We are pleased to announce that Config Tools for i.MX v15.0 are now available.
Full details on the release (features, known issues...)Version 15.0
• The product is based on Eclipse 2023-06
TEE
– Setting a security level for a special three-state model is improved.
Pins
– Validation to ensure that elements can be configured by the selected core is added.
– Rows are sorted in the Peripheral Signals routing dialog.
– A connected pins column in External User Signals always shows the pin's full name.
– The missing scroll bar in the External User Signals view is fixed.
Clocks
– Support for multicore code generation is added.
– Global configuration elements now support a tree structure and can be categorized.
– Fractional PLL now supports a custom range and negative numerator.
– Scrolling in the clock diagram by pressing the mouse wheel (drag and drop) is supported.
DCD
– The issue with the code generation that stopped working after the drag and drop of a group is fixed.
