where to set up device id of simple descriptor within endpoint
2,067 次查看
jason525
hi,
where to set up device id of simple descriptor within endpoint, I found nothing about device id within eHA_RegisterxxxEndPoint function or other source code. I'm working with zigbee stack JN-SW-4168.
标记 (3)
1,929 次查看
davidashraf
You can set device id in ZPS Configuration Editor in the chosen End Point
1,930 次查看
davidashraf
1,929 次查看
jason525
hi David
thanks! this answer is helpful for me.
best regard!
1,929 次查看
davidashraf
Glad it helped,Jason :smileyhappy:
Best Regards
