To enable USB 2.0 port on BB for USB OTG, you need to apply below two changes:
diff --git a/imx8q/mek_8q/init.usb.rc b/imx8q/mek_8q/init.usb.rc
index af4e388..0f3ab0b 100644
--- a/imx8q/mek_8q/init.usb.rc
+++ b/imx8q/mek_8q/init.usb.rc
@@ -44,7 +44,7 @@ on early-boot
mount functionfs mtp /dev/usb-ffs/mtp rmode=0770,fmode=0660,uid=1024,gid=1024,no_disconnect=1
mount functionfs ptp /dev/usb-ffs/ptp rmode=0770,fmode=0660,uid=1024,gid=1024,no_disconnect=1
setprop sys.usb.mtp.device_type 3
- setprop vendor.usb.config "5b110000.usb3"
+ setprop vendor.usb.config "ci_hdrc.0"
write /sys/module/libcomposite/parameters/disable_l1_for_hs "y"
symlink /config/usb_gadget/g1/configs/b.1 /config/usb_gadget/g1/os_desc/b.1
revert below patch:
commit 2f9586c120971312e61df464264993899cf34536
Author: yang.tian <yang.tian@nxp.com>
Date: Tue Jan 7 13:30:02 2020 +0800
MA-15242 Set usb2.0 port as usb host only for mek_8q
