[i.MX8MM] Chromium cannot show datepicker when control item is at bottom
223 次查看
adv-johnchang
We are running Chromium on an i.MX8MM. When an HTML input control is located at the bottom of a webpage, the datepicker doesn't display correctly. Unfortunately, we cannot modify the webpage.
Do you have any suggestions?
example html: test_date.html
Related version:
Yocto 4.2
Chromium v101
Weston v10.0.5
标记 (1)
216 次查看
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
Is this behavior reproducible in latest BSP?
176 次查看
adv-johnchang
The issue is reproducible on Yocto 5.0.
Yocto 5.0
Chromium v117
Weston v12.0.5
