How to enable BT on i.MX 6SoloLite EVK Board
Search instead for
No ratings
Here is the explaination of relationship of SD-CAN, SD-MAN, 6233, 6003, 3002:
  • AR6003 + AR3002 = AR6233
  • AR6233 + RF Components = SX-SDMAN-2830S
  • SX-SDMAN-2830S + SDIO CONN = SX-SDCAN-2830BT
  • SX-SDCAN-2830BT card is inserted into SD3 slot.
  • BT adaptor board (attached files) is inserted into SD1 slot.
  • SX-SDCAN-2830BT card is connected with BT adaptor board via 20-pin FFC.
  • Software: signals of SD1 are muxed into UART4 and GPIO for BT application.
Below is the description of IO mux on SD1:
Comments
Beiduo, could ths document be moved to public community, so that everyone could share?
Yixing
dear beiduo:
      can you  introduction these link like LCD-27839_A.doc todo something。
del , Hello -
Taking the below link into account , do we need such hardware changes to do in the SoloLite EVK , ?
How to enable BT on board imx6q_sabresd RevC.
Let me know your views on this.
--Pankaj Rana
del
Hi pankajrana,
No HW rework is need on SL EVK board.
You just need the additional "BT adaptor board" and proper S/W.
del
Hi Yixing,
I think this doc can be public for all.
del
Hi Issta,
Sorry I don't quite understand your meaning......
Version history
Revision #:
1 of 1
Last update:
‎06-21-2013 01:44 AM
Updated by:
