Unable to program RW610-based custom board with External Flash
132件の閲覧回数
snjy
I have a custom dev board based on the RW610 chip. I am trying to write firmware using a Jlink adapter from the FRDM-RW612 board (will eventuallly shift to MCU-Link).
For some reason, the default memory config with only ram declared at address 0x0 for size 0x130000 works normally in debug mode. But as soon as I add external flash address to the memory configuration, it stops working. Even the memory monitor doesnt show any data on the whole range.
I have attached a screenshots of one of the ranges i tried.
2 返答(返信)
112件の閲覧回数
Christine_Li
Hi, @snjy
Do you forget to share to me you screenshot?
If you can provide me more details related to this issue, we can provide you better support.
Christine.
4件の閲覧回数
Christine_Li
Hi, @snjy
Christine.
