BDI3000 config file with iMX6 DDR initialization
Here is a BDI3000 config file I used with a SABRE SD board sometimes
ago that includes DDR initialization. I had several request on this in the past
so I am placing it here in case anyone needs it. Please feel free to comment
or update the document according to your own experience and results.
Sinan Akman
添付
コメント
I have used this file to init the sabresd and also a custom imx6 board, using memory with similar part number.
It worked very well.
評価なし
バージョン履歴
最終更新日:
‎07-21-2015 06:49 AM
更新者:
