AVB/TSN demo on i.MX8MP
Overview
AVB/TSN
Wikipedia: Audio Video Bridging (AVB) is a common name for the set of technical standards which provide improved synchronization, low-latency, and reliability for switched Ethernet networks. AVB was initially developed by the Institute of Electrical and Electronics Engineers (IEEE) Audio Video Bridging task group of the IEEE 802.1 standards committee. In November 2012, Audio Video Bridging task group was renamed to Time-Sensitive Networking (TSN) task group to reflect the expanded scope of its work, which is to "provide the specifications that will allow time-synchronized low latency streaming services through IEEE 802 networks". Further standardization efforts are ongoing in IEEE 802.1 TSN task group.
AVB and TSN technologies and standards:
Standard
Area of Definition
Title of Standard
AVB/TSN
IEEE 802.1AS
Timing and synchronization
Timing and Synchronization for Time-Sensitive Applications (gPTP)
AVB
TSN
IEEE 802.1Qav
Forwarding and queuing
Forwarding and Queuing for Time-Sensitive Streams (FQTSS)
AVB
IEEE 802.1Qat
Path control and reservation
Stream Reservation Protocol (SRP)
AVB
IEEE 802.1BA
Bridging
Audio Video Bridging (AVB) Systems
AVB
IEEE 1722 AVTP
AV transport
Layer 2 Transport Protocol for Time Sensitive Applications
AVB
IEEE 1722 AVDECC
Device manage and control
Device Discovery, Enumeration, Connection Management and Control Protocol
AVB
IEEE 802.1Qbu and IEEE 802.3br
Frame preemption
TSN
IEEE 802.1Qbv
Enhancements for scheduled traffic
TSN
IEEE 802.1Qca
TSN
IEEE 802.1Qcc
Central configuration method
Enhancements and performance improvements
TSN
IEEE 802.1Qci
Time-based ingress policing
Per-stream filtering and policing
TSN
IEEE 802.1CB
Seamless redundancy
Frame replication and elimination for reliability
TSN
Since many of the standards are only for TSN switch/bridges and i.MX8MP is design to be a TSN/AVB endpoint, this demo does not implement a full stack or full standards. It only demonstrates the basic end-to-end point (talker to listener) A/V streaming without bridge or switch.
Below table shows what this demo supports:
Standard
Software
Hardware
IEEE 802.1AS
Linuxptp
ENET_QoS IP
IEEE 802.1Qav/Qbu/Qbv
TC qdisc (taprio, mqprio, etf, cbs)
ENET_QoS IP (multi queue + EST, FPE, CBS)
IEEE 1722 AVTP
Libavtp
N/A
Demo introduction
Two i.MX8MP EVK boards are used for this demo, one act as a AVB talker to send A/V streams, the other one act as a AVB listener to receive A/V streams who can be playback to audio codec and sink video to screen. The two boards are connected by a RJ45 ethernet cable on each ENET2 port (only ENET2 port has TSN features).
Three streams’ type and SR (Stream Reservation) class are defined as below to grantee time sensitive (sub-microsecond synchronization), low latency and bandwidth on the ethernet:
  • Stream A: SR class A, AVTP Compressed Video Format, H.264 profile High, 1920x1080, 30 fps.
  • Stream B: SR class B, AVTP Audio Format, PCM 16-bit sample, 48 kHz, stereo, 12 frames per AVTPDU.
  • Other stream: Best-effort streams
These three TSN streams would be allocated into different traffic control (TC) class for egress in Linux. Different TC class would be mapped to different hardware queues with dedicated DMA channel, thanks to the multi-queue support by ENET_QoS IP. Then the traffic control apply different scheduling policy on each queues for different types of streams egress, to make sure highest priority or critical packet can be sent in the correct time slot.
The TSN streams are transmitted over Virtual LANs (VLANs). Bridges use the VLAN priority information (PCP) to identify Stream Reservation (SR) traffic classes which are handled according to the Forward and Queuing Enhancements for Time-Sensitive Streams (FQTSS) mechanisms described in Chapter 34 of the IEEE 802.1Q standard.
The demo is built up by following blocks:
  • Linux TC (traffic control): streams egress control to meet AVB/TSN requirements, which take advantage of the i.MX8MP TSN ENET IP.
  • Linux PTP: clock sync in network, which take advantage of the i.MX8MP TSN ENET IP.
  • Libavtp: Time Sensitive Applications AV Transport protocol.
  • ALSA: AVTP audio format plugin uses the libavtp to transmit and receive AVTP audio PCM streams.
  • Gstreamer: avtp plugin uses the libavtp to transmit and receive AVTP audio/video streams (video should be encoded as H264, audio PCM). x264enc and libav is a software H.264 video encoder/decoder, which alternative to the on chip VPU acceleration plugin, due to the VPU plugin is not supported in the latest Gstreamer version (1.17.x).
Traffic control
This demo can use two different traffic control qdisc settings:
  • mqprio + cbs: use CBS features
  • taprio + pfifo: use EST and FPE features (802.1Qbu/bv).
The pfifo is the default traffic control class, which use FIFO schedule policy for egress packets. The CBS class is actually handled by hardware IP to select which queue for transmit in a certain time slot.
Credit Base Shaper (CBS)
CBS parameters come straight from the IEEE 802.1Q-2018 specification. They are the following:
  • idleSlope: rate credits are accumulated when queue isn’t transmitting;
  • sendSlope: rate credits are spent when queue is transmitting;
  • hiCredit: maximum amount of credits the queue is allowed to have;
  • loCredit: minimum amount of credits the queue is allowed to have;
Enhancements to Scheduled Traffic (EST)
The IEEE 802.1Qbv defines the schedule for each of the queues on every egress port which makes the implementation aware of traffic arrival schedule. This information can be used to block the lower priority traffic from transmission in this time window/slot. This ensures that scheduled traffic is forwarded from sender to receiver through all the network nodes with a deterministic delay. The i.MX8MP uses the gate control list with configurable time slot and frame preempt (IEEE 802.1Qbu) features to support EST.
Other than the CBS, the gate control list control the egress transmission by a fixed open interval for that queue.
Build demo
Build L5.4.24_2.1.0
$MACHINE=imx8mpevk DISTRO=fsl-imx-xwayland source imx-setup-release.sh -b build-8mp
$bitbake  fsl-image-validation-imx
Prepare a SD card and burn it with the built out images.
To add tc/tcpdump command in iproute2 package, please add package into IMAGE_INSTALL_append variable into conf/local.conf:
IMAGE_INSTALL_append = " iproute2 iproute2-tc tcpdump
Rebuild kernel
Rebuild the kernel after applying the 0001-qenet-add-queue-avoid-panic.patch (attached), and overwrite the Image and imx8mp-evk.dtb on the boot partition of the SD card.
Install the toolchain
$bitbake -f fsl-image-validation-imx -c populate_sdk
$sh tmp/deploy/sdk/fsl-imx-xwayland-glibc-x86_64-fsl-image-validation-imx-aarch64-imx8mpevk-toolchain-5.4-zeus.sh
The toolchain would be installed into /opt/fsl-imx-xwayland/5.4-zeus/
Create a install folder
$mkdir <your install folder>
Create a folder to install all of the shared libraries, binaries and configure files which built out manually in this doc. After built done, you should copy all of the contents in this folder to target board root.
Build libavtp
$source /opt/fsl-imx-xwayland/5.4-zeus/environment-setup-aarch64-poky-linux
$git clone https://github.com/Avnu/libavtp.git
$cd libavtp
$meson build
$ninja -C build
Copy the built out .so and .pc into the toolchain rootfs:
$sudo cp build/libavtp.so* /opt/fsl-imx-xwayland/5.4-zeus/sysroots/aarch64-poky-linux/usr/lib/
$sudo cp build/meson-private/*.pc /opt/fsl-imx-xwayland/5.4-zeus/sysroots/aarch64-poky-linux/usr/lib/pkgconfig/
To make sure you have avtp package installed correctly:
$pkg-config --list-all | grep avtp
Copy the .so into the install folder:
$cp build/libavtp.so* <install folder>/usr/lib/
Copy header files:
$cp libavtp/include/* files <toolchain_path>/sysroots/aarch64-poky-linux/usr/lib
Build ALSA aaf plugin
The AAF (ALSA AVTP Audio Format) plugin is a PCM plugin that uses Audio Video Transport Protocol (AVTP) to transmit/receive audio samples through a Time-Sensitive Network (TSN) capable network. The plugin enables media applications to easily implement AVTP Talker and Listener functionalities.
$cd <yocto build>/tmp/work/aarch64-mx8mp-poky-linux/alsa-plugins/1.1.9-r0/alsa-plugins-1.1.9
$./configure --build=x86_64-linux --host=aarch64-poky-linux --target=aarch64-poky-linux --prefix=<your install folder>/usr --disable-silent-rules --disable-dependency-tracking --with-libtool-sysroot=/opt/samba/nxa23059/jailhouse/yocto-5.x/build-8mp/tmp/work/aarch64-mx8mp-poky-linux/alsa-plugins/1.1.9-r0/recipe-sysroot  --disable-static  --enable-aaf --disable-jack --disable-libav --disable-maemo-plugin --disable-maemo-resource-manager --enable-pulseaudio --enable-samplerate --with-speex=lib
$make
$make install
Build Gstreamer AVTP plugins
Build Gstreamer 1.17.x (commit e4f7cdb0df7b)
$git clone https://gitlab.freedesktop.org/gstreamer/gstreamer.git
$cd gstreamer
$patch -p1 < gstreamer-1.0-pass-build.patch
$meson build --prefix=<your install folder>/usr
$ninja -C build
$ninja -C build install
After Gstreamer is installed into <your install folder>, please fix the “prefix” path in the .pc files by, and copy to the toolchain folders:
$cd <your install folder>
$grep -lR <your install folder> ./lib/pkgconfig/ | xargs sed -i 's/<your install folder>/\/usr/g'
NOTE: Make sure you use the ‘\’ for ‘/’ convert in your path.
$cp -rf ./usr/* /opt/fsl-imx-xwayland/5.4-zeus/sysroots/aarch64-poky-linux/usr/
Build gst-plugins-base (commit 22827e8f)
$git clone https://gitlab.freedesktop.org/gstreamer/gst-plugins-base.git
$cd gst-plugins-base
$patch -p1 < gst-plugins-base-pass-build.patch
$ninja -C build
Build gst-plugins-bad (commit ed14e0d5a)
$git clone https://gitlab.freedesktop.org/gstreamer/gst-plugins-bad.git
$cd gst-plugins-bad
$ninja -C build
  • If you met gdbus-codegen issue, please remove the “--c-generate-autocleanup” and “--output-directory” parameters in the build/build.ninja
  • If you met issue of include file like: “…/gst/gl/gstglapi.h:24:10: fatal error: gst/gl/gstglconfig.h: No such file or directory.” Please modify the build/build.ninja to correct the -I header file parameter of the build.
After gst-plugins-base and gst-plugins-bad installed into <your install folder>, please fix the “prefix” path in the .pc files and copy them into the toolchain folders:
Build H.264 SW plugins
AVTPDU uses H.264 as payload for streaming, this requires H.264 encoder/decoder plugins, either software or hardware accelerations. Since we upgrade the Gstreamer and its plugins to a new version, the VPU plugins cannot be used anymore. So software H.264 plugins are required: x264 for encoder, libav for decoder.
Build x264
As the yocto actually has the x264 recipes, but not included in our bblayers, we need to copy the x264 source into our bblayers path under <yocto>/source to build:
$cp -rf ./poky/meta/recipes-multimedia/x264 ./meta-openembedded/meta-multimedia/recipes-multimedia/
$vi ./meta-openembedded/meta-multimedia/recipes-multimedia/x264_git.bb
Remove the LICENSE_FLAGS line
$bitbake -f x264 -c do_install
$sudo cp -rf tmp/work/aarch64-poky-linux/x264/r2917+gitAUTOINC+72db437770-r0/image/usr/* /opt/fsl-imx-xwayland/5.4-zeus/sysroots/aarch64-poky-linux/usr/
Build gst-plugins-ugly (commit 995a135d)
$git clone https://gitlab.freedesktop.org/gstreamer/gst-plugins-ugly.git
$cd gst-plugins-ugly$meson build --prefix=<your install folder>/usr
$ninja -C build
If you met build issue, please remove "if have_cxx" from meson.build
Build libav
As the yocto actually has the libav recipes, but not included in our bblayers, we need to copy the its source into our bblayers path under <yocto>/source:
$cp -rf ./poky/meta/recipes-multimedia/gstreamer/gstreamer1.0-libav ./meta-openembedded/meta-multimedia/recipes-multimedia/gstreamer
$vi ./meta-openembedded/meta-multimedia/recipes-multimedia/gstreamer/gstreamer1.0-libav_1.16.1.bb
$bitbake -f gstreamer1.0-libav -c do_install
$cp tmp/work/aarch64-mx8mp-poky-linux/gstreamer1.0-libav/1.14.0-r0/image/usr/lib/gstreamer-1.0/libgstlibav.so <your install folder>/usr/lib/gstreamer-1.0
Now you have all of the Gstreamer plugins which required for AVB/TSN audio/video demo:
  • avtpsrc, avtpsink, avtpaafpay, avtpaafdepay, avtpcvfpay, avtpcvfdepay
  • x264_enc (encoder), avdec_h264 (decoder)
Install binaries
Final step is to copy all of your built out files from <your install folder> into your board / root, and boot up the board.
Verify the Gstreamer plugins install correctly or not:
$export GST_PLUGIN_PATH= /usr/lib/gstreamer-1.0/
$gst-inspect-1.0
Check if the above Gstreamer plugins we built out can be found by gst-instpect.
System Setup
VLAN
The ENTE_QoS is assigned to eth1 instance. So create eth1.5 for vlan id 5:
$ip link add link eth1 name eth1.5 type vlan id 5 \
       egress-qos-map 2:2 3:3
$ip link set eth1.5 up
Qdiscs
The TSN control plane is implemented through the Linux Traffic Control (TC) System. The transmission algorithms specified in the Forwarding and Queuing for Time-Sensitive Streams (FQTSS) chapter of IEEE 802.1Q-2018 are supported via TC Queuing Disciplines (qdiscs). Linux currently provides the following qdiscs relating to TSN:
  • Multiply queue qdiscs (These two qdiscs are mutually exclusive, select one for your demo):
    • MQPRIO: Mapping the TC class into different hardware queue in IP.
    • TAPRIO: Implements the Enhancements for Scheduled Traffic introduced by IEEE 1Qbv/Qbu. This is supported by i.MX8MP ENET_QoS IP through EST features:
      • Qbv – Time aware shaper
      • Qbu - frame preemption.
  • CBS qdisc: Implements the Credit-Based Shaper introduced by the IEEE 802.1Qav This is supported by i.MX8MP ENET_QoS IP through EST (Enhancements to Scheduled Traffic) features. It works with mqprio qdisc together.
  • ETF qdisc: While not an FQTSS feature, Linux also provides the Earliest TxTime First (ETF) qdisc which enables the LaunchTime Since the i.MX8MP ENET_QoS IP does not support LaunchTime feature, this qdisc configurations would be ignored.
MQPRIO qdisc
$tc qdisc add dev eth1 parent root handle 100 mqprio \
        num_tc 3 \
        map 0 0 2 1 0 0 0 0 0 0 0 0 0 0 0 0 \
        queues 1@0 1@1 1@2 \
        hw 1
NOTE, since ENET_QoS Q0 does not support hardware CBS, we have to avoid using Q0 for AVB streaming. Here’s the mapping:
  • socket SO_PRIORITY 2 -> TC CLASS 2 -> Q2
  • socket SO_PRIORITY 3 -> TC CLASS 1 -> Q1
  • Other socket priority -> TC CLASS 0 -> Q0
TAPRIO qdisc
Create a root qdisc handle to map the different CLASS streams to hardware queues w/ GCL (gate control list). This root handle maps the CLASS A stream to queue Q1, CLASS B stream to Q2, and others to Q0 by the “map” and “queues” parameters, same as mqprio above. The Q1/Q2(CLASS1/2) gates are open in the first 300us interval, then only Q1(CLASS1) gate is open in the next 300us with all other CLASS gated. The last sched-entry defines in after Q1 is open after 300us, all of the CLASS gates are open for next 200us. Then loopback to the first sched-entry for gate control.
Please note in this demo, we only enable features to support the 802.1Qbv, the Qbu (Frame preempt) requires patches for iproute2.
$tc qdisc add dev eth1 parent root handle 100 taprio \
        num_tc 3 \
        base-time 1000000000 \
        sched-entry S 0x6 300000 \
        sched-entry S 0x2 300000 \
        sched-entry S 0x7 200000 \
        flags 0x2
CBS qdisc
Q1 CBS for video, Q2 CBS for audio:
$tc qdisc replace dev eth1 parent 100:2 handle 777 cbs \
        idleslope 98688 sendslope -901312 hicredit 153 locredit -1389 \
        offload 1
$tc qdisc replace dev eth1 parent 100:3 handle 888 cbs \
        idleslope 3648 sendslope -996352 hicredit 12 locredit -113 \
       offload 1
NOTE: By default, the Q0 will be allocated for pfifo qdisc class if we do not define them.
ETF qdisc
As ENET_QOS does not support hardware launch time in IP, the ETF qdisc would not be used here.
TimeSync
Run the ptp4l and phc2sys in background, and use check_clocks to check the ptp sync works.
$ptp4l -i eth1 -f ./gPTP.cfg --step_threshold=1 &
$pmc -u -b 0 -t 1 "SET GRANDMASTER_SETTINGS_NP clockClass 248 \
        clockAccuracy 0xfe offsetScaledLogVariance 0xffff \
        currentUtcOffset 37 leap61 0 leap59 0 currentUtcOffsetValid 1 \
        ptpTimescale 1 timeTraceable 1 frequencyTraceable 0 \
        timeSource 0xa0"
$phc2sys -s eth1 -c CLOCK_REALTIME --step_threshold=1 \
        --transportSpecific=1 -w &
$./check_clocks -d eth1
The PTP Hardware Clock (PHC)  synced between PTP master/slave means the RMS offset between PHC and GM (master clock) is < 100ns. PHC and system clock (CLOCK_REALTIME) synced means the clock offset < 100ns
NOTE:
  • The check_clocks source code can be downloaded from here.
  • cfg is described below, if you want to identify which is master and which is slave, use “masterOnly 1” or “slaveOnly 1” in this configuration file.
# 802.1AS example configuration containing those attributes which
# differ from the defaults.  See the file, default.cfg, for the
# complete list of available options.
[global]
gmCapable               1
priority1               248
priority2               248
logAnnounceInterval     0
logSyncInterval         -3
syncReceiptTimeout      3
neighborPropDelayThresh 800
min_neighbor_prop_delay -20000000
assume_two_step         1
path_trace_enabled      1
follow_up_info          1
transportSpecific       0x1
ptp_dst_mac             01:80:C2:00:00:0E
network_transport       L2
delay_mechanism         P2P
Run demo
ALSA AAF audio
To run the alsa AAF demo, please add aaf0 and converter0 plugin device into /etc/asound.conf:
pcm.aaf0 {
        type aaf
        ifname eth1.5
        addr 01:AA:AA:AA:AA:AA
        prio 2
        streamid AA:BB:CC:DD:EE:FF:000B
        mtt 50000
        time_uncertainty 1000
        frames_per_pdu 12
        ptime_tolerance 100
pcm.converter0 {
        type linear
        slave {
                pcm "hw:2,0"
                format S16_LE
The “aaf0” plugin device defines the ethernet interface which AAF runs on, the socket priority which mapping to Traffic Class in kernel TC, the stream-id for the aaf streaming.
The “converter0” plugin device is used for convert the S16_BE format to S16_LE for the wm8960 PCM audio.
Select one device as AVB talker, and run:
$speaker-test -p 25000 -F S16_BE -c 2 -r 48000 -D aaf0
$arecord -F 25000 -t raw -f S16_BE -c 2 -r 48000 -D aaf0 | aplay -F 25000 -t raw -f S16_BE -c 2 -r 48000 -D converter0
You can hear the sound on the listener device. You can also check which qdisc queue is used for AAF by:
$tc -s qdisc
Gstreamer AAF audio
$gst-launch-1.0 clockselect. \( clock-id=realtime \
    audiotestsrc samplesperbuffer=12 is-live=true ! \
    audio/x-raw,format=S16BE,channels=2,rate=48000 ! \
    avtpaafpay mtt=50000000 tu=1000000 streamid=0xAABBCCDDEEFF000B processing-deadline=0 ! \
    avtpsink ifname=eth1.5 address=01:AA:AA:AA:AA:AA priority=2 processing-deadline=0 \)
Select one device as AVB listener, and run:
    avtpsrc ifname=eth1.5 ! avtpaafdepay streamid=0xAABBCCDDEEFF000B ! \
    queue max-size-bytes=0 max-size-buffers=0 max-size-time=0 ! \
    audioconvert ! audioresample !  alsasink device="hw:2,0" \)
Gstreamer CVF video
    videotestsrc is-live=true ! video/x-raw,width=480,height=320,framerate=15/1 ! \
    clockoverlay ! x264enc bframes=0  key-int-max=1 speed-preset=1 tune=4 ! h264parse config-interval=-1 ! \
    avtpcvfpay processing-deadline=20000000 mtu=1400 mtt=2000000 tu=125000 streamid=0xAABBCCDDEEFF000A ! \
    avtpsink ifname=eth1.5 priority=3 processing-deadline=20000000 \)
NOTE:
  • To eliminate the h.264 software encoding/decoding overhead with acceptable latency for this demo, we use several parameters for x264enc element:
    • bframes: x264enc and avdec_h264 together was found to have issues, remove bframes in the stream would help.
    • key-int-max: decoder can only decode the frame when a keyframe is present on stream to make sure decoder can work as faster as it can, the distance between two keyframes must be set to closest.
    • speed-preset: to low down the CPU loading for encoding, we use the option to make encoding as faster as we can. (=1 means ultrafast)
    • tune: 4 means zero latency
  • ‘mtu=1400’ parameters for avtpcvfpay element is very important, if using the default mtu=1500, the listener cannot get the AVTPDUs package correctly from VLAN. The reason is unknown yet.
    avtpsrc ifname=eth1.5 ! avtpcvfdepay streamid=0xAABBCCDDEEFF000A ! \
    avdec_h264 ! videoconvert ! clockoverlay halignment=right ! waylandsink \)
The demo screenshot below: there are two clocks show on the videotestsrc stream: left one is the timestamp recorded before x264enc encoding on the AVB talker side, right one is the timestamp recorded after avdec_h265 decoding and do video convert to YUV frames on AVB listener side. You can see the timestamp is sync in seconds.
Deep dive
Packet sniffer
Use tcpdump on board to dump the L2 ethernet packet:
./tcpdump -i eth1 ether proto 0x22f0 -w dump.pcap
The AVTP ether protocol code is 0x22f0 embedded inside the ether frame, or you can use "vlan 5" VLAN id for tcpdump parameters to dump.
Then open this dump.pcap in the windows/Linux PC by the wireshark tool, it will automatically show the protocol inside the package, it can also parser the IEEE1722 (AVTP) CVF/AFF package header as below:
Precise latency measurement
  • The clockoverlay plugin used in the above talker/listener is actually seconds level precision, which can not reflect the latency from talker videotestsrc -> listener avdec_h264 decoding finish. Here need a little hack to the clockoverlay element in the gst-plugins-base to get the millisecond precision. The patch is attached (gst-plugins-base-clockoverlay-us.patch), please apply and rebuild the gst-plugins-base, then replace the libgstpango.so on the board /usr/lib/gstreamer-1.0/. When doing CVF demo, you can take a picture of the screen, and check the two clock's diff. During my test, the latency is about 50ms, which include all the cost of encoding, AVTP packaging, streaming, ethernet transmit, ethernet receive, AVTP unpack and frame decoding.
  • To measure the package latency from transmit port (talker) to receive port (listener), you can use the tcpdump on both end-points. And compare the Epoch Time the packet dumped: "Epoch Time: 1596252905.688243000 seconds". The delta of the epoch time of the same packet is around 100us~500us. This latency actually includes the AF_PACKET clone cost in kernel netfilter, also the tcpdump application schedule latency.
References
添付
コメント
@xinyu_chen ,
When build ALSA aaf plugin.
"$./configure --build=x86_64-linux --host=aarch64-poky-linux --target=aarch64-poky-linux --prefix=<your install folder>/usr --disable-silent-rules --disable-dependency-tracking --with-libtool-sysroot=/opt/samba/nxa23059/jailhouse/yocto-5.x/build-8mp/tmp/work/aarch64-mx8mp-poky-linux/alsa-plugins/1.1.9-r0/recipe-sysroot  --disable-static  --enable-aaf --disable-jack --disable-libav --disable-maemo-plugin --disable-maemo-resource-manager --enable-pulseaudio --enable-samplerate --with-speex=lib
When define --with-libtool-sysroot,
Can I interpret it as "<yocto build>/tmp/work/aarch64-mx8mp-poky-linux/alsa-plugins/1.1.9-r0/recipe-sysroot "?
@xinyu_chen
How can i test with local mp4 video file?
I ran below cmd:
    filesrc location=sintel_trailer-480p.mp4 ! qtdemux ! h264parse config-interval=-1 ! \
But, i got error:
Pipeline is PREROLLING ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: DebugGstSystemClock
Got EOS from element "clockselect0".
Execution ended after 0:00:00.544463000
Setting pipeline to NULL ...
Freeing pipeline ...
with
basesrc gstbasesrc.c:3688:gst_base_src_start_complete:<filesrc0> pad not activated yet
@xinyu_chen
It seems that files changed in gstreamer-1.0-pass-build.patch are not the same as them under gstreamer path with cloning https://gitlab.freedesktop.org/gstreamer/gstreamer.git
For example, data/meson.build doesn't exist under gstreamer path.
diff --git a/data/meson.build b/data/meson.build
index c9130e0..3477dfe 100644
--- a/data/meson.build
+++ b/data/meson.build
@@ -1,5 +1,5 @@
if (bashcomp_found)
- subdir('bash-completion/helpers')
- install_data('bash-completion/completions/gst-launch-1.0', install_dir : bash_completions_dir)
- install_data('bash-completion/completions/gst-inspect-1.0', install_dir : bash_completions_dir)
+# subdir('bash-completion/helpers')
+# install_data('bash-completion/completions/gst-launch-1.0', install_dir : bash_completions_dir)
+# install_data('bash-completion/completions/gst-inspect-1.0', install_dir : bash_completions_dir)
endif
Please use the right version by this commit:
@xinyu_chen
Can you please help to check whether my gstreamer's version is not correct(1.16.3)?
Gstreamer source code is as below:
I used the below command to get current version:
git checkout -b dev e4f7cdb0df7b
Another question @xinyu_chen
There is no 'lib' path under my install folder(xxx/packages):
Does it mean "my install folder" ?
correct, the /lib path is in your device.
Thanks for your reply @xinyu_chen
But I still didn't fully get what you said. Actually,  my problem is that Gstreamer 1.17 can not be installed successfully on my machine. And there is error occured when I run below command:
if my folder where Gstreamer was installed into is "~/work/avb/packages". Can you please share me the correct command to fix the "prefix" path in the .pc files? Thanks a lot!
Oh, this command means, change the "~/work/avb/packages" to "/usr" in all of the .pc file inside ./lib/pkgconfig
@xinyu_chen Where is the path " ./lib/pkgconfig" ?  It doesn't exist under my installer folder.
"./lib/pkgconfig" should mean "lib/pkgconfig" under my installer folder. right?
but there is no "lib/pkgconfig" under my installer folder
@xinyu_chen   I used another command to perform fixing prefix from <my installer flder> to '/usr':
grep -lR '/home/yzg/work/avb/packages' --include='*.pc' .| xargs sed -i 'sI/home/yzg/work/avb/packages|/usr|g'
It worked fine but I am not sure whether this command is correct.
Now, I met another problem about installing gst-plugins-base
It seemed that Gstreamer was not installed successfully. Can you please help to clarify this issue? Thanks a lot!
@xinyu_chen Can you please give comments on my previous question? Thanks very much!
Hi @xinyu_chen ,
I build all the library step by step. But after I put "<install folder>/usr" into "root/usr" and input command "gst-inspect-1.0", I got some errors.
The following is my log:
root@imx8mpevk:~# export GST_PLUGIN_PATH=/usr/lib/gstreamer-1.0/
root@imx8mpevk:~# gst-inspect-1.0
(gst-inspect-1.0:795): GStreamer-WARNING **: 11:28:36.879: External plugin loader failed. This most likely means that the plugin loader helper binary was not found or could not be run. You might need to set the GST_PLUGIN_SCANNER environment variable if your setup is unusual. This should normally not be required though.
(gst-inspect-1.0:795): GStreamer-WARNING **: 11:28:37.029: Failed to load plugin '/usr/lib/gstreamer-1.0/libgstbeepdec.so': /usr/lib/libgstfsl-1.0.so.0: undefined symbol: gst_allocator_phymem_get_type
(gst-inspect-1.0:795): GStreamer-WARNING **: 11:28:37.115: Failed to load plugin '/usr/lib/gstreamer-1.0/libgstimxcompositor.so': /usr/lib/libgstfsl-1.0.so.0: undefined symbol: gst_allocator_phymem_get_type
(gst-inspect-1.0:795): GStreamer-WARNING **: 11:28:37.122: Failed to load plugin '/usr/lib/gstreamer-1.0/libgstx264.so': libx264.so.157: cannot open shared object file: No such file or directory
(gst-inspect-1.0:795): GStreamer-WARNING **: 11:28:37.217: Failed to load plugin '/usr/lib/gstreamer-1.0/libgstvideo4linux2.so': /usr/lib/gstreamer-1.0/libgstvideo4linux2.so: undefined symbol: gst_buffer_add_dmabuf_meta
(gst-inspect-1.0:795): GLib-GObject-WARNING **: 11:28:38.196: cannot register existing type 'GstDashDemux'
(gst-inspect-1.0:795): GLib-CRITICAL **: 11:28:38.196: g_once_init_leave: assertion 'result != 0' failed
(gst-inspect-1.0:795): GStreamer-CRITICAL **: 11:28:38.196: gst_element_register: assertion 'g_type_is_a (type, GST_TYPE_ELEMENT)' failed
(gst-inspect-1.0:795): GStreamer-WARNING **: 11:28:38.405: Failed to load plugin '/usr/lib/gstreamer-1.0/libgstimxvideoconvert.so': /usr/lib/libgstfsl-1.0.so.0: undefined symbol: gst_allocator_phymem_get_type
(gst-inspect-1.0:795): GStreamer-WARNING **: 11:28:38.510: Failed to load plugin '/usr/lib/gstreamer-1.0/libgstvpu.so': /usr/lib/libgstfsl-1.0.so.0: undefined symbol: gst_allocator_phymem_get_type
(gst-inspect-1.0:795): GStreamer-WARNING **: 11:28:38.795: Failed to load plugin '/usr/lib/gstreamer-1.0/libgstaiurdemux.so': /usr/lib/libgstfsl-1.0.so.0: undefined symbol: gst_allocator_phymem_get_type
mpegpsmux: mpegpsmux: MPEG Program Stream Muxer
spectrum: spectrum: Spectrum analyzer
shapewipe: shapewipe: Shape Wipe transition filter
videoparsersbad: h263parse: H.263 parser
videoparsersbad: h264parse: H.264 parser
videoparsersbad: diracparse: Dirac parser
videoparsersbad: mpegvideoparse: MPEG video elementary stream parser
videoparsersbad: mpeg4videoparse: MPEG 4 video elementary stream parser
videoparsersbad: pngparse: PNG parser
videoparsersbad: jpeg2000parse: JPEG 2000 parser
videoparsersbad: h265parse: H.265 parser
videoparsersbad: vc1parse: VC1 parser
dtmf: dtmfsrc: DTMF tone generator
dtmf: rtpdtmfsrc: RTP DTMF packet generator
dtmf: rtpdtmfdepay: RTP DTMF packet depayloader
dvdsub: dvdsubdec: DVD subtitle decoder
dvdsub: dvdsubparse: DVD subtitle parser
fieldanalysis: fieldanalysis: Video field analysis
jpeg: jpegenc: JPEG image encoder
jpeg: jpegdec: JPEG image decoder
videofilter: gamma: Video gamma correction
videofilter: videobalance: Video balance
videofilter: videoflip: Video flipper
videofilter: videomedian: Median effect
y4menc: y4menc: YUV4MPEG video encoder
dvbsubenc: dvbsubenc: DVB subtitle encoder
aiff: aiffparse: AIFF audio demuxer
aiff: aiffmux: AIFF audio muxer
subenc: srtenc: Srt encoder
subenc: webvttenc: WebVTT encoder
soup: souphttpsrc: HTTP client source
soup: souphttpclientsink: HTTP client sink
dvdlpcmdec: dvdlpcmdec: DVD LPCM Audio decoder
theora: theoradec: Theora video decoder
theora: theoraenc: Theora video encoder
theora: theoraparse: Theora video parser
compositor: compositor: Compositor
audiomixmatrix: audiomixmatrix: Matrix audio mix
sbc: sbcdec: Bluetooth SBC audio decoder
sbc: sbcenc: Bluetooth SBC audio encoder
ivfparse: ivfparse: IVF parser
legacyrawparse: videoparse: Video Parse
legacyrawparse: audioparse: Audio Parse
interleave: interleave: Audio interleaver
interleave: deinterleave: Audio deinterleaver
transcode: transcodebin: Transcode Bin
transcode: uritranscodebin: URITranscode Bin
videotestsrc: videotestsrc: Video test source
audiorate: audiorate: Audio rate adjuster
adpcmdec: adpcmdec: ADPCM decoder
ogg: oggdemux: Ogg demuxer
ogg: oggmux: Ogg muxer
ogg: ogmaudioparse: OGM audio stream parser
ogg: ogmvideoparse: OGM video stream parser
ogg: ogmtextparse: OGM text stream parser
ogg: oggparse: Ogg parser
ogg: oggaviparse: Ogg AVI parser
matroska: matroskademux: Matroska demuxer
%3CLINGO-SUB%20id%3D%22lingo-sub-1123791%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX8MP%E3%81%A7%E3%81%AEAVB%2FTSN%E3%81%AE%E3%83%87%E3%83%A2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123791%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH1%20id%3D%22toc-hId-382428397%22%20id%3D%22toc-hId-1303121173%22%3E%3CSPAN%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId--1425026066%22%20target%3D%22_blank%22%3EOverview%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId--734464592%22%20target%3D%22_blank%22%3EAVB%2FTSN%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId-1753048241%22%20target%3D%22_blank%22%3E%E3%83%87%E3%83%A2%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId--54406222%22%20target%3D%22_blank%22%3E%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E5%88%B6%E5%BE%A1%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId-636155252%22%20target%3D%22_blank%22%3E%E3%82%AF%E3%83%AC%E3%82%B8%E3%83%83%E3%83%88%E3%83%BB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%BB%E3%82%B7%E3%82%A7%E3%82%A4%E3%83%91%E3%83%BC%EF%BC%88CBS%EF%BC%89%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId--1171299211%22%20target%3D%22_blank%22%3E%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E6%8B%A1%E5%BC%B5%EF%BC%88EST%EF%BC%89%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId-615149044%22%20target%3D%22_blank%22%3E%E3%83%87%E3%83%A2%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId-1305710518%22%20target%3D%22_blank%22%3E%E3%83%93%E3%83%AB%E3%83%89%20L5.4.24_2.1.0%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId--501743945%22%20target%3D%22_blank%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E5%86%8D%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId--635428669%22%20target%3D%22_blank%22%3E%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId-1852084164%22%20target%3D%22_blank%22%3E%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%83%BB%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId-44629701%22%20target%3D%22_blank%22%3Elibavtp%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId--1762824762%22%20target%3D%22_blank%22%3EALSA%20aaf%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId--1082766392%22%20target%3D%22_blank%22%3EGStreamer%20AVTP%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId-1533829160%22%20target%3D%22_blank%22%3EGStreamer%201.17.x%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%EF%BC%88commit%20e4f7cdb0df7b%EF%BC%89%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId--2081079766%22%20target%3D%22_blank%22%3Egst-plugins-base%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%EF%BC%88commit%2022827e8f%EF%BC%89%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId--702859455%22%20target%3D%22_blank%22%3Egst-plugins-bad%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%EF%BC%88commit%20ed14e0d5a%EF%BC%89%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId-1655570659%22%20target%3D%22_blank%22%3EH.264%20SW%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId--22801085%22%20target%3D%22_blank%22%3Ex264%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId--1830255548%22%20target%3D%22_blank%22%3Egst-plugins-ugly%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%EF%BC%88commit%20995a135d%EF%BC%89%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId-657257285%22%20target%3D%22_blank%22%3Elibav%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId--1279279897%22%20target%3D%22_blank%22%3E%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId-1079150217%22%20target%3D%22_blank%22%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%BB%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId--599221527%22%20target%3D%22_blank%22%3EVLAN%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId-1888291306%22%20target%3D%22_blank%22%3EQdiscs%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId-209919562%22%20target%3D%22_blank%22%3EMQPRIO%20qdisc%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId-1588139873%22%20target%3D%22_blank%22%3ETAPRIO%20qdisc%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId--2026769053%22%20target%3D%22_blank%22%3ECBS%20qdisc%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId--1346710683%22%20target%3D%22_blank%22%3EETF%20qdisc%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId--795735032%22%20target%3D%22_blank%22%3ETimeSync%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId-1562695082%22%20target%3D%22_blank%22%3E%E3%83%87%E3%83%A2%E3%81%AE%E5%AE%9F%E8%A1%8C%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId--115676662%22%20target%3D%22_blank%22%3EALSA%20AAF%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId--1224969184%22%20target%3D%22_blank%22%3EGstreamer%20AAF%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId--544910814%22%20target%3D%22_blank%22%3EGstreamer%20CVF%E3%83%93%E3%83%87%E3%82%AA%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId-1813519300%22%20target%3D%22_blank%22%3EDeep%20dive%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId-135147556%22%20target%3D%22_blank%22%3E%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%83%BB%E3%82%B9%E3%83%8B%E3%83%95%E3%82%A1%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId--1672306907%22%20target%3D%22_blank%22%3E%E9%AB%98%E7%B2%BE%E5%BA%A6%E3%81%AA%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%83%BC%E6%B8%AC%E5%AE%9A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FAVB-TSN-demo-on-i-MX8MP%2Fta-p%2F1123791%23toc-hId-686123207%22%20target%3D%22_blank%22%3E%E5%8F%82%E8%80%83%E6%83%85%E5%A0%B1%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FSPAN%3E%3C%2FH1%3E%0A%3CH1%20id%3D%22toc-hId--1425026066%22%20id%3D%22toc-hId--504333290%22%3E%3CSPAN%3EOverview%3C%2FSPAN%3E%3C%2FH1%3E%0A%3CH2%20id%3D%22toc-hId--734464592%22%20id%3D%22toc-hId-186228184%22%3E%3CSPAN%3EAVB%2FTSN%3C%2FSPAN%3E%3C%2FH2%3E%0A%3CP%3E%3CSPAN%3EWikipedia%E3%82%88%E3%82%8A%EF%BC%9A%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%BB%E3%83%93%E3%83%87%E3%82%AA%E3%83%BB%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%83%B3%E3%82%B0%EF%BC%88AVB%EF%BC%89%E3%81%A8%E3%81%AF%E3%80%81%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E6%8E%A5%E7%B6%9A%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%BB%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E5%90%8C%E6%9C%9F%E3%80%81%E4%BD%8E%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%80%81%E4%BF%A1%E9%A0%BC%E6%80%A7%E3%82%92%E5%90%91%E4%B8%8A%E3%81%95%E3%81%9B%E3%82%8B%E4%B8%80%E9%80%A3%E3%81%AE%E6%8A%80%E8%A1%93%E6%A8%99%E6%BA%96%E3%81%AE%E9%80%9A%E7%A7%B0%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3EAVB%E3%81%AF%E3%82%82%E3%81%A8%E3%82%82%E3%81%A8%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fen.wikipedia.org%2Fwiki%2FInstitute_of_Electrical_and_Electronics_Engineers%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%20style%3D%22color%3A%20windowtext%3B%20text-decoration%3A%20none%3B%22%3EInstitute%20of%20Electrical%20and%20Electronics%20Engineers%3C%2FSPAN%3E%3C%2FA%3E%EF%BC%88IEEE%EF%BC%89%E3%81%AE%3CA%20href%3D%22https%3A%2F%2Fen.wikipedia.org%2Fwiki%2FIEEE_802.1%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%20style%3D%22color%3A%20windowtext%3B%20text-decoration%3A%20none%3B%22%3EIEEE%20802.1%3C%2FSPAN%3E%3C%2FA%3E%E6%A8%99%E6%BA%96%E5%8C%96%E5%A7%94%E5%93%A1%E4%BC%9A%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%BB%E3%83%93%E3%83%87%E3%82%AA%E3%83%BB%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%83%B3%E3%82%B0%E4%BD%9C%E6%A5%AD%E9%83%A8%E4%BC%9A%E3%81%A7%E9%96%8B%E7%99%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%822012%E5%B9%B411%E6%9C%88%E3%81%AB%E3%80%81%3CSPAN%3E%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%BB%E3%83%93%E3%83%87%E3%82%AA%E3%83%BB%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%83%B3%E3%82%B0%E4%BD%9C%E6%A5%AD%E9%83%A8%E4%BC%9A%E3%81%AF%E3%80%81%E3%81%9D%E3%81%AE%E4%BD%9C%E6%A5%AD%E7%AF%84%E5%9B%B2%E3%81%AE%E6%8B%A1%E5%A4%A7%E3%82%92%E8%B8%8F%E3%81%BE%E3%81%88%E3%81%A6%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fen.wikipedia.org%2Fwiki%2FTime-Sensitive_Networking%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%20style%3D%22color%3A%20windowtext%3B%20text-decoration%3A%20none%3B%22%3E%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%BB%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%86%E3%82%A3%E3%83%96%E3%83%BB%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AD%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3C%2FA%3E%EF%BC%88TSN%EF%BC%89%E4%BD%9C%E6%A5%AD%E9%83%A8%E4%BC%9A%E3%81%AB%E6%94%B9%E5%90%8D%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%AE%E4%BD%9C%E6%A5%AD%E3%81%A8%E3%81%AF%E3%80%81%E3%80%8C%E6%99%82%E5%88%BB%E5%90%8C%E6%9C%9F%E3%81%95%E3%82%8C%E3%81%9F%E4%BD%8E%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%81%AE%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E3%83%BB%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%92%3CA%20href%3D%22https%3A%2F%2Fen.wikipedia.org%2Fwiki%2FIEEE_802%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%20style%3D%22color%3A%20windowtext%3B%20text-decoration%3A%20none%3B%22%3EIEEE%20802%3C%2FSPAN%3E%3C%2FA%3E%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%A7%E5%AE%9F%E7%8F%BE%E3%81%A7%E3%81%8D%E3%82%8B%E4%BB%95%E6%A7%98%E3%82%92%E7%AD%96%E5%AE%9A%E3%81%99%E3%82%8B%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82IEEE%20802.1%20TSN%E4%BD%9C%E6%A5%AD%E9%83%A8%E4%BC%9A%E3%81%A7%E3%81%AF%E3%80%81%E3%81%95%E3%82%89%E3%81%AA%E3%82%8B%E6%A8%99%E6%BA%96%E5%8C%96%E3%81%AE%E5%8F%96%E3%82%8A%E7%B5%84%E3%81%BF%E3%81%8C%E9%80%B2%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EAVB%E3%81%A8TSN%E3%81%AE%E3%83%86%E3%82%AF%E3%83%8E%E3%83%AD%E3%82%B8%E3%81%A8%E6%A8%99%E6%BA%96%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CTABLE%20style%3D%22border%3A%20none%3B%20width%3A%20802px%3B%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-top%3A%201pt%20solid%20white%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-left%3A%201pt%20solid%20white%3B%20border-image%3A%20initial%3B%20border-right%3A%20none%3B%20background%3A%20%235b9bd5%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20131px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20white%3B%22%3E%3CSTRONG%3E%E8%A6%8F%E6%A0%BC%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%201pt%20solid%20white%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%20none%3B%20background%3A%20%235b9bd5%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20193px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20white%3B%22%3E%3CSTRONG%3E%E5%AE%9A%E7%BE%A9%E3%81%AE%E7%AF%84%E5%9B%B2%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%201pt%20solid%20white%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%20none%3B%20background%3A%20%235b9bd5%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20310px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20white%3B%22%3E%3CSTRONG%3E%E6%A8%99%E6%BA%96%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%88%E3%83%AB%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-image%3A%20initial%3B%20border-left%3A%20none%3B%20background%3A%20%235b9bd5%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20103px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20white%3B%22%3E%3CSTRONG%3EAVB%2FTSN%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20white%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-left%3A%201pt%20solid%20white%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%235b9bd5%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20131px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20white%3B%22%3E%3CSTRONG%3EIEEE%20802.1AS%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20193px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%A8%E5%90%8C%E6%9C%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20310px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%BB%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%86%E3%82%A3%E3%83%96%E3%83%BB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%A8%E5%90%8C%E6%9C%9F%EF%BC%88gPTP%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20103px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EAVB%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3ETSN%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20white%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-left%3A%201pt%20solid%20white%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%235b9bd5%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20131px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20white%3B%22%3E%3CSTRONG%3EIEEE%20802.1Qav%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20193px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E8%BB%A2%E9%80%81%E3%81%A8%E3%82%AD%E3%83%A5%E3%83%BC%E3%82%A4%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20310px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%BB%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%86%E3%82%A3%E3%83%96%E3%83%BB%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%AE%E8%BB%A2%E9%80%81%E3%81%A8%E3%82%AD%E3%83%A5%E3%83%BC%E3%82%A4%E3%83%B3%E3%82%B0%EF%BC%88FQTSS%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20103px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EAVB%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20white%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-left%3A%201pt%20solid%20white%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%235b9bd5%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20131px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20white%3B%22%3E%3CSTRONG%3EIEEE%20802.1Qat%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20193px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E7%B5%8C%E8%B7%AF%E5%88%B6%E5%BE%A1%E3%81%A8%E4%BA%88%E7%B4%84%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20310px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E4%BA%88%E7%B4%84%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20(SRP)%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20103px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EAVB%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20white%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-left%3A%201pt%20solid%20white%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%235b9bd5%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20131px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20white%3B%22%3E%3CSTRONG%3EIEEE%20802.1BA%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20193px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20310px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%BB%E3%83%93%E3%83%87%E3%82%AA%E3%83%BB%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%83%B3%E3%82%B0%EF%BC%88AVB%EF%BC%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20103px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EAVB%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20white%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-left%3A%201pt%20solid%20white%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%235b9bd5%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20131px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20white%3B%22%3E%3CSTRONG%3EIEEE%201722%20AVTP%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20193px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EAV%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20310px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%BB%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%86%E3%82%A3%E3%83%96%E3%83%BB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E3%83%AC%E3%82%A4%E3%83%A42%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%BB%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20103px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EAVB%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20white%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-left%3A%201pt%20solid%20white%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%235b9bd5%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20131px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20white%3B%22%3E%3CSTRONG%3EIEEE%201722%20AVDECC%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20193px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E7%AE%A1%E7%90%86%E3%81%A8%E5%88%B6%E5%BE%A1%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20310px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E6%A4%9C%E5%87%BA%E3%80%81%E5%88%97%E6%8C%99%E3%80%81%E6%8E%A5%E7%B6%9A%E7%AE%A1%E7%90%86%E3%80%81%E5%88%B6%E5%BE%A1%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20103px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EAVB%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20white%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-left%3A%201pt%20solid%20white%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%235b9bd5%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20131px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20white%3B%22%3E%3CSTRONG%3EIEEE%20802.1Qbu%20%E3%81%8A%E3%82%88%E3%81%B3%20IEEE%20802.3br%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20193px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E8%BB%A2%E9%80%81%E3%81%A8%E3%82%AD%E3%83%A5%E3%83%BC%E3%82%A4%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20310px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%97%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20103px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3ETSN%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20white%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-left%3A%201pt%20solid%20white%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%235b9bd5%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20131px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20white%3B%22%3E%3CSTRONG%3EIEEE%20802.1Qbv%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20193px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E8%BB%A2%E9%80%81%E3%81%A8%E3%82%AD%E3%83%A5%E3%83%BC%E3%82%A4%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20310px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AE%E5%BC%B7%E5%8C%96%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20103px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3ETSN%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20white%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-left%3A%201pt%20solid%20white%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%235b9bd5%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20131px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20white%3B%22%3E%3CSTRONG%3EIEEE%20802.1Qca%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20193px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E7%B5%8C%E8%B7%AF%E5%88%B6%E5%BE%A1%E3%81%A8%E4%BA%88%E7%B4%84%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20310px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E7%B5%8C%E8%B7%AF%E5%88%B6%E5%BE%A1%E3%81%A8%E4%BA%88%E7%B4%84%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20103px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3ETSN%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20white%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-left%3A%201pt%20solid%20white%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%235b9bd5%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20131px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20white%3B%22%3E%3CSTRONG%3EIEEE%20802.1Qcc%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20193px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E4%B8%80%E5%85%83%E8%A8%AD%E5%AE%9A%E3%81%AE%E6%96%B9%E6%B3%95%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20310px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E6%A9%9F%E8%83%BD%E5%BC%B7%E5%8C%96%E3%81%A8%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%AE%E5%90%91%E4%B8%8A%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20103px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3ETSN%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20white%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-left%3A%201pt%20solid%20white%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%235b9bd5%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20131px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20white%3B%22%3E%3CSTRONG%3EIEEE%20802.1Qci%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20193px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E6%99%82%E9%96%93%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B0%E3%83%AC%E3%82%B9%E3%83%BB%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20310px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%94%E3%81%A8%E3%81%AE%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%A8%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20103px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3ETSN%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20white%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-left%3A%201pt%20solid%20white%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%235b9bd5%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20131px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20white%3B%22%3E%3CSTRONG%3EIEEE%20802.1CB%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20193px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%82%B7%E3%83%BC%E3%83%A0%E3%83%AC%E3%82%B9%E3%81%AA%E5%86%97%E9%95%B7%E6%80%A7%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20310px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E4%BF%A1%E9%A0%BC%E6%80%A7%E3%82%92%E9%AB%98%E3%82%81%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%AE%E8%A4%87%E8%A3%BD%E3%81%A8%E5%89%8A%E9%99%A4%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20white%3B%20border-right%3A%201pt%20solid%20white%3B%20background%3A%20%23deeaf6%3B%20padding%3A%200cm%205.4pt%3B%20width%3A%20103px%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3ETSN%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%A4%9A%E3%81%8F%E3%81%AE%E6%A8%99%E6%BA%96%E3%81%AFTSN%E3%81%AE%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%2F%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%81%AE%E3%81%BF%E3%82%92%E5%AF%BE%E8%B1%A1%E3%81%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81i.MX8MP%E3%81%AFTSN%2FAVB%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%81%AE%E3%83%87%E3%83%A2%E3%81%A7%E3%81%AF%E3%83%95%E3%83%AB%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%82%84%E5%AE%8C%E5%85%A8%E3%81%AA%E6%A8%99%E6%BA%96%E3%81%AF%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%82%84%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E9%96%93%EF%BC%88%E3%83%88%E3%83%BC%E3%82%AB%E3%83%BC%E3%81%8B%E3%82%89%E3%83%AA%E3%82%B9%E3%83%8A%E3%83%BC%EF%BC%89%E3%81%AE%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AAA%2FV%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AE%E3%81%BF%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%83%87%E3%83%A2%E3%81%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E5%86%85%E5%AE%B9%E3%82%92%E6%AC%A1%E3%81%AE%E8%A1%A8%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CTABLE%20style%3D%22border%3A%20none%3B%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22184%22%20style%3D%22border%3A%20solid%20white%201.0pt%3B%20border-right%3A%20none%3B%20background%3A%20%234472C4%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20white%3B%22%3E%3CSTRONG%3E%E8%A6%8F%E6%A0%BC%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22184%22%20style%3D%22border-top%3A%20solid%20white%201.0pt%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20none%3B%20background%3A%20%234472C4%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20white%3B%22%3E%3CSTRONG%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22184%22%20style%3D%22border%3A%20solid%20white%201.0pt%3B%20border-left%3A%20none%3B%20background%3A%20%234472C4%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20white%3B%22%3E%3CSTRONG%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22184%22%20style%3D%22border%3A%20solid%20white%201.0pt%3B%20border-top%3A%20none%3B%20background%3A%20%234472C4%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20white%3B%22%3E%3CSTRONG%3EIEEE%20802.1AS%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22184%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%23B4C6E7%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3ELinuxptp%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22184%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%23B4C6E7%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EENET_QoS%20IP%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22184%22%20style%3D%22border%3A%20solid%20white%201.0pt%3B%20border-top%3A%20none%3B%20background%3A%20%234472C4%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20white%3B%22%3E%3CSTRONG%3EIEEE%20802.1Qav%2FQbu%2FQbv%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22184%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%23D9E2F3%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3ETC%20qdisc%20(taprio%2C%20mqprio%2C%20etf%2C%20cbs)%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22184%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%23D9E2F3%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EENET_QoS%20IP%20(multi%20queue%20%2B%20EST%2C%20FPE%2C%20CBS)%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22184%22%20style%3D%22border%3A%20solid%20white%201.0pt%3B%20border-top%3A%20none%3B%20background%3A%20%234472C4%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20white%3B%22%3E%3CSTRONG%3EIEEE%201722%20AVTP%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22184%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%23B4C6E7%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3ELibavtp%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20width%3D%22184%22%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20white%201.0pt%3B%20border-right%3A%20solid%20white%201.0pt%3B%20background%3A%20%23B4C6E7%3B%20padding%3A%200cm%205.4pt%200cm%205.4pt%3B%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EN%2FA%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH2%20id%3D%22toc-hId-1753048241%22%20id%3D%22toc-hId--1621226279%22%3E%3CSPAN%3E%E3%83%87%E3%83%A2%E3%81%AE%E7%B4%B9%E4%BB%8B%3C%2FSPAN%3E%3C%2FH2%3E%0A%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%83%87%E3%83%A2%E3%81%A7%E3%81%AF2%E3%81%A4%E3%81%AEi.MX8MP%20EVK%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%821%E3%81%A4%E3%81%AFA%2FV%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8BAVB%E3%83%88%E3%83%BC%E3%82%AB%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E6%A9%9F%E8%83%BD%E3%81%97%E3%80%81%E3%82%82%E3%81%861%E3%81%A4%E3%81%AFA%2FV%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%99%E3%82%8BAVB%E3%83%AA%E3%82%B9%E3%83%8A%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82AVB%E3%83%AA%E3%82%B9%E3%83%8A%E3%83%BC%E3%81%AF%E3%80%81%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%BB%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%82%92%E9%80%9A%E3%81%98%E3%81%9F%E9%9F%B3%E5%A3%B0%E3%81%AE%E5%86%8D%E7%94%9F%E3%82%84%E3%80%81%E7%94%BB%E9%9D%A2%E3%81%B8%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%81%AE%E8%A1%A8%E7%A4%BA%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%822%E3%81%A4%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AEENET2%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81RJ45%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%88TSN%E6%A9%9F%E8%83%BD%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%AFENET2%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E3%81%BF%E3%81%A7%E3%81%99%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%20style%3D%22width%3A%20554px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110491i930FD01C7FB1DC93%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_4.png%22%20alt%3D%22pastedImage_4.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%BB%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%86%E3%82%A3%E3%83%96%EF%BC%88%E3%82%B5%E3%83%96%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E7%A7%92%E3%81%AE%E5%90%8C%E6%9C%9F%EF%BC%89%E3%80%81%E4%BD%8E%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E4%B8%8A%E3%81%AE%E5%B8%AF%E5%9F%9F%E5%B9%85%E3%82%92%E4%BF%9D%E8%A8%BC%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%813%E3%81%A4%E3%81%AE%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%83%BB%E3%82%BF%E3%82%A4%E3%83%97%E3%81%A8SR%EF%BC%88%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E4%BA%88%E7%B4%84%EF%BC%89%E3%82%AF%E3%83%A9%E3%82%B9%E3%81%8C%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3E%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0A%EF%BC%9ASR%E3%82%AF%E3%83%A9%E3%82%B9A%E3%80%81AVTP%E5%9C%A7%E7%B8%AE%E3%83%93%E3%83%87%E3%82%AA%E5%BD%A2%E5%BC%8F%E3%80%81H.264%E3%83%8F%E3%82%A4%E3%83%BB%E3%83%97%E3%83%AD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%811920x1080%E3%80%8130fps%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3E%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%20B%EF%BC%9ASR%20%E3%82%AF%E3%83%A9%E3%82%B9%20B%E3%80%81AVTP%20%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%80%81PCM%2016%E3%83%93%E3%83%83%E3%83%88%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%80%8148%20kHz%E3%80%81%E3%82%B9%E3%83%86%E3%83%AC%E3%82%AA%E3%80%81AVTPDU%E3%81%82%E3%81%9F%E3%82%8A12%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3E%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%EF%BC%9A%E3%83%99%E3%82%B9%E3%83%88%E3%82%A8%E3%83%95%E3%82%A9%E3%83%BC%E3%83%88%E5%9E%8B%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%82%893%E3%81%A4%E3%81%AETSN%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%AF%E3%80%81Linux%E3%81%A7%E3%82%A4%E3%83%BC%E3%82%B0%E3%83%AC%E3%82%B9%E7%94%A8%E3%81%AB%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E5%88%B6%E5%BE%A1%EF%BC%88TC%EF%BC%89%E3%82%AF%E3%83%A9%E3%82%B9%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82ENET_QoS%20IP%E3%81%AE%E3%83%9E%E3%83%AB%E3%83%81%E3%82%AD%E3%83%A5%E3%83%BC%E3%83%BB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AETC%E3%82%AF%E3%83%A9%E3%82%B9%E3%81%AF%E3%80%81%E5%B0%82%E7%94%A8%E3%81%AEDMA%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E6%8C%81%E3%81%A4%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E3%81%86%E3%81%88%E3%81%A7%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E5%88%B6%E5%BE%A1%E3%81%AF%E3%80%81%E7%A8%AE%E9%A1%9E%E3%81%8C%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B0%E3%83%AC%E3%82%B9%E7%94%A8%E3%81%AE%E5%90%84%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AB%E3%80%81%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%BB%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%BC%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%80%81%E5%84%AA%E5%85%88%E9%A0%86%E4%BD%8D%E3%81%8C%E6%9C%80%E3%82%82%E9%AB%98%E3%81%84%E9%87%8D%E8%A6%81%E3%81%AA%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%BB%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%81%A7%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ETSN%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%AF%E4%BB%AE%E6%83%B3LAN%EF%BC%88VLAN%EF%BC%89%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%81%AF%E3%80%81VLAN%E5%84%AA%E5%85%88%E5%BA%A6%E6%83%85%E5%A0%B1%EF%BC%88PCP%EF%BC%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E4%BA%88%E7%B4%84%EF%BC%88SR%EF%BC%89%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%83%BB%E3%82%AF%E3%83%A9%E3%82%B9%E3%82%92%E8%AD%98%E5%88%A5%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%87%A6%E7%90%86%E3%81%AF%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fstandards.ieee.org%2Fstandard%2F802_1Q-2018.html%26amp%3Bsa%3DD%26amp%3Bust%3D1573162068591000%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%20style%3D%22color%3A%20windowtext%3B%20text-decoration%3A%20none%3B%22%3EIEEE%20802.1Q%E6%A8%99%E6%BA%96%3C%2FSPAN%3E%3C%2FA%3E%E3%81%AE%E7%AC%AC34%E7%AB%A0%E3%81%A7%E5%AE%9A%E3%82%81%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%BB%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%86%E3%82%A3%E3%83%96%E3%83%BB%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%AE%E8%BB%A2%E9%80%81%E3%81%A8%E3%82%AD%E3%83%A5%E3%83%BC%E3%82%A4%E3%83%B3%E3%82%B0%E3%81%AE%E5%BC%B7%E5%8C%96%EF%BC%88FQTSS%EF%BC%89%E3%81%AE%E3%83%A1%E3%82%AB%E3%83%8B%E3%82%BA%E3%83%A0%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%83%87%E3%83%A2%E3%81%AF%E6%AC%A1%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3ELinux%20TC%EF%BC%88%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E5%88%B6%E5%BE%A1%EF%BC%89%EF%BC%9Ai.MX8MP%20TSN%20ENET%20IP%E3%82%92%E6%B4%BB%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81AVB%2FTSN%E8%A6%81%E4%BB%B6%E3%82%92%E6%BA%80%E3%81%9F%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B0%E3%83%AC%E3%82%B9%E3%82%92%E5%88%B6%E5%BE%A1%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3ELinux%20PTP%EF%BC%9A%20i.MX8MP%20TSN%20ENET%20IP%E3%82%92%E6%B4%BB%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E5%86%85%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%90%8C%E6%9C%9F%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3ELibavtp%EF%BC%9A%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%BB%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%86%E3%82%A3%E3%83%96%E3%83%BB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AEAV%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%BB%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EALSA%EF%BC%9AAVTP%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%BB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%83%BB%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%8Clibavtp%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6AVTP%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AAPCM%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%82%92%E9%80%81%E5%8F%97%E4%BF%A1%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EGStreamer%EF%BC%9Aavtp%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%8Clibavtp%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6AVTP%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%2F%E3%83%93%E3%83%87%E3%82%AA%E3%83%BB%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%82%92%E9%80%81%E5%8F%97%E4%BF%A1%EF%BC%88%E3%83%93%E3%83%87%E3%82%AA%E3%81%AFH264%E3%80%81%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%81%AFPCM%E3%81%A7%E3%81%AE%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E5%BF%85%E8%A6%81%EF%BC%89%E3%80%82x264enc%E3%81%A8libav%E3%81%AF%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2H.264%E3%83%93%E3%83%87%E3%82%AA%E3%83%BB%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%2F%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97%E3%81%AEVPU%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%BB%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%AE%E4%BB%A3%E6%9B%BF%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81VPU%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%8C%E6%9C%80%E6%96%B0%E3%81%AEGstreamer%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%EF%BC%881.17.x%EF%BC%89%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20533px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110533i98B209863BCCCB7A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_5.png%22%20alt%3D%22pastedImage_5.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH2%20id%3D%22toc-hId--54406222%22%20id%3D%22toc-hId-866286554%22%3E%3CSPAN%3E%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E5%88%B6%E5%BE%A1%3C%2FSPAN%3E%3C%2FH2%3E%0A%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%83%87%E3%83%A2%E3%81%A7%E3%81%AF%E3%80%81%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E5%88%B6%E5%BE%A1%E3%81%AB%E6%AC%A1%E3%81%AE2%E7%A8%AE%E9%A1%9E%E3%81%AEqdisc%E8%A8%AD%E5%AE%9A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3Emqprio%20%2B%20cbs%EF%BC%9ACBS%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3Etaprio%20%2B%20pfifo%3A%20EST%20%E3%81%8A%E3%82%88%E3%81%B3%20FPE%20%E6%A9%9F%E8%83%BD%20(802.1Qbu%2Fbv)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%3Epfifo%E3%81%AF%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E5%88%B6%E5%BE%A1%E3%82%AF%E3%83%A9%E3%82%B9%E3%81%A7%E3%80%81%E3%82%A4%E3%83%BC%E3%82%B0%E3%83%AC%E3%82%B9%E3%83%BB%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%81%AB%E3%81%AFFIFO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%83%BB%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%BC%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82CBS%E3%82%AF%E3%83%A9%E3%82%B9%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AEIP%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%80%81%E7%89%B9%E5%AE%9A%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%BB%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%81%A7%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20554px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110641iD871A5B53C056918%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH3%20id%3D%22toc-hId-636155252%22%20id%3D%22toc-hId-1556848028%22%3E%3CSPAN%3E%E3%82%AF%E3%83%AC%E3%82%B8%E3%83%83%E3%83%88%E3%83%BB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%BB%E3%82%B7%E3%82%A7%E3%82%A4%E3%83%91%E3%83%BC%EF%BC%88CBS%EF%BC%89%3C%2FSPAN%3E%3C%2FH3%3E%0A%3CP%3E%3CSPAN%3ECBS%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AFIEEE%20802.1Q-2018%E4%BB%95%E6%A7%98%E3%81%AB%E3%81%9D%E3%81%AE%E3%81%BE%E3%81%BE%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%86%85%E5%AE%B9%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3EidleSlope%EF%BC%9A%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%A8%E3%81%8D%E3%81%AB%E3%82%AF%E3%83%AC%E3%82%B8%E3%83%83%E3%83%88%E3%81%8C%E8%93%84%E7%A9%8D%E3%81%95%E3%82%8C%E3%82%8B%E9%80%9F%E3%81%95%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EsendSlope%EF%BC%9A%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%82%AF%E3%83%AC%E3%82%B8%E3%83%83%E3%83%88%E3%81%8C%E6%B6%88%E8%B2%BB%E3%81%95%E3%82%8C%E3%82%8B%E9%80%9F%E3%81%95%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EhiCredit%EF%BC%9A%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%8C%E4%BF%9D%E6%8C%81%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%AF%E3%83%AC%E3%82%B8%E3%83%83%E3%83%88%E3%81%AE%E6%9C%80%E5%A4%A7%E9%87%8F%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EloCredit%3A%20%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%8C%E4%BF%9D%E6%8C%81%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%AF%E3%83%AC%E3%82%B8%E3%83%83%E3%83%88%E3%81%AE%E6%9C%80%E5%B0%8F%E9%87%8F%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_51.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_51.png%22%20style%3D%22width%3A%20557px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111059i23FA01BD9C171DAB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_51.png%22%20alt%3D%22pastedImage_51.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH3%20id%3D%22toc-hId--1171299211%22%20id%3D%22toc-hId--250606435%22%3E%3CSPAN%3E%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E6%8B%A1%E5%BC%B5%EF%BC%88EST%EF%BC%89%3C%2FSPAN%3E%3C%2FH3%3E%0A%3CP%3E%3CSPAN%3EIEEE%20802.1Qbv%E3%81%AF%E3%80%81%E5%90%84%E3%82%A4%E3%83%BC%E3%82%B0%E3%83%AC%E3%82%B9%E3%83%BB%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AE%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E5%AE%9F%E8%A3%85%E3%81%AF%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AE%E5%88%B0%E7%9D%80%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E8%AA%8D%E8%AD%98%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E5%88%A9%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E5%90%8C%E4%B8%80%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%BB%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%2F%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E5%84%AA%E5%85%88%E5%BA%A6%E3%81%AE%E4%BD%8E%E3%81%84%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AE%E9%80%81%E4%BF%A1%E3%82%92%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%86%E3%81%97%E3%81%A6%E3%80%81%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%BB%E3%83%8E%E3%83%BC%E3%83%89%E3%82%92%E9%80%9A%E3%81%98%E3%81%A6%E3%80%81%E6%B1%BA%E5%AE%9A%E8%AB%96%E7%9A%84%E3%81%AA%E9%81%85%E5%BB%B6%E3%81%AE%E3%82%82%E3%81%A8%E3%81%A7%E9%80%81%E4%BF%A1%E8%80%85%E3%81%8B%E3%82%89%E5%8F%97%E4%BF%A1%E8%80%85%E3%81%AB%E8%BB%A2%E9%80%81%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82i.MX8MP%20%E3%81%AF%E3%80%81%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%BB%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%B2%E3%83%BC%E3%83%88%E5%88%B6%E5%BE%A1%E3%83%AA%E3%82%B9%E3%83%88%E3%81%A8%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%BB%E3%83%97%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%97%E3%83%88%EF%BC%88IEEE%20802.1Qbu%EF%BC%89%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81EST%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_52.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_52.png%22%20style%3D%22width%3A%20554px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110639i916E012C0500B546%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_52.png%22%20alt%3D%22pastedImage_52.