Is demoFramework the easiest way to show images or videos on screen? Does i.mx8qm have any function like DCU in S32V?
Solved! Go to Solution.
A1) Yes,
A2) No the i.mx8 use OpenCV 3.x and the S32V use 2.x but the both GPU are from Vivante you may adapt it.
