Openvg library support in iMX8mm
deeksha
Hello All,
I would like to know whether Openvg library is supported in imx8 mm. If so then how to add this library in yocto.
Thanks in advance
Deeksha
Tags (2)
joanxie
when you boot up the board, you can find the viv_samples under /opt, then you should find different test demo, choose what you need
joanxie
yes, current bsp includes this, the directory viv_samples is found under /opt. It contains binary samples for OpenGL ES 1.1/2.0 and OpenVG 1.1.
deeksha
Hi ,
Could you tell me the procedure to run the sample programs.
Deeksha
joanxie