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ECBS%E4%BB%A5%E5%A4%96%E3%81%AB%E3%80%81%E3%82%B2%E3%83%BC%E3%83%88%E5%88%B6%E5%BE%A1%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AF%E3%80%81%E5%90%84%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E9%96%93%E9%9A%94%E3%82%92%E5%9B%BA%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%80%81%E3%82%A4%E3%83%BC%E3%82%B0%E3%83%AC%E3%82%B9%E4%BC%9D%E9%80%81%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH1%20id%3D%22toc-hId-615149044%22%20id%3D%22toc-hId-1535841820%22%3E%3CSPAN%3E%E3%83%87%E3%83%A2%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FSPAN%3E%3C%2FH1%3E%0A%3CH2%20id%3D%22toc-hId-1305710518%22%20id%3D%22toc-hId--2068564002%22%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%89%20L5.4.24_2.1.0%3C%2FSPAN%3E%3C%2FH2%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24MACHINE%3Dimx8mpevk%20DISTRO%3Dfsl-imx-xwayland%20source%20imx-setup-release.sh%20-b%20build-8mp%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24bitbake%26nbsp%3B%20fsl-image-validation-imx%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%3ESD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E7%94%A8%E6%84%8F%E3%81%97%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3Eiproute2%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%ABtc%2Ftcpdump%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81conf%2Flocal.conf%E3%81%AEIMAGE_INSTALL_append%E5%A4%89%E6%95%B0%E3%81%AB%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3EIMAGE_INSTALL_append%20%3D%20%22%20iproute2%20iproute2-tc%20tcpdump%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CH2%20id%3D%22toc-hId--501743945%22%20id%3D%22toc-hId-418948831%22%3E%3CSPAN%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E5%86%8D%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FH2%3E%0A%3CP%3E%3CSPAN%3E0001-qenet-add-queue-avoid-panic.patch%EF%BC%88%E6%B7%BB%E4%BB%98%EF%BC%89%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E5%86%8D%E6%A7%8B%E7%AF%89%E3%81%97%E3%80%81SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%83%BB%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%82%E3%82%8BImage%E3%81%A8imx8mp-evk.dtb%E3%82%92%E4%B8%8A%E6%9B%B8%E3%81%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH2%20id%3D%22toc-hId--635428669%22%20id%3D%22toc-hId-285264107%22%3E%3CSPAN%3E%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FSPAN%3E%3C%2FH2%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24bitbake%20-f%20fsl-image-validation-imx%20-c%20populate_sdk%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24sh%20tmp%2Fdeploy%2Fsdk%2Ffsl-imx-xwayland-glibc-x86_64-fsl-image-validation-imx-aarch64-imx8mpevk-toolchain-5.4-zeus.sh%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%3E%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AF%2Fopt%2Ffsl-imx-xwayland%2F5.4-zeus%2F%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH2%20id%3D%22toc-hId-1852084164%22%20id%3D%22toc-hId--1522190356%22%3E%3CSPAN%3E%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%83%BB%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AE%E4%BD%9C%E6%88%90%3C%2FSPAN%3E%3C%2FH2%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24mkdir%20%3CYOUR%20install%3D%22%22%20folder%3D%22%22%3E%3C%2FYOUR%3E%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E4%B8%AD%E3%81%A7%E6%89%8B%E5%8B%95%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E5%85%B1%E6%9C%89%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%80%81%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%80%81%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%A7%E3%80%81%E3%81%93%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E5%86%85%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%BB%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%88%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH2%20id%3D%22toc-hId-44629701%22%20id%3D%22toc-hId-965322477%22%3E%3CSPAN%3Elibavtp%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FSPAN%3E%3C%2FH2%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24source%20%2Fopt%2Ffsl-imx-xwayland%2F5.4-zeus%2Fenvironment-setup-aarch64-poky-linux%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24git%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FAvnu%2Flibavtp.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FAvnu%2Flibavtp.git%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24cd%20libavtp%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24meson%20build%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24ninja%20-C%20build%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F.so%E3%81%A8.pc%E3%82%92%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AErootfs%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%22%3E%24sudo%20cp%20build%2Flibavtp.so*%20%2Fopt%2Ffsl-imx-xwayland%2F5.4-zeus%2Fsysroots%2Faarch64-poky-linux%2Fusr%2Flib%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%22%3E%24sudo%20cp%20build%2Fmeson-private%2F*.pc%20%2Fopt%2Ffsl-imx-xwayland%2F5.4-zeus%2Fsysroots%2Faarch64-poky-linux%2Fusr%2Flib%2Fpkgconfig%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%3Eavtp%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E6%AC%A1%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%22%3E%24pkg-config%20--list-all%20%7C%20grep%20avtp%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%3E.so%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%83%BB%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%22%3E%24cp%20build%2Flibavtp.so*%20%3CINSTALL%20folder%3D%22%22%3E%2Fusr%2Flib%2F%3C%2FINSTALL%3E%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E3%83%98%E3%83%83%E3%83%80%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%24cp%20libavtp%2Finclude%2F*%20files%20%3CTOOLCHAIN_PATH%3E%2Fsysroots%2Faarch64-poky-linux%2Fusr%2Flib%3C%2FTOOLCHAIN_PATH%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CH2%20id%3D%22toc-hId--1762824762%22%20id%3D%22toc-hId--842131986%22%3E%3CSPAN%3EALSA%20aaf%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FH2%3E%0A%3CP%3E%3CSPAN%3EAAF%EF%BC%88ALSA%20AVTP%20Audio%20Format%EF%BC%89%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%AF%E3%80%81Audio%20Video%20Transport%20Protocol%EF%BC%88AVTP%EF%BC%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81Time-Sensitive%20Network%EF%BC%88TSN%EF%BC%89%E5%AF%BE%E5%BF%9C%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E9%80%81%E5%8F%97%E4%BF%A1%E3%81%99%E3%82%8BPCM%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AFAVTP%E3%83%88%E3%83%BC%E3%82%AB%E3%83%BC%E3%81%8A%E3%82%88%E3%81%B3%E3%83%AA%E3%82%B9%E3%83%8A%E3%83%BC%E6%A9%9F%E8%83%BD%E3%82%92%E5%AE%B9%E6%98%93%E3%81%AB%E5%AE%9F%E8%A3%85%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24cd%20%3CYOCTO%20build%3D%22%22%3E%2Ftmp%2Fwork%2Faarch64-mx8mp-poky-linux%2Falsa-plugins%2F1.1.9-r0%2Falsa-plugins-1.1.9%3C%2FYOCTO%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24.%2Fconfigure%20--build%3Dx86_64-linux%20--host%3Daarch64-poky-linux%20--target%3Daarch64-poky-linux%20--prefix%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2370ad47%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%3CYOUR%20install%3D%22%22%20folder%3D%22%22%3E%3C%2FYOUR%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%2Fusr%20--disable-silent-rules%20--disable-dependency-tracking%20--with-libtool-sysroot%3D%2Fopt%2Fsamba%2Fnxa23059%2Fjailhouse%2Fyocto-5.x%2Fbuild-8mp%2Ftmp%2Fwork%2Faarch64-mx8mp-poky-linux%2Falsa-plugins%2F1.1.9-r0%2Frecipe-sysroot%26nbsp%3B%20--disable-static%26nbsp%3B%20--%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20red%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Eenable-aaf%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E--disable-jack%20--disable-libav%20--disable-maemo-plugin%20--disable-maemo-resource-manager%20--enable-pulseaudio%20--enable-samplerate%20--with-speex%3Dlib%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24make%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24make%20install%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CH2%20id%3D%22toc-hId-724688071%22%20id%3D%22toc-hId-1645380847%22%3E%26nbsp%3B%3C%2FH2%3E%0A%3CH2%20id%3D%22toc-hId--1082766392%22%20id%3D%22toc-hId--162073616%22%3E%3CSPAN%3EGStreamer%20AVTP%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FSPAN%3E%3C%2FH2%3E%0A%3CH3%20id%3D%22toc-hId-1533829160%22%20id%3D%22toc-hId--1840445360%22%3E%3CSPAN%3EGStreamer%201.17.x%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%EF%BC%88commit%20e4f7cdb0df7b%EF%BC%89%3C%2FSPAN%3E%3C%2FH3%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24git%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgitlab.freedesktop.org%2Fgstreamer%2Fgstreamer.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgitlab.freedesktop.org%2Fgstreamer%2Fgstreamer.git%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24cd%20gstreamer%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24patch%20-p1%20%26lt%3B%20gstreamer-1.0-pass-build.patch%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24meson%20build%20--prefix%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2370ad47%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%3CYOUR%20install%3D%22%22%20folder%3D%22%22%3E%3C%2FYOUR%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%2Fusr%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24ninja%20-C%20build%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24ninja%20-C%20build%20install%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%3EGstreamer%E3%81%8C%3CYOUR%20install%3D%22%22%20folder%3D%22%22%3E%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E5%BE%8C%E3%81%A7%E3%80%81.pc%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%80%8Cprefix%E3%80%8D%E3%83%91%E3%82%B9%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%80%81%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%83%BB%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FYOUR%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24cd%20%3CYOUR%20install%3D%22%22%20folder%3D%22%22%3E%3C%2FYOUR%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24grep%20-lR%20%3CYOUR%20install%3D%22%22%20folder%3D%22%22%3E%20.%2Flib%2Fpkgconfig%2F%20%7C%20xargs%20sed%20-i%20's%2F%3C%2FYOUR%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20red%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%3CYOUR%20install%3D%22%22%20folder%3D%22%22%3E%3C%2FYOUR%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%2F%5C%2Fusr%2Fg'%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20red%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E3%83%91%E3%82%B9%E5%86%85%E3%81%AE%E3%80%8C%2F%E3%80%8D%E3%81%AE%E5%A4%89%E6%8F%9B%E3%81%AB%E3%81%AF%E3%80%81%E5%BF%85%E3%81%9A%E3%80%8C%5C%E3%80%8D%E3%82%92%E4%BB%98%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24cp%20-rf%20.%2Fusr%2F*%20%2Fopt%2Ffsl-imx-xwayland%2F5.4-zeus%2Fsysroots%2Faarch64-poky-linux%2Fusr%2F%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%0A%3CH3%20id%3D%22toc-hId--273625303%22%20id%3D%22toc-hId-647067473%22%3E%26nbsp%3B%3C%2FH3%3E%0A%3CH3%20id%3D%22toc-hId--2081079766%22%20id%3D%22toc-hId--1160386990%22%3E%3CSPAN%3Egst-plugins-base%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%EF%BC%88commit%2022827e8f%EF%BC%89%3C%2FSPAN%3E%3C%2FH3%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24git%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgitlab.freedesktop.org%2Fgstreamer%2Fgst-plugins-base.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgitlab.freedesktop.org%2Fgstreamer%2Fgst-plugins-base.git%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24cd%20gst-plugins-base%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24patch%20-p1%20%26lt%3B%20gst-plugins-base-pass-build.patch%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24meson%20build%20--prefix%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2370ad47%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%3CYOUR%20install%3D%22%22%20folder%3D%22%22%3E%3C%2FYOUR%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%2Fusr%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24ninja%20-C%20build%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24ninja%20-C%20build%20install%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CH3%20id%3D%22toc-hId-406433067%22%20id%3D%22toc-hId-1327125843%22%3E%26nbsp%3B%3C%2FH3%3E%0A%3CH3%20id%3D%22toc-hId--702859455%22%20id%3D%22toc-hId-217833321%22%3E%3CSPAN%3Egst-plugins-bad%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%EF%BC%88commit%20ed14e0d5a%EF%BC%89%3C%2FSPAN%3E%3C%2FH3%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24git%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgitlab.freedesktop.org%2Fgstreamer%2Fgst-plugins-bad.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgitlab.freedesktop.org%2Fgstreamer%2Fgst-plugins-bad.git%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24cd%20gst-plugins-bad%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24meson%20build%20--prefix%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2370ad47%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%3CYOUR%20install%3D%22%22%20folder%3D%22%22%3E%3C%2FYOUR%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%2Fusr%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24ninja%20-C%20build%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24ninja%20-C%20build%20install%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3Egdbus-codegen%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81build%2Fbuild.ninja%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8B%E3%82%89%E3%80%8C--c-generate-autocleanup%E3%80%8D%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%A8%E3%80%8C--output-directory%E3%80%8D%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3E%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%80%8C%E2%80%A6%2Fgst%2Fgl%2Fgstglapi.h%3A24%3A10%3A%20fatal%20error%3A%20gst%2Fgl%2Fgstglconfig.h%3A%20No%20such%20file%20or%20directory.%E3%80%8D%E3%81%9D%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81build%2Fbuild.ninja%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E3%80%8C-I%E3%80%8D%E3%83%98%E3%83%83%E3%83%80%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%BB%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%3Egst-plugins-base%E3%81%A8gst-plugins-bad%E3%81%8C%3CYOUR%20install%3D%22%22%20folder%3D%22%22%3E%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E5%BE%8C%E3%81%A7%E3%80%81.pc%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%80%8Cprefix%E3%80%8D%E3%83%91%E3%82%B9%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%80%81%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%83%BB%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FYOUR%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24cd%20%3CYOUR%20install%3D%22%22%20folder%3D%22%22%3E%3C%2FYOUR%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24grep%20-lR%20%3CYOUR%20install%3D%22%22%20folder%3D%22%22%3E%20.%2Flib%2Fpkgconfig%2F%20%7C%20xargs%20sed%20-i%20's%2F%3C%2FYOUR%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20red%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%3CYOUR%20install%3D%22%22%20folder%3D%22%22%3E%3C%2FYOUR%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%2F%5C%2Fusr%2Fg'%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20red%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E3%83%91%E3%82%B9%E5%86%85%E3%81%AE%E3%80%8C%2F%E3%80%8D%E3%81%AE%E5%A4%89%E6%8F%9B%E3%81%AB%E3%81%AF%E3%80%81%E5%BF%85%E3%81%9A%E3%80%8C%5C%E3%80%8D%E3%82%92%E4%BB%98%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24cp%20-rf%20.%2Fusr%2F*%20%2Fopt%2Ffsl-imx-xwayland%2F5.4-zeus%2Fsysroots%2Faarch64-poky-linux%2Fusr%2F%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20red%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH2%20id%3D%22toc-hId-1655570659%22%20id%3D%22toc-hId--1718703861%22%3E%3CSPAN%3EH.264%20SW%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FH2%3E%0A%3CP%3E%3CSPAN%3EAVTPDU%E3%81%AF%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AE%E3%83%9A%E3%82%A4%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A8%E3%81%97%E3%81%A6H.264%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8BH.264%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%2F%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BB%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82GStreamer%E3%81%A8%E3%81%9D%E3%81%AE%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E6%96%B0%E3%81%97%E3%81%84%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81VPU%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AEH.264%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%81%AB%E3%81%AFx264%E3%80%81%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%81%AB%E3%81%AFlibav%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH3%20id%3D%22toc-hId--22801085%22%20id%3D%22toc-hId-897891691%22%3E%3CSPAN%3Ex264%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FSPAN%3E%3C%2FH3%3E%0A%3CP%3E%3CSPAN%3EYocto%E3%81%AB%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AFx264%E3%81%AE%E3%83%AC%E3%82%B7%E3%83%94%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%E3%81%AFbblayers%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81x264%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%3CYOCTO%3E%2Fsource%E3%81%AE%E4%B8%8B%E3%81%AEbblayers%E3%83%91%E3%82%B9%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FYOCTO%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%20color%3A%20%2324292e%3B%20font-size%3A%2010.0pt%3B%22%3E%24cp%20-rf%20.%2Fpoky%2Fmeta%2Frecipes-multimedia%2Fx264%20.%2Fmeta-openembedded%2Fmeta-multimedia%2Frecipes-multimedia%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%20color%3A%20%2324292e%3B%20font-size%3A%2010.0pt%3B%22%3E%24vi%20.%2Fmeta-openembedded%2Fmeta-multimedia%2Frecipes-multimedia%2Fx264_git.bb%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%20color%3A%20%2324292e%3B%20font-size%3A%2010.0pt%3B%22%3ELICENSE_FLAGS%E8%A1%8C%E3%82%92%E5%89%8A%E9%99%A4%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%20color%3A%20%2324292e%3B%20font-size%3A%2010.0pt%3B%22%3E%24bitbake%20-f%20x264%20-c%20do_install%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%20color%3A%20%2324292e%3B%20font-size%3A%2010.0pt%3B%22%3E%24sudo%20cp%20-rf%20tmp%2Fwork%2Faarch64-poky-linux%2Fx264%2Fr2917%2BgitAUTOINC%2B72db437770-r0%2Fimage%2Fusr%2F*%20%2Fopt%2Ffsl-imx-xwayland%2F5.4-zeus%2Fsysroots%2Faarch64-poky-linux%2Fusr%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CH3%20id%3D%22toc-hId--1830255548%22%20id%3D%22toc-hId--909562772%22%3E%3CSPAN%3Egst-plugins-ugly%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%EF%BC%88commit%20995a135d%EF%BC%89%3C%2FSPAN%3E%3C%2FH3%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24git%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgitlab.freedesktop.org%2Fgstreamer%2Fgst-plugins-ugly.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgitlab.freedesktop.org%2Fgstreamer%2Fgst-plugins-ugly.git%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24cd%20gst-plugins-ugly%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24meson%20build%20--prefix%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2370ad47%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%3CYOUR%20install%3D%22%22%20folder%3D%22%22%3E%3C%2FYOUR%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%2Fusr%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24ninja%20-C%20build%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24ninja%20-C%20build%20install%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81meson.build%E3%81%8B%E3%82%89%E3%80%8Cif%20have_cxx%E3%80%8D%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId-657257285%22%20id%3D%22toc-hId-1577950061%22%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Elibav%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FSPAN%3E%3C%2FH3%3E%0A%3CP%3E%3CSPAN%3Eyocto%E3%81%AB%E3%81%AFlibav%E3%83%AC%E3%82%B7%E3%83%94%E3%81%8C%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81bblayers%E3%81%AB%E3%81%AF%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%81%9D%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%3CYOCTO%3E%2Fsource%E3%81%AE%E4%B8%8B%E3%81%AEbblayers%E3%81%AE%E3%83%91%E3%82%B9%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FYOCTO%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24cp%20-rf%20.%2Fpoky%2Fmeta%2Frecipes-multimedia%2Fgstreamer%2Fgstreamer1.0-libav%20.%2Fmeta-openembedded%2Fmeta-multimedia%2Frecipes-multimedia%2Fgstreamer%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24vi%20.%2Fmeta-openembedded%2Fmeta-multimedia%2Frecipes-multimedia%2Fgstreamer%2Fgstreamer1.0-libav_1.16.1.bb%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3ELICENSE_FLAGS%E8%A1%8C%E3%82%92%E5%89%8A%E9%99%A4%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24bitbake%20-f%20gstreamer1.0-libav%20-c%20do_install%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24cp%20tmp%2Fwork%2Faarch64-mx8mp-poky-linux%2Fgstreamer1.0-libav%2F1.14.0-r0%2Fimage%2Fusr%2Flib%2Fgstreamer-1.0%2Flibgstlibav.so%20%3CYOUR%20install%3D%22%22%20folder%3D%22%22%3E%2Fusr%2Flib%2Fgstreamer-1.0%3C%2FYOUR%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81AVB%2FTSN%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%2F%E3%83%93%E3%83%87%E3%82%AA%E3%83%BB%E3%83%87%E3%83%A2%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AAGStreamer%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%8C%E3%81%99%E3%81%B9%E3%81%A6%E6%8F%83%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Eavtpsrc%2C%20avtpsink%2C%20avtpaafpay%2C%20avtpaafdepay%2C%20avtpcvfpay%2C%20avtpcvfdepay%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Ex264_enc%EF%BC%88%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%EF%BC%89%E3%80%81avdec_h264%EF%BC%88%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH2%20id%3D%22toc-hId--1279279897%22%20id%3D%22toc-hId--358587121%22%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FH2%3E%0A%3CP%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%E6%9C%80%E5%BE%8C%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%3CYOUR%20install%3D%22%22%20folder%3D%22%22%3E%E3%81%8B%E3%82%89%E3%83%9C%E3%83%BC%E3%83%89%2F%E3%83%AB%E3%83%BC%E3%83%88%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FYOUR%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EGStreamer%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24export%20GST_PLUGIN_PATH%3D%20%2Fusr%2Flib%2Fgstreamer-1.0%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24gst-inspect-1.0%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%E3%81%93%E3%81%93%E3%81%BE%E3%81%A7%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%9FGStreamer%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%8Cgst-instpect%E3%81%A7%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH1%20id%3D%22toc-hId-1079150217%22%20id%3D%22toc-hId-1999842993%22%3E%3CSPAN%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%BB%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FSPAN%3E%3C%2FH1%3E%0A%3CH2%20id%3D%22toc-hId--599221527%22%20id%3D%22toc-hId-321471249%22%3E%3CSPAN%3EVLAN%3C%2FSPAN%3E%3C%2FH2%3E%0A%3CP%3E%3CSPAN%3EENTE_QoS%20%E3%81%AF%20eth1%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81VLAN%20ID%205%20%E3%81%AE%20eth1.5%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24ip%20link%20add%20link%20eth1%20name%20eth1.5%20type%20vlan%20id%205%20%5C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20egress-qos-map%202%3A2%203%3A3%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24ip%20link%20set%20eth1.5%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CH2%20id%3D%22toc-hId-1888291306%22%20id%3D%22toc-hId--1485983214%22%3E%3CSPAN%3EQdiscs%3C%2FSPAN%3E%3C%2FH2%3E%0A%3CP%3E%3CSPAN%3ETSN%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%83%BB%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E3%81%AF%E3%80%81Linux%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E5%88%B6%E5%BE%A1%EF%BC%88TC%EF%BC%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82IEEE%20802.1Q-2018%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%BB%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%86%E3%82%A3%E3%83%96%E3%83%BB%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%AE%E8%BB%A2%E9%80%81%E3%81%A8%E3%82%AD%E3%83%A5%E3%83%BC%E3%82%A4%E3%83%B3%E3%82%B0%EF%BC%88FQTSS%EF%BC%89%E3%81%AE%E7%AB%A0%E3%81%A7%E8%A6%8F%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E4%BC%9D%E9%80%81%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%AF%E3%80%81TC%E3%81%AE%E3%82%AD%E3%83%A5%E3%83%BC%E3%82%A4%E3%83%B3%E3%82%B0%E8%A6%8F%E5%89%87%EF%BC%88qdiscs%EF%BC%89%E3%82%92%E9%80%9A%E3%81%98%E3%81%A6%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82Linux%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%80%81TSN%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E4%BB%A5%E4%B8%8B%E3%81%AEqdisc%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3E%E3%83%9E%E3%83%AB%E3%83%81%E3%82%AD%E3%83%A5%E3%83%BCqdisc%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%3CSTRONG%3E%EF%BC%88%E3%81%93%E3%81%AE2%E3%81%A4%E3%81%AEqdisc%E3%81%AF%E7%9B%B8%E4%BA%92%E6%8E%92%E4%BB%96%E7%9A%84%E3%81%A7%E3%81%99%E3%80%82%E3%83%87%E3%83%A2%E3%81%AB%E3%81%AF%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B1%E3%81%A4%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%EF%BC%89%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%3C%2FSPAN%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3EMQPRIO%3A%20TC%E3%82%AF%E3%83%A9%E3%82%B9%E3%82%92IP%E5%86%85%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3ETAPRIO%EF%BC%9AIEEE%20%3CSPAN%20style%3D%22color%3A%20%2370ad47%3B%22%3E%3CSTRONG%3E1Qbv%2FQbu%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%81%A7%E5%B0%8E%E5%85%A5%E3%81%95%E3%82%8C%E3%81%9F%E3%80%81%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E6%8B%A1%E5%BC%B5%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81i.MX8MP%20ENET_QoS%20IP%E3%81%AEEST%E6%A9%9F%E8%83%BD%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3EQbv%20%E2%80%93%20%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%BB%E3%82%A2%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%82%B7%E3%82%A7%E3%82%A4%E3%83%91%E3%83%BC%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EQbu%20-%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%BB%E3%83%97%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3ECBS%20qdisc%EF%BC%9A%3CSPAN%20style%3D%22color%3A%20%2370ad47%3B%22%3E%3CSTRONG%3EIEEE%20802.1Qav%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%81%A7%E5%B0%8E%E5%85%A5%E3%81%95%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AC%E3%82%B8%E3%83%83%E3%83%88%E3%83%BB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%BB%E3%82%B7%E3%82%A7%E3%82%A4%E3%83%91%E3%83%BC%EF%BC%88CBS%EF%BC%89%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81i.MX8MP%20ENET_QoS%20IP%E3%81%AEEST%EF%BC%88%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E6%8B%A1%E5%BC%B5%EF%BC%89%E6%A9%9F%E8%83%BD%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82MQPRIO%20qdisc%E3%81%A8%E4%BD%B5%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EETF%20qdisc%EF%BC%9AFQTSS%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81Linux%E3%81%AB%E3%81%AF%3CSPAN%20style%3D%22color%3A%20%2370ad47%3B%22%3E%3CSTRONG%3ELaunchTime%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8BEarliest%20TxTime%20First%EF%BC%88ETF%EF%BC%89qdisc%E3%82%82%E7%94%A8%E6%84%8F%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82i.MX8MP%20ENET_QoS%20IP%E3%81%AFLaunchTime%E6%A9%9F%E8%83%BD%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%81%AEqdisc%E8%A8%AD%E5%AE%9A%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%20style%3D%22margin-left%3A%2021.0pt%3B%20text-indent%3A%200cm%3B%22%3E%3CSPAN%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_18.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_18.png%22%20style%3D%22width%3A%20554px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110863iD8E734F06D163C2F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_18.png%22%20alt%3D%22pastedImage_18.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId-209919562%22%20id%3D%22toc-hId-1130612338%22%3E%3CSPAN%3EMQPRIO%20qdisc%3C%2FSPAN%3E%3C%2FH3%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24tc%20qdisc%20add%20dev%20eth1%20parent%20root%20handle%20100%20mqprio%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20num_tc%203%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20map%200%200%202%201%200%200%200%200%200%200%200%200%200%200%200%200%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20queues%201%400%201%401%201%402%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20hw%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%3CSTRONG%3E%E6%B3%A8%E6%84%8F%EF%BC%9AENET_QoS%20Q0%E3%81%AF%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2CBS%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81AVB%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AB%E3%81%AFQ0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%3CSTRONG%3E%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%20SO_PRIORITY%202%20-%26gt%3B%20TC%20CLASS%202%20-%26gt%3B%20Q2%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%3CSTRONG%3E%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%20SO_PRIORITY%203%20-%26gt%3B%20TC%20CLASS%201%20-%26gt%3B%20Q1%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%3CSTRONG%3E%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E5%84%AA%E5%85%88%E5%BA%A6%20-%26gt%3B%20TC%20CLASS%200%20-%26gt%3B%20Q0%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CH3%20id%3D%22toc-hId--899372960%22%20id%3D%22toc-hId-21319816%22%3E%26nbsp%3B%3C%2FH3%3E%0A%3CH3%20id%3D%22toc-hId-1588139873%22%20id%3D%22toc-hId--1786134647%22%3E%3CSPAN%3ETAPRIO%20qdisc%3C%2FSPAN%3E%3C%2FH3%3E%0A%3CP%3E%3CSPAN%3E%E3%83%AB%E3%83%BC%E3%83%88qdisc%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81GCL%EF%BC%88%E3%82%B2%E3%83%BC%E3%83%88%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%83%BB%E3%83%AA%E3%82%B9%E3%83%88%EF%BC%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AACLASS%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%82%92%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%88%E3%83%BB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%E3%81%AF%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AEMQPRIO%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AB%E3%80%81%E3%80%8Cmap%E3%80%8D%E3%81%8A%E3%82%88%E3%81%B3%E3%80%8Cqueues%E3%80%8D%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%80%81CLASS%20A%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%82%92%E3%82%AD%E3%83%A5%E3%83%BCQ1%E3%81%AB%E3%80%81CLASS%20B%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%82%92Q2%E3%81%AB%E3%80%81%E3%81%9D%E3%81%AE%E4%BB%96%E3%82%92Q0%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E5%88%9D%E3%81%AE300%CE%BCs%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%90%E3%83%AB%E3%81%A7%E3%81%AFQ1%2FQ2%EF%BC%88CLASS1%2F2%EF%BC%89%E3%82%B2%E3%83%BC%E3%83%88%E3%81%8C%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E7%B6%9A%E3%81%8F300%CE%BCs%E3%81%A7%E3%81%AFQ1%EF%BC%88CLASS1%EF%BC%89%E3%82%B2%E3%83%BC%E3%83%88%E3%81%AE%E3%81%BF%E3%81%8C%E9%96%8B%E3%81%8D%E3%80%81%E4%BB%96%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AECLASS%E3%81%AF%E3%82%B2%E3%83%BC%E3%83%88%E3%81%8C%E9%96%89%E3%81%98%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E5%BE%8C%E3%81%AEsched-entry%E3%81%A7%E3%81%AF%E3%80%81Q1%E3%81%8C300%CE%BCs%E9%96%8B%E3%81%84%E3%81%9F%E5%BE%8C%E3%81%A7%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AECLASS%E3%81%AE%E3%82%B2%E3%83%BC%E3%83%88%E3%81%8C200%CE%BCs%E9%96%8B%E3%81%8F%E3%82%88%E3%81%86%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%AF%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AEsched-entry%E3%81%AE%E3%82%B2%E3%83%BC%E3%83%88%E5%88%B6%E5%BE%A1%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%83%87%E3%83%A2%E3%81%A7%E3%81%AF%E3%80%81802.1Qbv%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E6%A9%9F%E8%83%BD%E3%81%AE%E3%81%BF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82Qbu%EF%BC%88%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%97%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%97%E3%83%88%EF%BC%89%E3%81%AB%E3%81%AF%20iproute2%20%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E3%81%94%E6%B3%A8%E6%84%8F%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24tc%20qdisc%20add%20dev%20eth1%20parent%20root%20handle%20100%20taprio%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20num_tc%203%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20map%200%200%202%201%200%200%200%200%200%200%200%200%200%200%200%200%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20queues%201%400%201%401%201%402%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20base-time%201000000000%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20sched-entry%20S%200x6%20300000%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20sched-entry%20S%200x2%20300000%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20sched-entry%20S%200x7%20200000%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%E3%83%95%E3%83%A9%E3%82%B0%200x2%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CH3%20id%3D%22toc-hId--219314590%22%20id%3D%22toc-hId-701378186%22%3E%26nbsp%3B%3C%2FH3%3E%0A%3CH3%20id%3D%22toc-hId--2026769053%22%20id%3D%22toc-hId--1106076277%22%3E%3CSPAN%3ECBS%20qdisc%3C%2FSPAN%3E%3C%2FH3%3E%0A%3CP%3E%3CSPAN%3EQ1%E3%81%AECBS%E3%81%AF%E3%83%93%E3%83%87%E3%82%AA%E7%94%A8%E3%80%81Q2%E3%81%AECBS%E3%81%AF%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E7%94%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24tc%20qdisc%20replace%20dev%20eth1%20parent%20100%3A2%20handle%20777%20cbs%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20idleslope%2098688%20sendslope%20-901312%20hicredit%20153%20locredit%20-1389%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%E3%82%AA%E3%83%95%E3%83%AD%E3%83%BC%E3%83%89%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24tc%20qdisc%20replace%20dev%20eth1%20parent%20100%3A3%20handle%20888%20cbs%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20idleslope%203648%20sendslope%20-996352%20hicredit%2012%20locredit%20-113%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%E3%82%AA%E3%83%95%E3%83%AD%E3%83%BC%E3%83%89%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E5%AE%9A%E7%BE%A9%E3%81%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%81%AFQ0%E3%81%AFpfifo%20qdisc%E3%82%AF%E3%83%A9%E3%82%B9%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId-460743780%22%20id%3D%22toc-hId-1381436556%22%3E%26nbsp%3B%3C%2FH3%3E%0A%3CH3%20id%3D%22toc-hId--1346710683%22%20id%3D%22toc-hId--426017907%22%3E%3CSPAN%3EETF%20qdisc%3C%2FSPAN%3E%3C%2FH3%3E%0A%3CP%3E%3CSPAN%3EENET_QOS%E3%81%AFIP%E3%81%A7%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2LaunchTime%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81ETF%20qdisc%E3%81%AF%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH2%20id%3D%22toc-hId-1011719431%22%20id%3D%22toc-hId-1932412207%22%3E%26nbsp%3B%3C%2FH2%3E%0A%3CH2%20id%3D%22toc-hId--795735032%22%20id%3D%22toc-hId-124957744%22%3E%3CSPAN%3ETimeSync%3C%2FSPAN%3E%3C%2FH2%3E%0A%3CP%3E%3CSPAN%3Eptp4l%E3%81%A8phc2sys%E3%82%92%E3%83%90%E3%83%83%E3%82%AF%E3%82%B0%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81check_clocks%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81ptp%E5%90%8C%E6%9C%9F%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24ptp4l%20-i%20eth1%20-f%20.%2FgPTP.cfg%20--step_threshold%3D1%20%26amp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24pmc%20-u%20-b%200%20-t%201%20%22SET%20GRANDMASTER_SETTINGS_NP%20clockClass%20248%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20clockAccuracy%200xfe%20offsetScaledLogVariance%200xffff%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20currentUtcOffset%2037%20leap61%200%20leap59%200%20currentUtcOffsetValid%201%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ptpTimescale%201%20timeTraceable%201%20frequencyTraceable%200%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20timeSource%200xa0%22%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24phc2sys%20-s%20eth1%20-c%20CLOCK_REALTIME%20--step_threshold%3D1%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20--transportSpecific%3D1%20-w%20%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24.%2Fcheck_clocks%20-d%20eth1%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%3EPTP%E3%81%AE%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%2F%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E9%96%93%E3%81%A7%3CSPAN%20style%3D%22color%3A%20%23404040%3B%20background-color%3A%20%23fcfcfc%3B%22%3EPTP%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%EF%BC%88PHC%EF%BC%89%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%E3%81%8C%E5%90%8C%E6%9C%9F%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%AF%E3%80%81%3CSPAN%20style%3D%22color%3A%20%23404040%3B%20background-color%3A%20%23fcfcfc%3B%22%3EPHC%E3%81%A8GM%EF%BC%88%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%BB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%EF%BC%89%E3%81%AE%E9%96%93%E3%81%AERMS%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3C%2FSPAN%3E%E3%81%8C100ns%E6%9C%AA%E6%BA%80%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%A1%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82PHC%E3%81%A8%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%BB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%EF%BC%88CLOCK_REALTIME%EF%BC%89%E3%81%8C%E5%90%8C%E6%9C%9F%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%AF%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%BB%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C100ns%E6%9C%AA%E6%BA%80%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%A1%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E6%B3%A8%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3Echeck_clocks%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Ftsn.readthedocs.io%2F_downloads%2Ff329e8dec804247b1dbb5835bd949e6f%2Fcheck_clocks.c%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%81%93%E3%81%A1%E3%82%89%3C%2FA%3E%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%A8%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%82%92%E5%8C%BA%E5%88%A5%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%80%8CmasterOnly%201%E3%80%8D%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%8CslaveOnly%201%E3%80%8D%E3%81%A8%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%23%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%23%20802.1AS%E3%81%AE%E8%A8%AD%E5%AE%9A%E4%BE%8B%E3%80%82%E3%81%93%E3%81%AE%E4%B8%AD%E3%81%AB%E3%81%AF%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A8%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8B%E5%B1%9E%E6%80%A7%E3%81%8C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%23%20%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%ABdefault.cfg%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%A8%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%23%20%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E4%B8%80%E8%A6%A7%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%23%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%5Bglobal%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EgmCapable%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Epriority1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20248%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Epriority2%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20248%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3ElogAnnounceInterval%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3ElogSyncInterval%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-3%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EsyncReceiptTimeout%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EneighborPropDelayThresh%20800%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Emin_neighbor_prop_delay%20-20000000%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Eassume_two_step%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Epath_trace_enabled%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Efollow_up_info%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EtransportSpecific%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Eptp_dst_mac%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2001%3A80%3AC2%3A00%3A00%3A0E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Enetwork_transport%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20L2%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Edelay_mechanism%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20P2P%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH1%20id%3D%22toc-hId-1562695082%22%20id%3D%22toc-hId--1811579438%22%3E%3CSPAN%3E%E3%83%87%E3%83%A2%E3%81%AE%E5%AE%9F%E8%A1%8C%3C%2FSPAN%3E%3C%2FH1%3E%0A%3CH2%20id%3D%22toc-hId--115676662%22%20id%3D%22toc-hId-805016114%22%3E%3CSPAN%3EALSA%20AAF%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%3C%2FSPAN%3E%3C%2FH2%3E%0A%3CP%3E%3CSPAN%3Ealsa%20AAF%E3%83%87%E3%83%A2%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81aaf0%E3%81%A8converter0%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%80%81%2Fetc%2Fasound.conf%E3%81%AB%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Epcm.aaf0%20%7B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%E3%82%BF%E3%82%A4%E3%83%97%20aaf%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ifname%20eth1.5%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Eaddr%2001%3AAA%3AAA%3AAA%3AAA%3AAA%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%E5%84%AA%E5%85%88%E5%BA%A62%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20streamid%20AA%3ABB%3ACC%3ADD%3AEE%3AFF%3A000B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20mtt%2050000%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Etime_uncertainty%201000%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Eframes_per_pdu%2012%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Eptime_tolerance%20100%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Epcm.converter0%20%7B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20type%20linear%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20slave%20%7B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Epcm%20%22hw%3A2%2C0%22%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20format%20S16_LE%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%80%8Caaf0%E3%80%8D%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E3%80%81AAF%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%ABTC%E3%81%AE%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%83%BB%E3%82%AF%E3%83%A9%E3%82%B9%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%82%8B%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E5%84%AA%E5%85%88%E5%BA%A6%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3aaf%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AE%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0ID%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%80%8Cconverter0%E3%80%8D%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E3%80%81wm8960%20PCM%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E7%94%A8%E3%81%ABS16_BE%E5%BD%A2%E5%BC%8F%E3%82%92S16_LE%E5%BD%A2%E5%BC%8F%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E1%E3%81%A4%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92AVB%E3%83%88%E3%83%BC%E3%82%AB%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E6%AC%A1%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24speaker-test%20-p%2025000%20-F%20S16_BE%20-c%202%20-r%2048000%20-D%20aaf0%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%3E1%E3%81%A4%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92AVB%E3%83%88%E3%83%BC%E3%82%AB%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E6%AC%A1%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24arecord%20-F%2025000%20-t%20raw%20-f%20S16_BE%20-c%202%20-r%2048000%20-D%20aaf0%20%7C%20aplay%20-F%2025000%20-t%20raw%20-f%20S16_BE%20-c%202%20-r%2048000%20-D%20converter0%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%E3%83%AA%E3%82%B9%E3%83%8A%E3%83%BC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E9%9F%B3%E3%81%8C%E8%81%9E%E3%81%93%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81AAF%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8Bqdisc%E3%82%AD%E3%83%A5%E3%83%BC%E3%82%92%E6%AC%A1%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24tc%20-s%20qdisc%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH2%20id%3D%22toc-hId--1224969184%22%20id%3D%22toc-hId--304276408%22%3E%3CSPAN%3EGstreamer%20AAF%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%3C%2FSPAN%3E%3C%2FH2%3E%0A%3CP%3E%3CSPAN%3E1%E3%81%A4%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92AVB%E3%83%88%E3%83%BC%E3%82%AB%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E6%AC%A1%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24gst-launch-1.0%20clockselect.%20%5C(%20clock-id%3Drealtime%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20audiotestsrc%20samplesperbuffer%3D12%20is-live%3Dtrue%20!%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20audio%2Fx-raw%2Cformat%3DS16BE%2Cchannels%3D2%2Crate%3D48000%20!%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20avtpaafpay%20mtt%3D50000000%20tu%3D1000000%20streamid%3D0xAABBCCDDEEFF000B%20processing-deadline%3D0%20!%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3Bavtpsink%20ifname%3Deth1.5%20address%3D01%3AAA%3AAA%3AAA%3AAA%3AAA%20priority%3D2%20processing-deadline%3D0%20%5C)%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E1%E3%81%A4%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92AVB%E3%83%AA%E3%82%B9%E3%83%8A%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E6%AC%A1%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24gst-launch-1.0%20clockselect.%20%5C(%20clock-id%3Drealtime%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20avtpsrc%20ifname%3Deth1.5%20!%20avtpaafdepay%20streamid%3D0xAABBCCDDEEFF000B%20!%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20queue%20max-size-bytes%3D0%20max-size-buffers%3D0%20max-size-time%3D0%20!%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20audioconvert%20!%20audioresample%20!%26nbsp%3B%20alsasink%20device%3D%22hw%3A2%2C0%22%20%5C)%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CH2%20id%3D%22toc-hId-1262543649%22%20id%3D%22toc-hId--2111730871%22%3E%26nbsp%3B%3C%2FH2%3E%0A%3CH2%20id%3D%22toc-hId--544910814%22%20id%3D%22toc-hId-375781962%22%3E%3CSPAN%3EGstreamer%20CVF%E3%83%93%E3%83%87%E3%82%AA%3C%2FSPAN%3E%3C%2FH2%3E%0A%3CP%3E%3CSPAN%3E1%E3%81%A4%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92AVB%E3%83%88%E3%83%BC%E3%82%AB%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E6%AC%A1%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24gst-launch-1.0%20clockselect.%20%5C(%20clock-id%3Drealtime%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20videotestsrc%20is-live%3Dtrue%20!%20video%2Fx-raw%2Cwidth%3D480%2Cheight%3D320%2Cframerate%3D15%2F1%20!%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20clockoverlay%20!%20x264enc%20bframes%3D0%26nbsp%3B%20key-int-max%3D1%20speed-preset%3D1%20tune%3D4%20!%20h264parse%20config-interval%3D-1%20!%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20avtpcvfpay%20processing-deadline%3D20000000%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20red%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Emtu%3D1400%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3Emtt%3D2000000%20tu%3D125000%20streamid%3D0xAABBCCDDEEFF000A%20!%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20avtpsink%20ifname%3Deth1.5%20priority%3D3%20processing-deadline%3D20000000%20%5C)%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%3CSTRONG%3E%E6%B3%A8%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%83%87%E3%83%A2%E3%81%A7%E3%81%AF%E3%80%81%E8%A8%B1%E5%AE%B9%E5%8F%AF%E8%83%BD%E3%81%AA%E9%81%85%E5%BB%B6%E3%81%A7h.264%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%2F%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%98%E3%83%83%E3%83%89%E3%82%92%E6%8E%92%E9%99%A4%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81x264enc%E8%A6%81%E7%B4%A0%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3Ebframes%EF%BC%9Ax264enc%E3%81%A8avdec_h264%E3%82%92%E4%B8%80%E7%B7%92%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E5%86%85%E3%81%AEbframes%E3%82%92%E3%81%AA%E3%81%8F%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3Ekey-int-max%EF%BC%9A%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%81%AF%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E4%B8%8A%E3%81%AB%E3%82%AD%E3%83%BC%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AE%E3%81%BF%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%82%92%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%81%AE%E5%8B%95%E4%BD%9C%E3%82%92%E5%8F%AF%E8%83%BD%E3%81%AA%E9%99%90%E3%82%8A%E9%AB%98%E9%80%9F%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%812%E3%81%A4%E3%81%AE%E3%82%AD%E3%83%BC%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E9%96%93%E3%81%AE%E8%B7%9D%E9%9B%A2%E3%82%92%E6%9C%80%E7%9F%AD%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3Espeed-preset%EF%BC%9A%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AECPU%E8%B2%A0%E8%8D%B7%E3%82%92%E8%BB%BD%E6%B8%9B%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E5%8F%AF%E8%83%BD%E3%81%AA%E9%99%90%E3%82%8A%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%92%E9%AB%98%E9%80%9F%E5%8C%96%E3%81%99%E3%82%8B%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%EF%BC%88%3D1%E3%81%AF%E8%B6%85%E9%AB%98%E9%80%9F%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3Etune%3A%204%20%E3%81%AF%E3%82%BC%E3%83%AD%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3Eavtpcvfpay%E8%A6%81%E7%B4%A0%E3%81%AE%E3%80%8Cmtu%3D1400%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E9%87%8D%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AEmtu%3D1500%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%AA%E3%82%B9%E3%83%8A%E3%83%BC%E3%81%AFVLAN%E3%81%8B%E3%82%89AVTPDU%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%90%86%E7%94%B1%E3%81%AF%E4%BB%8A%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E4%B8%8D%E6%98%8E%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E1%E3%81%A4%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92AVB%E3%83%AA%E3%82%B9%E3%83%8A%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E6%AC%A1%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%24gst-launch-1.0%20clockselect.%20%5C(%20clock-id%3Drealtime%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20avtpsrc%20ifname%3Deth1.5%20!%20avtpcvfdepay%20streamid%3D0xAABBCCDDEEFF000A%20!%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%20%26nbsp%3B%26nbsp%3Bqueue%20max-size-bytes%3D0%20max-size-buffers%3D0%20max-size-time%3D0%20!%20%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%2324292e%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20avdec_h264%20!%20videoconvert%20!%20clockoverlay%20halignment%3Dright%20!%20waylandsink%20%5C)%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%E4%B8%8B%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%9F%E3%83%87%E3%83%A2%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81videotestsrc%E3%81%AE%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%AB2%E3%81%A4%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%B7%A6%E5%81%B4%E3%81%AF%E3%80%81AVB%E3%83%88%E3%83%BC%E3%82%AB%E3%83%BC%E5%81%B4%E3%81%A7x264enc%E3%81%AE%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E5%89%8D%E3%81%AB%E8%A8%98%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%97%E3%80%81%E5%8F%B3%E5%81%B4%E3%81%AFAVB%E3%83%AA%E3%82%B9%E3%83%8A%E3%83%BC%E5%81%B4%E3%81%A7avdec_h265%E3%81%AE%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8YUV%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%B8%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E5%A4%89%E6%8F%9B%E3%81%AE%E5%BE%8C%E3%81%AB%E8%A8%98%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%97%E3%81%A7%E3%81%99%E3%80%82%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%97%E3%81%8C%E7%A7%92%E5%8D%98%E4%BD%8D%E3%81%A7%E5%90%8C%E6%9C%9F%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_30.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_30.png%22%20style%3D%22width%3A%20275px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110981i6BAF5E9668453678%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_30.png%22%20alt%3D%22pastedImage_30.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH1%20id%3D%22toc-hId-1813519300%22%20id%3D%22toc-hId--1560755220%22%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EDeep%20dive%3C%2FSPAN%3E%3C%2FH1%3E%0A%3CH2%20id%3D%22toc-hId-135147556%22%20id%3D%22toc-hId-1055840332%22%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%83%BB%E3%82%B9%E3%83%8B%E3%83%95%E3%82%A1%3C%2FSPAN%3E%3C%2FH2%3E%0A%3CP%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%E3%82%AA%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AEtcpdump%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81L2%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%BB%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%82%92%E3%83%80%E3%83%B3%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E.%2Ftcpdump%20-i%20eth1%20ether%20proto%200x22f0%20-w%20dump.pcap%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3EAVTP%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%BB%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%BB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%BB%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E5%86%85%E3%81%AB%E5%9F%8B%E3%82%81%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%9F0x22f0%E3%81%A7%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81tcpdump%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AB%E3%80%8Cvlan%205%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86VLAN%20ID%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%A6%E3%83%80%E3%83%B3%E3%83%97%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%E6%AC%A1%E3%81%AB%E3%80%81Windows%2FLinux%20PC%E3%81%A7Wireshark%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%93%E3%81%AEdump.pcap%E3%82%92%E9%96%8B%E3%81%8F%E3%81%A8%E3%80%81%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E5%86%85%E3%81%AE%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%8C%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81IEEE1722%EF%BC%88AVTP%EF%BC%89CVF%2FAFF%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%83%BB%E3%83%98%E3%83%83%E3%83%80%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A7%A3%E6%9E%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%20style%3D%22width%3A%20865px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110193i15CF8AE7329F0582%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_4.png%22%20alt%3D%22pastedImage_4.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH2%20id%3D%22toc-hId--1672306907%22%20id%3D%22toc-hId--751614131%22%3E%E9%AB%98%E7%B2%BE%E5%BA%A6%E3%81%AA%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%83%BC%E6%B8%AC%E5%AE%9A%3C%2FH2%3E%0A%3CUL%3E%0A%3CLI%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%88%E3%83%BC%E3%82%AB%E3%83%BC%2F%E3%83%AA%E3%82%B9%E3%83%8A%E3%83%BC%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8Bclockoverlay%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%AF%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E7%A7%92%E5%8D%98%E4%BD%8D%E3%81%AE%E7%B2%BE%E5%BA%A6%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E7%B2%BE%E5%BA%A6%E3%81%A7%E3%81%AF%E3%80%81%E3%83%88%E3%83%BC%E3%82%AB%E3%83%BC%E3%81%AEvideotestsrc%E3%81%8B%E3%82%89%E3%83%AA%E3%82%B9%E3%83%8A%E3%83%BC%E3%81%AEavdec_h264%E3%81%AE%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%E5%AE%8C%E4%BA%86%E3%81%BE%E3%81%A7%E3%81%AE%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%82%92%E5%8F%8D%E6%98%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%81%E3%83%9F%E3%83%AA%E7%A7%92%E5%8D%98%E4%BD%8D%E3%81%AE%E7%B2%BE%E5%BA%A6%E3%82%92%E5%BE%97%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81gst-plugins-base%E3%81%AEclockoverlay%E8%A6%81%E7%B4%A0%E3%81%AB%E5%B0%91%E3%81%97%E6%89%8B%E3%82%92%E5%8A%A0%E3%81%88%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%91%E3%83%83%E3%83%81%E3%81%8C%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%88gst-plugins-base-clockoverlay-us.patch%EF%BC%89%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6gst-plugins-base%E3%82%92%E5%86%8D%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%9F%E3%81%86%E3%81%88%E3%81%A7%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%2Fusr%2Flib%2Fgstreamer-1.0%2F%E3%81%AElibgstpango.so%E3%82%92%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82CVF%E3%81%AE%E3%83%87%E3%83%A2%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E3%80%81%E7%94%BB%E9%9D%A2%E3%81%AE%E5%86%99%E7%9C%9F%E3%82%92%E6%92%AE%E5%BD%B1%E3%81%97%E3%81%A6%E3%80%812%E3%81%A4%E3%81%AE%E6%99%82%E5%88%BB%E3%81%AE%E5%B7%AE%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%81%AF%E7%B4%8450%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E3%80%81%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%80%81AVTP%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%83%B3%E3%82%B0%E3%80%81%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E3%80%81%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E9%80%81%E4%BF%A1%E3%80%81%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E5%8F%97%E4%BF%A1%E3%80%81AVTP%E3%82%A2%E3%83%B3%E3%83%91%E3%83%83%E3%82%AD%E3%83%B3%E3%82%B0%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%BB%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%82%B9%E3%83%88%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110276i1D3D50E116858C9A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E9%80%81%E4%BF%A1%E3%83%9D%E3%83%BC%E3%83%88%EF%BC%88%E3%83%88%E3%83%BC%E3%82%AB%E3%83%BC%EF%BC%89%E3%81%8B%E3%82%89%E5%8F%97%E4%BF%A1%E3%83%9D%E3%83%BC%E3%83%88%EF%BC%88%E3%83%AA%E3%82%B9%E3%83%8A%E3%83%BC%EF%BC%89%E3%81%BE%E3%81%A7%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%83%BB%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%B8%A1%E6%96%B9%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%A7tcpdump%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%83%80%E3%83%B3%E3%83%97%E3%81%95%E3%82%8C%E3%81%9F%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%81%AE%E3%82%A8%E3%83%9D%E3%83%83%E3%82%AF%E3%83%BB%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%92%E3%80%81%E3%80%8CEpoch%20Time%3A%201596252905.688243000%20seconds%E3%80%8D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E9%83%A8%E5%88%86%E3%82%92%E5%9F%BA%E3%81%AB%E6%AF%94%E8%BC%83%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%90%8C%E3%81%98%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%81%AE%E3%82%A8%E3%83%9D%E3%83%83%E3%82%AF%E3%83%BB%E3%82%BF%E3%82%A4%E3%83%A0%E3%81%AE%E5%B7%AE%E7%95%B0%E3%81%AF%E7%B4%84100%CE%BCs%EF%BD%9E500%CE%BCs%E3%81%A7%E3%81%99%E3%80%82%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%81%AB%E3%81%AF%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AEnetfilter%E3%81%A7%E3%81%AEAF_PACKET%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%83%BB%E3%82%B3%E3%82%B9%E3%83%88%E3%81%A8%E3%80%81tcpdump%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%83%BB%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CH1%20id%3D%22toc-hId-686123207%22%20id%3D%22toc-hId-1606815983%22%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200cm%3B%22%3E%E5%8F%82%E8%80%83%E6%83%85%E5%A0%B1%3C%2FSPAN%3E%3C%2FH1%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3ELinux%E3%81%A7%E3%81%AEAVB%E5%85%A5%E9%96%80%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Ftsn.readthedocs.io%2Favb.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Ftsn.readthedocs.io%2Favb.html%3C%2FA%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3ETSN%E3%81%A8AVB%E3%81%AE%E9%81%95%E3%81%84%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fdornerworks.com%2Fblog%2Favb-vs-tsn-choose-the-best-deterministic-ethernet-solution-for-your-networked-devices%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fdornerworks.com%2Fblog%2Favb-vs-tsn-choose-the-best-deterministic-ethernet-solution-for-your-networked-devices%2F%3C%2FA%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EALSA%20aaf%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Ffossies.org%2Flinux%2Falsa-plugins%2Fdoc%2Faaf.txt%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Ffossies.org%2Flinux%2Falsa-plugins%2Fdoc%2Faaf.txt%3C%2FA%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EGStreamer%20avtp%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fgstreamer.freedesktop.org%2Fdocumentation%2Favtp%2Findex.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgstreamer.freedesktop.org%2Fdocumentation%2Favtp%2Findex.html%3C%2FA%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EAVTP%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Favnu.org%2Fwp-content%2Fuploads%2F2014%2F05%2FAVnu-AAA2C_Audio-Video-Transport-Protocol-AVTP_Dave-Olsen.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Favnu.org%2Fwp-content%2Fuploads%2F2014%2F05%2FAVnu-AAA2C_Audio-Video-Transport-Protocol-AVTP_Dave-Olsen.pdf%3C%2FA%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EMX8MP%20RM%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1987792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20AVB%2FTSN%20demo%20on%20i.MX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1987792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F29913%22%20target%3D%22_blank%22%3E%40xinyu_chen%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%80%8C%3CINSTALL%20folder%3D%22%22%3E%2Fusr%E3%80%8D%E3%81%AE%E9%83%A8%E5%88%86%E3%82%92%E3%80%8Croot%2Fusr%E3%80%8D%E3%81%A8%E3%81%97%E3%81%9F%E3%81%86%E3%81%88%E3%81%A7%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%80%8Cgst-inspect-1.0%E3%80%8D%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FINSTALL%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%A1%E3%82%89%E3%81%8C%E3%83%AD%E3%82%B0%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3Eroot%40imx8mpevk%3A~%23%20export%20GST_PLUGIN_PATH%3D%2Fusr%2Flib%2Fgstreamer-1.0%2F%3CBR%20%2F%3Eroot%40imx8mpevk%3A~%23%20gst-inspect-1.0%3C%2FP%3E%3CP%3E(gst-inspect-1.0%3A795)%3A%20GStreamer-WARNING%20**%3A%2011%3A28%3A36.879%3A%20External%20plugin%20loader%20failed.%20This%20most%20likely%20means%20that%20the%20plugin%20loader%20helper%20binary%20was%20not%20found%20or%20could%20not%20be%20run.%20You%20might%20need%20to%20set%20the%20GST_PLUGIN_SCANNER%20environment%20variable%20if%20your%20setup%20is%20unusual.%20This%20should%20normally%20not%20be%20required%20though.%3C%2FP%3E%3CP%3E(gst-inspect-1.0%3A795)%3A%20GStreamer-WARNING%20**%3A%2011%3A28%3A37.029%3A%20Failed%20to%20load%20plugin%20'%2Fusr%2Flib%2Fgstreamer-1.0%2Flibgstbeepdec.so'%3A%20%2Fusr%2Flib%2Flibgstfsl-1.0.so.0%3A%20undefined%20symbol%3A%20gst_allocator_phymem_get_type%3C%2FP%3E%3CP%3E(gst-inspect-1.0%3A795)%3A%20GStreamer-WARNING%20**%3A%2011%3A28%3A37.115%3A%20Failed%20to%20load%20plugin%20'%2Fusr%2Flib%2Fgstreamer-1.0%2Flibgstimxcompositor.so'%3A%20%2Fusr%2Flib%2Flibgstfsl-1.0.so.0%3A%20undefined%20symbol%3A%20gst_allocator_phymem_get_type%3C%2FP%3E%3CP%3E(gst-inspect-1.0%3A795)%3A%20GStreamer-WARNING%20**%3A%2011%3A28%3A37.122%3A%20Failed%20to%20load%20plugin%20'%2Fusr%2Flib%2Fgstreamer-1.0%2Flibgstx264.so'%3A%20libx264.so.157%3A%20cannot%20open%20shared%20object%20file%3A%20No%20such%20file%20or%20directory%3C%2FP%3E%3CP%3E(gst-inspect-1.0%3A795)%3A%20GStreamer-WARNING%20**%3A%2011%3A28%3A37.217%3A%20Failed%20to%20load%20plugin%20'%2Fusr%2Flib%2Fgstreamer-1.0%2Flibgstvideo4linux2.so'%3A%20%2Fusr%2Flib%2Fgstreamer-1.0%2Flibgstvideo4linux2.so%3A%20undefined%20symbol%3A%20gst_buffer_add_dmabuf_meta%3C%2FP%3E%3CP%3E(gst-inspect-1.0%3A795)%3A%20GLib-GObject-WARNING%20**%3A%2011%3A28%3A38.196%3A%20cannot%20register%20existing%20type%20'GstDashDemux'%3C%2FP%3E%3CP%3E(gst-inspect-1.0%3A795)%3A%20GLib-CRITICAL%20**%3A%2011%3A28%3A38.196%3A%20g_once_init_leave%3A%20assertion%20'result%20!%3D%200'%20failed%3C%2FP%3E%3CP%3E(gst-inspect-1.0%3A795)%3A%20GStreamer-CRITICAL%20**%3A%2011%3A28%3A38.196%3A%20gst_element_register%3A%20assertion%20'g_type_is_a%20(type%2C%20GST_TYPE_ELEMENT)'%20failed%3C%2FP%3E%3CP%3E(gst-inspect-1.0%3A795)%3A%20GStreamer-WARNING%20**%3A%2011%3A28%3A38.405%3A%20Failed%20to%20load%20plugin%20'%2Fusr%2Flib%2Fgstreamer-1.0%2Flibgstimxvideoconvert.so'%3A%20%2Fusr%2Flib%2Flibgstfsl-1.0.so.0%3A%20undefined%20symbol%3A%20gst_allocator_phymem_get_type%3C%2FP%3E%3CP%3E(gst-inspect-1.0%3A795)%3A%20GStreamer-WARNING%20**%3A%2011%3A28%3A38.510%3A%20Failed%20to%20load%20plugin%20'%2Fusr%2Flib%2Fgstreamer-1.0%2Flibgstvpu.so'%3A%20%2Fusr%2Flib%2Flibgstfsl-1.0.so.0%3A%20undefined%20symbol%3A%20gst_allocator_phymem_get_type%3C%2FP%3E%3CP%3E(gst-inspect-1.0%3A795)%3A%20GStreamer-WARNING%20**%3A%2011%3A28%3A38.795%3A%20Failed%20to%20load%20plugin%20'%2Fusr%2Flib%2Fgstreamer-1.0%2Flibgstaiurdemux.so'%3A%20%2Fusr%2Flib%2Flibgstfsl-1.0.so.0%3A%20undefined%20symbol%3A%20gst_allocator_phymem_get_type%3CBR%20%2F%3Empegpsmux%3A%20mpegpsmux%3A%20MPEG%20Program%20Stream%20Muxer%3CBR%20%2F%3Espectrum%3A%20spectrum%3A%20Spectrum%20analyzer%3CBR%20%2F%3Eshapewipe%3A%20shapewipe%3A%20Shape%20Wipe%20transition%20filter%3CBR%20%2F%3Evideoparsersbad%3A%20h263parse%3A%20H.263%20parser%3CBR%20%2F%3Evideoparsersbad%3A%20h264parse%3A%20H.264%20parser%3CBR%20%2F%3Evideoparsersbad%3A%20diracparse%3A%20Dirac%20parser%3CBR%20%2F%3Evideoparsersbad%3A%20mpegvideoparse%3A%20MPEG%20video%20elementary%20stream%20parser%3CBR%20%2F%3Evideoparsersbad%3A%20mpeg4videoparse%3A%20MPEG%204%20video%20elementary%20stream%20parser%3CBR%20%2F%3Evideoparsersbad%3A%20pngparse%3A%20PNG%20parser%3CBR%20%2F%3Evideoparsersbad%3A%20jpeg2000parse%3A%20JPEG%202000%20parser%3CBR%20%2F%3Evideoparsersbad%3A%20h265parse%3A%20H.265%20parser%3CBR%20%2F%3Evideoparsersbad%3A%20vc1parse%3A%20VC1%20parser%3CBR%20%2F%3Edtmf%3A%20dtmfsrc%3A%20DTMF%20tone%20generator%3CBR%20%2F%3Edtmf%3A%20rtpdtmfsrc%3A%20RTP%20DTMF%20packet%20generator%3CBR%20%2F%3Edtmf%3A%20rtpdtmfdepay%3A%20RTP%20DTMF%20packet%20depayloader%3CBR%20%2F%3Edvdsub%3A%20dvdsubdec%3A%20DVD%20subtitle%20decoder%3CBR%20%2F%3Edvdsub%3A%20dvdsubparse%3A%20DVD%20subtitle%20parser%3CBR%20%2F%3Efieldanalysis%3A%20fieldanalysis%3A%20Video%20field%20analysis%3CBR%20%2F%3Ejpeg%3A%20jpegenc%3A%20JPEG%20image%20encoder%3CBR%20%2F%3Ejpeg%3A%20jpegdec%3A%20JPEG%20image%20decoder%3CBR%20%2F%3Evideofilter%3A%20gamma%3A%20Video%20gamma%20correction%3CBR%20%2F%3Evideofilter%3A%20videobalance%3A%20Video%20balance%3CBR%20%2F%3Evideofilter%3A%20videoflip%3A%20Video%20flipper%3CBR%20%2F%3Evideofilter%3A%20videomedian%3A%20Median%20effect%3CBR%20%2F%3Ey4menc%3A%20y4menc%3A%20YUV4MPEG%20video%20encoder%3CBR%20%2F%3Edvbsubenc%3A%20dvbsubenc%3A%20DVB%20subtitle%20encoder%3CBR%20%2F%3Eaiff%3A%20aiffparse%3A%20AIFF%20audio%20demuxer%3CBR%20%2F%3Eaiff%3A%20aiffmux%3A%20AIFF%20audio%20muxer%3CBR%20%2F%3Esubenc%3A%20srtenc%3A%20Srt%20encoder%3CBR%20%2F%3Esubenc%3A%20webvttenc%3A%20WebVTT%20encoder%3CBR%20%2F%3Esoup%3A%20souphttpsrc%3A%20HTTP%20client%20source%3CBR%20%2F%3Esoup%3A%20souphttpclientsink%3A%20HTTP%20client%20sink%3CBR%20%2F%3Edvdlpcmdec%3A%20dvdlpcmdec%3A%20DVD%20LPCM%20Audio%20decoder%3CBR%20%2F%3Etheora%3A%20theoradec%3A%20Theora%20video%20decoder%3CBR%20%2F%3Etheora%3A%20theoraenc%3A%20Theora%20video%20encoder%3CBR%20%2F%3Etheora%3A%20theoraparse%3A%20Theora%20video%20parser%3CBR%20%2F%3Ecompositor%3A%20compositor%3A%20Compositor%3CBR%20%2F%3Eaudiomixmatrix%3A%20audiomixmatrix%3A%20Matrix%20audio%20mix%3CBR%20%2F%3Esbc%3A%20sbcdec%3A%20Bluetooth%20SBC%20audio%20decoder%3CBR%20%2F%3Esbc%3A%20sbcenc%3A%20Bluetooth%20SBC%20audio%20encoder%3CBR%20%2F%3Eivfparse%3A%20ivfparse%3A%20IVF%20parser%3CBR%20%2F%3Elegacyrawparse%3A%20videoparse%3A%20Video%20Parse%3CBR%20%2F%3Elegacyrawparse%3A%20audioparse%3A%20Audio%20Parse%3CBR%20%2F%3Einterleave%3A%20interleave%3A%20Audio%20interleaver%3CBR%20%2F%3Einterleave%3A%20deinterleave%3A%20Audio%20deinterleaver%3CBR%20%2F%3Etranscode%3A%20transcodebin%3A%20Transcode%20Bin%3CBR%20%2F%3Etranscode%3A%20uritranscodebin%3A%20URITranscode%20Bin%3CBR%20%2F%3Evideotestsrc%3A%20videotestsrc%3A%20Video%20test%20source%3CBR%20%2F%3Eaudiorate%3A%20audiorate%3A%20Audio%20rate%20adjuster%3CBR%20%2F%3Eadpcmdec%3A%20adpcmdec%3A%20ADPCM%20decoder%3CBR%20%2F%3Eogg%3A%20oggdemux%3A%20Ogg%20demuxer%3CBR%20%2F%3Eogg%3A%20oggmux%3A%20Ogg%20muxer%3CBR%20%2F%3Eogg%3A%20ogmaudioparse%3A%20OGM%20audio%20stream%20parser%3CBR%20%2F%3Eogg%3A%20ogmvideoparse%3A%20OGM%20video%20stream%20parser%3CBR%20%2F%3Eogg%3A%20ogmtextparse%3A%20OGM%20text%20stream%20parser%3CBR%20%2F%3Eogg%3A%20oggparse%3A%20Ogg%20parser%3CBR%20%2F%3Eogg%3A%20oggaviparse%3A%20Ogg%20AVI%20parser%3CBR%20%2F%3Ematroska%3A%20matroskademux%3A%20Matroska%20demuxer%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1969430%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20AVB%2FTSN%20demo%20on%20i.MX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1969430%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F29913%22%20target%3D%22_blank%22%3E%40xinyu_chen%3C%2FA%3E%26nbsp%3B%E5%89%8D%E5%9B%9E%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%A9%E3%81%86%E3%81%8B%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1962618%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20AVB%2FTSN%20demo%20on%20i.MX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1962618%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F29913%22%20target%3D%22_blank%22%3E%40xinyu_chen%3C%2FA%3E%20%E5%88%A5%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%3CMY%20installer%3D%22%22%20folder%3D%22%22%3E%20%E3%81%8B%E3%82%89%E3%80%8C%2Fusr%E3%80%8D%E3%81%B8%E3%81%AEprefix%E3%81%AE%E4%BF%AE%E6%AD%A3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FMY%3E%3C%2FP%3E%3CP%3Egrep%20-lR%20'%2Fhome%2Fyzg%2Fwork%2Favb%2Fpackages'%20--include%3D'*.pc'%20.%7C%20xargs%20sed%20-i%20'sI%2Fhome%2Fyzg%2Fwork%2Favb%2Fpackages%7C%2Fusr%7Cg'%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81gst-plugins-base%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E6%96%B0%E3%81%9F%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22brady3_1-1727346882923.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22brady3_1-1727346882923.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301448i8C9B76818DA1E0C4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22brady3_1-1727346882923.png%22%20alt%3D%22brady3_1-1727346882923.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EGStreamer%20%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1961592%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20AVB%2FTSN%20demo%20on%20i.MX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1961592%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F29913%22%20target%3D%22_blank%22%3E%40xinyu_chen%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AEGStreamer%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%881.16.3%EF%BC%89%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22brady3_1-1727255159131.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22brady3_1-1727255159131.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301161i311C4E8EF3E5DD2F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22brady3_1-1727255159131.png%22%20alt%3D%22brady3_1-1727255159131.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EGStreamer%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22brady3_0-1727254746803.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22brady3_0-1727254746803.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F301157i872F39517463A52B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22brady3_0-1727254746803.png%22%20alt%3D%22brady3_0-1727254746803.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Egit%20checkout%20-b%20dev%20e4f7cdb0df7b%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1961317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20AVB%2FTSN%20demo%20on%20i.MX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1961317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%AD%A3%E3%81%97%E3%81%84%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E3%81%AF%E3%81%93%E3%81%AE%E5%80%A4%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId-1533829160%22%20id%3D%22toc-hId-1316156599%22%20id%3D%22toc-hId-57526958%22%3E%3CSPAN%3EGStreamer%201.17.x%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%EF%BC%88commit%20e4f7cdb0df7b%EF%BC%89%3C%2FSPAN%3E%3C%2FH3%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1961278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20AVB%2FTSN%20demo%20on%20i.MX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1961278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F29913%22%20target%3D%22_blank%22%3E%40xinyu_chen%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3Egstreamer-1.0-pass-build.patch%E3%81%A7%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fgitlab.freedesktop.org%2Fgstreamer%2Fgstreamer.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgitlab.freedesktop.org%2Fgstreamer%2Fgstreamer.git%3C%2FA%3E%3C%2FSPAN%3E%E3%82%92%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%81%9Fgstreamer%E3%83%91%E3%82%B9%E3%81%AB%E3%81%82%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81gstreamer%E3%83%91%E3%82%B9%E3%81%AE%E4%B8%8B%E3%81%AB%E3%81%AFdata%2Fmeson.build%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Ediff%20--git%20a%2Fdata%2Fmeson.build%20b%2Fdata%2Fmeson.build%3CBR%20%2F%3Eindex%20c9130e0..3477dfe%20100644%3CBR%20%2F%3E---%20a%2Fdata%2Fmeson.build%3CBR%20%2F%3E%2B%2B%2B%20b%2Fdata%2Fmeson.build%3CBR%20%2F%3E%40%40%20-1%2C5%20%2B1%2C5%20%40%40%3CBR%20%2F%3Eif%20(bashcomp_found)%3CBR%20%2F%3E-%20subdir('bash-completion%2Fhelpers')%3CBR%20%2F%3E-%20install_data('bash-completion%2Fcompletions%2Fgst-launch-1.0'%2C%20install_dir%20%3A%20bash_completions_dir)%3CBR%20%2F%3E-%20install_data('bash-completion%2Fcompletions%2Fgst-inspect-1.0'%2C%20install_dir%20%3A%20bash_completions_dir)%3CBR%20%2F%3E%2B%23%20subdir('bash-completion%2Fhelpers')%3CBR%20%2F%3E%2B%23%20install_data('bash-completion%2Fcompletions%2Fgst-launch-1.0'%2C%20install_dir%20%3A%20bash_completions_dir)%3CBR%20%2F%3E%2B%23%20install_data('bash-completion%2Fcompletions%2Fgst-inspect-1.0'%2C%20install_dir%20%3A%20bash_completions_dir)%3CBR%20%2F%3Eendif%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1808913%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20AVB%2FTSN%20demo%20on%20i.MX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1808913%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F29913%22%20target%3D%22_blank%22%3E%40xinyu_chen%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%81%AEmp4%E5%8B%95%E7%94%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3Egst-launch-1.0%20clockselect.%20%5C(%20clock-id%3Drealtime%20%5C%0A%20%20%20%20filesrc%20location%3Dsintel_trailer-480p.mp4%20!%20qtdemux%20!%20h264parse%20config-interval%3D-1%20!%20%5C%0A%20%20%20%20avtpcvfpay%20processing-deadline%3D20000000%20mtu%3D1400%20mtt%3D2000000%20tu%3D125000%20streamid%3D0xAABBCCDDEEFF000A%20!%20%5C%3CBR%20%2F%3E%20%20%20%20avtpsink%20ifname%3Deth1.5%20priority%3D3%20processing-deadline%3D20000000%20%5C)%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E3%81%A8%E3%81%93%E3%82%8D%E3%81%8C%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EPipeline%20is%20PREROLLING%20...%0APipeline%20is%20PREROLLED%20...%0ASetting%20pipeline%20to%20PLAYING%20...%0ANew%20clock%3A%20DebugGstSystemClock%0AGot%20EOS%20from%20element%20%22clockselect0%22.%0AExecution%20ended%20after%200%3A00%3A00.544463000%0ASetting%20pipeline%20to%20NULL%20...%0AFreeing%20pipeline%20...%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E3%81%A8%3C%2FP%3E%3CP%3Ebasesrc%20gstbasesrc.c%3A3688%3Agst_base_src_start_complete%3A%3CFILESRC0%3E%E3%83%91%E3%83%83%E3%83%89%E3%81%AF%E3%81%BE%E3%81%A0%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FFILESRC0%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1158515%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20AVB%2FTSN%20demo%20on%20i.MX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1158515%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F29913%22%20target%3D%22_blank%22%3E%40xinyu_chen%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EALSA%20aaf%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E9%83%A8%E5%88%86%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%22%3CSPAN%3E%24.%2Fconfigure%20--build%3Dx86_64-linux%20--host%3Daarch64-poky-linux%20--target%3Daarch64-poky-linux%20--prefix%3D%3C%2FSPAN%3E%3CSPAN%3E%3CYOUR%20install%3D%22%22%20folder%3D%22%22%3E%3C%2FYOUR%3E%3C%2FSPAN%3E%3CSPAN%3E%2Fusr%20--disable-silent-rules%20--disable-dependency-tracking%20--with-libtool-sysroot%3D%2Fopt%2Fsamba%2Fnxa23059%2Fjailhouse%2Fyocto-5.x%2Fbuild-8mp%2Ftmp%2Fwork%2Faarch64-mx8mp-poky-linux%2Falsa-plugins%2F1.1.9-r0%2Frecipe-sysroot%20--disable-static%20--%3C%2FSPAN%3E%3CSPAN%3Eenable-aaf%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E--disable-jack%20--disable-libav%20--disable-maemo-plugin%20--disable-maemo-resource-manager%20--enable-pulseaudio%20--enable-samplerate%20--with-speex%3Dlib%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E--with-libtool-sysroot%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%AE%9A%E7%BE%A9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E--with-libtool-sysroot%3D%2Fopt%2Fsamba%2Fnxa23059%2Fjailhouse%2Fyocto-5.x%2Fbuild-8mp%2Ftmp%2Fwork%2Faarch64-mx8mp-poky-linux%2Falsa-plugins%2F1.1.9-r0%2Frecipe-sysroot%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%80%8C%3CYOCTO%20build%3D%22%22%3E%2Ftmp%2Fwork%2Faarch64-mx8mp-poky-linux%2Falsa-plugins%2F1.1.9-r0%2Frecipe-sysroot%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E8%A7%A3%E9%87%88%E3%81%A7%E3%82%88%E3%82%8D%E3%81%97%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FYOCTO%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎05-18-2021 02:08 AM
更新者:
