Matter Zigbee Bridge ---base on i.MX MPU and K32W
Traditional non-matter devices cannot directly join the matter network. But Matter Bridge solves the problem. Matter bridge can join a Matter network as a Matter device and nonmatter devices need to be mapped to Matter network as a dynamic endpoint. In this way,
other Matter devices can communicate with non-matter devices through dynamic endpoints.
The Guide is a Matter Zigbee Bridge implement based on i.MX93 + K32W0.
Feature List
• Matter over Ethernet
• Matter over Wi-Fi
• Register and Remove Zigbee Deivces
• Connect Zigbee devices into Matter ecosystem seamlessly
• Zigbee Devices o OnOff cluster o Temperature Sensor Cluster
• Matter Actions o Start Zigbee Network o Zigbee Network Permit Join o Factory Reset
• No limitation if migrating to other i.MX MPU like i.MX6ULL, i.MX8MP
• OTBR and Zigbee bridge can be integrated into one single device
添付
評価なし
バージョン履歴
最終更新日:
‎11-23-2023 01:53 AM
更新者:
