How to Use Trace32 to Run U-boot in the i.MX6Q SABRE Platform
The document in attachment describes how to learn System Boot Flow of Linux by code using Trace32.
The hardware platform is i.MX6Q SABRE and the software in PC is Trace32.
Contents
1. Introduction
2. Hardware Connection
3. Serial Connection Setup
4. U-boot Directory Setup
5. Trace32 Installation & U-boot Debugging
添付
コメント
Hi, Kane
Step by step according to the "Trace32 Basic Tutorial"
where to download attach script.zip (include "Trace32 and attach script should be downloaded from the server")
thanks
Hi Lei Zhang,
Is your platform i.MX6Q SABRE board?
Hi kane Jiang,
My board is i.MX6Q SABRE.
Hi Lei Zhang,
I attached the script file in the attachment, you can have a try.
Hi Kane Jiang,
Very good, it's well work. thank you!
You are welcome.
評価なし
バージョン履歴
最終更新日:
‎08-08-2016 11:53 PM
更新者:
