Disable SD clock gated off for i.MX6
Some of SDIO cards need SD clock active for 4-bit mode, in order to generate interrupt.
But i.MX6 SD controller enables SD clock gated by default, the attached patch is an example to disable SD clock gated.
It's able to check if clock gated is enable or not by the register, "uSDHCx_PRES_STATE:SDOFF", of SD controller.
标签 (1)
附件
无评分
版本历史
最后更新:
‎09-12-2013 12:58 AM
更新人:
