Build Ubuntu For i.MX8 Series Platform
The Guide is how to use Ubuntu filesystem with i.MX8 series platform.At present, I had try it on i.MX8QXP with 4.14.98 kernel with ubuntu16.04.
The Document will be continuously updated with enable VPU, ubuntu18.04. The desktop we can chose Gnome or weston.  Because driver
support issue, gc7000 series gpu not support render Gnome destop but it can render weston destop.
Update 2019/7/31:
Ubuntu-i.MX8-weston.pdf
Feature:
  • weston + ubuntu18.04 + 4.14.98 kernel
  • VPU (enable with gplay or gst-play)
  • GPU (could render desktop and run GPU demo under root privileges on Weston Desktop)
I also try ubuntu with gnome desktop, ubuntu18.04 can not run gnome, need use ubuntu19.04. But Gnome Desktop just render by CPU.
Update 2020/3/6:
Ubuntu-i.MX8M.pdf
Just a simple guide for IMX8M series, will be  continuously updated.
タグ(1)
添付
コメント
Hi Gnar Fang,
       Thanks for the doc. Yes, i verified and added galcore module to auto load on startup. But unfortunately i am still not getting the desktop with the following error:
sudo -E weston --tty=1
Date: 2019-04-11 UTC
[17:00:10.607] weston 5.0.0
https://wayland.freedesktop.org
Bug reports to: https://gitlab.freedesktop.org/wayland/weston/issues/
Build: 5.0.0-33-gfb563901 MGS-4627 [#ccc] weston will turn off when panel-psotion=none and use gplay (2019-03-14 11:30:30 +0800)
[17:00:10.607] Command line: weston --tty=1
[17:00:10.607] OS: Linux, 4.19.35-1.1.0+g0f9917c56d59, #1 SMP PREEMPT Wed Oct 30 13:54:51 UTC 2019, aarch64
[17:00:10.608] warning: XDG_RUNTIME_DIR "/run/user/1001" is not configured
correctly. Unix access mode must be 0700 (current mode is 700),
and must be owned by the user (current owner is UID 1001).
Refer to your distribution on how to get it, or
http://www.freedesktop.org/wiki/Specifications/basedir-spec
on how to implement it.
[17:00:10.608] Starting with no config file.
[17:00:10.608] Output repaint window is 16 ms maximum.
[17:00:10.608] Loading module '/usr/lib/libweston-5/drm-backend.so'
[17:00:10.612] initializing drm backend
[17:00:10.614] using /dev/dri/card0
[17:00:10.614] DRM: supports universal planes
[17:00:10.614] DRM: supports atomic modesetting
[17:00:10.614] DRM: supports picture aspect ratio
[17:00:10.614] Loading module '/usr/lib/libweston-5/gl-renderer.so'
[17:00:10.626] EGL client extensions: EGL_EXT_client_extensions
EGL_EXT_platform_base EGL_KHR_platform_wayland
EGL_EXT_platform_wayland EGL_KHR_platform_gbm
[17:00:10.627] warning: neither EGL_EXT_swap_buffers_with_damage or EGL_KHR_swap_buffers_with_damage is supported. Performance could be affected.
[17:00:10.627] EGL_KHR_surfaceless_context available
[17:00:10.627] failed to create context
[17:00:10.627] EGL error state: EGL_BAD_ALLOC (0x3003)
[17:00:10.627] EGL error state: EGL_SUCCESS (0x3000)
[17:00:10.627] failed to initialize egl
Segmentation fault
Hi Gnar Fang,
            If i run weston --use-pixman then there is no issue with the display. This means HW acceleration is not working. This is due to the OpenGL ES driver issue or we need to enable HW acceleration during weston compilatio? Thanks
The issue is look like below.
1.warning: XDG_RUNTIME_DIR "/run/user/1001" is not configured correctly. Unix access mode must be 0700 (current mode is 700), and must be owned by the user (current owner is UID 1001).
2.[17:00:10.627] EGL error state: EGL_BAD_ALLOC (0x3003)
You can try it.
$ sudo su
XDG_RUNTIME_DIR =/run/user/1001
$ weston --tty=1
It is sure that need to enable HW acceleration during weston compilatio. which the config parameter in build weston? same as my guide?
Hi Gnar Fang,
              My apologies for the late reply. Yes, i did use the arguments as per the documents to build Weston/Wayland. Regarding the rUNTIME_DIR whatever the ownership/permission i change the warning message continues to exist. Thanks
Hi , I am not sure why cause it.  you can check if there are /usr/lib/aarch64-xx  libGLES, libEGL。if so, delete them.
Hi prashanth:
   How do you get this desktop? After I run "sudo -E weston --tty = 1", the displayed desktop is just the same as the yocto-wayland desktop. Does your system have apt-get install some software?
Tks~
HI :
yes, It' yocto-wayland desktop. If you want other desktop , you can try apt-get to install .
江亚强
软件工程师
Shenzhen Huameishi Technology Co., Ltd
深圳市华美视科技有限公司
深圳市南山区科苑路6号科技园工业大厦605
Tel:0755-26037882-616
Mail:[email protected]
Hi,Gnar Fang
Whether the GPU cannot be enabled as long as the Ubuntu file system is used?
It guide is support use GPU when running Ubuntu file system
In Ubuntu-i.MX8M.pdf ,I did not build weston in step 7 and I apt-get install lxqt.Use lxqt as the display desktop.I get follow results:
I have successfully loaded the gpu driver,But why no application uses gpu.When I do not use ubuntu filesyste,I get follow results:
have 26 apps uses gpu.
Please help me answer,thanks,have a nice day!
our GPU is support wayland only.
You should try build the desktop with source code and enable xwayland.
how to enable xwayland in lxqt.I can install gnome-wayland only.In lxqt desktopNo xwayland related configuration options.
you can refernce the yocto script to build xwayland.
But I am not sure if you use LXQT could use GPU, The best way,
you should build LXQT source code with our gpu driver instead of apt-get LXQT directly.
Hi Gnar,
I want weston auto load on device startup, where can I add weston --tty=1?
Refere to the yocto's  weston.ini file.
Hii PrashanthKumar
Could you please provide me the steps for solving the below problem which you also encountered while running  sudo -E weston --tty=1
[13:03:01.810] warning: XDG_RUNTIME_DIR "/run/user/1000" is not configured
correctly. Unix access mode must be 0700 (current mode is 755),
and must be owned by the user (current owner is UID 1000).
[13:03:01.817] Starting with no config file.
[13:03:01.821] Output repaint window is 16 ms maximum.
[13:03:01.822] Loading module '/usr/lib/libweston-5/drm-backend.so'
[13:03:01.830] Failed to load module: /usr/lib/libweston-5/drm-backend.so: undefined symbol: gbm_surface_get_in_fence_fd
[13:03:01.830] fatal: failed to create compositor backend
regards,
Abhijeet
Hi all,
I am following the guide for imx8mq guide for ubuntu 20.04,
I came across an error for building weson-imx, the error is as follows.
libweston/compositor-drm.c: In function ‘hdr10_metadata_set_metadata’:
libweston/compositor-drm.c:7250:29: error: storage size of ‘hdr_metadata’ isn’t known
struct hdr_static_metadata hdr_metadata;
This query is already posted on this thread by @prashanthkumar, but there was no solution posted for it. So how can I solve this problem
I believe the Google Coral Dev Board 4GB and ASUS Tinker Edge T both use the NXP i.MX 8M processor.
Hence, would the Ubuntu i.MX 8M PDF at the top of this chain be applicable?
Has this instruction been updated at all?
And has anyone done it/be interested in helping out? If possible, I'd be thinking go to the latest LTS of Ubuntu.
%3CLINGO-SUB%20id%3D%22lingo-sub-1128708%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128708%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AF%E3%80%81i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7Ubuntu%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E6%99%82%E7%82%B9%E3%81%A7%E3%81%AF%E3%80%814.14.98%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A8Ubuntu%2016.04%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9Fi.MX8QXP%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E3%80%81VPU%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%9Fubuntu18.04%E3%81%A7%E7%B6%99%E7%B6%9A%E7%9A%84%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%A7%E3%81%AFGnome%E3%81%BE%E3%81%9F%E3%81%AFweston%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AA%E3%81%AE%E3%81%A7%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E5%95%8F%E9%A1%8C%E3%80%81gc7000%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%AEGPU%E3%81%AFGnome%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%AE%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81Weston%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%AF%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUpdate%202019%2F7%2F31%3A%3C%2FP%3E%3CP%3EUbuntu-i.MX8-weston.pdf%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%E7%89%B9%E9%95%B7%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3Eweston%20%2B%20ubuntu18.04%20%2B%204.14.98%20kernel%3C%2FLI%3E%3CLI%3EVPU%EF%BC%88gplay%E3%81%BE%E3%81%9F%E3%81%AFgst-play%E3%81%A7%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%EF%BC%89%3C%2FLI%3E%3CLI%3EGPU%EF%BC%88%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%82%92%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%97%E3%80%81Weston%20Desktop%E3%81%AEroot%E6%A8%A9%E9%99%90%E3%81%A7GPU%E3%83%87%E3%83%A2%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%EF%BC%89%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81gnome%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%A7Ubuntu%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81Ubuntu18.04%E3%81%A7%E3%81%AFgnome%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81Ubuntu19.04%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81Gnome%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%AFCPU%E3%81%A7%E3%81%AE%E3%81%BF%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E-------------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E%3CSPAN%3EUpdate%202020%2F3%2F6%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EUbuntu-i.MX8M.pdf%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EIMX8M%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%AE%E7%B0%A1%E5%8D%98%E3%81%AA%E3%82%AC%E3%82%A4%E3%83%89%E3%81%A7%E3%81%99%E3%80%82%E7%B6%99%E7%B6%9A%E7%9A%84%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1128708%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%20%7C%20i.MX%208QuadMax%E2%80%AF(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1755142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1755142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%B0%E3%83%BC%E3%82%B0%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%A9%E3%83%AB%E3%83%87%E3%83%99%E3%83%AD%E3%83%83%E3%83%91%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%894GB%E3%81%A8ASUS%E3%83%86%E3%82%A3%E3%83%B3%E3%82%AB%E3%83%BC%E3%82%A8%E3%83%83%E3%82%B8T%E3%81%AF%E3%81%A9%E3%81%A1%E3%82%89%E3%82%82NXP%20i.MX%208M%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%81%93%E3%81%AE%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AE%E5%85%88%E9%A0%AD%E3%81%AB%E3%81%82%E3%82%8B%20Ubuntu%20i.MX%208M%20PDF%20%E3%81%AF%E9%81%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%8C%87%E7%A4%BA%E3%81%AF%E3%81%9D%E3%82%82%E3%81%9D%E3%82%82%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%82%92%E3%82%84%E3%81%A3%E3%81%9F%E6%96%B9%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%89%8B%E4%BC%9D%E3%81%86%E3%81%93%E3%81%A8%E3%81%AB%E8%88%88%E5%91%B3%E3%81%8C%E3%81%82%E3%82%8B%E6%96%B9%E3%81%AF%E3%81%84%E3%82%89%E3%81%A3%E3%81%97%E3%82%83%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81Ubuntu%E3%81%AE%E6%9C%80%E6%96%B0%E7%89%88LTS%E3%81%AB%E7%A7%BB%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1723118%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1723118%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%9A%86%E3%81%95%E3%82%93%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFUbuntu20.04%E7%94%A8%E3%81%AEimx8mq%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Eweson-imx%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E4%B8%AD%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3Elibweston%2Fcompositor-drm.c%3A%20%E9%96%A2%E6%95%B0%E3%80%8Chdr10_metadata_set_metadata%E3%80%8D%E3%81%A7%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Elibweston%2Fcompositor-drm.c%3A7250%3A29%3A%20%3C%2FSPAN%3E%3CSTRONG%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%80%8Chdr_metadata%E3%80%8D%E3%81%AE%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%E4%B8%8D%E6%98%8E%E3%81%A7%E3%81%99%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSPAN%3E%E6%A7%8B%E9%80%A0%E4%BD%93hdr_static_metadata%20hdr_metadata%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%82%AF%E3%82%A8%E3%83%AA%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F74139%22%20target%3D%22_blank%22%3E%40prashanthkumar%3C%2FA%3E%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%81%93%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%AB%E6%8A%95%E7%A8%BF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%81%BE%E3%81%A0%E6%8A%95%E7%A8%BF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%A7%E3%81%AF%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1719521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1719521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%97%E3%83%A9%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E3%82%AF%E3%83%9E%E3%83%BC%E3%83%AB%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3Esudo%20-E%20weston%20--tty%3D1%E3%81%AE%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%9F%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%5B13%3A03%3A01.810%5D%E8%AD%A6%E5%91%8A%EF%BC%9AXDG_RUNTIME_DIR%E3%80%8C%2Frun%2Fuser%2F1000%E3%80%8D%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3EUnix%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF0700%EF%BC%88%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF755%EF%BC%89%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%3CBR%20%2F%3E%E3%81%8B%E3%81%A4%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%8C%E6%89%80%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%88%E7%8F%BE%E5%9C%A8%E3%81%AE%E6%89%80%E6%9C%89%E8%80%85%E3%81%AFUID%201000%EF%BC%89%E3%80%82%3CBR%20%2F%3E%E5%85%A5%E6%89%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%3CA%20href%3D%22http%3A%2F%2Fwww.freedesktop.org%2Fwiki%2FSpecifications%2Fbasedir-spec%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.freedesktop.org%2Fwiki%2FSpecifications%2Fbasedir-spec%3C%2FA%3E%E3%81%9D%E3%82%8C%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%82%3CBR%20%2F%3E%5B13%3A03%3A01.817%5D%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%AA%E3%81%84%E7%8A%B6%E6%85%8B%E3%81%A7%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B13%3A03%3A01.821%5D%E5%87%BA%E5%8A%9B%E5%86%8D%E6%8F%8F%E7%94%BB%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%AE%E6%9C%80%E5%A4%A7%E5%80%A4%E3%81%AF16%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B13%3A03%3A01.822%5D%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%8C%2Fusr%2Flib%2Flibweston-5%2Fdrm-backend.so%E3%80%8D%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B13%3A03%3A01.830%5D%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20%2Fusr%2Flib%2Flibweston-5%2Fdrm-backend.so%3A%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AB%EF%BC%9Agbm_surface_get_in_fence_fd%3CBR%20%2F%3E%5B13%3A03%3A01.830%5D%E8%87%B4%E5%91%BD%E7%9A%84%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9A%E3%82%B3%E3%83%B3%E3%83%9D%E3%82%B8%E3%82%BF%E3%83%BC%E3%83%90%E3%83%83%E3%82%AF%E3%82%A8%E3%83%B3%E3%83%89%E3%81%AE%E4%BD%9C%E6%88%90%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%93%E3%82%B8%E3%83%BC%E3%83%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128773%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128773%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Eyocto%E3%81%AEweston.ini%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%26nbsp%3B%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EGnar%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%ABweston%3CSPAN%3E%E3%82%92%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3Eweston%20--tty%3D1%3C%2FSPAN%3E%E3%82%92%E3%81%A9%E3%81%93%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EYocto%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6Xwayland%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81LXQT%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6GPU%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%9C%80%E5%96%84%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3Eapt-get%20LXQT%E3%82%92%E7%9B%B4%E6%8E%A5%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AEGPU%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6LXQT%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128770%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128770%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ELXQt%E3%81%A7XWayland%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%80%82GNOME-Wayland%E3%81%AE%E3%81%BF%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82LXQt%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%AB%E3%81%AFXWayland%E9%96%A2%E9%80%A3%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%BD%93%E7%A4%BE%E3%81%AE%20GPU%20%E3%81%AF%20Wayland%20%E3%81%AE%E3%81%BF%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%80%81xwayland%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EUbuntu-i.MX8M.pdf%20%E3%81%A7%E3%81%AF%E3%80%81%E6%89%8B%E9%A0%86%207%20%E3%81%A7%20weston%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%9B%E3%81%9A%E3%80%81apt-get%20install%20lxqt%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%A8%E3%81%97%E3%81%A6%20lxqt%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E7%B5%90%E6%9E%9C%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20675px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F108840i7E4281D1019C7D98%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EGPU%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%AA%E3%81%9C%E3%81%A9%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%82GPU%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82Ubuntu%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E7%B5%90%E6%9E%9C%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22galcore-last.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22galcore-last.png%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F108841i874260C38CB2AD52%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22galcore-last.png%22%20alt%3D%22galcore-last.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Egalcore-last.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E26%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%81%8CGPU%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%9E%E7%AD%94%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E8%89%AF%E3%81%84%E4%B8%80%E6%97%A5%E3%82%92%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128767%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128767%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AF%E3%80%81Ubuntu%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%ABGPU%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2CGnar%20Fang%3C%2FP%3E%3CP%3EUbuntu%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E9%99%90%E3%82%8A%E3%80%81GPU%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AFyocto-wayland%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%A7%E3%81%99%E3%80%82%E4%BB%96%E3%81%AE%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81apt-get%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%B1%9F%E4%BA%9A%E5%BC%BA%3C%2FP%3E%3CP%3E%E8%BD%AF%E4%BB%B6%E5%B7%A5%E7%A8%8B%E5%B8%88%3C%2FP%3E%3CP%3E%E6%B7%B1%E3%82%BB%E3%83%B3%E8%8F%AF%E7%BE%8E%E7%9F%B3%E7%A7%91%E6%8A%80%E6%9C%89%E9%99%90%E5%85%AC%E5%8F%B8%3C%2FP%3E%3CP%3E%E6%B7%B1%E5%9C%B3%E5%B8%82%E5%8D%8E%E7%BE%8E%E8%A7%86%E7%A7%91%E6%8A%80%E6%9C%89%E9%99%90%E5%85%AC%E5%8F%B8%3C%2FP%3E%3CP%3E%E6%B7%B1%E5%9C%B3%E5%B8%82%E5%8D%97%E5%B1%B1%E5%8C%BA%E7%A7%91%E8%8B%91%E8%B7%AF6%E5%8F%B7%E7%A7%91%E6%8A%80%E5%9B%AD%E5%B7%A5%E4%B8%9A%E5%A4%A7%E5%8E%A6605%3C%2FP%3E%3CP%3ETel%EF%BC%9A0755-26037882-616%3C%2FP%3E%3CP%3EMail%3Ayaqiang.jiang%40huameishi.com%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20font-weight%3A%20200%3B%22%3Eprashanth%E3%81%95%E3%82%93%EF%BC%9A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E3%81%93%E3%81%AE%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E6%89%8B%E3%81%AB%E5%85%A5%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%E3%80%8Csudo%20-E%20weston%20--tty%20%3D%201%E3%80%8D%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%AFyocto-wayland%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%A8%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E3%81%AFapt-get%E3%81%A7%E4%BD%95%E3%81%8B%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20font-weight%3A%20200%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20font-weight%3A%20200%3B%22%3ETks~%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%81%AA%E3%81%9C%E3%81%9D%E3%82%8C%E3%81%8C%E8%B5%B7%E3%81%93%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%2Fusr%2Flib%2Faarch64-xx%20libGLES%E3%80%81libEGL%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128762%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128762%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%20Fang%2C%3C%2FP%3E%3CP%3E%E8%BF%94%E4%BF%A1%E3%81%8C%E9%81%85%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%A6%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%AF%E3%81%84%E3%80%81Weston%2FWayland%20%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E5%BC%95%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82rUNTIME_DIR%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%E6%89%80%E6%9C%89%E6%A8%A9%E3%82%84%E6%A8%A9%E9%99%90%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E8%AD%A6%E5%91%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128761%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128761%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E1.%E8%AD%A6%E5%91%8A%EF%BC%9AXDG_RUNTIME_DIR%E3%80%8C%2Frun%2Fuser%2F1001%E3%80%8D%E3%81%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82Unix%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C0700%EF%BC%88%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF700%EF%BC%89%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%8B%E3%81%A4%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%8C%E6%89%80%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%88%E7%8F%BE%E5%9C%A8%E3%81%AE%E6%89%80%E6%9C%89%E8%80%85%E3%81%AFUID%201001%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E2.%3CSPAN%3E%5B17%3A00%3A10.627%5D%20EGL%E3%82%A8%E3%83%A9%E3%83%BC%E7%8A%B6%E6%85%8B%3A%20EGL_BAD_ALLOC%20(0x3003)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%5B17%3A00%3A10.627%5D%20EGL%E3%82%A8%E3%83%A9%E3%83%BC%E7%8A%B6%E6%85%8B%3A%20EGL_SUCCESS%20(0x3000)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%5B17%3A00%3A10.627%5D%20egl%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%E3%81%8A%E8%A9%A6%E3%81%97%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%24%20sudo%20su%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%24%26nbsp%3B%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3EXDG_RUNTIME_DIR%20%3D%2Frun%2Fuser%2F1001%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%24%20weston%20--tty%3D1%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3EWeston%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E4%B8%AD%E3%81%AB%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%AF%E7%A2%BA%E3%81%8B%E3%81%A7%E3%81%99%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E6%99%82%E3%81%AEWeston%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AF%E3%81%A9%E3%82%8C%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%E7%A7%81%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%89%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%20Fang%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bweston%20--use-pixman%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E8%A1%A8%E7%A4%BA%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81HW%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81OpenGL%20ES%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%82%88%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82Weston%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E4%B8%AD%E3%81%ABHW%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%20Fang%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%AF%E3%81%84%E3%80%81%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%ABgalcore%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%8C%E3%81%BE%E3%81%A0%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3Esudo%20-E%20weston%20--tty%3D1%3CBR%20%2F%3E%E6%97%A5%E4%BB%98%EF%BC%9A2019%E5%B9%B44%E6%9C%8811%E6%97%A5%20UTC%3CBR%20%2F%3E%5B17%3A00%3A10.607%5Dweston%205.0.0%3CBR%20%2F%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fwayland.freedesktop.org%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwayland.freedesktop.org%3C%2FA%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%83%90%E3%82%B0%E5%A0%B1%E5%91%8A%E5%85%88%EF%BC%9A%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fgitlab.freedesktop.org%252Fwayland%252Fweston%252Fissues%252F%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgitlab.freedesktop.org%2Fwayland%2Fweston%2Fissues%2F%3C%2FA%3E%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%EF%BC%9A5.0.0-33-gfb563901MGS-4627%20%5B%23ccc%5D%20%E3%83%91%E3%83%8D%E3%83%AB%E4%BD%8D%E7%BD%AE%E3%81%8C%E3%80%8C%E3%81%AA%E3%81%97%E3%80%8D%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81weston%E3%81%AF%E3%82%AA%E3%83%95%E3%81%AB%E3%81%AA%E3%82%8A%E3%80%81gplay%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%EF%BC%882019-03-14%2011%3A30%3A30%20%2B0800%EF%BC%89%3CBR%20%2F%3E%5B17%3A00%3A10.607%5D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%EF%BC%9Aweston%20--tty%3D1%3CBR%20%2F%3E%EF%BC%BB17%3A00%3A10.607%EF%BC%BDOS%3A%20Linux%E3%80%814.19.35-1.1.0%2Bg0f9917c56d59%E3%80%81%231%20SMP%20PREEMPT%202019%E5%B9%B410%E6%9C%8830%E6%97%A5(%E6%B0%B4)%2013%3A54%3A51%20UTC%2C%20aarch64%3CBR%20%2F%3E%5B17%3A00%3A10.608%5D%E8%AD%A6%E5%91%8A%3A%20XDG_RUNTIME_DIR%E3%80%8C%2Frun%2Fuser%2F1001%E3%80%8D%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%80%82Unix%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C0700%EF%BC%88%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%20700%EF%BC%89%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%3CBR%20%2F%3E%E3%81%8B%E3%81%A4%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%8C%E6%89%80%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%88%E7%8F%BE%E5%9C%A8%E3%81%AE%E6%89%80%E6%9C%89%E8%80%85%E3%81%AF%20UID%201001%EF%BC%89%E3%80%82%3CBR%20%2F%3E%E5%85%A5%E6%89%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%3CBR%20%2F%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freedesktop.org%252Fwiki%252FSpecifications%252Fbasedir-spec%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.freedesktop.org%2Fwiki%2FSpecifications%2Fbasedir-spec%3C%2FA%3E%3CBR%20%2F%3E%E3%81%9D%E3%82%8C%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%82%3CBR%20%2F%3E%5B17%3A00%3A10.608%5D%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%AA%E3%81%84%E7%8A%B6%E6%85%8B%E3%81%A7%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B17%3A00%3A10.608%5D%E5%87%BA%E5%8A%9B%E5%86%8D%E6%8F%8F%E7%94%BB%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%AE%E6%9C%80%E5%A4%A7%E5%80%A4%E3%81%AF16%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B17%3A00%3A10.608%5D%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%8C%2Fusr%2Flib%2Flibweston-5%2Fdrm-backend.so%E3%80%8D%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B17%3A00%3A10.612%5DDRM%E3%83%90%E3%83%83%E3%82%AF%E3%82%A8%E3%83%B3%E3%83%89%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B17%3A00%3A10.614%5D%2Fdev%2Fdri%2Fcard0%E3%82%92%E4%BD%BF%E7%94%A8%E4%B8%AD%3CBR%20%2F%3E%5B17%3A00%3A10.614%5DDRM%EF%BC%9A%E3%83%A6%E3%83%8B%E3%83%90%E3%83%BC%E3%82%B5%E3%83%AB%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%5B17%3A00%3A10.614%5DDRM%EF%BC%9A%E3%82%A2%E3%83%88%E3%83%9F%E3%83%83%E3%82%AF%E3%83%A2%E3%83%BC%E3%83%89%E8%A8%AD%E5%AE%9A%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B17%3A00%3A10.614%5DDRM%EF%BC%9A%E7%94%BB%E5%83%8F%E3%81%AE%E3%82%A2%E3%82%B9%E3%83%9A%E3%82%AF%E3%83%88%E6%AF%94%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B17%3A00%3A10.614%5D%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%8C%2Fusr%2Flib%2Flibweston-5%2Fgl-renderer.so%E3%80%8D%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E4%B8%AD%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B17%3A00%3A10.626%5DEGL%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E6%8B%A1%E5%BC%B5%EF%BC%9AEGL_EXT_client_extensions%3CBR%20%2F%3E%20EGL_EXT_platform_base%20EGL_KHR_platform_wayland%3CBR%20%2F%3E%20EGL_EXT_platform_wayland%20EGL_KHR_platform_gbm%3CBR%20%2F%3E%5B17%3A00%3A10.627%5D%E8%AD%A6%E5%91%8A%EF%BC%9AEGL_EXT_swap_buffers_with_damage%E3%82%82EGL_KHR_swap_buffers_with_damage%E3%82%82%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%81%8C%E5%87%BA%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B17%3A00%3A10.627%5DEGL_KHR_surfaceless_context%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%3CBR%20%2F%3E%5B17%3A00%3A10.627%5D%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%AE%E4%BD%9C%E6%88%90%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B17%3A00%3A10.627%5DEGL%E3%82%A8%E3%83%A9%E3%83%BC%E7%8A%B6%E6%85%8B%EF%BC%9AEGL_BAD_ALLOC%EF%BC%880x3003%EF%BC%89%3CBR%20%2F%3E%5B17%3A00%3A10.627%5DEGL%20%E3%82%A8%E3%83%A9%E3%83%BC%E7%8A%B6%E6%85%8B%EF%BC%9AEGL_SUCCESS%EF%BC%880x3000%EF%BC%89%3CBR%20%2F%3E%5B17%3A00%3A10.627%5Degl%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E9%9A%9C%E5%AE%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128757%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Build%20Ubuntu%20For%20i.MX8%20Series%20Platform%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128757%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHI%20gaobo%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%AD%E3%83%BC%E3%81%A8%E3%81%AA%E3%82%8B%E3%81%AE%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE2%E3%81%A4%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%E3%81%94%E5%8F%82%E7%85%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%20%2Flib%2Fudev%2Frules.d%2F50-firmware.rules%20%3C%2FP%3E%3CP%3E%20%2Fusr%2Fbin%2Ffirmware.sh%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ecat%20%2Flib%2Fudev%2Frules.d%2F50-firmware.rules%20%3C%2FP%3E%3COL%3E%3CLI%20level%3D%221%22%20type%3D%22ol%22%3E%3CP%3Estub%20for%20immediately%20telling%20the%20kernel%20that%20userspace%20firmware%20loading%3C%2FP%3E%3C%2FLI%3E%3CLI%20level%3D%221%22%20type%3D%22ol%22%3E%3CP%3Efailed%3B%20necessary%20to%20avoid%20long%20timeouts%20with%20CONFIG_FW_LOADER_USER_HELPER%3Dy%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%23SUBSYSTEM%3D%3D%22firmware%22%2C%20ACTION%3D%3D%22add%22%2C%20ATTR%3CSPAN%20__jive_macro_name%3D%22loading%22%3E%3C%2FSPAN%3E%3D%22-1%22%3C%2FP%3E%3CP%3ESUBSYSTEM%3D%3D%22firmware%22%2C%20ACTION%3D%3D%22add%22%2C%20RUN%2B%3D%22%2Fbin%2Fsh%20%2Fusr%2Fbin%2Ffirmware.sh%22%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eimx8m%40localhost%3A~%24%20cat%20%2Fusr%2Fbin%2Ffirmware.sh%20%3C%2FP%3E%3CP%3E%23echo%201%20%26gt%3B%20%2Fsys%2F%24DEVPATH%2Floading%3C%2FP%3E%3CP%3E%23cat%20%24HOTPLUG_FW_DIR%20%26gt%3B%20%26gt%3B%20%2Fsysfs%2F%24DEVPATH%2Fdata%3C%2FP%3E%3CP%3E%23echo%200%20%26gt%3B%20%2Fsys%2F%24DEVPATH%2Floading%3C%2FP%3E%3CP%3Eecho%20-n%201%20%26gt%3B%20%2Fsys%2F%24DEVPATH%2Floading%3C%2FP%3E%3CP%3Esleep%201%3C%2FP%3E%3CP%3Ecat%20%2Flib%2Ffirmware%2F%24FIRMWARE%20%26gt%3B%20%2Fsys%2F%24DEVPATH%2Fdata%20%3C%2FP%3E%3CP%3Eif%20%3B%20then%3C%2FP%3E%3COL%3E%3CLI%20level%3D%221%22%20type%3D%22ol%22%3E%3CP%3Eecho%20-n%201%20%26gt%3B%20%2Fsys%2F%24DEVPATH%2Floading%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3Eecho%20-n%200%20%26gt%3B%20%2Fsys%2F%24DEVPATH%2Floading%3C%2FP%3E%3CP%3Efi%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%BB%E3%83%A4%E5%BC%B7%3C%2FP%3E%3CP%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%8B%E3%82%A2%3C%2FP%3E%3CP%3EShenzhen%20Huameishi%20Technology%20Co.%2C%20Ltd%3C%2FP%3E%3CP%3E%E6%B7%B1%E3%82%BB%E3%83%B3%E8%8F%AF%E7%BE%8E%E7%9F%B3%E6%8A%80%E8%A1%93%E6%9C%89%E9%99%90%E5%85%AC%E5%8F%B8%3C%2FP%3E%3CP%3E%E6%B7%B1%E3%82%BB%E3%83%B3%E5%B8%82%E5%8D%97%E5%B1%B1%E5%8C%BA%E7%A7%91%E9%99%A2%E8%B7%AF6%E5%8F%B7%E3%82%B5%E3%82%A4%E3%82%A8%E3%83%B3%E3%82%B9%E3%83%91%E3%83%BC%E3%82%AF%E5%B7%A5%E6%A5%AD%E3%83%93%E3%83%AB605%E5%8F%B7%E5%AE%A4%3C%2FP%3E%3CP%3ETel%EF%BC%9A0755-26037882-616%3C%2FP%3E%3CP%3EMail%3Ayaqiang.jiang%40huameishi.com%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128756%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Build%20Ubuntu%20For%20i.MX8%20Series%20Platform%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128756%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E7%A7%81%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E6%A7%8B%E6%88%90%E6%99%82%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E8%B5%B7%E5%8B%95%E5%BE%8C%E3%81%AB%E6%89%8B%E5%8B%95%E3%81%A7%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%82%82%E3%81%AE%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%AD%E3%82%B0%E3%81%8C%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E8%A7%A3%E6%B1%BA%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%81%BE%E3%82%8A%E8%89%AF%E3%81%84%E6%96%B9%E6%B3%95%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%A3%E3%81%A8%E3%81%84%E3%81%84%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%A6%E3%82%A7%E3%82%B9%E3%83%88%E3%83%B3%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABDOC%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82GPU%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3Eroot%40ubuntu%3A~%23%20ls%20%2Fdev%2Fgalcore%3C%2FP%3E%3CP%3E%2Fdev%2Fgalcor%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128754%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128754%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%20Fang%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E9%80%B2%E5%B1%95%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128751%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128751%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%20Fang%2C%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81IM8MM%20DDR4%20EVK%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128749%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128749%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%20Fang%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BWeston%20tty%E3%82%92%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AB%E3%80%81%E3%80%8C%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%8D%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%8C%E8%87%B4%E5%91%BD%E7%9A%84%EF%BC%9ADRM%20%E3%81%AF%E3%83%90%E3%83%83%E3%82%AF%E3%82%B0%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E4%BD%95%E3%81%8B%E3%82%AC%E3%82%A4%E3%83%80%E3%83%B3%E3%82%B9%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%A9%E3%83%BC%E3%82%B8%E3%82%A7%E3%82%B7%E3%83%A5%20K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128748%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128748%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%80%E3%82%A6%E3%83%8B%E3%83%BC%E3%81%95%E3%82%93%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AE%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%20imx8md%2Fq%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%80%8Cg2d%E3%80%8D%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81weston-imx%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E3%80%8C--disable-imxg2d%E3%80%8D%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%B1%9F%E4%BA%9A%E5%BC%BA%3C%2FP%3E%3CP%3E%E8%BD%AF%E4%BB%B6%E5%B7%A5%E7%A8%8B%E5%B8%88%3C%2FP%3E%3CP%3E%E6%B7%B1%E3%82%BB%E3%83%B3%E8%8F%AF%E7%BE%8E%E7%9F%B3%E7%A7%91%E6%8A%80%E6%9C%89%E9%99%90%E5%85%AC%E5%8F%B8%3C%2FP%3E%3CP%3EMail%3Ayaqiang.jiang%40huameishi.com%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHI%26nbsp%3B%20Gnar%20Fang%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81imx8mq%E3%81%A7ubuntu18.04%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Eimx-sdma%2030bd0000.sdma%3A%E5%A4%96%E9%83%A8%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%AE%E3%81%A7%E3%80%81ROM%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%20%2Flib%2Ffirmware%2F%20%E3%81%AB%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128744%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128744%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%26nbsp%3B%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%22321819%22%20data-username%3D%22nxf47724%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fnxf47724%22%20style%3D%22color%3A%20%233d9ce7%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20text-decoration%3A%20none%3B%20font-size%3A%201.286rem%3B%22%20target%3D%22_blank%22%3EGnar%20Fang%3C%2FA%3E%3A%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%22%3Eaarch64-poky-linux%2F%3C%2FSTRONG%3E%E3%81%AE%E4%B8%8B%E3%81%AB%3CSTRONG%3Elibdrm%2F%3C%2FSTRONG%3E%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E6%A1%88%E5%86%85%E3%81%95%E3%82%8C%E3%81%9F%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%3CSTRONG%3Eweston-imx%3C%2FSTRONG%3E%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%9F%E9%9A%9B%E3%81%AB%E3%80%81%E5%88%A5%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%60%60%60%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B...%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81libweston%2Fg2d-renderer.c%3A44%3A0%3A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Blibweston%2Fg2d-renderer.h%3A30%3A10%3A%E8%87%B4%E5%91%BD%E7%9A%84%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%3A%20g2dExt.h%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%23include%20%3CG2DEXT.H%3E%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%5E~~~~~~~~~%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FG2DEXT.H%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3BMakefile%3A5107%3A%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%80%8Clibweston%2Fg2d_renderer_la-g2d-renderer.lo%E3%80%8D%E3%81%AE%E3%83%AC%E3%82%B7%E3%83%94%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%60%60%60%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%EF%BC%88libweston%EF%BC%89%E3%81%8C%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%9D%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%8C%E3%81%9D%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%E6%93%8D%E4%BD%9C%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E5%9B%9E%E9%81%BF%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E6%9C%80%E5%88%9D%E3%81%8B%E3%82%89%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AE%E5%A0%B4%E5%90%88%E3%82%82%E5%95%8F%E9%A1%8C%E3%81%AF%E5%90%8C%E3%81%98%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%E3%83%80%E3%82%A6%E3%83%8B%E3%83%BC%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%97%E3%83%A9%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E8%A6%81%E4%BB%B6%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E6%9B%B4%E6%96%B0%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3EGnar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82i.MX8%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7Ubuntu%2018.04%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%9F%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E3%83%BB%E3%82%AF%E3%83%9E%E3%83%BC%E3%83%AB%20K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20font-size%3A%201.286rem%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2018.004px%3B%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2018.004px%3B%22%3Eprashanth%E3%81%95%E3%82%93%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20font-size%3A%201.286rem%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2018.004px%3B%22%3Eweston%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81weston%20GUI%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82Gnome%20GUI%E3%82%92%E5%85%A5%E6%89%8B%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E3%81%8A%E8%80%83%E3%81%88%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81CPU%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E3%81%BF%E3%81%A7%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%88apt-get%20install%20gnome-core%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%EF%BC%89%E3%80%82GPU%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E5%82%99%E3%81%88%E3%81%9FGnome%20GUI%E3%81%AB%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E9%96%93%E9%81%95%E3%81%84%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20font-size%3A%201.286rem%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2018.004px%3B%22%3EBR%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20font-size%3A%201.286rem%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2018.004px%3B%22%3EGnar%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20font-size%3A%201.286rem%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2018.004px%3B%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128740%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128740%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWeston%E3%81%A7GUI%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AEGUI%E3%81%AE%E5%A4%96%E8%A6%B3%E3%81%AF%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97Ubuntu%E3%81%AEGUI%E3%81%A8%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%90%8C%E3%81%98GUI%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%E7%AB%AF%E6%9C%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%23%20lsb_release%20-a%3C%2FP%3E%3CP%3ELSB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AF%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BCID%EF%BC%9AUbuntu%3CBR%20%2F%3E%E8%AA%AC%E6%98%8E%EF%BC%9AUbuntu%2018.04.2LTS%3CBR%20%2F%3E%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%EF%BC%9A18.04%3CBR%20%2F%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%83%8D%E3%83%BC%E3%83%A0%EF%BC%9A%E3%83%90%E3%82%A4%E3%82%AA%E3%83%8B%E3%83%83%E3%82%AF%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22wayland-screenshot-2018-01-28_15-59-17.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22wayland-screenshot-2018-01-28_15-59-17.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F95097i602280E3CB27379B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22wayland-screenshot-2018-01-28_15-59-17.png%22%20alt%3D%22wayland-screenshot-2018-01-28_15-59-17.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ewayland-screenshot-2018-01-28_15-59-17.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E3%83%BB%E3%82%AF%E3%83%9E%E3%83%BC%E3%83%AB%20K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E1.%20libdrm%E3%81%AF%3CSTRONG%3Ebuildxwayland%2Ftmp%2Fwork%2Faarch64-poky-linux%3C%2FSTRONG%3E%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E2.