imx6 Rotary has a bug How to solve
6,339 次查看
小李
hi,
I made a try on imX6Q Linux4.1.15 version,Rotate the screen 180 degrees. use  command echo 1 > /sys/class/graphics/fb0/rotate  .But the display is abnormal,Not only up and down, but also left and right.It's very confusing.So I tried to find the problem in the driver .I have found
drivers/video/fbdev/mxc/mxc_ipuv3_fb.c  A corresponding parameter is passed 。I can't find the corresponding call ,but I can't find the corresponding calls and modifications that make it upside down, not left to right
Thank you for your help!
标记 (3)
6 回复数
6,331 次查看
小李
@Juan-Rodarte
    There is no good solution?
thank you for your help!
6,323 次查看
joanxie
this couldn't be supported, you can use GPU2D to support rotation
6,319 次查看
小李
hi,@joanxie
    Is there any way to rotate 180 degrees? Is there any specific modification routine
6,306 次查看
joanxie
refer to the chapter  7.3.14 Video conversion of enclosed file
6,261 次查看
小李
hi,@joanxie
    What I want to do is display rotation of the screen, not play video rotation, do you have any other suggestions
6,252 次查看
joanxie
pls refer to the chapter 6.2 XRandR of enclosed file
