Patch to Support BT656 and BT1120 Output For i.MX6 BSP
Here are two patches to support BT656 and BT1120 output for i.MX6 ipuv3. With this patch, the i.MX6 can support the CVBS output on TV encoder. It is useful for a TV box.
"L3.0.35_1.1.0_GA_bt656_output_patch.zip" is the patch for Freescale L3.0.35_1.1.0_GA_iMX6DQ BSP.
"r13.4.1_bt656_output_patch.zip" is the patch for Freescale Android R13.4.1 BSP.
1. Features supported:
    1) Support BT656(8 bits) and BT1120 (16 bits)interlaced output on display port.
    2) Support both RGB and YUV frame buffer for BT656/BT1120 output.
    3) Support PAL and NTSC mode.
    4) Support on the fly switch between PAL and NTSC mode.
    5) Support CVBS output based on adv7391 TV encoder.
2. Hardware link between iMX6 and adv7391 TV encoder chip.
    IPU1_DI0_DISP_CLK connected to adv7391 CLKIN pin.
    IPU1_DISP0_DAT_23~DISP0_DAT_16 connected to adv7391 P7~P0 pins.
    IPU1_DI0_PIN2 connected to adv7391 HSYNC pin. (option)
    IPU1_DI0_PIN4 connected to adv7391 VSYNC pin. (option)
- Android R13.4.1 kernel.
3. How to use
-- Copy the two patch files to kernel folder.
    $ git apply ./0001-Support-BT656-and-BT1120-output-for-iMX6-ipuv3.patch
    $ git apply ./0002-Support-adv739x-TV-encoder-for-BT656-output.patch
-- Select them in kernel config and build the new kernel image:
                    Device Drivers  --->
                      Graphics support  --->
                          [*]   MXC BT656 and BT1120 output
                          [*]   ADV7390/7391 TV Output Encoder
-- Uboot parameters for video mode
   Output BT656 NTSC data to display port with UVYV frame buffer mode:
      "video=mxcfb0:dev=bt656,BT656-NTSC,if=BT656,fbpix=UYVY16"
   Output BT656 NTSC data to display port with RGB565 frame buffer mode:
      "video=mxcfb0:dev=bt656,BT656-NTSC,if=BT656,fbpix=RGB565"
   Output BT656 PAL data to display port with RGB24 frame buffer mode:
      "video=mxcfb0:dev=bt656,BT656-PAL,if=BT656,fbpix=RGB24"
   Output CVBS NTSC signal on adv7391 with UYVY frame buffer mode:
      "video=mxcfb0:dev=adv739x,BT656-NTSC,if=BT656,fbpix=UYVY16"
   Output CVBS PAL signal on adv7391 with RGB565 frame buffer mode:
      "video=mxcfb0:dev=adv739x,BT656-PAL,if=BT656,fbpix=RGB565"
-- Switch between PAL and NTSC
   $ echo D:720x480i-60 > /sys/class/graphics/fb0/mode
   $ echo D:720x576i-50 > /sys/class/graphics/fb0/mode
4. Note
    1) For 8 bits BT656 interface, the default data pins are "DISP0_DAT_23~DISP0_DAT_16", it can also
       be any other continued display data pins, for example if "DISP0_DAT_7~DISP0_DAT_0" are used, the
       macro "BT656_IF_DI_MSB" in "kernel_imx/drivers/mxc/ipu3/ipu_disp.c" should be changed from "23"
       to "7".
    2) For 16 bits BT1120 interface, the default data pins are "DISP0_DAT_23~DISP0_DAT_8", it can also
       be any other continued display data pins, the macro "BT656_IF_DI_MSB" should be modified if the
       hardware pins are changed.
    3) When bt656 interface is the second display for each IPU,1-layer-fb (it can be checked with command
       "$ cat /sys/class/graphics/fbx/fsl_disp_propperty"), the frame buffer can only be YUV format. In this
       case, the IPU DC channel was used for BT656 display, it has no CSC function, so RGB frame buffer was
       not supported.
2013-08-09 updated:
The new release package "L3.0.35_1.1.0_GA_bt656_output_patch_2013-08-09.zip" had fixed the BT656 dual display issue on iMX6S/DL.
Removed the old release package.
2013-09-04 updated:
The new release package "r13.4.1_bt656_output_patch_2013-09-04.zip" had fixed the BT656 dual display issue on iMX6S/DL.
For default, the dual display was tested with HDMI + CVBS, HDMI is the main display and adv739x CVBS output is the second display.
For iMX6DQ which has two IPUs, please assign dual display to two IPUs, for example adv739x is on IPU1 DI0, it is fixed, because hardware pins used for it is fixed. Then we can assign HDMI or LVDS to another IPU (IPU2).
For iMX6S/DL which has only one IPU, since adv739x had used IPU1 DI0, another display should be IPU1 DI1.
2013-09-30 updated:
Added patch for L3.0.35_4.1.0_GA BSP, the file is "L3.0.35_4.1.0_GA_bt656_output_patch_2013-09-30.zip".
2014-07-21 updated:
Added patch for L3.10.17_1.0.0_GA BSP, the file is "L3.10.17_1.0.0_GA_bt656_output_patch_2014-07-21.zip".
2015-01-26 updated:
Updated the IPU microcode for 1080i50 and 1080i60 BT1120 output, the parameters "N" for command BMA is a 8 bits parameters, so its max value is 255, but for 1080i50 and 1080i60 output, it needs more blank data in each line, the "N" will be bigger than 255, the updated IPU microcode can fix this limitation.
The updated file is "IPU_Microcode_Update_for_BT1120_1080i_20150126.zip". You can update the macro "DC_MCODE_BT656_xxx"  and function _ipu_dc_setup_bt656_interlaced() to the old patch if you used BT1120 mode to support 1080i display.
The verified 1080i display mode is:
   /* 1080I60 Interlaced output */
  "BT1120-1080I60", 30, 1920, 1080, 13468,
  20, 3,
  20, 2,
  280, 1,
  FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT,
  FB_VMODE_INTERLACED,
  FB_MODE_IS_DETAILED,},
  /* 1080I50 Interlaced output */
  "BT1120-1080I50", 25, 1920, 1080, 13468,
  20, 3,
  20, 2,
  720, 1,
2016-01-28 updated:
Updated IPU microcode to align with BT656.4 specification for NTSC output. For other BSP version with NTSC format support, please reference to ipu_disp_update.c for the final microcode.
File "L3.0.35_4.1.0_GA_bt656_output_patch_20160128.zip"., Details, please reference to the readme.txt file in the package.
2016-06-24 update:
Added BT656 and BT1120 progressive mode support.
File "L3.0.35_4.1.0_GA_bt656_output_patch_20160624.zip". Details, please reference to the readme.txt file in the package.
The patch for 3.14.52 GA1.1.0 BSP will be released in next week.
2016-06-27 update:
Add BT656 and BT1120 display patch for 3.14.52 BSP. File "L3.14.52_1.1.0_GA_bt656_output_patch_2016-06-27.zip", details, please reference to the readme.txt in the package.
2017-03-10 update:
Fixed a hard coding DC macro issue for progressive mode. Added patch "0008-Fixed-a-hard-coding-DC-macro-issue-for-progressive-m.patch" in L3.0.35_4.1.0_GA_bt656_output_patch_2017-03-10.zip.
The code in patch "L3.14.52_1.1.0_GA_bt656_output_patch_2016-06-27" is correct.
添付
コメント
Hi Qiang,
     Could I use this patch for iMX6dl board ?
Yes, it can also work on iMX6S and iMX6DL. But there is issue for dual display mode with BT656 ouput support, I planed to give an update in this month to fix it. Currently single BT656/BT1120 output on iMX6S/DL is OK.
Hi Qiang,
I want the patch of dual display mode with BT656 ouput support.
When do you plan to release updated patch?
I planned to make dual display with BT656 work on iMX6S/DL before the end of June.
Hi Qiang,
I'm using your the patch and the output to adv7391 is good. Now I want to use both HDMI and BT656 to adv7391 and I did the things you told in Update but I can see always BT656 not HDMI.
The uboot paramaters remain the same?
I put also video=mxcfb2:dev=hdmi,1920x1080M@50,if=RGB24 after your uboot params but I can see working only the ADV.
Any suggestion??
Thank you
I planned to release the updated code for dual display support on BT656 at the end of July.
You mean that this patch still not working? I'm using this on a sabrelite board with iMX6Quad...I forgot to tell you....
If you are using iMX6Q which had two IPU, the BT656 is OK for dual display, you can reference to the OTT TVBox reference design, it is OK for HDMI + BT656 on IMX6Q. https://community.freescale.com/docs/DOC-94561
For iMX6S/DL, there is still some issue to enable the dual display with BT656 support, this update will be released at the end of July.
I'm not using Freescale Android R13.4.1 BSP but Freescale L3.0.35_1.1.0_GA_iMX6DQ BSP....
Hi Qiang,
We are working on an automotive project using the iMX.6 DL & iMX.6 Solo SOC with the Android 4.2 BSP.
Is it possible to use ldb as the primary display and bt656 as a second one?
Hi Qiang,
How about the status of dual display with BT656 output on iMX6 Solo for Android build r13.4.1?
I notice you have updated the package of Linux build on 2013-08-09, will you update Android build as well or I have to dig the patch and revise r13.4.1 accordingly by myself?
BTW, we use LCD device as primary display and ADV7391 be second, after I apply r13.4.1 patch, LCD display becomes crushing, is it caused by dual display issue you mentioned on 2013-04-15?
ADV7391 IOMUX setting:
MX6DL_PAD_EIM_A16__IPU1_DI1_DISP_CLK,
MX6DL_PAD_EIM_D29__IPU1_DI1_PIN15,
MX6DL_PAD_EIM_EB3__IPU1_DI1_PIN3,
MX6DL_PAD_EIM_DA9__IPU1_DISP1_DAT_0,
MX6DL_PAD_EIM_DA8__IPU1_DISP1_DAT_1,
MX6DL_PAD_EIM_DA7__IPU1_DISP1_DAT_2,
MX6DL_PAD_EIM_DA6__IPU1_DISP1_DAT_3,
MX6DL_PAD_EIM_DA5__IPU1_DISP1_DAT_4,
MX6DL_PAD_EIM_DA4__IPU1_DISP1_DAT_5,
MX6DL_PAD_EIM_DA3__IPU1_DISP1_DAT_6,
MX6DL_PAD_EIM_DA2__IPU1_DISP1_DAT_7,
Oliver
The old patch had used pll5 as clock source for both CVBS and other display (such as lcd and hdmi), so when use dual display mode for lcd+cvbs and hdmi+cvbs, then when the second display was enabled, the first display will be impacted, because pll5 frequency will be changed by second display.
We need select different clock source for dual display. The new patch had added such code modification in arch\arm\mach-mx6\clock.c.
LVDS + CVBS output had no such isssue, because lvds clock source is not pll5.
Is there a similar patch to support BT1120 for CAPTURE on imx6s?
In "https://community.freescale.com/thread/295157", there is some kernel code modification in V4L2 capture driver to support BT1120 capture,
although it is for iMX53 BSP, the same modification can also be applied on iMX6 BSP.
Hi Qiang,
Do you have a similar patch for MCIMX6Q-SDP with L3.0.35_4.0.0_130424_source BSP to output "progressive" BT656/1120?
Satoshi
For BT656/BT1120 progressive mode, a new IPU microcode was needed, it is not ready yet.
Hi Qiang,
After apply 3 patches in "r13.4.1_bt656_output_patch_2013-09-04.zip", I still can't make adv7391 work properly on our custom board.
We use LCD as primary display which connect to IPU1 DI0 (DISP0) and ADV7391 connect to IPU1 DI1.
I can't find DISP1's pads definition from user manual; refer to IOMUX tool and iomux-mx6dl.h we connect ADV7391 to the pads as below.
I make ADV7391 as main display to make sure it work properly, boot environment set "video=mxcfb0:dev=adv739x,BT656-NTSC,if=BT656,fbpix=UYVY16"; however no output from ADV7391 and lots of message  "mxc_sdc_fb mxc_sdc_fb.0: timeout when waiting for flip irq" posted on console.
I can't measure clock output on IPU1_DI1_DISP_CLK, only 3.3V output.
ADV7391 setting:
static struct fsl_mxc_lcd_platform_data adv739x_data = {
  .ipu_id = 0,
  .disp_id = 1,
  .default_ifmt = IPU_PIX_FMT_BT656,
ADV7391 IOMUX:
/* ipu1 di1 :: CVBS out */
MX6DL_PAD_GPIO_18__GPIO_7_13,/* CVBS_OUT_RST */
//MX6DL_PAD_EIM_D29__IPU1_DI1_PIN15,
//MX6DL_PAD_EIM_EB3__IPU1_DI1_PIN3,
Our target is to make LCD as primary display and ADV7391 as secondary output.
Do you have any suggestion?
Thanks for your kindly help.
Oliver
Can you check if the adv7391 IPU framebuffer driver is ready with the followed commands:
# cat /sys/class/graphics/fb0/fsl_disp_dev_property
By the way, since you are using BT656 interface on DI1 port, the arch\arm\mach-mx6\clock.c should also be adjusted:
clk_set_parent(&ipu1_di_clk[0], &pll3_pfd_540M);  //for CVBS 27MHz clock
clk_set_parent(&ipu1_di_clk[1], &pll5_video_main_clk);
should be changed to:
clk_set_parent(&ipu1_di_clk[0], &pll5_video_main_clk);
clk_set_parent(&ipu1_di_clk[1], &pll3_pfd_540M);  //for CVBS 27MHz clock
Dear Qiang Lin,
When will you be able to provide it?
If you need a long time to provide the patch for progressive output, we have to create it by ourselves because our schedule is very tight.
In the case, we need a additional information about the register on the following address, because reference manual (IMX6DQRM Rev.1) doesn't provide the information about it even though the released patch access the address.
Address: 0x02400000+0x00200000+0x00180000
Could you let us know the register information?
Satoshi
There is no confirmed schedule yet.
Address: 0x02400000 + 0x002000000 + 0x00180000: it is the IPU DC Template Memory, you can reference to reference manual "37.4.7 DC - Display Control"
Hi Qiang,
After change clock setting as you mentioned, I can see output from ADV7391 but the display color is grotesque.
Since ADV7391 uses DISP1_DAT0~7 and these pins are also shared for boot setting, there is a 10k ohm resistor pull to ground.
Would this affects ADV7391 data input accurate? Any suggestion for the hardware connection?
Really thanks for your great support.
Oliver
Hi Oliver,
If you had set "fbpix=UYVY16", that means the frame buffer is in YUV format, you should draw it in YUV format. You can try to play video on it, the video playback is OK to support YUV frame buffer.
If you draw the YUV frame buffer with RGB data, there will be color issue.
Hi Qiang,
     Since ADV7391 only support YUV 4:2:2 input, no matter what kind of frame buffer data format, the BT656 interface output should be YUV 4:2:2 with EAV/SAV embedded, I believe BT656 driver is implemented to do so.
     So, if I feel like to output Android desktop to ADV7391, what kind of data format will be filled in frame buffer? RGB,YUV or I cat assign the data format? Do I have to convert the data in frame buffer to fit YUV 4:2:2 output to ADV7391 by myself?
     Furthermore, you said "I can try to paly video on it"! If I set LCD panel as main display, how to play video on ADV7391? I can't find gstream built in Android kernel, may I copy an Ubuntu version into Android kernel or any APK can achieve this?
Hi  Qiang:
i'm using imx6 dual lite ,android 4.2.2 1.1.0 BSP.and using this patch
this patch fix rear monitor cvbs output to TV_BOX 's SYNC error, and it realy woks.
but during blank opertion, your patch do retry by checking INT_STATE register, till there's no sync error.
this may cost a lot of time , and during this period, front monitor(main lcd display) is ALSO be freezed.
it's terrible. T_T
so, if any suggest or new patch, please notice us, thks.
For Android, the frame buffer must be RGB format, so for BY656 output, before sending the frame buffer data to DI port, the IPU DP will be used to convert the RGB frame buffer to YUV422 format.
If you use LCD as main display, the "0003-Enhance-dual-display-support-for-BT656-output.patch" will assign IPU DC for LCD, which has no hardware CSC and assign IPU DP to adv7391 which can support hardware CSC.
From my test, video playback has no issue in Android on the two displays.
Hi Qiang,
I create a thread to discuss my question, could you please leave your advice there, thanks.
https://community.freescale.com/message/360506#360506
Dear li:
           I add your patch,and use  uboot parameters : video=mxcfb0:dev=bt656,BT1120-PAL,if=UYVY16,fbpix=RGB565, but the vsync is error.it is not rule.
and other question is how to change this pin:
kai
The HSYNC and VSYNC pins are already enabled by the patch, they will output from DI0_PIN2 and DI0_PIN4.
Since BT656 mode doesn't need VSYNC and HSYNC, these signals haven't been checked, just reserved.
The followed DI config code are for them:
    /* COUNTER_2: HSYNC for each line */
    _ipu_di_sync_config(ipu,
      disp,   /* display */
      DI_BT656_SYNC_HSYNC,   /* counter */
      h_total - 1,  /* run count */
      DI_SYNC_CLK, /* run_resolution */
      0,   /* offset */
      DI_SYNC_NONE,  /* offset resolution */
      0,   /* repeat count */
      DI_SYNC_NONE,  /* CNT_CLR_SEL */
      0,   /* CNT_POLARITY_GEN_EN */
      DI_SYNC_NONE,  /* CNT_POLARITY_CLR_SEL */
      DI_SYNC_NONE,  /* CNT_POLARITY_TRIGGER_SEL */
      0,   /* COUNT UP */
      2*div  /* COUNT DOWN */
    /* COUNTER_4: VSYNC for field1 only */
      disp,   /* display */
      DI_BT656_SYNC_VSYNC,   /* counter */
      0,  /* run count */
      DI_BT656_SYNC_HSYNC, /* run_resolution */
      bt656_v_start_width_field0 + height / 2 + bt656_v_end_width_field0,  /*  offset */
      DI_BT656_SYNC_HSYNC,  /* offset resolution */
      1,   /* repeat count */
      DI_BT656_SYNC_IVSYNC,  /* CNT_CLR_SEL */
      0,   /* COUNT UP */
Dear li:
             how to achieve 1080i? i add some code on mxc_bt656.c .but my screen not display.
add some code like it:
  /* PAL Interlaced output */
  "BT1120-PAL-1080i", 25, 1920,1080, 13468,
  148, 484,
  36, 4,
  88, 5,
does some parameter is error?
Beat Regards
kai
Hi sun, that driver can only support BT1120 mode 1080i, and the left_margin, right_margin, up_margin, down_margin in video mode is protocol data, they can't be changed.
You also need make sure your TV encoder chip can support BT1120 input.
Hi li :
          Thanks for your reply, that  is a previous questions:i need sabresd board output parallel yuv4:2:2  display, thanks for your help ,720P format  display is OK . but you konw the interlaced is not support,
i communitcte with the TV encoder fae,the chip is support the bt1120 mode,i used your patch ,the 576i format is display ok(but not audio, chip is not support well on bt1120 mode). this TV chip fae let me test 1080i format ,may be have audio,so i added the above code ,but the 1080i is not well,the screen is black. my screen have nothing and then ask for your help. i guess  the parameter is error.
          and i always think the left_margin right_margin etc  through SAV and EAV in display data   is not well. and maybe because of this protocol data  the audio can not  insert the display data( on this chip the audio is insert  on display data gaps).  But anything is to project.
          so can you support the parameter about 1080i, mxc_bt656if.c is only have 576i parameter.
Beat Regard
kai
In clock.c, the current clock setting is for 27MHz NTSC and PAL mode, for 1080i, you need the 74.25MHz clock, so you should change the clock source in clock.c.
From
To
By the way, audio data is not transfered on BT1120 interface, so the audio issue should be the TV chip's issue, non business with BT1120 driver. No matter what, you should not change the margin data in the video mode, those data is for BT656/BT1120 protocol.
HI li :
         i  change the clock source on clock.c . and use :setenv bootargs console=ttymxc0,115200 init=/init rw video=mxcfb0:dev=bt656,BT1120-PAL-1080i,if=BT1120,fbpix=RGB565 . but my screen ids no signal.  you have said the margin data:
         148, 484,
         36, 4,
         88, 5,
i guess is this parameter is error.  The patch code is no 1080i format, thoes code about 1080i  may be wrong,can your provide a 1080i parameter for me。
kai
Checked with BT1120-8 protocol, I think you can try the followed parameter for 1080I60 and 1080I50:
  20, 3,
  20, 2,
  280, 1,
  20, 3,
  20, 2,
  720, 1,
I am also interested in BT.1120 1080 capability.  Could you explain how to include this support into the kernel a little further?  I am using Yocto with kernel 3.0.35_4.0.0.
I have already changed the clock source back to 75MHz, but I do not know where to add the BT1120 parameters.  Should it be placed in drivers/video/mxc/mxc_bt656if.c?  I imagine the boot parameters would look something like mentioned above (video=mxcfb0:dev=bt656,BT1120-PAL-1080i,if=BT1120,fbpix=UYVY16).  Is this correct?  Lastly, is their any support for 1080p?
Thank you,
Josh Kurland
If you just need iMX6 generate BT1120 signal, you can just add the 1080i video mode in file mxc_bt656if.c.
The uboot parameters can be "video=mxcfb0:dev=bt656,BT1120-1080I60,if=BT1120,fbpix=UYVY16" or "video=mxcfb0:dev=bt656,BT1120-1080I60,if=BT1120,fbpix=RGB565". There is no 1080P support for BT1120 mode yet, but you can use VSYNC/HSYNC mode to support 1080P.
Thanks for the response.  I copied the 1080i modes to the bottom of struct fb_videomode bt656if_modedb[] in mxc_bt656if.c and modified the u-boot parameters, but I am not getting the correct clock.  Before I load the kernel (still in uboot) the pixel clock is good at 74.25MHz.  After I load the kernel,the pixel clock is stuck at 50MHz.  Also I do not see anything on the HSYNC and VSYNC pins.  Is that supposed to happen or is that a sign something else is wrong?  In arch\arm\mach-mx6\clock.c I have clk_set_parent(&ipu1_di_clk[0], &pll5_video_main_clk);.  Is their anything else I have to set?  I back-ported the patch to run on kernel 3.0.35_4.0.0.  Are you aware of any conflicts that might occur with this?
Thank you,
Josh Kurland
I think you should check if the correct mode had been used or not?
$ cat  /sys/class/graphics/fb0/mode
With BT1120-1080I60 set using the recommended u-boot parameters, the output of /sys/class/graphics/fb0/mode is D:1920x1080i-30.  I believe this is the correct setting, but the clock is still running at 50MHz.  For BT1120-1080I50 I get D:1920x1080i-25.  I am running this on a SabreLite and a Wandboard quad; I do not have a SabreSD board.  I made the necessary additions to the board-xxx.c and defconfig files.  Can this patch be applied to ALL imx6 boards, or is it specific to the SabreSD?
Can you attach your kernel boot log?
By kernel boot log do you mean dmesg?  This is a link to dmesg when BT1120-1080I60 is set:  https://drive.google.com/file/d/0B1-NpS0YmbqNZEJJeDFvNFNwTGs/edit?usp=sharing
I am also attaching a file named /var/log/boot:  https://drive.google.com/file/d/0B1-NpS0YmbqNZXJRbW90X054c28/edit?usp=sharing
The google drive can't be accessed from China, I had tried your video mode on my SabreSD board, it can get the 74.25MHz pixel clock correctly. Of cource, ipu1_di0 clock should be sourced from PLL5.
I am setting clk_set_parent(&ipu1_di_clk[0], &pll5_video_main_clk);  In the line directly above this one I am setting the clock rate as clk_set_rate(&pll5_video_main_clk, 650000000); (line 5458).  Is this the correct value to set PLL5 in order to achieve a 74.25MHz clock?  I have also uploaded my kernel dmesg log to pastebin.com:  imx6 dmesg for BT.1120 - Pastebin.com.  I do not see anything directly defining any video settings.  Could you tell me what I should be looking for?  Lastly, should I move this question to a new thread?  It is starting to become long.  Thank you.
Hi Josh, you can set pll5 to 297MHz for 74.25MHz pixel clock.
PLL5 clock has been changed, clk_set_rate(&pll5_video_main_clk, 297000000);.  I get the same results.  I also tried to run the clock using PLL3 at 27MHz, just to see what would happen.  This also gave me 50MHz.  Is it possible that something is overriding the clock definitions?
Hi Qiang,
I've been using this patch for some time with 3.0.35 and am now updating to the 3.10.17_1.0.0_beta kernel.  Are you planning on creating a patch for that kernel?  Why is this support not part of the Freescale BSP?
Tim
Hi Li
Thanks for your such useful patch to the iMX6 about BT656 functions.
But here I have a problem about the patch into iMX6S customer board with AK8817 encoder chip.
1, Using no external HSYNC/VSYNC, just with BT656 itself . iMX6S can not send correct BT656 signal to AK8817
source like bellow
/driver/video/mxc/mxc_bt656if.c
static struct fb_videomode bt656if_modedb[] = {
     /* NTSC Interlaced output */
     "BT656-NTSC", 60, 720, 480, 37037,
     19, 3,
     20, 3,
     276, 1,
        disp,         /* display */
        0,         /* offset */
        0,         /* COUNT UP */
/* COUNTER_3: internal VSYNC for each frame */
        disp,         /* display */
        DI_BT656_SYNC_IVSYNC,         /* counter */
        v_total - 1,     /* run count */
        0,             /* offset */
        0,         /* COUNT UP */
       0        /* COUNT DOWN */
2, Using external HSYNC/VSYNC, just with BT656 itself . iMX6S can send correct BT656 signal to AK8817
     19, 3,
     20, 3,
     276, 1,
     0,
        disp,         /* display */
        0,         /* offset */
        0,         /* COUNT UP */
        20*div        /* COUNT DOWN */
        disp,         /* display */
        0,             /* offset */
        0,         /* COUNT UP */
Could you please tell me, how to make correct BT656 signals from iMX6 to AK8817 without external HSYNC/VSYNC ?
When use patch on iMX6 Sabre board, there is no such problem.
The patch was verified on iMX6S board too, the use case without external HSYNC/VSYNC is the only workable case for this patch, external VSYNC and HSYNC mode hasn't been fine tuned.
I think you should check your hardware for which data pins are used for the BT656 interface, and add the IOMUX setting for these pins.
Hi Li
Sorry for disturbing you again.
As the question just like I took above.
I can see thes two comments
1, /* COUNTER_2: HSYNC for each line */
2, /* COUNTER_3: internal VSYNC for each frame */
My apologies, I am a newer about BT.656 and IPU.
Could you please tell me, HSYNC/VSYNC which set by function ipu_init_sync_panel(). are internal SYNC or External SYNC?
The internal SYNC and external SYNC are just the name, if we don't ouput these signals from IPU DI pins, they are just internal signal, if we enabled output from IPU DI PINs for them, they will be external signal too.
%3CLINGO-SUB%20id%3D%22lingo-sub-1125685%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125685%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%81i.MX6%20ipuv3%20%E3%81%AE%20BT656%20%E3%81%A8%20BT1120%20%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%202%20%E3%81%A4%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81i.MX6%20%E3%81%AF%20TV%20%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%20CVBS%20%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%83%86%E3%83%AC%E3%83%93%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AA%E3%81%A9%E3%81%AB%E4%BE%BF%E5%88%A9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%80%8CL3.0.35_1.1.0_GA_bt656_output_patch.zip%E3%80%8D%E3%81%AF%E3%80%81Freescale%20L3.0.35_1.1.0_GA_iMX6DQ%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E3%81%99%E3%80%82BSP%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%80%8Cr13.4.1_bt656_output_patch.zip%E3%80%8D%E3%81%AF%E3%80%81Freescale%20Android%20R13.4.1%20BSP%E7%94%A8%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%A9%9F%E8%83%BD%3A%3C%2FP%3E%3CP%3E1)%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7BT656(8%E3%83%93%E3%83%83%E3%83%88)%E3%81%8A%E3%82%88%E3%81%B3BT1120(16%E3%83%93%E3%83%83%E3%83%88)%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3CBR%20%2F%3E2)BT656%20%2F%20BT1120%E5%87%BA%E5%8A%9B%E7%94%A8%E3%81%AERGB%E3%81%A8YUV%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B3)PAL%E3%81%8A%E3%82%88%E3%81%B3NTSC%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E4)PAL%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A8NTSC%E3%83%A2%E3%83%BC%E3%83%89%E9%96%93%E3%81%AE%E3%82%AA%E3%83%B3%E3%82%B6%E3%83%95%E3%83%A9%E3%82%A4%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%80%82%3CBR%20%2F%3E5)adv7391TV%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8FCVBS%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%20iMX6%E3%81%A8adv7391%20TV%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%81%E3%83%83%E3%83%97%E9%96%93%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%AF%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3BIPU1_DI0_DISP_CLK%20adv7391%20CLKIN%E3%83%94%E3%83%B3%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3Badv7391%20P7~P0%E3%83%94%E3%83%B3%E3%81%AB%E6%8E%A5%E7%B6%9AIPU1_DISP0_DAT_23~DISP0_DAT_16%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3BIPU1_DI0_PIN2%20adv7391%20HSYNC%E3%83%94%E3%83%B3%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82(%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3)%3CBR%20%2F%3EIPU1_DI0_PIN4%20adv7391%E3%81%AEVSYNC%E3%83%94%E3%83%B3%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82(%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3)%3CBR%20%2F%3E%26nbsp%3B%20%3CBR%20%2F%3E-%20Android%20R13.4.1%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E3.%20%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%3C%2FP%3E%3CP%3E--%202%20%E3%81%A4%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%24%20git%20apply%20.%2F0001-Support-BT656-and-BT1120-output-for-iMX6-ipuv3.patch%3CBR%20%2F%3E%24%20git%20apply%20.%2F0002-Support-adv739x-TV-encoder-for-BT656-output.patch%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E--%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC---%26gt%3B%3CBR%20%2F%3E%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20---%26gt%3B%3CBR%20%2F%3E%5B*%5D%26nbsp%3B%20MXC%20BT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%20%3CBR%20%2F%3E%5B*%5D%26nbsp%3B%20ADV7390%2F7391%20TV%E5%87%BA%E5%8A%9B%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E--%20%E3%83%93%E3%83%87%E3%82%AA%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%20Uboot%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%3CBR%20%2F%3EBT656%20NTSC%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92UVYV%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%22video%3Dmxcfb0%3Adev%3Dbt656%2CBT656-NTSC%2Cif%3DBT656%2Cfbpix%3DUYVY16%22%3C%2FP%3E%3CP%3EBT656%20NTSC%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92RGB565%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%22video%3Dmxcfb0%3Adev%3Dbt656%2CBT656-NTSC%2Cif%3DBT656%2Cfbpix%3DRGB565%22%3C%2FP%3E%3CP%3EBT656%20PAL%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92RGB24%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E8%A1%A8%E7%A4%BA%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%22video%3Dmxcfb0%3Adev%3Dbt656%2CBT656-PAL%2Cif%3DBT656%2Cfbpix%3DRGB24%22%3C%2FP%3E%3CP%3EUYVY%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%BB%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%BB%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6adv7391%E3%81%A7CVBS%20NTSC%E4%BF%A1%E5%8F%B7%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%22video%3Dmxcfb0%3Adev%3Dadv739x%2CBT656-NTSC%2Cif%3DBT656%2Cfbpix%3DUYVY16%22%3C%2FP%3E%3CP%3Eadv7391%E3%81%AECVBS%20PAL%E4%BF%A1%E5%8F%B7%E3%82%92RGB565%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%BB%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%BB%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%22video%3Dmxcfb0%3Adev%3Dadv739x%2CBT656-PAL%2Cif%3DBT656%2Cfbpix%3DRGB565%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-PAL%E3%81%A8NTSC%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3CBR%20%2F%3E%24%20echo%20D%3A720x480i-60%20%26gt%3B%20%2Fsys%2Fclass%2Fgraphics%2Ffb0%2Fmode%3CBR%20%2F%3E%24%20echo%20D%3A720x576i-50%20%26gt%3B%20%2Fsys%2Fclass%2Fgraphics%2Ffb0%2Fmode%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E4.%20%E6%B3%A8%E6%84%8F%E4%BA%8B%E9%A0%85%3CBR%20%2F%3E1)%208%E3%83%93%E3%83%83%E3%83%88BT656%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%83%94%E3%83%B3%E3%81%AF%E3%80%8CDISP0_DAT_23~DISP0_DAT_16%E3%80%8D%E3%81%A7%E3%80%81%E3%81%9D%E3%82%8C%E3%82%82%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%20%3CBR%20%2F%3E%E4%BB%96%E3%81%AE%E9%80%A3%E7%B6%9A%E8%A1%A8%E7%A4%BA%E3%83%87%E3%83%BC%E3%82%BF%E3%83%94%E3%83%B3%E3%81%A7%E3%81%82%E3%81%A3%E3%81%A6%E3%82%82%E3%80%81%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%8CDISP0_DAT_7~DISP0_DAT_0%E3%80%8D%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%20%3CBR%20%2F%3E%E3%80%8Ckernel_imx%2Fdrivers%2Fmxc%2Fipu3%2Fipu_disp.c%E3%80%8D%E3%81%AE%E3%83%9E%E3%82%AF%E3%83%AD%E3%80%8CBT656_IF_DI_MSB%E3%80%8D%E3%82%92%E3%80%8C23%E3%80%8D%E3%81%8B%E3%82%89%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3CBR%20%2F%3E%E3%82%92%20%227%22%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E2)%2016%E3%83%93%E3%83%83%E3%83%88BT1120%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%83%94%E3%83%B3%E3%81%AF%E3%80%8CDISP0_DAT_23~DISP0_DAT_8%E3%80%8D%E3%81%A7%E3%80%81%E3%81%9D%E3%82%8C%E3%82%82%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%3CBR%20%2F%3E%E4%BB%96%E3%81%AE%E7%B6%99%E7%B6%9A%E7%9A%84%E3%81%AA%E8%A1%A8%E7%A4%BA%E3%83%87%E3%83%BC%E3%82%BF%E3%83%94%E3%83%B3%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%9E%E3%82%AF%E3%83%AD%20%22BT656_IF_DI_MSB%22%20%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3CBR%20%2F%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%94%E3%83%B3%E3%81%8C%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E3)%20bt656%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%8C%E5%90%84IPU%E3%81%AE2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%811%E5%B1%A4-fb(%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%E7%A2%BA%E8%AA%8D%E5%8F%AF%E8%83%BD)%3CBR%20%2F%3E%22%24%20cat%20%2Fsys%2Fclass%2Fgraphics%2Ffbx%2Ffsl_disp_propperty%22)%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AF%20YUV%20%E5%BD%A2%E5%BC%8F%E3%81%AE%E3%81%BF%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E4%B8%AD%E3%81%A7%3CBR%20%2F%3E%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%AF%E3%80%81BT656%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E3%81%AFIPU%20DC%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81CSC%E6%A9%9F%E8%83%BD%E3%81%8C%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81RGB%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AF%3CBR%20%2F%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CSTRONG%3E2013-08-09%20%E6%9B%B4%E6%96%B0%E6%97%A5%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%E6%96%B0%E3%81%97%E3%81%84%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%80%8CL3.0.35_1.1.0_GA_bt656_output_patch_2013-08-09.zip%E3%80%8D%E3%81%A7%E3%81%AF%E3%80%81iMX6S%2FDL%E3%81%AEBT656%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%E5%8F%A4%E3%81%84%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3CSTRONG%3E2013-09-04%20%E6%9B%B4%E6%96%B0%E6%97%A5%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%80%8Cr13.4.1_bt656_output_patch_2013-09-04.zip%E3%80%8D%E3%81%A7%E3%81%AF%E3%80%81iMX6S%20%2F%20DL%E3%81%AEBT656%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AFHDMI%20%2B%20CVBS%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%80%81HDMI%E3%81%8C%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%80%81adv739x%20CVBS%E5%87%BA%E5%8A%9B%E3%81%8C%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%89%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EiMX6DQ%E3%81%AB2%E3%81%A4%E3%81%AEIPU%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%922%E3%81%A4%E3%81%AEIPU%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84(%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81adv739x%E3%81%AFIPU1%20DI0%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%94%E3%83%B3%E3%81%8C%E5%9B%BA%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%9B%BA%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99)%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81HDMI%E3%81%BE%E3%81%9F%E3%81%AFLVDS%E3%82%92%E5%88%A5%E3%81%AEIPU(IPU2)%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EiMX6S%2FDL%E3%81%A7IPU%E3%81%8C1%E3%81%A4%E3%81%97%E3%81%8B%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81adv739x%E3%81%AFIPU1%20DI0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81%E5%88%A5%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AFIPU1%20DI1%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3CSTRONG%3E2013-09-30%20%E6%9B%B4%E6%96%B0%E6%97%A5%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EL3.0.35_4.1.0_GA%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E8%BF%BD%E5%8A%A0BSP%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%8CL3.0.35_4.1.0_GA_bt656_output_patch_2013-09-30.zip%E3%80%8D%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E2014-07-21%20%E6%9B%B4%E6%96%B0%E6%97%A5%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EL3.10.17_1.0.0_GA%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E8%BF%BD%E5%8A%A0BSP%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%8CL3.10.17_1.0.0_GA_bt656_output_patch_2014-07-21.zip%E3%80%8D%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E2015-01-26%20%E6%9B%B4%E6%96%B0%E6%97%A5%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E1080i50%E3%81%8A%E3%82%88%E3%81%B31080i60%20BT1120%E5%87%BA%E5%8A%9B%E3%81%AEIPU%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89BMA%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%80%8CN%E3%80%8D%E3%81%AF8%E3%83%93%E3%83%83%E3%83%88%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E6%9C%80%E5%A4%A7%E5%80%A4%E3%81%AF255%E3%81%A7%E3%81%99%E3%81%8C%E3%80%811080i50%E3%81%8A%E3%82%88%E3%81%B31080i60%E5%87%BA%E5%8A%9B%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E5%90%84%E8%A1%8C%E3%81%AB%E3%82%88%E3%82%8A%E5%A4%9A%E3%81%8F%E3%81%AE%E7%A9%BA%E7%99%BD%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%80%8CN%E3%80%8D%E3%81%AF255%E3%82%88%E3%82%8A%E5%A4%A7%E3%81%8D%E3%81%8F%E3%81%AA%E3%82%8A%E3%80%81%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%9FIPU%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%81%93%E3%81%AE%E5%88%B6%E9%99%90%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%8CIPU_Microcode_Update_for_BT1120_1080i_20150126.zip%E3%80%8D%E3%81%A7%E3%81%99%E3%80%821080i%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABBT1120%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%9E%E3%82%AF%E3%83%AD%E3%80%8CDC_MCODE_BT656_xxx%E3%80%8D%E3%81%A8%E9%96%A2%E6%95%B0_ipu_dc_setup_bt656_interlaced()%E3%82%92%E5%8F%A4%E3%81%84%E3%83%91%E3%83%83%E3%83%81%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A2%BA%E8%AA%8D%E6%B8%88%E3%81%BF%E3%81%AE%201080i%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%2F*%201080I60%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E5%87%BA%E5%8A%9B%20*%2F%3C%2FP%3E%3CP%3E%E3%80%8CBT1120-1080I60%E3%80%8D%E3%80%8130%E3%80%811920%E3%80%811080%E3%80%8113468%E3%80%81%3C%2FP%3E%3CP%3E%26nbsp%3B%2020%2C%203%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%2020%2C%202%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20280%2C%201%2C%3C%2FP%3E%3CP%3EFB_SYNC_HOR_HIGH_ACT%20%7CFB_SYNC_VERT_HIGH_ACT%E3%80%81%3C%2FP%3E%3CP%3EFB_VMODE_INTERLACED%E3%80%81%3C%2FP%3E%3CP%3EFB_MODE_IS_DETAILED%2C%7D%2C%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%2F*%201080I50%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E5%87%BA%E5%8A%9B%20*%2F%3C%2FP%3E%3CP%3E%E3%80%8CBT1120-1080I50%E3%80%8D%E3%80%8125%E3%80%811920%E3%80%811080%E3%80%8113468%E3%80%81%3C%2FP%3E%3CP%3E%26nbsp%3B%2020%2C%203%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%2020%2C%202%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20720%2C%201%2C%3C%2FP%3E%3CP%3EFB_SYNC_HOR_HIGH_ACT%20%7CFB_SYNC_VERT_HIGH_ACT%E3%80%81%3C%2FP%3E%3CP%3EFB_VMODE_INTERLACED%E3%80%81%3C%2FP%3E%3CP%3EFB_MODE_IS_DETAILED%2C%7D%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E2016-01-28%20%E6%9B%B4%E6%96%B0%E6%97%A5%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3ENTSC%E5%87%BA%E5%8A%9B%E3%81%AEBT656.4%E4%BB%95%E6%A7%98%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6IPU%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82NTSC%20%E5%BD%A2%E5%BC%8F%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%20BSP%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81ipu_disp_update.c%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AA%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%BC%E3%83%89%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8CL3.0.35_4.1.0_GA_bt656_output_patch_20160128.zip%E3%80%8D%E3%81%AF%E3%80%81%E8%A9%B3%E7%B4%B0%E3%81%AF%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E5%86%85%E3%81%AEreadme.txt%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E2016-06-24%20update%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8CL3.0.35_4.1.0_GA_bt656_output_patch_20160624.zip%E3%80%8D%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AF%E3%80%81%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E5%86%85%E3%81%AEreadme.txt%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E3.14.52%20GA1.1.0%20%E3%81%AE%E3%83%91%E3%83%83%E3%83%81BSP%E3%81%AF%E6%9D%A5%E9%80%B1%E3%81%AB%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E2016-06-27%20update%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E656%20BSP%20%E7%94%A8%E3%81%AE%20BT1120%20%E3%81%8A%E3%82%88%E3%81%B3%20BT3.14.52%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%20%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8CL3.14.52_1.1.0_GA_bt656_output_patch_2016-06-27.zip%E3%80%8D%E3%80%81%E8%A9%B3%E7%B4%B0%E3%81%AF%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E5%86%85%E3%81%AEreadme.txt%E3%82%92%E3%81%94%E5%8F%82%E7%85%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2017-03-10%20update%3A%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%20DC%20%E3%83%9E%E3%82%AF%E3%83%AD%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%B3%E3%83%BC%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82L3.0.35_4.1.0_GA_bt656_output_patch_2017-03-10.zip%E3%81%AB%E3%83%91%E3%83%83%E3%83%81%E3%80%8C0008-Fixed-a-hard-coding-DC-macro-issue-for-progressive-m.patch%E3%80%8D%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E3%80%8CL3.14.52_1.1.0_GA_bt656_output_patch_2016-06-27%E3%80%8D%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1125685%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A8%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6DL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6S%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125900%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125900%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E8%B5%B7%E5%8B%95%E4%B8%AD%E3%80%81%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%89%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AF%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E7%A9%BA%E7%99%BD%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%99%82%E8%A8%88%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E7%94%BB%E9%9D%A2%E3%82%92%E6%B6%88%E5%8E%BB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Eecho%200%20%26gt%3B%20%2Fsys%2Fclass%2Fgraphics%2Ffb2%2Fblank%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125898%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125898%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%AD%E3%82%B0%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3EIOMUX%20%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125897%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125897%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%81%E3%83%A3%E3%83%B3%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81IPU2-DI0%20%E3%81%A8%20IPU1-DI1%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%9F%E6%AD%A3%E3%81%97%E3%81%84%E6%83%85%E5%A0%B1%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EClock%20source%E6%98%AF%E8%AE%BE%E7%9A%84pll3%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AF%84%E4%BB%B6%E8%80%85%3A%20Qiang_FSL%20%3C%2FP%3E%3CP%3E%E9%85%8D%E4%BF%A1%E6%97%A5%E6%99%82%EF%BC%9A2020%E5%B9%B43%E6%9C%8811%E6%97%A5%2011%E6%99%8240%E5%88%86%3C%2FP%3E%3CP%3E%E5%8F%97%E4%BF%A1%E8%80%85%3A%20Allon%20Li(%E6%9D%8E%E6%96%B0%E9%BE%8D)(SZX)%3C%2FP%3E%3CP%3E%E4%B8%BB%E6%97%A8%3A%20Re%3A%20%20-%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENXP%20Community%20%26lt%3B%26gt%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPatch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Enew%20comment%20by%20Qiang%20Li%20-%20Mpu%20Se%26lt%3B%26gt%3B%20View%20all%20comments%20on%20this%20document%26lt%3B%26gt%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125896%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125896%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E7%8F%BE%E8%B1%A1%E3%81%8B%E3%82%89%E3%80%812%E3%81%A4%E3%81%AEIPU%E3%81%AF%E6%98%8E%E7%A2%BA%E3%81%AB%E5%88%86%E9%9B%A2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E4%BA%92%E3%81%84%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%82%92%E5%8F%8A%E3%81%BC%E3%81%97%E5%90%88%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%822%E3%81%A4%E3%81%AEIPU%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8BPIN%E3%81%8C%E7%95%B0%E3%81%AA%E3%82%8B%E5%A0%B4%E5%90%88%EF%BC%88%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81%E4%B8%80%E6%96%B9%E3%81%8CDATA0-7%E3%81%A7%E3%80%81%E3%82%82%E3%81%86%E4%B8%80%E6%96%B9%E3%81%8CDATA16-23%EF%BC%89%E3%80%81ipu_disp.c%E3%81%AEBT656_IF_DI_MSB%E3%81%AF2%E3%81%A4%E3%81%AEIPU%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E7%95%B0%E3%81%AA%E3%82%8B%E5%80%A4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E3%81%BF%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%81%97%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AB%E3%81%AF%E5%BD%B1%E9%9F%BF%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2%E3%81%A4%E3%81%AEBT656%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AF%E5%90%8C%E3%81%98%E3%82%82%E3%81%AE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81clock.c%E3%81%A7%E3%81%AF%E3%80%812%E3%81%A4%E3%81%AEBT656%E3%81%AFIPU1_DI0%E3%81%A8IPU2_DI1%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3Bclk_set_parent(%26amp%3Bipu1_di_clk%5B0%5D%2C%20%26amp%3Bpll3_pfd_540M)%3B%26nbsp%3B%20%2F*%20For%20CVBS%2027MHz%20clock%20*%2F%3CBR%20%2F%3E%26nbsp%3Bclk_set_parent(%26amp%3Bipu1_di_clk%5B1%5D%2C%20%26amp%3Bpll5_video_main_clk)%3B%3CBR%20%2F%3E%26nbsp%3Bclk_set_parent(%26amp%3Bipu2_di_clk%5B0%5D%2C%20%26amp%3Bpll2_pfd_352M)%3B%3CBR%20%2F%3E%26nbsp%3Bclk_set_parent(%26amp%3Bipu2_di_clk%5B1%5D%2C%20%26amp%3Bpll3_pfd_540M)%3B%26nbsp%3B%20%2F*%20For%20CVBS%2027MHz%20clock%20*%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Edrver%20%E3%81%A7%E3%81%AF%E3%80%81ipu_id%20%E3%81%A8%20ipu_di%20%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%A9%E3%81%93%E3%81%AB%E3%81%82%E3%82%8B%E3%81%8B%E3%81%8C%E7%B0%A1%E5%8D%98%E3%81%AB%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125894%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125894%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EiMX6DQ%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%812%E3%81%A4%E3%81%AEIPU%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81DI%E3%81%8C%E5%8D%A0%E6%9C%89%E3%81%95%E3%82%8C%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125893%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125893%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E5%88%9D%E3%81%AEBT656%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%812%E7%95%AA%E7%9B%AE%E3%81%AEBT656%E3%81%AF%E6%97%A2%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125892%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125892%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E8%B5%B7%E5%8B%95%E3%83%AD%E3%82%B0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7LVDS%E3%81%A8HDMI%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E4%B8%8A%E6%9B%B8%E3%81%8D%E3%81%95%E3%82%8C%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%202%20%E3%81%A4%E3%81%AE%20BT656%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Evideo%3Dmxcfb0%3Adev%3Dbt656%2CBT656-NTSC%2Cif%3DBT656%2Cfbpix%3DRGB32%20video%3Dmxcfb1%3Adev%3Dbt656%2CBT656-NTSC%2Cif%3DBT656%2Cfbpix%3DRGB32%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125891%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125891%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%8C%E3%82%892%E3%81%A4%E3%81%AF%E5%89%8A%E9%99%A4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%812%E3%81%A4%E3%81%AEBT656%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%BE%E3%81%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125888%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125888%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E2%E3%81%A4%E3%81%AEIPU%E3%82%92%E6%8C%81%E3%81%A4iMX6DQ%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%812%E3%81%A4%E3%81%AEBT656%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%922%E3%81%A4%E3%81%AEIPU%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%80%81%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E3%80%812%E3%81%A4%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Evideo%3Dmxcfb0%3Adev%3Dbt656%2CBT656-NTSC%2Cif%3DBT656%2Cfbpix%3DRGB32%20video%3Dmxcfb1%3Adev%3Dbt656%2CBT656-NTSC%2Cif%3DBT656%2Cfbpix%3DRGB32%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EiMX6S%2FDL%E3%81%A7IPU%E3%81%8C1%E3%81%A4%E3%81%97%E3%81%8B%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81CPMEM%E3%81%AB%E3%81%AF1%E3%81%A4%E3%81%AEIPU%E3%81%A72%E3%81%A4%E3%81%AEBT656%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%8D%81%E5%88%86%E3%81%AA%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%A6%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%82%B9%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125886%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125886%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%90%84%E8%A1%8C%E3%81%AE%E7%A9%BA%E7%99%BD%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E5%A4%9A%E3%81%99%E3%81%8E%E3%81%A6%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E6%9C%80%E5%A4%A7%E5%80%A4%E3%82%92%E8%B6%85%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E4%B8%8B%E3%81%92%E3%82%8B%E3%81%AA%E3%81%A9%E3%80%81%E7%A9%BA%E7%99%BD%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E6%B8%9B%E3%82%89%E3%81%99%E6%96%B9%E6%B3%95%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125884%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125884%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125882%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125882%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3EQiang%20Li%20-%20Mpu%20Se%20%E6%92%B0%E5%86%99%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHDMI%20%E3%81%AE%20720*576%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E3%81%AF%20pll3_pfd1_540m%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%20%3CA%20data-content-finding%3D%22Community%22%20target%3D%22_blank%22%3EBT1120%20%E3%81%AE%3C%2FA%3E%3CA%20class%3D%22jive-link-email-small%22%20data-content-finding%3D%22Community%22%20href%3D%22mailto%3A1280*720%4025%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E1280*720%4025%3C%2FA%3E%E3%81%AB%E3%81%AF%20PLL5%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E5%89%8D%E3%80%81HDMI%E3%81%ABpll3_pfd1_540m%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82HDMI%E3%81%AFIPU1_DI1%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81clk-imx6q.c%E3%81%AB%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9Amx_clk_set_parent(clk%5BIMX6QDL_CLK_IPU1_DI1_PRE_SEL%5D%2C%20clk%5BIMX6QDL_CLK_PLL3_PFD1_540M%5D)%3B%E3%80%81%E3%81%97%E3%81%8B%E3%81%97HDMI%E5%87%BA%E5%8A%9B%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82PLL5%E3%81%AB%E6%88%BB%E3%81%99%E3%81%A8%E7%94%BB%E5%83%8F%E5%87%BA%E5%8A%9B%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BB%96%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E7%AE%87%E6%89%80%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%AF%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125881%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125881%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHDMI%20%E3%81%AE%20720*576%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E3%81%AF%20pll3_pfd1_540m%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%20%3CA%3EBT1120%20%E3%81%AE%3C%2FA%3E%3CA%20href%3D%22mailto%3A1280*720%4025%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E1280*720%4025%3C%2FA%3E%E3%81%AB%E3%81%AF%20PLL5%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125880%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125880%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%20%E2%80%8C%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82HDMI%E3%81%AE%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%81%AF720*576%E3%81%A7%E3%81%99%E3%80%82%E3%81%94%E8%AA%AC%E6%98%8E%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81PLL5%E3%81%AFBT1120%E3%81%A8HDMI%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82IPU1_DI0%EF%BC%88BT1120%201280*720%4025%EF%BC%89%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%82%82%E3%81%97%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81clk-imx6q.c%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20mmdc_ch0_axi%20528MHz%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bpll3_usb_otg%20480MHz%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bpll2_pfd0_352m%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bpll2_pfd2_396m%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bpll3_pfd1_540m%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIPU1_DI0%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92pll3_pfd1_540m%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9Amx_clk_set_parent(clk%5BIMX6QDL_CLK_IPU1_DI0_PRE_SEL%5D%2C%20clk%5BIMX6QDL_CLK_PLL3_PFD1_540M%5D)%3B%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%3CSPAN%20style%3D%22color%3A%20%23333333%3B%22%3Estruct%20fb_videomode%E3%81%AEpixclock%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E5%87%BA%E5%8A%9B%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82BT1120%E7%94%BB%E9%9D%A2%E5%87%BA%E5%8A%9B%E3%81%AF%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E8%89%B2%E3%81%8C%E3%81%B2%E3%81%A9%E3%81%8F%E6%AD%AA%E3%82%93%E3%81%A7%E3%81%8A%E3%82%8A%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%82%E5%AE%8C%E5%85%A8%E3%81%AB74.25MHz%E3%81%AB%E3%81%AF%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FSPAN%3E%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125879%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125879%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AA%B0%E3%81%8B%E3%81%8C%E3%81%99%E3%81%A7%E3%81%AB%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB4.9.123%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E7%A7%BB%E6%A4%8D%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%8B%95%E3%81%8B%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%83%91%E3%83%8B%E3%83%83%E3%82%AF%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E3%80%8CFailed%20set%20parent%20clk%E3%80%8D%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E6%AF%94%E8%BC%83%E3%81%97%E3%81%9F%E7%B5%90%E6%9E%9C%E3%80%814.1.15%20%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%20clk%20%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%8C%E5%8A%A0%E3%81%88%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%AF%E3%83%AA%E3%83%B3%E3%83%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125878%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125878%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHDMI%E3%81%A7%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81PLL5%E3%81%AE%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82HDMI%E3%81%8C%E7%89%B9%E5%88%A5%E3%81%AA%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81PLL5%E3%82%92%E5%9B%BA%E5%AE%9A%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81BT1120%E3%81%A8HDMI%E3%81%A7%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E7%94%9F%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81PLL5%E3%81%8C594MHz%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%811080P%20HDMI(148.5MHz%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF)%2B%20BT1120(74.25MHz%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF)%E3%82%92%E4%B8%80%E7%B7%92%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E5%8F%AF%E8%83%BD%E3%81%AA%20PLL5%20%E3%82%92%E9%99%A4%E3%81%8D%E3%80%81IPU_DI%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%BF%BD%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bmmdc_ch0_axi%20528MHz%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bpll3_usb_otg%20480MHz%3C%2FP%3E%3CP%3Epll2_pfd0_352m%3C%2FP%3E%3CP%3Epll2_pfd2_396m%3C%2FP%3E%3CP%3Epll3_pfd1_540m%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125877%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125877%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82L3.14.28%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A8i.mx6q%20CPU%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AEL3.14.52_1.1.0_GA_bt656_output_patch_2016-06-27%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E9%81%A9%E7%94%A8%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81arch%2Farm%2Fmach-imx%2Fclk-imx6q.c%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E8%A8%AD%E5%AE%9A%E3%81%8C%E5%85%83%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%3C%2FP%3E%3CP%3Eimx_clk_set_parent(clk%5BIMX6QDL_CLK_IPU1_DI0_PRE_SEL%5D%2Cclk%5BIMX6QDL_CLK_PLL5_VIDEO_DIV%5D)%3B%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81BT1120%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%AF1280*720%4025%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AF74.25MHz%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E7%8F%BE%E6%99%82%E7%82%B9%E3%81%A7%E3%81%AFHDMI%E3%81%A7%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E3%83%91%E3%83%83%E3%83%81%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%A8%3C%2FP%3E%3CP%3Emx_clk_set_parent(clk%5BIMX6QDL_CLK_IPU1_DI0_PRE_SEL%5D%2C%20clk%5BIMX6QDL_CLK_PLL3_PFD1_540M%5D)%3B%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%86%E3%81%99%E3%82%8B%E3%81%A8BT1120%E3%81%AF%E5%87%BA%E5%8A%9B%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82IPU1_DI0%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6PLL3_PFD1_540M%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81BT1120%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E5%87%BA%E5%8A%9B%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BB%96%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E8%A8%AD%E5%AE%9A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%BE%E3%81%9F%E3%80%81%E3%81%93%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%93%E3%81%AE%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E4%BB%96%E3%81%AB%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%92%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125876%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125876%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%20class%3D%22%22%20style%3D%22color%3A%20%23777777%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CDIV%20class%3D%22%22%20style%3D%22background-color%3A%20%23ffffff%3B%20padding-bottom%3A%2056px%3B%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%20style%3D%22background-color%3A%20%23ffffff%3B%20padding%3A%2020px%200px%200px%3B%22%3E%3CDIV%20class%3D%22%22%20style%3D%22padding%3A%200px%2016px%200px%2028px%3B%22%3E%3CDIV%20class%3D%22%22%20style%3D%22color%3A%20%23777777%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3EHI%20.%20Qiang%20Li-Mpu%20se%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%20style%3D%22color%3A%20%23777777%3B%22%3E%3CSPAN%20style%3D%22color%3A%20rgba(0%2C%200%2C%200%2C%200.87)%3B%20background-color%3A%20%23f5f5f5%3B%22%3E%E3%81%93%E3%81%AE%E5%BA%A6%E3%81%AF%E3%81%8A%E8%BF%94%E4%BA%8B%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E8%AA%A0%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6IIC%E3%81%AE%E4%BF%A1%E5%8F%B7%E5%BC%B7%E5%BA%A6%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%20style%3D%22color%3A%20%23777777%3B%22%3E%20%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%20style%3D%22margin-top%3A%2010px%3B%20margin-right%3A%2010px%3B%22%3E%3CDIV%3E%3CDIV%20class%3D%22%22%3E%3CA%20data-tooltip%3D%22%E6%89%93%E5%BC%80%E8%BE%93%E5%85%A5%E6%B3%95%22%20data-tooltip-align%3D%22t%2Cc%22%20style%3D%22color%3A%20%23444444%3B%20background-color%3A%20%23f5f5f5%3B%20border%3A%201px%20solid%20%23dcdcdc%3B%20font-weight%3A%20bold%3B%20font-size%3A%2011px%3B%22%20tabindex%3D%220%22%20target%3D%22_blank%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22margin%3A%206px%200px%200px%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20data-tooltip%3D%22%E9%80%89%E6%8B%A9%E8%BE%93%E5%85%A5%E5%B7%A5%E5%85%B7%22%20data-tooltip-align%3D%22t%2Cc%22%20style%3D%22color%3A%20%23444444%3B%20background-color%3A%20%23f5f5f5%3B%20border%3A%201px%20solid%20%23dcdcdc%3B%20font-weight%3A%20bold%3B%20font-size%3A%2011px%3B%20margin%3A%200px%200px%200px%20-1px%3B%22%20tabindex%3D%220%22%20target%3D%22_blank%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22margin%3A%206px%200px%200px%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%20style%3D%22font-size%3A%2012px%3B%20margin-top%3A%2012px%3B%20margin-right%3A%2020px%3B%22%3E%3CDIV%20class%3D%22%22%3E26%2F5000%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%20data-tooltip%3D%22%E5%BC%80%E5%90%AF%E8%AF%AD%E9%9F%B3%E8%BE%93%E5%85%A5%E5%8A%9F%E8%83%BD%22%20data-tooltip-align%3D%22t%2Cc%22%20style%3D%22color%3A%20%23444444%3B%20background%3A%20none%20transparent%3B%20border%3A%20none%3B%20font-weight%3A%20bold%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011px%3B%20margin%3A%204px%200px%200px%204px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22margin%3A%206px%200px%200px%206px%3B%22%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%20data-tooltip%3D%22%E6%9C%97%E8%AF%BB%22%20data-tooltip-align%3D%22t%2Cc%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20normal%3B%20font-size%3A%2013px%3B%20margin-right%3A%201px%3B%22%3E%3CDIV%20class%3D%22%22%20style%3D%22margin%3A%209px%200px%200px%2012px%3B%22%3E%20%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%20style%3D%22color%3A%20%23777777%3B%20background-color%3A%20%23f5f5f5%3B%20font-size%3A%2016px%3B%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%20style%3D%22background-color%3A%20%23f5f5f5%3B%20padding%3A%2020px%2016px%2056px%2028px%3B%22%3E%3CDIV%20class%3D%22%22%3E%20%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%20style%3D%22padding-right%3A%2044px%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22en%22%20style%3D%22color%3A%20rgba(0%2C%200%2C%200%2C%200.87)%3B%20font-size%3A%2024px%3B%20padding-right%3A%208px%3B%22%3E%3CSPAN%20class%3D%22%22%20title%3D%22%22%3E%E3%81%93%E3%81%AE%E5%BA%A6%E3%81%AF%E3%81%8A%E8%BF%94%E4%BA%8B%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E8%AA%A0%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6IIC%E3%81%AE%E4%BF%A1%E5%8F%B7%E5%BC%B7%E5%BA%A6%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125874%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125874%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%40%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20style%3D%22color%3A%20%233d9ce7%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.9994px%3B%22%20target%3D%22_blank%22%3EQiang%20Li%20-%20Mpu%20Se%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E5%BC%8A%E7%A4%BE%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E7%9B%A3%E8%A6%96%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E8%BB%8A%E8%BC%89%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%AEimx6q%E3%83%81%E3%83%83%E3%83%97%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%81Inbet%20Sabrelite%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E5%8F%82%E8%80%83%E3%81%AB%E6%94%B9%E9%80%A0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AFLinux%203.0.35%E3%81%A7%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AFCVBS%E5%87%BA%E5%8A%9B%E3%81%A8HDMI%E5%87%BA%E5%8A%9B%E3%81%AE2%E3%81%A4%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%8C%E6%90%AD%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82CVBS%E5%87%BA%E5%8A%9B%E3%81%AB%E3%81%AFADV7391%E3%83%81%E3%83%83%E3%83%97%E3%81%8C%E6%8E%A1%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81ADV7391%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E5%8B%95%E4%BD%9C%E6%B8%A9%E5%BA%A6%E7%AF%84%E5%9B%B2%E3%81%AF-40%E2%84%83%EF%BD%9E85%E2%84%83%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%95%E3%82%8C%E3%81%9FL3.0.35_4.1.0_GA_bt656_output_patch_2017-03-10.zip%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%91%E3%83%83%E3%83%81%E9%81%A9%E7%94%A8%E5%BE%8C%E3%80%81board-mx6q_sabrelite.c%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%80%81adv7391%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82IIC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%80%82%E3%83%94%E3%83%B3%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%82%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%94%E3%83%B3%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2024.05pt%3B%20text-indent%3A%2018.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3E%2F*%3C%2FSPAN%3E%20DISPLAY%20RGB%20%E3%81%AE%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%B3%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3E*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2024.05pt%3B%20text-indent%3A%2018.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3E%2F*New%20Code%20for%20Board%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2024.05pt%3B%20text-indent%3A%2018.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3E%E3%82%AA%E3%83%AA%E3%82%B8%E3%83%8A%E3%83%AB%E3%81%AE%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3ESabrelite%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3E%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AF%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3EMX6_PAD_DISP0_DAT0%E3%80%9CMX6_PAD_DISP0_DAT23%E3%81%AE24%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3E%E3%83%93%E3%83%83%E3%83%88%3C%2FSPAN%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2024.05pt%3B%20text-indent%3A%2021.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3E%E6%96%B0%E3%81%97%E3%81%84%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3E%20DIS0%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3E%20%E3%81%AF%20ADV7391BCPZ%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3E%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3E%20%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3E%208%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3E%20%E3%83%93%E3%83%83%E3%83%88%E3%83%90%E3%82%B9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3E%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2045.05pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3EMX6Q_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK%E3%80%81%2F*DISP0_CLK*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2045.05pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3E%2F%2FMX6Q_PAD_DI0_PIN15__IPU1_DI0_PIN15%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20DE%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2045.05pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3EMX6Q_PAD_DI0_PIN2__IPU1_DI0_PIN2%E3%80%81%2F*%20DISP0_HSYNC%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2045.05pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3EMX6Q_PAD_DI0_PIN3__IPU1_DI0_PIN3%2C%20%2F*%20DISP0_VSYNC%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2045.05pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3EMX6Q_PAD_DI0_PIN4__IPU1_DI0_PIN4%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2045.05pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3EMX6Q_PAD_DI0_PIN4__GPIO_4_20%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20CVBS_nRST%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2045.05pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3EMX6Q_PAD_DISP0_DAT0__IPU1_DISP0_DAT_0%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2045.05pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3EMX6Q_PAD_DISP0_DAT1__IPU1_DISP0_DAT_1%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2045.05pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3EMX6Q_PAD_DISP0_DAT2__IPU1_DISP0_DAT_2%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2045.05pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3EMX6Q_PAD_DISP0_DAT3__IPU1_DISP0_DAT_3%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2045.05pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3EMX6Q_PAD_DISP0_DAT4__IPU1_DISP0_DAT_4%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2045.05pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3EMX6Q_PAD_DISP0_DAT5__IPU1_DISP0_DAT_5%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2045.05pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3EMX6Q_PAD_DISP0_DAT6__IPU1_DISP0_DAT_6%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2045.05pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3EMX6Q_PAD_DISP0_DAT7__IPU1_DISP0_DAT_7%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2045.05pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2018.0pt%3B%20text-indent%3A%200cm%3B%22%3E%3CSPAN%3Elinux3.0.35%2Fdrivers%2Fmxc%2Fipu3%2Fipu_disp.c%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%2062%3C%2FSPAN%3E%E8%A1%8C%E7%9B%AE%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2017.95pt%3B%20text-indent%3A%2015.75pt%3B%22%3E%E3%83%9E%E3%82%AF%E3%83%AD%E5%AE%9A%E7%BE%A9%3CSPAN%3E23%3C%2FSPAN%3E%E3%82%92%3CSPAN%3E7%3C%2FSPAN%3E%E3%81%AB%E5%A4%89%E6%9B%B4%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2018.0pt%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20206.95pt%3B%20text-indent%3A%20-189.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3E%23%E5%AE%9A%E7%BE%A9%20BT656_IF_DI_MSB%207%2F%2F%2023%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20206.95pt%3B%20text-indent%3A%20-189.0pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3E%2F*%20For%208%20bits%20BT656%3A%2023%20for%20DISP_DAT23%20~%20DISP_DAT16%3B%207%20for%20DISP_DAT7%20~%20DISP_DAT0%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2018.0pt%3B%20text-indent%3A%200cm%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3E%2F*%20For%2016%20bits%20BT1120%3A%2023%20for%20DISP_DAT23%20~%20DISP_DAT8%3B%2015%20for%20DISP_DAT15%20~%20DISP_DAT0%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2018.0pt%3B%20text-indent%3A%200cm%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2018.0pt%3B%20text-indent%3A%200cm%3B%22%3E%E7%A7%81%E3%81%AE%E5%80%8B%E4%BA%BA%E7%9A%84%E3%81%AA%E3%83%91%E3%83%83%E3%83%81%E8%A8%98%E9%8C%B2%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Elinux%40ubuntu%3A~%2Fworkspace%2Fmx6q%2Flinux-3.0.35%24%20patch%20-p1%20%26lt%3B%200001-Support-BT656-and-BT1120-output-for-iMX6-ipuv3.patch%3CBR%20%2F%3Epatching%20file%20arch%2Farm%2Fconfigs%2Fimx6_defconfig%3CBR%20%2F%3Epatching%20file%20arch%2Farm%2Fmach-mx6%2Fboard-mx6q_sabresd.c%3CBR%20%2F%3Epatching%20file%20arch%2Farm%2Fmach-mx6%2Fdevices-imx6q.h%3CBR%20%2F%3Epatching%20file%20arch%2Farm%2Fplat-mxc%2Finclude%2Fmach%2Fipu-v3.h%3CBR%20%2F%3Epatching%20file%20drivers%2Fmedia%2Fvideo%2Fmxc%2Foutput%2Fmxc_vout.c%3CBR%20%2F%3Epatching%20file%20drivers%2Fmxc%2Fipu3%2Fipu_common.c%3CBR%20%2F%3Epatching%20file%20drivers%2Fmxc%2Fipu3%2Fipu_device.c%3CBR%20%2F%3Epatching%20file%20drivers%2Fmxc%2Fipu3%2Fipu_disp.c%3CBR%20%2F%3Epatching%20file%20drivers%2Fmxc%2Fipu3%2Fipu_regs.h%3CBR%20%2F%3Epatching%20file%20drivers%2Fvideo%2Fmxc%2FKconfig%3CBR%20%2F%3Epatching%20file%20drivers%2Fvideo%2Fmxc%2FMakefile%3CBR%20%2F%3Epatching%20file%20drivers%2Fvideo%2Fmxc%2Fmxc_bt656if.c%3CBR%20%2F%3Epatching%20file%20drivers%2Fvideo%2Fmxc%2Fmxc_ipuv3_fb.c%3CBR%20%2F%3Epatching%20file%20include%2Flinux%2Fipu.h%3CBR%20%2F%3Epatching%20file%20include%2Flinux%2Fmxcfb.h%3C%2FP%3E%3CP%3Elinux%40ubuntu%3A~%2Fworkspace%2Fmx6q%2Flinux-3.0.35%24%20patch%20-p1%20%26lt%3B%200002-Support-adv739x-TV-encoder-for-BT656-output.patch%3CBR%20%2F%3Epatching%20file%20arch%2Farm%2Fmach-mx6%2Fboard-mx6q_sabresd.c%3CBR%20%2F%3Epatching%20file%20drivers%2Fvideo%2Fmxc%2FKconfig%3CBR%20%2F%3Epatching%20file%20drivers%2Fvideo%2Fmxc%2FMakefile%3CBR%20%2F%3Epatching%20file%20drivers%2Fvideo%2Fmxc%2Fmxcfb_adv739x.c%3C%2FP%3E%3CP%3Elinux%40ubuntu%3A~%2Fworkspace%2Fmx6q%2Flinux-3.0.35%24%20patch%20-p1%20%26lt%3B%200003-Enhance-dual-display-support-for-BT656-output.patch%3CBR%20%2F%3Epatching%20file%20arch%2Farm%2Fmach-mx6%2Fboard-mx6q_sabresd.c%3CBR%20%2F%3Epatching%20file%20arch%2Farm%2Fmach-mx6%2Fclock.c%3CBR%20%2F%3Epatching%20file%20arch%2Farm%2Fplat-mxc%2Finclude%2Fmach%2Fipu-v3.h%3CBR%20%2F%3Epatching%20file%20drivers%2Fmedia%2Fvideo%2Fmxc%2Fcapture%2Fipu_bg_overlay_sdc.c%3CBR%20%2F%3Epatching%20file%20drivers%2Fmedia%2Fvideo%2Fmxc%2Fcapture%2Fipu_csi_enc.c%3CBR%20%2F%3Epatching%20file%20drivers%2Fmedia%2Fvideo%2Fmxc%2Fcapture%2Fipu_fg_overlay_sdc.c%3CBR%20%2F%3Epatching%20file%20drivers%2Fmedia%2Fvideo%2Fmxc%2Fcapture%2Fipu_prp_enc.c%3CBR%20%2F%3Epatching%20file%20drivers%2Fmedia%2Fvideo%2Fmxc%2Fcapture%2Fipu_prp_vf_sdc.c%3CBR%20%2F%3Epatching%20file%20drivers%2Fmedia%2Fvideo%2Fmxc%2Fcapture%2Fipu_prp_vf_sdc_bg.c%3CBR%20%2F%3Epatching%20file%20drivers%2Fmedia%2Fvideo%2Fmxc%2Fcapture%2Fipu_still.c%3CBR%20%2F%3Epatching%20file%20drivers%2Fmxc%2Fipu3%2Fipu_common.c%3CBR%20%2F%3Epatching%20file%20drivers%2Fmxc%2Fipu3%2Fipu_device.c%3CBR%20%2F%3Epatching%20file%20drivers%2Fmxc%2Fipu3%2Fipu_disp.c%3CBR%20%2F%3Epatching%20file%20drivers%2Fmxc%2Fipu3%2Fipu_prv.h%3CBR%20%2F%3Epatching%20file%20drivers%2Fvideo%2Fmxc%2Fmxc_ipuv3_fb.c%3C%2FP%3E%3CP%3Elinux%40ubuntu%3A~%2Fworkspace%2Fmx6q%2Flinux-3.0.35%24%20patch%20-p1%20%26lt%3B%200004-BT656-Display-updated-for-BT1120-1080i-support.patch%3CBR%20%2F%3Epatching%20file%20drivers%2Fmxc%2Fipu3%2Fipu_disp.c%3CBR%20%2F%3Epatching%20file%20drivers%2Fvideo%2Fmxc%2Fmxc_bt656if.c%3C%2FP%3E%3CP%3Elinux%40ubuntu%3A~%2Fworkspace%2Fmx6q%2Flinux-3.0.35%24%20patch%20-p1%20%26lt%3B%200005-Update-IPU-microcode-to-align-with-BT656.4-specifica.patch%3CBR%20%2F%3Epatching%20file%20drivers%2Fmxc%2Fipu3%2Fipu_disp.c%3CBR%20%2F%3Epatching%20file%20drivers%2Fvideo%2Fmxc%2Fmxc_bt656if.c%3CBR%20%2F%3Epatching%20file%20drivers%2Fvideo%2Fmxc%2Fmxcfb_adv739x.c%3C%2FP%3E%3CP%3Elinux%40ubuntu%3A~%2Fworkspace%2Fmx6q%2Flinux-3.0.35%24%20patch%20-p1%20%26lt%3B%200006-Set-Y-range-16-235-U-V-range-16-240-for-BT656-displa.patch%3CBR%20%2F%3Epatching%20file%20drivers%2Fmxc%2Fipu3%2Fipu_disp.c%3C%2FP%3E%3CP%3Elinux%40ubuntu%3A~%2Fworkspace%2Fmx6q%2Flinux-3.0.35%24%20patch%20-p1%20%26lt%3B%200007-Add-progressive-mode-support-for-BT656-and-BT1120-di.patch%3CBR%20%2F%3Epatching%20file%20drivers%2Fmxc%2Fipu3%2Fipu_disp.c%3CBR%20%2F%3Epatching%20file%20drivers%2Fvideo%2Fmxc%2Fmxc_bt656if.c%3CBR%20%2F%3Epatching%20file%20drivers%2Fvideo%2Fmxc%2Fmxc_ipuv3_fb.c%3C%2FP%3E%3CP%3Elinux%40ubuntu%3A~%2Fworkspace%2Fmx6q%2Flinux-3.0.35%24%20patch%20-p1%20%26lt%3B%200008-Fixed-a-hard-coding-DC-macro-issue-for-progressive-m.patch%3CBR%20%2F%3Epatching%20file%20drivers%2Fmxc%2Fipu3%2Fipu_disp.c%3CBR%20%2F%3Elinux%40ubuntu%3A~%2Fworkspace%2Fokmx6q%2Flinux-3.0.35%24%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2018.0pt%3B%20text-indent%3A%200cm%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23548dd4%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%233d3d3d%3B%22%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A8%E5%A4%89%E6%9B%B4%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E5%AE%A4%E6%B8%A9%E3%81%A7%E3%83%93%E3%83%87%E3%82%AA%E7%94%BB%E5%83%8F%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%8B%E3%81%A4%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%A6%E8%A1%A8%E7%A4%BA%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190507174048.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190507174048.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F72960i216C3087421ADD08%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190507174048.jpg%22%20alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190507174048.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF-40%E2%84%83%E3%81%AE%E4%BD%8E%E6%B8%A9%E7%92%B0%E5%A2%83%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E7%94%BB%E5%83%8F%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82adv7391%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82adv7391%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8C%E3%81%B0%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AF%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92HDMI%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8C%E3%81%B0%E3%80%81%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190507174045.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190507174045.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F72516iB961D7FA71659A39%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190507174045.jpg%22%20alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20190507174045.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%23%20cat%20%2Fsys%2Fclass%2Fgraphics%2Ffb0%2Ffsl_disp_dev_property%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3Barch%5Carm%5Cmach-mx6%5Cclock.c%26nbsp%3B%20%26nbsp%3B%20%E9%85%8D%E7%BD%AE%E6%88%90%E4%BA%86%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3Eclk_set_parent(%26amp%3Bipu1_di_clk%5B0%5D%2C%20%26amp%3Bpll3_pfd_540M)%3B%26nbsp%3B%20%2F%2Ffor%20CVBS%2027MHz%20clock%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3Eclk_set_parent(%26amp%3Bipu1_di_clk%5B1%5D%2C%20%26amp%3Bpll5_video_main_clk)%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%22video%3Dmxcfb0%3Adev%3Dadv739x%2CBT656-PAL%2Cif%3DBT656%2Cfbpix%3DRGB565%22%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E4%B8%8A%E8%A8%98%E3%81%8C%E7%A7%81%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E6%9C%9B%E6%8C%87%E6%95%99%EF%BC%81%26nbsp%3B%20%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125872%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125872%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20%2C%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%A9%E3%83%AC%E3%83%AB%E3%83%93%E3%83%87%E3%82%AA%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88YUV422%208bit%E3%81%A8Hsync%20Vsync%20DE%20Pclk%E4%BF%A1%E5%8F%B7%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%99%E3%82%8BIPU%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EL4.1.15%20%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E4%BD%95%E3%81%8B%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%87%AA%E5%88%86%E3%81%A7%E7%A7%BB%E6%A4%8D%E3%81%97%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%89%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E4%BD%95%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%82%8B%E3%81%AE%E3%81%8C%E6%9C%80%E5%96%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F339528-1-418896%2FL3.14.52_1.1.0_GA_bt656_output_patch_2016-06-27.zip%22%20target%3D%22_blank%22%3EL3.14.52_1.1.0_GA_bt656_output_patch_2016-06-27.zip%3C%2FA%3E%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%26nbsp%3BMartin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%3C%2FP%3E%3CP%3EHi%2C%20Qiang%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELinux%204.1.15%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99IMX6Q%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E4%B8%8A%E3%81%A7%E3%80%81Linux%204.1.15%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81%E3%81%93%E3%81%93%E3%81%AELinux%203.x%E7%94%A8%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81Linux%204.1.15%E3%81%AB%E3%82%82%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125861%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125861%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%86%E3%81%A0%E3%81%91%E3%81%A7%E3%80%81%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%81%94%E3%81%A8%E3%81%AB2%E3%81%A4%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%2F*%20%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%20*%2F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20_ipu_di_sync_config(ipu%2C%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20disp%2C%26nbsp%3B%26nbsp%3B%20%2F*%20display%20*%2F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EDI_SYNC_APIXEL%E3%80%81%2F*%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC*%2F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E0%2C%20%2F*%20%E3%83%A9%E3%83%B3%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%20*%2F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSTRONG%20style%3D%22border%3A%200px%3B%20font-weight%3A%20bold%3B%22%3EDI_SYNC_CLK%20*%202%2C%20%2F*%20run_resolution%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3Eh_start_width%20%2B%20h_sync_width%2C%20%2F*%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20*%2F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EDI_SYNC_CLK%2C%20%2F*%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E5%88%86%E8%A7%A3%E8%83%BD%20*%2F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3Ewidth%2C%20%2F*%20%E3%83%AA%E3%83%94%E3%83%BC%E3%83%88%E5%9B%9E%E6%95%B0%20*%2F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EDI_SYNC_ALINE%2C%20%2F*%20CNT_CLR_SEL%20*%2F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%2C%26nbsp%3B%26nbsp%3B%20%2F*%20CNT_POLARITY_GEN_EN%26nbsp%3B%20*%2F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EDI_SYNC_NONE%2C%20%2F*%20CNT_POLARITY_CLR_SEL%20*%2F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20DI_SYNC_NONE%2C%26nbsp%3B%20%2F*%20CNT_POLARITY_TRIGGER_SEL%26nbsp%3B%20*%2F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E0%2C%20%2F*%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%20*%2F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E0%20%2F*%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%83%80%E3%82%A6%E3%83%B3%20*%2F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20)%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125857%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125857%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%A2%E3%83%8C%E3%83%A9%E3%83%80%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3EHSYNC%20%E3%81%8A%E3%82%88%E3%81%B3%20HSYNC%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%2016%20%E3%83%93%E3%83%83%E3%83%88%20YCbCr%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E5%8F%82%E7%85%A7%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-100657%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-100657%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Evideo%3Dmxcfb0%3Adev%3Dlcd%2CLCD-1080i50%2Cif%3DUYVY16%2Cfbpix%3DRGB32%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%22if%3DUYVY16%22%20%E3%81%AF%2016%20%E3%83%93%E3%83%83%E3%83%88%20YCbCr%20%E3%81%A7%E3%80%81HSYNC%20%E3%81%8A%E3%82%88%E3%81%B3%20HSYNC%20%E5%87%BA%E5%8A%9B%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%80%8CLCD-1080i50%E3%80%8D%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E7%8B%AC%E8%87%AA%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AEBSP%E3%81%AFUYVY16%E3%83%A2%E3%83%BC%E3%83%89%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81%E3%81%9D%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%80%8CBT656%208%E3%83%93%E3%83%83%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%E7%94%A8RGB%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%80%8D%E3%82%82%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%80%81%E8%A1%A8%E7%A4%BA%E3%81%ABDC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81CSC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%9B%E3%81%9A%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E5%86%85%E3%81%AERGB%E3%83%87%E3%83%BC%E3%82%BF%E3%82%928%E3%83%93%E3%83%83%E3%83%88LCD%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%AB%E7%9B%B4%E6%8E%A5%E9%80%81%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125856%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125856%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%26nbsp%3BQiang-Li%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFADV7342%E3%83%81%E3%83%83%E3%83%97%E3%82%9216%E3%83%93%E3%83%83%E3%83%88%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%90%E3%82%B9(16%E3%83%93%E3%83%83%E3%83%88YCbCr%E5%85%A5%E5%8A%9B)%E3%82%82%E5%8F%97%E3%81%91%E5%85%A5%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8BTV%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%84%E3%81%9A%E3%82%8C%E3%81%AB%E3%81%9B%E3%82%88%E3%80%81EAV%20%2F%20SAV%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E5%A4%96%E9%83%A8VSYNC%E3%81%A8HSYNC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%A7%E3%81%99%E3%80%82BT1120%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E4%BD%BF%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%AF%E3%81%84%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E5%BD%A2%E5%BC%8F%E3%81%AF%E4%BD%95%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Efb_lcd%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bif_fmt%20%3D%20BT1120%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bif_pixel_fmt%20%3D%20%3F%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81BT656%208%E3%83%93%E3%83%83%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AERGB%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E5%BD%A2%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125855%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125855%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20_jive_internal%3D%22true%22%20class%3D%22%22%20data-content-finding%3D%22Community%22%20data-userid%3D%2236648%22%20data-username%3D%22Qiang_FSL%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20style%3D%22color%3A%20%235e89c1%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20text-decoration%3A%20underline%3B%20font-size%3A%201.286rem%3B%22%20target%3D%22_blank%22%3EQiang%3C%2FA%3E%3C%2FP%3E%3CP%3E%E8%BE%9B%E6%8A%B1%E5%BC%B7%E3%81%8F%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%AE%9F%E8%A3%85%E6%96%B9%E6%B3%95%E3%81%8C%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%94%B9%E3%82%81%E3%81%A6%E6%84%9F%E8%AC%9D%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125854%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125854%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%80%8CBT656%E3%83%87%E3%83%BC%E3%82%BF%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%EF%BC%888%E3%83%93%E3%83%83%E3%83%88%E3%83%87%E3%83%BC%E3%82%BF%E3%83%90%E3%82%B9%EF%BC%89%E3%81%AB%E3%81%8A%E3%81%84%E3%81%A6%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AF%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E5%87%BA%E5%8A%9B%E3%81%AEVSYNC%2FHSYNC%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%80%8D%E5%89%8D%E5%9B%9E%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%A7%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%8F%90%E6%A1%88%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82EAV%2FSAV%E3%81%AF%E3%83%96%E3%83%A9%E3%83%B3%E3%82%AF%E6%99%82%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81HSYNC%2FVSYNC%E3%81%AE%E5%8F%97%E4%BF%A1%E3%81%AB%E3%81%AF%E5%BD%B1%E9%9F%BF%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%AE%9F%E9%9A%9B%E3%81%AB%E6%B3%A2%E5%BD%A2%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%99%E3%82%8C%E3%81%B0%E3%80%81%E3%83%96%E3%83%A9%E3%83%B3%E3%82%AF%E3%81%8C255%E3%82%92%E8%B6%85%E3%81%88%E3%81%AA%E3%81%84%E9%99%90%E3%82%8A%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E7%8A%B6%E3%81%A7%E3%81%AF%E3%81%93%E3%82%8C%E3%81%8C%E6%9C%80%E3%82%82%E7%B0%A1%E5%8D%98%E3%81%AA%E6%96%B9%E6%B3%95%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIPU%E3%81%AF%E3%80%81BT656%E4%BB%A5%E5%A4%96%E3%81%AE8%E3%83%93%E3%83%83%E3%83%88UYVY%2BHSYNC%2FVSYNC%E5%87%BA%E5%8A%9B%E3%82%82%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%B8%BB%E3%81%AA%E5%A4%89%E6%9B%B4%E7%82%B9%E3%81%AF%E3%80%81IPU%E5%81%B4%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%80%811%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%922%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%E5%87%BA%E5%8A%9B%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E6%97%A2%E8%A3%BD%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81IPU%E3%81%AEDI%E9%83%A8%E5%88%86%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%8D%81%E5%88%86%E3%81%AA%E7%90%86%E8%A7%A3%E3%81%8C%E6%B1%82%E3%82%81%E3%82%89%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%94%E8%87%AA%E8%BA%AB%E3%81%A7%E9%96%8B%E7%99%BA%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIPU%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A8%E3%81%AF%E9%96%A2%E4%BF%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82DE%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81IPU%20DI%E3%82%92%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81IPU_DI_PIN%E3%81%8B%E3%82%89%E5%BF%85%E8%A6%81%E3%81%AA%E6%B3%A2%E5%BD%A2%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125853%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125853%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E8%A9%B3%E7%B4%B0%E3%81%AA%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E5%A4%9A%E3%81%8F%E3%81%AE%E7%96%91%E5%95%8F%E3%81%8C%E8%A7%A3%E6%B6%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CBR%20%2F%3E%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81BT656%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%AF%20BT656%20%E6%A8%99%E6%BA%96%E5%BD%A2%E5%BC%8F%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81HSYNC%20%E3%81%A8%20VSYNC%20%E3%81%AE%E5%90%8C%E6%9C%9F%E4%BF%A1%E5%8F%B7%E3%82%92%E5%90%8C%E6%99%82%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BB%96%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%A7%E3%81%AF%E3%80%81VSYNC%2FHSYNC%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%A8%80%E5%8F%8A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E8%AA%AC%E6%98%8E%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20VSYNC%2FHSYNC%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E3%81%AF%20EAV%2FSAV%20%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%9B%E3%81%9A%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%20%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E3%81%BF%E3%81%8C%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E4%BF%A1%E5%8F%B7%E3%81%AF%20VSYNC%20%E3%83%94%E3%83%B3%E3%81%A8%20HSYNC%20%E3%83%94%E3%83%B3%E3%81%A7%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%9D%E3%81%93%E3%81%A7%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%8CBT656%E3%83%87%E3%83%BC%E3%82%BF%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%EF%BC%888%E3%83%93%E3%83%83%E3%83%88%E3%83%87%E3%83%BC%E3%82%BF%E3%83%90%E3%82%B9%EF%BC%89%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E5%87%BA%E5%8A%9B%E3%81%AEVSYNC%2FHSYNC%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%82%82%E3%81%97%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E5%BD%93%E3%81%A6%E3%81%A6%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%93%E3%82%8C%E3%81%AF%E5%A4%A7%E5%A4%89%E3%81%AA%E4%BD%9C%E6%A5%AD%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%81%BE%E3%81%A0EAV%2FSAV%E5%87%BA%E5%8A%9B%E3%81%AE%E3%81%AA%E3%81%84%E7%B4%94%E7%B2%8B%E3%81%AAUYVY%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%81%BE%E3%81%9F%E3%80%81DE%E4%BF%A1%E5%8F%B7%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%A7%A6%E3%82%8C%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%97%A2%E5%AD%98%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A8%E3%81%AE%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A7%E3%80%81%E3%82%88%E3%82%8A%E8%A9%B3%E3%81%97%E3%81%8F%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AFDE%E5%87%BA%E5%8A%9B%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%A9%E3%81%AE%E3%83%94%E3%83%B3%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E4%B8%8A%E8%A8%98%E3%81%AE%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%A7%E6%8F%90%E6%A1%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%80%81DE%E4%BF%A1%E5%8F%B7%E5%87%BA%E5%8A%9B%E3%81%AB%E5%88%A5%E3%81%AE%E3%83%94%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E7%82%B9%E3%81%AF%E3%80%81%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B33.0.xx%E3%82%92%E5%89%8D%E6%8F%90%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B33.14.52%E3%81%AE%E4%BE%8B%E3%82%92%E6%8C%99%E3%81%92%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E6%9C%80%E5%BE%8C%E3%81%AB%E3%80%81DE%20%E4%BF%A1%E5%8F%B7%E3%81%AF%20LCD%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%AE%E3%81%BF%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125851%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125851%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1083553394%22%20id%3D%22toc-hId-2004394017%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E1.%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%9FBT656%20720P%E5%87%BA%E5%8A%9B%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%3C%2FSPAN%3E%3C%2FH3%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F*%201280x720%20Progressive%20output%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%22BT656-720P%22%2C%2060%2C%201280%2C%20720%2C%2020833%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B25%2C%205%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B0%2C%200%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B732%2C%201%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B0%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3BFB_VMODE_NONINTERLACED%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3BFB_MODE_IS_DETAILED%2C%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%90%8C%E6%99%82%E3%81%AB%E3%80%81arch%2Farm%2Fmach-imx%2Fclk-imx6q.c%20%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%2021.0000pt%3B%22%3E---%20a%2F3-kernel%2Farch%2Farm%2Fmach-imx%2Fclk-imx6q.c%3CBR%20%2F%3E%2B%2B%2B%20b%2F3-kernel%2Farch%2Farm%2Fmach-imx%2Fclk-imx6q.c%3CBR%20%2F%3E%40%40%20-489%2C8%20%2B489%2C8%20%40%40%20static%20void%20__init%20imx6q_clocks_init(struct%20device_node%20*ccm_node)%3CBR%20%2F%3E%20clk_register_clkdev(clk%5BIMX6QDL_CLK_ENET_REF%5D%2C%20%22enet_ref%22%2C%20NULL)%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%2F*%20ipu%20clock%20initialization%20*%2F%3CBR%20%2F%3E-%20%2F%2Fimx_clk_set_parent(clk%5BIMX6QDL_CLK_IPU1_DI0_PRE_SEL%5D%2C%20clk%5BIMX6QDL_CLK_PLL5_VIDEO_DIV%5D)%3B%3CBR%20%2F%3E-%20imx_clk_set_parent(clk%5BIMX6QDL_CLK_IPU1_DI0_PRE_SEL%5D%2C%20clk%5BIMX6QDL_CLK_PLL3_PFD1_540M%5D)%3B%3CBR%20%2F%3E%2B%20imx_clk_set_parent(clk%5BIMX6QDL_CLK_IPU1_DI0_PRE_SEL%5D%2C%20clk%5BIMX6QDL_CLK_PLL5_VIDEO_DIV%5D)%3B%3CBR%20%2F%3E%2B%20%2F%2Fimx_clk_set_parent(clk%5BIMX6QDL_CLK_IPU1_DI0_PRE_SEL%5D%2C%20clk%5BIMX6QDL_CLK_PLL3_PFD1_540M%5D)%3B%3CBR%20%2F%3E%20imx_clk_set_parent(clk%5BIMX6QDL_CLK_IPU1_DI1_PRE_SEL%5D%2C%20clk%5BIMX6QDL_CLK_PLL5_VIDEO_DIV%5D)%3B%3CBR%20%2F%3E%20imx_clk_set_parent(clk%5BIMX6QDL_CLK_IPU2_DI0_PRE_SEL%5D%2C%20clk%5BIMX6QDL_CLK_PLL5_VIDEO_DIV%5D)%3B%3CBR%20%2F%3E%20imx_clk_set_parent(clk%5BIMX6QDL_CLK_IPU2_DI1_PRE_SEL%5D%2C%20clk%5BIMX6QDL_CLK_PLL5_VIDEO_DIV%5D)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%2021.0000pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AFipu_disp.c%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E6%B3%A2%E5%BD%A2%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E7%95%B0%E5%B8%B8%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%2021.0000pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E7%9C%8B%E4%B8%8A%E5%8E%BB%E4%B8%8D%E6%AD%A3%E5%B8%B8%E7%9A%84%E6%97%B6%E9%92%9F%E6%B3%A2%E5%BD%A2.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E7%9C%8B%E4%B8%8A%E5%8E%BB%E4%B8%8D%E6%AD%A3%E5%B8%B8%E7%9A%84%E6%97%B6%E9%92%9F%E6%B3%A2%E5%BD%A2.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F31457iB97E472C7F248DF3%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E7%9C%8B%E4%B8%8A%E5%8E%BB%E4%B8%8D%E6%AD%A3%E5%B8%B8%E7%9A%84%E6%97%B6%E9%92%9F%E6%B3%A2%E5%BD%A2.jpg%22%20alt%3D%22%E7%9C%8B%E4%B8%8A%E5%8E%BB%E4%B8%8D%E6%AD%A3%E5%B8%B8%E7%9A%84%E6%97%B6%E9%92%9F%E6%B3%A2%E5%BD%A2.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%2021.0000pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E%E7%A7%81%E3%81%8C%E6%B0%97%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E8%AA%A4%E3%81%A3%E3%81%9F%E8%A8%AD%E5%AE%9A%E3%81%8C%E3%81%AA%E3%81%84%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%2021.0000pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E---%20a%2F3-kernel%2Fdrivers%2Fmxc%2Fipu3%2Fipu_disp.c%3CBR%20%2F%3E%2B%2B%2B%20b%2F3-kernel%2Fdrivers%2Fmxc%2Fipu3%2Fipu_disp.c%3CBR%20%2F%3E%40%40%20-3011%2C7%20%2B3011%2C7%20%40%40%20int32_t%20ipu_init_sync_panel(struct%20ipu_soc%20*ipu%2C%20int%20disp%2C%20uint32_t%20pixel_clk%2C%3CBR%20%2F%3E%200%2C%20%2F*%20COUNT%20UP%20*%2F%3CBR%20%2F%3E%200%20%2F*%20COUNT%20DOWN%20*%2F%3CBR%20%2F%3E%20)%3B%3CBR%20%2F%3E-%3CBR%20%2F%3E%2Bprintk(KERN_ALERT%20%22ipu_init_sync_panel%2C%20div%3D%25d%2C%20h_total%3D%25d%2C%20v_total%3D%25d%5Cn%22%2C%20div%2C%20h_total%2C%20v_total)%3B%3CBR%20%2F%3E%20%2F*%20COUNTER_2%3A%20HSYNC%20for%20each%20line%20*%2F%3CBR%20%2F%3E%20_ipu_di_sync_config(ipu%2C%3CBR%20%2F%3E%20disp%2C%20%2F*%20display%20*%2F%3CBR%20%2F%3E%40%40%20-3022%2C11%20%2B3022%2C11%20%40%40%20int32_t%20ipu_init_sync_panel(struct%20ipu_soc%20*ipu%2C%20int%20disp%2C%20uint32_t%20pixel_clk%2C%3CBR%20%2F%3E%20DI_SYNC_NONE%2C%20%2F*%20offset%20resolution%20*%2F%3CBR%20%2F%3E%200%2C%20%2F*%20repeat%20count%20*%2F%3CBR%20%2F%3E%20DI_SYNC_NONE%2C%20%2F*%20CNT_CLR_SEL%20*%2F%3CBR%20%2F%3E-%200%2C%20%2F*%20CNT_POLARITY_GEN_EN%20*%2F%3CBR%20%2F%3E%2B%201%2C%20%2F*%20CNT_POLARITY_GEN_EN%20*%2F%3CBR%20%2F%3E%20DI_SYNC_NONE%2C%20%2F*%20CNT_POLARITY_CLR_SEL%20*%2F%3CBR%20%2F%3E-%20DI_SYNC_NONE%2C%20%2F*%20CNT_POLARITY_TRIGGER_SEL%20*%2F%3CBR%20%2F%3E%2B%20DI_BT656_SYNC_BASECLK%2C%20%2F*%20CNT_POLARITY_TRIGGER_SEL%20*%2F%3CBR%20%2F%3E%200%2C%20%2F*%20COUNT%20UP%20*%2F%3CBR%20%2F%3E-%202*div%20%2F*%20COUNT%20DOWN%20*%2F%3CBR%20%2F%3E%2B%202*80%20%2F*%20COUNT%20DOWN%20*%2F%3CBR%20%2F%3E%20)%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20vsync_cnt%20%3D%20DI_BT656_SYNC_IVSYNC%3B%3CBR%20%2F%3E%40%40%20-3041%2C11%20%2B3041%2C11%20%40%40%20int32_t%20ipu_init_sync_panel(struct%20ipu_soc%20*ipu%2C%20int%20disp%2C%20uint32_t%20pixel_clk%2C%3CBR%20%2F%3E%20DI_SYNC_NONE%2C%20%2F*%20offset%20resolution%20*%2F%3CBR%20%2F%3E%200%2C%20%2F*%20repeat%20count%20*%2F%3CBR%20%2F%3E%20DI_SYNC_NONE%2C%20%2F*%20CNT_CLR_SEL%20*%2F%3CBR%20%2F%3E-%200%2C%20%2F*%20CNT_POLARITY_GEN_EN%20*%2F%3CBR%20%2F%3E%2B%201%2C%20%2F*%20CNT_POLARITY_GEN_EN%20*%2F%3CBR%20%2F%3E%20DI_SYNC_NONE%2C%20%2F*%20CNT_POLARITY_CLR_SEL%20*%2F%3CBR%20%2F%3E-%20DI_SYNC_NONE%2C%20%2F*%20CNT_POLARITY_TRIGGER_SEL%20*%2F%3CBR%20%2F%3E%2B%20DI_BT656_SYNC_HSYNC%2C%20%2F*%20CNT_POLARITY_TRIGGER_SEL%20*%2F%3CBR%20%2F%3E%200%2C%20%2F*%20COUNT%20UP%20*%2F%3CBR%20%2F%3E-%200%20%2F*%20COUNT%20DOWN%20*%2F%3CBR%20%2F%3E%2B%202*10%20%2F*%20COUNT%20DOWN%20*%2F%3CBR%20%2F%3E%20)%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%2F*%20COUNTER_5%3A%20first%20active%20line%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%2021.0000pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--723901069%22%20id%3D%22toc-hId-196939554%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E2.%20%E3%81%93%E3%82%8C%E3%81%AB%E5%85%88%E7%AB%8B%E3%81%A1%E3%80%81BT656%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6720P%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E5%A4%96%E9%83%A8%E5%90%8C%E6%9C%9F%E3%82%92%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FH3%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E%E8%A7%A3%E5%83%8F%E5%BA%A6%3A%201280*720%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E%E5%87%BA%E5%8A%9B%E3%83%87%E3%83%BC%E3%82%BF%E5%BD%A2%E5%BC%8F%3A%20YUV%208%E3%83%93%E3%83%83%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E%E5%B8%A7%E7%8E%87%EF%BC%9A30fps%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3EPIXCLK%3D74.25MHZ%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3EVS%3D30HZ%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3EHS%3D22.5KHZ%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BT656%E5%A4%96%E5%90%8C%E6%AD%A5%E4%B8%8B%E6%91%84%E5%83%8F%E5%A4%B4%E8%BE%93%E5%87%BA720PUYVY%E6%95%B0%E6%8D%AE%E6%B3%A2%E5%BD%A2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BT656%E5%A4%96%E5%90%8C%E6%AD%A5%E4%B8%8B%E6%91%84%E5%83%8F%E5%A4%B4%E8%BE%93%E5%87%BA720PUYVY%E6%95%B0%E6%8D%AE%E6%B3%A2%E5%BD%A2.png%22%20style%3D%22width%3A%20553px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F31498i3CFA74182D4F6608%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22BT656%E5%A4%96%E5%90%8C%E6%AD%A5%E4%B8%8B%E6%91%84%E5%83%8F%E5%A4%B4%E8%BE%93%E5%87%BA720PUYVY%E6%95%B0%E6%8D%AE%E6%B3%A2%E5%BD%A2.png%22%20alt%3D%22BT656%E5%A4%96%E5%90%8C%E6%AD%A5%E4%B8%8B%E6%91%84%E5%83%8F%E5%A4%B4%E8%BE%93%E5%87%BA720PUYVY%E6%95%B0%E6%8D%AE%E6%B3%A2%E5%BD%A2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E%E4%BB%8A%E3%82%84%E3%82%8A%E3%81%9F%E3%81%84%E3%81%AE%E3%81%AF%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3EBT656%E3%81%AE%E5%A4%96%E9%83%A8%E5%90%8C%E6%9C%9F%E5%87%BA%E5%8A%9B%E3%82%92%E9%80%9A%E3%81%97%E3%81%A6%E3%80%81%E3%81%93%E3%82%8C%E3%81%A8%E4%BC%BC%E3%81%9F%E6%B3%A2%E5%BD%A2%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1763611764%22%20id%3D%22toc-hId--1610514909%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E3.%20%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%882%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E8%A6%81%E4%BB%B6%E3%81%AB%E5%BE%93%E3%81%84%E3%80%81%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF20833%E3%82%9213468%E3%81%AB%E8%AA%BF%E6%95%B4%E3%81%97%E3%80%81PIXCLK%E3%80%81VSYNC%E3%80%81HSYNC%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%882%E3%81%AB%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E5%A4%96%E9%83%A8%E5%90%8C%E6%9C%9F%E9%9D%9E%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AA%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%8F%96%E5%BE%97%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%BE%E3%81%9F%E3%80%81%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E8%A8%88%E7%AE%97%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%93%E3%81%AE%E7%82%B9%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E6%83%85%E5%A0%B1%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FH3%3E%3CP%20style%3D%22text-indent%3A%2021.0000pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E20833%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%2021.0000pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E25%2C%205%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B0%2C%200%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%2021.0000pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E732%2C%201%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--43842699%22%20id%3D%22toc-hId-876997924%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.5000pt%3B%22%3E4.