManagerService.java:17254) waiters=2 in boolean com.android.server.am.ActivityManagerService.isUserRunning(int, int) for 403ms W 486 system art Long monitor contention with owner Binder:486_5 (1182) at boolean com.android.server.am.ActivityManagerService.finishActivity(android.os.IBinder, int, android.content.Intent, int)(ActivityManagerService.java:4838) waiters=3 in void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread) for 323ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system WifiService New client listening to asynchronous messages W 1473 android.process.media System ClassLoader referenced unknown path: /system/priv-app/MediaProvider/lib/arm D 1473 android.process.media ApplicationLoaders ignored Vulkan layer search path /system/priv-app/MediaProvider/lib/arm:/system/priv-app/MediaProvider/MediaProvider.apk!/lib/armeabi-v7a:/system/lib:/vendor/lib for namespace 0xb34a1090 W 1504 pre System ClassLoader referenced unknown path: /system/app/KeyChain/lib/arm I 486 system DevicePolicyManagerService Set ro.device_owner property to false W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media DownloadManager Upgrading downloads database from version 0 to version 110, which will destroy all old data W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system ActivityManager START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000100 cmp=com.android.launcher/com.android.launcher2.Launcher} from uid 0 on display 0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.deferSurfaceLayout() for 516ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.moveTaskToTop(int) for 523ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.addAppToken(int, android.view.IApplicationToken, int, int, int, boolean, boolean, int, int, boolean, boolean, android.graphics.Rect, android.content.res.Configuration, int, boolean, boolean, int, int) for 528ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.continueSurfaceLayout() for 523ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.continueSurfaceLayout() for 534ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.stopAppFreezingScreen(android.os.IBinder, boolean) for 520ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system ActivityManager Start proc 1525:com.android.launcher/u0a16 for activity com.android.launcher/com.android.launcher2.Launcher W 486 system art Long monitor contention with owner Binder:486_1 (513) at void com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java:6915) waiters=0 in com.android.server.am.ProcessRecord com.android.server.am.ActivityManagerService.findAppProcess(android.os.IBinder, java.lang.String) for 3.612s W 486 system art Long monitor contention with owner Binder:486_1 (513) at void com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java:6915) waiters=1 in com.android.server.am.ProcessRecord com.android.server.am.ActivityManagerService.findAppProcess(android.os.IBinder, java.lang.String) for 3.605s W 486 system art Long monitor contention with owner Binder:486_1 (513) at void com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java:6915) waiters=2 in android.content.pm.UserInfo com.android.server.am.UserController.getCurrentUser() for 3.597s W 486 system art Long monitor contention with owner Binder:486_1 (513) at void com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java:6915) waiters=3 in android.content.Intent com.android.server.am.ActivityManagerService.registerReceiver(android.app.IApplicationThread, java.lang.String, android.content.IIntentReceiver, android.content.IntentFilter, java.lang.String, int) for 3.418s W 486 system art Long monitor contention with owner Binder:486_1 (513) at void com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java:6915) waiters=4 in void com.android.server.am.ActivityStack$ActivityStackHandler.handleMessage(android.os.Message) for 3.223s I 486 system Choreographer Skipped 32 frames! The application may be doing too much work on its main thread. W 1080 com.android.systemui KeyguardUpdateMonitor invalid subId in handleSimStateChange() W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaProvider Upgrading media database from version 0 to 800, which will destroy all old data W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 1473 android.process.media MediaProvider Adjusting external storage paths to: /storage/emulated/0 E 1473 android.process.media SQLiteLog (1) no such table: album_info W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.prepareAppTransition(int, boolean) for 495ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in void com.android.server.wm.WindowManagerService.statusBarVisibilityChanged(int) for 482ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=2 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 482ms W 486 system art Long monitor contention with owner ActivityManager (516) at void com.android.server.am.ActivityStackSupervisor$ActivityStackSupervisorHandler.handleMessage(android.os.Message)(ActivityStackSupervisor.java:3884) waiters=0 in com.android.server.am.ProcessRecord com.android.server.am.ActivityManagerService.findAppProcess(android.os.IBinder, java.lang.String) for 496ms W 486 system art Long monitor contention with owner ActivityManager (516) at void com.android.server.am.ActivityStackSupervisor$ActivityStackSupervisorHandler.handleMessage(android.os.Message)(ActivityStackSupervisor.java:3884) waiters=1 in com.android.server.am.ProcessRecord com.android.server.am.ActivityManagerService.findAppProcess(android.os.IBinder, java.lang.String) for 496ms W 486 system art Long monitor contention with owner ActivityManager (516) at void com.android.server.am.ActivityStackSupervisor$ActivityStackSupervisorHandler.handleMessage(android.os.Message)(ActivityStackSupervisor.java:3884) waiters=2 in void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread) for 475ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner Binder:486_4 (1106) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=1 in void com.android.server.wm.WindowManagerService.startAppFreezingScreen(android.os.IBinder, int) for 525ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 391ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system art Long monitor contention with owner Binder:486_3 (1056) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=0 in void com.android.server.wm.WindowManagerService.setAppVisibility(android.os.IBinder, boolean) for 540ms W 486 system art Long monitor contention with owner Binder:486_1 (513) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=0 in com.android.server.am.ProcessRecord com.android.server.am.ActivityManagerService.findAppProcess(android.os.IBinder, java.lang.String) for 1.085s W 486 system art Long monitor contention with owner Binder:486_1 (513) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=1 in void com.android.server.am.ActivityManagerService.serviceDoneExecuting(android.os.IBinder, int, int, int) for 1.029s W 486 system art Long monitor contention with owner Binder:486_1 (513) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=2 in com.android.server.am.ProcessRecord com.android.server.am.ActivityManagerService.findAppProcess(android.os.IBinder, java.lang.String) for 1.029s W 486 system art Long monitor contention with owner Binder:486_1 (513) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=4 in int com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread, android.content.Intent, java.lang.String, android.content.IIntentReceiver, int, java.lang.String, android.os.Bundle, java.lang.String[], int, android.os.Bundle, boolean, boolean, int) for 824ms W 486 system art Long monitor contention with owner Binder:486_1 (513) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=5 in void com.android.server.am.ActivityStack$ActivityStackHandler.handleMessage(android.os.Message) for 563ms W 486 system art Long monitor contention with owner Binder:486_1 (513) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=3 in void com.android.server.am.ActivityManagerService.publishContentProviders(android.app.IApplicationThread, java.util.List) for 969ms W 486 system art Long monitor contention with owner Binder:486_1 (513) at void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread)(ActivityManagerService.java:6668) waiters=6 in void com.android.server.am.ActivityManagerService$LocalService.notifyStartingWindowDrawn() for 564ms I 486 system Choreographer Skipped 62 frames! The application may be doing too much work on its main thread. W 1525 System ClassLoader referenced unknown path: /system/priv-app/Launcher2/lib/arm W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 1473 android.process.media MediaScannerReceiver action: android.intent.action.MEDIA_MOUNTED path: /storage/emulated/0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system ActivityManager Start proc 1547:com.android.managedprovisioning/u0a17 for broadcast com.android.managedprovisioning/.PreBootListener W 1547 System ClassLoader referenced unknown path: /system/priv-app/ManagedProvisioning/lib/arm W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PreBootBroadcaster Pre-boot of {com.android.providers.calendar/com.android.providers.calendar.CalendarUpgradeReceiver} for user 0 I 486 system ActivityManager Start proc 1567:com.android.providers.calendar/u0a4 for broadcast com.android.providers.calendar/.CalendarUpgradeReceiver W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1567 pre System ClassLoader referenced unknown path: /system/priv-app/CalendarProvider/lib/arm W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 405ms V 1473 android.process.media MediaScanner pruneDeadThumbnailFiles... android.content.ContentProviderClient$CursorWrapperInner@f8ad4d2 V 1473 android.process.media MediaScanner /pruneDeadThumbnailFiles... android.content.ContentProviderClient$CursorWrapperInner@f8ad4d2 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1567 pre CalendarDatabaseHelper Bootstrapping database W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1567 pre CalendarProvider2 Created com.android.providers.calendar.CalendarAlarmManager@5914b6e(com.android.providers.calendar.CalendarProvider2@8ecd20f) I 486 system RetailDemoModeService Deleting contents of /data/preloads I 1567 pre CalendarUpgradeReceiver Creating or opening calendar database W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PreBootBroadcaster Pre-boot of {com.android.providers.contacts/com.android.providers.contacts.ContactsUpgradeReceiver} for user 0 I 486 system ActivityManager Start proc 1585:android.process.acore/u0a3 for broadcast com.android.providers.contacts/.ContactsUpgradeReceiver W 1585 System ClassLoader referenced unknown path: /system/priv-app/ContactsProvider/lib/arm W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 535ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in float com.android.server.wm.WindowManagerService.getCurrentAnimatorScale() for 535ms I 486 system Choreographer Skipped 31 frames! The application may be doing too much work on its main thread. W 1080 com.android.systemui KeyguardUpdateMonitor invalid subId in handleServiceStateChange() W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) V 486 system KeyguardServiceDelegate **** SHOWN CALLED **** I 1080 com.android.systemui Choreographer Skipped 1856 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1585 android.process.acore ContactsPerf VoicemailContentProvider.onCreate start W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1585 android.process.acore ContactsPerf VoicemailContentProvider.onCreate finish W 1585 android.process.acore System ClassLoader referenced unknown path: /system/priv-app/BlockedNumberProvider/lib/arm D 1585 android.process.acore ApplicationLoaders ignored Vulkan layer search path /system/priv-app/BlockedNumberProvider/lib/arm:/system/lib:/vendor/lib for namespace 0xb34a1090 I 1585 android.process.acore ContactsDatabaseHelper Bootstrapping database version: 1111 W 1585 android.process.acore System ClassLoader referenced unknown path: /system/app/UserDictionaryProvider/lib/arm D 1585 android.process.acore ApplicationLoaders ignored Vulkan layer search path /system/app/UserDictionaryProvider/lib/arm:/system/lib:/vendor/lib for namespace 0xb34a10d0 D 1585 android.process.acore StrictMode StrictMode policy violation; ~duration=184 ms: android.os.StrictMode$StrictModeDiskWriteViolation: policy=65565 violation=1 D 1585 android.process.acore StrictMode at android.os.StrictMode$AndroidBlockGuardPolicy.onWriteToDisk(StrictMode.java:1253) D 1585 android.process.acore StrictMode at libcore.io.BlockGuardOs.mkdir(BlockGuardOs.java:173) D 1585 android.process.acore StrictMode at android.system.Os.mkdir(Os.java:282) D 1585 android.process.acore StrictMode at android.app.ContextImpl.ensurePrivateDirExists(ContextImpl.java:514) D 1585 android.process.acore StrictMode at android.app.ContextImpl.getPreferencesDir(ContextImpl.java:468) D 1585 android.process.acore StrictMode at android.app.ContextImpl.getSharedPreferencesPath(ContextImpl.java:627) D 1585 android.process.acore StrictMode at android.app.ContextImpl.getSharedPreferences(ContextImpl.java:345) D 1585 android.process.acore StrictMode at android.content.ContextWrapper.getSharedPreferences(ContextWrapper.java:164) D 1585 android.process.acore StrictMode at android.preference.PreferenceManager.getDefaultSharedPreferences(PreferenceManager.java:487) D 1585 android.process.acore StrictMode at com.android.providers.contacts.FastScrollingIndexCache.getInstance(FastScrollingIndexCache.java:95) D 1585 android.process.acore StrictMode at com.android.providers.contacts.ContactsProvider2.initialize(ContactsProvider2.java:1573) D 1585 android.process.acore StrictMode at com.android.providers.contacts.ContactsProvider2.onCreate(ContactsProvider2.java:1548) D 1585 android.process.acore StrictMode at android.content.ContentProvider.attachInfo(ContentProvider.java:1751) D 1585 android.process.acore StrictMode at android.content.ContentProvider.attachInfo(ContentProvider.java:1726) D 1585 android.process.acore StrictMode at android.app.ActivityThread.installProvider(ActivityThread.java:5853) D 1585 android.process.acore StrictMode at android.app.ActivityThread.installContentProviders(ActivityThread.java:5445) D 1585 android.process.acore StrictMode at android.app.ActivityThread.handleBindApplication(ActivityThread.java:5384) D 1585 android.process.acore StrictMode at android.app.ActivityThread.-wrap2(ActivityThread.java) D 1585 android.process.acore StrictMode at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1545) D 1585 android.process.acore StrictMode at android.os.Handler.dispatchMessage(Handler.java:102) D 1585 android.process.acore StrictMode at android.os.Looper.loop(Looper.java:154) D 1585 android.process.acore StrictMode at android.app.ActivityThread.main(ActivityThread.java:6119) D 1585 android.process.acore StrictMode at java.lang.reflect.Method.invoke(Native Method) D 1585 android.process.acore StrictMode at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:886) D 1585 android.process.acore StrictMode at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:776) D 1585 android.process.acore StrictMode StrictMode policy violation; ~duration=177 ms: android.os.StrictMode$StrictModeDiskWriteViolation: policy=65565 violation=1 D 1585 android.process.acore StrictMode at android.os.StrictMode$AndroidBlockGuardPolicy.onWriteToDisk(StrictMode.java:1253) D 1585 android.process.acore StrictMode at libcore.io.BlockGuardOs.chmod(BlockGuardOs.java:73) D 1585 android.process.acore StrictMode at android.system.Os.chmod(Os.java:68) D 1585 android.process.acore StrictMode at android.app.ContextImpl.ensurePrivateDirExists(ContextImpl.java:515) D 1585 android.process.acore StrictMode at android.app.ContextImpl.getPreferencesDir(ContextImpl.java:468) D 1585 android.process.acore StrictMode at android.app.ContextImpl.getSharedPreferencesPath(ContextImpl.java:627) D 1585 android.process.acore StrictMode at android.app.ContextImpl.getSharedPreferences(ContextImpl.java:345) D 1585 android.process.acore StrictMode at android.content.ContextWrapper.getSharedPreferences(ContextWrapper.java:164) D 1585 android.process.acore StrictMode at android.preference.PreferenceManager.getDefaultSharedPreferences(PreferenceManager.java:487) D 1585 android.process.acore StrictMode at com.android.providers.contacts.FastScrollingIndexCache.getInstance(FastScrollingIndexCache.java:95) D 1585 android.process.acore StrictMode at com.android.providers.contacts.ContactsProvider2.initialize(ContactsProvider2.java:1573) D 1585 android.process.acore StrictMode at com.android.providers.contacts.ContactsProvider2.onCreate(ContactsProvider2.java:1548) D 1585 android.process.acore StrictMode at android.content.ContentProvider.attachInfo(ContentProvider.java:1751) D 1585 android.process.acore StrictMode at android.content.ContentProvider.attachInfo(ContentProvider.java:1726) D 1585 android.process.acore StrictMode at android.app.ActivityThread.installProvider(ActivityThread.java:5853) D 1585 android.process.acore StrictMode at android.app.ActivityThread.installContentProviders(ActivityThread.java:5445) D 1585 android.process.acore StrictMode at android.app.ActivityThread.handleBindApplication(ActivityThread.java:5384) D 1585 android.process.acore StrictMode at android.app.ActivityThread.-wrap2(ActivityThread.java) D 1585 android.process.acore StrictMode at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1545) D 1585 android.process.acore StrictMode at android.os.Handler.dispatchMessage(Handler.java:102) D 1585 android.process.acore StrictMode at android.os.Looper.loop(Looper.java:154) D 1585 android.process.acore StrictMode at android.app.ActivityThread.main(ActivityThread.java:6119) D 1585 android.process.acore StrictMode at java.lang.reflect.Method.invoke(Native Method) D 1585 android.process.acore StrictMode at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:886) D 1585 android.process.acore StrictMode at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:776) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1585 android.process.acore ContactsUpgradeReceiver Creating or opening contacts database W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 473ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) E 1525 com.android.launcher StrictMode A resource was acquired at attached stack trace but never released. See java.io.Closeable for information on avoiding resource leaks. E 1525 com.android.launcher StrictMode java.lang.Throwable: Explicit termination method 'close' not called E 1525 com.android.launcher StrictMode at dalvik.system.CloseGuard.open(CloseGuard.java:180) E 1525 com.android.launcher StrictMode at android.content.ContentResolver$CursorWrapperInner.<init>(ContentResolver.java:2627) E 1525 com.android.launcher StrictMode at android.content.ContentResolver.query(ContentResolver.java:558) E 1525 com.android.launcher StrictMode at android.content.ContentResolver.query(ContentResolver.java:474) E 1525 com.android.launcher StrictMode at com.android.launcher2.LauncherProvider$DatabaseHelper.convertDatabase(LauncherProvider.java:413) E 1525 com.android.launcher StrictMode at com.android.launcher2.LauncherProvider$DatabaseHelper.onCreate(LauncherProvider.java:389) E 1525 com.android.launcher StrictMode at android.database.sqlite.SQLiteOpenHelper.getDatabaseLocked(SQLiteOpenHelper.java:251) E 1525 com.android.launcher StrictMode at android.database.sqlite.SQLiteOpenHelper.getWritableDatabase(SQLiteOpenHelper.java:163) E 1525 com.android.launcher StrictMode at com.android.launcher2.LauncherProvider$DatabaseHelper.<init>(LauncherProvider.java:335) E 1525 com.android.launcher StrictMode at com.android.launcher2.LauncherProvider.onCreate(LauncherProvider.java:103) E 1525 com.android.launcher StrictMode at android.content.ContentProvider.attachInfo(ContentProvider.java:1751) E 1525 com.android.launcher StrictMode at android.content.ContentProvider.attachInfo(ContentProvider.java:1726) E 1525 com.android.launcher StrictMode at android.app.ActivityThread.installProvider(ActivityThread.java:5853) E 1525 com.android.launcher StrictMode at android.app.ActivityThread.installContentProviders(ActivityThread.java:5445) E 1525 com.android.launcher StrictMode at android.app.ActivityThread.handleBindApplication(ActivityThread.java:5384) E 1525 com.android.launcher StrictMode at android.app.ActivityThread.-wrap2(ActivityThread.java) E 1525 com.android.launcher StrictMode at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1545) E 1525 com.android.launcher StrictMode at android.os.Handler.dispatchMessage(Handler.java:102) E 1525 com.android.launcher StrictMode at android.os.Looper.loop(Looper.java:154) E 1525 com.android.launcher StrictMode at android.app.ActivityThread.main(ActivityThread.java:6119) E 1525 com.android.launcher StrictMode at java.lang.reflect.Method.invoke(Native Method) E 1525 com.android.launcher StrictMode at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:886) E 1525 com.android.launcher StrictMode at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:776) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1585 android.process.acore ContactsProviderV1 Bootstrapping database legacy support W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1567 com.android.providers.calendar CalendarProvider2 Sending notification intent: Intent { act=android.intent.action.PROVIDER_CHANGED dat=content://com.android.calendar flg=0x20000000 } W 1567 com.android.providers.calendar ContentResolver Failed to get type for: content://com.android.calendar (Unknown URL content://com.android.calendar) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 523ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in void com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session, android.view.IWindow) for 519ms W 486 system art Long monitor contention with owner Binder:486_1 (513) at void com.android.server.am.ActivityManagerService.setRequestedOrientation(android.os.IBinder, int)(ActivityManagerService.java:4784) waiters=0 in boolean com.android.server.am.ActivityManagerService.isUserRunning(int, int) for 328ms W 486 system art Long monitor contention with owner Binder:486_1 (513) at void com.android.server.am.ActivityManagerService.setRequestedOrientation(android.os.IBinder, int)(ActivityManagerService.java:4784) waiters=2 in int com.android.server.am.ActivityManagerService.broadcastIntent(android.app.IApplicationThread, android.content.Intent, java.lang.String, android.content.IIntentReceiver, int, java.lang.String, android.os.Bundle, java.lang.String[], int, android.os.Bundle, boolean, boolean, int) for 292ms I 486 system Choreographer Skipped 31 frames! The application may be doing too much work on its main thread. W 1080 com.android.systemui FingerprintManager isFingerprintHardwareDetected(): Service not connected! W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1585 android.process.acore art Long monitor contention with owner ContactsProviderWorker (1605) at long android.database.sqlite.SQLiteConnection.nativePrepareStatement(long, java.lang.String)(SQLiteConnection.java:-2) waiters=1 in android.database.sqlite.SQLiteDatabase android.database.sqlite.SQLiteOpenHelper.getWritableDatabase() for 1.067s W 1585 android.process.acore art Long monitor contention with owner ContactsProviderWorker (1605) at long android.database.sqlite.SQLiteConnection.nativePrepareStatement(long, java.lang.String)(SQLiteConnection.java:-2) waiters=0 in android.database.sqlite.SQLiteDatabase android.database.sqlite.SQLiteOpenHelper.getWritableDatabase() for 1.099s I 1585 android.process.acore CallLogDatabaseHelper Migrating from old tables... W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1585 android.process.acore CallLogDatabaseHelper Source tables don't exist. I 1585 android.process.acore ContactsDatabaseHelper Bootstrapping database version: 1111 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1585 android.process.acore CallLogDatabaseHelper Migrating from old tables... I 1585 android.process.acore CallLogDatabaseHelper Source tables don't exist. W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 511ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in float com.android.server.wm.WindowManagerService.getCurrentAnimatorScale() for 491ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1585 android.process.acore ContactLocale AddressBook Labels [[en_US]]: […, A, B, C, D, E, F, G, H, I, J, K, L, M, N, O, P, Q, R, S, T, U, V, W, X, Y, Z, Α, Β, Γ, Δ, Ε, Ζ, Η, Θ, Ι, Κ, Λ, Μ, Ν, Ξ, Ο, Π, Ρ, Σ, Τ, Υ, Φ, Χ, Ψ, Ω, …, А, Б, В, Г, Д, ?, Е, ?, Ж, З, И, ?, Й, ?, К, Л, ?, М, Н, ?, О, П, Р, С, Т, ?, У, Ф, Х, Ц, Ч, ?, Ш, Щ, Ю, Я, …, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, …, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, …, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, …, ㄱ, ㄴ, ㄷ, ㄹ, ㅁ, ㅂ, ㅅ, ㅇ, ㅈ, ㅊ, ㅋ, ㅌ, ㅍ, ㅎ, …, あ, か, さ, た, な, は, ま, や, ら, わ, #, …] W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1585 android.process.acore ContactsProviderV1 Bootstrapping database legacy support W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1585 android.process.acore ContactsProvider Locale has changed from null to [en_US] I 1585 android.process.acore ContactsDatabaseHelper Switching to locale [en_US] (ICU v56.1) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=2 in int com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.view.InputChannel) for 982ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowManagerService$H.handleMessage(android.os.Message)(WindowManagerService.java:8850) waiters=2 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 536ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1585 android.process.acore ContactsDatabaseHelper Locale change completed in 252ms I 1585 android.process.acore ContactsDatabaseHelper Switching to locale [en_US] (ICU v56.1) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1585 android.process.acore ContactsDatabaseHelper Locale change completed in 223ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=2 in float com.android.server.wm.WindowManagerService.getCurrentAnimatorScale() for 1.058s W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowManagerService$H.handleMessage(android.os.Message)(WindowManagerService.java:8361) waiters=3 in int com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.view.InputChannel) for 533ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=3 in void com.android.server.wm.WindowManagerService.notifyAppRelaunchesCleared(android.os.IBinder) for 628ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=3 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 530ms W 486 system art Long monitor contention with owner ActivityManager (516) at void com.android.server.am.ActivityStackSupervisor$ActivityStackSupervisorHandler.activityIdleInternal(com.android.server.am.ActivityRecord)(ActivityStackSupervisor.java:3841) waiters=0 in android.content.Intent com.android.server.am.ActivityManagerService.registerReceiver(android.app.IApplicationThread, java.lang.String, android.content.IIntentReceiver, android.content.IntentFilter, java.lang.String, int) for 470ms I 486 system Choreographer Skipped 32 frames! The application may be doing too much work on its main thread. I 1525 com.android.launcher imx6.gralloc open gpu gralloc module! W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1585 android.process.acore ContactDirectoryManager deleted 0 stale rows which don't have any relevant directory W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1585 android.process.acore ContactDirectoryManager Discovered 0 contact directories in 127ms I 1585 android.process.acore ContactsProvider Upgrading aggregation algorithm I 1585 android.process.acore ContactAggregator Marked all visible contacts for aggregation: 0 raw contacts, 2 ms I 1585 android.process.acore ContactsProvider Aggregation algorithm upgraded for 0 raw contacts in 37ms I 1585 android.process.acore ContactsFTS Rebuild contact search index in 34ms, 0 contacts W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.notifyAppRelaunchesCleared(android.os.IBinder) for 507ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in int com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.view.InputChannel) for 477ms W 486 system art Long monitor contention with owner Binder:486_4 (1106) at android.content.Intent com.android.server.am.ActivityManagerService.registerReceiver(android.app.IApplicationThread, java.lang.String, android.content.IIntentReceiver, android.content.IntentFilter, java.lang.String, int)(ActivityManagerService.java:17578) waiters=4 in void com.android.server.am.ActivityManagerService$3.handleMessage(android.os.Message) for 522ms W 486 system art Long monitor contention with owner Binder:486_8 (1472) at void com.android.server.am.ActivityManagerService.activityDestroyed(android.os.IBinder)(ActivityManagerService.java:6951) waiters=1 in void com.android.server.am.ActivityManagerService$MainHandler.handleMessage(android.os.Message) for 520ms W 486 system art Long monitor contention with owner Binder:486_8 (1472) at void com.android.server.am.ActivityManagerService.activityDestroyed(android.os.IBinder)(ActivityManagerService.java:6951) waiters=2 in int com.android.server.am.ActivityManagerService.getLockTaskModeState() for 520ms W 486 system art Long monitor contention with owner Binder:486_8 (1472) at void com.android.server.am.ActivityManagerService.activityDestroyed(android.os.IBinder)(ActivityManagerService.java:6951) waiters=4 in com.android.server.am.ProcessRecord com.android.server.am.ActivityManagerService.findAppProcess(android.os.IBinder, java.lang.String) for 487ms W 486 system art Long monitor contention with owner Binder:486_8 (1472) at void com.android.server.am.ActivityManagerService.activityDestroyed(android.os.IBinder)(ActivityManagerService.java:6951) waiters=3 in void com.android.server.am.ActivityManagerService.unregisterReceiver(android.content.IIntentReceiver) for 500ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. I 486 system PreBootBroadcaster Pre-boot of {com.android.providers.media/com.android.providers.media.MediaUpgradeReceiver} for user 0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 1400 com.android.deskclock Events [Analog Widget] [Create] I 486 system ActivityManager Start proc 1618:com.android.calendar/u0a34 for broadcast com.android.calendar/.alerts.AlertReceiver I 486 system art Background sticky concurrent mark sweep GC freed 15898(1264KB) AllocSpace objects, 17(516KB) LOS objects, 22% free, 6MB/7MB, paused 8.368ms total 66.283ms E 1149 com.android.phone PhoneInterfaceManager [PhoneIntfMgr] getCarrierPackageNamesForIntent: No UICC D 1149 com.android.phone CarrierSvcBindHelper No carrier app for: 0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1618 System ClassLoader referenced unknown path: /system/app/Calendar/lib/arm W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 1618 com.android.calendar ExtensionsFactory No custom extensions. D 1618 com.android.calendar AlertReceiver onReceive: a=android.intent.action.PROVIDER_CHANGED Intent { act=android.intent.action.PROVIDER_CHANGED dat=content://com.android.calendar flg=0x20000010 cmp=com.android.calendar/.alerts.AlertReceiver } W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 1618 com.android.calendar AlertUtils Flushing old alerts from shared prefs table D 1618 com.android.calendar AlertService 0 Action = android.intent.action.PROVIDER_CHANGED W 486 system ActivityManager Launch timeout has expired, giving up wake lock! W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaUpgradeReceiver ---> Start upgrade of media database external.db W 486 system BroadcastQueue Timeout of broadcast BroadcastRecord{8cf6977 u-1 android.intent.action.TIME_TICK} - receiver=android.os.BinderProxy@293899d, started 10000ms ago W 486 system BroadcastQueue Receiver during timeout: BroadcastFilter{281f9e3 u0 ReceiverList{92d9e12 1080 com.android.systemui/10026/u0 remote:293899d}} I 1473 android.process.media MediaUpgradeReceiver <--- Finished upgrade of media database external.db in 39ms I 486 system PreBootBroadcaster Pre-boot of {com.android.settings/com.android.settings.SettingsInitialize} for user 0 I 486 system Process Sending signal. PID: 1080 SIG: 3 I 1080 com.android.systemui art Thread[3,tid=1091,WaitingInMainSignalCatcherLoop,Thread*=0xa72bb800,peer=0x12c00af0,"Signal Catcher"]: reacting to signal 3 I 1080 com.android.systemui art W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.removeWindow(com.android.server.wm.Session, android.view.IWindow) for 518ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in int com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.view.InputChannel) for 488ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=2 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 486ms I 486 system Choreographer Skipped 32 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1080 com.android.systemui art Wrote stack traces to '/data/anr/traces.txt' E 486 system ActivityManager ANR in com.android.systemui E 486 system ActivityManager PID: 1080 E 486 system ActivityManager Reason: Broadcast of Intent { act=android.intent.action.TIME_TICK flg=0x50000014 (has extras) } E 486 system ActivityManager Load: 0.0 / 0.0 / 0.0 E 486 system ActivityManager CPU usage from 6352ms to 0ms ago (2017-07-05 02:37:25.654 to 2017-07-05 02:37:32.006): E 486 system ActivityManager 26% 486/system_server: 16% user + 10% kernel / faults: 738 minor E 486 system ActivityManager 14% 108/mmcqd/3: 0% user + 14% kernel E 486 system ActivityManager 9.9% 1473/android.process.media: 8.3% user + 1.5% kernel / faults: 1786 minor E 486 system ActivityManager 5.8% 1080/com.android.systemui: 4.5% user + 1.2% kernel / faults: 5700 minor E 486 system ActivityManager 4.8% 223/adbd: 1.1% user + 3.7% kernel / faults: 1164 minor E 486 system ActivityManager 2.3% 653/kworker/0:1H: 0% user + 2.3% kernel E 486 system ActivityManager 1.5% 1490/com.android.printspooler: 1.1% user + 0.4% kernel / faults: 406 minor E 486 system ActivityManager 1.4% 199/logd: 0.9% user + 0.4% kernel / faults: 13 minor E 486 system ActivityManager 1.2% 228/zygote: 0% user + 1.2% kernel / faults: 631 minor E 486 system ActivityManager 0.9% 1400/com.android.deskclock: 0.4% user + 0.4% kernel / faults: 184 minor E 486 system ActivityManager 0.6% 959/logcat: 0.4% user + 0.1% kernel / faults: 2 minor E 486 system ActivityManager 0.4% 191/jbd2/mmcblk3p4-: 0% user + 0.4% kernel E 486 system ActivityManager 0.4% 220/servicemanager: 0% user + 0.4% kernel E 486 system ActivityManager 0.4% 1332/com.android.settings: 0.4% user + 0% kernel / faults: 8 minor E 486 system ActivityManager 0.4% 1504/com.android.keychain: 0.3% user + 0.1% kernel / faults: 151 minor E 486 system ActivityManager 0% 3/ksoftirqd/0: 0% user + 0% kernel E 486 system ActivityManager 0% 219/lmkd: 0% user + 0% kernel E 486 system ActivityManager 0% 1063/sdcard: 0% user + 0% kernel / faults: 4 minor E 486 system ActivityManager 0.1% 6/kworker/u8:0: 0% user + 0.1% kernel E 486 system ActivityManager 0.1% 7/rcu_preempt: 0% user + 0.1% kernel E 486 system ActivityManager 0.1% 39/cfinteractive: 0% user + 0.1% kernel E 486 system ActivityManager 0% 113/galcore deamon : 0% user + 0% kernel E 486 system ActivityManager 0% 185/kworker/3:1: 0% user + 0% kernel E 486 system ActivityManager 0.1% 1149/com.android.phone: 0% user + 0.1% kernel / faults: 3 minor E 486 system ActivityManager 0.1% 1437/android.ext.services: 0.1% user + 0% kernel / faults: 8 minor E 486 system ActivityManager 0.1% 1458/com.android.provision: 0.1% user + 0% kernel E 486 system ActivityManager +0% 1525/com.android.launcher: 0% user + 0% kernel E 486 system ActivityManager +0% 1547/com.android.managedprovisioning: 0% user + 0% kernel E 486 system ActivityManager +0% 1567/com.android.providers.calendar: 0% user + 0% kernel E 486 system ActivityManager +0% 1585/android.process.acore: 0% user + 0% kernel E 486 system ActivityManager +0% 1618/com.android.calendar: 0% user + 0% kernel E 486 system ActivityManager 41% TOTAL: 22% user + 13% kernel + 4.6% iowait + 1.2% softirq E 486 system ActivityManager CPU usage from 185394ms to 185394ms ago (1970-01-01 00:00:00.000 to 1970-01-01 00:00:00.000) with 0% awake: E 486 system ActivityManager 0% TOTAL: 0% user + 0% kernel W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner Binder:486_3 (1056) at int com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.view.InputChannel)(WindowManagerService.java:1884) waiters=2 in void com.android.server.wm.WindowManagerService.notifyAppRelaunchesCleared(android.os.IBinder) for 509ms W 486 system art Long monitor contention with owner Binder:486_8 (1472) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=2 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 365ms W 486 system art Long monitor contention with owner Binder:486_8 (1472) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=1 in void com.android.server.wm.WindowAnimator$1.doFrame(long) for 515ms I 1525 com.android.launcher OpenGLRenderer Initialized EGL, version 1.4 D 1525 com.android.launcher OpenGLRenderer Swap behavior 2 I 1525 com.android.launcher Choreographer Skipped 60 frames! The application may be doing too much work on its main thread. D 486 system ActivityManager Sending BOOT_COMPLETE user #0 I 486 system ActivityManager Killing 1080:com.android.systemui/u0a26 (adj -800): bg anr W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) V 486 system KeyguardServiceDelegate *** Keyguard disconnected (boo!) W 486 system InputDispatcher channel 'c707108 DockedStackDivider (server)' ~ Consumer closed input channel or an error occurred. events=0x9 E 486 system InputDispatcher channel 'c707108 DockedStackDivider (server)' ~ Channel is unrecoverably broken and will be disposed! W 486 system InputDispatcher channel '6a3fa81 StatusBar (server)' ~ Consumer closed input channel or an error occurred. events=0x9 E 486 system InputDispatcher channel '6a3fa81 StatusBar (server)' ~ Channel is unrecoverably broken and will be disposed! W 486 system InputDispatcher channel '33a5eac AssistPreviewPanel (server)' ~ Consumer closed input channel or an error occurred. events=0x9 E 486 system InputDispatcher channel '33a5eac AssistPreviewPanel (server)' ~ Channel is unrecoverably broken and will be disposed! W 486 system InputDispatcher channel '498630a NavigationBar (server)' ~ Consumer closed input channel or an error occurred. events=0x9 E 486 system InputDispatcher channel '498630a NavigationBar (server)' ~ Channel is unrecoverably broken and will be disposed! W 486 system InputDispatcher channel '5dd23b0 com.android.systemui.ImageWallpaper (server)' ~ Consumer closed input channel or an error occurred. events=0x9 E 486 system InputDispatcher channel '5dd23b0 com.android.systemui.ImageWallpaper (server)' ~ Channel is unrecoverably broken and will be disposed! W 486 system InputDispatcher channel 'eecbb69 DockedStackDivider (server)' ~ Consumer closed input channel or an error occurred. events=0x9 E 486 system InputDispatcher channel 'eecbb69 DockedStackDivider (server)' ~ Channel is unrecoverably broken and will be disposed! W 486 system InputDispatcher channel '7db448b AssistPreviewPanel (server)' ~ Consumer closed input channel or an error occurred. events=0x9 E 486 system InputDispatcher channel '7db448b AssistPreviewPanel (server)' ~ Channel is unrecoverably broken and will be disposed! D 486 system WifiService Client connection lost with reason: 4 D 486 system GraphicsStats Buffer count: 2 W 486 system AudioService Current remote volume controller died, unregistering I 486 system ActivityManager Process com.android.systemui (pid 1080) has died D 486 system ActivityManager cleanUpApplicationRecord -- 1080 W 486 system WallpaperManagerService Wallpaper service gone: ComponentInfo{com.android.systemui/com.android.systemui.ImageWallpaper} W 486 system ActivityManager Scheduling restart of crashed service com.android.systemui/.ImageWallpaper in 0ms W 486 system ActivityManager Scheduling restart of crashed service com.android.systemui/.keyguard.KeyguardService in 0ms W 486 system ActivityManager Scheduling restart of crashed service com.android.systemui/.SystemUIService in 0ms W 486 system ActivityManager Re-adding persistent process ProcessRecord{c7eaaf9 1080:com.android.systemui/u0a26} W 486 system VolumeController Error calling dismiss W 486 system VolumeController android.os.DeadObjectException W 486 system VolumeController at android.os.BinderProxy.transactNative(Native Method) W 486 system VolumeController at android.os.BinderProxy.transact(Binder.java:615) W 486 system VolumeController at android.media.IVolumeController$Stub$Proxy.dismiss(IVolumeController.java:162) W 486 system VolumeController at com.android.server.audio.AudioService$VolumeController.postDismiss(AudioService.java:6138) W 486 system VolumeController at com.android.server.audio.AudioService.setVolumeController(AudioService.java:5986) W 486 system VolumeController at com.android.server.audio.AudioService$4.binderDied(AudioService.java:5995) W 486 system VolumeController at android.os.BinderProxy.sendDeathNotice(Binder.java:688) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system libprocessgroup failed to open /acct/uid_10026/pid_1080/cgroup.procs: No such file or directory D 486 system ConnectivityService ConnectivityService NetworkRequestInfo binderDied(NetworkRequest [ LISTEN id=4, [] ], android.os.BinderProxy@33f4d80) E 486 system ConnectivityService RemoteException caught trying to send a callback msg for NetworkRequest [ LISTEN id=4, [] ] I 486 system ActivityManager Start proc 1658:com.android.systemui/u0a26 for restart com.android.systemui W 486 system BroadcastQueue Failure sending broadcast Intent { act=android.intent.action.TIME_TICK flg=0x50000014 (has extras) } W 486 system BroadcastQueue android.os.RemoteException: app.thread must not be null W 486 system BroadcastQueue at com.android.server.am.BroadcastQueue.performReceiveLocked(BroadcastQueue.java:492) W 486 system BroadcastQueue at com.android.server.am.BroadcastQueue.deliverToRegisteredReceiverLocked(BroadcastQueue.java:666) W 486 system BroadcastQueue at com.android.server.am.BroadcastQueue.processNextBroadcast(BroadcastQueue.java:951) W 486 system BroadcastQueue at com.android.server.am.BroadcastQueue$BroadcastHandler.handleMessage(BroadcastQueue.java:172) W 486 system BroadcastQueue at android.os.Handler.dispatchMessage(Handler.java:102) W 486 system BroadcastQueue at android.os.Looper.loop(Looper.java:154) W 486 system BroadcastQueue at android.os.HandlerThread.run(HandlerThread.java:61) W 486 system BroadcastQueue at com.android.server.ServiceThread.run(ServiceThread.java:46) W 486 system BroadcastQueue Failure sending broadcast Intent { act=android.intent.action.BOOT_COMPLETED flg=0x9000010 (has extras) } W 486 system BroadcastQueue android.os.RemoteException: app.thread must not be null W 486 system BroadcastQueue at com.android.server.am.BroadcastQueue.performReceiveLocked(BroadcastQueue.java:492) W 486 system BroadcastQueue at com.android.server.am.BroadcastQueue.deliverToRegisteredReceiverLocked(BroadcastQueue.java:666) W 486 system BroadcastQueue at com.android.server.am.BroadcastQueue.processNextBroadcast(BroadcastQueue.java:951) W 486 system BroadcastQueue at com.android.server.am.BroadcastQueue$BroadcastHandler.handleMessage(BroadcastQueue.java:172) W 486 system BroadcastQueue at android.os.Handler.dispatchMessage(Handler.java:102) W 486 system BroadcastQueue at android.os.Looper.loop(Looper.java:154) W 486 system BroadcastQueue at android.os.HandlerThread.run(HandlerThread.java:61) W 486 system BroadcastQueue at com.android.server.ServiceThread.run(ServiceThread.java:46) W 486 system BroadcastQueue Failure sending broadcast Intent { act=android.intent.action.TIME_TICK flg=0x50000014 (has extras) } W 486 system BroadcastQueue android.os.RemoteException: app.thread must not be null W 486 system BroadcastQueue at com.android.server.am.BroadcastQueue.performReceiveLocked(BroadcastQueue.java:492) W 486 system BroadcastQueue at com.android.server.am.BroadcastQueue.deliverToRegisteredReceiverLocked(BroadcastQueue.java:666) W 486 system BroadcastQueue at com.android.server.am.BroadcastQueue.processNextBroadcast(BroadcastQueue.java:951) W 486 system BroadcastQueue at com.android.server.am.BroadcastQueue$BroadcastHandler.handleMessage(BroadcastQueue.java:172) W 486 system BroadcastQueue at android.os.Handler.dispatchMessage(Handler.java:102) W 486 system BroadcastQueue at android.os.Looper.loop(Looper.java:154) W 486 system BroadcastQueue at android.os.HandlerThread.run(HandlerThread.java:61) W 486 system BroadcastQueue at com.android.server.ServiceThread.run(ServiceThread.java:46) E 486 system BootReceiver Error reading /data/system/last-header.txt E 486 system BootReceiver java.io.FileNotFoundException: /data/system/last-header.txt (No such file or directory) E 486 system BootReceiver at java.io.FileInputStream.open(Native Method) E 486 system BootReceiver at java.io.FileInputStream.<init>(FileInputStream.java:146) E 486 system BootReceiver at android.os.FileUtils.readTextFile(FileUtils.java:263) E 486 system BootReceiver at com.android.server.BootReceiver.getPreviousBootHeaders(BootReceiver.java:121) E 486 system BootReceiver at com.android.server.BootReceiver.getBootHeadersToLogAndUpdate(BootReceiver.java:143) E 486 system BootReceiver at com.android.server.BootReceiver.logBootEvents(BootReceiver.java:163) E 486 system BootReceiver at com.android.server.BootReceiver.-wrap2(BootReceiver.java) E 486 system BootReceiver at com.android.server.BootReceiver$1.run(BootReceiver.java:93) I 486 system RecoverySystem No recovery log file I 486 system BootReceiver No existing last log timestamp file /data/system/log-files.xml; starting empty I 486 system ActivityManager Start proc 1673:com.android.dialer/u0a10 for broadcast com.android.dialer/.calllog.CallLogReceiver W 486 system BroadcastQueue Failure sending broadcast Intent { act=android.intent.action.TIME_TICK flg=0x50000014 (has extras) } W 486 system BroadcastQueue android.os.RemoteException: app.thread must not be null W 486 system BroadcastQueue at com.android.server.am.BroadcastQueue.performReceiveLocked(BroadcastQueue.java:492) W 486 system BroadcastQueue at com.android.server.am.BroadcastQueue.deliverToRegisteredReceiverLocked(BroadcastQueue.java:666) W 486 system BroadcastQueue at com.android.server.am.BroadcastQueue.processNextBroadcast(BroadcastQueue.java:951) W 486 system BroadcastQueue at com.android.server.am.BroadcastQueue$BroadcastHandler.handleMessage(BroadcastQueue.java:172) W 486 system BroadcastQueue at android.os.Handler.dispatchMessage(Handler.java:102) W 486 system BroadcastQueue at android.os.Looper.loop(Looper.java:154) W 486 system BroadcastQueue at android.os.HandlerThread.run(HandlerThread.java:61) W 486 system BroadcastQueue at com.android.server.ServiceThread.run(ServiceThread.java:46) I 486 system BootReceiver Copying audit failures to DropBox I 486 system BootReceiver Checking for fsck errors W 1658 Binder Binder call failed. W 1658 Binder android.os.DeadObjectException W 1658 Binder at android.os.BinderProxy.transactNative(Native Method) W 1658 Binder at android.os.BinderProxy.transact(Binder.java:615) W 1658 Binder at android.content.IIntentReceiver$Stub$Proxy.performReceive(IIntentReceiver.java:124) W 1658 Binder at android.app.ActivityThread$ApplicationThread.scheduleRegisteredReceiver(ActivityThread.java:946) W 1658 Binder at android.app.ApplicationThreadNative.onTransact(ApplicationThreadNative.java:404) W 1658 Binder at android.os.Binder.execTransact(Binder.java:565) W 1658 System ClassLoader referenced unknown path: /system/priv-app/SystemUI/lib/arm W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system art Background partial concurrent mark sweep GC freed 13083(1324KB) AllocSpace objects, 18(1224KB) LOS objects, 33% free, 5MB/8MB, paused 5.336ms total 151.061ms V 1658 com.android.systemui SystemUIService Starting SystemUI services for user 0. W 1673 com.android.dialer System ClassLoader referenced unknown path: /system/priv-app/Dialer/lib/arm W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 1673 com.android.dialer ExtensionsFactory No custom extensions. I 1673 com.android.dialer BlockedNumbersAuto Updating state as already checked for auto-migrate. I 1673 com.android.dialer BlockedNumbersAuto Attempting to auto-migrate. D 1149 com.android.phone CarrierConfigLoader mHandler: 13 phoneId: 0 D 1149 com.android.phone CarrierConfigLoader mHandler: 7 phoneId: 0 E 1149 com.android.phone CarrierConfigLoader Cannot restore config with null packageName or iccid. D 1149 com.android.phone CarrierConfigLoader Binding to com.android.carrierconfig for phone 0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1673 com.android.dialer CountryDetector No location permissions, not registering for location updates. I 486 system ActivityManager Start proc 1698:com.android.carrierconfig/u0a5 for service com.android.carrierconfig/.DefaultCarrierConfigService D 1618 com.android.calendar AlertReceiver onReceive: a=android.intent.action.BOOT_COMPLETED Intent { act=android.intent.action.BOOT_COMPLETED flg=0x9000010 cmp=com.android.calendar/.alerts.AlertReceiver (has extras) } I 1400 com.android.deskclock AlarmClock AlarmInitReceiver android.intent.action.BOOT_COMPLETED W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1698 System ClassLoader referenced unknown path: /system/priv-app/CarrierConfig/lib/arm I 1673 com.android.dialer BlockedNumbersAuto Auto-migrating: no blocked numbers. V 1400 com.android.deskclock AlarmClock AlarmInitReceiver finished D 1698 DefaultCarrierConfigService Service created I 486 system ActivityManager Start proc 1717:com.android.email/u0a42 for broadcast com.android.email/.service.EmailUpgradeBroadcastReceiver D 1149 com.android.phone CarrierConfigLoader Connected to config app: com.android.carrierconfig/com.android.carrierconfig.DefaultCarrierConfigService D 1149 com.android.phone CarrierConfigLoader mHandler: 3 phoneId: 0 D 1698 DefaultCarrierConfigService Config being fetched D 1698 DefaultCarrierConfigService java.io.FileNotFoundException: carrier_config_.xml E 1149 com.android.phone CarrierConfigLoader Cannot save config with null packageName or iccid. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 1149 com.android.phone CarrierConfigLoader mHandler: 5 phoneId: 0 E 1149 com.android.phone PhoneInterfaceManager [PhoneIntfMgr] getCarrierPackageNamesForIntent: No UICC I 486 system Telecom PhoneAccountRegistrar: SimCallManager queried, returning: null: TSI.gSCMFU@AA8 W 1717 System ClassLoader referenced unknown path: /system/app/Email/lib/arm W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system ActivityManager Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found D 1717 com.android.email ActivityThread Loading provider com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider W 486 system ActivityManager Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found D 1717 com.android.email ActivityThread Loading provider com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider W 486 system ActivityManager Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found D 1717 com.android.email ActivityThread Loading provider com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider W 486 system ActivityManager Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found D 1717 com.android.email ActivityThread Loading provider com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider W 486 system ActivityManager Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.Session.setWallpaperPosition(android.os.IBinder, float, float, float, float) for 1.015s W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in void com.android.server.wm.WindowState$DeathRecipient.binderDied() for 941ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=2 in void com.android.server.wm.WindowState$DeathRecipient.binderDied() for 942ms I 486 system WindowManager WIN DEATH: Window{7db448b u0 AssistPreviewPanel} W 486 system InputDispatcher Attempted to unregister already unregistered input channel '7db448b AssistPreviewPanel (server)' W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=3 in void com.android.server.wm.WindowState$DeathRecipient.binderDied() for 955ms I 486 system InputReader Reconfiguring input devices. changes=0x00000010 I 486 system WindowManager WIN DEATH: Window{5dd23b0 u0 com.android.systemui.ImageWallpaper} W 486 system InputDispatcher Attempted to unregister already unregistered input channel '5dd23b0 com.android.systemui.ImageWallpaper (server)' W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=4 in void com.android.server.wm.WindowState$DeathRecipient.binderDied() for 959ms I 486 system WindowManager WIN DEATH: Window{6a3fa81 u0 StatusBar} W 486 system InputDispatcher Attempted to unregister already unregistered input channel '6a3fa81 StatusBar (server)' W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=5 in void com.android.server.wm.WindowManagerService$9.binderDied() for 966ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=6 in void com.android.server.wm.WindowState$DeathRecipient.binderDied() for 965ms I 486 system WindowManager WIN DEATH: Window{33a5eac u0 AssistPreviewPanel} W 486 system InputDispatcher Attempted to unregister already unregistered input channel '33a5eac AssistPreviewPanel (server)' W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=7 in void com.android.server.wm.WindowState$DeathRecipient.binderDied() for 970ms I 486 system WindowManager WIN DEATH: Window{498630a u0 NavigationBar} W 486 system InputDispatcher Attempted to unregister already unregistered input channel '498630a NavigationBar (server)' W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=8 in void com.android.server.wm.WindowState$DeathRecipient.binderDied() for 968ms I 486 system WindowManager WIN DEATH: Window{c707108 u0 DockedStackDivider} W 486 system InputDispatcher Attempted to unregister already unregistered input channel 'c707108 DockedStackDivider (server)' W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=9 in void com.android.server.wm.Session.binderDied() for 970ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=10 in float com.android.server.wm.WindowManagerService.getCurrentAnimatorScale() for 769ms I 486 system WindowManager WIN DEATH: Window{eecbb69 u0 DockedStackDivider} W 486 system InputDispatcher Attempted to unregister already unregistered input channel 'eecbb69 DockedStackDivider (server)' V 1658 com.android.systemui MediaRouter Adding route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=null types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null } V 1658 com.android.systemui MediaRouter Updating audio routes: AudioRoutesInfo{ type=SPEAKER } V 1658 com.android.systemui MediaRouter Selecting route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=null types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null } I 486 system Choreographer Skipped 35 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system WindowManager On display=0 Rebuild removed 2 windows but added 1 rebuildAppWindowListLocked() callers=com.android.server.wm.WindowManagerService.rebuildAppWindowListLocked:9438 com.android.server.wm.WindowManagerService.handleAnimatingStoppedAndTransitionLocked:9582 com.android.server.wm.WindowSurfacePlacer.performSurfacePlacementInner:350 com.android.server.wm.WindowSurfacePlacer.performSurfacePlacementLoop:236 com.android.server.wm.WindowSurfacePlacer.performSurfacePlacement:184 com.android.server.wm.WindowManagerService.removeWindowInnerLocked:2639 com.android.server.wm.AppWindowToken.destroySurfaces:422 com.android.server.wm.AppWindowToken.destroySurfaces:384 com.android.server.wm.WindowStateAnimator.finishExit:566 com.android.server.wm.WindowStateAnimator.stepAnimationLocked:492 W 486 system WindowManager This window was lost: Window{c135c0e u0 com.android.settings/com.android.settings.FallbackHome} W 486 system WindowManager mDisplayId=0 mSession=Session{a56f3f 1332:1000} mClient=android.os.BinderProxy@fb9d209 W 486 system WindowManager mOwnerUid=1000 mShowToOwnerOnly=true package=com.android.settings appop=NONE W 486 system WindowManager mAttrs=WM.LayoutParams{(0,0)(fillxfill) sim=#20 ty=1 fl=#81810500 pfl=0x20000 wanim=0x1030468 vsysui=0x1606 needsMenuKey=2} W 486 system WindowManager Requested w=1280 h=800 mLayoutSeq=30 W 486 system WindowManager mBaseLayer=21000 mSubLayer=0 mAnimLayer=21000+0=21000 mLastLayer=21005 W 486 system WindowManager mToken=AppWindowToken{247c5dd token=Token{90942c6 ActivityRecord{280c0a1 u0 com.android.settings/.FallbackHome t2}}} W 486 system WindowManager mRootToken=AppWindowToken{247c5dd token=Token{90942c6 ActivityRecord{280c0a1 u0 com.android.settings/.FallbackHome t2}}} W 486 system WindowManager mAppToken=AppWindowToken{247c5dd token=Token{90942c6 ActivityRecord{280c0a1 u0 com.android.settings/.FallbackHome t2}}} W 486 system WindowManager isAnimatingWithSavedSurface()=false mAppDied=false W 486 system WindowManager mViewVisibility=0x8 mHaveFrame=true mObscured=false W 486 system WindowManager mSeq=0 mSystemUiVisibility=0x1606 W 486 system WindowManager mGivenContentInsets=[0,0][0,0] mGivenVisibleInsets=[0,0][0,0] W 486 system WindowManager mMergedConfiguration={1.0 ?mcc?mnc [en_US] ldltr sw800dp w1280dp h728dp 160dpi xlrg land finger -keyb/h/h -nav/h s.5} W 486 system WindowManager mHasSurface=true mShownPosition=[0,0] isReadyForDisplay()=false hasSavedSurface()=false mWindowRemovalAllowed=true W 486 system WindowManager mFrame=[0,0][1280,800] last=[0,0][1280,800] W 486 system WindowManager Frames: containing=[0,0][1280,800] parent=[0,0][1280,800] W 486 system WindowManager display=[0,0][1280,800] overscan=[0,0][1280,800] W 486 system WindowManager content=[0,0][1280,752] visible=[0,0][1280,752] W 486 system WindowManager decor=[0,0][1280,800] W 486 system WindowManager outset=[0,0][1280,752] W 486 system WindowManager Cur insets: overscan=[0,0][0,0] content=[0,0][0,48] visible=[0,0][0,48] stable=[0,24][0,48] surface=[0,0][0,0] outsets=[0,0][0,0] W 486 system WindowManager Lst insets: overscan=[0,0][0,0] content=[0,0][0,48] visible=[0,0][0,48] stable=[0,24][0,48] physical=[0,0][0,0] outset=[0,0][0,0] W 486 system WindowManager WindowStateAnimator{9989236 com.android.settings/com.android.settings.FallbackHome}: W 486 system WindowManager mSurface=Surface(name=com.android.settings/com.android.settings.FallbackHome) W 486 system WindowManager Surface: shown=false layer=21005 alpha=1.0 rect=(0.0,0.0) 1280.0 x 800.0 W 486 system WindowManager mDrawState=HAS_DRAWN mLastHidden=true W 486 system WindowManager mSystemDecorRect=[0,0][1280,800] last=[0,0][0,0] mHasClipRect=false mLastClipRect=[0,0][1280,800] W 486 system WindowManager mGlobalScale=1.0 mDsDx=1.0 mDtDx=0.0 mDsDy=0.0 mDtDy=1.0 W 486 system WindowManager mAnimatingExit=false mRemoveOnExit=true mDestroying=true mRemoved=false W 486 system WindowManager Current app token list: V 486 system WindowManager Stack #0 tasks from bottom to top: V 486 system WindowManager Task #3 activities from bottom to top: V 486 system WindowManager activity #0: Token{e0a76d0 null} V 486 system WindowManager Task #4 activities from bottom to top: V 486 system WindowManager activity #0: Token{d5c6d78 ActivityRecord{623fedb u0 com.android.launcher/com.android.launcher2.Launcher t4}} W 486 system WindowManager Final window list: V 486 system WindowManager Display #0 V 486 system WindowManager #3: Window{498630a u0 NavigationBar EXITING} V 486 system WindowManager #2: Window{6a3fa81 u0 StatusBar EXITING} V 486 system WindowManager #1: Window{db0591e u0 KeyguardScrim} V 486 system WindowManager #0: Window{d1c6fa u0 com.android.launcher/com.android.launcher2.Launcher} D 486 system TrustManagerService Removing dead TrustListener. V 1658 com.android.systemui FingerprintManager FingerprintManagerService was null W 1658 com.android.systemui FingerprintManager isFingerprintHardwareDetected(): Service not connected! W 1658 com.android.systemui FingerprintManager addLockoutResetCallback(): Service not connected! W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 1658 com.android.systemui OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 1658 com.android.systemui OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process W 486 system ActivityManager Unable to start service Intent { act=com.android.mail.action.BACKUP_DATA_CHANGED pkg=com.android.email } U=0: not found W 486 system ActivityManager Unable to start service Intent { act=com.android.mail.action.BACKUP_DATA_CHANGED pkg=com.android.email } U=0: not found W 486 system ActivityManager Unable to start service Intent { act=com.android.mail.action.BACKUP_DATA_CHANGED pkg=com.android.email } U=0: not found W 486 system ActivityManager Unable to start service Intent { act=com.android.mail.action.BACKUP_DATA_CHANGED pkg=com.android.email } U=0: not found W 486 system ActivityManager Unable to start service Intent { act=com.android.mail.action.BACKUP_DATA_CHANGED pkg=com.android.email } U=0: not found W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1658 com.android.systemui vol.Events writeEvent collection_started W 486 system ActivityManager Unable to start service Intent { act=com.android.mail.action.BACKUP_DATA_CHANGED pkg=com.android.email } U=0: not found W 486 system ActivityManager Unable to start service Intent { act=com.android.mail.action.BACKUP_DATA_CHANGED pkg=com.android.email } U=0: not found I 1658 com.android.systemui vol.Events writeEvent external_ringer_mode_changed normal I 1658 com.android.systemui vol.Events writeEvent internal_ringer_mode_changed normal I 237 /system/bin/mediaserver MediaPlayerService MediaPlayerService::getOMX I 1658 com.android.systemui OMXClient MuxOMX ctor I 234 media.codec OMXMaster makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process W 1717 com.android.email art Long monitor contention with owner AsyncTask #1 (1735) at com.android.mail.preferences.MailPrefs com.android.mail.preferences.MailPrefs.get(android.content.Context)(MailPrefs.java:-1) waiters=0 in com.android.mail.preferences.MailPrefs com.android.mail.preferences.MailPrefs.get(android.content.Context) for 567ms W 1717 com.android.email art Long monitor contention with owner AsyncTask #1 (1735) at com.android.mail.preferences.MailPrefs com.android.mail.preferences.MailPrefs.get(android.content.Context)(MailPrefs.java:-1) waiters=1 in com.android.mail.preferences.MailPrefs com.android.mail.preferences.MailPrefs.get(android.content.Context) for 557ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1717 com.android.email art Long monitor contention with owner AsyncTask #1 (1735) at com.android.mail.preferences.MailPrefs com.android.mail.preferences.MailPrefs.get(android.content.Context)(MailPrefs.java:-1) waiters=2 in com.android.mail.preferences.MailPrefs com.android.mail.preferences.MailPrefs.get(android.content.Context) for 571ms W 486 system ActivityManager Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found W 486 system ActivityManager Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found W 486 system ActivityManager Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out I 1717 com.android.email Email Observing account changes for notifications W 486 system ActivityManager Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found W 486 system ActivityManager Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found W 486 system ActivityManager Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system ActivityManager Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found W 486 system ActivityManager Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found I 486 system ActivityManager Start proc 1763:com.android.gallery3d/u0a45 for broadcast com.android.gallery3d/com.android.camera.DisableCameraReceiver W 486 system ActivityManager Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found I 1717 com.android.email Email Onetime initialization: 1 W 486 system ActivityManager Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1717 com.android.email Email Onetime initialization: 2 I 1717 com.android.email Email Onetime initialization: completed. W 486 system ActivityManager Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found W 486 system ActivityManager Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found E 1717 com.android.email ActivityThread Service com.android.email.service.EmailBroadcastProcessorService has leaked ServiceConnection com.android.emailcommon.service.ServiceProxy$ProxyConnection@df185d0 that was originally bound here E 1717 com.android.email ActivityThread android.app.ServiceConnectionLeaked: Service com.android.email.service.EmailBroadcastProcessorService has leaked ServiceConnection com.android.emailcommon.service.ServiceProxy$ProxyConnection@df185d0 that was originally bound here E 1717 com.android.email ActivityThread at android.app.LoadedApk$ServiceDispatcher.<init>(LoadedApk.java:1336) E 1717 com.android.email ActivityThread at android.app.LoadedApk.getServiceDispatcher(LoadedApk.java:1231) E 1717 com.android.email ActivityThread at android.app.ContextImpl.bindServiceCommon(ContextImpl.java:1450) E 1717 com.android.email ActivityThread at android.app.ContextImpl.bindService(ContextImpl.java:1422) E 1717 com.android.email ActivityThread at android.content.ContextWrapper.bindService(ContextWrapper.java:636) E 1717 com.android.email ActivityThread at com.android.emailcommon.service.ServiceProxy.setTask(ServiceProxy.java:181) E 1717 com.android.email ActivityThread at com.android.emailcommon.service.ServiceProxy.test(ServiceProxy.java:224) E 1717 com.android.email ActivityThread at com.android.email.service.EmailServiceUtils.isServiceAvailable(EmailServiceUtils.java:160) E 1717 com.android.email ActivityThread at com.android.email.provider.AccountReconciler.reconcileAccountsInternal(AccountReconciler.java:171) E 1717 com.android.email ActivityThread at com.android.email.provider.AccountReconciler.reconcileAccounts(AccountReconciler.java:115) E 1717 com.android.email ActivityThread at com.android.email.service.EmailBroadcastProcessorService.reconcileAndStartServices(EmailBroadcastProcessorService.java:305) E 1717 com.android.email ActivityThread at com.android.email.service.EmailBroadcastProcessorService.onBootCompleted(EmailBroadcastProcessorService.java:295) E 1717 com.android.email ActivityThread at com.android.email.service.EmailBroadcastProcessorService.onHandleIntent(EmailBroadcastProcessorService.java:130) E 1717 com.android.email ActivityThread at android.app.IntentService$ServiceHandler.handleMessage(IntentService.java:68) E 1717 com.android.email ActivityThread at android.os.Handler.dispatchMessage(Handler.java:102) E 1717 com.android.email ActivityThread at android.os.Looper.loop(Looper.java:154) E 1717 com.android.email ActivityThread at android.os.HandlerThread.run(HandlerThread.java:61) W 486 system ActivityManager Unbind failed: could not find connection for android.os.BinderProxy@987f4e6 I 1658 com.android.systemui vol.Events writeEvent level_changed STREAM_ALARM 6 I 1658 com.android.systemui vol.Events writeEvent level_changed STREAM_BLUETOOTH_SCO 7 I 1658 com.android.systemui vol.Events writeEvent level_changed STREAM_MUSIC 11 I 1658 com.android.systemui vol.Events writeEvent level_changed STREAM_RING 5 I 1658 com.android.systemui vol.Events writeEvent level_changed STREAM_SYSTEM 5 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1658 com.android.systemui vol.Events writeEvent level_changed STREAM_VOICE_CALL 4 I 1763 G:DisableCameraReceiver no back camera I 1763 G:DisableCameraReceiver disable all camera activities I 1039 com.android.inputmethod.latin SystemBroadcastReceiver Boot has been completed I 1039 com.android.inputmethod.latin SystemBroadcastReceiver toggleAppIcon() : FLAG_SYSTEM = true W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system ActivityManager Start proc 1779:com.android.onetimeinitializer/u0a19 for broadcast com.android.onetimeinitializer/.OneTimeInitializerReceiver W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1779 System ClassLoader referenced unknown path: /system/priv-app/OneTimeInitializer/lib/arm V 1779 com.android.onetimeinitializer OneTimeInitializerRece OneTimeInitializerReceiver.onReceive W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in float com.android.server.wm.WindowManagerService.getCurrentAnimatorScale() for 248ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session, android.view.IWindow) for 520ms I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. V 1149 com.android.phone VvmBootCompletedRcvr processing subId list W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1779 com.android.onetimeinitializer OneTimeInitializerServ Updating to version 1. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1149 com.android.phone VvmSimChangeReceiver Received SIM change for invalid subscription id. D 1473 android.process.media MtpService starting MTP server in MTP mode I 1473 android.process.media MediaProvider Upgrading media database from version 0 to 800, which will destroy all old data W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 1473 android.process.media MediaProvider Adjusting external storage paths to: /storage/emulated/0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) E 1473 android.process.media SQLiteLog (1) no such table: files I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Alarm_Beep_01.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Alarm_Beep_02.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Alarm_Beep_03.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowManagerService$H.handleMessage(android.os.Message)(WindowManagerService.java:8361) waiters=1 in void com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session, android.view.IWindow) for 520ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in float com.android.server.wm.WindowManagerService.getCurrentAnimatorScale() for 514ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system ActivityManager Displayed com.android.launcher/com.android.launcher2.Launcher: +9s636ms (total +16s539ms) I 1525 com.android.launcher Choreographer Skipped 156 frames! The application may be doing too much work on its main thread. I 1658 com.android.systemui imx6.gralloc open gpu gralloc module! I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Alarm_Buzzer.ogg since build fingerprint changed W 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Alarm_Classic.oggsince ringtone setting didn't finish W 1473 android.process.media MediaProvider Missing volume for /system; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media; assuming invalid W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1473 android.process.media MediaProvider Missing volume for /system/media/audio; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Alarm_Beep_01.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Alarm_Beep_02.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Alarm_Beep_03.ogg; assuming invalid E 237 /system/bin/mediaserver MetadataRetrieverClient failed to extract an album art W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Alarm_Buzzer.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Alarm_Classic.ogg; assuming invalid W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1400 com.android.deskclock AlarmClock Detected change to system default alarm ringtone; clearing caches I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Alarm_Rooster_02.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Argon.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Barium.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Carbon.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Cesium.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Fermium.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Hassium.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Helium.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Krypton.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Neon.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Neptunium.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Nobelium.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Osmium.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Oxygen.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Platinum.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Plutonium.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Promethium.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/alarms/Scandium.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Adara.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Aldebaran.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Altair.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Alya.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.ui (517) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=0 in void com.android.server.wm.WindowAnimator$1.doFrame(long) for 1.040s W 486 system art Long monitor contention with owner android.ui (517) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=1 in void com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session, android.view.IWindow) for 1.014s W 486 system art Long monitor contention with owner android.ui (517) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=2 in int com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.view.InputChannel) for 1.014s W 486 system InputMethodManagerService Focus gain on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@423de46 (uid=10016 pid=1525) W 1525 com.android.launcher System ClassLoader referenced unknown path: W 1525 com.android.launcher System ClassLoader referenced unknown path: /system/app/DeskClock/lib/arm D 1525 com.android.launcher ApplicationLoaders ignored Vulkan layer search path /system/app/DeskClock/lib/arm:/system/lib:/vendor/lib for namespace 0xb34a1090 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Antares.ogg since build fingerprint changed D 1658 com.android.systemui StorageNotification Notifying about private volume: VolumeInfo{private}: D 1658 com.android.systemui StorageNotification type=PRIVATE diskId=null partGuid=null mountFlags=0 mountUserId=-1 D 1658 com.android.systemui StorageNotification state=MOUNTED D 1658 com.android.systemui StorageNotification fsType=null fsUuid=null fsLabel=null D 1658 com.android.systemui StorageNotification path=/data internalPath=null W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1525 com.android.launcher Choreographer Skipped 70 frames! The application may be doing too much work on its main thread. I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Antimony.ogg since build fingerprint changed I 486 system art Background partial concurrent mark sweep GC freed 14928(1296KB) AllocSpace objects, 8(204KB) LOS objects, 33% free, 6MB/9MB, paused 3.581ms total 140.949ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Arcturus.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Argon.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Beat_Box_Android.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Bellatrix.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Beryllium.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Betelgeuse.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/CaffeineSnake.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Canopus.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Capella.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Castor.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/CetiAlpha.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=2 in int com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.view.InputChannel) for 325ms W 486 system InputMethodManagerService Window already focused, ignoring focus gain of: android.view.inputmethod.InputMethodManager$1@a7922a3 attribute=null, token = android.view.ViewRootImpl$W@a7145ff W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 363ms V 486 system KeyguardServiceDelegate *** Keyguard connected (yay!) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Cobalt.ogg since build fingerprint changed I 1618 com.android.calendar GlobalDismissManager no sender configured D 1618 com.android.calendar AlertService Beginning updateAlertNotification I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Cricket.ogg since build fingerprint changed D 1618 com.android.calendar AlertService No fired or scheduled alerts I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/DearDeer.ogg since build fingerprint changed D 1618 com.android.calendar AlertService Scheduling next alarm with AlarmScheduler. sEventReminderReceived: null I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Deneb.ogg since build fingerprint changed D 1618 com.android.calendar AlarmScheduler No events found starting within 1 week. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 1618 com.android.calendar AlertService 0 Action = android.intent.action.BOOT_COMPLETED D 1618 com.android.calendar AlertService Scheduling next alarm with AlarmScheduler. sEventReminderReceived: null D 1618 com.android.calendar AlarmScheduler No events found starting within 1 week. I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Doink.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/DontPanic.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Drip.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Electra.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/F1_MissedCall.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/F1_New_MMS.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/F1_New_SMS.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Fluorine.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Fomalhaut.ogg since build fingerprint changed I 1473 android.process.media art Do partial code cache collection, code=8KB, data=22KB I 1473 android.process.media art After code cache collection, code=8KB, data=22KB I 1473 android.process.media art Increasing code cache capacity to 128KB I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Gallium.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Heaven.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Helium.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Highwire.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Hojus.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowManagerService.showStrictModeViolation(int, int)(WindowManagerService.java:6257) waiters=1 in int com.android.server.wm.WindowManagerService.addWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.view.InputChannel) for 532ms W 486 system art Long monitor contention with owner Binder:486_F (1657) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=1 in void com.android.server.wm.WindowManagerService.showStrictModeViolation(int, int) for 538ms W 486 system art Long monitor contention with owner Binder:486_F (1657) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=2 in void com.android.server.policy.PhoneWindowManager.onKeyguardShowingStateChanged(boolean) for 539ms I 486 system Choreographer Skipped 31 frames! The application may be doing too much work on its main thread. W 486 system art Long monitor contention with owner Binder:486_F (1657) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=3 in void com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session, android.view.IWindow) for 527ms I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Iridium.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Krypton.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/KzurbSonar.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Lalande.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Merope.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Mira.ogg since build fingerprint changed W 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/OnTheHunt.oggsince ringtone setting didn't finish W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications; assuming invalid W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Alarm_Rooster_02.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Argon.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Barium.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Carbon.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Cesium.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Fermium.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Hassium.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Helium.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Krypton.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Neon.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Neptunium.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Nobelium.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Osmium.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Oxygen.ogg; assuming invalid W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Platinum.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Plutonium.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Promethium.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/alarms/Scandium.ogg; assuming invalid W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Adara.ogg; assuming invalid E 237 /system/bin/mediaserver MetadataRetrieverClient failed to extract an album art W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Aldebaran.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Altair.ogg; assuming invalid W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media art Waiting for a blocking GC DisableMovingGc I 1473 android.process.media art Starting a blocking GC DisableMovingGc W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Alya.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Antares.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Antimony.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Arcturus.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Argon.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Beat_Box_Android.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Bellatrix.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Beryllium.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Betelgeuse.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/CaffeineSnake.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Canopus.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Capella.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Castor.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/CetiAlpha.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Cobalt.ogg; assuming invalid W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Cricket.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/DearDeer.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Deneb.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Doink.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/DontPanic.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Drip.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Electra.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/F1_MissedCall.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/F1_New_MMS.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/F1_New_SMS.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Fluorine.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Fomalhaut.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Gallium.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Heaven.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Helium.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Highwire.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Hojus.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Iridium.ogg; assuming invalid W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Krypton.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/KzurbSonar.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Lalande.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Merope.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Mira.ogg; assuming invalid E 1673 com.android.dialer StrictMode Finalizing a Cursor that has not been deactivated or closed. database = /data/user/0/com.android.dialer/databases/dialer.db, table = filtered_numbers_table, query = SELECT _id FROM filtered_numbers_table WHERE (type=1) E 1673 com.android.dialer StrictMode android.database.sqlite.DatabaseObjectNotClosedException: Application did not close the cursor or database object that was opened here E 1673 com.android.dialer StrictMode at android.database.sqlite.SQLiteCursor.<init>(SQLiteCursor.java:98) E 1673 com.android.dialer StrictMode at android.database.sqlite.SQLiteDirectCursorDriver.query(SQLiteDirectCursorDriver.java:50) E 1673 com.android.dialer StrictMode at android.database.sqlite.SQLiteDatabase.rawQueryWithFactory(SQLiteDatabase.java:1318) E 1673 com.android.dialer StrictMode at android.database.sqlite.SQLiteQueryBuilder.query(SQLiteQueryBuilder.java:399) E 1673 com.android.dialer StrictMode at android.database.sqlite.SQLiteQueryBuilder.query(SQLiteQueryBuilder.java:294) E 1673 com.android.dialer StrictMode at com.android.dialer.database.FilteredNumberProvider.query(FilteredNumberProvider.java:96) E 1673 com.android.dialer StrictMode at android.content.ContentProvider.query(ContentProvider.java:1020) E 1673 com.android.dialer StrictMode at android.content.ContentProvider$Transport.query(ContentProvider.java:239) E 1673 com.android.dialer StrictMode at android.content.ContentResolver.query(ContentResolver.java:532) E 1673 com.android.dialer StrictMode at android.content.ContentResolver.query(ContentResolver.java:474) E 1673 com.android.dialer StrictMode at android.content.AsyncQueryHandler$WorkerHandler.handleMessage(AsyncQueryHandler.java:79) E 1673 com.android.dialer StrictMode at android.os.Handler.dispatchMessage(Handler.java:102) E 1673 com.android.dialer StrictMode at android.os.Looper.loop(Looper.java:154) E 1673 com.android.dialer StrictMode at android.os.HandlerThread.run(HandlerThread.java:61) E 1673 com.android.dialer StrictMode A resource was acquired at attached stack trace but never released. See java.io.Closeable for information on avoiding resource leaks. E 1673 com.android.dialer StrictMode java.lang.Throwable: Explicit termination method 'close' not called E 1673 com.android.dialer StrictMode at dalvik.system.CloseGuard.open(CloseGuard.java:180) E 1673 com.android.dialer StrictMode at android.content.ContentResolver$CursorWrapperInner.<init>(ContentResolver.java:2627) E 1673 com.android.dialer StrictMode at android.content.ContentResolver.query(ContentResolver.java:558) E 1673 com.android.dialer StrictMode at android.content.ContentResolver.query(ContentResolver.java:474) E 1673 com.android.dialer StrictMode at android.content.AsyncQueryHandler$WorkerHandler.handleMessage(AsyncQueryHandler.java:79) E 1673 com.android.dialer StrictMode at android.os.Handler.dispatchMessage(Handler.java:102) E 1673 com.android.dialer StrictMode at android.os.Looper.loop(Looper.java:154) E 1673 com.android.dialer StrictMode at android.os.HandlerThread.run(HandlerThread.java:61) W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/OnTheHunt.ogg; assuming invalid I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Palladium.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Plastic_Pipe.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Polaris.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Pollux.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Procyon.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Proxima.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Radon.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Rubidium.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Selenium.ogg since build fingerprint changed W 486 system art Long monitor contention with owner Binder:486_E (1656) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=1 in void com.android.server.wm.WindowManagerService$H.handleMessage(android.os.Message) for 1.052s W 486 system art Long monitor contention with owner Binder:486_E (1656) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=1 in void com.android.server.policy.PhoneWindowManager.onKeyguardShowingStateChanged(boolean) for 1.053s W 486 system art Long monitor contention with owner Binder:486_E (1656) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=2 in void com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session, android.view.IWindow) for 923ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1525 com.android.launcher Choreographer Skipped 62 frames! The application may be doing too much work on its main thread. I 1658 com.android.systemui Choreographer Skipped 188 frames! The application may be doing too much work on its main thread. I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Shaula.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Sirrah.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/SpaceSeed.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Spica.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Strontium.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Syrma.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/TaDa.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Talitha.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Tejat.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Thallium.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Tinkerbell.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Upsilon.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Vega.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Voila.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Xenon.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 460ms W 1525 com.android.launcher OpenGLRenderer Incorrectly called buildLayer on View: ShortcutAndWidgetContainer, destroying layer... I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/Zirconium.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/arcturus.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/moonbeam.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/pixiedust.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/pizzicato.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/regulus.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/sirius.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/tweeters.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/notifications/vega.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/ANDROMEDA.ogg since build fingerprint changed W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Palladium.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Plastic_Pipe.ogg; assuming invalid W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Polaris.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Pollux.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Procyon.ogg; assuming invalid E 237 /system/bin/mediaserver MetadataRetrieverClient failed to extract an album art W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Proxima.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Radon.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Rubidium.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Selenium.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Shaula.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Sirrah.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/SpaceSeed.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Spica.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Strontium.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Syrma.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/TaDa.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Talitha.ogg; assuming invalid W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Tejat.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Thallium.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Tinkerbell.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Upsilon.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Vega.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Voila.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Xenon.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/Zirconium.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/arcturus.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/moonbeam.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/pixiedust.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/pizzicato.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/regulus.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/sirius.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/tweeters.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/notifications/vega.ogg; assuming invalid W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/ANDROMEDA.ogg; assuming invalid E 237 /system/bin/mediaserver MetadataRetrieverClient failed to extract an album art W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out I 486 system Choreographer Skipped 31 frames! The application may be doing too much work on its main thread. W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 535ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Andromeda.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Aquila.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/ArgoNavis.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Atria.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/BOOTES.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Backroad.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/BeatPlucker.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/BentleyDubs.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Big_Easy.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/BirdLoop.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Bollywood.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/BussaMove.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/CANISMAJOR.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/CASSIOPEIA.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Cairo.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Calypso_Steel.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 528ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/CanisMajor.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/CaribbeanIce.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Carina.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Centaurus.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Champagne_Edition.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Club_Cubano.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/CrayonRock.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/CrazyDream.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/CurveBall.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Cygnus.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/DancinFool.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Ding.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/DonMessWivIt.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Draco.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/DreamTheme.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Eastern_Sky.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Enter_the_Nexus.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Eridani.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.setInsetsWindow(com.android.server.wm.Session, android.view.IWindow, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Region) for 522ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in void com.android.server.wm.WindowManagerService.setDockedStackDividerTouchRegion(android.graphics.Rect) for 527ms I 486 system StatusBarManagerService registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@a254983 I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/EtherShake.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/FreeFlight.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/FriendlyGhost.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Funk_Yall.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/GameOverGuitar.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Gimme_Mo_Town.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Girtab.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Glacial_Groove.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Growl.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/HalfwayHome.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Hydra.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/InsertCoin.ogg since build fingerprint changed W 1658 com.android.systemui System ClassLoader referenced unknown path: D 1658 com.android.systemui ApplicationLoaders ignored Vulkan layer search path /system/app/Camera2/lib/arm:/system/app/Camera2/Camera2.apk!/lib/armeabi-v7a:/system/lib:/vendor/lib for namespace 0xb34a1090 I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Kuma.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/LoopyLounge.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/LoveFlute.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Lyra.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Machina.ogg since build fingerprint changed D 486 system BluetoothManagerService Message: 20 D 486 system BluetoothManagerService Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@cabcfe1:true D 486 system BluetoothManagerService Message: 30 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/MidEvilJaunt.ogg since build fingerprint changed D 486 system BluetoothManagerService Message: 30 D 1658 com.android.systemui LocalBluetoothProfileManager Adding local MAP profile D 1658 com.android.systemui BluetoothMap Create BluetoothMap proxy object D 486 system BluetoothManagerService Message: 30 D 486 system BluetoothManagerService Message: 30 D 1658 com.android.systemui LocalBluetoothProfileManager LocalBluetoothProfileManager construction complete I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/MildlyAlarming.ogg since build fingerprint changed I 1658 com.android.systemui CameraManagerGlobal Connecting to camera service I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Nairobi.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Nassau.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/NewPlayer.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/No_Limits.ogg since build fingerprint changed D 1658 com.android.systemui OpenGLRenderer profile bars disabled D 1658 com.android.systemui OpenGLRenderer ambientRatio = 1.50 D 1658 com.android.systemui PhoneStatusBar disable: < EXPAND* icons alerts system_info BACK* HOME* RECENT* clock SEARCH* quick_settings > I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Noises1.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Noises2.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 1658 com.android.systemui PhoneStatusBar heads up is enabled I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Noises3.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/OrganDub.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Orion.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/PERSEUS.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Paradise_Island.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Pegasus.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Perseus.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Playa.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Pyxis.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Rasalas.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Revelation.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Rigel.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Ring_Classic_02.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Ring_Digital_02.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Ring_Synth_02.ogg since build fingerprint changed E 1149 com.android.phone PhoneInterfaceManager [PhoneIntfMgr] getCarrierPackageNamesForIntent: No UICC D 1149 com.android.phone CarrierSvcBindHelper No carrier app for: 0 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) E 1149 com.android.phone PhoneInterfaceManager [PhoneIntfMgr] getCarrierPackageNamesForIntent: No UICC D 1149 com.android.phone CarrierSvcBindHelper No carrier app for: 0 E 1149 com.android.phone PhoneInterfaceManager [PhoneIntfMgr] getCarrierPackageNamesForIntent: No UICC D 1149 com.android.phone CarrierSvcBindHelper No carrier app for: 0 W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out E 1149 com.android.phone PhoneInterfaceManager [PhoneIntfMgr] getCarrierPackageNamesForIntent: No UICC D 1149 com.android.phone CarrierSvcBindHelper No carrier app for: 0 W 486 system art Long monitor contention with owner android.ui (517) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=0 in void com.android.server.wm.WindowManagerService$H.handleMessage(android.os.Message) for 519ms W 486 system art Long monitor contention with owner android.ui (517) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=1 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 519ms I 486 system InputReader Reconfiguring input devices. changes=0x00000010 E 1149 com.android.phone PhoneInterfaceManager [PhoneIntfMgr] getCarrierPackageNamesForIntent: No UICC D 1149 com.android.phone CarrierSvcBindHelper No carrier app for: 0 I 486 system InputReader Reconfiguring input devices. changes=0x00000010 I 486 system InputReader Reconfiguring input devices. changes=0x00000010 I 486 system InputReader Reconfiguring input devices. changes=0x00000010 I 486 system InputReader Reconfiguring input devices. changes=0x00000010 I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Ring_Synth_04.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Road_Trip.ogg since build fingerprint changed W 486 system ResourceType No known package when getting value for resource number 0x7f0200fc W 486 system ResourceType No known package when getting value for resource number 0x7f0e03a1 W 486 system ResourceType No known package when getting value for resource number 0x7f0200fb W 486 system ResourceType No known package when getting value for resource number 0x7f0e092f W 486 system ResourceType No known package when getting value for resource number 0x7f0200fa W 486 system ResourceType No known package when getting value for resource number 0x7f0e07dd I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/RomancingTheTone.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Safari.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Savannah.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Scarabaeus.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Sceptrum.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Seville.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Shes_All_That.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/SilkyWay.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/SitarVsSitar.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Solarium.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/SpringyJalopy.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.ui (517) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=2 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 935ms I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Steppin_Out.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Terminated.ogg since build fingerprint changed W 486 system BroadcastQueue Timeout of broadcast BroadcastRecord{8cf6977 u-1 android.intent.action.TIME_TICK} - receiver=android.os.BinderProxy@7989041, started 10001ms ago W 486 system BroadcastQueue Receiver during timeout: BroadcastFilter{3585b27 u0 ReceiverList{b2f69e6 1080 com.android.systemui/10026/u0 remote:7989041}} W 1658 com.android.systemui Binder Binder call failed. W 1658 com.android.systemui Binder android.os.DeadObjectException W 1658 com.android.systemui Binder at android.os.BinderProxy.transactNative(Native Method) W 1658 com.android.systemui Binder at android.os.BinderProxy.transact(Binder.java:615) W 1658 com.android.systemui Binder at android.content.IIntentReceiver$Stub$Proxy.performReceive(IIntentReceiver.java:124) W 1658 com.android.systemui Binder at android.app.ActivityThread$ApplicationThread.scheduleRegisteredReceiver(ActivityThread.java:946) W 1658 com.android.systemui Binder at android.app.ApplicationThreadNative.onTransact(ApplicationThreadNative.java:404) W 1658 com.android.systemui Binder at android.os.Binder.execTransact(Binder.java:565) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Testudo.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Themos.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Third_Eye.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Thunderfoot.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/TwirlAway.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/URSAMINOR.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/UrsaMinor.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/VeryAlarmed.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner Binder:486_4 (1106) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=1 in void com.android.server.wm.WindowManagerService$H.handleMessage(android.os.Message) for 1.019s I 486 system Choreographer Skipped 62 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Vespa.ogg since build fingerprint changed I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/World.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1658 com.android.systemui KeyguardUpdateMonitor invalid subId in handleSimStateChange() W 1658 com.android.systemui KeyguardUpdateMonitor invalid subId in handleServiceStateChange() I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/Zeta.ogg since build fingerprint changed V 486 system KeyguardServiceDelegate **** SHOWN CALLED **** I 1658 com.android.systemui Choreographer Skipped 128 frames! The application may be doing too much work on its main thread. D 1658 com.android.systemui ViewRootImpl[StatusBar] changeCanvasOpacity: opaque=true I 1473 android.process.media MediaScanner forcing rescan of /system/media/audio/ringtones/hydra.ogg since build fingerprint changed W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 389ms W 1473 android.process.media MediaScanner Error opening directory '/oem/media/', skipping: No such file or directory. W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ui; assuming invalid W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Andromeda.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Aquila.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/ArgoNavis.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Atria.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/BOOTES.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Backroad.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/BeatPlucker.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/BentleyDubs.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Big_Easy.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/BirdLoop.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Bollywood.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/BussaMove.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/CANISMAJOR.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/CASSIOPEIA.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Cairo.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Calypso_Steel.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/CanisMajor.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/CaribbeanIce.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Carina.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Centaurus.ogg; assuming invalid W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Champagne_Edition.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Club_Cubano.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/CrayonRock.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/CrazyDream.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/CurveBall.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Cygnus.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/DancinFool.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Ding.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/DonMessWivIt.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Draco.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/DreamTheme.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Eastern_Sky.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Enter_the_Nexus.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Eridani.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/EtherShake.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/FreeFlight.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/FriendlyGhost.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Funk_Yall.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/GameOverGuitar.ogg; assuming invalid W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Gimme_Mo_Town.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Girtab.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Glacial_Groove.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Growl.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/HalfwayHome.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Hydra.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/InsertCoin.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Kuma.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/LoopyLounge.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/LoveFlute.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Lyra.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Machina.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/MidEvilJaunt.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/MildlyAlarming.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Nairobi.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Nassau.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/NewPlayer.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/No_Limits.ogg; assuming invalid W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Noises1.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Noises2.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Noises3.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/OrganDub.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Orion.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/PERSEUS.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Paradise_Island.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Pegasus.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Perseus.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Playa.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Pyxis.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Rasalas.ogg; assuming invalid E 237 /system/bin/mediaserver MetadataRetrieverClient failed to extract an album art W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Revelation.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Rigel.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Ring_Classic_02.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Ring_Digital_02.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Ring_Synth_02.ogg; assuming invalid W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Ring_Synth_04.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Road_Trip.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/RomancingTheTone.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Safari.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Savannah.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Scarabaeus.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Sceptrum.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Seville.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Shes_All_That.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/SilkyWay.ogg; assuming invalid W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/SitarVsSitar.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Solarium.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/SpringyJalopy.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Steppin_Out.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Terminated.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Testudo.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Themos.ogg; assuming invalid W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Third_Eye.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Thunderfoot.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/TwirlAway.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/URSAMINOR.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/UrsaMinor.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/VeryAlarmed.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Vespa.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/World.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/Zeta.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ringtones/hydra.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ui/Dock.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ui/Effect_Tick.ogg; assuming invalid E 237 /system/bin/mediaserver MetadataRetrieverClient failed to extract an album art W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ui/KeypressDelete.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ui/KeypressInvalid.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ui/KeypressReturn.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ui/KeypressSpacebar.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ui/KeypressStandard.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ui/Lock.ogg; assuming invalid W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ui/LowBattery.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ui/Trusted.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ui/Undock.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ui/Unlock.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ui/VideoRecord.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ui/VideoStop.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ui/WirelessChargingStarted.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ui/camera_click.ogg; assuming invalid W 1473 android.process.media MediaProvider Missing volume for /system/media/audio/ui/camera_focus.ogg; assuming invalid W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) V 1473 android.process.media MediaScanner pruneDeadThumbnailFiles... android.content.ContentProviderClient$CursorWrapperInner@9a2673a V 1473 android.process.media MediaScanner /pruneDeadThumbnailFiles... android.content.ContentProviderClient$CursorWrapperInner@9a2673a W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.ui (517) at int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface)(WindowManagerService.java:2850) waiters=1 in void com.android.server.wm.WindowManagerService$H.handleMessage(android.os.Message) for 1.075s W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1658 com.android.systemui OpenGLRenderer Initialized EGL, version 1.4 D 1658 com.android.systemui OpenGLRenderer Swap behavior 2 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 477ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in boolean com.android.server.wm.WindowManagerService.inputMethodClientHasFocus(com.android.internal.view.IInputMethodClient) for 418ms I 1525 com.android.launcher Choreographer Skipped 31 frames! The application may be doing too much work on its main thread. W 486 system IInputConnectionWrapper reportFullscreenMode on inexistent InputConnection W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 485ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out I 1525 com.android.launcher Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system WifiService New client listening to asynchronous messages I 1658 com.android.systemui Choreographer Skipped 186 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session, android.view.IWindow) for 352ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session, android.view.IWindow) for 500ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session, android.view.IWindow) for 532ms I 486 system Choreographer Skipped 31 frames! The application may be doing too much work on its main thread. D 1658 com.android.systemui PhoneStatusBar disable: < expand* icons alerts system_info back* home* recent* clock search* quick_settings > W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.statusBarVisibilityChanged(int) for 509ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 519ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowManagerService$H.handleMessage(android.os.Message)(WindowManagerService.java:8850) waiters=1 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 518ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in void com.android.server.wm.WindowManagerService.statusBarVisibilityChanged(int) for 1.051s I 486 system Choreographer Skipped 31 frames! The application may be doing too much work on its main thread. W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 541ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowManagerService$H.handleMessage(android.os.Message)(WindowManagerService.java:8361) waiters=1 in void com.android.server.wm.WindowManagerService.statusBarVisibilityChanged(int) for 534ms W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=1 in int com.android.server.wm.WindowManagerService.relayoutWindow(com.android.server.wm.Session, android.view.IWindow, int, android.view.WindowManager$LayoutParams, int, int, int, int, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.graphics.Rect, android.content.res.Configuration, android.view.Surface) for 530ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 1658 com.android.systemui Choreographer Skipped 225 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 486 system art Long monitor contention with owner android.display (523) at void com.android.server.wm.WindowAnimator$1.doFrame(long)(WindowAnimator.java:144) waiters=0 in void com.android.server.wm.WindowManagerService.finishDrawingWindow(com.android.server.wm.Session, android.view.IWindow) for 264ms W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system ActivityManager Waited long enough for: ServiceRecord{5011cce u0 com.android.calendar/.alerts.InitAlarmsService} W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 486 system DhcpClient Received packet: 20:d5:ab:e9:d9:cd ACK: your new IP /192.168.10.189, netmask /255.255.0.0, gateways [/192.168.10.1] DNS servers: /203.248.252.2 /164.124.101.2 , lease time 604800 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system BroadcastQueue Timeout of broadcast BroadcastRecord{8cf6977 u-1 android.intent.action.TIME_TICK} - receiver=android.os.BinderProxy@69cef7d, started 10001ms ago W 486 system BroadcastQueue Receiver during timeout: BroadcastFilter{96582c3 u0 ReceiverList{9783e72 1080 com.android.systemui/10026/u0 remote:69cef7d}} W 1658 com.android.systemui Binder Binder call failed. W 1658 com.android.systemui Binder android.os.DeadObjectException W 1658 com.android.systemui Binder at android.os.BinderProxy.transactNative(Native Method) W 1658 com.android.systemui Binder at android.os.BinderProxy.transact(Binder.java:615) W 1658 com.android.systemui Binder at android.content.IIntentReceiver$Stub$Proxy.performReceive(IIntentReceiver.java:124) W 1658 com.android.systemui Binder at android.app.ActivityThread$ApplicationThread.scheduleRegisteredReceiver(ActivityThread.java:946) W 1658 com.android.systemui Binder at android.app.ApplicationThreadNative.onTransact(ApplicationThreadNative.java:404) W 1658 com.android.systemui Binder at android.os.Binder.execTransact(Binder.java:565) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 486 system BroadcastQueue Timeout of broadcast BroadcastRecord{8cf6977 u-1 android.intent.action.TIME_TICK} - receiver=android.os.BinderProxy@3785c17, started 10001ms ago W 486 system BroadcastQueue Receiver during timeout: BroadcastFilter{c2db1ed u0 ReceiverList{7186804 1080 com.android.systemui/10026/u0 remote:3785c17}} W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) D 1618 com.android.calendar InitAlarmsService Clearing and rescheduling alarms. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) I 486 system PowerManagerService Going to sleep due to screen timeout (uid 1000)... W 1658 com.android.systemui FingerprintManager isFingerprintHardwareDetected(): Service not connected! W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out I 486 system Choreographer Skipped 30 frames! The application may be doing too much work on its main thread. W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) V 486 system KeyguardServiceDelegate onScreenTurnedOff() E 486 system Surface getSlotFromBufferLocked: unknown buffer: 0x83aaf040 E 486 system libEGL call to OpenGL ES API with no current context (logged once per thread) I 486 system Choreographer Skipped 33 frames! The application may be doing too much work on its main thread. I 486 system DisplayManagerService Display device changed state: "Built-in Screen", OFF W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) W 221 /system/bin/surfaceflinger imx6.gralloc FBIOPAN_DISPLAY failed: Connection timed out D 221 /system/bin/surfaceflinger SurfaceFlinger Set power mode=0, type=0 flinger=0xa8732000 W 221 /system/bin/surfaceflinger SurfaceFlinger Ignoring duplicate VSYNC event from HWC (t=0) ... |
| sabresd_6dq:/ # ls -al /dev/graphics/ ls -al /dev/graphics/ total 0 drwxr-xr-x 2 root root 80 1970-01-01 00:01 . drwxr-xr-x 17 root root 2800 1970-01-01 00:01 .. crw-rw---- 1 system graphics 29, 0 1970-01-01 00:01 fb0 crw-rw---- 1 root graphics 29, 1 1970-01-01 00:01 fb1 sabresd_6dq:/ # |
Hi,DongHyun Kim
I face the same problem in imx6qp board. Have you sovle your problem?
Leo
你好,我使用L3.0.35的BSP,使用官方的ubuntu系统,我做了两个Patch(uboot和kernel)能达到预期的效果,但是ubuntu系统在使用ctrl+alt+F1来切换控制台时,出现问题。系统没有切换回去,而是依然显示原有桌面,触摸屏幕没反应,跟死机一样效果,然后使用ctrl+alt+F7切换到桌面,一切又显示正常。我换回没有打patch的kernel, ctrl+alt+F1能正常工作,所以我想,应该是这个patch引起这个问题的。请问有解决办法吗?
Hi leavs lee, the patch had disabled frame buffer console in kernel, so "ctrl+alt+F1" will not work in Ubuntu, during kernel boot up, the framebuffer console will reset the framebuffer driver, it will make display disabled and re-enabled. If it is OK in your side, you can add back the frame buffer console to your kernel. "CONFIG_FRAMEBUFFER_CONSOLE=y"
Thanks for your quickly response, I will try it.
I also face the same problem in imx6qp board. Have you sovle your problem?
请问,这个补丁适用IMX6UL吗?
我在L5.1.1_2.10上面参考M6.0.1_2.1.0的补丁。uboot显示正常了。但到内核,跑着就不显示了。
LVDS1 ipu1 di0
必须运行下面这两条命令才正常.
# echo 1 > /sys/class/graphics/fb0/blank
# echo 0 > /sys/class/graphics/fb0/blank
The iMX6UL has no IPU hardware, so this patch will not work on it.
The iMX6UL used LCDIF, it is a simple display controller, you just need enable it in Uboot and avoid kernel re-initialize it.
We will patch in L4.1.15_2.0.0_ga version yocto bsp.When I tried last patch will make system restart.
is it possible to apply this L4.1.15_2.0.0_ga patches on yocto source ?
How do I understand
sudo dd if = logo.bmp of = / dev / sdc bs = 1 seek = 1048576 skip = 54
If I want to change to EMMC like how to amend
I finished patch now uboot is a white screen how I changed
How can I change if I change to another address?
There should be a place to go back to read the memory bmp picture, where is his position
Looking forward to your reply
Hi Jieh,
"sudo dd if = logo.bmp of = / dev / sdc bs = 1 seek = 1048576 skip = 54"
This is just an example, it saves the bmp image to sd card address 1048576, you can save it to any unused SD/EMMC address, the "skip=54" means it skips 54 bytes of logo.bmp, this 54 bytes is the bmp file header, we don't need it to be saved, we just use the RGB data of the bmp file.
In normal case, when you create partitions on SD/EMMC, you can reserve some space to save thebmp image.
thank you for your reply
I've written logo.bmp into EMMC, but the uboot has not changed yet
I mean uboot is how to call emmc logo.bmp should not tell uboot address
I will bmpReady = 0; uboot as shown above The question now is that I will bmpReady = 1uboot as a white screen dd if = logo.bmp of = / dev / mmcblk0p1 bs = 1 seek = 1048576 skip = 54 write EMMC, the phenomenon is still Similarly, my understanding is that uboot did not find this picture bmp, I do not know the right
Thank you logo is already on the screen
Hello ubootlogo can already be displayed on the screen I now want ubootlogo and kernellogo non-stop display, and now I hit 0001-Keep-uboot-logo-for-Linux-boot-supports-HDMI-LCD-and.patch, Kernel when the screen is black screen, how can I solve
你好,我增加这个patch之后,做了双LVDS的1920x360的分辨率,LOGO能显示,只是显示时只有奇像素点亮,偶像素点不亮。如下图。单LVDS的屏显示正常。请问这个是哪里的问题呢?
应该是设置错了,因为你未提供如何设置的,所以猜不出你错在哪里,请自行分析吧。
谢谢你的回复,我的配置如下:
#ifdef LVDS28
#define DISPLAY_WIDTH 1920
#define DISPLAY_HEIGHT 360
#define DISPLAY_BPP 32
#define DISPLAY_IF_BPP 24 /* RGB24 interface */
#define DISPLAY_HSYNC_START 139
#define DISPLAY_HSYNC_END 139
#define DISPLAY_HSYNC_WIDTH 2
#define DISPLAY_VSYNC_START 22
#define DISPLAY_VSYNC_END 22
#define DISPLAY_VSYNC_WIDTH 1
#define DISPLAY_PIX_CLOCK 148500000
#define LVDS_SPLIT_MODE // For dual channel split mode.
#endif
#define DISPLAY_VSYNC_POLARITY 1
#define DISPLAY_HSYNC_POLARITY 1
#define DISPLAY_CLOCK_POLARITY 1
#define DISPLAY_DATA_POLARITY 0
#define DISPLAY_DATA_ENABLE_POLARITY 1
#define IPU_NUM 1 /* 1 for IPU1, 2 for IPU2. */
#define DI_NUM 0 /* 0 for DI0, 1 for DI1.*/
#define LVDS_PORT 0 /* 0 for LVDS0, 1 for LVDS1. */
#define DI_CLOCK_EXTERNAL_MODE /* When clock external mode was defined, the DI clock root will be PLL3 PFD1, */
/* without this macro, the DI root clock is IPU internal clock. */
屏的时序如下:
你的参数设置的是1920*360 @ 166Hz,但是实际的屏是1920*1080@60Hz的,显然是错的,DISPLAY_HEIGHT应该是1080,另外请确保硬件上,2个LVDS口都连接到了屏上。
谢谢您的回复,屏是1920*360的分辨率的长条屏,以上的时序配置在内核和Uboot默认的logo显示中是没问题的。我刚刚测试了把DISPLAY_HEIGHT设置成1080,屏幕上只显示红色。像素还是会有隔列的情况。如下图:
@Qiang Li
The path can be pathed to IMX6QP board. I have pathed the uboot and kernel patch.Uboot and Kernel can display the same logo but when input android animation it's blank and the teminal console appear MXCFB_WAIT_FOR_VSYNC: timeout 0
The kernel patch can't support iMX6QP, iMX6QP has PRE/PRG hardware, which can't work with this patch.
Thanks your reply! If i don't use these patches,my board will be blank when kernel start-up and the teminal console appear MXCFB_WAIT_FOR_VSYNC: timeout 0 sometimes.
How can i fix it?
If i delete the ipu code in uboot and don't use patches ,it can be resolved?
你好,我使用了4.1.15内核的补丁,uboot和内核logo都显示出来了,有一点不足就是在uboot向内核过渡时,还是会有一些轻微的闪动。请问有什么建议吗?
你可以实际测量一下display的信号,看看中间有没有中断过,如果有的话,应该是patch整合的不太对,你要仔细看一下。
Best Regards
发件人: leavs
发送时间: 2018年2月7日 11:36
收件人: Qiang Li - Mpu Se <qiang.li@nxp.com>
主题: Re: - Patch to support uboot logo keep from uboot to kernel for NXP Linux and Android BSP (HDMI, LCD and LVDS)
NXP Community <https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fcommunity.freescale.com%2Fresources%2Fstatics%2F1000%2F35400-NXP-Community-Email-banner-600x75.jpg&data=02%7C01%7Cqiang.li%40nxp.com%7C6d0712ddeb3a45d7e6fc08d56ddbf5d3%7Cbd8a2a2207224ec7b35f1c4f0497e341%7C0%7C0%7C636535713845765360&sdata=Xdy4xMoSqkHdp4I8j9fmkbStbo39XpYlMd1YVwBx%2FoU%3D&reserved=0>
new comment by leavs lee<https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fleavs%3Fet%3Dwatches.email.document_comment&data=02%7C01%7Cqiang.li%40nxp.com%7C6d0712ddeb3a45d7e6fc08d56ddbf5d3%7Cbd8a2a2207224ec7b35f1c4f0497e341%7C0%7C0%7C636535713845765360&sdata=%2F1ioxQXMJp%2FV%2F%2FMnGNNjBILZXlTgVWXVhdqdR55esrQ%3D&reserved=0> View all comments on this document<https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-98109%3FcommentID%3D51137%26et%3Dwatches.email.document_comment%23comment-51137&data=02%7C01%7Cqiang.li%40nxp.com%7C6d0712ddeb3a45d7e6fc08d56ddbf5d3%7Cbd8a2a2207224ec7b35f1c4f0497e341%7C0%7C0%7C636535713845765360&sdata=CB5TO%2B%2FKqgm04ZS5%2BpkaBA35gCagpUUhwnkXrPmOYDk%3D&reserved=0>
