read multplie index from circular buffer
1,587件の閲覧回数
vijay_0806
Hello Every one.
I'm using jn5168 sdk here im facing issue with circular buffer (FIFO) i can't read multiple index in a loop .i can read only one segment at one time.
4 返答(返信)
1,517件の閲覧回数
vijay_0806
im using iAHi (apphardwareAPi_jn516x.h) using  for writing ad reading through EEPROM segments,
1,507件の閲覧回数
Ricardo_Zamora
Could you please help me checking this User Guide (JN516x Integrated Peripherals API User Guide)? Are the parameters correct?
Ricardo
1,488件の閲覧回数
vijay_0806
jn-3087 api peripherals using for sensor ,actually am working with nits sensor  i need send multiple reading(timestamp,temp reading,battery status) to hat in single data packet while hat  after wake up i need to send .I'm using 64 segment internal eeprom also initialized circular buffer in ram .
1,566件の閲覧回数
Ricardo_Zamora
Hope you are doing well. Could you please clarify what API's are you using?
If you are using a FIFO, you would need to read one by one.
Also, one important remark: JN5189/88T is preferred for any new Zigbee®, Thread design. No new software releases planned for JN5168.
Ricardo
