How to enable opengl in IMX8qxp with yocto for latest version of source code <>
1,828 次查看
sandeep_rai
I have been trying to write some user space program for openbgl but by default it is not working at all they all are missing library. hence, I do require to enable opengl/opengl es in imx8xp. Anyone have idea? i am new to opengl so not much idea.
I have checked following, I CONCLUDED that no full/complete support is given:
/usr/include/gl - found [EGL]
/usr/include/opengl-not found or similar *.so not found for so to prove its availability.
glxinfo doesnot work ..
There is no bydefault example I found somewhere, Is there any refrnce document for so, I have been through older document based on VTK. but  do require with opengl function to be run on system so excluded the idea of VTK.
Sandeep K Rai
0 回复数
