Add lvds/hdmi to imx8mm
ソリューションへジャンプ
3,312件の閲覧回数
FlorentLeroy
Hello the community,
I need to add a lvds or HDMI interface for a LCD display 10 or 12 inches. I need to find an industrial solution for this. We currently use a SOM with imx8mm. Have you any solution for this purpose ?
Thanks in advance,
Florent.
3,296件の閲覧回数
joanxie
current imx8mm support mipi to hdmi
https://www.nxp.com/part/IMX-MIPI-HDMI#/, but your LCD can connect HDMI port? what lcd do you use? any part number or data sheet?
5 返答(返信)
3,299件の閲覧回数
FlorentLeroy
Thank's for the quick answer.
Yes we know but we must use a SOM with a IMX8MM because of an organizationnal choice. That's why we need to find a solution to handle LVDS or HDMI interface to the IMX8MM. At this time we did'nt find any industrial solution to handle a LCD display 10 or 12 inches because of all of those screen have a LVDS interface.
Did you have an idea to add HDMI or LVDS interface to the IMX8MM with a chip for example ?
3,297件の閲覧回数
joanxie
3,294件の閲覧回数
FlorentLeroy
Currently, our lcd support LVDS but we can change the display to have an hdmi interface no problem for us.
Thank's i will order one mipi to hdmi interface to test this.
3,280件の閲覧回数
joanxie
ok, you can test first, any further issue, you can contact us again, I will close this case in advanced
3,300件の閲覧回数
joanxie
i.mx8mm only has mipi dsi interface, and supports OLED display as default in the bsp
"https://www.nxp.com/part/MX8-DSI-OLED1A#/"
I don't know what LCD do you need to use
