I'm working with the i.MX 8M Plus EVK and VX delegate. I tried to run a full-int quantized tflite model using tflite_runtime version 2.6
delegate = [tflite.load_delegate('/usr/lib/libvx_delegate.so')]
interpreter = tflite.Interpreter(model_path=path, experimental_delegates=delegate)
After allocating and setting input tensor, interpreter.invoke() generates following output:
Vx delegate: allowed_builtin_code set to 0. Vx delegate: error_during_init set to 0. Vx delegate: error_during_prepare set to 0. Vx delegate: error_during_invoke set to 0.
W [HandleLayoutInfer:257]Op 18: default layout inference pass. W [HandleLayoutInfer:257]Op 18: default layout inference pass. W [HandleLayoutInfer:257]Op 18: default layout inference pass. W [HandleLayoutInfer:257]Op 18: default layout inference pass. W [HandleLayoutInfer:257]Op 18: default layout inference pass. W [HandleLayoutInfer:257]Op 18: default layout inference pass. W [HandleLayoutInfer:257]Op 18: default layout inference pass. W [HandleLayoutInfer:257]Op 18: default layout inference pass. W [HandleLayoutInfer:257]Op 18: default layout inference pass. W [HandleLayoutInfer:257]Op 18: default layout inference pass. W [HandleLayoutInfer:257]Op 18: default layout inference pass. W [HandleLayoutInfer:257]Op 18: default layout inference pass. W [HandleLayoutInfer:257]Op 18: default layout inference pass. W [HandleLayoutInfer:257]Op 18: default layout inference pass. E [vsi_nn_OpOptimize:253]Optimize node RESHAPE fail E [optimize_node_backward:260]Backward optimize node[63] RESHAPE fail ERROR: Failed to verify graph
Following OpCodes are used in the already converted tflite model:
(Conversion is also done with tensorflow 2.6.0 lite converter)
index | builtin_code | custom_code | version |
0 | PAD | 2 | |
1 | RESHAPE | 1 | |
2 | CONV_2D | 3 | |
3 | MAX_POOL_2D | 2 | |
4 | TRANSPOSE_CONV | 3 | |
5 | ADD | 2 |
As attached in the i.mx machine learning user guide, the listed operations above are all supported by the ovxlib.
What could cause this error? Can someone help?
Thanks and best regards
I have the same issue with both Thunder and Lightning MoveNet models (https://tfhub.dev/google/movenet/singlepose/thunder/4) (https://tfhub.dev/google/movenet/singlepose/lightning/4). I attach a .txt file with logs.
