Looking at p57 of the i.MX Graphics User's Guide, I see that the entry for "Local Storage Registers On-chip" is blank in the "GC7000UL" column (screenshot attached). Does that mean that the GC7000UL has no local on-chip registers (i.e. only global memory)?
Solved! Go to Solution.
yes you're right, I double check the IP spec, GC7000UL has no local on-chip registers
