MAX resolution 1024 x 768 Factory Details: Long name: Freescale: Hardware (VPU) Encoder Class: Codec/Encoder/Video Description: Encodes raw YUV 4:2:0 data to MPEG4 SP, H.264 BP or H.263 (Annex J, K (RS=0 and ASO=0) and T) elementary data;Enco des raw YUV 4:2:0, 4:2:2 horizontal, 4:2:2 vertical or 4:0:0 data into MJPEG elementary data; Author(s): Multimedia Team <shmmmw@freescale.com> Rank: primary (256) Plugin Details: Name: mfw_vpuencoder Description: Encodes Raw YUV Data to MPEG4 SP, H.264 BP or H.263 data. For H.263 P0, the source frame rate must be 3000 0/1001 fps Filename: /usr/lib/gstreamer-0.10/libmfw_gst_vpu_enc.so Version: 2.0.2 License: unknown Source module: gst-fsl-plugin Binary package: Gstreamer Multimedia Plugins (Freescale) Origin URL: http://www.freescale.com GObject +----GstObject +----GstElement +----MfwGstVPU_Enc Pad Templates: SINK template: 'sink' Availability: Always Capabilities: video/x-raw-yuv format: I420 width: [ 48, 8192 ] height: [ 32, 8192 ] video/x-raw-yuv format: YV12 width: [ 48, 8192 ] height: [ 32, 8192 ] video/x-raw-yuv format: NV12 width: [ 48, 8192 ] height: [ 32, 8192 ] video/x-raw-yuv format: Y42B width: [ 48, 8192 ] height: [ 32, 8192 ] video/x-raw-yuv format: Y444 width: [ 48, 8192 ] height: [ 32, 8192 ] SRC template: 'src' Availability: Always Capabilities: video/mpeg width: [ 48, 1280 ] height: [ 32, 720 ] mpegversion: 4 systemstream: false video/x-h263 width: [ 48, 1280 ] height: [ 32, 720 ] video/x-h264 width: [ 48, 1280 ] height: [ 32, 720 ] image/jpeg width: [ 48, 8192 ] height: [ 32, 8192 ] Element Flags: no flags set Element Implementation: Has change_state() function: 0x2b01c98c Has custom save_thyself() function: gst_element_save_thyself Has custom restore_thyself() function: gst_element_restore_thyself Element has no clocking capabilities. Element has no indexing capabilities. Element has no URI handling capabilities. Pads: SRC: 'src' Implementation: Pad Template: 'src' SINK: 'sink' Implementation: Has chainfunc(): 0x2b01de28 Has custom eventfunc(): mfw_gst_vpuenc_sink_event Has bufferallocfunc(): mfw_gst_vpuenc_buffer_alloc Pad Template: 'sink' Element Properties: name : The name of the object flags: readable, writable String. Default: null Current: "mfwgstvpu_enc0" codec-type : selects the codec type for encoding flags: readable, writable Enum "MfwGstVpuEncCodecs" Default: 2, "std_avc" Current: 2, "std_avc" (0): std_mpeg4 - STD_MPEG4 (1): std_h263 - STD_H263 (2): std_avc - STD_AVC (7): std_mjpg - STD_MJPG profile : enable time profile of the vpu encoder plug-in flags: readable, writable Boolean. Default: false Current: false width : width of the frame to be encoded flags: readable, writable Unsigned Integer. Range: 48 - 8192 Default: 48 Current: 0 height : height of the frame to be encoded flags: readable, writable Unsigned Integer. Range: 32 - 8192 Default: 32 Current: 0 bitrate : target bitrate (in kbps) at which stream is to be encoded - 0 for VBR and others for CBR flags: readable, writable Unsigned Integer. Range: 0 - 32767 Default: 0 Current: 32768 gopsize : gets the GOP size at which stream is to be encoded flags: readable, writable Unsigned Integer. Range: 0 - 32767 Default: 30 Current: 30 qp : gets the quantization parameter - range is 0-51 - will be ignored for CBR (bitrate!=0) flags: readable, writable Unsigned Integer. Range: 0 - 51 Default: 15 Current: 4294967295 max-qp : Maximum quantization parameter for CBR - range is 0-51 for H264 and 1-31 for MPEG4 - lower value brings be tter video quality but higher frame sizes flags: readable, writable Unsigned Integer. Range: 0 - 51 Default: 51 Current: 4294967295 min-qp : Minimum quantization parameter for CBR - range is 0-51 for H264 and 1-31 for MPEG4 - lower value brings be tter video quality but higher frame sizes flags: readable, writable Unsigned Integer. Range: 0 - 51 Default: 0 Current: 4294967295 gamma : gamma value for CBR - tells VPU the speed on changing qp - lower will cause better video quality flags: readable, writable Unsigned Integer. Range: 0 - 32768 Default: 24576 Current: 24576 intrarefresh : 0 - Intra MB refresh is not used. Otherwise - At least N MB's in every P-frame will be encoded as intra MB 's. flags: readable, writable Unsigned Integer. Range: 0 - 3600 Default: 0 Current: 0 h263profile0 : enable encoding of H.263 profile 0 when codec-type is set to std_h263 flags: readable, writable Boolean. Default: false Current: false loopback : disables parallelization for performance - turn off if pipeline with decoder flags: readable, writable Boolean. Default: true Current: true intra-qp : Quantization parameter for I frame. When this value is -1, the quantization parameter for I frames is auto matically determined by the VPU. In MPEG4/H.263 mode, the range is 1.C31; in H.264 mode, the range is from 0.C51. This is ignored for STD_MJPG flags: readable, writable Unsigned Integer. Range: 0 - 51 Default: 15 Current: 4294967295 crop-left : The left crop value of input frame to be encoded flags: readable, writable Unsigned Integer. Range: 0 - 4294967295 Default: 0 Current: 0 crop-top : The top crop value of input frame to be encoded flags: readable, writable Unsigned Integer. Range: 0 - 4294967295 Default: 0 Current: 0 crop-right : The right crop value of input frame to be encoded flags: readable, writable Unsigned Integer. Range: 0 - 4294967295 Default: 0 Current: 0 crop-bottom : The bottom crop value of input frame to be encoded flags: readable, writable Unsigned Integer. Range: 0 - 4294967295 Default: 0 Current: 0 rotation-angle : Pre-rotation angle - should be 0, 90, 180 or 270 flags: readable, writable Unsigned Integer. Range: 0 - 270 Default: 0 Current: 0 mirror-direction : mirror direction from source image to encoded image flags: readable, writable Enum "MfwGstVpuEncMirDir" Default: 0, "none " Current: 0, "none " (0): none - MIRDIR_NONE (1): vertical mirroring - MIRDIR_VER (2): horizontal mirroring - MIRDIR_HOR (3): both directions - MIRDIR_HOR_VER h264-byte-stream : Generate H.264 byte stream format of NALU. Take effect for H.264 stream only. flags: readable, writable Boolean. Default: true Current: true
