enable dsi driver with imx8mp
3,627 次查看
DEEPIKA19
Hi team,
I am trying to enable dsi display with imx8mp.
As suggested in the forum, i tried to add st7701 with the device tree as below
&lcdif1 {
status = "okay";
&mipi_dsi {
status = "okay";
panel@0 {
compatible = "techstar,ts8550b";
reg = <0>;
dsi-lanes = <2>;
I tried to boot the board and i am getting the following error.
[ 6.813406] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[ 6.979483] imx-drm display-subsystem: bound imx-lcdifv3-crtc.1 (ops lcdifv3_crtc_ops)
[ 7.118113] imx-drm display-subsystem: bound imx-lcdifv3-crtc.2 (ops lcdifv3_crtc_ops)
[7.144740] imx_sec_dsim_drv 32e60000.mipi_dsi: Unbalanced imx_sec_dsi!
m.
[ 7.169083] imx_sec_dsim_drv 32e60000.mipi_dsi: version number is 0x1060200
[ 7.186515] panel-sitronix-st7701 32e60000.mipi_dsi.0: supply v3p3 not found, using dur
[ 7.219249] panel-sitronix-st7701 32e60000.mipi_dsi.0: supply v1p8 not found, using dummy regulator
[ 7.243099] imx_sec_dsim_drv 32e60000.mipi_dsi: unsupported dsi mode
[ 7.249684] panel-sitronix-st7701: probe of 32e60000.mipi_dsi.0 failed with error -22
[ 7.303549] imx_sec_dsim_drv 32e60000.mipi_dsi: failed to bind sec dsim bridge: -517
[ 7.433465] imx_sec_dsim_drv 32e60000.mipi_dsi: Unbalanced imx_sec_dsim_runtime_resume!
Please could you help me on how to debug this issue.
Thanks in advance
deepika
标记 (1)
5 回复数
3,612 次查看
Zhiming_Liu
Hi @DEEPIKA19
The core log: 'unsupported dsi mode', you need check your panel driver about dsi mode.
3,582 次查看
DEEPIKA19
Thanks for your reply @Zhiming_Liu
I tried to change the dsi mode in the panel driver and the error is resolved.
But nothing on the dsi.
While checking the logs, I observed the below error related to dsi
imx_sec_dsim_drv 32e60000.mipi_dsi: wait payload tx done time out
Please could you suggest a way to debug the issue.
Thanks in advance
deepika
3,570 次查看
DEEPIKA19
Hi team,
Please could someone help me with the above query.
deepika
3,552 次查看
DEEPIKA19
Hi team,
Could someone help me with the above issue....
deepika
2,389 次查看
Udhay_
@DEEPIKA19
I am facing similar issue
did you resolve that issue
