How do I connect DSI screen with flat ribbon cable to mini-SAS?
Search instead for
anthonykwinters
I am using a i.MX 8M Nano EVK Board and need to connect to a MIPI DSI LCD Screen with a 24-pin flat ribbon cable (0.5mm Pitch FFC FPC Cable). The EVK board only has a mini-SAS connector for the MIPI DSI out. Please direct me to an adapter or breakout board so I can connect the screen to my EVK board.
Qmiller
Hi @anthonykwinters
You need design bridge pcb by yourself.
About MIPI DSI signal defination, you can refer to  our official mipi-hdmi board https://www.nxp.com.cn/webapp/Download?colCode=IMX-MIPI-HDMI&appType=license
Best Regards
Zhiming
