Usage of GPU on i.MX8M mini.
Kavya_2025
I'm trying to use GPU of i.MX8M mini for scaling purpose. for this I'm using g2d API's. Am I doing it with correct approach. If wrong how can I make use of GPU for my application. Has someone worked on this before? Just using those API will I be able to use GPU for scaling? I have written a small code which uses these API but I am getting error as g2d.h is not present. but the shared object is already installed.
#G2D usage for GPU, @i.MX8M mini
Bio_TICFSL
You can see the Linux reference manual on your BSP documentation, there is a example how to use g2d.
regards
Bio_TICFSL
regards
%3CLINGO-SUB%20id%3D%22lingo-sub-2057085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUsage%20of%20GPU%20on%20i.MX8M%20mini.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2057085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI'm%20trying%20to%20use%20GPU%20of%20i.MX8M%20mini%20for%20scaling%20purpose.%20for%20this%20I'm%20using%20g2d%20API's.%20Am%20I%20doing%20it%20with%20correct%20approach.%20If%20wrong%20how%20can%20I%20make%20use%20of%20GPU%20for%20my%20application.%20Has%20someone%20worked%20on%20this%20before%3F%20Just%20using%20those%20API%20will%20I%20be%20able%20to%20use%20GPU%20for%20scaling%3F%20I%20have%20written%20a%20small%20code%20which%20uses%20these%20API%20but%20I%20am%20getting%20error%20as%20g2d.h%20is%20not%20present.%20but%20the%20shared%20object%20is%20already%20installed.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%23G2D%20usage%20for%20GPU%2C%20%40i.MX8M%20mini%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2058791%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Usage%20of%20GPU%20on%20i.MX8M%20mini.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2058791%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EYou%20can%20see%20the%20Linux%20reference%20manual%20on%20your%20BSP%20documentation%2C%20there%20is%20a%20example%20how%20to%20use%20g2d.%3C%2FP%3E%0A%3CP%3Eregards%3C%2FP%3E%3C%2FLINGO-BODY%3E
