end device without association send data
2,338 次查看
29603655
Hi All:
how can end device without association send data to coordinator?
thanks!
标签 (2)
6 回复数
2,159 次查看
mario_castaneda
Hi Liang,
Could you please provide more details?
Do you have the sniffer log? What is the command that you are seeing before the association?
Mario
2,159 次查看
29603655
Hi Mario:
Thanks for your replay!
I use the 802.15.4 Stack  with JN5168,first endDevice active scan the coordinator's channel, then I want send data to coordinator without association process!
I have another device with JN5148, it can send data without association to my coordinator device, so I want to know how to do this?
liang
2,159 次查看
mario_castaneda
Hi Liang,
What is the example that you are working on?
The JN5148 is sending the data through the beacon commands, right?
Mario
2,159 次查看
29603655
Hi Mario:
I use the JN-AN-1143 TOF demo. I don't know JN5148 send data with what commands, so I want to know how JN5148 send the data!
thanks
2,159 次查看
mario_castaneda
Hi Liang Guo,
Unfortunately, the JN5148  is no longer manufacture and is not recommended for new design. It is not supported.
If you are working on JN5168 the ToF is not supported as well.
Mario
2,159 次查看
29603655
Hi Mario:
How can I use JN5168 send data through the beacon commands.