%20%E3%81%94%E6%8F%90%E4%BE%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E3%83%91%E3%83%83%E3%83%81%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E5%86%85%E3%81%AEUYVY%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF8%E3%83%93%E3%83%83%E3%83%88%E3%83%87%E3%83%BC%E3%82%BF%E3%83%90%E3%82%B9%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%A4%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E5%87%BA%E5%8A%9B%E3%81%AF%E5%90%8C%E6%9C%9F%E4%BF%A1%E5%8F%B7%E3%81%A8%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%B8%80%E8%87%B4%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9FUYVY%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AFHSYNC%E3%81%AE%E7%AB%8B%E3%81%A1%E4%B8%8A%E3%81%8C%E3%82%8A%E3%82%A8%E3%83%83%E3%82%B8%E3%81%A7%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E7%AB%8B%E3%81%A1%E4%B8%8B%E3%81%8C%E3%82%8A%E3%82%A8%E3%83%83%E3%82%B8%E3%81%A7%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E5%87%BA%E5%8A%9B%E3%81%AFHSYNC%E3%81%AE%E7%AB%8B%E3%81%A1%E4%B8%8A%E3%81%8C%E3%82%8A%E3%82%A8%E3%83%83%E3%82%B8%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E7%AB%8B%E3%81%A1%E4%B8%8B%E3%81%8C%E3%82%8A%E3%82%A8%E3%83%83%E3%82%B8%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E7%8F%BE%E5%9C%A8%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%AF%E3%80%81SAV%2FEAV%E3%81%8A%E3%82%88%E3%81%B3%E3%83%96%E3%83%A9%E3%83%B3%E3%82%AD%E3%83%B3%E3%82%B0%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AF%E3%81%AA%E3%81%84%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%82%88%E3%81%AD%EF%BC%9F%E5%B0%91%E3%81%97%E5%88%9D%E6%AD%A9%E7%9A%84%E3%81%AA%E8%B3%AA%E5%95%8F%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%94%E5%AE%B9%E8%B5%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FH3%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125850%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125850%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%82%8B%20HSYNC%20%E3%81%A8%20VSYNC%20%E3%81%AF%E3%80%81%E3%81%A9%E3%81%A1%E3%82%89%E3%82%82%E6%9C%80%E5%A4%A7%E5%80%A4%E3%81%8C%20255%20%E3%81%AE%E3%83%91%E3%83%AB%E3%82%B9%E4%BF%A1%E5%8F%B7%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%AC%E3%83%99%E3%83%AB%E4%BF%A1%E5%8F%B7%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%88%E3%82%8A%E8%A4%87%E9%9B%91%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82IPU%E3%81%AEDI%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%82%92%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%AC%E3%83%99%E3%83%AB%E4%BF%A1%E5%8F%B7%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82DI_PIN04%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6DE%E4%BF%A1%E5%8F%B7%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%99%E3%82%8BDI%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E4%BE%8B%E3%82%92%E4%BB%A5%E4%B8%8B%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82https%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F392943%22%20target%3D%22_blank%22%3E%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F392943%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125849%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125849%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E6%97%A9%E9%80%9F%E3%81%AE%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3CBR%20%2F%3E%20%E3%81%93%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81HSYNC%E3%81%A8VSYNC%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E4%BF%A1%E5%8F%B7%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82HSYNC%E3%81%AE%E6%9C%89%E5%8A%B9%E4%BF%A1%E5%8F%B7%E3%81%AF80%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%80%81VSYNC%E3%81%AE%E6%9C%89%E5%8A%B9%E4%BF%A1%E5%8F%B7%E3%81%AF10HSYNC%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%AB%E7%9B%B8%E5%BD%93%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%E3%81%97%E3%81%8B%E3%81%97%E5%A5%87%E5%A6%99%E3%81%AA%E3%81%AE%E3%81%AF%3CBR%20%2F%3E%202*80%20%2F*%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%83%80%E3%82%A6%E3%83%B3%20*%2F%20%E5%90%8C%E6%A7%98%E3%81%AB%202*10%20%2F*%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%83%80%E3%82%A6%E3%83%B3%20*%2F%3CBR%20%2F%3E%20%E3%81%93%E3%82%8C%E3%82%892%E3%81%A4%E3%81%AE%E5%80%A4%E3%81%AB%E3%81%AF%E5%88%B6%E7%B4%84%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%812*80%E3%82%922*720%E3%81%AB%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF2*10%E3%82%922*480%E3%81%AB%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81VYSNC%E3%81%A8HSYNC%E3%81%AB%E4%BF%A1%E5%8F%B7%E3%81%8C%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82480P%E3%81%AEUYVY%E7%94%BB%E5%83%8F%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%812*80%E3%82%922*720*2%E3%81%AB%E3%80%812*10%E3%82%922*(480%2B%E3%83%96%E3%83%A9%E3%83%B3%E3%82%AD%E3%83%B3%E3%82%B0%E3%83%A9%E3%82%A4%E3%83%B3%E6%95%B0)%E3%81%AB%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%20%E3%81%BE%E3%81%9F%E3%80%81%E4%BB%A5%E5%89%8D%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%83%91%E3%83%83%E3%83%81%E3%81%AFL3.0.x%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E7%94%A8%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AFL3.14.52%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81arch%2Farm%2Fmach-mx6%2Fclock.c%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82b%2Farch%2Farm%2Fmach-mx6%2Fclock.c%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%3CBR%20%2F%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3L3.14.52%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%EF%BC%9F%E3%81%BE%E3%81%9F%E3%81%AE%E3%81%94%E5%8D%94%E5%8A%9B%E3%82%92%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125847%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125847%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8CHi%20Qiang%3CBR%20%2F%3E%20%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%B7%A5%E4%BD%9C%EF%BC%8C%E6%88%91%E4%BB%AC%E6%8C%89%E7%85%A7%E8%BF%99%E4%B8%AA%E6%96%87%E7%AB%A0%E6%89%93%E4%BA%86L3.14.52_1.1.0_GA_bt656_output_patch_2016-06-27%E8%BF%99%E4%B8%AA%E8%A1%A5%E4%B8%81%EF%BC%8CBT656%E4%BA%A4%E9%94%99%E6%A8%A1%E5%BC%8F%E4%B8%8B%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%E3%80%82%3CBR%20%2F%3E%20%E7%9B%AE%E5%89%8D%E6%88%91%E4%BB%AC%E6%9C%89%E6%96%B0%E7%9A%84%E9%9C%80%E6%B1%82%EF%BC%8C%E6%83%B3%E9%80%9A%E8%BF%878%E4%BD%8D%E6%95%B0%E6%8D%AE%E7%BA%BF%2BCLK%2BVSYNC%2BHSYNC%E8%BE%93%E5%87%BA720P%E7%9A%84UYVY%E6%95%B0%E6%8D%AE%EF%BC%8C%E6%8B%9F%E4%BD%BF%E7%94%A8%E5%BC%95%E8%84%9A%E5%A6%82%E4%B8%8B%EF%BC%9A%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20pinctrl_ipu1_bt656%3A%20ipu1grp-3%20%7B%3CBR%20%2F%3E%20fsl%2Cpins%20%3D%20%26lt%3B%3CBR%20%2F%3E%20MX6QDL_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK%200x10%3CBR%20%2F%3E%20MX6QDL_PAD_DI0_PIN15__IPU1_DI0_PIN15%200x10%3CBR%20%2F%3E%20MX6QDL_PAD_DI0_PIN2__IPU1_DI0_PIN02%200x10%3CBR%20%2F%3E%20MX6QDL_PAD_DI0_PIN3__IPU1_DI0_PIN03%200x10%3CBR%20%2F%3E%20MX6QDL_PAD_DI0_PIN4__IPU1_DI0_PIN04%200x80000000%3CBR%20%2F%3E%20MX6QDL_PAD_DISP0_DAT16__IPU1_DISP0_DATA16%200x10%3CBR%20%2F%3E%20MX6QDL_PAD_DISP0_DAT17__IPU1_DISP0_DATA17%200x10%3CBR%20%2F%3E%20MX6QDL_PAD_DISP0_DAT18__IPU1_DISP0_DATA18%200x10%3CBR%20%2F%3E%20MX6QDL_PAD_DISP0_DAT19__IPU1_DISP0_DATA19%200x10%3CBR%20%2F%3E%20MX6QDL_PAD_DISP0_DAT20__IPU1_DISP0_DATA20%200x10%3CBR%20%2F%3E%20MX6QDL_PAD_DISP0_DAT21__IPU1_DISP0_DATA21%200x10%3CBR%20%2F%3E%20MX6QDL_PAD_DISP0_DAT22__IPU1_DISP0_DATA22%200x10%3CBR%20%2F%3E%20MX6QDL_PAD_DISP0_DAT23__IPU1_DISP0_DATA23%200x10%3CBR%20%2F%3E%20%26gt%3B%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%E6%88%91%E4%BB%AC%E7%9A%84%E7%96%91%E9%97%AE%E6%98%AF%EF%BC%8C%E5%9C%A8%E6%9C%AC%E6%96%87%E8%A1%A5%E4%B8%81%E4%B8%8B%EF%BC%8C%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E6%94%AF%E6%8C%81%E8%BF%99%E4%B9%88%E6%93%8D%E4%BD%9C%EF%BC%8C%E6%88%91%E4%BB%AC%E8%AF%A5%E5%A6%82%E4%BD%95%E9%85%8D%E7%BD%AE%E7%9B%B8%E5%85%B3%E8%B5%84%E6%BA%90%EF%BC%9F%E5%8F%AF%E4%BB%A5%E7%BB%99%E5%87%BA%E4%B8%80%E4%BA%9B%E6%8C%87%E5%AF%BC%E6%84%8F%E8%A7%81%EF%BC%8C%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125841%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125841%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDear%20%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F179116%22%3E%40qiang%3C%2Fa%3E%20Li%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81xserver%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F*%20NTSC%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E5%87%BA%E5%8A%9B%20*%2F%3CBR%20%2F%3E%2B%E3%80%8CBT656-NTSC%E3%80%8D%E3%80%8160%E3%80%81720%E3%80%81480%E3%80%8137037%E3%80%81%3CBR%20%2F%3E%2B%2019%2C%203%2C%3CBR%20%2F%3E%2B%2020%2C%203%2C%3CBR%20%2F%3E%2B%20276%2C%201%2C%3CBR%20%2F%3E%2B%20FB_SYNC_HOR_HIGH_ACT%20%7CFB_SYNC_VERT_HIGH_ACT%E3%80%81%3CBR%20%2F%3E%2B%20FB_VMODE_INTERLACED%E3%80%81%3CBR%20%2F%3E%2B%20FB_MODE_IS_DETAILED%2C%7D%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A3%E3%81%97%E3%81%84%20Xserver%20%E3%83%A2%E3%83%BC%E3%83%89%E8%A8%AD%E5%AE%9A%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E9%AB%98%E9%80%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%BC%E5%87%BA%E5%8A%9B%E3%82%92%20fb0%20%E3%81%AB%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99!!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AFQiang%E3%80%81%E4%BB%8A%E7%A7%81%E3%81%AF%E3%83%86%E3%83%AC%E3%83%93%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A7%E6%AC%A1%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E5%89%8D%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7xorg%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E8%BF%B0%E3%81%B9%E3%81%BE%E3%81%97%E3%81%9F%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F17330i3765D58DC68495FE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.jpg%22%20alt%3D%22pastedImage_3.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ELCD%E3%81%AE%E4%B8%8A%E5%81%B4%E3%81%AB%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%B0%B4%E5%B9%B3%E7%B7%9A%E3%81%AFimxeglvivsink%E3%81%8B%E3%82%89%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%20imxeglvivsink%20%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%80%81X11%20%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%AA%E3%81%9C%E3%83%93%E3%83%87%E3%82%AA%E3%81%8C%E7%A0%B4%E6%90%8D%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E4%BB%A5%E5%A4%96%E3%81%AB%E3%80%81%E4%BD%95%E3%81%8B%E3%82%92%E8%A6%8B%E8%90%BD%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82imxg2dsink%E3%81%A8%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3Eimxipuvideosink%3C%2FSPAN%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%86%E3%82%B9%E3%83%88%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E6%AD%AA%E3%81%BF%E3%81%AA%E3%81%8F%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%80%81xorg.conf%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125816%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125816%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDear%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81imx6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AEPAL-NTSC%E3%83%A2%E3%83%BC%E3%83%89%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%80%81BT656-NTSC%E3%82%92%E6%9C%80%E5%88%9D%E3%81%ABuboot%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8(adv%E3%81%AFNTSC%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99)%E3%80%81uboot%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%9B%E3%81%9A%E3%81%AB%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92BT656-PAL%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6i2c%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E7%95%B0%E3%81%AA%E3%82%8BADV7391%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%AD%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%82%A2%E3%83%8C%E3%83%A9%E3%83%BC%E3%83%80%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125814%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125814%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EiMX6S%2FDL%E3%81%AF%E3%83%80%E3%83%96%E3%83%ABadv739x%E5%90%8C%E6%99%82%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B4%E3%83%BC%E3%83%89%E3%83%B3%E3%83%BB%E3%83%AA%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125813%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125813%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E6%84%9A%E3%81%8B%E3%81%AA%E8%B3%AA%E5%95%8F%E3%81%A0%E3%81%A3%E3%81%9F%E3%82%89%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%813.14.52%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AEadv739x%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125810%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125810%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AFD-Chip%E3%81%A8%E3%81%AE%E5%85%B1%E5%90%8C%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%ABv4.%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%2037.4.6.2.1%20%E3%81%A7%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%81%93%E3%82%8C%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%81%BE%E3%81%A0%E3%81%93%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E4%BD%95%E3%81%8B%E6%8F%90%E6%A1%88%E3%82%84%E5%A4%89%E6%9B%B4%E8%AA%AC%E6%98%8E%E6%9B%B8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%A7%81%E3%81%AE%E9%80%A3%E7%B5%A1%E5%85%88%E3%81%AF%E3%80%81%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Aabelcao2012us%40gmail.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eabelcao2012us%40gmail.com%3C%2FA%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAbel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125809%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125809%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%20qiang%2C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E3%80%8C_ipu_dc_setup_bt656_interlaced%EF%BC%9F%E3%80%8D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AAIPU%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81%E7%A7%81%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%AF%E9%9B%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3EBT656%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%3C%2FSPAN%3E%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E8%A8%88%E7%94%BB%E3%82%92%E6%94%AF%E6%8F%B4%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125807%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125807%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%2Cqiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eimx6%E3%81%A7BT656%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%3C%2FSPAN%3E%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%E3%80%8C%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%E3%81%9D%E3%81%AE%E3%83%91%E3%83%8D%E3%83%AB%E3%81%ABVSYNC%20%2F%20HSYNC%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FSPAN%3E%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E6%89%8B%E6%AE%B5%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%22%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AELCD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125805%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125805%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%20qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EYUV%20LCD(%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AFYUV)TFTMD030011%E3%80%818%E3%83%93%E3%83%83%E3%83%88BT656NTSC%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%20%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%2027MHZ%20%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81LCD%20%E3%81%AF%2054MHZ%20%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22QQ%E5%9B%BE%E7%89%8720160325164915.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22QQ%E5%9B%BE%E7%89%8720160325164915.png%22%20style%3D%22width%3A%20540px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F25999iD2B2F7781B18BCDA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22QQ%E5%9B%BE%E7%89%8720160325164915.png%22%20alt%3D%22QQ%E5%9B%BE%E7%89%8720160325164915.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F443002%23comment-443002%22%20title%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fmessage%2F443002%23comment-443002%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fmessage%2F443002%23comment-443002%3C%2FA%3E%20%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%26nbsp%3B%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E8%A8%80%E3%81%A3%E3%81%9F%3A%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E8%E3%83%93%E3%83%83%E3%83%88BT656%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%80%81NTSC%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AF27MHz%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E5%90%84%E8%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E6%95%B0%E3%81%A7%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3A%E5%90%88%E8%A8%881716%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3D%20EAV%E3%82%B3%E3%83%BC%E3%83%89(4)%2B%E3%83%96%E3%83%A9%E3%83%B3%E3%82%AD%E3%83%B3%E3%82%B0%E3%83%93%E3%83%87%E3%82%AA(67%20*%204)%2B%20SAV%E3%82%B3%E3%83%BC%E3%83%89(4)%2B%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%83%93%E3%83%87%E3%82%AA(720%20*%202)%3D%20276%20%2B%201440%E3%80%81NTSC%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%E5%90%84%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%AB%E5%90%88%E8%A8%88525%E8%A1%8C(19%20%2B%20240%20%2B%203%20%2B%2020%20%2B%20240%20%2B%203)%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AF30Hz%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%3D%20525%20*%201716%20*%2030%20%3D%2027.027MHz%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E3%81%93%E3%81%93%E3%81%A7%E3%80%81%E3%83%AA%E3%83%95%E3%83%AC%E3%83%83%E3%82%B7%E3%83%A5%E3%82%9260HZ%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AF%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E525%20*%201716%20*%2060%20%3D%2054.054MHz%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3EBSP%20BT656%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125803%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125803%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Li%20Qiang%3A%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81CVBS%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E8%A1%A8%E7%A4%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E7%94%BB%E9%9D%A2%E5%8F%B3%E5%81%B4%E3%81%AE%E8%89%B2%E3%81%8C%E7%99%BD%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E7%94%BB%E9%9D%A2%E3%81%8C%E7%82%B9%E6%BB%85%E3%81%97%E3%81%BE%E3%81%99(%E7%94%BB%E9%9D%A2%E3%81%AE%E4%B8%8A%E9%83%A8%E3%81%A7%E7%82%B9%E6%BB%85%E3%81%97%E3%81%BE%E3%81%99)%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E3%82%B1%E3%83%BC%E3%82%B9%3AGST-LAUNCH-1.0videotestsrc%20horizontal-speed%3D-3%20%E3%81%A7%E3%81%99!imxv4l2%E3%82%B7%E3%83%B3%E3%82%AF%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E7%94%BB%E9%9D%A2%E5%8F%B3%E5%81%B4%E3%81%AB%E7%99%BD%E8%89%B2%E3%81%AE%E5%A0%B4%E5%90%88%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C(gplay%E3%81%A8gst-play%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%93%E3%83%87%E3%82%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%86%8D%E7%94%9F)%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%AC%9D%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDear%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EKeita%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125801%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125801%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%20drivers%2Fmxc%2Fipu3%2Fipu_disp.c%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Y%20%3D%20R%20*%26nbsp%3B%201.200%20%2B%20G%20*%26nbsp%3B%202.343%20%2B%20B%20*%26nbsp%3B%20.453%20%2B%200.250%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20U%20%3D%20R%20*%20-.672%20%2B%20G%20*%20-1.328%20%2B%20B%20*%26nbsp%3B%202.000%20%2B%20512.250.%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20V%20%3D%20R%20*%26nbsp%3B%202.000%20%2B%20G%20*%20-1.672%20%2B%20B%20*%20-.328%20%2B%20512.250.%3B*%2F%3C%2FP%3E%3CP%3E%E9%9D%99%E7%9A%84%20const%20int%20rgb2ycbcr_coeff%5B5%5D%5B3%5D%20%3D%20%7B%3C%2FP%3E%3CP%3E%20%7B0x4D%E3%80%810x96%E3%80%810x1D%7D%E3%80%81%3C%2FP%3E%3CP%3E%20%7B-0x2B%2C%20-0x55%2C%200x80%7D%2C%3C%2FP%3E%3CP%3E%20%7B0x80%2C%20-0x6B%2C%20-0x15%7D%2C%3C%2FP%3E%3CP%3E%20%7B0x0000%2C%200x0200%2C%200x0200%7D%2C%20%2F*%20B0%2C%20B1%2C%20B2%20*%2F%3C%2FP%3E%3CP%3E%20%7B0x2%2C%200x2%2C%200x2%7D%2C%20%2F*%20S0%2C%20S1%2C%20S2%20*%2F%3C%2FP%3E%3CP%3E%7D%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125800%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125800%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDear%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E3%81%AFjb4.2.2_1.1.0%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81CSC%E6%A9%9F%E8%83%BD%E3%81%A7%E8%89%B2%E7%A9%BA%E9%96%93%E3%82%92RGB%E3%81%8B%E3%82%89BT.656%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EIMX6DQRM%20(Rev.2)%E3%81%AE%E3%80%8C37.4.9.5%20%E8%89%B2%E7%A9%BA%E9%96%93%E5%A4%89%E6%8F%9B%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%20-%20CSC%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E8%89%B2%E7%A9%BA%E9%96%93%E3%81%AE%E5%A4%89%E6%8F%9B%E4%BF%82%E6%95%B0%E5%80%A4(CSC_A0~A8%E3%80%81CSC_B0~B2%E3%80%81CSC_S0~2)%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E(%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%81%A7%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E3%83%80%E3%83%B3%E3%83%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EKeita%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125795%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125795%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%3C%2FP%3E%3CP%3Eimx6sx%20%E3%81%A8%20L3.10.53_1.1.0-ga%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%83%A8%E3%82%AF%E3%83%88%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBT656%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emxc_ipuv3_fb.c%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%82%92mxcfb_set_par%E9%96%A2%E6%95%B0%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82(%20static%20int%20mxcfb_set_par(struct%20fb_info%20*fbi)%20)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20if%20((mxc_fbi-%26gt%3Bipu_di_pix_fmt%20%3D%3D%20IPU_PIX_FMT_BT656)%20%7C%7C%20(mxc_fbi-%26gt%3Bipu_di_pix_fmt%20%3D%3D%20IPU_PIX_FMT_BT1120))%20%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20if%20(mxc_fbi-%26gt%3Bdispdrv%20%26amp%3B%26amp%3B%20mxc_fbi-%26gt%3Bdispdrv-%26gt%3Bdrv-%26gt%3Bdisable)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20mxc_fbi-%26gt%3Bdispdrv-%26gt%3Bdrv-%26gt%3Bdisable(mxc_fbi-%26gt%3Bdispdrv)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%AE%E7%B5%90%E6%9E%9C%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Edrivers%2Fvideo%2Fmxc%2Fmxc_ipuv3_fb.c%3A510%3A4%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%96%A2%E6%95%B0%20'mxc_fbi-%26gt%3Bdispdrv-%26gt%3Bdrv-%26gt%3Bdisable'%E3%81%AE%E5%BC%95%E6%95%B0%E3%81%8C%E5%B0%91%E3%81%AA%E3%81%99%E3%81%8E%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20mxc_fbi-%26gt%3Bdispdrv-%26gt%3Bdrv-%26gt%3Bdisable(mxc_fbi-%26gt%3Bdispdrv)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5E%3C%2FP%3E%3CP%3Emake%5B3%5D%3A%20***%20%5B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%2F%E3%83%93%E3%83%87%E3%82%AA%2FMXC%2Fmxc_ipuv3_fb.o%5D%E3%82%A8%E3%83%A9%E3%83%BC%201%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%93%E3%81%A7%E3%80%81mxc_dsipdrv.h%E3%81%A7%E3%80%8Cdisable%20func%E3%80%8D%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2033%E6%A7%8B%E9%80%A0%E4%BD%93mxc_dispdrv_driver%7B%3C%2FP%3E%3CP%3E%2034%20const%20char%20*%E5%90%8D%E5%89%8D%3B%3C%2FP%3E%3CP%3E%2035%20int%20(*init)%20(%E6%A7%8B%E9%80%A0%E4%BD%93%20mxc_dispdrv_handle%20*%2C%20%E6%A7%8B%E9%80%A0%E4%BD%93%20mxc_dispdrv_setting%20*)%3B%3C%2FP%3E%3CP%3E%2036%20void%20(*deinit)%20(%E6%A7%8B%E9%80%A0%E4%BD%93%20mxc_dispdrv_handle%20*)%3B%3C%2FP%3E%3CP%3E%2037%20%2F*%E6%8B%A1%E5%BC%B5%E6%A9%9F%E8%83%BD%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E6%9C%89%E5%8A%B9%E5%8C%96%E6%A9%9F%E8%83%BD*%2F%3C%2FP%3E%3CP%3E%2038%20int%20(*%E6%9C%89%E5%8A%B9)%20(struct%20mxc_dispdrv_handle%20*%2C%20struct%20fb_info%20*)%3B%3C%2FP%3E%3CP%3E%2039%20%2F*%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E7%84%A1%E5%8A%B9%E5%8C%96%E6%A9%9F%E8%83%BD%E3%80%81fb_blank%E3%81%AE%E6%97%A9%E3%81%84%E6%AE%B5%E9%9A%8E%E3%81%A7%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%20*%2F%3C%2FP%3E%3CP%3E%2040%20void%20(*disable)%20(struct%20mxc_dispdrv_handle%20*%2C%20struct%20fb_info%20*)%3B%3C%2FP%3E%3CP%3E%2041%20%2F*%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E8%A8%AD%E5%AE%9A%E6%A9%9F%E8%83%BD%E3%80%81fb_set_par%E3%81%AE%E6%97%A9%E3%81%84%E6%AE%B5%E9%9A%8E%E3%81%A7%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%20*%2F%3C%2FP%3E%3CP%3E%2042%20int%20(*setup)%20(struct%20mxc_dispdrv_handle%20*%2C%20struct%20fb_info%20*fbi)%3B%3C%2FP%3E%3CP%3E%2043%20%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Edisable%E3%81%AE%E9%96%A2%E6%95%B0pionter%E3%81%AF2%E3%81%A4%E3%81%AE%E5%BC%95%E6%95%B0%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E3%81%AF%E3%80%81%E5%BC%95%E6%95%B0%E3%81%8C1%E3%81%A4%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A6%E3%83%A0%E3%80%82%E3%80%82%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%A7%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20if%20((mxc_fbi-%26gt%3Bipu_di_pix_fmt%20%3D%3D%20IPU_PIX_FMT_BT656)%20%7C%7C%20(mxc_fbi-%26gt%3Bipu_di_pix_fmt%20%3D%3D%20IPU_PIX_FMT_BT1120))%20%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20if%20(mxc_fbi-%26gt%3Bdispdrv%20%26amp%3B%26amp%3B%20mxc_fbi-%26gt%3Bdispdrv-%26gt%3Bdrv-%26gt%3Bdisable)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20mxc_fbi-%26gt%3Bdispdrv-%26gt%3Bdrv-%26gt%3Bdisable(mxc_fbi-%26gt%3Bdispdrv%2C%20fbi%20)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%8A%E8%AA%AD%E3%81%BF%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%E3%83%81%E3%83%A3%E3%83%B3%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81LVDS%20%E5%87%BA%E5%8A%9B%E7%94%A8%E3%81%AB%E4%BB%96%E3%81%AE%20IPU%20%E3%82%92%E7%8F%BE%E5%9C%A8%E3%81%AE%20IPU%20%E3%81%8B%E3%82%89%E5%A4%89%E6%9B%B4%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%BC%E3%82%89%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20%22ret%20%3D%20mxcfb_setup_overlay(pdev%2C%20fbi%2C%20res)%3B%22%20%E3%81%8C%20%22ipu_id%20%3D%201%22%20%E3%81%AB%E5%A4%89%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E4%BD%9C%E6%88%90%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81LVDS%E5%87%BA%E5%8A%9B%E3%81%AF%E5%88%A5%E3%81%AEIPU%E3%81%A8%E5%87%BA%E5%8A%9B%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EKeita%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%9A%86%E6%A7%98%E3%81%AE%E5%A4%9A%E5%A4%A7%E3%81%AA%E3%82%8B%E3%81%94%E6%94%AF%E6%8F%B4%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%80%8Cr13.4.1_bt656_output_patch_2013-09-04.zip%E3%80%8D%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E7%A7%81%E3%81%AE%E7%90%86%E8%A7%A3%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E9%A1%A7%E5%AE%A2%E3%81%AF%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%80%81i.MX6DQ%E3%81%A7%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%BC%E3%81%AF%E3%80%81%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E5%A4%89%E6%9B%B4%E3%81%AE%E5%BD%B1%E9%9F%BF%E3%82%92%E5%8F%97%E3%81%91%E3%81%A6%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E7%B5%90%E6%9E%9C%E3%80%82%E5%83%8D%E3%81%8F%E3%81%93%E3%81%A8%E3%81%AF%E4%B8%8D%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBT.656%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4%E7%94%A8%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E(%E5%BD%BC%E3%82%89%E3%81%AF%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%A7%E3%81%99%E3%81%8B%E3%82%89%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A0%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%5B%E3%80%8Cr13.4.1_bt656_output_patch_2013-09-04.zip%E3%80%8D%E3%81%AEme.txt%E3%82%92%E8%AA%AD%E3%82%93%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%5D%3C%2FP%3E%3CP%3E%26gt%3B%204)%20iMX6S%2FDL%20Android%E3%81%A7%E3%81%AF%E3%80%81IPU%E3%81%AF1%E3%81%A4%E3%81%97%E3%81%8B%E3%81%AA%E3%81%8F%E3%80%81%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81BT656%E5%87%BA%E5%8A%9B%E3%81%AF2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%26gt%3B0003-Enhance-dual-display-support-for-BT656-output.patch%E3%81%AF%E3%80%81IPU%20DC%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%26gt%3B%E3%81%A8BT656%E3%81%AFIPU%20DP%E3%82%92fb2%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4%E3%81%AFfb1%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EKeita%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125791%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125791%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%20qiang%2C%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81CVBS%20%2B%20LVDS%20%2B%20HDMI%E3%82%92%E5%90%8C%E6%99%82%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Esetenv%20bootargs_mmc%20'setenv%20bootargs%20%24%7Bbootargs%7D%20root%3D%2Fdev%2Fmmcblk0p1%20rootwait%20rw%20video%3Dmxcfb1%3Adev%3Dldb%2CLDB-SVGA%2Cif%3DRGB24%20ldb%3Dsin0%20video%3Dmxcfb2%3Adev%3Dhdmi%2C1920x1080M%4060%2Cif%3DRGB24%20video%3Dmxcfb0%3Adev%3Dadv739x%2CBT656-PAL%2Cif%3DBT656%2Cfbpix%3DRGB565'%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECVBS%20%E3%81%8C%20fb0%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECVBS%20%E3%82%92%20fb2%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Esetenv%20bootargs_mmc%20'setenv%20bootargs%20%24%7Bbootargs%7D%20root%3D%2Fdev%2Fmmcblk0p1%20rootwait%20rw%20video%3Dmxcfb0%3Adev%3Dldb%2CLDB-SVGA%2Cif%3DRGB24%20ldb%3Dsin0%20video%3Dmxcfb1%3Adev%3Dhdmi%2C1920x1080M%4060%2Cif%3DRGB24%20video%3Dmxcfb2%3Adev%3Dadv739x%2CBT656-PAL%2Cif%3DBT656%2Cfbpix%3DRGB565'%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E3%83%AD%E3%82%B0%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E..................................%3C%2FP%3E%3CP%3E.................................%3C%2FP%3E%3CP%3E%20JFFS2%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.2.(NAND)%202001-2006%20%E3%83%AC%E3%83%83%E3%83%89%E3%83%8F%E3%83%83%E3%83%88%E6%A0%AA%E5%BC%8F%E4%BC%9A%E7%A4%BE%3CBR%20%2F%3Emsgmni%20%E3%81%8C%202822%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%3CBR%20%2F%3Ealg%3A%20stdrng%20(krng)%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%AA%E3%81%97%3CBR%20%2F%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9NOOP%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%E3%81%AE%E7%B7%A0%E5%88%87%E6%97%A5%E7%99%BB%E9%8C%B2%3CBR%20%2F%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9CFQ%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF(%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88)%3CBR%20%2F%3Emxc_sdc_fb%20mxc_sdc_fb.0%3AMXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCLDB%E3%81%AE%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E_regulator_get%3A%20%E8%AD%98%E5%88%A5%E5%AD%90%E3%81%AA%E3%81%97%E3%81%AE%20get()%3CBR%20%2F%3Emxc_ldb%20mxc_ldb%3ALDB%20channel0%E3%81%AEIPU%20DI1%E3%82%92IPU%20DI0%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EIMX-IPUV3%20IMX-IPUV3.1%3AIPU%20DMFC%20DP%20%E9%AB%98%E5%88%86%E8%A7%A3%E8%83%BD%3A%201(0%2C1)%2C%205B(2~5)%2C%205F(6%2C7)%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9128x48%E3%81%B8%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3CBR%20%2F%3Emxc_sdc_fb%20mxc_sdc_fb.1%3AMXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCHDMI%E3%81%AE%E7%99%BB%E9%8C%B2%3CBR%20%2F%3Emxc_hdmi%20mxc_hdmi%3A%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%9FHDMI%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%200x13%3A0xa%3A0xa0%3A0xc1%3CBR%20%2F%3Efbcvt%3A%201920x1080%4060%3A%20CVT%20%E5%90%8D%20-%202.073M9%3CBR%20%2F%3Emxc_sdc_fb%20mxc_sdc_fb.2%3AMXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCADV739x%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%20%3CSTRONG%3E%E3%81%BE%E3%81%99(%E3%81%93%E3%81%93%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%80%81%E7%B6%9A%E8%A1%8C%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84)%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E4%BD%95%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E4%BD%95%E3%81%8B%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125788%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125788%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%94%E3%81%A8%E3%81%AB%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%20%3C%2FP%3E%3CP%3E(%E4%BF%AE%E6%AD%A3%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%AB%E3%80%81%E3%81%A9%E3%81%86%E3%82%84%E3%81%A3%E3%81%A6%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBSP%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%B7%AE%E3%81%97%E6%9B%BF%E3%81%88%E3%81%A6%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EKeita%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125787%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125787%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FQiang_FSL%22%20target%3D%22_blank%22%3EQiang_FSL%3C%2FA%3E%E2%80%8B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ebt656%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92fb4%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%83%A6%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%AF%E3%80%813%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%81%99%E3%80%822%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AF%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81HMI%20%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84%E3%81%AB%E3%81%AF%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ebt656%20%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AF%E3%83%93%E3%83%87%E3%82%AA%E5%86%8D%E7%94%9F%E3%82%92%E7%9B%AE%E7%9A%84%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A41%20---%26gt%3B%20%26gt%3B%20fb0(%E8%83%8C%E6%99%AF)%20fb1(%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4)%3C%2FP%3E%3CP%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A42%20---%26gt%3B%20%26gt%3B%20fb2(%E8%83%8C%E6%99%AF)%20fb3(%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4)%3C%2FP%3E%3CP%3EDisplay%203%20--%26gt%3B%26nbsp%3B%20fb4%20(bt656)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%EF%BC%8Cqiang%2C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E8%BF%85%E9%80%9F%E3%81%AA%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E3%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%8C%E9%96%89%E3%81%98%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125784%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125784%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E7%A7%81%E3%81%AFarch%2Farm%2Fmach-mx6%2Fclock.c%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E7%A7%81%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%3A%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3Eint%20__init%20mx6_clocks_init(%E7%AC%A6%E5%8F%B7%E3%81%AA%E3%81%97%E3%83%AD%E3%83%B3%E3%82%B0%20CKYL%2C%20%E7%AC%A6%E5%8F%B7%E3%81%AA%E3%81%97%E3%83%AD%E3%83%B3%E3%82%B0%20OSC%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%20style%3D%22border%3A%200px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3CTBODY%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CTR%20style%3D%22border%3A%200px%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CTD%20style%3D%22padding%3A%202px%204px%3B%20border%3A%200px%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%204px%3B%20border%3A%200px%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3Eclk_set_parent(%26amp%3Bipu1_di_clk%5B0%5D%2C%20%26amp%3Bpll3_pfd_540M)%3B%20%2F*%20CVBS%2027MHz%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E5%A0%B4%E5%90%88%20*%2F%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border%3A%200px%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CTD%20style%3D%22padding%3A%202px%204px%3B%20border%3A%200px%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%204px%3B%20border%3A%200px%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3Eclk_set_parent(%26amp%3Bipu1_di_clk%5B1%5D%2C%20%26amp%3Bpll5_video_main_clk)%3B%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border%3A%200px%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CTD%20style%3D%22padding%3A%202px%204px%3B%20border%3A%200px%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%204px%3B%20border%3A%200px%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3Eclk_set_parent(%26amp%3Bipu2_di_clk%5B0%5D%2C%20%26amp%3Bpll5_video_main_clk)%3B%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border%3A%200px%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CTD%20style%3D%22padding%3A%202px%204px%3B%20border%3A%200px%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%204px%3B%20border%3A%200px%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3Eclk_set_parent(%26amp%3Bipu2_di_clk%5B1%5D%2C%20%26amp%3Bpll5_video_main_clk)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3Eclk_set_parent(%26amp%3Bldb_di0_clk%2C%26amp%3Bpll2_pfd_352M)%3B%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3Eclk_set_parent(%26amp%3Bldb_di1_clk%2C%26amp%3Bpll2_pfd_352M)%3B%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%22%3EBT656%20on%20IPU1%20DI0%2C%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%22%3EHDMI%20on%20IPU2%20DI0%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%22%3ELVDS%20on%20IPU2%20DI1%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%22%3E%E4%B8%8A%E8%A8%98%E3%81%AF%E5%A4%A7%E4%B8%88%E5%A4%AB%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%22%3E%E7%A7%81%E3%81%AF%E3%81%BE%E3%81%9F%E4%BB%96%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%22%3E%E7%A7%81%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%22%3E%3CSTRONG%20style%3D%22font-style%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-size%3A%209pt%3B%20font-family%3A%20CourierStd%3B%22%3Esetenv%20bootargs_mmc%20'setenv%20bootargs%20%24%7Bbootargs%7D%20root%3D%2Fdev%2Fmmcblk0p1%20rootwait%20rw%20video%3Dmxcfb0%3Adev%3Dadv739x%2CBT656-PAL%2Cif%3DBT656%2Cfbpix%3DRGB565%20video%3Dmxcfb1%3Adev%3Dhdmi%2C1920x1080M%4060%2Cif%3DRGB24%20video%3Dmxcfb2%3Adev%3Dldb%2CLDB-SVGA%2Cif%3DRGB24%20ldb%3Dsin0'%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3EHDMI%E3%81%AB%E7%B7%91%E8%89%B2%E3%81%AE%E8%89%B2%E3%82%92%E6%8F%8F%E7%94%BB%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C.%2Ffb_green%20%2Fdev%2Ffb2%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%80%8C.%2F%E3%80%8D%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84fb_green%2Fdev%2Ffb1%22%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125783%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125783%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AFarch%2Farm%2Fmach-mx6%2Fclock.c%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%3A%3C%2FP%3E%3CP%3Eint%20__init%20mx6_clocks_init(%E7%AC%A6%E5%8F%B7%E3%81%AA%E3%81%97%E3%83%AD%E3%83%B3%E3%82%B0%20CKYL%2C%20%E7%AC%A6%E5%8F%B7%E3%81%AA%E3%81%97%E3%83%AD%E3%83%B3%E3%82%B0%20OSC%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%3C%2FTD%3E%3CTD%3Eclk_set_parent(%26amp%3Bipu1_di_clk%5B0%5D%2C%20%26amp%3Bpll3_pfd_540M)%3B%20%2F*%20CVBS%2027MHz%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E5%A0%B4%E5%90%88%20*%2F%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%20%3C%2FTD%3E%3CTD%3Eclk_set_parent(%26amp%3Bipu1_di_clk%5B1%5D%2C%20%26amp%3Bpll5_video_main_clk)%3B%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%20%3C%2FTD%3E%3CTD%3Eclk_set_parent(%26amp%3Bipu2_di_clk%5B0%5D%2C%20%26amp%3Bpll5_video_main_clk)%3B%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%20%3C%2FTD%3E%3CTD%3E%3CP%3Eclk_set_parent(%26amp%3Bipu2_di_clk%5B1%5D%2C%20%26amp%3Bpll5_video_main_clk)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eclk_set_parent(%26amp%3Bldb_di0_clk%2C%26amp%3Bpll2_pfd_352M)%3B%3C%2FP%3E%3CP%3Eclk_set_parent(%26amp%3Bldb_di1_clk%2C%26amp%3Bpll2_pfd_352M)%3B%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3EBT656%20on%20IPU1%20DI0%2C%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3EHDMI%20on%20IPU2%20DI0%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3ELVDS%20on%20IPU2%20DI1%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E4%B8%8A%E8%A8%98%E3%81%AF%E5%A4%A7%E4%B8%88%E5%A4%AB%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E7%A7%81%E3%81%AF%E3%81%BE%E3%81%9F%E4%BB%96%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E7%A7%81%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%3CSTRONG%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-size%3A%209pt%3B%20font-family%3A%20CourierStd%3B%22%3Esetenv%20bootargs_mmc%20'setenv%20bootargs%20%24%7Bbootargs%7D%20root%3D%2Fdev%2Fmmcblk0p1%20rootwait%20rw%20video%3Dmxcfb0%3Adev%3Dadv739x%2CBT656-PAL%2Cif%3DBT656%2Cfbpix%3DRGB565%20video%3Dmxcfb1%3Adev%3Dhdmi%2C1920x1080M%4060%2Cif%3DRGB24%20video%3Dmxcfb2%3Adev%3Dldb%2CLDB-SVGA%2Cif%3DRGB24%20ldb%3Dsin0'%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHDMI%E3%81%AB%E7%B7%91%E8%89%B2%E3%81%AE%E8%89%B2%E3%82%92%E6%8F%8F%E7%94%BB%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C.%2Ffb_green%20%2Fdev%2Ffb2%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%80%8C.%2F%E3%80%8D%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84fb_green%2Fdev%2Ffb1%22%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125781%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125781%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%2Cqiang%2C%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFlinux%E3%81%AErootfs%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%3A%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20CourierStd%3B%22%3Esetenv%20bootargs_mmc%20'setenv%20bootargs%20%24%7Bbootargs%7D%20root%3D%2Fdev%2Fmmcblk0p1%20rootwait%20rw%20video%3Dmxcfb0%3Adev%3Dadv739x%2CBT656-PAL%2Cif%3DBT656%2Cfbpix%3DRGB565%20video%3Dmxcfb1%3Adev%3Dhdmi%2C1920x1080M%4060%2Cif%3DRGB24%20video%3Dmxcfb2%3Adev%3Dldb%2CLDB-SVGA%2Cif%3DRGB24%20ldb%3Dsin0'%20%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20CourierStd%3B%22%3ECVBS%E3%81%A8HDMI%E3%81%AB%E4%BD%95%E3%81%8B%E3%82%92%E6%8F%8F%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E4%BB%95%E4%BA%8B%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81lvds%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AB%E4%BD%95%E3%81%8B%E3%82%92%E6%8F%8F%E7%94%BB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%BD%95%E3%82%82%E8%A6%8B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20CourierStd%3B%22%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20CourierStd%3B%22%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%82%82%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20CourierStd%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20CourierStd%3B%22%3Esetenv%20bootargs_mmc%20'setenv%20bootargs%20%24%7Bbootargs%7D%20root%3D%2Fdev%2Fmmcblk0p1%20rootwait%20rw%20video%3Dmxcfb0%3Adev%3Dadv739x%2CBT656-PAL%2Cif%3DBT656%2Cfbpix%3DRGB565%20%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20CourierStd%3B%22%3Evideo%3Dmxcfb2%3Adev%3Dldb%2CLDB-SVGA%2Cif%3DRGB24%20ldb%3Dsin0%3C%2FSPAN%3E%3C%2FSTRONG%3E%20video%3Dmxcfb1%3Adev%3Dhdmi%2C1920x1080M%4060%2Cif%3DRGB24%20'%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20CourierStd%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20CourierStd%3B%22%3ECVBS%E3%81%A8LVDS%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E4%BD%95%E3%81%8B%E3%82%92%E6%8F%8F%E3%81%8F%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81HDMI%E3%81%AF%E6%8F%8F%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20CourierStd%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20CourierStd%3B%22%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20CourierStd%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20CourierStd%3B%22%3E%E4%BD%95%E3%81%8C%E3%81%9D%E3%82%93%E3%81%AA%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125780%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Patch%20to%20Support%20BT656%20and%20BT1120%20Output%20For%20i.MX6%20BSP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125780%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%8A%E6%97%A5%E3%81%AE%E5%8D%88%E5%BE%8C%E3%80%81%E6%8A%95%E7%A8%BF%E3%82%92%E3%82%88%E3%81%8F%E6%8B%9D%E8%A6%8B%E3%81%95%E3%81%9B%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3EHi%20Qiang%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3EF%E3%83%93%E3%83%83%E3%83%88(field1%2Ffield2)%E3%80%81V%E3%83%93%E3%83%83%E3%83%88%E3%80%81H%E3%83%93%E3%83%83%E3%83%88(SAV%2FEAV)%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6BT.656%E4%BB%95%E6%A7%98%E9%81%95%E5%8F%8D%E3%82%92%E7%99%BA%E8%A6%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3EBT.656%E4%BB%95%E6%A7%98%E9%81%95%E5%8F%8D%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%88%86%E6%9E%90%E7%B5%90%E6%9E%9C%E3%82%92%E3%83%A1%E3%83%BC%E3%83%AB%E3%81%AB%E3%81%A6%E3%81%8A%E9%80%81%E3%82%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%5BQ1%5D%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3EBT.656%E3%81%AB%E6%BA%96%E6%8B%A0%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E5%9B%BA%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E(%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A0%E3%81%91%E6%97%A9%E3%81%8F%E7%AD%94%E3%81%88%E3%81%8C%E6%AC%B2%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%5BQ2%5D%3C%2FP%3E%3CP%3EQ1%E3%81%8C%E3%80%8C%E3%81%AF%E3%81%84%E3%80%8D%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E4%BF%AE%E6%AD%A3%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%81%84%E3%81%A4%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3EKeita%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20font-size%3A%20small%3B%20line-height%3A%20normal%3B%20background-color%3A%20%23ffffff%3B%22%3EBT.656%E4%BB%95%E6%A7%98%E9%81%95%E5%8F%8D%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%A7%A3%E6%9E%90%E7%B5%90%E6%9E%9C%E3%82%92%E3%81%8A%E9%80%81%E3%82%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125775%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125775%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%E8%BF%85%E9%80%9F%E3%81%AA%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99!%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%86%E4%B8%80%E3%81%A4%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81BT.656%20%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%20%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E5%8F%82%E7%85%A7%E3%82%B3%E3%83%BC%E3%83%89%20%5BF%20bit(field1%2Ffield2)%2C%20V%20bit%2C%20H%20bit(SAV%2FEAV)%5D%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EKeita%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125773%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125773%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%20jb4.2.2_1.1.0%20%E3%81%A7%20BT.656%20%E5%87%BA%E5%8A%9B%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E6%AC%A1%E6%9C%9F%E8%A3%BD%E5%93%81%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A7%E3%81%AF%E3%80%81%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%B8%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%E6%A4%9C%E8%A8%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E(%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E3%82%BD%E3%83%BC%E3%82%B9i.MX6%E3%81%BE%E3%81%9F%E3%81%AFHDMI%20Rx%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E7%94%BB%E5%83%8F%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Display%20out.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Display%20out.png%22%20style%3D%22width%3A%20581px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55900iBEB9E48354C7082F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Display%20out.png%22%20alt%3D%22Display%20out.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%80%90%E8%B3%AA%E5%95%8F%E3%80%91%3C%2FP%3E%3CP%3E%E8%B3%AA%E5%95%8F1.%3C%2FP%3E%3CP%3EDSE%3DHi-z%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81i.MX6%E3%81%A8HDMI%20Rx%E3%81%AE%E3%83%90%E3%82%B9%E3%82%92%E3%82%AB%E3%83%83%E3%83%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E(%E5%A4%96%E9%83%A8%E3%83%90%E3%82%B9%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%83%A3%E3%83%BC%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AE%E5%88%A4%E6%96%AD%E3%82%92%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B3%AA%E5%95%8F2.%3C%2FP%3E%3CP%3EDSE%E8%A8%AD%E5%AE%9A%E4%BB%A5%E5%A4%96%E3%81%AE%E7%89%B9%E5%88%A5%E3%81%AA%E5%87%A6%E7%90%86%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EKeita%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125770%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125770%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22font-size%3A%2013.3333330154419px%3B%22%3EHi%20Qiang%2C%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2013.3333330154419px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2013.3333330154419px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2013.3333330154419px%3B%22%3E%E5%87%BA%E5%8A%9B%E3%83%93%E3%83%87%E3%82%AA%E3%81%AB%E7%AA%81%E7%84%B6%E3%80%8C%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%E3%80%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2013.3333330154419px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2013.3333330154419px%3B%22%3EFGPA%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E5%87%BA%E5%8A%9B%E3%82%92%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%9E%82%E7%9B%B4%E3%83%96%E3%83%A9%E3%83%B3%E3%82%AD%E3%83%B3%E3%82%B0%E4%B8%AD%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%8C%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%81%A7%E3%81%99%3A%20%3CA%20href%3D%22http%3A%2F%2Fi.imgur.com%2F3wvuZFB.png%22%20title%3D%22http%3A%2F%2Fi.imgur.com%2F3wvuZFB.png%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fi.imgur.com%2F3wvuZFB.png%3C%2FA%3E%3CSPAN%20style%3D%22font-size%3A%2013.3333330154419px%3B%20line-height%3A%201.5em%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2013.3333330154419px%3B%20line-height%3A%201.5em%3B%22%3E%E5%9E%82%E7%9B%B4%E3%83%96%E3%83%A9%E3%83%B3%E3%82%AD%E3%83%B3%E3%82%B0%E4%B8%AD%E3%81%AE%20%3CSTRONG%3E000%3C%2FSTRONG%3E%20%E3%81%A8%20%3CSTRONG%3E2AC%3C%2FSTRONG%3E%20%E3%81%AE%E5%80%A4%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%20%3CSTRONG%3E200%3C%2FSTRONG%3E%20%E3%81%A8%20%3CSTRONG%3E040%3C%2FSTRONG%3E%E3%81%AB%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%20%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2013.3333330154419px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2013.3333330154419px%3B%22%3E%E7%A7%81%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E6%A7%8B%E6%88%90%E3%81%AF%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2013px%3B%22%3EBT1120-1080I50%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%81%E3%83%A3%E3%83%B3%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB3.10.17%E3%82%92iMX6Q%E3%81%A7ADV7391%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Eunzip%20%22L3.10.17_1.0.0_GA_bt656_output_patch_2014-07-21.zip%3CSPAN%20class%3D%22j-attach-meta%20font-color-meta%22%3E%3C%2FSPAN%3E%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%80%8C0001-Support-BT656-and-BT1120-output-for-iMX6-ipuv3.patch%E3%80%8D%E3%81%AE%E3%81%BF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EADV7391%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7%E6%89%8B%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%80%8CL3.0.35_1.1.0_GA_bt656_output_patch_2013-08-09.zip%E3%80%8D%E3%81%AE%E5%8F%A4%E3%81%84%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%80%8C0002-Support-adv739x-TV-encoder-for-BT656-output.patch%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EDarren%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125767%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125767%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESD%20PAL%20CVBS%E3%83%93%E3%83%87%E3%82%AA(%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3Eclk%20%2B%208%E3%83%87%E3%83%BC%E3%82%BF%E3%83%A9%E3%82%A4%E3%83%B3%E3%80%81EAV%2FSAV%E3%80%81ADV7391)%3C%2FSPAN%3E%E7%94%A8%E3%81%AB2%E3%81%A4%E3%81%AE%E7%8B%AC%E7%AB%8B%E3%81%97%E3%81%9FBT.656%E3%83%93%E3%83%87%E3%82%AA%E5%87%BA%E5%8A%9B%E3%82%92%E6%8C%81%E3%81%A4%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E4%BB%96%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E5%87%BA%E5%8A%9B%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3Ei.MX6Q%20automotive%E3%81%A7%E3%81%AF%E3%80%81Yocto%E3%81%A8%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB3.10%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2%E3%81%A4%E3%81%AEADV7391%E3%82%92%E3%81%A9%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMario%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AFQiang%E3%80%81%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99-%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eipu1%20disp0%20%3D%20lcd%3C%2FP%3E%3CP%3Eipu1%20disp1%20%3D%20%E6%9C%AA%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Eipu2%20disp0%20%3D%20hdmi%3C%2FP%3E%3CP%3Eipu2%20disp1%20%3D%20Mipi%20Display%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81HDMI%E5%87%BA%E5%8A%9B%E3%81%A7%E5%86%8D%E7%94%9F%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81Mipi%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%8C%E5%A3%8A%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%82%B7%E3%83%8A%E3%83%AA%E3%82%AA%E3%81%A7%E3%81%AF%20LCD%20%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%82%8C%E3%81%8C%E4%BD%95%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E4%BD%95%E3%81%8B%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3FL3.10.17_1.0.0_GA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%82%93%E3%81%AA%E3%83%92%E3%83%B3%E3%83%88%E3%81%A7%E3%82%82%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%2FOtto%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%E3%81%9D%E3%82%8C%E3%82%92%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB(Bluechip%20Technology%E3%81%AEYocto%20Layer)%E3%81%AB%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E6%89%8B%E5%8B%95%E3%81%A7%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82mxcfb0%3Adev%3Dadv739x%2CBT656-NTSC%2Cif%3DBT656%2Cfbpix%3DRGB24%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20NTSC%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%A7%20mxc_v4l2_tvin.out%20%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%81%86%E3%81%BE%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81PAL%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%AF%E3%80%81%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E3%81%AE%E9%A0%86%E5%BA%8F%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%A1%E3%82%89%E3%81%A4%E3%81%8D%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81IPU%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%82%E6%99%82%E6%8A%98%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%3A%20IPU%20Warning%20-%20IPU_INT_STAT_5%20%3D%200x00000001%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%3A%20IPU%20Warning%20-%20IPU_INT_STAT_10%20%3D%200x00080000%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPAL%E3%81%A8NTSC%E3%81%AE%E9%81%95%E3%81%84%E3%81%AB%E6%B0%97%E4%BB%98%E3%81%84%E3%81%9F%E3%81%AE%E3%81%AFmxcfb_adv739x.c%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82adv739x_modedb%E3%81%AB%E3%81%AFFB_SYNC_HOR_HIGH_ACT%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%7CFB_SYNC_VERT_HIGH_ACT%20PAL%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%20NTSC%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B8%E3%82%A7%E3%82%A4%E3%83%9F%E3%83%BC%E3%83%BB%E3%83%9B%E3%82%A4%E3%82%B5%E3%83%A0%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125761%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125761%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBT656%20%2F%20BT1120%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E6%9B%B4%E6%96%B0%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E7%B7%A0%E3%82%81%E5%88%87%E3%82%8A%E3%82%82%E5%8E%B3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%81%BE%E3%81%A0%E6%B1%BA%E3%81%BE%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E4%BD%95%E3%82%92%E3%81%99%E3%81%B9%E3%81%8D%E3%81%8B%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E8%AA%AC%E6%98%8E%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eandroid-4.4.2_r1%E7%94%A8%E3%81%AEADV7393%E3%81%BE%E3%81%9F%E3%81%AFBT656%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%81%A9%E3%81%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%2CQiang%2C%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE2%E3%81%A4%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%81%E7%A7%81%E3%81%AE%E7%92%B0%E5%A2%83%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%3A%20IMX6Q%3C%2FP%3E%3CP%3Elinux%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%20linux3.0.35%3C%2FP%3E%3CP%3E1.