Hi all,
I am developing a smart curtain device. It use Window Covering Server Cluster.
But I see something wrong with this cluster in "ZigBee Cluster Library Specification".
Window Covering Information Attribute Set and Window Covering Setting Attribute Set use the same attribute ID.
I think it should be:
Window Covering Information Attribute Set: 0x0000 - 0x000F
Window Covering Setting Attribute Set: 0x0010 - 0x001F
Can you explain it?
已解决! 转到解答。
Did you manage to add the Window Covering Server Cluster for NXP? I am trying to add it to our Gateway /Control Bridge. Can you let me know the steps to follow and possibly share the code that will help me?
