can't use report in JN5168
1,888件の閲覧回数
leoxie
hello,every one,
the status was returned "E_ZCL_ERR_ATTRIBUTE_IS_SERVER" when I using "eZCL_CreateLocalReport",using "eZCL_ReportAllAttributes" can't report too.
the code is shown as follow:
/***************************************************************************** * * MODULE: JN-AN-1189 * * COMPONENT: app_reporting.c * * DESCRIPTION: ZHA Demo : Stack <-> Mains Power Outlet-App Interaction (Implementation) * **************************************************************************** * * This software is owned by NXP B.V. and/or its supplier and is protected * under applicable copyright laws. All rights are reserved. We grant You, * and any third parties, a license to use this software solely and * exclusively on NXP products [NXP Microcontrollers such as JN5168, JN5164, * JN5161, JN5148, JN5142, JN5139]. * You, and any third parties must reproduce the copyright and warranty notice * and any other legend of ownership on each copy or partial copy of the * software. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE * POSSIBILITY OF SUCH DAMAGE. * * Copyright NXP B.V. 2014. All rights reserved * ***************************************************************************/ /****************************************************************************/ /*** Include files ***/ /****************************************************************************/ #include #include #include "dbg.h" #include "os.h" #include "os_gen.h" #include "pdum_gen.h" #include "pdm.h" #include "pdum_gen.h" #include "zps_gen.h" #include "zps_apl.h" #include "zps_apl_aib.h" #include "zps_nwk_sap.h" #include "app_common.h" #include "PDM_IDs.h" #include "zcl_options.h" #include "app_zbp_utilities.h" #include "zcl_common.h" #include "app_reporting.h" #include "IASZone.h" #ifdef CLD_GROUPS #include "groups.h" #include "Groups_internal.h" #endif /****************************************************************************/ /*** Macro Definitions ***/ /****************************************************************************/ #define DEBUG_REPORT #ifndef DEBUG_REPORT #define TRACE_REPORT FALSE #else #define TRACE_REPORT TRUE #endif #define NUMBER_OF_REPORTS_MAX 2 /****************************************************************************/ /*** Type Definitions ***/ /****************************************************************************/ /****************************************************************************/ /*** Local Function Prototypes ***/ /****************************************************************************/ /****************************************************************************/ /*** Exported Variables ***/ /****************************************************************************/ /****************************************************************************/ /*** Local Variables ***/ /****************************************************************************/ /*Just Two reports for time being*/ PRIVATE tsReports asSavedReports[NUMBER_OF_REPORTS_MAX]; /****************************************************************************/ /*** Exported Functions ***/ /****************************************************************************/ /**************************************************************************** * * NAME: eRestoreReports * * DESCRIPTION: * Loads the reporting information from the EEPROM/PDM * * RETURNS: * void * ****************************************************************************/ PUBLIC OS_teStatus eRestoreReports( void ) { /* Restore any report data that is previously saved to flash */ uint16 u16ByteRead; PDM_teStatus eStatusReportReload = PDM_eReadDataFromRecord(PDM_ID_APP_IASZONE_NODE, asSavedReports, sizeof(asSavedReports), &u16ByteRead); DBG_vPrintf(TRACE_REPORT,"eStatusReportReload=%d\n",eStatusReportReload); /* Restore any application data previously saved to flash */ return (eStatusReportReload); } /**************************************************************************** * * NAME: vMakeSupportedAttributesReportable * * DESCRIPTION: * Makes the attributes reportable for On Off and Level control * * RETURNS: * void * ****************************************************************************/ PUBLIC void vMakeSupportedAttributesReportable(void) { uint16 u16AttributeEnum; uint16 u16ClusterId; uint8 i; tsZCL_AttributeReportingConfigurationRecord *psAttributeReportingConfigurationRecord; DBG_vPrintf(TRACE_REPORT, "\n\r%s", __FUNCTION__); for(i = 0; i < NUMBER_OF_REPORTS_MAX; i++) { teZCL_Status eStatus; u16AttributeEnum = asSavedReports[i].sAttributeReportingConfigurationRecord.u16AttributeEnum; u16ClusterId = asSavedReports[i].u16ClusterID; psAttributeReportingConfigurationRecord = &(asSavedReports[i].sAttributeReportingConfigurationRecord); eStatus = eZCL_SetReportableFlag(1, u16ClusterId, TRUE, FALSE, u16AttributeEnum); DBG_vPrintf(TRACE_REPORT, "\n\reZCL_SetReportableFlag: %x\n", eStatus); eStatus = eZCL_CreateLocalReport(1, u16ClusterId, 0, TRUE, psAttributeReportingConfigurationRecord); DBG_vPrintf(TRACE_REPORT, "\n\reZCL_CreateLocalReport: %x\n", eStatus); } } /**************************************************************************** * * NAME: vLoadDefaultConfigForReportable * * DESCRIPTION: * Loads a default configuration * * RETURNS: * void * ****************************************************************************/ PUBLIC void vLoadDefaultConfigForReportable(void) { uint8 u8Index; /* For OnOff attribute in ON Off Cluster */ asSavedReports[0].u16ClusterID = SECURITY_AND_SAFETY_CLUSTER_ID_IASZONE; asSavedReports[0].sAttributeReportingConfigurationRecord.eAttributeDataType = E_ZCL_ENUM16; asSavedReports[0].sAttributeReportingConfigurationRecord.u16AttributeEnum = E_CLD_IASZONE_ATTR_ID_ZONE_TYPE; asSavedReports[0].sAttributeReportingConfigurationRecord.u16MaximumReportingInterval = 2;//HA_SYSTEM_MAX_REPORT_INTERVAL; asSavedReports[0].sAttributeReportingConfigurationRecord.u16MinimumReportingInterval = 5; //HA_SYSTEM_MIN_REPORT_INTERVAL; asSavedReports[0].sAttributeReportingConfigurationRecord.u16TimeoutPeriodField = 0; asSavedReports[0].sAttributeReportingConfigurationRecord.u8DirectionIsReceived = 0; asSavedReports[0].sAttributeReportingConfigurationRecord.uAttributeReportableChange.zuint8ReportableChange = 0; asSavedReports[1].u16ClusterID = SECURITY_AND_SAFETY_CLUSTER_ID_IASZONE; asSavedReports[1].sAttributeReportingConfigurationRecord.eAttributeDataType = E_ZCL_BMAP16; asSavedReports[1].sAttributeReportingConfigurationRecord.u16AttributeEnum = E_CLD_IASZONE_ATTR_ID_ZONE_STATUS; asSavedReports[1].sAttributeReportingConfigurationRecord.u16MaximumReportingInterval = 3;//HA_SYSTEM_MAX_REPORT_INTERVAL; asSavedReports[1].sAttributeReportingConfigurationRecord.u16MinimumReportingInterval = 6; //HA_SYSTEM_MIN_REPORT_INTERVAL; asSavedReports[1].sAttributeReportingConfigurationRecord.u16TimeoutPeriodField = 0; asSavedReports[1].sAttributeReportingConfigurationRecord.u8DirectionIsReceived = 0; asSavedReports[1].sAttributeReportingConfigurationRecord.uAttributeReportableChange.zuint8ReportableChange = 1; DBG_vPrintf(TRACE_REPORT,"\nLoaded Defaults Records \n"); for(u8Index = 0; u8Index < NUMBER_OF_REPORTS_MAX; u8Index++) { DBG_vPrintf(TRACE_REPORT,"\nCluster %d",asSavedReports[u8Index].u16ClusterID); DBG_vPrintf(TRACE_REPORT,"\nAtt Dta Type = %d",asSavedReports[u8Index].sAttributeReportingConfigurationRecord.eAttributeDataType); DBG_vPrintf(TRACE_REPORT,"\nAttr No = %d",asSavedReports[u8Index].sAttributeReportingConfigurationRecord.u16AttributeEnum); DBG_vPrintf(TRACE_REPORT,"\nMax = %d",asSavedReports[u8Index].sAttributeReportingConfigurationRecord.u16MaximumReportingInterval); DBG_vPrintf(TRACE_REPORT,"\nMin = %d",asSavedReports[u8Index].sAttributeReportingConfigurationRecord.u16MinimumReportingInterval); DBG_vPrintf(TRACE_REPORT,"\nTimeOut = %d",asSavedReports[u8Index].sAttributeReportingConfigurationRecord.u16TimeoutPeriodField); DBG_vPrintf(TRACE_REPORT,"\nDirection = %d",asSavedReports[u8Index].sAttributeReportingConfigurationRecord.u8DirectionIsReceived); DBG_vPrintf(TRACE_REPORT,"\nChange = %d\n",asSavedReports[u8Index].sAttributeReportingConfigurationRecord.uAttributeReportableChange.zuint8ReportableChange); } /*Save this Records*/ PDM_eSaveRecordData(PDM_ID_APP_IASZONE_NODE, asSavedReports, sizeof(asSavedReports)); } /**************************************************************************** * * NAME: vSaveReportableRecord * * DESCRIPTION: * Loads a default configuration * * RETURNS: * void * ****************************************************************************/ PUBLIC void vSaveReportableRecord(uint8 u8Index,uint16 u16ClusterID, tsZCL_AttributeReportingConfigurationRecord* psAttributeReportingConfigurationRecord) { asSavedReports[u8Index].u16ClusterID = u16ClusterID; memcpy(&(asSavedReports[u8Index].sAttributeReportingConfigurationRecord),psAttributeReportingConfigurationRecord,sizeof(tsZCL_AttributeReportingConfigurationRecord)); DBG_vPrintf(TRACE_REPORT,"\nSaving Records \n"); DBG_vPrintf(TRACE_REPORT,"\nCluster %d",asSavedReports[u8Index].u16ClusterID); DBG_vPrintf(TRACE_REPORT,"\nAtt Dta Type = %d",asSavedReports[u8Index].sAttributeReportingConfigurationRecord.eAttributeDataType); DBG_vPrintf(TRACE_REPORT,"\nAttr No = %d",asSavedReports[u8Index].sAttributeReportingConfigurationRecord.u16AttributeEnum); DBG_vPrintf(TRACE_REPORT,"\nMax = %d",asSavedReports[u8Index].sAttributeReportingConfigurationRecord.u16MaximumReportingInterval); DBG_vPrintf(TRACE_REPORT,"\nMin = %d",asSavedReports[u8Index].sAttributeReportingConfigurationRecord.u16MinimumReportingInterval); DBG_vPrintf(TRACE_REPORT,"\nTimeOut = %d",asSavedReports[u8Index].sAttributeReportingConfigurationRecord.u16TimeoutPeriodField); DBG_vPrintf(TRACE_REPORT,"\nDirection = %d",asSavedReports[u8Index].sAttributeReportingConfigurationRecord.u8DirectionIsReceived); DBG_vPrintf(TRACE_REPORT,"\nChange = %d\n\n",asSavedReports[u8Index].sAttributeReportingConfigurationRecord.uAttributeReportableChange.zuint8ReportableChange); /*Save this Records*/ PDM_eSaveRecordData(PDM_ID_APP_IASZONE_NODE, asSavedReports, sizeof(asSavedReports)); } /****************************************************************************/ /*** END OF FILE ***/ /****************************************************************************/
2 返答(返信)
1,466件の閲覧回数
mario_castaneda
Hi Leo,
I was checking your code. Did you modify this define NUMBER_OF_REPORTS_MAX?
/* Only one reportable attribute that is On/Off attribute */
#define MAINS_POWER_OUTLET_NUMBER_OF_REPORTS 1
Could you please modify that value with 1?
Mario
1,466件の閲覧回数
leoxie
Dear Mario,
thanks very much for your reply.
It's only sent a on/off report when I call "eZCL_ReportAllAttributes" in Mainpoweroutlet demo,but It's nothing is sent when I call "eZCL_ReportAllAttributes" in IAS ZONE demo.
also I try to modify MAINS_POWER_OUTLET_NUMBER_OF_REPORTS to 3 ,but still nothing is sent.
* software.
