build error : 'apduZDP' undeclared (first use in this function)
650件の閲覧回数
y_miya
Build error: 'apduZDP' undeclared (first use in this function)
I searched but couldn't find apduZDP.
../zigbee/BDB/Source/FindAndBind/bdb_fb_initiator.c:504:48: error: 'apduZDP' undeclared (first use in this function)
arm-none-eabi-gcc -std=gnu99 -DCPU_K32W1480VFTA -DCPU_K32W1480VFTA_cm33 -
MT"source/app_main.d" -o "source/app_main.o" "../source/app_main.c"
  504 |     hAPduInst = PDUM_hAPduAllocateAPduInstance(apduZDP);
Finished building: ../utilities/fsl_memcpy.S
Building file: ../source/app_serial_commands.c
SDK Details
  • Windows
  • 24.12.00
  • K32W148-EVK
  • MCUXpresso IDE
Import SDK example : zigbee_coordinator_freertos
タグ(1)
630件の閲覧回数
sofiaurueta
Hope you are doing well.
This error may be due to some missing python modules, could you please try installing lxml module for python? You can try using:
pip install lxml
This action does a modification in the content for .h files, so the library content inside pdum_gen.h changes, this modification declares the apduZDP and apduZCL inside this library.
Ana Sofia.
631件の閲覧回数
sofiaurueta
pip install lxml
Ana Sofia.
