Why the terminal continue to output "."
2,005 次查看
quanjunzhang
EndDivice
application note: JN-AN-1217-Zigbee-3-0-Base-Device
When I press the button of SW3, the terminal as following.
Thans for your help.
1,906 次查看
quanjunzhang
The reason may be that NTAG is turned on by default.
I am modifying it in the Makefile of EndDevice (it should be to turn off NTAG), "." is gone.
Is my way ok?
1,906 次查看
mario_castaneda
Hi Zhang,
The Application Note: JN-AN-1217 ZigBee 3.0 Base Device documentation the button 3 (SW3)  is unused.
Mario
1,906 次查看
quanjunzhang
For some reason, the picture seems to have failed to transfer.
