GPU
GPU
2,505 次查看
linhaha
May I ask who provided the display obtained by EGL in openVG demo of IMX RT1170  board?
6 回复数
2,494 次查看
Omar_Anguiano
Hello
I hope you are well.
Display for RT1170 can be found here: 5.5" LCD Panel | NXP Semiconductors
Omar
2,478 次查看
linhaha
I can`t understand,What is the connection between fbGetDisplay API and LCD driver?Where is fbGetDisplay implemented?
2,467 次查看
Omar_Anguiano
Could you please detail your question? What example, in particular, are you referring to?
The official is to ask Vivante for these materials like Vivante OpenVG API, source code, etc.
Omar
2,443 次查看
linhaha
Do I have to use the operating system to use the openVG API on the RT1170 board, and if so, why?
2,110 次查看
howardliu
@linhaha You have to use FreeRTOS OS. The source code of EGL isn't available. You still can use the other display panel. To use new display, you need to modify the display_support.c and .h files for new display panel.
2,400 次查看
Omar_Anguiano
I suggest you consult this with Vivante to check whether the OS is strictly necessary.
Omar
