how to configure 8KB flexram as general RAM at KW36
1,521 次查看
zhi_wang
hi someone,
will the FlexRAM could be configured as general RAM at KW36 platform?
there is no demo code nor help doc about this issue.
标签 (2)
1 回复
1,427 次查看
Ricardo_Zamora
Hope you are doing well. Yes, the FlexRAM can be used as a traditional RAM.
From the Reference Manual (Chapter 29):
Could you please check section 29.4.11.17?
The Set FlexRAM Function command changes the function of the FlexRAM.
Hope this helps.
Ricardo
