How to change I2S from Slave to Master mode on IMX51
Current the SSI is set to I2S slave mode in FSL default release BSP.
attached the code for how to set it to master mode.
ラベル(2)
添付
評価なし
バージョン履歴
最終更新日:
‎09-04-2013 06:03 AM
更新者:
