@andy_Musk
From your picture, your PNEV5180 PC driver is an older version, ABEND driver. This interface has been replaced with a VCOM interface, so the ABEND driver is not required any more. Please install VCOM driver manually. user manual is AN11744 PN5180 Evaluation board quick start guide.
Please refer to AN11744 , chapter 3 and chapter 5 for more details.
after you install the correct driver, you can update BootLoader_And_Nfcrdlib_SimplifiedAPI_EMVCo_Secondary.bin file, if you need to use cockpit.
