connecting wifi bluetooth module and imx6qp sabre ai board
1,178 次查看
lavakumars
Recently I bought imx6qp sabre ai board and want to connect the muRata's  Wi-Fi Bluetooth module.
I have problem in connecting the Base board(MCIMXABASEV1) and the Wi-Fi BT module(LBEH5DU1BW-TEMP-DS-SD). Help me to connect them. Also help how to use and test. And I am using yocto platform to build the image , used the fsl-bsp-release for building the image.
Lavakumar S
0 回复数
