How to support exFAT in i.MX6DQ Linux release
Development environment: i.MX6Q SabreSD w/ L3.0.35_1.1.0_121218 release.
Quoting from Wikipedia about exFAT (exFAT - Wikipedia, the free encyclopedia) as following:
exFAT (Extended File Allocation Table) is a Microsoft file system optimized for flash drives.[3] It is proprietary and patent-pending.[1] It is supported in Windows XP and Windows Server 2003 with update KB955704,[2] Windows Embedded CE 6.0, Windows Vista with Service Pack 1,[4] Windows Server 2008,[5] Windows 7, Windows 8, Windows Server 2008 R2 (except Windows Server 2008 Server Core), Mac OS X Snow Leopard starting from 10.6.5,[6] Mac OS X Lion and OS X Mountain Lion.
The history of support exFAT in Linux was since from 2.6.x, it involves several parts that will be described followingly.
Part 1: Linux Kernel
           Enable FUSE (Filesystem in userspace) feature in Kernel Config, then build a new uImage and module if set it to be "M";
Part 2: fuse-2.9.2.tar.gz
           Download fuse-2.9.2.tar.gz from http://sourceforge.net/projects/fuse/files/fuse-2.X/, untar it, then build it with following commands:
./configure --prefix=/home/alanz/i.MX6_L3.0.35_121218/ltib/rootfs/usr --host=`/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi-gcc -dumpmachine` --enable-lib --enable-util --enable-example --exec-prefix=/home/alanz/i.MX6_L3.0.35_121218/ltib/rootfs/usr
make
sudo make install
Part 3: exfat-utils-1.0.1.tar.gz
           Download exfat-utils-1.0.1.tar.gz from http://code.google.com/p/exfat/downloads/list, untar it, then build it with following command:
sudo scons SYSROOT=/home/alanz/i.MX6_L3.0.35_121218/ltib/rootfs DESTDIR=/home/alanz/i.MX6_L3.0.35_121218/ltib/rootfs/sbin CC=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi-gcc AR=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi-ar RANLIB=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi-ranlib STRIP=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi-strip install
Part 4: fuse-exfat.git
git clone git://sources.progress-linux.org/git/releases/baureo-backports/packages/fuse-exfat.git  fuse-exfat.git
cd fuse-exfat.git
Replace the root SConstruct with the attached one, then execute command:
After all above steps done, you can check whether the necessary files under your rootfs like I did as following:
http://en.wikipedia.org/wiki/ExFAT#cite_note-uspatent-2alanz@alanz-VirtualBox:~/i.MX6_L3.0.35_121218/ltib$ find ./rootfs/ -name *exfat*./rootfs/sbin/exfatlabel
./rootfs/sbin/mount.exfat
./rootfs/sbin/fsck.exfat
./rootfs/sbin/dumpexfat
./rootfs/sbin/exfatfsck
./rootfs/sbin/mount.exfat-fuse
./rootfs/sbin/mkexfatfs
./rootfs/sbin/mkfs.exfat
alanz@alanz-VirtualBox:~/i.MX6_L3.0.35_121218/ltib$ find ./rootfs/ -name *fuse*./rootfs/usr/include/fuse
./rootfs/usr/include/fuse/fuse_common_compat.h
./rootfs/usr/include/fuse/fuse_compat.h
./rootfs/usr/include/fuse/fuse_lowlevel_compat.h
./rootfs/usr/include/fuse/fuse_opt.h
./rootfs/usr/include/fuse/fuse_lowlevel.h
./rootfs/usr/include/fuse/fuse.h
./rootfs/usr/include/fuse/fuse_common.h
./rootfs/usr/include/fuse.h
./rootfs/usr/src/linux/include/linux/fuse.h
./rootfs/usr/lib/libfuse.so
./rootfs/usr/lib/libfuse.a
./rootfs/usr/lib/libfuse.so.2.9.2
./rootfs/usr/lib/libfuse.la
Check Steps can be referenced by the steps presented on internet.
NOTE: The directory name "/home/alanz/i.MX..." should be revised per your self development environment.