%E5%88%86%E5%89%B2%E3%83%A2%E3%83%BC%E3%83%89(1080p)%E3%81%AElvds%E3%81%ABipu1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81HDMI%E3%81%ABipu2%E3%81%AEDI0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81BT656%E3%81%ABipu2%E3%81%AEDI1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82imx6q%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E2.%20MXCFB0%2FMAXCFB1%2FMXCFB2(BOOTARG%E3%81%AEdev%3DMXCFB0%2FMXCFB1%2FMXCFB2)%E3%81%A8IPU1%2FIPU2%E3%81%AE%E9%96%A2%E4%BF%82%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%20%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ewangzg%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125752%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125752%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EQiang%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E7%A7%81%E3%81%AE%E7%90%86%E8%A7%A3%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%95%E3%81%9B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%26gt%3B%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81720P%E5%87%BA%E5%8A%9B%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81VSYNC%20%2F%20HSYNC%E5%87%BA%E5%8A%9B%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%80%81HSYNC%E3%80%81VSYNC(BT.656%E3%81%8A%E3%82%88%E3%81%B3BT.1120%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84)%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AERGB%E3%83%87%E3%83%BC%E3%82%BF%E5%87%BA%E5%8A%9B%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EKeita%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4(BT.656%E3%81%A8BT.1120%E3%81%AE%E5%90%8C%E6%99%82%E5%87%BA%E5%8A%9B)%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%20%E2%97%8FIPU2%20DI0%20%26gt%3B--%26gt%3B%20BT.656%20w%2F1280%C3%97720p%4030fps%3C%2FP%3E%3CP%3E%20%E2%97%8FIPU1%20DI1%20%26gt%3B--%26gt%3B%20BT.1120%20w%2F1280%C3%97720p%4060fps%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBR%2C%3C%2FP%3E%3CP%3EKeita%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125749%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125749%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'%EB%A7%91%EC%9D%80%20%EA%B3%A0%EB%94%95'%3B%20font-size%3A%2010pt%3B%20mso-bidi-font-size%3A%2011.0pt%3B%20mso-ascii-theme-font%3A%20minor-latin%3B%20mso-fareast-theme-font%3A%20minor-fareast%3B%20mso-hansi-theme-font%3A%20minor-latin%3B%20mso-bidi-font-family%3A%20'Times%20New%20Roman'%3B%20mso-bidi-theme-font%3A%20minor-bidi%3B%20mso-ansi-language%3A%20EN-US%3B%20mso-fareast-language%3A%20KO%3B%20mso-bidi-language%3A%20AR-SA%3B%22%3E%E3%82%AB%E3%83%A1%E3%83%A9%E5%85%A5%E5%8A%9B%E3%81%8B%E3%82%89BT656%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89720P%3C%2FSPAN%3E%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AEi.MX6Q%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E5%87%BA%E5%8A%9B%E3%81%AE%E3%81%9F%E3%82%81%E3%81%A0%E3%81%91%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E7%94%A8%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIPU%20CSI%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%AA%E3%83%83%E3%82%AF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%20Li%3C%2FP%3E%3CP%3ELTIB%E3%81%AEBSP%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E9%96%8B%E7%99%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AF%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EL3.0.35_4.1.0%20%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81BT1120%20%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3EL3.0.35_4.1.0_GA_bt656_output_patch%20%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%20LTIB%20%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AB%E3%81%AF%202%20%E3%81%A4%E3%81%AE%E5%88%B6%E9%99%90%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1.Android%E3%81%AFRGB%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E3%81%BF%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81Android%E3%81%A7%E3%80%8Cfbpix%20%3D%20UYVY16%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E2.%E5%8D%98%E4%B8%80%E3%81%AEIPU%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81DP%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AE%E3%81%BF%E3%81%8CRGB%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%8B%E3%82%89YUV%20BT656%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%B8%E3%81%AECSC%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E3%81%AF%E3%80%81BT656%E3%81%AF%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%89%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E6%99%82%E3%81%AB%E3%80%81DC%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AFfb0%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%80%81DP%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AFfb1%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8CBT656%E3%82%92fb0%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E9%96%A2%E6%95%B0mxcfb_probe()%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E5%9B%9E%E5%BE%A9%E3%81%97%E3%80%81BT656%E5%87%BA%E5%8A%9B%E3%81%AB%E3%80%8Cfbpix%3DBGR32%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eif%20(((mxcfbi-%26gt%3Bipu_di_pix_fmt%20%3D%3D%20IPU_PIX_FMT_BT656)%20%7C%7C(mxcfbi-%26gt%3Bipu_di_pix_fmt%20%3D%3D%20IPU_PIX_FMT_BT1120))%26amp%3B%26amp%3B%20(mxcfbi-%26gt%3Bipu_id%20%3D%3D%200)%20%26amp%3B%20cpu_is_mx6dl())%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%2F*%20%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AF%20DC%20%E3%82%92%E4%BD%BF%E7%94%A8%20*%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A4%89%E6%9B%B4%E5%85%88%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%97%20(0)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%2F*%20%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AF%20DC%20%E3%82%92%E4%BD%BF%E7%94%A8%20*%2F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMX6Q%20LCD%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8B%E3%82%89%E3%81%AE1080p%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E9%80%B2%E8%A1%8C%E4%B8%AD%E3%81%AE%E4%BD%9C%E6%A5%AD%E3%82%92%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Li%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E8%8B%B1%E8%AA%9E%E3%81%AF%E3%80%81%E7%A7%81%E3%81%8C%E8%81%9E%E3%81%8D%E3%81%9F%E3%81%84%E8%B3%AA%E5%95%8F%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%8D%81%E5%88%86%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E5%90%8D%E5%89%8D%E3%81%8B%E3%82%89%E3%81%97%E3%81%A6%E4%B8%AD%E5%9B%BD%E4%BA%BA%E3%81%A7%E3%81%99%E3%81%AD%E3%80%82%E4%B8%AD%E5%9B%BD%E8%AA%9E%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E8%B3%AA%E5%95%8F%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%AD%E5%9B%BD%E8%AA%9E%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%82%E8%8B%B1%E8%AA%9E%E3%81%A7%E8%AA%AC%E6%98%8E%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E9%A0%91%E5%BC%B5%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%E7%8E%B0%E7%8A%B6%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E6%AD%A3%E5%B8%B8%E5%9C%A8%E4%BD%BF%E7%94%A8%E8%BF%87%E7%A8%8B%E4%B8%AD%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%83%B3%E6%9B%B4%E6%94%B9fb0%E7%9A%84%E6%A0%BC%E5%BC%8F%EF%BC%8C%E5%8F%AF%E4%BB%A5%E7%9B%B4%E6%8E%A5%E4%BD%BF%E7%94%A8fbset%20-g%201024%20768%201024%20768%2032%E7%9A%84%E5%91%BD%E4%BB%A4%E6%9D%A5%E5%AE%8C%E6%88%90%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E6%88%91%E5%81%9A%E4%BA%86%E4%B8%A4%E5%A5%97%E7%8E%AF%E5%A2%83%EF%BC%8CA.%E4%BD%BF%E7%94%A8patch%E4%B9%8B%E5%89%8D%EF%BC%8CB.%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E4%BD%BF%E7%94%A8patch%E4%B9%8B%E5%90%8E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E5%9C%A8%E8%BF%99%E4%B8%A4%E4%B8%AA%E7%8E%AF%E5%A2%83%E4%B8%AD%EF%BC%8C%E6%88%91%E5%81%9A%E8%BF%99%E4%BA%9B%E6%93%8D%E4%BD%9C%EF%BC%8C%E5%90%AF%E5%8A%A8%E5%AE%9E%E6%9C%BA%E5%BD%93%E5%89%8Dfb0%E4%B8%BA16%E4%BD%8D%EF%BC%8C%E5%90%AF%E5%8A%A8%E6%9F%90UI%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%85%B3%E9%97%ADUI%E7%A8%8B%E5%BA%8F%EF%BC%8Cfbset%E6%9B%B4%E6%94%B9%E4%B8%BA32%E4%BD%8D%EF%BC%8C%E5%86%8D%E6%AC%A1%E5%90%AF%E5%8A%A8UI%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20A%E7%8E%AF%E5%A2%83%E4%B8%AD%EF%BC%8C%E9%80%9A%E8%BF%87fbset%E6%9B%B4%E6%94%B9fb0%E6%A0%BC%E5%BC%8F%E5%89%8D%E5%90%8E%EF%BC%8C%E5%90%AF%E5%8A%A8%E7%9A%84UI%E7%A8%8B%E5%BA%8F%EF%BC%8C%E6%98%BE%E7%A4%BA%E9%83%BD%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20B%E7%8E%AF%E5%A2%83%E4%B8%AD%EF%BC%8C%E9%80%9A%E8%BF%87fbset%E6%9B%B4%E6%94%B9fb0%E6%A0%BC%E5%BC%8F%E5%89%8D%EF%BC%8C%E6%98%BE%E7%A4%BA%E6%AD%A3%E5%B8%B8%EF%BC%8C%E6%9B%B4%E6%94%B9%E5%90%8E%EF%BC%8C%E6%98%BE%E7%A4%BA%E4%B8%8D%E6%AD%A3%E5%B8%B8%E3%80%82%E5%B0%86%E6%9B%B4%E6%94%B9%E5%90%8E%E7%9A%84fb0%E7%9A%84%E6%95%B0%E6%8D%AE%E9%80%9A%E8%BF%87cat%E8%AF%AD%E5%8F%A5dump%E5%88%B0%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E5%9C%A8PC%E4%B8%8A%E6%9F%A5%E7%9C%8B%EF%BC%8C%E6%98%BE%E7%A4%BA%E4%B8%BA%E6%AD%A3%E5%B8%B8%E7%9A%8432%E4%BD%8D%E6%95%B0%E6%8D%AE%EF%BC%8C%E5%AE%9E%E6%9C%BA%E7%94%BB%E9%9D%A2%E6%98%BE%E7%A4%BA%E6%95%88%E6%9E%9C%E4%B8%BA%E5%AE%BD%E5%BA%A6%E6%8B%89%E4%BC%B8%E4%BA%862%E5%80%8D%E7%9A%84%E6%95%88%E6%9E%9C%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E5%A6%82%E6%9E%9C%E9%80%9A%E8%BF%87uboot%E5%90%AF%E5%8A%A8%E5%8F%82%E6%95%B0%E4%B8%AD%EF%BC%8Cbpp%3D32%E6%9D%A5%E8%AE%BE%E7%BD%AEfb0%EF%BC%8C%E5%90%AF%E5%8A%A8%E5%90%8E32%E4%BD%8D%E6%98%BE%E7%A4%BA%E6%AD%A3%E5%B8%B8%EF%BC%8C%E4%BD%86%E6%98%AFfbset%E6%9B%B4%E6%94%B916%E4%BD%8D%E4%BB%A5%E5%90%8E%EF%BC%8C16%E4%BD%8D%E6%98%BE%E7%A4%BA%E4%B8%8D%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E6%80%BB%E7%BB%93%E7%9A%84%E9%97%AE%E9%A2%98%E4%B8%BA%EF%BC%8C%E6%97%A0%E6%B3%95%E5%9C%A8%E5%AE%9E%E6%9C%BA%E5%90%AF%E5%8A%A8%E4%BB%A5%E5%90%8E%EF%BC%8C%E5%8E%BB%E6%9B%B4%E6%94%B9fb0%E6%A0%BC%E5%BC%8F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%E5%88%86%E6%9E%90%EF%BC%9A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E6%9F%A5%E7%9C%8B%E4%BA%86%E4%B8%80%E9%83%A8%E5%88%86patch%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%8F%91%E7%8E%B0%E5%90%AF%E5%8A%A8%E6%9C%89%E5%AF%B9%E5%AE%9E%E6%9C%BA%E5%90%AF%E5%8A%A8%E4%BB%A5%E5%90%8E%EF%BC%8C%E6%9B%B4%E6%94%B9fb%E6%A0%BC%E5%BC%8F%E7%9A%84%E4%BB%A3%E7%A0%81%E3%80%82%E5%A6%82%E6%9E%9Cuboot%E5%8F%82%E6%95%B0%E4%B8%AD%EF%BC%8C%E6%B2%A1%E6%9C%89%E5%AE%9A%E4%B9%89%E4%B8%80%E4%BA%9B%E5%8F%98%E9%87%8F%EF%BC%8C%E9%82%A3%E4%B9%88%E6%97%A0%E6%B3%95%E6%9B%B4%E6%94%B9fb%E6%A0%BC%E5%BC%8F%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E4%BD%86%E6%98%AF%E5%85%B7%E4%BD%93%E6%9B%B4%E6%94%B9%E5%93%AA%E4%BA%9B%E5%8F%98%E9%87%8F%EF%BC%8C%E6%88%91%E4%B8%8D%E5%A4%AA%E6%B8%85%E6%A5%9A%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%20%E8%BF%99%E4%B8%AA%E7%8E%B0%E8%B1%A1%E5%9C%A8%E4%BD%A0%E7%9A%84%E7%8E%AF%E5%A2%83%E4%B8%AD%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%EF%BC%9F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202%20%E5%A6%82%E6%9E%9C%E6%83%B3%E5%9C%A8%E5%AE%9E%E6%9C%BA%E5%90%AF%E5%8A%A8%E5%90%8E%E6%9B%B4%E6%94%B9fb%E6%A0%BC%E5%BC%8F%EF%BC%8C%E5%A6%82%E4%BD%95%E8%BF%9B%E8%A1%8C%EF%BC%9F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203%20%E5%A6%82%E6%9E%9C%E6%97%A0%E6%B3%95%E5%9C%A8%E5%AE%9E%E6%9C%BA%E5%90%AF%E5%8A%A8%E5%90%8E%E6%9B%B4%E6%94%B9fb%E6%A0%BC%E5%BC%8F%EF%BC%8C%E6%98%AF%E5%90%A6%E4%B8%BAbug%EF%BC%8C%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%E5%A4%9A%E8%B0%A2Li%20Qiang%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Li%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%80%B3%E9%9A%9C%E3%82%8A%E3%81%AA%E7%AD%94%E3%81%88%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8A%E3%81%A7%E3%81%99%E3%80%81%E3%81%A9%E3%81%86%E3%82%82%E5%AE%9C%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E8%87%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125734%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125734%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Li%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%81%8A%E9%82%AA%E9%AD%94%E3%81%97%E3%81%A6%E3%81%99%E3%81%BF%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E4%B8%8A%E3%81%A7%E5%8F%96%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A8%E5%90%8C%E3%81%98%E3%82%88%E3%81%86%E3%81%AB%E8%B3%AA%E5%95%8F%E3%81%A8%E3%81%97%E3%81%A6%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF2%E3%81%A4%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E1%2C%20%2F*%20COUNTER_2%3A%20%E5%90%84%E8%A1%8C%E3%81%AE%20HSYNC%20*%2F%3C%2FP%3E%3CP%3E2%2C%20%2F*%20COUNTER_3%3A%20%E5%90%84%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%AE%E5%86%85%E9%83%A8%20VSYNC%20*%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22op_dict_text2%22%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AFBT.656%E3%81%A8IPU%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E6%96%B0%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E9%96%A2%E6%95%B0ipu_init_sync_panel()%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8BHSYNC%2FVSYNC%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%86%85%E9%83%A8%E5%90%8C%E6%9C%9F%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E5%A4%96%E9%83%A8%E5%90%8C%E6%9C%9F%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125732%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125732%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Li%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBT656%E6%A9%9F%E8%83%BD%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8BiMX6%E3%81%B8%E3%81%AE%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E4%BE%BF%E5%88%A9%E3%81%AA%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%E7%A7%81%E3%81%AFAK8817%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%83%81%E3%83%83%E3%83%97%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FiMX6S%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1%E3%80%81%E5%A4%96%E9%83%A8HSYNC%20%2F%20VSYNC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%9B%E3%81%9A%E3%80%81BT656%E8%87%AA%E4%BD%93%E3%81%AE%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82iMX6S%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84BT656%E4%BF%A1%E5%8F%B7%E3%82%92AK8817%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%82%92%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3E%2F%2F-----------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E%3CSTRONG%3E%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%2F%E3%83%93%E3%83%87%E3%82%AA%2Fmxc%2Fmxc_bt656if.c%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E9%9D%99%E7%9A%84%E6%A7%8B%E9%80%A0%E4%BD%93%20fb_videomode%20bt656if_modedb%5B%5D%20%3D%20%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3C%2FP%3E%3CP%3E%2F*%20NTSC%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E5%87%BA%E5%8A%9B%20*%2F%3C%2FP%3E%3CP%3E%E3%80%8CBT656-NTSC%E3%80%8D%E3%80%8160%E3%80%81720%E3%80%81480%E3%80%8137037%E3%80%81%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2019%2C%203%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2020%2C%203%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20276%2C%201%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSTRONG%3EFB_SYNC_HOR_HIGH_ACT%20%7CFB_SYNC_VERT_HIGH_ACT%E3%80%81%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EFB_VMODE_INTERLACED%E3%80%81%3C%2FP%3E%3CP%3EFB_MODE_IS_DETAILED%2C%7D%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20......%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20......%3C%2FP%3E%3CP%3E%7D%3B%3C%2FP%3E%3CP%3E%2F%2F------------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E%3CSTRONG%3E%2Fdrivers%2Fmxc%2Fipu3%2Fipu_disp.c%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%2F*%20COUNTER_2%3A%20%E5%90%84%E8%A1%8C%E3%81%AE%20HSYNC%20*%2F%3C%2FP%3E%3CP%3E%2F*%20COUNTER_2%3A%20%E5%90%84%E8%A1%8C%E3%81%AE%20HSYNC%20*%2F%3C%2FP%3E%3CP%3E_ipu_di_sync_config(ipu%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20disp%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20display%20*%2F%3C%2FP%3E%3CP%3EDI_BT656_SYNC_HSYNC%E3%80%81%2F*%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC*%2F%3C%2FP%3E%3CP%3Eh_total%20-%201%2C%20%2F*%20%E3%83%A9%E3%83%B3%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%20*%2F%3C%2FP%3E%3CP%3EDI_SYNC_CLK%2C%20%2F*%20run_resolution%20*%2F%3C%2FP%3E%3CP%3E0%2C%20%2F*%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20*%2F%3C%2FP%3E%3CP%3EDI_SYNC_NONE%2C%20%2F*%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E8%A7%A3%E5%83%8F%E5%BA%A6%20*%2F%3C%2FP%3E%3CP%3E0%2C%20%2F*%20%E3%83%AA%E3%83%94%E3%83%BC%E3%83%88%E5%9B%9E%E6%95%B0%20*%2F%3C%2FP%3E%3CP%3EDI_SYNC_NONE%2C%20%2F*%20CNT_CLR_SEL%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20CNT_POLARITY_GEN_EN%20*%2F%3C%2FP%3E%3CP%3EDI_SYNC_NONE%2C%20%2F*%20CNT_POLARITY_CLR_SEL%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20DI_SYNC_NONE%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20CNT_POLARITY_TRIGGER_SEL%20*%2F%3C%2FP%3E%3CP%3E0%2C%20%2F*%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSTRONG%3E2*div%20%2F*%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%83%80%E3%82%A6%E3%83%B3%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F*%20COUNTER_3%3A%20%E5%90%84%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%AE%E5%86%85%E9%83%A8%20VSYNC%20*%2F%3C%2FP%3E%3CP%3E_ipu_di_sync_config(ipu%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20disp%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20display%20*%2F%3C%2FP%3E%3CP%3EDI_BT656_SYNC_IVSYNC%E3%80%81%2F*%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC*%2F%3C%2FP%3E%3CP%3Ev_total%20-%201%2C%20%2F*%20%E3%83%A9%E3%83%B3%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%20*%2F%3C%2FP%3E%3CP%3EDI_BT656_SYNC_HSYNC%2C%20%2F*%20run_resolution%20*%2F%3C%2FP%3E%3CP%3E0%2C%20%2F*%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20*%2F%3C%2FP%3E%3CP%3EDI_SYNC_NONE%2C%20%2F*%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E8%A7%A3%E5%83%8F%E5%BA%A6%20*%2F%3C%2FP%3E%3CP%3E0%2C%20%2F*%20%E3%83%AA%E3%83%94%E3%83%BC%E3%83%88%E5%9B%9E%E6%95%B0%20*%2F%3C%2FP%3E%3CP%3EDI_SYNC_NONE%2C%20%2F*%20CNT_CLR_SEL%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20CNT_POLARITY_GEN_EN%20*%2F%3C%2FP%3E%3CP%3EDI_SYNC_NONE%2C%20%2F*%20CNT_POLARITY_CLR_SEL%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20DI_SYNC_NONE%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20CNT_POLARITY_TRIGGER_SEL%20*%2F%3C%2FP%3E%3CP%3E0%2C%20%2F*%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSTRONG%3E%200%20%2F*%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%83%80%E3%82%A6%E3%83%B3%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2%E3%80%81%E5%A4%96%E9%83%A8HSYNC%20%2F%20VSYNC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81BT656%E8%87%AA%E4%BD%93%E3%81%A0%E3%81%91%E3%81%A7%E3%80%82iMX6S%E3%81%AF%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84BT656%E4%BF%A1%E5%8F%B7%E3%82%92AK8817%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%2F%2F-----------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E%3CSTRONG%3E%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%2F%E3%83%93%E3%83%87%E3%82%AA%2Fmxc%2Fmxc_bt656if.c%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E9%9D%99%E7%9A%84%E6%A7%8B%E9%80%A0%E4%BD%93%20fb_videomode%20bt656if_modedb%5B%5D%20%3D%20%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3C%2FP%3E%3CP%3E%2F*%20NTSC%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E5%87%BA%E5%8A%9B%20*%2F%3C%2FP%3E%3CP%3E%E3%80%8CBT656-NTSC%E3%80%8D%E3%80%8160%E3%80%81720%E3%80%81480%E3%80%8137037%E3%80%81%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2019%2C%203%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2020%2C%203%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20276%2C%201%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSTRONG%3E0%2C%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EFB_VMODE_INTERLACED%E3%80%81%3C%2FP%3E%3CP%3EFB_MODE_IS_DETAILED%2C%7D%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20......%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20......%3C%2FP%3E%3CP%3E%7D%3B%3C%2FP%3E%3CP%3E%2F%2F------------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E%3CSTRONG%3E%2Fdrivers%2Fmxc%2Fipu3%2Fipu_disp.c%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%2F*%20COUNTER_2%3A%20%E5%90%84%E8%A1%8C%E3%81%AE%20HSYNC%20*%2F%3C%2FP%3E%3CP%3E%2F*%20COUNTER_2%3A%20%E5%90%84%E8%A1%8C%E3%81%AE%20HSYNC%20*%2F%3C%2FP%3E%3CP%3E_ipu_di_sync_config(ipu%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20disp%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20display%20*%2F%3C%2FP%3E%3CP%3EDI_BT656_SYNC_HSYNC%E3%80%81%2F*%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC*%2F%3C%2FP%3E%3CP%3Eh_total%20-%201%2C%20%2F*%20%E3%83%A9%E3%83%B3%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%20*%2F%3C%2FP%3E%3CP%3EDI_SYNC_CLK%2C%20%2F*%20run_resolution%20*%2F%3C%2FP%3E%3CP%3E0%2C%20%2F*%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20*%2F%3C%2FP%3E%3CP%3EDI_SYNC_NONE%2C%20%2F*%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E8%A7%A3%E5%83%8F%E5%BA%A6%20*%2F%3C%2FP%3E%3CP%3E0%2C%20%2F*%20%E3%83%AA%E3%83%94%E3%83%BC%E3%83%88%E5%9B%9E%E6%95%B0%20*%2F%3C%2FP%3E%3CP%3EDI_SYNC_NONE%2C%20%2F*%20CNT_CLR_SEL%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20CNT_POLARITY_GEN_EN%20*%2F%3C%2FP%3E%3CP%3EDI_SYNC_NONE%2C%20%2F*%20CNT_POLARITY_CLR_SEL%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20DI_SYNC_NONE%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20CNT_POLARITY_TRIGGER_SEL%20*%2F%3C%2FP%3E%3CP%3E0%2C%20%2F*%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSTRONG%3E20*div%20%2F*%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%83%80%E3%82%A6%E3%83%B3%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F*%20COUNTER_3%3A%20%E5%90%84%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%AE%E5%86%85%E9%83%A8%20VSYNC%20*%2F%3C%2FP%3E%3CP%3E_ipu_di_sync_config(ipu%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20disp%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20display%20*%2F%3C%2FP%3E%3CP%3EDI_BT656_SYNC_IVSYNC%E3%80%81%2F*%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC*%2F%3C%2FP%3E%3CP%3Ev_total%20-%201%2C%20%2F*%20%E3%83%A9%E3%83%B3%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%20*%2F%3C%2FP%3E%3CP%3EDI_BT656_SYNC_HSYNC%2C%20%2F*%20run_resolution%20*%2F%3C%2FP%3E%3CP%3E0%2C%20%2F*%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20*%2F%3C%2FP%3E%3CP%3EDI_SYNC_NONE%2C%20%2F*%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E8%A7%A3%E5%83%8F%E5%BA%A6%20*%2F%3C%2FP%3E%3CP%3E0%2C%20%2F*%20%E3%83%AA%E3%83%94%E3%83%BC%E3%83%88%E5%9B%9E%E6%95%B0%20*%2F%3C%2FP%3E%3CP%3EDI_SYNC_NONE%2C%20%2F*%20CNT_CLR_SEL%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20CNT_POLARITY_GEN_EN%20*%2F%3C%2FP%3E%3CP%3EDI_SYNC_NONE%2C%20%2F*%20CNT_POLARITY_CLR_SEL%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20DI_SYNC_NONE%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20CNT_POLARITY_TRIGGER_SEL%20*%2F%3C%2FP%3E%3CP%3E0%2C%20%2F*%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSTRONG%3E%202*div%20%2F*%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%83%80%E3%82%A6%E3%83%B3%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A4%96%E9%83%A8%20HSYNC%2FVSYNC%20%E3%81%AA%E3%81%97%E3%81%A7%20iMX6%20%E3%81%8B%E3%82%89%20AK8817%20%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%84%20BT656%20%E4%BF%A1%E5%8F%B7%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3EiMX6%20Sabre%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EHi%20Qiang%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%923.0.35%E3%81%A7%E3%81%97%E3%81%B0%E3%82%89%E3%81%8F%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E7%8F%BE%E5%9C%A8%E3%80%813.10.17_1.0.0_beta%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%93%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABBSP%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E3%83%86%E3%82%A3%E3%83%A0%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125719%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125719%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EBT1120-8%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%A8%E3%80%811080I60%E3%81%8A%E3%82%88%E3%81%B31080I50%E3%81%AE%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E8%A9%A6%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%7B%3C%2FP%3E%3CP%3E%2F*%201080I60%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E5%87%BA%E5%8A%9B%20*%2F%3C%2FP%3E%3CP%3E%E3%80%8CBT1120-1080I60%E3%80%8D%E3%80%8130%E3%80%811920%E3%80%811080%E3%80%8113468%E3%80%81%3C%2FP%3E%3CP%3E%26nbsp%3B%2020%2C%203%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%2020%2C%202%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20280%2C%201%2C%3C%2FP%3E%3CP%3EFB_SYNC_HOR_HIGH_ACT%20%7CFB_SYNC_VERT_HIGH_ACT%E3%80%81%3C%2FP%3E%3CP%3EFB_VMODE_INTERLACED%E3%80%81%3C%2FP%3E%3CP%3EFB_MODE_IS_DETAILED%2C%7D%2C%3C%2FP%3E%3CP%3E%20%7B%3C%2FP%3E%3CP%3E%2F*%201080I50%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E5%87%BA%E5%8A%9B%20*%2F%3C%2FP%3E%3CP%3E%E3%80%8CBT1120-1080I50%E3%80%8D%E3%80%8125%E3%80%811920%E3%80%811080%E3%80%8113468%E3%80%81%3C%2FP%3E%3CP%3E%26nbsp%3B%2020%2C%203%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%2020%2C%202%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20720%2C%201%2C%3C%2FP%3E%3CP%3EFB_SYNC_HOR_HIGH_ACT%20%7CFB_SYNC_VERT_HIGH_ACT%E3%80%81%3C%2FP%3E%3CP%3EFB_VMODE_INTERLACED%E3%80%81%3C%2FP%3E%3CP%3EFB_MODE_IS_DETAILED%2C%7D%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125718%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125718%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHI%20li%20%3A%3C%2FP%3E%3CP%3Eclock.c%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%20%3Asetenv%20bootargs%20console%3Dttymxc0%2C115200%20init%3D%2Finit%20rw%20video%3Dmxcfb0%3Adev%3Dbt656%2CBT1120-PAL-1080i%2Cif%3DBT1120%2Cfbpix%3DRGB565%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AE%E7%94%BB%E9%9D%A2%E3%81%AF%E4%BF%A1%E5%8F%B7%E3%82%92%E8%AD%98%E5%88%A5%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E3%83%9E%E3%83%BC%E3%82%B8%E3%83%B3%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%A8%80%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%3A%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3C%2FP%3E%3CP%3E%2F*%20PAL%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E5%87%BA%E5%8A%9B%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%22BT1120-PAL-1080i%22%2C%2025%2C%201920%2C1080%2C%2013468%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20148%2C%20484%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2036%2C%204%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2088%2C%205%2C%3C%2FP%3E%3CP%3EFB_SYNC_HOR_HIGH_ACT%20%7CFB_SYNC_VERT_HIGH_ACT%E3%80%81%3C%2FP%3E%3CP%3EFB_VMODE_INTERLACED%E3%80%81%3C%2FP%3E%3CP%3EFB_MODE_IS_DETAILED%2C%7D%2C%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%91%E3%83%83%E3%83%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF1080i%E5%BD%A2%E5%BC%8F%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%811080i%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE1080i%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Ekai%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20li%20%3A%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%BF%94%E4%BF%A1%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E5%89%8D%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%A7%E3%81%99%3A%E7%A7%81%E3%81%AFsabresd%E3%83%9C%E3%83%BC%E3%83%89%E5%87%BA%E5%8A%9B%E3%83%91%E3%83%A9%E3%83%AC%E3%83%AByuv4%3A2%3A2%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%8A%A9%E3%81%91%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81720P%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AFOK%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E3%81%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%20%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFTV%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80FAE%E3%81%A8%E9%80%9A%E4%BF%A1%E3%81%97%E3%80%81%E3%83%81%E3%83%83%E3%83%97%E3%81%AFbt1120%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81576i%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%AF%E8%A1%A8%E7%A4%BAOK%E3%81%A7%E3%81%99(%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%81%E3%83%83%E3%83%97%E3%81%AFBT1120%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%86%E3%81%BE%E3%81%8F%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93)%E3%80%82%E3%81%93%E3%81%AETV%E3%83%81%E3%83%83%E3%83%97%E3%81%AEfae%E3%81%AF%E3%80%811080i%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%95%E3%81%9B%E3%80%81%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E7%A7%81%E3%81%AF%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%811080i%E3%81%AF%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E7%94%BB%E9%9D%A2%E3%81%AF%E9%BB%92%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E7%94%BB%E9%9D%A2%E3%81%AB%E3%81%AF%E4%BD%95%E3%82%82%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%8A%A9%E3%81%91%E3%82%92%E6%B1%82%E3%82%81%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E8%A1%A8%E7%A4%BA%E3%83%87%E3%83%BC%E3%82%BF%E3%81%A7%E3%81%AESAV%E3%82%84EAV%E3%81%AB%E3%82%88%E3%82%8Bleft_margin%20right_margin%E3%81%AA%E3%81%A9%E3%81%8C%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%A8%E5%B8%B8%E3%80%85%E6%80%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E3%81%9B%E3%81%84%E3%81%A7%E3%80%81%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%81%AF%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E6%8C%BF%E5%85%A5%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93(%E3%81%93%E3%81%AE%E3%83%81%E3%83%83%E3%83%97%E3%81%A7%E3%81%AF%E3%80%81%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%81%AF%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%E3%81%AB%E6%8C%BF%E5%85%A5%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99)%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BD%95%E3%81%A7%E3%82%82%E6%8A%95%E5%BD%B1%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%E3%81%A0%E3%81%8B%E3%82%89%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E7%B4%841080i%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%81mxc_bt656if.c%E3%81%AF576i%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%97%E3%81%8B%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%BC%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3Ekai%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125714%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125714%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDear%20li%3A%3C%2FP%3E%3CP%3E1080i%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%3Fmxc_bt656.c%E3%81%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%A0%E3%81%8C%E3%81%97%E3%81%8B%E3%81%97%E7%94%BB%E9%9D%A2%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%2F*%20PAL%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%BC%E3%82%B9%E5%87%BA%E5%8A%9B%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%20%22BT1120-PAL-1080i%22%2C%2025%2C%201920%2C1080%2C%2013468%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20148%2C%20484%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%2036%2C%204%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%2088%2C%205%2C%3C%2FP%3E%3CP%3EFB_SYNC_HOR_HIGH_ACT%20%7CFB_SYNC_VERT_HIGH_ACT%E3%80%81%3C%2FP%3E%3CP%3EFB_VMODE_INTERLACED%E3%80%81%3C%2FP%3E%3CP%3EFB_MODE_IS_DETAILED%2C%7D%2C%3C%2FP%3E%3CP%3E%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%BC%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3Ekai%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHSYNC%20%E3%83%94%E3%83%B3%E3%81%A8%20VSYNC%20%E3%83%94%E3%83%B3%E3%81%AF%E3%83%91%E3%83%83%E3%83%81%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%81%99%E3%81%A7%E3%81%AB%E3%82%A4%E3%83%8D%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81DI0_PIN2%20%E3%83%94%E3%83%B3%E3%81%A8%20DI0_PIN4%20%E3%83%94%E3%83%B3%E3%81%8B%E3%82%89%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBT656%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%20VSYNC%20%E3%81%A8%20HSYNC%20%E3%82%92%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E4%BF%A1%E5%8F%B7%E3%81%AF%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%81%9A%E3%80%81%E4%BA%88%E7%B4%84%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%20DI%20%E8%A8%AD%E5%AE%9A%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%2F*%20COUNTER_2%3A%20%E5%90%84%E8%A1%8C%E3%81%AE%20HSYNC%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20_ipu_di_sync_config(ipu%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20disp%2C%26nbsp%3B%26nbsp%3B%20%2F*%20display%20*%2F%3C%2FP%3E%3CP%3EDI_BT656_SYNC_HSYNC%E3%80%81%2F*%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC*%2F%3C%2FP%3E%3CP%3Eh_total%20-%201%2C%20%2F*%20%E3%83%A9%E3%83%B3%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%20*%2F%3C%2FP%3E%3CP%3EDI_SYNC_CLK%2C%20%2F*%20run_resolution%20*%2F%3C%2FP%3E%3CP%3E0%2C%20%2F*%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20*%2F%3C%2FP%3E%3CP%3EDI_SYNC_NONE%2C%20%2F*%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E8%A7%A3%E5%83%8F%E5%BA%A6%20*%2F%3C%2FP%3E%3CP%3E0%2C%20%2F*%20%E3%83%AA%E3%83%94%E3%83%BC%E3%83%88%E5%9B%9E%E6%95%B0%20*%2F%3C%2FP%3E%3CP%3EDI_SYNC_NONE%2C%20%2F*%20CNT_CLR_SEL%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%2C%26nbsp%3B%26nbsp%3B%20%2F*%20CNT_POLARITY_GEN_EN%20*%2F%3C%2FP%3E%3CP%3EDI_SYNC_NONE%2C%20%2F*%20CNT_POLARITY_CLR_SEL%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20DI_SYNC_NONE%2C%26nbsp%3B%20%2F*%20CNT_POLARITY_TRIGGER_SEL%20*%2F%3C%2FP%3E%3CP%3E0%2C%20%2F*%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%20*%2F%3C%2FP%3E%3CP%3E2*div%20%2F*%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%83%80%E3%82%A6%E3%83%B3%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F*%20COUNTER_4%3A%20field1%20%E3%81%AE%E3%81%BF%E3%81%AE%20VSYNC%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20_ipu_di_sync_config(ipu%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20disp%2C%26nbsp%3B%26nbsp%3B%20%2F*%20display%20*%2F%3C%2FP%3E%3CP%3EDI_BT656_SYNC_VSYNC%2C%20%2F*%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%20*%2F%3C%2FP%3E%3CP%3E0%2C%20%2F*%20%E3%83%A9%E3%83%B3%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%20*%2F%3C%2FP%3E%3CP%3EDI_BT656_SYNC_HSYNC%2C%20%2F*%20run_resolution%20*%2F%3C%2FP%3E%3CP%3Ebt656_v_start_width_field0%20%2B%20%E9%AB%98%E3%81%95%20%2F%202%20%2B%20bt656_v_end_width_field0%2C%20%2F*%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20*%2F%3C%2FP%3E%3CP%3EDI_BT656_SYNC_HSYNC%2C%20%2F*%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E5%88%86%E8%A7%A3%E8%83%BD%20*%2F%3C%2FP%3E%3CP%3E1%2C%20%2F*%20%E3%83%AA%E3%83%94%E3%83%BC%E3%83%88%E5%9B%9E%E6%95%B0%20*%2F%3C%2FP%3E%3CP%3EDI_BT656_SYNC_IVSYNC%2C%20%2F*%20CNT_CLR_SEL%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%2C%26nbsp%3B%26nbsp%3B%20%2F*%20CNT_POLARITY_GEN_EN%20*%2F%3C%2FP%3E%3CP%3EDI_SYNC_NONE%2C%20%2F*%20CNT_POLARITY_CLR_SEL%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20DI_SYNC_NONE%2C%26nbsp%3B%20%2F*%20CNT_POLARITY_TRIGGER_SEL%20*%2F%3C%2FP%3E%3CP%3E0%2C%20%2F*%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%20*%2F%3C%2FP%3E%3CP%3E2*div%20%2F*%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%83%80%E3%82%A6%E3%83%B3%20*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20)%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125712%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125712%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDear%20li%3A%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81uboot%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3Avideo%20%3D%20mxcfb0%3Adev%20%3D%20bt656%E3%80%81BT1120-PAL%E3%80%81if%20%3D%20UYVY16%E3%80%81fbpix%20%3D%20RGB565%E3%80%81%E3%81%97%E3%81%8B%E3%81%97vsync%E3%81%AF%E3%83%AB%E3%83%BC%E3%83%AB%20error.it%20%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%20%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E4%BB%96%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E3%80%81%E3%81%93%E3%81%AEPIN%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EIPU1_DI0_PIN2%20adv7391%20HSYNC%E3%83%94%E3%83%B3%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82(%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EIPU1_DI0_PIN4%20adv7391%E3%81%AEVSYNC%E3%83%94%E3%83%B3%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82(%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3Ekai%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125711%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125711%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%82%92%E8%AD%B0%E8%AB%96%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%E3%81%9D%E3%81%93%E3%81%AB%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%AE%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F360506%23360506%22%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fmessage%2F360506%23360506%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125708%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125708%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EADV7391%20YUV%204%3A2%3A2%20%E5%85%A5%E5%8A%9B%E3%81%AE%E3%81%BF%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%BC%20%E3%83%87%E3%83%BC%E3%82%BF%E5%BD%A2%E5%BC%8F%E3%81%AB%E9%96%A2%E4%BF%82%E3%81%AA%E3%81%8F%E3%80%81BT656%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E5%87%BA%E5%8A%9B%E3%81%AF%20EAV%2FSAV%20%E3%81%8C%E5%9F%8B%E3%82%81%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%9F%20YUV%204%3A2%3A2%20%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81BT656%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A7%E3%81%AF%E3%80%81Android%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%82%92ADV7391%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%87%E3%83%BC%E3%82%BF%E5%BD%A2%E5%BC%8F%E3%81%8C%E5%9F%8B%E3%81%BE%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3FRGB%E3%80%81YUV%E3%81%BE%E3%81%9F%E3%81%AF%E7%A7%81%E3%81%AF%E3%83%87%E3%83%BC%E3%82%BF%E5%BD%A2%E5%BC%8F%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E5%86%85%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92YUV%204%3A2%3A2%E5%87%BA%E5%8A%9B%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E8%87%AA%E5%88%86%E3%81%A7ADV7391%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E3%80%8C%E3%83%93%E3%83%87%E3%82%AA%E3%81%A7%E3%83%91%E3%83%AA%E3%83%BC%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%82%82%E3%81%84%E3%81%84%E3%80%8D%E3%81%A8%E3%81%8A%E3%81%A3%E3%81%97%E3%82%83%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%AD!LCD%E3%83%91%E3%83%8D%E3%83%AB%E3%82%92%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81ADV7391%E3%81%A7%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E5%86%8D%E7%94%9F%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3FAndroid%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%9Fgstream%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81Ubuntu%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92Android%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E4%BB%BB%E6%84%8F%E3%81%AEAPK%E3%81%A7%E3%81%93%E3%82%8C%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125706%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125706%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%8A%E3%81%A3%E3%81%97%E3%82%83%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E6%99%82%E8%A8%88%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81ADV7391%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AF%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E8%A1%A8%E7%A4%BA%E8%89%B2%E3%81%8C%E3%82%B0%E3%83%AD%E3%83%86%E3%82%B9%E3%82%AF%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EADV7391%E3%81%AFDISP1_DAT0~7%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AF%E3%83%96%E3%83%BC%E3%83%88%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%82%82%E5%85%B1%E6%9C%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%B0%E3%83%A9%E3%83%B3%E3%83%89%E3%81%AB%E3%81%AF10k%CE%A9%E3%81%AE%E6%8A%B5%E6%8A%97%E3%81%8C%E5%BC%95%E3%81%8B%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E5%85%A5%E5%8A%9B%E3%81%AE%E7%B2%BE%E5%BA%A6ADV7391%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E6%8E%A5%E7%B6%9A%E3%81%AE%E6%8F%90%E6%A1%88%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%AC%E5%BD%93%E3%81%AB%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%AA%E3%83%90%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%80%8Cr13.4.1_bt656_output_patch_2013-09-04.zip%E3%80%8D%E3%81%A73%E3%81%A4%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E7%A7%81%E3%81%AF%E3%81%BE%E3%81%A0adv7391%E3%82%92%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E9%81%A9%E5%88%87%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%82%A4%E3%83%9E%E3%83%AA%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AFLCD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81IPU1%20DI0(DISP0)%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97ADV7391%20IPU1%20DI1%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%8B%E3%82%89DISP1%E3%81%AE%E3%83%91%E3%83%83%E3%83%89%E5%AE%9A%E7%BE%A9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82IOMUX%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A8iomux-mx6dl.h%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%ABADV7391%E3%83%91%E3%83%83%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EADV7391%E3%82%92%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E8%B5%B7%E5%8B%95%E7%92%B0%E5%A2%83%E3%81%8C%E9%81%A9%E5%88%87%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E7%92%B0%E5%A2%83%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%20%22video%3Dmxcfb0%3Adev%3Dadv739x%2CBT656-NTSC%2Cif%3DBT656%2Cfbpix%3DUYVY16%22%3B%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81ADV7391%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%80%8Cmxc_sdc_fb%20mxc_sdc_fb.0%3ATimeout%20When%20Waiting%20for%20Flip%20IRQ%E3%80%8D%E3%81%8C%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%AB%E6%8A%95%E7%A8%BF%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EIPU1_DI1_DISP_CLK%E3%81%A7%E3%81%AF%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%87%BA%E5%8A%9B%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%9A%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E3%80%813.3V%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%8B%E6%B8%AC%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EADV7391%E8%A8%AD%E5%AE%9A%3A%3C%2FP%3E%3CP%3E%E9%9D%99%E7%9A%84%E6%A7%8B%E9%80%A0%E4%BD%93%20fsl_mxc_lcd_platform_data%20adv739x_data%20%3D%20%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%20.ipu_id%20%3D%200%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20.disp_id%20%3D%201%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20.default_ifmt%20%3D%20IPU_PIX_FMT_BT656%2C%3C%2FP%3E%3CP%3E%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EADV7391%20IOMUX%3A%3C%2FP%3E%3CTABLE%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%3C%2FTD%3E%3CTD%3E%2F*%20ipu1%20di1%20%3A%3A%20CVBS%20out%20*%2F%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3C%2FTD%3E%3CTD%3EMX6DL_PAD_GPIO_18__GPIO_7_13%2C%3C%2FTD%3E%3CTD%3E%3C%2FTD%3E%3CTD%3E%3C%2FTD%3E%3CTD%3E%3C%2FTD%3E%3CTD%3E%3C%2FTD%3E%3CTD%3E%3C%2FTD%3E%3CTD%3E%2F*%20CVBS_OUT_RST%20*%2F%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3C%2FTD%3E%3CTD%3EMX6DL_PAD_EIM_A16__IPU1_DI1_DISP_CLK%E3%80%81%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3C%2FTD%3E%3CTD%3EMX6DL_PAD_EIM_D29__IPU1_DI1_PIN15%E3%80%81%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3C%2FTD%3E%3CTD%3EMX6DL_PAD_EIM_EB3__IPU1_DI1_PIN3%E3%80%81%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3C%2FTD%3E%3CTD%3EMX6DL_PAD_EIM_DA9__IPU1_DISP1_DAT_0%2C%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3C%2FTD%3E%3CTD%3EMX6DL_PAD_EIM_DA8__IPU1_DISP1_DAT_1%2C%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3C%2FTD%3E%3CTD%3EMX6DL_PAD_EIM_DA7__IPU1_DISP1_DAT_2%2C%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3C%2FTD%3E%3CTD%3EMX6DL_PAD_EIM_DA6__IPU1_DISP1_DAT_3%2C%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3C%2FTD%3E%3CTD%3EMX6DL_PAD_EIM_DA5__IPU1_DISP1_DAT_4%2C%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3C%2FTD%3E%3CTD%3EMX6DL_PAD_EIM_DA4__IPU1_DISP1_DAT_5%2C%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3C%2FTD%3E%3CTD%3EMX6DL_PAD_EIM_DA3__IPU1_DISP1_DAT_6%2C%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3C%2FTD%3E%3CTD%3EMX6DL_PAD_EIM_DA2__IPU1_DISP1_DAT_7%2C%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E7%9B%AE%E6%A8%99%E3%81%AF%E3%80%81LCD%E3%82%92%E3%83%97%E3%83%A9%E3%82%A4%E3%83%9E%E3%83%AA%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81ADV7391%E3%82%92%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E5%87%BA%E5%8A%9B%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%8B%E6%8F%90%E6%A1%88%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%AA%E3%83%90%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125700%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125700%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EL3.0.35_4.0.0_130424_source%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20MCIMX6Q-SDP%20%E7%94%A8%E3%81%AE%E5%90%8C%E6%A7%98%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3FBSP%E3%81%AF%E3%80%8C%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%E3%80%8DBT656%2F1120%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%88%E3%82%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125696%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125696%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EiMX6%20Solo%20for%20Android%E3%83%93%E3%83%AB%E3%83%89r656.4.1%E3%81%AE%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EBT656%E5%87%BA%E5%8A%9B%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FSPAN%3E%20%E3%81%AE%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF%E3%81%A9%E3%81%86%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C2013-08-09%E3%81%ABLinux%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E5%90%8C%E6%A7%98%E3%81%ABAndroid%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E7%A7%81%E3%81%AF%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E6%8E%98%E3%82%8A%E4%B8%8B%E3%81%92%E3%81%A6%E3%80%81%E8%87%AA%E5%88%86%E3%81%A7r13.4.1%E3%82%92%E6%94%B9%E8%A8%82%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%83%97%E3%83%A9%E3%82%A4%E3%83%9E%E3%83%AA%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A8%E3%81%97%E3%81%A6LCD%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81ADV7391%202%E7%95%AA%E7%9B%AE%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%81r13.4.1%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81LCD%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%8C%E6%8A%BC%E3%81%97%E3%81%A4%E3%81%B6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C2013-04-15%E3%81%A7%E8%BF%B0%E3%81%B9%E3%81%9F%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3EIOMUX%20%E8%A8%AD%E5%AE%9AADV7391%3A%3C%2FP%3E%0A%3CTABLE%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%3E%3C%2FTD%3E%0A%3CTD%3EMX6DL_PAD_EIM_A16__IPU1_DI1_DISP_CLK%E3%80%81%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3C%2FTD%3E%0A%3CTD%3EMX6DL_PAD_EIM_D29__IPU1_DI1_PIN15%E3%80%81%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3C%2FTD%3E%0A%3CTD%3EMX6DL_PAD_EIM_EB3__IPU1_DI1_PIN3%E3%80%81%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3C%2FTD%3E%0A%3CTD%3EMX6DL_PAD_EIM_DA9__IPU1_DISP1_DAT_0%2C%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3C%2FTD%3E%0A%3CTD%3EMX6DL_PAD_EIM_DA8__IPU1_DISP1_DAT_1%2C%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3C%2FTD%3E%0A%3CTD%3EMX6DL_PAD_EIM_DA7__IPU1_DISP1_DAT_2%2C%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3C%2FTD%3E%0A%3CTD%3EMX6DL_PAD_EIM_DA6__IPU1_DISP1_DAT_3%2C%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3C%2FTD%3E%0A%3CTD%3EMX6DL_PAD_EIM_DA5__IPU1_DISP1_DAT_4%2C%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3C%2FTD%3E%0A%3CTD%3EMX6DL_PAD_EIM_DA4__IPU1_DISP1_DAT_5%2C%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3C%2FTD%3E%0A%3CTD%3EMX6DL_PAD_EIM_DA3__IPU1_DISP1_DAT_6%2C%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3C%2FTD%3E%0A%3CTD%3EMX6DL_PAD_EIM_DA2__IPU1_DISP1_DAT_7%2C%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%AA%E3%83%90%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Arial%2C%20Helvetica%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3EHi%20Qiang%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Arial%2C%20Helvetica%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Arial%2C%20Helvetica%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%80%81Android%204.2%20BSP%E3%81%A8iMX.6%20DL%E3%81%8A%E3%82%88%E3%81%B3iMX.6%20Solo%20SOC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E8%87%AA%E5%8B%95%E8%BB%8A%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Arial%2C%20Helvetica%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3Eldb%E3%82%92%E3%83%97%E3%83%A9%E3%82%A4%E3%83%9E%E3%83%AA%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81bt656%E3%82%92%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%89%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125690%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125690%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81adv7391%E3%81%B8%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AF%E8%89%AF%E5%A5%BD%E3%81%A7%E3%81%99%E3%80%82%E4%BB%8A%E3%80%81%E7%A7%81%E3%81%AFHDMI%E3%81%A8BT656%E3%81%AE%E4%B8%A1%E6%96%B9%E3%82%92adv7391%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%A7%E8%A8%80%E3%82%8F%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81HDMI%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8FBT656%E3%81%8C%E5%B8%B8%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%20uboot%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AF%E5%90%8C%E3%81%98%E3%81%BE%E3%81%BE%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3Euboot%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AE%E5%BE%8C%E3%81%ABvideo%3Dmxcfb2%3Adev%3Dhdmi%2C1920x1080M%4050%2Cif%3DRGB24%E3%82%82%E5%85%A5%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81ADV%E3%81%A0%E3%81%91%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%8B%E6%8F%90%E6%A1%88%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3EBT656%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%A2%E3%83%BC%E3%83%89%3C%2FSPAN%3E%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%8C%E6%AC%B2%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%81%84%E3%81%A4%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1125686%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20BSP%E3%81%AEBT656%E3%81%8A%E3%82%88%E3%81%B3BT1120%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125686%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Qiang%2C%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92iMX6dl%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%20%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎02-01-2013 12:22 AM
更新者:
