I was curious to know if the clock limitations were due to heat or current limit or something else?
You stated that the capture limitations for the second camera would be limited by the DDR size.
That Application note was for the ISI. I know we need the ISP for at least one of the cameras which needs to capture 4k @ 30fps. Can you point me to the proper ISP-related document which would explain what the limitations of the second camera would be?
This what we have:
https://www.nxp.com/docs/en/application-note/AN13712.pdf
https://www.nxp.com/docs/en/application-note/AN12060.pdf
A1, No the clock limitation are made by the processor itself.
A2. depend of your DDR size.
A3. No,
You better read the following app note:
https://www.nxp.com/docs/en/application-note/AN13573.pdf