%20%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81rootfs%E3%81%8B%E3%82%89libdrm%E3%81%8C%E5%A4%B1%E3%82%8F%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82libdrm%E3%82%92rootfs%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%96%E3%81%AB%E3%81%94%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E6%9C%80%E8%BF%91%E3%81%AF%E4%BB%96%E3%81%AE%E6%A1%88%E4%BB%B6%E3%81%8C%E5%A4%9A%E3%81%99%E3%81%8E%E3%81%A6%E3%80%81%E8%BF%94%E4%BF%A1%E3%81%8C%E9%81%85%E3%81%8F%E3%81%AA%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3EGnar%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128738%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128738%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%26nbsp%3B%3CA%20_jive_internal%3D%22true%22%20class%3D%22%22%20data-avatarid%3D%2229594%22%20data-externalid%3D%22%22%20data-online%3D%22false%22%20data-presence%3D%22null%22%20data-userid%3D%22321819%22%20data-username%3D%22nxf47724%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fnxf47724%22%20style%3D%22color%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%2014px%3B%22%20target%3D%22_blank%22%3EGnar%20Fang%3C%2FA%3E%3A%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%9B%B4%E6%96%B0%E3%82%92%E6%A5%BD%E3%81%97%E3%81%BF%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A1%E3%81%AA%E3%81%BF%E3%81%AB%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE2%E7%95%AA%E7%9B%AE%E3%81%AE%E8%B3%AA%E5%95%8F%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%88weston-imx%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%89%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%80%E3%82%A6%E3%83%8B%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%818mq%20yocto%E3%81%AB%E3%81%AFlibdrm%E3%81%8C%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%82%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%9D%A5%E9%80%B1%E7%A2%BA%E8%AA%8D%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EDRM%E3%81%AFLinux%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3EGnar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%22321819%22%20data-username%3D%22nxf47724%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fnxf47724%22%20style%3D%22color%3A%20%233d9ce7%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20font-size%3A%201.286rem%3B%22%20target%3D%22_blank%22%3EGnar%20Fang%3C%2FA%3E%EF%BC%9A%3C%2FP%3E%3CP%3EUbuntu%2018.04%E3%82%92i.mx8mq-evk%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E8%AA%AD%E3%82%93%E3%81%A7%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%812%E3%81%A4%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.%E3%82%B9%E3%83%86%E3%83%83%E3%83%979%E3%80%81%E3%83%91%E3%83%BC%E3%83%882%EF%BC%9A%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%80%8Clibdrm%2F2.4.91.imx-r0%2Fimage%2F*%E3%80%8D%E3%81%A8%E3%80%8Cimx-dpu-g2d-1.7.0%2Fimx-dpu-g2d%2F1.7.0-r0%2Fimage%2F*%E3%80%8D%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%82%892%E3%81%A4%E3%81%AE%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AF%E7%A7%81%E3%81%AEYocto%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E3%81%AF%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E7%A2%BA%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82i.mx8mq-evk%E3%81%AB%E3%81%AFdpu%E3%81%8C%E3%81%AA%E3%81%84%E3%81%A8%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81libdrm%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%82%88%E3%81%8F%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%AE%E3%81%A7%E3%80%81%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%80%81%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EDISTRO%3Dfsl-imx-wayland%20MACHINE%3Dimx8mqevk%20source%20fsl-setup-release.sh%20-b%20build%3C%2FP%3E%3CP%3Ebitbake%20fsl-image-qt5-validation-imx%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%20%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC1%E3%81%AB%E9%96%A2%E4%BF%82%E3%81%AA%E3%81%8F%E3%80%81%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E7%B6%9A%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81weston-imx%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%89%8B%E9%A0%86%EF%BC%9A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bgit%20clone%20%3CA%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Fweston-imx.git%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Fweston-imx.git%3C%2FA%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bcd%20weston-imx%3C%2FP%3E%3CP%3Egit%20checkout%20fb563901657b296c7c7c86d26602a622429e334f%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B.%2Fautogen.sh%20--prefix%3D%2Fusr%20--disable-silent-rules%20--disable-dependency-tracking%20.........%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bmake%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%E3%81%93%E3%82%8C%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%20make%5B1%5D%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%80%8C%2Froot%2Fweston%2Fweston-imx%E3%80%8D%E3%81%AE%E5%85%A5%E5%8A%9B%3CBR%20%2F%3E%26nbsp%3B%2Fbin%2Fbash%20.%2Flibtool--tag%3DCC%20--mode%3Dcompile%20gcc%20-DHAVE_CONFIG_H%20-I.%20-I.%2Flibweston%20-I.%2Flibweston%20-I.%2Fclients%20-I.%2Ftests%20-I.%2Fshared%20-I.%2Fprotocol%20-DLIBWESTON_MODULEDIR%3D'%22%2Fusr%2Flib%2Flibweston-5%22'%20-DLIBEXECDIR%3D'%22%2Fusr%2Flibexec%22'%20-DBINDIR%3D'%22%2Fusr%2Fbin%22'%20-DIN_WESTON%20-Wall%20-Wextra%20-Wno-unused-parameter%20-Wno-shift-negative-value%20-Wno-missing-field-initializers%20-g%20-fvisibility%3Dhidden%20-Wstrict-prototypes%20-Wmissing-prototypes%20-Wsign-compare%20-DLINUX%20-DEGL_API_FB%20-DWL_EGL_PLATFORM%20-I%2Fusr%2Finclude%2Fpixman-1%20-DLINUX%20-DEGL_API_FB%20-DWL_EGL_PLATFORM%20-I%2Fusr%2Finclude%2Flibdrm%20-g%20-O2%20-c%20-o%20libweston%2Flibweston_5_la-pixel-formats.lo%20%60test%20-f%20'libweston%2Fpixel-formats.c'%20%7C%7C%20echo%20'.%2F'%60libweston%2Fpixel-formats.c%3CBR%20%2F%3Elibtool%3A%20compile%3A%20gcc%20-DHAVE_CONFIG_H%20-I.-I.%2Flibweston%20-I.%2Flibweston%20-I.%2Fclients%20-I.%2Ftests%20-I.%2Fshared%20-I.%2Fprotocol%20-DLIBWESTON_MODULEDIR%3D%5C%22%2Fusr%2Flib%2Flibweston-5%5C%22%20-DLIBEXECDIR%3D%5C%22%2Fusr%2Flibexec%5C%22%20-DBINDIR%3D%5C%22%2Fusr%2Fbin%5C%22%20-DIN_WESTON%20-Wall%20-Wextra%20-Wno-unused-parameter%20-Wno-shift-negative-value%20-Wno-missing-field-initializers%20-g%20-fvisibility%3Dhidden%20-Wstrict-prototypes%20-Wmissing-prototypes%20-Wsign-compare%20-DLINUX%20-DEGL_API_FB%20-DWL_EGL_PLATFORM%20-I%2Fusr%2Finclude%2Fpixman-1%20-DLINUX%20-DEGL_API_FB%20-DWL_EGL_PLATFORM%20-I%2Fusr%2Finclude%2Flibdrm%20-g%20-O2%20-c%20libweston%2Fpixel-formats.c%20-fPIC%20-DPIC%20-o%20libweston%2F.libs%2Flibweston_5_la-pixel-formats.o%3C%2FP%3E%3CP%3E%3CBR%20%2F%3Elibweston%2Fpixel-formats.c%3A268%3A13%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%80%8CDRM_FORMAT_P010%E3%80%8D%E3%81%AF%E3%81%93%E3%81%93%E3%81%A7%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%88%E9%96%A2%E6%95%B0%E5%86%85%E3%81%AB%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%89%E3%80%82%E3%80%8CDRM_FORMAT_NV12%E3%80%8D%E3%81%AE%E9%96%93%E9%81%95%E3%81%84%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E.format%3D%20DRM_FORMAT_P010%2C%20%26nbsp%3B%5E~~~~~~~~~~~~~~%3CBR%20%2F%3E%20DRM_FORMAT_NV12%3CBR%20%2F%3EMakefile%3A5527%EF%BC%9A%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%80%8Clibweston%2Flibweston_5_la-pixel-formats.lo%E3%80%8D%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E4%BA%8C%E3%81%A4%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E4%BF%A1%E5%8F%B7%E3%82%92%E9%80%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%3CP%3E%E3%83%80%E3%82%A6%E3%83%8B%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128735%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128735%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUbuntu%2018.04%E3%81%A7Weston%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fnxf47724%22%20target%3D%22_blank%22%3Enxf47724%3C%2FA%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E4%B8%8A%E8%A8%98%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%80%81%E4%BD%95%E3%81%8B%E6%9B%B4%E6%96%B0%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E3%83%BB%E3%82%AF%E3%83%9E%E3%83%BC%E3%83%AB%20K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128734%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128734%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%EF%BC%8C%26nbsp%3B%3C%2FP%3E%3CP%3EPC%E3%81%8B%E3%82%89rootf%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%83%81%E3%82%B1%E3%83%83%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3EGnar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EiMX8QM%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E7%94%A8%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%9F%3CSTRONG%3Eubuntu-rootfs.tar.gz%3C%2FSTRONG%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E3%81%94%E6%8F%90%E4%BE%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E3%83%BB%E3%82%AF%E3%83%9E%E3%83%BC%E3%83%AB%20K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%26nbsp%3B%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EGnar%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%22%3CSTRONG%3E10.build%20weston%3C%2FSTRONG%3E%22%20%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81qemu%20%E7%92%B0%E5%A2%83%E3%81%AE%20ubuntu-rootfs%20%E3%81%A7%20Weston%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%BE%E3%81%9F%E3%80%81%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81ubuntu-rootfs%E5%85%A8%E4%BD%93%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E12.%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%82%8B%3CBR%20%2F%3E%24%20mkdir%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3CBR%20%2F%3E%24%20umount%20%2Fdev%2Fsdb2%3CBR%20%2F%3E%24%20mkfs.ext4%20%2Fdev%2Fsdb2%3CBR%20%2F%3E%24%20mount%20%2Fdev%2Fsdb2%20%2Fhome%2Fgnar%2Fmountpoint%3CBR%20%2F%3E%24%20cp%20-a%20%2Fhome%2Fgnar%2Frootfs%2Fubuntu-rootfs%20%2F*%20%2Fhome%2Fgnar%2Fmountpoint%2F%3CBR%20%2F%3Eumount%20%2Fhome%2Fgnar%2Fmountpoint%3CBR%20%2F%3Esync%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3Eubuntu%40ubuntu%3A~%24%20export%20XDG_RUNTIME_DIR%3D%2Frun%2Fuser%2F1000%3CBR%20%2F%3Eubuntu%40ubuntu%3A~%24%20sudo%20-E%20weston%20--tty%3D1%3CBR%20%2F%3E%5Bsudo%5D%20iwave%E3%81%AE%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%EF%BC%9A%3CBR%20%2F%3E%E6%97%A5%E4%BB%98%EF%BC%9A2019%E5%B9%B410%E6%9C%8820%E6%97%A5%20UTC%3CBR%20%2F%3E%5B12%3A05%3A59.961%5Dweston%205.0.0%3CBR%20%2F%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CA%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fwayland.freedesktop.org%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwayland.freedesktop.org%3C%2FA%3E%3CBR%20%2F%3E%3CSPAN%3E%20%E3%83%90%E3%82%B0%E5%A0%B1%E5%91%8A%E5%85%88%EF%BC%9A%3C%2FSPAN%3E%3CA%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fgitlab.freedesktop.org%252Fwayland%252Fweston%252Fissues%252F%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgitlab.freedesktop.org%2Fwayland%2Fweston%2Fissues%2F%3C%2FA%3E%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%EF%BC%9A5.0.0-33-gfb563901MGS-4627%20%5B%23ccc%5D%20weston%E3%81%AF%E3%80%81panel-position%E3%81%8Cnone%E3%81%AE%E3%81%A8%E3%81%8D%E3%81%ABgplay%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AA%E3%83%95%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%882019%E5%B9%B43%E6%9C%8814%E6%97%A5%2011%3A30%3A30%20%2B0800%EF%BC%89%3CBR%20%2F%3E%5B12%3A05%3A59.961%5D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%EF%BC%9Aweston%20--tty%3D1%3CBR%20%2F%3E%5B12%3A05%3A59.961%5DOS%3A%20Linux%E3%80%814.14.98-imx_4.14.98_2.0.0_ga%2Bg5d6cbea%E3%80%81%231%20SMP%20PREEMPT%202019%E5%B9%B410%E6%9C%8814%E6%97%A5(%E6%9C%88)%2008%3A11%3A41%20UTC%E3%80%81aarch64%3CBR%20%2F%3E%5B12%3A05%3A59.961%5D%E8%AD%A6%E5%91%8A%EF%BC%9AXDG_RUNTIME_DIR%E3%80%8C%2Frun%2Fuser%2F1000%E3%80%8D%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3EUnix%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF0700%EF%BC%88%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF700%EF%BC%89%E3%81%A7%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%8C%E6%89%80%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%88%E7%8F%BE%E5%9C%A8%E3%81%AE%E6%89%80%E6%9C%89%E8%80%85%E3%81%AFUID%201000%EF%BC%89%E3%80%82%E5%85%A5%E6%89%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%BE%E3%81%9F%E3%81%AF%3CBR%20%2F%3E%3CA%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freedesktop.org%252Fwiki%252FSpecifications%252Fbasedir-spec%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.freedesktop.org%2Fwiki%2FSpecifications%2Fbasedir-spec%3C%2FA%3E%3CBR%20%2F%3E%E3%81%9D%E3%82%8C%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%82%3CBR%20%2F%3E%5B12%3A05%3A59.961%5D%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%AA%E3%81%84%E7%8A%B6%E6%85%8B%E3%81%A7%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B12%E6%99%8205%E5%88%8659%E7%A7%92962%5D%E5%87%BA%E5%8A%9B%E5%86%8D%E6%8F%8F%E7%94%BB%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%AE%E6%9C%80%E5%A4%A7%E5%80%A4%E3%81%AF16%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CSTRONG%3E%5B12%3A05%3A59.962%5D%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%8C%2Fusr%2Flib%2Flibweston-5%2Fdrm-backend.so%E3%80%8D%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B12%3A05%3A59.964%5D%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%2Fusr%2Flib%2Flibweston-5%2Fdrm-backend.so%EF%BC%9A%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AB%EF%BC%9Agbm_surface_get_in_fence_fd%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B12%3A05%3A59.964%5D%20%E8%87%B4%E5%91%BD%E7%9A%84%3A%20%E3%82%B3%E3%83%B3%E3%83%9D%E3%82%B8%E3%82%BF%E3%83%BC%E3%83%90%E3%83%83%E3%82%AF%E3%82%A8%E3%83%B3%E3%83%89%E3%81%AE%E4%BD%9C%E6%88%90%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSTRONG%3E%3CBR%20%2F%3Eubuntu%40ubuntu%3A~%24%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%80%8C%3CSTRONG%3Edrm-backend.so%3C%2FSTRONG%3E%E3%80%8D%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%80%8C%3CSTRONG%3Eweston%3C%2FSTRONG%3E%E3%80%8D%E3%81%8A%E3%82%88%E3%81%B3yocto%E3%83%93%E3%83%AB%E3%83%89%E3%81%8B%E3%82%89ubuntu-rootfs%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E9%96%A2%E9%80%A3%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E3%83%91%E3%82%B9%E3%82%82%E3%81%94%E6%8F%90%E4%BE%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E3%83%BB%E3%82%AF%E3%83%9E%E3%83%BC%E3%83%AB%20K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%E3%81%A7ARM64%E7%92%B0%E5%A2%83%E3%81%AE%E3%82%B7%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%80%81weston%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81weston%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%A0%E3%81%91%E3%81%A7%E3%81%AA%E3%81%8F%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E5%85%A8%E4%BD%93%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3EGnar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AFarm64-linux%E3%82%B7%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E7%92%B0%E5%A2%83%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E7%92%B0%E5%A2%83%E3%81%A7Weston%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%9D%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%2Fusr%2Flib%2Faarch64-xx%20libGLES%E3%80%81libEGL%20%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBR%2C%3C%2FP%3E%3CP%3EGnar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%26nbsp%3B%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EGnar%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EWeston%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%E9%9A%9B%E3%81%AB%E3%80%81%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3Eexport%20XDG_RUNTIME_DIR%3D%2Frun%2Fuser%2F1000%3CBR%20%2F%3Esudo%20-E%20weston%20--tty%3D1%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3Eubuntu%40ubuntu%3A~%24%20export%20XDG_RUNTIME_DIR%3D%2Frun%2Fuser%2F1000%3CBR%20%2F%3Eubuntu%40ubuntu%3A~%24%20sudo%20-E%20weston%20--tty%3D1%3CBR%20%2F%3E%5Bsudo%5D%20iwave%E3%81%AE%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%EF%BC%9A%3CBR%20%2F%3E%E6%97%A5%E4%BB%98%EF%BC%9A2019%E5%B9%B410%E6%9C%8820%E6%97%A5%20UTC%3CBR%20%2F%3E%5B12%3A05%3A59.961%5Dweston%205.0.0%3CBR%20%2F%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fwayland.freedesktop.org%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwayland.freedesktop.org%3C%2FA%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%83%90%E3%82%B0%E5%A0%B1%E5%91%8A%E5%85%88%EF%BC%9A%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fgitlab.freedesktop.org%252Fwayland%252Fweston%252Fissues%252F%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgitlab.freedesktop.org%2Fwayland%2Fweston%2Fissues%2F%3C%2FA%3E%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%EF%BC%9A5.0.0-33-gfb563901MGS-4627%20%5B%23ccc%5D%20weston%E3%81%AF%E3%80%81panel-position%E3%81%8Cnone%E3%81%AE%E3%81%A8%E3%81%8D%E3%81%ABgplay%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AA%E3%83%95%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%882019%E5%B9%B43%E6%9C%8814%E6%97%A5%2011%3A30%3A30%20%2B0800%EF%BC%89%3CBR%20%2F%3E%5B12%3A05%3A59.961%5D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%EF%BC%9Aweston%20--tty%3D1%3CBR%20%2F%3E%5B12%3A05%3A59.961%5DOS%3A%20Linux%E3%80%814.14.98-imx_4.14.98_2.0.0_ga%2Bg5d6cbea%E3%80%81%231%20SMP%20PREEMPT%202019%E5%B9%B410%E6%9C%8814%E6%97%A5(%E6%9C%88)%2008%3A11%3A41%20UTC%E3%80%81aarch64%3CBR%20%2F%3E%5B12%3A05%3A59.961%5D%E8%AD%A6%E5%91%8A%EF%BC%9AXDG_RUNTIME_DIR%E3%80%8C%2Frun%2Fuser%2F1000%E3%80%8D%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3EUnix%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF0700%EF%BC%88%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF700%EF%BC%89%E3%81%A7%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%8C%E6%89%80%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%88%E7%8F%BE%E5%9C%A8%E3%81%AE%E6%89%80%E6%9C%89%E8%80%85%E3%81%AFUID%201000%EF%BC%89%E3%80%82%E5%85%A5%E6%89%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%3CBR%20%2F%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freedesktop.org%252Fwiki%252FSpecifications%252Fbasedir-spec%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.freedesktop.org%2Fwiki%2FSpecifications%2Fbasedir-spec%3C%2FA%3E%3CBR%20%2F%3E%E3%81%9D%E3%82%8C%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%82%3CBR%20%2F%3E%5B12%3A05%3A59.961%5D%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%AA%E3%81%84%E7%8A%B6%E6%85%8B%E3%81%A7%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B12%E6%99%8205%E5%88%8659%E7%A7%92962%5D%E5%87%BA%E5%8A%9B%E5%86%8D%E6%8F%8F%E7%94%BB%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%AE%E6%9C%80%E5%A4%A7%E5%80%A4%E3%81%AF16%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CSTRONG%3E%5B12%3A05%3A59.962%5D%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%8C%2Fusr%2Flib%2Flibweston-5%2Fdrm-backend.so%E3%80%8D%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B12%3A05%3A59.964%5D%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%2Fusr%2Flib%2Flibweston-5%2Fdrm-backend.so%EF%BC%9A%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AB%3A%20gbm_surface_get_in_fence_fd%3C%2FSTRONG%3E%3CBR%20%2F%3E%5B12%3A05%3A59.964%5D%E8%87%B4%E5%91%BD%E7%9A%84%EF%BC%9A%E3%82%B3%E3%83%B3%E3%83%9D%E3%82%B8%E3%82%BF%E3%83%BC%E3%81%AE%E3%83%90%E3%83%83%E3%82%AF%E3%82%A8%E3%83%B3%E3%83%89%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3Eubuntu%40ubuntu%3A~%24%3CBR%20%2F%3Eubuntu%40ubuntu%3A~%24%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3Eyocto%20build%E3%81%8B%E3%82%89ubuntu-rootfs%E3%81%AB%E3%80%8C%3CSTRONG%3Eweston%3C%2FSTRONG%3E%E3%80%8D%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%97%E3%81%9F%E3%82%89%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E3%83%BB%E3%82%AF%E3%83%9E%E3%83%BC%E3%83%AB%20K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%2C%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%8A%E4%BC%BA%E3%81%84%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%80%8C%3CSPAN%20class%3D%22%22%3Esudo%20mount%20-t%20proc%20%2Fproc%20%24%7B2%7Dproc%3C%2FSPAN%3E%E3%80%8D%E3%81%AA%E3%81%A9%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3CBR%20style%3D%22font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20line-height%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20-webkit-auto%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-size-adjust%3A%20auto%3B%20-webkit-text-stroke-width%3A%200px%3B%22%20%2F%3E%E3%83%9B%E3%82%B9%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWeston%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%82%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81Weston%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E6%AC%A1%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3Esudo%20-E%20weston%20--tty%3D1%3CBR%20%2F%3E%5Bsudo%5D%20password%20for%20user%3A%3CBR%20%2F%3EDate%3A%202019-10-18%20UTC%3CBR%20%2F%3E%5B08%3A42%3A03.809%5D%20weston%205.0.0%3CBR%20%2F%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fwayland.freedesktop.org%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwayland.freedesktop.org%3C%2FA%3E%3CBR%20%2F%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Bug%20reports%20to%3A%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fgitlab.freedesktop.org%252Fwayland%252Fweston%252Fissues%252F%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgitlab.freedesktop.org%2Fwayland%2Fweston%2Fissues%2F%3C%2FA%3E%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Build%3A%205.0.0-33-gfb563901%20MGS-4627%20%5B%23ccc%5D%20weston%20will%20turn%20off%20when%20panel-psotion%3Dnone%20and%20use%20gplay%20(2019-03-14%2011%3A30%3A30%20%2B0800)%3CBR%20%2F%3E%5B08%3A42%3A03.816%5D%20Command%20line%3A%20weston%20--tty%3D1%3CBR%20%2F%3E%5B08%3A42%3A03.816%5D%20OS%3A%20Linux%2C%204.14.98-imx_4.14.98_2.0.0_ga%2Bg64ad07d%2C%20%231%20SMP%20PREEMPT%20Tue%20Aug%2013%2013%3A06%3A25%20UTC%202019%2C%20aarch64%3CBR%20%2F%3E%5B08%3A42%3A03.816%5D%20warning%3A%20XDG_RUNTIME_DIR%20%22%2Frun%2Fuser%2F1000%22%20is%20not%20configured%3CBR%20%2F%3Ecorrectly.%26nbsp%3B%20Unix%20access%20mode%20must%20be%200700%20(current%20mode%20is%20700)%2C%3CBR%20%2F%3Eand%20must%20be%20owned%20by%20the%20user%20(current%20owner%20is%20UID%201000).%3CBR%20%2F%3ERefer%20to%20your%20distribution%20on%20how%20to%20get%20it%2C%20or%3CBR%20%2F%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freedesktop.org%252Fwiki%252FSpecifications%252Fbasedir-spec%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.freedesktop.org%2Fwiki%2FSpecifications%2Fbasedir-spec%3C%2FA%3E%3CBR%20%2F%3Eon%20how%20to%20implement%20it.%3CBR%20%2F%3E%5B08%3A42%3A03.826%5D%20Starting%20with%20no%20config%20file.%3CBR%20%2F%3E%5B08%3A42%3A03.839%5D%20Output%20repaint%20window%20is%2016%20ms%20maximum.%3CBR%20%2F%3E%5B08%3A42%3A03.845%5D%20Loading%20module%20'%2Fusr%2Flib%2Flibweston-5%2Fdrm-backend.so'%3CBR%20%2F%3E%5B08%3A42%3A03.952%5D%20initializing%20drm%20backend%3CBR%20%2F%3E%5B08%3A42%3A03.955%5D%20using%20%2Fdev%2Fdri%2Fcard0%3CBR%20%2F%3E%5B08%3A42%3A03.955%5D%20DRM%3A%20supports%20universal%20planes%3CBR%20%2F%3E%5B08%3A42%3A03.955%5D%20DRM%3A%20supports%20atomic%20modesetting%3CBR%20%2F%3E%5B08%3A42%3A03.955%5D%20DRM%3A%20does%20not%20support%20picture%20aspect%20ratio%3CBR%20%2F%3E%5B08%3A42%3A03.960%5D%20Loading%20module%20'%2Fusr%2Flib%2Flibweston-5%2Fgl-renderer.so'%3CBR%20%2F%3E%5B08%3A42%3A04.302%5D%20EGL%20client%20extensions%3A%20EGL_EXT_device_base%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20EGL_EXT_device_enumeration%20EGL_EXT_device_query%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20EGL_EXT_platform_base%20EGL_KHR_client_get_all_proc_addresses%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20EGL_EXT_client_extensions%20EGL_KHR_debug%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20EGL_EXT_platform_wayland%20EGL_EXT_platform_x11%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20EGL_MESA_platform_gbm%20EGL_MESA_platform_surfaceless%3CBR%20%2F%3E%5B08%3A42%3A04.304%5D%20failed%20to%20initialize%20display%3CBR%20%2F%3E%5B08%3A42%3A04.304%5D%20EGL%20error%20state%3A%20EGL_NOT_INITIALIZED%20(0x3001)%3CBR%20%2F%3E%5B08%3A42%3A04.304%5D%20failed%20to%20initialize%20egl%3CBR%20%2F%3E%5B08%3A42%3A04.341%5D%20fatal%3A%20failed%20to%20create%20compositor%20backend%3C%2FP%3E%3C%2FBLOCKQUOTE%3EHave%20you%20ever%20seen%20a%20similar%20error%20message%3F%20%3CBR%20%2F%3EThank%20you.%20%3CBR%20%2F%3E%3CBR%20%2F%3ERegards%2C%3CBR%20%2F%3ELorenzo%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128726%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128726%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%20%3CSTRONG%3Emake%3C%2FSTRONG%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AB%E3%80%81%3CSTRONG%3Eweston-imx%3C%2FSTRONG%3E%20%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%AC%A1%E3%81%AE%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%AE%A3%E8%A8%80%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Eweston%E3%81%AE%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23cd%20~%2Fweston%3CBR%20%2F%3E%3CSPAN%3E%23git%20clone%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fsource.codeaurora.org%252Fexternal%252Fimx%252Fweston-imx.git%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Fweston-imx.git%3C%2FA%3E%3CBR%20%2F%3E%23cd%20weston-imx%3CBR%20%2F%3E%23git%20checkout%20fb563901657b296c7c7c86d26602a622429e334f%3CBR%20%2F%3E%23.%2Fautogen.sh%20--prefix%3D%2Fusr%20--disable-silent-rules%20--disable-dependency-tracking%26nbsp%3B%20--enable-setuid-install%20--disable-rdp-compositor%20--enable-clients%20--enable-simple-clients%20--enable-demo-clients-install%20--disable-colord%20--enable-egl%20--enable-simple-egl-clients%20--enable-fbdev-compositor%20--disable-headless-compositor%20--enable-drm-compositor%20--enable-weston-launch%20--disable-lcms%20--disable-libunwind%20--with-pam--disable-vaapi-recorder%20--enable-wayland-compositor%20--without-webp%20--disable-x11-compositor%20--enable-xwayland%20--enable-imxg2d%20--enable-imxgpu%20--enable-drm-compositor%20--enable-opengl%3CBR%20%2F%3E%23make%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3Elibweston%2Fcompositor-drm.c%3A%E9%96%A2%E6%95%B0%E3%80%8Cdrm_fb_addfb%E3%80%8D%E5%86%85%E3%81%A7%EF%BC%9Alibweston%2Fcompositor-drm.c%3A962%3A23%3A%3CSTRONG%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E2%80%98DRM_FORMAT_MOD_AMPHION_TILED%E2%80%99%20%E3%81%8C%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSTRONG%3E%EF%BC%88%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E5%86%85%E3%81%A7%E6%9C%80%E5%88%9D%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%99%EF%BC%89%EF%BC%9B%E2%80%98DRM_FORMAT_MOD_VIVANTE_TILED%E2%80%99%E3%81%AE%E8%AA%A4%E3%82%8A%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%EF%BC%9F%20if%20(fb-%26gt%3Bmodifier%20%3D%3D%20DRM_FORMAT_MOD_AMPHION_TILED)%20%7BDRM_FORMAT_MOD_VIVANTE_TILEDlibweston%2Fcompositor-drm.c%3A962%3A23%3A%E6%B3%A8%3A%20%E6%9C%AA%E5%AE%A3%E8%A8%80%E3%81%AE%E8%AD%98%E5%88%A5%E5%AD%90%E3%81%AF%E3%80%81%E5%87%BA%E7%8F%BE%E3%81%99%E3%82%8B%E5%90%84%E9%96%A2%E6%95%B0%E3%81%A71%E5%9B%9E%E3%81%A0%E3%81%91%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99libweston%2Fcompositor-drm.c%3A%E9%96%A2%E6%95%B0%E3%80%8Edrm_clip_overlay_coordinate%E3%80%8F%3Alibweston%2Fcompositor-drm.c%3A1518%3A36%3A%20%E8%AD%A6%E5%91%8A%3A%20%E7%AC%A6%E5%8F%B7%E4%BB%98%E3%81%8D%E6%95%B4%E6%95%B0%E5%BC%8F%E3%81%A8%E7%AC%A6%E5%8F%B7%E3%81%AA%E3%81%97%E6%95%B4%E6%95%B0%E5%BC%8F%E3%81%AE%E6%AF%94%E8%BC%83%20%5B-Wsign-compare%5D%20if%20(state-%26gt%3Bdest_x%20%2B%20state-%26gt%3Bdest_w%20%26gt%3B%20output-%26gt%3Bbase.current_mode-%26gt%3Bwidth)%7B%5Elibweston%2Fcompositor-drm.c%3A1526%3A36%3A%E8%AD%A6%E5%91%8A%3A%E7%AC%A6%E5%8F%B7%E4%BB%98%E3%81%8D%E6%95%B4%E6%95%B0%E5%BC%8F%E3%81%A8%E7%AC%A6%E5%8F%B7%E3%81%AA%E3%81%97%E6%95%B4%E6%95%B0%E5%BC%8F%E3%81%AE%E6%AF%94%E8%BC%83%5B-Wsign-compare%5D%20if%20(state-%26gt%3Bdest_y%20%2B%20state-%26gt%3Bdest_h%20%26gt%3B%20output-%26gt%3Bbase.current_mode-%26gt%3Bheight)%7B%5Elibweston%2Fcompositor-drm.c%3A%20%E9%96%A2%E6%95%B0%E3%80%8Edrm_get_gbm_alignment%E3%80%8F%3Alibweston%2Fcompositor-drm.c%3A2184%3A9%3A%20%3CSTRONG%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%80%8EDRM_FORMAT_MOD_VIVANTE_SUPER_TILED_FC%E3%80%8F%E3%81%8C%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSTRONG%3E%EF%BC%88%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%A7%E5%88%9D%E3%82%81%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%EF%BC%89%EF%BC%9B%E3%80%8CDRM_FORMAT_MOD_VIVANTE_SUPER_TILED%E3%80%8D%E3%81%A8%E8%A8%80%E3%81%84%E3%81%9F%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%E3%82%B1%E3%83%BC%E3%82%B9%20DRM_FORMAT_MOD_VIVANTE_SUPER_TILED_FC%3ADRM_FORMAT_MOD_VIVANTE_SUPER_TILEDlibweston%2Fcompositor-drm.c%3A%20%E9%96%A2%E6%95%B0%E3%80%8Cdrm_output_apply_state_atomic%E3%80%8D%EF%BC%9Alibweston%2Fcompositor-drm.c%3A2600%3A4%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A%E9%96%A2%E6%95%B0%E3%80%8Cgbm_surface_set_sync_post%E3%80%8D%E3%81%AE%E6%9A%97%E9%BB%99%E3%81%AE%E5%AE%A3%E8%A8%80%EF%BC%9B%E3%80%8Cgbm_surface_destroy%E3%80%8D%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%5B-Wimplicit-function-declaration%5D%20gbm_surface_set_sync_post(output-%26gt%3Bgbm_surface%2C%200)%3Bgbm_surface_destroylibweston%2Fcompositor-drm.c%3A2601%3A18%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A%E9%96%A2%E6%95%B0%E3%80%8Cgbm_surface_get_in_fence_fd%E3%80%8D%E3%81%AE%E6%9A%97%E9%BB%99%E3%81%AE%E5%AE%A3%E8%A8%80%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%80%8Cwl_surface_send_enter%E3%80%8D%E3%81%AE%E8%AA%A4%E3%82%8A%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%EF%BC%9F%20%5B-Wimplicit-function-declaration%5D%20in_fence_fd%20%3D%20gbm_surface_get_in_fence_fd(output-%26gt%3Bgbm_surface)%3Bwl_surface_send_enterlibweston%2Fcompositor-drm.c%3A%E9%96%A2%E6%95%B0%20%E2%80%98drm_query_dmabuf_modifiers%E2%80%99%3Alibweston%2Fcompositor-drm.c%3A3291%3A49%3A%20%E8%AD%A6%E5%91%8A%3A%20%E7%AC%A6%E5%8F%B7%E4%BB%98%E3%81%8D%E6%95%B4%E6%95%B0%E5%BC%8F%E3%81%A8%E7%AC%A6%E5%8F%B7%E3%81%AA%E3%81%97%E6%95%B4%E6%95%B0%E5%BC%8F%E3%81%AE%E6%AF%94%E8%BC%83%20%5B-Wsign-compare%5D%20if%20(p-%26gt%3Bformats%5Bi%5D.format%20!