添付
%3CLINGO-SUB%20id%3D%22lingo-sub-1111868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6DQ%20Linux%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A7exFAT%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%96%8B%E7%99%BA%E7%92%B0%E5%A2%83%3Ai.MX6Q%20SabreSD%20w%2F%20L3.0.35_1.1.0_121218%E8%A7%A3%E6%94%BE%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EexFAT%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E3%82%A6%E3%82%A3%E3%82%AD%E3%83%9A%E3%83%87%E3%82%A3%E3%82%A2%E3%81%8B%E3%82%89%E3%81%AE%E5%BC%95%E7%94%A8(%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FExFAT%22%20title%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FExFAT%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EexFAT%20-%20Wikipedia%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E7%99%BE%E7%A7%91%E4%BA%8B%E5%85%B8%3C%2FA%3E)%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3EexFAT(%3C%2FSTRONG%3E%20%3CSTRONG%3EExtended%20File%20Allocation%20Table)%E3%81%AF%E3%80%81%3C%2FSTRONG%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFlash_drive%22%20title%3D%22%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%3C%2FA%3E%20%E7%94%A8%E3%81%AB%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%20%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FMicrosoft%22%20title%3D%22Microsoft%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMicrosoft%3C%2FA%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile_system%22%20title%3D%22%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FA%3E%3CSUP%20class%3D%22reference%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FExFAT%23cite_note-flash-format-4%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20%E3%81%A7%E3%81%99%E3%80%82%5B3%5D%3C%2FA%3E%3C%2FSUP%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FProprietary_format%22%20title%3D%22%E7%8B%AC%E8%87%AA%E3%81%AE%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%81%93%E3%82%8C%E3%81%AF%E7%8B%AC%E8%87%AA%E3%81%AE%3C%2FA%3E%E3%82%82%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%3CA%20class%3D%22mw-redirect%22%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FPatent-pending%22%20title%3D%22%E7%89%B9%E8%A8%B1%E5%87%BA%E9%A1%98%E4%B8%AD%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E7%89%B9%E8%A8%B1%E5%87%BA%E9%A1%98%E4%B8%AD%3C%2FA%3E%E3%81%A7%E3%81%99%E3%80%82%3CSUP%20class%3D%22reference%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FExFAT%23cite_note-uspatent-2%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%5B1%5D%3C%2FA%3E%3C%2FSUP%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FWindows_XP%22%20title%3D%22Windows%20XP%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EWindows%20XP%3C%2FA%3E%20%E3%81%8A%E3%82%88%E3%81%B3%20%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FWindows_Server_2003%22%20title%3D%22Windows%20Server%202003%20%E3%81%AE%E5%A0%B4%E5%90%88%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EWindows%20Server%202003%3C%2FA%3E%20(Update%20KB955704%3CSUP%20class%3D%22reference%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FExFAT%23cite_note-xpkb-3%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%5B2%5D%3C%2FA%3E%3C%2FSUP%3E%E3%80%81%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FWindows_Embedded_CE_6.0%22%20title%3D%22Windows%20Embedded%20CE%206.0%20(%E8%8B%B1%E8%AA%9E)%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EWindows%20Embedded%20CE%206.0%3C%2FA%3E%E3%80%81%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FWindows_Vista%23Service_Pack_1%22%20title%3D%22Windows%20Vista%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EWindows%20Vista%20Service%20Pack%201%3C%2FA%3E%3CSUP%20class%3D%22reference%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FExFAT%23cite_note-5%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%5B4%5D%E3%80%81%3C%2FA%3E%3C%2FSUP%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FWindows_Server_2008%22%20title%3D%22%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%82%BA%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%202008%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EWindows%20Server%202008%3C%2FA%3E%3CSUP%20class%3D%22reference%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FExFAT%23cite_note-Server2008exFATsupport-6%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%5B5%5D%3C%2FA%3E%3C%2FSUP%3E%E3%80%81%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FWindows_7%22%20title%3D%22%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%82%BA%207%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EWindows%207%3C%2FA%3E%E3%80%81%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FWindows_8%22%20title%3D%22Windows%208%E3%81%AE%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EWindows%208%3C%2FA%3E%E3%80%81%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FWindows_Server_2008_R2%22%20title%3D%22Windows%20Server%202008%20R2%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EWindows%20Server%202008%20R2%3C%2FA%3E%20(Windows%20Server%202008%20Server%20Core%20%E3%82%92%E9%99%A4%E3%81%8F)%E3%80%81%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FMac_OS_X_Snow_Leopard%22%20title%3D%22Mac%20OS%20X%20Snow%20Leopard%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMac%20OS%20X%20Snow%20Leopard%3C%2FA%3E%2010.6.5%20%E4%BB%A5%E9%99%8D%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%82%8B%3CSUP%20class%3D%22reference%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FExFAT%23cite_note-7%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%5B6%5D%E3%80%82%3C%2FA%3E%3C%2FSUP%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FMac_OS_X_Lion%22%20title%3D%22Mac%20OS%20X%20Lion(Mac%20OS%20X%20Lion)%20%E3%81%AE%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMac%20OS%20X%20Lion%3C%2FA%3E%20%E3%81%8A%E3%82%88%E3%81%B3%20%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FOS_X_Mountain_Lion%22%20title%3D%22OS%20X%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%86%E3%83%B3%E3%83%A9%E3%82%A4%E3%82%AA%E3%83%B3%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EOS%20X%20Mountain%20Lion%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELinux%E3%81%A7%E3%81%AEexFAT%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E6%AD%B4%E5%8F%B2%E3%81%AF2.6.x%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%A7%E8%AA%AC%E6%98%8E%E3%81%99%E3%82%8B%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E9%83%A8%E5%88%86%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPart%201%3A%20Linux%20Kernel%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%B0%E3%81%A7FUSE(Filesystem%20in%20userspace)%E6%A9%9F%E8%83%BD%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%80%81%E6%96%B0%E3%81%97%E3%81%84uImage%E3%81%A8%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%8C%E3%80%8CM%E3%80%8D%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%BC%E3%83%882%3Afuse-2.9.2.tar.gz%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fsourceforge.net%2Fprojects%2Ffuse%2Ffiles%2Ffuse-2.X%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fsourceforge.net%2Fprojects%2Ffuse%2Ffiles%2Ffuse-2.X%2F%3C%2FA%3E%3CSPAN%3E%20%E3%81%8B%E3%82%89%20fuse-2.9.2.tar.gz%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%20%E3%80%81%E8%A7%A3%E5%87%8D%E3%81%97%E3%81%A6%E3%80%81%20%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E.%2Fconfigure%20--prefix%3D%2Fhome%2Falanz%2Fi.MX6_L3.0.35_121218%2Fltib%2Frootfs%2Fusr%20--host%3D'%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%2Ffsl-linaro-toolchain%2Fbin%2Farm-none-linux-gnueabi-gcc%20-dumpmachine'%20--enable-lib%20--enable-util%20--enable-example%20--exec-prefix%3D%2Fhome%2Falanz%2Fi.MX6_L3.0.35_121218%2Fltib%2Frootfs%2Fusr%3C%2FP%3E%3CP%3E%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3Esudo%E3%83%A1%E3%82%A4%E3%82%AF%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPart%203%3A%20exfat-utils-1.0.1.tar.gz%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fcode.google.com%2Fp%2Fexfat%2Fdownloads%2Flist%22%20title%3D%22http%3A%2F%2Fcode.google.com%2Fp%2Fexfat%2Fdownloads%2Flist%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fcode.google.com%2Fp%2Fexfat%2Fdownloads%2Flist%3C%2FA%3E%20%E3%81%8B%E3%82%89exfat-utils-1.0.1.tar.gz%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E8%A7%A3%E5%87%8D%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Esudo%20scons%20SYSROOT%3D%2Fhome%2Falanz%2Fi.MX6_L3.0.35_121218%2Fltib%2Frootfsdestdir%3D%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Falanz%2Fi.mx6_l3.0.35_121218%2FLTIB%2Frootfs%2FSBINCC%3D%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%2Ffsl-linaro-toolchain%2Fbin%2Farm-none-linux-gnueabi-gcc%20AR%3D%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%2Ffsl-linaro-toolchain%2Fbin%2Farm-none-linux-gnueabi-ar%20RANLIB%3D%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%2Ffsl-linaro-toolchain%2Fbin%2Farm-none-linux-gnueabi-ranlib%20STRIP%3D%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%20%2F%20FSL%20-linaro-toolchain%20%2F%20bin%20%2F%20arm-none-linux-gnueabi-strip%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%BC%E3%83%88%204%3A%20fuse-exfat.git%3C%2FP%3E%3CP%3Egit%20clone%20git%3A%2F%2Fsources.progress-linux.org%2Fgit%2Freleases%2Fbaureo-backports%2Fpackages%2Ffuse-exfat.git%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA-%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%95%E3%82%A1%E3%83%83%E3%83%88.git%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3Ecd%20fuse-exfat.git%3C%2FP%3E%3CP%3E%E3%83%AB%E3%83%BC%E3%83%88%20SConstruct%20%E3%82%92%E3%82%A2%E3%82%BF%E3%83%83%E3%83%81%E3%81%95%E3%82%8C%E3%81%9F%E3%82%82%E3%81%AE%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%A6%E3%81%8B%E3%82%89%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Esudo%20scons%20SYSROOT%3D%2Fhome%2Falanz%2Fi.MX6_L3.0.35_121218%2Fltib%2Frootfsdestdir%3D%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Falanz%2Fi.mx6_l3.0.35_121218%2FLTIB%2Frootfs%2FSBINCC%3D%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%2Ffsl-linaro-toolchain%2Fbin%2Farm-none-linux-gnueabi-gcc%20AR%3D%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%2Ffsl-linaro-toolchain%2Fbin%2Farm-none-linux-gnueabi-ar%20RANLIB%3D%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%2Ffsl-linaro-toolchain%2Fbin%2Farm-none-linux-gnueabi-ranlib%20STRIP%3D%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%20%2F%20FSL%20-linaro-toolchain%20%2F%20bin%20%2F%20arm-none-linux-gnueabi-strip%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%ABrootfs%E3%81%AE%E4%B8%8B%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FExFAT%23cite_note-uspatent-2%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fen.wikipedia.org%2Fwiki%2FExFAT%23cite_note-uspatent-2%3C%2FA%3Ealanz%40alanz-VirtualBox%3A~%2Fi.MX6_L3.0.35_121218%2Fltib%24%20find%20.%2Frootfs%2F-%E5%90%8D%E5%89%8D*exfat*%E3%80%82%2Frootfs%2Fsbin%2Fexfatlabel%20%3CBR%20%2F%3E.%2Frootfs%2Fsbin%2Fmount.exfat%3CBR%20%2F%3E.%2Frootfs%2Fsbin%2Ffsck.exfat%3CBR%20%2F%3E.%2Frootfs%2Fsbin%2Fdumpexfat%3CBR%20%2F%3E.%2Frootfs%2Fsbin%2Fexfatfsck%3CBR%20%2F%3E.%2Frootfs%2Fsbin%2Fmount.exfat-fuse%3CBR%20%2F%3E.%2Frootfs%2Fsbin%2Fmkexfatfs%3CBR%20%2F%3E.%2Frootfs%2Fsbin%2Fmkfs.exfat%3CBR%20%2F%3Ealanz%40alanz-VirtualBox%3A~%2Fi.MX6_L3.0.35_121218%2Fltib%24%20find%20.%2Frootfs%2F-name%20*fuse*.%2Frootfs%2Fusr%2Finclude%2Ffuse%3CBR%20%2F%3E.%2Frootfs%2Fusr%2Finclude%2Ffuse%2Ffuse_common_compat.h%3CBR%20%2F%3E.%2Frootfs%2Fusr%2Finclude%2Ffuse%2Ffuse_compat.h%3CBR%20%2F%3E.%2Frootfs%2Fusr%2Finclude%2Ffuse%2Ffuse_lowlevel_compat.h%3CBR%20%2F%3E.%2Frootfs%2Fusr%2Finclude%2Ffuse%2Ffuse_opt.h%3CBR%20%2F%3E.%2Frootfs%2Fusr%2Finclude%2Ffuse%2Ffuse_lowlevel.h%3CBR%20%2F%3E.%2Frootfs%2Fusr%2Finclude%2Ffuse%2Ffuse.h%3CBR%20%2F%3E.%2Frootfs%2Fusr%2Finclude%2Ffuse%2Ffuse_common.h%3CBR%20%2F%3E.%2Frootfs%2Fusr%2Finclude%2Ffuse.h%3CBR%20%2F%3E.%2Frootfs%2Fusr%2Fsrc%2Flinux%2Finclude%2Flinux%2Ffuse.h%3CBR%20%2F%3E.%2Frootfs%2Fusr%2Flib%2Flibfuse.so%3CBR%20%2F%3E.%2Frootfs%2Fusr%2Flib%2Flibfuse.a%3CBR%20%2F%3E.%2Frootfs%2Fusr%2Flib%2Flibfuse.so.2.9.2%3CBR%20%2F%3E.%2Frootfs%2Fusr%2Flib%2Flibfuse.la%3CBR%20%2F%3E.%2Frootfs%2Fusr%2Flib%2Flibfuse.so.2%3CBR%20%2F%3E.%2Frootfs%2Fsbin%2Fmount.exfat-fuse%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECheck%20Steps%E3%81%AF%E3%80%81%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%8D%E3%83%83%E3%83%88%E4%B8%8A%E3%81%A7%E6%8F%90%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%A7%E5%8F%82%E7%85%A7%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%B3%A8%3A%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E5%90%8D%E3%80%8C%2Fhome%2Falanz%2Fi.MX...%E3%80%8D%E3%81%AF%E3%80%81%E8%87%AA%E5%B7%B1%E9%96%8B%E7%99%BA%E7%92%B0%E5%A2%83%E3%81%94%E3%81%A8%E3%81%AB%E6%94%B9%E8%A8%82%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎05-21-2013 07:06 AM
更新者:
