Whether the code of KW38 and KW45 is common
wenjie
I am using KW38 now, and the RAM of KW38 is not enough. As far as I know, many software of KW38 and KW45 are compatible, so whether the program of KW38 can be directly run on KW45? I just want to quickly replace it and test how much memory is needed, and verify how much RAM is needed first
luis_maravilla
KW38 and KW45 are not pin compatible, there are some differences in Application structure and APIs used for each device. For development using a new board, and in order to avoid any issues related to the software, I would recommend checking on the Bluetooth Low Energy Application Developer’s Guide Chapter 9 to see how this structures are integrated; also, this document describes the most commonly used APIs and provides code examples applicable to KW45.
I would recommend using the SDK examples for KW45 as base for developing your application if you are trying to move to KW45.
Best Regards
luis_maravilla
Best Regards
wenjie
Ok, thank you for your answer
%3CLINGO-SUB%20id%3D%22lingo-sub-2060265%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EWhether%20the%20code%20of%20KW38%20and%20KW45%20is%20common%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2060265%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20using%20KW38%20now%2C%20and%20the%20RAM%20of%20KW38%20is%20not%20enough.%20As%20far%20as%20I%20know%2C%20many%20software%20of%20KW38%20and%20KW45%20are%20compatible%2C%20so%20whether%20the%20program%20of%20KW38%20can%20be%20directly%20run%20on%20KW45%3F%20I%20just%20want%20to%20quickly%20replace%20it%20and%20test%20how%20much%20memory%20is%20needed%2C%20and%20verify%20how%20much%20RAM%20is%20needed%20first%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2060265%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EProduct%3A%20KW%2037%7C38%7C39%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2061704%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Whether%20the%20code%20of%20KW38%20and%20KW45%20is%20common%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2061704%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EOk%2C%20thank%20you%20for%20your%20answer%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2060732%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Whether%20the%20code%20of%20KW38%20and%20KW45%20is%20common%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2060732%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%0A%3CP%3EKW38%20and%20KW45%20are%20not%20pin%20compatible%2C%20there%20are%20some%20differences%20in%20Application%20structure%20and%20APIs%20used%20for%20each%20device.%20For%20development%20using%20a%20new%20board%2C%20and%20in%20order%20to%20avoid%20any%20issues%20related%20to%20the%20software%2C%20I%20would%20recommend%20checking%20on%20the%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2Fmcuxsdk%2Flatest%2Fhtml%2F_static%2Fwireless%2FBluetooth%2FBluetooth_Low_Energy_Application_Developer%2527s_Guide.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EBluetooth%20Low%20Energy%20Application%20Developer%E2%80%99s%20Guide%3C%2FA%3E%20Chapter%209%20to%20see%20how%20this%20structures%20are%20integrated%3B%20also%2C%20this%20document%20describes%20the%20most%20commonly%20used%20APIs%20and%20provides%20code%20examples%20applicable%20to%20KW45.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20would%20recommend%20using%20the%20SDK%20examples%20for%20KW45%20as%20base%20for%20developing%20your%20application%20if%20you%20are%20trying%20to%20move%20to%20KW45.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20Regards%3C%2FP%3E%3C%2FLINGO-BODY%3E
