Build error: 'apduZDP' undeclared (first use in this function)
I searched but couldn't find apduZDP.
../zigbee/BDB/Source/FindAndBind/bdb_fb_initiator.c:504:48: error: 'apduZDP' undeclared (first use in this function)
arm-none-eabi-gcc -std=gnu99 -DCPU_K32W1480VFTA -DCPU_K32W1480VFTA_cm33 -
MT"source/app_main.d" -o "source/app_main.o" "../source/app_main.c"
504 | hAPduInst = PDUM_hAPduAllocateAPduInstance(apduZDP);
Finished building: ../utilities/fsl_memcpy.S
Building file: ../source/app_serial_commands.c
SDK Details
Import SDK example : zigbee_coordinator_freertos
Solved! Go to Solution.
Hope you are doing well.
This error may be due to some missing python modules, could you please try installing lxml module for python? You can try using:
pip install lxml
This action does a modification in the content for .h files, so the library content inside pdum_gen.h changes, this modification declares the apduZDP and apduZCL inside this library.
Ana Sofia.
pip install lxml
Ana Sofia.