#include <jendefs.h>
#include <string.h>
#include "dbg.h"
#include "os.h"
#include "os_gen.h"
#include "pdm.h"
#ifdef CLD_GROUPS
#include "groups.h"
#endif
#else
#endif
PRIVATE tsReports asSavedReports[MAINS_POWER_OUTLET_NUMBER_OF_REPORTS];
* DESCRIPTION:
* RETURNS:
* void
uint16 u16ByteRead;
PDM_teStatus eStatusReportReload = PDM_eReadDataFromRecord(PDM_ID_APP_REPORTS,
asSavedReports,
&u16ByteRead);
* DESCRIPTION:
* RETURNS:
* void
uint8 i;
DBG_vPrintf(TRACE_REPORT, "%s\n", __FUNCTION__);
for(i = 0; i < MAINS_POWER_OUTLET_NUMBER_OF_REPORTS; i++)
DBG_vPrintf(TRACE_REPORT, "eZCL_SetReportableFlag: %d\n", eStatus);
DBG_vPrintf(TRACE_REPORT, "eZCL_CreateLocalReport: %d\n", eStatus);
* DESCRIPTION:
* RETURNS:
* void
uint8 u8Index;
asSavedReports[0].u16ClusterID = GENERAL_CLUSTER_ID_ONOFF;
asSavedReports[0].sAttributeReportingConfigurationRecord.eAttributeDataType = E_ZCL_BOOL;
asSavedReports[0].sAttributeReportingConfigurationRecord.u16AttributeEnum = E_CLD_ONOFF_ATTR_ID_ONOFF;
asSavedReports[0].sAttributeReportingConfigurationRecord.u16MaximumReportingInterval = HA_SYSTEM_MAX_REPORT_INTERVAL;
asSavedReports[0].sAttributeReportingConfigurationRecord.u16MinimumReportingInterval = HA_SYSTEM_MIN_REPORT_INTERVAL;
asSavedReports[0].sAttributeReportingConfigurationRecord.uAttributeReportableChange.zuint8ReportableChange = 10;
asSavedReports[1].u16ClusterID = GENERAL_CLUSTER_ID_ONOFF;
asSavedReports[1].sAttributeReportingConfigurationRecord.eAttributeDataType = E_ZCL_BOOL;
asSavedReports[1].sAttributeReportingConfigurationRecord.u16AttributeEnum = E_CLD_ONOFF_ATTR_ID_GLOBAL_SCENE_CONTROL;
asSavedReports[1].sAttributeReportingConfigurationRecord.u16MaximumReportingInterval = HA_SYSTEM_MAX_REPORT_INTERVAL;
asSavedReports[1].sAttributeReportingConfigurationRecord.u16MinimumReportingInterval = HA_SYSTEM_MIN_REPORT_INTERVAL;
asSavedReports[1].sAttributeReportingConfigurationRecord.uAttributeReportableChange.zuint8ReportableChange = 12;
asSavedReports[2].u16ClusterID = GENERAL_CLUSTER_ID_ONOFF;
asSavedReports[2].sAttributeReportingConfigurationRecord.eAttributeDataType = E_ZCL_BOOL;
asSavedReports[2].sAttributeReportingConfigurationRecord.u16AttributeEnum = E_CLD_ONOFF_ATTR_ID_ON_TIME;
asSavedReports[2].sAttributeReportingConfigurationRecord.u16MaximumReportingInterval = HA_SYSTEM_MAX_REPORT_INTERVAL;
asSavedReports[2].sAttributeReportingConfigurationRecord.u16MinimumReportingInterval = HA_SYSTEM_MIN_REPORT_INTERVAL;
asSavedReports[2].sAttributeReportingConfigurationRecord.u16TimeoutPeriodField = 0;
asSavedReports[2].sAttributeReportingConfigurationRecord.u8DirectionIsReceived = 0;
asSavedReports[2].sAttributeReportingConfigurationRecord.uAttributeReportableChange.zuint8ReportableChange = 14;
for(u8Index = 0; u8Index < MAINS_POWER_OUTLET_NUMBER_OF_REPORTS; u8Index++)
PDM_eSaveRecordData(PDM_ID_APP_REPORTS,
asSavedReports,
The log:
Deice Power Up!
PWRM Init OSCON and RAMON
PDUM iniaialise....
System initial ...
HAL_LEDS_Init ...
HAL_Buttons_Init ...
APP_vInitialiseNode .....
eStatusReportReload=0
Link key:5a,69,67,42,65,65,41,6c,6c,69,61,6e,63,65,30,39,
Restore default channel:134215680
Default mask saved = 0x07fff800, Mask Set to = 0x00002000
HA initailise status:0
HA register endpoint status:0
eZCL_SetSupportedSecurity: 0x0
ZCL Device information:
ZCL Device APP version:1
ZCL Device HW version:1
ZCL Device mode identifier:ZHA-MainsPowerOutlet
ZCL Device manufacture:YCD
ZCL Device code date:20170109
ZCL Device out status:1
Cluster 6
Att Dta Type = 16
Attr No = 0
Max = 60
Min = 1
TimeOut = 0
Direction = 0
Change = 10
Cluster 6
Att Dta Type = 16
Attr No = 16384
Max = 60
Min = 1
TimeOut = 0
Direction = 0
Change = 12
Cluster 6
Att Dta Type = 16
Attr No = 16385
Max = 60
Min = 1
TimeOut = 0
Direction = 0
Change = 14
eZCL_SetReportableFlag: 0
eZCL_CreateLocalReport: 0
The code:
* DESCRIPTION:
* RETURNS:
* void
asSavedReports,
