how to assigned ID for multiple sleeping device in JN5168?
dheerajsawant
Contributor V
Hello mario_castaneda‌,
I am using JN5168-001-M00 Module.
after finishing data transfer from Sleeping Device to Coordinator Successfully.
Now i want to assigned ID for SED(Sleeping End Device).
In multiple SED(Sleeping End Device):
How will i understand that which SED(Sleeping End Device) is sending data to coordinator.
is there any API?
so i can assigned A ID for SED(Sleeping End Device).
I hope you understand my question.
Dheeraj Sawant
mario_castaneda
Hi Dheeraj,
I'm sorry, What do you mean with ID for sleep end device?
Do you want to modify the short address assigned by the coordinator?
Mario
dheerajsawant
Contributor V
Did you find any solution for this?
or any available API is Present?
Dheeraj Sawant
mario_castaneda
Hi Dheeraj,
You will look for the source address from the message and it will depend on the type of destination, please see the Table 7: Addressing Modes
This structure is used in the ZPS_EVENT_APS_DATA_INDICATION event, which indicates the arrival of data on the local node.
ZPS_tsAfDataIndEvent
https://www.nxp.com/docs/en/user-guide/JN-UG-3101.pdf?fsrch=1&sr=9&pageNum=1
Mario
dheerajsawant
Contributor V
ID means i just wanted to assign a Number to Sleeping End Device.
like example:
if i am having more than 20 sleeping End Device who are sending data to Coordinator. (All are Working)
but i want to find out that which Sleeping End Device is sending data to coordinator.
same thing i want to do.
Hope you understand!
Dheeaj Sawant