%3D%20format)libweston%2Fcompositor-drm.c%3A%20%E9%96%A2%E6%95%B0%E3%80%8Cdrm_import_dmabuf%E3%80%8D%E5%86%85%3Alibweston%2Fcompositor-drm.c%3A3342%3A37%3A%20%3CSTRONG%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%80%8CDRM_FORMAT_P010%E3%80%8D%E3%81%8C%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSTRONG%3E%EF%BC%88%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%A7%E3%81%AE%E5%88%9D%E5%9B%9E%E4%BD%BF%E7%94%A8%EF%BC%89%3B%E3%80%8CDRM_FORMAT_R16%E3%80%8D%E3%81%A8%E8%A8%80%E3%81%84%E3%81%9F%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%20%26amp%3B%26amp%3B%20dmabuf-%26gt%3Battributes.format%20%3D%3D%20DRM_FORMAT_P010)DRM_FORMAT_R16libweston%2Fcompositor-drm.c%3A%E9%96%A2%E6%95%B0%E3%80%8Cdrm_output_propose_state%E3%80%8D%E3%81%A7%3Alibweston%2Fcompositor-drm.c%3A3752%3A38%3A%20%3CSTRONG%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%80%8CDRM_FORMAT_P010%E3%80%8D%E3%81%8C%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSTRONG%3E%EF%BC%88%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%A7%E3%81%AE%E5%88%9D%E5%9B%9E%E4%BD%BF%E7%94%A8%EF%BC%89%3B%E3%80%8CDRM_FORMAT_R16%E3%80%8D%E3%81%A8%E8%A8%80%E3%81%84%E3%81%9F%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%20%7C%7C%20dmabuf-%26gt%3Battributes.format%20%3D%3D%20DRM_FORMAT_P010DRM_FORMAT_R16libweston%2Fcompositor-drm.c%3A%E9%96%A2%E6%95%B0%E3%80%8Chdr10_metadata_set_metadata%E3%80%8D%E3%81%A7%EF%BC%9A%3CBR%20%2F%3Elibweston%2Fcompositor-drm.c%3A7250%3A29%3A%20%3CSTRONG%3E%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9A%E3%80%8Chdr_metadata%E3%80%8D%E3%81%AE%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%E4%B8%8D%E6%98%8E%E3%81%A7%E3%81%99%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%E6%A7%8B%E9%80%A0%E4%BD%93%20hdr_static_metadata%20hdr_metadata%3B%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E3%83%BB%E3%82%AF%E3%83%9E%E3%83%BC%E3%83%AB%20K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128725%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128725%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%3C%2FP%3E%3CP%3Eqemu%E7%92%B0%E5%A2%83%E3%81%A7%3CSTRONG%3Eweston%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%3C%2FSTRONG%3E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3EGnar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F343939-3-454211%2FUbuntu-i.MX8-weston.pdf%22%20target%3D%22_blank%22%3E%E3%81%BE%E3%81%9F%E3%80%81https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F343939-3-454211%2FUbuntu-i.MX8-weston.pdf%3C%2FA%3E%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%80%81Ubuntu%2018.04%E3%82%924.14.98%20BSP%E3%81%AEiMX8%E3%82%AF%E3%82%A2%E3%83%83%E3%83%89%E3%83%9E%E3%83%83%E3%82%AF%E3%82%B9%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%9F%E6%96%87%E6%9B%B8%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%3CSTRONG%3E9.%20imx-gpu-viv%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%3C%2FSTRONG%3E%E3%81%BE%E3%81%A7%E3%81%AF%E3%80%81%E6%AD%A3%E3%81%97%E3%81%8F%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%3CSTRONG%3E10.weston%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FSTRONG%3E%E3%81%AE%E5%BE%8C%E3%80%81weston%E3%80%81wayland%E3%80%81gstreamer%E3%80%81gst-plugins%E3%82%92%E3%81%A9%E3%81%93%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%AF%E6%9B%B8%E3%81%8B%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%EF%BC%9F%E4%B8%8A%E8%A8%98%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E3%80%8C%3CSTRONG%3Eubuntu-rootfs%3C%2FSTRONG%3E%E3%80%8D%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%2F%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%97%E3%81%9F%E3%82%89%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E3%83%BB%E3%82%AF%E3%83%9E%E3%83%BC%E3%83%AB%20K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128721%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128721%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%B0%A1%E5%8D%98%E3%81%AA%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Flinux-imx%2F%22%20title%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Flinux-imx%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Elinux-imx%20-%20i.MX%20Linux%20kernel%3C%2FA%3E%E7%94%A8%E3%81%AElinux-imx%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%80%8C%24%20make%20defconfig%E3%80%81%24%20make%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%94%BB%E5%83%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%8F%BE%E5%9C%A8%E3%81%AE%E7%94%BB%E5%83%8F%E3%82%92%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3EGnar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E5%80%8B%E5%88%A5%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E7%A7%81%E3%81%AF%E3%83%95%E3%82%A7%E3%83%AD%E3%83%BC%E3%82%A4%E3%83%B3%E3%82%B0%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%9D%E3%82%8C%E3%82%92%E4%BD%9C%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ebitbake%20-c%20compile%20-f%20-v%20linux-imx%3CBR%20%2F%3Ebitbake%20linux-imx%20-c%20compile_kernelmodules%20-f%20-v%3CBR%20%2F%3Ebitbake%20-c%20deploy%20-f%20-v%20linux-imx%3C%2FP%3E%3CP%3Eresult%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20637px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F84926i2FE987F365C30814%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E5%89%8D%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F84984i550C72CDFC021B7E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Egalcore%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8B%E7%95%AA%E5%8F%B7%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81qca6174%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%A4%9A%E3%81%8F%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E3%81%9D%E3%82%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128719%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128719%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20gao%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81GPU%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90galcore%E3%81%AF.ko%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E5%86%85%E3%81%ABgalcore%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E5%88%A5%E9%80%94%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3EGnar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128717%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128717%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2CAnrit%3C%2FP%3E%3CP%3E1.%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EYocto%E3%81%AE%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eimx-dpu-2d%E3%83%91%E3%82%B9%E3%81%AF%2Fbuildxwayland%2Ftmp%2Fwork%2Faarch64-mx8mm-poky-linux%2Fimx-gpu-g2d%E3%81%A7%E3%80%818MM%E3%81%AB%E3%81%AFDPU%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E2.%20%E6%9C%80%E5%88%9D%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AB%E6%88%BB%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%22%3E.%2Fautogen.sh%20--prefix%3D%2Fusr%20--disable-silent-rules%20--disable-dependency-tracking%20--enable-setuid-install%20--disable-rdp-compositor%20--enable-clients%20--enable-simple-clients%20--enable-demo-clients-install%20--disable-colord%20--enable-egl%20--enable-simple-egl-clients%20--enable-fbdev-compositor%20--disable-headless-compositor%20--enable-drm-compositor%20--enable-weston-launch%20--disable-lcms%20--disable-libunwind%20--with-pam%20--disable-vaapi-recorder%20--enable-wayland-compositor%20--without-webp%20--disable-x11-compositor%20--disable-xwayland%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%22%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%AD%E3%82%B0%E3%81%AF%E6%AC%A1%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%22%3E1)configure%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A--build%E3%80%81--host%E3%80%81--target%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%22%3E2)%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E7%84%A1%E5%8A%B9%E3%81%AA%E8%A8%AD%E5%AE%9A%E3%80%8Cclients%E3%80%8D%EF%BC%9A%E3%83%9E%E3%82%B7%E3%83%B3%E3%80%8Cclients%E3%80%8D%E3%81%8C%E8%AA%8D%E8%AD%98%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eqemu%E7%92%B0%E5%A2%83%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E7%A7%81%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%A7%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%9B%E3%81%9A%E3%80%81%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%82%82%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%83%AD%E3%82%B0%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81Weston%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%96%B9%E6%B3%95%E3%82%92Google%E3%81%A7%E6%A4%9C%E7%B4%A2%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E--build%E3%80%81--host%E3%80%81--target%3C%2FSPAN%3E%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E5%BC%95%E6%95%B0%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%E3%81%BE%E3%81%9Axwayland%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%22%3Exwayland%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%22%3EBR%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%22%3EGnar%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20Gnar%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%96%87%E6%9B%B8%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%9F%E3%81%8A%E3%81%8B%E3%81%92%E3%81%A7%E3%80%81%E7%A7%81%E3%81%AF%E4%BB%8AUbuntu%E3%81%AE%E6%A7%8B%E7%AF%89%E3%81%AB%E9%9D%9E%E5%B8%B8%E3%81%AB%E8%BF%91%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%AE%8B%E3%82%8A%E3%81%AE%E3%82%A2%E3%82%A4%E3%83%86%E3%83%A0%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1.%E7%A7%81%E3%81%AEYocto%E3%83%93%E3%83%AB%E3%83%89%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E3%81%AB%E3%81%AF%E3%80%81imx-dpu-2d%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%AE%E3%82%82%E3%81%AE%E3%81%AF%E8%A6%8B%E5%BD%93%E3%81%9F%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E5%86%85%E3%81%A7%E3%81%93%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Esudo%20cp%20-Pra%20imx-dpu-g2d-1.7.0%2Fimx-dpu-g2d%2F1.7.0-r0%2Fimage%2F*%20ubuntu18.04%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E7%A7%81%E3%81%AEDISTRO%E3%81%AFfsl-imx-xwayland%E3%81%A7%E3%80%81MACHINE%E3%81%AFimx8mmevk%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E2.%3C%2FSPAN%3E.%E5%89%8D%E5%9B%9E%E3%81%AEweston-imx%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%A7%E3%81%8A%E3%81%A3%E3%81%97%E3%82%83%E3%81%A3%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%82%AA%E3%83%BC%E3%83%88%E3%82%B8%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E8%87%AA%E5%8B%95%E7%94%9F%E6%88%90%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E4%B8%AD%E3%81%AB%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%A1%E3%82%89%E3%81%8C%E7%A7%81%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E.........................%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eroot%40UB160401%3A~%2Fweston%2Fweston-imx%23%20.%2Fautogen.sh%20--prefix%3D%2Fusr%20--disable-silent-rules%20--disable-dependency-tracking%20--enable-setuid-install%20--disable-rdp-compositor%20--enable-clients%20--enable-simple-clients%20--enable-demo-clients-install%20--disable-colord%20--enable-egl%20--enable-simple-egl-clients%20--enable-fbdev-compositor%20--disable-headless-compositor%20--enable-drm-compositor%20--enable-weston-launch%20--disable-lcms%20--disable-libunwind%20--with-pam%20--disable-vaapi-recorder%20--enable-wayland-compositor%20--without-webp%20--disable-x11-compositor%20--enable-xwayland%20--enable-imxg2d%20--enable-imxgpu%20--enable-drm-compositor%20--enable-opengl%3C%2FSPAN%3E....%3C%2FP%3E%3CP%3E..................%3C%2FP%3E%3CP%3E.................%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EOpenGL%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E2%80%A6%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EGL_RENDERER%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EXKBCOMMON_COMPOSE%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EXWAYLAND%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%E3%81%84%E3%81%84%E3%81%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Econfigure%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9A%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E8%A6%81%E4%BB%B6%EF%BC%88xcb%E3%80%81xcb-xfixes%E3%80%81xcb-composite%E3%80%81xcb-shape%E3%80%81xcursor%E3%80%81cairo-xcb%EF%BC%89%E3%81%8C%E6%BA%80%E3%81%9F%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%80%8Cxcb-xfixes%E3%80%8D%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%80%8Cxcb-composite%E3%80%8D%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%80%8Cxcb-shape%E3%80%8D%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%20'xcursor'%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EPKG_CONFIG_PATH%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%82%92%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%A4%9C%E8%A8%8E%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E9%9D%9E%E6%A8%99%E6%BA%96%E3%81%AE%E3%83%97%E3%83%AC%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E3%80%81%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0XWAYLAND_CFLAGS%E3%82%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EXWAYLAND_LIBS%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%80%81pkg-config%E3%82%92%E8%AA%AD%E3%81%BF%E5%87%BA%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81pkg-config%20%E3%81%AE%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%9A%E3%83%BC%E3%82%B8%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E4%BD%95%E3%81%8B%E3%81%94%E6%8F%90%E6%A1%88%E3%81%AF%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EAmrit%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128714%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128714%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81Gnar%E3%81%95%E3%82%93%E3%81%A8Kyle%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A4%87%E6%95%B0%E3%81%AE%E4%BA%BA%E3%81%8C%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%AC%89%E3%81%97%E3%81%8F%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9A%E3%80%81%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E9%87%8D%E8%A6%81%E3%81%AA%E6%89%8B%E9%A0%86%E3%82%92%E6%A6%82%E8%AA%AC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%A3%E3%81%9F%20Gnar%20%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%AB%E3%82%A4%E3%83%AB%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81yocto%E3%83%93%E3%83%AB%E3%83%89%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E3%81%8B%E3%82%89%20~%2Frootfs%2Fubuntu-rootfs%EF%BC%88%E3%81%BE%E3%81%9F%E3%81%AF%20~%2Frootfs%2Fubuntu18.04%EF%BC%89%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E7%89%B9%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%90%84%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E5%90%8D%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Ecd%20~%2Fimx-yocto-bsp%2Fbuild%2Ftmp%2Fwork%2Faarch64-mx8mm-poky-linux%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Esudo%20cp%20-Pra%20libdrm%2F2.4.91.imx-r0%2Fimage%2F*%20%3CSPAN%3E~%2Frootfs%2Fubuntu-rootfs%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Esudo%20cp%20-Pra%20imx-gpu-viv%2F1_6.2.4.p4.0-aarch64-r0%2Fimage%2F*%20~%2Frootfs%2Fubuntu-rootfs%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Esudo%20cp%20-Pra%20~%2Fimx-yocto-bsp%2Fbuild%2Ftmp%2Fwork%2Faarch64-mx8mm-poky-linux%2Fimx-gpu-g2d%2F6.2.4.p4.0-r0%2Fimage%2F*%20~%2Frootfs%2Fubuntu-rootfs%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Ecd%20~%2Fimx-yocto-bsp%2Fbuild%2Ftmp%2Fwork%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Esudo%20cp%20-r%20all-poky-linux%2Ffirmware-imx%2F1_8.1-r0%2Fimage%2F*%20~%2Frootfs%2Fubuntu-rootfs%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E7%A7%81%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81rootfs%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E3%81%AF~%2Frootfs%2Fubuntu-rootfs%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EGnar%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EGnome%E3%81%BE%E3%81%9F%E3%81%AFxfce4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E5%BD%A2%E5%BC%8F%E3%81%A7ubuntu18.04%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%82%92rootfs%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E9%80%94%E4%B8%AD%E3%81%A7%E3%81%99%E3%80%82weston-imx%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%973%EF%BC%89%E3%81%A7%E5%A5%87%E5%A6%99%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E6%B0%97%E4%BB%98%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eweston-imx%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6autogen%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E9%9A%9B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%AD%E3%82%B0%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eroot%40UB160401%3A~%2Fweston%2Fweston-imx%23%20.%2Fautogen.sh%20--prefix%3D%2Fusr%20--disable-silent-rules%20--disable-dependency-tracking%20--enable-setuid-install%20--disable-rdp-compositor%20--enable-clients%20--enable-simple-%20clients%20--enable-demo-clients-install%20--disable-colord%20--enable-egl%20--enable-%20simple-egl-clients%20--enable-fbdev-compositor%20--disable-headless-compositor%20--%20enable-drm-compositor%20--enable-weston-launch%20--disable-lcms%20--disable-libunwind%20--with-pam%20--disable-vaapi-recorder%20--enable-wayland-compositor%20--without-webp%20--disable-x11-compositor%20--disable-xwayland%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eautoreconf%3A%20%E5%85%A5%E5%8A%9B%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%60.'%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eautoreconf%3A%20configure.ac%3AGettext%E3%81%AF%E6%9C%AA%E4%BD%BF%E7%94%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eautoreconf%3A%20%E5%AE%9F%E8%A1%8C%E4%B8%AD%3A%20aclocal%20--force%20-I%20m4%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eautoreconf%3A%20configure.ac%3A%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eautoreconf%3A%20%E5%AE%9F%E8%A1%8C%E4%B8%AD%3A%20libtoolize%20--copy%20--force%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Elibtoolize%3A%20%E8%A3%9C%E5%8A%A9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%20AC_CONFIG_AUX_DIR%E3%80%81%E3%80%8Cbuild-aux%E3%80%8D%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Elibtoolize%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8Cbuild-aux%2Fltmain.sh%E3%80%8D%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Elibtoolize%3A%20%E3%83%9E%E3%82%AF%E3%83%AD%E3%82%92AC_CONFIG_MACRO_DIRS%E3%80%81%E3%80%8Cm4%E3%80%8D%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Elibtoolize%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8Cm4%2Flibtool.m4%E3%80%8D%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Elibtoolize%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8Cm4%2Fltoptions.m4%E3%80%8D%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Elibtoolize%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8Cm4%2Fltsugar.m4%E3%80%8D%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Elibtoolize%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8Cm4%2Fltversion.m4%E3%80%8D%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Elibtoolize%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8Cm4%2Flt~obsolete.m4%E3%80%8D%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eautoreconf%3A%20%E5%AE%9F%E8%A1%8C%E4%B8%AD%3A%20%2Fusr%2Fbin%2Fautoconf%20--force%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eautoreconf%3A%20%E5%AE%9F%E8%A1%8C%E4%B8%AD%3A%20%2Fusr%2Fbin%2Fautoheader%20--force%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eautoreconf%3A%20%E5%AE%9F%E8%A1%8C%E4%B8%AD%3A%20automake%20--add-missing%20--copy%20--force-missing%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Econfigure.ac%3A35%3A%E3%80%8Cbuild-aux%2Fcompile%E3%80%8D%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Econfigure.ac%3A43%3A%E3%80%8Cbuild-aux%2Fmissing%E3%80%8D%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EMakefile.am%3A%E3%80%8Cbuild-aux%2Fdepcomp%E3%80%8D%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eautoreconf%3A%20%E5%87%BA%E5%8F%A3%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20%60.'%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Econfigure%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A--build%E3%80%81--host%E3%80%81--target%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Econfigure%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A--build%E3%80%81--host%E3%80%81--target%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Econfigure%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A--build%E3%80%81--host%E3%80%81--target%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Econfigure%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A--build%E3%80%81--host%E3%80%81--target%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Econfigure%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A--build%E3%80%81--host%E3%80%81--target%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Econfigure%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A--build%E3%80%81--host%E3%80%81--target%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Econfigure%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A--build%E3%80%81--host%E3%80%81--target%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Econfigure%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A--build%E3%80%81--host%E3%80%81--target%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Econfigure%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A--build%E3%80%81--host%E3%80%81--target%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Econfigure%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A--build%E3%80%81--host%E3%80%81--target%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Econfigure%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A--build%E3%80%81--host%E3%80%81--target%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Econfigure%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A--build%E3%80%81--host%E3%80%81--target%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Econfigure%3A%20%E8%AD%A6%E5%91%8A%3A%20%E8%AA%8D%E8%AD%98%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3A%20--enable-simple-%E3%80%81--enable-%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E7%94%A8gcc%E3%81%AE%E7%A2%BA%E8%AA%8D...%20%E3%81%AA%E3%81%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Egcc%E3%81%AE%E7%A2%BA%E8%AA%8D...%20gcc%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EC%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EC%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E5%87%BA%E5%8A%9B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20a.out%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E6%8E%A5%E5%B0%BE%E8%AA%9E%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E3%82%AF%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%84%E3%81%84%E3%81%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%82%B5%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...o%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EGNU%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Egcc%20%E3%81%8C%20-g%20%E3%82%92%E5%8F%97%E3%81%91%E5%85%A5%E3%82%8C%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%AF%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EISO%20C89%E3%82%92%E5%8F%97%E3%81%91%E5%85%A5%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AEgcc%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E4%BD%95%E3%82%82%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Egcc%20%E3%81%8C%20-c%20%E3%81%A8%20-o%20%E3%82%92%E5%90%8C%E6%99%82%E3%81%AB%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EC%E3%83%97%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%E5%AE%9F%E8%A1%8C%E6%96%B9%E6%B3%95%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20gcc%20-E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E9%95%B7%E3%81%84%E8%A1%8C%E3%81%A8-e%E3%82%92%E5%87%A6%E7%90%86%E3%81%99%E3%82%8Bgrep%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%2Fbin%2Fgrep%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eegrep%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%2Fbin%2Fgrep%20-E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EANSI%20C%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Esys%2Ftypes.h%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Esys%2Fstat.h%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Estdlib.h%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Estring.h%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Ememory.h%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Estrings.h%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Einttypes.h%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Estdint.h%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eunistd.h%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eminix%2Fconfig.h%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%93%E3%83%AA%E3%83%86%E3%82%A3%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20...%E3%81%84%E3%81%84%E3%81%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eminix%2Fconfig.h%E3%81%AE%E5%AD%98%E5%9C%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E2%80%A6%20%E3%81%84%E3%81%84%E3%81%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eminix%2Fconfig.h%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%84%E3%81%84%E3%81%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E__EXTENSIONS__%20%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%A6%E3%82%82%E5%AE%89%E5%85%A8%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E5%A4%A7%E3%81%8D%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E7%89%B9%E5%88%A5%E3%81%AAC%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%E3%81%84%E3%81%84%E3%81%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E5%A4%A7%E3%81%8D%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA_FILE_OFFSET_BITS%E3%81%AE%E5%80%A4%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%E3%81%84%E3%81%84%E3%81%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Esys%2Ftypes.h%E3%81%8Cmakedev%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%84%E3%81%84%E3%81%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Esys%2Fmkdev.h%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%93%E3%83%AA%E3%83%86%E3%82%A3%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20...%E3%81%84%E3%81%84%E3%81%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Esys%2Fmkdev.h%E3%81%AE%E5%AD%98%E5%9C%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E2%80%A6%20%E3%81%84%E3%81%84%E3%81%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Esys%2Fmkdev.h%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%84%E3%81%84%E3%81%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Esys%2Fsysmacros.h%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%93%E3%83%AA%E3%83%86%E3%82%A3%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E2%80%A6%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Esys%2Fsysmacros.h%E3%81%AE%E5%AD%98%E5%9C%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E2%80%A6%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Esys%2Fsysmacros.h%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EBSD%E4%BA%92%E6%8F%9B%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%2Fusr%2Fbin%2Finstall%20-c%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E3%83%93%E3%83%AB%E3%83%89%E7%92%B0%E5%A2%83%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%E3%81%AF%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%BB%E3%83%BC%E3%83%95%E3%81%AA%20mkdir%20-p%20%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%2Fbin%2Fmkdir%20-p%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Egawk%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%84%E3%81%84%E3%81%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Emawk%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...mawk%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Emake%E3%81%8C%24(MAKE)%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Emake%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8Binclude%E3%81%AE%E3%82%B9%E3%82%BF%E3%82%A4%E3%83%AB%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20GNU%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Emake%20%E3%81%8C%E3%83%8D%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E5%A4%89%E6%95%B0%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Egcc%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%B9%E3%82%BF%E3%82%A4%E3%83%AB%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%E3%81%AA%E3%81%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Emake%20%E3%81%8C%E3%83%8D%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E5%A4%89%E6%95%B0%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E4%B8%AD...%EF%BC%88%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E6%B8%88%E3%81%BF%EF%BC%89%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AEgcc%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20gcc%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EGNU%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%EF%BC%88%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E6%B8%88%E3%81%BF%EF%BC%89%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Egcc%E3%81%8C-g%E3%82%92%E5%8F%97%E3%81%91%E5%85%A5%E3%82%8C%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%EF%BC%88%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E6%B8%88%E3%81%BF%EF%BC%89%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EISO%20C89%E3%82%92%E5%8F%97%E3%81%91%E5%85%A5%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AEgcc%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%EF%BC%88%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E6%B8%88%E3%81%BF%EF%BC%89%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Egcc%E3%81%8C-c%E3%81%A8-o%E3%82%92%E5%90%8C%E6%99%82%E3%81%AB%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E2%80%A6%EF%BC%88%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E6%B8%88%E3%81%BF%EF%BC%89%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E5%87%BA%E5%8A%9B%E3%82%92%E5%88%87%E3%82%8A%E6%8D%A8%E3%81%A6%E3%81%AA%E3%81%84sed%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%20%2Fbin%2Fsed%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E3%83%93%E3%83%AB%E3%83%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E7%A8%AE%E9%A1%9E%E3%82%92%E7%A2%BA%E8%AA%8D%E4%B8%AD...%20%E7%84%A1%E5%8A%B9%E3%81%AA%E6%A7%8B%E6%88%90%E3%80%8Cclients%E3%80%8D%3A%20%E3%83%9E%E3%82%B7%E3%83%B3%E3%80%8Cclients%E3%80%8D%E3%81%8C%E8%AA%8D%E8%AD%98%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Econfigure%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%2Fbin%2Fbash%20build-aux%2Fconfig.sub%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E7%A7%81%E3%81%8C%E8%A6%8B%E9%80%83%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%AA%E3%81%84%E3%82%82%E3%81%AE%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E4%BD%95%E3%81%8B%E6%89%8B%E3%81%8C%E3%81%8B%E3%82%8A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E3%81%A1%E3%81%AA%E3%81%BF%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AF%20imx8m%20mini%20evk%20-%20yocto%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%AF%E9%81%95%E3%81%84%E3%81%8C%E3%81%AA%E3%81%84%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E3%81%8A%E4%BA%8C%E4%BA%BA%E3%81%A8%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EAmrit%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AB%E4%BD%95%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%AE%E3%81%8B%E3%80%81%E5%B0%91%E3%81%97%E6%B7%B7%E4%B9%B1%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%EF%BC%88Ubuntu-imx8-weston.pdf%EF%BC%89%3CBR%20%2F%3E%E3%81%93%E3%81%A1%E3%82%89%E3%81%AB%E3%81%AF%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E2)%20Yocto%E3%81%8B%E3%82%89libdrm%E3%80%81wayland%E3%80%81vpu-firmware%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%24sudo%20cp%20-Pra%20libdrm%2F2.4.91.imx-r0%2Fimage%2F*%20ubuntu18.04%2F%3C%2FP%3E%3CP%3E%24sudo%20cp%20-Pra%20imx-gpu-viv%2F1_6.2.4.p4.0-aarch64-r0%2Fimage%2F*%20ubuntu18.04%2F%3C%2FP%3E%3CP%3E%24sudo%20cp%20-Pra%20imx-dpu-g2d-1.7.0%2Fimx-dpu-g2d%2F1.7.0-ro%2Fimage%2F*%20ubuntu%2018.04%2F%3C%2FP%3E%3CP%3E%24sudo%20cp%20-r%20all-poky-linux%2Ffirmware-imx%2F1_8.1-r0%2Fimage%2F*%20ubuntu18.04%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AE%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E3%83%91%E3%82%B9%E3%81%8C%E5%88%86%E3%81%8B%E3%82%8C%E3%81%B0%E3%80%81%E7%90%86%E8%A7%A3%E3%81%97%E3%82%84%E3%81%99%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E6%83%B3%E5%AE%9A%E3%81%A7%E3%81%AF%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AFYocto%E3%83%93%E3%83%AB%E3%83%89%E3%81%8B%E3%82%89%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99...%20%2Flibdrm%2F2.4.91.imx-ro%2Fimage%2F%E3%80%81%2Fimx-gpu-viv%2F1_6.2.4.p4.0-aarch64-ro%2Fimage%2F%E3%80%81%2Fimx-dpu-g2d-1.7.0%2Fimx-dpu-g2d%2F1.7.0-ro%2Fimage%2F*%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%20all-poky-linux%2Ffirmware-imx%2F1_8.1-r0%2Fimage%2F*%20%E3%81%B8%E3%81%AE%E3%83%95%E3%83%AB%E3%83%91%E3%82%B9%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2%E7%95%AA%E7%9B%AE%E3%81%AB%E3%80%81%E3%80%8Cubuntu18.04%2F%E3%80%8D%E3%81%AE%E5%AE%9B%E5%85%88%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%99%E3%82%8B%E9%9A%9B%E3%80%81%2Fubuntu18.04%2F%E3%81%8CUbuntu%E3%81%AErootfs%20%E3%81%AE%E3%83%99%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E6%83%B3%E5%AE%9A%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%AC%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ekylef%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128712%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128712%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%AB%E3%82%A4%E3%83%AB%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%82%A6%E3%82%A7%E3%83%96%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E4%BB%96%E3%81%AE%E4%BA%BA%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%BD%BC%E3%81%8C%E3%81%9D%E3%82%8C%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E4%BB%96%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E8%A1%8C%E3%81%86%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%A6%E3%82%A7%E3%83%96%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8CUSB%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A7UVC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82VPU%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%2Flib%2Ffirmware%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%BE%E3%81%9F%E3%80%81Yocto%E3%81%8B%E3%82%89unit_test%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%80%81v4l2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3EGnar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128711%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128711%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUbuntu%E3%81%A7%E3%82%A6%E3%82%A7%E3%83%96%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%80%81%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%82%B7%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AALogitech%E3%81%AE%E3%82%A6%E3%82%A7%E3%83%96%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%AE%E3%81%AB%E8%8B%A6%E5%8A%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%80%8CVPU_firmware_download%20Failed%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86dmesg%E3%82%A2%E3%83%A9%E3%83%BC%E3%83%88%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E2%80%A6%E3%81%A0%E3%81%8B%E3%82%89%E3%80%81VPU%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E4%B8%8D%E5%85%B7%E5%90%88%E3%82%92%E8%B5%B7%E3%81%93%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%80%81%E3%81%A9%E3%81%93%E3%81%8B%E3%81%AE%E6%99%82%E7%82%B9%E3%81%A7%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ek%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128710%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128710%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20Amrit%3C%2FP%3E%3CP%3E1.%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%A9%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%EF%BC%88cd%20~%2F%3F%3F%3F%3F%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E3%83%9B%E3%82%B9%E3%83%88PC%E5%81%B4%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82ubuntu%20rootfs%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%BE%E3%81%9Atar%20-xvf%20ubuntu-base-18.04.2-base-arm64.tar.gz%20-C%20ubuntu-rootfs%E3%81%AA%E3%81%A9%E3%81%AErootfs%E3%82%92%E8%A7%A3%E5%87%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%3CSPAN%3Eubuntu-rootfs%E3%82%92%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Eubuntu%2018.04%E3%81%AB%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%A8%E8%AA%A4%E8%A7%A3%E3%82%92%E6%8B%9B%E3%81%8F%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%8D%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%92%E7%B5%B1%E4%B8%80%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%AF%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3EGPU%E9%96%A2%E9%80%A3%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92ubuntu-rootfs%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%3CP%3E2.%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E5%80%8B%E5%88%A5%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EGPU%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AF%E3%80%81Yocto%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7galcore.ko%E3%81%A8%E3%81%97%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%3CSPAN%3E%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E5%88%A5%E9%80%94%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%E3%80%81%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%ABGPU%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%90%AB%E3%82%81%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%EF%BC%88%E7%A7%81%E3%81%AF%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Flinux-imx%22%20title%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Flinux-imx%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Elinux-imx%20-%20i.MX%20Linux%20kernel%3C%2FA%3E%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82yocto%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%89%E3%81%A7%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%24%20make%20menuconfig%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81.config%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3ECONFIG_MXC_GPU_VIV%3Dy.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3EGnar%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8Ubuntu%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20Gnar%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AA%E6%96%87%E6%9B%B8%E3%82%92%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AFNXP%20iMX8M%20Mini%20EVK%E7%94%A8%E3%81%AB%E3%81%9D%E3%82%8C%E3%82%92%E8%BF%BD%E5%BE%93%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AByocto%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E4%BB%8A%E5%BA%A6%E3%81%AF%E3%81%93%E3%81%AEevk%E3%81%A7weston%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FUbuntu%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82Ubuntu-i.MX8-weston.pdf%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B39%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%9B%B8%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E2)copy%20libdrm%2Cwayland%20vpu-firmware%20from%20yocto%3CBR%20%2F%3E%24sudo%20cp%20-Pra%20libdrm%2F2.4.91.imx-r0%2Fimage%2F*%20ubuntu18.04%2F%3CBR%20%2F%3E%24sudo%20cp%20-Pra%20imx-gpu-viv%2F1_6.2.4.p4.0-aarch64-r0%2Fimage%2F*%20ubuntu18.04%2F%3CBR%20%2F%3E%24sudo%20cp%20-Pra%20imx-dpu-g2d-1.7.0%2Fimx-dpu-g2d%2F1.7.0-r0%2Fimage%2F*%20ubuntu18.04%2F%3CBR%20%2F%3E%24sudo%20cp%20-r%20all-poky-linux%2Ffirmware-imx%2F1_8.1-r0%2Fimage%2F*%20ubuntu18.04%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E3%81%A9%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%EF%BC%88cd%20~%2F%3F%3F%3F%3F%EF%BC%89%E3%81%8B%E3%82%89%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%BE%E3%81%9F%E3%80%81%E3%81%93%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BCubuntu%2018.04%E3%81%AF%E3%81%A9%E3%81%93%E3%81%AB%E3%82%82%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%BE%8C%E3%81%A7%E3%81%A9%E3%81%93%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E3%81%AF%E3%80%81%E3%80%8Cubuntu%2018.04%E3%80%8D%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E3%81%B8%E3%81%AE%E4%BB%96%E3%81%AE%E5%8F%82%E7%85%A7%E3%81%AF%E8%A6%8B%E5%BD%93%E3%81%9F%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eimx-dpu-g2d%E3%81%AF%E3%82%BF%E3%82%A4%E3%83%97%E3%83%9F%E3%82%B9%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82imx-gpu-g2d%E3%81%AB%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E3%81%93%E3%81%86%E8%A8%80%E3%81%84%E3%81%BE%E3%81%99%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E2.%20yocto%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E5%88%A5%E9%80%94%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eyocto%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%AB%E3%80%81bitbake%20linux-imx%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E6%84%8F%E5%91%B3%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%E7%8F%BE%E5%9C%A8%E3%80%81Yocto%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EAmrit%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
100%が役に立ったと言っています (1/1)
バージョン履歴
最終更新日:
‎07-19-2019 12:09 AM
更新者:
